[GRASS-SVN] r31893 - in grass-addons/visualization/nviz2/wxpython: . nviz
Mon Jun 30 06:34:45 EDT 2008
Author: martinl
Date: 2008-06-30 06:34:45 -0400 (Mon, 30 Jun 2008)
New Revision: 31893
   grass-addons/visualization/nviz2/wxpython/nviz.py
   grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
   grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
   grass-addons/visualization/nviz2/wxpython/preferences.py
nviz2: wxGUI set draw resolution (fine, wire)
Modified: grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-06-30 09:49:08 UTC (rev 31892)
+++ grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-06-30 10:34:45 UTC (rev 31893)
@@ -30,6 +30,8 @@
     Nviz_draw_cplane(data, -1, -1);
+    data->draw_coarse = 1;
     if (data->draw_coarse) { /* coarse */
 	GS_set_draw(GSD_BACK);
 	GS_ready_draw();
Modified: grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
--- grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-06-30 09:49:08 UTC (rev 31892)
+++ grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-06-30 10:34:45 UTC (rev 31893)
@@ -79,6 +79,7 @@
     int UnsetSurfaceMask(int);
     int UnsetSurfaceTransp(int);
     int UnsetSurfaceEmit(int);
+    int SetSurfaceRes(int, int, int, int, int);
 #endif /* __NVIZ_H__ */
Modified: grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	2008-06-30 09:49:08 UTC (rev 31892)
+++ grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	2008-06-30 10:34:45 UTC (rev 31893)
@@ -206,3 +206,19 @@
     return Nviz_unset_attr(id, MAP_OBJ_SURF, attr);
+  \brief Set surface resolution
+  \param id surface id
+  \param xres,yres x/y resolution
+  \param xwire,ywire x/y wire resolution
+  \return -1 on error
+  \return 0 on success
+int Nviz::SetSurfaceRes(int id, int xres, int yres,
+			 int xwire, int ywire)
+    return GS_set_drawres(id, xres, yres, xwire, ywire);
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-30 09:49:08 UTC (rev 31892)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-30 10:34:45 UTC (rev 31893)
@@ -284,6 +284,12 @@
         for raster in self.Map.GetListOfLayers(l_type='raster', l_active=True):
             id = self.nvizClass.LoadRaster(str(raster.name), None, None)
+            # set resolution
+            res = UserSettings.Get(group='nviz', key='surface',
+                                   subkey=['draw', 'res-fine'])
+            wire = UserSettings.Get(group='nviz', key='surface',
+                                    subkey=['draw', 'res-coarse'])
+            self.nvizClass.SetSurfaceRes(id, res, res, wire, wire)
             self.object[self.Map.GetLayerIndex(raster)] = id
     def Reset(self):
@@ -628,8 +634,11 @@
                                  initial=1,
                                  min=1,
                                  max=100)
+        self.win['surface']['res'] = resolution.GetId()
         gridSizer.Add(item=resolution, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(0, 3))
+        # update resolution widget
+        self.SetSurfaceMode(mode.GetSelection())
         # style
         gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
@@ -915,7 +924,7 @@
                 del self.mapWindow.update[attr]
         # drawing mode
-        if self.update.has_key('draw-mode'):
+        if self.mapWindow.update.has_key('draw-mode'):
             self.mapWindow.nvizClass.SetDrawMode(self.update['draw-mode'])
         self.mapWindow.Refresh(False)
@@ -1013,16 +1022,29 @@
     def OnSurfaceMode(self, event):
         """Drawing mode changed"""
-        selection = event.GetSelection()
+        self.SetSurfaceMode(event.GetSelection())
+        event.Skip()
+    def SetSurfaceMode(self, selection):
+        """Set drawing mode and resolution"""
+        win = self.FindWindowById(self.win['surface']['res'])
         if selection == 0: # coarse
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_COARSE
+            if not win.IsEnabled():
+                win.Enable(True)
+            win.SetValue(UserSettings.Get(group='nviz', key='surface',
+                                          subkey=['draw', 'res-coarse']))
         elif selection == 1: # fine
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_FINE
+                win.Enable(True)
+                                          subkey=['draw', 'res-fine']))
         elif selection == 2: # both
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_BOTH
+            self.FindWindowById(self.win['surface']['res']).Enable(False)
-        event.Skip()
     def OnSurfaceStyle(self, event):
         pass
Modified: grass-addons/visualization/nviz2/wxpython/preferences.py
--- grass-addons/visualization/nviz2/wxpython/preferences.py	2008-06-30 09:49:08 UTC (rev 31892)
+++ grass-addons/visualization/nviz2/wxpython/preferences.py	2008-06-30 10:34:45 UTC (rev 31893)
@@ -237,9 +237,9 @@
                         'color' : (136, 136, 136, 255),
                         'mode' : 1, # fine
                         'style' : 1, # surface
-                        'shading' : 1, # gouraud
-                        'res-fine' : 1,
-                        'res-coarse' : 1,
+                        'shading' : 100, # gouraud
+                        'res-fine' : 6,
+                        'res-coarse' : 9,
                     'position' : {
                         'x' : 0,
