[GRASS-SVN] r32102 - grass/branches/develbranch_6/mswindows
Mon Jul 14 12:42:43 EDT 2008
Author: marcopx
Date: 2008-07-14 12:42:42 -0400 (Mon, 14 Jul 2008)
New Revision: 32102
Added:
   grass/branches/develbranch_6/mswindows/README.html
Updated Installer files
Added: grass/branches/develbranch_6/mswindows/README.html
--- grass/branches/develbranch_6/mswindows/README.html	                        (rev 0)
+++ grass/branches/develbranch_6/mswindows/README.html	2008-07-14 16:42:42 UTC (rev 32102)
@@ -0,0 +1,416 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+<meta http-equiv="Content-Language" content="en" />
+<meta name="Author" content="Marco Pasetti" />
+<meta name="Description" content="SVN mswindows README" />
+<title>SVN mswindows README</title>
+<style type="text/css" />
+/* Wiki Pages Styles */
+/* TableOfContents */
+.table-of-contents	{
+					border: 1px solid #bbbbbb;
+					color: black; background-color: #eeeeee;
+					font-size: small;
+					text-align:left;
+					margin: 0.5em; padding-left: 1em;
+					width: 360;
+/* Contents */
+html	{
+		background-color: white;
+		color: black;
+		font-family: Arial, Lucida Grande, sans-serif;
+		font-size: 10pt;
+body	{
+		margin: 30;
+ol	{
+	font-size: 10pt;
+	margin-top: 0;
+	margin-bottom: 0;
+	margin-left: 0;
+h1	{
+	font-size: 18pt;
+	margin-top: 0;
+	margin-bottom: 50;
+h2	{
+	font-size: 16pt;
+	margin-top: 60;
+	margin-bottom: 20;
+h3	{
+	font-size: 14pt;
+	margin-top: 60;
+h4	{
+	font-size: 11pt;
+	margin-top: 0;
+	margin-bottom: 0;
+p	{
+	font-size: 10pt;
+	margin-top: 10;
+	margin-bottom: 10;
+code	{
+		font-family: Courier-new, monospace;
+		font-size: 10pt;
+		margin-top: 10;
+pre	{
+	padding: 1em;
+	border: 1px dashed #2f6fab;
+	color: black;
+	background-color: #f9f9f9;
+	line-height: 1.1em;
+/* Tables */
+table
+	margin: 0.5em 0 0 0.5em;
+	border-collapse: collapse;
+td
+	padding: 0.25em 0.5em 0.25em 0.5em;
+	border: 0pt solid #ADB9CC;
+	font-size: 10pt;
+/* Links */
+a	{
+	text-decoration: none;
+	color: #002bb8;
+	background: none;
+a:hover {
+		text-decoration: underline;
+		color: green;
+a:visited:hover	{
+				color: red;
+</style>
+</head>
+<body>
+<h1>How to prepare a WinGRASS Release</h1>
+<div class="table-of-contents">
+<p><strong>Table of Contents</strong></p>
+<p><a href="#Introduction">Introduction</a></p>
+<p><ol>
+<li><a href="#Install MSYS">Install MSYS</a></li>
+<li><a href="#Install MinGW">Install MinGW</a></li>
+<li><a href="#Install the GRASS MSYS Environment">Install the GRASS MSYS Environment</a></li>
+<li><a href="#Build and Install GRASS">Build and Install GRASS</a></li>
+<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
+<li><a href="#Install NSIS">Install NSIS</a></li>
+<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
+</ol></p>
+<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
+<br>
+</div>
+<div id="Introduction">
+<p><h3>Introduction</h3></p>
+<p>This document explains how to prepare a WinGRASS release (as a self-contained package installer) using the scripts contained
+in the SVN Win32 folder. In order to avoid mistakes or misunderstandings, I highly recommend to follow each step and command
+exactly as they are written in this document.</p>
+</div>
+<div id="Install MSYS">
+<p><h3>1. Install MSYS (1.0.11)</h3></p>
+<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/mingw/MSYS-1.0.11-2004.04.30-1.exe">MSYS installer</a></p>
+<p>Install to <code>c:\msys</code></p>
+<p>At the command prompt question for post install, type <code>n</code> and then enter.</p>
+<p>Download the <a target="_blank" href="http://downloads.sourceforge.net/mingw/coreutils-5.97-MSYS-1.0.11-snapshot.tar.bz2">MSYS coreutils package</a></p>
+<p>Unpack it to a temporary folder, then copy all the content of the <code>coreutils-5.97</code> folder to <code>c:\msys</code>
+(overwrite the existing files when asked)</p>
+</div>
+<div id="Install MinGW">
+<p><h3>2. Install MinGW (5.1.4)</h3></p>
+<p>Download the <a target="_blank" href="http://downloads.sourceforge.net/mingw/MinGW-5.1.4.exe">MinGW installer</a></p>
+<p>Select "Download and Install Current Version";</p>
+<p>Install only "g++ compiler" and "MinGW Make";</p>
+<p>Install to <code>c:\msys\mingw</code></p>
+</div>
+<div id="Install the GRASS MSYS Environment">
+<p><h3>3. Install the GRASS MSYS Environment</h3></p>
+<p>Download the <a target="_blank" href="http://grass.osgeo.org/grass63/binary/mswindows/native/GRASS_MSYS_Environment.zip">
+GRASS MSYS Environment</a></p>
+<p>Extract the whole package to <code>c:\msys\local</code></p>
+</div>
+<div id="Build and Install GRASS">
+<p><h3>4. Build and Install GRASS (6.3.0)</h3></p>
+<p>Download the <a target="_blank" href="http://grass.osgeo.org/grass63/source/grass-6.3.0.tar.gz">GRASS source code</a></p>
+<p>Unpack to <code>c:\msys\local\src</code></p>
+<p>Open <code>c:\msys\local\src\grass-6.3.0\man\Makefile</code></p>
+<p>At line 13, replace:</p>
+<pre><code>default: $(MANPAGES)</pre></code>
+<p>with:</p>
+<pre><code>default:</pre></code>
+<p>In MSYS console, type:</p>
+<pre><code>cd /usr/local/src/grass-6.3.0
+./configure \
+--prefix=/usr/local \
+--with-includes=/usr/local/include \
+--with-libs=/usr/local/lib \
+--disable-x11 \
+--without-x \
+--with-cxx \
+--enable-shared \
+--enable-largefile \
+--with-opengl=windows \
+--with-fftw \
+--with-freetype \
+--with-proj-share=/usr/local/share/proj \
+--with-gdal=/usr/local/bin/gdal-config \
+--with-tcltk --with-tcltk-includes=/usr/local/tcl-tk/include --with-tcltk-libs=/usr/local/tcl-tk/bin \
+--with-sqlite --with-sqlite-includes=/usr/local/sqlite/include --with-sqlite-libs=/usr/local/sqlite/lib \
+--with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib</code></pre>
+<p>When finished, you should have the following screen output:</p>
+<pre><code>GRASS is now configured for:  i686-pc-mingw32
+ Source directory:            /usr/local/src/grass-6.3.0
+ Build directory:             /usr/local/src/grass-6.3.0
+ Installation directory:      ${prefix}/grass-6.3.0
+ Startup script in directory: ${exec_prefix}/bin
+ C compiler:                  gcc -g -O2
+ C++ compiler:                c++ -g -O2
+ Building shared libraries:   yes
+ 64bit support:               no
+ OpenGL platform:             Windows
+  NVIZ:                       yes
+  BLAS support:               no
+  C++ support:                yes
+  DWG support:                no
+  FFMPEG support:             no
+  FFTW support:               yes
+  FreeType support:           yes
+  GDAL support:               yes
+  GLw support:                no
+  JPEG support:               yes
+  LAPACK support:             no
+  Large File Support (LFS):   yes
+  Motif support:              no
+  MySQL support:              no
+  NLS support:                no
+  ODBC support:               no
+  OGR support:                yes
+  OpenGL support:             yes
+  PNG support:                yes
+  PostgreSQL support:         yes
+  Python support:             no
+  Readline support:           no
+  SQLite support:             yes
+  Tcl/Tk support:             yes
+  wxWidgets support:          no
+  TIFF support:               yes
+  X11 support:                no
+  MacOSX application:         no</code></pre>
+Having GRASS successfully configured, now you can build it:
+<pre><code>export PATH="/usr/local/bin:/usr/local/tcl-tk/bin:/usr/local/sqlite/bin:/usr/local/pgsql/lib:$PATH"
+make</code></pre>
+<p>When finished, you should have the following compilation log:</p>
+<pre><code>GRASS GIS compilation log
+Started compilation: Mon Jun 16 09:08:19 GMT 2008
+Errors in:
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.daemon
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.edgedensity
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.patchdensity
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.patchnum
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.shape
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.simpson
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.shannon
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.mps
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.mpa
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.padcv
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.padsd
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.padrange
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.cwed
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.richness
+/usr/local/src/grass-6.3.0/raster/r.li/r.li.dominance
+In case of errors please change into the directory with error and run 'make'.
+If you get multiple errors, you need to deal with them in the order they
+appear in the error log. If you get an error building a library, you will
+also get errors from anything which uses the library.
+Finished compilation: Mon Jun 16 10:11:17 GMT 2008
+make: *** [default] Error 1</code></pre>
+<p>Then install GRASS:</p>
+<pre><code>make install</code></pre>
+<p>Now GRASS should be installed in <code>c:\msys\local\grass-6.3.0</code></p>
+</div>
+<div id="Create a GRASS self-contained Package">
+<p><h3>5. Create a GRASS self-contained Package</h3></p>
+<p>Copy all the content of the SVN Win32 folder to a temporary directory, for example <code>c:\temp</code>.</p>
+<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select the option number 1.</p>
+<p>When finished, you should have a GRASS self-contained release package in <code>c:\temp\GRASS-Release-Package</code>.</p>
+</div>
+<div id="Install NSIS">
+<p><h3>6. Install NSIS (2.38)</h3></p>
+<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.38-setup.exe">NSIS installer</a></p>
+<p>Install to <code>c:\DevTools</code></p>
+</div>
+<div id="Create the WinGRASS Installer">
+<p><h3>7. Create the WinGRASS Installer</h3></p>
+<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
+<p>At line 17 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>, then, at lines 23-25, set the
+<code>RELEASE_VERSION_NUMBER</code>, the <code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code> variables.</p>
+<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code> and select <code>Compile NSIS Script</code>.</p>
+<p>When finished, you should have the WinGRASS release installer in <code>c:\temp</code>.</p>
+</div>
+<div id="Credits and Contacts">
+<p><h3>Credits and Contacts</h3></p>
+<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts are provided by Marco Pasetti.</p>
+<p>To contact him, e-mail to: GRASS Development Mailing List
+(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
+<p>Edited by Marco Pasetti on 14 July 2008.</p>
+</div>
+</body>
+</html>
\ No newline at end of file
