[GRASS-SVN] r30548 - in grass/trunk/scripts: d.polar d.vect.thematic db.dropcol db.in.ogr r.univar.sh v.db.dropcol v.db.univar v.in.e00 v.in.mapgen v.univar.sh
Thu Mar 13 04:57:27 EDT 2008
Author: hamish
Date: 2008-03-13 04:57:26 -0400 (Thu, 13 Mar 2008)
New Revision: 30548
   grass/trunk/scripts/d.polar/d.polar
   grass/trunk/scripts/d.vect.thematic/d.vect.thematic
   grass/trunk/scripts/db.dropcol/db.dropcol
   grass/trunk/scripts/db.in.ogr/db.in.ogr
   grass/trunk/scripts/r.univar.sh/r.univar.sh
   grass/trunk/scripts/v.db.dropcol/v.db.dropcol
   grass/trunk/scripts/v.db.univar/v.db.univar
   grass/trunk/scripts/v.in.e00/v.in.e00
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen
   grass/trunk/scripts/v.univar.sh/v.univar.sh
quote some filename variables
Modified: grass/trunk/scripts/d.polar/d.polar
--- grass/trunk/scripts/d.polar/d.polar	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/d.polar/d.polar	2008-03-13 08:57:26 UTC (rev 30548)
@@ -116,23 +116,23 @@
 # this file contains everthing:
-r.stats -1 "$GIS_OPT_MAP" > ${TMP}_raw
-TOTALNUMBER=`wc -l ${TMP}_raw | awk '{print $1}'`
+r.stats -1 "$GIS_OPT_MAP" > "${TMP}_raw"
+TOTALNUMBER=`wc -l "${TMP}_raw" | awk '{print $1}'`
 g.message "Calculating statistics for polar diagram... (be patient)"
 #wipe out NULL data and undef data if defined by user
 # - generate degree binned to integer, eliminate NO DATA (NULL):
 # change 360 to 0 to close polar diagram:
-cat ${TMP}_raw | grep -v '^\*$' | grep -v "^${GIS_OPT_UNDEF}$" | \
-    awk '{printf "%d\n", int($1 + .5)}' | sed 's+^360+0+g'  > ${TMP}_binned
+cat "${TMP}_raw" | grep -v '^\*$' | grep -v "^${GIS_OPT_UNDEF}$" | \
+    awk '{printf "%d\n", int($1 + .5)}' | sed 's+^360+0+g'  > "${TMP}_binned"
 # make radians
-cat ${TMP}_binned | awk '{printf "%f\n", (3.14159265 * $1 ) / 180.}'  > ${TMP}_binned_radians
+cat "${TMP}_binned" | awk '{printf "%f\n", (3.14159265 * $1 ) / 180.}'  > "${TMP}_binned_radians"
 # generate numbers for max circle
-TOTALVALIDNUMBER=`wc -l ${TMP}_binned_radians | awk '{print $1}'`
+TOTALVALIDNUMBER=`wc -l "${TMP}_binned_radians" | awk '{print $1}'`
 if [ "$TOTALVALIDNUMBER" -eq 0 ] ; then
    g.message -e "No data pixel found"
@@ -142,41 +142,41 @@
 # unit vector on raw data converted to radians without no data:
-cat ${TMP}_raw | grep -v '^\*' | grep -v "^${GIS_OPT_UNDEF}$" | awk 'BEGIN {sum = 0.0}
+cat "${TMP}_raw" | grep -v '^\*' | grep -v "^${GIS_OPT_UNDEF}$" | awk 'BEGIN {sum = 0.0}
 NR == 1{}
        {sum += cos(3.14159265 * $1 / 180.)}
-END{print sum}' > ${TMP}_cos_sums
+END{print sum}' > "${TMP}_cos_sums"
 NR == 1{}
        {sum += sin(3.14159265 * $1 / 180.)}
-END{print sum}' > ${TMP}_sin_sums
+END{print sum}' > "${TMP}_sin_sums"
 # cos -> x, sin -> y
-echo "`cat ${TMP}_cos_sums` $TOTALVALIDNUMBER" | awk '{printf "%.8f\n", $1/$2}' > ${TMP}_x_unit_vector
-echo "`cat ${TMP}_sin_sums` $TOTALVALIDNUMBER" | awk '{printf "%.8f\n", $1/$2}' > ${TMP}_y_unit_vector
-UNITVECTOR="`paste -d' ' ${TMP}_x_unit_vector ${TMP}_y_unit_vector`"
+echo "`cat "${TMP}_cos_sums"` $TOTALVALIDNUMBER" | awk '{printf "%.8f\n", $1/$2}' > "${TMP}_x_unit_vector"
+echo "`cat "${TMP}_sin_sums"` $TOTALVALIDNUMBER" | awk '{printf "%.8f\n", $1/$2}' > "${TMP}_y_unit_vector"
+UNITVECTOR=`paste -d' ' "${TMP}_x_unit_vector" "${TMP}_y_unit_vector"`
 # how many are there?:
-wordcount ${TMP}_binned_radians | sort -n -t ' ' -k 1 > ${TMP}_occurencies
+wordcount "${TMP}_binned_radians" | sort -n -t ' ' -k 1 > "${TMP}_occurrences"
 # find the maximum value
-MAXRADIUS="`cat ${TMP}_occurencies | sort -n -t ' ' -k 2 | tail -n 1 | cut -d' ' -f2`"
+MAXRADIUS="`cat "${TMP}_occurrences" | sort -n -t ' ' -k 2 | tail -n 1 | cut -d' ' -f2`"
 # now do cos() sin()
-cat ${TMP}_occurencies | awk '{printf "%f %f\n", cos($1) * $2 , sin($1) *$2}' > ${TMP}_sine_cosine
+cat "${TMP}_occurrences" | awk '{printf "%f %f\n", cos($1) * $2 , sin($1) *$2}' > "${TMP}_sine_cosine"
 # to close the curve, we replicate the first value
-REPLICATE=`head -n 1 ${TMP}_sine_cosine`
-echo "\"Real data angles"           >  ${TMP}_sine_cosine_replic
-cat ${TMP}_sine_cosine >> ${TMP}_sine_cosine_replic
-echo $REPLICATE >> ${TMP}_sine_cosine_replic
+REPLICATE=`head -n 1 "${TMP}_sine_cosine"`
+echo "\"Real data angles"           >  "${TMP}_sine_cosine_replic"
+cat "${TMP}_sine_cosine" >> "${TMP}_sine_cosine_replic"
+echo $REPLICATE >> "${TMP}_sine_cosine_replic"
 PI=3.14159265358979323846
 if [ -n "$GIS_OPT_EPS" ] || [ $GIS_FLAG_X -eq 1 ] ; then
   rm -f "${TMP}_outercircle"
-    echo "\"All Data incl. NULLs"           > ${TMP}_outercircle
+    echo "\"All Data incl. NULLs"           > "${TMP}_outercircle"
   awk -v PI=$PI -v TOTAL=$TOTALNUMBER -v TOTALVALID=$TOTALVALIDNUMBER \
       -v MAXRADIUS=$MAXRADIUS 'BEGIN {
@@ -185,16 +185,16 @@
 	      cos(i * PI/180) * TOTAL/TOTALVALID * MAXRADIUS,
 	      sin(i * PI/180) * TOTAL/TOTALVALID * MAXRADIUS)
-   }' >> ${TMP}_outercircle
+   }' >> "${TMP}_outercircle"
 fi
 # fix vector length to become visible (x? of $MAXRADIUS):
 AUTOSTRETCH="1"
-echo "\"Avg. Direction" >  ${TMP}_vector
-echo "0 0"         >> ${TMP}_vector
+echo "\"Avg. Direction" > "${TMP}_vector"
+echo "0 0"         >> "${TMP}_vector"
 echo "$UNITVECTOR $MAXRADIUS $AUTOSTRETCH" | \
-    awk '{printf "%f %f\n", $1 * $3, $2 * $3}' >> ${TMP}_vector
+    awk '{printf "%f %f\n", $1 * $3, $2 * $3}' >> "${TMP}_vector"
@@ -203,9 +203,9 @@
 plot_xgraph()
 # by M.Neteler
-echo "" > ${TMP}_newline
-cat ${TMP}_sine_cosine_replic ${TMP}_newline ${TMP}_outercircle \
-      ${TMP}_newline ${TMP}_vector | xgraph
+echo "" > "${TMP}_newline"
+cat "${TMP}_sine_cosine_replic" "${TMP}_newline" "${TMP}_outercircle" \
+      "${TMP}_newline" "${TMP}_vector" | xgraph
@@ -262,9 +262,9 @@
 SCALEVAL=`awk -v RING=$RING -v TOTAL=$TOTALNUMBER -v TOTALVALID=$TOTALVALIDNUMBER \
     'BEGIN { print RING * TOTALVALID/TOTAL }'`
-cat ${TMP}_sine_cosine_replic | tail -n +2 | awk -v SCL=$SCALEVAL -v MAX=$MAXRADIUS \
+cat "${TMP}_sine_cosine_replic" | tail -n +2 | awk -v SCL=$SCALEVAL -v MAX=$MAXRADIUS \
     '{printf "%f %f\n", ((SCL * $1/MAX) +1)*50, ((SCL * $2/MAX) +1)*50}' \
-       > ${TMP}_sine_cosine_replic_normalized
+       > "${TMP}_sine_cosine_replic_normalized"
 # create circle
 awk -v RING=$RING -v PI=$PI 'BEGIN {
@@ -272,10 +272,10 @@
      printf("%f %f\n", 50*(1+(RING * sin(i * (PI/180)))),
 	    50*(1+(RING * cos(i * (PI/180)))) )
- }' > ${TMP}_circle
+ }' > "${TMP}_circle"
 # trend vector
-VECT=`cat ${TMP}_vector | tail -n 1 | awk -v SCL=$SCALEVAL -v MAX=$MAXRADIUS \
+VECT=`cat "${TMP}_vector" | tail -n 1 | awk -v SCL=$SCALEVAL -v MAX=$MAXRADIUS \
     '{printf "%f %f\n", ((SCL * $1/MAX)+1)*50, ((SCL * $2/MAX)+1)*50}'`
@@ -296,7 +296,7 @@
   #   mandatory when drawing proportional to non-square frame
   color 180:255:180
   polyline
-    `cat ${TMP}_circle`
+    `cat "${TMP}_circle"`
   # draw axes
   color 180:180:180
@@ -310,7 +310,7 @@
   color red
   width 0
   polyline
-   `cat ${TMP}_sine_cosine_replic_normalized`
+   `cat "${TMP}_sine_cosine_replic_normalized"`
   # draw vector
   color blue
@@ -405,7 +405,7 @@
 AVERAGEDIRECTIONLEGENDY=`echo "1.85 $HALFFRAME" | awk '{printf "%.1f", $1 * $2}'`
-cat ${GISBASE}/etc/d.polar/ps_defs.eps > $PSOUT
+cat ${GISBASE}/etc/d.polar/ps_defs.eps > "$PSOUT"
 echo "
 $EPSSCALE $EPSSCALE scale                           %% EPS-SCALE EPS-SCALE scale
@@ -434,15 +434,15 @@
 newpath
                                         %% coordinates of rescaled, translated outer circle follow
                                         %% first point moveto, then lineto
-" >> $PSOUT
+" >> "$PSOUT"
-SUBLENGTH=`wc -l ${TMP}_outercircle | awk '{printf "%d", $1 - 2}'`
-LINE1=`head -n 2 ${TMP}_outercircle | tail -n 1`
-echo $LINE1 $SCALE $HALFFRAME | awk '{printf "%.2f %.2f moveto\n", $1*$3+$4, $2*$3+$4}' >> $PSOUT
+SUBLENGTH=`wc -l "${TMP}_outercircle" | awk '{printf "%d", $1 - 2}'`
+LINE1=`head -n 2 "${TMP}_outercircle" | tail -n 1`
+echo $LINE1 $SCALE $HALFFRAME | awk '{printf "%.2f %.2f moveto\n", $1*$3+$4, $2*$3+$4}' >> "$PSOUT"
-tail -n $SUBLENGTH ${TMP}_outercircle | sed "s+\$+ $SCALE $HALFFRAME+g" > ${TMP}_outercircle_lineto
+tail -n $SUBLENGTH "${TMP}_outercircle" | sed "s+\$+ $SCALE $HALFFRAME+g" > "${TMP}_outercircle_lineto"
-cat ${TMP}_outercircle_lineto | awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> $PSOUT
+cat "${TMP}_outercircle_lineto" | awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> "$PSOUT"
 rm -f "${TMP}_outercircle_lineto"
 echo "stroke
@@ -470,15 +470,18 @@
 newpath
                                         %% coordinates of rescaled, translated diagram follow
-" >> $PSOUT
+" >> "$PSOUT"
-SUBLENGTH=`wc -l ${TMP}_sine_cosine_replic | awk '{printf "%d", $1 - 2}'`
-LINE1=`head -n 2 ${TMP}_sine_cosine_replic | tail -n 1`
+SUBLENGTH=`wc -l "${TMP}_sine_cosine_replic" | awk '{printf "%d", $1 - 2}'`
+LINE1=`head -n 2 "${TMP}_sine_cosine_replic" | tail -n 1`
-tail -n $SUBLENGTH ${TMP}_sine_cosine_replic | sed "s+\$+ $SCALE $HALFFRAME+g" > ${TMP}_sine_cosine_replic_lineto
+tail -n $SUBLENGTH "${TMP}_sine_cosine_replic" | \
+   sed "s+\$+ $SCALE $HALFFRAME+g" > "${TMP}_sine_cosine_replic_lineto"
-cat ${TMP}_sine_cosine_replic_lineto | awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> $PSOUT
+cat "${TMP}_sine_cosine_replic_lineto" | \
+   awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> "$PSOUT"
 rm -f "${TMP}_sine_cosine_replic_lineto"
 echo "stroke
@@ -494,13 +497,13 @@
                                         %% first point moveto, second lineto
 " >> $PSOUT
-SUBLENGTH=`wc -l ${TMP}_vector | awk '{printf "%d", $1 - 2}'`
-LINE1=`head -n 2 ${TMP}_vector | tail -n 1`
+SUBLENGTH=`wc -l "${TMP}_vector" | awk '{printf "%d", $1 - 2}'`
+LINE1=`head -n 2 "${TMP}_vector" | tail -n 1`
-tail -n $SUBLENGTH ${TMP}_vector | sed "s+\$+ $SCALE $HALFFRAME+g" > ${TMP}_vector_lineto
+tail -n $SUBLENGTH "${TMP}_vector" | sed "s+\$+ $SCALE $HALFFRAME+g" > "${TMP}_vector_lineto"
-cat ${TMP}_vector_lineto | awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> $PSOUT
+cat "${TMP}_vector_lineto" | awk '{printf "%.2f %.2f lineto\n",$1*$3+$4, $2*$3+$4 }' >> "$PSOUT"
 rm -f "${TMP}_vector_lineto"
 echo "stroke
@@ -520,7 +523,7 @@
 col1                                    %% colAVERAGE-DIRECTION-COLOR
 %% Line below: (AVERAGE-DIRECTION-STRING) LEGENDS-X AVERAGE-DIRECTION-LEGEND-Y 4 just-string
 ($AVERAGEDIRECTIONSTRING) $LEGENDSX $AVERAGEDIRECTIONLEGENDY 4 just-string
-" >> $PSOUT
+" >> "$PSOUT"
 g.message "Done."
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic	2008-03-13 08:57:26 UTC (rev 30548)
@@ -394,15 +394,15 @@
  fi
 fi
-min="`grep 'min=' $TMP1 | sed s/min=//`"
-max="`grep 'max=' $TMP1 | sed s/max=//`"
-mean="`grep 'mean=' $TMP1 | sed s/mean=//`"
-sd="`grep 'population_stddev=' $TMP1 | sed s/'population_stddev='//`"
-q1="`grep 'first_quartile=' $TMP1 | sed s/'first_quartile='//`"
-q2="`grep 'median=' $TMP1 | sed s/'median='//`"
-q3="`grep 'third_quartile=' $TMP1 | sed s/'third_quartile='//`"
-q4=$max
-ptsize=$GIS_OPT_SIZE
+min=`grep 'min=' "$TMP1" | sed s/min=//`
+max=`grep 'max=' "$TMP1" | sed s/max=//`
+mean=`grep 'mean=' "$TMP1" | sed s/mean=//`
+sd=`grep 'population_stddev=' "$TMP1" | sed s/'population_stddev='//`
+q1=`grep 'first_quartile=' "$TMP1" | sed s/'first_quartile='//`
+q2=`grep 'median=' "$TMP1" | sed s/'median='//`
+q3=`grep 'third_quartile=' "$TMP1" | sed s/'third_quartile='//`
+q4="$max"
+ptsize="$GIS_OPT_SIZE"
 if [ -n "$GIS_OPT_BREAKPOINTS" ] && [ "$GIS_OPT_THEMECALC" != "custom_breaks" ] ; then
     g.message -w "Custom breakpoints ignored due to themecalc setting."
@@ -471,11 +471,11 @@
 echo "title - - - {Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP}" > "$TMP6"
 echo "text 1% 95% Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP" >> "$TMP5"
-echo "  ref bottom left" >> $TMP5
-echo "end" >> $TMP5
+echo "  ref bottom left" >> "$TMP5"
+echo "end" >> "$TMP5"
 echo "text 4% 90% Value range: $min - $max" >> "$TMP5"
 g.message message="Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP"
 g.message message="Value range: $min - $max"
@@ -558,8 +558,8 @@
 		echo "subtitle - - - {Mapped by $numint intervals of $step}" >> "$TMP6"
         echo "text 4% 87% Mapped by $numint intervals of $step" >> "$TMP5"
-        echo "  ref bottom left" >> $TMP5
-        echo "end" >> $TMP5
+        echo "  ref bottom left" >> "$TMP5"
+        echo "end" >> "$TMP5"
         g.message message="Mapped by $numint intervals of $step"
     fi
@@ -573,8 +573,8 @@
 		echo "subtitle - - - {Mapped by standard deviation units of $sd (mean =$mean)}" >> "$TMP6"
         echo "text 4% 87% Mapped by standard deviation units of $sd (mean =$mean)" >> "$TMP5"
         g.message message="Mapped by standard deviation units of $sd (mean =$mean)"
     fi
@@ -588,8 +588,8 @@
 		echo "subtitle - - - {Mapped by quartiles (median =$q2)}" >> "$TMP6"
         echo "text 4% 87% Mapped by quartiles (median =$q2)" >> "$TMP5"
@@ -607,17 +607,17 @@
     echo "text 4% 83% Color" >> "$TMP5"
     echo "text 14% 83% Value" >> "$TMP5"
     echo "text 4% 80% =====" >> "$TMP5"
     echo "text 14% 80% ============" >> "$TMP5"
     echo "Color(R:G:B)" "Value" | awk '{print $1 "\t" $2}'
@@ -695,7 +695,7 @@
         echo "text $openbracket$rangemin - $rangemax$closebracket $extranote"  >> "$TMP2"
     else
         if [ $i -eq $xlower ]; then
-            echo "color 0:0:0" >>"$TMP2"
+            echo "color 0:0:0" >> "$TMP2"
             echo "move 10 $line2" >> "$TMP2"
             echo "text ..." >> "$TMP2"
         else
@@ -708,12 +708,12 @@
       echo "area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
         if [ "$GIS_OPT_TYPE" = "line" -o "$GIS_OPT_TYPE" = "boundary" ] ; then
-          echo "line 5% $xline1% 8% $xline1%" >> $TMP5
-          echo "  color $linecolor" >> $TMP5
+          echo "line 5% $xline1% 8% $xline1%" >> "$TMP5"
+          echo "  color $linecolor" >> "$TMP5"
           echo "text 14% $xline1% $openbracket$rangemin - $rangemax$closebracket $extranote"  >> "$TMP5"
-          echo "  ref center left" >> $TMP5
+          echo "  ref center left" >> "$TMP5"
         elif [ "$GIS_OPT_TYPE" = "point" -o "$GIS_OPT_TYPE" = "centroid" ] ; then
           echo "point 8% $xline1%" >> "$TMP5"
@@ -722,23 +722,23 @@
           echo "  symbol $GIS_OPT_ICON" >> "$TMP5"
         else
           echo "rectangle 5% $xline1% 8% $xline3%" >> "$TMP5"
           echo "  color 0:0:0" >> "$TMP5"
           echo "  fcolor $themecolor" >> "$TMP5"
           echo "text 14% $xline3% $openbracket$rangemin - $rangemax$closebracket DCADCA $extranote"  >> "$TMP5"
         fi
     else
             echo "color 0:0:0" >>"$TMP5"
             echo "text 14% $xline3% ..." >> "$TMP5"
             echo "text - - - {...}" >> "$TMP6"
         fi
@@ -821,31 +821,31 @@
             color=$linecolor fcolor=$themecolor icon=$GIS_OPT_ICON size=$ptsize
-		  echo "vlines $GIS_OPT_MAP" >> $TMP4
-		  echo "  type $GIS_OPT_TYPE" >> $TMP4
-		  echo "  layer $GIS_OPT_LAYER" >> $TMP4
-		  echo "  where $sqlwhere" >> $TMP4
-		  echo "  color $linecolor" >> $TMP4
-		  echo "  label $rangemin - $rangemax" >> $TMP4
-		  echo "end" >> $TMP4
+		  echo "vlines $GIS_OPT_MAP" >> "$TMP4"
+		  echo "  type $GIS_OPT_TYPE" >> "$TMP4"
+		  echo "  layer $GIS_OPT_LAYER" >> "$TMP4"
+		  echo "  where $sqlwhere" >> "$TMP4"
+		  echo "  color $linecolor" >> "$TMP4"
+		  echo "  label $rangemin - $rangemax" >> "$TMP4"
+		  echo "end" >> "$TMP4"
-		  echo "vpoints $GIS_OPT_MAP" >> $TMP4
-		  echo "  fcolor $themecolor" >> $TMP4
-		  echo "  symbol $GIS_OPT_ICON" >> $TMP4
+		  echo "vpoints $GIS_OPT_MAP" >> "$TMP4"
+		  echo "  fcolor $themecolor" >> "$TMP4"
+		  echo "  symbol $GIS_OPT_ICON" >> "$TMP4"
 	else
-		  echo "vareas $GIS_OPT_MAP" >> $TMP4
+		  echo "vareas $GIS_OPT_MAP" >> "$TMP4"
 	fi
@@ -879,8 +879,8 @@
     fi
@@ -894,8 +894,8 @@
     fi
@@ -909,8 +909,8 @@
         g.message message="Mapped by quartiles (median = $q2)"
     fi
@@ -928,17 +928,17 @@
     echo "text 4% 83% Icon size" >> "$TMP5"
     echo "text 25% 83% Value" >> "$TMP5"
     echo "text 4% 80% ============" >> "$TMP5"
     echo "text 25% 80% ============" >> "$TMP5"
     echo "Size/width" "Value" | awk '{print $1 " " $2"\t"$3}'
@@ -1036,8 +1036,8 @@
         echo "text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote"  >> "$TMP5"
     else
 	    echo "text 25% $xline1% ..."  >> "$TMP5"
@@ -1121,16 +1121,16 @@
 		fi
-	  echo "  size $ptsize" >> $TMP4
+	  echo "  size $ptsize" >> "$TMP4"
         ptsize=`echo $ptsize $pointstep | awk '{print $1 - $2}'`
@@ -1158,7 +1158,7 @@
         d.mon select=$GIS_OPT_MONITOR > /dev/null
         d.erase
     fi
-    d.graph input=$TMP2
+    d.graph input="$TMP2"
     if [ -n "$currmon" ] ; then
       d.mon select=$currmon
     fi
@@ -1167,27 +1167,27 @@
 # Create group file for GIS Manager
 echo "End" >> "$TMP3"
 if [ "$GIS_FLAG_G" -eq 1 ] ; then
-    cat $TMP3 > $group".dm"
+    cat "$TMP3" > "${group}.dm"
 fi
 # Create ps.map map file
 if [ "$GIS_OPT_PSMAP" ] ; then
-    cat $TMP4 > $GIS_OPT_PSMAP.psmap
+    cat "$TMP4" > "$GIS_OPT_PSMAP.psmap"
 fi
 # Create ps.map legend file
-    cat $TMP5 > $GIS_OPT_PSMAP\_legend.psmap
+    cat "$TMP5" > "$GIS_OPT_PSMAP\_legend.psmap"
 fi
 # Create text file to use with d.graph in GIS Manager
 if [ "$GIS_FLAG_S" -eq 1 ] ; then
-	tmpdir=`eval dirname $TMP6`
+	tmpdir=`eval dirname "$TMP6"`
 	tlegfile="$tmpdir/gismlegend.txt"
 #	echo $tlegfile > outtxt.txt
-    cp $TMP6 $tlegfile
+    cp "$TMP6" "$tlegfile"
 fi
 cleanup
Modified: grass/trunk/scripts/db.dropcol/db.dropcol
--- grass/trunk/scripts/db.dropcol/db.dropcol	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/db.dropcol/db.dropcol	2008-03-13 08:57:26 UTC (rev 30548)
@@ -131,11 +131,11 @@
 if [ "$driver" = "sqlite" ] ; then
 	#echo "Using special trick for SQLite"
 	# http://www.sqlite.org/faq.html#q13
-	db.describe -c $table | grep '^Column ' | cut -d':' -f2,3 | grep -v "${col}:" > $TMP.coldesc
-	cat $TMP.coldesc | cut -d':' -f2 > $TMP.coltypes
-	cat $TMP.coldesc | cut -d':' -f1 > $TMP.colnames
-	COLDEF=`paste -d' ' $TMP.colnames $TMP.coltypes | tr '\n' ',' | sed 's+,$++g'`
-	COLNAMES=`cat $TMP.colnames | tr '\n' ',' | sed 's+,$++g'`
+	db.describe -c $table | grep '^Column ' | cut -d':' -f2,3 | grep -v "${col}:" > "$TMP.coldesc"
+	cat "$TMP.coldesc" | cut -d':' -f2 > "$TMP.coltypes"
+	cat "$TMP.coldesc" | cut -d':' -f1 > "$TMP.colnames"
+	COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n' ',' | sed 's+,$++g'`
+	COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
 echo "BEGIN TRANSACTION;
 CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
 INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
@@ -143,8 +143,8 @@
 CREATE TABLE ${table}(${COLDEF});
 INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
 DROP TABLE ${table}_backup;
-COMMIT;" > $TMP
-	db.execute input=$TMP
+COMMIT;" > "$TMP"
+	db.execute input="$TMP"
 	if [ $? -eq 1 ] ; then
 	    	g.message -e "Cannot continue (problem deleting column)."
 	    	cleanup
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr
--- grass/trunk/scripts/db.in.ogr/db.in.ogr	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr	2008-03-13 08:57:26 UTC (rev 30548)
@@ -89,8 +89,8 @@
 if [ -z "$GIS_OPT_OUTPUT" ] ; then
   # file name laundery
-  TMPNAME="`echo $INPUT | tr -s '.' '_'`"
-  GIS_OPT_OUTPUT="`basename $TMPNAME`"
+  TMPNAME=`echo "$INPUT" | tr -s '.' '_'`
+  GIS_OPT_OUTPUT=`basename "$TMPNAME"`
 fi
 if [ -z "$GRASS_OVERWRITE" ] ; then
Modified: grass/trunk/scripts/r.univar.sh/r.univar.sh
--- grass/trunk/scripts/r.univar.sh/r.univar.sh	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/r.univar.sh/r.univar.sh	2008-03-13 08:57:26 UTC (rev 30548)
@@ -101,7 +101,7 @@
 # calculate statistics
 g.message "Calculating statistics..."
-cat $TMP | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
+cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
 function abs(x){return x < 0 ? -x : x}
 NR == 1{min = $1 ; max = $1}
        {sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++}
@@ -124,14 +124,14 @@
 if [ $GIS_FLAG_E -eq 1 ] ; then
   #preparations:
-  cat $TMP | sort -n > $TMP.sort
-  NUMBER=`cat $TMP.sort | wc -l | awk '{print $1}'`
+  cat "$TMP" | sort -n > "$TMP.sort"
+  NUMBER=`cat "$TMP.sort" | wc -l | awk '{print $1}'`
   ODDEVEN=`echo $NUMBER | awk '{print $1%2}'`
   # 0.25 quartile
   QUARTILE=0.25
   QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2 + 0.5}'`
-  QELEMENT=`head -n $QPOS $TMP.sort | tail -n 1`
+  QELEMENT=`head -n $QPOS "$TMP.sort" | tail -n 1`
   echo "1st Quartile: $QELEMENT"
   #Calculate median
@@ -141,13 +141,13 @@
    EVENMEDIANNUMBER=`expr $NUMBER / 2`
    EVENMEDIANNUMBERPLUSONE=`expr $EVENMEDIANNUMBER + 1`
    # select two numbers
-   SELECTEDNUMBERS=`cat $TMP.sort | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
+   SELECTEDNUMBERS=`cat "$TMP.sort" | head -n "$EVENMEDIANNUMBERPLUSONE" | tail -n 2`
    RESULTEVENMEDIAN=`echo $SELECTEDNUMBERS | awk '{printf "%f", ($1 + $2)/2.0}'`
    echo "Median (even N): $RESULTEVENMEDIAN"
   else
    # odd
    ODDMEDIANNUMBER=`echo $NUMBER | awk '{printf "%d", int($1/2+.5)}'`
-   RESULTODDMEDIAN=`cat $TMP.sort | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
+   RESULTODDMEDIAN=`cat "$TMP.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
    echo "Median (odd N): $RESULTODDMEDIAN"
   fi
@@ -155,13 +155,13 @@
   # 0.75 quartile
   QUARTILE=0.75
   echo "3rd Quartile: $QELEMENT"
   # XX percentile
   QUARTILE=$GIS_OPT_PERCENTILE
   QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2/100. + 0.5}'`
-  QELEMENT=`head -n $QPOS $TMP.sort | tail -1`
+  QELEMENT=`head -n $QPOS "$TMP.sort" | tail -1`
   echo "${GIS_OPT_PERCENTILE} Percentile: $QELEMENT"
 fi
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol	2008-03-13 08:57:26 UTC (rev 30548)
@@ -125,12 +125,12 @@
-	v.info --q -c map=$table | cut -d'|' -f1,2 | grep -v "|${col}$" > $TMP.coldesc
+	v.info --q -c map=$table | cut -d'|' -f1,2 | grep -v "|${col}$" > "$TMP.coldesc"
 	# need to revert order:
-	cat $TMP.coldesc | cut -d'|' -f1 > $TMP.coltypes
-	cat $TMP.coldesc | cut -d'|' -f2 > $TMP.colnames
+	cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
+	cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
@@ -138,8 +138,8 @@
-COMMIT;" > $TMP
+COMMIT;" > "$TMP"
 	    	g.message -e 'Cannot continue (problem deleting column)'
 	    	cleanup
Modified: grass/trunk/scripts/v.db.univar/v.db.univar
--- grass/trunk/scripts/v.db.univar/v.db.univar	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/v.db.univar/v.db.univar	2008-03-13 08:57:26 UTC (rev 30548)
@@ -139,7 +139,7 @@
-cat $TMP | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
+cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
 (NF>0) {
 	sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++;
@@ -167,14 +167,14 @@
   #preparations:
   # 0.25 quartile
   QUARTILE=0.25
   #Calculate median
@@ -184,13 +184,13 @@
+   SELECTEDNUMBERS=`cat "$TMP.sort" | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
   else
    # odd
   fi
@@ -198,13 +198,13 @@
   # 0.75 quartile
   QUARTILE=0.75
   # 0.90 percentile
   QUARTILE=0.9
   echo "90th Percentile: $QELEMENT"
 fi
Modified: grass/trunk/scripts/v.in.e00/v.in.e00
--- grass/trunk/scripts/v.in.e00/v.in.e00	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/v.in.e00/v.in.e00	2008-03-13 08:57:26 UTC (rev 30548)
@@ -165,11 +165,11 @@
 if [ $MERGING -eq 1 ] ; then
   if  [ "$EXTENSION" = "CAPS" ] ; then
-     cat `ls -1 $E00NAME.E* | sort` > $E00NAME.cat.$E00TMP.e00
+     cat `ls -1 "$E00NAME.E"* | sort` > "$E00NAME.cat.$E00TMP.e00"
      GIS_OPT_FILE="$E00NAME.cat.$E00TMP.e00"
   fi
   if  [ "$EXTENSION" = "NOCAPS" ] ; then
-     cat `ls -1 $E00NAME.e* | sort` > $E00NAME.cat.$E00TMP.e00
+     cat `ls -1 "$E00NAME.e"* | sort` > "$E00NAME.cat.$E00TMP.e00"
   fi
 fi
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen	2008-03-13 08:57:26 UTC (rev 30548)
@@ -122,7 +122,7 @@
   #  tac $FILE | $AWK 'BEGIN { FS="," ; R=0 }
   #    $1~/\d*/   { printf("L %d\n", R) }
   #    $1~/   .*/ { printf(" %lf %lf\n", $2, $1) ; ++R }
-  #    $1~/END/   { }' | tac > $TMP
+  #    $1~/END/   { }' | tac > "$TMP"
   ## matlab format. Cleanse with NaN->nan and spaces to tabs
   tac "$FILE" | awk '{print $1 "\t" $2 "\t" $3}
Modified: grass/trunk/scripts/v.univar.sh/v.univar.sh
--- grass/trunk/scripts/v.univar.sh/v.univar.sh	2008-03-13 08:01:14 UTC (rev 30547)
+++ grass/trunk/scripts/v.univar.sh/v.univar.sh	2008-03-13 08:57:26 UTC (rev 30548)
@@ -170,14 +170,14 @@
   #preparations:
-  cat "$TMP" | sort -n > $TMP.sort
   ODDEVEN=`echo "$NUMBER" | awk '{print $1%2}'`
   # 0.25 quartile
   QUARTILE=0.25
   #Calculate median
@@ -187,13 +187,13 @@
   else
    # odd
   fi
@@ -201,13 +201,13 @@
   # 0.75 quartile
   QUARTILE=0.75
   # 0.90 percentile
   QUARTILE=0.9
 fi
