[GRASS-SVN] r32357 - grass/trunk/gui/wxpython/gui_modules
Tue Jul 29 08:12:46 EDT 2008
Author: martinl
Date: 2008-07-29 08:12:46 -0400 (Tue, 29 Jul 2008)
New Revision: 32357
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/nviz.py
wxGUI/nviz2: 3D vector data supported
EnsureCaretVisible() enabled in goutput module, trac #201 re-opened
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-29 10:50:03 UTC (rev 32356)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-29 12:12:46 UTC (rev 32357)
@@ -367,7 +367,7 @@
         for line in s.split(os.linesep):
             p1 = self.gmstc.GetCurrentPos() # get caret position
             self.gmstc.AddTextWrapped(line, wrap=None) # no wrapping && adds os.linesep
-            # self.gmstc.EnsureCaretVisible()
+            self.gmstc.EnsureCaretVisible()
             p2 = self.gmstc.GetCurrentPos()
             self.gmstc.StartStyling(p1, 0xff)
             self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleOutput)
@@ -435,7 +435,7 @@
                 if len(line) > 0:
                     self.gmstc.AddTextWrapped(line, wrap=60) # wrap && add os.linesep
                     self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleUnknown)
@@ -452,7 +452,7 @@
                     self.gmstc.AddTextWrapped(self.message, wrap=60) #wrap && add os.linesep
                 else:
                     self.gmstc.AddText(self.message + os.linesep)
                 if self.type == 'error':
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-29 10:50:03 UTC (rev 32356)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-29 12:12:46 UTC (rev 32357)
@@ -439,8 +439,7 @@
         id = self.nvizClass.LoadSurface(str(layer.name), None, None)
         if id < 0:
-            raise gcmd.NvizError(parent=self.parent,
-                                 message=_("Raster map <%s> not loaded" % layer.name))
+            print >> sys.stderr, _("Loading raster map <%s> failed") % layer.name
         self.layers['raster']['name'].append(layer.name)
         self.layers['raster']['id'].append(id)
@@ -475,8 +474,9 @@
         id = data['surface']['object']['id']
         if self.nvizClass.UnloadSurface(id) == 0:
-                                 message=_("Unable to unload raster map <%s>" % layer.name))
+            print >> sys.stderr, _("Unable to unload raster map <%s>") % layer.name
+        else:
+            print _("Raster map <%s> unloaded") % layer.name
         data['surface'].pop('object')
@@ -629,10 +629,10 @@
                 id = self.nvizClass.LoadVector(str(layer.name), True)
             if id < 0:
-                print >> sys.stderr, _("Vector map <%s> (%s) not loaded") % \
+                print >> sys.stderr, _("Loading vector map <%s> (%s) failed") % \
                     (layer.name, type)
                 continue
             # update layer properties
             self.SetLayerData(item, id, type)
@@ -679,9 +679,13 @@
             else:
                 ret = self.nvizClass.UnloadVector(id, True)
             if ret == 0:
-                                     message=_("Unable to unload vector map <%s>" % layer.name))
+                print >> sys.stderr, _("Unable to unload vector map <%s> (%s)") % \
+                    (layer.name, vtype)
+            else:
+                print >> sys.stderr, _("Vector map <%s> (%s) unloaded") % \
             data[vtype].pop('object')
             idx = self.layers['v' + vtype]['id'].index(id)
@@ -1496,6 +1500,16 @@
         self.win['vector'] = {}
+        # desc
+        desc = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                             label="")
+        self.win['vector']['desc'] = desc.GetId()
+        pageSizer.Add(item=desc, proportion=0,
+                      flag=wx.EXPAND | wx.ALL,
+                      border=10)
         # vector lines
         self.win['vector']['lines'] = {}
@@ -1506,7 +1520,7 @@
         showLines.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
         pageSizer.Add(item=showLines, proportion=0,
-                      flag=wx.ALL | wx.EXPAND, border=5)
+                      flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
         box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
                             label=" %s " % (_("Vector lines")))
@@ -2846,6 +2860,26 @@
         self.SetSurfaceWireColor(color.GetColour())
     def UpdateVectorPage(self, layer, data):
+        vInfo = gcmd.Command(['v.info',
+                              'map=%s' % layer.name])
+        for line in vInfo.ReadStdOutput():
+            if 'Map is 3D' in line:
+                mapIs3D = int(line.replace('|', '').split(':')[1].strip())
+                break
+        if mapIs3D:
+            desc = _("Vector map <%s> is 3D") % layer.name
+            enable = False
+        else:
+            desc = _("Vector map <%s> is 2D") % layer.name
+            enable = True
+        self.FindWindowById(self.win['vector']['lines']['flat']).Enable(enable)
+        for v in ('lines', 'points'):
+            self.FindWindowById(self.win['vector'][v]['surface']).Enable(enable)
+            self.FindWindowById(self.win['vector'][v]['height']['slider']).Enable(enable)
+            self.FindWindowById(self.win['vector'][v]['height']['spin']).Enable(enable)
+        self.FindWindowById(self.win['vector']['desc']).SetLabel(desc)
         # lines
