[GRASS-SVN] r31684 - grass/trunk/lib/ogsf
Wed Jun 11 16:02:51 EDT 2008
Author: martinl
Date: 2008-06-11 16:02:51 -0400 (Wed, 11 Jun 2008)
New Revision: 31684
   grass/trunk/lib/ogsf/GS2.c
   grass/trunk/lib/ogsf/GV2.c
   grass/trunk/lib/ogsf/gsd_prim.c
   grass/trunk/lib/ogsf/gsdrape.c
   grass/trunk/lib/ogsf/gv.c
   grass/trunk/lib/ogsf/gvd.c
ogsflib: doxygen strings updated, debug messages cosmetics (merge devbr6, r31683)
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/GS2.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -187,7 +187,7 @@
     int i, found = 0;
-    G_debug(3, "GS_surf_exists");
+    G_debug(3, "GS_surf_exists(): id=%d", id);
     if (NULL == gs_get_surf(id)) {
Modified: grass/trunk/lib/ogsf/GV2.c
--- grass/trunk/lib/ogsf/GV2.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/GV2.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -64,14 +64,14 @@
     geovect *nv;
-    G_debug(3, "GV_new_vector");
     if (Next_vect < MAX_VECTS) {
 	nv = gv_get_new_vect();
 	gv_set_defaults(nv);
 	Vect_ID[Next_vect] = nv->gvect_id;
 	++Next_vect;
+	G_debug(3, "GV_new_vector(): id=%d", nv->gvect_id);
 	return (nv->gvect_id);
@@ -220,10 +220,10 @@
   \brief Set vector set mode
   \param id vector set id
-  \param mem
+  \param mem non-zero for use memory
   \param color color value
-  \param width
-  \param flat
+  \param width line width
+  \param flat non-zero for flat mode
   \return -1 on error (invalid vector set id)
   \return 1 on success
Modified: grass/trunk/lib/ogsf/gsd_prim.c
--- grass/trunk/lib/ogsf/gsd_prim.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/gsd_prim.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -248,7 +248,7 @@
-  \brief ADD
+  \brief Set width of rasterized lines
   \param n line width
Modified: grass/trunk/lib/ogsf/gsdrape.c
--- grass/trunk/lib/ogsf/gsdrape.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/gsdrape.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -50,6 +50,7 @@
 #include <stdlib.h>
 #include <grass/gstypes.h>
+#include <grass/glocale.h>
 #include "gsget.h"
 #include "rowcol.h"
@@ -66,10 +67,6 @@
 #define SAME_SIGNS( a, b ) \
     ((a >= 0 && b >= 0) || (a < 0 && b < 0))
-#define DEBUGDRAPE
 static int drape_line_init(int, int);
 static Point3 *_gsdrape_get_segments(geosurf *, float *, float *, int *);
 static float dist_squared_2d(float *, float *);
@@ -87,38 +84,56 @@
 static int Flat;
+  \brief Initizalize
+  \param rows number of rows
+  \param cols number of columns
+  \return -1 on failure
+  \return 1 on success
 static int drape_line_init(int rows, int cols)
+    /* use G_calloc() [-> G_fatal_error] instead of calloc ? */
     if (NULL == (I3d = (Point3 *) calloc(2 * (rows + cols), sizeof(Point3)))) {
-	return (-1);		/* exit? */
+	return (-1);
     if (NULL == (Vi = (Point3 *) calloc(cols, sizeof(Point3)))) {
-	free(I3d);
+	G_free(I3d);
+	return (-1);
     if (NULL == (Hi = (Point3 *) calloc(rows, sizeof(Point3)))) {
-	free(I3d);
-	free(Vi);
+	G_free(I3d);
+	G_free(Vi);
+	return (-1);
     if (NULL == (Di = (Point3 *) calloc(rows + cols, sizeof(Point3)))) {
-	free(I3d);
-	free(Vi);
-	free(Hi);
+	G_free(I3d);
+	G_free(Vi);
+	G_free(Hi);
+	return (-1);
     return (1);
+  \brief Get segments
+  \param gs surface (geosurf)
+  \param bgn begin point
+  \param end end point
+  \param num
+  \return pointer to Point3 struct
 static Point3 *_gsdrape_get_segments(geosurf * gs, float *bgn, float *end,
 				     int *num)
@@ -149,17 +164,20 @@
     *num = order_intersects(gs, f, l, vi, hi, di);
     /* fills in return values, eliminates dupes (corners) */
-#ifdef DEBUGDRAPE
-	fprintf(stderr, "vi = %d \thi = %d \tdi = %d\n", vi, hi, di);
-	fprintf(stderr, "num = %d\n", *num);
-#endif
+    G_debug(4, "_gsdrape_get_segments vi=%d, hi=%d, di=%d, num=%d",
+	    vi, hi, di, *num);
     return (I3d);
+  \brief Calculate 2D distance
+  \param p1 first point
+  \param p2 second point
+  \return distance
 static float dist_squared_2d(float *p1, float *p2)
     float dx, dy;
@@ -170,7 +188,14 @@
     return (dx * dx + dy * dy);
+  \brief ADD
 int gsdrape_set_surface(geosurf * gs)
     static int first = 1;
@@ -179,7 +204,7 @@
 	first = 0;
 	if (0 > drape_line_init(gs->rows, gs->cols)) {
-	    fprintf(stderr, "Unable to process vector - out of memory!\n");
+	    G_warning (_("Unable to process vector map - out of memory"));
 	    Ebuf = NULL;
 	    return (-1);
@@ -191,12 +216,19 @@
     return (1);
- * returns 0 if segment doesn't intersect the viewregion, or intersects
- * only at corner, otherwise returns 1.
- * Clipping performed:
- * bgn and end are replaced so that both points are within viewregion
- * if seg intersects
+  \brief Check if segment intersect vector region
+  Clipping performed:
+   - bgn and end are replaced so that both points are within viewregion
+   - if seg intersects
+   \return 0 if segment doesn't intersect the viewregion, or intersects only at corner
+   \return otherwise returns 1
 int seg_intersect_vregion(geosurf * gs, float *bgn, float *end)
@@ -305,7 +337,16 @@
     return (1);
+  \brief ADD
+  \param bgn begin point (x,y)
+  \param end end point (x,y)
+  \param num
 Point3 *gsdrape_get_segments(geosurf * gs, float *bgn, float *end, int *num)
     gsdrape_set_surface(gs);
@@ -347,7 +388,16 @@
+  \brief Get all segments
+  \param num
 Point3 *gsdrape_get_allsegments(geosurf * gs, float *bgn, float *end,
 				int *num)
@@ -379,7 +429,15 @@
     return (_gsdrape_get_segments(gs, bgn, end, num));
+  \brief ADD
+  \param f first
+  \param l last
 void interp_first_last(geosurf * gs, float *bgn, float *end, Point3 f,
 		       Point3 l)
@@ -400,7 +458,12 @@
     return;
+  \brief ADD
+  \param pt
 int _viewcell_tri_interp(geosurf * gs, Point3 pt)
     typbuff *buf;
@@ -410,8 +473,11 @@
     return (viewcell_tri_interp(gs, buf, pt, 0));
-/* In gsd_surf, tmesh draws polys like so:
+  \brief ADD
+  In gsd_surf, tmesh draws polys like so:
+  <pre>
@@ -426,13 +492,17 @@
+   </pre>
    UNLESS the top right or bottom left point is masked, in which case a
    single triangle with the opposite diagonal is drawn.  This case is
    not yet handled here & should only occur on edges.
-   pt has X & Y coordinates in it, we interpolate Z here & return:
-   1 if point is in view region, otherwise 0.
-   Returns 0 if masked.
-   This could probably be much shorter, but not much faster.
+   pt has X & Y coordinates in it, we interpolate Z here
+   This could probably be much shorter, but not much faster.
+   \return 1 if point is in view region
+   \return otherwise 0 (if masked)
 int viewcell_tri_interp(geosurf * gs, typbuff * buf, Point3 pt,
 			int check_mask)
@@ -615,7 +685,14 @@
     return (0);
+  \brief ADD
+  \return 1
+  \return 0
 int in_vregion(geosurf * gs, float *pt)
     if (pt[X] >= 0.0 && pt[Y] <= gs->yrange) {
@@ -627,15 +704,27 @@
     return (0);
-* After all the intersections between the segment and triangle
-* edges have been found, they are in three lists.  (intersections
-* with vertical, horizontal, and diagonal triangle edges)
-* Each list is ordered in space from first to last segment points,
-* but now the lists need to be woven together.  This routine
-* starts with the first point of the segment and then checks the
-* next point in each list to find the closest, eliminating duplicates
-* along the way and storing the result in I3d.
+  \brief ADD
+  After all the intersections between the segment and triangle
+  edges have been found, they are in three lists.  (intersections
+  with vertical, horizontal, and diagonal triangle edges)
+  Each list is ordered in space from first to last segment points,
+  but now the lists need to be woven together.  This routine
+  starts with the first point of the segment and then checks the
+  next point in each list to find the closest, eliminating duplicates
+  along the way and storing the result in I3d.
+  \param first first point
+  \param last last point
+  \param vi
+  \param hi
+  \param di
+  \return
 int order_intersects(geosurf * gs, Point3 first, Point3 last, int vi, int hi,
 		     int di)
@@ -748,9 +837,9 @@
 	if (i == cv + ch + cd) {
-	    fprintf(stderr, "stuck on %d\n", cnum);
-	    fprintf(stderr, "cv = %d, ch = %d, cd = %d\n", cv, ch, cd);
-	    fprintf(stderr, "dv = %f, dh = %f, dd = %f\n", dv, dh, dd);
+	    G_debug(4, "order_intersects(): stuck on %d", cnum);
+	    G_debug(4, "order_intersects(): cv = %d, ch = %d, cd = %d", cv, ch, cd);
+	    G_debug(4, "order_intersects(): dv = %f, dh = %f, dd = %f", dv, dh, dd);
 	    break;
@@ -771,12 +860,23 @@
     return (cnum);
-/* TODO: for consistancy, need to decide how last row & last column are
-   displayed - would it look funny to always draw last row/col with
-   finer resolution if necessary, or would it be better to only show
-   full rows/cols? */
-/* colinear already eliminated */
+  \brief ADD
+  \todo For consistancy, need to decide how last row & last column are
+  displayed - would it look funny to always draw last row/col with
+  finer resolution if necessary, or would it be better to only show
+  full rows/cols?
+  Colinear already eliminated
+  \param dir direction
+  \return
 int get_vert_intersects(geosurf * gs, float *bgn, float *end, float *dir)
     int fcol, lcol, incr, hits, num, offset, drow1, drow2;
@@ -863,7 +963,16 @@
     return (hits);
+  \brief Get horizontal intersects
+  \param dir
+  \return number of intersects
 int get_horz_intersects(geosurf * gs, float *bgn, float *end, float *dir)
     int frow, lrow, incr, hits, num, offset, dcol1, dcol2;
@@ -948,9 +1057,18 @@
     return (hits);
+  \brief Get diagonal intersects
+  \param dir ? (unused)
 int get_diag_intersects(geosurf * gs, float *bgn, float *end, float *dir)
     int fdig, ldig, incr, hits, num, offset;
@@ -1067,30 +1185,26 @@
     return (hits);
-/* lines_intersect:  AUTHOR: Mukesh Prasad
- * modified for floating point: Bill Brown
- *   This function computes whether two line segments,
- *   respectively joining the input points (x1,y1) -- (x2,y2)
- *   and the input points (x3,y3) -- (x4,y4) intersect.
- *   If the lines intersect, the output variables x, y are
- *   set to coordinates of the point of intersection.
- *   Entry
- *        x1, y1,  x2, y2   Coordinates of endpoints of one segment.
- *        x3, y3,  x4, y4   Coordinates of endpoints of other segment.
- *   Exit
- *        x, y              Coordinates of intersection point.
- *   The value returned by the function is one of:
- *        DONT_INTERSECT    0
- *        DO_INTERSECT      1
- *        COLLINEAR         2
+  \brief Line intersect
+  Author: Mukesh Prasad
+  Modified for floating point: Bill Brown
+  This function computes whether two line segments,
+  respectively joining the input points (x1,y1) -- (x2,y2)
+  and the input points (x3,y3) -- (x4,y4) intersect.
+  If the lines intersect, the output variables x, y are
+  set to coordinates of the point of intersection.
+  \param x1,y1,x2,y2 coordinates of endpoints of one segment
+  \param x3,y3,x4,y4 coordinates of endpoints of other segment
+  \param[out] x,y coordinates of intersection point
+  \return 0 no intersection
+  \return 1 intersect
+  \return 2 collinear
 int segs_intersect(float x1, float y1, float x2, float y2, float x3, float y3,
 		   float x4, float y4, float *x, float *y)
@@ -1160,8 +1274,17 @@
     return (DO_INTERSECT);
-/* Plane defined by three points here; user fills in unk[X] & unk[Y] */
+  \brief Check if point is on plane
+  Plane defined by three points here; user fills in unk[X] & unk[Y]
+  \param p1,p2,p3 points defining plane
+  \param unk point
+  \return 1 point on plane
+  \return 0 point not on plane
 int Point_on_plane(Point3 p1, Point3 p2, Point3 p3, Point3 unk)
     float plane[4];
@@ -1171,9 +1294,19 @@
     return (XY_intersect_plane(unk, plane));
-/* Ax + By + Cz + D = 0, so z = (Ax + By + D) / -C */
-/* user fills in intersect[X] & intersect[Y] */
+  \brief Check for intersection (point and plane)
+  Ax + By + Cz + D = 0, so z = (Ax + By + D) / -C
+  User fills in intersect[X] & intersect[Y]
+  \param[out] intersect intersect coordinates
+  \param plane plane definition
+  \return 0 doesn't intersect
+  \return 1 intesects
 int XY_intersect_plane(float *intersect, float *plane)
     float x, y;
@@ -1189,7 +1322,14 @@
     return (1);
+  \brief Define plane
+  \param p1,p2,p3 three point on plane
+  \param[out] plane plane defintion
+  \return 1
 int P3toPlane(Point3 p1, Point3 p2, Point3 p3, float *plane)
     Point3 v1, v2, norm;
@@ -1213,12 +1353,18 @@
-/* return the cross product c = a cross b */
+  \brief Get cross product
+  \param a,b,c
+  \return cross product c = a cross b
 int V3Cross(Point3 a, Point3 b, Point3 c)
     c[X] = (a[Y] * b[Z]) - (a[Z] * b[Y]);
     c[Y] = (a[Z] * b[X]) - (a[X] * b[Z]);
     c[Z] = (a[X] * b[Y]) - (a[Y] * b[X]);
     return (1);
Modified: grass/trunk/lib/ogsf/gv.c
--- grass/trunk/lib/ogsf/gv.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/gv.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -120,8 +120,6 @@
     geovect *nv, *lv;
-    G_debug(4, "gv_get_new_vect()");
     nv = (geovect *) G_malloc(sizeof(geovect));
     if (!nv) {
 	/* G_fatal_error */
@@ -139,6 +137,8 @@
     nv->next = NULL;
+    G_debug(4, "gv_get_new_vect() id=%d", nv->gvect_id);
     return (nv);
Modified: grass/trunk/lib/ogsf/gvd.c
--- grass/trunk/lib/ogsf/gvd.c	2008-06-11 19:58:41 UTC (rev 31683)
+++ grass/trunk/lib/ogsf/gvd.c	2008-06-11 20:02:51 UTC (rev 31684)
@@ -1,7 +1,7 @@
   \file gvd.c
-  \brief OGSF library - loading and manipulating vector sets
+  \brief OGSF library - loading and manipulating vector sets (lower level functions)
   GRASS OpenGL gsurf OGSF Library
@@ -13,28 +13,33 @@
   for details.
   \author Bill Brown USACERL (December 1993)
+  \author Doxygenized by Martin Landa (June 2008)
 #include <stdio.h>
 #include <stdlib.h>
 #include <grass/gis.h>
 #include "rowcol.h"
-#define DEBUGVECT
-#define DEBUGVECT_2
-#ifdef DEBUGVECT
-static int K=0;
-#endif
 #define CHK_FREQ 5
 /* check for cancel every CHK_FREQ lines */
-/* FIX to use fast clipping and move to gs.c */
+  \brief Clip segment
+  \todo to use fast clipping and move to gs.c
+  \param gs surface
+  \param region region settings
+  \return 1 segment inside region
+  \return 0 segment outside region
 int gs_clip_segment(geosurf *gs, float *bgn, float *end, float *region)
     float top, bottom, left, right;
@@ -61,13 +66,22 @@
 	   end[Y] >= bottom && end[Y] <= top);
-/* need to think about translations - If user translates surface,
-vector should automatically go with it, but translating vector should
-translate it relative to surface on which it's displayed?
+  \brief Draw vector set
-handling mask checking here, but may be more appropriate to
-handle in get_drape_segments? */
+  Need to think about translations - If user translates surface,
+  vector should automatically go with it, but translating vector should
+  translate it relative to surface on which it's displayed?
+  Handling mask checking here, but may be more appropriate to
+  handle in get_drape_segments?
+  \param gv vector set
+  \param gs surface
+  \param do_fast non-zero for fast mode
+  \return
 int gvd_vect(geovect *gv, geosurf *gs, int do_fast)
     int i,j,k;
@@ -77,7 +91,8 @@
     int npts, src, check;
     geoline *gln;
-    G_debug(3, "Draw vector layer.");
+    G_debug(4, "gvd_vect(): id=%d", gv->gvect_id);
     if (GS_check_cancel())
     	return(0);
@@ -134,7 +149,7 @@
     for (; gln; gln=gln->next)
-        G_debug(3, "Draw vector layer object type = %d dims = %d", gln->type, gln->dims);
+        G_debug(4, "gvd_vect(): type = %d dims = %d", gln->type, gln->dims);
 	if (!(++check % CHK_FREQ))
@@ -149,7 +164,7 @@
 	if ( gln->type == OGSF_LINE ) { /* line */
 	    if ( gln->dims  == 2 ) {    /* 2d line */
-                G_debug(3, "Draw 2D vector line.");
+                G_debug(4, "gvd_vect(): 2D vector line");
 		for (k=0; k < gln->npts - 1; k++) {
 		    bgn[X] = gln->p2[k][X] + gv->x_trans - gs->ox;
 		    bgn[Y] = gln->p2[k][Y] + gv->y_trans - gs->oy;
@@ -197,7 +212,7 @@
 	    else /* 3D line */
-                G_debug(3, "Draw 3D vector line.");
+                G_debug(4, "gvd_vect(): 3D vector line");
 		points = (Point3 *) malloc ( sizeof(Point3) );
                 gsd_color_func(gv->color);
@@ -214,7 +229,7 @@
 	} else if ( gln->type == OGSF_POLYGON ) { /* polygon */
 	    if ( gln->dims  == 3 ) {    /* 3D polygon */
-		G_debug(3, "Draw 3D polygon.");
+		G_debug(4, "gvd_vect(): draw 3D polygon");
 		/* We want at least 3 points */
 		if ( gln->npts >= 3 ) {
@@ -244,7 +259,7 @@
 		    glEnd();
 		    glLightModeli ( GL_LIGHT_MODEL_TWO_SIDE, GL_FALSE);
-		    free ( points );
+		    G_free ( points );
 	    } else { /* 2D polygons */
                 /* TODO */
@@ -258,7 +273,14 @@
     return(1);
+  \brief Draw line on surface
+  \param gs surface
+  \param bgn first line point
+  \param end end line point
+  \param color color value
 void gvd_draw_lineonsurf(geosurf *gs, float *bgn, float *end, int color)
     Point3 *points;
