[GRASS-SVN] r32323 - grass/trunk
Sat Jul 26 18:52:20 EDT 2008
Author: glynn
Date: 2008-07-26 18:52:19 -0400 (Sat, 26 Jul 2008)
New Revision: 32323
   grass/trunk/aclocal.m4
   grass/trunk/configure
   grass/trunk/configure.in
Add --with-tcltk-framework=
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2008-07-26 21:04:11 UTC (rev 32322)
+++ grass/trunk/aclocal.m4	2008-07-26 22:52:19 UTC (rev 32323)
@@ -50,6 +50,24 @@
 fi
+AC_DEFUN([LOC_CHECK_FRAMEWORK_PATH],[
+AC_MSG_CHECKING(for location of $2 framework)
+case "$with_$1_framework" in
+y | ye | yes | n | no)
+	AC_MSG_ERROR([*** You must supply a directory to --with-$1-framework.])
+esac
+AC_MSG_RESULT($with_$1_framework)
+if test -n "$with_$1_framework"; then
+    if test -d $with_$1_framework; then
+        $3="$$3 -F$with_$1_framework"
+    else
+        AC_MSG_ERROR([*** $2 framework directory $dir does not exist.])
+    fi
+fi
 AC_DEFUN([LOC_CHECK_SHARE_PATH],[
 AC_MSG_CHECKING(for location of $2 data files)
 case "$with_$1_share" in
@@ -225,6 +243,11 @@
 LOC_PAD([  --with-$1-share=DIR])[$2 data files are in DIR])
+AC_DEFUN([LOC_ARG_WITH_FRAMEWORK],[
+AC_ARG_WITH($1-framework,
+LOC_PAD([  --with-$1-framework=DIR])[$2 framework is in DIR])
 AC_DEFUN([LOC_OPTIONAL],[
 AC_MSG_CHECKING(whether to build $1)
 if test -n "$USE_$2" ; then
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-07-26 21:04:11 UTC (rev 32322)
+++ grass/trunk/configure	2008-07-26 22:52:19 UTC (rev 32323)
@@ -111,6 +111,9 @@
 ac_help="$ac_help
   --with-tcltk-libs=DIRS  Tcl/Tk library files are in DIRS"
 ac_help="$ac_help
+  --with-tcltk-framework=DIR
+                          Tcl/Tk framework is in DIR"
+ac_help="$ac_help
   --with-postgres-includes=DIRS
                           PostgreSQL include files are in DIRS"
 ac_help="$ac_help
@@ -721,7 +724,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:725: checking host system type" >&5
+echo "configure:728: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -744,7 +747,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:748: checking for $ac_word" >&5
+echo "configure:751: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -771,7 +774,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:775: checking for $ac_word" >&5
+echo "configure:778: checking for $ac_word" >&5
@@ -819,7 +822,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:823: checking for $ac_word" >&5
+echo "configure:826: checking for $ac_word" >&5
@@ -848,7 +851,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:852: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:855: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -859,12 +862,12 @@
 cat > conftest.$ac_ext << EOF
-#line 863 "configure"
+#line 866 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -890,19 +893,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:894: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:897: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:899: checking whether we are using GNU C" >&5
+echo "configure:902: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:906: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -920,7 +923,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:924: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:927: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -949,10 +952,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:953: checking for Cygwin environment" >&5
+echo "configure:956: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 956 "configure"
+#line 959 "configure"
 int main() {
@@ -963,7 +966,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -979,17 +982,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:983: checking for mingw32 environment" >&5
+echo "configure:986: checking for mingw32 environment" >&5
-#line 986 "configure"
+#line 989 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1007,7 +1010,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1011: checking for executable suffix" >&5
+echo "configure:1014: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1026,23 +1029,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1030: checking for full floating-point support" >&5
+echo "configure:1033: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1035: checking whether "cc -mieee" works" >&5
+echo "configure:1038: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1039 "configure"
+#line 1042 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1046: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1058,7 +1061,7 @@
 else
-#line 1062 "configure"
+#line 1065 "configure"
 #include <float.h>
@@ -1072,7 +1075,7 @@
 EOF
-if { (eval echo configure:1076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1085,14 +1088,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1089: checking for full floating-point support with -mieee" >&5
+echo "configure:1092: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1096 "configure"
+#line 1099 "configure"
 #include <float.h>
@@ -1106,7 +1109,7 @@
 EOF
-if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1143,7 +1146,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1147: checking for $ac_word" >&5
+echo "configure:1150: checking for $ac_word" >&5
 case "$pwd" in
@@ -1181,7 +1184,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1185: checking for source directory" >&5
+echo "configure:1188: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1192,7 +1195,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1196: checking for build directory" >&5
+echo "configure:1199: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1277,7 +1280,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1281: checking for MacOSX App" >&5
+echo "configure:1284: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1300,7 +1303,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1304: checking how to build libraries" >&5
+echo "configure:1307: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1343,7 +1346,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1347: checking for $ac_word" >&5
+echo "configure:1350: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1368,7 +1371,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1372: checking how to run the C preprocessor" >&5
+echo "configure:1375: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1381,13 +1384,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1385 "configure"
+#line 1388 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1398,13 +1401,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1402 "configure"
+#line 1405 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1408: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1415,13 +1418,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1419 "configure"
+#line 1422 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1449,7 +1452,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1453: checking if 64bit support is requested" >&5
+echo "configure:1456: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1469,7 +1472,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1473: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1476: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1493,7 +1496,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1497: checking system version (for dynamic loading)" >&5
+echo "configure:1500: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1519,13 +1522,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1523: checking for dlopen in -ldl" >&5
+echo "configure:1526: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1529 "configure"
+#line 1532 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1536,7 +1539,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1583,7 +1586,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1587: checking for $ac_word" >&5
+echo "configure:1590: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1712,13 +1715,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1716: checking for gettimeofday in -lbsd" >&5
+echo "configure:1719: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1722 "configure"
+#line 1725 "configure"
@@ -1729,7 +1732,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1770,13 +1773,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1774: checking for inet_ntoa in -lbind" >&5
+echo "configure:1777: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1780 "configure"
+#line 1783 "configure"
@@ -1787,7 +1790,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1848,13 +1851,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1852: checking for shl_load in -ldld" >&5
+echo "configure:1855: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1858 "configure"
+#line 1861 "configure"
@@ -1865,7 +1868,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1930,13 +1933,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1934: checking for shl_load in -ldld" >&5
+echo "configure:1937: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1940 "configure"
+#line 1943 "configure"
@@ -1947,7 +1950,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2069,15 +2072,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2073: checking for dld.h" >&5
+echo "configure:2076: checking for dld.h" >&5
-#line 2076 "configure"
+#line 2079 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2081: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2137,15 +2140,15 @@
 	    else
-echo "configure:2141: checking for dld.h" >&5
+echo "configure:2144: checking for dld.h" >&5
-#line 2144 "configure"
+#line 2147 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2242,9 +2245,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2246: checking for ELF" >&5
+echo "configure:2249: checking for ELF" >&5
-#line 2248 "configure"
+#line 2251 "configure"
 #ifdef __ELF__
@@ -2274,15 +2277,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2278: checking for dlfcn.h" >&5
+echo "configure:2281: checking for dlfcn.h" >&5
-#line 2281 "configure"
+#line 2284 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2306,9 +2309,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2310: checking for ELF" >&5
+echo "configure:2313: checking for ELF" >&5
-#line 2312 "configure"
+#line 2315 "configure"
 #ifdef __ELF__
@@ -2632,17 +2635,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2636: checking for ld accepts -Bexport flag" >&5
+echo "configure:2639: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2639 "configure"
+#line 2642 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3132,7 +3135,15 @@
+# Check whether --with-tcltk-framework or --without-tcltk-framework was given.
+if test "${with_tcltk_framework+set}" = set; then
+  withval="$with_tcltk_framework"
+fi
 # Check whether --with-postgres-includes or --without-postgres-includes was given.
 if test "${with_postgres_includes+set}" = set; then
   withval="$with_postgres_includes"
@@ -3387,7 +3398,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3391: checking for additional include dirs" >&5
+echo "configure:3402: checking for additional include dirs" >&5
 case "$with_includes" in
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3410,7 +3421,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3414: checking for additional library dirs" >&5
+echo "configure:3425: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3444,7 +3455,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3448: checking for a BSD compatible install" >&5
+echo "configure:3459: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3497,7 +3508,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3501: checking for $ac_word" >&5
+echo "configure:3512: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3528,13 +3539,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3532: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3543: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3538 "configure"
+#line 3549 "configure"
@@ -3545,7 +3556,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3570,7 +3581,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3574: checking for $ac_word" >&5
+echo "configure:3585: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3610,7 +3621,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3614: checking for $ac_word" >&5
+echo "configure:3625: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3641,7 +3652,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3645: checking for $ac_word" >&5
+echo "configure:3656: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3679,7 +3690,7 @@
-echo "configure:3683: checking for $ac_word" >&5
+echo "configure:3694: checking for $ac_word" >&5
@@ -3708,7 +3719,7 @@
-echo "configure:3712: checking for $ac_word" >&5
+echo "configure:3723: checking for $ac_word" >&5
@@ -3739,7 +3750,7 @@
-echo "configure:3743: checking for $ac_word" >&5
+echo "configure:3754: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3768,7 +3779,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3772: checking for $ac_word" >&5
+echo "configure:3783: checking for $ac_word" >&5
 case "$PERL" in
@@ -3799,10 +3810,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3803: checking for ANSI C header files" >&5
+echo "configure:3814: checking for ANSI C header files" >&5
-#line 3806 "configure"
+#line 3817 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3810,7 +3821,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3827,7 +3838,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3831 "configure"
+#line 3842 "configure"
 #include <string.h>
 EOF
@@ -3845,7 +3856,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3849 "configure"
+#line 3860 "configure"
 #include <stdlib.h>
 EOF
@@ -3866,7 +3877,7 @@
 else
-#line 3870 "configure"
+#line 3881 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3877,7 +3888,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3904,15 +3915,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3908: checking for $ac_hdr" >&5
+echo "configure:3919: checking for $ac_hdr" >&5
-#line 3911 "configure"
+#line 3922 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3941,15 +3952,15 @@
 do
-echo "configure:3945: checking for $ac_hdr" >&5
+echo "configure:3956: checking for $ac_hdr" >&5
-#line 3948 "configure"
+#line 3959 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3978,15 +3989,15 @@
 do
-echo "configure:3982: checking for $ac_hdr" >&5
+echo "configure:3993: checking for $ac_hdr" >&5
-#line 3985 "configure"
+#line 3996 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4015,15 +4026,15 @@
 do
-echo "configure:4019: checking for $ac_hdr" >&5
+echo "configure:4030: checking for $ac_hdr" >&5
-#line 4022 "configure"
+#line 4033 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4052,15 +4063,15 @@
 do
-echo "configure:4056: checking for $ac_hdr" >&5
+echo "configure:4067: checking for $ac_hdr" >&5
-#line 4059 "configure"
+#line 4070 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4086,10 +4097,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4090: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4101: checking whether time.h and sys/time.h may both be included" >&5
-#line 4093 "configure"
+#line 4104 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4098,7 +4109,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4118,10 +4129,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4122: checking for off_t" >&5
+echo "configure:4133: checking for off_t" >&5
-#line 4125 "configure"
+#line 4136 "configure"
 #if STDC_HEADERS
@@ -4148,10 +4159,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4152: checking for uid_t in sys/types.h" >&5
+echo "configure:4163: checking for uid_t in sys/types.h" >&5
-#line 4155 "configure"
+#line 4166 "configure"
 EOF
@@ -4179,10 +4190,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4183: checking return type of signal handlers" >&5
+echo "configure:4194: checking return type of signal handlers" >&5
-#line 4186 "configure"
+#line 4197 "configure"
 #include <signal.h>
@@ -4199,7 +4210,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4203: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4214: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4217,10 +4228,10 @@
-echo "configure:4221: checking for Cygwin environment" >&5
+echo "configure:4232: checking for Cygwin environment" >&5
-#line 4224 "configure"
+#line 4235 "configure"
 int main() {
@@ -4231,7 +4242,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4249,10 +4260,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4253: checking for $ac_func" >&5
+echo "configure:4264: checking for $ac_func" >&5
-#line 4256 "configure"
+#line 4267 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4275,7 +4286,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4301,10 +4312,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4305: checking for $ac_func" >&5
+echo "configure:4316: checking for $ac_func" >&5
-#line 4308 "configure"
+#line 4319 "configure"
@@ -4327,7 +4338,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4353,10 +4364,10 @@
 for ac_func in drand48
 do
-echo "configure:4357: checking for $ac_func" >&5
+echo "configure:4368: checking for $ac_func" >&5
-#line 4360 "configure"
+#line 4371 "configure"
@@ -4379,7 +4390,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4405,10 +4416,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4409: checking for $ac_func" >&5
+echo "configure:4420: checking for $ac_func" >&5
-#line 4412 "configure"
+#line 4423 "configure"
@@ -4431,7 +4442,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4457,10 +4468,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4461: checking for $ac_func" >&5
+echo "configure:4472: checking for $ac_func" >&5
-#line 4464 "configure"
+#line 4475 "configure"
@@ -4483,7 +4494,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4508,13 +4519,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4512: checking whether setpgrp takes no argument" >&5
+echo "configure:4523: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4518 "configure"
+#line 4529 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4534,7 +4545,7 @@
 EOF
-if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4562,16 +4573,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4566: checking for long long int" >&5
+echo "configure:4577: checking for long long int" >&5
-#line 4568 "configure"
+#line 4579 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4575: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4591,7 +4602,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4595: checking for W11" >&5
+echo "configure:4606: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4619,7 +4630,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4623: checking for X" >&5
+echo "configure:4634: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4679,12 +4690,12 @@
   # First, try using that file with no special directory specified.
-#line 4683 "configure"
+#line 4694 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4753,14 +4764,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4757 "configure"
+#line 4768 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4865,17 +4876,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4869: checking whether -R must be followed by a space" >&5
+echo "configure:4880: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4872 "configure"
+#line 4883 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4891,14 +4902,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4895 "configure"
+#line 4906 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4930,13 +4941,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4934: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4945: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4940 "configure"
+#line 4951 "configure"
@@ -4947,7 +4958,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4968,13 +4979,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4972: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4983: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4978 "configure"
+#line 4989 "configure"
@@ -4985,7 +4996,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5013,10 +5024,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5017: checking for gethostbyname" >&5
+echo "configure:5028: checking for gethostbyname" >&5
-#line 5020 "configure"
+#line 5031 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5039,7 +5050,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5059,13 +5070,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5063: checking for gethostbyname in -lnsl" >&5
+echo "configure:5074: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5069 "configure"
+#line 5080 "configure"
@@ -5076,7 +5087,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5105,10 +5116,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5109: checking for connect" >&5
+echo "configure:5120: checking for connect" >&5
-#line 5112 "configure"
+#line 5123 "configure"
     which can conflict with char connect(); below.  */
@@ -5131,7 +5142,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5151,13 +5162,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5155: checking for connect in -lsocket" >&5
+echo "configure:5166: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5161 "configure"
+#line 5172 "configure"
@@ -5168,7 +5179,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5191,10 +5202,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5195: checking for remove" >&5
+echo "configure:5206: checking for remove" >&5
-#line 5198 "configure"
+#line 5209 "configure"
     which can conflict with char remove(); below.  */
@@ -5217,7 +5228,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5237,13 +5248,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5241: checking for remove in -lposix" >&5
+echo "configure:5252: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5247 "configure"
+#line 5258 "configure"
@@ -5254,7 +5265,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5277,10 +5288,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5281: checking for shmat" >&5
+echo "configure:5292: checking for shmat" >&5
-#line 5284 "configure"
+#line 5295 "configure"
     which can conflict with char shmat(); below.  */
@@ -5303,7 +5314,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5323,13 +5334,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5327: checking for shmat in -lipc" >&5
+echo "configure:5338: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5333 "configure"
+#line 5344 "configure"
@@ -5340,7 +5351,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5372,13 +5383,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5376: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5387: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5382 "configure"
+#line 5393 "configure"
@@ -5389,7 +5400,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5427,7 +5438,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5431: checking whether to use Curses" >&5
+echo "configure:5442: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5446,15 +5457,15 @@
 do
-echo "configure:5450: checking for $ac_hdr" >&5
+echo "configure:5461: checking for $ac_hdr" >&5
-#line 5453 "configure"
+#line 5464 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5485,10 +5496,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5489: checking curses.h WINDOW structure component" >&5
+echo "configure:5500: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5492 "configure"
+#line 5503 "configure"
 #include <curses.h>
@@ -5497,7 +5508,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5512: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5506,7 +5517,7 @@
 fi
 rm -f conftest*
-#line 5510 "configure"
+#line 5521 "configure"
 #include <curses.h>
@@ -5515,7 +5526,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5530: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5531,13 +5542,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5535: checking for initscr in -lncurses" >&5
+echo "configure:5546: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5541 "configure"
+#line 5552 "configure"
@@ -5548,7 +5559,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5567,13 +5578,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5571: checking for initscr in -lcurses" >&5
+echo "configure:5582: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5577 "configure"
+#line 5588 "configure"
@@ -5584,7 +5595,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5613,13 +5624,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5617: checking for keypad in -lncurses" >&5
+echo "configure:5628: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5623 "configure"
+#line 5634 "configure"
@@ -5630,7 +5641,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5652,13 +5663,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5656: checking for keypad in -lcurses" >&5
+echo "configure:5667: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5662 "configure"
+#line 5673 "configure"
@@ -5669,7 +5680,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5699,13 +5710,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5703: checking for gtty in -lcompat" >&5
+echo "configure:5714: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5709 "configure"
+#line 5720 "configure"
@@ -5716,7 +5727,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5735,13 +5746,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5739: checking for gtty in -lbsd-compat" >&5
+echo "configure:5750: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5745 "configure"
+#line 5756 "configure"
@@ -5752,7 +5763,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5771,13 +5782,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5775: checking for gtty in -lbsd" >&5
+echo "configure:5786: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5781 "configure"
+#line 5792 "configure"
@@ -5788,7 +5799,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5822,12 +5833,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5826: checking for library containing cuserid" >&5
+echo "configure:5837: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5831 "configure"
+#line 5842 "configure"
@@ -5838,7 +5849,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5849,7 +5860,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5853 "configure"
+#line 5864 "configure"
@@ -5860,7 +5871,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5886,10 +5897,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5890: checking for xdrmem_create" >&5
+echo "configure:5901: checking for xdrmem_create" >&5
-#line 5893 "configure"
+#line 5904 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5912,7 +5923,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5930,13 +5941,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5934: checking for xdrmem_create in -lsun" >&5
+echo "configure:5945: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5940 "configure"
+#line 5951 "configure"
@@ -5947,7 +5958,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5966,13 +5977,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5970: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5981: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5976 "configure"
+#line 5987 "configure"
@@ -5983,7 +5994,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6002,13 +6013,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6006: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6017: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6012 "configure"
+#line 6023 "configure"
@@ -6019,7 +6030,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6038,13 +6049,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6042: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6053: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6048 "configure"
+#line 6059 "configure"
@@ -6055,7 +6066,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6089,10 +6100,10 @@
 for ac_func in asprintf
 do
-echo "configure:6093: checking for $ac_func" >&5
+echo "configure:6104: checking for $ac_func" >&5
-#line 6096 "configure"
+#line 6107 "configure"
@@ -6115,7 +6126,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6142,10 +6153,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6146: checking for atan" >&5
+echo "configure:6157: checking for atan" >&5
-#line 6149 "configure"
+#line 6160 "configure"
     which can conflict with char atan(); below.  */
@@ -6168,7 +6179,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6186,13 +6197,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6190: checking for atan in -lm" >&5
+echo "configure:6201: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6196 "configure"
+#line 6207 "configure"
@@ -6203,7 +6214,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6230,10 +6241,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6234: checking for dlsym" >&5
+echo "configure:6245: checking for dlsym" >&5
-#line 6237 "configure"
+#line 6248 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6256,7 +6267,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6274,13 +6285,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6278: checking for dlsym in -ldl" >&5
+echo "configure:6289: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6284 "configure"
+#line 6295 "configure"
@@ -6291,7 +6302,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6318,10 +6329,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6322: checking for iconv" >&5
+echo "configure:6333: checking for iconv" >&5
-#line 6325 "configure"
+#line 6336 "configure"
     which can conflict with char iconv(); below.  */
@@ -6344,7 +6355,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6362,13 +6373,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6366: checking for iconv in -liconv" >&5
+echo "configure:6377: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6372 "configure"
+#line 6383 "configure"
@@ -6379,7 +6390,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6398,13 +6409,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6402: checking for iconv in -lgiconv" >&5
+echo "configure:6413: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6408 "configure"
+#line 6419 "configure"
@@ -6415,7 +6426,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6434,10 +6445,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6438: checking for libiconv" >&5
+echo "configure:6449: checking for libiconv" >&5
-#line 6441 "configure"
+#line 6452 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6460,7 +6471,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6478,13 +6489,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6482: checking for libiconv in -liconv" >&5
+echo "configure:6493: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6488 "configure"
+#line 6499 "configure"
@@ -6495,7 +6506,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6514,13 +6525,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6518: checking for libiconv in -lgiconv" >&5
+echo "configure:6529: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6524 "configure"
+#line 6535 "configure"
@@ -6531,7 +6542,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6568,10 +6579,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6572: checking for socket" >&5
+echo "configure:6583: checking for socket" >&5
-#line 6575 "configure"
+#line 6586 "configure"
     which can conflict with char socket(); below.  */
@@ -6594,7 +6605,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6612,13 +6623,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6616: checking for socket in -lsocket" >&5
+echo "configure:6627: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6622 "configure"
+#line 6633 "configure"
@@ -6629,7 +6640,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6677,7 +6688,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6681: checking for location of zlib includes" >&5
+echo "configure:6692: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6703,15 +6714,15 @@
 do
-echo "configure:6707: checking for $ac_hdr" >&5
+echo "configure:6718: checking for $ac_hdr" >&5
-#line 6710 "configure"
+#line 6721 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6745,7 +6756,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6749: checking for location of zlib library" >&5
+echo "configure:6760: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6770,13 +6781,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6774: checking for deflate in -lz" >&5
+echo "configure:6785: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6780 "configure"
+#line 6791 "configure"
@@ -6787,7 +6798,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6835,7 +6846,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6839: checking for location of External PROJ.4 includes" >&5
+echo "configure:6850: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6861,15 +6872,15 @@
 do
-echo "configure:6865: checking for $ac_hdr" >&5
+echo "configure:6876: checking for $ac_hdr" >&5
-#line 6868 "configure"
+#line 6879 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6906,7 +6917,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6910: checking External PROJ.4 version" >&5
+echo "configure:6921: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6914,7 +6925,7 @@
 else
-#line 6918 "configure"
+#line 6929 "configure"
 #include <stdio.h>
@@ -6926,7 +6937,7 @@
 EOF
-if { (eval echo configure:6930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6951,7 +6962,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6955: checking for location of External PROJ.4 library" >&5
+echo "configure:6966: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6976,13 +6987,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6980: checking for pj_get_def in -lproj" >&5
+echo "configure:6991: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6986 "configure"
+#line 6997 "configure"
@@ -6993,7 +7004,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7027,7 +7038,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7031: checking for location of External PROJ.4 data files" >&5
+echo "configure:7042: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7051,14 +7062,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7055: checking for epsg" >&5
+echo "configure:7066: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7062: checking for $PROJSHARE/epsg" >&5
+echo "configure:7073: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7090,7 +7101,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7094: checking for $ac_word" >&5
+echo "configure:7105: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7130,7 +7141,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7134: checking whether to use Readline" >&5
+echo "configure:7145: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7151,7 +7162,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7155: checking for location of Readline includes" >&5
+echo "configure:7166: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7177,15 +7188,15 @@
 do
-echo "configure:7181: checking for $ac_hdr" >&5
+echo "configure:7192: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7184 "configure"
+#line 7195 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7221,15 +7232,15 @@
 do
-echo "configure:7225: checking for $ac_hdr" >&5
+echo "configure:7236: checking for $ac_hdr" >&5
-#line 7228 "configure"
+#line 7239 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7233: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7263,7 +7274,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7267: checking for location of Readline library" >&5
+echo "configure:7278: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7288,13 +7299,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7292: checking for readline in -lreadline" >&5
+echo "configure:7303: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7298 "configure"
+#line 7309 "configure"
@@ -7305,7 +7316,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7340,13 +7351,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7344: checking for add_history in -lhistory" >&5
+echo "configure:7355: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7350 "configure"
+#line 7361 "configure"
@@ -7357,7 +7368,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7400,7 +7411,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7404: checking whether to use JPEG" >&5
+echo "configure:7415: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7420,7 +7431,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7424: checking for location of JPEG includes" >&5
+echo "configure:7435: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7446,15 +7457,15 @@
 do
-echo "configure:7450: checking for $ac_hdr" >&5
+echo "configure:7461: checking for $ac_hdr" >&5
-#line 7453 "configure"
+#line 7464 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7488,7 +7499,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7492: checking for location of JPEG library" >&5
+echo "configure:7503: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7515,13 +7526,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7519: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7530: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7525 "configure"
+#line 7536 "configure"
@@ -7532,7 +7543,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7551,13 +7562,13 @@
-echo "configure:7555: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7566: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7561 "configure"
+#line 7572 "configure"
@@ -7568,7 +7579,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7617,7 +7628,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7621: checking whether to use GDAL" >&5
+echo "configure:7632: checking whether to use GDAL" >&5
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
@@ -7630,7 +7641,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7634: checking for $ac_word" >&5
+echo "configure:7645: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7690,14 +7701,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7694 "configure"
+#line 7705 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7706,14 +7717,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7710 "configure"
+#line 7721 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7741,7 +7752,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7745: checking whether to use TIFF" >&5
+echo "configure:7756: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7761,7 +7772,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7765: checking for location of TIFF includes" >&5
+echo "configure:7776: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7787,15 +7798,15 @@
 do
-echo "configure:7791: checking for $ac_hdr" >&5
+echo "configure:7802: checking for $ac_hdr" >&5
-#line 7794 "configure"
+#line 7805 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7829,7 +7840,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7833: checking for location of TIFF library" >&5
+echo "configure:7844: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7860,13 +7871,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7864: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7870 "configure"
+#line 7881 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7877,7 +7888,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7896,13 +7907,13 @@
-echo "configure:7900: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7906 "configure"
+#line 7917 "configure"
@@ -7913,7 +7924,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7932,13 +7943,13 @@
-echo "configure:7936: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7942 "configure"
+#line 7953 "configure"
@@ -7949,7 +7960,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7968,13 +7979,13 @@
-echo "configure:7972: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7978 "configure"
+#line 7989 "configure"
@@ -7985,7 +7996,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8004,13 +8015,13 @@
-echo "configure:8008: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8014 "configure"
+#line 8025 "configure"
@@ -8021,7 +8032,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8040,13 +8051,13 @@
-echo "configure:8044: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8050 "configure"
+#line 8061 "configure"
@@ -8057,7 +8068,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8076,13 +8087,13 @@
-echo "configure:8080: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8086 "configure"
+#line 8097 "configure"
@@ -8093,7 +8104,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8112,13 +8123,13 @@
-echo "configure:8116: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8127: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8122 "configure"
+#line 8133 "configure"
@@ -8129,7 +8140,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8227,7 +8238,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8231: checking whether to use PNG" >&5
+echo "configure:8242: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8246,7 +8257,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8250: checking for location of PNG includes" >&5
+echo "configure:8261: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8272,15 +8283,15 @@
 do
-echo "configure:8276: checking for $ac_hdr" >&5
+echo "configure:8287: checking for $ac_hdr" >&5
-#line 8279 "configure"
+#line 8290 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8314,7 +8325,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8318: checking for location of PNG library" >&5
+echo "configure:8329: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8339,13 +8350,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8343: checking for png_read_image in -lpng" >&5
+echo "configure:8354: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8349 "configure"
+#line 8360 "configure"
@@ -8356,7 +8367,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8398,7 +8409,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8402: checking whether to use Tcl/Tk" >&5
+echo "configure:8413: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8414,11 +8425,180 @@
 if test -n "$USE_TCLTK"; then
+echo $ac_n "checking for location of Tcl/Tk framework""... $ac_c" 1>&6
+echo "configure:8431: checking for location of Tcl/Tk framework" >&5
+case "$with_tcltk_framework" in
+y | ye | yes | n | no)
+	{ echo "configure: error: *** You must supply a directory to --with-tcltk-framework." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_tcltk_framework" 1>&6
+if test -n "$with_tcltk_framework"; then
+    if test -d $with_tcltk_framework; then
+        TCLTKLIBPATH="$TCLTKLIBPATH -F$with_tcltk_framework"
+    else
+        { echo "configure: error: *** Tcl/Tk framework directory $dir does not exist." 1>&2; exit 1; }
+    fi
+fi
+if test -n "$TCLTKLIBPATH" ; then
+dir="$with_tcltk_framework"
+TCLINCDIR="-I$dir/Tcl.framework/Headers -I$dir/Tk.framework/Headers -I$dir/Tk.framework/PrivateHeaders"
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$TCLINCDIR $CPPFLAGS"
+for ac_hdr in tcl.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:8460: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 8463 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:8468: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+for ac_hdr in tk.h
+do
+echo "configure:8504: checking for $ac_hdr" >&5
+#line 8507 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:8512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+EOF
+else
+{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
+fi
+done
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$TCLTKLIBPATH -framework Tcl -framework Tk $LIBS"
+echo $ac_n "checking for Tk_MainWindow""... $ac_c" 1>&6
+echo "configure:8545: checking for Tk_MainWindow" >&5
+#line 8548 "configure"
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char Tk_MainWindow(); below.  */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tk_MainWindow();
+int main() {
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_Tk_MainWindow) || defined (__stub___Tk_MainWindow)
+choke me
+#else
+Tk_MainWindow();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_func_Tk_MainWindow=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_func_Tk_MainWindow=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'Tk_MainWindow`\" = yes"; then
+TCLTKLIBS = -framework Tcl -framework Tk
+else
+{ echo "configure: error: *** Unable to locate Tcl/Tk libraries." 1>&2; exit 1; }
+fi
+LDFLAGS=$ac_save_ldflags
+else
 # With Tcl/Tk includes directory
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8422: checking for location of Tcl/Tk includes" >&5
+echo "configure:8602: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8444,15 +8624,15 @@
 do
-echo "configure:8448: checking for $ac_hdr" >&5
+echo "configure:8628: checking for $ac_hdr" >&5
-#line 8451 "configure"
+#line 8631 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8636: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8489,15 +8669,15 @@
 do
-echo "configure:8493: checking for $ac_hdr" >&5
+echo "configure:8673: checking for $ac_hdr" >&5
-#line 8496 "configure"
+#line 8676 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8501: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8531,7 +8711,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8535: checking Tcl version" >&5
+echo "configure:8715: checking Tcl version" >&5
 if test "$cross_compiling" = yes; then
@@ -8539,7 +8719,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8543 "configure"
+#line 8723 "configure"
 #include <stdio.h>
@@ -8551,7 +8731,7 @@
 EOF
-if { (eval echo configure:8555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8569,7 +8749,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8573: checking Tk version" >&5
+echo "configure:8753: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8577,7 +8757,7 @@
 else
-#line 8581 "configure"
+#line 8761 "configure"
 #include <stdio.h>
@@ -8589,7 +8769,7 @@
 EOF
-if { (eval echo configure:8593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8618,7 +8798,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8622: checking for location of Tcl/Tk library" >&5
+echo "configure:8802: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8648,13 +8828,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8652: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8832: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8658 "configure"
+#line 8838 "configure"
@@ -8665,7 +8845,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8684,13 +8864,13 @@
-echo "configure:8688: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8868: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8694 "configure"
+#line 8874 "configure"
@@ -8701,7 +8881,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8728,13 +8908,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8732: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8912: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8738 "configure"
+#line 8918 "configure"
@@ -8745,7 +8925,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8764,13 +8944,13 @@
-echo "configure:8768: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8948: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8774 "configure"
+#line 8954 "configure"
@@ -8781,7 +8961,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8808,13 +8988,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8812: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8992: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8818 "configure"
+#line 8998 "configure"
@@ -8825,7 +9005,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8844,13 +9024,13 @@
-echo "configure:8848: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9028: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8854 "configure"
+#line 9034 "configure"
@@ -8861,7 +9041,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8939,13 +9119,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8943: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9123: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8949 "configure"
+#line 9129 "configure"
@@ -8956,7 +9136,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8975,13 +9155,13 @@
-echo "configure:8979: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9159: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8985 "configure"
+#line 9165 "configure"
@@ -8992,7 +9172,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9019,13 +9199,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9023: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9203: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9029 "configure"
+#line 9209 "configure"
@@ -9036,7 +9216,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9055,13 +9235,13 @@
-echo "configure:9059: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9239: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9065 "configure"
+#line 9245 "configure"
@@ -9072,7 +9252,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9099,13 +9279,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9103: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9283: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9109 "configure"
+#line 9289 "configure"
@@ -9116,7 +9296,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9135,13 +9315,13 @@
-echo "configure:9139: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9319: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9145 "configure"
+#line 9325 "configure"
@@ -9152,7 +9332,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9224,6 +9404,9 @@
 TCLTKLIBS="$TKLIB $TCLLIB"
+fi
 cat >> confdefs.h <<\EOF
 #define HAVE_TCLTK 1
 EOF
@@ -9244,7 +9427,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9248: checking whether to use PostgreSQL" >&5
+echo "configure:9431: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9271,7 +9454,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9275: checking for location of PostgreSQL includes" >&5
+echo "configure:9458: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9297,15 +9480,15 @@
 do
-echo "configure:9301: checking for $ac_hdr" >&5
+echo "configure:9484: checking for $ac_hdr" >&5
-#line 9304 "configure"
+#line 9487 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9343,7 +9526,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9347: checking for location of PostgreSQL library" >&5
+echo "configure:9530: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9372,13 +9555,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9376: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9559: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9382 "configure"
+#line 9565 "configure"
@@ -9389,7 +9572,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9408,13 +9591,13 @@
-echo "configure:9412: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9595: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9418 "configure"
+#line 9601 "configure"
@@ -9425,7 +9608,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9444,13 +9627,13 @@
-echo "configure:9448: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9631: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9454 "configure"
+#line 9637 "configure"
@@ -9461,7 +9644,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9480,13 +9663,13 @@
-echo "configure:9484: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9667: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9490 "configure"
+#line 9673 "configure"
@@ -9497,7 +9680,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9554,13 +9737,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9558: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9741: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9564 "configure"
+#line 9747 "configure"
@@ -9571,7 +9754,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9593,13 +9776,13 @@
-echo "configure:9597: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9780: checking for PQcmdTuples in -lpq" >&5
-#line 9603 "configure"
+#line 9786 "configure"
@@ -9610,7 +9793,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9653,7 +9836,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9657: checking whether to use MySQL" >&5
+echo "configure:9840: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9673,7 +9856,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9677: checking for location of MySQL includes" >&5
+echo "configure:9860: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9699,15 +9882,15 @@
 do
-echo "configure:9703: checking for $ac_hdr" >&5
+echo "configure:9886: checking for $ac_hdr" >&5
-#line 9706 "configure"
+#line 9889 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9744,7 +9927,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9748: checking for location of MySQL library" >&5
+echo "configure:9931: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9775,13 +9958,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9779: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9962: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9785 "configure"
+#line 9968 "configure"
@@ -9792,7 +9975,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9811,13 +9994,13 @@
-echo "configure:9815: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9998: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9821 "configure"
+#line 10004 "configure"
@@ -9828,7 +10011,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9847,13 +10030,13 @@
-echo "configure:9851: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10034: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9857 "configure"
+#line 10040 "configure"
@@ -9864,7 +10047,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9883,13 +10066,13 @@
-echo "configure:9887: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10070: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9893 "configure"
+#line 10076 "configure"
@@ -9900,7 +10083,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9919,13 +10102,13 @@
-echo "configure:9923: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10106: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9929 "configure"
+#line 10112 "configure"
@@ -9936,7 +10119,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9955,13 +10138,13 @@
-echo "configure:9959: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10142: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9965 "configure"
+#line 10148 "configure"
@@ -9972,7 +10155,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9991,13 +10174,13 @@
-echo "configure:9995: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10178: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10001 "configure"
+#line 10184 "configure"
@@ -10008,7 +10191,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10027,13 +10210,13 @@
-echo "configure:10031: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10214: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10037 "configure"
+#line 10220 "configure"
@@ -10044,7 +10227,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10134,7 +10317,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10138: checking for $ac_word" >&5
+echo "configure:10321: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10175,10 +10358,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10179: checking for mysql_server_init" >&5
+echo "configure:10362: checking for mysql_server_init" >&5
-#line 10182 "configure"
+#line 10365 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -10201,7 +10384,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10239,7 +10422,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10243: checking whether to use SQLite" >&5
+echo "configure:10426: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10259,7 +10442,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10263: checking for location of SQLite includes" >&5
+echo "configure:10446: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10285,15 +10468,15 @@
 do
-echo "configure:10289: checking for $ac_hdr" >&5
+echo "configure:10472: checking for $ac_hdr" >&5
-#line 10292 "configure"
+#line 10475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10336,7 +10519,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10340: checking for location of SQLite library" >&5
+echo "configure:10523: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10363,13 +10546,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10367: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10550: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10373 "configure"
+#line 10556 "configure"
@@ -10380,7 +10563,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10399,13 +10582,13 @@
-echo "configure:10403: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10586: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10409 "configure"
+#line 10592 "configure"
@@ -10416,7 +10599,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10469,7 +10652,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10473: checking whether to use FFMPEG" >&5
+echo "configure:10656: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10489,7 +10672,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10493: checking for location of FFMPEG includes" >&5
+echo "configure:10676: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10515,15 +10698,15 @@
 do
-echo "configure:10519: checking for $ac_hdr" >&5
+echo "configure:10702: checking for $ac_hdr" >&5
-#line 10522 "configure"
+#line 10705 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10559,15 +10742,15 @@
 do
-echo "configure:10563: checking for $ac_hdr" >&5
+echo "configure:10746: checking for $ac_hdr" >&5
-#line 10566 "configure"
+#line 10749 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10603,15 +10786,15 @@
 do
-echo "configure:10607: checking for $ac_hdr" >&5
+echo "configure:10790: checking for $ac_hdr" >&5
-#line 10610 "configure"
+#line 10793 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10654,7 +10837,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10658: checking for location of FFMPEG library" >&5
+echo "configure:10841: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10681,13 +10864,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10685: checking for av_free in -lavutil" >&5
+echo "configure:10868: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10691 "configure"
+#line 10874 "configure"
@@ -10698,7 +10881,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10717,13 +10900,13 @@
-echo "configure:10721: checking for av_free in -lavutil" >&5
+echo "configure:10904: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10727 "configure"
+#line 10910 "configure"
@@ -10734,7 +10917,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10779,13 +10962,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10783: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10966: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10789 "configure"
+#line 10972 "configure"
@@ -10796,7 +10979,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10815,13 +10998,13 @@
-echo "configure:10819: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11002: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10825 "configure"
+#line 11008 "configure"
@@ -10832,7 +11015,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10877,13 +11060,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10881: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11064: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10887 "configure"
+#line 11070 "configure"
@@ -10894,7 +11077,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10913,13 +11096,13 @@
-echo "configure:10917: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11100: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10923 "configure"
+#line 11106 "configure"
@@ -10930,7 +11113,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10990,7 +11173,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10994: checking whether to use OpenGL" >&5
+echo "configure:11177: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11024,7 +11207,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11028: checking for location of OpenGL includes" >&5
+echo "configure:11211: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11050,15 +11233,15 @@
 do
-echo "configure:11054: checking for $ac_hdr" >&5
+echo "configure:11237: checking for $ac_hdr" >&5
-#line 11057 "configure"
+#line 11240 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11245: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11092,7 +11275,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11096: checking for location of OpenGL library" >&5
+echo "configure:11279: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11121,13 +11304,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11125: checking for glBegin in -lGL" >&5
+echo "configure:11308: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11131 "configure"
+#line 11314 "configure"
@@ -11138,7 +11321,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11157,13 +11340,13 @@
-echo "configure:11161: checking for glBegin in -lGL" >&5
+echo "configure:11344: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11167 "configure"
+#line 11350 "configure"
@@ -11174,7 +11357,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11193,13 +11376,13 @@
-echo "configure:11197: checking for glBegin in -lGL" >&5
+echo "configure:11380: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11203 "configure"
+#line 11386 "configure"
@@ -11210,7 +11393,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11229,13 +11412,13 @@
-echo "configure:11233: checking for glBegin in -lGL" >&5
+echo "configure:11416: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11239 "configure"
+#line 11422 "configure"
@@ -11246,7 +11429,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11308,13 +11491,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11312: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11495: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11318 "configure"
+#line 11501 "configure"
@@ -11325,7 +11508,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11344,13 +11527,13 @@
-echo "configure:11348: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11531: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11354 "configure"
+#line 11537 "configure"
@@ -11361,7 +11544,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11405,10 +11588,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11409: checking for glXCreatePbuffer" >&5
+echo "configure:11592: checking for glXCreatePbuffer" >&5
-#line 11412 "configure"
+#line 11595 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11431,7 +11614,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11453,10 +11636,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11457: checking for glXCreateGLXPixmap" >&5
+echo "configure:11640: checking for glXCreateGLXPixmap" >&5
-#line 11460 "configure"
+#line 11643 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11479,7 +11662,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11518,7 +11701,7 @@
-echo "configure:11522: checking for location of OpenGL includes" >&5
+echo "configure:11705: checking for location of OpenGL includes" >&5
@@ -11544,15 +11727,15 @@
 do
-echo "configure:11548: checking for $ac_hdr" >&5
+echo "configure:11731: checking for $ac_hdr" >&5
-#line 11551 "configure"
+#line 11734 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11587,10 +11770,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11591: checking for glBegin" >&5
+echo "configure:11774: checking for glBegin" >&5
-#line 11594 "configure"
+#line 11777 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11613,7 +11796,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11628,10 +11811,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11632: checking for gluBeginCurve" >&5
+echo "configure:11815: checking for gluBeginCurve" >&5
-#line 11635 "configure"
+#line 11818 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11654,7 +11837,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11698,7 +11881,7 @@
-echo "configure:11702: checking for location of OpenGL includes" >&5
+echo "configure:11885: checking for location of OpenGL includes" >&5
@@ -11724,15 +11907,15 @@
 do
-echo "configure:11728: checking for $ac_hdr" >&5
+echo "configure:11911: checking for $ac_hdr" >&5
-#line 11731 "configure"
+#line 11914 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11766,7 +11949,7 @@
-echo "configure:11770: checking for location of OpenGL library" >&5
+echo "configure:11953: checking for location of OpenGL library" >&5
@@ -11791,18 +11974,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11795: checking for OpenGL library" >&5
+echo "configure:11978: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11799 "configure"
+#line 11982 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11826,18 +12009,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11830: checking for GLU library" >&5
+echo "configure:12013: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11834 "configure"
+#line 12017 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11886,7 +12069,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11890: checking whether to use ODBC" >&5
+echo "configure:12073: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11905,7 +12088,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11909: checking for location of ODBC includes" >&5
+echo "configure:12092: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11931,15 +12114,15 @@
 do
-echo "configure:11935: checking for $ac_hdr" >&5
+echo "configure:12118: checking for $ac_hdr" >&5
-#line 11938 "configure"
+#line 12121 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11973,7 +12156,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11977: checking for location of ODBC library" >&5
+echo "configure:12160: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11998,13 +12181,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12002: checking for SQLConnect in -lodbc" >&5
+echo "configure:12185: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12008 "configure"
+#line 12191 "configure"
@@ -12015,7 +12198,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12040,13 +12223,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12044: checking for SQLConnect in -liodbc" >&5
+echo "configure:12227: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12050 "configure"
+#line 12233 "configure"
@@ -12057,7 +12240,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12082,11 +12265,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12086: checking for ODBC library" >&5
+echo "configure:12269: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12090 "configure"
+#line 12273 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12094,7 +12277,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12143,7 +12326,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12147: checking whether to use FFTW" >&5
+echo "configure:12330: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12162,7 +12345,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12166: checking for location of FFTW includes" >&5
+echo "configure:12349: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12188,15 +12371,15 @@
 do
-echo "configure:12192: checking for $ac_hdr" >&5
+echo "configure:12375: checking for $ac_hdr" >&5
-#line 12195 "configure"
+#line 12378 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12383: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12224,15 +12407,15 @@
 do
-echo "configure:12228: checking for $ac_hdr" >&5
+echo "configure:12411: checking for $ac_hdr" >&5
-#line 12231 "configure"
+#line 12414 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12260,15 +12443,15 @@
 do
-echo "configure:12264: checking for $ac_hdr" >&5
+echo "configure:12447: checking for $ac_hdr" >&5
-#line 12267 "configure"
+#line 12450 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12314,7 +12497,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12318: checking for location of FFTW library" >&5
+echo "configure:12501: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12339,13 +12522,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12343: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12526: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12349 "configure"
+#line 12532 "configure"
@@ -12356,7 +12539,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12381,13 +12564,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12385: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12568: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12391 "configure"
+#line 12574 "configure"
@@ -12398,7 +12581,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12423,13 +12606,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12427: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12610: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12433 "configure"
+#line 12616 "configure"
@@ -12440,7 +12623,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12497,7 +12680,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12501: checking whether to use BLAS" >&5
+echo "configure:12684: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12518,7 +12701,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12522: checking for location of BLAS includes" >&5
+echo "configure:12705: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12538,7 +12721,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12542: checking for location of BLAS library" >&5
+echo "configure:12725: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12564,15 +12747,15 @@
 do
-echo "configure:12568: checking for $ac_hdr" >&5
+echo "configure:12751: checking for $ac_hdr" >&5
-#line 12571 "configure"
+#line 12754 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12607,13 +12790,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12611: checking for dnrm2_ in -lblas" >&5
+echo "configure:12794: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12617 "configure"
+#line 12800 "configure"
@@ -12624,7 +12807,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12643,13 +12826,13 @@
-echo "configure:12647: checking for dnrm2_ in -lblas" >&5
+echo "configure:12830: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12653 "configure"
+#line 12836 "configure"
@@ -12660,7 +12843,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12704,13 +12887,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12708: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12891: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12714 "configure"
+#line 12897 "configure"
@@ -12721,7 +12904,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12736,13 +12919,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12740: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12923: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12746 "configure"
+#line 12929 "configure"
@@ -12753,7 +12936,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12768,13 +12951,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12772: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12955: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12778 "configure"
+#line 12961 "configure"
@@ -12785,7 +12968,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12830,16 +13013,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12834: checking for sgemm in $vlib_flags" >&5
+echo "configure:13017: checking for sgemm in $vlib_flags" >&5
-#line 12836 "configure"
+#line 13019 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12857,13 +13040,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12861: checking for sgemm_ in -lblas" >&5
+echo "configure:13044: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12867 "configure"
+#line 13050 "configure"
@@ -12874,7 +13057,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12889,13 +13072,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12893: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13076: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12899 "configure"
+#line 13082 "configure"
@@ -12906,7 +13089,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12921,13 +13104,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12925: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13108: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12931 "configure"
+#line 13114 "configure"
@@ -12938,7 +13121,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12972,13 +13155,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12976: checking for acosp in -lsunmath" >&5
+echo "configure:13159: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12982 "configure"
+#line 13165 "configure"
@@ -12989,7 +13172,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13004,13 +13187,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13008: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13191: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13014 "configure"
+#line 13197 "configure"
@@ -13021,7 +13204,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13051,13 +13234,13 @@
 # Generic BLAS library
-echo "configure:13055: checking for sgemm_ in -lblas" >&5
+echo "configure:13238: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13061 "configure"
+#line 13244 "configure"
@@ -13068,7 +13251,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13107,7 +13290,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13111: checking whether to use LAPACK" >&5
+echo "configure:13294: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13132,7 +13315,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13136: checking for location of LAPACK includes" >&5
+echo "configure:13319: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13152,7 +13335,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13156: checking for location of LAPACK library" >&5
+echo "configure:13339: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13178,15 +13361,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13182: checking for $ac_hdr" >&5
+echo "configure:13365: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 13185 "configure"
+#line 13368 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13190: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13373: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13218,10 +13401,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13222: checking for dsegv_" >&5
+echo "configure:13405: checking for dsegv_" >&5
-#line 13225 "configure"
+#line 13408 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char dsegv_(); below.  */
@@ -13244,7 +13427,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13271,13 +13454,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13275: checking for desgv_ in -llapack" >&5
+echo "configure:13458: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13281 "configure"
+#line 13464 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13288,7 +13471,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13320,13 +13503,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13324: checking for dgesv_ in -llapack" >&5
+echo "configure:13507: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13330 "configure"
+#line 13513 "configure"
@@ -13337,7 +13520,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13356,13 +13539,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13360: checking for dgesv_ in -llapack" >&5
+echo "configure:13543: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13366 "configure"
+#line 13549 "configure"
@@ -13373,7 +13556,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13429,7 +13612,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13433: checking whether to use Motif" >&5
+echo "configure:13616: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13448,7 +13631,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13452: checking for location of Motif includes" >&5
+echo "configure:13635: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13474,15 +13657,15 @@
 do
-echo "configure:13478: checking for $ac_hdr" >&5
+echo "configure:13661: checking for $ac_hdr" >&5
-#line 13481 "configure"
+#line 13664 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13516,7 +13699,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13520: checking for location of Motif library" >&5
+echo "configure:13703: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13541,13 +13724,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13545: checking for XmStringCreate in -lXm" >&5
+echo "configure:13728: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13551 "configure"
+#line 13734 "configure"
@@ -13558,7 +13741,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13599,7 +13782,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13603: checking whether to use Cairo" >&5
+echo "configure:13786: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13625,15 +13808,15 @@
 do
-echo "configure:13629: checking for $ac_hdr" >&5
+echo "configure:13812: checking for $ac_hdr" >&5
-#line 13632 "configure"
+#line 13815 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13820: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13670,10 +13853,10 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13674: checking for cairo_create" >&5
+echo "configure:13857: checking for cairo_create" >&5
-#line 13677 "configure"
+#line 13860 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13696,7 +13879,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13731,7 +13914,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13735: checking whether to use GLw" >&5
+echo "configure:13918: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13750,7 +13933,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13754: checking for location of GLw includes" >&5
+echo "configure:13937: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13776,15 +13959,15 @@
 do
-echo "configure:13780: checking for $ac_hdr" >&5
+echo "configure:13963: checking for $ac_hdr" >&5
-#line 13783 "configure"
+#line 13966 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13812,15 +13995,15 @@
 do
-echo "configure:13816: checking for $ac_hdr" >&5
+echo "configure:13999: checking for $ac_hdr" >&5
-#line 13819 "configure"
+#line 14002 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13860,7 +14043,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13864: checking for location of GLw library" >&5
+echo "configure:14047: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13885,13 +14068,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13889: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14072: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13895 "configure"
+#line 14078 "configure"
@@ -13902,7 +14085,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13927,13 +14110,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13931: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14114: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13937 "configure"
+#line 14120 "configure"
@@ -13944,7 +14127,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13969,13 +14152,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13973: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14156: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13979 "configure"
+#line 14162 "configure"
@@ -13986,7 +14169,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14011,13 +14194,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14015: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14198: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14021 "configure"
+#line 14204 "configure"
@@ -14028,7 +14211,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14053,13 +14236,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14057: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14240: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14063 "configure"
+#line 14246 "configure"
@@ -14070,7 +14253,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14095,13 +14278,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14099: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14282: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14105 "configure"
+#line 14288 "configure"
@@ -14112,7 +14295,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14139,13 +14322,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14143: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14326: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14149 "configure"
+#line 14332 "configure"
@@ -14156,7 +14339,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14175,13 +14358,13 @@
-echo "configure:14179: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14362: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14185 "configure"
+#line 14368 "configure"
@@ -14192,7 +14375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14219,13 +14402,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14223: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14406: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14229 "configure"
+#line 14412 "configure"
@@ -14236,7 +14419,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14255,13 +14438,13 @@
-echo "configure:14259: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14442: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14265 "configure"
+#line 14448 "configure"
@@ -14272,7 +14455,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14385,7 +14568,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14389: checking whether to use FreeType" >&5
+echo "configure:14572: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14404,7 +14587,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14408: checking for location of FreeType includes" >&5
+echo "configure:14591: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14430,15 +14613,15 @@
 do
-echo "configure:14434: checking for $ac_hdr" >&5
+echo "configure:14617: checking for $ac_hdr" >&5
-#line 14437 "configure"
+#line 14620 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14472,7 +14655,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14476: checking for location of FreeType library" >&5
+echo "configure:14659: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14497,13 +14680,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14501: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14684: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14507 "configure"
+#line 14690 "configure"
@@ -14514,7 +14697,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14555,7 +14738,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14559: checking whether to use NLS" >&5
+echo "configure:14742: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14575,10 +14758,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14579: checking for gettext" >&5
+echo "configure:14762: checking for gettext" >&5
-#line 14582 "configure"
+#line 14765 "configure"
     which can conflict with char gettext(); below.  */
@@ -14601,7 +14784,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14619,13 +14802,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14623: checking for gettext in -lintl" >&5
+echo "configure:14806: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14629 "configure"
+#line 14812 "configure"
@@ -14636,7 +14819,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14671,7 +14854,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14675: checking whether to use C++" >&5
+echo "configure:14858: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14687,7 +14870,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14691: checking for $ac_word" >&5
+echo "configure:14874: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14716,7 +14899,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14720: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14903: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14727,12 +14910,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14731 "configure"
+#line 14914 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14758,19 +14941,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14762: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14945: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14767: checking whether we are using GNU C++" >&5
+echo "configure:14950: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14788,7 +14971,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14792: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14975: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14829,7 +15012,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14833: checking whether to use openDWG" >&5
+echo "configure:15016: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14849,7 +15032,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14853: checking for location of openDGW includes" >&5
+echo "configure:15036: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14875,15 +15058,15 @@
 do
-echo "configure:14879: checking for $ac_hdr" >&5
+echo "configure:15062: checking for $ac_hdr" >&5
-#line 14882 "configure"
+#line 15065 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14917,7 +15100,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14921: checking for location of openDWG library" >&5
+echo "configure:15104: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14964,7 +15147,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14968: checking for special C compiler options needed for large files" >&5
+echo "configure:15151: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14972,7 +15155,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14976 "configure"
+#line 15159 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14988,7 +15171,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14997,7 +15180,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15001 "configure"
+#line 15184 "configure"
@@ -15013,7 +15196,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15200: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15033,11 +15216,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15037: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15220: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15041 "configure"
+#line 15224 "configure"
@@ -15053,14 +15236,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15240: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15064 "configure"
+#line 15247 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15078,7 +15261,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15097,11 +15280,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15101: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15284: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15105 "configure"
+#line 15288 "configure"
@@ -15117,14 +15300,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15121: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15304: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15128 "configure"
+#line 15311 "configure"
 #define _LARGE_FILES 1
@@ -15142,7 +15325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15146: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15329: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15161,25 +15344,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15165: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15348: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15169 "configure"
+#line 15352 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15176: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15359: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15183 "configure"
+#line 15366 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15188,7 +15371,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15192: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15209,10 +15392,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15213: checking if system supports Large Files at all" >&5
+echo "configure:15396: checking if system supports Large Files at all" >&5
-#line 15216 "configure"
+#line 15399 "configure"
 #include <stdio.h>
@@ -15244,7 +15427,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15273,7 +15456,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15277: checking whether to use Python" >&5
+echo "configure:15460: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15293,7 +15476,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15297: checking for $ac_word" >&5
+echo "configure:15480: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15338,15 +15521,15 @@
 do
-echo "configure:15342: checking for $ac_hdr" >&5
+echo "configure:15525: checking for $ac_hdr" >&5
-#line 15345 "configure"
+#line 15528 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15350: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15386,7 +15569,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15390: checking for $ac_word" >&5
+echo "configure:15573: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15432,7 +15615,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15436: checking whether to use wxWidgets" >&5
+echo "configure:15619: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15452,7 +15635,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15456: checking for $ac_word" >&5
+echo "configure:15639: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15500,7 +15683,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15504: checking wxWidgets version" >&5
+echo "configure:15687: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15523,15 +15706,15 @@
 do
-echo "configure:15527: checking for $ac_hdr" >&5
+echo "configure:15710: checking for $ac_hdr" >&5
-#line 15530 "configure"
+#line 15713 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15567,15 +15750,15 @@
 do
-echo "configure:15571: checking for $ac_hdr" >&5
+echo "configure:15754: checking for $ac_hdr" >&5
-#line 15574 "configure"
+#line 15757 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15579: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-07-26 21:04:11 UTC (rev 32322)
+++ grass/trunk/configure.in	2008-07-26 22:52:19 UTC (rev 32323)
@@ -233,6 +233,7 @@
 LOC_ARG_WITH_INC(tcltk, Tcl/Tk)
 LOC_ARG_WITH_LIB(tcltk, Tcl/Tk)
+LOC_ARG_WITH_FRAMEWORK(tcltk, Tcl/Tk)
 LOC_ARG_WITH_INC(postgres, PostgreSQL)
 LOC_ARG_WITH_LIB(postgres, PostgreSQL)
@@ -798,6 +799,27 @@
 if test -n "$USE_TCLTK"; then
+LOC_CHECK_FRAMEWORK_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
+if test -n "$TCLTKLIBPATH" ; then
+dir="$with_tcltk_framework"
+TCLINCDIR="-I$dir/Tcl.framework/Headers -I$dir/Tk.framework/Headers -I$dir/Tk.framework/PrivateHeaders"
+LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
+LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR)
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$TCLTKLIBPATH -framework Tcl -framework Tk $LIBS"
+AC_CHECK_FUNC(Tk_MainWindow,[
+TCLTKLIBS = -framework Tcl -framework Tk
+AC_MSG_ERROR([*** Unable to locate Tcl/Tk libraries.])
+LDFLAGS=$ac_save_ldflags
+else
 # With Tcl/Tk includes directory
 LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
@@ -844,6 +866,9 @@
 TCLTKLIBS="$TKLIB $TCLLIB"
+fi
 AC_DEFINE(HAVE_TCLTK)
 fi # $USE_TCLTK
