[GRASS-SVN] r32352 - in grass/trunk/gui/wxpython: gui_modules xml
Mon Jul 28 18:22:28 EDT 2008
Author: martinl
Date: 2008-07-28 18:22:28 -0400 (Mon, 28 Jul 2008)
New Revision: 32352
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/xml/grass-gxw.dtd
nviz2/wxGUI: workspace fixes (vector lines/points)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-28 13:31:49 UTC (rev 32351)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-28 22:22:28 UTC (rev 32352)
@@ -356,7 +356,7 @@
                     self.LoadVector(item)
             except gcmd.NvizError, e:
                 print >> sys.stderr, "Nviz: " + e.message
         stop = time.time()
         Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
@@ -364,54 +364,53 @@
         # print stop - start
     def SetLayerData(self, item, id, nvizType):
-        """Set map object properties"""
+        """Set map object properties
+        @param item layer item
+        @param id nviz layer id (or -1)
+        @param nvizType nviz data type (surface, points, vector)
         type = self.tree.GetPyData(item)[0]['maplayer'].type
-        data = self.tree.GetPyData(item)[0]['nviz']
+        # reference to original layer properties (can be None)
+        dataOrig = self.tree.GetPyData(item)[0]['nviz']
-        # set default properties
-        if data is None:
+        if dataOrig is None:
+            # set default properties
             self.tree.GetPyData(item)[0]['nviz'] = {}
+        else:
+            data = dataOrig
-            if type == 'raster':
-                data['surface'] = {}
-                for sec in ('attribute', 'draw', 'mask', 'position'):
-                    data['surface'][sec] = {}
+        # reset data
+        if type == 'raster':
+            data[nvizType] = {}
+            for sec in ('attribute', 'draw', 'mask', 'position'):
+                data[nvizType][sec] = {}
+            if id > 0:
+                data[nvizType]['object'] = { 'id' : id,
+                                             'init' : False }
-                if id > 0 and not data[nvizType].has_key('object'):
-                    data[nvizType]['object'] = { 'id' : id,
-                                                 'init' : False }
+            self.SetSurfaceDefaultProp(data[nvizType])
+        elif type == 'vector':
+            data['vector'] = {}
+            for sec in ('lines', 'points'):
+                data['vector'][sec] = {}
+            if id > 0:
+                data['vector'][nvizType]['object'] = { 'id' : id,
+                                                       'init' : False }
-                self.SetSurfaceDefaultProp(data['surface'])
-            elif type == 'vector':
-                data['vector'] = {}
-                for sec in ('lines', 'points'):
-                    data['vector'][sec] = {}
+            self.SetVectorDefaultProp(data['vector']) # for both - lines/points
-                if id > 0 and not data['vector'][nvizType].has_key('object'):
-                    data['vector'][nvizType]['object'] = { 'id' : id,
-                                                           'init' : False }
-                self.SetVectorDefaultProp(data['vector'])
         # set updates
-        else:
-            if id > 0:
-                    if not data[nvizType].has_key('object'):
-                                                     'init' : False }
-                    if not data['vector'][nvizType].has_key('object'):
-                                                               'init' : False }
+        if dataOrig:
             for sec in data.keys():
                 for sec1 in data[sec].keys():
                     for sec2 in data[sec][sec1].keys():
-                        if sec2 != 'object':
+                        if sec2 not in ('object'):
                             self.update.append('%s:%s:%s' % (sec, sec1, sec2))
         return data
     def LoadRaster(self, item):
@@ -584,9 +583,10 @@
                                  'all' : False }
     def LoadVector(self, item, vecType=None):
-        """Load vector map overlay (lines / points)
+        """Load 2D or 3D vector map overlay
+        @param vecType vector type (lines / points)
         layer = self.tree.GetPyData(item)[0]['maplayer']
@@ -594,11 +594,16 @@
             return
         if vecType is None:
+            # load data type by default
             vecType = []
             for v in ('lines', 'points'):
                 if UserSettings.Get(group='nviz', key='vector',
                                     subkey=[v, 'show']):
                     vecType.append(v)
+                self.SetLayerData(item, -1, v)
         id = -1
         for type in vecType:
             if type == 'lines':
@@ -606,20 +611,16 @@
             else:
                 id = self.nvizClass.LoadVector(str(layer.name), True)
-            # set default/workspace layer properties
-            data = self.SetLayerData(item, id, type)['vector']
             if id < 0:
                 print >> sys.stderr, _("Vector map <%s> (%s) not loaded") % \
                     (layer.name, type)
                 continue
+            # update layer properties
+            self.SetLayerData(item, id, type)
             self.layers['v' + type]['name'].append(layer.name)
             self.layers['v'  + type]['id'].append(id)
-        if id < 0:
-            self.SetLayerData(item, id, 'lines')
-            self.SetLayerData(item, id, 'points')
         # update properties
         self.UpdateLayerProperties(item)
@@ -1573,7 +1574,7 @@
         self.win['vector']['points'] = {}
         showPoints = wx.CheckBox(parent=panel, id=wx.ID_ANY,
-                                label=_("Show vector points"))
+                                 label=_("Show vector points"))
         self.win['vector']['points']['show'] = showPoints.GetId()
         showPoints.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
@@ -2532,16 +2533,11 @@
     def OnVectorShow(self, event):
         """Show vector lines/points"""
         winId = event.GetId()
-        vecType = None
         if winId == self.win['vector']['lines']['show']:
             vecType = 'lines'
-        elif winId == self.win['vector']['points']['show']:
+        else: # points
             vecType = 'points'
-        if vecType is None:
-            return
         checked = event.IsChecked()
         item = self.mapWindow.GetSelectedLayer(type='item')
         data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']
@@ -2550,23 +2546,24 @@
             self.mapWindow.LoadVector(item, (vecType,))
         else:
             self.mapWindow.UnloadVector(item, (vecType,))
         self.UpdateVectorShow(vecType, checked)
         if checked:
             try:
                 id = data[vecType]['object']['id']
             except KeyError:
-                return
+                id = -1
-            self.mapWindow.SetLayerData(item, id, vecType)
+            if id > 0:
+                self.mapWindow.SetLayerData(item, id, vecType)
-            # update properties
-            self.mapWindow.UpdateLayerProperties(item)
+                # update properties
+                self.mapWindow.UpdateLayerProperties(item)
         if self.parent.autoRender.IsChecked():
             self.mapWindow.Refresh(False)
         event.Skip()
     def OnVectorDisplay(self, event):
@@ -2831,13 +2828,15 @@
         # lines
-        show = self.FindWindowById(self.win['vector']['lines']['show'])
+        showLines = self.FindWindowById(self.win['vector']['lines']['show'])
         if data['lines'].has_key('object'):
-            show.SetValue(True)
+            showLines.SetValue(True)
         else:
-            show.SetValue(False)
-        self.UpdateVectorShow(show.GetId(),
-                              show.IsChecked())
+            showLines.SetValue(False)
+        self.UpdateVectorShow(showLines.GetId(),
+                              showLines.IsChecked())
         width = self.FindWindowById(self.win['vector']['lines']['width'])
         width.SetValue(data['lines']['width'])
@@ -2866,14 +2865,15 @@
         # points
-        show = self.FindWindowById(self.win['vector']['points']['show'])
+        showPoints = self.FindWindowById(self.win['vector']['points']['show'])
         if data['points'].has_key('object'):
+            showPoints.SetValue(True)
         else:
-                              show.IsChecked())
+            showPoints.SetValue(False)
+        self.UpdateVectorShow(showPoints.GetId(),
+                              showPoints.IsChecked())
         for prop in ('size', 'width', 'marker', 'color'):
             win = self.FindWindowById(self.win['vector']['points'][prop])
             name = win.GetName()
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-07-28 13:31:49 UTC (rev 32351)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-07-28 22:22:28 UTC (rev 32352)
@@ -44,11 +44,13 @@
                     'layer_manager',
                     'nviz',
                     # surface
-                    'attribute', 'draw', 'resolution',
+                    'surface', 'attribute', 'draw', 'resolution',
                     'wire_color', 'position', 'x', 'y', 'z',
                     # vector lines
-                    'lines', 'color', 'width', 'mode',
-                    'map', 'height'):
+                    'vlines', 'color', 'width', 'mode',
+                    'map', 'height',
+                    # vector points
+                    'vpoints'):
             self.inTag[tag] = False
@@ -163,43 +165,47 @@
                     self.layerNviz['surface'][sec] = {}
             elif self.layerType == 'vector':
                 self.layerNviz['vector'] = {}
-                for sec in ('lines', ):
                     self.layerNviz['vector'][sec] = {}
         elif name == 'attribute':
-            tagName = str(name)
-            attrbName = str(attrs.get('name', ''))
-            self.layerNviz['surface'][tagName][attrbName] = {}
-            if attrs.get('map', '0') == '0':
-                self.layerNviz['surface'][tagName][attrbName]['map'] = False
-            else:
-                self.layerNviz['surface'][tagName][attrbName]['map'] = True
+            if self.inTag['nviz'] and self.inTag['surface']:
+                tagName = str(name)
+                attrbName = str(attrs.get('name', ''))
+                self.layerNviz['surface'][tagName][attrbName] = {}
+                if attrs.get('map', '0') == '0':
+                    self.layerNviz['surface'][tagName][attrbName]['map'] = False
+                else:
+                    self.layerNviz['surface'][tagName][attrbName]['map'] = True
-            self.refAttribute = self.layerNviz['surface'][tagName][attrbName]
+                self.refAttribute = self.layerNviz['surface'][tagName][attrbName]
         elif name == 'draw':
-            self.layerNviz['surface'][tagName]['mode'] = {}
-            self.layerNviz['surface'][tagName]['mode']['all'] = False
-            self.layerNviz['surface'][tagName]['mode']['value'] = -1 # to be calculated
-            self.layerNviz['surface'][tagName]['mode']['desc'] = {}
-            self.layerNviz['surface'][tagName]['mode']['desc']['shading'] = \
-                str(attrs.get('shading', ''))
-            self.layerNviz['surface'][tagName]['mode']['desc']['style'] = \
-                str(attrs.get('style', ''))
-            self.layerNviz['surface'][tagName]['mode']['desc']['mode'] = \
-                str(attrs.get('mode', ''))
+                self.layerNviz['surface'][tagName]['mode'] = {}
+                self.layerNviz['surface'][tagName]['mode']['all'] = False
+                self.layerNviz['surface'][tagName]['mode']['value'] = -1 # to be calculated
+                self.layerNviz['surface'][tagName]['mode']['desc'] = {}
+                self.layerNviz['surface'][tagName]['mode']['desc']['shading'] = \
+                    str(attrs.get('shading', ''))
+                self.layerNviz['surface'][tagName]['mode']['desc']['style'] = \
+                    str(attrs.get('style', ''))
+                self.layerNviz['surface'][tagName]['mode']['desc']['mode'] = \
+                    str(attrs.get('mode', ''))
         elif name == 'resolution':
-            self.resolutionType = str(attrs.get('type', ''))
-            if not self.layerNviz['surface']['draw'].has_key(str(name)):
-                self.layerNviz['surface']['draw'][str(name)] = {}
+                self.resolutionType = str(attrs.get('type', ''))
+                if not self.layerNviz['surface']['draw'].has_key(str(name)):
+                    self.layerNviz['surface']['draw'][str(name)] = {}
         elif name == 'position':
-            self.layerNviz['surface']['position'] = {}
+            if self.inTag['nviz'] and inTag['surface']:
+                self.layerNviz['surface']['position'] = {}
         elif name == 'mode':
-            if self.inTag['nviz'] and self.inTag['lines']:
+            if self.inTag['nviz'] and self.inTag['vlines']:
                 self.layerNviz['vector']['lines']['mode'] = {}
                 self.layerNviz['vector']['lines']['mode']['type'] = str(attrs.get('type', ''))
@@ -237,47 +243,53 @@
         # Nviz section
-            try:
-                self.refAttribute['value'] = int(self.value)
-            except ValueError:
                 try:
-                    self.refAttribute['value'] = float(self.value)
+                    self.refAttribute['value'] = int(self.value)
                 except ValueError:
-                    self.refAttribute['value'] = str(self.value)
+                    try:
+                        self.refAttribute['value'] = float(self.value)
+                    except ValueError:
+                        self.refAttribute['value'] = str(self.value)
-            self.layerNviz['surface']['draw']['resolution']['all'] = False
-            self.layerNviz['surface']['draw']['resolution'][self.resolutionType] = int(self.value)
-            del self.resolutionType
+                self.layerNviz['surface']['draw']['resolution']['all'] = False
+                self.layerNviz['surface']['draw']['resolution'][self.resolutionType] = int(self.value)
+                del self.resolutionType
         elif name == 'wire_color':
-            self.layerNviz['surface']['draw']['wire-color'] = {}
-            self.layerNviz['surface']['draw']['wire-color']['all'] = False
-            self.layerNviz['surface']['draw']['wire-color']['value'] = str(self.value)
+                self.layerNviz['surface']['draw']['wire-color'] = {}
+                self.layerNviz['surface']['draw']['wire-color']['all'] = False
+                self.layerNviz['surface']['draw']['wire-color']['value'] = str(self.value)
         elif name == 'x':
-            self.layerNviz['surface']['position']['x'] = int(self.value)
+                self.layerNviz['surface']['position']['x'] = int(self.value)
         elif name == 'y':
-            self.layerNviz['surface']['position']['y'] = int(self.value)
+                self.layerNviz['surface']['position']['y'] = int(self.value)
         elif name == 'z':
-            self.layerNviz['surface']['position']['z'] = int(self.value)
+                self.layerNviz['surface']['position']['z'] = int(self.value)
         elif name == 'color':
                 self.layerNviz['vector']['lines']['color'] = str(self.value)
         elif name == 'width':
                 self.layerNviz['vector']['lines']['width'] = int(self.value)
         elif name == 'height':
                 self.layerNviz['vector']['lines']['height'] = int(self.value)
         self.inTag[name] = False
@@ -426,6 +438,8 @@
             return
         self.indent += 4
+        self.file.write('%s<surface>\n' % (' ' * self.indent))
+        self.indent += 4
         for attrb in data.iterkeys():
             if len(data[attrb]) < 1: # skip empty attributes
                 continue
@@ -486,6 +500,8 @@
                 self.file.write('%s</%s>\n' % (' ' * self.indent, attrb))
         self.indent -= 4
+        self.file.write('%s</surface>\n' % (' ' * self.indent))
+        self.indent -= 4
     def __writeNvizVector(self, data):
         """Save Nviz vector layer properties (lines/points) to workspace
@@ -500,7 +516,7 @@
             if not data[attrb].has_key('object'): # skip disabled
                 continue
-            self.file.write('%s<%s>\n' % (' ' * self.indent, attrb))
+            self.file.write('%s<v%s>\n' % (' ' * self.indent, attrb))
             self.indent += 4
             for name in data[attrb].iterkeys():
                 if name == 'object':
@@ -521,7 +537,7 @@
                     self.indent -= 4
                     self.file.write('%s</%s>\n' % (' ' * self.indent, name))
             self.indent -= 4
-            self.file.write('%s</%s>\n' % (' ' * self.indent, attrb))
+            self.file.write('%s</v%s>\n' % (' ' * self.indent, attrb))
         self.indent -= 4
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-07-28 13:31:49 UTC (rev 32351)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-07-28 22:22:28 UTC (rev 32352)
@@ -75,10 +75,16 @@
 <!ELEMENT flag          EMPTY>
 <!ATTLIST flag          name            CDATA #REQUIRED>
+<!-- *********************** Nviz *********************** -->
 <!--    nviz layer properties
-<!ELEMENT nviz	        (attribute*, draw?, position?, lines?)>
+<!ELEMENT nviz	        (surface? | (vlines | vpoints)?)>
+<!--    nviz surface properties
+<!ELEMENT surface       (attribute*, draw?, position?)>
 <!--    nviz surface attribute parameter
 <!ELEMENT attribute     (value)>
@@ -112,7 +118,7 @@
 <!--    nviz vector lines element
-<!ELEMENT lines     (color?, width?, mode?, height?)>
+<!ELEMENT vlines    (color?, width?, mode?, height?)>
 <!ELEMENT color     (value)>
 <!ELEMENT width     (value)>
 <!ELEMENT height    (value)>
