[GRASS-SVN] r32206 - in grass/trunk: gui/wxpython/gui_modules gui/wxpython/nviz include lib/nviz visualization/nviz2/cmd
Tue Jul 22 06:40:27 EDT 2008
Author: martinl
Date: 2008-07-22 06:40:15 -0400 (Tue, 22 Jul 2008)
New Revision: 32206
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/nviz/init.cpp
   grass/trunk/include/nviz.h
   grass/trunk/lib/nviz/draw.c
   grass/trunk/lib/nviz/map_obj.c
   grass/trunk/lib/nviz/nvizlib.dox
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/vector.c
nviz2: support for 2d vector points added (drawing points)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-22 10:40:15 UTC (rev 32206)
@@ -106,8 +106,7 @@
         if Debug.get_level() == 0:
             # don't redirect when debugging is enabled
             # sys.stderr = self.cmd_stderr
-            pass
             return True
         return False
Modified: grass/trunk/gui/wxpython/nviz/init.cpp
--- grass/trunk/gui/wxpython/nviz/init.cpp	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/gui/wxpython/nviz/init.cpp	2008-07-22 10:40:15 UTC (rev 32206)
@@ -75,7 +75,7 @@
     Nviz_init_data(data);
     /* define default attributes for map objects */
-    Nviz_set_attr_default();
+    Nviz_set_surface_attr_default();
     /* set background color */
     Nviz_set_bgcolor(data, Nviz_color_from_str("white")); /* TODO */
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/include/nviz.h	2008-07-22 10:40:15 UTC (rev 32206)
@@ -148,6 +148,8 @@
 /* draw.c */
 int Nviz_draw_all_surf(nv_data *);
 int Nviz_draw_all_vect(nv_data *);
+int Nviz_draw_all_site(nv_data *);
+int Nviz_draw_all_vol(nv_data *);
 int Nviz_draw_all(nv_data *);
 int Nviz_draw_quick(nv_data *);
@@ -172,6 +174,7 @@
 int Nviz_set_attr(int, int, int, int, const char *, float,
 		  nv_data *);
 void Nviz_set_surface_attr_default();
+int Nviz_set_vpoint_attr_default();
 int Nviz_unset_attr(int, int, int);
 /* nviz.c */
Modified: grass/trunk/lib/nviz/draw.c
--- grass/trunk/lib/nviz/draw.c	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/lib/nviz/draw.c	2008-07-22 10:40:15 UTC (rev 32206)
@@ -113,7 +113,7 @@
-  \brief Draw all loaded vector sets
+  \brief Draw all loaded vector sets (lines)
   \param dc nviz data
@@ -140,6 +140,51 @@
+  \brief Draw all loaded vector point sets
+  \param dc nviz data
+  \return 1
+int Nviz_draw_all_site(nv_data *dc)
+    int i;
+    int *site_list, nsites;
+    site_list = GP_get_site_list(&nsites);
+    /* in case transparency is set */
+    GS_set_draw(GSD_BOTH);
+    GS_ready_draw();
+    for (i = 0; i < nsites; i++) {
+	GP_draw_site(site_list[i]);
+    G_free (site_list);
+    GS_done_draw();
+    GS_set_draw(GSD_BACK);
+    return 1;
+  \brief Draw all loaded volume sets
+  \todo To be implement
+  \return 1
+int Nviz_draw_all_vol(nv_data *dc)
+    return 1;
   \brief Draw all map objects (in full resolution) and decorations
   \param data nviz data
@@ -149,12 +194,10 @@
     int draw_surf, draw_vect, draw_site, draw_vol;
     int draw_north_arrow, arrow_x, draw_label, draw_legend;
     int draw_fringe, draw_scalebar, draw_bar_x;
-    // const char* draw_is_drawing = Tcl_GetVar(interp, "is_drawing", TCL_GLOBAL_ONLY);
-    // const char* EMPTYSTRING = "";
     draw_surf = 1;
     draw_vect = 1;
-    draw_site = 0;
+    draw_site = 1;
     draw_vol = 0;
     draw_north_arrow = 0;
     arrow_x = 0;
@@ -164,147 +207,27 @@
     draw_scalebar = 0;
     draw_bar_x = 0;
-    if (buf_is_drawing && atoi(buf_is_drawing))
-	return (TCL_OK);
-    // Tcl_SetVar(interp, "is_drawing", "1", TCL_GLOBAL_ONLY);
     GS_set_draw(GSD_BACK); /* needs to be BACK to avoid flickering */
     GS_ready_draw();
     GS_clear(data->bgcolor);
-    buf_surf     = Tcl_GetVar(interp, "surface", TCL_GLOBAL_ONLY);
-    buf_vect     = Tcl_GetVar(interp, "vector", TCL_GLOBAL_ONLY);
-    buf_site     = Tcl_GetVar(interp, "sites", TCL_GLOBAL_ONLY);
-    buf_vol      = Tcl_GetVar(interp, "volume", TCL_GLOBAL_ONLY);
-    buf_north_arrow = Tcl_GetVar(interp, "n_arrow", TCL_GLOBAL_ONLY);
-    arrow_x      = Tcl_GetVar(interp, "n_arrow_x", TCL_GLOBAL_ONLY);
-    buf_label    = Tcl_GetVar(interp, "labels", TCL_GLOBAL_ONLY);
-    buf_legend   = Tcl_GetVar(interp, "legend", TCL_GLOBAL_ONLY);
-    buf_fringe   = Tcl_GetVar(interp, "fringe", TCL_GLOBAL_ONLY);
-    buf_scalebar = Tcl_GetVar(interp, "scalebar", TCL_GLOBAL_ONLY);
-    bar_x        = Tcl_GetVar(interp, "scalebar_x", TCL_GLOBAL_ONLY);
     if (draw_surf)
 	Nviz_draw_all_surf(data);
     if (draw_vect)
-	Nviz_draw_all_vect (data);
+	Nviz_draw_all_vect(data);
     if (draw_site)
-	site_draw_all_together(data, interp);
+	Nviz_draw_all_site(data);
     if (draw_vol)
-	vol_draw_all_cmd(data, interp, argc, argv);
+	Nviz_draw_all_vol(data);
     GS_done_draw();
-    if (!draw_north_arrow)
-	draw_north_arrow = EMPTYSTRING;
-    if (!arrow_x)
-	arrow_x = EMPTYSTRING;
-    if (!draw_scalebar)
-	draw_scalebar = EMPTYSTRING;
-    if (!draw_bar_x)
-	bar_x = EMPTYSTRING;
-    if (!draw_fringe)
-	draw_fringe = EMPTYSTRING;
-    if (!draw_label)
-	draw_label = EMPTYSTRING;
-    if (!draw_legend)
-	draw_legend = EMPTYSTRING;
-    /* Draw decorations */
-    /* North Arrow
-    if (atoi(draw_north_arrow) == 1 && atoi(arrow_x) != 999 ) {
-	const char *arrow_y, *arrow_z, *arrow_len;
-	float coords[3], len;
-	int arrow_clr, text_clr;
-	arrow_y = Tcl_GetVar(interp, "n_arrow_y", TCL_GLOBAL_ONLY);
-	arrow_z = Tcl_GetVar(interp, "n_arrow_z", TCL_GLOBAL_ONLY);
-	arrow_len = Tcl_GetVar(interp, "n_arrow_size", TCL_GLOBAL_ONLY);
-	arrow_clr = (int) tcl_color_to_int(Tcl_GetVar(interp, "arw_clr", TCL_GLOBAL_ONLY));
-	text_clr = (int) tcl_color_to_int(Tcl_GetVar(interp, "arw_text_clr", TCL_GLOBAL_ONLY));
-	coords[0] = atoi(arrow_x);
-	coords[1] = atoi(arrow_y);
-	coords[2] = atoi(arrow_z);
-	len = atof(arrow_len);
-	FontBase = load_font(TOGL_BITMAP_HELVETICA_18);
-	gsd_north_arrow(coords, len, FontBase, arrow_clr, text_clr);
-    /* Scale Bar
-    if (atoi(draw_scalebar) == 1 && atoi(bar_x) != 999 ) {
-	const char *bar_y, *bar_z, *bar_len;
-	int bar_clr, text_clr;
-	bar_y = Tcl_GetVar(interp, "scalebar_y", TCL_GLOBAL_ONLY);
-	bar_z = Tcl_GetVar(interp, "scalebar_z", TCL_GLOBAL_ONLY);
-	bar_len = Tcl_GetVar(interp, "scalebar_size", TCL_GLOBAL_ONLY);
-	bar_clr = (int) tcl_color_to_int(Tcl_GetVar(interp, "bar_clr", TCL_GLOBAL_ONLY));
-	text_clr = (int) tcl_color_to_int(Tcl_GetVar(interp, "bar_text_clr", TCL_GLOBAL_ONLY));
-	coords[0] = atoi(bar_x);
-	coords[1] = atoi(bar_y);
-	coords[2] = atoi(bar_z);
-	len = atof(bar_len);
-	gsd_scalebar(coords, len, FontBase, bar_clr, bar_clr);
-    /* fringe
-    if (atoi(draw_fringe) == 1) {
-	const char *fringe_ne, *fringe_nw, *fringe_se, *fringe_sw;
-	const char *surf_id;
-	int flags[4], id;
-	int fringe_clr;
-	float fringe_elev;
-	fringe_clr = (int) tcl_color_to_int(Tcl_GetVar(interp, "fringe_color", TCL_GLOBAL_ONLY));
-	fringe_elev = (float) atof(Tcl_GetVar(interp, "fringe_elev", TCL_GLOBAL_ONLY));
-	fringe_ne = Tcl_GetVar(interp, "fringe_ne", TCL_GLOBAL_ONLY);
-	fringe_nw = Tcl_GetVar(interp, "fringe_nw", TCL_GLOBAL_ONLY);
-	fringe_se = Tcl_GetVar(interp, "fringe_se", TCL_GLOBAL_ONLY);
-	fringe_sw = Tcl_GetVar(interp, "fringe_sw", TCL_GLOBAL_ONLY);
-	flags[0] = atoi(fringe_nw);
-	flags[1] = atoi(fringe_ne);
-	flags[2] = atoi(fringe_sw);
-	flags[3] = atoi(fringe_se);
-	surf_id = Tcl_GetVar2(interp, "Nv_", "CurrSurf", TCL_GLOBAL_ONLY);
-	id = atoi(surf_id);
-	GS_draw_fringe(id, fringe_clr, fringe_elev, flags);
-    /* Legend and/or labels
-    if (atoi(draw_label) == 1 || atoi(draw_legend) == 1)
-	GS_draw_all_list();
-    // Tcl_SetVar(interp, "is_drawing", "0", TCL_GLOBAL_ONLY);
-    // flythrough_postdraw_cb();
     return 1;
Modified: grass/trunk/lib/nviz/map_obj.c
--- grass/trunk/lib/nviz/map_obj.c	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/lib/nviz/map_obj.c	2008-07-22 10:40:15 UTC (rev 32206)
@@ -118,7 +118,6 @@
     /* vector points overlay */
     else if (type == MAP_OBJ_SITE) {
-	geosite * gp;
 	if (GP_num_sites() >= MAX_SITES) {
 	    G_warning (_("Maximum vector point maps loaded!"));
 	    return -1;
@@ -127,13 +126,8 @@
 	new_id = GP_new_site();
 	/* initizalize site attributes */
-	/* TODO: move to ogsflib */
-	gp = gp_get_site(new_id);
+	Nviz_set_vpoint_attr_default(new_id);
-	for (i = 0; i < GPT_MAX_ATTR; i++)
-	    gp->use_attr[i] = ST_ATT_NONE;
 	/* load vector points */
 	if (0 > GP_load_site(new_id, name)) {
 	    GP_delete_site(new_id);
@@ -308,6 +302,30 @@
+  \brief Set default vector point attributes
+  \param id vector point set id
+  \return 1 on success
+  \return 0 on failure
+int Nviz_set_vpoint_attr_default(int id)
+    int i;
+    geosite * gp;
+    gp = gp_get_site(id);
+    if (!gp)
+	return 0;
+    for (i = 0; i < GPT_MAX_ATTR; i++)
+	gp->use_attr[i] = ST_ATT_NONE;
+    return 1;
   Unset map object attribute
   \param id map object id
Modified: grass/trunk/lib/nviz/nvizlib.dox
--- grass/trunk/lib/nviz/nvizlib.dox	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/lib/nviz/nvizlib.dox	2008-07-22 10:40:15 UTC (rev 32206)
@@ -59,7 +59,7 @@
  - Nviz_set_attr()
- - Nviz_set_attr_default()
+ - Nviz_set_surface_attr_default()
  - Nviz_unset_attr()
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2008-07-22 10:40:15 UTC (rev 32206)
@@ -365,6 +365,18 @@
     params->vpoint_size->options = "1-1000";
     params->vpoint_size->answer = "100";
+    /* point width */
+    params->vpoint_width = G_define_option();
+    params->vpoint_width->key = "vpoint_width";
+    params->vpoint_width->key_desc = "value";
+    params->vpoint_width->type = TYPE_INTEGER;
+    params->vpoint_width->required = NO;
+    params->vpoint_width->multiple = YES;
+    params->vpoint_width->description = _("Icon width");
+    params->vpoint_width->guisection = _("Vector points");
+    params->vpoint_width->options = "1-1000";
+    params->vpoint_width->answer = "2";
     /* point color */
     params->vpoint_color = G_define_standard_option(G_OPT_C_FG);
     params->vpoint_color->multiple = YES;
@@ -375,16 +387,16 @@
     params->vpoint_color->guisection = _("Vector points");
     /* point mode */
-    params->vpoint_symbol = G_define_option();
-    params->vpoint_symbol->key = "vpoint_symbol";
-    params->vpoint_symbol->key_desc = "string";
-    params->vpoint_symbol->type = TYPE_STRING;
-    params->vpoint_symbol->required = YES;
-    params->vpoint_symbol->multiple = YES;
-    params->vpoint_symbol->description = _("Icon symbol");
-    params->vpoint_symbol->options = "x,sphere,diamond,cube,box,gyro,aster,histogram";
-    params->vpoint_symbol->answer = "sphere";
-    params->vpoint_symbol->guisection = _("Vector points");
+    params->vpoint_marker = G_define_option();
+    params->vpoint_marker->key = "vpoint_marker";
+    params->vpoint_marker->key_desc = "string";
+    params->vpoint_marker->type = TYPE_STRING;
+    params->vpoint_marker->required = YES;
+    params->vpoint_marker->multiple = YES;
+    params->vpoint_marker->description = _("Icon marker");
+    params->vpoint_marker->options = "x,sphere,diamond,cube,box,gyro,aster,histogram";
+    params->vpoint_marker->answer = "sphere";
+    params->vpoint_marker->guisection = _("Vector points");
     return;
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2008-07-22 10:40:15 UTC (rev 32206)
@@ -15,7 +15,7 @@
   /* vector lines */
     *vlines, *vline_width, *vline_color, *vline_mode, *vline_height,
   /* vector points */
-    *vpoints, *vpoint_size, *vpoint_symbol, *vpoint_color,
+    *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width,
   /* misc */
     *exag, *bgcolor,
   /* viewpoint */
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2008-07-22 09:59:39 UTC (rev 32205)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2008-07-22 10:40:15 UTC (rev 32206)
@@ -135,5 +135,42 @@
 int vpoints_set_attrb(const struct GParams *params)
+    int i;
+    int marker, color, width;
+    float size;
+    char *marker_str;
+    for(i = 0; i < nsites; i++) {
+	color =  Nviz_color_from_str(params->vpoint_color->answers[i]);
+	size = atof(params->vpoint_size->answers[i]);
+	width = atoi(params->vpoint_width->answers[i]);
+	marker_str = params->vpoint_marker->answers[i];
+	if (strcmp(marker_str, "x") == 0)
+	    marker = ST_X;
+	else if (strcmp(marker_str, "sphere") == 0)
+	    marker = ST_SPHERE;
+	else if (strcmp(marker_str, "diamond") == 0)
+	    marker = ST_DIAMOND;
+	else if (strcmp(marker_str, "cube") == 0)
+	    marker = ST_CUBE;
+	else if (strcmp(marker_str, "box") == 0)
+	    marker = ST_BOX;
+	else if (strcmp(marker_str, "gyro") == 0)
+	    marker = ST_GYRO;
+	else if (strcmp(marker_str, "aster") == 0)
+	    marker = ST_ASTER;
+	else if (strcmp(marker_str, "histogram") == 0)
+	    marker = ST_HISTOGRAM;
+	else
+	    G_fatal_error(_("Unknow icon marker"));
+	GP_set_sitemode(site_list[i], ST_ATT_NONE,
+			color, width, size, marker);
     return 1;
