[GRASS-SVN] r32268 - grass/trunk/raster/r.mapcalc
Thu Jul 24 13:14:51 EDT 2008
Author: glynn
Date: 2008-07-24 13:14:50 -0400 (Thu, 24 Jul 2008)
New Revision: 32268
   grass/trunk/raster/r.mapcalc/map3.c
Make r3.mapcalc work on 64-bit systems (where a void* won't fit into an int)
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c	2008-07-24 16:52:45 UTC (rev 32267)
+++ grass/trunk/raster/r.mapcalc/map3.c	2008-07-24 17:14:50 UTC (rev 32268)
@@ -49,6 +49,10 @@
 static int num_maps;
 static int max_maps;
+static void **omaps;
+static int num_omaps;
+static int max_omaps;
 static unsigned char *red, *grn, *blu;
 static unsigned char *set;
@@ -59,16 +63,6 @@
-static int handle_to_fd(void *handle)
-	return (int) handle;
-static void *fd_to_handle(int fd)
-	return (void *) fd;
 static void read_row(void *handle, char *buf, int type, int depth, int row)
 	int i;
@@ -586,7 +580,6 @@
 int open_output_map(const char *name, int res_type)
 	void *handle;
-	int fd;
 	G3d_setFileType(res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE);
@@ -599,21 +592,28 @@
 	if (!handle)
 		G_fatal_error(_("Unable to create raster map <%s>"), name);
-	fd = handle_to_fd(handle);
-	return fd;
+	if (num_omaps >= max_omaps)
+		max_omaps += 10;
+		omaps = G_realloc(omaps, max_omaps * sizeof(void *));
+	omaps[num_omaps] = handle;
+	return num_omaps++;
 void put_map_row(int fd, void *buf, int res_type)
-	void *handle = fd_to_handle(fd);
+	void *handle = omaps[fd];
 	write_row(handle, buf, res_type, current_depth, current_row);
 void close_output_map(int fd)
 	if (!G3d_closeCell(handle))
 		G_fatal_error(_("Unable to close output raster map"));
