[GRASS-SVN] r30788 - grass/trunk/visualization/nviz/src
Fri Mar 28 19:38:13 EDT 2008
Author: glynn
Date: 2008-03-28 19:38:13 -0400 (Fri, 28 Mar 2008)
New Revision: 30788
   grass/trunk/visualization/nviz/src/do_zoom.c
   grass/trunk/visualization/nviz/src/interface.h
Clean-up, handle more failure modes
Modified: grass/trunk/visualization/nviz/src/do_zoom.c
--- grass/trunk/visualization/nviz/src/do_zoom.c	2008-03-28 22:10:32 UTC (rev 30787)
+++ grass/trunk/visualization/nviz/src/do_zoom.c	2008-03-28 23:38:13 UTC (rev 30788)
@@ -25,6 +25,7 @@
 #include <GL/glx.h>
 static Display *dpy;
+static int scr;
 static GLXContext ctx;
 #ifdef HAVE_PBUFFERS
 static GLXPbuffer pbuffer;
@@ -37,6 +38,8 @@
 extern void swap_togl(void);
+static int init_ctx(void);
 int Nstart_zoom_cmd(Nv_data * data,	/* Local data */
 		    Tcl_Interp * interp,	/* Current interpreter */
@@ -202,20 +205,16 @@
     return (TCL_OK);
  * callbacks for PBuffer and GLXPixmap to
  * swap buffers
-void swap_os(void)
+static void swap_os(void)
 #ifdef OPENGL_X11
     if (pbuffer)
 	glXSwapBuffers(dpy, pbuffer);
-	return;
 #endif
 #ifdef HAVE_PIXMAPS
     if (glxpixmap)
@@ -227,125 +226,148 @@
  * open an off-screen render context
-int Create_OS_Ctx(int width, int height)
+static void create_pbuffer(int width, int height)
-#if defined(OPENGL_X11) && (defined(HAVE_PBUFFERS) || defined(HAVE_PIXMAPS))
-    int scr;
-    GLXFBConfig *fbc;
+#if defined(GLX_PBUFFER_WIDTH) && defined(GLX_PBUFFER_HEIGHT)
+    static int ver_major, ver_minor;
+    static int fb_attrib[] = {
+	GLX_DOUBLEBUFFER, False,
+	GLX_RED_SIZE, 1,
+	GLX_GREEN_SIZE, 1,
+	GLX_BLUE_SIZE, 1,
+	GLX_DEPTH_SIZE, 1,
+	GLX_DRAWABLE_TYPE, GLX_PBUFFER_BIT,
+	None
+    static GLXFBConfig *fbc;
+    int pbuf_attrib[] = {
+	GLX_PBUFFER_WIDTH, width,
+	GLX_PBUFFER_HEIGHT, height,
+	None
     int elements;
-#endif
     XVisualInfo *vi;
-    dpy = togl_display();
-    if (dpy == NULL) {
-	fprintf(stderr, "Togl_Display Failed!\n");
-	return (-1);
+    if (fbc) {
+	XFree(fbc);
+	fbc = NULL;
-    scr = togl_screen_number();
-#ifdef HAVE_PBUFFERS
-#if defined(GLX_PBUFFER_WIDTH) && defined(GLX_PBUFFER_HEIGHT)
-    if (!getenv("GRASS_NO_GLX_PBUFFERS"))
-	static int ver_major, ver_minor;
+    if (getenv("GRASS_NO_GLX_PBUFFERS"))
+	return;
-	if (!ver_major)
-	    glXQueryVersion(dpy, &ver_major, &ver_minor);
+    if (!ver_major)
+	glXQueryVersion(dpy, &ver_major, &ver_minor);
-	if (ver_minor >= 3)
-	    int fb_attrib[] = {
-		GLX_DOUBLEBUFFER, False,
-		GLX_RED_SIZE, 1,
-		GLX_GREEN_SIZE, 1,
-		GLX_BLUE_SIZE, 1,
-		GLX_DEPTH_SIZE, 1,
-		GLX_DRAWABLE_TYPE, GLX_PBUFFER_BIT,
-		None
+    if (ver_minor < 3)
+	return;
-	    fprintf(stderr, "Creating PBuffer Using GLX 1.3\n");
+    fprintf(stderr, "Creating PBuffer Using GLX 1.3\n");
-	    fbc = glXChooseFBConfig(dpy, scr, fb_attrib, &elements);
-	    if (fbc)
-		int pbuf_attrib[] = {
-		    GLX_PBUFFER_WIDTH, width,
-		    GLX_PBUFFER_HEIGHT, height,
-		    None
+    fbc = glXChooseFBConfig(dpy, scr, fb_attrib, &elements);
+    if (!fbc) {
+	fprintf(stderr, "Unable to get FBConfig\n");
+	return;
-		pbuffer = glXCreatePbuffer(dpy, fbc[0], pbuf_attrib);
-		if (pbuffer)
-		    vi = glXGetVisualFromFBConfig(dpy, fbc[0]);
-		    if (vi == NULL) {
-			fprintf(stderr, "Unable to get Visual\n");
-			return (-1);
+    vi = glXGetVisualFromFBConfig(dpy, fbc[0]);
+    if (!vi) {
+	fprintf(stderr, "Unable to get Visual\n");
+	return;
-		    ctx = glXCreateContext(dpy, vi, NULL, GL_FALSE);
-		    if (ctx == NULL) {
-			fprintf(stderr, "Unable to create context\n");
-			return (-1);
+    ctx = glXCreateContext(dpy, vi, NULL, False);
+    if (!ctx) {
+	fprintf(stderr, "Unable to create context\n");
+	return;
-		    glXMakeContextCurrent(dpy, pbuffer, pbuffer, ctx);
+    pbuffer = glXCreatePbuffer(dpy, fbc[0], pbuf_attrib);
+    if (!pbuffer) {
+	fprintf(stderr, "Unable to create Pbuffer\n");
+	return;
+    if (!glXMakeContextCurrent(dpy, pbuffer, pbuffer, ctx)) {
+	fprintf(stderr, "Unable to use context\n");
+	glXDestroyPbuffer(dpy, pbuffer);
+	pbuffer = None;
+	return;
 #endif
 #endif
+static void create_pixmap(int width, int height)
 #ifdef HAVE_PIXMAPS
-    if (!pbuffer)
-#endif
-    if (!getenv("GRASS_NO_GLX_PIXMAPS"))
-	int att[] = {
-	    GLX_RGBA,
-	    GLX_RED_SIZE, 1,
-	    GLX_BLUE_SIZE, 1,
-	    None
-	fprintf(stderr, "Create PixMap Using GLX 1.1\n");
+    static int att[] = {
+	GLX_RGBA,
+	GLX_RED_SIZE, 1,
+	GLX_BLUE_SIZE, 1,
+	None
+    XVisualInfo *vi;
-	vi = glXChooseVisual(dpy, scr, att);
-	if (vi == NULL) {
-	    return (-1);
+    if (getenv("GRASS_NO_GLX_PIXMAPS"))
+	return;
-	    return (-1);
+    fprintf(stderr, "Create PixMap Using GLX 1.1\n");
-	pixmap =
-	    XCreatePixmap(dpy, RootWindow(dpy, vi->screen), width, height,
-			  vi->depth);
-	if (!pixmap) {
-	    fprintf(stderr, "Unable to create pixmap\n");
-	    return (-1);
-	glxpixmap = glXCreateGLXPixmap(dpy, vi, pixmap);
-	if (!glxpixmap) {
-	    return (-1);
-	glXMakeCurrent(dpy, glxpixmap, ctx);
+    vi = glXChooseVisual(dpy, scr, att);
+    if (!vi) {
+	return;
+    ctx = glXCreateContext(dpy, vi, NULL, GL_FALSE);
+    if (!ctx) {
+	return;
+    pixmap = XCreatePixmap(dpy, RootWindow(dpy, vi->screen),
+			   width, height, vi->depth);
+    if (!pixmap) {
+	fprintf(stderr, "Unable to create pixmap\n");
+	return;
+    glxpixmap = glXCreateGLXPixmap(dpy, vi, pixmap);
+    if (!glxpixmap) {
+	fprintf(stderr, "Unable to create GLX pixmap\n");
+	return;
+    if (!glXMakeCurrent(dpy, glxpixmap, ctx)) {
+	glXDestroyGLXPixmap(dpy, glxpixmap);
+	glxpixmap = None;
+	return;
 #endif
+int Create_OS_Ctx(int width, int height)
+#if defined(OPENGL_X11) && (defined(HAVE_PBUFFERS) || defined(HAVE_PIXMAPS))
+    dpy = togl_display();
+    if (dpy == NULL) {
+	fprintf(stderr, "Togl_Display Failed!\n");
+	return (-1);
+    scr = togl_screen_number();
+    create_pbuffer(width, height);
+#ifdef HAVE_PBUFFERS
+    if (!pbuffer)
+#endif
+    create_pixmap(width, height);
     if (!pbuffer && !glxpixmap)
-	    return 1;
+	return 1;
     /* hide togl canvas before init_ctx
      * This prevents bindings from re-initializing
@@ -353,14 +375,13 @@
     hide_togl_win();
     /* Initalize off screen context */
-	if ( init_ctx() != 1) {
-		fprintf(stderr, "Error: Failed to Initiailze drawing area\n");
-		return (-1);
+    if ( init_ctx() != 1) {
+	fprintf(stderr, "Error: Failed to Initiailze drawing area\n");
+	return (-1);
     GS_set_swap_func(swap_os);
     GS_set_viewport(0, width, 0, height);
     GS_set_draw(GSD_BACK);
     GS_ready_draw();
@@ -368,9 +389,7 @@
     GS_done_draw();
     return (1);
 #else
     fprintf(stderr, "It appears that X is not available!\n");
     return (-1);
 #endif /* defined(OPENGL_X11) && (defined(HAVE_PBUFFERS) || defined(HAVE_PIXMAPS)) */
@@ -411,9 +430,7 @@
 	fprintf(stderr, "Destroy Pixmap\n");
 	XFreePixmap(dpy, pixmap);
 	pixmap = None;
-	return (1);
 #endif
     GS_set_swap_func(swap_togl);
     show_togl_win();
@@ -426,7 +443,7 @@
  * Initialize graphics (lights) for new context
-int init_ctx(void)
     float x, y, z;
     int num, w;
Modified: grass/trunk/visualization/nviz/src/interface.h
--- grass/trunk/visualization/nviz/src/interface.h	2008-03-28 22:10:32 UTC (rev 30787)
+++ grass/trunk/visualization/nviz/src/interface.h	2008-03-28 23:38:13 UTC (rev 30788)
@@ -264,7 +264,6 @@
 /* do_zoom.c */
 int Create_OS_Ctx(int, int);
 int Destroy_OS_Ctx(void);
-int init_ctx(void);
 /* query_vect.c */
 char *query_vect( char *, double, double);
