[GRASS-SVN] r31832 - in grass/trunk/scripts: i.fusion.brovey i.in.spotvgt
Mon Jun 23 13:42:52 EDT 2008
Author: hamish
Date: 2008-06-23 13:42:52 -0400 (Mon, 23 Jun 2008)
New Revision: 31832
   grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt
merge fixes from devbr6 (trac bug #194)
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey	2008-06-23 17:35:57 UTC (rev 31831)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey	2008-06-23 17:42:52 UTC (rev 31832)
@@ -9,7 +9,7 @@
 #                 - SPOT MS and pan (high res)
 #                 - QuickBird MS and pan (high res)
-# COPYRIGHT:	(C) 2002,2004 by the GRASS Development Team
+# COPYRIGHT:	(C) 2002-2008 by the GRASS Development Team
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -78,19 +78,10 @@
 #% required : yes
 #%end
-# what to do in case of user break:
-exitprocedure()
- g.message -e message='User break!'
- cleanup
- exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 15
 if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+   echo "You must be in GRASS GIS to run this program." >&2
+   exit 1
 fi
 # save command line
@@ -103,8 +94,27 @@
     exec g.parser "$0" "$@"
 fi
-PROG=`basename $0`
+cleanup()
+   #remove temporary region file
+   unset WIND_OVERRIDE
+   g.remove region="i.fusion.brovey.$TMP" --quiet
+# what to do in case of user break:
+exitprocedure()
+   g.message -e message='User break!'
+   cleanup
+   exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
 #### check if we have awk
 if [ ! -x "`which awk`" ] ; then
     g.message -e "awk required, please install awk or gawk first"
@@ -116,12 +126,6 @@
 LC_NUMERIC=C
 export LC_NUMERIC
-cleanup()
-   #restore settings:
-   g.region region="i.fusion.brovey.$TMP"
 TMP=$$
 if [ $GIS_FLAG_S -eq 0 -a $GIS_FLAG_L -eq 0 -a $GIS_FLAG_Q -eq 0 ] ; then
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt	2008-06-23 17:35:57 UTC (rev 31831)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt	2008-06-23 17:42:52 UTC (rev 31832)
@@ -10,7 +10,7 @@
 #               SPOT Vegetation (1km, global) data:
 #               http://free.vgt.vito.be/
-# COPYRIGHT:    (c) 2004,2007 GRASS Development Team
+# COPYRIGHT:    (c) 2004-2008 GRASS Development Team
@@ -51,6 +51,7 @@
 #% required : no
 #%end
     exit 1
@@ -66,7 +67,6 @@
 fi
-PROG=`basename $0`
@@ -90,11 +90,33 @@
     exit 1
 fi
-#### trap ctrl-c
-trap 2 3 15
+PID=$$
+TMPFILE="`g.tempfile $PID`"
+cleanup()
+   g.remove region="spot_$PID" --quiet
+   #### clean up the mess
+   rm -f "$VRTFILE" "$TMPFILE"
+exitprocedure()
+   cleanup
+   exit 1
 #### a function for writing VRT files
 create_VRT_file(){
  WESTCENTER=`cat $PROJFILE  | grep CARTO_UPPER_LEFT_X  | tr -s ' ' ' ' | cut -d' ' -f2`
  NORTHCENTER=`cat $PROJFILE | grep CARTO_UPPER_LEFT_Y  | tr -s ' ' ' ' | cut -d' ' -f2`
@@ -129,43 +151,41 @@
  #echo $RESOLUTION
  echo "<VRTDataset rasterXSize=\"$XSIZE\" rasterYSize=\"$YSIZE\">" >> "$1"
- echo " <SRS>GEOGCS[&quot;wgs84&quot;,DATUM[&quot;WGS_1984&quot;,SPHEROID[&quot;wgs84&quot;,6378137,298.257223563],TOWGS84[0.000,0.000,0.000]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;degree&quot;,0.0174532925199433]]</SRS>" >> $1
- echo "   <GeoTransform>$WESTCORNER, $RESOLUTION, 0.0000000000000000e+00, $NORTHCORNER, 0.0000000000000e+00, -$RESOLUTION</GeoTransform>" >> $1
- echo "   <VRTRasterBand dataType=\"Byte\" band=\"1\">" >> $1
- echo "    <NoDataValue>0.00000000000000E+00</NoDataValue>" >> $1
- echo "    <ColorInterp>Gray</ColorInterp>" >> $1
- echo "    <SimpleSource>" >> $1
- echo "     <SourceFilename>$2</SourceFilename>" >> $1
- echo "      <SourceBand>1</SourceBand>" >> $1
- echo "      <SrcRect xOff=\"0\" yOff=\"0\" xSize=\"$XSIZE\" ySize=\"$YSIZE\"/>" >> $1
- echo "      <DstRect xOff=\"0\" yOff=\"0\" xSize=\"$XSIZE\" ySize=\"$YSIZE\"/>" >> $1
- echo "    </SimpleSource>" >> $1
- echo " </VRTRasterBand>" >> $1
- echo "</VRTDataset>" >> $1
+ echo " <SRS>GEOGCS[&quot;wgs84&quot;,DATUM[&quot;WGS_1984&quot;,SPHEROID[&quot;wgs84&quot;,6378137,298.257223563],TOWGS84[0.000,0.000,0.000]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;degree&quot;,0.0174532925199433]]</SRS>" >> "$1"
+ echo "   <GeoTransform>$WESTCORNER, $RESOLUTION, 0.0000000000000000e+00, $NORTHCORNER, 0.0000000000000e+00, -$RESOLUTION</GeoTransform>" >> "$1"
+ echo "   <VRTRasterBand dataType=\"Byte\" band=\"1\">" >> "$1"
+ echo "    <NoDataValue>0.00000000000000E+00</NoDataValue>" >> "$1"
+ echo "    <ColorInterp>Gray</ColorInterp>" >> "$1"
+ echo "    <SimpleSource>" >> "$1"
+ echo "     <SourceFilename>$2</SourceFilename>" >> "$1"
+ echo "      <SourceBand>1</SourceBand>" >> "$1"
+ echo "      <SrcRect xOff=\"0\" yOff=\"0\" xSize=\"$XSIZE\" ySize=\"$YSIZE\"/>" >> "$1"
+ echo "      <DstRect xOff=\"0\" yOff=\"0\" xSize=\"$XSIZE\" ySize=\"$YSIZE\"/>" >> "$1"
+ echo "    </SimpleSource>" >> "$1"
+ echo " </VRTRasterBand>" >> "$1"
+ echo "</VRTDataset>" >> "$1"
 ################### let's go
-PID=$$
-TMPFILE="`g.tempfile $PID`"
-if [ ! -z "$GIS_OPT_FILE" ] ; then
+if [ -n "$GIS_OPT_FILE" ] ; then
     SPOTDIR="`dirname $GIS_OPT_FILE`"
     SPOTNAME=`basename $GIS_OPT_FILE .HDF`
 fi
-if [ ! -z "$GIS_OPT_RAST" ] ; then
+if [ -n "$GIS_OPT_RAST" ] ; then
     NAME="$GIS_OPT_RAST"
 else
-    NAME=$SPOTNAME
+    NAME="$SPOTNAME"
 fi
-if [ ! -z `g.findfile elem=cell file="$NAME" | grep ^file | cut -f2 -d=` ] ; then
+if [ -n `g.findfile elem=cell file="$NAME" | grep ^file | cut -f2 -d=` ] ; then
 	g.message -e message="<$NAME> already exists. Aborting."
 	exit 1
 fi
-# still a ZIP file?
+# still a ZIP file?  (is this portable?? see the r.in.srtm script for ideas)
 if [ "`file -ib $GIS_OPT_FILE`" = "application/x-zip" ] ; then
   g.message -e message="Please extract $GIS_OPT_FILE before import."
   exit 1
@@ -186,6 +206,7 @@
 r.in.gdal "$VRTFILE" output="$NAME"
 if [ $? -eq 1 ] ; then
    g.message -e "An error occurred. Stop."
+   cleanup
    exit 1
 fi
@@ -200,10 +221,14 @@
 # Coefficient a = 0.004
 # Coefficient b = -0.1
+# clone current region
+g.region save="spot_$PID"
 # switch to a temporary region
-WIND_OVERRIDE=spot_$PID
+WIND_OVERRIDE="spot_$PID"
 export WIND_OVERRIDE
-g.region -d --quiet
 g.region rast="$NAME" --quiet
 g.message "Remapping digital numbers to NDVI..."
@@ -251,6 +276,7 @@
   r.in.gdal "$VRTFILE" output="$NAME.sm"
+     cleanup
      exit 1
   fi
@@ -278,13 +304,10 @@
   g.message message="Filtered SPOT VEGETATION NDVI map <${NAME}_filt>."
 fi
-# remove the temporary region
-g.remove region="spot_$PID" --quiet
-#### clean up the mess
-rm -f "$VRTFILE" "$TMPFILE"
+# remove the temporary region and files
+cleanup
-#### end
 # write cmd history:
 r.support "$NAME" history="${CMDLINE}"
