[GRASS-SVN] r32179 - in grass/trunk/lib: . init python
    svn_grass at osgeo.org
    Sun Jul 20 06:42:22 EDT 2008
Author: glynn
Date: 2008-07-20 06:42:22 -0400 (Sun, 20 Jul 2008)
New Revision: 32179
Added:
   grass/trunk/lib/python/
   grass/trunk/lib/python/Makefile
   grass/trunk/lib/python/grass.py
   grass/trunk/lib/Makefile
   grass/trunk/lib/init/init.sh
Add Python library
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile	2008-07-20 06:32:41 UTC (rev 32178)
+++ grass/trunk/lib/Makefile	2008-07-20 10:42:22 UTC (rev 32179)
@@ -34,7 +34,8 @@
 	symbol \
 	init \
 	cdhc \
-	stats
+	stats \
+	python
 include $(MODULE_TOPDIR)/include/Make/Platform.make
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2008-07-20 06:32:41 UTC (rev 32178)
+++ grass/trunk/lib/init/init.sh	2008-07-20 10:42:22 UTC (rev 32179)
@@ -296,6 +296,13 @@
 fi
 export GRASS_PYTHON
+# Set PYTHONPATH to find GRASS Python modules
+if [ ! "PYTHONPATH" ] ; then
+  PYTHONPATH="$GISBASE/etc/python"
+else
+  PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
+fi
+export PYTHONPATH
 # try and find a web browser if one isn't already specified
 if [ ! "$GRASS_HTML_BROWSER" ] ; then
Added: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile	                        (rev 0)
+++ grass/trunk/lib/python/Makefile	2008-07-20 10:42:22 UTC (rev 32179)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Platform.make
+include $(MODULE_TOPDIR)/include/Make/Grass.make
+include $(MODULE_TOPDIR)/include/Make/Rules.make
+default: $(ETC)/python
+$(ETC)/python: *.py
+	if [ ! -d $@ ]; then $(MKDIR) $@; fi
+	for file in $^ ; do $(INSTALL_DATA) $$file $@ ; done
+clean:
Added: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	                        (rev 0)
+++ grass/trunk/lib/python/grass.py	2008-07-20 10:42:22 UTC (rev 32179)
@@ -0,0 +1,112 @@
+import os
+import os.path
+import sys
+import types
+import subprocess
+# GRASS-oriented interface to subprocess module
+_popen_args = ["bufsize", "executable", "stdin", "stdout", "stderr",
+	       "preexec_fn", "close_fds", "cwd", "env",
+	       "universal_newlines", "startupinfo", "creationflags"]
+def _make_val(val):
+    if isinstance(val, types.StringType):
+	return val
+    if isinstance(val, types.ListType):
+	return ",".join(map(_make_val, val))
+    if isinstance(val, types.TupleType):
+	return _make_val(list(val))
+    return str(val)
+def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
+    args = [prog]
+    if overwrite:
+	args.append("--o")
+    if quiet:
+	args.append("--q")
+    if verbose:
+	args.append("--v")
+    if flags:
+	args.append("-%s" % flags)
+    for opt, val in options.iteritems():
+	args.append("%s=%s" % (opt, _make_val(val)))
+    return args
+def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
+    options = {}
+    popts = {}
+    for opt, val in kwargs.iteritems():
+	if opt in _popen_args:
+	    popts[opt] = val
+	else:
+	    options[opt] = val
+    args = make_command(prog, flags, overwrite, quiet, verbose, **options)
+    return subprocess.Popen(args, **popts)
+def run_command(*args, **kwargs):
+    ps = start_command(*args, **kwargs)
+    return ps.wait()
+def read_command(*args, **kwargs):
+    kwargs['stdout'] = subprocess.PIPE
+    return ps.communicate()[0]
+# interface to g.message
+def message(msg, flag = None):
+    run_command("g.message", flags = flag, message = msg)
+def debug(msg):
+    message(msg, flag = 'd')
+def verbose(msg):
+    message(msg, flag = 'v')
+def info(msg):
+    message(msg, flag = 'i')
+def warning(msg):
+    message(msg, flag = 'w')
+def error(msg):
+    message(msg, flag = 'e')
+def fatal(msg):
+    error(msg)
+    sys.exit(1)
+# interface to g.parser
+def _parse_env():
+    options = {}
+    flags = {}
+    for var, val in os.environ.iteritems():
+	if var.startswith("GIS_OPT_"):
+	    opt = var.replace("GIS_OPT_", "", 1).lower()
+	    options[opt] = val;
+	if var.startswith("GIS_FLAG_"):
+	    flg = var.replace("GIS_FLAG_", "", 1).lower()
+	    flags[flg] = bool(int(val));
+    return (options, flags)
+def parser():
+    if not os.getenv("GISBASE"):
+        print >> sys.stderr, "You must be in GRASS GIS to run this program."
+        sys.exit(1)
+    if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
+	return _parse_env()
+    argv = sys.argv[:]
+    name = argv[0]
+    if not os.path.isabs(name):
+	if os.sep in name or (os.altsep and os.altsep in name):
+	    argv[0] = os.path.abspath(name)
+	else:
+	    argv[0] = os.path.join(sys.path[0], name)
+    os.execvp("g.parser", [name] + argv)
+    raise OSError("error executing g.parser")
