[GRASS-SVN] r32094 - grass/branches/develbranch_6/mswindows
Mon Jul 14 11:44:50 EDT 2008
Author: marcopx
Date: 2008-07-14 11:44:50 -0400 (Mon, 14 Jul 2008)
New Revision: 32094
Removed:
   grass/branches/develbranch_6/mswindows/README.html
Removed README.html file due to redundant replication with GRASS web
Deleted: grass/branches/develbranch_6/mswindows/README.html
--- grass/branches/develbranch_6/mswindows/README.html	2008-07-14 11:12:24 UTC (rev 32093)
+++ grass/branches/develbranch_6/mswindows/README.html	2008-07-14 15:44:50 UTC (rev 32094)
@@ -1,411 +0,0 @@
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
-<meta http-equiv="Content-Language" content="en" />
-<meta name="Author" content="Marco Pasetti" />
-<meta name="Description" content="SVN mswindows README" />
-<title>SVN mswindows README</title>
-<style type="text/css" />
-/* Wiki Pages Styles */
-/* TableOfContents */
-.table-of-contents	{
-					border: 1px solid #bbbbbb;
-					color: black; background-color: #eeeeee;
-					font-size: small;
-					text-align:left;
-					margin: 0.5em; padding-left: 1em;
-					width: 360;
-/* Contents */
-html	{
-		background-color: white;
-		color: black;
-		font-family: Arial, Lucida Grande, sans-serif;
-		font-size: 10pt;
-body	{
-		margin: 30;
-ol	{
-	font-size: 10pt;
-	margin-top: 0;
-	margin-bottom: 0;
-	margin-left: 0;
-h1	{
-	font-size: 18pt;
-	margin-top: 0;
-	margin-bottom: 50;
-h2	{
-	font-size: 16pt;
-	margin-top: 60;
-	margin-bottom: 20;
-h3	{
-	font-size: 14pt;
-	margin-top: 60;
-h4	{
-	font-size: 11pt;
-	margin-top: 0;
-	margin-bottom: 0;
-p	{
-	font-size: 10pt;
-	margin-top: 10;
-	margin-bottom: 10;
-code	{
-		font-family: Courier-new, monospace;
-		font-size: 10pt;
-		margin-top: 10;
-pre	{
-	padding: 1em;
-	border: 1px dashed #2f6fab;
-	color: black;
-	background-color: #f9f9f9;
-	line-height: 1.1em;
-/* Tables */
-table
-	margin: 0.5em 0 0 0.5em;
-	border-collapse: collapse;
-td
-	padding: 0.25em 0.5em 0.25em 0.5em;
-	border: 0pt solid #ADB9CC;
-	font-size: 10pt;
-/* Links */
-a	{
-	text-decoration: none;
-	color: #002bb8;
-	background: none;
-a:hover {
-		text-decoration: underline;
-		color: green;
-a:visited:hover	{
-				color: red;
-</style>
-</head>
-<body>
-<h1>How to prepare a WinGRASS Release</h1>
-<div class="table-of-contents">
-<p><strong>Table of Contents</strong></p>
-<p><a href="#Introduction">Introduction</a></p>
-<p><ol>
-<li><a href="#Install MSYS">Install MSYS</a></li>
-<li><a href="#Install MinGW">Install MinGW</a></li>
-<li><a href="#Install the GRASS MSYS Environment">Install the GRASS MSYS Environment</a></li>
-<li><a href="#Build and Install GRASS">Build and Install GRASS</a></li>
-<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
-<li><a href="#Install NSIS">Install NSIS</a></li>
-<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
-</ol></p>
-<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
-<br>
-</div>
-<div id="Introduction">
-<p><h3>Introduction</h3></p>
-<p>This document explains how to prepare a WinGRASS release (as a self-contained package installer) using the scripts contained
-in the SVN Win32 folder. In order to avoid mistakes or misunderstandings, I highly recommend to follow each step and command
-exactly as they are written in this document.</p>
-</div>
-<div id="Install MSYS">
-<p><h3>1. Install MSYS (1.0.11)</h3></p>
-<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/mingw/MSYS-1.0.11-2004.04.30-1.exe">MSYS installer</a></p>
-<p>Install to <code>c:\msys</code></p>
-<p>At the command prompt question for post install, type <code>n</code> and then enter.</p>
-</div>
-<div id="Install MinGW">
-<p><h3>2. Install MinGW (5.1.3)</h3></p>
-<p>Download the <a target="_blank" href="http://downloads.sourceforge.net/mingw/MinGW-5.1.3.exe">MinGW installer</a></p>
-<p>Select "Download and Install Current Version";</p>
-<p>Install only "g++ compiler" and "MinGW Make";</p>
-<p>Install to <code>c:\msys\mingw</code></p>
-</div>
-<div id="Install the GRASS MSYS Environment">
-<p><h3>3. Install the GRASS MSYS Environment</h3></p>
-<p>Download the <a target="_blank" href="http://grass.osgeo.org/grass63/binary/mswindows/native/GRASS_MSYS_Environment.zip">
-GRASS MSYS Environment</a></p>
-<p>Extract the whole package to <code>c:\msys\local</code></p>
-</div>
-<div id="Build and Install GRASS">
-<p><h3>4. Build and Install GRASS (6.3.0)</h3></p>
-<p>Download the <a target="_blank" href="http://grass.osgeo.org/grass63/source/grass-6.3.0.tar.gz">GRASS source code</a></p>
-<p>Unpack to <code>c:\msys\local\src</code></p>
-<p>Open <code>c:\msys\local\src\grass-6.3.0\man\Makefile</code></p>
-<p>At line 13, replace:</p>
-<pre><code>default: $(MANPAGES)</pre></code>
-<p>with:</p>
-<pre><code>default:</pre></code>
-<p>In MSYS console, type:</p>
-<pre><code>cd /usr/local/src/grass-6.3.0
-./configure \
---prefix=/usr/local \
---with-includes=/usr/local/include \
---with-libs=/usr/local/lib \
---disable-x11 \
---without-jpeg \
---without-x \
---with-cxx \
---enable-shared \
---enable-largefile \
---with-opengl=windows \
---with-fftw \
---with-freetype \
---with-proj-share=/usr/local/share/proj \
---with-gdal=/usr/local/bin/gdal-config \
---with-tcltk --with-tcltk-includes=/usr/local/tcl-tk/include --with-tcltk-libs=/usr/local/tcl-tk/bin \
---with-sqlite --with-sqlite-includes=/usr/local/sqlite/include --with-sqlite-libs=/usr/local/sqlite/lib \
---with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib</code></pre>
-<p>When finished, you should have the following screen output:</p>
-<pre><code>GRASS is now configured for:  i686-pc-mingw32
- Source directory:            /usr/local/src/grass-6.3.0
- Build directory:             /usr/local/src/grass-6.3.0
- Installation directory:      ${prefix}/grass-6.3.0
- Startup script in directory: ${exec_prefix}/bin
- C compiler:                  gcc -g -O2
- C++ compiler:                c++ -g -O2
- Building shared libraries:   yes
- 64bit support:               no
- OpenGL platform:             Windows
-  NVIZ:                       yes
-  BLAS support:               no
-  C++ support:                yes
-  DWG support:                no
-  FFMPEG support:             no
-  FFTW support:               yes
-  FreeType support:           yes
-  GDAL support:               yes
-  GLw support:                no
-  JPEG support:               no
-  LAPACK support:             no
-  Large File Support (LFS):   yes
-  Motif support:              no
-  MySQL support:              no
-  NLS support:                no
-  ODBC support:               no
-  OGR support:                yes
-  OpenGL support:             yes
-  PNG support:                yes
-  PostgreSQL support:         yes
-  Python support:             no
-  Readline support:           no
-  SQLite support:             yes
-  Tcl/Tk support:             yes
-  wxWidgets support:          no
-  TIFF support:               yes
-  X11 support:                no
-  MacOSX application:         no</code></pre>
-Having GRASS successfully configured, now you can build it:
-<pre><code>export PATH="/usr/local/bin:/usr/local/tcl-tk/bin:/usr/local/sqlite/bin:/usr/local/pgsql/lib:$PATH"
-make</code></pre>
-<p>When finished, you should have the following compilation log:</p>
-<pre><code>GRASS GIS compilation log
-Started compilation: Thu Apr 24 07:56:14 GMT 2008
-Errors in:
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.daemon
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.edgedensity
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.patchdensity
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.patchnum
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.shape
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.simpson
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.shannon
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.mps
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.mpa
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.padcv
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.padsd
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.padrange
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.cwed
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.richness
-/usr/local/src/grass-6.3.0/raster/r.li/r.li.dominance
-In case of errors please change into the directory with error and run 'make'.
-If you get multiple errors, you need to deal with them in the order they
-appear in the error log. If you get an error building a library, you will
-also get errors from anything which uses the library.
-Finished compilation: Thu Apr 24 10:54:25 GMT 2008</code></pre>
-<p>Then install GRASS:</p>
-<pre><code>make install</code></pre>
-<p>Now GRASS should be installed in <code>c:\msys\local\grass-6.3.0</code></p>
-</div>
-<div id="Create a GRASS self-contained Package">
-<p><h3>5. Create a GRASS self-contained Package</h3></p>
-<p>Copy all the content of the SVN Win32 folder to a temporary directory, for example <code>c:\temp</code>.</p>
-<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select the option number 1.</p>
-<p>When finished, you should have a GRASS self-contained release package in <code>c:\temp\GRASS-6-Release-Package</code>.</p>
-</div>
-<div id="Install NSIS">
-<p><h3>6. Install NSIS (2.36)</h3></p>
-<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.36-setup.exe">NSIS installer</a></p>
-<p>Install to <code>c:\DevTools</code></p>
-</div>
-<div id="Create the WinGRASS Installer">
-<p><h3>7. Create the WinGRASS Installer</h3></p>
-<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
-<p>At line 17 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>, then, at lines 23-25, set the
-<code>RELEASE_VERSION_NUMBER</code>, the <code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code> variables.</p>
-<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code> and select <code>Compile NSIS Script</code>.</p>
-<p>When finished, you should have the WinGRASS release installer in <code>c:\temp</code>.</p>
-</div>
-<div id="Credits and Contacts">
-<p><h3>Credits and Contacts</h3></p>
-<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts are provided by Marco Pasetti.</p>
-<p>To contact him, e-mail to: GRASS Development Mailing List
-(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
-<p>Edited by Marco Pasetti on 16 May 2008.</p>
-</div>
-</body>
-</html>
\ No newline at end of file
