[GRASS-SVN] r32071 - in grass/trunk/gui/wxpython: . gui_modules nviz xml
Thu Jul 10 08:20:08 EDT 2008
Author: martinl
Date: 2008-07-10 08:20:08 -0400 (Thu, 10 Jul 2008)
New Revision: 32071
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/nviz/change_view.cpp
   grass/trunk/gui/wxpython/nviz/nviz.h
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/grass-gxw.dtd
nviz2/wxGUI: initial workspace upgrade
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-10 12:20:08 UTC (rev 32071)
@@ -104,9 +104,16 @@
         # default values
-        self.view = UserSettings.Get(group='nviz', key='view') # reference
+        self.view = copy.deepcopy(UserSettings.Get(group='nviz', key='view')) # copy
         self.iview = UserSettings.Get(group='nviz', key='view', internal=True)
         self.update = {} # update view/controls
+        self.update['view'] = None
+        self.update['surface'] = {}
+        for sec in ('attribute', 'draw', 'mask', 'position'):
+            self.update['surface'][sec] = {}
+        self.update['vector'] = {}
+        for sec in ('lines', ):
+            self.update['vector'][sec] = {}
         self.object = {} # loaded data objects (layer index / gsurf id)
         self.size = None
@@ -139,14 +146,17 @@
         self.SetCurrent()
         if not self.init:
             self.nvizClass.InitView()
             self.LoadDataLayers()
-            self.view['z-exag']['value'], \
-                self.iview['height']['value'] = self.nvizClass.SetViewDefault()
+            self.ResetView()
             if hasattr(self.parent, "nvizToolWin"):
                 self.parent.nvizToolWin.UpdatePage('view')
                 self.parent.nvizToolWin.UpdateSettings()
             self.init = True
         self.UpdateMap()
     def OnMouseAction(self, event):
@@ -226,16 +236,16 @@
             self.parent.onRenderGauge.SetRange(2)
             self.parent.onRenderGauge.SetValue(0)
-        if 'view' in self.update.keys():
+        if self.update['view']:
+            if 'z-exag' in self.update['view']:
+                self.nvizClass.SetZExag(self.view['z-exag']['value'])
             self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
                                    self.iview['height']['value'],
                                    self.view['persp']['value'],
                                    self.view['twist']['value'])
-            del self.update['view']
-        if 'z-exag' in self.update.keys():
-            self.nvizClass.SetZExag(self.view['z-exag']['value'])
-            del self.update['z-exag']
         if self.render is True:
             self.parent.onRenderGauge.SetValue(1)
@@ -370,16 +380,21 @@
     def ResetView(self):
         """Reset to default view"""
-        self.view['pos']['x'] = wxnviz.VIEW_DEFAULT_POS_X
-        self.view['pos']['y'] = wxnviz.VIEW_DEFAULT_POS_Y
-        self.view['persp']['value'] = wxnviz.VIEW_DEFAULT_PERSP
-        self.view['twist']['value'] = wxnviz.VIEW_DEFAULT_TWIST
-        self.update['view'] = None
-        self.update['z-exag'] = None
+        self.view['pos']['x'] = UserSettings.Get(group='nviz', key='view',
+                                                 subkey=('pos', 'x'))
+        self.view['pos']['y'] = UserSettings.Get(group='nviz', key='view',
+        self.view['persp']['value'] = UserSettings.Get(group='nviz', key='view',
+                                                       subkey=('persp', 'value'))
+        self.view['twist']['value'] = UserSettings.Get(group='nviz', key='view',
+                                                       subkey=('twist', 'value'))
+        self.update['view'] = ('z-exag', 'pos', 'persp', 'twist')
     def GetMapObjId(self, layer):
         """Get map object id of given map layer (2D)
@@ -392,26 +407,6 @@
         except:
             return -1
-    def SetLayerSettings(self, data):
-        """Set settings for selected layer
-        @param data settings
-        @return 1 on success
-        @return 0 on failure
-        # get currently selected map layer
-        if not self.tree or not self.tree.GetSelection():
-            return 0
-        item = self.tree.GetSelection()
-        try:
-            self.tree.SetPyData(item)[0]['nviz'] = data
-        except:
-            return 0
-        return 1
 class NvizToolWindow(wx.Frame):
     """Experimental window for Nviz tools
@@ -1317,14 +1312,17 @@
         if not winName:
             return
-        self.mapWindow.view[winName]['value'] = event.GetInt()
+        if winName == 'height':
+            view = self.mapWindow.iview # internal
+        else:
+            view = self.mapWindow.view
+        view[winName]['value'] = event.GetInt()
         for win in self.win['view'][winName].itervalues():
-            self.FindWindowById(win).SetValue(self.mapWindow.view[winName]['value'])
+            self.FindWindowById(win).SetValue(view[winName]['value'])
-        if winName in ('pos', 'height', 'twist', 'persp'):
-            self.mapWindow.update['view'] = None
-        else:
-            self.mapWindow.update[winName] = None
+        self.mapWindow.update['view'] = (winName, )
         self.mapWindow.render = False
         self.mapWindow.Refresh(False)
@@ -1336,6 +1334,8 @@
     def OnViewChangedSpin(self, event):
         """View changed, render in full resolution"""
+        # TODO: use step value instead
         self.OnViewChange(event)
         self.OnViewChanged(None)
@@ -1376,7 +1376,7 @@
             self.mapWindow.view['pos']['x'] = 0.0
             self.mapWindow.view['pos']['y'] = 1.0
+        self.mapWindow.update['view'] = ('pos', )
         self.UpdateSettings()
@@ -1439,15 +1439,6 @@
             file = UserSettings.SaveToFile(fileSettings)
             self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
-#         # save settings
-#         type = self.mapWindow.GetSelectedLayer().type
-#         data = self.mapWindow.GetSelectedLayer(nviz=True)
-#         if data is None: # no settings
-#             data = {}
-#         if type == 'raster': # -> surface
 #             # surface attributes
@@ -1502,21 +1493,24 @@
         if mapLayer.type == 'raster':
             self.UpdateRasterProperties(id, data)
+            # reset updates
+            for sec in self.mapWindow.update['surface'].keys():
+                self.mapWindow.update['surface'][sec] = {}
         elif mapLayer.type == 'vector':
             self.UpdateVectorProperties(id, data)
+            # reset updates
+            for sec in self.mapWindow.update['vector'].keys():
+                self.mapWindow.update['vector'][sec] = {}
-        # reset
-        self.mapWindow.update = {}
+        print self.mapWindow.GetSelectedLayer(nviz=True)
-        # print self.mapWindow.GetSelectedLayer(nviz=True)
     def UpdateRasterProperties(self, id, data):
         """Apply changes for surfaces"""
         for attrb in ('topo', 'color', 'mask',
                      'transp', 'shine', 'emit'):
-            if self.mapWindow.update.has_key(attrb):
-                map, value = self.mapWindow.update[attrb]
+            if self.mapWindow.update['surface']['attribute'].has_key(attrb):
+                map, value = self.mapWindow.update['surface']['attribute'][attrb]
                 if map is None: # unset
                     # only optional attributes
                     if attrb == 'mask':
@@ -1546,32 +1540,32 @@
                         self.mapWindow.nvizClass.SetSurfaceEmit(id, map, str(value))
         # draw res
-        if self.mapWindow.update.has_key('draw-res'):
-            coarse, fine, all = self.mapWindow.update['draw-res']
+        if self.mapWindow.update['surface']['draw'].has_key('resolution'):
+            coarse, fine, all = self.mapWindow.update['surface']['draw']['resolution']
             if all:
                 self.mapWindow.nvizClass.SetSurfaceRes(-1, fine, coarse)
             else:
                 self.mapWindow.nvizClass.SetSurfaceRes(id, fine, coarse)
         # draw style
-        if self.mapWindow.update.has_key('draw-style'):
-            style, all = self.mapWindow.update['draw-style']
+        if self.mapWindow.update['surface']['draw'].has_key('mode'):
+            style, all = self.mapWindow.update['surface']['draw']['mode']
             if all:
                 self.mapWindow.nvizClass.SetSurfaceStyle(-1, style)
             else:
                 self.mapWindow.nvizClass.SetSurfaceStyle(id, style)
         # wire color
-        if self.mapWindow.update.has_key('draw-color'):
-            color, all = self.mapWindow.update['draw-color']
+        if self.mapWindow.update['surface']['draw'].has_key('color'):
+            color, all = self.mapWindow.update['surface']['draw']['color']
             if all:
                 self.mapWindow.nvizClass.SetWireColor(id, str(color))
             else:
                 self.mapWindow.nvizClass.SetWireColor(-1, str(color))
         # position
-        if self.mapWindow.update.has_key('surface-position'):
-            axis, value = self.mapWindow.update['surface-position']
+        if self.mapWindow.update['surface']['position'].has_key('coords'):
+            axis, value = self.mapWindow.update['surface']['position']['coords']
             x, y, z = self.mapWindow.nvizClass.GetSurfacePosition(id)
             if axis == 0:
                 x = value
@@ -1579,25 +1573,32 @@
                 y = value
             else:
                 z = value
+            self.mapWindow.update['surface']['position']['coords'] = (x, y, z)
             self.mapWindow.nvizClass.SetSurfacePosition(id, x, y, z)
         # update properties
-        for prop in self.mapWindow.update.keys():
-            data[prop] = self.mapWindow.update[prop]
+            if not data.has_key(sec):
+                data[sec] = {}
+            for prop in self.mapWindow.update['surface'][sec].keys():
+                data[sec][prop] = self.mapWindow.update['surface'][sec][prop]
     def UpdateVectorProperties(self, id, data):
         """Apply changes for vector"""
-        if self.mapWindow.update.has_key('vector-lines'):
-            width, color, flat = self.mapWindow.update['vector-lines']
+        if self.mapWindow.update['vector']['lines'].has_key('mode'):
+            width, color, flat = self.mapWindow.update['vector']['lines']['mode']
             self.mapWindow.nvizClass.SetVectorLineMode(id, color, width, flat)
-        if self.mapWindow.update.has_key('vector-height'):
-            height = self.mapWindow.update['vector-height']
+        if self.mapWindow.update['vector']['lines'].has_key('height'):
+            height = self.mapWindow.update['vector']['lines']['height']
             self.mapWindow.nvizClass.SetVectorHeight(id, height)
         # update properties
+                data[sec] = {}
+            for prop in self.mapWindow.update['vector'][sec].keys():
+                data[sec][prop] = self.mapWindow.update['vector'][sec][prop]
     def OnBgColor(self, event):
         """Background color changed"""
@@ -1626,6 +1627,9 @@
         if not attrb:
             return
+        # reset updates
+        self.mapWindow.update['surface']['attribute'] = {}
         selection = event.GetSelection()
         if self.win['surface'][attrb]['required']: # no 'unset'
             selection += 1
@@ -1645,7 +1649,7 @@
         self.SetSurfaceUseMap(attrb, useMap)
-        self.mapWindow.update[attrb] = (useMap, str(value))
+        self.mapWindow.update['surface']['attribute'][attrb] = (useMap, str(value))
         self.UpdateLayerProperties()
         if self.parent.autoRender.IsChecked():
@@ -1702,7 +1706,7 @@
             map = False
         if self.pageUpdated: # do not update when selection is changed
-            self.mapWindow.update[attrb] = (map, str(value))
+            self.mapWindow.update['surface']['attribute'][attrb] = (map, str(value))
@@ -1720,7 +1724,10 @@
         coarse = self.FindWindowById(self.win['surface']['draw']['res-coarse']).GetValue()
         fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
-        self.mapWindow.update['draw-res'] = (coarse, fine, all)
+        # reset updates
+        self.mapWindow.update['surface']['draw'] = {}
+        self.mapWindow.update['surface']['draw']['resolution'] = (coarse, fine, all)
     def SetSurfaceMode(self, all=False):
@@ -1757,7 +1764,9 @@
             value |= wxnviz.DM_GOURAUD
-            self.mapWindow.update['draw-style'] = (value, all)
+            # reset updates
+            self.mapWindow.update['surface']['draw']['style'] = (value, all)
     def OnSurfaceMode(self, event):
@@ -1782,7 +1791,9 @@
         value = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
-            self.mapWindow.update['draw-color'] = (value, all)
+            # reset updates
+            self.mapWindow.update['surface']['draw']['color'] = (value, all)
     def OnSurfaceWireColor(self, event):
@@ -1817,7 +1828,8 @@
         axis = self.FindWindowById(self.win['surface']['position']['axis']).GetSelection()
         value = event.GetInt()
-        self.mapWindow.update['surface-position'] = (axis, value)
+        self.mapWindow.update['surface']['position'] = {}
+        self.mapWindow.update['surface']['position']['coords'] = (axis, value)
@@ -1848,7 +1860,7 @@
         else:
             flat = True
-        self.mapWindow.update['vector-lines'] = (width, color, flat)
+        self.mapWindow.update['vector']['lines']['mode'] = (width, color, flat)
@@ -1864,7 +1876,7 @@
             win = self.FindWindowById(self.win['vector']['lines']['height']['slider'])
         win.SetValue(value)
-        self.mapWindow.update['vector-height'] = value
+        self.mapWindow.update['vector']['lines']['height'] = value
@@ -2015,9 +2027,11 @@
             w, h = self.GetClientSize()
             x = float(x) / w
             y = float(y) / h
-            self.mapWindow.view['pos']['x'] = x
-            self.mapWindow.view['pos']['y'] = y
+            if x >= 0 and x <= 1.0:
+                self.mapWindow.view['pos']['x'] = x
+            if y >= 0 and y <= 1.0:
+                self.mapWindow.view['pos']['y'] = y
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-07-10 12:20:08 UTC (rev 32071)
@@ -626,7 +626,8 @@
                 else:
                     return settings[group][key]
             else:
-                if type(subkey) == type([]):
+                if type(subkey) == type([]) or \
+                        type(subkey) == type(()):
                     return settings[group][key][subkey[0]][subkey[1]]
                 else:
                     return settings[group][key][subkey]
Modified: grass/trunk/gui/wxpython/nviz/change_view.cpp
--- grass/trunk/gui/wxpython/nviz/change_view.cpp	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/nviz/change_view.cpp	2008-07-10 12:20:08 UTC (rev 32071)
@@ -60,9 +60,10 @@
     Nviz_get_exag_height(&vp_height, NULL, NULL);
     ret.push_back(vp_height);
     SetView(VIEW_DEFAULT_POS_X, VIEW_DEFAULT_POS_Y,
 	    vp_height, VIEW_DEFAULT_PERSP, VIEW_DEFAULT_TWIST);
     G_debug(1, "Nviz::SetViewDefault()");
     return ret;
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-10 12:20:08 UTC (rev 32071)
@@ -24,11 +24,6 @@
 #include <wx/glcanvas.h>
-#define VIEW_DEFAULT_POS_X 0.85
-#define VIEW_DEFAULT_POS_Y 0.85
-#define VIEW_DEFAULT_PERSP 40.0
-#define VIEW_DEFAULT_TWIST 0.0
 class Nviz
 private:
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-07-10 12:20:08 UTC (rev 32071)
@@ -866,11 +866,41 @@
                         file.write('%s</parameter>\n' % (' ' * self.indent));
                 self.indent -= 4
                 file.write('%s</task>\n' % (' ' * self.indent));
+                nviz = mapTree.GetPyData(item)[0]['nviz']
+                if nviz:
+                    file.write('%s<nviz>\n' % (' ' * self.indent));
+                    self.WriteNvizToWorkspace(file, self.indent, nviz, type=maplayer.type)
+                    file.write('%s</nviz>\n' % (' ' * self.indent));
                 self.indent -= 4
                 file.write('%s</layer>\n' % (' ' * self.indent));
             item = mapTree.GetNextSibling(item)
         self.indent -= 4
+    def WriteNvizToWorkspace(self, file, indent, data, type):
+        """Save Nviz layer properties to workspace
+        @param file file stream
+        @param indent indentation value
+        @param data Nviz layer properties
+        @param type map layer type ('raster' or 'vector')
+        indent += 4
+        if type == 'raster':
+            for attrb in data.iterkeys():
+                if len(data[attrb]) < 1: # skip empty attributes
+                    continue
+                for name in data[attrb].iterkeys():
+                    if attrb == 'attribute': # surface attribute
+                        map, value = data[attrb][name]
+                        print '%s<%s name="%s" map="%d">\n' % \
+                            (' ' * indent, attrb, name, map)
+                    indent += 4
+                    print '%s<value>%s</value>\n' % (' ' * indent, value)
+                    indent -= 4
+                    print '%s<%s>\n' % (' ' * indent, attrb)
+        elif type == 'vector':
+            pass
     def SaveToWorkspaceFile(self, filename):
         """Save layer tree layout to workspace file
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-07-10 09:08:21 UTC (rev 32070)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-07-10 12:20:08 UTC (rev 32071)
@@ -1,6 +1,6 @@
 <!--	grass-gxw.dtd
-	Copyright (C) 2007 by the GRASS Development Team
+	Copyright (C) 2007-2008 by the GRASS Development Team
 	Author: Martin Landa <landa.martin gmail.com>
 	This program is free software under the GPL (>=v2)
@@ -45,7 +45,7 @@
 <!--    map layer
-<!ELEMENT layer (selected?, task?)>
+<!ELEMENT layer (selected?, task?, nviz?)>
 <!ATTLIST layer	type	CDATA   #REQUIRED>
 <!ATTLIST layer	name	CDATA   #REQUIRED>
 <!ATTLIST layer	checked (0 | 1) #REQUIRED>
@@ -70,8 +70,16 @@
 <!ELEMENT value         (#PCDATA)>
 <!--    enabled flag
 <!ELEMENT flag          EMPTY>
 <!ATTLIST flag          name            CDATA #REQUIRED>
+<!--    nviz layer properties
+<!ELEMENT nviz	        (attribute*)>
+<!--    nviz  surface attribute parameter
+<!ELEMENT attribute     (value)>
+<!ATTLIST attribute	map		(0 | 1) #REQUIRED>
