[GRASS-SVN] r32346 - grass-addons/gipe/i.eb.h_SEBAL95
Sun Jul 27 19:10:29 EDT 2008
Author: ychemin
Date: 2008-07-27 19:10:29 -0400 (Sun, 27 Jul 2008)
New Revision: 32346
Removed:
   grass-addons/gipe/i.eb.h_SEBAL95/dtair_0.c
   grass-addons/gipe/i.eb.h_SEBAL95/main.c
   grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
   grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
rearranged initialization parameters of cold and dry pixels, allowed external dT map to overrule internal initialization of cold and dry pixels
Deleted: grass-addons/gipe/i.eb.h_SEBAL95/dtair_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/dtair_0.c	2008-07-27 22:32:43 UTC (rev 32345)
+++ grass-addons/gipe/i.eb.h_SEBAL95/dtair_0.c	2008-07-27 23:10:29 UTC (rev 32346)
@@ -1,44 +0,0 @@
-#include<stdio.h>
-#include<math.h>
-#include"functions.h"
-/* Pixel-based input required are: tempk water & desert
- * additionally, dtair in Desert is vaguely initialized
-#define ZERO 273.15
-double dt_air_0(double t0_dem, double tempk_water, double tempk_desert)
-	double a, b, result;
-	double dtair_desert_0;
-	if(tempk_desert > (ZERO+48.0)){
-		dtair_desert_0 = 13.0;
-	} else if(tempk_desert >= (ZERO+40.0) && tempk_desert < (ZERO+48.0)){
-		dtair_desert_0 = 10.0;
-	} else if(tempk_desert >= (ZERO+32.0) && tempk_desert < (ZERO+40.0)){
-		dtair_desert_0 = 7.0;
-	} else if(tempk_desert >= (ZERO+25.0) && tempk_desert < (ZERO+32.0)){
-		dtair_desert_0 = 5.0;
-	} else if(tempk_desert >= (ZERO+18.0) && tempk_desert < (ZERO+25.0)){
-		dtair_desert_0 = 3.0;
-	} else if(tempk_desert >= (ZERO+11.0) && tempk_desert < (ZERO+18.0)){
-		dtair_desert_0 = 1.0;
-	} else {
-		dtair_desert_0 = 0.0;
-//		printf("WARNING!!! dtair_desert_0 is NOT VALID!\n");
-//	printf("dtair0 = %.0f K\t",dtair_desert_0);
-	a = (dtair_desert_0-0.0)/(tempk_desert-tempk_water);
-	b = 0.0 - a * tempk_water;
-//	printf("dt_air_0(a) = %5.3f Tempk(b) %5.3f\n",a,b);
-	result = t0_dem * a + b;
-//	printf("dt_air_0 = %5.3f\n",result);
-	return result;
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-27 22:32:43 UTC (rev 32345)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-27 23:10:29 UTC (rev 32346)
@@ -26,8 +26,8 @@
 /*#include <omp.h>*/
-double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert);
-double sensi_h_noz0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double dtair0, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert);
+double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert, double dtair_desert);
+double sensi_h_noz0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double dtair0, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert, double dtair_desert);
 int main(int argc, char *argv[])
@@ -427,6 +427,8 @@
 	DCELL d_g0_dry;
 	DCELL d_t0dem_dry;
 	DCELL d_dem_dry;
+	DCELL d_dT_dry;
+	DCELL d_dT;
 	/*START Temperature minimum search */
 	/* THREAD 1 */
 	/*This is correcting for un-Earthly temperatures*/
@@ -618,6 +620,10 @@
 				G_fatal_error(_("Could not read from <%s>"),Rn);
 			if(G_get_raster_row(infd_g0, inrast_g0, row,data_type_g0) < 0)
 				G_fatal_error(_("Could not read from <%s>"),g0);
+			if(input_dT->answer){
+				if(G_get_raster_row(infd_dT,inrast_dT,row,data_type_dT)<0)
+					G_fatal_error(_("Could not read from <%s>"),T);
 			/*process the data */
 			for (col=0; col < ncols; col++)
@@ -676,11 +682,26 @@
 						d_g0 = (double) ((DCELL *) inrast_g0)[col];
 						break;
+					switch(data_type_dT){
+						case CELL_TYPE:
+							d_dT=(double) ((CELL *) inrast_dT)[col];
+							break;
+						case FCELL_TYPE:
+							d_dT=(double) ((FCELL *)inrast_dT)[col];
+							break;
+						case DCELL_TYPE:
+							d_dT=(double) ((DCELL *)inrast_dT)[col];
+							break;
 				if(G_is_d_null_value(&d_albedo)||
 				G_is_d_null_value(&d_tempk)||
 				G_is_d_null_value(&d_dem)||
 				G_is_d_null_value(&d_Rn)||
-				G_is_d_null_value(&d_g0)){
+				G_is_d_null_value(&d_g0)||
+				((input_dT->answer)&&
+				(G_is_d_null_value(&d_dT)))){
 					/* do nothing */
 				}else{
 					d_t0dem = d_tempk + 0.001649*d_dem;
@@ -717,6 +738,8 @@
 							d_dem_dry=d_dem;
 							col_dry=col;
 							row_dry=row;
+								d_dT_dry=d_dT;
 						if(flag1->answer&&
 						d_tempk>=(double)i_peak3-0.0&&
@@ -732,6 +755,8 @@
 							d_dem_dry=d_dem;
 							col_dry=col;
 							row_dry=row;
+								d_dT_dry=d_dT;
@@ -750,6 +775,8 @@
 		G_message("rnet_dry=%f\n",d_Rn_dry);
 		G_message("g0_dry=%f\n",d_g0_dry);
 		G_message("h0_dry=%f\n",d_Rn_dry-d_g0_dry);
+			G_message("dT_dry=%f\n",d_dT_dry);
 	} /* END OF FLAG2 */
 	/*MPI_BARRIER*/
@@ -771,6 +798,7 @@
 		DCELL d_tempk;
 		DCELL d_dem;
 		DCELL d_t0dem;
+		DCELL d_dT;
 		if(G_get_raster_row(infd_T,inrast_T,row,data_type_T)<0)
 		if(G_get_raster_row(infd_dem,inrast_dem,row,data_type_dem)<0)
@@ -779,6 +807,10 @@
 		switch(data_type_T){
 			case CELL_TYPE:
 				d_tempk = (double) ((CELL *) inrast_T)[col];
@@ -823,13 +855,28 @@
 				break;
+				case CELL_TYPE:
+					break;
+				case FCELL_TYPE:
+					break;
+				case DCELL_TYPE:
+					break;
 		d_t0dem 	= d_tempk + 0.001649 * d_dem;
 		d_t0dem_dry	= d_t0dem;
 		d_tempk_dry	= d_tempk;
 		d_Rn_dry	= d_Rn;
 		d_g0_dry	= d_g0;
 		d_dem_dry	= d_dem;
+			d_dT_dry = d_dT;
 		/*WET PIXEL*/
 		if(flag3->answer){
 			/*Calculate coordinates of row/col from projected ones*/
@@ -867,6 +914,8 @@
 	/* END OF MANUAL WET/DRY PIXELS */
@@ -1038,8 +1087,8 @@
 				G_set_d_null_value(&outrast[col],1);
 			} else {
 				/* Albedo < 0*/
-				if(d_albedo<0.01){
-					d_albedo=0.01;
+				if(d_albedo<0.001){
+					d_albedo=0.001;
 				/* Calculate T0dem */
 				d_t0dem = (double)d_tempk + 0.001649 * (double) d_dem;
@@ -1056,18 +1105,22 @@
 						/* do nothing */
 					} else {
-						/* let the internal constant take over */
+						/* let the internal constant
+						 * take over */
 						d_dT = -1.0;
+						d_dT_dry = -1.0;
-					d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry);
+					d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
 				} else {
 						/* do nothing */
 					} else {
+						 * take over */
 						d_dT = -1.0;
+						d_dT_dry = -1.0;
-					d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry);
+					d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
 		//		G_message(" d_h0=%5.3f",d);
 				if (zero->answer && d<0.0){
Modified: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-27 22:32:43 UTC (rev 32345)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-27 23:10:29 UTC (rev 32346)
@@ -6,7 +6,10 @@
 /* Arrays Declarations */
 #define ITER_MAX 10
+/* if dtair_desert < 0 then internal calculations */
+/* if dtair0 < 0 then internal calculations */
 	double dtair[ITER_MAX], roh_air[ITER_MAX], rah[ITER_MAX];
@@ -17,7 +20,6 @@
 	int	i, j, ic, debug=0;
 	double u_0, zom0;
 	double h_desert, rah_desert, roh_air_desert;
-	double dtair_desert;
 	double psih, psim, psih_desert,psim_desert;
 	double ustar_desert,ustar_desertold,zom_desert;
 	double result;
@@ -33,12 +35,8 @@
 		printf("ndvi = %5.3f ndvimax = %5.3f\n",ndvi,ndvi_max);
 		printf("*****************************\n");
-//	dtair[0] 	= dt_air_0(t0_dem, tempk_water, tempk_desert);
-	if(dtair0 < 0){
-		dtair[0] = 5.0;
-	} else {
-		dtair[0] = dtair0;
+	if(t0_dem<250.0)
+		t0_dem=250.0;
 // 	printf("*****************************dtair = %5.3f\n",dtair[0]);
 	roh_air[0] 	= roh_air_0(tempk);
 // 	printf("*****************************rohair=%5.3f\n",roh_air[0]);
@@ -50,6 +48,21 @@
 // 	printf("*****************************u0\n");
 	rah[0] 		= rah_0(zom0, u_hu, hu);
 // 	printf("*****************************rah = %5.3f\n",rah[0]);
+	if(dtair_desert < 0.0){
+		h_desert= rnet_desert - g0_desert;
+		zom_desert= 0.002;
+		ustar_desert= u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u_hu,hu);
+		psih_desert= psi_h(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
+		psim_desert= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
+		rah_desert = rah1(zom_desert,psih_desert,psim_desert,ustar_desert);
+// 		printf("*****************************rah_desert = %5.3f\n",rah_desert);
+		dtair_desert = dt_air_desert(h_desert, roh_air_desert, rah_desert);
+	if(dtair0 < 0.0){
+		dtair[0] = dt_air(t0_dem,tempk_water,tempk_desert,dtair_desert);
+	} else {
+		dtair[0] = dtair0;
 	h[0] 		= h_0(roh_air[0], rah[0], dtair[0]);
 // 	printf("*****************************h\n");
 	if(debug==1){
@@ -69,26 +82,20 @@
 		if(debug==1){
 			printf("\n ******** ITERATION %i *********\n",ic);
-		/* Where is roh_air[i]? */
 		ustar[ic] = u_star(t0_dem,h[ic-1],u_0,roh_air[ic-1],zom[0],u_hu,hu);
 		psih = psi_h(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
 		psim = psi_m(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
 		rah[ic] = rah1(zom0, psih, psim, ustar[ic]);
+		if(rah[ic]<0.0)
+			rah[ic]=0.0;
 		/* get desert point values from maps */
-		if(ic==1){
-			h_desert	= rnet_desert - g0_desert;
-			zom_desert	= 0.002;
-			ustar_desert	= u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u_hu,hu);
-			psih_desert 	= psi_h(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
-			psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
-		} else {
-			roh_air_desert	= rohair(dem_desert,tempk_desert,dtair_desert);
-			h_desert	= h1(roh_air_desert,rah_desert,dtair_desert);
-			ustar_desertold = ustar_desert;
-			ustar_desert	= u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u_hu,hu);
-			psih_desert 	= psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
-		rah_desert	= rah1(zom0,psih_desert,psim_desert,ustar_desert);
+		roh_air_desert	= rohair(dem_desert,tempk_desert,dtair_desert);
+		h_desert	= h1(roh_air_desert,rah_desert,dtair_desert);
+		ustar_desertold = ustar_desert;
+		ustar_desert	= u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u_hu,hu);
+		psih_desert 	= psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
+		psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
 		/* This should find the new dtair from inversed h equation...*/
 		dtair[ic] 	= dt_air(t0_dem, tempk_water, tempk_desert, dtair_desert);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c	2008-07-27 22:32:43 UTC (rev 32345)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c	2008-07-27 23:10:29 UTC (rev 32346)
@@ -6,7 +6,10 @@
 #define ITER_MAX 10
+double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert,double dtair_desert)
@@ -17,7 +20,6 @@
 	double u_0;
 	double psih,psim,psih_desert,psim_desert;
 	double result;
@@ -33,21 +35,31 @@
 		printf("z0m0 = %5.3f\n",zom0);
-	if(dtair0 < 0){
-		dtair[0] = 5.0;
-	} else {
-// 	printf("*****************************dtair = %5.3f\n",dtair[0]);
+	if(t0_dem<250.0)
+		t0_dem=250.0;
+// 	printf("****************************dtair = %5.3f\n",dtair[0]);
-// 	printf("*****************************rohair=%5.3f\n",roh_air[0]);
+// 	printf("***************************rohair=%5.3f\n",roh_air[0]);
 	roh_air_desert 	= roh_air_0(tempk_desert);
 // 	printf("**rohairdesert = %5.3f\n",roh_air_desert);
 	u_0 		= U_0(zom0, u_hu, hu);
+		rah_desert= rah1(zom0,psih_desert,psim_desert,ustar_desert);
+		dtair_desert= dt_air_desert(h_desert, roh_air_desert, rah_desert);
+	if(dtair0 < 0.0){
+	} else {
 	if(debug==1){
@@ -67,26 +79,19 @@
 		if(debug==1){
-		psih = psi_h(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
-		psim = psi_m(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
-		rah[ic] = rah1(zom0,psih,psim,ustar[ic]);
+		psih= psi_h(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
+		psim= psi_m(t0_dem,h[ic-1],ustar[ic],roh_air[ic-1],hu);
+		rah[ic] = rah1(zom0,psih,psim,ustar[ic]);
+		if(rah[ic]<0.0)
+			rah[ic]=0.0;
-		if(ic==1){
-		} else {
-			psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
+		psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
