[GRASS-SVN] r31819 - in grass-addons/visualization/nviz2: cmd lib wxpython
Mon Jun 23 05:47:49 EDT 2008
Author: martinl
Date: 2008-06-23 05:47:49 -0400 (Mon, 23 Jun 2008)
New Revision: 31819
   grass-addons/visualization/nviz2/cmd/main.c
   grass-addons/visualization/nviz2/lib/render.c
   grass-addons/visualization/nviz2/wxpython/mapdisp.py
   grass-addons/visualization/nviz2/wxpython/nviz.py
nviz2: wxGUI intergration in progress, related to r31818
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c	2008-06-23 09:46:09 UTC (rev 31818)
+++ grass-addons/visualization/nviz2/cmd/main.c	2008-06-23 09:47:49 UTC (rev 31819)
@@ -71,11 +71,34 @@
     /* initialize nviz data */
     Nviz_init_data(&data);
     /* define default attributes for map objects */
     Nviz_set_attr_default();
     /* set background color */
     Nviz_set_bgcolor(&data, Nviz_color_from_str(params->bgcolor->answer));
+    /* init view */
+    Nviz_init_view();
+    /* set lights */
+    /* TODO: add options */
+    Nviz_set_light_position(&data, 0,
+			    0.68, -0.68, 0.80, 0.0);
+    Nviz_set_light_bright(&data, 0,
+			  0.8);
+    Nviz_set_light_color(&data, 0,
+			 1.0, 1.0, 1.0);
+    Nviz_set_light_ambient(&data, 0,
+			   0.2, 0.2, 0.2);
+    Nviz_set_light_position(&data, 1,
+			    0.0, 0.0, 1.0, 0.0);
+    Nviz_set_light_bright(&data, 1,
+			  0.5);
+    Nviz_set_light_color(&data, 1,
+			 1.0, 1.0, 1.0);
+    Nviz_set_light_ambient(&data, 1,
+			   0.3, 0.3, 0.3);
     /* load data */
     nelev = ncolor_map = ncolor_const = 0;
@@ -153,42 +176,10 @@
 	nvect++;
-    /* init view */
-    Nviz_init_view();
+    /* focus on loaded data */
     Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
-    /* set lights */
-    /* TODO: add options */
-    Nviz_set_light_position(&data, 0,
-			    0.68, -0.68, 0.80, 0.0);
-    Nviz_set_light_bright(&data, 0,
-			  0.8);
-    Nviz_set_light_color(&data, 0,
-			 1.0, 1.0, 1.0);
-    Nviz_set_light_ambient(&data, 0,
-			   0.2, 0.2, 0.2);
-    light_set_position(&data, 1,
-    light_set_bright(&data, 1,
-		     0.8);
-    light_set_color(&data, 1,
-		    1.0, 1.0, 1.0);
-    light_set_ambient(&data, 1,
-		      0.2, 0.2, 0.2);
-    Nviz_set_light_position(&data, 1,
-			    0.0, 0.0, 1.0, 0.0);
-    Nviz_set_light_bright(&data, 1,
-			  0.5);
-    Nviz_set_light_color(&data, 1,
-			 1.0, 1.0, 1.0);
-    Nviz_set_light_ambient(&data, 1,
-			   0.3, 0.3, 0.3);
     /* define view point */
     if (params->height->answer) {
 	vp_height = atof(params->height->answer);
@@ -214,6 +205,7 @@
     Nviz_draw_cplane(&data, -1, -1);
     Nviz_draw_all (&data);
+    /* write to image */
     ret = 0;
     if (strcmp(params->format->answer, "ppm") == 0)
 	ret = write_img(output_name, FORMAT_PPM);
Modified: grass-addons/visualization/nviz2/lib/render.c
--- grass-addons/visualization/nviz2/lib/render.c	2008-06-23 09:46:09 UTC (rev 31818)
+++ grass-addons/visualization/nviz2/lib/render.c	2008-06-23 09:47:49 UTC (rev 31819)
@@ -110,7 +110,7 @@
     /* create an off-screen GLX rendering area */
     rwin->windowId = glXCreateGLXPixmap(rwin->displayId,
-				       v, rwin->pixmap);
+					v, rwin->pixmap);
     if (v) {
 	XFree(v);
@@ -124,7 +124,8 @@
   \param win pointer to render_window struct
-  \return 1
+  \return 1 on success
+  \return 0 on failure
 int Nviz_make_current_render_window(const struct render_window *rwin)
Modified: grass-addons/visualization/nviz2/wxpython/mapdisp.py
--- grass-addons/visualization/nviz2/wxpython/mapdisp.py	2008-06-23 09:46:09 UTC (rev 31818)
+++ grass-addons/visualization/nviz2/wxpython/mapdisp.py	2008-06-23 09:47:49 UTC (rev 31819)
@@ -60,7 +60,6 @@
 import globalvar
 import utils
 import gdialogs
-import nviz
 from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
 from vdigit import VDigitZBulkDialog    as VDigitZBulkDialog
 from vdigit import VDigitDuplicatesDialog as VDigitDuplicatesDialog
@@ -122,7 +121,16 @@
         sys.exit()
-class BufferedWindow(wx.Window):
+class MapWindow(object):
+    """Generic map window class"""
+    def __init__(self, parent, id,
+                 pos=wx.DefaultPosition,
+                 size=wx.DefaultSize,
+                 style=wx.NO_FULL_REPAINT_ON_RESIZE,
+                 Map=None, tree=None, gismgr=None):
+        pass
+class BufferedWindow(MapWindow, wx.Window):
     A Buffered window class.
@@ -138,7 +146,10 @@
+        MapWindow.__init__(self, parent, id, pos, size, style,
+                           Map, tree, gismgr)
         wx.Window.__init__(self, parent, id, pos, size, style)
         self.parent = parent
         self.Map = Map
         self.tree = tree
@@ -546,7 +557,6 @@
         @param render re-render map composition
         @param renderVector re-render vector map layer enabled for editing (used for digitizer)
         start = time.clock()
         self.resize = False
@@ -2370,7 +2380,8 @@
         # Init map display (buffered DC & set default cursor)
-        self.MapWindow = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self.gismanager)
+        self.MapWindow = BufferedWindow(self, id=wx.ID_ANY,
+                                        Map=self.Map, tree=self.tree, gismgr=self.gismanager)
         self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
         self.MapWindow.SetCursor(self.cursors["default"])
         self.MapWindowGL = None # used by Nviz (default is 2D display mode)
@@ -2480,6 +2491,7 @@
                               CloseButton(False).Layer(2))
         # nviz
         elif name == "nviz":
+            import nviz
             # check for GLCanvas and OpenGL
             msg = None
             if not nviz.haveGLCanvas:
@@ -2501,7 +2513,8 @@
             # create GL window & NVIZ toolbar
-            self.MapWindowGL = nviz.GLWindow(self)
+            self.MapWindowGL = nviz.GLWindow(self, id=wx.ID_ANY,
             self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-23 09:46:09 UTC (rev 31818)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-23 09:47:49 UTC (rev 31819)
@@ -4,7 +4,7 @@
 @brief 2.5/3D visialization mode for Map Display Window
 List of classes:
- - GLCanvas
+ - GLWindow
 (C) 2008 by the GRASS Development Team
@@ -12,7 +12,7 @@
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
- at author Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
 import wx
@@ -30,6 +30,8 @@
     haveOpenGL = False
 import globalvar
+from debug import Debug as Debug
+from mapdisp import MapWindow as MapWindow
 #try:
 nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
 sys.path.append(nvizPath)
@@ -38,18 +40,27 @@
 #except ImportError:
 #    haveNviz = False
-class GLWindow(glcanvas.GLCanvas):
+class GLWindow(MapWindow, glcanvas.GLCanvas):
     """OpenGL canvas for Map Display Window"""
-    def __init__(self, parent):
-        self.parent = parent # MapWindow
-        glcanvas.GLCanvas.__init__(self, parent, id=wx.ID_ANY)
-#                                    attribList=[wx.WX_GL_RGBA, wx.GLX_RED_SIZE, 1,
-#                                                wx.GLX_GREEN_SIZE, 1,
-#                                                wx.GLX_BLUE_SIZE, 1,
-#                                                wx.GLX_DEPTH_SIZE, 1,
-#                                                None])
+        glcanvas.GLCanvas.__init__(self, parent, id)
+        # MapWindow.__init__(self, parent, id, pos, size, style,
+        #                   Map, tree, gismgr)
+        self.parent = parent # MapFrame
+        # attribList=[wx.WX_GL_RGBA, wx.GLX_RED_SIZE, 1,
+        #             wx.GLX_GREEN_SIZE, 1,
+        #             wx.GLX_BLUE_SIZE, 1,
+        #             wx.GLX_DEPTH_SIZE, 1,
+        #             None])
         self.init = False
@@ -63,8 +74,8 @@
         self.nvizClass.SetDisplay(self)
         # initialize mouse position
-        self.lastx = self.x = 30
-        self.lasty = self.y = 30
+        # self.lastx = self.x = 30
+        # self.lasty = self.y = 30
         self.size = None
         self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
@@ -78,96 +89,33 @@
         pass # do nothing, to avoid flashing on MSW
     def OnSize(self, event):
-        size = self.size = self.parent.GetClientSize()
+        self.size = self.parent.GetClientSize()
         if self.GetContext():
+            Debug.msg(3, "GLCanvas.OnPaint(): w=%d, h=%d" % \
+                      (self.size.width, self.size.height))
             self.SetCurrent()
-            # glViewport(0, 0, size.width, size.height)
-            self.nvizClass.ResizeWindow(size.width, size.height)
+            self.nvizClass.ResizeWindow(self.size.width,
+                                        self.size.height)
         event.Skip()
     def OnPaint(self, event):
+        Debug.msg(3, "GLCanvas.OnPaint()")
         dc = wx.PaintDC(self)
         self.SetCurrent()
         if not self.init:
-            # self.InitGL()
-            # nvizClass.InitView()
+            self.nvizClass.InitView()
             self.nvizClass.LoadRaster("elevation", None, None);
+            self.nvizClass.SetViewportDefault()
+            self.nvizClass.SetLightsDefault()
             self.init = True
         self.OnDraw()
-    def InitGL(self):
-        # set viewing projection
-        glMatrixMode(GL_PROJECTION)
-        glFrustum(-0.5, 0.5, -0.5, 0.5, 1.0, 3.0)
-        # position viewer
-        glMatrixMode(GL_MODELVIEW)
-        glTranslatef(0.0, 0.0, -2.0)
-        # position object
-        glRotatef(self.y, 1.0, 0.0, 0.0)
-        glRotatef(self.x, 0.0, 1.0, 0.0)
-        glEnable(GL_DEPTH_TEST)
-        glEnable(GL_LIGHTING)
-        glEnable(GL_LIGHT0)
     def OnDraw(self):
         """Draw data layers"""
-        self.nvizClass.Draw()
+        Debug.msg(3, "GLCanvas.OnDraw()")
-    def OnDraw1(self):
-        # clear color and depth buffers
-        glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT)
-        # draw six faces of a cube
-        glBegin(GL_QUADS)
-        glNormal3f( 0.0, 0.0, 1.0)
-        glVertex3f( 0.5, 0.5, 0.5)
-        glVertex3f(-0.5, 0.5, 0.5)
-        glVertex3f(-0.5,-0.5, 0.5)
-        glVertex3f( 0.5,-0.5, 0.5)
-        glNormal3f( 0.0, 0.0,-1.0)
-        glVertex3f(-0.5,-0.5,-0.5)
-        glVertex3f(-0.5, 0.5,-0.5)
-        glVertex3f( 0.5, 0.5,-0.5)
-        glVertex3f( 0.5,-0.5,-0.5)
-        glNormal3f( 0.0, 1.0, 0.0)
-        glNormal3f( 0.0,-1.0, 0.0)
-        glNormal3f( 1.0, 0.0, 0.0)
-        glNormal3f(-1.0, 0.0, 0.0)
-        glEnd()
-        if self.size is None:
-            self.size = self.GetClientSize()
-        w, h = self.size
-        w = max(w, 1.0)
-        h = max(h, 1.0)
-        xScale = 180.0 / w
-        yScale = 180.0 / h
-        glRotatef((self.y - self.lasty) * yScale, 1.0, 0.0, 0.0);
-        glRotatef((self.x - self.lastx) * xScale, 0.0, 1.0, 0.0);
+        self.nvizClass.Draw()
         self.SwapBuffers()
