[GRASS-SVN] r31458 - in grass/trunk: doc lib/proj vector/v.db.select
Wed May 21 04:39:23 EDT 2008
Author: neteler
Date: 2008-05-21 04:39:23 -0400 (Wed, 21 May 2008)
New Revision: 31458
   grass/trunk/doc/howto_release.txt
   grass/trunk/lib/proj/projlib.dox
   grass/trunk/vector/v.db.select/description.html
   grass/trunk/vector/v.db.select/main.c
sync'ed with devel_grass6
Modified: grass/trunk/doc/howto_release.txt
--- grass/trunk/doc/howto_release.txt	2008-05-21 08:03:07 UTC (rev 31457)
+++ grass/trunk/doc/howto_release.txt	2008-05-21 08:39:23 UTC (rev 31458)
@@ -171,6 +171,7 @@
    redazionenews at mondogis.net
    mfeilner at linuxnewmedia.de
    info at harzer.de
+   info at j-geoinfo.net
  Web:
    http://slashgeo.org/submit.pl
@@ -190,6 +191,7 @@
    http://www.foss4g.org/FOSS4G/modules.php?name=Submit_News
    http://groups.google.com/group/Remote-Sensing-GIS-for-a-New-World
    http://groups.google.com/group/comp.infosystems.gis
+   http://www.heise.de/software/download/edit_7105 (update, MN)
    ... anywhere else? Please add here.
Modified: grass/trunk/lib/proj/projlib.dox
--- grass/trunk/lib/proj/projlib.dox	2008-05-21 08:03:07 UTC (rev 31457)
+++ grass/trunk/lib/proj/projlib.dox	2008-05-21 08:39:23 UTC (rev 31458)
@@ -1,8 +1,12 @@
-/*! \mainpage projlib GRASS and the PROJ4 projection library
+/*! \page projlib GRASS and the PROJ4 projection library
 <!-- doxygenized from "GRASS 5 Programmer's Manual"
      by M. Neteler 11/2005
+by GRASS Development Team
+http://grass.osgeo.org
 \section projintro GRASS and the PROJ4 projection library
 GRASS utilizes the PROJ4 library originally developed by Gerald
Modified: grass/trunk/vector/v.db.select/description.html
--- grass/trunk/vector/v.db.select/description.html	2008-05-21 08:03:07 UTC (rev 31457)
+++ grass/trunk/vector/v.db.select/description.html	2008-05-21 08:39:23 UTC (rev 31458)
@@ -1,9 +1,11 @@
 <h2>DESCRIPTION</h2>
-<em>v.db.select</em> prints attributes of a vector map.
+<em>v.db.select</em> prints attributes of a vector map from one or several
+user selected attribute table columns.
 <h2>EXAMPLE</h2>
+Select and show entire table:
 <div class="code"><pre>
 v.db.select roads
 cat|label
@@ -15,6 +17,20 @@
 5|unimproved road
 </pre></div>
+<p>
+Select and show single column from table (multiple columns can be specified as comma separated list):
+<div class="code"><pre>
+v.db.select roads col=label
+label
+no data
+interstate
+primary highway, hard surface
+secondary highway, hard surface
+light-duty road, improved surface
+unimproved road
+</pre></div>
 <h2>SEE ALSO</h2>
 <em><a HREF="db.select.html">db.select</a></em>
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2008-05-21 08:03:07 UTC (rev 31457)
+++ grass/trunk/vector/v.db.select/main.c	2008-05-21 08:39:23 UTC (rev 31458)
@@ -49,9 +49,9 @@
     map_opt = G_define_standard_option(G_OPT_V_MAP);
     field_opt = G_define_standard_option(G_OPT_V_FIELD) ;
-    col_opt 		= G_define_standard_option(G_OPT_COLUMN);
+    col_opt 		= G_define_standard_option(G_OPT_COLUMNS);
-    where_opt = G_define_standard_option(G_OPT_WHERE);
+    where_opt           = G_define_standard_option(G_OPT_WHERE);
     fs_opt 		= G_define_standard_option(G_OPT_F_SEP);
     fs_opt->description = _("Output field separator");
