[GRASS-SVN] r31731 - grass/branches/develbranch_6
Tue Jun 17 04:48:45 EDT 2008
Author: neteler
Date: 2008-06-17 04:48:44 -0400 (Tue, 17 Jun 2008)
New Revision: 31731
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
backported FFMPEG fixes
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2008-06-17 08:24:06 UTC (rev 31730)
+++ grass/branches/develbranch_6/configure	2008-06-17 08:48:44 UTC (rev 31731)
@@ -10712,14 +10712,112 @@
+echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
+echo "configure:10717: checking for av_free in -lavutil" >&5
+ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lavutil  $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 10723 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char av_free();
+int main() {
+av_free()
+; return 0; }
+EOF
+if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+  FFMPEGLIB="$FFMPEGLIB -lavutil "
+else
+  echo "$ac_t""no" 1>&6
+echo "configure:10753: checking for av_free in -lavutil" >&5
+LIBS="-lavutil $MATHLIB $LIBS"
+#line 10759 "configure"
+char av_free();
+int main() {
+av_free()
+; return 0; }
+EOF
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+else
+  rm -rf conftest*
+fi
+rm -f conftest*
+  FFMPEGLIB="$FFMPEGLIB -lavutil $MATHLIB"
+else
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate FFMPEG library." 1>&2; exit 1; }
+fi
+fi
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$FFMPEGLIBPATH $LDFLAGS"
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10717: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10815: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
-LIBS="-lavcodec  $LIBS"
+LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10723 "configure"
+#line 10821 "configure"
@@ -10730,7 +10828,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10749,13 +10847,13 @@
-echo "configure:10753: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10851: checking for avcodec_init in -lavcodec" >&5
-LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
+LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10759 "configure"
+#line 10857 "configure"
@@ -10766,7 +10864,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10780,7 +10878,7 @@
-  FFMPEGLIB="$FFMPEGLIB -lavcodec -lavutil $MATHLIB"
+  FFMPEGLIB="$FFMPEGLIB -lavcodec $MATHLIB"
 else
@@ -10811,13 +10909,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10815: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10913: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
-LIBS="-lavformat  $LIBS"
+LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10821 "configure"
+#line 10919 "configure"
@@ -10828,7 +10926,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10847,13 +10945,13 @@
-echo "configure:10851: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10949: checking for av_set_parameters in -lavformat" >&5
-LIBS="-lavformat -lavutil $MATHLIB $LIBS"
+LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10857 "configure"
+#line 10955 "configure"
@@ -10864,7 +10962,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10878,7 +10976,7 @@
-  FFMPEGLIB="$FFMPEGLIB -lavformat -lavutil $MATHLIB"
+  FFMPEGLIB="$FFMPEGLIB -lavformat $MATHLIB"
 else
@@ -10924,7 +11022,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10928: checking whether to use OpenGL" >&5
+echo "configure:11026: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10958,7 +11056,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10962: checking for location of OpenGL includes" >&5
+echo "configure:11060: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10984,15 +11082,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10988: checking for $ac_hdr" >&5
+echo "configure:11086: checking for $ac_hdr" >&5
-#line 10991 "configure"
+#line 11089 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:10996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11026,7 +11124,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11030: checking for location of OpenGL library" >&5
+echo "configure:11128: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11055,13 +11153,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11059: checking for glBegin in -lGL" >&5
+echo "configure:11157: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11065 "configure"
+#line 11163 "configure"
@@ -11072,7 +11170,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11091,13 +11189,13 @@
-echo "configure:11095: checking for glBegin in -lGL" >&5
+echo "configure:11193: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11101 "configure"
+#line 11199 "configure"
@@ -11108,7 +11206,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11127,13 +11225,13 @@
-echo "configure:11131: checking for glBegin in -lGL" >&5
+echo "configure:11229: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11137 "configure"
+#line 11235 "configure"
@@ -11144,7 +11242,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11163,13 +11261,13 @@
-echo "configure:11167: checking for glBegin in -lGL" >&5
+echo "configure:11265: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11173 "configure"
+#line 11271 "configure"
@@ -11180,7 +11278,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11184: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11242,13 +11340,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11246: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11344: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11252 "configure"
+#line 11350 "configure"
@@ -11259,7 +11357,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11278,13 +11376,13 @@
-echo "configure:11282: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11380: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11288 "configure"
+#line 11386 "configure"
@@ -11295,7 +11393,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11339,10 +11437,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11343: checking for glXCreatePbuffer" >&5
+echo "configure:11441: checking for glXCreatePbuffer" >&5
-#line 11346 "configure"
+#line 11444 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11365,7 +11463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11387,10 +11485,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11391: checking for glXCreateGLXPixmap" >&5
+echo "configure:11489: checking for glXCreateGLXPixmap" >&5
-#line 11394 "configure"
+#line 11492 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11413,7 +11511,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11452,7 +11550,7 @@
-echo "configure:11456: checking for location of OpenGL includes" >&5
+echo "configure:11554: checking for location of OpenGL includes" >&5
@@ -11478,15 +11576,15 @@
 do
-echo "configure:11482: checking for $ac_hdr" >&5
+echo "configure:11580: checking for $ac_hdr" >&5
-#line 11485 "configure"
+#line 11583 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11521,10 +11619,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11525: checking for glBegin" >&5
+echo "configure:11623: checking for glBegin" >&5
-#line 11528 "configure"
+#line 11626 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11547,7 +11645,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11562,10 +11660,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11566: checking for gluBeginCurve" >&5
+echo "configure:11664: checking for gluBeginCurve" >&5
-#line 11569 "configure"
+#line 11667 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11588,7 +11686,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11634,7 +11732,7 @@
-echo "configure:11638: checking for location of OpenGL includes" >&5
+echo "configure:11736: checking for location of OpenGL includes" >&5
@@ -11660,15 +11758,15 @@
 do
-echo "configure:11664: checking for $ac_hdr" >&5
+echo "configure:11762: checking for $ac_hdr" >&5
-#line 11667 "configure"
+#line 11765 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11702,7 +11800,7 @@
-echo "configure:11706: checking for location of OpenGL library" >&5
+echo "configure:11804: checking for location of OpenGL library" >&5
@@ -11725,33 +11823,33 @@
 ac_save_libs="$LIBS"
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11729: checking for OpenGL library" >&5
+echo "configure:11827: checking for OpenGL library" >&5
 LIBS="-lopengl32"
-#line 11732 "configure"
+#line 11830 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
 OPENGLLIB=-lopengl32
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11745: checking for GLU library" >&5
+echo "configure:11843: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB"
-#line 11748 "configure"
+#line 11846 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11802,7 +11900,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11806: checking whether to use ODBC" >&5
+echo "configure:11904: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11821,7 +11919,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11825: checking for location of ODBC includes" >&5
+echo "configure:11923: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11847,15 +11945,15 @@
 do
-echo "configure:11851: checking for $ac_hdr" >&5
+echo "configure:11949: checking for $ac_hdr" >&5
-#line 11854 "configure"
+#line 11952 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11889,7 +11987,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11893: checking for location of ODBC library" >&5
+echo "configure:11991: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11914,13 +12012,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11918: checking for SQLConnect in -lodbc" >&5
+echo "configure:12016: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11924 "configure"
+#line 12022 "configure"
@@ -11931,7 +12029,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11956,13 +12054,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11960: checking for SQLConnect in -liodbc" >&5
+echo "configure:12058: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11966 "configure"
+#line 12064 "configure"
@@ -11973,7 +12071,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12022,7 +12120,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12026: checking whether to use FFTW" >&5
+echo "configure:12124: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12041,7 +12139,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12045: checking for location of FFTW includes" >&5
+echo "configure:12143: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12067,15 +12165,15 @@
 do
-echo "configure:12071: checking for $ac_hdr" >&5
+echo "configure:12169: checking for $ac_hdr" >&5
-#line 12074 "configure"
+#line 12172 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12079: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12103,15 +12201,15 @@
 do
-echo "configure:12107: checking for $ac_hdr" >&5
+echo "configure:12205: checking for $ac_hdr" >&5
-#line 12110 "configure"
+#line 12208 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12139,15 +12237,15 @@
 do
-echo "configure:12143: checking for $ac_hdr" >&5
+echo "configure:12241: checking for $ac_hdr" >&5
-#line 12146 "configure"
+#line 12244 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12193,7 +12291,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12197: checking for location of FFTW library" >&5
+echo "configure:12295: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12218,13 +12316,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12222: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12320: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12228 "configure"
+#line 12326 "configure"
@@ -12235,7 +12333,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12260,13 +12358,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12264: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12362: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12270 "configure"
+#line 12368 "configure"
@@ -12277,7 +12375,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12302,13 +12400,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12306: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12404: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12312 "configure"
+#line 12410 "configure"
@@ -12319,7 +12417,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12376,7 +12474,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12380: checking whether to use BLAS" >&5
+echo "configure:12478: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12397,7 +12495,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12401: checking for location of BLAS includes" >&5
+echo "configure:12499: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12417,7 +12515,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12421: checking for location of BLAS library" >&5
+echo "configure:12519: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12443,15 +12541,15 @@
 do
-echo "configure:12447: checking for $ac_hdr" >&5
+echo "configure:12545: checking for $ac_hdr" >&5
-#line 12450 "configure"
+#line 12548 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12486,13 +12584,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12490: checking for dnrm2_ in -lblas" >&5
+echo "configure:12588: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12496 "configure"
+#line 12594 "configure"
@@ -12503,7 +12601,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12522,13 +12620,13 @@
-echo "configure:12526: checking for dnrm2_ in -lblas" >&5
+echo "configure:12624: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12532 "configure"
+#line 12630 "configure"
@@ -12539,7 +12637,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12583,13 +12681,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12587: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12685: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12593 "configure"
+#line 12691 "configure"
@@ -12600,7 +12698,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12615,13 +12713,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12619: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12717: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12625 "configure"
+#line 12723 "configure"
@@ -12632,7 +12730,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12647,13 +12745,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12651: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12749: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12657 "configure"
+#line 12755 "configure"
@@ -12664,7 +12762,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12709,16 +12807,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12713: checking for sgemm in $vlib_flags" >&5
+echo "configure:12811: checking for sgemm in $vlib_flags" >&5
-#line 12715 "configure"
+#line 12813 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12736,13 +12834,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12740: checking for sgemm_ in -lblas" >&5
+echo "configure:12838: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12746 "configure"
+#line 12844 "configure"
@@ -12753,7 +12851,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12768,13 +12866,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12772: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12870: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12778 "configure"
+#line 12876 "configure"
@@ -12785,7 +12883,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12800,13 +12898,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12804: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12902: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12810 "configure"
+#line 12908 "configure"
@@ -12817,7 +12915,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12851,13 +12949,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12855: checking for acosp in -lsunmath" >&5
+echo "configure:12953: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12861 "configure"
+#line 12959 "configure"
@@ -12868,7 +12966,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12883,13 +12981,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12887: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12985: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12893 "configure"
+#line 12991 "configure"
@@ -12900,7 +12998,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12930,13 +13028,13 @@
 # Generic BLAS library
-echo "configure:12934: checking for sgemm_ in -lblas" >&5
+echo "configure:13032: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12940 "configure"
+#line 13038 "configure"
@@ -12947,7 +13045,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12986,7 +13084,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12990: checking whether to use LAPACK" >&5
+echo "configure:13088: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13011,7 +13109,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13015: checking for location of LAPACK includes" >&5
+echo "configure:13113: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13031,7 +13129,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13035: checking for location of LAPACK library" >&5
+echo "configure:13133: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13057,15 +13155,15 @@
 do
-echo "configure:13061: checking for $ac_hdr" >&5
+echo "configure:13159: checking for $ac_hdr" >&5
-#line 13064 "configure"
+#line 13162 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13097,10 +13195,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13101: checking for dsegv_" >&5
+echo "configure:13199: checking for dsegv_" >&5
-#line 13104 "configure"
+#line 13202 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13123,7 +13221,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13150,13 +13248,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13154: checking for desgv_ in -llapack" >&5
+echo "configure:13252: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13160 "configure"
+#line 13258 "configure"
@@ -13167,7 +13265,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13199,13 +13297,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13203: checking for dgesv_ in -llapack" >&5
+echo "configure:13301: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13209 "configure"
+#line 13307 "configure"
@@ -13216,7 +13314,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13235,13 +13333,13 @@
-echo "configure:13239: checking for dgesv_ in -llapack" >&5
+echo "configure:13337: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13245 "configure"
+#line 13343 "configure"
@@ -13252,7 +13350,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13308,7 +13406,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13312: checking whether to use Motif" >&5
+echo "configure:13410: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13327,7 +13425,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13331: checking for location of Motif includes" >&5
+echo "configure:13429: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13353,15 +13451,15 @@
 do
-echo "configure:13357: checking for $ac_hdr" >&5
+echo "configure:13455: checking for $ac_hdr" >&5
-#line 13360 "configure"
+#line 13458 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13365: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13395,7 +13493,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13399: checking for location of Motif library" >&5
+echo "configure:13497: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13420,13 +13518,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13424: checking for XmStringCreate in -lXm" >&5
+echo "configure:13522: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13430 "configure"
+#line 13528 "configure"
@@ -13437,7 +13535,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13478,7 +13576,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13482: checking whether to use Cairo" >&5
+echo "configure:13580: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13504,15 +13602,15 @@
 do
-echo "configure:13508: checking for $ac_hdr" >&5
+echo "configure:13606: checking for $ac_hdr" >&5
-#line 13511 "configure"
+#line 13609 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13516: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13614: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13549,10 +13647,10 @@
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13553: checking for cairo_create" >&5
+echo "configure:13651: checking for cairo_create" >&5
-#line 13556 "configure"
+#line 13654 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13575,7 +13673,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13610,7 +13708,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13614: checking whether to use GLw" >&5
+echo "configure:13712: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13629,7 +13727,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13633: checking for location of GLw includes" >&5
+echo "configure:13731: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13655,15 +13753,15 @@
 do
-echo "configure:13659: checking for $ac_hdr" >&5
+echo "configure:13757: checking for $ac_hdr" >&5
-#line 13662 "configure"
+#line 13760 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13691,15 +13789,15 @@
 do
-echo "configure:13695: checking for $ac_hdr" >&5
+echo "configure:13793: checking for $ac_hdr" >&5
-#line 13698 "configure"
+#line 13796 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13739,7 +13837,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13743: checking for location of GLw library" >&5
+echo "configure:13841: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13764,13 +13862,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13768: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13866: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13774 "configure"
+#line 13872 "configure"
@@ -13781,7 +13879,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13806,13 +13904,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13810: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13908: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13816 "configure"
+#line 13914 "configure"
@@ -13823,7 +13921,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13848,13 +13946,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13852: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13950: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13858 "configure"
+#line 13956 "configure"
@@ -13865,7 +13963,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13890,13 +13988,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13894: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13992: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13900 "configure"
+#line 13998 "configure"
@@ -13907,7 +14005,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13932,13 +14030,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13936: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14034: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13942 "configure"
+#line 14040 "configure"
@@ -13949,7 +14047,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13974,13 +14072,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13978: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14076: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13984 "configure"
+#line 14082 "configure"
@@ -13991,7 +14089,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14018,13 +14116,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14022: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14120: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14028 "configure"
+#line 14126 "configure"
@@ -14035,7 +14133,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14054,13 +14152,13 @@
-echo "configure:14058: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14156: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14064 "configure"
+#line 14162 "configure"
@@ -14071,7 +14169,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14098,13 +14196,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14102: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14200: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14108 "configure"
+#line 14206 "configure"
@@ -14115,7 +14213,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14134,13 +14232,13 @@
-echo "configure:14138: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14236: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14144 "configure"
+#line 14242 "configure"
@@ -14151,7 +14249,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14264,7 +14362,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14268: checking whether to use FreeType" >&5
+echo "configure:14366: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14283,7 +14381,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14287: checking for location of FreeType includes" >&5
+echo "configure:14385: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14309,15 +14407,15 @@
 do
-echo "configure:14313: checking for $ac_hdr" >&5
+echo "configure:14411: checking for $ac_hdr" >&5
-#line 14316 "configure"
+#line 14414 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14351,7 +14449,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14355: checking for location of FreeType library" >&5
+echo "configure:14453: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14376,13 +14474,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14380: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14478: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14386 "configure"
+#line 14484 "configure"
@@ -14393,7 +14491,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14434,7 +14532,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14438: checking whether to use NLS" >&5
+echo "configure:14536: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14454,10 +14552,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14458: checking for gettext" >&5
+echo "configure:14556: checking for gettext" >&5
-#line 14461 "configure"
+#line 14559 "configure"
     which can conflict with char gettext(); below.  */
@@ -14480,7 +14578,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14498,13 +14596,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14502: checking for gettext in -lintl" >&5
+echo "configure:14600: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14508 "configure"
+#line 14606 "configure"
@@ -14515,7 +14613,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14550,7 +14648,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14554: checking whether to use C++" >&5
+echo "configure:14652: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14566,7 +14664,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14570: checking for $ac_word" >&5
+echo "configure:14668: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14595,7 +14693,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14599: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14697: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14606,12 +14704,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14610 "configure"
+#line 14708 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14637,19 +14735,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14641: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14739: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14646: checking whether we are using GNU C++" >&5
+echo "configure:14744: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14667,7 +14765,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14671: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14769: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14708,7 +14806,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14712: checking whether to use openDWG" >&5
+echo "configure:14810: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14728,7 +14826,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14732: checking for location of openDGW includes" >&5
+echo "configure:14830: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14754,15 +14852,15 @@
 do
-echo "configure:14758: checking for $ac_hdr" >&5
+echo "configure:14856: checking for $ac_hdr" >&5
-#line 14761 "configure"
+#line 14859 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14864: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14796,7 +14894,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14800: checking for location of openDWG library" >&5
+echo "configure:14898: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14843,7 +14941,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14847: checking for special C compiler options needed for large files" >&5
+echo "configure:14945: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14851,7 +14949,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14855 "configure"
+#line 14953 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14867,7 +14965,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14871: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14876,7 +14974,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14880 "configure"
+#line 14978 "configure"
@@ -14892,7 +14990,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14896: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14912,11 +15010,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14916: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15014: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14920 "configure"
+#line 15018 "configure"
@@ -14932,14 +15030,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14936: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15034: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14943 "configure"
+#line 15041 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14957,7 +15055,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14976,11 +15074,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14980: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15078: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14984 "configure"
+#line 15082 "configure"
@@ -14996,14 +15094,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15007 "configure"
+#line 15105 "configure"
 #define _LARGE_FILES 1
@@ -15021,7 +15119,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15025: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15040,25 +15138,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15044: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15142: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15048 "configure"
+#line 15146 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15055: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15153: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15062 "configure"
+#line 15160 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15067,7 +15165,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15071: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15169: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15088,10 +15186,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15092: checking if system supports Large Files at all" >&5
+echo "configure:15190: checking if system supports Large Files at all" >&5
-#line 15095 "configure"
+#line 15193 "configure"
 #include <stdio.h>
@@ -15123,7 +15221,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15152,7 +15250,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15156: checking whether to use Python" >&5
+echo "configure:15254: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15172,7 +15270,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15176: checking for $ac_word" >&5
+echo "configure:15274: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15217,15 +15315,15 @@
 do
-echo "configure:15221: checking for $ac_hdr" >&5
+echo "configure:15319: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 15224 "configure"
+#line 15322 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15265,7 +15363,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15269: checking for $ac_word" >&5
+echo "configure:15367: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15311,7 +15409,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15315: checking whether to use wxWidgets" >&5
+echo "configure:15413: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15331,7 +15429,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15335: checking for $ac_word" >&5
+echo "configure:15433: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15379,7 +15477,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15383: checking wxWidgets version" >&5
+echo "configure:15481: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15402,15 +15500,15 @@
 do
-echo "configure:15406: checking for $ac_hdr" >&5
+echo "configure:15504: checking for $ac_hdr" >&5
-#line 15409 "configure"
+#line 15507 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15446,15 +15544,15 @@
 do
-echo "configure:15450: checking for $ac_hdr" >&5
+echo "configure:15548: checking for $ac_hdr" >&5
-#line 15453 "configure"
+#line 15551 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2008-06-17 08:24:06 UTC (rev 31730)
+++ grass/branches/develbranch_6/configure.in	2008-06-17 08:48:44 UTC (rev 31731)
@@ -1018,8 +1018,9 @@
 LOC_CHECK_LIB_PATH(ffmpeg, FFMPEG, FFMPEGLIBPATH)
-LOC_CHECK_LIBS(avcodec, avcodec_init, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,-lavutil $MATHLIB)
-LOC_CHECK_LIBS(avformat, av_set_parameters, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,-lavutil $MATHLIB)
+LOC_CHECK_LIBS(avutil, av_free, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,$MATHLIB)
+LOC_CHECK_LIBS(avcodec, avcodec_init, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avformat, av_set_parameters, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
 fi # $USE_FFMPEG
