[GRASS-SVN] r31602 - grass-addons/vector/v.parallel2
Sun Jun 1 15:07:06 EDT 2008
Author: rmatev
Date: 2008-06-01 15:07:05 -0400 (Sun, 01 Jun 2008)
New Revision: 31602
Added:
   grass-addons/vector/v.parallel2/Makefile
   grass-addons/vector/v.parallel2/main.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
(almost) fixed parallel_line(), added features
Added: grass-addons/vector/v.parallel2/Makefile
--- grass-addons/vector/v.parallel2/Makefile	                        (rev 0)
+++ grass-addons/vector/v.parallel2/Makefile	2008-06-01 19:07:05 UTC (rev 31602)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = v.parallel2
+LIBES = $(VECTLIB) $(GISLIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c	                        (rev 0)
+++ grass-addons/vector/v.parallel2/main.c	2008-06-01 19:07:05 UTC (rev 31602)
@@ -0,0 +1,94 @@
+ * MODULE:       v.parallel
+ * AUTHOR(S):    Radim Blazek
+ * PURPOSE:      Create parallel lines
+ * COPYRIGHT:    (C) 2001 by the GRASS Development Team
+ *               This program is free software under the
+ *               GNU General Public License (>=v2).
+ *               Read the file COPYING that comes with GRASS
+ *               for details.
+ * TODO/BUG:     The vector segments are not properly connected
+ *               and should be snapped.
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+int
+main (int argc, char *argv[])
+    struct GModule *module;
+    struct Option *in_opt, *out_opt, *distance_opt;
+    struct Map_info In, Out;
+    struct line_pnts *Points, *Points2;
+    struct line_cats *Cats;
+    int    line, nlines;
+    double distance, tolerance;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("vector, geometry");
+    module->description = _("Create parallel line to input lines");
+    in_opt = G_define_standard_option(G_OPT_V_INPUT);
+    out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+    /* layer_opt = G_define_standard_option(G_OPT_V_FIELD); */
+    distance_opt = G_define_option();
+    distance_opt->key = "distance";
+    distance_opt->type =  TYPE_DOUBLE;
+    distance_opt->required = YES;
+    distance_opt->multiple = NO;
+    distance_opt->description = _("Offset in map units, positive for right side, "
+	                        "negative for left side.");
+    if (G_parser (argc, argv)) exit(EXIT_FAILURE);
+    /* layer = atoi ( layer_opt->answer ); */
+    distance = atof ( distance_opt->answer );
+    tolerance = distance/10.;
+    Vect_set_open_level (2);
+    Vect_open_old (&In, in_opt->answer, "");
+    Vect_open_new (&Out, out_opt->answer, 0);
+    Vect_copy_head_data (&In, &Out);
+    Vect_hist_copy (&In, &Out);
+    Vect_hist_command ( &Out );
+    Points = Vect_new_line_struct ();
+    Points2 = Vect_new_line_struct ();
+    Cats = Vect_new_cats_struct ();
+    nlines = Vect_get_num_lines ( &In );
+    for ( line = 1; line <= nlines; line++ ) {
+	int ltype;
+	G_percent ( line, nlines, 1 );
+	ltype = Vect_read_line ( &In, Points, Cats, line);
+	if ( ltype & GV_LINES ) {
+	    Vect_line_parallel ( Points, distance, tolerance, 1, Points2 );
+	    Vect_write_line ( &Out, ltype, Points2, Cats );
+	} else {
+	    Vect_write_line ( &Out, ltype, Points, Cats );
+    Vect_close (&In);
+    Vect_build (&Out, stderr);
+    Vect_close (&Out);
+    exit(EXIT_SUCCESS) ;
Added: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	                        (rev 0)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-06-01 19:07:05 UTC (rev 31602)
@@ -0,0 +1,612 @@
+/* Functions: nearest, adjust_line, parallel_line
+** Author: Radim Blazek Feb 2000
+#include <math.h>
+#define LENGTH(DX, DY)  (  sqrt( (DX*DX)+(DY*DY) )  )
+#define PI M_PI
+/* norm_vector() calculates normalized vector form two points */
+static void norm_vector(double x1, double y1, double x2, double y2, double *x, double *y )
+    double dx, dy, l;
+    dx  = x2 - x1;
+    dy  = y2 - y1;
+    l = LENGTH(dx, dy);
+    if (l == 0) {
+        /* assume that dx == dy == 0, which should give (NaN,NaN) */
+        /* without this, very small dx or dy could result in Infinity */
+        dx = dy = 0;
+    *x = dx/l;
+    *y = dy/l;
+/* find_cross find first crossing between segments from s1 to s2 and from s3 to s4
+** s5 is set to first segment and s6 to second
+** neighbours are taken as crossing each other only if overlap
+** returns: 1 found
+**         -1 found overlap
+**          0 not found
+int find_cross ( struct line_pnts *Points, int s1, int s2, int s3, int s4,  int *s5, int *s6 )
+    int i, j, np, ret;
+    double *x, *y;
+    G_debug (5, "find_cross(): npoints = %d, s1 = %d, s2 = %d, s3 = %d, s4 = %d",
+	                 Points->n_points, s1, s2, s3, s4 );
+    x = Points->x;
+    y = Points->y;
+    np = Points->n_points;
+    for ( i=s1; i<=s2; i++)
+	for ( j=s3; j<=s4; j++)
+	    if ( j==i ){
+		continue;
+	    ret = dig_test_for_intersection ( x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1] );
+	    if ( ret == 1 &&  ( (i-j) > 1 || (i-j) < -1 )  )
+		*s5 = i;
+		*s6 = j;
+                G_debug (5, "  intersection: s5 = %d, s6 = %d", *s5, *s6 );
+		return 1;
+	    if (  ret == -1  )
+		*s5 = i;
+		*s6 = j;
+                G_debug (5, "  overlap: s5 = %d, s6 = %d", *s5, *s6 );
+		return -1;
+    G_debug (5, "  no intersection" );
+    return 0;
+/* point_in_buf - test if point px,py is in d buffer of Points
+** returns:  1 in buffer
+**           0 not  in buffer
+int point_in_buf ( struct line_pnts *Points, double px, double py, double d )
+    int i, np;
+    double sd;
+    d *= d;
+    for ( i=0; i < np-1; i++)
+	sd = dig_distance2_point_to_line ( px, py, 0,
+		Points->x[i], Points->y[i], 0, Points->x[i+1], Points->y[i+1], 0,
+	        0, NULL, NULL, NULL, NULL, NULL	);
+	if ( sd <= d )
+	    return 1;
+    return 0;
+/* clean_parallel - clean parallel line created by parallel_line:
+** - looking for loops and if loop doesn't contain any other loop
+**   and centroid of loop is in buffer removes this loop (repeated)
+** - optionaly removes all end points in buffer
+*    parameters:
+*	Points - parallel line
+*	origPoints - original line
+*	d - offset
+*	rm_end - remove end points in buffer
+** note1: on some lines (multiply selfcrossing; lines with end points
+**        in buffer of line other; some shapes of ends ) may create nosense
+** note2: this function is stupid and slow, somebody more clever
+**        than I am should write paralle_line + clean_parallel
+**        better;    RB March 2000
+void clean_parallel ( struct line_pnts *Points, struct line_pnts *origPoints, double d , int rm_end )
+    int i, j, np, npn, sa, sb;
+    int sa_max = 0;
+    int first=0, current, last, lcount;
+    double *x, *y, px, py, ix, iy;
+    static struct line_pnts *sPoints = NULL;
+    G_debug (4, "clean_parallel(): npoints = %d, d = %f, rm_end = %d", Points->n_points, d, rm_end );
+    x = Points->x;
+    y = Points->y;
+    if ( sPoints == NULL )
+        sPoints = Vect_new_line_struct();
+    Vect_reset_line ( sPoints );
+    npn=1;
+    /* remove loops */
+    while( first < np-2 ){
+	/* find first loop which doesn't contain any other loop */
+	current=first;  last=Points->n_points-2;  lcount=0;
+	while( find_cross ( Points, current, last-1, current+1, last,  &sa, &sb ) != 0 )
+	    if ( lcount == 0 ){ first=sa; } /* move first forward */
+	    current=sa+1;
+	    last=sb;
+	    lcount++;
+            G_debug (5, "  current = %d, last = %d, lcount = %d", current, last, lcount);
+	if ( lcount == 0 ) { break; }   /* loop not found */
+	/* ensure sa is monotonically increasing, so npn doesn't reset low */
+	if (sa > sa_max ) sa_max = sa;
+	if (sa < sa_max ) break;
+	/* remove loop if in buffer */
+	if ( (sb-sa) == 1 ){ /* neighbouring lines overlap */
+	    j=sb+1;
+	    npn=sa+1;
+	} else {
+	    dig_find_intersection ( x[sa],y[sa],x[sa+1],y[sa+1],x[sb],y[sb],x[sb+1],y[sb+1], &ix,&iy);
+	    Vect_append_point ( sPoints, ix, iy, 0 );
+	    for ( i=sa+1 ; i < sb+1; i++ ) { /* create loop polygon */
+		Vect_append_point ( sPoints, x[i], y[i], 0 );
+	    Vect_find_poly_centroid  ( sPoints, &px, &py);
+	    if ( point_in_buf( origPoints, px, py, d )  ){ /* is loop in buffer ? */
+		npn=sa+1;
+		x[npn] = ix;
+		y[npn] = iy;
+		j=sb+1;
+		npn++;
+		if ( lcount == 0 ){ first=sb; }
+	    } else {  /* loop is not in buffer */
+		first=sb;
+	        continue;
+	for (i=j;i<Points->n_points;i++) /* move points down */
+	    x[npn] = x[i];
+	    y[npn] = y[i];
+	    npn++;
+	Points->n_points=npn;
+    if ( rm_end ) {
+	/* remove points from start in buffer */
+	j=0;
+	for (i=0;i<Points->n_points-1;i++)
+	    px=(x[i]+x[i+1])/2;
+	    py=(y[i]+y[i+1])/2;
+	    if ( point_in_buf ( origPoints, x[i], y[i], d*0.9999)
+		 && point_in_buf ( origPoints, px, py, d*0.9999) ){
+		j++;
+	    } else {
+		break;
+	if (j>0){
+	    npn=0;
+		x[npn] = x[i];
+		y[npn] = y[i];
+		npn++;
+	    Points->n_points = npn;
+	/* remove points from end in buffer */
+	j=0;
+	for (i=Points->n_points-1 ;i>=1; i--)
+	    px=(x[i]+x[i-1])/2;
+	    py=(y[i]+y[i-1])/2;
+		j++;
+	    } else {
+		break;
+	if (j>0){
+	    Points->n_points -= j;
+#ifdef this_is_comment
+/* parallel_line - remove duplicate points from input line and
+*  creates new parallel line in 'd' offset distance;
+*  'tol' is tolerance between arc and polyline;
+*  this function doesn't care about created loops;
+*  New line is written to existing nPoints structure.
+void parallel_line (struct line_pnts *Points, double d, double tol, struct line_pnts *nPoints)
+    int i, j, np, na, side;
+    double *x, *y, nx, ny, tx, ty, vx, vy, ux, uy, wx, wy;
+    double atol, atol2, a, av, aw;
+    G_debug (4, "parallel_line()" );
+    Vect_reset_line ( nPoints );
+    Vect_line_prune ( Points );
+    x = Points->x;
+    y = Points->y;
+    if ( np == 0 )
+	return;
+    if ( np == 1 ) {
+	Vect_append_point ( nPoints, x[0], y[0], 0 ); /* ? OK, should make circle for points ? */
+	return;
+    if ( d == 0 ) {
+	Vect_copy_xyz_to_pnts ( nPoints, x, y, NULL, np );
+	return;
+    side = (int)(d/fabs(d));
+    atol = 2 * acos( 1-tol/fabs(d) );
+    for (i = 0; i < np-1; i++)
+	norm_vector( x[i], y[i], x[i+1], y[i+1], &tx, &ty);
+	vx  = ty * d;
+	vy  = -tx * d;
+	nx = x[i] + vx;
+	ny = y[i] + vy;
+	Vect_append_point ( nPoints, nx, ny, 0 );
+	nx = x[i+1] + vx;
+	ny = y[i+1] + vy;
+	if ( i < np-2 ) {  /* use polyline instead of arc between line segments */
+	    norm_vector( x[i+1], y[i+1], x[i+2], y[i+2], &ux, &uy);
+	    wx  =  uy * d;
+	    wy  = -ux * d;
+	    av = atan2 ( vy, vx );
+	    aw = atan2 ( wy, wx );
+	    a = (aw - av) * side;
+	    if ( a < 0 )  a+=2*PI;
+            /* TODO: a <= PI can probably fail because of representation error */
+	    if ( a <= PI && a > atol)
+		na = (int) (a/atol);
+		atol2 = a/(na+1) * side;
+		for (j = 0; j < na; j++)
+		    av+=atol2;
+		    nx = x[i+1] + fabs(d) * cos(av);
+		    ny = y[i+1] + fabs(d) * sin(av);
+    Vect_line_prune ( nPoints );
+#endif
+* (x, y) shoud be normalized vector; This func transforms it to a vector corresponding to da, db, dalpha params
+static void elliptic_transform(double x, double y, double da, double db, double dalpha, double *nx, double *ny) {
+    double cosa = cos(dalpha);
+    double sina = sin(dalpha);
+    double cc = cosa*cosa;
+    double ss = sina*sina;
+    double t = (da-db)*sina*cosa;
+    *nx = (da*cc + db*ss)*x + t*y;
+    *ny = (da*ss + db*cc)*y + t*x;
+    return;
+* !!! This is not line in GRASS' sense. See http://en.wikipedia.org/wiki/Line_%28mathematics%29
+static void line_coefficients(double x1, double y1, double x2, double y2, double *a, double *b, double *c) {
+    *a = y2 - y1;
+    *b = x1 - x2;
+    *c = x2*y1 - x1*y2;
+    return;
+* Finds intersection of two straight lines. Returns 0 if the lines are parallel, 1 if they cross,
+* 2 if they are the same line.
+* !!!!!!!!!!!!!!!! FIX THIS TOLLERANCE CONSTANTS BAD (and UGLY) CODE !!!!!!!!!
+static int line_intersection(double a1, double b1, double c1, double a2, double b2, double c2, double *x, double *y) {
+    double ka = a2/a1;
+    double kb = b2/b1;
+    double kc;
+    double d;
+    if (fabs(ka - kb) < 1e-10) {
+        kc = c2/c1;
+        if (fabs(ka-kc) < 1e-10)
+            return 2;
+        else
+            return 0;
+    else {
+        d = a1*b2 - a2*b1;
+        *x = (b1*c2 - b2*c1)/d;
+        *y = (c1*a2 - c2*a1)/d;
+        return 1;
+* This function generates parallel line (with loops, but not like the old ones).
+* It is not to be used directly for creating buffers.
+* + added elliptical buffers/par.lines support
+* dalpha - direction of elliptical buffer major axis
+* da - distance along major axis
+* db: distance along minor (perp.) axis
+* side: side >= 0 - right side, side < 0 - left side
+* when (da == db) we have plain distances (old case)
+* round_corners - 1 for round, 0 for sharp. (tol is used only if round_corners == 1)
+* round_corners == 1 will be implemented soon
+void parallel_line(struct line_pnts *Points, double da, double db, double dalpha, double tol, int round_corners, struct line_pnts *nPoints)
+    int i, j, res, np, na;
+    double *x, *y;
+    double tx, ty, vx, vy, nx, ny, mx, my, rx, ry, side;
+    double a0, b0, c0, a1, b1, c1;
+    double ux, uy, wx, wy;
+    G_debug(4, "parallel_line2()");
+    x = Points->x;
+    y = Points->y;
+    if ( np == 0 )
+        return;
+    if ( np == 1 ) {
+        /* Vect_append_point ( nPoints, x[0], y[0], 0 ); /* ? OK, should make circle for points ? */
+        return;
+    if ((da == 0) && (db == 0)) {
+        Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
+        return;
+    side = (side >= 0)?(1):(-1);
+/*    atol = 2 * acos( 1-tol/fabs(d) ); */
+        norm_vector(x[i], y[i], x[i+1], y[i+1], &tx, &ty);
+        elliptic_transform(ty*side, -tx*side, da, db, dalpha, &vx, &vy);
+        nx = x[i] + vx;
+        ny = y[i] + vy;
+        mx = x[i+1] + vx;
+        my = y[i+1] + vy;
+        line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
+        if (i == 0) {
+            Vect_append_point(nPoints, nx, ny, 0);
+        else {
+            res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
+            if (res == 0) {
+                /* THIS ISN'T SUPPOSED TO HAPPEN, MUST THROW ERROR*/
+                G_fatal_error(("Two consequtive line segments are parallel, but not on one straight line!\nThis should never happen."));
+                return;
+            else if (res == 1) {
+                Vect_append_point(nPoints, rx, ry, 0);
+            /* else if (res == 2) do nothing */
+        if (i == np-2) {
+            Vect_append_point(nPoints, mx, my, 0);
+        a0 = a1;
+        b0 = b1;
+        c0 = c1;
+	if ( i < np-2 ) {   /*use polyline instead of arc between line segments
+	    wx  =  uy * d;
+	    wy  = -ux * d;
+             /*TODO: a <= PI can probably fail because of representation error
+		    av+=atol2;
+  \fn void Vect_line_parallel ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
+                       struct line_pnts *OutPoints )
+  \brief Create parrallel line
+  \param InPoints input line
+  \param distance
+  \param tolerance maximum distance between theoretical arc and polygon segments
+  \param rm_end remove end points falling into distance
+  \param OutPoints output line
+void
+Vect_line_parallel ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
+    G_debug (4, "Vect_line_parallel(): npoints = %d, distance = %f, tolerance = %f",
+	          InPoints->n_points, distance, tolerance);
+/*    parallel_line ( InPoints, distance, tolerance, OutPoints);  */
+    parallel_line (InPoints, distance, distance, 0, tolerance, 0, OutPoints);
+    /*clean_parallel ( OutPoints, InPoints, distance, rm_end );*/
+  \fn void Vect_line_buffer ( struct line_pnts *InPoints, double distance, double tolerance,
+  \brief Create buffer around the line line.
+         Buffer is closed counter clockwise polygon.
+         Warning: output line may contain loops!
+  \param distance
+void
+Vect_line_buffer ( struct line_pnts *InPoints, double distance, double tolerance,
+    double dangle;
+    int    side, npoints;
+    static struct line_pnts *Points = NULL;
+    static struct line_pnts *PPoints = NULL;
+    distance = fabs (distance );
+    dangle = 2 * acos( 1-tolerance/fabs(distance) ); /* angle step */
+    if ( Points == NULL )
+        Points = Vect_new_line_struct();
+    if ( PPoints == NULL )
+        PPoints = Vect_new_line_struct();
+    /* Copy and prune input */
+    Vect_reset_line ( Points );
+    Vect_append_points ( Points, InPoints, GV_FORWARD );
+    Vect_reset_line ( OutPoints );
+    npoints = Points->n_points;
+    if ( npoints <= 0 ) {
+	return;
+    } else if ( npoints == 1 ) { /* make a circle */
+	double angle, x, y;
+	for ( angle = 0; angle < 2*PI; angle += dangle ) {
+	    x = Points->x[0] + distance * cos( angle );
+	    y = Points->y[0] + distance * sin( angle );
+	    Vect_append_point ( OutPoints, x, y, 0 );
+	/* Close polygon */
+	Vect_append_point ( OutPoints, OutPoints->x[0], OutPoints->y[0], 0 );
+    } else { /* 2 and more points */
+	for ( side = 0; side < 2; side++ ) {
+	    double angle, sangle;
+	    double lx1, ly1, lx2, ly2;
+	    double x, y, nx, ny, sx, sy, ex, ey;
+	    /* Parallel on one side */
+	    if ( side == 0 ) {
+		Vect_line_parallel ( Points, distance, tolerance, 0, PPoints );
+		Vect_append_points ( OutPoints, PPoints, GV_FORWARD );
+	    } else {
+		Vect_line_parallel ( Points, -distance, tolerance, 0, PPoints );
+		Vect_append_points ( OutPoints, PPoints, GV_BACKWARD );
+	    /* Arc at the end */
+	    /* 2 points at theend of original line */
+		lx1 = Points->x[npoints-2];
+		ly1 = Points->y[npoints-2];
+		lx2 = Points->x[npoints-1];
+		ly2 = Points->y[npoints-1];
+	    } else {
+		lx1 = Points->x[1];
+		ly1 = Points->y[1];
+		lx2 = Points->x[0];
+		ly2 = Points->y[0];
+	    /* normalized vector */
+	    norm_vector( lx1, ly1, lx2, ly2, &nx, &ny);
+	    /* starting point */
+	    sangle = atan2 ( -nx, ny ); /* starting angle */
+	    sx  = lx2 + ny * distance;
+	    sy  = ly2 - nx * distance;
+	    /* end point */
+	    ex  = lx2 - ny * distance;
+	    ey  = ly2 + nx * distance;
+	    Vect_append_point ( OutPoints, sx, sy, 0 );
+	    /* arc */
+	    for ( angle = dangle; angle < PI; angle += dangle ) {
+		x = lx2 + distance * cos( sangle + angle );
+		y = ly2 + distance * sin( sangle + angle );
+	    Vect_append_point ( OutPoints, ex, ey, 0 );
+    Vect_line_prune ( OutPoints );
