[GRASS-SVN] r31356 - grass/trunk/lib/ogsf
Thu May 15 12:34:04 EDT 2008
Author: martinl
Date: 2008-05-15 12:34:04 -0400 (Thu, 15 May 2008)
New Revision: 31356
   grass/trunk/lib/ogsf/gs_query.c
   grass/trunk/lib/ogsf/gsget.c
   grass/trunk/lib/ogsf/gvl.c
   grass/trunk/lib/ogsf/gvl_calc.c
   grass/trunk/lib/ogsf/gvl_calc2.c
   grass/trunk/lib/ogsf/gvl_file.c
   grass/trunk/lib/ogsf/gvld.c
ogsflib: initial doxygen strings
fprintf -> G_m/w/e/d
minor indentation fixes
[sync'ed with devbr6]
Modified: grass/trunk/lib/ogsf/gs_query.c
--- grass/trunk/lib/ogsf/gs_query.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gs_query.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gs_query.c
-  \brief OGSF library -
+  \brief OGSF library - query (lower level functions)
   GRASS OpenGL gsurf OGSF Library
@@ -13,16 +13,18 @@
   for details.
   \author Bill Brown USACERL (January 1994)
+  \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
 #include <math.h>
-#include <stdio.h>
+#include <grass/gis.h>
 #include <grass/gstypes.h>
-/* Values needed for Ray-Convex Polyhedron Intersection Test below
- * originally by Eric Haines, erich at eye.com
+  \brief Values needed for Ray-Convex Polyhedron Intersection Test below
+  originally by Eric Haines, erich at eye.com
 #ifndef	HUGE_VAL
 #define	HUGE_VAL	1.7976931348623157e+308
 #endif
@@ -33,11 +35,20 @@
 #define	BACKFACE	-1
 /* end Ray-Convex Polyhedron Intersection Test values */
-/* Crude method of intersecting line of sight with closest part of surface.
-   Uses los vector to determine the point of first intersection
-   which is returned in point. Returns 0 if los doesn't intersect.  */
-/* los should ALREADY be in surf-world coordinates */
+  \biref Crude method of intersecting line of sight with closest part of surface.
+  Uses los vector to determine the point of first intersection
+  which is returned in point. Returns 0 if los doesn't intersect.
+  \param surfid surface id
+  \param los should be in surf-world coordinates
+  \param[out] point intersect point (real)
+  \return 0 on failure
+  \return 1 on success
 int gs_los_intersect1(int surfid, float (*los)[3], float *point)
     float dx, dy, dz, u_d[3];
@@ -47,6 +58,8 @@
     geosurf *gs;
     typbuff *buf;
+    G_debug (3, "gs_los_intersect1():");
     if (NULL == (gs = gs_get_surf(surfid))) {
 	return (0);
@@ -149,7 +162,7 @@
     if ((edge) && (b[Z] - (a[Z] + dz * 2.0) > incr * u_d[Z])) {
-	fprintf(stderr, "looking under surface\n");
+	G_debug (3, "  looking under surface");
 	return 0;
@@ -161,10 +174,19 @@
     return (1);
- * This version uses the shadow of the los projected down to
- * the surface to generate a line_on_surf, then follows each
- * point in that line until the los intersects it.
+  This version uses the shadow of the los projected down to
+  the surface to generate a line_on_surf, then follows each
+  point in that line until the los intersects it.
 int gs_los_intersect(int surfid, float **los, float *point)
@@ -177,6 +199,8 @@
     typbuff *buf;
     Point3 *points;
+    G_debug (3, "gs_los_intersect");
 	return (0);
@@ -200,41 +224,40 @@
     points = gsdrape_get_allsegments(gs, bgn, end, &num);
 /* DEBUG
-float t1[3], t2[3];
-t1[X] = los[FROM][X] ;
-t1[Y] = los[FROM][Y] ;
-t2[X] = los[TO][X] ;
-t2[Y] = los[TO][Y] ;
-GS_set_draw(GSD_FRONT);
-gsd_pushmatrix();
-gsd_do_scale(1);
-gsd_translate(gs->x_trans, gs->y_trans, gs->z_trans);
-gsd_linewidth(1);
-gsd_color_func(GS_default_draw_color());
-gsd_line_onsurf(gs, t1, t2);
-gsd_popmatrix();
-GS_set_draw(GSD_BACK);
-gsd_flush();
-fprintf(stderr,"%d points to check\n", num);
-fprintf(stderr,"point0 = %.6lf %.6lf %.6lf FT =%.6lf %.6lf %.6lf\n",
+   float t1[3], t2[3];
+   t1[X] = los[FROM][X] ;
+   t1[Y] = los[FROM][Y] ;
+   t2[X] = los[TO][X] ;
+   t2[Y] = los[TO][Y] ;
+   GS_set_draw(GSD_FRONT);
+   gsd_pushmatrix();
+   gsd_do_scale(1);
+   gsd_translate(gs->x_trans, gs->y_trans, gs->z_trans);
+   gsd_linewidth(1);
+   gsd_color_func(GS_default_draw_color());
+   gsd_line_onsurf(gs, t1, t2);
+   gsd_popmatrix();
+   GS_set_draw(GSD_BACK);
+   gsd_flush();
+   fprintf(stderr,"%d points to check\n", num);
+   fprintf(stderr,"point0 = %.6lf %.6lf %.6lf FT =%.6lf %.6lf %.6lf\n",
 	points[0][X],points[0][Y],points[0][Z],
 	los[FROM][X],los[FROM][Y],los[FROM][Z]);
-fprintf(stderr,"incr1 = %.6lf: %.6lf %.6lf %.6lf\n",incr,u_d[X],u_d[Y],u_d[Z]);
-fprintf(stderr,"first point below surf\n");
-fprintf(stderr,"incr2 = %f\n", (float)incr);
-fprintf(stderr,"(%d/%d) %f > %f\n", i,num, a[Z], points[i][Z]);
-fprintf(stderr,"incr3 = %f\n", (float)incr);
-fprintf(stderr,"all points above surf\n");
+	fprintf(stderr,"incr1 = %.6lf: %.6lf %.6lf %.6lf\n",incr,u_d[X],u_d[Y],u_d[Z]);
+	fprintf(stderr,"first point below surf\n");
+	fprintf(stderr,"incr2 = %f\n", (float)incr);
+	fprintf(stderr,"(%d/%d) %f > %f\n", i,num, a[Z], points[i][Z]);
+	fprintf(stderr,"incr3 = %f\n", (float)incr);
+	fprintf(stderr,"all points above surf\n");
     if (num < 2) {
-	fprintf(stderr, "-----------------------------\n");
-	fprintf(stderr, "%d points to check\n", num);
+	G_debug (3, "  %d points to check", num);
 	return (0);
@@ -255,16 +278,16 @@
 /* DEBUG
-fprintf(stderr,"-----------------------------\n");
-fprintf(stderr,"incr1 = %.6lf: %.9f %.9f %.9f\n",incr,u_d[X],u_d[Y],u_d[Z]);
-fprintf(stderr,
-"\tpoint0 = %.6f %.6f %.6f\n\tFT = %.6f %.6f %.6f\n\tpoint%d = %.6f %.6f\n",
-	points[0][X],points[0][Y],points[0][Z],
-	los[FROM][X],los[FROM][Y],los[FROM][Z],
-	num-1, points[num-1][X],points[num-1][Y]);
+   fprintf(stderr,"-----------------------------\n");
+   fprintf(stderr,"incr1 = %.6lf: %.9f %.9f %.9f\n",incr,u_d[X],u_d[Y],u_d[Z]);
+   fprintf(stderr,
+   "\tpoint0 = %.6f %.6f %.6f\n\tFT = %.6f %.6f %.6f\n\tpoint%d = %.6f %.6f\n",
+   points[0][X],points[0][Y],points[0][Z],
+   los[FROM][X],los[FROM][Y],los[FROM][Z],
+   num-1, points[num-1][X],points[num-1][Y]);
     /* This should bring us right above (or below) the first point */
     a[X] = los[FROM][X] + incr * u_d[X] - gs->x_trans;
     a[Y] = los[FROM][Y] + incr * u_d[Y] - gs->y_trans;
@@ -274,14 +297,14 @@
 	/*  viewing from below surface  */
 	/*  don't use this method */
 /* DEBUG
-fprintf(stderr,"aZ= %.6f point0 = %.6f %.6f %.6f FT =%.6f %.6f %.6f\n",
-	a[Z], points[0][X],points[0][Y],points[0][Z],
-	los[FROM][X],los[FROM][Y],los[FROM][Z]);
+   fprintf(stderr,"aZ= %.6f point0 = %.6f %.6f %.6f FT =%.6f %.6f %.6f\n",
+   a[Z], points[0][X],points[0][Y],points[0][Z],
+   los[FROM][X],los[FROM][Y],los[FROM][Z]);
 	return (0);
     GS_v3eq(a1, a);
     GS_v3eq(b, a);
@@ -327,34 +350,36 @@
 	    return (1);
-	fprintf(stderr, "line of sight error %d\n", ret);
+	G_debug (3, "  line of sight error %d", ret);
 	return 0;
     /* over surface */
     return 0;
-/* Ray-Convex Polyhedron Intersection Test
- * This test checks the ray against each face of a polyhedron, checking whether
- * the set of intersection points found for each ray-plane intersection
- * overlaps the previous intersection results.  If there is no overlap (i.e.
- * no line segment along the ray that is inside the polyhedron), then the
- * ray misses and returns 0; else 1 is returned if the ray is entering the
- * polyhedron, -1 if the ray originates inside the polyhedron.  If there is
- * an intersection, the distance and the nunber of the face hit is returned.
- *  org, dir	origin and direction of ray
- *  tmax    	maximum useful distance along ray
- *  phdrn[] 	list of planes in convex polyhedron
- *  ph_num  	number of planes in convex polyhedron
- * *tresult 	returned: distance of intersection along ray
- * *pn	    	returned: number of face hit (0 to ph_num-1)
+  \brief Ray-Convex Polyhedron Intersection Test
+  Originally by Eric Haines, erich at eye.com
+  This test checks the ray against each face of a polyhedron, checking whether
+  the set of intersection points found for each ray-plane intersection
+  overlaps the previous intersection results.  If there is no overlap (i.e.
+  no line segment along the ray that is inside the polyhedron), then the
+  ray misses and returns 0; else 1 is returned if the ray is entering the
+  polyhedron, -1 if the ray originates inside the polyhedron.  If there is
+  an intersection, the distance and the nunber of the face hit is returned.
+  \param org,dir origin and direction of ray
+  \param tmax maximum useful distance along ray
+  \param phdrn list of planes in convex polyhedron
+  \param ph_num number of planes in convex polyhedron
+  \param[out] tresult distance of intersection along ray
+  \param[out] pn number of face hit (0 to ph_num-1)
+  \return FACE code
 int RayCvxPolyhedronInt(Point3 org, Point3 dir, double tmax, Point4 * phdrn,
 			int ph_num, double *tresult, int *pn)
@@ -436,7 +461,11 @@
+  \brief Get data bounds for plane
+  \param[out] planes
 void gs_get_databounds_planes(Point4 * planes)
     float n, s, w, e, b, t;
@@ -486,10 +515,16 @@
     return;
-/* Gets all current cutting planes & data bounding planes, intersects
-   los with resulting convex polyhedron, then replaces los[FROM] with
-   first point on ray inside data.
+  Gets all current cutting planes & data bounding planes
+  Intersects los with resulting convex polyhedron, then replaces los[FROM] with
+  first point on ray inside data.
+  \param[out] los
 int gs_setlos_enterdata(Point3 * los)
Modified: grass/trunk/lib/ogsf/gsget.c
--- grass/trunk/lib/ogsf/gsget.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gsget.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gsd_get.c
+  \brief OGSF library - get map attribute (lower level functions)
@@ -13,10 +13,21 @@
   for details.
   \author Bill Brown USACERL (January 1993)
+  \brief Get map attributes
+  \param buff
+  \param offset
+  \param[out] att
 int get_mapatt(typbuff * buff, int offset, float *att)
     if (buff->nm) {
Modified: grass/trunk/lib/ogsf/gvl.c
--- grass/trunk/lib/ogsf/gvl.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gvl.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gvl.c
-  \brief OGSF library - loading and manipulating volumes
+  \brief OGSF library - loading and manipulating volumes (lower level functions)
@@ -13,160 +13,175 @@
   for details.
   \author Bill Brown, UI-GMSL (May 1997)
-  Tomas Paudits (February 2004)
+  \author Tomas Paudits (February 2004)
-#include <stdio.h>
 #include <stdlib.h>
 #include "gsget.h"
 #define FIRST_VOL_ID 81721
 static geovol *Vol_top = NULL;
+  \brief Get volume
+  \param id volume set id
+  \return pointer to geovol struct
+  \return NULL on failure
 geovol *gvl_get_vol(int id)
     geovol *gvl;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_get_vol");
-#endif
+    G_debug (3, "gvl_get_vol");
     for (gvl = Vol_top; gvl; gvl = gvl->next) {
-    if (gvl->gvol_id == id) {
-        return (gvl);
+	if (gvl->gvol_id == id) {
+	    return (gvl);
     return (NULL);
+  \brief Get previous volume
+  \param id current volume set id
 geovol *gvl_get_prev_vol(int id)
     geovol *pv;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_get_prev_vol");
-#endif
+    G_debug (3, "gvl_get_prev_vol");
     for (pv = Vol_top; pv; pv = pv->next) {
-    if (pv->gvol_id == id - 1) {
-        return (pv);
+	if (pv->gvol_id == id - 1) {
+	    return (pv);
     return (NULL);
+  \brief Get all volumes
+  \param[out] list of geovol structs
+  \return number of available volume sets
 int gvl_getall_vols(geovol ** gvols)
     geovol *gvl;
     int i;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_getall_vols");
-#endif
+    G_debug(3, "gvl_getall_vols");
     for (i = 0, gvl = Vol_top; gvl; gvl = gvl->next, i++) {
-    gvols[i] = gvl;
+	gvols[i] = gvl;
     return (i);
+  \brief Get number of registrated volume sets
+  \return number of volumes
 int gvl_num_vols(void)
     geovol *gvl;
     int i;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_num_vols");
-#endif
+    G_debug (3, "gvl_num_vols");
     for (i = 0, gvl = Vol_top; gvl; gvl = gvl->next, i++);
     return (i);
+  \brief Get last volume
 geovol *gvl_get_last_vol(void)
     geovol *lvl;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_get_last_vol");
-#endif
+    G_debug(3, "gvl_get_last_vol");
     if (!Vol_top) {
-    return (NULL);
+	return (NULL);
     for (lvl = Vol_top; lvl->next; lvl = lvl->next);
+    G_debug (3, "  last vol id: %d", lvl->gvol_id);
-#ifdef DEBUG
-    fprintf(stderr, "last vol id: %d\n", lvl->gvol_id);
-#endif
     return (lvl);
+  \brief Allocate new volume set and add it to the list
+  \return pointer to new geovol struct
 geovol *gvl_get_new_vol(void)
     geovol *nvl, *lvl;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_get_new_vol");
-#endif
+    G_debug(3, "gvl_get_new_vol");
-    if (NULL == (nvl = (geovol *) malloc(sizeof(geovol)))) {
-    gs_err("gvl_get_new_vol");
+    nvl = (geovol *) G_malloc(sizeof(geovol)); /* G_fatal_error */
+    if (!nvl) {
     return (NULL);
     if ((lvl = gvl_get_last_vol())) {
-    lvl->next = nvl;
-    nvl->gvol_id = lvl->gvol_id + 1;
+	lvl->next = nvl;
+	nvl->gvol_id = lvl->gvol_id + 1;
     else {
-    Vol_top = nvl;
-    nvl->gvol_id = FIRST_VOL_ID;
+	Vol_top = nvl;
+	nvl->gvol_id = FIRST_VOL_ID;
     nvl->next = NULL;
     return (nvl);
+  \brief Initialize volume
+  \param gvl pointer to geovol struct
+  \param ox,oy,oz
+  \param rows number of rows
+  \param cols number of cols
+  \param xres,yres,zres x/y/z resolution value
+  \return -1 on failure
 int gvl_init_vol(geovol * gvl, double ox, double oy, double oz,
         int rows, int cols, int depths, double xres, double yres, double zres)
-#ifdef TRACE_FUNCS
-        Gs_status("gvl_init_vol");
-#endif
+    G_debug(3, "gvl_init_vol");
     if (!gvl) {
        return (-1);
@@ -199,7 +214,7 @@
     gvl->isosurf_y_mod = 1;
     gvl->isosurf_z_mod = 1;
-	gvl->n_slices = 0;
+    gvl->n_slices = 0;
     gvl->slice_x_mod = 1;
     gvl->slice_y_mod = 1;
     gvl->slice_z_mod = 1;
@@ -210,76 +225,83 @@
     return (1);
+  \brief Remove volume set from list
 void gvl_delete_vol(int id)
     geovol *fvl;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_delete_vol");
-#endif
+    G_debug (3, "gvl_delete_vol");
     fvl = gvl_get_vol(id);
     if (fvl) {
-    gvl_free_vol(fvl);
+	gvl_free_vol(fvl);
     return;
+  \brief Free geovol struct
+  \param fvl pointer to geovol struct
 int gvl_free_vol(geovol * fvl)
     geovol *gvl;
     int found = 0;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_free_vol");
-#endif
+    G_debug(3, "gvl_free_vol");
     if (Vol_top) {
-    if (fvl == Vol_top) {
-        if (Vol_top->next) {
-        /* can't free top if last */
-        found = 1;
-        Vol_top = fvl->next;
-        else {
-        gvl_free_volmem(fvl);
-        free(fvl);
-        Vol_top = NULL;
+	if (fvl == Vol_top) {
+	    if (Vol_top->next) {
+		/* can't free top if last */
+		found = 1;
+		Vol_top = fvl->next;
+	    else {
+		gvl_free_volmem(fvl);
+		G_free(fvl);
+		Vol_top = NULL;
+	else {
+	    for (gvl = Vol_top; gvl && !found; gvl = gvl->next) {
+		/* can't free top */
+		if (gvl->next) {
+		    if (gvl->next == fvl) {
+			found = 1;
+			gvl->next = fvl->next;
+	if (found) {
+	    G_free(fvl);
+	    fvl = NULL;
+	return (1);
-    else {
-        for (gvl = Vol_top; gvl && !found; gvl = gvl->next) {
-        /* can't free top */
-        if (gvl->next) {
-            if (gvl->next == fvl) {
-            found = 1;
-            gvl->next = fvl->next;
-    if (found) {
-        free(fvl);
-        fvl = NULL;
-    return (1);
     return (-1);
+  \brief Free geovol struct memory
 void gvl_free_volmem(geovol * fvl)
     if (0 < fvl->hfile)
@@ -288,21 +310,33 @@
     return;
+  \brief Debug volume fields
 void print_vol_fields(geovol *gvl)
-    fprintf(stderr, "ID: %d\n", gvl->gvol_id);
-    fprintf(stderr, "cols: %d rows: %d depths: %d\n", gvl->cols, gvl->rows, gvl->depths);
-    fprintf(stderr, "ox: %lf oy: %lf oz: %lf\n", gvl->ox, gvl->oy, gvl->oz);
-    fprintf(stderr, "xres: %lf yres: %lf zres: %lf\n", gvl->xres, gvl->yres, gvl->zres);
-    fprintf(stderr, "xmin: %f ymin: %f zmin: %f\n", gvl->xmin, gvl->ymin, gvl->zmin);
-    fprintf(stderr, "xmax: %f ymax: %f zmax: %f\n", gvl->xmax, gvl->ymax, gvl->zmax);
-    fprintf(stderr, "x_trans: %f y_trans: %f z_trans: %f\n", gvl->x_trans, gvl->y_trans, gvl->z_trans);
+    G_debug(4, "ID: %d", gvl->gvol_id);
+    G_debug(4, "cols: %d rows: %d depths: %d", gvl->cols, gvl->rows, gvl->depths);
+    G_debug(4, "ox: %lf oy: %lf oz: %lf", gvl->ox, gvl->oy, gvl->oz);
+    G_debug(4, "xres: %lf yres: %lf zres: %lf", gvl->xres, gvl->yres, gvl->zres);
+    G_debug(4, "xmin: %f ymin: %f zmin: %f", gvl->xmin, gvl->ymin, gvl->zmin);
+    G_debug(4, "xmax: %f ymax: %f zmax: %f", gvl->xmax, gvl->ymax, gvl->zmax);
+    G_debug(4, "x_trans: %f y_trans: %f z_trans: %f", gvl->x_trans, gvl->y_trans, gvl->z_trans);
     return;
+  \brief Get volume x-extent value
+  \param[out] min x-min value
+  \param[out] max y-max value
+  \return 1
 int gvl_get_xextents(geovol * gvl, float *min, float *max)
     *min = gvl->xmin + gvl->x_trans;
@@ -311,7 +345,15 @@
     return (1);
+  \brief Get volume y-extent value
+  \param[out] min y-min value
+  \return 1
 int gvl_get_yextents(geovol * gvl, float *min, float *max)
     *min = gvl->ymin + gvl->y_trans;
@@ -320,7 +362,15 @@
     return (1);
+  \brief Get volume z-extent value
+  \param[out] min z-min value
+  \param[out] max z-max value
+  \return 1
 int gvl_get_zextents(geovol * gvl, float *min, float *max)
     *min = gvl->zmin + gvl->z_trans;
@@ -329,7 +379,14 @@
     return (1);
+  \brief Get volume x-range value
+  \param[out] max x-max value
+  \return 1
 int gvl_get_xrange(float *min, float *max)
     geovol *gvl;
@@ -359,7 +416,14 @@
     return (1);
+  \brief Get volume y-range value
+  \return 1
 int gvl_get_yrange(float *min, float *max)
     geovol *gvl;
@@ -389,7 +453,14 @@
     return (1);
+  \brief Get volume z-range value
+  \return 1
 int gvl_get_zrange(float *min, float *max)
     geovol *gvl;
@@ -423,16 +494,19 @@
 /* ISOSURFACES */
+  \brief Initialize geovol_isosurf struct
+  \param isosurf pointer to geovol_isosurf struct
 int gvl_isosurf_init(geovol_isosurf *isosurf)
     int i;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_init");
-#endif
+    G_debug (3, "gvl_isosurf_init");
     if (!isosurf)
         return (-1);
@@ -444,23 +518,25 @@
     isosurf->data = NULL;
-	isosurf->data_desc = 0;
+    isosurf->data_desc = 0;
     isosurf->inout_mode = 0;
     return (1);
+  \brief Free geovol_isosurf struct
 int gvl_isosurf_freemem(geovol_isosurf *isosurf)
     int i;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_freemem");
-#endif
+    G_debug (3, "gvl_isosurf_freemem");
     if (!isosurf)
         return (-1);
@@ -469,12 +545,20 @@
         gvl_isosurf_set_att_src(isosurf, i, NOTSET_ATT);
-    free(isosurf->data);
+    G_free(isosurf->data);
     return (1);
+  \brief Get geovol_isosurf struct of given volume set
+  \param isosurf_id isosurface id
+  \return pointer to geovol_isosurf struct
 geovol_isosurf* gvl_isosurf_get_isosurf(int id, int isosurf_id)
     geovol *gvl;
@@ -491,37 +575,44 @@
     return (NULL);
+  \brief Get attribute source
+  \param desc attribute id
+  \return attribute value
 int gvl_isosurf_get_att_src(geovol_isosurf *isosurf, int desc)
+    G_debug(3, "isosurf_get_att_src");
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_get_att_src");
-#endif
     if (!LEGAL_ATT(desc)) {
-    return (-1);
+	return (-1);
     if (isosurf) {
-    return (isosurf->att[desc].att_src);
+	return (isosurf->att[desc].att_src);
     return (-1);
+  \brief Set attribute source
+  \param src attribute value
 int gvl_isosurf_set_att_src(geovol_isosurf *isosurf, int desc, int src)
+    G_debug(3, "gvl_isosurf_set_att_src");
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_set_att_src");
-#endif
     /* check if old source was MAP_ATT, deattach volfile */
     if (MAP_ATT == gvl_isosurf_get_att_src(isosurf, desc)) {
         gvl_file_free_datah(isosurf->att[desc].hfile);
@@ -529,92 +620,99 @@
         if (desc == ATT_COLOR) {
             Gvl_unload_colors_data(isosurf->att[desc].att_data);
     if (isosurf && LEGAL_SRC(src)) {
         isosurf->att[desc].att_src = src;
-		gvl_isosurf_set_att_changed(isosurf, desc);
+	gvl_isosurf_set_att_changed(isosurf, desc);
         return (1);
     return (-1);
+  \brief Set attribute constant
+  \param constant attribute value
 int gvl_isosurf_set_att_const(geovol_isosurf *isosurf, int desc, float constant)
+    G_debug(3, "gvl_isosurf_set_att_const");
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_set_att_const");
-#endif
     if (isosurf) {
-    isosurf->att[desc].constant = constant;
-    gvl_isosurf_set_att_src(isosurf, desc, CONST_ATT);
-    return (1);
+	isosurf->att[desc].constant = constant;
+	gvl_isosurf_set_att_src(isosurf, desc, CONST_ATT);
+	return (1);
     return (-1);
+  \brief Set attribute map
+  \param filename filename
 int gvl_isosurf_set_att_map(geovol_isosurf *isosurf, int desc, char *filename)
     int hfile;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_set_att_map");
-#endif
+    G_debug(3, "gvl_isosurf_set_att_map(): att_map: %s", filename);
-#ifdef DEBUG_MSG
-    fprintf(stderr, "att_map: %s\n", filename);
-#endif
     if (isosurf) {
-    if (0 > (hfile = gvl_file_newh(filename, VOL_FTYPE_G3D)))
-        return (-1);
-    gvl_isosurf_set_att_src(isosurf, desc, MAP_ATT);
-    isosurf->att[desc].hfile = hfile;
-    if (ATT_COLOR == desc) {
-        Gvl_load_colors_data(&(isosurf->att[desc].att_data), filename);
+	if (0 > (hfile = gvl_file_newh(filename, VOL_FTYPE_G3D)))
+	    return (-1);
+	gvl_isosurf_set_att_src(isosurf, desc, MAP_ATT);
+	isosurf->att[desc].hfile = hfile;
+	if (ATT_COLOR == desc) {
+	    Gvl_load_colors_data(&(isosurf->att[desc].att_data), filename);
+	return (1);
-    return (1);
     return (-1);
+  \brief Set attribute changed
 int gvl_isosurf_set_att_changed(geovol_isosurf *isosurf, int desc)
-	int i;
+    int i;
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_isosurf_set_att_changed");
-#endif
+    G_debug(3, "gvl_isosurf_set_att_changed");
     if (isosurf && LEGAL_ATT(desc)) {
         isosurf->att[desc].changed = 1;
-		if ((desc == ATT_TOPO) || (desc == ATT_MASK)) {
-			for (i = 1; i < MAX_ATTS; i++)
-				isosurf->att[i].changed = 1;
+	if ((desc == ATT_TOPO) || (desc == ATT_MASK)) {
+	    for (i = 1; i < MAX_ATTS; i++)
+		isosurf->att[i].changed = 1;
         return (1);
@@ -625,47 +723,61 @@
 /* SLICES */
+  \brief Initialize geovol_slice struct
+  \param slice pointer to geovol_slice struct
 int gvl_slice_init(geovol_slice *slice)
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_slice_init");
-#endif
+    G_debug(3, "gvl_slice_init");
     if (!slice)
         return (-1);
     slice->data = NULL;
-	slice->changed = 0;
-	slice->mode = 1;
-	slice->transp = 0;
-	slice->z1 = 0;
-	slice->z2 = 99;
+    slice->changed = 0;
+    slice->mode = 1;
+    slice->transp = 0;
+    slice->z1 = 0;
+    slice->z2 = 99;
     return (1);
+  \brief Free geovol_slice struct
 int gvl_slice_freemem(geovol_slice *slice)
-#ifdef TRACE_FUNCS
-    Gs_status("gvl_slice_freemem");
-#endif
+    G_debug(3, "gvl_slice_freemem");
     if (!slice)
         return (-1);
-    free(slice->data);
+    G_free(slice->data);
     return (1);
+  \brief Get geovol_slice struct
+  \param slice_id slice id
+  \return pointer to geovol_slice struct
 geovol_slice* gvl_slice_get_slice(int id, int slice_id)
     geovol *gvl;
@@ -675,7 +787,7 @@
     if (gvl) {
         if ((slice_id < 0) || (slice_id > (gvl->n_slices - 1)))
             return (NULL);
         return gvl->slice[slice_id];
Modified: grass/trunk/lib/ogsf/gvl_calc.c
--- grass/trunk/lib/ogsf/gvl_calc.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gvl_calc.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gvl_calc.c
@@ -13,9 +13,9 @@
   for details.
-#include <stdio.h>
 #include <math.h>
@@ -24,7 +24,9 @@
 #include "rgbpack.h"
 #include "mc33_table.h"
-/* memory buffer for writing */
+  \brief memory buffer for writing
 #define BUFFER_SIZE 1000000
 /* USEFUL MACROS */
@@ -43,12 +45,16 @@
 #define FOR_VAR i_for
 #define FOR_0_TO_N(n, cmd) { int FOR_VAR; for (FOR_VAR = 0; FOR_VAR < n; FOR_VAR++) {cmd;} }
-/* writing and reading isosurface data */
+  \brief writing and reading isosurface data
 #define WRITE(c) gvl_write_char(dbuff->ndx_new++, &(dbuff->new), c)
 #define READ() gvl_read_char(dbuff->ndx_old++, dbuff->old)
 #define SKIP(n) dbuff->ndx_old = dbuff->ndx_old + n
-/* check and set data descriptor */
+  \brief check and set data descriptor
 #define IS_IN_DATA(att) ((isosurf->data_desc >> att) & 1)
 #define SET_IN_DATA(att) isosurf->data_desc = (isosurf->data_desc | (1 << att))
@@ -70,10 +76,12 @@
 /* ISOSURFACES */
+  \brief Write cube index
-/* write cube index */
+  \param ndx
+  \param dbuff
 void iso_w_cndx(int ndx, data_buffer * dbuff)
     /* cube don't contains polys */
@@ -104,8 +112,11 @@
-/* read cube index */
+  \brief Read cube index
+  \param dbuff
 int iso_r_cndx(data_buffer * dbuff)
     int ndx, ndx2;
@@ -130,8 +141,17 @@
     return ndx;
-/* get value from data input */
+  \brief Get value from data input
+  \param isosurf
+  \param desc
+  \param x,y,z
+  \param[out] value
+  \return 0
+  \return ?
 int iso_get_cube_value(geovol_isosurf * isosurf, int desc, int x, int y, int z,
 		       float *v)
@@ -175,16 +195,30 @@
     return ret;
-/* get volume file values range */
+  \brief Get volume file values range
+  \param isosurf
+  \param desc
+  \param[out] min
+  \param[out] max
 void iso_get_range(geovol_isosurf * isosurf, int desc, double *min, double *max)
     gvl_file_get_min_max(gvl_file_get_volfile(isosurf->att[desc].hfile), min,
 			 max);
-/* read values for cube */
+  \brief Read values for cube
+  \param isosurf
+  \param desc
+  \param x,y,z
+  \param[out] v
+  \return
 int iso_get_cube_values(geovol_isosurf * isosurf, int desc, int x, int y, int z,
 			float *v)
@@ -201,8 +235,13 @@
     return ret;
-/* calc cube grads */
+  \brief Calculate cube grads
+  \param isosurf
+  \param x,y,z
+  \param grad
 void iso_get_cube_grads(geovol_isosurf * isosurf, int x, int y, int z,
 			float (*grad)[3])
@@ -273,8 +312,13 @@
-/* process cube */
+  \brief Process cube
+  \param isosurf
+  \param x,y,z
+  \param dbuff
 void iso_calc_cube(geovol_isosurf * isosurf, int x, int y, int z,
@@ -526,8 +570,13 @@
-/* fill data structure with computed isosurfaces polygons */
+  \brief Fill data structure with computed isosurfaces polygons
+  \param gvol pointer to geovol struct
+  \return 1
 int gvl_isosurf_calc(geovol * gvol)
     int x, y, z;
@@ -665,51 +714,60 @@
     return (1);
+  \brief ADD
+  \param pos
+  \param data
+  \param c
 void gvl_write_char(int pos, unsigned char **data, unsigned char c)
     /* check to need allocation memory */
     if ((pos % BUFFER_SIZE) == 0) {
-	if ((*data =
-	     (char *)G_realloc(*data,
-			       sizeof(char) * ((pos / BUFFER_SIZE) +
-					       1) * BUFFER_SIZE)) == NULL) {
-	    gs_err("can't malloc");
+	*data = (char *) G_realloc(*data,
+				   sizeof(char) * ((pos / BUFFER_SIZE) +
+						   1) * BUFFER_SIZE);
+	if (!(*data)) {
 	    return;
-#ifdef DEBUG
-	    fprintf(stderr, "reallocate memory for pos : %d to : %d B\n", pos,
-		    sizeof(char) * ((pos / BUFFER_SIZE) + 1) * BUFFER_SIZE);
-#endif
+	G_debug (3, "gvl_write_char(): reallocate memory for pos : %d to : %d B", pos,
+		 sizeof(char) * ((pos / BUFFER_SIZE) + 1) * BUFFER_SIZE);
     (*data)[pos] = c;
+  \brief Read char
+  \param pos position index
+  \param data data buffer
+  \param char
 unsigned char gvl_read_char(int pos, unsigned char *data)
     return data[pos];
+  \brief Append data to buffer
 void gvl_align_data(int pos, unsigned char *data)
     /* realloc memory to fit in data length */
-    if ((data = (char *)G_realloc(data, sizeof(char) * pos)) == NULL) {
+    data = (char *) G_realloc(data, sizeof(char) * pos); /* G_fatal_error */
+    if (!data) {
 	return;
-#ifdef DEBUG
-	fprintf(stderr, "reallocate memory finally to : %d B\n", pos);
-#endif
+    G_debug(3, "gvl_align_data(): reallocate memory finally to : %d B", pos);
     return;
@@ -723,8 +781,14 @@
 #define SLICE_MODE_INTERP_NO	0
 #define SLICE_MODE_INTERP_YES	1
-/* get value from geovol file */
+  \brief Get volume value
+  \param x,y,z
+  \return value
 float slice_get_value(geovol * gvl, int x, int y, int z)
     static double d;
@@ -755,7 +819,15 @@
     return value;
+  \brief Calculate slices
+  \param ndx_slc
+  \param colors
+  \return 1
 int slice_calc(geovol * gvl, int ndx_slc, void *colors)
     int cols, rows, c, r;
@@ -929,7 +1001,13 @@
     return (1);
+  \return 1
 int gvl_slices_calc(geovol * gvol)
     int i;
Modified: grass/trunk/lib/ogsf/gvl_calc2.c
--- grass/trunk/lib/ogsf/gvl_calc2.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gvl_calc2.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gvl_calc2.c
+  \brief OGSF library - loading and manipulating volumes, MarchingCubes 33 Algorithm (lower level functions)
@@ -16,6 +16,7 @@
   for details.
   \author Tomas Paudits, 2004
 #include <float.h>
@@ -27,7 +28,14 @@
 unsigned char m_case, m_config, m_subconfig;
+  \brief ADD
+  \param face
+  \param v
+  \return
 int mc33_test_face( char face , float *v)
 	float A,B,C,D ;
@@ -72,7 +80,14 @@
 	return face * A * ( A*C - B*D ) >= 0;
+  \brief ADD
+  \param s
+  \param v
+  \return
 int mc33_test_interior( char s, float *v)
 	float t, At = 0, Bt = 0, Ct = 0, Dt = 0, a, b ;
@@ -242,7 +257,14 @@
 	return s < 0;
+  \brief ADD
+  \param c_ndx
+  \param v
+  \return
 int mc33_process_cube(int c_ndx, float *v)
 	m_case   = cases[c_ndx][0] ;
Modified: grass/trunk/lib/ogsf/gvl_file.c
--- grass/trunk/lib/ogsf/gvl_file.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gvl_file.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gvl_file.c
@@ -11,12 +11,15 @@
   GNU General Public License (>=v2).
   Read the file COPYING that comes with GRASS
   for details.
-#include <stdio.h>
 #include <string.h>
 #include <stdlib.h>
 #include <grass/gsurf.h>
 #include <grass/G3d.h>
@@ -34,7 +37,9 @@
 #define STATUS_READY           0
 #define STATUS_BUSY            1
-/* structure for slice mode reading from volume file*/
+  \brief structure for slice mode reading from volume file
 typedef struct
     int num, skip;
@@ -57,126 +62,174 @@
 void *open_g3d_file(char *, IFLAG *, double *, double *);
 int close_g3d_file(void *);
-/* initialize */
+  \brief Initialize volume files
+  \return 1
 static int init_volfiles(void)
     int i;
     G3D_Region *w3;
     for (i = 0; i < MAX_VOL_FILES; i++) {
-    /* avoiding dynamic allocation */
-    Data[i] = &(Df[i]);
+	/* avoiding dynamic allocation */
+	Data[i] = &(Df[i]);
     Cur_max = MAX_VOL_FILES;
     /* get window */
     w3 = GVL_get_window();
     /* set cols, rows, depths from window */
     Cols = w3->cols;
     Rows = w3->rows;
     Depths = w3->depths;
     return (1);
-/* check number of files */
+  \brief Check number of files
+  \return 0
 static int check_num_volfiles(void)
     if (Numfiles < Cur_max) {
-    return (0);
+	return (0);
+    G_fatal_error (_("Maximum number of datafiles exceeded"));
-    fprintf(stderr, "maximum number of datafiles exceeded\n");
-    exit(0);
     /* This return statement keeps compilers happy, it is never executed */
     return (0);
-/* get geovol_file structure for given handle */
+  \brief Get geovol_file structure for given handle
+  \param id
+  \return pointer to geovol_file struct
 geovol_file *gvl_file_get_volfile(int id)
     int i;
     for (i = 0; i < Numfiles; i++) {
-    if (Data[i]->data_id == id) {
-        return (Data[i]);
+	if (Data[i]->data_id == id) {
+	    return (Data[i]);
     return (NULL);
-/* find file with name and type in geovol_file array an return handle*/
+  \brief Find file with name and type in geovol_file array an return handle
+  \param name file name
+  \para begin
+  \param data id
+  \param -1 not found
 int find_datah(char *name, IFLAG type, int begin)
     static int i;
     int start;
     start = begin ? 0 : i + 1;
     for (i = start; i < Numfiles; i++) {
-    if (!strcmp(Data[i]->file_name, name)) {
-        if (Data[i]->file_type == type) {
-            return (Data[i]->data_id);
+	if (!strcmp(Data[i]->file_name, name)) {
+	    if (Data[i]->file_type == type) {
+		return (Data[i]->data_id);
     return (-1);
-/* return file name for given handle */
+  \brief Get file name for given handle
+  \param id handle id
+  \return file name
 char *gvl_file_get_name(int id)
     int i;
     geovol_file *fvf;
     static char retstr[NAME_SIZ];
-        fvf = Data[i];
-        strcpy(retstr, fvf->file_name);
-        return (retstr);
+	    fvf = Data[i];
+	    strcpy(retstr, fvf->file_name);
+	    return (retstr);
     return (NULL);
-/* return file type for given handle */
+  \brief Get file type for given handle
+  \param vf pointer to geovol_file struct
+  \return file type
 int gvl_file_get_file_type(geovol_file *vf)
     return (vf->file_type);
-/* return data type for given handle */
+  \brief Get data type for given handle
+  \return data type
 int gvl_file_get_data_type(geovol_file *vf)
     return (vf->data_type);
-/* return minimum and maximum value in volume file */
+  \brief Get minimum and maximum value in volume file
+  \param[out] min min value
+  \param[out] max max value
 void gvl_file_get_min_max(geovol_file *vf, double *min, double *max)
     *min = vf->min;
     *max = vf->max;
-/* open volume file */
+  \brief Open volume file
+  \param file_type file type
+  \param data_type data type
+  \return pointer to file
 void *open_volfile(char *name, IFLAG file_type, IFLAG *data_type, double *min, double *max)
      if (file_type == VOL_FTYPE_G3D) {
@@ -186,8 +239,15 @@
     return (NULL);
-/* close volume file */
+  \brief Close volume file
+  \param map volume filename
+  \param type file type
+  \return
 int close_volfile(void *map, IFLAG type)
      if (type == VOL_FTYPE_G3D) {
@@ -197,8 +257,15 @@
     return (-1);
-/* get handle for given file name and type */
+  \brief Get handle for given file name and type
+  \param name volume filename
+  \return data id
 int gvl_file_newh(char *name, IFLAG file_type)
     geovol_file *new;
@@ -209,116 +276,122 @@
     double min, max;
     if (first) {
-    if (0 > init_volfiles()) {
-        return (-1);
+	if (0 > init_volfiles()) {
+	    return (-1);
+	first = 0;
-    first = 0;
     if ( 0 <= (id = find_datah(name, file_type, 1))) {
-            new = Data[i];
-            new->count++;
-            return (id);
+		new = Data[i];
+		new->count++;
+		return (id);
     if (0 > check_num_volfiles()) {
-    return (-1);
+	return (-1);
     if (!name) {
-    return (-1);
+	return (-1);
     if ((m = open_volfile(name, file_type, &data_type, &min, &max)) == NULL) {
-    return (-1);
+	return (-1);
     new = Data[Numfiles];
     if (new) {
-    Numfiles++;
-    new->data_id = Cur_id++;
-    strcpy(new->file_name, name);
-    new->file_type = file_type;
-    new->count = 1;
-    new->map = m;
-    new->min = min;
-    new->max = max;
-    new->data_type = data_type;
-    new->status = STATUS_READY;
-    new->buff = NULL;
+	Numfiles++;
+	new->data_id = Cur_id++;
+	strcpy(new->file_name, name);
+	new->file_type = file_type;
+	new->count = 1;
+	new->map = m;
+	new->min = min;
+	new->max = max;
+	new->data_type = data_type;
+	new->status = STATUS_READY;
+	new->buff = NULL;
 	new->mode = 255;
 	gvl_file_set_mode(new, MODE_DEFAULT);
-    return (new->data_id);
+	return (new->data_id);
     return (-1);
-/* free allocated buffers */
+  \brief Free allocated buffers
+  \return 1
 int free_volfile_buffs(geovol_file * vf)
     if (vf->mode == MODE_SLICE) {
-        free(vf->buff);
+        G_free(vf->buff);
         vf->buff = NULL;
-	if (vf->mode == MODE_PRELOAD) {
-		free(vf->buff);
-        vf->buff = NULL;
+    if (vf->mode == MODE_PRELOAD) {
+	G_free(vf->buff);
+	vf->buff = NULL;
     return (1);
-/* free geovol_file structure for given handle */
+  \brief Free geovol_file structure for given handle
+  \param id
+  \return
 int gvl_file_free_datah(int id)
     int i, j, found = -1;
     geovol_file *fvf;
-#ifdef TRACE_FUNCS
-    fprintf(stderr, "gvl_file_free_datah\n");
-#endif
+    G_debug (3, "gvl_file_free_datah");
-        found = 1;
-        fvf = Data[i];
-        if (fvf->count > 1) {
-            fvf->count--;
-        } else {
-            close_volfile(fvf->map, fvf->file_type);
-            free_volfile_buffs(fvf);
-            strcpy(fvf->file_name, "");
-            fvf->data_id = 0;
-            for (j = i; j < (Numfiles - 1); j++) {
-            Data[j] = Data[j + 1];
-            Data[j] = fvf;
-            --Numfiles;
+	    found = 1;
+	    fvf = Data[i];
+	    if (fvf->count > 1) {
+		fvf->count--;
+	    } else {
+		close_volfile(fvf->map, fvf->file_type);
+		free_volfile_buffs(fvf);
+		strcpy(fvf->file_name, "");
+		fvf->data_id = 0;
+		for (j = i; j < (Numfiles - 1); j++) {
+		    Data[j] = Data[j + 1];
+		Data[j] = fvf;
+		--Numfiles;
     return (found);
@@ -326,8 +399,16 @@
 /* reading from G3D raster volume files */
-/* open g3d file */
+  \brief Open g3d file
+  \param filename file name
+  \param type data type
+  \pointer to data
 void *open_g3d_file(char *filename, IFLAG *type, double *min, double *max)
     char *mapset;
@@ -335,80 +416,100 @@
     void *map;
     /* search for g3d file a return his mapset */
-    if (NULL == (mapset = G_find_grid3(filename,""))) {
+    mapset = G_find_grid3(filename, "");
+    if (!mapset) {
 	G_warning (_("3D raster map <%s> not found"),
 		   filename);
         return (NULL);
     /* open g3d file */
-    if (NULL == (map = G3d_openCellOld(filename, mapset, G3D_DEFAULT_WINDOW, G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT))) {
-#ifdef DEBUG_MSG
-        fprintf(stderr, "error opening grid3 file : %s\n", filename);
-#endif
+    map = G3d_openCellOld(filename, mapset, G3D_DEFAULT_WINDOW, G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT);
+    if (!map) {
+        G_warning (_("Unable to open 3D raster map <%s>"), filename);
         return (NULL);
     /* load range into range structure of map */
     if (!G3d_range_load(map)) {
-#ifdef DEBUG_MSG
-        fprintf(stderr, "error reading range for file : %s\n", filename);
-#endif
+        G_warning ("Unable to read range of 3D raster map <%s>", filename);
         return (NULL);
     G3d_range_min_max(map, min, max);
     /* get file data type */
     itype = G3d_fileTypeMap(map);
     if (itype == FCELL_TYPE)
         *type = VOL_DTYPE_FLOAT;
     if (itype == DCELL_TYPE)
         *type = VOL_DTYPE_DOUBLE;
     return (map);
-/* close g3d file */
+  \brief Close g3d file
+  \param map 3d raster map
 int close_g3d_file(void *map)
     /* close opened g3d file */
-    if (G3d_closeCell(map) != 1) {
-#ifdef DEBUG_MSG
-        fprintf(stderr, "error closing grid3 file");
-#endif
-        return (-1);
+    if (G3d_closeCell((G3D_Map *)map) != 1) {
+	G_warning (_("Unable to close 3D raster map <%s>"), ((G3D_Map *)map)->fileName);
+	return (-1);
     return (1);
-/* read value from g3d file */
+  \brief Eead value from g3d file
+  \param map 3D raster map
+  \param x,y,z real coordinates
+  \param[out] value data value
 int read_g3d_value(IFLAG type, void *map, int x, int y, int z, void *value)
     switch (type) {
         /* float data type */
-        case (VOL_DTYPE_FLOAT) :
-            *((float *)value) = G3d_getFloat(map, x, y, z);
-            break;
+    case (VOL_DTYPE_FLOAT) :
+	*((float *)value) = G3d_getFloat(map, x, y, z);
+	break;
         /* double data type */
-        case (VOL_DTYPE_DOUBLE) :
-            *((double *)value) = G3d_getDouble(map, x, y, z);
-            break;
+    case (VOL_DTYPE_DOUBLE) :
+	*((double *)value) = G3d_getDouble(map, x, y, z);
+	break;
         /* unsupported data type */
-        default :
-            return (-1);
+    default :
+	return (-1);
     return (1);
-/* read slice of values at level from g3d file */
+  \brief Read slice of values at level from g3d file
+  \param level
+  \param[out] data
+  \return 0 on success
 int read_g3d_slice(IFLAG type, void *map, int level, void *data)
     int x, y;
@@ -444,8 +545,16 @@
     return (1);
-/* read all values from g3d file */
+  \brief Read all values from g3d file
+  \param[out] data data buffer
 int read_g3d_vol(IFLAG type, void *map, void *data)
     int x, y, z;
@@ -485,7 +594,16 @@
     return (1);
+  \brief Check for null value
+  \param value
+  \return 1 if value is null
+  \return 0 if value is not null
+  \return -1 on failure (unsupported data type
 int is_null_g3d_value(IFLAG type, void *value)
     switch (type) {
@@ -503,14 +621,25 @@
         default :
             return (-1);
+    return (-1);
 /* reading from buffer */
-/* get value from buffer */
+  \brief Get value from buffer
+  \param offset
+  \param value
+  \return -1 on failure (unsupported data type)
 int get_buff_value(IFLAG type, void *data, int offset, void *value)
     switch (type) {
@@ -536,8 +665,16 @@
 /* direct mode reading from volume file */
-/* read value direct from volume file */
+  \brief Read value direct from volume file
+  \param x,y,z real point
+  \oaram[out] value data value
 int get_direct_value(geovol_file *vf, int x, int y, int z, void *value)
     switch (vf->file_type) {
@@ -558,20 +695,26 @@
 /* full mode reading from volume file */
-/* allocate buffer memory for full mode reading */
+  \brief Allocate buffer memory for full mode reading
 int alloc_vol_buff(geovol_file *vf)
     switch (vf->data_type) {
-            if ((vf->buff = (float*) malloc(sizeof(float) * Cols * Rows * Depths)) == NULL)
+            if ((vf->buff = (float*) G_malloc(sizeof(float) * Cols * Rows * Depths)) == NULL)
                 return (-1);
             break;
-            if ((vf->buff = (double*) malloc(sizeof(double) * Cols * Rows * Depths)) == NULL)
+            if ((vf->buff = (double*) G_malloc(sizeof(double) * Cols * Rows * Depths)) == NULL)
                 return (-1);
             break;
@@ -583,17 +726,28 @@
     return (1);
-/* free memory buffer memory */
+  \brief Free memory buffer memory
+  \return 1
 int free_vol_buff(geovol_file *vf)
-    free(vf->buff);
+    G_free(vf->buff);
     return (1);
-/* read all values from volume file */
+  \brief Read all values from volume file
 int read_vol(geovol_file *vf)
@@ -610,8 +764,15 @@
     return (1);
-/* get value from volume buffer */
+  \brief Get value from volume buffer
+  \return 1
 int get_vol_value(geovol_file *vf, int x, int y, int z, void *value)
     get_buff_value(vf->data_type, vf->buff, z * Rows * Cols + y * Cols + x, value);
@@ -623,8 +784,14 @@
 /* slice mode reading from volume file */
-/* allocate buffer for slice mode reading */
+  \brief Allocate buffer for slice mode reading
 int alloc_slice_buff(geovol_file *vf)
     int i;
@@ -634,7 +801,7 @@
             for (i = 0; i < sd->num; i++) {
-                if ((sd->slice[i] = (float*) malloc(sizeof(float) * Cols * Rows)) == NULL)
+                if ((sd->slice[i] = (float*) G_malloc(sizeof(float) * Cols * Rows)) == NULL)
                     return (-1);
             break;
@@ -642,7 +809,7 @@
-                if ((sd->slice[i] = (double*) malloc(sizeof(double) * Cols * Rows)) == NULL)
+                if ((sd->slice[i] = (double*) G_malloc(sizeof(double) * Cols * Rows)) == NULL)
                     return (-1);
             break;
@@ -655,22 +822,35 @@
     return (1);
-/* free buffer for slice mode reading */
+  \brief Free buffer for slice mode reading
+  \return 1
 int free_slice_buff(geovol_file *vf)
     int i;
     slice_data *sd = (slice_data *) vf->buff;
-        free(sd->slice[i]);
+        G_free(sd->slice[i]);
     return (1);
-/* read slice of values at level from volume file */
+  \brief Read slice of values at level from volume file
+  \param s
+  \param l
 int read_slice(geovol_file *vf, int s, int l)
     /* get slice structure */
@@ -680,7 +860,7 @@
     /* G3D file format */
         case (VOL_FTYPE_G3D) :
             if (0 > read_g3d_slice(vf->data_type, vf->map, l, sd->slice[s]))
-                    return (-1);
+		return (-1);
             break;
         /* unsupported file format */
         default :
@@ -690,8 +870,11 @@
     return (1);
-/* read new slice into buffer */
+  \brief Read new slice into buffer
 void shift_slices(geovol_file *vf)
     void *tmp;
@@ -713,8 +896,16 @@
     sd->crnt++;
-/* get value from slice buffer */
+  \brief Get value from slice buffer
 int get_slice_value(geovol_file *vf, int x, int y, int z, void *value)
@@ -744,8 +935,14 @@
 /* reading from volume file */
-/* start read - allocate memory buffer a read first data into buffer */
+  \brief Start read - allocate memory buffer a read first data into buffer
 int gvl_file_start_read(geovol_file *vf)
     int i;
@@ -789,8 +986,14 @@
     return (1);
-/* end read - free buffer memory */
+  \brief End read - free buffer memory
 int gvl_file_end_read(geovol_file *vf)
      /* check status */
@@ -815,8 +1018,14 @@
     return (1);
-/* get value for volume file at x, y, z */
+  \brief Get value for volume file at x, y, z
 int gvl_file_get_value(geovol_file *vf, int x, int y, int z, void *value)
     /*  check status */
@@ -845,7 +1054,15 @@
     return (1);
+  \param value data value
 int gvl_file_is_null_value(geovol_file *vf, void *value)
@@ -857,57 +1074,73 @@
         default :
             return (-1);
+    return (-1);
 /* set parameters for reading volumes */
-/* set read mode */
+  \brief Set read mode
+  \param mode
 int gvl_file_set_mode(geovol_file *vf, IFLAG mode)
     slice_data *sd;
     if (vf->status == STATUS_BUSY)
         return (-1);
     if (vf->mode == mode)
         return (1);
-        free(vf->buff);
-        free(vf->buff);
-	if (mode == MODE_SLICE) {
-        if ((vf->buff = (slice_data *) malloc(sizeof(slice_data))) == NULL)
-            return (-1);
-        sd = (slice_data *) vf->buff;
-        sd->num = 1;
-        sd->crnt = 0;
-        sd->base = 1;
+        G_free(vf->buff);
+	G_free(vf->buff);
+    if (mode == MODE_SLICE) {
+	if ((vf->buff = (slice_data *) G_malloc(sizeof(slice_data))) == NULL)
+		return (-1);
+	sd = (slice_data *) vf->buff;
+	sd->num = 1;
+	sd->crnt = 0;
+	sd->base = 1;
-	if (mode == MODE_PRELOAD) {
-		/* allocate memory */
-        if (0 > alloc_vol_buff(vf))
-          return (-1);
-        /* read volume */
-        read_vol(vf);
+    if (mode == MODE_PRELOAD) {
+	/* allocate memory */
+	if (0 > alloc_vol_buff(vf))
+	    return (-1);
+	/* read volume */
+	read_vol(vf);
     vf->mode = mode;
     return (1);
-/* set parameters for slice reading */
+  \brief Set parameters for slice reading
+  \param n
+  \param b
 int gvl_file_set_slices_param(geovol_file *vf, int n, int b)
     slice_data *sd;
@@ -924,4 +1157,3 @@
     return (1);
Modified: grass/trunk/lib/ogsf/gvld.c
--- grass/trunk/lib/ogsf/gvld.c	2008-05-15 16:32:49 UTC (rev 31355)
+++ grass/trunk/lib/ogsf/gvld.c	2008-05-15 16:34:04 UTC (rev 31356)
@@ -1,7 +1,7 @@
   \file gvld.c
@@ -13,26 +13,30 @@
   for details.
-#include <stdio.h>
 #include <math.h>
 /* usefull macros */
 #define READ() gvl_read_char(pos[i]++, gvl->isosurf[i]->data)
+  \brief ADD
 int gvld_vol(geovol * gvl)
-#ifdef TRACE_DFUNCS
-	Gs_status("gvld_vol");
-#endif
+    G_debug(3, "gvld_vol");
     /* SLICES */
     /* calculate slices data, if slices changed */
@@ -53,14 +57,17 @@
     return (1);
+  \brief ADD
 int gvld_wire_vol(geovol * gvl)
-#endif
     gvld_wind3_box(gvl);
@@ -73,7 +80,14 @@
     return (1);
+  \brief ADD
 int gvld_isosurf(geovol * gvl)
     float tx, ty, tz;
@@ -118,21 +132,12 @@
     nz = G_malloc(n_i * sizeof(int));
     e_dl = G_malloc(n_i * sizeof(int));
-	Gs_status("gvld_isosurf");
+    G_debug(3, "gvld_isosurf():");
+    for (i = 0; i < gvl->n_isosurfs; i++) {
+	G_debug(4, "  start : gvl: %s isosurf : %d\n",
+		gvl_file_get_name(gvl->hfile), i);
-#endif
-#ifdef DEBUG
-	for (i = 0; i < gvl->n_isosurfs; i++) {
-	    fprintf(stderr, "start : gvl: %s isosurf : %d\n",
-		    gvl_file_get_name(gvl->hfile), i);
-#endif
     /* shade */
     gsd_shademodel(gvl->isosurf_draw_mode & DM_GOURAUD);
@@ -233,24 +238,17 @@
 	nz[i] = 0;
-#ifdef DEBUG
-	fprintf(stderr, "intialize OK\n", gvl_file_get_name(gvl->hfile), i);
-#endif
+    G_debug (3, "  intialize OK", gvl_file_get_name(gvl->hfile), i);
     for (z = 0; z < depths - 1; z++) {
 	zc = z * zres;
 	if (GS_check_cancel()) {
-#ifdef DEBUG
-		    fprintf(stderr, "break : isosurf : %d datalength : %d B\n",
-			    i, pos[i]);
+		G_debug(4, "  break : isosurf : %d datalength : %d B\n",
+			i, pos[i]);
-#endif
 	    gsd_set_material(1, 1, 0., 0., 0x0);
 	    gsd_popmatrix();
 	    gsd_blend(0);
@@ -387,14 +385,10 @@
-#ifdef DEBUG
-	    fprintf(stderr, "end : isosurf : %d datalength : %d B\n", i,
-		    pos[i]);
+	G_debug(4, "  end : isosurf : %d datalength : %d B\n", i,
+		pos[i]);
-#endif
     gsd_popmatrix();
@@ -404,7 +398,13 @@
     return (0);
+  \brief ADD
+  \return 0
 int gvld_wire_isosurf(geovol * gvl)
     return (0);
@@ -417,9 +417,13 @@
 #define DISTANCE_2(x1, y1, x2, y2)	sqrt((x1-x2)*(x1-x2)+(y1-y2)*(y1-y2))
-/* draw slices */
+  \brief Draw slices
+  \return 0
 int gvld_slices(geovol * gvl)
     float tx, ty, tz;
@@ -429,11 +433,7 @@
     GLint viewport[4];
     GLint window[4];
-	Gs_status("gvld_slices");
-#endif
+    G_debug(3, "gvld_slices");
     /* shade */
     gsd_shademodel(gvl->slice_draw_mode & DM_GOURAUD);
@@ -473,9 +473,14 @@
     return (0);
-/* draw slice */
+  \brief Draw slice
+  \param ndx
+  \return 1
 int gvld_slice(geovol * gvl, int ndx)
     geovol_slice *slice;
@@ -647,8 +652,13 @@
     return (1);
-/* draw wire slices */
+  \brief Draw wire slices
+  \return 0
 int gvld_wire_slices(geovol * gvl)
     float pt[3];
@@ -657,11 +667,7 @@
-	Gs_status("gvld_wire_slices");
-#endif
+    G_debug (3, "gvld_wire_slices");
     gsd_pushmatrix();
@@ -749,17 +755,18 @@
     return (0);
-/* draw wind3 box */
+  \brief Draw wind3 box
+  \return 0
 int gvld_wind3_box(geovol * gvl)
     float pt[3];
-	Gs_status("gvld_wind3_box");
-#endif
+    G_debug(3, "gvld_wind3_box");
     gsd_pushmatrix();
