[GRASS-SVN] r30774 - grass/trunk/lib/init
Fri Mar 28 02:55:48 EDT 2008
Author: hamish
Date: 2008-03-28 02:55:47 -0400 (Fri, 28 Mar 2008)
New Revision: 30774
   grass/trunk/lib/init/grass.bat
move %PATH% to end as MSys versions of generic tool names should probably take precidence
Modified: grass/trunk/lib/init/grass.bat
--- grass/trunk/lib/init/grass.bat	2008-03-28 04:23:07 UTC (rev 30773)
+++ grass/trunk/lib/init/grass.bat	2008-03-28 06:55:47 UTC (rev 30774)
@@ -20,7 +20,7 @@
 rem Path to utilities used by some scripts, such as awk, sed, etc
 rem (adjust to where you installed msys, gnuwin32, or other similar utilises)
-rem set PATH=%PATH%;c:\msys\1.0\bin;c:\msys\1.0\lib
+rem set PATH=c:\msys\1.0\bin;c:\msys\1.0\lib;%PATH%
 rem Path to your web browser
 rem set GRASS_HTML_BROWSER=%SYSTEMDRIVE%/PROGRA~1/INTERN~1/IEXPLORE.EX
