[GRASS-SVN] r31651 - grass-addons/vector/v.parallel2
Sat Jun 7 08:56:26 EDT 2008
Author: rmatev
Date: 2008-06-07 08:56:26 -0400 (Sat, 07 Jun 2008)
New Revision: 31651
   grass-addons/vector/v.parallel2/main.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
Added cmdline options in v.parallel2
Modified: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c	2008-06-06 16:17:02 UTC (rev 31650)
+++ grass-addons/vector/v.parallel2/main.c	2008-06-07 12:56:26 UTC (rev 31651)
@@ -2,7 +2,7 @@
  * MODULE:       v.parallel
- * AUTHOR(S):    Radim Blazek
+ * AUTHOR(S):    Radim Blazek, Rosen Matev
  * PURPOSE:      Create parallel lines
@@ -22,16 +22,18 @@
 #include <grass/Vect.h>
 #include <grass/glocale.h>
-int
-main (int argc, char *argv[])
+int main (int argc, char *argv[])
     struct GModule *module;
-    struct Option *in_opt, *out_opt, *distance_opt;
+    struct Option *in_opt, *out_opt, *dista_opt;
+    struct Option *distb_opt, *angle_opt, *side_opt;
+    struct Flag *round_flag, *loops_flag;
     struct Map_info In, Out;
     struct line_pnts *Points, *Points2;
     struct line_cats *Cats;
     int    line, nlines;
-    double distance, tolerance;
+    double da, db, dalpha, tolerance;
+    int side;
     G_gisinit(argv[0]);
@@ -43,19 +45,57 @@
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
     /* layer_opt = G_define_standard_option(G_OPT_V_FIELD); */
-    distance_opt = G_define_option();
-    distance_opt->key = "distance";
-    distance_opt->type =  TYPE_DOUBLE;
-    distance_opt->required = YES;
-    distance_opt->multiple = NO;
-    distance_opt->description = _("Offset in map units, positive for right side, "
-	                        "negative for left side.");
+    dista_opt = G_define_option();
+    dista_opt->key = "dista";
+    dista_opt->type =  TYPE_DOUBLE;
+    dista_opt->required = YES;
+    dista_opt->multiple = NO;
+    dista_opt->description = _("Offset along major axis in map units");
-    if (G_parser (argc, argv)) exit(EXIT_FAILURE);
+    distb_opt = G_define_option();
+    distb_opt->key = "distb";
+    distb_opt->type =  TYPE_DOUBLE;
+    distb_opt->required = YES;
+    distb_opt->multiple = NO;
+    distb_opt->description = _("Offset along minor axis in map units");
+    angle_opt = G_define_option();
+    angle_opt->key = "angle";
+    angle_opt->type =  TYPE_DOUBLE;
+    angle_opt->required = YES;
+    angle_opt->answer = "0";
+    angle_opt->multiple = NO;
+    angle_opt->description = _("Angle of major axis in degrees");
+    side_opt = G_define_option();
+    side_opt->key = "side";
+    side_opt->type =  TYPE_STRING;
+    side_opt->required = YES;
+    side_opt->answer = "right";
+    side_opt->multiple = NO;
+    side_opt->options = "left,right";
+    side_opt->description = _("left;Parallel line is on the left;right;Parallel line is on the right;");
+    round_flag = G_define_flag();
+    round_flag->key = 'r';
+    round_flag->description = _("Make outside corners round");
+    loops_flag = G_define_flag();
+    loops_flag->key = 'l';
+    loops_flag->description = _("Don't remove loops");
+    if (G_parser (argc, argv))
+        exit(EXIT_FAILURE);
     /* layer = atoi ( layer_opt->answer ); */
-    distance = atof ( distance_opt->answer );
-    tolerance = distance/10.;
+    da = atof(dista_opt->answer);
+    db = atof(distb_opt->answer);
+    dalpha = atof(angle_opt->answer);
+    tolerance = ((da>db)?da:db)/10.;
+    if (strcmp(side_opt->answer, "right"))
+        side = 1;
+    else if (strcmp(side_opt->answer, "left"))
+        side = -1;
     Vect_set_open_level (2);
     Vect_open_old (&In, in_opt->answer, "");
@@ -71,18 +111,18 @@
     nlines = Vect_get_num_lines ( &In );
     for ( line = 1; line <= nlines; line++ ) {
-	int ltype;
-	G_percent ( line, nlines, 1 );
-	ltype = Vect_read_line ( &In, Points, Cats, line);
-	if ( ltype & GV_LINES ) {
-	    Vect_line_parallel ( Points, distance, tolerance, 1, Points2 );
-	    Vect_write_line ( &Out, ltype, Points2, Cats );
-	} else {
-	    Vect_write_line ( &Out, ltype, Points, Cats );
+        int ltype;
+        G_percent ( line, nlines, 1 );
+        ltype = Vect_read_line ( &In, Points, Cats, line);
+        if ( ltype & GV_LINES ) {
+            Vect_line_parallel2(Points, da, db, dalpha, side, round_flag->answer, loops_flag->answer, tolerance, Points2);
+            Vect_write_line(&Out, ltype, Points2, Cats);
+        } else {
+            Vect_write_line(&Out, ltype, Points, Cats);
     Vect_close (&In);
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-06-06 16:17:02 UTC (rev 31650)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-06-07 12:56:26 UTC (rev 31651)
@@ -369,25 +369,26 @@
 * It is not to be used directly for creating buffers.
 * + added elliptical buffers/par.lines support
-* dalpha - direction of elliptical buffer major axis
+* dalpha - direction of elliptical buffer major axis in degrees
 * da - distance along major axis
 * db: distance along minor (perp.) axis
 * side: side >= 0 - right side, side < 0 - left side
 * when (da == db) we have plain distances (old case)
-* round_corners - 1 for round, 0 for sharp. (tol is used only if round_corners == 1)
-* round_corners == 1 will be implemented soon
+* round - 1 for round corners, 0 for sharp corners. (tol is used only if round == 1)
+* round == 1 will be implemented soon
-void parallel_line(struct line_pnts *Points, double da, double db, double dalpha, double tol, int round_corners, struct line_pnts *nPoints)
+void parallel_line(struct line_pnts *Points, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *nPoints)
     int i, j, res, np, na;
     double *x, *y;
-    double tx, ty, vx, vy, nx, ny, mx, my, rx, ry, side;
+    double tx, ty, vx, vy, nx, ny, mx, my, rx, ry;
     double a0, b0, c0, a1, b1, c1;
     double ux, uy, wx, wy;
     double atol, atol2, a, av, aw;
     G_debug(4, "parallel_line2()");
+    dalpha *= 180/PI;
     Vect_reset_line ( nPoints );
     Vect_line_prune ( Points );
@@ -414,7 +415,7 @@
     for (i = 0; i < np-1; i++)
         norm_vector(x[i], y[i], x[i+1], y[i+1], &tx, &ty);
-        elliptic_transform(ty*side, -tx*side, da, db, dalpha, &vx, &vy);
+        elliptic_transform(-ty*side, tx*side, da, db, dalpha, &vx, &vy);
         nx = x[i] + vx;
         ny = y[i] + vy;
@@ -476,8 +477,8 @@
     Vect_line_prune ( nPoints );
-  \fn void Vect_line_parallel ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
+  \fn void Vect_line_parallel2 ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
                        struct line_pnts *OutPoints )
   \brief Create parrallel line
   \param InPoints input line
@@ -486,17 +487,16 @@
   \param rm_end remove end points falling into distance
   \param OutPoints output line
-void
-Vect_line_parallel ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
-                     struct line_pnts *OutPoints )
+void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, int loops, double tol, struct line_pnts *OutPoints )
-    G_debug (4, "Vect_line_parallel(): npoints = %d, distance = %f, tolerance = %f",
-	          InPoints->n_points, distance, tolerance);
+    G_debug(4, "Vect_line_parallel(): npoints = %d, da = %f, db = %f, dalpha = %f, side = %d, round_corners = %d, loops = %d, tol = %f",
+            InPoints->n_points, da, db, dalpha, side, round, loops, tol);
-/*    parallel_line ( InPoints, distance, tolerance, OutPoints);  */
-    parallel_line (InPoints, distance, distance, 0, tolerance, 0, OutPoints);
-    /*clean_parallel ( OutPoints, InPoints, distance, rm_end );*/
+    parallel_line (InPoints, da, db, dalpha, side, round, tol, OutPoints);
+/*    if (!loops)
+        clean_parallel(OutPoints, InPoints, distance, rm_end);
