[GRASS-SVN] r32164 - grass/trunk/db/drivers/sqlite
Fri Jul 18 13:23:49 EDT 2008
Author: glynn
Date: 2008-07-18 13:23:49 -0400 (Fri, 18 Jul 2008)
New Revision: 32164
   grass/trunk/db/drivers/sqlite/create_table.c
   grass/trunk/db/drivers/sqlite/describe.c
   grass/trunk/db/drivers/sqlite/fetch.c
   grass/trunk/db/drivers/sqlite/proto.h
Use SQL types in preference to SQLite affinity types
Modified: grass/trunk/db/drivers/sqlite/create_table.c
--- grass/trunk/db/drivers/sqlite/create_table.c	2008-07-18 17:22:57 UTC (rev 32163)
+++ grass/trunk/db/drivers/sqlite/create_table.c	2008-07-18 17:23:49 UTC (rev 32164)
@@ -29,9 +29,6 @@
 db__driver_create_table (dbTable *table)
     int col, ncols;
-    dbColumn   *column;
-    const char *colname;
-    int sqltype;
     sqlite3_stmt *statement;
     dbString sql;
     const char *rest;
@@ -52,10 +49,12 @@
     ncols = db_get_table_number_of_columns(table);
     for ( col = 0; col < ncols; col++ ) {
-        column = db_get_table_column (table, col);
-	colname = db_get_column_name (column);
-	sqltype = db_get_column_sqltype (column);
+        dbColumn *column = db_get_table_column (table, col);
+	const char *colname = db_get_column_name (column);
+	int sqltype = db_get_column_sqltype (column);
+	int collen = db_get_column_length (column);
+	char buf[32];
 	G_debug ( 3, "%s (%s)", colname, db_sqltype_name(sqltype) );
 	if ( col > 0 ) db_append_string ( &sql, ", " );
@@ -63,25 +62,45 @@
 	db_append_string ( &sql, " " );
 	switch ( sqltype ) {
 	    case DB_SQL_TYPE_CHARACTER:
-	    case DB_SQL_TYPE_TEXT:
-		db_append_string ( &sql, "text");
+		sprintf(buf, "varchar(%d)", collen);
+		db_append_string ( &sql, buf);
                 break;
 	    case DB_SQL_TYPE_SMALLINT:
+		db_append_string ( &sql, "smallint");
+		break;
 	    case DB_SQL_TYPE_INTEGER:
 		db_append_string ( &sql, "integer");
 		break;
 	    case DB_SQL_TYPE_REAL:
+		db_append_string ( &sql, "real");
+		break;
 	    case DB_SQL_TYPE_DOUBLE_PRECISION:
+		db_append_string ( &sql, "double precision");
+		break;
 	    case DB_SQL_TYPE_DECIMAL:
+		db_append_string ( &sql, "decimal");
+		break;
 	    case DB_SQL_TYPE_NUMERIC:
-	    case DB_SQL_TYPE_INTERVAL:
-		db_append_string ( &sql, "real");
+		db_append_string ( &sql, "numeric");
 		break;
 	    case DB_SQL_TYPE_DATE:
+		db_append_string ( &sql, "date");
+		break;
 	    case DB_SQL_TYPE_TIME:
+		db_append_string ( &sql, "time");
+		break;
 	    case DB_SQL_TYPE_TIMESTAMP:
+		db_append_string ( &sql, "timestamp");
+		break;
+	    case DB_SQL_TYPE_INTERVAL:
+		db_append_string ( &sql, "interval");
+		break;
+	    case DB_SQL_TYPE_TEXT:
-		break;
+                break;
+	    case DB_SQL_TYPE_SERIAL:
+		db_append_string ( &sql, "serial");
+                break;
  	    default:
                 G_warning ( "Unknown column type (%s)", colname);
 		return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/describe.c
--- grass/trunk/db/drivers/sqlite/describe.c	2008-07-18 17:22:57 UTC (rev 32163)
+++ grass/trunk/db/drivers/sqlite/describe.c	2008-07-18 17:23:49 UTC (rev 32164)
@@ -20,8 +20,10 @@
 /* function prototypes */
 static int affinity_type (const char *);
+static int parse_type (const char *, int *);
+static void get_column_info ( sqlite3_stmt *statement, int col,
+			      int *litetype, int *sqltype, int *length );
  * \fn int db__driver_describe_table (dbString *table_name, dbTable **table)
@@ -105,9 +107,9 @@
     for (i = 0; i < ncols; i++)
-        int  litetype, sqltype;
+        int  litetype, sqltype, length;
-	get_column_info ( statement, i, &litetype, &sqltype );
+	get_column_info ( statement, i, &litetype, &sqltype, &length );
 	if ( sqltype == DB_SQL_TYPE_UNKNOWN ) continue;
@@ -150,7 +152,7 @@
 	fname = sqlite3_column_name ( statement, i );
+	get_column_info ( statement, i, &litetype, &sqltype, &fsize );
 	G_debug(2, "col: %s, nkcols %d, litetype : %d, sqltype %d",
 		    fname, nkcols, litetype, sqltype );
@@ -163,22 +165,38 @@
 	    continue;
-	switch ( litetype) {
-	case SQLITE_INTEGER:
+	switch (sqltype) {
+	case DB_SQL_TYPE_SMALLINT:
+	case DB_SQL_TYPE_INTEGER:
 	    fsize = 20;
 	    break;
-	case SQLITE_FLOAT:
+	case DB_SQL_TYPE_REAL:
+	case DB_SQL_TYPE_DOUBLE_PRECISION:
+	case DB_SQL_TYPE_DECIMAL:
+	case DB_SQL_TYPE_NUMERIC:
 	    fsize = 20;
 	    break;
-	case SQLITE_TEXT:
-	    fsize = 255;
+	case DB_SQL_TYPE_DATE:
+	case DB_SQL_TYPE_TIME:
+	case DB_SQL_TYPE_TIMESTAMP:
+	    fsize = 20;
 	    break;
+	case DB_SQL_TYPE_CHARACTER:
+	    /* fsize is already correct */
+	    break;
+	    /* fudge for clients which don't understand variable-size fields */
+	    fsize = 1000;
+	    break;
-	/* SQLITE_BLOB, SQLITE_NULL needed here? */
 	default:
+	    G_warning("SQLite driver: unknown type: %d", sqltype);
 	    fsize = 99999; /* sqlite doesn't care, it must be long enough to
                           satisfy tests in GRASS */
@@ -223,6 +241,17 @@
+static int dbmi_type ( int litetype )
+    switch (litetype) {
+    case SQLITE_INTEGER:	return DB_SQL_TYPE_INTEGER;
+    case SQLITE_FLOAT:		return DB_SQL_TYPE_DOUBLE_PRECISION;
+    case SQLITE_TEXT:		return DB_SQL_TYPE_TEXT;
+    case SQLITE_NULL:		return DB_SQL_TYPE_TEXT; /* good choice? */
+    default:			return DB_SQL_TYPE_UNKNOWN;
  * \fn void get_column_info (sqlite3_stmt *statement, int col, int *litetype, int *sqltype)
@@ -234,8 +263,8 @@
  * \param[in,out] sqltype
-void get_column_info ( sqlite3_stmt *statement, int col,
-		int *litetype, int *sqltype )
     const char *decltype;
@@ -243,6 +272,7 @@
     if ( decltype )
 	G_debug ( 4, "column: %s, decltype = %s", sqlite3_column_name ( statement, col), decltype );
+	*sqltype = parse_type ( decltype, length );
 	*litetype = affinity_type ( decltype );
     else
@@ -251,54 +281,12 @@
 	/* If there are no results it gives 0 */
 	*litetype = sqlite3_column_type ( statement, col );
+	*sqltype = dbmi_type ( *litetype );
+	*length = 0;
+    G_debug ( 3, "sqltype = %d", *sqltype );
     G_debug ( 3, "litetype = %d", *litetype );
-    /* http://www.sqlite.org/capi3ref.html#sqlite3_column_type
-           SQLITE_INTEGER  1
-           SQLITE_FLOAT    2
-           SQLITE_TEXT     3
-           SQLITE_BLOB     4
-           SQLITE_NULL     5
-       lib/db/dbmi_base/sqltype.c:
-           DB_SQL_TYPE_CHARACTER:        0 "CHARACTER"
-           DB_SQL_TYPE_NUMERIC:          1 "NUMERIC"
-           DB_SQL_TYPE_DECIMAL:          2 "DECIMAL"
-           DB_SQL_TYPE_SMALLINT:         3 "SMALLINT"
-           DB_SQL_TYPE_INTEGER:          4 "INTEGER"
-           DB_SQL_TYPE_REAL:             5 "REAL"
-           DB_SQL_TYPE_DOUBLE_PRECISION: 6 "DOUBLE PRECISION"
-           DB_SQL_TYPE_DATE:             7 "DATE"
-           DB_SQL_TYPE_TIME:             8 "TIME"
-           DB_SQL_TYPE_SERIAL:           9 "SERIAL"
-           DB_SQL_TYPE_TEXT:             10 "TEXT"
-           DB_SQL_TYPE_TIMESTAMP:        11 "TIMESTAMP"
-           DB_SQL_TYPE_INTERVAL:         12 "INTERVAL"
-           default                       13 "unknown"
-    switch ( *litetype) {
-	    *sqltype = DB_SQL_TYPE_INTEGER;
-	    break;
-	    *sqltype = DB_SQL_TYPE_DOUBLE_PRECISION;
-	    break;
-	case SQLITE_TEXT:
-	    *sqltype = DB_SQL_TYPE_TEXT;
-	    break;
-	case SQLITE_NULL:
-	    *sqltype = DB_SQL_TYPE_TEXT; /* good choice? */
-	    break;
-	default:
-	    *sqltype = DB_SQL_TYPE_UNKNOWN;
 /*  SQLite documentation:
@@ -325,7 +313,7 @@
     char *lc;
     int aff = SQLITE_FLOAT;
-    lc = strdup ( declared );
+    lc = G_store ( declared );
     G_tolcase ( lc );
     G_debug(4, "affinity_type: %s", lc);
@@ -342,7 +330,131 @@
         aff = SQLITE_BLOB;
+    G_free(lc);
     return aff;
+static int parse_type (const char *declared, int *length)
+    char buf[256];
+    char word[4][256];
+    strncpy(buf, declared, sizeof(buf));
+    buf[sizeof(buf)-1] = '\0';
+    G_chop(buf);
+    G_tolcase(buf);
+    *length = 1;
+#define streq(a,b) (strcmp((a),(b)) == 0)
+    if (streq(buf, "smallint") ||
+	streq(buf, "int2"))
+	return DB_SQL_TYPE_SMALLINT;
+    if (streq(buf, "integer") ||
+	streq(buf, "int") ||
+	streq(buf, "int4") ||
+	streq(buf, "bigint") ||
+	streq(buf, "int8"))
+	return DB_SQL_TYPE_INTEGER;
+    if (streq(buf, "real") ||
+	streq(buf, "float4"))
+	return DB_SQL_TYPE_REAL;
+    if (streq(buf, "double") ||
+	streq(buf, "float8"))
+	return DB_SQL_TYPE_DOUBLE_PRECISION;
+    if (streq(buf, "decimal"))
+	return DB_SQL_TYPE_DECIMAL;
+    if (streq(buf, "numeric"))
+	return DB_SQL_TYPE_NUMERIC;
+    if (streq(buf, "date"))
+	return DB_SQL_TYPE_DATE;
+    if (streq(buf, "time") ||
+	streq(buf, "timetz"))
+	return DB_SQL_TYPE_TIME;
+    if (streq(buf, "timestamp") ||
+	streq(buf, "timestamptz"))
+	return DB_SQL_TYPE_TIMESTAMP;
+    if (streq(buf, "interval"))
+	return DB_SQL_TYPE_INTERVAL;
+    if (streq(buf, "text"))
+	return DB_SQL_TYPE_TEXT;
+    if (streq(buf, "serial") ||
+	streq(buf, "serial4"))
+	return DB_SQL_TYPE_SERIAL;
+    if (streq(buf, "character")
+	|| streq(buf, "char")
+	|| streq(buf, "varchar"))
+	return DB_SQL_TYPE_CHARACTER;
+    if (sscanf(buf, "%s %s", word[0], word[1]) == 2)
+	if (streq(word[0], "double") && streq(word[1], "precision"))
+	if (streq(word[0], "character") && streq(word[1], "varying"))
+    if (sscanf(buf, "%s %s %s %s", word[0], word[1], word[2], word[3]) == 4 &&
+	(streq(word[1], "with") || streq(word[1], "without")) &&
+	streq(word[2], "time") &&
+	streq(word[3], "zone"))
+	if (streq(word[0], "time"))
+	if (streq(word[0], "timestamp"))
+    if (sscanf(buf, "varchar ( %d )", length) == 1 ||
+	sscanf(buf, "character varying ( %d )", length) == 1 ||
+	sscanf(buf, "character ( %d )", length) == 1 ||
+	sscanf(buf, "char ( %d )", length) == 1)
+    if (sscanf(buf, "interval ( %d )", length) == 1)
+    if (sscanf(buf, "numeric ( %d , %d )", length, length) == 2)
+    if (sscanf(buf, "decimal ( %d , %d )", length, length) == 2)
+    if (sscanf(buf, "time ( %d )", length) == 1 ||
+	sscanf(buf, "timetz ( %d )", length) == 1)
+    if (sscanf(buf, "timestamp ( %d )", length) == 1 ||
+	sscanf(buf, "timestamptz ( %d )", length) == 1)
+    if (sscanf(buf, "%s ( %d ) %s %s %s", word[0], length, word[1], word[2], word[3]) == 5 &&
+#undef streq
+    G_warning("SQLite driver: unable to parse decltype: %s", declared);
+    return DB_SQL_TYPE_UNKNOWN;
Modified: grass/trunk/db/drivers/sqlite/fetch.c
--- grass/trunk/db/drivers/sqlite/fetch.c	2008-07-18 17:22:57 UTC (rev 32163)
+++ grass/trunk/db/drivers/sqlite/fetch.c	2008-07-18 17:23:49 UTC (rev 32164)
@@ -106,6 +106,8 @@
 	int col, litetype, sqltype;
 	dbColumn   *column;
 	dbValue    *value;
+	const char *text;
+	dbDateTime *dt;
 	col = c->kcols[i]; /* known cols */
@@ -115,6 +117,7 @@
         litetype  = db_get_column_host_type(column);
 	litetype = sqlite3_column_type ( c->statement, col );
+	text = (const char *) sqlite3_column_text ( c->statement, col);
 	value  = db_get_column_value (column);
 	db_zero_string (&value->s);
@@ -128,8 +131,7 @@
 	G_debug (3, "col %d, litetype %d, sqltype %d: val = '%s'",
-		    col, litetype, sqltype,
-		    sqlite3_column_text ( c->statement, col) );
+		    col, litetype, sqltype, text );
            SQLITE_INTEGER  1
@@ -145,38 +147,88 @@
 	/* Note: we have set DATESTYLE TO ISO in db_driver_open_select_cursor() so datetime
 	 *       format should be ISO */
-	switch ( litetype ) {
-	    case SQLITE_TEXT:
-		if (sqltype == DB_SQL_TYPE_DATE ) { /* date string */
-		   /* Example: '1999-01-25' */
-		   G_debug(3, "sqlite fetched date: %s",sqlite3_column_text ( c->statement, col));
-		   ns = sscanf((char *) sqlite3_column_text ( c->statement, col), "%4d-%2d-%2d",
-                             &(value->t.year), &(value->t.month), &(value->t.day) );
-		   if ( ns != 3 ) {
-			append_error ( "Cannot scan date:");
-			append_error ((char *) sqlite3_column_text (c->statement, col));
-			report_error();
-			return DB_FAILED;
-                   value->t.hour = 0;
-                   value->t.minute = 0;
-                   value->t.seconds = 0.0;
-		} else { /* other string */
-		    db_set_string ( &(value->s), (char *) sqlite3_column_text ( c->statement, col));
-		break;
+	switch ( sqltype ) {
+	    value->i = sqlite3_column_int ( c->statement, col);
+	    break;
-	    	value->i = sqlite3_column_int ( c->statement, col);
-		break;
-	    	value->d = sqlite3_column_double ( c->statement, col);
-		break;
+	    value->d = sqlite3_column_double ( c->statement, col);
+	    break;
-	    case SQLITE_NULL:
-		/* do nothing  ? */
-		break;
+	    dt = &value->t;
+	    dt->hour = 0;
+	    dt->minute = 0;
+	    dt->seconds = 0.0;
+	    G_debug(3, "sqlite fetched date: %s", text);
+	    ns = sscanf(text, "%4d-%2d-%2d",
+			&dt->year, &dt->month, &dt->day);
+	    if ( ns != 3 ) {
+		append_error ( "Cannot scan date:");
+		append_error (text);
+		report_error();
+		return DB_FAILED;
+	    break;
+	    dt = &value->t;
+	    dt->year = 0;
+	    dt->month = 0;
+	    dt->day = 0;
+	    ns = sscanf(text, "%2d:%2d:%lf",
+			&dt->hour, &dt->minute, &dt->seconds);
+	    if ( ns != 3 ) {
+		append_error ( "Cannot scan time:");
+		report_error();
+		return DB_FAILED;
+	    break;
+	    dt = &value->t;
+	    G_debug(3, "sqlite fetched timestamp: %s", text);
+	    ns = sscanf(text, "%4d-%2d-%2d %2d:%2d:%lf",
+			&dt->year, &dt->month, &dt->day,
+	    if ( ns != 6 ) {
+		append_error ( "Cannot scan timestamp:");
+		report_error();
+		return DB_FAILED;
+	    break;
+	    dt = &value->t;
+	    dt->year = 0;
+	    dt->month = 0;
+	    dt->day = 0;
+	    dt->hour = 0;
+	    dt->minute = 0;
+	    G_debug(3, "sqlite fetched interval: %s", text);
+	    G_warning("SQLite driver: parsing of interval values not implemented; assuming seconds");
+	    ns = sscanf(text, "%lf", &dt->seconds);
+	    if ( ns != 1 ) {
+		append_error ( "Cannot scan interval:");
+		report_error();
+		return DB_FAILED;
+	    break;
+	    db_set_string ( &value->s, text);
+	    break;
Modified: grass/trunk/db/drivers/sqlite/proto.h
--- grass/trunk/db/drivers/sqlite/proto.h	2008-07-18 17:22:57 UTC (rev 32163)
+++ grass/trunk/db/drivers/sqlite/proto.h	2008-07-18 17:23:49 UTC (rev 32164)
@@ -14,6 +14,5 @@
 /* describe.c*/
 int describe_table ( sqlite3_stmt *, dbTable **, cursor * );
-void get_column_info ( sqlite3_stmt *, int, int *, int * );
 #endif /* __SQLITE_PROTO_H__ */
