[GRASS-SVN] r32412 - grass/trunk/swig/perl
Thu Jul 31 13:44:23 EDT 2008
Author: glynn
Date: 2008-07-31 13:44:22 -0400 (Thu, 31 Jul 2008)
New Revision: 32412
Removed:
   grass/trunk/swig/perl/grass_wrap.c
Remove SWIG auto-generated wrapper (not a source file)
Deleted: grass/trunk/swig/perl/grass_wrap.c
--- grass/trunk/swig/perl/grass_wrap.c	2008-07-31 17:43:47 UTC (rev 32411)
+++ grass/trunk/swig/perl/grass_wrap.c	2008-07-31 17:44:22 UTC (rev 32412)
@@ -1,26546 +0,0 @@
- * This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.24
- * This file is not intended to be easily readable and contains a number of
- * coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
-#ifndef SWIG_TEMPLATE_DISAMBIGUATOR
-#  if defined(__SUNPRO_CC)
-#    define SWIG_TEMPLATE_DISAMBIGUATOR template
-#  else
-#  endif
-#endif
- * swigrun.swg
- *     This file contains generic CAPI SWIG runtime support for pointer
- *     type checking.
-/* This should only be incremented when either the layout of swig_type_info changes,
-   or for whatever reason, the runtime changes incompatibly */
-#define SWIG_RUNTIME_VERSION "1"
-/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
-#ifdef SWIG_TYPE_TABLE
-#define SWIG_QUOTE_STRING(x) #x
-#define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
-#define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
-#else
-#endif
-#include <string.h>
-#ifndef SWIGINLINE
-#if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
-#  define SWIGINLINE inline
-#else
-#endif
-#endif
-  You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
-  creating a static or dynamic library from the swig runtime code.
-  In 99.9% of the cases, swig just needs to declare them as 'static'.
-  But only do this if is strictly necessary, ie, if you have problems
-  with your compiler or so.
-#ifndef SWIGRUNTIME
-#define SWIGRUNTIME static
-#endif
-#ifndef SWIGRUNTIMEINLINE
-#define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef void *(*swig_converter_func)(void *);
-typedef struct swig_type_info *(*swig_dycast_func)(void **);
-typedef struct swig_type_info {
-  const char             *name;
-  swig_converter_func     converter;
-  const char             *str;
-  void                   *clientdata;
-  swig_dycast_func        dcast;
-  struct swig_type_info  *next;
-  struct swig_type_info  *prev;
-} swig_type_info;
-  Compare two type names skipping the space characters, therefore
-  "char*" == "char *" and "Class<int>" == "Class<int >", etc.
-  Return 0 when the two name types are equivalent, as in
-  strncmp, but skipping ' '.
-SWIGRUNTIME int
-SWIG_TypeNameComp(const char *f1, const char *l1,
-		  const char *f2, const char *l2) {
-  for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
-    while ((*f1 == ' ') && (f1 != l1)) ++f1;
-    while ((*f2 == ' ') && (f2 != l2)) ++f2;
-    if (*f1 != *f2) return *f1 - *f2;
-  return (l1 - f1) - (l2 - f2);
-  Check type equivalence in a name list like <name1>|<name2>|...
-SWIGRUNTIME int
-SWIG_TypeEquiv(const char *nb, const char *tb) {
-  int equiv = 0;
-  const char* te = tb + strlen(tb);
-  const char* ne = nb;
-  while (!equiv && *ne) {
-    for (nb = ne; *ne; ++ne) {
-      if (*ne == '|') break;
-    equiv = SWIG_TypeNameComp(nb, ne, tb, te) == 0;
-    if (*ne) ++ne;
-  return equiv;
-  Register a type mapping with the type-checking
-SWIGRUNTIME swig_type_info *
-SWIG_TypeRegisterTL(swig_type_info **tl, swig_type_info *ti) {
-  swig_type_info *tc, *head, *ret, *next;
-  /* Check to see if this type has already been registered */
-  tc = *tl;
-  while (tc) {
-    /* check simple type equivalence */
-    int typeequiv = (strcmp(tc->name, ti->name) == 0);
-    /* check full type equivalence, resolving typedefs */
-    if (!typeequiv) {
-      /* only if tc is not a typedef (no '|' on it) */
-      if (tc->str && ti->str && !strstr(tc->str,"|")) {
-	typeequiv = SWIG_TypeEquiv(ti->str,tc->str);
-    if (typeequiv) {
-      /* Already exists in the table.  Just add additional types to the list */
-      if (ti->clientdata) tc->clientdata = ti->clientdata;
-      head = tc;
-      next = tc->next;
-      goto l1;
-    tc = tc->prev;
-  head = ti;
-  next = 0;
-  /* Place in list */
-  ti->prev = *tl;
-  *tl = ti;
-  /* Build linked lists */
-  l1:
-  ret = head;
-  tc = ti + 1;
-  /* Patch up the rest of the links */
-  while (tc->name) {
-    head->next = tc;
-    tc->prev = head;
-    head = tc;
-    tc++;
-  if (next) next->prev = head;
-  head->next = next;
-  return ret;
-  Check the typename
-SWIG_TypeCheck(const char *c, swig_type_info *ty) {
-  swig_type_info *s;
-  if (!ty) return 0;        /* Void pointer */
-  s = ty->next;             /* First element always just a name */
-  do {
-    if (strcmp(s->name,c) == 0) {
-      if (s == ty->next) return s;
-      /* Move s to the top of the linked list */
-      s->prev->next = s->next;
-      if (s->next) {
-        s->next->prev = s->prev;
-      /* Insert s as second element in the list */
-      s->next = ty->next;
-      if (ty->next) ty->next->prev = s;
-      ty->next = s;
-      s->prev = ty;
-      return s;
-    s = s->next;
-  } while (s && (s != ty->next));
-  return 0;
-  Cast a pointer up an inheritance hierarchy
-SWIGRUNTIMEINLINE void *
-SWIG_TypeCast(swig_type_info *ty, void *ptr) {
-  return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr);
-   Dynamic pointer casting. Down an inheritance hierarchy
-SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
-  swig_type_info *lastty = ty;
-  if (!ty || !ty->dcast) return ty;
-  while (ty && (ty->dcast)) {
-    ty = (*ty->dcast)(ptr);
-    if (ty) lastty = ty;
-  return lastty;
-  Return the name associated with this type
-SWIGRUNTIMEINLINE const char *
-SWIG_TypeName(const swig_type_info *ty) {
-  return ty->name;
-  Return the pretty name associated with this type,
-  that is an unmangled type name in a form presentable to the user.
-SWIGRUNTIME const char *
-SWIG_TypePrettyName(const swig_type_info *type) {
-  /* The "str" field contains the equivalent pretty names of the
-     type, separated by vertical-bar characters.  We choose
-     to print the last name, as it is often (?) the most
-     specific. */
-  if (type->str != NULL) {
-    const char *last_name = type->str;
-    const char *s;
-    for (s = type->str; *s; s++)
-      if (*s == '|') last_name = s+1;
-    return last_name;
-  else
-    return type->name;
-  Search for a swig_type_info structure
-SWIG_TypeQueryTL(swig_type_info *tl, const char *name) {
-  swig_type_info *ty = tl;
-  while (ty) {
-    if (ty->str && (SWIG_TypeEquiv(ty->str,name))) return ty;
-    if (ty->name && (strcmp(name,ty->name) == 0)) return ty;
-    ty = ty->prev;
-  return 0;
-   Set the clientdata field for a type
-SWIGRUNTIME void
-SWIG_TypeClientDataTL(swig_type_info *tl, swig_type_info *ti, void *clientdata) {
-  swig_type_info *tc, *equiv;
-  if (ti->clientdata) return;
-  /* if (ti->clientdata == clientdata) return; */
-  ti->clientdata = clientdata;
-  equiv = ti->next;
-  while (equiv) {
-    if (!equiv->converter) {
-      tc = tl;
-      while (tc) {
-        if ((strcmp(tc->name, equiv->name) == 0))
-          SWIG_TypeClientDataTL(tl,tc,clientdata);
-        tc = tc->prev;
-    equiv = equiv->next;
-   Pack binary data into a string
-SWIGRUNTIME char *
-SWIG_PackData(char *c, void *ptr, size_t sz) {
-  static char hex[17] = "0123456789abcdef";
-  unsigned char *u = (unsigned char *) ptr;
-  const unsigned char *eu =  u + sz;
-  register unsigned char uu;
-  for (; u != eu; ++u) {
-    uu = *u;
-    *(c++) = hex[(uu & 0xf0) >> 4];
-    *(c++) = hex[uu & 0xf];
-  return c;
-   Unpack binary data from a string
-SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
-  register unsigned char *u = (unsigned char *) ptr;
-  register const unsigned char *eu =  u + sz;
-    register int d = *(c++);
-    register unsigned char uu = 0;
-    if ((d >= '0') && (d <= '9'))
-      uu = ((d - '0') << 4);
-    else if ((d >= 'a') && (d <= 'f'))
-      uu = ((d - ('a'-10)) << 4);
-    else
-      return (char *) 0;
-    d = *(c++);
-      uu |= (d - '0');
-      uu |= (d - ('a'-10));
-    else
-    *u = uu;
-  return c;
-  This function will propagate the clientdata field of type to any new
-  swig_type_info structures that have been added into the list of
-  equivalent types.  It is like calling SWIG_TypeClientData(type,
-  clientdata) a second time.
-SWIGRUNTIME void
-SWIG_PropagateClientDataTL(swig_type_info *tl, swig_type_info *type) {
-  swig_type_info *equiv = type->next;
-  swig_type_info *tc;
-  if (!type->clientdata) return;
-  while (equiv) {
-      tc = tl;
-      while (tc) {
-        if ((strcmp(tc->name, equiv->name) == 0) && !tc->clientdata)
-          SWIG_TypeClientDataTL(tl,tc, type->clientdata);
-        tc = tc->prev;
-   Pack 'void *' into a string buffer.
-SWIGRUNTIME char *
-SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
-  char *r = buff;
-  if ((2*sizeof(void *) + 2) > bsz) return 0;
-  *(r++) = '_';
-  r = SWIG_PackData(r,&ptr,sizeof(void *));
-  if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
-  strcpy(r,name);
-  return buff;
-SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
-  if (*c != '_') {
-    if (strcmp(c,"NULL") == 0) {
-      *ptr = (void *) 0;
-      return name;
-    } else {
-      return 0;
-  return SWIG_UnpackData(++c,ptr,sizeof(void *));
-SWIGRUNTIME char *
-SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
-  char *r = buff;
-  size_t lname = (name ? strlen(name) : 0);
-  if ((2*sz + 2 + lname) > bsz) return 0;
-  *(r++) = '_';
-  r = SWIG_PackData(r,ptr,sz);
-  if (lname) {
-    strncpy(r,name,lname+1);
-  } else {
-    *r = 0;
-  return buff;
-SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
-  if (*c != '_') {
-      memset(ptr,0,sz);
-      return name;
-    } else {
-      return 0;
-  return SWIG_UnpackData(++c,ptr,sz);
-#ifdef __cplusplus
-#endif
- * common.swg
- *     This file contains generic SWIG runtime support for pointer
- *     type checking as well as a few commonly used macros to control
- *     external linkage.
- * Author : David Beazley (beazley at cs.uchicago.edu)
- * Copyright (c) 1999-2000, The University of Chicago
- * This file may be freely redistributed without license or fee provided
- * this copyright message remains intact.
-#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-#  if !defined(STATIC_LINKED)
-#    define SWIGEXPORT(a) __declspec(dllexport) a
-#  else
-#    define SWIGEXPORT(a) a
-#  endif
-#else
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* The static type info list */
-static swig_type_info *swig_type_list = 0;
-static swig_type_info **swig_type_list_handle = &swig_type_list;
-/* Register a type mapping with the type-checking */
-SWIG_TypeRegister(swig_type_info *ti) {
-  return SWIG_TypeRegisterTL(swig_type_list_handle, ti);
-/* Search for a swig_type_info structure */
-SWIG_TypeQuery(const char *name) {
-  return SWIG_TypeQueryTL(*swig_type_list_handle, name);
-/* Set the clientdata field for a type */
-static void
-SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
-  SWIG_TypeClientDataTL(*swig_type_list_handle, ti, clientdata);
-/* This function will propagate the clientdata field of type to
-* any new swig_type_info structures that have been added into the list
-* of equivalent types.  It is like calling
-* SWIG_TypeClientData(type, clientdata) a second time.
-static void
-SWIG_PropagateClientData(swig_type_info *type) {
-  SWIG_PropagateClientDataTL(*swig_type_list_handle, type);
-#ifdef __cplusplus
-#endif
-/* ---------------------------------------------------------------------- -*- c -*-
- * perl5.swg
- * Perl5 runtime library
- * $Header$
-#define SWIGPERL
-#define SWIGPERL5
-#ifdef __cplusplus
-/* Needed on some windows machines---since MS plays funny games with the header files under C++ */
-#include <math.h>
-#include <stdlib.h>
-extern "C" {
-#endif
-#include "EXTERN.h"
-#include "perl.h"
-#include "XSUB.h"
-/* Get rid of free and malloc defined by perl */
-#undef free
-#undef malloc
-#ifndef pTHX_
-#define pTHX_
-#endif
-#ifdef __cplusplus
-#endif
-/* Macro to call an XS function */
-#ifdef PERL_OBJECT
-#  define SWIG_CALLXS(_name) _name(cv,pPerl)
-#else
-#  ifndef MULTIPLICITY
-#    define SWIG_CALLXS(_name) _name(cv)
-#  else
-#    define SWIG_CALLXS(_name) _name(PERL_GET_THX, cv)
-#  endif
-#endif
-/* Contract support */
-#define SWIG_contract_assert(expr,msg) if (!(expr)) { SWIG_croak(msg); } else
-/* Note: SwigMagicFuncHack is a typedef used to get the C++ compiler to just shut up already */
-#ifdef PERL_OBJECT
-#define MAGIC_PPERL  CPerlObj *pPerl = (CPerlObj *) this;
-typedef int (CPerlObj::*SwigMagicFunc)(SV *, MAGIC *);
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef int (CPerlObj::*SwigMagicFuncHack)(SV *, MAGIC *);
-#ifdef __cplusplus
-#endif
-#define SWIG_MAGIC(a,b) (SV *a, MAGIC *b)
-#define SWIGCLASS_STATIC
-#else
-#define SWIGCLASS_STATIC static
-#ifndef MULTIPLICITY
-typedef int (*SwigMagicFunc)(SV *, MAGIC *);
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef int (*SwigMagicFuncHack)(SV *, MAGIC *);
-#ifdef __cplusplus
-#endif
-#else
-#define SWIG_MAGIC(a,b) (struct interpreter *interp, SV *a, MAGIC *b)
-typedef int (*SwigMagicFunc)(struct interpreter *, SV *, MAGIC *);
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef int (*SwigMagicFuncHack)(struct interpreter *, SV *, MAGIC *);
-#ifdef __cplusplus
-#endif
-#endif
-#endif
-#if defined(WIN32) && defined(PERL_OBJECT) && !defined(PerlIO_exportFILE)
-#define PerlIO_exportFILE(fh,fl) (FILE*)(fh)
-#endif
-/* Modifications for newer Perl 5.005 releases */
-#if !defined(PERL_REVISION) || ((PERL_REVISION >= 5) && ((PERL_VERSION < 5) || ((PERL_VERSION == 5) && (PERL_SUBVERSION < 50))))
-#  ifndef PL_sv_yes
-#    define PL_sv_yes sv_yes
-#  endif
-#  ifndef PL_sv_undef
-#    define PL_sv_undef sv_undef
-#  endif
-#  ifndef PL_na
-#    define PL_na na
-#  endif
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define SWIG_OWNER 1
-#define SWIG_SHADOW 2
-/* Common SWIG API */
-#ifdef PERL_OBJECT
-#  define SWIG_ConvertPtr(obj, pp, type, flags) \
-     SWIG_Perl_ConvertPtr(pPerl, obj, pp, type, flags)
-#  define SWIG_NewPointerObj(p, type, flags) \
-     SWIG_Perl_NewPointerObj(pPerl, p, type, flags)
-#  define SWIG_MakePackedObj(sv, p, s, type)	\
-     SWIG_Perl_MakePackedObj(pPerl, sv, p, s, type)
-#  define SWIG_ConvertPacked(obj, p, s, type, flags) \
-     SWIG_Perl_ConvertPacked(pPerl, obj, p, s, type, flags)
-#else
-     SWIG_Perl_ConvertPtr(obj, pp, type, flags)
-     SWIG_Perl_NewPointerObj(p, type, flags)
-     SWIG_Perl_MakePackedObj(sv, p, s, type )
-     SWIG_Perl_ConvertPacked(obj, p, s, type, flags)
-#endif
-/* Perl-specific API */
-#ifdef PERL_OBJECT
-#  define SWIG_MakePtr(sv, ptr, type, flags) \
-     SWIG_Perl_MakePtr(pPerl, sv, ptr, type, flags)
-#  define SWIG_SetError(str) \
-     SWIG_Perl_SetError(pPerl, str)
-#else
-     SWIG_Perl_MakePtr(sv, ptr, type, flags)
-     SWIG_Perl_SetError(str)
-#  define SWIG_SetErrorSV(str) \
-     SWIG_Perl_SetErrorSV(str)
-#endif
-#define SWIG_SetErrorf SWIG_Perl_SetErrorf
-#ifdef PERL_OBJECT
-#  define SWIG_MAYBE_PERL_OBJECT CPerlObj *pPerl,
-#else
-#endif
-SWIG_Perl_GetTypeListHandle() {
-  static void *type_pointer = (void *)0;
-  SV *pointer;
-  /* first check if pointer already created */
-  if (!type_pointer) {
-    pointer = get_sv("swig_runtime_data::type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME, FALSE);
-    if (pointer && SvOK(pointer)) {
-      type_pointer = INT2PTR(swig_type_info **, SvIV(pointer));
-  return (swig_type_info **) type_pointer;
-SWIGRUNTIMEINLINE swig_type_info *
-SWIG_Perl_GetTypeList() {
-  swig_type_info **tlh = SWIG_Perl_GetTypeListHandle();
-  return tlh ? *tlh : (swig_type_info*)0;
-#define SWIG_Runtime_GetTypeList SWIG_Perl_GetTypeList
-SWIG_Perl_TypeCheckRV(SWIG_MAYBE_PERL_OBJECT SV *rv, swig_type_info *ty) {
-  do {
-    if (sv_derived_from(rv, (char *) s->name)) {
-      if (s->next) {
-      ty->next = s;
-      s->prev = ty;
-      return s;
-    s = s->next;
-  return 0;
-/* Function for getting a pointer value */
-static int
-SWIG_Perl_ConvertPtr(SWIG_MAYBE_PERL_OBJECT SV *sv, void **ptr, swig_type_info *_t, int flags) {
-  void *voidptr = (void *)0;
-  /* If magical, apply more magic */
-  if (SvGMAGICAL(sv))
-    mg_get(sv);
-  /* Check to see if this is an object */
-  if (sv_isobject(sv)) {
-    SV *tsv = (SV*) SvRV(sv);
-    IV tmp = 0;
-    if ((SvTYPE(tsv) == SVt_PVHV)) {
-      MAGIC *mg;
-      if (SvMAGICAL(tsv)) {
-        mg = mg_find(tsv,'P');
-        if (mg) {
-          sv = mg->mg_obj;
-            tmp = SvIV((SV*)SvRV(sv));
-      } else {
-        return -1;
-    } else {
-    voidptr = (void *)tmp;
-    if (!_t) {
-      *(ptr) = voidptr;
-      return 0;
-  } else if (! SvOK(sv)) {            /* Check for undef */
-    *(ptr) = (void *) 0;
-    return 0;
-  } else if (SvTYPE(sv) == SVt_RV) {  /* Check for NULL pointer */
-    if (!SvROK(sv))
-      return 0;
-    else
-      return -1;
-  } else {                            /* Don't know what it is */
-    return -1;
-  if (_t) {
-    /* Now see if the types match */
-    char *_c = HvNAME(SvSTASH(SvRV(sv)));
-    tc = SWIG_TypeCheck(_c,_t);
-    if (!tc) {
-      *ptr = voidptr;
-      return -1;
-    *ptr = SWIG_TypeCast(tc,voidptr);
-    return 0;
-  *ptr = voidptr;
-  return 0;
-static void
-SWIG_Perl_MakePtr(SWIG_MAYBE_PERL_OBJECT SV *sv, void *ptr, swig_type_info *t, int flags) {
-  if (ptr && (flags & SWIG_SHADOW)) {
-    SV *self;
-    SV *obj=newSV(0);
-    HV *hash=newHV();
-    HV *stash;
-    sv_setref_pv(obj, (char *) t->name, ptr);
-    stash=SvSTASH(SvRV(obj));
-    if (flags & SWIG_OWNER) {
-      HV *hv;
-      GV *gv=*(GV**)hv_fetch(stash, "OWNER", 5, TRUE);
-      if (!isGV(gv))
-        gv_init(gv, stash, "OWNER", 5, FALSE);
-      hv=GvHVn(gv);
-      hv_store_ent(hv, obj, newSViv(1), 0);
-    sv_magic((SV *)hash, (SV *)obj, 'P', Nullch, 0);
-    SvREFCNT_dec(obj);
-    self=newRV_noinc((SV *)hash);
-    sv_setsv(sv, self);
-    SvREFCNT_dec((SV *)self);
-    sv_bless(sv, stash);
-  else {
-    sv_setref_pv(sv, (char *) t->name, ptr);
-static SWIGINLINE SV *
-SWIG_Perl_NewPointerObj(SWIG_MAYBE_PERL_OBJECT void *ptr, swig_type_info *t, int flags) {
-  SV *result = sv_newmortal();
-  SWIG_MakePtr(result, ptr, t, flags);
-  return result;
-static void
-  SWIG_Perl_MakePackedObj(SWIG_MAYBE_PERL_OBJECT SV *sv, void *ptr, int sz, swig_type_info *type) {
-  char result[1024];
-  char *r = result;
-  if ((2*sz + 1 + strlen(type->name)) > 1000) return;
-  *(r++) = '_';
-  strcpy(r,type->name);
-  sv_setpv(sv, result);
-/* Convert a packed value value */
-static int
-SWIG_Perl_ConvertPacked(SWIG_MAYBE_PERL_OBJECT SV *obj, void *ptr, int sz, swig_type_info *ty, int flags) {
-  const char  *c = 0;
-  if ((!obj) || (!SvOK(obj))) return -1;
-  c = SvPV(obj, PL_na);
-  /* Pointer values must start with leading underscore */
-  if (*c != '_') return -1;
-  c++;
-  c = SWIG_UnpackData(c,ptr,sz);
-  if (ty) {
-    tc = SWIG_TypeCheck(c,ty);
-    if (!tc) return -1;
-  return 0;
-static SWIGINLINE void
-SWIG_Perl_SetError(SWIG_MAYBE_PERL_OBJECT const char *error) {
-  if (error) sv_setpv(perl_get_sv("@", TRUE), error);
-SWIG_Perl_SetErrorSV(SWIG_MAYBE_PERL_OBJECT SV *error) {
-  if (error) sv_setsv(perl_get_sv("@", TRUE), error);
-static void
-SWIG_Perl_SetErrorf(const char *fmt, ...) {
-  va_list args;
-  va_start(args, fmt);
-  sv_vsetpvfn(perl_get_sv("@", TRUE), fmt, strlen(fmt), &args, Null(SV**), 0, Null(bool*));
-  va_end(args);
-/* Macros for low-level exception handling */
-#define SWIG_fail       goto fail
-#define SWIG_croak(x)   { SWIG_SetError(x); goto fail; }
-#define SWIG_croakSV(x) { SWIG_SetErrorSV(x); goto fail; }
-/* most preprocessors do not support vararg macros :-( */
-/* #define SWIG_croakf(x...) { SWIG_SetErrorf(x); goto fail; } */
-typedef XS(SwigPerlWrapper);
-typedef SwigPerlWrapper *SwigPerlWrapperPtr;
-/* Structure for command table */
-typedef struct {
-  const char         *name;
-  SwigPerlWrapperPtr  wrapper;
-} swig_command_info;
-/* Information for constant table */
-#define SWIG_INT     1
-#define SWIG_FLOAT   2
-#define SWIG_STRING  3
-#define SWIG_POINTER 4
-#define SWIG_BINARY  5
-/* Constant information structure */
-typedef struct swig_constant_info {
-    int              type;
-    const char      *name;
-    long             lvalue;
-    double           dvalue;
-    void            *pvalue;
-    swig_type_info **ptype;
-} swig_constant_info;
-#ifdef __cplusplus
-#endif
-/* Structure for variable table */
-typedef struct {
-  const char   *name;
-  SwigMagicFunc   set;
-  SwigMagicFunc   get;
-  swig_type_info  **type;
-} swig_variable_info;
-/* Magic variable code */
-#ifndef PERL_OBJECT
-#define swig_create_magic(s,a,b,c) _swig_create_magic(s,a,b,c)
-  #ifndef MULTIPLICITY
-     static void _swig_create_magic(SV *sv, char *name, int (*set)(SV *, MAGIC *), int (*get)(SV *,MAGIC *)) {
-  #else
-     static void _swig_create_magic(SV *sv, char *name, int (*set)(struct interpreter*, SV *, MAGIC *), int (*get)(struct interpreter*, SV *,MAGIC *)) {
-  #endif
-#else
-#  define swig_create_magic(s,a,b,c) _swig_create_magic(pPerl,s,a,b,c)
-static void _swig_create_magic(CPerlObj *pPerl, SV *sv, const char *name, int (CPerlObj::*set)(SV *, MAGIC *), int (CPerlObj::*get)(SV *, MAGIC *)) {
-#endif
-  MAGIC *mg;
-  sv_magic(sv,sv,'U',(char *) name,strlen(name));
-  mg = mg_find(sv,'U');
-  mg->mg_virtual = (MGVTBL *) malloc(sizeof(MGVTBL));
-  mg->mg_virtual->svt_get = (SwigMagicFuncHack) get;
-  mg->mg_virtual->svt_set = (SwigMagicFuncHack) set;
-  mg->mg_virtual->svt_len = 0;
-  mg->mg_virtual->svt_clear = 0;
-  mg->mg_virtual->svt_free = 0;
-#ifdef do_open
-  #undef do_open
-#endif
-#ifdef do_close
-  #undef do_close
-#endif
-#ifdef scalar
-  #undef scalar
-#endif
-#ifdef list
-  #undef list
-#endif
-#ifdef apply
-  #undef apply
-#endif
-#ifdef convert
-  #undef convert
-#endif
-#ifdef Error
-  #undef Error
-#endif
-#ifdef form
-  #undef form
-#endif
-#ifdef vform
-  #undef vform
-#endif
-#ifdef LABEL
-  #undef LABEL
-#endif
-#ifdef METHOD
-  #undef METHOD
-#endif
-#ifdef Move
-  #undef Move
-#endif
-#ifdef yylex
-  #undef yylex
-#endif
-#ifdef yyparse
-  #undef yyparse
-#endif
-#ifdef yyerror
-  #undef yyerror
-#endif
-#ifdef invert
-  #undef invert
-#endif
-#ifdef ref
-  #undef ref
-#endif
-#ifdef ENTER
-  #undef ENTER
-#endif
-/* -------- TYPES TABLE (BEGIN) -------- */
-#define  SWIGTYPE_p_Cell_head swig_types[0]
-#define  SWIGTYPE_p_Categories swig_types[1]
-#define  SWIGTYPE_p_DateTime swig_types[2]
-#define  SWIGTYPE_p_RASTER_MAP_TYPE swig_types[3]
-#define  SWIGTYPE_p_f_p_q_const__char_int__int swig_types[4]
-#define  SWIGTYPE_p_f_int_int__int swig_types[5]
-#define  SWIGTYPE_p_p_char swig_types[6]
-#define  SWIGTYPE_p_char swig_types[7]
-#define  SWIGTYPE_p_p_p_char swig_types[8]
-#define  SWIGTYPE_p_FPRange swig_types[9]
-#define  SWIGTYPE_p_FCELL swig_types[10]
-#define  SWIGTYPE_p_void swig_types[11]
-#define  SWIGTYPE_p_p_double swig_types[12]
-#define  SWIGTYPE_p_double swig_types[13]
-#define  SWIGTYPE_p_f_double__double swig_types[14]
-#define  SWIGTYPE_p_stat swig_types[15]
-#define  SWIGTYPE_p_size_t swig_types[16]
-#define  SWIGTYPE_p_Option swig_types[17]
-#define  SWIGTYPE_p_Range swig_types[18]
-#define  SWIGTYPE_p_G_3dview swig_types[19]
-#define  SWIGTYPE_p_Key_Value swig_types[20]
-#define  SWIGTYPE_p_f_CELL_CELL_CELL__void swig_types[21]
-#define  SWIGTYPE_p_Cell_stats swig_types[22]
-#define  SWIGTYPE_p_long swig_types[23]
-#define  SWIGTYPE_p_CELL swig_types[24]
-#define  SWIGTYPE_p_DCELL swig_types[25]
-#define  SWIGTYPE_p__Color_Rule_ swig_types[26]
-#define  SWIGTYPE_p_FPReclass swig_types[27]
-#define  SWIGTYPE_p_Quant swig_types[28]
-#define  SWIGTYPE_p_Flag swig_types[29]
-#define  SWIGTYPE_p_Reclass swig_types[30]
-#define  SWIGTYPE_p_p_unsigned_char swig_types[31]
-#define  SWIGTYPE_p_unsigned_char swig_types[32]
-#define  SWIGTYPE_p_GModule swig_types[33]
-#define  SWIGTYPE_p_TimeStamp swig_types[34]
-#define  SWIGTYPE_p_f_p_q_const__char_p_q_const__char_p_q_const__char__int swig_types[35]
-#define  SWIGTYPE_p_History swig_types[36]
-#define  SWIGTYPE_p_Histogram swig_types[37]
-#define  SWIGTYPE_p__Color_Info_ swig_types[38]
-#define  SWIGTYPE_p_f___int swig_types[39]
-#define  SWIGTYPE_p_Colors swig_types[40]
-#define  SWIGTYPE_p_INTERP_TYPE swig_types[41]
-#define  SWIGTYPE_p_FILE swig_types[42]
-#define  SWIGTYPE_p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int swig_types[43]
-#define  SWIGTYPE_p_Quant_table swig_types[44]
-#define  SWIGTYPE_p_p_float swig_types[45]
-#define  SWIGTYPE_p_float swig_types[46]
-#define  SWIGTYPE_p_p_int swig_types[47]
-#define  SWIGTYPE_p_int swig_types[48]
-static swig_type_info *swig_types[50];
-/* -------- TYPES TABLE (END) -------- */
-#define SWIG_init    boot_Grass
-#define SWIG_name   "Grassc::boot_Grass"
-#define SWIG_prefix "Grassc::"
-#ifdef __cplusplus
-extern "C"
-#endif
-SWIGEXPORT(void) SWIG_init (CV* cv);
-#else
-SWIGEXPORT(void) SWIG_init (pTHXo_ CV* cv);
-#endif
-#else
-SWIGEXPORT(void) SWIG_init (CV *cv, CPerlObj *);
-#endif
-#include "gis.h"
-#ifdef PERL_OBJECT
-#define MAGIC_CLASS _wrap_Grass_var::
-class _wrap_Grass_var : public CPerlObj {
-public:
-#else
-#endif
-SWIGCLASS_STATIC int swig_magic_readonly(pTHX_ SV *sv, MAGIC *mg) {
-    MAGIC_PPERL
-    sv = sv; mg = mg;
-    croak("Value is read-only.");
-    return 0;
-#ifdef PERL_OBJECT
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-XS(_wrap_G_adjust_Cell_head) {
-        struct Cell_head *arg1 = (struct Cell_head *) 0 ;
-        int arg2 ;
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 3) || (items > 3)) {
-            SWIG_croak("Usage: G_adjust_Cell_head(struct Cell_head *,int,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_adjust_Cell_head. Expected _p_Cell_head");
-        arg2 = (int) SvIV(ST(1));
-        arg3 = (int) SvIV(ST(2));
-        result = (char *)G_adjust_Cell_head(arg1,arg2,arg3);
-        ST(argvi) = sv_newmortal();
-        if (result) {
-            sv_setpv((SV*)ST(argvi++), (char *) result);
-        } else {
-            sv_setsv((SV*)ST(argvi++), &PL_sv_undef);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_adjust_Cell_head3) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 4) || (items > 4)) {
-            SWIG_croak("Usage: G_adjust_Cell_head3(struct Cell_head *,int,int,int);");
-                SWIG_croak("Type error in argument 1 of G_adjust_Cell_head3. Expected _p_Cell_head");
-        arg4 = (int) SvIV(ST(3));
-        result = (char *)G_adjust_Cell_head3(arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_align_window) {
-        struct Cell_head *arg2 = (struct Cell_head *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 2) || (items > 2)) {
-            SWIG_croak("Usage: G_align_window(struct Cell_head *,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 1 of G_align_window. Expected _p_Cell_head");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_align_window. Expected _p_Cell_head");
-        result = (char *)G_align_window(arg1,(struct Cell_head const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_malloc) {
-        size_t arg1 ;
-        void *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 1) || (items > 1)) {
-            SWIG_croak("Usage: G_malloc(size_t);");
-        arg1 = (size_t) SvUV(ST(0));
-        result = (void *)G_malloc(arg1);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_void, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_calloc) {
-        size_t arg1 ;
-        size_t arg2 ;
-        void *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_calloc(size_t,size_t);");
-        arg2 = (size_t) SvUV(ST(1));
-        result = (void *)G_calloc(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_realloc) {
-        void *arg1 = (void *) 0 ;
-        size_t arg2 ;
-        void *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_realloc(void *,size_t);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, 0,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_realloc. Expected _p_void");
-        result = (void *)G_realloc(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free(void *);");
-                SWIG_croak("Type error in argument 1 of G_free. Expected _p_void");
-        G_free(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_size) {
-        RASTER_MAP_TYPE arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_size(RASTER_MAP_TYPE);");
-            RASTER_MAP_TYPE * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_raster_size. Expected _p_RASTER_MAP_TYPE");
-            arg1 = *argp;
-        result = (int)G_raster_size(arg1);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_cell_buf) {
-        CELL *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 0) || (items > 0)) {
-            SWIG_croak("Usage: G_allocate_cell_buf();");
-        result = (CELL *)G_allocate_cell_buf();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_CELL, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_raster_buf) {
-        void *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_allocate_raster_buf(RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_allocate_raster_buf. Expected _p_RASTER_MAP_TYPE");
-            arg1 = *argp;
-        result = (void *)G_allocate_raster_buf(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_c_raster_buf) {
-        CELL *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_allocate_c_raster_buf();");
-        result = (CELL *)G_allocate_c_raster_buf();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_f_raster_buf) {
-        FCELL *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_allocate_f_raster_buf();");
-        result = (FCELL *)G_allocate_f_raster_buf();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_FCELL, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_d_raster_buf) {
-        DCELL *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_allocate_d_raster_buf();");
-        result = (DCELL *)G_allocate_d_raster_buf();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_DCELL, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_allocate_null_buf) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_allocate_null_buf();");
-        result = (char *)G_allocate_null_buf();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__allocate_null_bits) {
-        int arg1 ;
-        unsigned char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__allocate_null_bits(int);");
-        arg1 = (int) SvIV(ST(0));
-        result = (unsigned char *)G__allocate_null_bits(arg1);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_unsigned_char, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__null_bitstream_size) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__null_bitstream_size(int);");
-        result = (int)G__null_bitstream_size(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_cell_area_calculations) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_cell_area_calculations();");
-        result = (int)G_begin_cell_area_calculations();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_area_of_cell_at_row) {
-        int arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_area_of_cell_at_row(int);");
-        result = (double)G_area_of_cell_at_row(arg1);
-        sv_setnv(ST(argvi++), (double) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_polygon_area_calculations) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_polygon_area_calculations();");
-        result = (int)G_begin_polygon_area_calculations();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_area_of_polygon) {
-        double *arg1 = (double *) 0 ;
-        double *arg2 = (double *) 0 ;
-        int arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_area_of_polygon(double const *,double const *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_area_of_polygon. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_area_of_polygon. Expected _p_double");
-        result = (double)G_area_of_polygon((double const *)arg1,(double const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_zone_area_on_ellipsoid) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_zone_area_on_ellipsoid(double,double,double);");
-        arg1 = (double) SvNV(ST(0));
-        arg2 = (double) SvNV(ST(1));
-        arg3 = (double) SvNV(ST(2));
-        result = (int)G_begin_zone_area_on_ellipsoid(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_darea0_on_ellipsoid) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_darea0_on_ellipsoid(double);");
-        result = (double)G_darea0_on_ellipsoid(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_area_for_zone_on_ellipsoid) {
-        double arg1 ;
-        double arg2 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_area_for_zone_on_ellipsoid(double,double);");
-        result = (double)G_area_for_zone_on_ellipsoid(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_ellipsoid_polygon_area) {
-        double arg1 ;
-        double arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_ellipsoid_polygon_area(double,double);");
-        result = (int)G_begin_ellipsoid_polygon_area(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ellipsoid_polygon_area) {
-        int arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ellipsoid_polygon_area(double const *,double const *,int);");
-                SWIG_croak("Type error in argument 1 of G_ellipsoid_polygon_area. Expected _p_double");
-                SWIG_croak("Type error in argument 2 of G_ellipsoid_polygon_area. Expected _p_double");
-        result = (double)G_ellipsoid_polygon_area((double const *)arg1,(double const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_planimetric_polygon_area) {
-        int arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_planimetric_polygon_area(double const *,double const *,int);");
-                SWIG_croak("Type error in argument 1 of G_planimetric_polygon_area. Expected _p_double");
-                SWIG_croak("Type error in argument 2 of G_planimetric_polygon_area. Expected _p_double");
-        result = (double)G_planimetric_polygon_area((double const *)arg1,(double const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_zone_area_on_sphere) {
-        double arg1 ;
-        double arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_zone_area_on_sphere(double,double);");
-        result = (int)G_begin_zone_area_on_sphere(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_darea0_on_sphere) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_darea0_on_sphere(double);");
-        result = (double)G_darea0_on_sphere(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_area_for_zone_on_sphere) {
-        double arg1 ;
-        double arg2 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_area_for_zone_on_sphere(double,double);");
-        result = (double)G_area_for_zone_on_sphere(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ascii_check) {
-        char *arg1 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ascii_check(char *);");
-        if (!SvOK((SV*) ST(0))) arg1 = 0;
-        else arg1 = (char *) SvPV(ST(0), PL_na);
-        result = (int)G_ascii_check(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_new) {
-        char *arg2 = (char *) 0 ;
-        char *arg3 = (char *) 0 ;
-        char *arg4 = (char *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_new(char const *,char *,char *,char *);");
-        if (!SvOK((SV*) ST(1))) arg2 = 0;
-        else arg2 = (char *) SvPV(ST(1), PL_na);
-        if (!SvOK((SV*) ST(2))) arg3 = 0;
-        else arg3 = (char *) SvPV(ST(2), PL_na);
-        if (!SvOK((SV*) ST(3))) arg4 = 0;
-        else arg4 = (char *) SvPV(ST(3), PL_na);
-        result = (char *)G_ask_new((char const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_new_ext) {
-        char *arg5 = (char *) 0 ;
-        int (*arg6)() = (int (*)()) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 6) || (items > 6)) {
-            SWIG_croak("Usage: G_ask_new_ext(char const *,char *,char *,char *,char *,int (*)());");
-        if (!SvOK((SV*) ST(4))) arg5 = 0;
-        else arg5 = (char *) SvPV(ST(4), PL_na);
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_f___int,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_ask_new_ext. Expected _p_f___int");
-        result = (char *)G_ask_new_ext((char const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_old) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_old(char const *,char *,char *,char *);");
-        result = (char *)G_ask_old((char const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_old_ext) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_old_ext(char const *,char *,char *,char *,char *,int (*)());");
-                SWIG_croak("Type error in argument 6 of G_ask_old_ext. Expected _p_f___int");
-        result = (char *)G_ask_old_ext((char const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_any) {
-        int arg5 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 5) || (items > 5)) {
-            SWIG_croak("Usage: G_ask_any(char const *,char *,char *,char *,int);");
-        arg5 = (int) SvIV(ST(4));
-        result = (char *)G_ask_any((char const *)arg1,arg2,arg3,arg4,arg5);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_any_ext) {
-        int arg5 ;
-        char *arg6 = (char *) 0 ;
-        int (*arg7)() = (int (*)()) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 7) || (items > 7)) {
-            SWIG_croak("Usage: G_ask_any_ext(char const *,char *,char *,char *,int,char *,int (*)());");
-        if (!SvOK((SV*) ST(5))) arg6 = 0;
-        else arg6 = (char *) SvPV(ST(5), PL_na);
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_f___int,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_ask_any_ext. Expected _p_f___int");
-        result = (char *)G_ask_any_ext((char const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_in_mapset) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_in_mapset(char const *,char *,char *,char *);");
-        result = (char *)G_ask_in_mapset((char const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_in_mapset_ext) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_in_mapset_ext(char const *,char *,char *,char *,char *,int (*)());");
-                SWIG_croak("Type error in argument 6 of G_ask_in_mapset_ext. Expected _p_f___int");
-        result = (char *)G_ask_in_mapset_ext((char const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_new_file) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_new_file(char const *,char *,char *,char *);");
-        result = (char *)G_ask_new_file((char const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_old_file) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_old_file(char const *,char *,char *,char *);");
-        result = (char *)G_ask_old_file((char const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_ask_return_msg) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_ask_return_msg(char const *);");
-        result = (int)G_set_ask_return_msg((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ask_return_msg) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ask_return_msg();");
-        result = (char *)G_get_ask_return_msg();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_cell_new) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_cell_new(char const *,char *);");
-        result = (char *)G_ask_cell_new((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_cell_old) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_cell_old(char const *,char *);");
-        result = (char *)G_ask_cell_old((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_cell_in_mapset) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_cell_in_mapset(char const *,char *);");
-        result = (char *)G_ask_cell_in_mapset((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_cell_any) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_cell_any(char const *,char *);");
-        result = (char *)G_ask_cell_any((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_vector_new) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_vector_new(char const *,char *);");
-        result = (char *)G_ask_vector_new((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_vector_old) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_vector_old(char const *,char *);");
-        result = (char *)G_ask_vector_old((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_vector_any) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_vector_any(char const *,char *);");
-        result = (char *)G_ask_vector_any((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_vector_in_mapset) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_vector_in_mapset(char const *,char *);");
-        result = (char *)G_ask_vector_in_mapset((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__check_for_auto_masking) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__check_for_auto_masking();");
-        result = (int)G__check_for_auto_masking();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_suppress_masking) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_suppress_masking();");
-        result = (int)G_suppress_masking();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unsuppress_masking) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unsuppress_masking();");
-        result = (int)G_unsuppress_masking();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_basename) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_basename(char *,char const *);");
-        result = (char *)G_basename(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_bresenham_line) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int (*arg5)(int,int) = (int (*)(int,int)) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_bresenham_line(int,int,int,int,int (*)(int,int));");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_f_int_int__int,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_bresenham_line. Expected _p_f_int_int__int");
-        result = (int)G_bresenham_line(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_cats) {
-        struct Categories *arg3 = (struct Categories *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_cats(char const *,char const *,struct Categories *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_cats. Expected _p_Categories");
-        result = (int)G_read_cats((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_raster_cats(char const *,char const *,struct Categories *);");
-                SWIG_croak("Type error in argument 3 of G_read_raster_cats. Expected _p_Categories");
-        result = (int)G_read_raster_cats((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_vector_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_vector_cats(char const *,char const *,struct Categories *);");
-                SWIG_croak("Type error in argument 3 of G_read_vector_cats. Expected _p_Categories");
-        result = (int)G_read_vector_cats((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_number_of_cats) {
-        CELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_number_of_cats(char const *,char const *);");
-        result = G_number_of_cats((char const *)arg1,(char const *)arg2);
-            CELL * resultobj = (CELL *) malloc(sizeof(CELL));
-            memmove(resultobj, &result, sizeof(CELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_CELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_cats) {
-        struct Categories *arg4 = (struct Categories *) 0 ;
-        int arg5 ;
-        CELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_cats(char const *,char const *,char const *,struct Categories *,int);");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G__read_cats. Expected _p_Categories");
-        result = G__read_cats((char const *)arg1,(char const *)arg2,(char const *)arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_cats_title) {
-        struct Categories *arg1 = (struct Categories *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_cats_title(struct Categories const *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_cats_title. Expected _p_Categories");
-        result = (char *)G_get_cats_title((struct Categories const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_cats_title) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_cats_title(struct Categories const *);");
-                SWIG_croak("Type error in argument 1 of G_get_raster_cats_title. Expected _p_Categories");
-        result = (char *)G_get_raster_cats_title((struct Categories const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_cat) {
-        CELL arg1 ;
-        struct Categories *arg2 = (struct Categories *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_cat(CELL,struct Categories *);");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_cat. Expected _p_CELL");
-            arg1 = *argp;
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_cat. Expected _p_Categories");
-        result = (char *)G_get_cat(arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_c_raster_cat) {
-        CELL *arg1 = (CELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_c_raster_cat(CELL *,struct Categories *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_c_raster_cat. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_get_c_raster_cat. Expected _p_Categories");
-        result = (char *)G_get_c_raster_cat(arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_f_raster_cat) {
-        FCELL *arg1 = (FCELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_f_raster_cat(FCELL *,struct Categories *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_f_raster_cat. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 2 of G_get_f_raster_cat. Expected _p_Categories");
-        result = (char *)G_get_f_raster_cat(arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_d_raster_cat) {
-        DCELL *arg1 = (DCELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_d_raster_cat(DCELL *,struct Categories *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_d_raster_cat. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_get_d_raster_cat. Expected _p_Categories");
-        result = (char *)G_get_d_raster_cat(arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_cat) {
-        RASTER_MAP_TYPE arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_cat(void *,struct Categories *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_get_raster_cat. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_raster_cat. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (char *)G_get_raster_cat(arg1,arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unmark_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unmark_raster_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_unmark_raster_cats. Expected _p_Categories");
-        result = (int)G_unmark_raster_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mark_c_raster_cats) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mark_c_raster_cats(CELL *,int,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_mark_c_raster_cats. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_mark_c_raster_cats. Expected _p_Categories");
-        result = (int)G_mark_c_raster_cats(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mark_f_raster_cats) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mark_f_raster_cats(FCELL *,int,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_mark_f_raster_cats. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 3 of G_mark_f_raster_cats. Expected _p_Categories");
-        result = (int)G_mark_f_raster_cats(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mark_d_raster_cats) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mark_d_raster_cats(DCELL *,int,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_mark_d_raster_cats. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_mark_d_raster_cats. Expected _p_Categories");
-        result = (int)G_mark_d_raster_cats(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mark_raster_cats) {
-        int arg2 ;
-        RASTER_MAP_TYPE arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mark_raster_cats(void *,int,struct Categories *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_mark_raster_cats. Expected _p_void");
-                SWIG_croak("Type error in argument 3 of G_mark_raster_cats. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_mark_raster_cats. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_mark_raster_cats(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rewind_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rewind_raster_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_rewind_raster_cats. Expected _p_Categories");
-        result = (int)G_rewind_raster_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_next_marked_d_raster_cat) {
-        DCELL *arg2 = (DCELL *) 0 ;
-        DCELL *arg3 = (DCELL *) 0 ;
-        long *arg4 = (long *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_next_marked_d_raster_cat(struct Categories *,DCELL *,DCELL *,long *);");
-                SWIG_croak("Type error in argument 1 of G_get_next_marked_d_raster_cat. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_next_marked_d_raster_cat. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_next_marked_d_raster_cat. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_long,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_next_marked_d_raster_cat. Expected _p_long");
-        result = (char *)G_get_next_marked_d_raster_cat(arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_next_marked_c_raster_cat) {
-        CELL *arg2 = (CELL *) 0 ;
-        CELL *arg3 = (CELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_next_marked_c_raster_cat(struct Categories *,CELL *,CELL *,long *);");
-                SWIG_croak("Type error in argument 1 of G_get_next_marked_c_raster_cat. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_next_marked_c_raster_cat. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_next_marked_c_raster_cat. Expected _p_CELL");
-                SWIG_croak("Type error in argument 4 of G_get_next_marked_c_raster_cat. Expected _p_long");
-        result = (char *)G_get_next_marked_c_raster_cat(arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_next_marked_f_raster_cat) {
-        FCELL *arg2 = (FCELL *) 0 ;
-        FCELL *arg3 = (FCELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_next_marked_f_raster_cat(struct Categories *,FCELL *,FCELL *,long *);");
-                SWIG_croak("Type error in argument 1 of G_get_next_marked_f_raster_cat. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_next_marked_f_raster_cat. Expected _p_FCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_next_marked_f_raster_cat. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 4 of G_get_next_marked_f_raster_cat. Expected _p_long");
-        result = (char *)G_get_next_marked_f_raster_cat(arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_next_marked_raster_cat) {
-        void *arg2 = (void *) 0 ;
-        void *arg3 = (void *) 0 ;
-        RASTER_MAP_TYPE arg5 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_next_marked_raster_cat(struct Categories *,void *,void *,long *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_next_marked_raster_cat. Expected _p_Categories");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, 0,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_next_marked_raster_cat. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, 0,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_next_marked_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_get_next_marked_raster_cat. Expected _p_long");
-            if (SWIG_ConvertPtr(ST(4),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_get_next_marked_raster_cat. Expected _p_RASTER_MAP_TYPE");
-            arg5 = *argp;
-        result = (char *)G_get_next_marked_raster_cat(arg1,arg2,arg3,arg4,arg5);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_cat) {
-        CELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_cat(CELL,char *,struct Categories *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_cat. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 3 of G_set_cat. Expected _p_Categories");
-        result = (int)G_set_cat(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_c_raster_cat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_c_raster_cat(CELL *,CELL *,char *,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_set_c_raster_cat. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_set_c_raster_cat. Expected _p_CELL");
-                SWIG_croak("Type error in argument 4 of G_set_c_raster_cat. Expected _p_Categories");
-        result = (int)G_set_c_raster_cat(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_f_raster_cat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_f_raster_cat(FCELL *,FCELL *,char *,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_set_f_raster_cat. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 2 of G_set_f_raster_cat. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 4 of G_set_f_raster_cat. Expected _p_Categories");
-        result = (int)G_set_f_raster_cat(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_d_raster_cat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_d_raster_cat(DCELL *,DCELL *,char *,struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_set_d_raster_cat. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_set_d_raster_cat. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 4 of G_set_d_raster_cat. Expected _p_Categories");
-        result = (int)G_set_d_raster_cat(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_cat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_cat(void *,void *,char *,struct Categories *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_set_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_set_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_set_raster_cat. Expected _p_Categories");
-                SWIG_croak("Type error in argument 5 of G_set_raster_cat. Expected _p_RASTER_MAP_TYPE");
-            arg5 = *argp;
-        result = (int)G_set_raster_cat(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_cats(char *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_write_cats. Expected _p_Categories");
-        result = (int)G_write_cats(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_raster_cats(char *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_write_raster_cats. Expected _p_Categories");
-        result = (int)G_write_raster_cats(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_vector_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_vector_cats(char *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_write_vector_cats. Expected _p_Categories");
-        result = (int)G_write_vector_cats(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_cats(char *,char *,struct Categories *);");
-                SWIG_croak("Type error in argument 3 of G__write_cats. Expected _p_Categories");
-        result = (int)G__write_cats(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ith_d_raster_cat) {
-        int arg2 ;
-        DCELL *arg4 = (DCELL *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ith_d_raster_cat(struct Categories const *,int,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_get_ith_d_raster_cat. Expected _p_Categories");
-                SWIG_croak("Type error in argument 3 of G_get_ith_d_raster_cat. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_ith_d_raster_cat. Expected _p_DCELL");
-        result = (char *)G_get_ith_d_raster_cat((struct Categories const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ith_f_raster_cat) {
-        int arg2 ;
-        void *arg4 = (void *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ith_f_raster_cat(struct Categories const *,int,void *,void *);");
-                SWIG_croak("Type error in argument 1 of G_get_ith_f_raster_cat. Expected _p_Categories");
-                SWIG_croak("Type error in argument 3 of G_get_ith_f_raster_cat. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, 0,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_ith_f_raster_cat. Expected _p_void");
-        result = (char *)G_get_ith_f_raster_cat((struct Categories const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ith_c_raster_cat) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ith_c_raster_cat(struct Categories const *,int,void *,void *);");
-                SWIG_croak("Type error in argument 1 of G_get_ith_c_raster_cat. Expected _p_Categories");
-                SWIG_croak("Type error in argument 3 of G_get_ith_c_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_get_ith_c_raster_cat. Expected _p_void");
-        result = (char *)G_get_ith_c_raster_cat((struct Categories const *)arg1,arg2,arg3,arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ith_raster_cat) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ith_raster_cat(struct Categories const *,int,void *,void *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_ith_raster_cat. Expected _p_Categories");
-                SWIG_croak("Type error in argument 3 of G_get_ith_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_get_ith_raster_cat. Expected _p_void");
-                SWIG_croak("Type error in argument 5 of G_get_ith_raster_cat. Expected _p_RASTER_MAP_TYPE");
-            arg5 = *argp;
-        result = (char *)G_get_ith_raster_cat((struct Categories const *)arg1,arg2,arg3,arg4,arg5);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_cats) {
-        CELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_cats(CELL,char const *,struct Categories *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_init_cats. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 3 of G_init_cats. Expected _p_Categories");
-        result = (int)G_init_cats(arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_raster_cats(char const *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_init_raster_cats. Expected _p_Categories");
-        result = (int)G_init_raster_cats((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_cats_title) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_cats_title(char const *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_set_cats_title. Expected _p_Categories");
-        result = (int)G_set_cats_title((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_cats_title) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_cats_title(char const *,struct Categories *);");
-                SWIG_croak("Type error in argument 2 of G_set_raster_cats_title. Expected _p_Categories");
-        result = (int)G_set_raster_cats_title((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_cats_fmt) {
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        struct Categories *arg6 = (struct Categories *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_cats_fmt(char const *,double,double,double,double,struct Categories *);");
-        arg4 = (double) SvNV(ST(3));
-        arg5 = (double) SvNV(ST(4));
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_set_cats_fmt. Expected _p_Categories");
-        result = (int)G_set_cats_fmt((char const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_cats_fmt) {
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_cats_fmt(char const *,double,double,double,double,struct Categories *);");
-                SWIG_croak("Type error in argument 6 of G_set_raster_cats_fmt. Expected _p_Categories");
-        result = (int)G_set_raster_cats_fmt((char const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_free_cats. Expected _p_Categories");
-        result = (int)G_free_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_raster_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_free_raster_cats. Expected _p_Categories");
-        result = (int)G_free_raster_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_copy_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_copy_raster_cats(struct Categories *,struct Categories const *);");
-                SWIG_croak("Type error in argument 1 of G_copy_raster_cats. Expected _p_Categories");
-                SWIG_croak("Type error in argument 2 of G_copy_raster_cats. Expected _p_Categories");
-        result = (int)G_copy_raster_cats(arg1,(struct Categories const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_number_of_raster_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_number_of_raster_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_number_of_raster_cats. Expected _p_Categories");
-        result = (int)G_number_of_raster_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sort_cats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sort_cats(struct Categories *);");
-                SWIG_croak("Type error in argument 1 of G_sort_cats. Expected _p_Categories");
-        result = (int)G_sort_cats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_cell_stats) {
-        struct Cell_stats *arg1 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_cell_stats(struct Cell_stats *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_init_cell_stats. Expected _p_Cell_stats");
-        result = (int)G_init_cell_stats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_update_cell_stats) {
-        int arg2 ;
-        struct Cell_stats *arg3 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_update_cell_stats(CELL const *,int,struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_update_cell_stats. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_update_cell_stats. Expected _p_Cell_stats");
-        result = (int)G_update_cell_stats((CELL const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_cell_stat) {
-        CELL arg1 ;
-        long *arg2 = (long *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_cell_stat(CELL,long *,struct Cell_stats const *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_find_cell_stat. Expected _p_CELL");
-            arg1 = *argp;
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_long,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_find_cell_stat. Expected _p_long");
-                SWIG_croak("Type error in argument 3 of G_find_cell_stat. Expected _p_Cell_stats");
-        result = (int)G_find_cell_stat(arg1,arg2,(struct Cell_stats const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rewind_cell_stats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rewind_cell_stats(struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_rewind_cell_stats. Expected _p_Cell_stats");
-        result = (int)G_rewind_cell_stats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_next_cell_stat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_next_cell_stat(CELL *,long *,struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_next_cell_stat. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_next_cell_stat. Expected _p_long");
-                SWIG_croak("Type error in argument 3 of G_next_cell_stat. Expected _p_Cell_stats");
-        result = (int)G_next_cell_stat(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_stats_for_null_value) {
-        long *arg1 = (long *) 0 ;
-        struct Cell_stats *arg2 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_stats_for_null_value(long *,struct Cell_stats const *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_long,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_stats_for_null_value. Expected _p_long");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_stats_for_null_value. Expected _p_Cell_stats");
-        result = (int)G_get_stats_for_null_value(arg1,(struct Cell_stats const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_cell_stats) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_cell_stats(struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_free_cell_stats. Expected _p_Cell_stats");
-        result = (int)G_free_cell_stats(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_cell_title) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_cell_title(char const *,char const *);");
-        result = (char *)G_get_cell_title((char const *)arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_cell_stats_histo_eq) {
-        CELL arg2 ;
-        CELL arg3 ;
-        CELL arg4 ;
-        CELL arg5 ;
-        int arg6 ;
-        void (*arg7)(CELL,CELL,CELL) = (void (*)(CELL,CELL,CELL)) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_cell_stats_histo_eq(struct Cell_stats *,CELL,CELL,CELL,CELL,int,void (*)(CELL,CELL,CELL));");
-                SWIG_croak("Type error in argument 1 of G_cell_stats_histo_eq. Expected _p_Cell_stats");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_cell_stats_histo_eq. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_cell_stats_histo_eq. Expected _p_CELL");
-            arg3 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_cell_stats_histo_eq. Expected _p_CELL");
-            arg4 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(4),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_cell_stats_histo_eq. Expected _p_CELL");
-            arg5 = *argp;
-        arg6 = (int) SvIV(ST(5));
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_f_CELL_CELL_CELL__void,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_cell_stats_histo_eq. Expected _p_f_CELL_CELL_CELL__void");
-        result = (int)G_cell_stats_histo_eq(arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_chop) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_chop(char *);");
-        result = (char *)G_chop(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_clear_screen) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_clear_screen();");
-        result = (int)G_clear_screen();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_clicker) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_clicker();");
-        result = (int)G_clicker();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_close_cell) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_close_cell(int);");
-        result = (int)G_close_cell(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unopen_cell) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unopen_cell(int);");
-        result = (int)G_unopen_cell(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_fp_format) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_fp_format(int);");
-        result = (int)G__write_fp_format(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_ryg_colors) {
-        struct Colors *arg1 = (struct Colors *) 0 ;
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_ryg_colors(struct Colors *,CELL,CELL);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_make_ryg_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_ryg_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_ryg_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_ryg_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_ryg_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_ryg_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_ryg_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_make_ryg_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_make_ryg_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_ryg_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_aspect_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_aspect_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_aspect_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_aspect_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_aspect_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_aspect_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_aspect_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_aspect_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_aspect_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_aspect_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_aspect_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_aspect_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_byr_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_byr_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_byr_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_byr_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_byr_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_byr_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_byr_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_byr_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_byr_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_byr_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_byr_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_byr_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_byg_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_byg_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_byg_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_byg_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_byg_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_byg_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_byg_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_byg_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_byg_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_byg_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_byg_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_byg_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_grey_scale_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_grey_scale_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_grey_scale_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_grey_scale_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_grey_scale_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_grey_scale_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_grey_scale_fp_colors) {
-        double arg2 ;
-        double arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_grey_scale_fp_colors(struct Colors *,double,double);");
-                SWIG_croak("Type error in argument 1 of G_make_grey_scale_fp_colors. Expected _p_Colors");
-        result = (int)G_make_grey_scale_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_gyr_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_gyr_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_gyr_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_gyr_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_gyr_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_gyr_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_gyr_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_gyr_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_gyr_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_gyr_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_gyr_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_gyr_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_rainbow_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_rainbow_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_rainbow_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_rainbow_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_rainbow_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_rainbow_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_rainbow_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_rainbow_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_rainbow_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_rainbow_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_rainbow_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_rainbow_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_ramp_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_ramp_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_ramp_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_ramp_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_ramp_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_ramp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_ramp_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_ramp_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_ramp_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_ramp_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_ramp_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_ramp_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_wave_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_wave_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_wave_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_wave_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_wave_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_wave_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_wave_fp_colors) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_wave_fp_colors(struct Colors *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_wave_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_wave_fp_colors. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_wave_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-        result = (int)G_make_wave_fp_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_colors(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_free_colors. Expected _p_Colors");
-        result = (int)G_free_colors(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__color_free_rules) {
-        struct _Color_Info_ *arg1 = (struct _Color_Info_ *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__color_free_rules(struct _Color_Info_ *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p__Color_Info_,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__color_free_rules. Expected _p__Color_Info_");
-        result = (int)G__color_free_rules(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__color_free_lookup) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__color_free_lookup(struct _Color_Info_ *);");
-                SWIG_croak("Type error in argument 1 of G__color_free_lookup. Expected _p__Color_Info_");
-        result = (int)G__color_free_lookup(arg1);
-        ST(argvi) = sv_newmortal();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__color_free_fp_lookup) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__color_free_fp_lookup(struct _Color_Info_ *);");
-                SWIG_croak("Type error in argument 1 of G__color_free_fp_lookup. Expected _p__Color_Info_");
-        result = (int)G__color_free_fp_lookup(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__color_reset) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__color_reset(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G__color_reset. Expected _p_Colors");
-        result = (int)G__color_reset(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_color) {
-        CELL arg1 ;
-        int *arg2 = (int *) 0 ;
-        int *arg3 = (int *) 0 ;
-        int *arg4 = (int *) 0 ;
-        struct Colors *arg5 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_color(CELL,int *,int *,int *,struct Colors *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_get_color. Expected _p_CELL");
-            arg1 = *argp;
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_color. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_color. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_color. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_get_color. Expected _p_Colors");
-        result = (int)G_get_color(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_color) {
-        void *arg1 = (void *) 0 ;
-        RASTER_MAP_TYPE arg6 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_color(void const *,int *,int *,int *,struct Colors *,RASTER_MAP_TYPE);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, 0,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_raster_color. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_get_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_get_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 5 of G_get_raster_color. Expected _p_Colors");
-            RASTER_MAP_TYPE * argp;
-            if (SWIG_ConvertPtr(ST(5),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_get_raster_color. Expected _p_RASTER_MAP_TYPE");
-            arg6 = *argp;
-        result = (int)G_get_raster_color((void const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_c_raster_color) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_c_raster_color(CELL const *,int *,int *,int *,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_get_c_raster_color. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_get_c_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_c_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_get_c_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 5 of G_get_c_raster_color. Expected _p_Colors");
-        result = (int)G_get_c_raster_color((CELL const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_f_raster_color) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_f_raster_color(FCELL const *,int *,int *,int *,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_get_f_raster_color. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 2 of G_get_f_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_f_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_get_f_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 5 of G_get_f_raster_color. Expected _p_Colors");
-        result = (int)G_get_f_raster_color((FCELL const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_d_raster_color) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_d_raster_color(DCELL const *,int *,int *,int *,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_get_d_raster_color. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_get_d_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_d_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_get_d_raster_color. Expected _p_int");
-                SWIG_croak("Type error in argument 5 of G_get_d_raster_color. Expected _p_Colors");
-        result = (int)G_get_d_raster_color((DCELL const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_null_value_color) {
-        int *arg1 = (int *) 0 ;
-        struct Colors *arg4 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 4) || (items > 4)) {
-            SWIG_croak("Usage: G_get_null_value_color(int *,int *,int *,struct Colors const *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_null_value_color. Expected _p_int");
-                SWIG_croak("Type error in argument 2 of G_get_null_value_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_null_value_color. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_null_value_color. Expected _p_Colors");
-        result = (int)G_get_null_value_color(arg1,arg2,arg3,(struct Colors const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_default_color) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_default_color(int *,int *,int *,struct Colors const *);");
-                SWIG_croak("Type error in argument 1 of G_get_default_color. Expected _p_int");
-                SWIG_croak("Type error in argument 2 of G_get_default_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_get_default_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_get_default_color. Expected _p_Colors");
-        result = (int)G_get_default_color(arg1,arg2,arg3,(struct Colors const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_histogram_eq_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 2) || (items > 2)) {
-            SWIG_croak("Usage: G_make_histogram_eq_colors(struct Colors *,struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_make_histogram_eq_colors. Expected _p_Colors");
-                SWIG_croak("Type error in argument 2 of G_make_histogram_eq_colors. Expected _p_Cell_stats");
-        result = (int)G_make_histogram_eq_colors(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_histogram_log_colors) {
-        int arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_histogram_log_colors(struct Colors *,struct Cell_stats *,int,int);");
-                SWIG_croak("Type error in argument 1 of G_make_histogram_log_colors. Expected _p_Colors");
-                SWIG_croak("Type error in argument 2 of G_make_histogram_log_colors. Expected _p_Cell_stats");
-        arg3 = (int) SvIV(ST(2));
-        arg4 = (int) SvIV(ST(3));
-        result = (int)G_make_histogram_log_colors(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 1) || (items > 1)) {
-            SWIG_croak("Usage: G_init_colors(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_init_colors. Expected _p_Colors");
-        result = (int)G_init_colors(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__insert_color_into_lookup) {
-        CELL arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        struct _Color_Info_ *arg5 = (struct _Color_Info_ *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__insert_color_into_lookup(CELL,int,int,int,struct _Color_Info_ *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G__insert_color_into_lookup. Expected _p_CELL");
-            arg1 = *argp;
-        arg2 = (int) SvIV(ST(1));
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p__Color_Info_,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G__insert_color_into_lookup. Expected _p__Color_Info_");
-        result = (int)G__insert_color_into_lookup(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_invert_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_invert_colors(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_invert_colors. Expected _p_Colors");
-        result = (int)G_invert_colors(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_colors) {
-        unsigned char *arg2 = (unsigned char *) 0 ;
-        unsigned char *arg3 = (unsigned char *) 0 ;
-        unsigned char *arg4 = (unsigned char *) 0 ;
-        unsigned char *arg5 = (unsigned char *) 0 ;
-        int arg6 ;
-        struct Colors *arg7 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lookup_colors(CELL const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_lookup_colors. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_lookup_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_lookup_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_lookup_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_lookup_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_lookup_colors. Expected _p_Colors");
-        result = (int)G_lookup_colors((CELL const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_c_raster_colors) {
-        int arg6 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lookup_c_raster_colors(CELL const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_lookup_c_raster_colors. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_lookup_c_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_lookup_c_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G_lookup_c_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G_lookup_c_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 7 of G_lookup_c_raster_colors. Expected _p_Colors");
-        result = (int)G_lookup_c_raster_colors((CELL const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_raster_colors) {
-        int arg6 ;
-        RASTER_MAP_TYPE arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 8) || (items > 8)) {
-            SWIG_croak("Usage: G_lookup_raster_colors(void const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_lookup_raster_colors. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_lookup_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_lookup_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G_lookup_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G_lookup_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 7 of G_lookup_raster_colors. Expected _p_Colors");
-            if (SWIG_ConvertPtr(ST(7),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 8 of G_lookup_raster_colors. Expected _p_RASTER_MAP_TYPE");
-            arg8 = *argp;
-        result = (int)G_lookup_raster_colors((void const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_f_raster_colors) {
-        int arg6 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 7) || (items > 7)) {
-            SWIG_croak("Usage: G_lookup_f_raster_colors(FCELL const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_lookup_f_raster_colors. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 2 of G_lookup_f_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_lookup_f_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G_lookup_f_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G_lookup_f_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 7 of G_lookup_f_raster_colors. Expected _p_Colors");
-        result = (int)G_lookup_f_raster_colors((FCELL const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_d_raster_colors) {
-        int arg6 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lookup_d_raster_colors(DCELL const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_lookup_d_raster_colors. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_lookup_d_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_lookup_d_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G_lookup_d_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G_lookup_d_raster_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 7 of G_lookup_d_raster_colors. Expected _p_Colors");
-        result = (int)G_lookup_d_raster_colors((DCELL const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__lookup_colors) {
-        int arg6 ;
-        int arg8 ;
-        int arg9 ;
-        RASTER_MAP_TYPE arg10 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 10) || (items > 10)) {
-            SWIG_croak("Usage: G__lookup_colors(void const *,unsigned char *,unsigned char *,unsigned char *,unsigned char *,int,struct Colors *,int,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G__lookup_colors. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G__lookup_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G__lookup_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G__lookup_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G__lookup_colors. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 7 of G__lookup_colors. Expected _p_Colors");
-        arg8 = (int) SvIV(ST(7));
-        arg9 = (int) SvIV(ST(8));
-            if (SWIG_ConvertPtr(ST(9),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 10 of G__lookup_colors. Expected _p_RASTER_MAP_TYPE");
-            arg10 = *argp;
-        result = (int)G__lookup_colors((void const *)arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__interpolate_color_rule) {
-        DCELL arg1 ;
-        struct _Color_Rule_ *arg5 = (struct _Color_Rule_ *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 5) || (items > 5)) {
-            SWIG_croak("Usage: G__interpolate_color_rule(DCELL,unsigned char *,unsigned char *,unsigned char *,struct _Color_Rule_ const *);");
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__interpolate_color_rule. Expected _p_DCELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 2 of G__interpolate_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G__interpolate_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G__interpolate_color_rule. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p__Color_Rule_,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G__interpolate_color_rule. Expected _p__Color_Rule_");
-        result = (int)G__interpolate_color_rule(arg1,arg2,arg3,arg4,(struct _Color_Rule_ const *)arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__organize_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__organize_colors(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G__organize_colors. Expected _p_Colors");
-        result = (int)G__organize_colors(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_random_colors) {
-        CELL arg2 ;
-        CELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 3) || (items > 3)) {
-            SWIG_croak("Usage: G_make_random_colors(struct Colors *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_random_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_make_random_colors. Expected _p_CELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_random_colors. Expected _p_CELL");
-            arg3 = *argp;
-        result = (int)G_make_random_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_color_range) {
-        CELL arg1 ;
-        CELL arg2 ;
-        struct Colors *arg3 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_color_range(CELL,CELL,struct Colors *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_color_range. Expected _p_CELL");
-            arg1 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 2 of G_set_color_range. Expected _p_CELL");
-            arg2 = *argp;
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_set_color_range. Expected _p_Colors");
-        result = (int)G_set_color_range(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_d_color_range) {
-        DCELL arg1 ;
-        DCELL arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_d_color_range(DCELL,DCELL,struct Colors *);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_d_color_range. Expected _p_DCELL");
-            arg1 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_set_d_color_range. Expected _p_DCELL");
-            arg2 = *argp;
-                SWIG_croak("Type error in argument 3 of G_set_d_color_range. Expected _p_Colors");
-        result = (int)G_set_d_color_range(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_color_range) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_color_range(CELL *,CELL *,struct Colors const *);");
-                SWIG_croak("Type error in argument 1 of G_get_color_range. Expected _p_CELL");
-                SWIG_croak("Type error in argument 2 of G_get_color_range. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_get_color_range. Expected _p_Colors");
-        result = (int)G_get_color_range(arg1,arg2,(struct Colors const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_d_color_range) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_d_color_range(DCELL *,DCELL *,struct Colors const *);");
-                SWIG_croak("Type error in argument 1 of G_get_d_color_range. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_get_d_color_range. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_get_d_color_range. Expected _p_Colors");
-        result = (int)G_get_d_color_range(arg1,arg2,(struct Colors const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_colors) {
-        char *arg1 = (char *) 0 ;
-        char *arg2 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_colors(char const *,char const *,struct Colors *);");
-        if (!SvOK((SV*) ST(0))) arg1 = 0;
-        else arg1 = (char *) SvPV(ST(0), PL_na);
-        if (!SvOK((SV*) ST(1))) arg2 = 0;
-        else arg2 = (char *) SvPV(ST(1), PL_na);
-                SWIG_croak("Type error in argument 3 of G_read_colors. Expected _p_Colors");
-        result = (int)G_read_colors((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mark_colors_as_fp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mark_colors_as_fp(struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_mark_colors_as_fp. Expected _p_Colors");
-        result = (int)G_mark_colors_as_fp(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_colors(char const *,char const *);");
-        result = (int)G_remove_colors((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_d_raster_color_rule) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        DCELL *arg5 = (DCELL *) 0 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        struct Colors *arg9 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 9) || (items > 9)) {
-            SWIG_croak("Usage: G_add_d_raster_color_rule(DCELL const *,int,int,int,DCELL const *,int,int,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_add_d_raster_color_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_add_d_raster_color_rule. Expected _p_DCELL");
-        arg7 = (int) SvIV(ST(6));
-            if (SWIG_ConvertPtr(ST(8), (void **) &arg9, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 9 of G_add_d_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_d_raster_color_rule((DCELL const *)arg1,arg2,arg3,arg4,(DCELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_f_raster_color_rule) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        FCELL *arg5 = (FCELL *) 0 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_f_raster_color_rule(FCELL const *,int,int,int,FCELL const *,int,int,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_add_f_raster_color_rule. Expected _p_FCELL");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_add_f_raster_color_rule. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 9 of G_add_f_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_f_raster_color_rule((FCELL const *)arg1,arg2,arg3,arg4,(FCELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_c_raster_color_rule) {
-        CELL *arg1 = (CELL *) 0 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        CELL *arg5 = (CELL *) 0 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_c_raster_color_rule(CELL const *,int,int,int,CELL const *,int,int,int,struct Colors *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_add_c_raster_color_rule. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_add_c_raster_color_rule. Expected _p_CELL");
-                SWIG_croak("Type error in argument 9 of G_add_c_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_c_raster_color_rule((CELL const *)arg1,arg2,arg3,arg4,(CELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_raster_color_rule) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        void *arg5 = (void *) 0 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_raster_color_rule(void const *,int,int,int,void const *,int,int,int,struct Colors *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_add_raster_color_rule. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, 0,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_add_raster_color_rule. Expected _p_void");
-                SWIG_croak("Type error in argument 9 of G_add_raster_color_rule. Expected _p_Colors");
-                SWIG_croak("Type error in argument 10 of G_add_raster_color_rule. Expected _p_RASTER_MAP_TYPE");
-            arg10 = *argp;
-        result = (int)G_add_raster_color_rule((void const *)arg1,arg2,arg3,arg4,(void const *)arg5,arg6,arg7,arg8,arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_color_rule) {
-        CELL arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        CELL arg5 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_color_rule(CELL const,int,int,int,CELL const,int,int,int,struct Colors *);");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_add_color_rule. Expected _p_CELL");
-            arg1 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 5 of G_add_color_rule. Expected _p_CELL");
-            arg5 = *argp;
-                SWIG_croak("Type error in argument 9 of G_add_color_rule. Expected _p_Colors");
-        result = (int)G_add_color_rule(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_modular_d_raster_color_rule) {
-        DCELL *arg1 = (DCELL *) 0 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_modular_d_raster_color_rule(DCELL const *,int,int,int,DCELL const *,int,int,int,struct Colors *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_add_modular_d_raster_color_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 5 of G_add_modular_d_raster_color_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 9 of G_add_modular_d_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_modular_d_raster_color_rule((DCELL const *)arg1,arg2,arg3,arg4,(DCELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_modular_f_raster_color_rule) {
-        FCELL *arg1 = (FCELL *) 0 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_modular_f_raster_color_rule(FCELL const *,int,int,int,FCELL const *,int,int,int,struct Colors *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_add_modular_f_raster_color_rule. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 5 of G_add_modular_f_raster_color_rule. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 9 of G_add_modular_f_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_modular_f_raster_color_rule((FCELL const *)arg1,arg2,arg3,arg4,(FCELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_modular_c_raster_color_rule) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_modular_c_raster_color_rule(CELL const *,int,int,int,CELL const *,int,int,int,struct Colors *);");
-                SWIG_croak("Type error in argument 1 of G_add_modular_c_raster_color_rule. Expected _p_CELL");
-                SWIG_croak("Type error in argument 5 of G_add_modular_c_raster_color_rule. Expected _p_CELL");
-                SWIG_croak("Type error in argument 9 of G_add_modular_c_raster_color_rule. Expected _p_Colors");
-        result = (int)G_add_modular_c_raster_color_rule((CELL const *)arg1,arg2,arg3,arg4,(CELL const *)arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_modular_raster_color_rule) {
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_modular_raster_color_rule(void const *,int,int,int,void const *,int,int,int,struct Colors *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_add_modular_raster_color_rule. Expected _p_void");
-                SWIG_croak("Type error in argument 5 of G_add_modular_raster_color_rule. Expected _p_void");
-                SWIG_croak("Type error in argument 9 of G_add_modular_raster_color_rule. Expected _p_Colors");
-                SWIG_croak("Type error in argument 10 of G_add_modular_raster_color_rule. Expected _p_RASTER_MAP_TYPE");
-            arg10 = *argp;
-        result = (int)G_add_modular_raster_color_rule((void const *)arg1,arg2,arg3,arg4,(void const *)arg5,arg6,arg7,arg8,arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_modular_color_rule) {
-        CELL arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        CELL arg5 ;
-        int arg6 ;
-        int arg7 ;
-        int arg8 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_modular_color_rule(CELL,int,int,int,CELL,int,int,int,struct Colors *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_add_modular_color_rule. Expected _p_CELL");
-            arg1 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 5 of G_add_modular_color_rule. Expected _p_CELL");
-            arg5 = *argp;
-                SWIG_croak("Type error in argument 9 of G_add_modular_color_rule. Expected _p_Colors");
-        result = (int)G_add_modular_color_rule(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_colors_count) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_colors_count(struct Colors const *);");
-                SWIG_croak("Type error in argument 1 of G_colors_count. Expected _p_Colors");
-        result = (int)G_colors_count((struct Colors const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_f_color_rule) {
-        unsigned char *arg6 = (unsigned char *) 0 ;
-        unsigned char *arg7 = (unsigned char *) 0 ;
-        unsigned char *arg8 = (unsigned char *) 0 ;
-        int arg10 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_f_color_rule(DCELL *,unsigned char *,unsigned char *,unsigned char *,DCELL *,unsigned char *,unsigned char *,unsigned char *,struct Colors const *,int);");
-                SWIG_croak("Type error in argument 1 of G_get_f_color_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 2 of G_get_f_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_get_f_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 4 of G_get_f_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 5 of G_get_f_color_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_get_f_color_rule. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_get_f_color_rule. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(7), (void **) &arg8, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 8 of G_get_f_color_rule. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 9 of G_get_f_color_rule. Expected _p_Colors");
-        arg10 = (int) SvIV(ST(9));
-        result = (int)G_get_f_color_rule(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,(struct Colors const *)arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_parse_color_rule) {
-        DCELL arg1 ;
-        DCELL arg2 ;
-        char *arg3 = (char *) 0 ;
-        int *arg5 = (int *) 0 ;
-        int *arg6 = (int *) 0 ;
-        int *arg7 = (int *) 0 ;
-        int *arg8 = (int *) 0 ;
-        int *arg9 = (int *) 0 ;
-        int *arg10 = (int *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_parse_color_rule(DCELL,DCELL,char const *,DCELL *,int *,int *,int *,int *,int *,int *);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 1 of G_parse_color_rule. Expected _p_DCELL");
-            arg1 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_parse_color_rule. Expected _p_DCELL");
-            arg2 = *argp;
-        if (!SvOK((SV*) ST(2))) arg3 = 0;
-        else arg3 = (char *) SvPV(ST(2), PL_na);
-                SWIG_croak("Type error in argument 4 of G_parse_color_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_parse_color_rule. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_parse_color_rule. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_parse_color_rule. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(7), (void **) &arg8, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 8 of G_parse_color_rule. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(8), (void **) &arg9, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 9 of G_parse_color_rule. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(9), (void **) &arg10, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 10 of G_parse_color_rule. Expected _p_int");
-        result = (int)G_parse_color_rule(arg1,arg2,(char const *)arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_parse_color_rule_error) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_parse_color_rule_error(int);");
-        arg1 = (int) SvIV(ST(0));
-        result = (char *)G_parse_color_rule_error(arg1);
-        if (result) {
-            sv_setpv((SV*)ST(argvi++), (char *) result);
-        } else {
-            sv_setsv((SV*)ST(argvi++), &PL_sv_undef);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_color_rule) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_color_rule(void *,DCELL,DCELL,DCELL *,int *,int *,int *,int *,int *,int *);");
-                SWIG_croak("Type error in argument 1 of G_read_color_rule. Expected _p_void");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_read_color_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_read_color_rule. Expected _p_DCELL");
-            arg3 = *argp;
-                SWIG_croak("Type error in argument 4 of G_read_color_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 5 of G_read_color_rule. Expected _p_int");
-                SWIG_croak("Type error in argument 6 of G_read_color_rule. Expected _p_int");
-                SWIG_croak("Type error in argument 7 of G_read_color_rule. Expected _p_int");
-                SWIG_croak("Type error in argument 8 of G_read_color_rule. Expected _p_int");
-                SWIG_croak("Type error in argument 9 of G_read_color_rule. Expected _p_int");
-                SWIG_croak("Type error in argument 10 of G_read_color_rule. Expected _p_int");
-        result = (int)G_read_color_rule(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_color_rules) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        read_rule_fn *arg4 = (read_rule_fn *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_color_rules(struct Colors *,DCELL,DCELL,read_rule_fn *,void *);");
-                SWIG_croak("Type error in argument 1 of G_read_color_rules. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_read_color_rules. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_read_color_rules. Expected _p_DCELL");
-            arg3 = *argp;
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_read_color_rules. Expected _p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int");
-                SWIG_croak("Type error in argument 5 of G_read_color_rules. Expected _p_void");
-        result = (int)G_read_color_rules(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_load_colors) {
-        CELL arg3 ;
-        CELL arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_load_colors(struct Colors *,char const *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_load_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_load_colors. Expected _p_CELL");
-            arg3 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 4 of G_load_colors. Expected _p_CELL");
-            arg4 = *argp;
-        result = (int)G_load_colors(arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_load_fp_colors) {
-        DCELL arg3 ;
-        DCELL arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_load_fp_colors(struct Colors *,char const *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_load_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_load_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_load_fp_colors. Expected _p_DCELL");
-            arg4 = *argp;
-        result = (int)G_load_fp_colors(arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_colors) {
-        CELL arg3 ;
-        CELL arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_colors(struct Colors *,char const *,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_make_colors. Expected _p_Colors");
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_colors. Expected _p_CELL");
-            arg3 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 4 of G_make_colors. Expected _p_CELL");
-            arg4 = *argp;
-        result = (int)G_make_colors(arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_fp_colors) {
-        DCELL arg3 ;
-        DCELL arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_fp_colors(struct Colors *,char const *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_make_fp_colors. Expected _p_Colors");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_make_fp_colors. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 4 of G_make_fp_colors. Expected _p_DCELL");
-            arg4 = *argp;
-        result = (int)G_make_fp_colors(arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_color) {
-        CELL arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_color(CELL,int,int,int,struct Colors *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_color. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 5 of G_set_color. Expected _p_Colors");
-        result = (int)G_set_color(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_d_color) {
-        DCELL arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_d_color(DCELL,int,int,int,struct Colors *);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_d_color. Expected _p_DCELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 5 of G_set_d_color. Expected _p_Colors");
-        result = (int)G_set_d_color(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_null_value_color) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_null_value_color(int,int,int,struct Colors *);");
-                SWIG_croak("Type error in argument 4 of G_set_null_value_color. Expected _p_Colors");
-        result = (int)G_set_null_value_color(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_default_color) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_default_color(int,int,int,struct Colors *);");
-                SWIG_croak("Type error in argument 4 of G_set_default_color. Expected _p_Colors");
-        result = (int)G_set_default_color(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_shift_colors) {
-        int arg1 ;
-        struct Colors *arg2 = (struct Colors *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_shift_colors(int,struct Colors *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_shift_colors. Expected _p_Colors");
-        result = (int)G_shift_colors(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_shift_d_colors) {
-        DCELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_shift_d_colors(DCELL,struct Colors *);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 1 of G_shift_d_colors. Expected _p_DCELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 2 of G_shift_d_colors. Expected _p_Colors");
-        result = (int)G_shift_d_colors(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_str_to_color) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_str_to_color(char const *,int *,int *,int *);");
-                SWIG_croak("Type error in argument 2 of G_str_to_color. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_str_to_color. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_str_to_color. Expected _p_int");
-        result = (int)G_str_to_color((char const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_colors(char const *,char const *,struct Colors *);");
-                SWIG_croak("Type error in argument 3 of G_write_colors. Expected _p_Colors");
-        result = (int)G_write_colors((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_colors) {
-        FILE *arg1 = (FILE *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_colors(FILE *,struct Colors *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__write_colors. Expected _p_FILE");
-                SWIG_croak("Type error in argument 2 of G__write_colors. Expected _p_Colors");
-        result = (int)G__write_colors(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_histogram_eq_colors) {
-        struct Cell_stats *arg3 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_histogram_eq_colors(struct Colors *,struct Colors *,struct Cell_stats *);");
-                SWIG_croak("Type error in argument 1 of G_histogram_eq_colors. Expected _p_Colors");
-                SWIG_croak("Type error in argument 2 of G_histogram_eq_colors. Expected _p_Colors");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_histogram_eq_colors. Expected _p_Cell_stats");
-        result = (int)G_histogram_eq_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_log_colors) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_log_colors(struct Colors *,struct Colors *,int);");
-                SWIG_croak("Type error in argument 1 of G_log_colors. Expected _p_Colors");
-                SWIG_croak("Type error in argument 2 of G_log_colors. Expected _p_Colors");
-        result = (int)G_log_colors(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_insert_commas) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_insert_commas(char *);");
-        result = (int)G_insert_commas(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_commas) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_commas(char *);");
-        result = (int)G_remove_commas(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_copy) {
-        void *arg2 = (void *) 0 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_copy(void *,void const *,int);");
-                SWIG_croak("Type error in argument 1 of G_copy. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, 0,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_copy. Expected _p_void");
-        result = (int)G_copy(arg1,(void const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_copy_file) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_copy_file(infile,outfile);");
-        result = (int)G_copy_file((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_vector) {
-        size_t arg1 ;
-        double *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_vector(size_t);");
-        arg1 = (size_t) SvUV(ST(0));
-        result = (double *)G_alloc_vector(arg1);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_double, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_matrix) {
-        int arg1 ;
-        int arg2 ;
-        double **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_matrix(int,int);");
-        result = (double **)G_alloc_matrix(arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_p_double, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_fvector) {
-        size_t arg1 ;
-        float *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_fvector(size_t);");
-        result = (float *)G_alloc_fvector(arg1);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_float, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_fmatrix) {
-        int arg1 ;
-        int arg2 ;
-        float **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_fmatrix(int,int);");
-        result = (float **)G_alloc_fmatrix(arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_p_float, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_vector) {
-        double *arg1 = (double *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_vector(double *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_vector. Expected _p_double");
-        result = (int)G_free_vector(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_matrix) {
-        double **arg1 = (double **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_matrix(double **);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_matrix. Expected _p_p_double");
-        result = (int)G_free_matrix(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_fmatrix) {
-        float **arg1 = (float **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_fmatrix(float **);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_float,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_fmatrix. Expected _p_p_float");
-        result = (int)G_free_fmatrix(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_date) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 0) || (items > 0)) {
-            SWIG_croak("Usage: G_date();");
-        result = (char *)G_date();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_datum_by_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_datum_by_name(char const *);");
-        result = (int)G_get_datum_by_name((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_datum_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_datum_name(int);");
-        result = (char *)G_datum_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_datum_description) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_datum_description(int);");
-        result = (char *)G_datum_description(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_datum_ellipsoid) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_datum_ellipsoid(int);");
-        result = (char *)G_datum_ellipsoid(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_datumparams_from_projinfo) {
-        struct Key_Value *arg1 = (struct Key_Value *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_datumparams_from_projinfo(projinfo,datumname,params);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Key_Value,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_datumparams_from_projinfo. Expected _p_Key_Value");
-        result = (int)G_get_datumparams_from_projinfo((struct Key_Value const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_debug) {
-        int arg1 ;
-        void *arg3 = 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 2) {
-            SWIG_croak("Usage: G_debug(int,char const *,...);");
-        result = (int)G_debug(arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_distance_calculations) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_distance_calculations();");
-        result = (int)G_begin_distance_calculations();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_distance) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_distance(double,double,double,double);");
-        arg1 = (double) SvNV(ST(0));
-        arg2 = (double) SvNV(ST(1));
-        arg3 = (double) SvNV(ST(2));
-        arg4 = (double) SvNV(ST(3));
-        result = (double)G_distance(arg1,arg2,arg3,arg4);
-        sv_setnv(ST(argvi++), (double) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_distance_between_line_segments) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        double arg6 ;
-        double arg7 ;
-        double arg8 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_distance_between_line_segments(double,double,double,double,double,double,double,double);");
-        arg5 = (double) SvNV(ST(4));
-        arg6 = (double) SvNV(ST(5));
-        arg7 = (double) SvNV(ST(6));
-        arg8 = (double) SvNV(ST(7));
-        result = (double)G_distance_between_line_segments(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_distance_point_to_line_segment) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        double arg6 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 6) || (items > 6)) {
-            SWIG_croak("Usage: G_distance_point_to_line_segment(double,double,double,double,double,double);");
-        result = (double)G_distance_point_to_line_segment(arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_done_msg) {
-        void *arg2 = 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_done_msg(char const *,...);");
-        result = (int)G_done_msg((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_tqli) {
-        double *arg1 ;
-        double *arg2 ;
-        int arg3 ;
-        double **arg4 = (double **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_tqli(double [],double [],int,double **);");
-                SWIG_croak("Type error in argument 1 of G_tqli. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_tqli. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_tqli. Expected _p_p_double");
-        result = (int)G_tqli(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_tred2) {
-        int arg2 ;
-        double *arg3 ;
-        double *arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_tred2(double **,int,double [],double []);");
-                SWIG_croak("Type error in argument 1 of G_tred2. Expected _p_p_double");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_tred2. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_tred2. Expected _p_double");
-        G_tred2(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_little_endian) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_little_endian();");
-        result = (int)G_is_little_endian();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_getenv) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_getenv(char const *);");
-        result = (char *)G_getenv((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_getenv2) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_getenv2(char const *,int);");
-        result = (char *)G_getenv2((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__getenv) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__getenv(char const *);");
-        result = (char *)G__getenv((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__getenv2) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__getenv2(char const *,int);");
-        result = (char *)G__getenv2((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_setenv) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_setenv(char const *,char const *);");
-        result = (int)G_setenv((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_setenv2) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_setenv2(char const *,char const *,int);");
-        result = (int)G_setenv2((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__setenv) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__setenv(char const *,char const *);");
-        result = (int)G__setenv((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__setenv2) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__setenv2(char const *,char const *,int);");
-        result = (int)G__setenv2((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unsetenv) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unsetenv(char const *);");
-        result = (int)G_unsetenv((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unsetenv2) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unsetenv2(char const *,int);");
-        result = (int)G_unsetenv2((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_env) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_env();");
-        result = (int)G__write_env();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__env_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__env_name(int);");
-        result = (char *)G__env_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_env) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_env();");
-        result = (int)G__read_env();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_gisrc_mode) {
-        int arg1 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_gisrc_mode(int);");
-        G_set_gisrc_mode(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_gisrc_mode) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_gisrc_mode();");
-        result = (int)G_get_gisrc_mode();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__set_gisrc_file) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__set_gisrc_file(char const *);");
-        result = (int)G__set_gisrc_file((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__get_gisrc_file) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__get_gisrc_file();");
-        result = (char *)G__get_gisrc_file();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__create_alt_env) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__create_alt_env();");
-        result = (int)G__create_alt_env();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__switch_env) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__switch_env();");
-        result = (int)G__switch_env();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_info_format) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_info_format();");
-        result = (int)G_info_format();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_message) {
-        void *arg2 = 0 ;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_message(char const *,...);");
-        G_message((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_verbose_message) {
-        void *arg2 = 0 ;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_verbose_message(char const *,...);");
-        G_verbose_message((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_important_message) {
-        void *arg2 = 0 ;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_important_message(char const *,...);");
-        G_important_message((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fatal_error) {
-        void *arg2 = 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_fatal_error(char const *,...);");
-        result = (int)G_fatal_error((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_warning) {
-        void *arg2 = 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 1) {
-            SWIG_croak("Usage: G_warning(char const *,...);");
-        result = (int)G_warning((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_suppress_warnings) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_suppress_warnings(int);");
-        result = (int)G_suppress_warnings(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sleep_on_error) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sleep_on_error(int);");
-        result = (int)G_sleep_on_error(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_error_routine) {
-        int (*arg1)(char const *,int) = (int (*)(char const *,int)) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_error_routine(int (*)(char const *,int));");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_f_p_q_const__char_int__int,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_set_error_routine. Expected _p_f_p_q_const__char_int__int");
-        result = (int)G_set_error_routine(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unset_error_routine) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unset_error_routine();");
-        result = (int)G_unset_error_routine();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__file_name) {
-        char *arg4 = (char *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__file_name(char *,char const *,char const *,char const *);");
-        if (!SvOK((SV*) ST(3))) arg4 = 0;
-        else arg4 = (char *) SvPV(ST(3), PL_na);
-        result = (char *)G__file_name(arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__file_name_misc) {
-        char *arg5 = (char *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__file_name_misc(char *,char const *,char const *,char const *,char const *);");
-        if (!SvOK((SV*) ST(4))) arg5 = 0;
-        else arg5 = (char *) SvPV(ST(4), PL_na);
-        result = (char *)G__file_name_misc(arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4,(char const *)arg5);
-        ST(argvi) = sv_newmortal();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_cell) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_cell(char *,char const *);");
-        result = (char *)G_find_cell(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_cell2) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_cell2(char const *,char const *);");
-        result = (char *)G_find_cell2((char const *)arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_file) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_file(char const *,char *,char const *);");
-        result = (char *)G_find_file((char const *)arg1,arg2,(char const *)arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_file2) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_file2(char const *,char const *,char const *);");
-        result = (char *)G_find_file2((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_file_misc) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_file_misc(char const *,char const *,char *,char const *);");
-        result = (char *)G_find_file_misc((char const *)arg1,(char const *)arg2,arg3,(char const *)arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_file2_misc) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_file2_misc(char const *,char const *,char const *,char const *);");
-        result = (char *)G_find_file2_misc((char const *)arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_etc) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_etc(char const *);");
-        result = (char *)G_find_etc((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_vector) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_vector(char *,char const *);");
-        result = (char *)G_find_vector(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_vector2) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_vector2(char const *,char const *);");
-        result = (char *)G_find_vector2((char const *)arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zlib_compress) {
-        unsigned char *arg1 = (unsigned char *) 0 ;
-        int arg2 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zlib_compress(unsigned char const *,int,unsigned char *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_zlib_compress. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_zlib_compress. Expected _p_unsigned_char");
-        result = (int)G_zlib_compress((unsigned char const *)arg1,arg2,arg3,arg4);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zlib_expand) {
-        int arg2 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zlib_expand(unsigned char const *,int,unsigned char *,int);");
-                SWIG_croak("Type error in argument 1 of G_zlib_expand. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_zlib_expand. Expected _p_unsigned_char");
-        result = (int)G_zlib_expand((unsigned char const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zlib_write) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zlib_write(int,unsigned char const *,int);");
-                SWIG_croak("Type error in argument 2 of G_zlib_write. Expected _p_unsigned_char");
-        result = (int)G_zlib_write(arg1,(unsigned char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zlib_read) {
-        int arg1 ;
-        int arg2 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zlib_read(int,int,unsigned char *,int);");
-                SWIG_croak("Type error in argument 3 of G_zlib_read. Expected _p_unsigned_char");
-        result = (int)G_zlib_read(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zlib_write_noCompress) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zlib_write_noCompress(int,unsigned char const *,int);");
-                SWIG_croak("Type error in argument 2 of G_zlib_write_noCompress. Expected _p_unsigned_char");
-        result = (int)G_zlib_write_noCompress(arg1,(unsigned char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fork) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fork();");
-        result = (int)G_fork();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__check_format) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__check_format(int);");
-        result = (int)G__check_format(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_row_ptrs) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_row_ptrs(int);");
-        result = (int)G__read_row_ptrs(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_row_ptrs) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_row_ptrs(int);");
-        result = (int)G__write_row_ptrs(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_clear) {
-        struct FPReclass *arg1 = (struct FPReclass *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_clear(struct FPReclass *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FPReclass,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_fpreclass_clear. Expected _p_FPReclass");
-        G_fpreclass_clear(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_reset) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_reset(struct FPReclass *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_reset. Expected _p_FPReclass");
-        G_fpreclass_reset(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_init) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_init(struct FPReclass *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_init. Expected _p_FPReclass");
-        result = (int)G_fpreclass_init(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_set_domain) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_set_domain(struct FPReclass *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_set_domain. Expected _p_FPReclass");
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_fpreclass_set_domain. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_fpreclass_set_domain. Expected _p_DCELL");
-            arg3 = *argp;
-        G_fpreclass_set_domain(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_set_range) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_set_range(struct FPReclass *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_set_range. Expected _p_FPReclass");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_fpreclass_set_range. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_fpreclass_set_range. Expected _p_DCELL");
-            arg3 = *argp;
-        G_fpreclass_set_range(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_get_limits) {
-        DCELL *arg2 = (DCELL *) 0 ;
-        DCELL *arg3 = (DCELL *) 0 ;
-        DCELL *arg4 = (DCELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_get_limits(struct FPReclass const *,DCELL *,DCELL *,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_get_limits. Expected _p_FPReclass");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_fpreclass_get_limits. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_fpreclass_get_limits. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_fpreclass_get_limits. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 5 of G_fpreclass_get_limits. Expected _p_DCELL");
-        result = (int)G_fpreclass_get_limits((struct FPReclass const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_nof_rules) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 1) || (items > 1)) {
-            SWIG_croak("Usage: G_fpreclass_nof_rules(struct FPReclass const *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_nof_rules. Expected _p_FPReclass");
-        result = (int)G_fpreclass_nof_rules((struct FPReclass const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_get_ith_rule) {
-        int arg2 ;
-        DCELL *arg6 = (DCELL *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_get_ith_rule(struct FPReclass const *,int,DCELL *,DCELL *,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_get_ith_rule. Expected _p_FPReclass");
-        arg2 = (int) SvIV(ST(1));
-                SWIG_croak("Type error in argument 3 of G_fpreclass_get_ith_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 4 of G_fpreclass_get_ith_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 5 of G_fpreclass_get_ith_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_fpreclass_get_ith_rule. Expected _p_DCELL");
-        G_fpreclass_get_ith_rule((struct FPReclass const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_set_neg_infinite_rule) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_set_neg_infinite_rule(struct FPReclass *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_set_neg_infinite_rule. Expected _p_FPReclass");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_fpreclass_set_neg_infinite_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_fpreclass_set_neg_infinite_rule. Expected _p_DCELL");
-            arg3 = *argp;
-        G_fpreclass_set_neg_infinite_rule(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_get_neg_infinite_rule) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_get_neg_infinite_rule(struct FPReclass const *,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_get_neg_infinite_rule. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_get_neg_infinite_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_get_neg_infinite_rule. Expected _p_DCELL");
-        result = (int)G_fpreclass_get_neg_infinite_rule((struct FPReclass const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_set_pos_infinite_rule) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_set_pos_infinite_rule(struct FPReclass *,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_set_pos_infinite_rule. Expected _p_FPReclass");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_fpreclass_set_pos_infinite_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_fpreclass_set_pos_infinite_rule. Expected _p_DCELL");
-            arg3 = *argp;
-        G_fpreclass_set_pos_infinite_rule(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_get_pos_infinite_rule) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_get_pos_infinite_rule(struct FPReclass const *,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_get_pos_infinite_rule. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_get_pos_infinite_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_get_pos_infinite_rule. Expected _p_DCELL");
-        result = (int)G_fpreclass_get_pos_infinite_rule((struct FPReclass const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_add_rule) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        DCELL arg4 ;
-        DCELL arg5 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_add_rule(struct FPReclass *,DCELL,DCELL,DCELL,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_add_rule. Expected _p_FPReclass");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_fpreclass_add_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_fpreclass_add_rule. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 4 of G_fpreclass_add_rule. Expected _p_DCELL");
-            arg4 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(4),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_fpreclass_add_rule. Expected _p_DCELL");
-            arg5 = *argp;
-        G_fpreclass_add_rule(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_reverse_rule_order) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_reverse_rule_order(struct FPReclass *);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_reverse_rule_order. Expected _p_FPReclass");
-        G_fpreclass_reverse_rule_order(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_get_cell_value) {
-        DCELL arg2 ;
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 2) || (items > 2)) {
-            SWIG_croak("Usage: G_fpreclass_get_cell_value(struct FPReclass const *,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_get_cell_value. Expected _p_FPReclass");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_fpreclass_get_cell_value. Expected _p_DCELL");
-            arg2 = *argp;
-        result = G_fpreclass_get_cell_value((struct FPReclass const *)arg1,arg2);
-            DCELL * resultobj = (DCELL *) malloc(sizeof(DCELL));
-            memmove(resultobj, &result, sizeof(DCELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_DCELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_di) {
-        CELL *arg3 = (CELL *) 0 ;
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 4) || (items > 4)) {
-            SWIG_croak("Usage: G_fpreclass_perform_di(struct FPReclass const *,DCELL const *,CELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_di. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_di. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_di. Expected _p_CELL");
-        arg4 = (int) SvIV(ST(3));
-        G_fpreclass_perform_di((struct FPReclass const *)arg1,(DCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_df) {
-        FCELL *arg3 = (FCELL *) 0 ;
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_df(struct FPReclass const *,DCELL const *,FCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_df. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_df. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_df. Expected _p_FCELL");
-        G_fpreclass_perform_df((struct FPReclass const *)arg1,(DCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_dd) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_dd(struct FPReclass const *,DCELL const *,DCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_dd. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_dd. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_dd. Expected _p_DCELL");
-        G_fpreclass_perform_dd((struct FPReclass const *)arg1,(DCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_fi) {
-        FCELL *arg2 = (FCELL *) 0 ;
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_fi(struct FPReclass const *,FCELL const *,CELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_fi. Expected _p_FPReclass");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_fi. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_fi. Expected _p_CELL");
-        G_fpreclass_perform_fi((struct FPReclass const *)arg1,(FCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_ff) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_ff(struct FPReclass const *,FCELL const *,FCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_ff. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_ff. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_ff. Expected _p_FCELL");
-        G_fpreclass_perform_ff((struct FPReclass const *)arg1,(FCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_fd) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_fd(struct FPReclass const *,FCELL const *,DCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_fd. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_fd. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_fd. Expected _p_DCELL");
-        G_fpreclass_perform_fd((struct FPReclass const *)arg1,(FCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_ii) {
-        CELL *arg2 = (CELL *) 0 ;
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_ii(struct FPReclass const *,CELL const *,CELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_ii. Expected _p_FPReclass");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_ii. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_ii. Expected _p_CELL");
-        G_fpreclass_perform_ii((struct FPReclass const *)arg1,(CELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_if) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_if(struct FPReclass const *,CELL const *,FCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_if. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_if. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_if. Expected _p_FCELL");
-        G_fpreclass_perform_if((struct FPReclass const *)arg1,(CELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fpreclass_perform_id) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fpreclass_perform_id(struct FPReclass const *,CELL const *,DCELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_fpreclass_perform_id. Expected _p_FPReclass");
-                SWIG_croak("Type error in argument 2 of G_fpreclass_perform_id. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_fpreclass_perform_id. Expected _p_DCELL");
-        G_fpreclass_perform_id((struct FPReclass const *)arg1,(CELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_geodesic_equation) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_geodesic_equation(double,double,double,double);");
-        result = (int)G_begin_geodesic_equation(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_geodesic_lat_from_lon) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_geodesic_lat_from_lon(double);");
-        result = (double)G_geodesic_lat_from_lon(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_geodesic_distance) {
-        double arg1 ;
-        double arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_geodesic_distance(double,double);");
-        result = (int)G_begin_geodesic_distance(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_geodesic_distance_lat1) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_geodesic_distance_lat1(double);");
-        result = (int)G_set_geodesic_distance_lat1(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_geodesic_distance_lat2) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_geodesic_distance_lat2(double);");
-        result = (int)G_set_geodesic_distance_lat2(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_geodesic_distance_lon_to_lon) {
-        double arg1 ;
-        double arg2 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_geodesic_distance_lon_to_lon(double,double);");
-        result = (double)G_geodesic_distance_lon_to_lon(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_geodesic_distance) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_geodesic_distance(double,double,double,double);");
-        result = (double)G_geodesic_distance(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_cellhd) {
-        char *arg1 = (char *) 0 ;
-        char *arg2 = (char *) 0 ;
-        struct Cell_head *arg3 = (struct Cell_head *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 3) || (items > 3)) {
-            SWIG_croak("Usage: G_get_cellhd(char const *,char const *,struct Cell_head *);");
-        if (!SvOK((SV*) ST(0))) arg1 = 0;
-        else arg1 = (char *) SvPV(ST(0), PL_na);
-        if (!SvOK((SV*) ST(1))) arg2 = 0;
-        else arg2 = (char *) SvPV(ST(1), PL_na);
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_cellhd. Expected _p_Cell_head");
-        result = (int)G_get_cellhd((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_datum_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_datum_name(char *,char *);");
-        result = (int)G_ask_datum_name(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_ellipse_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_ellipse_name(char *);");
-        result = (int)G_ask_ellipse_name(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ellipsoid_parameters) {
-        double *arg2 = (double *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ellipsoid_parameters(double *,double *);");
-                SWIG_croak("Type error in argument 1 of G_get_ellipsoid_parameters. Expected _p_double");
-                SWIG_croak("Type error in argument 2 of G_get_ellipsoid_parameters. Expected _p_double");
-        result = (int)G_get_ellipsoid_parameters(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_spheroid_by_name) {
-        double *arg3 = (double *) 0 ;
-        double *arg4 = (double *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_spheroid_by_name(char const *,double *,double *,double *);");
-                SWIG_croak("Type error in argument 2 of G_get_spheroid_by_name. Expected _p_double");
-                SWIG_croak("Type error in argument 3 of G_get_spheroid_by_name. Expected _p_double");
-                SWIG_croak("Type error in argument 4 of G_get_spheroid_by_name. Expected _p_double");
-        result = (int)G_get_spheroid_by_name((char const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_ellipsoid_by_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_ellipsoid_by_name(char const *,double *,double *);");
-                SWIG_croak("Type error in argument 2 of G_get_ellipsoid_by_name. Expected _p_double");
-                SWIG_croak("Type error in argument 3 of G_get_ellipsoid_by_name. Expected _p_double");
-        result = (int)G_get_ellipsoid_by_name((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ellipsoid_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ellipsoid_name(int);");
-        result = (char *)G_ellipsoid_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ellipsoid_description) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ellipsoid_description(int);");
-        result = (char *)G_ellipsoid_description(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_projunits) {
-        struct Key_Value *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_projunits();");
-        result = (struct Key_Value *)G_get_projunits();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_Key_Value, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_projinfo) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_projinfo();");
-        result = (struct Key_Value *)G_get_projinfo();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_proj_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_proj_name(char *,char *);");
-        result = (int)G_ask_proj_name(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_map_row_nomask) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_map_row_nomask(int,CELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_map_row_nomask. Expected _p_CELL");
-        arg3 = (int) SvIV(ST(2));
-        result = (int)G_get_map_row_nomask(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_row_nomask) {
-        int arg1 ;
-        int arg3 ;
-        RASTER_MAP_TYPE arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_row_nomask(int,void *,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 2 of G_get_raster_row_nomask. Expected _p_void");
-            RASTER_MAP_TYPE * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_raster_row_nomask. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_get_raster_row_nomask(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_c_raster_row_nomask) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_c_raster_row_nomask(int,CELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_c_raster_row_nomask. Expected _p_CELL");
-        result = (int)G_get_c_raster_row_nomask(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_f_raster_row_nomask) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_f_raster_row_nomask(int,FCELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_f_raster_row_nomask. Expected _p_FCELL");
-        result = (int)G_get_f_raster_row_nomask(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_d_raster_row_nomask) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_d_raster_row_nomask(int,DCELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_d_raster_row_nomask. Expected _p_DCELL");
-        result = (int)G_get_d_raster_row_nomask(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_map_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_map_row(int,CELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_map_row. Expected _p_CELL");
-        result = (int)G_get_map_row(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_row(int,void *,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 2 of G_get_raster_row. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_get_raster_row. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_get_raster_row(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_c_raster_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_c_raster_row(int,CELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_c_raster_row. Expected _p_CELL");
-        result = (int)G_get_c_raster_row(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_f_raster_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_f_raster_row(int,FCELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_f_raster_row. Expected _p_FCELL");
-        result = (int)G_get_f_raster_row(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_d_raster_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_d_raster_row(int,DCELL *,int);");
-                SWIG_croak("Type error in argument 2 of G_get_d_raster_row. Expected _p_DCELL");
-        result = (int)G_get_d_raster_row(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_null_value_row) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_null_value_row(int,char *,int);");
-        result = (int)G_get_null_value_row(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_row_colors) {
-        int arg1 ;
-        int arg2 ;
-        struct Colors *arg3 = (struct Colors *) 0 ;
-        unsigned char *arg4 = (unsigned char *) 0 ;
-        unsigned char *arg5 = (unsigned char *) 0 ;
-        unsigned char *arg6 = (unsigned char *) 0 ;
-        unsigned char *arg7 = (unsigned char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 7) || (items > 7)) {
-            SWIG_croak("Usage: G_get_raster_row_colors(int,int,struct Colors *,unsigned char *,unsigned char *,unsigned char *,unsigned char *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Colors,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_raster_row_colors. Expected _p_Colors");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_raster_row_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_get_raster_row_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_get_raster_row_colors. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_get_raster_row_colors. Expected _p_unsigned_char");
-        result = (int)G_get_raster_row_colors(arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_window) {
-        struct Cell_head *arg1 = (struct Cell_head *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_window(struct Cell_head *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_window. Expected _p_Cell_head");
-        result = (int)G_get_window(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_default_window) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_default_window(struct Cell_head *);");
-                SWIG_croak("Type error in argument 1 of G_get_default_window. Expected _p_Cell_head");
-        result = (int)G_get_default_window(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__get_window) {
-        char *arg3 = (char *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__get_window(struct Cell_head *,char const *,char const *,char const *);");
-                SWIG_croak("Type error in argument 1 of G__get_window. Expected _p_Cell_head");
-        if (!SvOK((SV*) ST(2))) arg3 = 0;
-        else arg3 = (char *) SvPV(ST(2), PL_na);
-        result = (char *)G__get_window(arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_getl) {
-        int arg2 ;
-        FILE *arg3 = (FILE *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_getl(char *,int,FILE *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_getl. Expected _p_FILE");
-        result = (int)G_getl(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_getl2) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_getl2(char *,int,FILE *);");
-                SWIG_croak("Type error in argument 3 of G_getl2. Expected _p_FILE");
-        result = (int)G_getl2(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_gets) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_gets(char *);");
-        result = (int)G_gets(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_gisbase) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_gisbase();");
-        result = (char *)G_gisbase();
-        if (result) {
-            sv_setpv((SV*)ST(argvi++), (char *) result);
-        } else {
-            sv_setsv((SV*)ST(argvi++), &PL_sv_undef);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_gisdbase) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_gisdbase();");
-        result = (char *)G_gisdbase();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_gishelp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_gishelp(char const *,char const *);");
-        result = (int)G_gishelp((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_gisinit) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_gisinit(char const *);");
-        result = (int)G_gisinit((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_no_gisinit) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_no_gisinit();");
-        result = (int)G_no_gisinit();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__check_gisinit) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__check_gisinit();");
-        result = (int)G__check_gisinit();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_histogram_eq) {
-        struct Histogram *arg1 = (struct Histogram *) 0 ;
-        unsigned char **arg2 = (unsigned char **) 0 ;
-        CELL *arg4 = (CELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_histogram_eq(struct Histogram const *,unsigned char **,CELL *,CELL *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Histogram,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_histogram_eq. Expected _p_Histogram");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_histogram_eq. Expected _p_p_unsigned_char");
-                SWIG_croak("Type error in argument 3 of G_histogram_eq. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_histogram_eq. Expected _p_CELL");
-        result = (int)G_histogram_eq((struct Histogram const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_histogram) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_histogram(struct Histogram *);");
-                SWIG_croak("Type error in argument 1 of G_init_histogram. Expected _p_Histogram");
-        result = (int)G_init_histogram(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_histogram) {
-        struct Histogram *arg3 = (struct Histogram *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_histogram(char const *,char const *,struct Histogram *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Histogram,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_histogram. Expected _p_Histogram");
-        result = (int)G_read_histogram((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_histogram) {
-        struct Histogram *arg2 = (struct Histogram *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_histogram(char const *,struct Histogram const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Histogram,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_write_histogram. Expected _p_Histogram");
-        result = (int)G_write_histogram((char const *)arg1,(struct Histogram const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_histogram_cs) {
-        struct Cell_stats *arg2 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_histogram_cs(char const *,struct Cell_stats *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_write_histogram_cs. Expected _p_Cell_stats");
-        result = (int)G_write_histogram_cs((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_histogram_cs) {
-        struct Cell_stats *arg1 = (struct Cell_stats *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_histogram_cs(struct Cell_stats *,struct Histogram *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_stats,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_make_histogram_cs. Expected _p_Cell_stats");
-                SWIG_croak("Type error in argument 2 of G_make_histogram_cs. Expected _p_Histogram");
-        result = (int)G_make_histogram_cs(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_histogram_num) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_histogram_num(struct Histogram const *);");
-                SWIG_croak("Type error in argument 1 of G_get_histogram_num. Expected _p_Histogram");
-        result = (int)G_get_histogram_num((struct Histogram const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_histogram_cat) {
-        int arg1 ;
-        CELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_histogram_cat(int,struct Histogram const *);");
-        arg1 = (int) SvIV(ST(0));
-                SWIG_croak("Type error in argument 2 of G_get_histogram_cat. Expected _p_Histogram");
-        result = G_get_histogram_cat(arg1,(struct Histogram const *)arg2);
-            CELL * resultobj = (CELL *) malloc(sizeof(CELL));
-            memmove(resultobj, &result, sizeof(CELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_CELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_histogram_count) {
-        int arg1 ;
-        long result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_histogram_count(int,struct Histogram const *);");
-                SWIG_croak("Type error in argument 2 of G_get_histogram_count. Expected _p_Histogram");
-        result = (long)G_get_histogram_count(arg1,(struct Histogram const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_histogram) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_histogram(struct Histogram *);");
-                SWIG_croak("Type error in argument 1 of G_free_histogram. Expected _p_Histogram");
-        result = (int)G_free_histogram(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sort_histogram) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sort_histogram(struct Histogram *);");
-                SWIG_croak("Type error in argument 1 of G_sort_histogram. Expected _p_Histogram");
-        result = (int)G_sort_histogram(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sort_histogram_by_count) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sort_histogram_by_count(struct Histogram *);");
-                SWIG_croak("Type error in argument 1 of G_sort_histogram_by_count. Expected _p_Histogram");
-        result = (int)G_sort_histogram_by_count(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_histogram) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_histogram(char const *);");
-        result = (int)G_remove_histogram((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_histogram) {
-        CELL arg1 ;
-        long arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_histogram(CELL,long,struct Histogram *);");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_add_histogram. Expected _p_CELL");
-            arg1 = *argp;
-        arg2 = (long) SvIV(ST(1));
-                SWIG_croak("Type error in argument 3 of G_add_histogram. Expected _p_Histogram");
-        result = (int)G_add_histogram(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_histogram) {
-        CELL arg1 ;
-        long arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_histogram(CELL,long,struct Histogram *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_set_histogram. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 3 of G_set_histogram. Expected _p_Histogram");
-        result = (int)G_set_histogram(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_extend_histogram) {
-        CELL arg1 ;
-        long arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_extend_histogram(CELL,long,struct Histogram *);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_extend_histogram. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 3 of G_extend_histogram. Expected _p_Histogram");
-        result = (int)G_extend_histogram(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zero_histogram) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zero_histogram(struct Histogram *);");
-                SWIG_croak("Type error in argument 1 of G_zero_histogram. Expected _p_Histogram");
-        result = (int)G_zero_histogram(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_history) {
-        struct History *arg3 = (struct History *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_history(char const *,char const *,struct History *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_History,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_history. Expected _p_History");
-        result = (int)G_read_history((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_history) {
-        struct History *arg2 = (struct History *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_history(char const *,struct History *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_History,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_write_history. Expected _p_History");
-        result = (int)G_write_history((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_short_history) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_short_history(char const *,char const *,struct History *);");
-                SWIG_croak("Type error in argument 3 of G_short_history. Expected _p_History");
-        result = (int)G_short_history((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_command_history) {
-        struct History *arg1 = (struct History *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_command_history(struct History *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_History,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_command_history. Expected _p_History");
-        result = (int)G_command_history(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_home) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_home();");
-        result = (char *)G_home();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__home) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__home();");
-        result = (char *)G__home();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_ivector) {
-        size_t arg1 ;
-        int *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_ivector(size_t);");
-        arg1 = (size_t) SvUV(ST(0));
-        result = (int *)G_alloc_ivector(arg1);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_int, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_alloc_imatrix) {
-        int arg1 ;
-        int arg2 ;
-        int **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_alloc_imatrix(int,int);");
-        result = (int **)G_alloc_imatrix(arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_p_int, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_ivector) {
-        int *arg1 = (int *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_ivector(int *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_ivector. Expected _p_int");
-        result = (int)G_free_ivector(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_imatrix) {
-        int **arg1 = (int **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_imatrix(int **);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_imatrix. Expected _p_p_int");
-        result = (int)G_free_imatrix(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_index) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_index(char const *,int);");
-        result = (char *)G_index((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rindex) {
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rindex(char const *,int);");
-        result = (char *)G_rindex((char const *)arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__random_d_initialize_0) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__random_d_initialize_0(int,int,int);");
-        result = (int)G__random_d_initialize_0(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__random_f_initialize_0) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__random_f_initialize_0(int,int,int);");
-        result = (int)G__random_f_initialize_0(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_interp_linear) {
-        double arg1 ;
-        DCELL arg2 ;
-        DCELL arg3 ;
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_interp_linear(double,DCELL,DCELL);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_interp_linear. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_interp_linear. Expected _p_DCELL");
-            arg3 = *argp;
-        result = G_interp_linear(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_interp_bilinear) {
-        double arg1 ;
-        double arg2 ;
-        DCELL arg3 ;
-        DCELL arg4 ;
-        DCELL arg5 ;
-        DCELL arg6 ;
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_interp_bilinear(double,double,DCELL,DCELL,DCELL,DCELL);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_interp_bilinear. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_interp_bilinear. Expected _p_DCELL");
-            arg4 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 5 of G_interp_bilinear. Expected _p_DCELL");
-            arg5 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(5),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_interp_bilinear. Expected _p_DCELL");
-            arg6 = *argp;
-        result = G_interp_bilinear(arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_interp_cubic) {
-        double arg1 ;
-        DCELL arg2 ;
-        DCELL arg3 ;
-        DCELL arg4 ;
-        DCELL arg5 ;
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 5) || (items > 5)) {
-            SWIG_croak("Usage: G_interp_cubic(double,DCELL,DCELL,DCELL,DCELL);");
-        arg1 = (double) SvNV(ST(0));
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_interp_cubic. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_interp_cubic. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 4 of G_interp_cubic. Expected _p_DCELL");
-            arg4 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 5 of G_interp_cubic. Expected _p_DCELL");
-            arg5 = *argp;
-        result = G_interp_cubic(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_interp_bicubic) {
-        double arg1 ;
-        double arg2 ;
-        DCELL arg3 ;
-        DCELL arg4 ;
-        DCELL arg5 ;
-        DCELL arg6 ;
-        DCELL arg7 ;
-        DCELL arg8 ;
-        DCELL arg9 ;
-        DCELL arg10 ;
-        DCELL arg11 ;
-        DCELL arg12 ;
-        DCELL arg13 ;
-        DCELL arg14 ;
-        DCELL arg15 ;
-        DCELL arg16 ;
-        DCELL arg17 ;
-        DCELL arg18 ;
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 18) || (items > 18)) {
-            SWIG_croak("Usage: G_interp_bicubic(double,double,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL,DCELL);");
-        arg2 = (double) SvNV(ST(1));
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_interp_bicubic. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 4 of G_interp_bicubic. Expected _p_DCELL");
-            arg4 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 5 of G_interp_bicubic. Expected _p_DCELL");
-            arg5 = *argp;
-            DCELL * argp;
-                SWIG_croak("Type error in argument 6 of G_interp_bicubic. Expected _p_DCELL");
-            arg6 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(6),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_interp_bicubic. Expected _p_DCELL");
-            arg7 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(7),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 8 of G_interp_bicubic. Expected _p_DCELL");
-            arg8 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(8),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 9 of G_interp_bicubic. Expected _p_DCELL");
-            arg9 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(9),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 10 of G_interp_bicubic. Expected _p_DCELL");
-            arg10 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(10),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 11 of G_interp_bicubic. Expected _p_DCELL");
-            arg11 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(11),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 12 of G_interp_bicubic. Expected _p_DCELL");
-            arg12 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(12),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 13 of G_interp_bicubic. Expected _p_DCELL");
-            arg13 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(13),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 14 of G_interp_bicubic. Expected _p_DCELL");
-            arg14 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(14),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 15 of G_interp_bicubic. Expected _p_DCELL");
-            arg15 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(15),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 16 of G_interp_bicubic. Expected _p_DCELL");
-            arg16 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(16),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 17 of G_interp_bicubic. Expected _p_DCELL");
-            arg17 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(17),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 18 of G_interp_bicubic. Expected _p_DCELL");
-            arg18 = *argp;
-        result = G_interp_bicubic(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11,arg12,arg13,arg14,arg15,arg16,arg17,arg18);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_intersect_line_segments) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        double arg6 ;
-        double arg7 ;
-        double arg8 ;
-        double *arg9 = (double *) 0 ;
-        double *arg10 = (double *) 0 ;
-        double *arg11 = (double *) 0 ;
-        double *arg12 = (double *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 12) || (items > 12)) {
-            SWIG_croak("Usage: G_intersect_line_segments(double,double,double,double,double,double,double,double,double *,double *,double *,double *);");
-        arg3 = (double) SvNV(ST(2));
-        arg4 = (double) SvNV(ST(3));
-        arg5 = (double) SvNV(ST(4));
-        arg6 = (double) SvNV(ST(5));
-        arg7 = (double) SvNV(ST(6));
-        arg8 = (double) SvNV(ST(7));
-            if (SWIG_ConvertPtr(ST(8), (void **) &arg9, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 9 of G_intersect_line_segments. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(9), (void **) &arg10, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 10 of G_intersect_line_segments. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(10), (void **) &arg11, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 11 of G_intersect_line_segments. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(11), (void **) &arg12, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 12 of G_intersect_line_segments. Expected _p_double");
-        result = (int)G_intersect_line_segments(arg1,arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11,arg12);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_intr_char) {
-        char result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 0) || (items > 0)) {
-            SWIG_croak("Usage: G_intr_char();");
-        result = (char)G_intr_char();
-        sv_setpvn((SV*)ST(argvi++), &result, 1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_gisbase) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_gisbase(char const *);");
-        result = (int)G_is_gisbase((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_location) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_location(char const *);");
-        result = (int)G_is_location((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_mapset) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_mapset(char const *);");
-        result = (int)G_is_mapset((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_create_key_value) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_create_key_value();");
-        result = (struct Key_Value *)G_create_key_value();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_key_value) {
-        struct Key_Value *arg3 = (struct Key_Value *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_key_value(char const *,char const *,struct Key_Value *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Key_Value,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_set_key_value. Expected _p_Key_Value");
-        result = (int)G_set_key_value((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_find_key_value) {
-        struct Key_Value *arg2 = (struct Key_Value *) 0 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_find_key_value(char const *,struct Key_Value const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Key_Value,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_find_key_value. Expected _p_Key_Value");
-        result = (char *)G_find_key_value((char const *)arg1,(struct Key_Value const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_key_value) {
-        struct Key_Value *arg1 = (struct Key_Value *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_key_value(struct Key_Value *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Key_Value,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_key_value. Expected _p_Key_Value");
-        result = (int)G_free_key_value(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fwrite_key_value) {
-        FILE *arg1 = (FILE *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fwrite_key_value(FILE *,struct Key_Value const *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_fwrite_key_value. Expected _p_FILE");
-                SWIG_croak("Type error in argument 2 of G_fwrite_key_value. Expected _p_Key_Value");
-        result = (int)G_fwrite_key_value(arg1,(struct Key_Value const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fread_key_value) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fread_key_value(FILE *);");
-                SWIG_croak("Type error in argument 1 of G_fread_key_value. Expected _p_FILE");
-        result = (struct Key_Value *)G_fread_key_value(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_key_value_file) {
-        int *arg3 = (int *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_key_value_file(char const *,struct Key_Value const *,int *);");
-                SWIG_croak("Type error in argument 2 of G_write_key_value_file. Expected _p_Key_Value");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_write_key_value_file. Expected _p_int");
-        result = (int)G_write_key_value_file((char const *)arg1,(struct Key_Value const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_key_value_file) {
-        int *arg2 = (int *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_key_value_file(char const *,int *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_read_key_value_file. Expected _p_int");
-        result = (struct Key_Value *)G_read_key_value_file((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_update_key_value_file) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_update_key_value_file(char const *,char const *,char const *);");
-        result = (int)G_update_key_value_file((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lookup_key_value_from_file) {
-        char *arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lookup_key_value_from_file(char const *,char const *,char [],int);");
-        arg3 = SvPV(ST(2),PL_na);
-        result = (int)G_lookup_key_value_from_file((char const *)arg1,(char const *)arg2,arg3,arg4);
-        ST(argvi) = sv_newmortal();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_legal_filename) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_legal_filename(char const *);");
-        result = (int)G_legal_filename((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_check_input_output_name) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_check_input_output_name(char const *,char const *,int);");
-        result = (int)G_check_input_output_name((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_distance_to_line_tolerance) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_distance_to_line_tolerance(double);");
-        result = (int)G_set_distance_to_line_tolerance(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_distance2_point_to_line) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        double arg6 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 6) || (items > 6)) {
-            SWIG_croak("Usage: G_distance2_point_to_line(double,double,double,double,double,double);");
-        result = (double)G_distance2_point_to_line(arg1,arg2,arg3,arg4,arg5,arg6);
-        sv_setnv(ST(argvi++), (double) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_list_hit_return) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_list_hit_return(int);");
-        result = (int)G_set_list_hit_return(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_list_element) {
-        int (*arg4)(char const *,char const *,char const *) = (int (*)(char const *,char const *,char const *)) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_list_element(char const *,char const *,char const *,int (*)(char const *,char const *,char const *));");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_f_p_q_const__char_p_q_const__char_p_q_const__char__int,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_list_element. Expected _p_f_p_q_const__char_p_q_const__char_p_q_const__char__int");
-        result = (int)G_list_element((char const *)arg1,(char const *)arg2,(char const *)arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_list) {
-        int arg1 ;
-        char *arg4 = (char *) 0 ;
-        char **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_list(int,char const *,char const *,char const *);");
-        if (!SvOK((SV*) ST(3))) arg4 = 0;
-        else arg4 = (char *) SvPV(ST(3), PL_na);
-        result = (char **)G_list(arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_p_char, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_list) {
-        char **arg1 = (char **) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_list(char **);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_char,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_list. Expected _p_p_char");
-        G_free_list(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lat_format) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lat_format(double,char *);");
-        result = (int)G_lat_format(arg1,arg2);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lat_format_string) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lat_format_string();");
-        result = (char *)G_lat_format_string();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lon_format) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lon_format(double,char *);");
-        result = (int)G_lon_format(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lon_format_string) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lon_format_string();");
-        result = (char *)G_lon_format_string();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_llres_format) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_llres_format(double,char *);");
-        result = (int)G_llres_format(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_llres_format_string) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_llres_format_string();");
-        result = (char *)G_llres_format_string();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lat_parts) {
-        double arg1 ;
-        char *arg5 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lat_parts(double,int *,int *,double *,char *);");
-                SWIG_croak("Type error in argument 2 of G_lat_parts. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_lat_parts. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_lat_parts. Expected _p_double");
-        if (!SvOK((SV*) ST(4))) arg5 = 0;
-        else arg5 = (char *) SvPV(ST(4), PL_na);
-        result = (int)G_lat_parts(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lon_parts) {
-        double arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lon_parts(double,int *,int *,double *,char *);");
-                SWIG_croak("Type error in argument 2 of G_lon_parts. Expected _p_int");
-                SWIG_croak("Type error in argument 3 of G_lon_parts. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_lon_parts. Expected _p_double");
-        result = (int)G_lon_parts(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lat_scan) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lat_scan(char const *,double *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_lat_scan. Expected _p_double");
-        result = (int)G_lat_scan((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lon_scan) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lon_scan(char const *,double *);");
-                SWIG_croak("Type error in argument 2 of G_lon_scan. Expected _p_double");
-        result = (int)G_lon_scan((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_llres_scan) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_llres_scan(char const *,double *);");
-                SWIG_croak("Type error in argument 2 of G_llres_scan. Expected _p_double");
-        result = (int)G_llres_scan((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_location_path) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_location_path();");
-        result = (char *)G_location_path();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_location) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_location();");
-        result = (char *)G_location();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__location_path) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__location_path();");
-        result = (char *)G__location_path();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__ls) {
-        char **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__ls(char const *,int *);");
-                SWIG_croak("Type error in argument 2 of G__ls. Expected _p_int");
-        result = (char **)G__ls((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ls) {
-        FILE *arg2 = (FILE *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ls(char const *,FILE *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_ls. Expected _p_FILE");
-        G_ls((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ls_format) {
-        int arg2 ;
-        int arg3 ;
-        FILE *arg4 = (FILE *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ls_format(char const **,int,int,FILE *);");
-                SWIG_croak("Type error in argument 1 of G_ls_format. Expected _p_p_char");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_ls_format. Expected _p_FILE");
-        G_ls_format((char const **)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ludcmp) {
-        double **arg1 = (double **) 0 ;
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ludcmp(double **,int,int *,double *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_ludcmp. Expected _p_p_double");
-                SWIG_croak("Type error in argument 3 of G_ludcmp. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_ludcmp. Expected _p_double");
-        result = (int)G_ludcmp(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lubksb) {
-        int arg2 ;
-        double *arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lubksb(double **,int,int *,double []);");
-                SWIG_croak("Type error in argument 1 of G_lubksb. Expected _p_p_double");
-                SWIG_croak("Type error in argument 3 of G_lubksb. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_lubksb. Expected _p_double");
-        G_lubksb(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_lzw_decode) {
-        unsigned char *arg1 = (unsigned char *) 0 ;
-        unsigned int arg2 ;
-        unsigned char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: lzw_decode(unsigned char *,unsigned int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 1 of lzw_decode. Expected _p_unsigned_char");
-        arg2 = (unsigned int) SvUV(ST(1));
-        result = (unsigned char *)lzw_decode(arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_unsigned_char, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_lzw_expand) {
-        int (*arg1)() = (int (*)()) 0 ;
-        int (*arg2)() = (int (*)()) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: lzw_expand(int (*)(),int (*)());");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_f___int,0) < 0) {
-                SWIG_croak("Type error in argument 1 of lzw_expand. Expected _p_f___int");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_f___int,0) < 0) {
-                SWIG_croak("Type error in argument 2 of lzw_expand. Expected _p_f___int");
-        result = (int)lzw_expand(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_nof_read_bytes) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_nof_read_bytes();");
-        result = (int)G_lzw_nof_read_bytes();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_max_used_bits) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_max_used_bits();");
-        result = (int)G_lzw_max_used_bits();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_set_bits) {
-        int arg1 ;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 1) || (items > 1)) {
-            SWIG_croak("Usage: G_lzw_set_bits(int);");
-        G_lzw_set_bits(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_compress) {
-        unsigned char *arg2 = (unsigned char *) 0 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_compress(unsigned char *,unsigned char *,int);");
-                SWIG_croak("Type error in argument 1 of G_lzw_compress. Expected _p_unsigned_char");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_unsigned_char,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_lzw_compress. Expected _p_unsigned_char");
-        result = (int)G_lzw_compress(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_expand) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_expand(unsigned char *,unsigned char *,int);");
-                SWIG_croak("Type error in argument 1 of G_lzw_expand. Expected _p_unsigned_char");
-                SWIG_croak("Type error in argument 2 of G_lzw_expand. Expected _p_unsigned_char");
-        result = (int)G_lzw_expand(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_compress_count_only_array) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_compress_count_only_array(unsigned char *,int);");
-                SWIG_croak("Type error in argument 1 of G_lzw_compress_count_only_array. Expected _p_unsigned_char");
-        arg2 = (int) SvIV(ST(1));
-        result = (int)G_lzw_compress_count_only_array(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_compress_count_only_file) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_compress_count_only_file(int);");
-        result = (int)G_lzw_compress_count_only_file(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_write) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_write(int,unsigned char *,int);");
-                SWIG_croak("Type error in argument 2 of G_lzw_write. Expected _p_unsigned_char");
-        result = (int)G_lzw_write(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_write_noCompress) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_write_noCompress(int,unsigned char *,int);");
-                SWIG_croak("Type error in argument 2 of G_lzw_write_noCompress. Expected _p_unsigned_char");
-        result = (int)G_lzw_write_noCompress(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_test_status) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_test_status(int);");
-        result = (int)G_lzw_test_status(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_read2) {
-        int arg1 ;
-        int arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_read2(int,unsigned char *,int,int);");
-                SWIG_croak("Type error in argument 2 of G_lzw_read2. Expected _p_unsigned_char");
-        result = (int)G_lzw_read2(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_read) {
-        int arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_read(int,unsigned char *,int);");
-                SWIG_croak("Type error in argument 2 of G_lzw_read. Expected _p_unsigned_char");
-        result = (int)G_lzw_read(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_transfer_compress) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_transfer_compress(int,int,int);");
-        result = (int)G_lzw_transfer_compress(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lzw_transfer_expand) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lzw_transfer_expand(int,int,int);");
-        result = (int)G_lzw_transfer_expand(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__machine_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__machine_name();");
-        result = (char *)G__machine_name();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_ask_colors) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_ask_colors(char const *,char const *,struct Colors *);");
-                SWIG_croak("Type error in argument 3 of G_ask_colors. Expected _p_Colors");
-        result = (int)G_ask_colors((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__make_location) {
-        struct Cell_head *arg2 = (struct Cell_head *) 0 ;
-        struct Key_Value *arg4 = (struct Key_Value *) 0 ;
-        FILE *arg5 = (FILE *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__make_location(char const *,struct Cell_head *,struct Key_Value *,struct Key_Value *,FILE *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G__make_location. Expected _p_Cell_head");
-                SWIG_croak("Type error in argument 3 of G__make_location. Expected _p_Key_Value");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_Key_Value,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G__make_location. Expected _p_Key_Value");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G__make_location. Expected _p_FILE");
-        result = (int)G__make_location((char const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_location) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_location(char const *,struct Cell_head *,struct Key_Value *,struct Key_Value *,FILE *);");
-                SWIG_croak("Type error in argument 2 of G_make_location. Expected _p_Cell_head");
-                SWIG_croak("Type error in argument 3 of G_make_location. Expected _p_Key_Value");
-                SWIG_croak("Type error in argument 4 of G_make_location. Expected _p_Key_Value");
-                SWIG_croak("Type error in argument 5 of G_make_location. Expected _p_FILE");
-        result = (int)G_make_location((char const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_compare_projections) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 4) || (items > 4)) {
-            SWIG_croak("Usage: G_compare_projections(struct Key_Value const *,struct Key_Value const *,struct Key_Value const *,struct Key_Value const *);");
-                SWIG_croak("Type error in argument 1 of G_compare_projections. Expected _p_Key_Value");
-                SWIG_croak("Type error in argument 2 of G_compare_projections. Expected _p_Key_Value");
-                SWIG_croak("Type error in argument 3 of G_compare_projections. Expected _p_Key_Value");
-                SWIG_croak("Type error in argument 4 of G_compare_projections. Expected _p_Key_Value");
-        result = (int)G_compare_projections((struct Key_Value const *)arg1,(struct Key_Value const *)arg2,(struct Key_Value const *)arg3,(struct Key_Value const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__make_mapset) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__make_mapset(gisdbase_name,location_name,mapset_name);");
-        result = (int)G__make_mapset((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_make_mapset) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_make_mapset(gisdbase_name,location_name,mapset_name);");
-        result = (int)G_make_mapset((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_tolcase) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_tolcase(char *);");
-        result = (char *)G_tolcase(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_toucase) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_toucase(char *);");
-        result = (char *)G_toucase(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mapset) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mapset();");
-        result = (char *)G_mapset();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__mapset) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__mapset();");
-        result = (char *)G__mapset();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__make_mapset_element) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__make_mapset_element(char const *);");
-        result = (int)G__make_mapset_element((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__make_mapset_element_misc) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 2) || (items > 2)) {
-            SWIG_croak("Usage: G__make_mapset_element_misc(char const *,char const *);");
-        result = (int)G__make_mapset_element_misc((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__mapset_permissions) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__mapset_permissions(char const *);");
-        result = (int)G__mapset_permissions((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__mapset_permissions2) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__mapset_permissions2(char const *,char const *,char const *);");
-        result = (int)G__mapset_permissions2((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__mapset_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__mapset_name(int);");
-        result = (char *)G__mapset_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__create_alt_search_path) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__create_alt_search_path();");
-        result = (int)G__create_alt_search_path();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__switch_search_path) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__switch_search_path();");
-        result = (int)G__switch_search_path();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_reset_mapsets) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_reset_mapsets();");
-        result = (int)G_reset_mapsets();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_available_mapsets) {
-        char **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_available_mapsets();");
-        result = (char **)G_available_mapsets();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_add_mapset_to_search_path) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_add_mapset_to_search_path(mapset);");
-        G_add_mapset_to_search_path((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mask_info) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mask_info();");
-        result = (char *)G_mask_info();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__mask_info) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__mask_info(char *,char *);");
-        result = (int)G__mask_info(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_maskfd) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_maskfd();");
-        result = (int)G_maskfd();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_myname) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_myname();");
-        result = (char *)G_myname();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_color_values) {
-        char *arg1 = (char *) 0 ;
-        float *arg2 = (float *) 0 ;
-        float *arg3 = (float *) 0 ;
-        float *arg4 = (float *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_color_values(char const *,float *,float *,float *);");
-        if (!SvOK((SV*) ST(0))) arg1 = 0;
-        else arg1 = (char *) SvPV(ST(0), PL_na);
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_float,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_color_values. Expected _p_float");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_float,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_color_values. Expected _p_float");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_float,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_color_values. Expected _p_float");
-        result = (int)G_color_values((char const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_color_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_color_name(int);");
-        result = (char *)G_color_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_newlines_to_spaces) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_newlines_to_spaces(char *);");
-        G_newlines_to_spaces(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__name_in_mapset) {
-        char *arg2 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 3) || (items > 3)) {
-            SWIG_croak("Usage: G__name_in_mapset(char const *,char *,char *);");
-        if (!SvOK((SV*) ST(1))) arg2 = 0;
-        else arg2 = (char *) SvPV(ST(1), PL_na);
-        result = (int)G__name_in_mapset((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__name_is_fully_qualified) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__name_is_fully_qualified(char const *,char *,char *);");
-        result = (int)G__name_is_fully_qualified((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fully_qualified_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fully_qualified_name(char const *,char const *);");
-        result = (char *)G_fully_qualified_name((char const *)arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__init_null_patterns) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__init_null_patterns();");
-        G__init_null_patterns();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__set_null_value) {
-        void *arg1 = (void *) 0 ;
-        int arg2 ;
-        int arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__set_null_value(void *,int,int,RASTER_MAP_TYPE);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, 0,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__set_null_value. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G__set_null_value. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        G__set_null_value(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_null_value) {
-        int arg2 ;
-        RASTER_MAP_TYPE arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_null_value(void *,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_set_null_value. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_set_null_value. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        G_set_null_value(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_c_null_value) {
-        CELL *arg1 = (CELL *) 0 ;
-        int arg2 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_c_null_value(CELL *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_set_c_null_value. Expected _p_CELL");
-        G_set_c_null_value(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_f_null_value) {
-        FCELL *arg1 = (FCELL *) 0 ;
-        int arg2 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_f_null_value(FCELL *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_set_f_null_value. Expected _p_FCELL");
-        G_set_f_null_value(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_d_null_value) {
-        DCELL *arg1 = (DCELL *) 0 ;
-        int arg2 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_d_null_value(DCELL *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_set_d_null_value. Expected _p_DCELL");
-        G_set_d_null_value(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_null_value) {
-        RASTER_MAP_TYPE arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_null_value(void const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_is_null_value. Expected _p_void");
-            RASTER_MAP_TYPE * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_is_null_value. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = (int)G_is_null_value((void const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_c_null_value) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_c_null_value(CELL const *);");
-                SWIG_croak("Type error in argument 1 of G_is_c_null_value. Expected _p_CELL");
-        result = (int)G_is_c_null_value((CELL const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_f_null_value) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_f_null_value(FCELL const *);");
-                SWIG_croak("Type error in argument 1 of G_is_f_null_value. Expected _p_FCELL");
-        result = (int)G_is_f_null_value((FCELL const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_d_null_value) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_d_null_value(DCELL const *);");
-                SWIG_croak("Type error in argument 1 of G_is_d_null_value. Expected _p_DCELL");
-        result = (int)G_is_d_null_value((DCELL const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_insert_null_values) {
-        int arg3 ;
-        RASTER_MAP_TYPE arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_insert_null_values(void *,char *,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_insert_null_values. Expected _p_void");
-        arg3 = (int) SvIV(ST(2));
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_insert_null_values. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_insert_null_values(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_insert_c_null_values) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_insert_c_null_values(CELL *,char *,int);");
-                SWIG_croak("Type error in argument 1 of G_insert_c_null_values. Expected _p_CELL");
-        result = (int)G_insert_c_null_values(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_insert_f_null_values) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_insert_f_null_values(FCELL *,char *,int);");
-                SWIG_croak("Type error in argument 1 of G_insert_f_null_values. Expected _p_FCELL");
-        result = (int)G_insert_f_null_values(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_insert_d_null_values) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_insert_d_null_values(DCELL *,char *,int);");
-                SWIG_croak("Type error in argument 1 of G_insert_d_null_values. Expected _p_DCELL");
-        result = (int)G_insert_d_null_values(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__check_null_bit) {
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__check_null_bit(unsigned char const *,int,int);");
-                SWIG_croak("Type error in argument 1 of G__check_null_bit. Expected _p_unsigned_char");
-        result = (int)G__check_null_bit((unsigned char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__set_flags_from_01_random) {
-        int arg3 ;
-        int arg4 ;
-        int arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__set_flags_from_01_random(char const *,unsigned char *,int,int,int);");
-                SWIG_croak("Type error in argument 2 of G__set_flags_from_01_random. Expected _p_unsigned_char");
-        arg4 = (int) SvIV(ST(3));
-        arg5 = (int) SvIV(ST(4));
-        result = (int)G__set_flags_from_01_random((char const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__convert_01_flags) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__convert_01_flags(char const *,unsigned char *,int);");
-                SWIG_croak("Type error in argument 2 of G__convert_01_flags. Expected _p_unsigned_char");
-        result = (int)G__convert_01_flags((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__convert_flags_01) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__convert_flags_01(char *,unsigned char const *,int);");
-                SWIG_croak("Type error in argument 2 of G__convert_flags_01. Expected _p_unsigned_char");
-        result = (int)G__convert_flags_01(arg1,(unsigned char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__init_null_bits) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__init_null_bits(unsigned char *,int);");
-                SWIG_croak("Type error in argument 1 of G__init_null_bits. Expected _p_unsigned_char");
-        result = (int)G__init_null_bits(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_new) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_new(char const *,char const *);");
-        result = (int)G_open_new((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_old) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_old(char const *,char const *,char const *);");
-        result = (int)G_open_old((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_update) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_update(char const *,char const *);");
-        result = (int)G_open_update((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_new) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_new(char const *,char const *);");
-        result = (FILE *)G_fopen_new((char const *)arg1,(char const *)arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_FILE, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_old) {
-        char *arg3 = (char *) 0 ;
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_old(char const *,char const *,char const *);");
-        if (!SvOK((SV*) ST(2))) arg3 = 0;
-        else arg3 = (char *) SvPV(ST(2), PL_na);
-        result = (FILE *)G_fopen_old((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_append) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_append(char const *,char const *);");
-        result = (FILE *)G_fopen_append((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_modify) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_modify(char const *,char const *);");
-        result = (FILE *)G_fopen_modify((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_new_misc) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_new_misc(char const *,char const *,char const *);");
-        result = (int)G_open_new_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_old_misc) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_old_misc(char const *,char const *,char const *,char const *);");
-        result = (int)G_open_old_misc((char const *)arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_update_misc) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_update_misc(char const *,char const *,char const *);");
-        result = (int)G_open_update_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_new_misc) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_new_misc(char const *,char const *,char const *);");
-        result = (FILE *)G_fopen_new_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_old_misc) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_old_misc(char const *,char const *,char const *,char const *);");
-        result = (FILE *)G_fopen_old_misc((char const *)arg1,(char const *)arg2,(char const *)arg3,(char const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_append_misc) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_append_misc(char const *,char const *,char const *);");
-        result = (FILE *)G_fopen_append_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_fopen_modify_misc) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_fopen_modify_misc(char const *,char const *,char const *);");
-        result = (FILE *)G_fopen_modify_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_cell_old) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_cell_old(char const *,char const *);");
-        result = (int)G_open_cell_old((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__open_cell_old) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__open_cell_old(char const *,char const *);");
-        result = (int)G__open_cell_old((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_cell_new) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_cell_new(char const *);");
-        result = (int)G_open_cell_new((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_cell_new_random) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_cell_new_random(char const *);");
-        result = (int)G_open_cell_new_random((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_cell_new_uncompressed) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_cell_new_uncompressed(char const *);");
-        result = (int)G_open_cell_new_uncompressed((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_want_histogram) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_want_histogram(int);");
-        result = (int)G_want_histogram(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_cell_format) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_cell_format(int);");
-        result = (int)G_set_cell_format(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_cellvalue_format) {
-        CELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_cellvalue_format(CELL);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 1 of G_cellvalue_format. Expected _p_CELL");
-            arg1 = *argp;
-        result = (int)G_cellvalue_format(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_fp_cell_new) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_fp_cell_new(char const *);");
-        result = (int)G_open_fp_cell_new((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_fp_cell_new_uncompressed) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_fp_cell_new_uncompressed(char const *);");
-        result = (int)G_open_fp_cell_new_uncompressed((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__reallocate_work_buf) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__reallocate_work_buf(int);");
-        result = (int)G__reallocate_work_buf(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__reallocate_null_buf) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__reallocate_null_buf();");
-        result = (int)G__reallocate_null_buf();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__reallocate_mask_buf) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__reallocate_mask_buf();");
-        result = (int)G__reallocate_mask_buf();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__reallocate_temp_buf) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__reallocate_temp_buf();");
-        result = (int)G__reallocate_temp_buf();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_fp_type) {
-        RASTER_MAP_TYPE arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_fp_type(RASTER_MAP_TYPE);");
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_set_fp_type. Expected _p_RASTER_MAP_TYPE");
-            arg1 = *argp;
-        result = (int)G_set_fp_type(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_map_is_fp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_map_is_fp(char const *,char const *);");
-        result = (int)G_raster_map_is_fp((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_map_type) {
-        RASTER_MAP_TYPE result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_map_type(char const *,char const *);");
-        result = G_raster_map_type((char const *)arg1,(char const *)arg2);
-            RASTER_MAP_TYPE * resultobj = (RASTER_MAP_TYPE *) malloc(sizeof(RASTER_MAP_TYPE));
-            memmove(resultobj, &result, sizeof(RASTER_MAP_TYPE));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_RASTER_MAP_TYPE, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_map_type2) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_map_type2(char const *,char const *);");
-        result = G_raster_map_type2((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__check_fp_type) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__check_fp_type(char const *,char const *);");
-        result = G__check_fp_type((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_map_type) {
-        int arg1 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_map_type(int);");
-        arg1 = (int) SvIV(ST(0));
-        result = G_get_raster_map_type(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_raster_new) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_raster_new(char const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 2 of G_open_raster_new. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = (int)G_open_raster_new((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_open_raster_new_uncompressed) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_open_raster_new_uncompressed(char const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 2 of G_open_raster_new_uncompressed. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = (int)G_open_raster_new_uncompressed((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_quant_rules) {
-        int arg1 ;
-        struct Quant *arg2 = (struct Quant *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_quant_rules(int,struct Quant *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Quant,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_set_quant_rules. Expected _p_Quant");
-        result = (int)G_set_quant_rules(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_disable_interactive) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_disable_interactive();");
-        result = (int)G_disable_interactive();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_define_module) {
-        struct GModule *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_define_module();");
-        result = (struct GModule *)G_define_module();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_GModule, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_define_flag) {
-        struct Flag *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_define_flag();");
-        result = (struct Flag *)G_define_flag();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_Flag, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_define_option) {
-        struct Option *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_define_option();");
-        result = (struct Option *)G_define_option();
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_Option, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_define_standard_option) {
-        int arg1 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_define_standard_option(int);");
-        result = (struct Option *)G_define_standard_option(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_parser) {
-        int arg1 ;
-        char **arg2 = (char **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_parser(int,char **);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_p_char,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_parser. Expected _p_p_char");
-        result = (int)G_parser(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_usage) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_usage();");
-        result = (int)G_usage();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_recreate_command) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_recreate_command();");
-        result = (char *)G_recreate_command();
-        if (result) {
-            sv_setpv((SV*)ST(argvi++), (char *) result);
-        } else {
-            sv_setsv((SV*)ST(argvi++), &PL_sv_undef);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_mkdir) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_mkdir(char const *);");
-        result = (int)G_mkdir((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_dirsep) {
-        char arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_dirsep(char);");
-        arg1 = (char) *SvPV(ST(0),PL_na);
-        result = (int)G_is_dirsep(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_absolute_path) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_absolute_path(char const *);");
-        result = (int)G_is_absolute_path((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_convert_dirseps_to_host) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_convert_dirseps_to_host(char *);");
-        result = (char *)G_convert_dirseps_to_host(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_convert_dirseps_from_host) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_convert_dirseps_from_host(char *);");
-        result = (char *)G_convert_dirseps_from_host(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_lstat) {
-        struct stat *arg2 = (struct stat *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_lstat(char const *,struct stat *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_stat,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_lstat. Expected _p_stat");
-        result = (int)G_lstat((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_stat) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_stat(char const *,struct stat *);");
-                SWIG_croak("Type error in argument 2 of G_stat. Expected _p_stat");
-        result = (int)G_stat((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_percent) {
-        long arg1 ;
-        long arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_percent(long,long,int);");
-        arg1 = (long) SvIV(ST(0));
-        arg2 = (long) SvIV(ST(1));
-        result = (int)G_percent(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_percent2) {
-        long arg1 ;
-        long arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_percent2(long,long,int,FILE *);");
-                SWIG_croak("Type error in argument 4 of G_percent2. Expected _p_FILE");
-        result = (int)G_percent2(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_percent_reset) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_percent_reset();");
-        result = (int)G_percent_reset();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_setup_plot) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        int (*arg5)(int,int) = (int (*)(int,int)) 0 ;
-        int (*arg6)(int,int) = (int (*)(int,int)) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_setup_plot(double,double,double,double,int (*)(int,int),int (*)(int,int));");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_f_int_int__int,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_setup_plot. Expected _p_f_int_int__int");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_f_int_int__int,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_setup_plot. Expected _p_f_int_int__int");
-        result = (int)G_setup_plot(arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_setup_fill) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_setup_fill(int);");
-        result = (int)G_setup_fill(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_where_xy) {
-        double arg1 ;
-        double arg2 ;
-        int *arg4 = (int *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_where_xy(double,double,int *,int *);");
-                SWIG_croak("Type error in argument 3 of G_plot_where_xy. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_plot_where_xy. Expected _p_int");
-        result = (int)G_plot_where_xy(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_where_en) {
-        int arg1 ;
-        int arg2 ;
-        double *arg3 = (double *) 0 ;
-        double *arg4 = (double *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_where_en(int,int,double *,double *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_plot_where_en. Expected _p_double");
-                SWIG_croak("Type error in argument 4 of G_plot_where_en. Expected _p_double");
-        result = (int)G_plot_where_en(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_point) {
-        double arg1 ;
-        double arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_point(double,double);");
-        arg1 = (double) SvNV(ST(0));
-        result = (int)G_plot_point(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_line) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_line(double,double,double,double);");
-        result = (int)G_plot_line(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_line2) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_line2(double,double,double,double);");
-        arg2 = (double) SvNV(ST(1));
-        result = (int)G_plot_line2(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_polygon) {
-        double *arg1 = (double *) 0 ;
-        double *arg2 = (double *) 0 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_polygon(double const *,double const *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_plot_polygon. Expected _p_double");
-                SWIG_croak("Type error in argument 2 of G_plot_polygon. Expected _p_double");
-        result = (int)G_plot_polygon((double const *)arg1,(double const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_area) {
-        double **arg2 = (double **) 0 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_area(double *const *,double *const *,int *,int);");
-                SWIG_croak("Type error in argument 1 of G_plot_area. Expected _p_p_double");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_plot_area. Expected _p_p_double");
-                SWIG_croak("Type error in argument 3 of G_plot_area. Expected _p_int");
-        result = (int)G_plot_area((double *const *)arg1,(double *const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_fx) {
-        double (*arg1)(double) = (double (*)(double)) 0 ;
-        double arg2 ;
-        double arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_plot_fx(double (*)(double),double,double);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_f_double__double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_plot_fx. Expected _p_f_double__double");
-        result = (int)G_plot_fx(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_plot_icon) {
-        double arg1 ;
-        double arg2 ;
-        int arg3 ;
-        double arg4 ;
-        double arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 5) || (items > 5)) {
-            SWIG_croak("Usage: G_plot_icon(double,double,int,double,double);");
-        result = (int)G_plot_icon(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_pole_in_polygon) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_pole_in_polygon(double const *,double const *,int);");
-                SWIG_croak("Type error in argument 1 of G_pole_in_polygon. Expected _p_double");
-                SWIG_croak("Type error in argument 2 of G_pole_in_polygon. Expected _p_double");
-        result = (int)G_pole_in_polygon((double const *)arg1,(double const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_popen) {
-        FILE *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_popen(char const *,char const *);");
-        result = (FILE *)G_popen((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_pclose) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_pclose(FILE *);");
-                SWIG_croak("Type error in argument 1 of G_pclose. Expected _p_FILE");
-        result = (int)G_pclose(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_program_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_program_name();");
-        result = (char *)G_program_name();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_program_name) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_program_name(char const *);");
-        result = (int)G_set_program_name((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_projection) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_projection();");
-        result = (int)G_projection();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__projection_units) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__projection_units(int);");
-        result = (int)G__projection_units(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__unit_name) {
-        int arg1 ;
-        int arg2 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__unit_name(int,int);");
-        result = (char *)G__unit_name(arg1,arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__projection_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__projection_name(int);");
-        result = (char *)G__projection_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_database_unit_name) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_database_unit_name(int);");
-        result = (char *)G_database_unit_name(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_database_projection_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 0) || (items > 0)) {
-            SWIG_croak("Usage: G_database_projection_name();");
-        result = (char *)G_database_projection_name();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_database_units_to_meters_factor) {
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_database_units_to_meters_factor();");
-        result = (double)G_database_units_to_meters_factor();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_database_datum_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_database_datum_name();");
-        result = (char *)G_database_datum_name();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_database_ellipse_name) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_database_ellipse_name();");
-        result = (char *)G_database_ellipse_name();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_cellhd) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_cellhd(char const *,struct Cell_head *);");
-                SWIG_croak("Type error in argument 2 of G_put_cellhd. Expected _p_Cell_head");
-        result = (int)G_put_cellhd((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zeros_r_nulls) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zeros_r_nulls(int);");
-        result = (int)G_zeros_r_nulls(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_map_row) {
-        int arg1 ;
-        CELL *arg2 = (CELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_map_row(int,CELL const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_put_map_row. Expected _p_CELL");
-        result = (int)G_put_map_row(arg1,(CELL const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_map_row_random) {
-        int arg1 ;
-        int arg3 ;
-        int arg4 ;
-        int arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_map_row_random(int,CELL const *,int,int,int);");
-                SWIG_croak("Type error in argument 2 of G_put_map_row_random. Expected _p_CELL");
-        result = (int)G_put_map_row_random(arg1,(CELL const *)arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__put_null_value_row) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__put_null_value_row(int,char const *);");
-        result = (int)G__put_null_value_row(arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_raster_row) {
-        int arg1 ;
-        void *arg2 = (void *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_raster_row(int,void const *,RASTER_MAP_TYPE);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, 0,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_put_raster_row. Expected _p_void");
-                SWIG_croak("Type error in argument 3 of G_put_raster_row. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (int)G_put_raster_row(arg1,(void const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_c_raster_row) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_c_raster_row(int,CELL const *);");
-                SWIG_croak("Type error in argument 2 of G_put_c_raster_row. Expected _p_CELL");
-        result = (int)G_put_c_raster_row(arg1,(CELL const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_f_raster_row) {
-        int arg1 ;
-        FCELL *arg2 = (FCELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_f_raster_row(int,FCELL const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_put_f_raster_row. Expected _p_FCELL");
-        result = (int)G_put_f_raster_row(arg1,(FCELL const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_d_raster_row) {
-        int arg1 ;
-        DCELL *arg2 = (DCELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_d_raster_row(int,DCELL const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_put_d_raster_row. Expected _p_DCELL");
-        result = (int)G_put_d_raster_row(arg1,(DCELL const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_data) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_data(int,int,int);");
-        result = (int)G__write_data(arg1,arg2,arg3);
-        ST(argvi) = sv_newmortal();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_data_compressed) {
-        int arg1 ;
-        int arg2 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_data_compressed(int,int,int);");
-        result = (int)G__write_data_compressed(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__open_null_write) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__open_null_write(int);");
-        result = (int)G__open_null_write(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_null_bits) {
-        int arg1 ;
-        int arg3 ;
-        int arg4 ;
-        int arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_null_bits(int,unsigned char const *,int,int,int);");
-                SWIG_croak("Type error in argument 2 of G__write_null_bits. Expected _p_unsigned_char");
-        result = (int)G__write_null_bits(arg1,(unsigned char const *)arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_cell_title) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_cell_title(char const *,char const *);");
-        result = (int)G_put_cell_title((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_window) {
-        struct Cell_head *arg1 = (struct Cell_head *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_window(struct Cell_head const *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_put_window. Expected _p_Cell_head");
-        result = (int)G_put_window((struct Cell_head const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__put_window) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__put_window(struct Cell_head const *,char *,char *);");
-                SWIG_croak("Type error in argument 1 of G__put_window. Expected _p_Cell_head");
-        result = (int)G__put_window((struct Cell_head const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_putenv) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_putenv(char const *,char const *);");
-        G_putenv((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_clear) {
-        struct Quant *arg1 = (struct Quant *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_clear(struct Quant *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Quant,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_quant_clear. Expected _p_Quant");
-        G_quant_clear(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_free) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_free(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G_quant_free. Expected _p_Quant");
-        G_quant_free(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__quant_organize_fp_lookup) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__quant_organize_fp_lookup(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G__quant_organize_fp_lookup. Expected _p_Quant");
-        result = (int)G__quant_organize_fp_lookup(arg1);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_init) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_init(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G_quant_init. Expected _p_Quant");
-        result = (int)G_quant_init(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_is_truncate) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_is_truncate(struct Quant const *);");
-                SWIG_croak("Type error in argument 1 of G_quant_is_truncate. Expected _p_Quant");
-        result = (int)G_quant_is_truncate((struct Quant const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_is_round) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_is_round(struct Quant const *);");
-                SWIG_croak("Type error in argument 1 of G_quant_is_round. Expected _p_Quant");
-        result = (int)G_quant_is_round((struct Quant const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_truncate) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_truncate(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G_quant_truncate. Expected _p_Quant");
-        result = (int)G_quant_truncate(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_round) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_round(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G_quant_round. Expected _p_Quant");
-        result = (int)G_quant_round(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_get_limits) {
-        DCELL *arg3 = (DCELL *) 0 ;
-        CELL *arg4 = (CELL *) 0 ;
-        CELL *arg5 = (CELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_get_limits(struct Quant const *,DCELL *,DCELL *,CELL *,CELL *);");
-                SWIG_croak("Type error in argument 1 of G_quant_get_limits. Expected _p_Quant");
-                SWIG_croak("Type error in argument 2 of G_quant_get_limits. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_quant_get_limits. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_quant_get_limits. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_quant_get_limits. Expected _p_CELL");
-        result = (int)G_quant_get_limits((struct Quant const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_nof_rules) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_nof_rules(struct Quant const *);");
-                SWIG_croak("Type error in argument 1 of G_quant_nof_rules. Expected _p_Quant");
-        result = (int)G_quant_nof_rules((struct Quant const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_get_ith_rule) {
-        int arg2 ;
-        DCELL *arg4 = (DCELL *) 0 ;
-        CELL *arg6 = (CELL *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 6) || (items > 6)) {
-            SWIG_croak("Usage: G_quant_get_ith_rule(struct Quant const *,int,DCELL *,DCELL *,CELL *,CELL *);");
-                SWIG_croak("Type error in argument 1 of G_quant_get_ith_rule. Expected _p_Quant");
-                SWIG_croak("Type error in argument 3 of G_quant_get_ith_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_quant_get_ith_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 5 of G_quant_get_ith_rule. Expected _p_CELL");
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_quant_get_ith_rule. Expected _p_CELL");
-        G_quant_get_ith_rule((struct Quant const *)arg1,arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_set_neg_infinite_rule) {
-        DCELL arg2 ;
-        CELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_set_neg_infinite_rule(struct Quant *,DCELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_quant_set_neg_infinite_rule. Expected _p_Quant");
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_quant_set_neg_infinite_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_quant_set_neg_infinite_rule. Expected _p_CELL");
-            arg3 = *argp;
-        G_quant_set_neg_infinite_rule(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_get_neg_infinite_rule) {
-        CELL *arg3 = (CELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_get_neg_infinite_rule(struct Quant const *,DCELL *,CELL *);");
-                SWIG_croak("Type error in argument 1 of G_quant_get_neg_infinite_rule. Expected _p_Quant");
-                SWIG_croak("Type error in argument 2 of G_quant_get_neg_infinite_rule. Expected _p_DCELL");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_quant_get_neg_infinite_rule. Expected _p_CELL");
-        result = (int)G_quant_get_neg_infinite_rule((struct Quant const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_set_pos_infinite_rule) {
-        DCELL arg2 ;
-        CELL arg3 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_set_pos_infinite_rule(struct Quant *,DCELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_quant_set_pos_infinite_rule. Expected _p_Quant");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_quant_set_pos_infinite_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_quant_set_pos_infinite_rule. Expected _p_CELL");
-            arg3 = *argp;
-        G_quant_set_pos_infinite_rule(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_get_pos_infinite_rule) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_get_pos_infinite_rule(struct Quant const *,DCELL *,CELL *);");
-                SWIG_croak("Type error in argument 1 of G_quant_get_pos_infinite_rule. Expected _p_Quant");
-                SWIG_croak("Type error in argument 2 of G_quant_get_pos_infinite_rule. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_quant_get_pos_infinite_rule. Expected _p_CELL");
-        result = (int)G_quant_get_pos_infinite_rule((struct Quant const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_add_rule) {
-        DCELL arg2 ;
-        DCELL arg3 ;
-        CELL arg4 ;
-        CELL arg5 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_add_rule(struct Quant *,DCELL,DCELL,CELL,CELL);");
-                SWIG_croak("Type error in argument 1 of G_quant_add_rule. Expected _p_Quant");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_quant_add_rule. Expected _p_DCELL");
-            arg2 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_quant_add_rule. Expected _p_DCELL");
-            arg3 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_quant_add_rule. Expected _p_CELL");
-            arg4 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(4),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_quant_add_rule. Expected _p_CELL");
-            arg5 = *argp;
-        G_quant_add_rule(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_reverse_rule_order) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_reverse_rule_order(struct Quant *);");
-                SWIG_croak("Type error in argument 1 of G_quant_reverse_rule_order. Expected _p_Quant");
-        G_quant_reverse_rule_order(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_get_cell_value) {
-        DCELL arg2 ;
-        CELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_get_cell_value(struct Quant *,DCELL);");
-                SWIG_croak("Type error in argument 1 of G_quant_get_cell_value. Expected _p_Quant");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_quant_get_cell_value. Expected _p_DCELL");
-            arg2 = *argp;
-        result = G_quant_get_cell_value(arg1,arg2);
-            CELL * resultobj = (CELL *) malloc(sizeof(CELL));
-            memmove(resultobj, &result, sizeof(CELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_CELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_perform_d) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_perform_d(struct Quant *,DCELL const *,CELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_quant_perform_d. Expected _p_Quant");
-                SWIG_croak("Type error in argument 2 of G_quant_perform_d. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_quant_perform_d. Expected _p_CELL");
-        G_quant_perform_d(arg1,(DCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quant_perform_f) {
-        int arg4 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quant_perform_f(struct Quant *,FCELL const *,CELL *,int);");
-                SWIG_croak("Type error in argument 1 of G_quant_perform_f. Expected _p_Quant");
-                SWIG_croak("Type error in argument 2 of G_quant_perform_f. Expected _p_FCELL");
-                SWIG_croak("Type error in argument 3 of G_quant_perform_f. Expected _p_CELL");
-        G_quant_perform_f(arg1,(FCELL const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__quant_get_rule_for_d_raster_val) {
-        DCELL arg2 ;
-        struct Quant_table *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__quant_get_rule_for_d_raster_val(struct Quant const *,DCELL);");
-                SWIG_croak("Type error in argument 1 of G__quant_get_rule_for_d_raster_val. Expected _p_Quant");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G__quant_get_rule_for_d_raster_val. Expected _p_DCELL");
-            arg2 = *argp;
-        result = (struct Quant_table *)G__quant_get_rule_for_d_raster_val((struct Quant const *)arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_Quant_table, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__quant_import) {
-        struct Quant *arg3 = (struct Quant *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__quant_import(char const *,char const *,struct Quant *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Quant,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G__quant_import. Expected _p_Quant");
-        result = (int)G__quant_import((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__quant_export) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__quant_export(char const *,char const *,struct Quant const *);");
-                SWIG_croak("Type error in argument 3 of G__quant_export. Expected _p_Quant");
-        result = (int)G__quant_export((char const *)arg1,(char const *)arg2,(struct Quant const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_truncate_fp_map) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_truncate_fp_map(char const *,char const *);");
-        result = (int)G_truncate_fp_map((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_round_fp_map) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_round_fp_map(char const *,char const *);");
-        result = (int)G_round_fp_map((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quantize_fp_map) {
-        CELL arg3 ;
-        CELL arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quantize_fp_map(char const *,char const *,CELL,CELL);");
-            CELL * argp;
-                SWIG_croak("Type error in argument 3 of G_quantize_fp_map. Expected _p_CELL");
-            arg3 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 4 of G_quantize_fp_map. Expected _p_CELL");
-            arg4 = *argp;
-        result = (int)G_quantize_fp_map((char const *)arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_quantize_fp_map_range) {
-        DCELL arg3 ;
-        DCELL arg4 ;
-        CELL arg5 ;
-        CELL arg6 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_quantize_fp_map_range(char const *,char const *,DCELL,DCELL,CELL,CELL);");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 3 of G_quantize_fp_map_range. Expected _p_DCELL");
-            arg3 = *argp;
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(3),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_quantize_fp_map_range. Expected _p_DCELL");
-            arg4 = *argp;
-            CELL * argp;
-                SWIG_croak("Type error in argument 5 of G_quantize_fp_map_range. Expected _p_CELL");
-            arg5 = *argp;
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(5),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_quantize_fp_map_range. Expected _p_CELL");
-            arg6 = *argp;
-        result = (int)G_quantize_fp_map_range((char const *)arg1,(char const *)arg2,arg3,arg4,arg5,arg6);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_quant) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_quant(char const *,char const *,struct Quant const *);");
-                SWIG_croak("Type error in argument 3 of G_write_quant. Expected _p_Quant");
-        result = (int)G_write_quant((char const *)arg1,(char const *)arg2,(struct Quant const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_quant) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_quant(char const *,char const *,struct Quant *);");
-                SWIG_croak("Type error in argument 3 of G_read_quant. Expected _p_Quant");
-        result = (int)G_read_quant((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_meridional_radius_of_curvature) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_meridional_radius_of_curvature(double,double,double);");
-        arg3 = (double) SvNV(ST(2));
-        result = (double)G_meridional_radius_of_curvature(arg1,arg2,arg3);
-        sv_setnv(ST(argvi++), (double) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_transverse_radius_of_curvature) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_transverse_radius_of_curvature(double,double,double);");
-        result = (double)G_transverse_radius_of_curvature(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_radius_of_conformal_tangent_sphere) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_radius_of_conformal_tangent_sphere(double,double,double);");
-        result = (double)G_radius_of_conformal_tangent_sphere(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__remove_fp_range) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 1) || (items > 1)) {
-            SWIG_croak("Usage: G__remove_fp_range(char const *);");
-        result = (int)G__remove_fp_range((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_construct_default_range) {
-        struct Range *arg1 = (struct Range *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_construct_default_range(struct Range *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Range,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_construct_default_range. Expected _p_Range");
-        result = (int)G_construct_default_range(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_fp_range) {
-        struct FPRange *arg3 = (struct FPRange *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_fp_range(char const *,char const *,struct FPRange *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_FPRange,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_fp_range. Expected _p_FPRange");
-        result = (int)G_read_fp_range((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_range) {
-        struct Range *arg3 = (struct Range *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_range(char const *,char const *,struct Range *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Range,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_range. Expected _p_Range");
-        result = (int)G_read_range((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_range) {
-        struct Range *arg2 = (struct Range *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 2) || (items > 2)) {
-            SWIG_croak("Usage: G_write_range(char const *,struct Range const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Range,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_write_range. Expected _p_Range");
-        result = (int)G_write_range((char const *)arg1,(struct Range const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_fp_range) {
-        struct FPRange *arg2 = (struct FPRange *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_fp_range(char const *,struct FPRange const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_FPRange,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_write_fp_range. Expected _p_FPRange");
-        result = (int)G_write_fp_range((char const *)arg1,(struct FPRange const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_update_range) {
-        CELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_update_range(CELL,struct Range *);");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_update_range. Expected _p_CELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 2 of G_update_range. Expected _p_Range");
-        result = (int)G_update_range(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_update_fp_range) {
-        DCELL arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_update_fp_range(DCELL,struct FPRange *);");
-            DCELL * argp;
-            if (SWIG_ConvertPtr(ST(0),(void **) &argp, SWIGTYPE_p_DCELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_update_fp_range. Expected _p_DCELL");
-            arg1 = *argp;
-                SWIG_croak("Type error in argument 2 of G_update_fp_range. Expected _p_FPRange");
-        result = (int)G_update_fp_range(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_row_update_range) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_row_update_range(CELL const *,int,struct Range *);");
-                SWIG_croak("Type error in argument 1 of G_row_update_range. Expected _p_CELL");
-        arg2 = (int) SvIV(ST(1));
-                SWIG_croak("Type error in argument 3 of G_row_update_range. Expected _p_Range");
-        result = (int)G_row_update_range((CELL const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__row_update_range) {
-        int arg2 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 4) || (items > 4)) {
-            SWIG_croak("Usage: G__row_update_range(CELL const *,int,struct Range *,int);");
-                SWIG_croak("Type error in argument 1 of G__row_update_range. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G__row_update_range. Expected _p_Range");
-        result = (int)G__row_update_range((CELL const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_row_update_fp_range) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_row_update_fp_range(void const *,int,struct FPRange *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_row_update_fp_range. Expected _p_void");
-                SWIG_croak("Type error in argument 3 of G_row_update_fp_range. Expected _p_FPRange");
-                SWIG_croak("Type error in argument 4 of G_row_update_fp_range. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_row_update_fp_range((void const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_range) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_range(struct Range *);");
-                SWIG_croak("Type error in argument 1 of G_init_range. Expected _p_Range");
-        result = (int)G_init_range(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_range_min_max) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_range_min_max(struct Range const *,CELL *,CELL *);");
-                SWIG_croak("Type error in argument 1 of G_get_range_min_max. Expected _p_Range");
-                SWIG_croak("Type error in argument 2 of G_get_range_min_max. Expected _p_CELL");
-                SWIG_croak("Type error in argument 3 of G_get_range_min_max. Expected _p_CELL");
-        result = (int)G_get_range_min_max((struct Range const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_fp_range) {
-        struct FPRange *arg1 = (struct FPRange *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_fp_range(struct FPRange *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FPRange,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_init_fp_range. Expected _p_FPRange");
-        result = (int)G_init_fp_range(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_fp_range_min_max) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 3) || (items > 3)) {
-            SWIG_croak("Usage: G_get_fp_range_min_max(struct FPRange const *,DCELL *,DCELL *);");
-                SWIG_croak("Type error in argument 1 of G_get_fp_range_min_max. Expected _p_FPRange");
-                SWIG_croak("Type error in argument 2 of G_get_fp_range_min_max. Expected _p_DCELL");
-                SWIG_croak("Type error in argument 3 of G_get_fp_range_min_max. Expected _p_DCELL");
-        result = (int)G_get_fp_range_min_max((struct FPRange const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_incr_void_ptr) {
-        void *arg1 = (void *) 0 ;
-        int arg2 ;
-        void *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_incr_void_ptr(void const *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, 0,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_incr_void_ptr. Expected _p_void");
-        result = (void *)G_incr_void_ptr((void const *)arg1,arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_void, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_cmp) {
-        RASTER_MAP_TYPE arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_cmp(void const *,void const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_raster_cmp. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_raster_cmp. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(2),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_raster_cmp. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (int)G_raster_cmp((void const *)arg1,(void const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_raster_cpy) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_raster_cpy(void *,void const *,int,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_raster_cpy. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_raster_cpy. Expected _p_void");
-                SWIG_croak("Type error in argument 4 of G_raster_cpy. Expected _p_RASTER_MAP_TYPE");
-            arg4 = *argp;
-        result = (int)G_raster_cpy(arg1,(void const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_value_c) {
-        CELL arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_value_c(void *,CELL,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_set_raster_value_c. Expected _p_void");
-            CELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_set_raster_value_c. Expected _p_CELL");
-            arg2 = *argp;
-                SWIG_croak("Type error in argument 3 of G_set_raster_value_c. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (int)G_set_raster_value_c(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_value_f) {
-        FCELL arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_value_f(void *,FCELL,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_set_raster_value_f. Expected _p_void");
-            FCELL * argp;
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_FCELL,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_set_raster_value_f. Expected _p_FCELL");
-            arg2 = *argp;
-            RASTER_MAP_TYPE * argp;
-                SWIG_croak("Type error in argument 3 of G_set_raster_value_f. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (int)G_set_raster_value_f(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_raster_value_d) {
-        DCELL arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_raster_value_d(void *,DCELL,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_set_raster_value_d. Expected _p_void");
-            DCELL * argp;
-                SWIG_croak("Type error in argument 2 of G_set_raster_value_d. Expected _p_DCELL");
-            arg2 = *argp;
-                SWIG_croak("Type error in argument 3 of G_set_raster_value_d. Expected _p_RASTER_MAP_TYPE");
-            arg3 = *argp;
-        result = (int)G_set_raster_value_d(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_value_c) {
-        RASTER_MAP_TYPE arg2 ;
-        CELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_value_c(void const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_raster_value_c. Expected _p_void");
-            if (SWIG_ConvertPtr(ST(1),(void **) &argp, SWIGTYPE_p_RASTER_MAP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_get_raster_value_c. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = G_get_raster_value_c((void const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_value_f) {
-        FCELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_value_f(void const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_raster_value_f. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_get_raster_value_f. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = G_get_raster_value_f((void const *)arg1,arg2);
-            FCELL * resultobj = (FCELL *) malloc(sizeof(FCELL));
-            memmove(resultobj, &result, sizeof(FCELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_FCELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_value_d) {
-        DCELL result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_raster_value_d(void const *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_get_raster_value_d. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_get_raster_value_d. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = G_get_raster_value_d((void const *)arg1,arg2);
-            DCELL * resultobj = (DCELL *) malloc(sizeof(DCELL));
-            memmove(resultobj, &result, sizeof(DCELL));
-            SWIG_MakePtr(ST(argvi++), (void *) resultobj, SWIGTYPE_p_DCELL, 0|SWIG_OWNER);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_raster_units) {
-        char *arg1 = (char *) 0 ;
-        char *arg2 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_raster_units(char const *,char const *,char *);");
-        if (!SvOK((SV*) ST(0))) arg1 = 0;
-        else arg1 = (char *) SvPV(ST(0), PL_na);
-        if (!SvOK((SV*) ST(1))) arg2 = 0;
-        else arg2 = (char *) SvPV(ST(1), PL_na);
-        result = (int)G_read_raster_units((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_raster_vdatum) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_raster_vdatum(char const *,char const *,char *);");
-        result = (int)G_read_raster_vdatum((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_raster_units) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_raster_units(char const *,char const *);");
-        result = (int)G_write_raster_units((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_raster_vdatum) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_raster_vdatum(char const *,char const *);");
-        result = (int)G_write_raster_vdatum((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__raster_misc_read_line) {
-        char *arg4 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__raster_misc_read_line(char const *,char const *,char const *,char *);");
-        if (!SvOK((SV*) ST(3))) arg4 = 0;
-        else arg4 = (char *) SvPV(ST(3), PL_na);
-        result = (int)G__raster_misc_read_line((char const *)arg1,(char const *)arg2,(char const *)arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__raster_misc_write_line) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__raster_misc_write_line(char const *,char const *,char const *);");
-        result = (int)G__raster_misc_write_line((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_Cell_head) {
-        FILE *arg1 = (FILE *) 0 ;
-        struct Cell_head *arg2 = (struct Cell_head *) 0 ;
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_Cell_head(FILE *,struct Cell_head *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_FILE,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__read_Cell_head. Expected _p_FILE");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G__read_Cell_head. Expected _p_Cell_head");
-        arg3 = (int) SvIV(ST(2));
-        result = (char *)G__read_Cell_head(arg1,arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_Cell_head_array) {
-        char **arg1 = (char **) 0 ;
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_Cell_head_array(char **,struct Cell_head *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_char,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G__read_Cell_head_array. Expected _p_p_char");
-                SWIG_croak("Type error in argument 2 of G__read_Cell_head_array. Expected _p_Cell_head");
-        result = (char *)G__read_Cell_head_array(arg1,arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_reclass) {
-        char *arg3 = (char *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_reclass(char const *,char const *,char *,char *);");
-        if (!SvOK((SV*) ST(2))) arg3 = 0;
-        else arg3 = (char *) SvPV(ST(2), PL_na);
-        result = (int)G_is_reclass((char const *)arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_is_reclassed_to) {
-        int *arg3 = (int *) 0 ;
-        char ***arg4 = (char ***) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_is_reclassed_to(char const *,char const *,int *,char ***);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_is_reclassed_to. Expected _p_int");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_p_p_char,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_is_reclassed_to. Expected _p_p_p_char");
-        result = (int)G_is_reclassed_to((char const *)arg1,(char const *)arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_reclass) {
-        struct Reclass *arg3 = (struct Reclass *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_reclass(char const *,char const *,struct Reclass *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Reclass,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_reclass. Expected _p_Reclass");
-        result = (int)G_get_reclass((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_reclass) {
-        struct Reclass *arg1 = (struct Reclass *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_reclass(struct Reclass *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Reclass,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_free_reclass. Expected _p_Reclass");
-        result = (int)G_free_reclass(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_reclass) {
-        struct Reclass *arg2 = (struct Reclass *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_reclass(char const *,struct Reclass const *);");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_Reclass,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_put_reclass. Expected _p_Reclass");
-        result = (int)G_put_reclass((char const *)arg1,(struct Reclass const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove(char const *,char const *);");
-        result = (int)G_remove((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_misc) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_misc(char const *,char const *,char const *);");
-        result = (int)G_remove_misc((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rename) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rename(char const *,char const *,char const *);");
-        result = (int)G_rename((char const *)arg1,(char const *)arg2,(char const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_begin_rhumbline_equation) {
-        double arg1 ;
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_begin_rhumbline_equation(double,double,double,double);");
-        arg4 = (double) SvNV(ST(3));
-        result = (int)G_begin_rhumbline_equation(arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rhumbline_lat_from_lon) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rhumbline_lat_from_lon(double);");
-        result = (double)G_rhumbline_lat_from_lon(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rotate_around_point) {
-        double arg1 ;
-        double arg2 ;
-        double arg5 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rotate_around_point(double,double,double *,double *,double);");
-                SWIG_croak("Type error in argument 3 of G_rotate_around_point. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_rotate_around_point. Expected _p_double");
-        arg5 = (double) SvNV(ST(4));
-        G_rotate_around_point(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_rotate_around_point_int) {
-        int arg1 ;
-        int arg2 ;
-        double arg5 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_rotate_around_point_int(int,int,int *,int *,double);");
-                SWIG_croak("Type error in argument 3 of G_rotate_around_point_int. Expected _p_int");
-                SWIG_croak("Type error in argument 4 of G_rotate_around_point_int. Expected _p_int");
-        G_rotate_around_point_int(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_raster_sample) {
-        int arg1 ;
-        struct Categories *arg3 = (struct Categories *) 0 ;
-        double arg4 ;
-        double arg5 ;
-        int arg6 ;
-        INTERP_TYPE arg7 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 7) || (items > 7)) {
-            SWIG_croak("Usage: G_get_raster_sample(int,struct Cell_head const *,struct Categories *,double,double,int,INTERP_TYPE);");
-                SWIG_croak("Type error in argument 2 of G_get_raster_sample. Expected _p_Cell_head");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Categories,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_get_raster_sample. Expected _p_Categories");
-        arg6 = (int) SvIV(ST(5));
-            INTERP_TYPE * argp;
-            if (SWIG_ConvertPtr(ST(6),(void **) &argp, SWIGTYPE_p_INTERP_TYPE,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_get_raster_sample. Expected _p_INTERP_TYPE");
-            arg7 = *argp;
-        result = (double)G_get_raster_sample(arg1,(struct Cell_head const *)arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_set_window) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_set_window(struct Cell_head *);");
-                SWIG_croak("Type error in argument 1 of G_get_set_window. Expected _p_Cell_head");
-        result = (int)G_get_set_window(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_window) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_window(struct Cell_head *);");
-                SWIG_croak("Type error in argument 1 of G_set_window. Expected _p_Cell_head");
-        result = (int)G_set_window(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_shortest_way) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_shortest_way(double *,double *);");
-                SWIG_croak("Type error in argument 1 of G_shortest_way. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_shortest_way. Expected _p_double");
-        result = (int)G_shortest_way(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sleep) {
-        unsigned int arg1 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sleep(unsigned int);");
-        arg1 = (unsigned int) SvUV(ST(0));
-        G_sleep(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_snprintf) {
-        size_t arg2 ;
-        void *arg4 = 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if (items < 3) {
-            SWIG_croak("Usage: G_snprintf(char *,size_t,char const *,...);");
-        arg2 = (size_t) SvUV(ST(1));
-        result = (int)G_snprintf(arg1,arg2,(char const *)arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_squeeze) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_squeeze(char *);");
-        result = (char *)G_squeeze(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_store) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_store(char const *);");
-        result = (char *)G_store((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strcpy) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strcpy(char *,char const *);");
-        result = (char *)G_strcpy(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_chrcpy) {
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_chrcpy(char *,char const *,int);");
-        result = (char *)G_chrcpy(arg1,(char const *)arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strncpy) {
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strncpy(char *,char const *,int);");
-        result = (char *)G_strncpy(arg1,(char const *)arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strcat) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strcat(char *,char const *);");
-        result = (char *)G_strcat(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_chrcat) {
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_chrcat(char *,char const *,int);");
-        result = (char *)G_chrcat(arg1,(char const *)arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strmov) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strmov(char *,char const *);");
-        result = (char *)G_strmov(arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_chrmov) {
-        int arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_chrmov(char *,char const *,int);");
-        result = (char *)G_chrmov(arg1,(char const *)arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strcasecmp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strcasecmp(char const *,char const *);");
-        result = (int)G_strcasecmp((char const *)arg1,(char const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strstr) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strstr(char const *,char const *);");
-        result = (char *)G_strstr((char const *)arg1,(char const *)arg2);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strdup) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strdup(char const *);");
-        result = (char *)G_strdup((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strchg) {
-        char arg2 ;
-        char arg3 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strchg(char *,char,char);");
-        arg2 = (char) *SvPV(ST(1),PL_na);
-        arg3 = (char) *SvPV(ST(2),PL_na);
-        result = (char *)G_strchg(arg1,arg2,arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_str_replace) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_str_replace(char *,char const *,char const *);");
-        result = (char *)G_str_replace(arg1,(char const *)arg2,(char const *)arg3);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_str_to_upper) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_str_to_upper(char *);");
-        G_str_to_upper(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_str_to_lower) {
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_str_to_lower(char *);");
-        G_str_to_lower(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_str_to_sql) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_str_to_sql(char *);");
-        result = (int)G_str_to_sql(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_strip) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_strip(char *);");
-        result = (int)G_strip(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_svdcmp) {
-        double **arg1 = (double **) 0 ;
-        int arg2 ;
-        int arg3 ;
-        double **arg5 = (double **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_svdcmp(double **,int,int,double *,double **);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_svdcmp. Expected _p_p_double");
-                SWIG_croak("Type error in argument 4 of G_svdcmp. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(4), (void **) &arg5, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 5 of G_svdcmp. Expected _p_p_double");
-        result = (int)G_svdcmp(arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_svbksb) {
-        double *arg2 ;
-        double **arg3 = (double **) 0 ;
-        int arg4 ;
-        int arg5 ;
-        double *arg6 ;
-        double *arg7 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_svbksb(double **,double [],double **,int,int,double [],double []);");
-                SWIG_croak("Type error in argument 1 of G_svbksb. Expected _p_p_double");
-                SWIG_croak("Type error in argument 2 of G_svbksb. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_svbksb. Expected _p_p_double");
-        arg4 = (int) SvIV(ST(3));
-        arg5 = (int) SvIV(ST(4));
-            if (SWIG_ConvertPtr(ST(5), (void **) &arg6, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 6 of G_svbksb. Expected _p_double");
-            if (SWIG_ConvertPtr(ST(6), (void **) &arg7, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 7 of G_svbksb. Expected _p_double");
-        result = (int)G_svbksb(arg1,arg2,arg3,arg4,arg5,arg6,arg7);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_svelim) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_svelim(double *,int);");
-                SWIG_croak("Type error in argument 1 of G_svelim. Expected _p_double");
-        result = (int)G_svelim(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_system) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_system(char const *);");
-        result = (int)G_system((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_tempfile) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_tempfile();");
-        result = (char *)G_tempfile();
-        if (result) {
-            sv_setpv((SV*)ST(argvi++), (char *) result);
-        } else {
-            sv_setsv((SV*)ST(argvi++), &PL_sv_undef);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__tempfile) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__tempfile(int);");
-        arg1 = (int) SvIV(ST(0));
-        result = (char *)G__tempfile(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__temp_element) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__temp_element(char *);");
-        result = (int)G__temp_element(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_init_timestamp) {
-        struct TimeStamp *arg1 = (struct TimeStamp *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_init_timestamp(struct TimeStamp *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_TimeStamp,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_init_timestamp. Expected _p_TimeStamp");
-        G_init_timestamp(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_timestamp) {
-        DateTime *arg2 = (DateTime *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_timestamp(struct TimeStamp *,DateTime const *);");
-                SWIG_croak("Type error in argument 1 of G_set_timestamp. Expected _p_TimeStamp");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_DateTime,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G_set_timestamp. Expected _p_DateTime");
-        G_set_timestamp(arg1,(DateTime const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_timestamp_range) {
-        DateTime *arg3 = (DateTime *) 0 ;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_timestamp_range(struct TimeStamp *,DateTime const *,DateTime const *);");
-                SWIG_croak("Type error in argument 1 of G_set_timestamp_range. Expected _p_TimeStamp");
-                SWIG_croak("Type error in argument 2 of G_set_timestamp_range. Expected _p_DateTime");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_DateTime,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_set_timestamp_range. Expected _p_DateTime");
-        G_set_timestamp_range(arg1,(DateTime const *)arg2,(DateTime const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__read_timestamp) {
-        struct TimeStamp *arg2 = (struct TimeStamp *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__read_timestamp(FILE *,struct TimeStamp *);");
-                SWIG_croak("Type error in argument 1 of G__read_timestamp. Expected _p_FILE");
-            if (SWIG_ConvertPtr(ST(1), (void **) &arg2, SWIGTYPE_p_TimeStamp,0) < 0) {
-                SWIG_croak("Type error in argument 2 of G__read_timestamp. Expected _p_TimeStamp");
-        result = (int)G__read_timestamp(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_timestamp(FILE *,struct TimeStamp const *);");
-                SWIG_croak("Type error in argument 1 of G__write_timestamp. Expected _p_FILE");
-                SWIG_croak("Type error in argument 2 of G__write_timestamp. Expected _p_TimeStamp");
-        result = (int)G__write_timestamp(arg1,(struct TimeStamp const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_timestamps) {
-        int *arg4 = (int *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_timestamps(struct TimeStamp const *,DateTime *,DateTime *,int *);");
-                SWIG_croak("Type error in argument 1 of G_get_timestamps. Expected _p_TimeStamp");
-                SWIG_croak("Type error in argument 2 of G_get_timestamps. Expected _p_DateTime");
-                SWIG_croak("Type error in argument 3 of G_get_timestamps. Expected _p_DateTime");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_int,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_get_timestamps. Expected _p_int");
-        result = (int)G_get_timestamps((struct TimeStamp const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_raster_timestamp) {
-        struct TimeStamp *arg3 = (struct TimeStamp *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_raster_timestamp(char const *,char const *,struct TimeStamp *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_TimeStamp,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_read_raster_timestamp. Expected _p_TimeStamp");
-        result = (int)G_read_raster_timestamp((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_vector_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_vector_timestamp(char const *,char const *,struct TimeStamp *);");
-                SWIG_croak("Type error in argument 3 of G_read_vector_timestamp. Expected _p_TimeStamp");
-        result = (int)G_read_vector_timestamp((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_raster_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_raster_timestamp(char const *,struct TimeStamp const *);");
-                SWIG_croak("Type error in argument 2 of G_write_raster_timestamp. Expected _p_TimeStamp");
-        result = (int)G_write_raster_timestamp((char const *)arg1,(struct TimeStamp const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_vector_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_vector_timestamp(char const *,struct TimeStamp const *);");
-                SWIG_croak("Type error in argument 2 of G_write_vector_timestamp. Expected _p_TimeStamp");
-        result = (int)G_write_vector_timestamp((char const *)arg1,(struct TimeStamp const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_format_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_format_timestamp(struct TimeStamp const *,char *);");
-                SWIG_croak("Type error in argument 1 of G_format_timestamp. Expected _p_TimeStamp");
-        result = (int)G_format_timestamp((struct TimeStamp const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_scan_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_scan_timestamp(struct TimeStamp *,char *);");
-                SWIG_croak("Type error in argument 1 of G_scan_timestamp. Expected _p_TimeStamp");
-        result = (int)G_scan_timestamp(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_raster_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_raster_timestamp(char const *);");
-        result = (int)G_remove_raster_timestamp((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_vector_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_vector_timestamp(char const *);");
-        result = (int)G_remove_vector_timestamp((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_read_grid3_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_read_grid3_timestamp(char const *,char const *,struct TimeStamp *);");
-                SWIG_croak("Type error in argument 3 of G_read_grid3_timestamp. Expected _p_TimeStamp");
-        result = (int)G_read_grid3_timestamp((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_remove_grid3_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_remove_grid3_timestamp(char const *);");
-        result = (int)G_remove_grid3_timestamp((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_grid3_timestamp) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_grid3_timestamp(char const *,struct TimeStamp const *);");
-                SWIG_croak("Type error in argument 2 of G_write_grid3_timestamp. Expected _p_TimeStamp");
-        result = (int)G_write_grid3_timestamp((char const *)arg1,(struct TimeStamp const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_tokenize) {
-        char **result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_tokenize(char const *,char const *);");
-        result = (char **)G_tokenize((char const *)arg1,(char const *)arg2);
-        SWIG_MakePtr(ST(argvi++), (void *) result, SWIGTYPE_p_p_char, 0|0);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_number_of_tokens) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_number_of_tokens(char **);");
-                SWIG_croak("Type error in argument 1 of G_number_of_tokens. Expected _p_p_char");
-        result = (int)G_number_of_tokens(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_free_tokens) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_free_tokens(char **);");
-                SWIG_croak("Type error in argument 1 of G_free_tokens. Expected _p_p_char");
-        result = (int)G_free_tokens(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_trim_decimal) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_trim_decimal(char *);");
-        result = (int)G_trim_decimal(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_unctrl) {
-        int arg1 ;
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_unctrl(int);");
-        result = (char *)G_unctrl(arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_get_fname) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_get_fname(char const *);");
-        result = (char *)G_sock_get_fname((char const *)arg1);
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_exists) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_exists(char const *);");
-        result = (int)G_sock_exists((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_bind) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_bind(char const *);");
-        result = (int)G_sock_bind((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_listen) {
-        int arg1 ;
-        unsigned int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_listen(int,unsigned int);");
-        arg2 = (unsigned int) SvUV(ST(1));
-        result = (int)G_sock_listen(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_accept) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_accept(int);");
-        result = (int)G_sock_accept(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_sock_connect) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_sock_connect(char const *);");
-        result = (int)G_sock_connect((char const *)arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_verbose) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 0) || (items > 0)) {
-            SWIG_croak("Usage: G_verbose();");
-        result = (int)G_verbose();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_verbose_min) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_verbose_min();");
-        result = (int)G_verbose_min();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_verbose_std) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_verbose_std();");
-        result = (int)G_verbose_std();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_verbose_max) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_verbose_max();");
-        result = (int)G_verbose_max();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_set_verbose) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_set_verbose(int);");
-        result = (int)G_set_verbose(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_3dview_warning) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_3dview_warning(int);");
-        result = (int)G_3dview_warning(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_3dview_defaults) {
-        struct G_3dview *arg1 = (struct G_3dview *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_3dview_defaults(struct G_3dview *,struct Cell_head *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_G_3dview,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_get_3dview_defaults. Expected _p_G_3dview");
-                SWIG_croak("Type error in argument 2 of G_get_3dview_defaults. Expected _p_Cell_head");
-        result = (int)G_get_3dview_defaults(arg1,arg2);
-        ST(argvi) = sv_newmortal();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_put_3dview) {
-        struct G_3dview *arg3 = (struct G_3dview *) 0 ;
-        struct Cell_head *arg4 = (struct Cell_head *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_put_3dview(char const *,char const *,struct G_3dview const *,struct Cell_head const *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_G_3dview,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_put_3dview. Expected _p_G_3dview");
-            if (SWIG_ConvertPtr(ST(3), (void **) &arg4, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 4 of G_put_3dview. Expected _p_Cell_head");
-        result = (int)G_put_3dview((char const *)arg1,(char const *)arg2,(struct G_3dview const *)arg3,(struct Cell_head const *)arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_get_3dview) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_get_3dview(char const *,char const *,struct G_3dview *);");
-                SWIG_croak("Type error in argument 3 of G_get_3dview. Expected _p_G_3dview");
-        result = (int)G_get_3dview((char const *)arg1,(char const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_whoami) {
-        char *result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_whoami();");
-        result = (char *)G_whoami();
-        if (result) {
-        } else {
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_adjust_window_to_box) {
-        struct Cell_head *arg1 = (struct Cell_head *) 0 ;
-        int arg3 ;
-        int arg4 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_adjust_window_to_box(struct Cell_head const *,struct Cell_head *,int,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_adjust_window_to_box. Expected _p_Cell_head");
-                SWIG_croak("Type error in argument 2 of G_adjust_window_to_box. Expected _p_Cell_head");
-        result = (int)G_adjust_window_to_box((struct Cell_head const *)arg1,arg2,arg3,arg4);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_format_northing) {
-        double arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_format_northing(double,char *,int);");
-        arg1 = (double) SvNV(ST(0));
-        result = (int)G_format_northing(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_format_easting) {
-        double arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_format_easting(double,char *,int);");
-        result = (int)G_format_easting(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_format_resolution) {
-        double arg1 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_format_resolution(double,char *,int);");
-        result = (int)G_format_resolution(arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_point_in_region) {
-        double arg1 ;
-        double arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_point_in_region(double,double);");
-        arg2 = (double) SvNV(ST(1));
-        result = (int)G_point_in_region(arg1,arg2);
-        sv_setiv(ST(argvi++), (IV) result);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_point_in_window) {
-        double arg1 ;
-        double arg2 ;
-        struct Cell_head *arg3 = (struct Cell_head *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_point_in_window(double,double,struct Cell_head const *);");
-            if (SWIG_ConvertPtr(ST(2), (void **) &arg3, SWIGTYPE_p_Cell_head,0) < 0) {
-                SWIG_croak("Type error in argument 3 of G_point_in_window. Expected _p_Cell_head");
-        result = (int)G_point_in_window(arg1,arg2,(struct Cell_head const *)arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_limit_east) {
-        double *arg1 = (double *) 0 ;
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_limit_east(double *,int);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_double,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_limit_east. Expected _p_double");
-        result = (int)G_limit_east(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_limit_west) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_limit_west(double *,int);");
-                SWIG_croak("Type error in argument 1 of G_limit_west. Expected _p_double");
-        result = (int)G_limit_west(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_limit_north) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_limit_north(double *,int);");
-                SWIG_croak("Type error in argument 1 of G_limit_north. Expected _p_double");
-        result = (int)G_limit_north(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_limit_south) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_limit_south(double *,int);");
-                SWIG_croak("Type error in argument 1 of G_limit_south. Expected _p_double");
-        result = (int)G_limit_south(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_window_overlap) {
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-        if ((items < 5) || (items > 5)) {
-            SWIG_croak("Usage: G_window_overlap(struct Cell_head const *,double,double,double,double);");
-                SWIG_croak("Type error in argument 1 of G_window_overlap. Expected _p_Cell_head");
-        result = (int)G_window_overlap((struct Cell_head const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_window_percentage_overlap) {
-        double arg2 ;
-        double arg3 ;
-        double arg4 ;
-        double arg5 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_window_percentage_overlap(struct Cell_head const *,double,double,double,double);");
-                SWIG_croak("Type error in argument 1 of G_window_percentage_overlap. Expected _p_Cell_head");
-        result = (double)G_window_percentage_overlap((struct Cell_head const *)arg1,arg2,arg3,arg4,arg5);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_scan_northing) {
-        double *arg2 = (double *) 0 ;
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_scan_northing(char const *,double *,int);");
-                SWIG_croak("Type error in argument 2 of G_scan_northing. Expected _p_double");
-        result = (int)G_scan_northing((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_scan_easting) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_scan_easting(char const *,double *,int);");
-                SWIG_croak("Type error in argument 2 of G_scan_easting. Expected _p_double");
-        result = (int)G_scan_easting((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_scan_resolution) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_scan_resolution(char const *,double *,int);");
-                SWIG_croak("Type error in argument 2 of G_scan_resolution. Expected _p_double");
-        result = (int)G_scan_resolution((char const *)arg1,arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__create_window_mapping) {
-        int arg1 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__create_window_mapping(int);");
-        result = (int)G__create_window_mapping(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_northing_to_row) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_northing_to_row(double,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 2 of G_northing_to_row. Expected _p_Cell_head");
-        result = (double)G_northing_to_row(arg1,(struct Cell_head const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_adjust_east_longitude) {
-        double arg1 ;
-        double arg2 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_adjust_east_longitude(double,double);");
-        result = (double)G_adjust_east_longitude(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_adjust_easting) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_adjust_easting(double,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 2 of G_adjust_easting. Expected _p_Cell_head");
-        result = (double)G_adjust_easting(arg1,(struct Cell_head const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_easting_to_col) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_easting_to_col(double,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 2 of G_easting_to_col. Expected _p_Cell_head");
-        result = (double)G_easting_to_col(arg1,(struct Cell_head const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_row_to_northing) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_row_to_northing(double,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 2 of G_row_to_northing. Expected _p_Cell_head");
-        result = (double)G_row_to_northing(arg1,(struct Cell_head const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_col_to_easting) {
-        double arg1 ;
-        double result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_col_to_easting(double,struct Cell_head const *);");
-                SWIG_croak("Type error in argument 2 of G_col_to_easting. Expected _p_Cell_head");
-        result = (double)G_col_to_easting(arg1,(struct Cell_head const *)arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_window_rows) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_window_rows();");
-        result = (int)G_window_rows();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_window_cols) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_window_cols();");
-        result = (int)G_window_cols();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__init_window) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__init_window();");
-        result = (int)G__init_window();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_row_repeat_nomask) {
-        int arg1 ;
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_row_repeat_nomask(int,int);");
-        result = (int)G_row_repeat_nomask(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_Cell_head) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_Cell_head(FILE *,struct Cell_head const *,int);");
-                SWIG_croak("Type error in argument 1 of G__write_Cell_head. Expected _p_FILE");
-                SWIG_croak("Type error in argument 2 of G__write_Cell_head. Expected _p_Cell_head");
-        result = (int)G__write_Cell_head(arg1,(struct Cell_head const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G__write_Cell_head3) {
-        int arg3 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G__write_Cell_head3(FILE *,struct Cell_head const *,int);");
-                SWIG_croak("Type error in argument 1 of G__write_Cell_head3. Expected _p_FILE");
-                SWIG_croak("Type error in argument 2 of G__write_Cell_head3. Expected _p_Cell_head");
-        result = (int)G__write_Cell_head3(arg1,(struct Cell_head const *)arg2,arg3);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_write_zeros) {
-        int arg1 ;
-        size_t arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_write_zeros(int,size_t);");
-        result = (int)G_write_zeros(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_yes) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_yes(char const *,int);");
-        result = (int)G_yes((char const *)arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zero) {
-        int arg2 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zero(void *,int);");
-                SWIG_croak("Type error in argument 1 of G_zero. Expected _p_void");
-        result = (int)G_zero(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zero_cell_buf) {
-        CELL *arg1 = (CELL *) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zero_cell_buf(CELL *);");
-            if (SWIG_ConvertPtr(ST(0), (void **) &arg1, SWIGTYPE_p_CELL,0) < 0) {
-                SWIG_croak("Type error in argument 1 of G_zero_cell_buf. Expected _p_CELL");
-        result = (int)G_zero_cell_buf(arg1);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zero_raster_buf) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zero_raster_buf(void *,RASTER_MAP_TYPE);");
-                SWIG_croak("Type error in argument 1 of G_zero_raster_buf. Expected _p_void");
-                SWIG_croak("Type error in argument 2 of G_zero_raster_buf. Expected _p_RASTER_MAP_TYPE");
-            arg2 = *argp;
-        result = (int)G_zero_raster_buf(arg1,arg2);
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_G_zone) {
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: G_zone();");
-        result = (int)G_zone();
-        XSRETURN(argvi);
-        fail:
-    croak(Nullch);
-XS(_wrap_r_slope_aspect) {
-        int arg1 ;
-        char **arg2 = (char **) 0 ;
-        int result;
-        int argvi = 0;
-        dXSARGS;
-            SWIG_croak("Usage: r_slope_aspect(argc,argv);");
-            AV *tempav;
-            I32 len;
-            int i;
-            SV **tv;
-            if (!SvROK(ST(1)))
-            croak("ST(1) is not a reference.");
-            if (SvTYPE(SvRV(ST(1))) != SVt_PVAV)
-            croak("ST(1) is not an array.");
-            tempav = (AV*)SvRV(ST(1));
-            len = av_len(tempav);
-            arg2 = (char **) malloc((len+2)*sizeof(char *));
-            for (i = 0; i <= len; i++) {
-                tv = av_fetch(tempav, i, 0);
-                arg2[i] = (char *) SvPV_nolen(*tv);
-            arg2[i] = 0;
-        result = (int)r_slope_aspect(arg1,arg2);
-            free(ST(1));
-        XSRETURN(argvi);
-        fail:
-            free(ST(1));
-    croak(Nullch);
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
-static swig_type_info _swigt__p_Cell_head[] = {{"_p_Cell_head", 0, "struct Cell_head *", 0, 0, 0, 0},{"_p_Cell_head", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Categories[] = {{"_p_Categories", 0, "struct Categories *", 0, 0, 0, 0},{"_p_Categories", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_DateTime[] = {{"_p_DateTime", 0, "DateTime *", 0, 0, 0, 0},{"_p_DateTime", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_RASTER_MAP_TYPE[] = {{"_p_RASTER_MAP_TYPE", 0, "RASTER_MAP_TYPE *", 0, 0, 0, 0},{"_p_RASTER_MAP_TYPE", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_p_q_const__char_int__int[] = {{"_p_f_p_q_const__char_int__int", 0, "int (*)(char const *,int)", 0, 0, 0, 0},{"_p_f_p_q_const__char_int__int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_int_int__int[] = {{"_p_f_int_int__int", 0, "int (*)(int,int)", 0, 0, 0, 0},{"_p_f_int_int__int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_char[] = {{"_p_p_char", 0, "char **", 0, 0, 0, 0},{"_p_p_char", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_char[] = {{"_p_char", 0, "char *", 0, 0, 0, 0},{"_p_char", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_p_char[] = {{"_p_p_p_char", 0, "char ***", 0, 0, 0, 0},{"_p_p_p_char", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_FPRange[] = {{"_p_FPRange", 0, "struct FPRange *", 0, 0, 0, 0},{"_p_FPRange", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_FCELL[] = {{"_p_FCELL", 0, "FCELL *", 0, 0, 0, 0},{"_p_FCELL", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_void[] = {{"_p_void", 0, "void *", 0, 0, 0, 0},{"_p_void", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_double[] = {{"_p_p_double", 0, "double **", 0, 0, 0, 0},{"_p_p_double", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_double[] = {{"_p_double", 0, "double *", 0, 0, 0, 0},{"_p_double", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_double__double[] = {{"_p_f_double__double", 0, "double (*)(double)", 0, 0, 0, 0},{"_p_f_double__double", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_stat[] = {{"_p_stat", 0, "struct stat *", 0, 0, 0, 0},{"_p_stat", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_size_t[] = {{"_p_size_t", 0, "size_t *", 0, 0, 0, 0},{"_p_size_t", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Option[] = {{"_p_Option", 0, "struct Option *", 0, 0, 0, 0},{"_p_Option", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Range[] = {{"_p_Range", 0, "struct Range *", 0, 0, 0, 0},{"_p_Range", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_G_3dview[] = {{"_p_G_3dview", 0, "struct G_3dview *", 0, 0, 0, 0},{"_p_G_3dview", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Key_Value[] = {{"_p_Key_Value", 0, "struct Key_Value *", 0, 0, 0, 0},{"_p_Key_Value", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_CELL_CELL_CELL__void[] = {{"_p_f_CELL_CELL_CELL__void", 0, "void (*)(CELL,CELL,CELL)", 0, 0, 0, 0},{"_p_f_CELL_CELL_CELL__void", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Cell_stats[] = {{"_p_Cell_stats", 0, "struct Cell_stats *", 0, 0, 0, 0},{"_p_Cell_stats", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_long[] = {{"_p_long", 0, "long *", 0, 0, 0, 0},{"_p_long", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_CELL[] = {{"_p_CELL", 0, "CELL *", 0, 0, 0, 0},{"_p_CELL", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_DCELL[] = {{"_p_DCELL", 0, "DCELL *", 0, 0, 0, 0},{"_p_DCELL", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p__Color_Rule_[] = {{"_p__Color_Rule_", 0, "struct _Color_Rule_ *", 0, 0, 0, 0},{"_p__Color_Rule_", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_FPReclass[] = {{"_p_FPReclass", 0, "struct FPReclass *", 0, 0, 0, 0},{"_p_FPReclass", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Quant[] = {{"_p_Quant", 0, "struct Quant *", 0, 0, 0, 0},{"_p_Quant", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Flag[] = {{"_p_Flag", 0, "struct Flag *", 0, 0, 0, 0},{"_p_Flag", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Reclass[] = {{"_p_Reclass", 0, "struct Reclass *", 0, 0, 0, 0},{"_p_Reclass", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_unsigned_char[] = {{"_p_p_unsigned_char", 0, "unsigned char **", 0, 0, 0, 0},{"_p_p_unsigned_char", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_unsigned_char[] = {{"_p_unsigned_char", 0, "unsigned char *", 0, 0, 0, 0},{"_p_unsigned_char", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_GModule[] = {{"_p_GModule", 0, "struct GModule *", 0, 0, 0, 0},{"_p_GModule", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_TimeStamp[] = {{"_p_TimeStamp", 0, "struct TimeStamp *", 0, 0, 0, 0},{"_p_TimeStamp", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_p_q_const__char_p_q_const__char_p_q_const__char__int[] = {{"_p_f_p_q_const__char_p_q_const__char_p_q_const__char__int", 0, "int (*)(char const *,char const *,char const *)", 0, 0, 0, 0},{"_p_f_p_q_const__char_p_q_const__char_p_q_const__char__int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_History[] = {{"_p_History", 0, "struct History *", 0, 0, 0, 0},{"_p_History", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Histogram[] = {{"_p_Histogram", 0, "struct Histogram *", 0, 0, 0, 0},{"_p_Histogram", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p__Color_Info_[] = {{"_p__Color_Info_", 0, "struct _Color_Info_ *", 0, 0, 0, 0},{"_p__Color_Info_", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f___int[] = {{"_p_f___int", 0, "int (*)()", 0, 0, 0, 0},{"_p_f___int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Colors[] = {{"_p_Colors", 0, "struct Colors *", 0, 0, 0, 0},{"_p_Colors", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_INTERP_TYPE[] = {{"_p_INTERP_TYPE", 0, "INTERP_TYPE *", 0, 0, 0, 0},{"_p_INTERP_TYPE", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_FILE[] = {{"_p_FILE", 0, "FILE *", 0, 0, 0, 0},{"_p_FILE", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int[] = {{"_p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int", 0, "int (*)(void *,DCELL,DCELL,DCELL *,int *,int *,int *,int *,int *,int *)|read_rule_fn *", 0, 0, 0, 0},{"_p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_Quant_table[] = {{"_p_Quant_table", 0, "struct Quant_table *", 0, 0, 0, 0},{"_p_Quant_table", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_float[] = {{"_p_p_float", 0, "float **", 0, 0, 0, 0},{"_p_p_float", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_float[] = {{"_p_float", 0, "float *", 0, 0, 0, 0},{"_p_float", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_p_int[] = {{"_p_p_int", 0, "int **", 0, 0, 0, 0},{"_p_p_int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info _swigt__p_int[] = {{"_p_int", 0, "int *", 0, 0, 0, 0},{"_p_int", 0, 0, 0, 0, 0, 0},{0, 0, 0, 0, 0, 0, 0}};
-static swig_type_info *swig_types_initial[] = {
-_swigt__p_Cell_head,
-_swigt__p_Categories,
-_swigt__p_DateTime,
-_swigt__p_RASTER_MAP_TYPE,
-_swigt__p_f_p_q_const__char_int__int,
-_swigt__p_f_int_int__int,
-_swigt__p_p_char,
-_swigt__p_char,
-_swigt__p_p_p_char,
-_swigt__p_FPRange,
-_swigt__p_FCELL,
-_swigt__p_void,
-_swigt__p_p_double,
-_swigt__p_double,
-_swigt__p_f_double__double,
-_swigt__p_stat,
-_swigt__p_size_t,
-_swigt__p_Option,
-_swigt__p_Range,
-_swigt__p_G_3dview,
-_swigt__p_Key_Value,
-_swigt__p_f_CELL_CELL_CELL__void,
-_swigt__p_Cell_stats,
-_swigt__p_long,
-_swigt__p_CELL,
-_swigt__p_DCELL,
-_swigt__p__Color_Rule_,
-_swigt__p_FPReclass,
-_swigt__p_Quant,
-_swigt__p_Flag,
-_swigt__p_Reclass,
-_swigt__p_p_unsigned_char,
-_swigt__p_unsigned_char,
-_swigt__p_GModule,
-_swigt__p_TimeStamp,
-_swigt__p_f_p_q_const__char_p_q_const__char_p_q_const__char__int,
-_swigt__p_History,
-_swigt__p_Histogram,
-_swigt__p__Color_Info_,
-_swigt__p_f___int,
-_swigt__p_Colors,
-_swigt__p_INTERP_TYPE,
-_swigt__p_FILE,
-_swigt__p_f_p_void_DCELL_DCELL_p_DCELL_p_int_p_int_p_int_p_int_p_int_p_int__int,
-_swigt__p_Quant_table,
-_swigt__p_p_float,
-_swigt__p_float,
-_swigt__p_p_int,
-_swigt__p_int,
-0
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
-static swig_constant_info swig_constants[] = {
-{0,0,0,0,0,0}
-#ifdef __cplusplus
-#endif
-static swig_variable_info swig_variables[] = {
-{0,0,0,0}
-static swig_command_info swig_commands[] = {
-{"Grassc::G_adjust_Cell_head", _wrap_G_adjust_Cell_head},
-{"Grassc::G_adjust_Cell_head3", _wrap_G_adjust_Cell_head3},
-{"Grassc::G_align_window", _wrap_G_align_window},
-{"Grassc::G_malloc", _wrap_G_malloc},
-{"Grassc::G_calloc", _wrap_G_calloc},
-{"Grassc::G_realloc", _wrap_G_realloc},
-{"Grassc::G_free", _wrap_G_free},
-{"Grassc::G_raster_size", _wrap_G_raster_size},
-{"Grassc::G_allocate_cell_buf", _wrap_G_allocate_cell_buf},
-{"Grassc::G_allocate_raster_buf", _wrap_G_allocate_raster_buf},
-{"Grassc::G_allocate_c_raster_buf", _wrap_G_allocate_c_raster_buf},
-{"Grassc::G_allocate_f_raster_buf", _wrap_G_allocate_f_raster_buf},
-{"Grassc::G_allocate_d_raster_buf", _wrap_G_allocate_d_raster_buf},
-{"Grassc::G_allocate_null_buf", _wrap_G_allocate_null_buf},
-{"Grassc::G__allocate_null_bits", _wrap_G__allocate_null_bits},
-{"Grassc::G__null_bitstream_size", _wrap_G__null_bitstream_size},
-{"Grassc::G_begin_cell_area_calculations", _wrap_G_begin_cell_area_calculations},
-{"Grassc::G_area_of_cell_at_row", _wrap_G_area_of_cell_at_row},
-{"Grassc::G_begin_polygon_area_calculations", _wrap_G_begin_polygon_area_calculations},
-{"Grassc::G_area_of_polygon", _wrap_G_area_of_polygon},
-{"Grassc::G_begin_zone_area_on_ellipsoid", _wrap_G_begin_zone_area_on_ellipsoid},
-{"Grassc::G_darea0_on_ellipsoid", _wrap_G_darea0_on_ellipsoid},
-{"Grassc::G_area_for_zone_on_ellipsoid", _wrap_G_area_for_zone_on_ellipsoid},
-{"Grassc::G_begin_ellipsoid_polygon_area", _wrap_G_begin_ellipsoid_polygon_area},
-{"Grassc::G_ellipsoid_polygon_area", _wrap_G_ellipsoid_polygon_area},
-{"Grassc::G_planimetric_polygon_area", _wrap_G_planimetric_polygon_area},
-{"Grassc::G_begin_zone_area_on_sphere", _wrap_G_begin_zone_area_on_sphere},
-{"Grassc::G_darea0_on_sphere", _wrap_G_darea0_on_sphere},
-{"Grassc::G_area_for_zone_on_sphere", _wrap_G_area_for_zone_on_sphere},
-{"Grassc::G_ascii_check", _wrap_G_ascii_check},
-{"Grassc::G_ask_new", _wrap_G_ask_new},
-{"Grassc::G_ask_new_ext", _wrap_G_ask_new_ext},
-{"Grassc::G_ask_old", _wrap_G_ask_old},
-{"Grassc::G_ask_old_ext", _wrap_G_ask_old_ext},
-{"Grassc::G_ask_any", _wrap_G_ask_any},
-{"Grassc::G_ask_any_ext", _wrap_G_ask_any_ext},
-{"Grassc::G_ask_in_mapset", _wrap_G_ask_in_mapset},
-{"Grassc::G_ask_in_mapset_ext", _wrap_G_ask_in_mapset_ext},
-{"Grassc::G_ask_new_file", _wrap_G_ask_new_file},
-{"Grassc::G_ask_old_file", _wrap_G_ask_old_file},
-{"Grassc::G_set_ask_return_msg", _wrap_G_set_ask_return_msg},
-{"Grassc::G_get_ask_return_msg", _wrap_G_get_ask_return_msg},
-{"Grassc::G_ask_cell_new", _wrap_G_ask_cell_new},
-{"Grassc::G_ask_cell_old", _wrap_G_ask_cell_old},
-{"Grassc::G_ask_cell_in_mapset", _wrap_G_ask_cell_in_mapset},
-{"Grassc::G_ask_cell_any", _wrap_G_ask_cell_any},
-{"Grassc::G_ask_vector_new", _wrap_G_ask_vector_new},
-{"Grassc::G_ask_vector_old", _wrap_G_ask_vector_old},
-{"Grassc::G_ask_vector_any", _wrap_G_ask_vector_any},
-{"Grassc::G_ask_vector_in_mapset", _wrap_G_ask_vector_in_mapset},
-{"Grassc::G__check_for_auto_masking", _wrap_G__check_for_auto_masking},
-{"Grassc::G_suppress_masking", _wrap_G_suppress_masking},
-{"Grassc::G_unsuppress_masking", _wrap_G_unsuppress_masking},
-{"Grassc::G_basename", _wrap_G_basename},
-{"Grassc::G_bresenham_line", _wrap_G_bresenham_line},
-{"Grassc::G_read_cats", _wrap_G_read_cats},
-{"Grassc::G_read_raster_cats", _wrap_G_read_raster_cats},
-{"Grassc::G_read_vector_cats", _wrap_G_read_vector_cats},
-{"Grassc::G_number_of_cats", _wrap_G_number_of_cats},
-{"Grassc::G__read_cats", _wrap_G__read_cats},
-{"Grassc::G_get_cats_title", _wrap_G_get_cats_title},
-{"Grassc::G_get_raster_cats_title", _wrap_G_get_raster_cats_title},
-{"Grassc::G_get_cat", _wrap_G_get_cat},
-{"Grassc::G_get_c_raster_cat", _wrap_G_get_c_raster_cat},
-{"Grassc::G_get_f_raster_cat", _wrap_G_get_f_raster_cat},
-{"Grassc::G_get_d_raster_cat", _wrap_G_get_d_raster_cat},
-{"Grassc::G_get_raster_cat", _wrap_G_get_raster_cat},
-{"Grassc::G_unmark_raster_cats", _wrap_G_unmark_raster_cats},
-{"Grassc::G_mark_c_raster_cats", _wrap_G_mark_c_raster_cats},
-{"Grassc::G_mark_f_raster_cats", _wrap_G_mark_f_raster_cats},
-{"Grassc::G_mark_d_raster_cats", _wrap_G_mark_d_raster_cats},
-{"Grassc::G_mark_raster_cats", _wrap_G_mark_raster_cats},
-{"Grassc::G_rewind_raster_cats", _wrap_G_rewind_raster_cats},
-{"Grassc::G_get_next_marked_d_raster_cat", _wrap_G_get_next_marked_d_raster_cat},
-{"Grassc::G_get_next_marked_c_raster_cat", _wrap_G_get_next_marked_c_raster_cat},
-{"Grassc::G_get_next_marked_f_raster_cat", _wrap_G_get_next_marked_f_raster_cat},
-{"Grassc::G_get_next_marked_raster_cat", _wrap_G_get_next_marked_raster_cat},
-{"Grassc::G_set_cat", _wrap_G_set_cat},
-{"Grassc::G_set_c_raster_cat", _wrap_G_set_c_raster_cat},
-{"Grassc::G_set_f_raster_cat", _wrap_G_set_f_raster_cat},
-{"Grassc::G_set_d_raster_cat", _wrap_G_set_d_raster_cat},
-{"Grassc::G_set_raster_cat", _wrap_G_set_raster_cat},
-{"Grassc::G_write_cats", _wrap_G_write_cats},
-{"Grassc::G_write_raster_cats", _wrap_G_write_raster_cats},
-{"Grassc::G_write_vector_cats", _wrap_G_write_vector_cats},
-{"Grassc::G__write_cats", _wrap_G__write_cats},
-{"Grassc::G_get_ith_d_raster_cat", _wrap_G_get_ith_d_raster_cat},
-{"Grassc::G_get_ith_f_raster_cat", _wrap_G_get_ith_f_raster_cat},
-{"Grassc::G_get_ith_c_raster_cat", _wrap_G_get_ith_c_raster_cat},
-{"Grassc::G_get_ith_raster_cat", _wrap_G_get_ith_raster_cat},
-{"Grassc::G_init_cats", _wrap_G_init_cats},
-{"Grassc::G_init_raster_cats", _wrap_G_init_raster_cats},
-{"Grassc::G_set_cats_title", _wrap_G_set_cats_title},
-{"Grassc::G_set_raster_cats_title", _wrap_G_set_raster_cats_title},
-{"Grassc::G_set_cats_fmt", _wrap_G_set_cats_fmt},
-{"Grassc::G_set_raster_cats_fmt", _wrap_G_set_raster_cats_fmt},
-{"Grassc::G_free_cats", _wrap_G_free_cats},
-{"Grassc::G_free_raster_cats", _wrap_G_free_raster_cats},
-{"Grassc::G_copy_raster_cats", _wrap_G_copy_raster_cats},
-{"Grassc::G_number_of_raster_cats", _wrap_G_number_of_raster_cats},
-{"Grassc::G_sort_cats", _wrap_G_sort_cats},
-{"Grassc::G_init_cell_stats", _wrap_G_init_cell_stats},
-{"Grassc::G_update_cell_stats", _wrap_G_update_cell_stats},
-{"Grassc::G_find_cell_stat", _wrap_G_find_cell_stat},
-{"Grassc::G_rewind_cell_stats", _wrap_G_rewind_cell_stats},
-{"Grassc::G_next_cell_stat", _wrap_G_next_cell_stat},
-{"Grassc::G_get_stats_for_null_value", _wrap_G_get_stats_for_null_value},
-{"Grassc::G_free_cell_stats", _wrap_G_free_cell_stats},
-{"Grassc::G_get_cell_title", _wrap_G_get_cell_title},
-{"Grassc::G_cell_stats_histo_eq", _wrap_G_cell_stats_histo_eq},
-{"Grassc::G_chop", _wrap_G_chop},
-{"Grassc::G_clear_screen", _wrap_G_clear_screen},
-{"Grassc::G_clicker", _wrap_G_clicker},
-{"Grassc::G_close_cell", _wrap_G_close_cell},
-{"Grassc::G_unopen_cell", _wrap_G_unopen_cell},
-{"Grassc::G__write_fp_format", _wrap_G__write_fp_format},
-{"Grassc::G_make_ryg_colors", _wrap_G_make_ryg_colors},
-{"Grassc::G_make_ryg_fp_colors", _wrap_G_make_ryg_fp_colors},
-{"Grassc::G_make_aspect_colors", _wrap_G_make_aspect_colors},
-{"Grassc::G_make_aspect_fp_colors", _wrap_G_make_aspect_fp_colors},
-{"Grassc::G_make_byr_colors", _wrap_G_make_byr_colors},
-{"Grassc::G_make_byr_fp_colors", _wrap_G_make_byr_fp_colors},
-{"Grassc::G_make_byg_colors", _wrap_G_make_byg_colors},
-{"Grassc::G_make_byg_fp_colors", _wrap_G_make_byg_fp_colors},
-{"Grassc::G_make_grey_scale_colors", _wrap_G_make_grey_scale_colors},
-{"Grassc::G_make_grey_scale_fp_colors", _wrap_G_make_grey_scale_fp_colors},
-{"Grassc::G_make_gyr_colors", _wrap_G_make_gyr_colors},
-{"Grassc::G_make_gyr_fp_colors", _wrap_G_make_gyr_fp_colors},
-{"Grassc::G_make_rainbow_colors", _wrap_G_make_rainbow_colors},
-{"Grassc::G_make_rainbow_fp_colors", _wrap_G_make_rainbow_fp_colors},
-{"Grassc::G_make_ramp_colors", _wrap_G_make_ramp_colors},
-{"Grassc::G_make_ramp_fp_colors", _wrap_G_make_ramp_fp_colors},
-{"Grassc::G_make_wave_colors", _wrap_G_make_wave_colors},
-{"Grassc::G_make_wave_fp_colors", _wrap_G_make_wave_fp_colors},
-{"Grassc::G_free_colors", _wrap_G_free_colors},
-{"Grassc::G__color_free_rules", _wrap_G__color_free_rules},
-{"Grassc::G__color_free_lookup", _wrap_G__color_free_lookup},
-{"Grassc::G__color_free_fp_lookup", _wrap_G__color_free_fp_lookup},
-{"Grassc::G__color_reset", _wrap_G__color_reset},
-{"Grassc::G_get_color", _wrap_G_get_color},
-{"Grassc::G_get_raster_color", _wrap_G_get_raster_color},
-{"Grassc::G_get_c_raster_color", _wrap_G_get_c_raster_color},
-{"Grassc::G_get_f_raster_color", _wrap_G_get_f_raster_color},
-{"Grassc::G_get_d_raster_color", _wrap_G_get_d_raster_color},
-{"Grassc::G_get_null_value_color", _wrap_G_get_null_value_color},
-{"Grassc::G_get_default_color", _wrap_G_get_default_color},
-{"Grassc::G_make_histogram_eq_colors", _wrap_G_make_histogram_eq_colors},
-{"Grassc::G_make_histogram_log_colors", _wrap_G_make_histogram_log_colors},
-{"Grassc::G_init_colors", _wrap_G_init_colors},
-{"Grassc::G__insert_color_into_lookup", _wrap_G__insert_color_into_lookup},
-{"Grassc::G_invert_colors", _wrap_G_invert_colors},
-{"Grassc::G_lookup_colors", _wrap_G_lookup_colors},
-{"Grassc::G_lookup_c_raster_colors", _wrap_G_lookup_c_raster_colors},
-{"Grassc::G_lookup_raster_colors", _wrap_G_lookup_raster_colors},
-{"Grassc::G_lookup_f_raster_colors", _wrap_G_lookup_f_raster_colors},
-{"Grassc::G_lookup_d_raster_colors", _wrap_G_lookup_d_raster_colors},
-{"Grassc::G__lookup_colors", _wrap_G__lookup_colors},
-{"Grassc::G__interpolate_color_rule", _wrap_G__interpolate_color_rule},
-{"Grassc::G__organize_colors", _wrap_G__organize_colors},
-{"Grassc::G_make_random_colors", _wrap_G_make_random_colors},
-{"Grassc::G_set_color_range", _wrap_G_set_color_range},
-{"Grassc::G_set_d_color_range", _wrap_G_set_d_color_range},
-{"Grassc::G_get_color_range", _wrap_G_get_color_range},
-{"Grassc::G_get_d_color_range", _wrap_G_get_d_color_range},
-{"Grassc::G_read_colors", _wrap_G_read_colors},
-{"Grassc::G_mark_colors_as_fp", _wrap_G_mark_colors_as_fp},
-{"Grassc::G_remove_colors", _wrap_G_remove_colors},
-{"Grassc::G_add_d_raster_color_rule", _wrap_G_add_d_raster_color_rule},
-{"Grassc::G_add_f_raster_color_rule", _wrap_G_add_f_raster_color_rule},
-{"Grassc::G_add_c_raster_color_rule", _wrap_G_add_c_raster_color_rule},
-{"Grassc::G_add_raster_color_rule", _wrap_G_add_raster_color_rule},
-{"Grassc::G_add_color_rule", _wrap_G_add_color_rule},
-{"Grassc::G_add_modular_d_raster_color_rule", _wrap_G_add_modular_d_raster_color_rule},
-{"Grassc::G_add_modular_f_raster_color_rule", _wrap_G_add_modular_f_raster_color_rule},
-{"Grassc::G_add_modular_c_raster_color_rule", _wrap_G_add_modular_c_raster_color_rule},
-{"Grassc::G_add_modular_raster_color_rule", _wrap_G_add_modular_raster_color_rule},
-{"Grassc::G_add_modular_color_rule", _wrap_G_add_modular_color_rule},
-{"Grassc::G_colors_count", _wrap_G_colors_count},
-{"Grassc::G_get_f_color_rule", _wrap_G_get_f_color_rule},
-{"Grassc::G_parse_color_rule", _wrap_G_parse_color_rule},
-{"Grassc::G_parse_color_rule_error", _wrap_G_parse_color_rule_error},
-{"Grassc::G_read_color_rule", _wrap_G_read_color_rule},
-{"Grassc::G_read_color_rules", _wrap_G_read_color_rules},
-{"Grassc::G_load_colors", _wrap_G_load_colors},
-{"Grassc::G_load_fp_colors", _wrap_G_load_fp_colors},
-{"Grassc::G_make_colors", _wrap_G_make_colors},
-{"Grassc::G_make_fp_colors", _wrap_G_make_fp_colors},
-{"Grassc::G_set_color", _wrap_G_set_color},
-{"Grassc::G_set_d_color", _wrap_G_set_d_color},
-{"Grassc::G_set_null_value_color", _wrap_G_set_null_value_color},
-{"Grassc::G_set_default_color", _wrap_G_set_default_color},
-{"Grassc::G_shift_colors", _wrap_G_shift_colors},
-{"Grassc::G_shift_d_colors", _wrap_G_shift_d_colors},
-{"Grassc::G_str_to_color", _wrap_G_str_to_color},
-{"Grassc::G_write_colors", _wrap_G_write_colors},
-{"Grassc::G__write_colors", _wrap_G__write_colors},
-{"Grassc::G_histogram_eq_colors", _wrap_G_histogram_eq_colors},
-{"Grassc::G_log_colors", _wrap_G_log_colors},
-{"Grassc::G_insert_commas", _wrap_G_insert_commas},
-{"Grassc::G_remove_commas", _wrap_G_remove_commas},
-{"Grassc::G_copy", _wrap_G_copy},
-{"Grassc::G_copy_file", _wrap_G_copy_file},
-{"Grassc::G_alloc_vector", _wrap_G_alloc_vector},
-{"Grassc::G_alloc_matrix", _wrap_G_alloc_matrix},
-{"Grassc::G_alloc_fvector", _wrap_G_alloc_fvector},
-{"Grassc::G_alloc_fmatrix", _wrap_G_alloc_fmatrix},
-{"Grassc::G_free_vector", _wrap_G_free_vector},
-{"Grassc::G_free_matrix", _wrap_G_free_matrix},
-{"Grassc::G_free_fmatrix", _wrap_G_free_fmatrix},
-{"Grassc::G_date", _wrap_G_date},
-{"Grassc::G_get_datum_by_name", _wrap_G_get_datum_by_name},
-{"Grassc::G_datum_name", _wrap_G_datum_name},
-{"Grassc::G_datum_description", _wrap_G_datum_description},
-{"Grassc::G_datum_ellipsoid", _wrap_G_datum_ellipsoid},
-{"Grassc::G_get_datumparams_from_projinfo", _wrap_G_get_datumparams_from_projinfo},
-{"Grassc::G_debug", _wrap_G_debug},
-{"Grassc::G_begin_distance_calculations", _wrap_G_begin_distance_calculations},
-{"Grassc::G_distance", _wrap_G_distance},
-{"Grassc::G_distance_between_line_segments", _wrap_G_distance_between_line_segments},
-{"Grassc::G_distance_point_to_line_segment", _wrap_G_distance_point_to_line_segment},
-{"Grassc::G_done_msg", _wrap_G_done_msg},
-{"Grassc::G_tqli", _wrap_G_tqli},
-{"Grassc::G_tred2", _wrap_G_tred2},
-{"Grassc::G_is_little_endian", _wrap_G_is_little_endian},
-{"Grassc::G_getenv", _wrap_G_getenv},
-{"Grassc::G_getenv2", _wrap_G_getenv2},
-{"Grassc::G__getenv", _wrap_G__getenv},
-{"Grassc::G__getenv2", _wrap_G__getenv2},
-{"Grassc::G_setenv", _wrap_G_setenv},
-{"Grassc::G_setenv2", _wrap_G_setenv2},
-{"Grassc::G__setenv", _wrap_G__setenv},
-{"Grassc::G__setenv2", _wrap_G__setenv2},
-{"Grassc::G_unsetenv", _wrap_G_unsetenv},
-{"Grassc::G_unsetenv2", _wrap_G_unsetenv2},
-{"Grassc::G__write_env", _wrap_G__write_env},
-{"Grassc::G__env_name", _wrap_G__env_name},
-{"Grassc::G__read_env", _wrap_G__read_env},
-{"Grassc::G_set_gisrc_mode", _wrap_G_set_gisrc_mode},
-{"Grassc::G_get_gisrc_mode", _wrap_G_get_gisrc_mode},
-{"Grassc::G__set_gisrc_file", _wrap_G__set_gisrc_file},
-{"Grassc::G__get_gisrc_file", _wrap_G__get_gisrc_file},
-{"Grassc::G__create_alt_env", _wrap_G__create_alt_env},
-{"Grassc::G__switch_env", _wrap_G__switch_env},
-{"Grassc::G_info_format", _wrap_G_info_format},
-{"Grassc::G_message", _wrap_G_message},
-{"Grassc::G_verbose_message", _wrap_G_verbose_message},
-{"Grassc::G_important_message", _wrap_G_important_message},
-{"Grassc::G_fatal_error", _wrap_G_fatal_error},
-{"Grassc::G_warning", _wrap_G_warning},
-{"Grassc::G_suppress_warnings", _wrap_G_suppress_warnings},
-{"Grassc::G_sleep_on_error", _wrap_G_sleep_on_error},
-{"Grassc::G_set_error_routine", _wrap_G_set_error_routine},
-{"Grassc::G_unset_error_routine", _wrap_G_unset_error_routine},
-{"Grassc::G__file_name", _wrap_G__file_name},
-{"Grassc::G__file_name_misc", _wrap_G__file_name_misc},
-{"Grassc::G_find_cell", _wrap_G_find_cell},
-{"Grassc::G_find_cell2", _wrap_G_find_cell2},
-{"Grassc::G_find_file", _wrap_G_find_file},
-{"Grassc::G_find_file2", _wrap_G_find_file2},
-{"Grassc::G_find_file_misc", _wrap_G_find_file_misc},
-{"Grassc::G_find_file2_misc", _wrap_G_find_file2_misc},
-{"Grassc::G_find_etc", _wrap_G_find_etc},
-{"Grassc::G_find_vector", _wrap_G_find_vector},
-{"Grassc::G_find_vector2", _wrap_G_find_vector2},
-{"Grassc::G_zlib_compress", _wrap_G_zlib_compress},
-{"Grassc::G_zlib_expand", _wrap_G_zlib_expand},
-{"Grassc::G_zlib_write", _wrap_G_zlib_write},
-{"Grassc::G_zlib_read", _wrap_G_zlib_read},
-{"Grassc::G_zlib_write_noCompress", _wrap_G_zlib_write_noCompress},
-{"Grassc::G_fork", _wrap_G_fork},
-{"Grassc::G__check_format", _wrap_G__check_format},
-{"Grassc::G__read_row_ptrs", _wrap_G__read_row_ptrs},
-{"Grassc::G__write_row_ptrs", _wrap_G__write_row_ptrs},
-{"Grassc::G_fpreclass_clear", _wrap_G_fpreclass_clear},
-{"Grassc::G_fpreclass_reset", _wrap_G_fpreclass_reset},
-{"Grassc::G_fpreclass_init", _wrap_G_fpreclass_init},
-{"Grassc::G_fpreclass_set_domain", _wrap_G_fpreclass_set_domain},
-{"Grassc::G_fpreclass_set_range", _wrap_G_fpreclass_set_range},
-{"Grassc::G_fpreclass_get_limits", _wrap_G_fpreclass_get_limits},
-{"Grassc::G_fpreclass_nof_rules", _wrap_G_fpreclass_nof_rules},
-{"Grassc::G_fpreclass_get_ith_rule", _wrap_G_fpreclass_get_ith_rule},
-{"Grassc::G_fpreclass_set_neg_infinite_rule", _wrap_G_fpreclass_set_neg_infinite_rule},
-{"Grassc::G_fpreclass_get_neg_infinite_rule", _wrap_G_fpreclass_get_neg_infinite_rule},
-{"Grassc::G_fpreclass_set_pos_infinite_rule", _wrap_G_fpreclass_set_pos_infinite_rule},
-{"Grassc::G_fpreclass_get_pos_infinite_rule", _wrap_G_fpreclass_get_pos_infinite_rule},
-{"Grassc::G_fpreclass_add_rule", _wrap_G_fpreclass_add_rule},
-{"Grassc::G_fpreclass_reverse_rule_order", _wrap_G_fpreclass_reverse_rule_order},
-{"Grassc::G_fpreclass_get_cell_value", _wrap_G_fpreclass_get_cell_value},
-{"Grassc::G_fpreclass_perform_di", _wrap_G_fpreclass_perform_di},
-{"Grassc::G_fpreclass_perform_df", _wrap_G_fpreclass_perform_df},
-{"Grassc::G_fpreclass_perform_dd", _wrap_G_fpreclass_perform_dd},
-{"Grassc::G_fpreclass_perform_fi", _wrap_G_fpreclass_perform_fi},
-{"Grassc::G_fpreclass_perform_ff", _wrap_G_fpreclass_perform_ff},
-{"Grassc::G_fpreclass_perform_fd", _wrap_G_fpreclass_perform_fd},
-{"Grassc::G_fpreclass_perform_ii", _wrap_G_fpreclass_perform_ii},
-{"Grassc::G_fpreclass_perform_if", _wrap_G_fpreclass_perform_if},
-{"Grassc::G_fpreclass_perform_id", _wrap_G_fpreclass_perform_id},
-{"Grassc::G_begin_geodesic_equation", _wrap_G_begin_geodesic_equation},
-{"Grassc::G_geodesic_lat_from_lon", _wrap_G_geodesic_lat_from_lon},
-{"Grassc::G_begin_geodesic_distance", _wrap_G_begin_geodesic_distance},
-{"Grassc::G_set_geodesic_distance_lat1", _wrap_G_set_geodesic_distance_lat1},
-{"Grassc::G_set_geodesic_distance_lat2", _wrap_G_set_geodesic_distance_lat2},
-{"Grassc::G_geodesic_distance_lon_to_lon", _wrap_G_geodesic_distance_lon_to_lon},
-{"Grassc::G_geodesic_distance", _wrap_G_geodesic_distance},
-{"Grassc::G_get_cellhd", _wrap_G_get_cellhd},
-{"Grassc::G_ask_datum_name", _wrap_G_ask_datum_name},
-{"Grassc::G_ask_ellipse_name", _wrap_G_ask_ellipse_name},
-{"Grassc::G_get_ellipsoid_parameters", _wrap_G_get_ellipsoid_parameters},
-{"Grassc::G_get_spheroid_by_name", _wrap_G_get_spheroid_by_name},
-{"Grassc::G_get_ellipsoid_by_name", _wrap_G_get_ellipsoid_by_name},
-{"Grassc::G_ellipsoid_name", _wrap_G_ellipsoid_name},
-{"Grassc::G_ellipsoid_description", _wrap_G_ellipsoid_description},
-{"Grassc::G_get_projunits", _wrap_G_get_projunits},
-{"Grassc::G_get_projinfo", _wrap_G_get_projinfo},
-{"Grassc::G_ask_proj_name", _wrap_G_ask_proj_name},
-{"Grassc::G_get_map_row_nomask", _wrap_G_get_map_row_nomask},
-{"Grassc::G_get_raster_row_nomask", _wrap_G_get_raster_row_nomask},
-{"Grassc::G_get_c_raster_row_nomask", _wrap_G_get_c_raster_row_nomask},
-{"Grassc::G_get_f_raster_row_nomask", _wrap_G_get_f_raster_row_nomask},
-{"Grassc::G_get_d_raster_row_nomask", _wrap_G_get_d_raster_row_nomask},
-{"Grassc::G_get_map_row", _wrap_G_get_map_row},
-{"Grassc::G_get_raster_row", _wrap_G_get_raster_row},
-{"Grassc::G_get_c_raster_row", _wrap_G_get_c_raster_row},
-{"Grassc::G_get_f_raster_row", _wrap_G_get_f_raster_row},
-{"Grassc::G_get_d_raster_row", _wrap_G_get_d_raster_row},
-{"Grassc::G_get_null_value_row", _wrap_G_get_null_value_row},
-{"Grassc::G_get_raster_row_colors", _wrap_G_get_raster_row_colors},
-{"Grassc::G_get_window", _wrap_G_get_window},
-{"Grassc::G_get_default_window", _wrap_G_get_default_window},
-{"Grassc::G__get_window", _wrap_G__get_window},
-{"Grassc::G_getl", _wrap_G_getl},
-{"Grassc::G_getl2", _wrap_G_getl2},
-{"Grassc::G_gets", _wrap_G_gets},
-{"Grassc::G_gisbase", _wrap_G_gisbase},
-{"Grassc::G_gisdbase", _wrap_G_gisdbase},
-{"Grassc::G_gishelp", _wrap_G_gishelp},
-{"Grassc::G_gisinit", _wrap_G_gisinit},
-{"Grassc::G_no_gisinit", _wrap_G_no_gisinit},
-{"Grassc::G__check_gisinit", _wrap_G__check_gisinit},
-{"Grassc::G_histogram_eq", _wrap_G_histogram_eq},
-{"Grassc::G_init_histogram", _wrap_G_init_histogram},
-{"Grassc::G_read_histogram", _wrap_G_read_histogram},
-{"Grassc::G_write_histogram", _wrap_G_write_histogram},
-{"Grassc::G_write_histogram_cs", _wrap_G_write_histogram_cs},
-{"Grassc::G_make_histogram_cs", _wrap_G_make_histogram_cs},
-{"Grassc::G_get_histogram_num", _wrap_G_get_histogram_num},
-{"Grassc::G_get_histogram_cat", _wrap_G_get_histogram_cat},
-{"Grassc::G_get_histogram_count", _wrap_G_get_histogram_count},
-{"Grassc::G_free_histogram", _wrap_G_free_histogram},
-{"Grassc::G_sort_histogram", _wrap_G_sort_histogram},
-{"Grassc::G_sort_histogram_by_count", _wrap_G_sort_histogram_by_count},
-{"Grassc::G_remove_histogram", _wrap_G_remove_histogram},
-{"Grassc::G_add_histogram", _wrap_G_add_histogram},
-{"Grassc::G_set_histogram", _wrap_G_set_histogram},
-{"Grassc::G_extend_histogram", _wrap_G_extend_histogram},
-{"Grassc::G_zero_histogram", _wrap_G_zero_histogram},
-{"Grassc::G_read_history", _wrap_G_read_history},
-{"Grassc::G_write_history", _wrap_G_write_history},
-{"Grassc::G_short_history", _wrap_G_short_history},
-{"Grassc::G_command_history", _wrap_G_command_history},
-{"Grassc::G_home", _wrap_G_home},
-{"Grassc::G__home", _wrap_G__home},
-{"Grassc::G_alloc_ivector", _wrap_G_alloc_ivector},
-{"Grassc::G_alloc_imatrix", _wrap_G_alloc_imatrix},
-{"Grassc::G_free_ivector", _wrap_G_free_ivector},
-{"Grassc::G_free_imatrix", _wrap_G_free_imatrix},
-{"Grassc::G_index", _wrap_G_index},
-{"Grassc::G_rindex", _wrap_G_rindex},
-{"Grassc::G__random_d_initialize_0", _wrap_G__random_d_initialize_0},
-{"Grassc::G__random_f_initialize_0", _wrap_G__random_f_initialize_0},
-{"Grassc::G_interp_linear", _wrap_G_interp_linear},
-{"Grassc::G_interp_bilinear", _wrap_G_interp_bilinear},
-{"Grassc::G_interp_cubic", _wrap_G_interp_cubic},
-{"Grassc::G_interp_bicubic", _wrap_G_interp_bicubic},
-{"Grassc::G_intersect_line_segments", _wrap_G_intersect_line_segments},
-{"Grassc::G_intr_char", _wrap_G_intr_char},
-{"Grassc::G_is_gisbase", _wrap_G_is_gisbase},
-{"Grassc::G_is_location", _wrap_G_is_location},
-{"Grassc::G_is_mapset", _wrap_G_is_mapset},
-{"Grassc::G_create_key_value", _wrap_G_create_key_value},
-{"Grassc::G_set_key_value", _wrap_G_set_key_value},
-{"Grassc::G_find_key_value", _wrap_G_find_key_value},
-{"Grassc::G_free_key_value", _wrap_G_free_key_value},
-{"Grassc::G_fwrite_key_value", _wrap_G_fwrite_key_value},
-{"Grassc::G_fread_key_value", _wrap_G_fread_key_value},
-{"Grassc::G_write_key_value_file", _wrap_G_write_key_value_file},
-{"Grassc::G_read_key_value_file", _wrap_G_read_key_value_file},
-{"Grassc::G_update_key_value_file", _wrap_G_update_key_value_file},
-{"Grassc::G_lookup_key_value_from_file", _wrap_G_lookup_key_value_from_file},
-{"Grassc::G_legal_filename", _wrap_G_legal_filename},
-{"Grassc::G_check_input_output_name", _wrap_G_check_input_output_name},
-{"Grassc::G_set_distance_to_line_tolerance", _wrap_G_set_distance_to_line_tolerance},
-{"Grassc::G_distance2_point_to_line", _wrap_G_distance2_point_to_line},
-{"Grassc::G_set_list_hit_return", _wrap_G_set_list_hit_return},
-{"Grassc::G_list_element", _wrap_G_list_element},
-{"Grassc::G_list", _wrap_G_list},
-{"Grassc::G_free_list", _wrap_G_free_list},
-{"Grassc::G_lat_format", _wrap_G_lat_format},
-{"Grassc::G_lat_format_string", _wrap_G_lat_format_string},
-{"Grassc::G_lon_format", _wrap_G_lon_format},
-{"Grassc::G_lon_format_string", _wrap_G_lon_format_string},
-{"Grassc::G_llres_format", _wrap_G_llres_format},
-{"Grassc::G_llres_format_string", _wrap_G_llres_format_string},
-{"Grassc::G_lat_parts", _wrap_G_lat_parts},
-{"Grassc::G_lon_parts", _wrap_G_lon_parts},
-{"Grassc::G_lat_scan", _wrap_G_lat_scan},
-{"Grassc::G_lon_scan", _wrap_G_lon_scan},
-{"Grassc::G_llres_scan", _wrap_G_llres_scan},
-{"Grassc::G_location_path", _wrap_G_location_path},
-{"Grassc::G_location", _wrap_G_location},
-{"Grassc::G__location_path", _wrap_G__location_path},
-{"Grassc::G__ls", _wrap_G__ls},
-{"Grassc::G_ls", _wrap_G_ls},
-{"Grassc::G_ls_format", _wrap_G_ls_format},
-{"Grassc::G_ludcmp", _wrap_G_ludcmp},
-{"Grassc::G_lubksb", _wrap_G_lubksb},
-{"Grassc::lzw_decode", _wrap_lzw_decode},
-{"Grassc::lzw_expand", _wrap_lzw_expand},
-{"Grassc::G_lzw_nof_read_bytes", _wrap_G_lzw_nof_read_bytes},
-{"Grassc::G_lzw_max_used_bits", _wrap_G_lzw_max_used_bits},
-{"Grassc::G_lzw_set_bits", _wrap_G_lzw_set_bits},
-{"Grassc::G_lzw_compress", _wrap_G_lzw_compress},
-{"Grassc::G_lzw_expand", _wrap_G_lzw_expand},
-{"Grassc::G_lzw_compress_count_only_array", _wrap_G_lzw_compress_count_only_array},
-{"Grassc::G_lzw_compress_count_only_file", _wrap_G_lzw_compress_count_only_file},
-{"Grassc::G_lzw_write", _wrap_G_lzw_write},
-{"Grassc::G_lzw_write_noCompress", _wrap_G_lzw_write_noCompress},
-{"Grassc::G_lzw_test_status", _wrap_G_lzw_test_status},
-{"Grassc::G_lzw_read2", _wrap_G_lzw_read2},
-{"Grassc::G_lzw_read", _wrap_G_lzw_read},
-{"Grassc::G_lzw_transfer_compress", _wrap_G_lzw_transfer_compress},
-{"Grassc::G_lzw_transfer_expand", _wrap_G_lzw_transfer_expand},
-{"Grassc::G__machine_name", _wrap_G__machine_name},
-{"Grassc::G_ask_colors", _wrap_G_ask_colors},
-{"Grassc::G__make_location", _wrap_G__make_location},
-{"Grassc::G_make_location", _wrap_G_make_location},
-{"Grassc::G_compare_projections", _wrap_G_compare_projections},
-{"Grassc::G__make_mapset", _wrap_G__make_mapset},
-{"Grassc::G_make_mapset", _wrap_G_make_mapset},
-{"Grassc::G_tolcase", _wrap_G_tolcase},
-{"Grassc::G_toucase", _wrap_G_toucase},
-{"Grassc::G_mapset", _wrap_G_mapset},
-{"Grassc::G__mapset", _wrap_G__mapset},
-{"Grassc::G__make_mapset_element", _wrap_G__make_mapset_element},
-{"Grassc::G__make_mapset_element_misc", _wrap_G__make_mapset_element_misc},
-{"Grassc::G__mapset_permissions", _wrap_G__mapset_permissions},
-{"Grassc::G__mapset_permissions2", _wrap_G__mapset_permissions2},
-{"Grassc::G__mapset_name", _wrap_G__mapset_name},
-{"Grassc::G__create_alt_search_path", _wrap_G__create_alt_search_path},
-{"Grassc::G__switch_search_path", _wrap_G__switch_search_path},
-{"Grassc::G_reset_mapsets", _wrap_G_reset_mapsets},
-{"Grassc::G_available_mapsets", _wrap_G_available_mapsets},
-{"Grassc::G_add_mapset_to_search_path", _wrap_G_add_mapset_to_search_path},
-{"Grassc::G_mask_info", _wrap_G_mask_info},
-{"Grassc::G__mask_info", _wrap_G__mask_info},
-{"Grassc::G_maskfd", _wrap_G_maskfd},
-{"Grassc::G_myname", _wrap_G_myname},
-{"Grassc::G_color_values", _wrap_G_color_values},
-{"Grassc::G_color_name", _wrap_G_color_name},
-{"Grassc::G_newlines_to_spaces", _wrap_G_newlines_to_spaces},
-{"Grassc::G__name_in_mapset", _wrap_G__name_in_mapset},
-{"Grassc::G__name_is_fully_qualified", _wrap_G__name_is_fully_qualified},
-{"Grassc::G_fully_qualified_name", _wrap_G_fully_qualified_name},
-{"Grassc::G__init_null_patterns", _wrap_G__init_null_patterns},
-{"Grassc::G__set_null_value", _wrap_G__set_null_value},
-{"Grassc::G_set_null_value", _wrap_G_set_null_value},
-{"Grassc::G_set_c_null_value", _wrap_G_set_c_null_value},
-{"Grassc::G_set_f_null_value", _wrap_G_set_f_null_value},
-{"Grassc::G_set_d_null_value", _wrap_G_set_d_null_value},
-{"Grassc::G_is_null_value", _wrap_G_is_null_value},
-{"Grassc::G_is_c_null_value", _wrap_G_is_c_null_value},
-{"Grassc::G_is_f_null_value", _wrap_G_is_f_null_value},
-{"Grassc::G_is_d_null_value", _wrap_G_is_d_null_value},
-{"Grassc::G_insert_null_values", _wrap_G_insert_null_values},
-{"Grassc::G_insert_c_null_values", _wrap_G_insert_c_null_values},
-{"Grassc::G_insert_f_null_values", _wrap_G_insert_f_null_values},
-{"Grassc::G_insert_d_null_values", _wrap_G_insert_d_null_values},
-{"Grassc::G__check_null_bit", _wrap_G__check_null_bit},
-{"Grassc::G__set_flags_from_01_random", _wrap_G__set_flags_from_01_random},
-{"Grassc::G__convert_01_flags", _wrap_G__convert_01_flags},
-{"Grassc::G__convert_flags_01", _wrap_G__convert_flags_01},
-{"Grassc::G__init_null_bits", _wrap_G__init_null_bits},
-{"Grassc::G_open_new", _wrap_G_open_new},
-{"Grassc::G_open_old", _wrap_G_open_old},
-{"Grassc::G_open_update", _wrap_G_open_update},
-{"Grassc::G_fopen_new", _wrap_G_fopen_new},
-{"Grassc::G_fopen_old", _wrap_G_fopen_old},
-{"Grassc::G_fopen_append", _wrap_G_fopen_append},
-{"Grassc::G_fopen_modify", _wrap_G_fopen_modify},
-{"Grassc::G_open_new_misc", _wrap_G_open_new_misc},
-{"Grassc::G_open_old_misc", _wrap_G_open_old_misc},
-{"Grassc::G_open_update_misc", _wrap_G_open_update_misc},
-{"Grassc::G_fopen_new_misc", _wrap_G_fopen_new_misc},
-{"Grassc::G_fopen_old_misc", _wrap_G_fopen_old_misc},
-{"Grassc::G_fopen_append_misc", _wrap_G_fopen_append_misc},
-{"Grassc::G_fopen_modify_misc", _wrap_G_fopen_modify_misc},
-{"Grassc::G_open_cell_old", _wrap_G_open_cell_old},
-{"Grassc::G__open_cell_old", _wrap_G__open_cell_old},
-{"Grassc::G_open_cell_new", _wrap_G_open_cell_new},
-{"Grassc::G_open_cell_new_random", _wrap_G_open_cell_new_random},
-{"Grassc::G_open_cell_new_uncompressed", _wrap_G_open_cell_new_uncompressed},
-{"Grassc::G_want_histogram", _wrap_G_want_histogram},
-{"Grassc::G_set_cell_format", _wrap_G_set_cell_format},
-{"Grassc::G_cellvalue_format", _wrap_G_cellvalue_format},
-{"Grassc::G_open_fp_cell_new", _wrap_G_open_fp_cell_new},
-{"Grassc::G_open_fp_cell_new_uncompressed", _wrap_G_open_fp_cell_new_uncompressed},
-{"Grassc::G__reallocate_work_buf", _wrap_G__reallocate_work_buf},
-{"Grassc::G__reallocate_null_buf", _wrap_G__reallocate_null_buf},
-{"Grassc::G__reallocate_mask_buf", _wrap_G__reallocate_mask_buf},
-{"Grassc::G__reallocate_temp_buf", _wrap_G__reallocate_temp_buf},
-{"Grassc::G_set_fp_type", _wrap_G_set_fp_type},
-{"Grassc::G_raster_map_is_fp", _wrap_G_raster_map_is_fp},
-{"Grassc::G_raster_map_type", _wrap_G_raster_map_type},
-{"Grassc::G_raster_map_type2", _wrap_G_raster_map_type2},
-{"Grassc::G__check_fp_type", _wrap_G__check_fp_type},
-{"Grassc::G_get_raster_map_type", _wrap_G_get_raster_map_type},
-{"Grassc::G_open_raster_new", _wrap_G_open_raster_new},
-{"Grassc::G_open_raster_new_uncompressed", _wrap_G_open_raster_new_uncompressed},
-{"Grassc::G_set_quant_rules", _wrap_G_set_quant_rules},
-{"Grassc::G_disable_interactive", _wrap_G_disable_interactive},
-{"Grassc::G_define_module", _wrap_G_define_module},
-{"Grassc::G_define_flag", _wrap_G_define_flag},
-{"Grassc::G_define_option", _wrap_G_define_option},
-{"Grassc::G_define_standard_option", _wrap_G_define_standard_option},
-{"Grassc::G_parser", _wrap_G_parser},
-{"Grassc::G_usage", _wrap_G_usage},
-{"Grassc::G_recreate_command", _wrap_G_recreate_command},
-{"Grassc::G_mkdir", _wrap_G_mkdir},
-{"Grassc::G_is_dirsep", _wrap_G_is_dirsep},
-{"Grassc::G_is_absolute_path", _wrap_G_is_absolute_path},
-{"Grassc::G_convert_dirseps_to_host", _wrap_G_convert_dirseps_to_host},
-{"Grassc::G_convert_dirseps_from_host", _wrap_G_convert_dirseps_from_host},
-{"Grassc::G_lstat", _wrap_G_lstat},
-{"Grassc::G_stat", _wrap_G_stat},
-{"Grassc::G_percent", _wrap_G_percent},
-{"Grassc::G_percent2", _wrap_G_percent2},
-{"Grassc::G_percent_reset", _wrap_G_percent_reset},
-{"Grassc::G_setup_plot", _wrap_G_setup_plot},
-{"Grassc::G_setup_fill", _wrap_G_setup_fill},
-{"Grassc::G_plot_where_xy", _wrap_G_plot_where_xy},
-{"Grassc::G_plot_where_en", _wrap_G_plot_where_en},
-{"Grassc::G_plot_point", _wrap_G_plot_point},
-{"Grassc::G_plot_line", _wrap_G_plot_line},
-{"Grassc::G_plot_line2", _wrap_G_plot_line2},
-{"Grassc::G_plot_polygon", _wrap_G_plot_polygon},
-{"Grassc::G_plot_area", _wrap_G_plot_area},
-{"Grassc::G_plot_fx", _wrap_G_plot_fx},
-{"Grassc::G_plot_icon", _wrap_G_plot_icon},
-{"Grassc::G_pole_in_polygon", _wrap_G_pole_in_polygon},
-{"Grassc::G_popen", _wrap_G_popen},
-{"Grassc::G_pclose", _wrap_G_pclose},
-{"Grassc::G_program_name", _wrap_G_program_name},
-{"Grassc::G_set_program_name", _wrap_G_set_program_name},
-{"Grassc::G_projection", _wrap_G_projection},
-{"Grassc::G__projection_units", _wrap_G__projection_units},
-{"Grassc::G__unit_name", _wrap_G__unit_name},
-{"Grassc::G__projection_name", _wrap_G__projection_name},
-{"Grassc::G_database_unit_name", _wrap_G_database_unit_name},
-{"Grassc::G_database_projection_name", _wrap_G_database_projection_name},
-{"Grassc::G_database_units_to_meters_factor", _wrap_G_database_units_to_meters_factor},
-{"Grassc::G_database_datum_name", _wrap_G_database_datum_name},
-{"Grassc::G_database_ellipse_name", _wrap_G_database_ellipse_name},
-{"Grassc::G_put_cellhd", _wrap_G_put_cellhd},
-{"Grassc::G_zeros_r_nulls", _wrap_G_zeros_r_nulls},
-{"Grassc::G_put_map_row", _wrap_G_put_map_row},
-{"Grassc::G_put_map_row_random", _wrap_G_put_map_row_random},
-{"Grassc::G__put_null_value_row", _wrap_G__put_null_value_row},
-{"Grassc::G_put_raster_row", _wrap_G_put_raster_row},
-{"Grassc::G_put_c_raster_row", _wrap_G_put_c_raster_row},
-{"Grassc::G_put_f_raster_row", _wrap_G_put_f_raster_row},
-{"Grassc::G_put_d_raster_row", _wrap_G_put_d_raster_row},
-{"Grassc::G__write_data", _wrap_G__write_data},
-{"Grassc::G__write_data_compressed", _wrap_G__write_data_compressed},
-{"Grassc::G__open_null_write", _wrap_G__open_null_write},
-{"Grassc::G__write_null_bits", _wrap_G__write_null_bits},
-{"Grassc::G_put_cell_title", _wrap_G_put_cell_title},
-{"Grassc::G_put_window", _wrap_G_put_window},
-{"Grassc::G__put_window", _wrap_G__put_window},
-{"Grassc::G_putenv", _wrap_G_putenv},
-{"Grassc::G_quant_clear", _wrap_G_quant_clear},
-{"Grassc::G_quant_free", _wrap_G_quant_free},
-{"Grassc::G__quant_organize_fp_lookup", _wrap_G__quant_organize_fp_lookup},
-{"Grassc::G_quant_init", _wrap_G_quant_init},
-{"Grassc::G_quant_is_truncate", _wrap_G_quant_is_truncate},
-{"Grassc::G_quant_is_round", _wrap_G_quant_is_round},
-{"Grassc::G_quant_truncate", _wrap_G_quant_truncate},
-{"Grassc::G_quant_round", _wrap_G_quant_round},
-{"Grassc::G_quant_get_limits", _wrap_G_quant_get_limits},
-{"Grassc::G_quant_nof_rules", _wrap_G_quant_nof_rules},
-{"Grassc::G_quant_get_ith_rule", _wrap_G_quant_get_ith_rule},
-{"Grassc::G_quant_set_neg_infinite_rule", _wrap_G_quant_set_neg_infinite_rule},
-{"Grassc::G_quant_get_neg_infinite_rule", _wrap_G_quant_get_neg_infinite_rule},
-{"Grassc::G_quant_set_pos_infinite_rule", _wrap_G_quant_set_pos_infinite_rule},
-{"Grassc::G_quant_get_pos_infinite_rule", _wrap_G_quant_get_pos_infinite_rule},
-{"Grassc::G_quant_add_rule", _wrap_G_quant_add_rule},
-{"Grassc::G_quant_reverse_rule_order", _wrap_G_quant_reverse_rule_order},
-{"Grassc::G_quant_get_cell_value", _wrap_G_quant_get_cell_value},
-{"Grassc::G_quant_perform_d", _wrap_G_quant_perform_d},
-{"Grassc::G_quant_perform_f", _wrap_G_quant_perform_f},
-{"Grassc::G__quant_get_rule_for_d_raster_val", _wrap_G__quant_get_rule_for_d_raster_val},
-{"Grassc::G__quant_import", _wrap_G__quant_import},
-{"Grassc::G__quant_export", _wrap_G__quant_export},
-{"Grassc::G_truncate_fp_map", _wrap_G_truncate_fp_map},
-{"Grassc::G_round_fp_map", _wrap_G_round_fp_map},
-{"Grassc::G_quantize_fp_map", _wrap_G_quantize_fp_map},
-{"Grassc::G_quantize_fp_map_range", _wrap_G_quantize_fp_map_range},
-{"Grassc::G_write_quant", _wrap_G_write_quant},
-{"Grassc::G_read_quant", _wrap_G_read_quant},
-{"Grassc::G_meridional_radius_of_curvature", _wrap_G_meridional_radius_of_curvature},
-{"Grassc::G_transverse_radius_of_curvature", _wrap_G_transverse_radius_of_curvature},
-{"Grassc::G_radius_of_conformal_tangent_sphere", _wrap_G_radius_of_conformal_tangent_sphere},
-{"Grassc::G__remove_fp_range", _wrap_G__remove_fp_range},
-{"Grassc::G_construct_default_range", _wrap_G_construct_default_range},
-{"Grassc::G_read_fp_range", _wrap_G_read_fp_range},
-{"Grassc::G_read_range", _wrap_G_read_range},
-{"Grassc::G_write_range", _wrap_G_write_range},
-{"Grassc::G_write_fp_range", _wrap_G_write_fp_range},
-{"Grassc::G_update_range", _wrap_G_update_range},
-{"Grassc::G_update_fp_range", _wrap_G_update_fp_range},
-{"Grassc::G_row_update_range", _wrap_G_row_update_range},
-{"Grassc::G__row_update_range", _wrap_G__row_update_range},
-{"Grassc::G_row_update_fp_range", _wrap_G_row_update_fp_range},
-{"Grassc::G_init_range", _wrap_G_init_range},
-{"Grassc::G_get_range_min_max", _wrap_G_get_range_min_max},
-{"Grassc::G_init_fp_range", _wrap_G_init_fp_range},
-{"Grassc::G_get_fp_range_min_max", _wrap_G_get_fp_range_min_max},
-{"Grassc::G_incr_void_ptr", _wrap_G_incr_void_ptr},
-{"Grassc::G_raster_cmp", _wrap_G_raster_cmp},
-{"Grassc::G_raster_cpy", _wrap_G_raster_cpy},
-{"Grassc::G_set_raster_value_c", _wrap_G_set_raster_value_c},
-{"Grassc::G_set_raster_value_f", _wrap_G_set_raster_value_f},
-{"Grassc::G_set_raster_value_d", _wrap_G_set_raster_value_d},
-{"Grassc::G_get_raster_value_c", _wrap_G_get_raster_value_c},
-{"Grassc::G_get_raster_value_f", _wrap_G_get_raster_value_f},
-{"Grassc::G_get_raster_value_d", _wrap_G_get_raster_value_d},
-{"Grassc::G_read_raster_units", _wrap_G_read_raster_units},
-{"Grassc::G_read_raster_vdatum", _wrap_G_read_raster_vdatum},
-{"Grassc::G_write_raster_units", _wrap_G_write_raster_units},
-{"Grassc::G_write_raster_vdatum", _wrap_G_write_raster_vdatum},
-{"Grassc::G__raster_misc_read_line", _wrap_G__raster_misc_read_line},
-{"Grassc::G__raster_misc_write_line", _wrap_G__raster_misc_write_line},
-{"Grassc::G__read_Cell_head", _wrap_G__read_Cell_head},
-{"Grassc::G__read_Cell_head_array", _wrap_G__read_Cell_head_array},
-{"Grassc::G_is_reclass", _wrap_G_is_reclass},
-{"Grassc::G_is_reclassed_to", _wrap_G_is_reclassed_to},
-{"Grassc::G_get_reclass", _wrap_G_get_reclass},
-{"Grassc::G_free_reclass", _wrap_G_free_reclass},
-{"Grassc::G_put_reclass", _wrap_G_put_reclass},
-{"Grassc::G_remove", _wrap_G_remove},
-{"Grassc::G_remove_misc", _wrap_G_remove_misc},
-{"Grassc::G_rename", _wrap_G_rename},
-{"Grassc::G_begin_rhumbline_equation", _wrap_G_begin_rhumbline_equation},
-{"Grassc::G_rhumbline_lat_from_lon", _wrap_G_rhumbline_lat_from_lon},
-{"Grassc::G_rotate_around_point", _wrap_G_rotate_around_point},
-{"Grassc::G_rotate_around_point_int", _wrap_G_rotate_around_point_int},
-{"Grassc::G_get_raster_sample", _wrap_G_get_raster_sample},
-{"Grassc::G_get_set_window", _wrap_G_get_set_window},
-{"Grassc::G_set_window", _wrap_G_set_window},
-{"Grassc::G_shortest_way", _wrap_G_shortest_way},
-{"Grassc::G_sleep", _wrap_G_sleep},
-{"Grassc::G_snprintf", _wrap_G_snprintf},
-{"Grassc::G_squeeze", _wrap_G_squeeze},
-{"Grassc::G_store", _wrap_G_store},
-{"Grassc::G_strcpy", _wrap_G_strcpy},
-{"Grassc::G_chrcpy", _wrap_G_chrcpy},
-{"Grassc::G_strncpy", _wrap_G_strncpy},
-{"Grassc::G_strcat", _wrap_G_strcat},
-{"Grassc::G_chrcat", _wrap_G_chrcat},
-{"Grassc::G_strmov", _wrap_G_strmov},
-{"Grassc::G_chrmov", _wrap_G_chrmov},
-{"Grassc::G_strcasecmp", _wrap_G_strcasecmp},
-{"Grassc::G_strstr", _wrap_G_strstr},
-{"Grassc::G_strdup", _wrap_G_strdup},
-{"Grassc::G_strchg", _wrap_G_strchg},
-{"Grassc::G_str_replace", _wrap_G_str_replace},
-{"Grassc::G_str_to_upper", _wrap_G_str_to_upper},
-{"Grassc::G_str_to_lower", _wrap_G_str_to_lower},
-{"Grassc::G_str_to_sql", _wrap_G_str_to_sql},
-{"Grassc::G_strip", _wrap_G_strip},
-{"Grassc::G_svdcmp", _wrap_G_svdcmp},
-{"Grassc::G_svbksb", _wrap_G_svbksb},
-{"Grassc::G_svelim", _wrap_G_svelim},
-{"Grassc::G_system", _wrap_G_system},
-{"Grassc::G_tempfile", _wrap_G_tempfile},
-{"Grassc::G__tempfile", _wrap_G__tempfile},
-{"Grassc::G__temp_element", _wrap_G__temp_element},
-{"Grassc::G_init_timestamp", _wrap_G_init_timestamp},
-{"Grassc::G_set_timestamp", _wrap_G_set_timestamp},
-{"Grassc::G_set_timestamp_range", _wrap_G_set_timestamp_range},
-{"Grassc::G__read_timestamp", _wrap_G__read_timestamp},
-{"Grassc::G__write_timestamp", _wrap_G__write_timestamp},
-{"Grassc::G_get_timestamps", _wrap_G_get_timestamps},
-{"Grassc::G_read_raster_timestamp", _wrap_G_read_raster_timestamp},
-{"Grassc::G_read_vector_timestamp", _wrap_G_read_vector_timestamp},
-{"Grassc::G_write_raster_timestamp", _wrap_G_write_raster_timestamp},
-{"Grassc::G_write_vector_timestamp", _wrap_G_write_vector_timestamp},
-{"Grassc::G_format_timestamp", _wrap_G_format_timestamp},
-{"Grassc::G_scan_timestamp", _wrap_G_scan_timestamp},
-{"Grassc::G_remove_raster_timestamp", _wrap_G_remove_raster_timestamp},
-{"Grassc::G_remove_vector_timestamp", _wrap_G_remove_vector_timestamp},
-{"Grassc::G_read_grid3_timestamp", _wrap_G_read_grid3_timestamp},
-{"Grassc::G_remove_grid3_timestamp", _wrap_G_remove_grid3_timestamp},
-{"Grassc::G_write_grid3_timestamp", _wrap_G_write_grid3_timestamp},
-{"Grassc::G_tokenize", _wrap_G_tokenize},
-{"Grassc::G_number_of_tokens", _wrap_G_number_of_tokens},
-{"Grassc::G_free_tokens", _wrap_G_free_tokens},
-{"Grassc::G_trim_decimal", _wrap_G_trim_decimal},
-{"Grassc::G_unctrl", _wrap_G_unctrl},
-{"Grassc::G_sock_get_fname", _wrap_G_sock_get_fname},
-{"Grassc::G_sock_exists", _wrap_G_sock_exists},
-{"Grassc::G_sock_bind", _wrap_G_sock_bind},
-{"Grassc::G_sock_listen", _wrap_G_sock_listen},
-{"Grassc::G_sock_accept", _wrap_G_sock_accept},
-{"Grassc::G_sock_connect", _wrap_G_sock_connect},
-{"Grassc::G_verbose", _wrap_G_verbose},
-{"Grassc::G_verbose_min", _wrap_G_verbose_min},
-{"Grassc::G_verbose_std", _wrap_G_verbose_std},
-{"Grassc::G_verbose_max", _wrap_G_verbose_max},
-{"Grassc::G_set_verbose", _wrap_G_set_verbose},
-{"Grassc::G_3dview_warning", _wrap_G_3dview_warning},
-{"Grassc::G_get_3dview_defaults", _wrap_G_get_3dview_defaults},
-{"Grassc::G_put_3dview", _wrap_G_put_3dview},
-{"Grassc::G_get_3dview", _wrap_G_get_3dview},
-{"Grassc::G_whoami", _wrap_G_whoami},
-{"Grassc::G_adjust_window_to_box", _wrap_G_adjust_window_to_box},
-{"Grassc::G_format_northing", _wrap_G_format_northing},
-{"Grassc::G_format_easting", _wrap_G_format_easting},
-{"Grassc::G_format_resolution", _wrap_G_format_resolution},
-{"Grassc::G_point_in_region", _wrap_G_point_in_region},
-{"Grassc::G_point_in_window", _wrap_G_point_in_window},
-{"Grassc::G_limit_east", _wrap_G_limit_east},
-{"Grassc::G_limit_west", _wrap_G_limit_west},
-{"Grassc::G_limit_north", _wrap_G_limit_north},
-{"Grassc::G_limit_south", _wrap_G_limit_south},
-{"Grassc::G_window_overlap", _wrap_G_window_overlap},
-{"Grassc::G_window_percentage_overlap", _wrap_G_window_percentage_overlap},
-{"Grassc::G_scan_northing", _wrap_G_scan_northing},
-{"Grassc::G_scan_easting", _wrap_G_scan_easting},
-{"Grassc::G_scan_resolution", _wrap_G_scan_resolution},
-{"Grassc::G__create_window_mapping", _wrap_G__create_window_mapping},
-{"Grassc::G_northing_to_row", _wrap_G_northing_to_row},
-{"Grassc::G_adjust_east_longitude", _wrap_G_adjust_east_longitude},
-{"Grassc::G_adjust_easting", _wrap_G_adjust_easting},
-{"Grassc::G_easting_to_col", _wrap_G_easting_to_col},
-{"Grassc::G_row_to_northing", _wrap_G_row_to_northing},
-{"Grassc::G_col_to_easting", _wrap_G_col_to_easting},
-{"Grassc::G_window_rows", _wrap_G_window_rows},
-{"Grassc::G_window_cols", _wrap_G_window_cols},
-{"Grassc::G__init_window", _wrap_G__init_window},
-{"Grassc::G_row_repeat_nomask", _wrap_G_row_repeat_nomask},
-{"Grassc::G__write_Cell_head", _wrap_G__write_Cell_head},
-{"Grassc::G__write_Cell_head3", _wrap_G__write_Cell_head3},
-{"Grassc::G_write_zeros", _wrap_G_write_zeros},
-{"Grassc::G_yes", _wrap_G_yes},
-{"Grassc::G_zero", _wrap_G_zero},
-{"Grassc::G_zero_cell_buf", _wrap_G_zero_cell_buf},
-{"Grassc::G_zero_raster_buf", _wrap_G_zero_raster_buf},
-{"Grassc::G_zone", _wrap_G_zone},
-{"Grassc::r_slope_aspect", _wrap_r_slope_aspect},
-{0,0}
-static void SWIG_Perl_SetTypeListHandle(swig_type_info **handle) {
-    SV *pointer;
-    /* create a new pointer */
-    pointer = get_sv("swig_runtime_data::type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME, TRUE);
-    sv_setiv(pointer, PTR2IV(swig_type_list_handle));
-static swig_type_info **
-SWIG_Perl_LookupTypePointer(swig_type_info **type_list_handle) {
-    swig_type_info **type_pointer;
-    /* first check if module already created */
-    type_pointer = SWIG_Perl_GetTypeListHandle();
-    if (type_pointer) {
-        return type_pointer;
-    } else {
-        /* create a new module and variable */
-        SWIG_Perl_SetTypeListHandle(type_list_handle);
-        return type_list_handle;
-#ifdef __cplusplus
-extern "C"
-#endif
-XS(SWIG_init) {
-    dXSARGS;
-    int i;
-    static int _init = 0;
-    if (!_init) {
-        swig_type_list_handle = SWIG_Perl_LookupTypePointer(swig_type_list_handle);
-        for (i = 0; swig_types_initial[i]; i++) {
-            swig_types[i] = SWIG_TypeRegister(swig_types_initial[i]);
-        _init = 1;
-    /* Install commands */
-    for (i = 0; swig_commands[i].name; i++) {
-        newXS((char*) swig_commands[i].name,swig_commands[i].wrapper, (char*)__FILE__);
-    /* Install variables */
-    for (i = 0; swig_variables[i].name; i++) {
-        SV *sv;
-        sv = perl_get_sv((char*) swig_variables[i].name, TRUE | 0x2);
-        if (swig_variables[i].type) {
-            SWIG_MakePtr(sv,(void *)1, *swig_variables[i].type,0);
-        } else {
-            sv_setiv(sv,(IV) 0);
-        swig_create_magic(sv, (char *) swig_variables[i].name, swig_variables[i].set, swig_variables[i].get);
-    /* Install constant */
-    for (i = 0; swig_constants[i].type; i++) {
-        SV *sv;
-        sv = perl_get_sv((char*)swig_constants[i].name, TRUE | 0x2);
-        switch(swig_constants[i].type) {
-            case SWIG_INT:
-            sv_setiv(sv, (IV) swig_constants[i].lvalue);
-            break;
-            case SWIG_FLOAT:
-            sv_setnv(sv, (double) swig_constants[i].dvalue);
-            break;
-            case SWIG_STRING:
-            sv_setpv(sv, (char *) swig_constants[i].pvalue);
-            break;
-            case SWIG_POINTER:
-            SWIG_MakePtr(sv, swig_constants[i].pvalue, *(swig_constants[i].ptype),0);
-            break;
-            case SWIG_BINARY:
-            SWIG_MakePackedObj(sv, swig_constants[i].pvalue, swig_constants[i].lvalue, *(swig_constants[i].ptype));
-            break;
-            default:
-            break;
-        SvREADONLY_on(sv);
-    ST(0) = &PL_sv_yes;
-    XSRETURN(1);
