[GRASS-SVN] r31655 - grass/branches/develbranch_6/db/drivers/sqlite
Mon Jun 9 03:41:57 EDT 2008
Author: neteler
Date: 2008-06-09 03:41:56 -0400 (Mon, 09 Jun 2008)
New Revision: 31655
   grass/branches/develbranch_6/db/drivers/sqlite/describe.c
case order fixed (cosmetics); docs added (merge from trunk)
Modified: grass/branches/develbranch_6/db/drivers/sqlite/describe.c
--- grass/branches/develbranch_6/db/drivers/sqlite/describe.c	2008-06-09 07:41:42 UTC (rev 31654)
+++ grass/branches/develbranch_6/db/drivers/sqlite/describe.c	2008-06-09 07:41:56 UTC (rev 31655)
@@ -168,14 +168,16 @@
 	    fsize = 20;
 	    break;
+	case SQLITE_FLOAT:
+	    fsize = 20;
+	    break;
 	case SQLITE_TEXT:
 	    fsize = 255;
 	    break;
-	case SQLITE_FLOAT:
-	    fsize = 20;
-	    break;
+	/* SQLITE_BLOB, SQLITE_NULL needed here? */
 	default:
 	    fsize = 99999; /* sqlite doesn't care, it must be long enough to
                           satisfy tests in GRASS */
@@ -253,19 +255,43 @@
     G_debug ( 3, "litetype = %d", *litetype );
+    /* http://www.sqlite.org/capi3ref.html#sqlite3_column_type
+           SQLITE_INTEGER  1
+           SQLITE_FLOAT    2
+           SQLITE_TEXT     3
+           SQLITE_BLOB     4
+           SQLITE_NULL     5
+       lib/db/dbmi_base/sqltype.c:
+           DB_SQL_TYPE_CHARACTER:        0 "CHARACTER"
+           DB_SQL_TYPE_NUMERIC:          1 "NUMERIC"
+           DB_SQL_TYPE_DECIMAL:          2 "DECIMAL"
+           DB_SQL_TYPE_SMALLINT:         3 "SMALLINT"
+           DB_SQL_TYPE_INTEGER:          4 "INTEGER"
+           DB_SQL_TYPE_REAL:             5 "REAL"
+           DB_SQL_TYPE_DOUBLE_PRECISION: 6 "DOUBLE PRECISION"
+           DB_SQL_TYPE_DATE:             7 "DATE"
+           DB_SQL_TYPE_TIME:             8 "TIME"
+           DB_SQL_TYPE_SERIAL:           9 "SERIAL"
+           DB_SQL_TYPE_TEXT:             10 "TEXT"
+           DB_SQL_TYPE_TIMESTAMP:        11 "TIMESTAMP"
+           DB_SQL_TYPE_INTERVAL:         12 "INTERVAL"
+           default                       13 "unknown"
     switch ( *litetype) {
 	case SQLITE_INTEGER:
 	    *sqltype = DB_SQL_TYPE_INTEGER;
 	    break;
+	    *sqltype = DB_SQL_TYPE_DOUBLE_PRECISION;
+	    break;
 	case SQLITE_TEXT:
 	    *sqltype = DB_SQL_TYPE_TEXT;
 	    break;
-	    *sqltype = DB_SQL_TYPE_DOUBLE_PRECISION;
-	    break;
 	case SQLITE_NULL:
 	    *sqltype = DB_SQL_TYPE_TEXT; /* good choice? */
 	    break;
