[GRASS-SVN] r31681 - grass/branches/develbranch_6/lib/vector/Vlib
Wed Jun 11 15:42:45 EDT 2008
Author: martinl
Date: 2008-06-11 15:42:45 -0400 (Wed, 11 Jun 2008)
New Revision: 31681
   grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
vlib: print number of vertices in build output
Modified: grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
--- grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c	2008-06-11 19:24:39 UTC (rev 31680)
+++ grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c	2008-06-11 19:42:45 UTC (rev 31681)
@@ -406,7 +406,7 @@
     struct Plus_head *plus ;
     int    i, j, s, type, lineid;
-    long offset;
+    long   offset;
     int    side, line, area;
     struct line_pnts *Points, *APoints;
     struct line_cats *Cats;
@@ -474,6 +474,7 @@
     List = Vect_new_list ();
     if ( plus->built < GV_BUILD_BASE ) {
+	int npoints;
 	*  We shall go through all primitives in coor file and
 	*  add new node for each end point to nodes structure
@@ -482,11 +483,13 @@
 	/* register lines, create nodes */
 	Vect_rewind ( Map );
-	prnmsg (_("Registering lines: "));
+	prnmsg (_("Registering primitives: "));
 	i = 1; j = 1;
+	npoints = 0;
 	while ( 1 ) {
 	    /* register line */
 	    type = Vect_read_next_line (Map, Points, Cats);
 	    /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
 	    if ( type == -1 ) {
 		G_warning(_("Unable to read vector map"));
@@ -494,6 +497,8 @@
 	    } else if ( type == -2 ) {
 		break;
+	    npoints += Points->n_points;
 	    offset = Map->head.last_offset;
@@ -523,7 +528,8 @@
 	    i++; j++;
-	prnmsg ("\r%d %s      \n", plus->n_lines, _("primitives registered"));
+	prnmsg ("\r%d %s            \n", npoints, _("vertices registered"));
+	prnmsg ("%d %s\n", plus->n_lines, _("primitives registered"));
 	plus->built = GV_BUILD_BASE;
