[GRASS-SVN] r32318 - grass/trunk/gui/wxpython/gui_modules
Sat Jul 26 16:24:16 EDT 2008
Author: martinl
Date: 2008-07-26 16:24:15 -0400 (Sat, 26 Jul 2008)
New Revision: 32318
Removed:
   grass/trunk/gui/wxpython/gui_modules/packages-uml.dia
   grass/trunk/gui/wxpython/gui_modules/packages-uml.svg
wxGUI: out-dated uml diagrams removed
Deleted: grass/trunk/gui/wxpython/gui_modules/packages-uml.dia
--- grass/trunk/gui/wxpython/gui_modules/packages-uml.dia	2008-07-26 20:23:32 UTC (rev 32317)
+++ grass/trunk/gui/wxpython/gui_modules/packages-uml.dia	2008-07-26 20:24:15 UTC (rev 32318)
@@ -1,4485 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<dia:diagram xmlns:dia="http://www.lysator.liu.se/~alla/dia/">
-  <dia:diagramdata>
-    <dia:attribute name="background">
-      <dia:color val="#ffffff"/>
-    </dia:attribute>
-    <dia:attribute name="pagebreak">
-      <dia:color val="#000099"/>
-    </dia:attribute>
-    <dia:attribute name="paper">
-      <dia:composite type="paper">
-        <dia:attribute name="name">
-          <dia:string>#A4#</dia:string>
-        </dia:attribute>
-        <dia:attribute name="tmargin">
-          <dia:real val="2.8222000598907471"/>
-        </dia:attribute>
-        <dia:attribute name="bmargin">
-        </dia:attribute>
-        <dia:attribute name="lmargin">
-        </dia:attribute>
-        <dia:attribute name="rmargin">
-        </dia:attribute>
-        <dia:attribute name="is_portrait">
-          <dia:boolean val="true"/>
-        </dia:attribute>
-        <dia:attribute name="scaling">
-          <dia:real val="1"/>
-        </dia:attribute>
-        <dia:attribute name="fitto">
-          <dia:boolean val="false"/>
-        </dia:attribute>
-      </dia:composite>
-    </dia:attribute>
-    <dia:attribute name="grid">
-      <dia:composite type="grid">
-        <dia:attribute name="width_x">
-        </dia:attribute>
-        <dia:attribute name="width_y">
-        </dia:attribute>
-        <dia:attribute name="visible_x">
-          <dia:int val="1"/>
-        </dia:attribute>
-        <dia:attribute name="visible_y">
-        </dia:attribute>
-        <dia:composite type="color"/>
-      </dia:composite>
-    </dia:attribute>
-    <dia:attribute name="color">
-      <dia:color val="#d8e5e5"/>
-    </dia:attribute>
-    <dia:attribute name="guides">
-      <dia:composite type="guides">
-        <dia:attribute name="hguides"/>
-        <dia:attribute name="vguides"/>
-      </dia:composite>
-    </dia:attribute>
-  </dia:diagramdata>
-  <dia:layer name="Background" visible="true">
-    <dia:object type="UML - LargePackage" version="0" id="O0">
-      <dia:attribute name="obj_pos">
-        <dia:point val="5,67"/>
-      </dia:attribute>
-      <dia:attribute name="obj_bb">
-        <dia:rectangle val="4.95,65.95;33.05,80.05"/>
-      </dia:attribute>
-      <dia:attribute name="elem_corner">
-      </dia:attribute>
-      <dia:attribute name="elem_width">
-        <dia:real val="28"/>
-      </dia:attribute>
-      <dia:attribute name="elem_height">
-        <dia:real val="13"/>
-      </dia:attribute>
-      <dia:attribute name="line_colour">
-        <dia:color val="#000000"/>
-      </dia:attribute>
-      <dia:attribute name="fill_colour">
-      </dia:attribute>
-      <dia:attribute name="stereotype">
-        <dia:string>##</dia:string>
-      </dia:attribute>
-        <dia:string>#gismutils#</dia:string>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - LargePackage" version="0" id="O1">
-        <dia:point val="5,17"/>
-      </dia:attribute>
-        <dia:rectangle val="4.95,15.95;53.05,64.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="48"/>
-      </dia:attribute>
-        <dia:real val="47"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#render#</dia:string>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O2">
-        <dia:point val="33,21"/>
-      </dia:attribute>
-        <dia:rectangle val="32.95,20.95;51.85,34.85"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="18.800000000000001"/>
-      </dia:attribute>
-        <dia:real val="13.799999999999999"/>
-      </dia:attribute>
-        <dia:string>#MapLayer#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:attribute name="comment">
-      </dia:attribute>
-      <dia:attribute name="abstract">
-      </dia:attribute>
-      <dia:attribute name="suppress_attributes">
-      </dia:attribute>
-      <dia:attribute name="suppress_operations">
-      </dia:attribute>
-      <dia:attribute name="visible_attributes">
-      </dia:attribute>
-      <dia:attribute name="visible_operations">
-      </dia:attribute>
-      <dia:attribute name="visible_comments">
-      </dia:attribute>
-      <dia:attribute name="wrap_operations">
-      </dia:attribute>
-      <dia:attribute name="wrap_after_char">
-        <dia:int val="40"/>
-      </dia:attribute>
-      <dia:attribute name="line_color">
-      </dia:attribute>
-      <dia:attribute name="fill_color">
-      </dia:attribute>
-      <dia:attribute name="text_color">
-      </dia:attribute>
-      <dia:attribute name="normal_font">
-        <dia:font family="monospace" style="0" name="Courier"/>
-      </dia:attribute>
-      <dia:attribute name="abstract_font">
-        <dia:font family="monospace" style="88" name="Courier"/>
-      </dia:attribute>
-      <dia:attribute name="polymorphic_font">
-        <dia:font family="monospace" style="8" name="Courier"/>
-      </dia:attribute>
-      <dia:attribute name="classname_font">
-        <dia:font family="sans" style="80" name="Helvetica"/>
-      </dia:attribute>
-      <dia:attribute name="abstract_classname_font">
-        <dia:font family="sans" style="88" name="Helvetica"/>
-      </dia:attribute>
-      <dia:attribute name="comment_font">
-        <dia:font family="sans" style="8" name="Helvetica"/>
-      </dia:attribute>
-      <dia:attribute name="font_height">
-        <dia:real val="0.80000000000000004"/>
-      </dia:attribute>
-      <dia:attribute name="polymorphic_font_height">
-      </dia:attribute>
-      <dia:attribute name="abstract_font_height">
-      </dia:attribute>
-      <dia:attribute name="classname_font_height">
-      </dia:attribute>
-      <dia:attribute name="abstract_classname_font_height">
-      </dia:attribute>
-      <dia:attribute name="comment_font_height">
-      </dia:attribute>
-      <dia:attribute name="attributes">
-        <dia:composite type="umlattribute">
-            <dia:string>#cmd#</dia:string>
-          </dia:attribute>
-          <dia:attribute name="type">
-            <dia:string>#string#</dia:string>
-          </dia:attribute>
-          <dia:attribute name="value">
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="visibility">
-            <dia:enum val="0"/>
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="class_scope">
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#name#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#layer name#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#mapset#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#type#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#active#</dia:string>
-          </dia:attribute>
-            <dia:string>#boolean#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#hidden#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#opacity#</dia:string>
-          </dia:attribute>
-            <dia:string>#integer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#mapfile#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#maskfile#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      <dia:attribute name="operations">
-        <dia:composite type="umloperation">
-            <dia:string>#init#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:enum val="1"/>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="inheritance_type">
-            <dia:enum val="2"/>
-          </dia:attribute>
-          <dia:attribute name="query">
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="parameters">
-            <dia:composite type="umlparameter">
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              <dia:attribute name="kind">
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#parameters#</dia:string>
-              </dia:attribute>
-                <dia:string>#dictionary#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#renderRasterLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#Stores d.rast command with all parameters in the cmd variable#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="parameters"/>
-        </dia:composite>
-            <dia:string>#renderVectorLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#Stores d.vect command with all parameters in the self.cmd variable#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#Render#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#name of rendered image or None#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#Runs all d.* commands#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      <dia:attribute name="template">
-      </dia:attribute>
-      <dia:attribute name="templates"/>
-    </dia:object>
-    <dia:object type="UML - Association" version="0" id="O3">
-        <dia:point val="42.4,21"/>
-      </dia:attribute>
-        <dia:rectangle val="17.15,17.25;44.5,21.75"/>
-      </dia:attribute>
-      <dia:attribute name="orth_points">
-        <dia:point val="42.4,18"/>
-        <dia:point val="17.9,18"/>
-        <dia:point val="17.9,21"/>
-      </dia:attribute>
-      <dia:attribute name="orth_orient">
-      </dia:attribute>
-      <dia:attribute name="autorouting">
-      </dia:attribute>
-      </dia:attribute>
-      <dia:attribute name="direction">
-      </dia:attribute>
-      <dia:attribute name="ends">
-        <dia:composite>
-          <dia:attribute name="role">
-            <dia:string>#layer#</dia:string>
-          </dia:attribute>
-          <dia:attribute name="multiplicity">
-            <dia:string>#0..*#</dia:string>
-          </dia:attribute>
-          <dia:attribute name="arrow">
-          </dia:attribute>
-          <dia:attribute name="aggregate">
-          </dia:attribute>
-        </dia:composite>
-        <dia:composite>
-          </dia:attribute>
-            <dia:string>#1#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      <dia:connections>
-        <dia:connection handle="0" to="O2" connection="1"/>
-        <dia:connection handle="1" to="O5" connection="1"/>
-      </dia:connections>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O4">
-        <dia:point val="5,68"/>
-      </dia:attribute>
-        <dia:rectangle val="4.95,67.95;19.65,75.65"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="14.6"/>
-      </dia:attribute>
-        <dia:real val="7.5999999999999996"/>
-      </dia:attribute>
-        <dia:string>#LayerTree#</dia:string>
-      </dia:attribute>
-        <dia:string>#wx.lib.customtreectrl.CustomTreeCtrl#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:attribute name="attributes"/>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#...#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#AddLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#idx#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#layertype#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onCollapseNode#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onExpandNone#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onActiveLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onChangeSel#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O5">
-        <dia:point val="5,21"/>
-      </dia:attribute>
-        <dia:rectangle val="4.95,20.95;30.85,62.85"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="25.800000000000001"/>
-      </dia:attribute>
-        <dia:real val="41.800000000000011"/>
-      </dia:attribute>
-        <dia:string>#Map#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-            <dia:string>#env#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#verbosity#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#width#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#height#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#windfile#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#region#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-          </dia:attribute>
-            <dia:string>#list#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#renderRegion#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#initRegion#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#initMonSize#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#initEnv#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#adjustRegion#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#GetRegion#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#SetRegion#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#GRASS_REGION or string#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#GetListOfLayers#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#list of layers#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#None#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#rendered image filename#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#force#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#AddRasterLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#added layer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#catlist#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#vallist#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#l_active#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#True#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#l_hidden#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#False#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#l_opacity#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#l_render#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#AddGraphLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#graph#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#color#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#255:0:0#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#coordsinmapunits#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#AddVectorLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#display#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#shape#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#attrcol#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#icon#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#basic/circle#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#size#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#8#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#cats#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#where#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#wcolumn#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#wscale#</dia:string>
-              </dia:attribute>
-                <dia:string>#inreger#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#000:000:000#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#fcolor#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#200:200:200#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#rgb_column#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#GRASSRBG#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#llayer#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#lcolor#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#256:000:000#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#bgcolor#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#bcolor#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#lsize#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#font#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#xref#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#left#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#yref#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-                <dia:string>#center#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#minreg#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#maxreg#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#colorfromtable#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#randomcolor#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#catasid#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#PopLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#Layer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#id#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#GetLayerIndex#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:string>#index or None#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#Clean#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O6">
-        <dia:point val="21,68"/>
-      </dia:attribute>
-        <dia:rectangle val="20.95,67.95;28.65,74.85"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="6.8000000000000007"/>
-      </dia:attribute>
-        <dia:string>#GMConsole#</dia:string>
-      </dia:attribute>
-        <dia:string>#wx.Panel#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#getGRASSCmd#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#runCmd#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#event#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#clearHistory#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#saveHistory#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - SmallPackage" version="0" id="O7">
-        <dia:point val="6,78"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,77.05;14.7,79.45"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="8.6500000000000004"/>
-      </dia:attribute>
-        <dia:real val="1.3999999999999999"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:attribute name="text">
-        <dia:composite type="text">
-          <dia:attribute name="string">
-            <dia:string>#GetTempFile (pref=None)#</dia:string>
-          </dia:attribute>
-          <dia:attribute name="font">
-          </dia:attribute>
-          <dia:attribute name="height">
-          </dia:attribute>
-          <dia:attribute name="pos">
-            <dia:point val="6.3,78.9"/>
-          </dia:attribute>
-          </dia:attribute>
-          <dia:attribute name="alignment">
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      <dia:childnode parent="O0"/>
-    </dia:object>
-    <dia:object type="UML - LargePackage" version="0" id="O8">
-        <dia:point val="5,83"/>
-      </dia:attribute>
-        <dia:rectangle val="4.95,81.95;24.05,96.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="19"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#toolbars#</dia:string>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O9">
-        <dia:point val="6,84"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,83.95;14,87.65"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="7.9499999999999993"/>
-      </dia:attribute>
-        <dia:real val="3.5999999999999996"/>
-      </dia:attribute>
-        <dia:string>#MapToolBar#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#mapdisplay#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#map#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onSelect#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:childnode parent="O8"/>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O10">
-        <dia:point val="6,89"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,88.95;12.95,95.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="6.8999999999999995"/>
-      </dia:attribute>
-        <dia:real val="6"/>
-      </dia:attribute>
-        <dia:string>#DigitToolbar#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#parent#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#initToolbar#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#onPoint#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#AddPoint#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-                <dia:string>#x#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-                <dia:string>#y#</dia:string>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-            <dia:string>#getListOfLayers#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - LargePackage" version="0" id="O11">
-        <dia:point val="5,99"/>
-      </dia:attribute>
-        <dia:rectangle val="4.95,97.95;19.75,125.45"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="14.700000000000003"/>
-      </dia:attribute>
-        <dia:real val="26.399999999999999"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#grassenv#</dia:string>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O12">
-        <dia:point val="6,100"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,99.95;14,103.05"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="3"/>
-      </dia:attribute>
-        <dia:string>#NotInGRASSSession#</dia:string>
-      </dia:attribute>
-        <dia:string>#Exception#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:attribute name="operations"/>
-      </dia:attribute>
-      <dia:childnode parent="O11"/>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O13">
-        <dia:point val="6,104"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,103.95;14.4,107.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="8.3499999999999996"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#CouldNotStartMonitor#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O14">
-        <dia:point val="6,112"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,111.95;12.8,115.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="6.75"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#CouldNotExecute#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O15">
-        <dia:point val="6,108"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,107.95;14.35,111.05"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="8.3000000000000007"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:string>#CouldNotStopMonitor#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - SmallPackage" version="0" id="O16">
-        <dia:point val="6,117"/>
-      </dia:attribute>
-        <dia:rectangle val="5.95,116.05;8.55,118.45"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="2.5"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-            <dia:point val="6.3,117.9"/>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-    </dia:object>
-    <dia:object type="UML - Class" version="0" id="O17">
-        <dia:point val="34,39"/>
-      </dia:attribute>
-        <dia:rectangle val="33.95,38.95;44.45,42.45"/>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:real val="10.4"/>
-      </dia:attribute>
-        <dia:real val="3.3999999999999999"/>
-      </dia:attribute>
-        <dia:string>#GRASSLayer#</dia:string>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-            <dia:string>#params#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-              </dia:attribute>
-            </dia:composite>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      </dia:attribute>
-      <dia:childnode parent="O1"/>
-    </dia:object>
-    <dia:object type="UML - Association" version="0" id="O18">
-        <dia:point val="39.2,39"/>
-      </dia:attribute>
-        <dia:rectangle val="38.4,34.05;46.25,39.8"/>
-      </dia:attribute>
-        <dia:point val="39.2,36.9"/>
-        <dia:point val="42.4,36.9"/>
-        <dia:point val="42.4,34.8"/>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-      </dia:attribute>
-        <dia:composite>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-        <dia:composite>
-            <dia:string>#grassLayer#</dia:string>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-          </dia:attribute>
-        </dia:composite>
-      </dia:attribute>
-      <dia:connections>
-        <dia:connection handle="0" to="O17" connection="1"/>
-        <dia:connection handle="1" to="O2" connection="6"/>
-    </dia:object>
-  </dia:layer>
-</dia:diagram>
Deleted: grass/trunk/gui/wxpython/gui_modules/packages-uml.svg
--- grass/trunk/gui/wxpython/gui_modules/packages-uml.svg	2008-07-26 20:23:32 UTC (rev 32317)
+++ grass/trunk/gui/wxpython/gui_modules/packages-uml.svg	2008-07-26 20:24:15 UTC (rev 32318)
@@ -1,218 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.0//EN" "http://www.w3.org/TR/2001/PR-SVG-20010719/DTD/svg10.dtd">
-<svg width="49cm" height="110cm" viewBox="4 15 49 110">
-  <rect style="fill: #ffffff" x="5" y="67" width="28" height="13"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="67" width="28" height="13"/>
-  <rect style="fill: #ffffff" x="5" y="66" width="3.35" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="66" width="3.35" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.1" y="66.75">gismutils</text>
-  <rect style="fill: #ffffff" x="5" y="17" width="48" height="47"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="17" width="48" height="47"/>
-  <rect style="fill: #ffffff" x="5" y="16" width="2.3" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="16" width="2.3" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.1" y="16.75">render</text>
-  <rect style="fill: #ffffff" x="33" y="21" width="18.8" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="33" y="21" width="18.8" height="1.4"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="42.4" y="22">MapLayer</text>
-  <rect style="fill: #ffffff" x="33" y="22.4" width="18.8" height="7.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="33" y="22.4" width="18.8" height="7.4"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="23.1">+cmd: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="23.9">+name: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="24.7">+mapset: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="25.5">+type: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="26.3">+active: boolean</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="27.1">+hidden: boolean</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="27.9">+opacity: integer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="28.7">+mapfile: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="29.5">+maskfile: string</text>
-  <rect style="fill: #ffffff" x="33" y="29.8" width="18.8" height="5"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="33" y="29.8" width="18.8" height="5"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="30.5">-init(type:string,name:string,mapset:string,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="31.1">      active:boolean,hidden:boolean,opacity:boolean,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="31.7">      parameters:dictionary)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="32.5">-renderRasterLayer()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="33.3">-renderVectorLayer()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="33.15" y="34.1">+Render(): name of rendered image or None</text>
-  <polyline style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="42.4,20.7764 42.4,18 17.9,18 17.9,21 "/>
-  <polyline style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="42,20.0882 42.4,20.8882 42.8,20.0882 "/>
-  <polygon style="fill: #ffffff" points="17.9,21 17.66,20.3 17.9,19.6 18.14,20.3 "/>
-  <polygon style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="17.9,21 17.66,20.3 17.9,19.6 18.14,20.3 "/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="30.15" y="17.85"></text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="42.75" y="20">layer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="42.75" y="20.8">0..*</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="18.25" y="20.2">1</text>
-  <rect style="fill: #ffffff" x="5" y="68" width="14.6" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="68" width="14.6" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="12.3" y="68.7">&lt;&lt;wx.lib.customtreectrl.CustomTreeCtrl&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="12.3" y="69.7">LayerTree</text>
-  <rect style="fill: #ffffff" x="5" y="70.2" width="14.6" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="70.2" width="14.6" height="0.4"/>
-  <rect style="fill: #ffffff" x="5" y="70.6" width="14.6" height="5"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="70.6" width="14.6" height="5"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="71.3">-init(...)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="72.1">+AddLayer(idx:integer,layertype:string)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="72.9">+onCollapseNode()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="73.7">+onExpandNone()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="74.5">+onActiveLayer()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="75.3">+onChangeSel()</text>
-  <rect style="fill: #ffffff" x="5" y="21" width="25.8" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="21" width="25.8" height="1.4"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="17.9" y="22">Map</text>
-  <rect style="fill: #ffffff" x="5" y="22.4" width="25.8" height="7.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="22.4" width="25.8" height="7.4"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="23.1">+env: dictionary</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="23.9">+verbosity: integer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="24.7">+width: integer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="25.5">+height: integer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="26.3">+windfile: string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="27.1">+region: dictionary</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="27.9">+layer: list</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="28.7">+renderRegion: dictionary</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="29.5">+mapfile: string</text>
-  <rect style="fill: #ffffff" x="5" y="29.8" width="25.8" height="33"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="29.8" width="25.8" height="33"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="30.5">-init()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="31.3">-initRegion()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="32.1">-initMonSize()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="32.9">-initEnv()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="33.7">-adjustRegion()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="34.5">+GetRegion(): region</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="35.3">+SetRegion(): GRASS_REGION or string</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="36.1">+GetListOfLayers(type:string=None,active:boolean=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="36.7">                 hidden:boolean=None): list of layers</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="37.5">+Render(force:boolean=None): rendered image filename</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="38.3">+AddRasterLayer(name:string,mapset:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="38.9">                catlist:string=None,vallist:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="39.5">                l_active:boolean=True,l_hidden:boolean=False,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="40.1">                l_opacity:integer=1,l_render:boolean=False): added layer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="40.9">+AddGraphLayer(name:string,graph:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="41.5">               color:string=255:0:0,coordsinmapunits:boolean=False,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="42.1">               l_active:boolean=True,l_hidden:boolean=False,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="42.7">               l_opacity:integer=1,l_render:boolean=False): added layer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="43.5">+AddVectorLayer(name:string,mapset:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="44.1">                type:string,display:string=shape,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="44.7">                attrcol:string=None,icon:string=basic/circle,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="45.3">                size:integer=8,layer:integer=1,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="45.9">                cats:string=None,where:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="46.5">                width:integer=1,wcolumn:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="47.1">                wscale:inreger=1,color:string=000:000:000,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="47.7">                fcolor:string=200:200:200,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="48.3">                rgb_column:string=GRASSRBG,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="48.9">                llayer:integer=1,lcolor:string=256:000:000,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="49.5">                bgcolor:string=None,bcolor:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="50.1">                lsize:integer=8,font:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="50.7">                xref:string=left,yref:string=center,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="51.3">                minreg:string=None,maxreg:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="51.9">                colorfromtable:boolean=False,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="52.5">                randomcolor:boolean=False,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="53.1">                catasid:boolean=False,l_active:boolean=True,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="53.7">                l_hidden:boolean=False,l_opacity:boolean=1,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="54.3">                l_render:boolean=False): added layer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="55.1">+PopLayer(name:string=None,mapset:string=None,</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="55.7">          id:integer=None): Layer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="56.5">+GetLayerIndex(name:string,mapset:string=None): index or None</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.15" y="57.3">+Clean()</text>
-  <rect style="fill: #ffffff" x="21" y="68" width="7.6" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="21" y="68" width="7.6" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="24.8" y="68.7">&lt;&lt;wx.Panel&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="24.8" y="69.7">GMConsole</text>
-  <rect style="fill: #ffffff" x="21" y="70.2" width="7.6" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="21" y="70.2" width="7.6" height="0.4"/>
-  <rect style="fill: #ffffff" x="21" y="70.6" width="7.6" height="4.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="21" y="70.6" width="7.6" height="4.2"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="21.15" y="71.3">-init()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="21.15" y="72.1">+getGRASSCmd()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="21.15" y="72.9">+runCmd(event)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="21.15" y="73.7">+clearHistory(event)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="21.15" y="74.5">+saveHistory(event)</text>
-  <rect style="fill: #ffffff" x="6" y="78" width="8.65" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="78" width="8.65" height="1.4"/>
-  <rect style="fill: #ffffff" x="6" y="77.1" width="1.5" height="0.9"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="77.1" width="1.5" height="0.9"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.3" y="78.9">GetTempFile (pref=None)</text>
-  <rect style="fill: #ffffff" x="5" y="83" width="19" height="13"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="83" width="19" height="13"/>
-  <rect style="fill: #ffffff" x="5" y="82" width="3" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="82" width="3" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.1" y="82.75">toolbars</text>
-  <rect style="fill: #ffffff" x="6" y="84" width="7.95" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="84" width="7.95" height="1.4"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="9.975" y="85">MapToolBar</text>
-  <rect style="fill: #ffffff" x="6" y="85.4" width="7.95" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="85.4" width="7.95" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="85.8" width="7.95" height="1.8"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="85.8" width="7.95" height="1.8"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="86.5">-init(mapdisplay,map)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="87.3">+onSelect(event)</text>
-  <rect style="fill: #ffffff" x="6" y="89" width="6.9" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="89" width="6.9" height="1.4"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="9.45" y="90">DigitToolbar</text>
-  <rect style="fill: #ffffff" x="6" y="90.4" width="6.9" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="90.4" width="6.9" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="90.8" width="6.9" height="4.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="90.8" width="6.9" height="4.2"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="91.5">-init(parent,map)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="92.3">+initToolbar()</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="93.1">+onPoint(event)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="93.9">+AddPoint(x,y)</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.15" y="94.7">+getListOfLayers()</text>
-  <rect style="fill: #ffffff" x="5" y="99" width="14.7" height="26.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="99" width="14.7" height="26.4"/>
-  <rect style="fill: #ffffff" x="5" y="98" width="3" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="5" y="98" width="3" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="5.1" y="98.75">grassenv</text>
-  <rect style="fill: #ffffff" x="6" y="100" width="7.95" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="100" width="7.95" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="9.975" y="100.7">&lt;&lt;Exception&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="9.975" y="101.7">NotInGRASSSession</text>
-  <rect style="fill: #ffffff" x="6" y="102.2" width="7.95" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="102.2" width="7.95" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="102.6" width="7.95" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="102.6" width="7.95" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="104" width="8.35" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="104" width="8.35" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="10.175" y="104.7">&lt;&lt;Exception&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="10.175" y="105.7">CouldNotStartMonitor</text>
-  <rect style="fill: #ffffff" x="6" y="106.2" width="8.35" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="106.2" width="8.35" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="106.6" width="8.35" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="106.6" width="8.35" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="112" width="6.75" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="112" width="6.75" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="9.375" y="112.7">&lt;&lt;Exception&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="9.375" y="113.7">CouldNotExecute</text>
-  <rect style="fill: #ffffff" x="6" y="114.2" width="6.75" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="114.2" width="6.75" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="114.6" width="6.75" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="114.6" width="6.75" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="108" width="8.3" height="2.2"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="108" width="8.3" height="2.2"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="10.15" y="108.7">&lt;&lt;Exception&gt;&gt;</text>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="10.15" y="109.7">CouldNotStopMonitor</text>
-  <rect style="fill: #ffffff" x="6" y="110.2" width="8.3" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="110.2" width="8.3" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="110.6" width="8.3" height="0.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="110.6" width="8.3" height="0.4"/>
-  <rect style="fill: #ffffff" x="6" y="117" width="2.5" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="117" width="2.5" height="1.4"/>
-  <rect style="fill: #ffffff" x="6" y="116.1" width="1.5" height="0.9"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="6" y="116.1" width="1.5" height="0.9"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="6.3" y="117.9">env</text>
-  <rect style="fill: #ffffff" x="34" y="39" width="10.4" height="1.4"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="34" y="39" width="10.4" height="1.4"/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 1; font-family: sans; font-style: normal; font-weight: 700" x="39.2" y="40">GRASSLayer</text>
-  <rect style="fill: #ffffff" x="34" y="40.4" width="10.4" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="34" y="40.4" width="10.4" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="34.15" y="41.1">+params: dictionary</text>
-  <rect style="fill: #ffffff" x="34" y="41.4" width="10.4" height="1"/>
-  <rect style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" x="34" y="41.4" width="10.4" height="1"/>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="34.15" y="42.1">-init(parameters:dictionary)</text>
-  <polyline style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="39.2,38.7764 39.2,36.9 42.4,36.9 42.4,34.8 "/>
-  <polyline style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="38.8,38.0882 39.2,38.8882 39.6,38.0882 "/>
-  <polygon style="fill: #ffffff" points="42.4,34.8 42.64,35.5 42.4,36.2 42.16,35.5 "/>
-  <polygon style="fill: none; fill-opacity:0; stroke-width: 0.1; stroke: #000000" points="42.4,34.8 42.64,35.5 42.4,36.2 42.16,35.5 "/>
-  <text style="fill: #000000; text-anchor:middle; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="40.8" y="36.75"></text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="39.55" y="38.8">1</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="42.75" y="37.6">grassLayer</text>
-  <text style="fill: #000000; text-anchor:start; font-size: 0.8; font-family: monospace; font-style: normal; font-weight: normal" x="42.75" y="38.4">1</text>
-</svg>
