[GRASS-SVN] r31414 - grass/branches/develbranch_6
Sun May 18 17:12:03 EDT 2008
Author: neteler
Date: 2008-05-18 17:12:03 -0400 (Sun, 18 May 2008)
New Revision: 31414
   grass/branches/develbranch_6/config.guess
   grass/branches/develbranch_6/config.sub
Update to current state (from http://git.savannah.gnu.org), see trac #158)
Modified: grass/branches/develbranch_6/config.guess
--- grass/branches/develbranch_6/config.guess	2008-05-18 15:42:22 UTC (rev 31413)
+++ grass/branches/develbranch_6/config.guess	2008-05-18 21:12:03 UTC (rev 31414)
@@ -1,9 +1,10 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
 #   Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-#   2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
+#   2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008
+#   Free Software Foundation, Inc.
-timestamp='2005-07-08'
+timestamp='2008-04-14'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -55,8 +56,8 @@
 GNU config.guess ($timestamp)
 Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
-Free Software Foundation, Inc.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -106,7 +107,7 @@
 trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
 trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
 : ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
  { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
  { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
  { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
@@ -160,6 +161,7 @@
 	    arm*) machine=arm-unknown ;;
 	    sh3el) machine=shl-unknown ;;
 	    sh3eb) machine=sh-unknown ;;
+	    sh5el) machine=sh5le-unknown ;;
 	    *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
 	esac
 	# The Operating System including object format, if it has switched
@@ -206,8 +208,11 @@
     *:ekkoBSD:*:*)
 	echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
 	exit ;;
+    *:SolidBSD:*:*)
+	echo ${UNAME_MACHINE}-unknown-solidbsd${UNAME_RELEASE}
+	exit ;;
     macppc:MirBSD:*:*)
-	echo powerppc-unknown-mirbsd${UNAME_RELEASE}
+	echo powerpc-unknown-mirbsd${UNAME_RELEASE}
 	exit ;;
     *:MirBSD:*:*)
 	echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
@@ -325,7 +330,7 @@
     sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
 	echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
-    i86pc:SunOS:5.*:*)
+    i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
 	echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
     sun4*:SunOS:6*:*)
@@ -527,7 +532,7 @@
 		echo rs6000-ibm-aix3.2
 	fi
 	exit ;;
-    *:AIX:*:[45])
+    *:AIX:*:[456])
 	IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
 	if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
 		IBM_ARCH=rs6000
@@ -764,12 +769,19 @@
 	echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
 	exit ;;
     *:FreeBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+	case ${UNAME_MACHINE} in
+	    pc98)
+		echo i386-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+	    amd64)
+		echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+		echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
+	esac
 	exit ;;
     i*:CYGWIN*:*)
 	echo ${UNAME_MACHINE}-pc-cygwin
 	exit ;;
-    i*:MINGW*:*)
+    *:MINGW*:*)
 	echo ${UNAME_MACHINE}-pc-mingw32
 	exit ;;
     i*:windows32*:*)
@@ -779,9 +791,18 @@
     i*:PW*:*)
 	echo ${UNAME_MACHINE}-pc-pw32
 	exit ;;
-    x86:Interix*:[34]*)
-	echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
-	exit ;;
+    *:Interix*:[3456]*)
+	    x86)
+		echo i586-pc-interix${UNAME_RELEASE}
+		exit ;;
+	    EM64T | authenticamd)
+		echo x86_64-unknown-interix${UNAME_RELEASE}
+		exit ;;
+	    IA64)
+		echo ia64-unknown-interix${UNAME_RELEASE}
+		exit ;;
+	esac ;;
     [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
 	echo i${UNAME_MACHINE}-pc-mks
 	exit ;;
@@ -794,7 +815,7 @@
     i*:UWIN*:*)
 	echo ${UNAME_MACHINE}-pc-uwin
 	exit ;;
-    amd64:CYGWIN*:*:*)
+    amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
 	echo x86_64-unknown-cygwin
 	exit ;;
     p*:CYGWIN*:*)
@@ -815,6 +836,16 @@
 	echo ${UNAME_MACHINE}-pc-minix
 	exit ;;
     arm*:Linux:*:*)
+	eval $set_cc_for_build
+	if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
+	    | grep -q __ARM_EABI__
+	then
+	    echo ${UNAME_MACHINE}-unknown-linux-gnu
+	else
+	    echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+	fi
+	exit ;;
+    avr32*:Linux:*:*)
 	exit ;;
     cris:Linux:*:*)
@@ -851,7 +882,11 @@
 	#endif
 	#endif
 EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
+	eval "`$CC_FOR_BUILD -E $dummy.c 2>/dev/null | sed -n '
+	    /^CPU/{
+		s: ::g
+		p
 	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
     mips64:Linux:*:*)
@@ -870,7 +905,11 @@
 	#endif
 	#endif
 EOF
+	    /^CPU/{
+		s: ::g
+		p
     or32:Linux:*:*)
@@ -919,9 +958,15 @@
     sparc:Linux:*:* | sparc64:Linux:*:*)
 	exit ;;
+    vax:Linux:*:*)
+	echo ${UNAME_MACHINE}-dec-linux-gnu
+	exit ;;
     x86_64:Linux:*:*)
 	echo x86_64-unknown-linux-gnu
 	exit ;;
+    xtensa*:Linux:*:*)
+	exit ;;
     i*86:Linux:*:*)
 	# The BFD linker knows what the default object file format is, so
 	# first see if it will tell us. cd to the root directory to prevent
@@ -940,9 +985,6 @@
 	  a.out-i386-linux)
 		echo "${UNAME_MACHINE}-pc-linux-gnuaout"
 		exit ;;
-	  coff-i386)
-		echo "${UNAME_MACHINE}-pc-linux-gnucoff"
-		exit ;;
 		# Either a pre-BFD a.out linker (linux-gnuoldld) or
 		# one that does not give us useful --help.
@@ -964,7 +1006,7 @@
 	LIBC=gnulibc1
 	# endif
 	#else
-	#ifdef __INTEL_COMPILER
+	#if defined(__INTEL_COMPILER) || defined(__PGI) || defined(__SUNPRO_C) || defined(__SUNPRO_CC)
 	LIBC=gnu
 	#else
 	LIBC=gnuaout
@@ -974,7 +1016,11 @@
 	LIBC=dietlibc
 	#endif
 EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
+	    /^LIBC/{
+		s: ::g
+		p
 	test x"${LIBC}" != x && {
 		echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
 		exit
@@ -1167,6 +1213,9 @@
     BePC:BeOS:*:*)	# BeOS running on Intel PC compatible.
 	echo i586-pc-beos
 	exit ;;
+    BePC:Haiku:*:*)	# Haiku running on Intel PC compatible.
+	echo i586-pc-haiku
+	exit ;;
     SX-4:SUPER-UX:*:*)
 	echo sx4-nec-superux${UNAME_RELEASE}
 	exit ;;
@@ -1176,6 +1225,15 @@
     SX-6:SUPER-UX:*:*)
 	echo sx6-nec-superux${UNAME_RELEASE}
 	exit ;;
+    SX-7:SUPER-UX:*:*)
+	echo sx7-nec-superux${UNAME_RELEASE}
+	exit ;;
+    SX-8:SUPER-UX:*:*)
+	echo sx8-nec-superux${UNAME_RELEASE}
+	exit ;;
+    SX-8R:SUPER-UX:*:*)
+	echo sx8r-nec-superux${UNAME_RELEASE}
+	exit ;;
     Power*:Rhapsody:*:*)
 	echo powerpc-apple-rhapsody${UNAME_RELEASE}
 	exit ;;
@@ -1185,7 +1243,6 @@
     *:Darwin:*:*)
 	UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
 	case $UNAME_PROCESSOR in
-	    *86) UNAME_PROCESSOR=i686 ;;
 	    unknown) UNAME_PROCESSOR=powerpc ;;
 	esac
 	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
@@ -1264,6 +1321,9 @@
     i*86:skyos:*:*)
 	echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
 	exit ;;
+    i*86:rdos:*:*)
+	echo ${UNAME_MACHINE}-pc-rdos
+	exit ;;
 esac
 #echo '(No uname command or uname output not recognized.)' 1>&2
@@ -1424,9 +1484,9 @@
 the operating system you are using. It is advised that you
 download the most up to date version of the config scripts from
-  http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
+  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
 and
-  http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
+  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
 If the version you run ($0) is already up to date, please
 send the following data and any information you think might be
Modified: grass/branches/develbranch_6/config.sub
--- grass/branches/develbranch_6/config.sub	2008-05-18 15:42:22 UTC (rev 31413)
+++ grass/branches/develbranch_6/config.sub	2008-05-18 21:12:03 UTC (rev 31414)
@@ -1,9 +1,10 @@
 #! /bin/sh
 # Configuration validation subroutine script.
 # This file is (in principle) common to ALL GNU software.
 # The presence of a machine in this file suggests that SOME GNU software
@@ -71,8 +72,8 @@
 version="\
 GNU config.sub ($timestamp)
@@ -119,8 +120,9 @@
 # Here we must recognize all the valid KERNEL-OS combinations.
 maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
 case $maybe_os in
-  nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
-  kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
+  nto-qnx* | linux-gnu* | linux-dietlibc | linux-newlib* | linux-uclibc* | \
+  uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | \
+  storm-chaos* | os2-emx* | rtmk-nova*)
     os=-$maybe_os
     basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -171,6 +173,10 @@
 	-hiux*)
 		os=-hiuxwe2
+	-sco6)
+		os=-sco5v6
+		basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
 	-sco5)
 		os=-sco3.2v5
@@ -187,6 +193,10 @@
 		# Don't forget version if it is 3.2v4 or newer.
+	-sco5v6*)
+		# Don't forget version if it is 3.2v4 or newer.
 	-sco*)
 		os=-sco3.2v2
@@ -231,20 +241,23 @@
 	| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
 	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
 	| am33_2.0 \
-	| arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+	| arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr | avr32 \
 	| bfin \
 	| c4x | clipper \
 	| d10v | d30v | dlx | dsp16xx \
-	| fr30 | frv \
+	| fido | fr30 | frv \
 	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
 	| i370 | i860 | i960 | ia64 \
 	| ip2k | iq2000 \
-	| m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
+	| m32c | m32r | m32rle | m68000 | m68k | m88k \
+	| maxq | mb | microblaze | mcore | mep | metag \
 	| mips | mipsbe | mipseb | mipsel | mipsle \
 	| mips16 \
 	| mips64 | mips64el \
+	| mips64octeon | mips64octeonel \
+	| mips64orion | mips64orionel \
+	| mips64r5900 | mips64r5900el \
 	| mips64vr | mips64vrel \
-	| mips64orion | mips64orionel \
 	| mips64vr4100 | mips64vr4100el \
 	| mips64vr4300 | mips64vr4300el \
 	| mips64vr5000 | mips64vr5000el \
@@ -257,28 +270,27 @@
 	| mipsisa64sr71k | mipsisa64sr71kel \
 	| mipstx39 | mipstx39el \
 	| mn10200 | mn10300 \
-	| ms1 \
+	| mt \
 	| msp430 \
+	| nios | nios2 \
 	| ns16k | ns32k \
 	| or32 \
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
 	| pyramid \
-	| sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+	| score \
+	| sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
 	| sh64 | sh64le \
-	| sparc | sparc64 | sparc64b | sparc86x | sparclet | sparclite \
-	| sparcv8 | sparcv9 | sparcv9b \
-	| strongarm \
+	| sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
+	| sparcv8 | sparcv9 | sparcv9b | sparcv9v \
+	| spu | strongarm \
 	| tahoe | thumb | tic4x | tic80 | tron \
 	| v850 | v850e \
 	| we32k \
-	| x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
+	| x86 | xc16x | xscale | xscalee[bl] | xstormy16 | xtensa \
 	| z8k)
 		basic_machine=$basic_machine-unknown
-	m32c)
-		basic_machine=$basic_machine-unknown
 	m6811 | m68hc11 | m6812 | m68hc12)
 		# Motorola 68HC11/12.
@@ -286,6 +298,9 @@
 	m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+	ms1)
+		basic_machine=mt-unknown
 	# We use `pc' rather than `unknown'
 	# because (1) that's what they normally are, and
@@ -305,25 +320,27 @@
 	| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
 	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
 	| arm-*  | armbe-* | armle-* | armeb-* | armv*-* \
-	| avr-* \
+	| avr-* | avr32-* \
 	| bfin-* | bs2000-* \
 	| c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
 	| clipper-* | craynv-* | cydra-* \
 	| d10v-* | d30v-* | dlx-* \
 	| elxsi-* \
-	| f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+	| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
 	| h8300-* | h8500-* \
 	| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
 	| i*86-* | i860-* | i960-* | ia64-* \
 	| ip2k-* | iq2000-* \
-	| m32r-* | m32rle-* \
+	| m32c-* | m32r-* | m32rle-* \
 	| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
-	| m88110-* | m88k-* | maxq-* | mcore-* \
+	| m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
 	| mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
 	| mips16-* \
 	| mips64-* | mips64el-* \
+	| mips64octeon-* | mips64octeonel-* \
+	| mips64orion-* | mips64orionel-* \
+	| mips64r5900-* | mips64r5900el-* \
 	| mips64vr-* | mips64vrel-* \
-	| mips64orion-* | mips64orionel-* \
 	| mips64vr4100-* | mips64vr4100el-* \
 	| mips64vr4300-* | mips64vr4300el-* \
 	| mips64vr5000-* | mips64vr5000el-* \
@@ -336,30 +353,33 @@
 	| mipsisa64sr71k-* | mipsisa64sr71kel-* \
 	| mipstx39-* | mipstx39el-* \
 	| mmix-* \
-	| ms1-* \
+	| mt-* \
 	| msp430-* \
+	| nios-* | nios2-* \
 	| none-* | np1-* | ns16k-* | ns32k-* \
 	| orion-* \
 	| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
 	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
 	| pyramid-* \
 	| romp-* | rs6000-* \
-	| sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | shbe-* \
+	| sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
 	| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
-	| sparc-* | sparc64-* | sparc64b-* | sparc86x-* | sparclet-* \
+	| sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
 	| sparclite-* \
-	| sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+	| sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | strongarm-* | sv1-* | sx?-* \
 	| tahoe-* | thumb-* \
-	| tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+	| tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* | tile-* \
 	| tron-* \
 	| v850-* | v850e-* | vax-* \
 	| we32k-* \
-	| x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
-	| xstormy16-* | xtensa-* \
+	| x86-* | x86_64-* | xc16x-* | xps100-* | xscale-* | xscalee[bl]-* \
+	| xstormy16-* | xtensa*-* \
 	| ymp-* \
 	| z8k-*)
-	m32c-*)
+	# Recognize the basic CPU types without company name, with glob match.
+	xtensa*)
+		basic_machine=$basic_machine-unknown
 	# Recognize the various machine names and aliases which stand
 	# for a CPU type and a company and sometimes even an OS.
@@ -431,6 +451,14 @@
 		basic_machine=ns32k-sequent
 		os=-dynix
+	blackfin)
+		basic_machine=bfin-unknown
+		os=-linux
+	blackfin-*)
+		basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
+		os=-linux
 	c90)
 		basic_machine=c90-cray
 		os=-unicos
@@ -463,8 +491,8 @@
 		basic_machine=craynv-cray
 		os=-unicosmp
-	cr16c)
-		basic_machine=cr16c-unknown
+	cr16)
+		basic_machine=cr16-unknown
 		os=-elf
 	crds | unos)
@@ -502,6 +530,10 @@
 		basic_machine=m88k-motorola
 		os=-sysv3
+	dicos)
+		basic_machine=i686-pc
+		os=-dicos
 	djgpp)
 		basic_machine=i586-pc
 		os=-msdosdjgpp
@@ -656,6 +688,14 @@
 		basic_machine=m68k-isi
 		os=-sysv
+	m68knommu)
+		basic_machine=m68k-unknown
+		os=-linux
+	m68knommu-*)
+		basic_machine=m68k-`echo $basic_machine | sed 's/^[^-]*-//'`
+		os=-linux
 	m88k-omron*)
 		basic_machine=m88k-omron
@@ -671,6 +711,10 @@
 		basic_machine=i386-pc
 		os=-mingw32
+	mingw32ce)
+		basic_machine=arm-unknown
+		os=-mingw32ce
 	miniframe)
 		basic_machine=m68000-convergent
@@ -696,6 +740,9 @@
 		os=-msdos
+	ms1-*)
+		basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
 	mvs)
 		basic_machine=i370-ibm
 		os=-mvs
@@ -794,6 +841,14 @@
 		basic_machine=i860-intel
 		os=-osf
+	parisc)
+		basic_machine=hppa-unknown
+		os=-linux
+	parisc-*)
+		basic_machine=hppa-`echo $basic_machine | sed 's/^[^-]*-//'`
+		os=-linux
 	pbd)
 		basic_machine=sparc-tti
@@ -803,6 +858,12 @@
 	pc532 | pc532-*)
 		basic_machine=ns32k-pc532
+	pc98)
+		basic_machine=i386-pc
+	pc98-*)
+		basic_machine=i386-`echo $basic_machine | sed 's/^[^-]*-//'`
 	pentium | p5 | k5 | k6 | nexgen | viac3)
@@ -859,6 +920,10 @@
 		basic_machine=i586-unknown
 		os=-pw32
+	rdos)
+		os=-rdos
 	rom68k)
 		basic_machine=m68k-rom68k
 		os=-coff
@@ -885,6 +950,10 @@
 	sb1el)
 		basic_machine=mipsisa64sb1el-unknown
+	sde)
+		basic_machine=mipsisa32-sde
+		os=-elf
 	sei)
 		basic_machine=mips-sei
 		os=-seiux
@@ -896,6 +965,9 @@
 		basic_machine=sh-hitachi
 		os=-hms
+	sh5el)
+		basic_machine=sh5le-unknown
 	sh64)
 		basic_machine=sh64-unknown
@@ -985,6 +1057,10 @@
 		basic_machine=tic6x-unknown
 		os=-coff
+	tile*)
+		basic_machine=tile-unknown
+		os=-linux-gnu
 	tx39)
 		basic_machine=mipstx39-unknown
@@ -1101,7 +1177,7 @@
 	sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
 		basic_machine=sh-unknown
-	sparc | sparcv8 | sparcv9 | sparcv9b)
+	sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
 		basic_machine=sparc-sun
 	cydra)
@@ -1174,21 +1250,23 @@
 	      | -aos* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
 	      | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
-	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
+	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
+	      | -openbsd* | -solidbsd* \
 	      | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
 	      | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
 	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
 	      | -chorusos* | -chorusrdb* \
 	      | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
-	      | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
+	      | -mingw32* | -linux-gnu* | -linux-newlib* | -linux-uclibc* \
+	      | -uxpv* | -beos* | -mpeix* | -udk* \
 	      | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
 	      | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
 	      | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
 	      | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
 	      | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
 	      | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
-	      | -skyos* | -haiku*)
+	      | -skyos* | -haiku* | -rdos* | -toppers* | -drops*)
 	# Remember, each alternative MUST END IN *, to match a version number.
 	-qnx*)
@@ -1318,6 +1396,9 @@
 	-zvmoe)
 		os=-zvmoe
+	-dicos*)
+		os=-dicos
 	-none)
@@ -1340,6 +1421,12 @@
 # system, and we'll never get to this point.
 case $basic_machine in
+        score-*)
+		os=-elf
+        spu-*)
+		os=-elf
 	*-acorn)
 		os=-riscix1.2
@@ -1349,9 +1436,9 @@
 	arm*-semi)
 		os=-aout
-    c4x-* | tic4x-*)
-        os=-coff
+        c4x-* | tic4x-*)
+        	os=-coff
 	# This must come before the *-dec entry.
 	pdp10-*)
 		os=-tops20
@@ -1377,6 +1464,9 @@
 	m68*-cisco)
 		os=-aout
+        mep-*)
+		os=-elf
 	mips*-cisco)
 		os=-elf
