[GRASS-SVN] r32237 - in grass/trunk/gui/wxpython: gui_modules nviz
Wed Jul 23 18:27:19 EDT 2008
Author: martinl
Date: 2008-07-23 18:27:19 -0400 (Wed, 23 Jul 2008)
New Revision: 32237
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/nviz/init.cpp
   grass/trunk/gui/wxpython/nviz/nviz.h
   grass/trunk/gui/wxpython/nviz/nviz.i
nviz2/wxGUI: nviz module log improved
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-23 21:28:04 UTC (rev 32236)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-23 22:27:19 UTC (rev 32237)
@@ -372,7 +372,7 @@
             self.gmstc.StartStyling(p1, 0xff)
             self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleOutput)
-class GMStderr:
+class GMStderr(object):
     """GMConsole standard error output
     Based on FrameOutErr.py
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-23 21:28:04 UTC (rev 32236)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-23 22:27:19 UTC (rev 32237)
@@ -94,7 +94,7 @@
         # create nviz instance
-        self.nvizClass = wxnviz.Nviz()
+        self.nvizClass = wxnviz.Nviz(sys.stderr)
         # set current display
@@ -349,14 +349,12 @@
                 if type == 'raster':
                     self.LoadRaster(item)
             except gcmd.NvizError, e:
-                print >> sys.stderr, "Nviz: %s" % (self.nvizClass.GetErrorMsg())
                 print >> sys.stderr, "Nviz: " + e.message
             try:
                 if type == 'vector':
                     self.LoadVector(item)
         stop = time.time()
Modified: grass/trunk/gui/wxpython/nviz/init.cpp
--- grass/trunk/gui/wxpython/nviz/init.cpp	2008-07-23 21:28:04 UTC (rev 32236)
+++ grass/trunk/gui/wxpython/nviz/init.cpp	2008-07-23 22:27:19 UTC (rev 32237)
@@ -20,16 +20,16 @@
 static void swap_gl();
 static int print_error(const char *, const int);
-static std::string *error;
+static PyObject *logStream;
   \brief Initialize Nviz class instance
-Nviz::Nviz()
+Nviz::Nviz(PyObject *log)
     G_gisinit(""); /* GRASS functions */
-    error = new std::string();
+    logStream = log;
     G_set_error_routine(&print_error);
     G_set_verbose(0); // TODO: read progress info
@@ -57,7 +57,7 @@
     data = NULL;
     glCanvas = NULL;
-    delete error;
+    logStream = NULL;
@@ -135,23 +135,20 @@
     return;
-std::string Nviz::GetErrorMsg()
-    if (error) {
-	std::string retStr(*error);
-	error->clear();
-	return retStr;
-    return std::string();
 int print_error(const char *msg, const int type)
-    if (error) {
-	error->append(msg);
-	error->append("\n");
+    char *fmsg;
+    if (logStream) {
+	fmsg = (char *) G_malloc (strlen(msg) + 6);
+	sprintf (fmsg, "Nviz: %s", msg);
+	PyFile_WriteString(fmsg, logStream);
+	G_free((void *) fmsg);
+    else {
+	fprintf(stderr, "Nviz: %s\n", msg);
     return 0;
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-23 21:28:04 UTC (rev 32236)
+++ grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-23 22:27:19 UTC (rev 32237)
@@ -1,7 +1,6 @@
 #ifndef WXNVIZ_H
 #define WXNVIZ_H
-#include <string>
 #include <vector>
 extern "C" {
@@ -25,6 +24,8 @@
 #include <wx/glcanvas.h>
+#include <Python.h>
 class Nviz
 private:
@@ -37,13 +38,11 @@
 public:
     /* constructor */
-    Nviz();
+    Nviz(PyObject *);
     /* destructor */
     ~Nviz();
-    std::string GetErrorMsg();
     /* change_view.cpp */
     int ResizeWindow(int, int);
     std::vector<double> SetViewDefault();
Modified: grass/trunk/gui/wxpython/nviz/nviz.i
--- grass/trunk/gui/wxpython/nviz/nviz.i	2008-07-23 21:28:04 UTC (rev 32236)
+++ grass/trunk/gui/wxpython/nviz/nviz.i	2008-07-23 22:27:19 UTC (rev 32237)
@@ -17,6 +17,4 @@
    %template(IntVecIntMap) map<int, vector<int> >;
-%include "std_string.i"
 %include "nviz.h"
