[GRASS-SVN] r32308 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sat Jul 26 06:40:51 EDT 2008
Author: martinl
Date: 2008-07-26 06:40:51 -0400 (Sat, 26 Jul 2008)
New Revision: 32308
   grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: force map name to be fully qualified, trac #236 (merged from trunk, r32307)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2008-07-26 10:38:23 UTC (rev 32307)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2008-07-26 10:40:51 UTC (rev 32308)
@@ -19,6 +19,7 @@
 import globalvar
 import gcmd
+import grassenv
 try:
     import subprocess
 except:
@@ -56,38 +57,41 @@
     except:
         return None
-def GetLayerNameFromCmd(dcmd):
-    """Get layer name from GRASS command
+def GetLayerNameFromCmd(dcmd, fullyQualified=False):
+    """Get map name from GRASS command
     @param dcmd GRASS command (given as list)
+    @param fullyQualified change map name to be fully qualified
     @return map name
     @return '' if no map name found in command
     mapname = ''
-    for item in dcmd:
-        if 'map=' in item:
-            mapname = item.split('=')[1]
-        elif 'input=' in item:
-        elif 'red=' in item:
-        elif 'h_map=' in item:
-        elif 'reliefmap' in item:
-        elif 'd.grid' in item:
-            mapname = 'grid'
-        elif 'd.geodesic' in item:
-            mapname = 'geodesic'
-        elif 'd.rhumbline' in item:
-            mapname = 'rhumb'
-        elif 'labels=' in item:
-            mapname = item.split('=')[1]+' labels'
+    if 'd.grid' == dcmd[0]:
+        mapname = 'grid'
+    elif 'd.geodesic' in dcmd[0]:
+        mapname = 'geodesic'
+    elif 'd.rhumbline' in dcmd[0]:
+        mapname = 'rhumb'
+    elif 'labels=' in dcmd[0]:
+        mapname = dcmd[idx].split('=')[1]+' labels'
+    else:
+        for idx in range(len(dcmd)):
+            if 'map=' in dcmd[idx] or \
+                    'input=' in dcmd[idx] or \
+                    'red=' in dcmd[idx] or \
+                    'h_map=' in dcmd[idx] or \
+                    'reliefmap' in dcmd[idx]:
+                break
-        if mapname != '':
-            break
+        if idx < len(dcmd):
+            if fullyQualified and '@' not in mapname:
+                dcmd[idx] = dcmd[idx].split('=')[0] + '=' + \
+                    mapname +  '@' + grassenv.GetGRASSVariable('MAPSET')
     return mapname
 def ListOfCatsToRange(cats):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-26 10:38:23 UTC (rev 32307)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-26 10:40:51 UTC (rev 32308)
@@ -1057,7 +1057,7 @@
         # set layer text to map name
         if dcmd:
-            mapname = utils.GetLayerNameFromCmd(dcmd)
+            mapname = utils.GetLayerNameFromCmd(dcmd, fullyQualified=True)
             self.SetItemText(layer, mapname)
         # update layer data
