[GRASS-SVN] r31863 - grass-addons/visualization/nviz2/wxpython/nviz
Fri Jun 27 17:31:44 EDT 2008
Author: martinl
Date: 2008-06-27 17:31:43 -0400 (Fri, 27 Jun 2008)
New Revision: 31863
Added:
   grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/lights.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/load.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
nviz2: wxGUI-related fixes
some debug messages added to nviz Python extension
surface attributes: setting color attr functional (only map)
Modified: grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -29,7 +29,14 @@
 int Nviz::ResizeWindow(int width, int height)
-    return Nviz_resize_window(width, height);
+    int ret;
+    ret = Nviz_resize_window(width, height);
+    G_debug(1, "Nviz::ResizeWindow(): width=%d height=%d",
+	    width, height);
+    return ret;
@@ -50,6 +57,8 @@
     SetView(VIEW_DEFAULT_POS_X, VIEW_DEFAULT_POS_Y,
 	    vp_height, VIEW_DEFAULT_PERSP, VIEW_DEFAULT_TWIST);
+    G_debug(1, "Nviz::SetViewDefault()");
     return vp_height;
@@ -75,6 +84,9 @@
     Nviz_set_viewpoint_persp(data,
 			     persp);
+    G_debug(1, "Nviz::SetView(): x=%f, y=%f, height=%f, persp=%f, twist=%f",
+	    x, y, height, persp, twist);
     return 1;
@@ -87,5 +99,11 @@
 int Nviz::SetZExag(float z_exag)
-    return Nviz_change_exag(data, z_exag);
+    int ret;
+    ret = Nviz_change_exag(data, z_exag);
+    G_debug(1, "Nviz::SetZExag(): z_exag=%f", z_exag);
+    return ret;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -35,6 +35,8 @@
     else
 	Nviz_draw_quick(data);
+    G_debug(1, "Nviz::Draw(): quick=%d", quick);
     return;
@@ -45,5 +47,7 @@
     GS_clear(data->bgcolor);
+    G_debug(1, "Nviz::EraseMap()");
     return;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/init.cpp	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/init.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -37,6 +37,8 @@
     /* GLCanvas */
     glCanvas = NULL;
+    G_debug(1, "Nviz::Nviz()");
@@ -61,6 +63,8 @@
     glCanvas = (wxGLCanvas *) display;
     // glCanvas->SetCurrent();
+    G_debug(1, "Nviz::SetDisplay()");
     return 1;
@@ -83,6 +87,8 @@
     /* clear window */
+    G_debug(1, "Nviz::InitView()");
     return;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/lights.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/lights.cpp	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/lights.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -43,5 +43,7 @@
     Nviz_set_light_ambient(data, 1,
 			   0.3, 0.3, 0.3);
+    G_debug(1, "Nviz::SetLightsDefault()");
     return;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/load.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/load.cpp	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/load.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -29,8 +29,8 @@
   \param color_name raster map for color (NULL for color_value)
   \param color_value color string (named color or RGB triptet)
-  \return 1 on success
-  \return 0 on failure
+  \return object id
+  \return -1 on failure
 int Nviz::LoadRaster(const char* name, const char *color_name, const char *color_value)
@@ -41,7 +41,7 @@
     if (mapset == NULL) {
 	G_warning(_("Raster map <%s> not found"),
 		  name);
-	return 0;
+	return -1;
     /* topography */
@@ -55,7 +55,7 @@
 		      color_name);
 	    GS_delete_surface(id);
-	    return 0;
+	    return -1;
 	Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
@@ -81,5 +81,7 @@
     /* focus on loaded data */
     Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
-    return 1;
+    G_debug(1, "Nviz::LoadRaster(): name=%s", name);
+    return id;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
--- grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-06-27 16:50:35 UTC (rev 31862)
+++ grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-06-27 21:31:43 UTC (rev 31863)
@@ -45,34 +45,28 @@
     /* change_view.cpp */
     int ResizeWindow(int, int);
-    /* set */
-    /* init.cpp */
-    int SetDisplay(void *);
-    void Reset();
-    /* lights */
-    /* lights.cpp */
-    void SetLightsDefault();
-    /* viewport */
-    /* change_view.cpp */
     float SetViewDefault();
     int SetView(float, float,
 		float, float, float);
     int SetZExag(float);
     /* init.cpp */
+    int SetDisplay(void *);
     void InitView();
+    void Reset();
-    /* load data */
+    /* lights.cpp */
+    void SetLightsDefault();
     /* load.cpp */
     int LoadRaster(const char*, const char *, const char *);
-    /* draw */
     /* draw.cpp */
     void Draw(bool);
     void EraseMap();
+    /* surface.cpp */
+    void SetSurfaceColor(int, bool, const char *);
 #endif /* __NVIZ_H__ */
Added: grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	                        (rev 0)
+++ grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	2008-06-27 21:31:43 UTC (rev 31863)
@@ -0,0 +1,40 @@
+   \file map_obj.cpp
+   \brief Experimental C++ wxWidgets Nviz prototype -- map object management
+   Used by wxGUI Nviz extension.
+   Copyright: (C) by the GRASS Development Team
+   This program is free software under the GNU General Public
+   License (>=v2). Read the file COPYING that comes with GRASS
+   for details.
+   \author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+   \date 2008
+#include "nviz.h"
+void Nviz::SetSurfaceColor(int id, bool map, const char *value)
+    if (map) {
+	Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
+		      value, -1.0,
+		      data);
+    else {
+	float val;
+	val = atof(value);
+	Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT,
+		      NULL, val,
+		      data);
+    G_debug(1, "Nviz::SetSurfaceColor(): id=%d, map=%d, value=%s",
+	    id, map, value);
+    return;
