[GRASS-SVN] r31696 - grass/trunk/lib/ogsf
Thu Jun 12 23:17:06 EDT 2008
Author: glynn
Date: 2008-06-12 23:17:05 -0400 (Thu, 12 Jun 2008)
New Revision: 31696
   grass/trunk/lib/ogsf/gsd_img_mpeg.c
Remove unused references to <swscale.h>
Modified: grass/trunk/lib/ogsf/gsd_img_mpeg.c
--- grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-06-13 00:38:16 UTC (rev 31695)
+++ grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-06-13 03:17:05 UTC (rev 31696)
@@ -27,7 +27,6 @@
 /* FFMPEG stuff */
 #ifdef HAVE_FFMPEG
 #include <avformat.h>
-#include <swscale.h>
 /* 5 seconds stream duration */
 #define STREAM_DURATION   5.0
@@ -35,8 +34,6 @@
 #define STREAM_NB_FRAMES  ((int)(STREAM_DURATION * STREAM_FRAME_RATE))
 #define STREAM_PIX_FMT PIX_FMT_YUV420P /* default pix_fmt */
-static int sws_flags = SWS_BICUBIC;
 AVFrame *picture, *tmp_picture;
 uint8_t *video_outbuf;
 int frame_count, video_outbuf_size;
@@ -206,7 +203,6 @@
     int out_size, ret;
     AVCodecContext *c;
-    static struct SwsContext *img_convert_ctx;
     c = st->codec;
