[GRASS-SVN] r32069 - grass/trunk/gui/wxpython/gui_modules
Thu Jul 10 03:50:38 EDT 2008
Author: martinl
Date: 2008-07-10 03:50:38 -0400 (Thu, 10 Jul 2008)
New Revision: 32069
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
nviz2/wxGUI: data layers can be loaded also to running nviz
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-07-10 06:20:32 UTC (rev 32068)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-07-10 07:50:38 UTC (rev 32069)
@@ -2606,6 +2606,7 @@
         # nviz
         elif name == "nviz":
             import nviz
             # check for GLCanvas and OpenGL
             msg = None
             if not nviz.haveGLCanvas:
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-10 06:20:32 UTC (rev 32068)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-10 07:50:38 UTC (rev 32069)
@@ -268,6 +268,13 @@
         self.nvizClass.EraseMap()
         self.SwapBuffers()
+    def IsLoaded(self, layer):
+        """Check if layer is already loaded"""
+        if self.Map.GetLayerIndex(layer) in self.object.keys():
+            return 1
+        return 0
     def LoadDataLayers(self):
         """Load raster/vector from current layer tree
@@ -1880,7 +1887,7 @@
             self.notebook.GetPage(self.page['vector']).Enable(False)
             # use default values
-            if data == {}:
+            if data == {} or data == None:
                 # attributes
                 for attr in ('topo', 'color'): # required
                     if layer and layer.type == 'raster':
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-07-10 06:20:32 UTC (rev 32068)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-07-10 07:50:38 UTC (rev 32069)
@@ -656,7 +656,7 @@
         Returns list of layers of selected properties or list of all
         layers.
-        @param l_type layer type, e.g. raster/vector/wms/overlay
+        @param l_type layer type, e.g. raster/vector/wms/overlay (value or tuple of values)
         @param l_mapset all layers from given mapset (only for maplayers)
         @param l_name all layers with given name
         @param l_active only layers with 'active' attribute set to True or False
@@ -667,7 +667,12 @@
         selected = []
-        if l_type == 'overlay':
+        if type(l_type) == type(''):
+            one_type = True
+        else:
+            one_type = False
+        if one_type and l_type == 'overlay':
             list = self.overlays
         else:
             list = self.layers
@@ -675,8 +680,11 @@
         # ["raster", "vector", "wms", ... ]
         for layer in list:
             # specified type only
-            if l_type != None and layer.type != l_type:
-                continue
+            if l_type != None:
+                if one_type and layer.type != l_type:
+                    continue
+                elif not one_type and layer.type not in l_type:
+                    continue
             # mapset
             if (l_mapset != None and type != 'overlay') and \
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-10 06:20:32 UTC (rev 32068)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-10 07:50:38 UTC (rev 32069)
@@ -818,7 +818,8 @@
         # update progress bar range (mapwindow statusbar)
         self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
-        if self.mapdisplay.toolbars['nviz']:
+        if self.mapdisplay.toolbars['nviz'] and \
+                self.GetPyData(item) is not None:
             # nviz - load/unload data layer
             mapLayer = self.GetPyData(item)[0]['maplayer']
             if checked: # enable
@@ -907,7 +908,9 @@
             pass
         # update nviz tools
+                self.GetPyData(self.layer_selected) is not None:
+            # update Nviz tool window
             type = self.GetPyData(self.layer_selected)[0]['maplayer'].type
             if type == 'raster':
                 self.mapdisplay.nvizToolWin.UpdatePage('surface')
@@ -1107,7 +1110,29 @@
         # change parameters for item in layers list in render.Map
         self.ChangeLayer(layer)
+        if self.mapdisplay.toolbars['nviz']:
+            # update nviz session
+            mapLayer = self.GetPyData(layer)[0]['maplayer']
+            mapWin = self.mapdisplay.MapWindow
+            if len(mapLayer.GetCmd()) > 0:
+                if mapLayer.type == 'raster':
+                    self.mapdisplay.nvizToolWin.UpdatePage('surface')
+                    self.mapdisplay.nvizToolWin.SetPage('surface')
+                    if not mapWin.IsLoaded(mapLayer):
+                        mapWin.LoadRaster(mapLayer)
+                elif mapLayer.type == 'vector':
+                    self.mapdisplay.nvizToolWin.UpdatePage('vector')
+                    self.mapdisplay.nvizToolWin.SetPage('vector')
+                        mapWin.LoadVector(mapLayer)
+                # reset view when first layer loaded
+                nlayers = len(mapWin.Map.GetListOfLayers(l_type=('raster', 'vector'),
+                                                         l_active=True))
+                if nlayers < 2:
+                    mapWin.ResetView()
     def ReorderLayers(self):
         """Add commands from data associated with
         any valid layers (checked or not) to layer list in order to
