[GRASS-SVN] r32366 - grass/trunk/gui/wxpython/gui_modules
Wed Jul 30 05:48:58 EDT 2008
Author: martinl
Date: 2008-07-30 05:48:57 -0400 (Wed, 30 Jul 2008)
New Revision: 32366
   grass/trunk/gui/wxpython/gui_modules/gcmd.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
wxGUI: gcmd module cleanning, update r32364
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-07-30 00:01:04 UTC (rev 32365)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-07-30 09:48:57 UTC (rev 32366)
@@ -4,11 +4,16 @@
 @brief GRASS command interface
 Classes:
- * GException
- * DigitError
- * Popen (from http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/440554)
- * Command
- * CommandThread
+ - GException
+ - GStdError
+ - CmdError
+ - SettingsError
+ - DigitError
+ - DBMError
+ - NvizError
+ - Popen (from http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/440554)
+ - Command
+ - CommandThread
 (C) 2007-2008 by the GRASS Development Team
 This program is free software under the GNU General Public
@@ -44,7 +49,7 @@
     import fcntl
 from threading import Thread
-# import wxgui_utils # log window
+import grass
 import globalvar
 import utils
 from debug import Debug as Debug
@@ -257,22 +262,6 @@
             raise Exception(message)
         data = buffer(data, sent)
-# Define notification event for thread completion
-EVT_RESULT_ID = wx.NewId()
-def EVT_RESULT(win, func):
-    """Define Result Event"""
-    win.Connect(-1, -1, EVT_RESULT_ID, func)
-class ResultEvent(wx.PyEvent):
-    """Simple event to carry arbitrary result data"""
-    def __init__(self, data):
-        wx.PyEvent.__init__(self)
-        self.SetEventType(EVT_RESULT_ID)
-        self.cmdThread = data
 class Command:
     Run GRASS command in separate thread
@@ -306,14 +295,14 @@
                   stdout=None, stderr=sys.stderr):
         self.cmd = cmd
+        self.stderr = stderr
 	# hack around platform-specific extension for binaries
 	if self.cmd[0] in globalvar.grassCmd['script']:
 	    self.cmd[0] = self.cmd[0] + globalvar.EXT_SCT
 	else:
 	    self.cmd[0] = self.cmd[0] + globalvar.EXT_BIN
-        self.stderr = stderr
         # set verbosity level
@@ -338,14 +327,10 @@
         # create command thread
-        self.cmdThread = CommandThread(cmd, stdin,
-                                       stdout, stderr)
-        # start thread
+        self.cmdThread = RunCommand(cmd, stdin,
+                                    stdout, stderr)
         self.cmdThread.start()
         if wait:
             self.cmdThread.join()
             if self.cmdThread.module:
@@ -482,133 +467,36 @@
         return msgString
 class CommandThread(Thread):
-    """Run command in separate thread
+    """Create separate thread for command
     @param cmd GRASS command (given as list)
     @param stdin standard input stream
     @param stdout  redirect standard output or None
     @param stderr  redirect standard error output or None
-    def __init__ (self, cmd,
-                  stdin=None, stdout=None, stderr=sys.stderr):
+    def __init__ (self, cmd, stdin=None,
+                  stdout=sys.stdout, stderr=sys.stderr):
         Thread.__init__(self)
         self.cmd    = cmd
         self.stdin  = stdin
         self.stdout = stdout
         self.module = None
-        self.rerr   = ''
+        self.error  = ''
         self._want_abort = False
         self.aborted = False
-        self.startTime = None
         self.setDaemon(True)
     def run(self):
-        """Run command"""
         if len(self.cmd) == 0:
             return
-        self.startTime = time.time()
-        # TODO: wx.Exectute/wx.Process (?)
-        try:
-            self.module = Popen(self.cmd,
-                                stdin=subprocess.PIPE,
-                                stdout=subprocess.PIPE,
-                                stderr=subprocess.PIPE)
-        except OSError, e:
-            self.rerr = str(e)
-            return
-        if self.stdin: # read stdin if requested ...
-            self.module.stdin.write(self.stdin)
-            self.module.stdin.close()
-        # redirect standard outputs...
-        if self.stdout or self.stderr:
-            self.__redirect_stream()
-    def __redirect_stream(self):
-        """Redirect stream"""
-        if self.stdout:
-            # make module stdout/stderr non-blocking
-            out_fileno = self.module.stdout.fileno()
-	    if not subprocess.mswindows:
-                flags = fcntl.fcntl(out_fileno, fcntl.F_GETFL)
-                fcntl.fcntl(out_fileno, fcntl.F_SETFL, flags| os.O_NONBLOCK)
-        if self.stderr:
-            out_fileno = self.module.stderr.fileno()
-        # wait for the process to end, sucking in stuff until it does end
-        while self.module.poll() is None:
-            if self._want_abort: # abort running process
-                self.module.kill()
-                self.aborted = True
-                if hasattr(self.stderr, "gmstc"):
-                    # -> GMConsole
-                    wx.PostEvent(self.stderr.gmstc.parent, ResultEvent(self))
-                    pass
-                return
-            if self.stdout:
-                line = recv_some(self.module, e=0, stderr=0)
-                self.stdout.write(line)
-            if self.stderr:
-                line = recv_some(self.module, e=0, stderr=1)
-                self.stderr.write(line)
-                self.rerr = line
-        # get the last output
-        if self.stdout:
-        if self.stderr:
-            if len(line) > 0:
-                self.rerr = line
-            # -> GMConsole
-            pass
-    def abort(self):
-        """Abort running process, used by main thread to signal an abort"""
-        self._want_abort = True
-class RunCommand:
-    @param cmd GRASS command (given as list)
-    @param stdin standard input stream
-    @param stdout  redirect standard output or None
-    @param stderr  redirect standard error output or None
-    def __init__ (self, cmd, stdin=None,
-                  stdout=sys.stdout, stderr=sys.stderr):
-        self.cmd    = cmd
-        self.stdin  = stdin
-        self.stdout = stdout
-        self._want_abort = False
-        self.aborted = False
-    def run(self):
         try:
@@ -617,7 +505,7 @@
         except OSError, e:
+            self.error = str(e)
             return 1
@@ -672,65 +560,3 @@
-# testing ...
-if __name__ == "__main__":
-    SEP = "-----------------------------------------------------------------------------"
-    print SEP
-    # d.rast verbosely, wait for process termination
-    print "Running d.rast..."
-    cmd = Command(cmd=["d.rast", "elevation.dem"], verbose=3, wait=True, rerr=True)
-    if cmd.returncode == None:
-        print "RUNNING"
-    elif cmd.returncode == 0:
-        print "SUCCESS"
-    else:
-        print "FAILURE (%d)" % cmd.returncode
-    print SEP
-    # v.net.path silently, wait for process termination
-    print "Running v.net.path for 0 593527.6875 4925297.0625 602083.875 4917545.8125..."
-    cmd = Command(cmd=["v.net.path", "in=roads at PERMANENT", "out=tmp", "dmax=100000", "--o"],
-                  stdin="0 593527.6875 4925297.0625 602083.875 4917545.8125",
-                  verbose=0,
-                  wait=True, rerr=None)
-        print "RUNNING"
-        print "SUCCESS"
-    else:
-    print SEP
-    # d.vect silently, do not wait for process termination
-    # returncode will be None
-    print "Running d.vect tmp..."
-    cmd = Command(["d.vect", "tmp"], verbose=2, wait=False, rerr=None)
-        print "RUNNING"
-        print "SUCCESS"
-    else:
-    cmd = Command(["g.region", "-p"])
-    for line in cmd.ReadStdOutput():
-        print line
-    cmd = Command(["g.region", "-p"], stderr=None)
-        print line
-    for line in cmd.ReadErrOutput():
-        print line
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-30 00:01:04 UTC (rev 32365)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-07-30 09:48:57 UTC (rev 32366)
@@ -39,9 +39,9 @@
 wxCmdAbort,    EVT_CMD_ABORT    = NewEvent()
 def GrassCmd(cmd, stdout, stderr):
-    """Run GRASS command on background"""
-    return gcmd.RunCommand(cmd=cmd,
-                           stdout=stdout, stderr=stderr)
+    """Return GRASS command thread"""
+    return gcmd.CommandThread(cmd=cmd,
+                              stdout=stdout, stderr=stderr)
 class CmdThread(threading.Thread):
     """Thread for GRASS commands"""
@@ -71,6 +71,7 @@
         while True:
             requestId, callable, args, kwds = self.requestQ.get()
             self.requestCmd = callable(*args, **kwds)
+            self.requestCmd.start()
             self.resultQ.put((requestId, self.requestCmd.run()))
             event = wxCmdDone(aborted=self.requestCmd.aborted,
