[GRASS-SVN] r31389 - in grass-addons/display: . d.region
Sat May 17 11:53:49 EDT 2008
Author: jachym
Date: 2008-05-17 11:53:48 -0400 (Sat, 17 May 2008)
New Revision: 31389
Added:
   grass-addons/display/d.region/
   grass-addons/display/d.region/d.region
New addon added: d.region
Added: grass-addons/display/d.region/d.region
--- grass-addons/display/d.region/d.region	                        (rev 0)
+++ grass-addons/display/d.region/d.region	2008-05-17 15:53:48 UTC (rev 31389)
@@ -0,0 +1,282 @@
+#!/bin/sh
+# MODULE:       d.region
+# AUTHOR(S):    Hamish Bowman, Jachym Cepicky
+# PURPOSE:      Draw selected region into current display
+# COPYRIGHT:    (C) 2007 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Draw desired region into current display
+#%  keywords: display, region
+#%End
+#%flag
+#%  key: d
+#%  description: Draw default region
+#%END
+#%flag
+#%  key: c
+#%  description: Draw current region
+#%END
+#%flag
+#%  key: f
+#%  description: Non-persistant box (doesn't survive redraw or zoom)
+#%END
+#%option
+#% key: name
+#% type: string
+#% description: Region name
+#% required : no
+#%end
+#%option
+#% key: color
+#% type: string
+#% description: Color to draw with, either a standard GRASS color or R:G:B triplet
+#% answer: black
+#% required : no
+#%end
+#%option
+#% key: width
+#% type: integer
+#% description: Line width
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: rast
+#% type: string
+#% description: Draw region to match this raster map
+#% required : no
+#%end
+#%option
+#% key: rast3d
+#% type: string
+#% description: Draw region to match this 3D raster map
+#% required : no
+#%end
+#%option
+#% key: vect
+#% type: string
+#% description: Draw region to match this vector map
+#% required : no
+#%end
+#%option
+#% key: 3dview
+#% type: string
+#% description: Draw region to match this 3dview file
+#% required : no
+#%end
+#%option
+#% key: n
+#% type: double
+#% description: Value for the northern edge
+#% required : no
+#%end
+#%option
+#% key: s
+#% type: double
+#% description: Value for the southern edge
+#% required : no
+#%end
+#%option
+#% key: e
+#% type: double
+#% description: Value for the eastern edge
+#% required : no
+#%end
+#%option
+#% key: w
+#% type: double
+#% description: Value for the western edge
+#% required : no
+#%end
+if test "$GISBASE" = ""; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+  exec g.parser "$0" "$@"
+fi
+# set defaults
+originalRegionName="d_region"$$
+g.region save=$originalRegionName
+# name:     clean
+# purpose:  clean region settings
+clean () {
+    g.region region=$originalRegionName;
+    g.remove --q region=$originalRegionName;
+# name:     default
+# purpose:  displays default region
+default () {
+    g.region -d
+    eval `g.region -g`
+# name:     current
+current () {
+# name:     raster
+# purpose:  displays raster region
+raster () {
+    g.region rast=$GIS_OPT_RAST
+# name:     vector
+# purpose:  displays vect region
+vector () {
+    g.region vect=$GIS_OPT_VECT
+# name:     rast3d
+# purpose:  displays rast3d region
+rast3d () {
+    g.region rast3d=$GIS_OPT_RAST3D
+# name:     3dview
+# purpose:  displays    3dview region
+view3d () {
+    g.region rast3d=$GIS_OPT_3DVIEW
+# name:     region
+# purpose:  displays  region
+region () {
+    error=''
+    if [ -z "$GIS_OPT_N" ]; then
+        g.message -e "parameter <n> not set"
+        error=1
+    fi
+    if [ -z "$GIS_OPT_S" ]; then
+        g.message -e "parameter <s> not set"
+        error=1
+    fi
+    if [ -z "$GIS_OPT_E" ]; then
+        g.message -e "parameter <e> not set"
+        error=1
+    fi
+    if [ -z "$GIS_OPT_W" ]; then
+        g.message -e "parameter <w> not set"
+        error=1
+    fi
+    if [ -n "$error" ]; then
+        clean
+        exit 1
+    fi
+    g.region w=$GIS_OPT_W s=$GIS_OPT_S e=$GIS_OPT_E n=$GIS_OPT_N
+# name:     draw
+draw () {
+    # setup temporary file
+    TMP="`g.tempfile pid=$$`"
+    if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+        g.message -e "unable to create temporary files"
+        exit 1
+    fi
+    cat << EOF >> "$TMP"
+width $GIS_OPT_WIDTH
+polyline
+$w $s
+$w $n
+$e $n
+$e $s
+$w $s
+EOF
+    echo $TMP
+    if [ $GIS_FLAG_F -eq 1 ]; then
+        cat $TMP|d.graph -m color=$GIS_OPT_COLOR
+    else
+        d.graph -m color=$GIS_OPT_COLOR input=$TMP
+    fi
+# in case of problems or user break:
+trap 'clean ; exit 1' 2 3 15
+# main code
+regionFunction=""
+if [ $GIS_FLAG_C -eq 1 ] ; then
+    regionFunction="current"
+fi
+if [ $GIS_FLAG_D -eq 1 ] ; then
+    regionFunction="default"
+fi
+if [ -n "$GIS_OPT_RAST" ] ; then
+    regionFunction="raster"
+fi
+if [ -n "$GIS_OPT_VECT" ] ; then
+    regionFunction="vector"
+fi
+if [ -n "$GIS_OPT_RAST3D" ] ; then
+    regionFunction="rast3d"
+fi
+if [ -n "$GIS_OPT_3DVIEW" ] ; then
+    regionFunction="view3d"
+fi
+if [ -n "$GIS_OPT_N" ] ; then
+    regionFunction="region"
+fi
+$regionFunction
+draw
+# end clean up
+clean
+exit 0
