[GRASS-SVN] r32155 - in grass-addons/gipe: . i.wi
Fri Jul 18 03:47:26 EDT 2008
Author: ychemin
Date: 2008-07-18 03:47:25 -0400 (Fri, 18 Jul 2008)
New Revision: 32155
Added:
   grass-addons/gipe/i.wi/
   grass-addons/gipe/i.wi/Makefile
   grass-addons/gipe/i.wi/description.html
   grass-addons/gipe/i.wi/lswi.c
   grass-addons/gipe/i.wi/main.c
Added i.wi for water indices
Added: grass-addons/gipe/i.wi/Makefile
--- grass-addons/gipe/i.wi/Makefile	                        (rev 0)
+++ grass-addons/gipe/i.wi/Makefile	2008-07-18 07:47:25 UTC (rev 32155)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = i.wi
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/i.wi/description.html
--- grass-addons/gipe/i.wi/description.html	                        (rev 0)
+++ grass-addons/gipe/i.wi/description.html	2008-07-18 07:47:25 UTC (rev 32155)
@@ -0,0 +1,26 @@
+<H2>DESCRIPTION</H2>
+<EM>i.wi</EM> calculates water indices based on biophysical parameters.
+1. LSWI: Land Surface Water Index
+<H2>NOTES</H2>
+Created the module following the i.vi modular architechture to add more water indices as they come in literature.
+<H2>TODO</H2>
+Find other water indices and add them.
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.vi.html">i.vi</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
+<p>
+<i>Last changed: $Date: 2006/10/09 21:30:42 $</i>
Added: grass-addons/gipe/i.wi/lswi.c
--- grass-addons/gipe/i.wi/lswi.c	                        (rev 0)
+++ grass-addons/gipe/i.wi/lswi.c	2008-07-18 07:47:25 UTC (rev 32155)
@@ -0,0 +1,25 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+// Land Surface Water Index (LWSI)
+// a kind of Normalized Difference Water Index
+// Xiao X., Boles S., Frolking S., Salas W., Moore B., Li C., et al. (2002)
+// Landscape-scale characterization of cropland in China using vegetation and Landsat TM images.
+// International Journal of Remote Sensing, 23:3579-3594.
+double ls_wi( double nirchan, double swirchan )
+	double result;
+	if( ( nirchan + swirchan ) ==  0.0 ){
+		result = -1.0;
+	} else {
+		result = ( nirchan - swirchan ) / ( nirchan + swirchan );
+	return result;
Added: grass-addons/gipe/i.wi/main.c
--- grass-addons/gipe/i.wi/main.c	                        (rev 0)
+++ grass-addons/gipe/i.wi/main.c	2008-07-18 07:47:25 UTC (rev 32155)
@@ -0,0 +1,200 @@
+ * MODULE:       i.wi
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculates water indices
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+double ls_wi( double nirchan, double swirchan );
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	char *wiflag;// Switch for particular index
+	struct GModule *module;
+	struct Option *input1,*input2,*input3, *output;
+	struct Flag *flag1;
+	struct History history; //metadata
+	struct Colors colors; //Color rules
+	/* FMEO Declarations*****************/
+	char *name;   // input raster name
+	char *result; //output raster name
+	//File Descriptors
+	int infd_nirchan, infd_swirchan;
+	int outfd;
+	char  *nirchan, *swirchan;
+	int i=0,j=0;
+	void  *inrast_nirchan, *inrast_swirchan;
+	DCELL *outrast;
+	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
+	RASTER_MAP_TYPE data_type_nirchan;
+	RASTER_MAP_TYPE data_type_swirchan;
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("Water index, biophysical parameters");
+	module->description = _("Water indices from nir and swir for the time being");
+	/* Define the different options */
+	input1 = G_define_option() ;
+	input1->key        =_("winame");
+	input1->type       = TYPE_STRING;
+	input1->required   = YES;
+	input1->gisprompt  =_("Name of WI");
+	input1->description=_("Name of WI: lswi");
+	input1->answer     =_("lswi");
+	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input2->key	   = _("nir");
+	input2->description=_("Name of the NIR Channel surface reflectance map [0.0;1.0]");
+	input2->answer     =_("nirchan");
+	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input3->key        =_("swir");
+	input3->description=_("Name of the SWIR Channel surface reflectance map [0.0;1.0]");
+	input3->answer     =_("swirchan");
+	output= G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output->key        =_("wi");
+	output->description=_("Name of the output wi layer");
+	output->answer     =_("wi");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	viflag		= input1->answer;
+	nirchan	 	= input2->answer;
+	swirchan 	= input3->answer;
+	result  = output->answer;
+	mapset = G_find_cell2 (nirchan, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"),nirchan);
+	data_type_nirchan = G_raster_map_type(nirchan,mapset);
+	if ( (infd_nirchan = G_open_cell_old (nirchan,mapset)) < 0)
+		G_fatal_error(_("Cannot open cell file [%s]"), nirchan);
+	if (G_get_cellhd (nirchan, mapset, &cellhd) < 0)
+		G_fatal_error(_("Cannot read file header of [%s]"), nirchan);
+	inrast_nirchan = G_allocate_raster_buf(data_type_nirchan);
+	mapset = G_find_cell2(swirchan, "");
+		G_fatal_error(_("cell file [%s] not found"), swirchan);
+	data_type_swirchan = G_raster_map_type(swirchan,mapset);
+	if ( (infd_swirchan = G_open_cell_old (swirchan,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), swirchan);
+	if (G_get_cellhd (swirchan, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), swirchan);
+	inrast_swirchan = G_allocate_raster_buf(data_type_swirchan);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	outrast = G_allocate_raster_buf(data_type_output);
+	/* Create New raster files */
+	if ( (outfd = G_open_raster_new (result,data_type_output)) < 0)
+		G_fatal_error(_("Could not open <%s>"),result);
+	/* Process pixels */
+	for (row = 0; row < nrows; row++)
+		DCELL d;
+		DCELL d_nirchan;
+		DCELL d_swirchan;
+		G_percent(row,nrows,2);
+//		printf("row = %i/%i\n",row,nrows);
+		if(G_get_raster_row(infd_nirchan,inrast_nirchan,row,data_type_nirchan)<0)
+			G_fatal_error(_("Could not read from <%s>"),nirchan);
+		if(G_get_raster_row(infd_swirchan,inrast_swirchan,row,data_type_swirchan)<0)
+			G_fatal_error(_("Could not read from <%s>"),swirchan);
+		/*process the data */
+		for (col=0; col < ncols; col++)
+			switch(data_type_nirchan){
+				case CELL_TYPE:
+					d_nirchan = (double) ((CELL *) inrast_nirchan)[col];
+					break;
+				case FCELL_TYPE:
+					d_nirchan = (double) ((FCELL *) inrast_nirchan)[col];
+					break;
+				case DCELL_TYPE:
+					d_nirchan = ((DCELL *) inrast_nirchan)[col];
+					break;
+			switch(data_type_swirchan){
+				case CELL_TYPE:
+					d_swirchan = (double) ((CELL *) inrast_swirchan)[col];
+					break;
+				case FCELL_TYPE:
+					d_swirchan = (double) ((FCELL *) inrast_swirchan)[col];
+					break;
+				case DCELL_TYPE:
+					d_swirchan = ((DCELL *) inrast_swirchan)[col];
+					break;
+			//	printf("col=%i/%i ",col,ncols);
+		// to change to multiple to output files.
+			if(G_is_d_null_value(&d_nirchan)||
+			G_is_d_null_value(&d_swirchan)){
+				G_set_d_null_value(&outrast[col],1);
+			} else {
+				/*calculate lswi	            */
+				if (!strcoll(wiflag,"lswi")){
+					if(d_nirchan+d_swirchan<0.001){
+					} else {
+						d =  ls_wi(d_nirchan,d_swirchan );
+						((DCELL *) outrast)[col] = d;
+		if (G_put_raster_row (outfd, outrast, data_type_output) < 0)
+			G_fatal_error(_("Cannot write to output raster file"));
+	G_free(inrast_nirchan);
+	G_close_cell(infd_nirchan);
+	G_free(inrast_swirchan);
+	G_close_cell(infd_swirchan);
+	G_free(outrast);
+	G_close_cell(outfd);
+	/* Color from -1.0 to +1.0 in grey */
+	G_init_colors(&colors);
+	G_add_color_rule(-1.0,0,0,0,1.0,255,255,255,&colors);
+	G_short_history(result, "raster", &history);
+	G_command_history(&history);
+	G_write_history(result,&history);
+	exit(EXIT_SUCCESS);
