[GRASS-SVN] r32228 - grass-addons/vector/v.parallel2
Wed Jul 23 11:15:36 EDT 2008
Author: rmatev
Date: 2008-07-23 11:15:36 -0400 (Wed, 23 Jul 2008)
New Revision: 32228
Added:
   grass-addons/vector/v.parallel2/dgraph.c
   grass-addons/vector/v.parallel2/dgraph.h
   grass-addons/vector/v.parallel2/main.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
Implemented contour extraction algorithm
Added: grass-addons/vector/v.parallel2/dgraph.c
--- grass-addons/vector/v.parallel2/dgraph.c	                        (rev 0)
+++ grass-addons/vector/v.parallel2/dgraph.c	2008-07-23 15:15:36 UTC (rev 32228)
@@ -0,0 +1,691 @@
+#include <stdlib.h>
+#include <math.h>
+#include <grass/Vect.h>
+#include <grass/gis.h>
+#include "dgraph.h"
+#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
+#define FZERO(X, TOL) (fabs(X)<TOL)
+#define FEQUAL(X, Y, TOL) (fabs(X-Y)<TOL)
+#ifndef MIN
+    #define MIN(X,Y) ((X<Y)?X:Y)
+#endif
+#ifndef MAX
+    #define MAX(X,Y) ((X>Y)?X:Y)
+#endif
+#define PI M_PI
+/* tollerance aware version */
+/* TODO: fix all =='s left */
+int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2, double tol)
+    double adx, ady, bdx, bdy;
+    double aa, bb;
+    double tola, tolb;
+    double d, d1, d2, ra, rb, t;
+    int    switched = 0;
+    /* TODO: Works for points ? */
+    G_debug(4, "segment_intersection_2d()");
+    G_debug(4, "    ax1  = %.18f, ay1  = %.18f", ax1, ay1);
+    G_debug(4, "    ax2  = %.18f, ay2  = %.18f", ax2, ay2);
+    G_debug(4, "    bx1  = %.18f, by1  = %.18f", bx1, by1);
+    G_debug(4, "    bx2  = %.18f, by2  = %.18f", bx2, by2);
+    /* Check identical lines */
+    if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) && FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
+        (FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) && FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
+        G_debug (2, " -> identical segments" );
+        *x1 = ax1; *y1 = ay1;
+        *x2 = ax2; *y2 = ay2;
+        return 5;
+    /*  'Sort' lines by x1, x2, y1, y2 */
+    if ( bx1 < ax1 )
+        switched = 1;
+    else if ( bx1 == ax1 ) {
+        if ( bx2 < ax2 ) switched = 1;
+        else if ( bx2 == ax2 ) {
+            if ( by1 < ay1 ) switched = 1;
+            else if ( by1 == ay1 ) {
+                if ( by2 < ay2 ) switched = 1; /* by2 != ay2 (would be identical */
+    if (switched) {
+        t = ax1; ax1 = bx1; bx1 = t; t = ay1; ay1 = by1; by1 = t;
+        t = ax2; ax2 = bx2; bx2 = t; t = ay2; ay2 = by2; by2 = t;
+    adx = ax2 - ax1;
+    ady = ay2 - ay1;
+    bdx = bx2 - bx1;
+    bdy = by2 - by1;
+    d  = (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2);
+    d1 = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
+    d2 = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
+    G_debug(2, "    d  = %.18f", d);
+    G_debug(2, "    d1 = %.18f", d1);
+    G_debug(2, "    d2 = %.18f", d2);
+    tola = tol/MAX(fabs(adx), fabs(ady));
+    tolb = tol/MAX(fabs(bdx), fabs(bdy));
+    G_debug(2, "    tol  = %.18f", tol);
+    G_debug(2, "    tola = %.18f", tola);
+    G_debug(2, "    tolb = %.18f", tolb);
+    if (!FZERO(d, tol)) {
+        ra = d1/d;
+        rb = d2/d;
+        G_debug(2, "    not parallel/collinear: ra = %.18f", ra);
+        G_debug(2, "                            rb = %.18f", rb);
+        if ((ra <= -tola) || (ra >= 1+tola) || (rb <= -tolb) || (rb >= 1+tolb)) {
+            G_debug(2, "        no intersection");
+            return 0;
+        ra = MIN(MAX(ra, 0), 1);
+        *x1 = ax1 + ra*(ax2 - ax1);
+        *y1 = ay1 + ra*(ay2 - ay1);
+        G_debug(2, "        intersection %.18f, %.18f", *x1, *y1);
+        return 1;
+    /* segments are parallel or collinear */
+    G_debug (3, " -> parallel/collinear" );
+    if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) { /* lines are parallel */
+        G_debug (2, "  -> parallel" );
+        return 0;
+    /* segments are colinear. check for overlap */
+/*    aa = adx*adx + ady*ady;
+    bb = bdx*bdx + bdy*bdy;
+    t = (ax1-bx1)*bdx + (ay1-by1)*bdy;*/
+    /* Collinear vertical */
+    /* original code assumed lines were not both vertical
+    *  so there is a special case if they are */
+    if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) && FEQUAL(ax1, bx1, tol)) {
+        G_debug(2, "  -> collinear vertical");
+        if (ay1 > ay2) { t=ay1; ay1=ay2; ay2=t;	} /* to be sure that ay1 < ay2 */
+        if (by1 > by2) { t=by1; by1=by2; by2=t; } /* to be sure that by1 < by2 */
+        if (ay1 > by2 || ay2 < by1) {
+            G_debug (2, "   -> no intersection");
+            return 0;
+        /* end points */
+        if (FEQUAL(ay1, by2, tol)) {
+            G_debug(2, "   -> connected by end points");
+            return 1; /* endpoints only */
+        if (FEQUAL(ay2, by1, tol)) {
+            *x1 = ax2; *y1 = ay2;
+            G_debug (2, "  -> connected by end points");
+        /* general overlap */
+        G_debug(3, "   -> vertical overlap");
+        /* a contains b */
+        if (ay1 <= by1 && ay2 >= by2) {
+            G_debug (2, "    -> a contains b" );
+           *x1 = bx1; *y1 = by1;
+            *x2 = bx2; *y2 = by2;
+            if (!switched)
+                return 3;
+            else
+                return 4;
+        /* b contains a */
+        if ( ay1 >= by1 && ay2 <= by2 ) {
+            G_debug (2, "    -> b contains a" );
+            if ( !switched )
+                return 4;
+            else
+                return 3;
+        /* general overlap, 2 intersection points */
+        G_debug (2, "    -> partial overlap" );
+        if ( by1 > ay1 && by1 < ay2 ) { /* b1 in a */
+            if ( !switched ) {
+            } else {
+                *x2 = bx1; *y2 = by1;
+            return 2;
+        if ( by2 > ay1 && by2 < ay2 ) { /* b2 in a */
+                *x1 = bx2; *y1 = by2;
+                *x2 = ax1; *y2 = ay1;
+            } else {
+            return 2;
+        /* should not be reached */
+        G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
+        G_warning("%.15g %.15g", ax1, ay1);
+        G_warning("%.15g %.15g", ax2, ay2);
+        G_warning("x");
+        G_warning("%.15g %.15g", bx1, by1);
+        G_warning("%.15g %.15g", bx2, by2);
+        return 0;
+    G_debug (2, "   -> collinear non vertical" );
+    /* Collinear non vertical */
+    if ( ( bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2 ) ||
+         ( bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2 ) ) {
+        G_debug (2, "   -> no intersection" );
+	return 0;
+    /* there is overlap or connected end points */
+    G_debug (2, "   -> overlap/connected end points" );
+    /* end points */
+    if ( (ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2) ) {
+	return 1;
+    if ( (ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2) ) {
+	return 1;
+    if (ax1 > ax2) { t=ax1; ax1=ax2; ax2=t; t=ay1; ay1=ay2; ay2=t; } /* to be sure that ax1 < ax2 */
+    if (bx1 > bx2) { t=bx1; bx1=bx2; bx2=t; t=by1; by1=by2; by2=t; } /* to be sure that bx1 < bx2 */
+    if ( ax1 <= bx1 && ax2 >= bx2 ) {
+        if ( !switched )
+       	    return 3;
+        else
+            return 4;
+    if ( ax1 >= bx1 && ax2 <= bx2 ) {
+        if ( !switched )
+            return 4;
+        else
+            return 3;
+    /* general overlap, 2 intersection points (lines are not vertical) */
+    if ( bx1 > ax1 && bx1 < ax2 ) { /* b1 is in a */
+	} else {
+	return 2;
+    if ( bx2 > ax1 && bx2 < ax2 ) { /* b2 is in a */
+	} else {
+	return 2;
+    G_warning(("Vect_segment_intersection() ERROR (collinear non vertical segments)"));
+    G_warning("x");
+    return 0;
+struct intersection_point {
+    double x;
+    double y;
+    int group; /* IPs with very similar dist will be in the same group */
+struct seg_intersection {
+    int with; /* second segment */
+    int ip; /* index of the IP */
+    double dist; /* distance from first point of first segment to intersection point (IP) */
+struct seg_intersection_list {
+    int count;
+    int allocated;
+    struct seg_intersection *a;
+struct seg_intersections {
+    int ipcount;
+    int ipallocated;
+    struct intersection_point *ip;
+    int ilcount;
+    struct seg_intersection_list *il;
+    int group_count;
+struct seg_intersections* create_si_struct(int segments_count) {
+    struct seg_intersections *si;
+    int i;
+    si = G_malloc(sizeof(struct seg_intersections));
+    si->ipcount = 0;
+    si->ipallocated = segments_count + 16;
+    si->ip = G_malloc((si->ipallocated)*sizeof(struct intersection_point));
+    si->ilcount = segments_count;
+    si->il = G_malloc(segments_count*sizeof(struct seg_intersection_list));
+    for (i = 0; i < segments_count; i++) {
+        si->il[i].count = 0;
+        si->il[i].allocated = 0;
+        si->il[i].a = NULL;
+    return si;
+void destroy_si_struct(struct seg_intersections *si) {
+    int i;
+    for (i = 0; i < si->ilcount; i++)
+        G_free(si->il[i].a);
+    G_free(si->il);
+    G_free(si->ip);
+    G_free(si);
+    return;
+/* internal use */
+void add_ipoint1(struct seg_intersection_list *il, int with, double dist, int ip) {
+    struct seg_intersection *s;
+    if (il->count == il->allocated) {
+        il->allocated += 4;
+        il->a = G_realloc(il->a, (il->allocated)*sizeof(struct seg_intersection));
+    s = &(il->a[il->count]);
+    s->with = with;
+    s->ip = ip;
+    s->dist = dist;
+    il->count++;
+    return;
+/* adds intersection point to the structure */
+void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg, double x, double y, struct seg_intersections *si) {
+    struct intersection_point *t;
+    int ip;
+    G_debug(4, "add_ipoint()");
+    if (si->ipcount == si->ipallocated) {
+        si->ipallocated += 16;
+        si->ip = G_realloc(si->ip, (si->ipallocated)*sizeof(struct intersection_point));
+    ip = si->ipcount;
+    t = &(si->ip[ip]);
+    t->x = x;
+    t->y = y;
+    t->group = -1;
+    si->ipcount++;
+    add_ipoint1(&(si->il[first_seg]), second_seg, LENGTH((Points->x[first_seg] - x), (Points->y[first_seg] - y)), ip);
+    if (second_seg >= 0)
+        add_ipoint1(&(si->il[second_seg]), first_seg, LENGTH((Points->x[second_seg] - x), (Points->y[second_seg] - y)), ip);
+void sort_intersection_list(struct seg_intersection_list *il) {
+    int n, i, j, min;
+    struct seg_intersection t;
+    G_debug(4, "sort_intersection_list()");
+    n = il->count;
+    G_debug(4, "    n=%d", n);
+    for (i = 0; i < n-1; i++) {
+        min = i;
+        for (j = i+1; j < n; j++) {
+            if (il->a[j].dist < il->a[min].dist) {
+                min = j;
+        if (min != i) {
+            t = il->a[i];
+            il->a[i] = il->a[min];
+            il->a[min] = t;
+    return;
+static int compare(const void *a, const void *b)
+    struct intersection_point *aa, *bb;
+    aa = *((struct intersection_point **)a);
+    bb = *((struct intersection_point **)b);
+    if (aa->x < bb->x)
+        return -1;
+    else if (aa->x > bb->x)
+        return 1;
+    else
+        return (aa->y < bb->y)?-1:((aa->y > bb->y)?1:0);
+/* currently O(n*n); future implementation O(nlogn) */
+struct seg_intersections* find_all_intersections(struct line_pnts *Points) {
+    int i, j, np;
+    int group, t;
+    int looped;
+    double EPSILON = 1e-10;
+    double *x, *y;
+    double x1, y1, x2, y2;
+    int res;
+    struct intersection_point **sorted;
+    G_debug(4, "find_all_intersections()");
+    G_debug(4, "    EPSILON=%.18f", EPSILON);
+    np = Points->n_points;
+    x = Points->x;
+    y = Points->y;
+    si = create_si_struct(np-1);
+    looped = FEQUAL(x[0], x[np-1], EPSILON) && FEQUAL(y[0], y[np-1], EPSILON);
+    G_debug(4, "    looped=%d", looped);
+    G_debug(4, "    finding intersections...");
+    for (i = 0; i < np-1; i++) {
+        for (j = i+1; j < np-1; j++) {
+            G_debug(3, "        checking %d-%d %d-%d", i, i+1, j, j+1);
+            res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2, EPSILON);
+            G_debug(3, "        intersection type = %d", res);
+            if (res == 1) {
+                add_ipoint(Points, i, j, x1, y1, si);
+            } else if ((res >= 2) && (res <= 5)) {
+                add_ipoint(Points, i, j, x2, y2, si);
+    if (!looped) {
+        /* these are not really intersection points */
+        add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
+        add_ipoint(Points, np-2, -1, Points->x[np-1], Points->y[np-1], si);
+    G_debug(4, "    finding intersections...done");
+    G_debug(4, "    postprocessing...");
+    if (si->ipallocated > si->ipcount) {
+        si->ipallocated = si->ipcount;
+        si->ip = G_realloc(si->ip, (si->ipcount)*sizeof(struct intersection_point));
+    for (i = 0; i < si->ilcount; i++) {
+        il = &(si->il[i]);
+        if (il->allocated > il->count) {
+            il->allocated = il->count;
+            il->a = G_realloc(il->a, (il->count)*sizeof(struct seg_intersection));
+        if (il->count > 0) {
+            sort_intersection_list(il);
+            /* is it ok to use qsort here ? */
+    /* si->ip will not be reallocated any more so we can use pointers */
+    sorted = G_malloc((si->ipcount)*sizeof(struct intersection_point *));
+    for (i = 0; i < si->ipcount; i++)
+        sorted[i] = &(si->ip[i]);
+    qsort(sorted, si->ipcount, sizeof(struct intersection_point *), compare);
+    /* assign groups */
+    group = 0; /* next available group number */
+    for (i = 0; i < si->ipcount; i++) {
+        t = group;
+        for (j = i-1; j >= 0; j--) {
+            if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
+                break;
+            if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
+                t = sorted[j]->group;
+                break;
+        G_debug(4, "        group=%d, ip=%d", t, (int)(sorted[i] - &(si->ip[0])));
+        sorted[i]->group = t;
+        if (t == group)
+            group++;
+    si->group_count = group;
+    G_debug(4, "    postprocessing...done");
+    /* output contents of si */
+        G_debug(4, "%d-%d :", i, i+1);
+        for (j = 0; j < si->il[i].count; j++) {
+            G_debug(4, "     %d-%d, group=%d", si->il[i].a[j].with, si->il[i].a[j].with+1, si->ip[si->il[i].a[j].ip].group);
+            G_debug(4, "            dist=%.18f", si->il[i].a[j].dist);
+            G_debug(4, "            x=%.18f, y=%.18f", si->ip[si->il[i].a[j].ip].x, si->ip[si->il[i].a[j].ip].y);
+    return si;
+/* create's graph with n vertices and allocates memory for e edges */
+/* trying to add more than e edges, produces fatal error */
+struct planar_graph* pg_create_struct(int n, int e) {
+    struct planar_graph *pg;
+    int i;
+    pg = G_malloc(sizeof(struct planar_graph));
+    pg->vcount = n;
+    pg->v = G_malloc(n*sizeof(struct pg_vertex));
+    memset(pg->v, 0, n*sizeof(struct pg_vertex));
+    pg->ecount = 0;
+    pg->eallocated = MAX(e, 0);
+    pg->e = NULL;
+    pg->e = G_malloc(e*sizeof(struct pg_edge));
+    return pg;
+void pg_destroy_struct(struct planar_graph *pg) {
+    int i;
+    for (i = 0; i < pg->vcount; i++) {
+        G_free(pg->v[i].edges);
+        G_free(pg->v[i].angles);
+    G_free(pg->v);
+    G_free(pg->e);
+    G_free(pg);
+/* v1 and v2 must be valid and v1 must be smaller than v2 (v1 < v2) */
+int pg_existsedge(struct planar_graph *pg, int v1, int v2) {
+    struct pg_vertex *v;
+    struct pg_edge *e;
+    int i, ecount;
+    if (pg->v[v1].ecount <= pg->v[v2].ecount)
+        v = &(pg->v[v1]);
+    else
+        v = &(pg->v[v2]);
+    ecount = v->ecount;
+    for (i = 0; i < ecount; i++) {
+        e = v->edges[i];
+        if ((e->v1 == v1) && (e->v2 == v2))
+            return 1;
+    return 0;
+/* for internal use */
+void pg_addedge1(struct pg_vertex *v, struct pg_edge *e) {
+    if (v->ecount == v->eallocated) {
+        v->eallocated += 4;
+        v->edges = G_realloc(v->edges, (v->eallocated)*sizeof(struct pg_edge *));
+    v->edges[v->ecount] = e;
+    v->ecount++;
+void pg_addedge(struct planar_graph *pg, int v1, int v2) {
+    int t;
+    G_debug(4, "pg_addedge(), v1=%d, v2=%d", v1, v2);
+    if ((v1 == v2) || (v1 < 0) || (v1 >= pg->vcount) || (v2 < 0) || (v2 >= pg->vcount)) {
+        G_warning("    v1=%d, v2=%d, pg->vcount=%d", v1, v2, pg->vcount);
+        G_fatal_error("    pg_addedge(), v1 and/or v2 is invalid");
+        return;
+    if (v2 < v1) {
+        t = v1;
+        v1 = v2;
+        v2 = t;
+    if (pg_existsedge(pg, v1, v2))
+        return;
+    if (pg->ecount == pg->eallocated) {
+        G_fatal_error("Trying to add more edges to the planar_graph than the initial allocation size allows");
+    e = &(pg->e[pg->ecount]);
+    e->v1 = v1;
+    e->v2 = v2;
+    e->visited_left = 0;
+    e->visited_right = 0;
+    pg->ecount++;
+    pg_addedge1(&(pg->v[v1]), e);
+    pg_addedge1(&(pg->v[v2]), e);
+    return;
+struct planar_graph* pg_create(struct line_pnts *Points) {
+    struct pg_vertex *vert;
+    struct pg_edge *edge;
+    int i, j, t, v;
+    G_debug(4, "pg_create()");
+    si = find_all_intersections(Points);
+    pg = pg_create_struct(si->group_count, 2*(si->ipcount));
+        ip = &(si->ip[i]);
+        t = ip->group;
+        pg->v[t].x = ip->x;
+        pg->v[t].y = ip->y;
+        v = si->ip[si->il[i].a[0].ip].group;
+        for (j = 1; j < si->il[i].count; j++) {
+            t = si->ip[si->il[i].a[j].ip].group;
+            if (t != v) {
+                pg_addedge(pg, t, v);
+                v = t;
+        vert = &(pg->v[i]);
+        vert->angles = G_malloc((vert->ecount)*sizeof(double));
+        for (j = 0; j < vert->ecount; j++) {
+            edge = vert->edges[j];
+            t = (edge->v1 != i)?(edge->v1):(edge->v2);
+            vert->angles[j] = atan2(pg->v[t].y - vert->y, pg->v[t].x - vert->x);
+    destroy_si_struct(si);
+    I'm not sure if shrinking of the allocated memory always preserves it's physical place.
+    That's why I don't want to do this:
+    if (pg->ecount < pg->eallocated) {
+        pg->eallocated = pg->ecount;
+        pg->e = G_realloc(pg->e, (pg->ecount)*sizeof(struct pg_edge));
+    /* very time consuming */
+        if (pg->v[i].ecount < pg->v[i].eallocated) {
+            pg->v[i].eallocated = pg->v[i].ecount;
+            pg->v[i].edges = G_realloc(pg->v[i].edges, (pg->v[i].ecount)*sizeof(struct pg_edges));
+    /* output pg */
+        G_debug(4, "    vertex %d (%g, %g)", i, pg->v[i].x, pg->v[i].y);
+        for (j = 0; j < pg->v[i].ecount; j++) {
+            G_debug(4, "        edge %d-%d", pg->v[i].edges[j]->v1, pg->v[i].edges[j]->v2);
+    return pg;
Added: grass-addons/vector/v.parallel2/dgraph.h
--- grass-addons/vector/v.parallel2/dgraph.h	                        (rev 0)
+++ grass-addons/vector/v.parallel2/dgraph.h	2008-07-23 15:15:36 UTC (rev 32228)
@@ -0,0 +1,35 @@
+#ifndef DGRAPH_H
+#define DGRAPH_H
+/* pg comes from "planar graph" */
+struct pg_edge {
+    int v1; /* v1 should be smaller than v2 */
+    int v2;
+    char visited_left;
+    char visited_right;
+struct pg_vertex {
+    double x; /* coordinates */
+    double y;
+    int ecount; /* number of neighbours */
+    int eallocated; /* size of the array bellow */
+    struct pg_edge **edges; /* array of pointers */
+    double *angles; /* precalculated angles with Ox */
+struct planar_graph {
+    int vcount; /* number of vertices */
+    int ecount;
+    int eallocated;
+struct planar_graph* pg_create_struct(int n, int e);
+void pg_destroy_struct(struct planar_graph *pg);
+int pg_existsedge(struct planar_graph *pg, int v1, int v2);
+void pg_addedge(struct planar_graph *pg, int v1, int v2);
+struct planar_graph* pg_create(struct line_pnts *Points);
+#endif
Modified: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c	2008-07-23 14:55:18 UTC (rev 32227)
+++ grass-addons/vector/v.parallel2/main.c	2008-07-23 15:15:36 UTC (rev 32228)
@@ -6,15 +6,13 @@
  * PURPOSE:      Create parallel lines
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
  *               This program is free software under the
  *               GNU General Public License (>=v2).
  *               Read the file COPYING that comes with GRASS
  *               for details.
- * TODO/BUG:     The vector segments are not properly connected
- *               and should be snapped.
 #include <stdlib.h>
 #include <math.h>
@@ -139,7 +137,7 @@
     for ( line = 1; line <= nlines; line++ ) {
         int ltype;
-        G_percent ( line, nlines, 1 );
+        G_percent(line, nlines, 1);
         ltype = Vect_read_line ( &In, Points, Cats, line);
@@ -168,8 +166,14 @@
+/*    Vect_build_partial(&Out, GV_BUILD_BASE, stderr);
+    Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL, stderr);
+    Vect_break_lines(&Out, GV_BOUNDARY, NULL, stderr);
+    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL, stderr);
+    Vect_build_partial (&Out, GV_BUILD_NONE, NULL); */
+    Vect_build (&Out, stderr);
     Vect_close (&In);
-    Vect_build (&Out, stderr);
     Vect_close (&Out);
     exit(EXIT_SUCCESS) ;
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-07-23 14:55:18 UTC (rev 32227)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-07-23 15:15:36 UTC (rev 32228)
@@ -1,6 +1,6 @@
 /* Functions: ...
-** Author: Radim Blazek, Rosen Matev; June 2008
+** Author: Radim Blazek, Rosen Matev; July 2008
@@ -8,6 +8,7 @@
 #include <math.h>
 #ifndef MIN
@@ -157,7 +158,7 @@
 void parallel_line(struct line_pnts *Points, double da, double db, double dalpha, int side, int round, int caps, int looped, double tol, struct line_pnts *nPoints)
-    int i, i_minus_1, j, res, np;
+    int i, j, res, np;
     double *x, *y;
     double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
     double vx1, vy1, wx1, wy1;
@@ -165,16 +166,24 @@
     double phi1, phi2, delta_phi;
     double nsegments, angular_tol, angular_step;
     double cosa, sina, r;
-    int inner_corner, turns180, loop_flag;
+    int inner_corner, turns180;
     G_debug(4, "parallel_line()");
-    Vect_reset_line(nPoints);
+    if (looped && 0) {
+        /* start point != end point */
+        return;
+    Vect_reset_line(nPoints);
+    if (looped) {
+        Vect_append_point(Points, Points->x[1], Points->y[1], Points->z[1]);
     x = Points->x;
     y = Points->y;
     if ((np == 0) || (np == 1))
         return;
@@ -186,22 +195,17 @@
     side = (side >= 0)?(1):(-1); /* normalize variable */
     dalpha *= PI/180; /* convert dalpha from degrees to radians */
     angular_tol = angular_tolerance(tol, da, db);
-    loop_flag = 1;
-    for (i = 0; (i < np)&&(loop_flag); i++)
-        i_minus_1 = i - 1;
-        if (i == np-1) {
-            if (!looped) {
-                break;
-            else {
-                i = 0;
-                i_minus_1 = np - 2;
-                loop_flag = 0;
+        /* save the old values */
+        a0 = a1;
+        b0 = b1;
+        c0 = c1;
+        wx = vx;
+        wy = vy;
         norm_vector(x[i], y[i], x[i+1], y[i+1], &tx, &ty);
         elliptic_tangent(side*tx, side*ty, da, db, dalpha, &vx, &vy);
@@ -212,286 +216,185 @@
         my = y[i+1] + vy;
         line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
-        if ((i == 0) && loop_flag) {
-            if (!looped) {
+        if (i == 0) {
+            if (!looped)
                 Vect_append_point(nPoints, nx, ny, 0);
-                G_debug(4, "append point x=%.18f y=%.18f i=%d", nx, ny, i);
+            continue;
+        delta_phi = atan2(ty, tx) - atan2(y[i]-y[i-1], x[i]-x[i-1]);
+        if (delta_phi > PI)
+            delta_phi -= 2*PI;
+        else if (delta_phi <= -PI)
+            delta_phi += 2*PI;
+        /* now delta_phi is in [-pi;pi] */
+        turns180 = (fabs(fabs(delta_phi) - PI) < 1e-15);
+        inner_corner = (side*delta_phi <= 0) && (!turns180);
+        if ((turns180) && (!(caps && round))) {
+            if (caps) {
+                norm_vector(0, 0, vx, vy, &tx, &ty);
+                elliptic_tangent(side*tx, side*ty, da, db, dalpha, &tx, &ty);
+            else {
+                tx = 0;
+                ty = 0;
+            Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
+            Vect_append_point(nPoints, nx + tx, ny + ty, 0); /* nx == x[i] + vx, ny == y[i] + vy */
+        else if ((!round) || inner_corner) {
+            res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
+/*                if (res == 0) {
+                G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
+                G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
+                return;
+            if (res == 1) {
+                Vect_append_point(nPoints, rx, ry, 0);
         else {
-            delta_phi = atan2(ty, tx) - atan2(y[i_minus_1+1]-y[i_minus_1], x[i_minus_1+1]-x[i_minus_1]);
-            if (delta_phi > PI)
-                delta_phi -= 2*PI;
-            else if (delta_phi <= -PI)
+            /* we should draw elliptical arc for outside corner */
+            /* inverse transforms */
+            elliptic_transform(wx, wy, 1/da, 1/db, dalpha, &wx1, &wy1);
+            elliptic_transform(vx, vy, 1/da, 1/db, dalpha, &vx1, &vy1);
+            phi1 = atan2(wy1, wx1);
+            phi2 = atan2(vy1, vx1);
+            delta_phi = side*(phi2 - phi1);
+            /* make delta_phi in [0, 2pi] */
+            if (delta_phi < 0)
                 delta_phi += 2*PI;
-            /* now delta_phi is in [-pi;pi] */
-            turns180 = (fabs(fabs(delta_phi) - PI) < 1e-15);
-            inner_corner = (side*delta_phi <= 0) && (!turns180);
-            if ((turns180) && (!(caps && round))) {
-                if (caps) {
-                    norm_vector(0, 0, vx, vy, &tx, &ty);
-                    elliptic_tangent(side*tx, side*ty, da, db, dalpha, &tx, &ty);
-                else {
-                    tx = 0;
-                    ty = 0;
-                Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
-                Vect_append_point(nPoints, nx + tx, ny + ty, 0); /* nx == x[i] + vx, ny == y[i] + vy */
+            nsegments = (int)(delta_phi/angular_tol) + 1;
+            angular_step = side*(delta_phi/nsegments);
+            for (j = 0; j <= nsegments; j++) {
+                elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx, &ty);
+                Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
+                phi1 += angular_step;
-            else if ((!round) || inner_corner) {
-                res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
-/*                if (res == 0) {
-                    G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
-                    G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
-                    return;
-                if (res == 1) {
-                    Vect_append_point(nPoints, rx, ry, 0);
-            else {
-                /* we should draw elliptical arc for outside corner */
-                /* inverse transforms */
-                elliptic_transform(wx, wy, 1/da, 1/db, dalpha, &wx1, &wy1);
-                elliptic_transform(vx, vy, 1/da, 1/db, dalpha, &vx1, &vy1);
-                phi1 = atan2(wy1, wx1);
-                phi2 = atan2(vy1, vx1);
-                delta_phi = side*(phi2 - phi1);
-                /* make delta_phi in [0, 2pi] */
-                if (delta_phi < 0)
-                    delta_phi += 2*PI;
-                nsegments = (int)(delta_phi/angular_tol) + 1;
-                angular_step = side*(delta_phi/nsegments);
-                for (j = 0; j <= nsegments; j++) {
-                    elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx, &ty);
-                    Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
-                    phi1 += angular_step;
-        if ((i == np-2) && (!looped)) {
+        if ((!looped) && (i == np-2)) {
             Vect_append_point(nPoints, mx, my, 0);
-        /* save the old values */
-        a0 = a1;
-        b0 = b1;
-        c0 = c1;
-        wx = vx;
-        wy = vy;
     if (looped) {
-        i = nPoints->n_points - 1;
-        Vect_line_insert_point(nPoints, 0, nPoints->x[i], nPoints->y[i], 0);
+        Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
     Vect_line_prune ( nPoints );
-static void split_at_intersections(struct line_pnts *Points, struct line_pnts *nPoints)
-    #define MAX_SEGMENT_INTERSECTIONS 10  /* we should make dynamic array here? */
-    #define EPSILON 1e-10 /*  */
-    int i, j, k, res, np;
-    double *x, *y; /* input coordinates */
-    double x1, y1, z1, x2, y2, z2; /* intersection points */
-    double len; /* current i-th line length */
-    double tdist, min;
-    double px[MAX_SEGMENT_INTERSECTIONS], py[MAX_SEGMENT_INTERSECTIONS], pdist[MAX_SEGMENT_INTERSECTIONS];
-    int pcount, min_i;
-    G_debug(1, "split_at_intersections()");
-    Vect_line_prune(Points);
-    np = Points->n_points;
-    x = Points->x;
-    y = Points->y;
-    if ((np == 0) || (np == 1))
-        return;
-    for (i = 0; i < np-1; i++) {
-        Vect_append_point(nPoints, x[i], y[i], 0);
-        G_debug(1, "appended point x=%f y=%f", x[i], y[i]);
-        /* find all intersections */
-        pcount = 0;
-        len = LENGTH((x[i]-x[i+1]), (y[i]-y[i+1]));
-        for (j = 0; j < np-1; j++) {
-            /* exclude previous (i-1)th, current i-th, and next (i+1)th line */
-            if ((j < i-1) || (j > i+1)) {
-                res = Vect_segment_intersection(x[i], y[i], 0, x[i+1], y[i+1], 0,
-                                                x[j], y[j], 0, x[j+1], y[j+1], 0,
-                                                &x1, &y1, &z1, &x2, &y2, &z2, 0);
-                G_debug(1, "intersection=%d", res);
-                if (res == 1) {
-                    /* generall intersection */
-                    tdist = LENGTH((x[i]-x1), (y[i]-y1));
-                    /* we only want intersections on the inside */
-                    G_debug(1, "x1=%f y1=%f tdist=%f len=%f, eps=%f", x1, y1, tdist, len, EPSILON);
-                    if ((tdist > EPSILON) && (tdist < len - EPSILON)) {
-                        px[pcount] = x1;
-                        py[pcount] = y1;
-                        pdist[pcount] = tdist;
-                        pcount++;
-                /* TODO: implement cases of overlappings */
-        /* now we shoud output interserction points ordered by distance to (x[i],y[i]) */
-        /* we do it in O(pcount^2) time, since pcount is usually small it's okey */
-        G_debug(1, "pcount=%d", pcount);
-        for (j = 0; j < pcount; j++) {
-            min = 2*len;
-            for (k = 0; k < pcount; k++) {
-                if (pdist[k] < min) {
-                    min = pdist[k];
-                    min_i = k;
-            pdist[min_i] = 4*len;
-            Vect_append_point(nPoints, px[min_i], py[min_i], 0);
-            G_debug(1, "appended point x=%f y=%f", px[min_i], py[min_i]);
+    if (looped) {
+        Vect_line_delete_point(Points, Points->n_points-1);
-    Vect_append_point(nPoints, x[np-1], y[np-1], 0);
-    Vect_line_prune(nPoints);
-* IMPORTANT: split_at_intersections() must be applied to input line before calling extract_contour().
-*            When visited != NULL, extract_contour() marks the sides of lines as visited along the contour.
-*            visited->a must have at least Points->n_points elements
-* side: side >= 0 - right contour, side < 0 - left contour
-* returns: -1 when contour is a loop; 0 or Points->n_points-1 when contour finishes at line end (depending on which one)
+* side: side >= 0 - extracts contour on right side of edge, side < 0 - extracts contour on left side of edge
+* returns: the side of the output line, where we should draw parallel line
-static int extract_contour(struct line_pnts *Points, int first_point, int first_step, int side, int stop_at_line_end, struct line_pnts *nPoints, struct visited_segments *visited) {
-    int i, is, j, k, step, np;
-    int ret;
-    double *x, *y;
-    double cx, cy, tx, ty;
-    double u, v, len, new_len, new_step;
-    int intersection_flag;
+static int extract_contour(struct planar_graph *pg, struct pg_edge *first, int side, int stop_at_line_end, struct line_pnts *nPoints) {
+    int i, j, ret;
+    int v; /* current vertex number */
+    int v0;
+    int eside; /* side of the current edge */
+    double eangle; /* current edge angle with Ox (according to the current direction) */
+    struct pg_vertex *vert; /* current vertex */
+    struct pg_vertex *vert0; /* last vertex */
+    struct pg_edge *edge; /* current edge; must be edge of vert */
+    int cs; /* on which side are we turning along the contour */
     double opt_angle, tangle;
-    int opt_j, opt_step, opt_flag;
+    int opt_j, opt_side, opt_flag;
-    G_debug(4, "extract_contour(): first_point=%d, first_step=%d, side=%d, stop_at_line_end=%d", first_point, first_step, side, stop_at_line_end);
+    G_debug(4, "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d", first->v1, first->v2, side, stop_at_line_end);
-    x = Points->x;
-    y = Points->y;
-    G_debug(4, "ec: Points->n_points=%d", np);
-        return;
-    /* normalize parameter side */
-    if (side >= 0)
-        side = 1;
-    else if (side < 0)
-        side = -1;
-    i = first_point;
-    step = first_step;
+    edge = first;
+    eside = (side >= 0)?(1):(-1);
+    v = edge->v1; /* we might select v1 or v2 if we always want ccw output line */
+    v0 = edge->v2;
+    vert = &(pg->v[v]);
+    vert0 = &(pg->v[v0]);
+    /*for (i = 0; i < pg->v[v0].ecount; i++)
+        if (pg->v[v0].edges[i] == edge) {
+            eangle = pg->v[v0].angles[i];
+            break;
+    eangle = atan2(vert->y - vert0->y, vert->x - vert0->x);
+    cs = -eside; /* because we chose to go v2-->v1 */
     while (1) {
-        /* precessing segment AB: A=(x[i],y[i]) B=(x[i+step],y[i+step]) */
-        G_debug(4, "ec: append point x=%.18f y=%.18f", x[i], y[i]);
-        is = i + step;
+        Vect_append_point(nPoints, vert0->x, vert0->y, 0);
+        G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0, v, eside, edge->v1, edge->v2);
+        G_debug(4, "ec: edge=%X, first=%X", edge, first);
+        //G_debug(4, "ec: first->v1=%d, first->v2=%d", first->v1, first->v2);
+        G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
+        /* mark current edge as visited on the appropriate side */
+        if (eside == 1)
+            edge->visited_right = 1;
+        else
+            edge->visited_left = 1;
-        if (visited != NULL) {
-            j = (3-step*side)/2; /* j is 1 when (step*side == 1), and j is 2 when (step*side == -1) */
-            k = MIN(i, is);
-            if ((visited->a[k] & j) == 0)
-                visited->n++;
-            visited->a[k] |= j;
-        cx = x[i] - x[is];
-        cy = y[i] - y[is];
         opt_flag = 1;
-            /* exclude current segment AB */
-            if (j != i - (1-step)/2) {
-                if ((fabs(x[j]-x[is]) < EPSILON) && (fabs(y[j]-y[is]) < EPSILON)) {
-                    tx = x[j+1] - x[j];
-                    ty = y[j+1] - y[j];
-                    tangle = atan2(ty, tx) - atan2(cy, cx);
-                    if (tangle < 0)
-                        tangle += 2*PI;
-                    /* now tangle is in [0, 2PI) */
-                    if (opt_flag || (side*tangle < side*opt_angle)) {
-                        opt_j = j;
-                        opt_step = 1;
-                        opt_angle = tangle;
-                        opt_flag = 0;
+            /* exclude current edge */
+            if (vert->edges[j] != edge) {
+                tangle = vert->angles[j] - eangle;
+                if (tangle < -PI)
+                    tangle += 2*PI;
+                else if (tangle > PI)
+                    tangle -= 2*PI;
+                /* now tangle is in (-PI, PI) */
+                if (opt_flag || (cs*tangle < cs*opt_angle)) {
+                    opt_j = j;
+                    opt_side = (vert->edges[j]->v1 == v)?(cs):(-cs);
+                    opt_angle = tangle;
+                    opt_flag = 0;
-                else if ((fabs(x[j+1]-x[is]) < EPSILON) && (fabs(y[j+1]-y[is]) < EPSILON)) {
-                    tx = x[j] - x[j+1];
-                    ty = y[j] - y[j+1];
-                    if (tangle < 0)
-                        tangle += 2*PI;
-                        opt_j = j+1;
-                        opt_step = -1;
-                        opt_flag = 0;
-        /* if line end is reached */
+//        G_debug(4, "ec: opt: side=%d opt_flag=%d opt_angle=%.18f opt_j=%d opt_step=%d", side, opt_flag, opt_angle, opt_j, opt_step);
+        /* if line end is reached (no other edges at curr vertex) */
         if (opt_flag) {
             if (stop_at_line_end) {
-                Vect_append_point(nPoints, x[is], y[is], 0);
-                ret = is;
+                ret = 2;
                 break;
             else {
-                opt_j = is;
-                opt_step = -step;
+                opt_j = 0; /* the only edge of vert is vert->edges[0] */
+                opt_side = -eside; /* go to the other side of the curr edge */
-        if ((opt_j == first_point) && (opt_step == first_step)) {
-            ret = -1;
+        if ((vert->edges[opt_j] == first) && (opt_side == side)) {
+            ret = 1;
             break;
-        i = opt_j;
-        step = opt_step;
-    return ret;
+        edge = vert->edges[opt_j];
+        eside = opt_side;
+        v0 = v;
+        v = (edge->v1 == v)?(edge->v2):(edge->v1);
+        vert0 = vert;
+        eangle = vert0->angles[opt_j];
+    Vect_append_point(nPoints, vert->x, vert->y, 0);
+    G_debug(4, "ec: append point x=%.18f y=%.18f", vert->x, vert->y);
+    return cs;
@@ -502,128 +405,91 @@
 * side: side > 0 - right contour, side < 0 - left contour, side = 0 - outer contour
 *       if side != 0 and there's only one contour, the function returns it
-* IMPORTANT: split_at_intersections() must be applied to input line before calling extract_outer_contour
 * TODO: Implement side != 0 feature;
-* returns: returns on which side of output line is the exterior of the input line
+* retunrs: the side of the output line, where we should draw parallel line
-static int extract_outer_contour(struct line_pnts *Points, int side, struct line_pnts *nPoints, struct visited_segments *visited) {
-    int i, np, res, ret;
-    double *x, *y;
+int extract_outer_contour(struct planar_graph *pg, int side, struct line_pnts *nPoints) {
+    int i;
+    int flag;
+    int v;
     double min_x, min_angle, ta;
-    int t1, t2, j1=-1, j2=-1;
     G_debug(4, "extract_outer_contour()");
-    x = Points->x;
-    y = Points->y;
     if (side != 0) {
-        res = extract_contour(Points, 0, 1, side, 1, nPoints, NULL); /* should save visited and later restore it if needed */
-        /* if we have finished at the other end */
-        if (res == Points->n_points-1) {
-            /* !!! WE ARE STILL NOT SURE WHETHER THIS IS PROPER OUTER CONTOUR.
-             * !!! CONSIDER THE CASE WHERE BOTH LINE ENDS ARE IN THE SAME LOOP.
-            return side;
+        G_fatal_error("    side != 0 feature not implemented");
+        return;
     /* find a line segment which is on the outer contour */
-    min_x = 1e300;
-        if (x[i] <= x[i+1]) {
-            t1 = i;
-            t2 = i+1;
+    flag = 1;
+        if (flag || (pg->v[i].x < min_x)) {
+            v = i;
+            min_x = pg->v[i].x;
+            flag = 0;
-        else {
-            t1 = i+1;
-            t2 = i;
+    flag = 1;
+    for (i = 0; i < vert->ecount; i++) {
+        if (flag || (vert->angles[i] < min_angle)) {
+            edge = vert->edges[i];
+            min_angle = vert->angles[i];
+            flag = 0;
-        G_debug(4, "t1=%d (%f,%f) t2=%d (%f,%f)", t1, x[t1], y[t1], t2, x[t2], y[t2]);
-        if (x[t1] < min_x) {
-            min_x = x[t1];
-            min_angle = atan2(y[t2]-y[t1], x[t2]-x[t1]);
-            j1 = t1;
-            j2 = t2;
-            G_debug(4, "j1=%d j2=%d", j1, j2);
-        else if ((x[t1] == min_x) && (y[t1] == y[j1])) {
-            ta = atan2(y[t2]-y[t1], x[t2]-x[t1]);
-            if (ta < min_angle) {
-                min_angle = ta;
-                j1 = t1;
-                j2 = t2;
-    G_debug(4, "j1=%d, j2-j1=%d, side=%d", j1, j2-j1, RIGHT_SIDE);
-    res = extract_contour(Points, j1, j2-j1, RIGHT_SIDE, 0, nPoints, visited);
-    return RIGHT_SIDE;
+    return extract_contour(pg, edge, (edge->v1 == v)?RIGHT_SIDE:LEFT_SIDE, 0, nPoints);
-* Extracts contours which are not visited. Generates counterclockwise closed lines.
-* IMPORTANT: split_at_intersections() must be applied to input line before calling extract_inner_contour
-* IMPORTANT: the outer contour must be visited, so that extract_inner_contour() doesn't return it
-* returns: 0 when there are no more inner contours; otherwise, returns on which side of output line is the interior of the loop
+* Extracts contours which are not visited.
+* IMPORTANT: the outer contour must be visited (you should call extract_outer_contour() to do that),
+*            so that extract_inner_contour() doesn't return it
+* returns: 0 when there are no more inner contours; otherwise, the side of the output line, where we should draw parallel line
-int extract_inner_contour(struct line_pnts *Points, struct line_pnts *nPoints, struct visited_segments *visited) {
-    int i, j, np, res;
-    double *x, *y;
+int extract_inner_contour(struct planar_graph *pg, struct line_pnts *nPoints) {
+    int i;
     G_debug(4, "extract_inner_contour()");
-    x = Points->x;
-    y = Points->y;
-        /* if right side is not visited */
-        if ((visited->a[i] & 1) == 0) {
-            res = extract_contour(Points, i+1, -1, LEFT_SIDE, 0, nPoints, visited);
-            return LEFT_SIDE;
-        /* if left side is not visited */
-        if ((visited->a[i] & 2) == 0) {
-            res = extract_contour(Points, i, 1, LEFT_SIDE, 0, nPoints, visited);
-            return LEFT_SIDE;
+    for (i = 0; i < pg->ecount; i++) {
+        if (!(pg->e[i].visited_right))
+            return extract_contour(pg, &(pg->e[i]), RIGHT_SIDE, 0, nPoints);
+        if (!(pg->e[i].visited_left))
+            return extract_contour(pg, &(pg->e[i]), LEFT_SIDE, 0, nPoints);
     return 0;
 void extract_all_inner_contours(struct line_pnts *Points, struct line_pnts ***iPoints, int *inner_count) {
-    struct line_pnts *Points2, *tPoints;
+    struct line_pnts *tPoints;
     struct line_pnts **arrPoints;
-    int i, side, count;
+    int i, res, count;
     int more = 8;
     int allocated = more;
-    struct visited_segments visited;
     G_debug(4, "extract_all_inner_contours()");
-    /* initializations and spliting of the input line */
+    /* initializations */
     tPoints = Vect_new_line_struct();
-    Points2 = Vect_new_line_struct();
-    split_at_intersections(Points, Points2);
-    visited.a = (char *)G_malloc(sizeof(char)*Points2->n_points);
-    memset(visited.a, 0, sizeof(char)*Points2->n_points);
     arrPoints = G_malloc(allocated*sizeof(struct line_pnts *));
+    pg = pg_create(Points);
+    /* extract outer contour so that we have visited edges appropriately */
+    extract_outer_contour(pg, 0, tPoints);
-    /* extract outer contour so that we have filled visited appropriately */
-    side = extract_outer_contour(Points2, 0, tPoints, &visited);
     /* inner contours */
     count = 0;
-    side = extract_inner_contour(Points2, tPoints, &visited);
-    while (side != 0) {
+    res = extract_inner_contour(pg, tPoints);
+    while (res != 0) {
         if (allocated < count+1) {
             allocated += more;
             arrPoints = G_realloc(arrPoints, allocated*sizeof(struct line_pnts *));
@@ -632,26 +498,19 @@
         Vect_copy_xyz_to_pnts(arrPoints[count], tPoints->x, tPoints->y, tPoints->z, tPoints->n_points);
         count++;
     arrPoints = G_realloc(arrPoints, count*sizeof(struct line_pnts *));
     *inner_count = count;
     *iPoints = arrPoints;
-    G_free(visited.a);
+    pg_destroy_struct(pg);
     Vect_destroy_line_struct(tPoints);
-    Vect_destroy_line_struct(Points2);
     return;
-double perp_dist(double x1, double y1, double x2, double y2, double px, double py) {
-    double a,b,c;
-    line_coefficients(x1, y1, x2, y2, &a, &b, &c);
-    return fabs((a*px+b*py+c)/sqrt(a*a+b*b));
 /* point_in_buf - test if point px,py is in d buffer of Points
 ** returns:  1 in buffer
 **           0 not  in buffer
@@ -699,8 +558,8 @@
             d = dig_distance2_point_to_line(nx + tx, ny + ty, 0, vx, vy, 0, wx, wy, 0,
                 0, NULL, NULL, NULL, NULL, NULL);
-/*            G_debug(4, "pdist = %g", perp_dist(vx, vy ,wx, wy, px, py));
-            G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny)));*/
+/*            G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny)));*/
             if (d <= 1)
                 return 1;
@@ -717,48 +576,47 @@
 void parallel_line_b(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
-    struct line_pnts *Points2, *tPoints, *sPoints;
+    struct planar_graph *pg, *pg2;
+    struct line_pnts *tPoints, *sPoints;
     struct line_pnts **arrPoints2;
-    int i, side, count, count2;
-    int res;
+    int i, count, count2;
+    int side, res;
     int more = 8;
-    int allocated = more;
+    int allocated = 0;
     double px, py;
     G_debug(4, "parallel_line_b()");
     sPoints = Vect_new_line_struct();
+    arrPoints = NULL;
-    arrPoints = G_malloc(allocated*sizeof(struct line_pnts *));
     /* outer contour */
     *oPoints = Vect_new_line_struct();
+    side = extract_outer_contour(pg, 0, tPoints);
+/*    parallel_line(tPoints, da, db, dalpha, side, round, caps, LOOPED_LINE, tol, *oPoints);*/
     parallel_line(tPoints, da, db, dalpha, side, round, caps, LOOPED_LINE, tol, sPoints);
-    split_at_intersections(sPoints, tPoints);
-    extract_outer_contour(tPoints, 0, *oPoints, NULL);
+    pg2 = pg_create(sPoints);
+    extract_outer_contour(pg2, 0, *oPoints);
+    pg_destroy_struct(pg2);
     count = 0;
+    side = extract_inner_contour(pg, tPoints);
     while (side != 0) {
         extract_all_inner_contours(sPoints, &arrPoints2, &count2);
         for (i = 0; i < count2; i++) {
             res = Vect_line_check_intersection(tPoints, arrPoints2[i], 0);
-            if (res != 0)
+            if (res != 0)
                 continue;
+            res = Vect_point_in_poly(arrPoints2[i]->x[0], arrPoints2[i]->y[0], tPoints);
+            if (res == 0)
+                continue;
             res = Vect_get_point_in_poly(arrPoints2[i], &px, &py);
             if (res != 0)
@@ -766,8 +624,7 @@
             if (point_in_buf(tPoints, px, py, da, db, dalpha))
                 continue;
-            /* passed all tests, add new island */
-            if (allocated < count+1) {
+            if (allocated == count) {
                 allocated += more;
@@ -776,17 +633,16 @@
             count++;
     Vect_destroy_line_struct(sPoints);
     return;
@@ -922,6 +778,3 @@
     Vect_line_prune ( OutPoints );
