[GRASS-SVN] r34284 - in grass/trunk: gui/wxpython/vdigit include lib/manage lib/sites lib/vector/Vlib lib/vector/vedit raster/r.carve raster/r.contour raster/r.flow raster/r.random raster/r.to.vect vector/lidar/v.outlier vector/v.buffer vector/v.build vector/v.build.polylines vector/v.category vector/v.clean vector/v.convert vector/v.digit vector/v.distance vector/v.drape vector/v.edit vector/v.external vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.in.ascii vector/v.in.db vector/v.in.dxf vector/v.in.ogr vector/v.in.region vector/v.in.sites vector/v.kcv vector/v.kernel vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.mkgrid vector/v.net vector/v.net.alloc vector/v.net.iso vector/v.net.path vector/v.net.salesman vector/v.net.steiner vector/v.net.visibility vector/v.overlay vector/v.parallel vector/v.patch vector/v.perturb vector/v.proj vector/v.qcount vector/v.random vector/v.reclass vector/v.sample vector/v.segment vector/v.select vector/v.split vector/v.surf.rst vector/v.to.points vector/v.transform vector/v.type vector/v.vol.rst vector/v.voronoi vector/v.what
Fri Nov 14 06:26:18 EST 2008
Author: glynn
Date: 2008-11-14 06:26:17 -0500 (Fri, 14 Nov 2008)
New Revision: 34284
   grass/trunk/gui/wxpython/vdigit/driver.cpp
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/include/Vect.h
   grass/trunk/lib/manage/do_copy.c
   grass/trunk/lib/manage/do_rename.c
   grass/trunk/lib/sites/sites.c
   grass/trunk/lib/vector/Vlib/break_lines.c
   grass/trunk/lib/vector/Vlib/break_polygons.c
   grass/trunk/lib/vector/Vlib/bridges.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/build_nat.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/clean_nodes.c
   grass/trunk/lib/vector/Vlib/dangles.c
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/remove_areas.c
   grass/trunk/lib/vector/Vlib/remove_duplicates.c
   grass/trunk/lib/vector/Vlib/select.c
   grass/trunk/lib/vector/Vlib/sindex.c
   grass/trunk/lib/vector/Vlib/snap.c
   grass/trunk/lib/vector/vedit/select.c
   grass/trunk/raster/r.carve/vect.c
   grass/trunk/raster/r.contour/main.c
   grass/trunk/raster/r.flow/io.c
   grass/trunk/raster/r.random/random.c
   grass/trunk/raster/r.to.vect/main.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.build.polylines/main.c
   grass/trunk/vector/v.build/main.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.clean/prune.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.digit/centre.c
   grass/trunk/vector/v.digit/main.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.edit/a2b.c
   grass/trunk/vector/v.edit/main.c
   grass/trunk/vector/v.edit/snap.c
   grass/trunk/vector/v.external/main.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.in.ascii/main.c
   grass/trunk/vector/v.in.db/main.c
   grass/trunk/vector/v.in.dxf/main.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.in.region/main.c
   grass/trunk/vector/v.in.sites/main.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.lrs/v.lrs.create/main.c
   grass/trunk/vector/v.lrs/v.lrs.label/main.c
   grass/trunk/vector/v.lrs/v.lrs.segment/main.c
   grass/trunk/vector/v.mkgrid/main.c
   grass/trunk/vector/v.net.alloc/main.c
   grass/trunk/vector/v.net.iso/main.c
   grass/trunk/vector/v.net.path/main.c
   grass/trunk/vector/v.net.salesman/main.c
   grass/trunk/vector/v.net.steiner/main.c
   grass/trunk/vector/v.net.visibility/main.c
   grass/trunk/vector/v.net/connect.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.overlay/area_area.c
   grass/trunk/vector/v.overlay/line_area.c
   grass/trunk/vector/v.overlay/main.c
   grass/trunk/vector/v.parallel/main.c
   grass/trunk/vector/v.patch/main.c
   grass/trunk/vector/v.perturb/main.c
   grass/trunk/vector/v.proj/main.c
   grass/trunk/vector/v.qcount/main.c
   grass/trunk/vector/v.random/main.c
   grass/trunk/vector/v.reclass/main.c
   grass/trunk/vector/v.sample/main.c
   grass/trunk/vector/v.segment/main.c
   grass/trunk/vector/v.select/main.c
   grass/trunk/vector/v.split/main.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.points/main.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.type/main.c
   grass/trunk/vector/v.vol.rst/main.c
   grass/trunk/vector/v.voronoi/dt_main.c
   grass/trunk/vector/v.voronoi/vo_main.c
   grass/trunk/vector/v.what/main.c
Eliminate non-standard logging mechanism
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp	2008-11-14 11:26:17 UTC (rev 34284)
@@ -104,8 +104,8 @@
     if (mapInfo) {
 	if (mapInfo->mode == GV_MODE_RW) {
 	    /* rebuild topology */
-	    Vect_build_partial(mapInfo, GV_BUILD_NONE, NULL);
-	    Vect_build(mapInfo, NULL);
+	    Vect_build_partial(mapInfo, GV_BUILD_NONE);
+	    Vect_build(mapInfo);
 	/* close map and store topo/cidx */
 	ret = Vect_close(mapInfo);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2008-11-14 11:26:17 UTC (rev 34284)
@@ -603,7 +603,7 @@
     changeset = AddActionsBefore();
     ret = Vect_break_lines_list(display->mapInfo, display->selected.values, NULL,
-				GV_LINES, NULL, NULL);
+				GV_LINES, NULL);
     if (ret > 0) {
 	AddActionsAfter(changeset, nlines);
@@ -639,7 +639,7 @@
     Vect_snap_lines_list (display->mapInfo, display->selected.values,
-			  thresh, NULL, NULL);
+			  thresh, NULL);
     if (nlines < Vect_get_num_lines(display->mapInfo)) {
@@ -957,7 +957,7 @@
     ret = Vect_break_lines_list(display->mapInfo, listBreak, listRef,
+				GV_LINES, NULL);
     for (int i = 0; i < listBreak->n_values; i++) {
 	if (Vect_line_alive(display->mapInfo, listBreak->value[i]))
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/include/Vect.h	2008-11-14 11:26:17 UTC (rev 34284)
@@ -194,9 +194,9 @@
 int Vect_open_update(struct Map_info *, const char *, const char *);
 int Vect_open_update_head(struct Map_info *, const char *, const char *);
 int Vect_copy_head_data(struct Map_info *, struct Map_info *);
-int Vect_build(struct Map_info *, FILE *);
+int Vect_build(struct Map_info *);
 int Vect_get_built(struct Map_info *);
-int Vect_build_partial(struct Map_info *, int, FILE *);
+int Vect_build_partial(struct Map_info *, int);
 int Vect_set_constraint_region(struct Map_info *, double, double, double,
 			       double, double, double);
 int Vect_set_constraint_type(struct Map_info *, int);
@@ -296,30 +296,25 @@
 int Vect_point_in_island(double, double, struct Map_info *, int);
 /* Cleaning */
-void Vect_break_lines(struct Map_info *, int, struct Map_info *, FILE *);
+void Vect_break_lines(struct Map_info *, int, struct Map_info *);
 int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
-			  int, struct Map_info *, FILE *);
-void Vect_break_polygons(struct Map_info *, int, struct Map_info *, FILE *);
-void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *,
-			    FILE *);
+			  int, struct Map_info *);
+void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
+void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
 int Vect_line_check_duplicate(const struct line_pnts *,
 			      const struct line_pnts *, int);
-void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *,
-		     FILE *);
+void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
 void Vect_snap_lines_list(struct Map_info *, struct ilist *, double,
-			  struct Map_info *, FILE *);
-void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *,
-			 FILE *);
-void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *,
-			 FILE *);
-void Vect_select_dangles(struct Map_info *, int, double, FILE *,
-			 struct ilist *);
-void Vect_remove_bridges(struct Map_info *, struct Map_info *, FILE *);
-void Vect_chtype_bridges(struct Map_info *, struct Map_info *, FILE *);
+			  struct Map_info *);
+void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
+void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
+void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
+void Vect_remove_bridges(struct Map_info *, struct Map_info *);
+void Vect_chtype_bridges(struct Map_info *, struct Map_info *);
 int Vect_remove_small_areas(struct Map_info *, double, struct Map_info *,
-			    FILE *, double *);
+			    double *);
 int Vect_clean_small_angles_at_nodes(struct Map_info *, int,
 /* Overlay */
 int Vect_overlay_str_to_operator(const char *);
@@ -360,8 +355,8 @@
 			    int);
 int Vect_option_to_types(struct Option *);
 int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
-int Vect_copy(const char *, const char *, const char *, FILE *);
-int Vect_rename(const char *, const char *, FILE *);
+int Vect_copy(const char *, const char *, const char *);
+int Vect_rename(const char *, const char *);
 int Vect_copy_table(struct Map_info *, struct Map_info *, int, int,
 		    const char *, int);
 int Vect_copy_table_by_cats(struct Map_info *, struct Map_info *, int, int,
@@ -392,8 +387,8 @@
 int Vect_open_spatial_index(struct Map_info *);
 int Vect_save_spatial_index(struct Map_info *);
 int Vect_spatial_index_dump(struct Map_info *, FILE *);
-int Vect_build_sidx_from_topo(struct Map_info *, FILE *);
-int Vect_build_spatial_index(struct Map_info *, FILE *);
+int Vect_build_sidx_from_topo(struct Map_info *);
+int Vect_build_spatial_index(struct Map_info *);
 int Vect__write_head(struct Map_info *);
 int Vect__read_head(struct Map_info *);
@@ -446,8 +441,8 @@
 #endif
     /* Miscellaneous */
-int Vect_build_nat(struct Map_info *, int, FILE *);
-int Vect_build_ogr(struct Map_info *, int, FILE *);
+int Vect_build_nat(struct Map_info *, int);
+int Vect_build_ogr(struct Map_info *, int);
 int Vect_build_line_area(struct Map_info *, int, int);
 int Vect_isle_find_area(struct Map_info *, int);
 int Vect_attach_isle(struct Map_info *, int);
Modified: grass/trunk/lib/manage/do_copy.c
--- grass/trunk/lib/manage/do_copy.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/manage/do_copy.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -24,7 +24,7 @@
     hold_signals(1);
     if (G_strcasecmp(list[n].alias, "vect") == 0) {
-	ret = Vect_copy(old, mapset, new, stderr);
+	ret = Vect_copy(old, mapset, new);
 	if (ret == -1) {
 	    G_warning("Cannot copy <%s> to current mapset as <%s>",
 		      G_fully_qualified_name(old, mapset), new);
Modified: grass/trunk/lib/manage/do_rename.c
--- grass/trunk/lib/manage/do_rename.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/manage/do_rename.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -37,7 +37,7 @@
 	    G_warning(_("Vector map <%s> not found"), old);
 	else {
-	    ret = Vect_rename(old, new, stderr);
+	    ret = Vect_rename(old, new);
 	    if (ret != -1) {
 		renamed = 1;
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/sites/sites.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -440,7 +440,7 @@
     int i, j;
     if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)
-	Vect_build(Map, stderr);
+	Vect_build(Map);
     Vect_close(Map);
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/break_lines.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -28,16 +28,14 @@
    \param Map input vector map
    \param type feature type
    \param[out] Err vector map where points at intersections will be written or NULL
-   \param[out] msgout file pointer where messages will be written or NULL
    \return
 void
-Vect_break_lines(struct Map_info *Map, int type, struct Map_info *Err,
-		 FILE * msgout)
+Vect_break_lines(struct Map_info *Map, int type, struct Map_info *Err)
-    Vect_break_lines_list(Map, NULL, NULL, type, Err, msgout);
+    Vect_break_lines_list(Map, NULL, NULL, type, Err);
     return;
@@ -60,15 +58,13 @@
    \param List_ref list of reference lines or NULL
    \return number of intersections
 int
 Vect_break_lines_list(struct Map_info *Map, struct ilist *List_break,
-		      struct ilist *List_ref, int type, struct Map_info *Err,
-		      FILE * msgout)
+		      struct ilist *List_ref, int type, struct Map_info *Err)
     struct line_pnts *APoints, *BPoints, *Points;
     struct line_pnts **AXLines, **BXLines;
@@ -84,7 +80,6 @@
     int is3d;
     int node, anode1, anode2, bnode1, bnode2;
     double nodex, nodey;
-    int printed;
     APoints = Vect_new_line_struct();
     BPoints = Vect_new_line_struct();
@@ -116,10 +111,8 @@
      * the file, and process next line (remaining lines overlapping box are skipped)
     nbreaks = 0;
-    printed = 0;
-    if (msgout)
-	fprintf(msgout, _("%s %5d"), _("Intersections:"), nbreaks);
+    G_verbose_message(_("Intersections: %5d"), nbreaks);
     for (iline = 0; iline < nlines; iline++) {
 	if (List_break) {
@@ -361,14 +354,6 @@
 		G_free(yx);
 		G_free(zx);
-	    if (msgout && printed > 1000) {
-		fprintf(msgout, "\r%s %5d (line %d)", _("Intersections:"),
-			nbreaks, aline);
-		fflush(msgout);
-		printed = 0;
-	    printed++;
 	    if (naxlines > 0)
 		break;		/* first line was broken and deleted -> take the next one */
@@ -382,9 +367,7 @@
 	G_debug(3, "nlines =  %d", nlines);
     }				/* for each line */
-    if (msgout)
-	fprintf(msgout, "\r%s %5d                        \n",
-		_("Intersections:"), nbreaks);
     Vect_destroy_list(List);
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -55,13 +55,11 @@
    \param Map input map where polygons will be broken
    \param type type of line to be broken
    \param Err vector map where points at intersections will be written or NULL
-   \param msgout file pointer where messages will be written or NULL
    \return
 void
-Vect_break_polygons(struct Map_info *Map, int type, struct Map_info *Err,
-		    FILE * msgout)
+Vect_break_polygons(struct Map_info *Map, int type, struct Map_info *Err)
     struct line_pnts *BPoints, *Points;
     struct line_cats *Cats;
@@ -73,7 +71,6 @@
     struct Rect rect;
     double dx, dy, a1 = 0, a2 = 0;
     int closed, last_point, cross;
-    int printed;
     RTree = RTreeNewIndex();
@@ -93,7 +90,6 @@
     nallpoints = 0;
     XPnts = NULL;
-    printed = 0;
     for (i = 1; i <= nlines; i++) {
 	G_debug(3, "i =  %d", i);
 	if (!Vect_line_alive(Map, i))
@@ -210,28 +206,11 @@
 		npoints++;
-	if (msgout && printed > 5000) {
-	    fprintf(msgout, "\r%s %d", _("Registering points"), npoints - 1);
-	    fflush(msgout);
-	    printed = 0;
-	printed++;
-    if (msgout) {
-	fprintf(msgout, "\n");
-	fprintf(msgout, "%s: %5d\n", _("All points (vertices)"), nallpoints);
-		_("Registered points (unique coordinates)"), npoints - 1);
-	fprintf(msgout, "%s: %5d\n", _("Points marked for break"), nmarks);
     /* G_sleep (10); */
     nbreaks = 0;
-    if (msgout)
-	fprintf(msgout, "%s: %5d", _("Breaks"), nbreaks);
-    printed = 0;
     /* Second loop through lines (existing when loop is started, no need to process lines written again)
      * and break at points marked for break */
@@ -305,13 +284,6 @@
 		broken = 1;
 		nbreaks++;
-		fprintf(msgout, "\r%s: %5d", _("Breaks"), nbreaks);
-		fflush(msgout);
-		printed = 0;
-	    printed++;
 	if (!broken && n_orig_points > Points->n_points) {	/* was pruned before -> rewrite */
 	    if (Points->n_points > 1) {
@@ -329,9 +301,6 @@
-    if (msgout)
     /* Write points on breaks */
     if (Err) {
 	Vect_reset_cats(Cats);
@@ -344,9 +313,6 @@
-    if (msgout)
     G_free(XPnts);
     RTreeDestroyNode(RTree);
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/bridges.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -23,8 +23,7 @@
 #include <grass/glocale.h>
 static void
-remove_bridges(struct Map_info *Map, int chtype, struct Map_info *Err,
-	       FILE * msgout);
+remove_bridges(struct Map_info *Map, int chtype, struct Map_info *Err);
    \brief Remove bridges from vector map.
@@ -37,15 +36,14 @@
    \param Map input map where bridges are deleted
    \param Err vector map where deleted bridges are written or NULL
    \return
 void
-Vect_remove_bridges(struct Map_info *Map, struct Map_info *Err, FILE * msgout)
+Vect_remove_bridges(struct Map_info *Map, struct Map_info *Err)
-    remove_bridges(Map, 0, Err, msgout);
+    remove_bridges(Map, 0, Err);
@@ -59,15 +57,14 @@
    \param Map input map where bridges are changed
    \param Err vector map where changed bridges are written or NULL
    \return
 void
-Vect_chtype_bridges(struct Map_info *Map, struct Map_info *Err, FILE * msgout)
+Vect_chtype_bridges(struct Map_info *Map, struct Map_info *Err)
-    remove_bridges(Map, 1, Err, msgout);
+    remove_bridges(Map, 1, Err);
@@ -84,8 +81,7 @@
    List of all lines in chain is created during the cycle.
 void
-	       FILE * msgout)
     int i, type, nlines, line;
     int left, right, node1, node2, current_line, next_line;
@@ -116,10 +112,6 @@
     G_debug(1, "nlines =  %d", nlines);
-    if (msgout)
-	fprintf(msgout, "%s: %5d  %s: %5d",
-		_("Removed bridges"), bridges_removed, lmsg, lines_removed);
     for (line = 1; line <= nlines; line++) {
 	if (!Vect_line_alive(Map, line))
 	    continue;
@@ -196,17 +188,5 @@
 	    bridges_removed++;
-	if (msgout) {
-	    fprintf(msgout, "\r%s: %5d  %s: %5d",
-		    lines_removed);
-	    fflush(msgout);
-    if (msgout) {
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/build.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -42,37 +42,17 @@
 #endif
-FILE *Msgout = NULL;
-int prnmsg(char *msg, ...)
-    char buffer[1000];
-    va_list ap;
-    if (Msgout != NULL) {
-	va_start(ap, msg);
-	vsprintf(buffer, msg, ap);
-	va_end(ap);
-	fprintf(Msgout, "%s", buffer);
-	fflush(Msgout);
-    return 1;
    \brief Build topology for vector map
    \param Map vector map
-   \param msgout file for message output (stdout/stderr for example) or NULL
    \return 1 on success
    \return 0 on error
-int Vect_build(struct Map_info *Map, FILE * msgout)
+int Vect_build(struct Map_info *Map)
-    return Vect_build_partial(Map, GV_BUILD_ALL, msgout);
+    return Vect_build_partial(Map, GV_BUILD_ALL);
@@ -121,17 +101,15 @@
    \param build highest level of build
-   \param msgout file pointer for message output (stdout/stderr for example) or NULL
    \return 1 on success, 0 on error
-int Vect_build_partial(struct Map_info *Map, int build, FILE * msgout)
+int Vect_build_partial(struct Map_info *Map, int build)
     struct Plus_head *plus;
     int ret;
     G_debug(3, "Vect_build(): build = %d", build);
-    Msgout = msgout;
     /* If topology is already build (map on level2), set level to 1 so that lines will
      *  be read by V1_read_ (all lines) */
@@ -141,8 +119,8 @@
     Map->plus.Spidx_built = 1;
     plus = &(Map->plus);
-    prnmsg(_("Building topology for vector map <%s>...\n"),
-	   Vect_get_name(Map));
+    G_verbose_message(_("Building topology for vector map <%s>..."),
+		      Vect_get_name(Map));
     plus->with_z = Map->head.with_z;
     plus->spidx_with_z = Map->head.with_z;
@@ -151,13 +129,13 @@
 	dig_cidx_init(plus);
-    ret = ((*Build_array[Map->format]) (Map, build, msgout));
+    ret = ((*Build_array[Map->format]) (Map, build));
     if (ret == 0) {
 	return 0;
-    prnmsg(_("Topology was built\n"));
+    G_verbose_message(_("Topology was built"));
     Map->level = LEVEL_2;
     plus->mode = GV_MODE_WRITE;
@@ -167,20 +145,18 @@
 	dig_cidx_sort(plus);
-    /* prnmsg ("Topology was built.\n") ; */
+    G_verbose_message(_("Number of nodes: %d"), plus->n_nodes);
+    G_verbose_message(_("Number of primitives: %d"), plus->n_lines);
+    G_verbose_message(_("Number of points: %d"), plus->n_plines);
+    G_verbose_message(_("Number of lines: %d"), plus->n_llines);
+    G_verbose_message(_("Number of boundaries: %d"), plus->n_blines);
+    G_verbose_message(_("Number of centroids: %d"), plus->n_clines);
-    prnmsg(_("Number of nodes     :   %d\n"), plus->n_nodes);
-    prnmsg(_("Number of primitives:   %d\n"), plus->n_lines);
-    prnmsg(_("Number of points    :   %d\n"), plus->n_plines);
-    prnmsg(_("Number of lines     :   %d\n"), plus->n_llines);
-    prnmsg(_("Number of boundaries:   %d\n"), plus->n_blines);
-    prnmsg(_("Number of centroids :   %d\n"), plus->n_clines);
     if (plus->n_flines > 0)
-	prnmsg(_("Number of faces     :   %d\n"), plus->n_flines);
+	G_verbose_message(_("Number of faces: %d"), plus->n_flines);
     if (plus->n_klines > 0)
-	prnmsg(_("Number of kernels   :   %d\n"), plus->n_klines);
+	G_verbose_message(_("Number of kernels: %d"), plus->n_klines);
     if (plus->built >= GV_BUILD_AREAS) {
 	int line, nlines, area, nareas, err_boundaries, err_centr_out,
@@ -220,29 +196,29 @@
 		err_nocentr++;
-	prnmsg(_("Number of areas     :   %d\n"), plus->n_areas);
-	prnmsg(_("Number of isles     :   %d\n"), plus->n_isles);
+	G_verbose_message(_("Number of areas: %d"), plus->n_areas);
+	G_verbose_message(_("Number of isles: %d"), plus->n_isles);
 	if (err_boundaries)
-	    prnmsg(_("Number of incorrect boundaries   :   %d\n"),
-		   err_boundaries);
+	    G_verbose_message(_("Number of incorrect boundaries: %d"),
+			      err_boundaries);
 	if (err_centr_out)
-	    prnmsg(_("Number of centroids outside area :   %d\n"),
-		   err_centr_out);
+	    G_verbose_message(_("Number of centroids outside area: %d"),
+			      err_centr_out);
 	if (err_centr_dupl)
-	    prnmsg(_("Number of duplicate centroids    :   %d\n"),
-		   err_centr_dupl);
+	    G_verbose_message(_("Number of duplicate centroids: %d"),
+			      err_centr_dupl);
 	if (err_nocentr)
-	    prnmsg(_("Number of areas without centroid :   %d\n"),
-		   err_nocentr);
+	    G_verbose_message(_("Number of areas without centroid: %d"),
+			      err_nocentr);
     else {
-	prnmsg(_("Number of areas     :   -\n"));
-	prnmsg(_("Number of isles     :   -\n"));
+	G_verbose_message(_("Number of areas: -"));
+	G_verbose_message(_("Number of isles: -"));
     return 1;
@@ -451,7 +427,7 @@
 int Vect_spatial_index_dump(struct Map_info *Map, FILE * out)
     if (!(Map->plus.Spidx_built)) {
-	Vect_build_sidx_from_topo(Map, NULL);
+	Vect_build_sidx_from_topo(Map);
     fprintf(out, "---------- SPATIAL INDEX DUMP ----------\n");
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/build_nat.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -23,9 +23,6 @@
 #include <grass/gis.h>
 #include <grass/Vect.h>
-extern FILE *Msgout;
-extern int prnmsg(char *msg, ...);
    \brief Build area on given side of line (GV_LEFT or GV_RIGHT)
@@ -417,12 +414,11 @@
    \param Map_info vector map
    \param build build level
-   \param msgout message output (stdout/stderr for example) or NULL
    \return 0 on error
-int Vect_build_nat(struct Map_info *Map, int build, FILE * msgout)
+int Vect_build_nat(struct Map_info *Map, int build)
     int i, j, s, type, lineid;
@@ -439,7 +435,6 @@
     G_debug(3, "Vect_build_nat() build = %d", build);
-    Msgout = msgout;
     if (build == plus->built)
 	return 1;		/* Do nothing */
@@ -507,7 +502,7 @@
 	/* register lines, create nodes */
 	Vect_rewind(Map);
-	prnmsg(_("Registering primitives: "));
+	G_verbose_message(_("Registering primitives:"));
 	i = 1;
 	j = 1;
 	npoints = 0;
@@ -547,18 +542,11 @@
 		if (Cats->n_cats == 0)	/* add field 0, cat 0 */
 		    dig_cidx_add_cat(plus, 0, 0, lineid, type);
-	    /* print progress */
-	    if (i == 1000) {
-		prnmsg("%7d\b\b\b\b\b\b\b", j);
-		i = 0;
 	    i++;
 	    j++;
-	prnmsg("\r%d %s            \n", plus->n_lines,
-	       _("primitives registered"));
-	prnmsg("%d %s\n", npoints, _("vertices registered"));
+	G_verbose_message(_("%d primitives registered"), plus->n_lines);
+	G_verbose_message(_("%d vertices registered"), npoints);
 	plus->built = GV_BUILD_BASE;
@@ -569,9 +557,9 @@
     if (plus->built < GV_BUILD_AREAS) {
 	/* Build areas */
 	/* Go through all bundaries and try to build area for both sides */
-	prnmsg(_("Building areas: "));
+	G_verbose_message(_("Building areas:"));
 	for (i = 1; i <= plus->n_lines; i++) {
-	    G_percent2(i, plus->n_lines, 1, msgout);
+	    G_percent(i, plus->n_lines, 1);
 	    /* build */
 	    if (plus->Line[i] == NULL) {
@@ -592,8 +580,8 @@
 		Vect_build_line_area(Map, i, side);
-	prnmsg("\r%d %s      \n%d %s\n", plus->n_areas, _("areas built"),
-	       plus->n_isles, _("isles built"));
+	G_verbose_message(_("%d areas built"), plus->n_areas);
+	G_verbose_message(_("%d isles built"), plus->n_isles);
 	plus->built = GV_BUILD_AREAS;
@@ -602,13 +590,11 @@
     /* Attach isles to areas */
     if (plus->built < GV_BUILD_ATTACH_ISLES) {
-	prnmsg(_("Attaching islands: "));
+	G_verbose_message(_("Attaching islands:"));
 	for (i = 1; i <= plus->n_isles; i++) {
-	    G_percent2(i, plus->n_isles, 1, msgout);
+	    G_percent(i, plus->n_isles, 1);
 	    Vect_attach_isle(Map, i);
-	if (i == 1)
-	    prnmsg("\n");
 	plus->built = GV_BUILD_ATTACH_ISLES;
@@ -619,11 +605,11 @@
     if (plus->built < GV_BUILD_CENTROIDS) {
 	int nlines;
-	prnmsg(_("Attaching centroids: "));
+	G_verbose_message(_("Attaching centroids:"));
 	nlines = Vect_get_num_lines(Map);
-	    G_percent2(line, nlines, 1, msgout);
+	    G_percent(line, nlines, 1);
 	    Line = plus->Line[line];
 	    if (!Line)
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -36,9 +36,6 @@
 #ifdef HAVE_OGR
 #include <ogr_api.h>
  *  This structure keeps info about geometry parts above current geometry, path to curent geometry in the
  *  feature. First 'part' number however is feature Id
@@ -321,12 +318,11 @@
    \return 0 on error
-int Vect_build_ogr(struct Map_info *Map, int build, FILE * msgout)
+int Vect_build_ogr(struct Map_info *Map, int build)
     int iFeature, count, FID;
     GEOM_PARTS parts;
@@ -336,8 +332,6 @@
     if (build != GV_BUILD_ALL)
 	G_fatal_error(_("Partial build for OGR is not supported"));
-    Msgout = msgout;
     /* TODO move this init to better place (Vect_open_ ?), because in theory build may be reused on level2 */
     Map->fInfo.ogr.offset = NULL;
     Map->fInfo.ogr.offset_num = 0;
@@ -352,7 +346,7 @@
     init_parts(&parts);
     /* Note: Do not use OGR_L_GetFeatureCount (it may scan all features)!!! */
-    prnmsg(_("Feature: "));
+    G_verbose_message(_("Feature: "));
     OGR_L_ResetReading(Map->fInfo.ogr.layer);
     count = iFeature = 0;
@@ -362,12 +356,6 @@
 	G_debug(4, "---- Feature %d ----", iFeature);
-	if (count == 1000) {
-	    prnmsg("%7d\b\b\b\b\b\b\b", iFeature);
-	    count = 0;
 	hGeom = OGR_F_GetGeometryRef(hFeature);
 	if (hGeom == NULL) {
 	    G_warning(_("Feature %d without geometry ignored"), iFeature);
@@ -391,8 +379,6 @@
     }				/* while */
     free_parts(&parts);
-    prnmsg("%4d\n", iFeature);
     Map->plus.built = GV_BUILD_ALL;
     return 1;
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -32,13 +32,12 @@
    \param Err vector map where error line segments are written
    \return number of line modifications
 int
 Vect_clean_small_angles_at_nodes(struct Map_info *Map, int otype,
-				 struct Map_info *Err, FILE * msgout)
+				 struct Map_info *Err)
     int node;
     int nmodif = 0;
@@ -50,9 +49,6 @@
     LCats = Vect_new_cats_struct();
     OCats = Vect_new_cats_struct();
-    if (msgout)
-	fprintf(msgout, "%s: %5d", _("Modifications"), nmodif);
     for (node = 1; node <= Vect_get_num_nodes(Map); node++) {
 	int i, nlines;
@@ -246,19 +242,10 @@
 		angle1 = angle2;
-	    if (msgout) {
-		fprintf(msgout, "\r%s: %5d", _("Modifications"), nmodif);
-		fflush(msgout);
 	    if (clean)
 		break;
-    if (msgout)
-	fprintf(stderr, "\n");
     return (nmodif);
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/dangles.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -27,7 +27,7 @@
 #define SELECT_DANGLE 2
 static void dangles(struct Map_info *, int, int, double,
-		    struct Map_info *, FILE *, struct ilist *);
+		    struct Map_info *, struct ilist *);
    \brief Remove dangles from vector map.
@@ -47,15 +47,14 @@
    \param type type of dangles (GV_LINES, GV_LINE or GV_BOUNDARY)
    \param maxlength maxlength of dangles or -1 for all dangles
    \param Err vector map where deleted dangles are written or NULL
    \return
 void
 Vect_remove_dangles(struct Map_info *Map, int type, double maxlength,
-    dangles(Map, type, REMOVE_DANGLE, maxlength, Err, msgout, NULL);
+    dangles(Map, type, REMOVE_DANGLE, maxlength, Err, NULL);
@@ -74,15 +73,14 @@
    \param Map input map where have to be deleted
    \return
 void
 Vect_chtype_dangles(struct Map_info *Map, double maxlength,
-    dangles(Map, 0, CHTYPE_DANGLE, maxlength, Err, msgout, NULL);
+    dangles(Map, 0, CHTYPE_DANGLE, maxlength, Err, NULL);
@@ -99,15 +97,14 @@
    \return
 void
 Vect_select_dangles(struct Map_info *Map, int type, double maxlength,
-		    FILE * msgout, struct ilist *List)
+		    struct ilist *List)
-    dangles(Map, type, SELECT_DANGLE, maxlength, NULL, msgout, List);
+    dangles(Map, type, SELECT_DANGLE, maxlength, NULL, List);
@@ -126,11 +123,10 @@
    option dangle option (REMOVE_DANGLE, CHTYPE_DANGLE, SELECT_DANGLE)
-   msgout file pointer where messages will be written or NULL
    List_dangle list of feature (selected dangles) ids
 static void dangles(struct Map_info *Map, int type, int option,
-		    double maxlength, struct Map_info *Err, FILE * msgout,
+		    double maxlength, struct Map_info *Err,
 		    struct ilist *List_dangle)
     struct line_pnts *Points;
@@ -168,10 +164,6 @@
     List = Vect_new_list();
-    if (msgout)
-	fprintf(msgout, "%s %5d  %s: %5d",
-		_("Removed dangles:"), dangles_removed, lmsg, lines_removed);
     nnodes = Vect_get_num_nodes(Map);
     G_debug(2, "nnodes =  %d", nnodes);
@@ -266,23 +258,7 @@
 	    }			/* delete the chain */
-	    if (msgout) {
-		if (msgout)
-		    fprintf(msgout, "\r%s %5d  %s: %5d",
-			    lines_removed);
-		fflush(msgout);
 	    dangles_removed++;
 	}			/* lcount == 1 */
     }				/* node <= nnodes */
-    if (msgout) {
-	if (msgout)
-		    lines_removed);
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/map.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -148,13 +148,12 @@
    \param[in] in input vector map name
    \param[in] mapset mapset name
    \param[in] out output vector map name
-   \param[in] msgout output file for messages or NULL
    \return -1 error
    \return 0 success
 int
-Vect_copy(const char *in, const char *mapset, const char *out, FILE * msgout)
+Vect_copy(const char *in, const char *mapset, const char *out)
     int i, n, ret, type;
     struct Map_info In, Out;
@@ -294,12 +293,11 @@
    \return -1 error
    \return 0 success
-int Vect_rename(const char *in, const char *out, FILE * msgout)
+int Vect_rename(const char *in, const char *out)
     struct Map_info Map;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/open.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -445,7 +445,7 @@
 	Map->plus.alloc_upnodes = 0;
 	/* Build spatial index from topo */
     return ret;
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -32,15 +32,13 @@
    \param thresh maximum area size for removed areas
    \param Err vector map where removed lines and centroids are written
    \param removed_area  pointer to where total size of removed area is stored or NULL
    \return number of removed areas
 int
 Vect_remove_small_areas(struct Map_info *Map, double thresh,
-			struct Map_info *Err, FILE * msgout,
-			double *removed_area)
+			struct Map_info *Err, double *removed_area)
     int area;
     int nremoved = 0;
@@ -55,9 +53,6 @@
-    if (msgout)
-	fprintf(msgout, "%s: %5d", _("Removed areas"), nremoved);
     for (area = 1; area <= Vect_get_num_areas(Map); area++) {
 	int i, j, centroid, dissolve_neighbour;
 	double length, size;
@@ -176,13 +171,7 @@
 	nremoved++;
-	if (msgout) {
-	    fprintf(msgout, "\r%s: %5d", _("Removed areas"), nremoved);
-	    fflush(stderr);
-    if (msgout)
     if (removed_area)
 	*removed_area = size_removed;
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -31,13 +31,11 @@
    \param Map vector map where duplicate lines will be deleted
    \param type type of line to be delete
    \param Err vector map where duplicate lines will be written or NULL
    \return void
 void
-Vect_remove_duplicates(struct Map_info *Map, int type, struct Map_info *Err,
-		       FILE * msgout)
+Vect_remove_duplicates(struct Map_info *Map, int type, struct Map_info *Err)
     struct line_pnts *APoints, *BPoints;
     struct line_cats *ACats, *BCats, *Cats;
@@ -65,9 +63,6 @@
     ndupl = 0;
-    if (msgout)
-	fprintf(msgout, "%s: %5d", _("Duplicates"), ndupl);
 	    continue;
@@ -113,20 +108,11 @@
 	    ndupl++;
-	    if (msgout) {
-		fprintf(msgout, "\r%s: %5d", _("Duplicates"), ndupl);
-		fflush(msgout);
 	    break;		/* line was deleted -> take the next one */
 	nlines = Vect_get_num_lines(Map);	/* For future when lines with cats will be rewritten */
 	G_debug(3, "nlines =  %d\n", nlines);
-    if (msgout)
-    return;
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/select.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -50,7 +50,7 @@
     if (!(plus->Spidx_built)) {
 	G_debug(3, "Building spatial index.");
     list->n_values = 0;
@@ -100,7 +100,7 @@
     dig_select_areas(&(Map->plus), Box, list);
@@ -137,7 +137,7 @@
     dig_select_isles(&(Map->plus), Box, list);
@@ -169,7 +169,7 @@
     list->n_values = 0;
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/sindex.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -121,14 +121,14 @@
    \return 0 OK
    \return 1 error
-int Vect_build_spatial_index(struct Map_info *Map, FILE * msgout)
+int Vect_build_spatial_index(struct Map_info *Map)
     if (Map->level < 2) {
 	G_fatal_error(_("Unable to build spatial index from topology, "
 			"vector map is not opened at topo level 2"));
-	return (Vect_build_sidx_from_topo(Map, msgout));
+	return (Vect_build_sidx_from_topo(Map));
     return 0;
@@ -137,12 +137,11 @@
    \brief Create spatial index from topo if necessary
    \param Map pointer to vector map
-   \param msgout print progress here
    \return 0 OK
    \return 1 error
-int Vect_build_sidx_from_topo(struct Map_info *Map, FILE * msgout)
+int Vect_build_sidx_from_topo(struct Map_info *Map)
     int i, total, done;
@@ -162,7 +161,7 @@
     /* Nodes */
     for (i = 1; i <= plus->n_nodes; i++) {
-	G_percent2(i, total, 1, msgout);
+	G_percent(i, total, 1);
 	Node = plus->Node[i];
 	if (!Node)
@@ -174,7 +173,7 @@
     /* Lines */
     done = plus->n_nodes;
-	G_percent2(done + i, total, 1, msgout);
+	G_percent(done + i, total, 1);
 	Line = plus->Line[i];
 	if (!Line)
@@ -193,7 +192,7 @@
     /* Areas */
     done += plus->n_lines;
     for (i = 1; i <= plus->n_areas; i++) {
 	Area = plus->Area[i];
 	if (!Area)
@@ -212,7 +211,7 @@
     /* Isles */
     done += plus->n_areas;
 	Isle = plus->Isle[i];
 	if (!Isle)
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/Vlib/snap.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -62,7 +62,6 @@
  * \param[in] List_lines list of lines to snap
  * \param[in] thresh threshold in which snap vertices
  * \param[out] Err vector map where lines representing snap are written or NULL
- * \param[out] msgout file pointer where messages will be written or NULL
  * \return void
@@ -80,13 +79,12 @@
 void
 Vect_snap_lines_list(struct Map_info *Map, struct ilist *List_lines,
-		     double thresh, struct Map_info *Err, FILE * msgout)
+		     double thresh, struct Map_info *Err)
     struct line_pnts *Points, *NPoints;
     int line, ltype, line_idx;
     double thresh2;
-    int printed;
     struct Node *RTree;
     int point;			/* index in points array */
@@ -100,7 +98,6 @@
     struct ilist *List;
     int *Index = NULL;		/* indexes of anchors for vertices */
     int aindex = 0;		/* allocated Index */
-    int width = 26;		/* fprintf width */
     if (List_lines->n_values < 1)
 	return;
@@ -118,11 +115,7 @@
     point = 1;			/* index starts from 1 ! */
     nvertices = 0;
     XPnts = NULL;
-    printed = 0;
-    if (msgout)
-	fprintf(msgout, "%s...", _("Registering points"));
     for (line_idx = 0; line_idx < List_lines->n_values; line_idx++) {
 	int v;
@@ -166,21 +159,8 @@
 		point++;
-	    fprintf(msgout, "\r%s... %d", _("Registering points"), point - 1);
-	    fflush(msgout);
-	    printed = 0;
-	printed++;
     npoints = point - 1;
-    if (msgout) {
-	fprintf(msgout,
-		"\r                                               \r");
-	fprintf(msgout, "%-*s: %4d\n", width, _("All vertices"), nvertices);
-	fprintf(msgout, "%-*s: %4d\n", width, _("Registered points"),
-		npoints);
     /* Go through all registered points and if not yet marked mark it as anchor and assign this anchor
      * to all not yet marked points in threshold */
@@ -226,21 +206,12 @@
-    if (msgout) {
-	fprintf(msgout, "%-*s: %4d\n", width, _("Nodes marked as anchor"),
-		nanchors);
-	fprintf(msgout, "%-*s: %4d\n", width, _("Nodes marked to be snapped"),
-		ntosnap);
     /* Go through all lines and:
      *   1) for all vertices: if not anchor snap it to its anchor
      *   2) for all segments: snap it to all anchors in threshold (except anchors of vertices of course) */
-    printed = 0;
     nsnapped = ncreated = 0;
-    if (msgout)
-	fprintf(msgout, "%-*s: %4d", width, _("Snaps"), nsnapped + ncreated);
 	int v, spoint, anchor;
@@ -407,22 +378,8 @@
 		Vect_write_line(Err, ltype, Points, Cats);
-	    fprintf(msgout, "\r%s: %5d  (line = %d)", _("Snaps"),
-		    nsnapped + ncreated, line);
-	    fflush(msgout);
-	    printed = 0;
-	printed++;
-    if (msgout) {
-	fprintf(msgout, "\r%-*s: %4d\n", width, _("Snapped vertices"),
-		nsnapped);
-	fprintf(msgout, "%-*s: %4d\n", width, _("New vertices"), ncreated);
     Vect_destroy_line_struct(Points);
     Vect_destroy_line_struct(NPoints);
     Vect_destroy_cats_struct(Cats);
@@ -454,13 +411,12 @@
  * \param[in] type type of lines to snap
  * \return void
 void
 Vect_snap_lines(struct Map_info *Map, int type, double thresh,
     int line, nlines, ltype;
@@ -484,7 +440,7 @@
 	Vect_list_append(List, line);
-    Vect_snap_lines_list(Map, List, thresh, Err, msgout);
+    Vect_snap_lines_list(Map, List, thresh, Err);
Modified: grass/trunk/lib/vector/vedit/select.c
--- grass/trunk/lib/vector/vedit/select.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/lib/vector/vedit/select.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -91,7 +91,7 @@
 	    thresh_tmp = fabs(thresh);
 	    /* select dangles shorter than 'thresh_tmp' */
-	    Vect_select_dangles(Map, type, thresh_tmp, NULL, List_dangle);
+	    Vect_select_dangles(Map, type, thresh_tmp, List_dangle);
 	    if (thresh <= 0.0) {	/* shorter than */
 		for (i = 0; i < List_dangle->n_values; i++) {
Modified: grass/trunk/raster/r.carve/vect.c
--- grass/trunk/raster/r.carve/vect.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/raster/r.carve/vect.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -42,7 +42,7 @@
 int close_vect(struct Map_info *map, const int build_support)
     if (build_support)
-	Vect_build(map, stderr);
+	Vect_build(map);
     Vect_set_release_support(map);
     Vect_close(map);
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/raster/r.contour/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -198,7 +198,7 @@
     db_close_database_shutdown_driver(Driver);
-    Vect_build(&Map, stderr);
+    Vect_build(&Map);
     Vect_close(&Map);
     G_done_msg("");
Modified: grass/trunk/raster/r.flow/io.c
--- grass/trunk/raster/r.flow/io.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/raster/r.flow/io.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -181,7 +181,7 @@
     /*   if (parm.lgout)
        G_close_cell(lgfd); */
     if (parm.flout) {
-	Vect_build(&fl, stderr);
+	Vect_build(&fl);
 	Vect_close(&fl);
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/raster/r.random/random.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -251,7 +251,7 @@
     if (theState->outvector) {
 	db_commit_transaction(driver);
 	db_close_database_shutdown_driver(driver);
-	Vect_build(&Out, stderr);
+	Vect_build(&Out);
 	Vect_close(&Out);
     if (theState->outraster)
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/raster/r.to.vect/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -240,7 +240,7 @@
     G_close_cell(input_fd);
     if (!no_topol->answer)
+	Vect_build(&Map);
     /* insert cats and optionally labels if raster cats were used */
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -352,7 +352,7 @@
     Vect_close(&Out);
     Vect_close(&Outlier);
     if (qgis_opt->answer) {
-	Vect_build(&Qgis, stderr);
+	Vect_build(&Qgis);
 	Vect_close(&Qgis);
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.buffer/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -222,8 +222,8 @@
     Vect_close(In);
     G_message(_("Rebuilding topology..."));
-    Vect_build_partial(Out, GV_BUILD_NONE, NULL);
-    Vect_build(Out, stderr);
+    Vect_build_partial(Out, GV_BUILD_NONE);
+    Vect_build(Out);
     Vect_close(Out);
@@ -601,7 +601,7 @@
     /* Break lines */
     G_message(_("Building parts of topology..."));
-    Vect_build_partial(&Out, GV_BUILD_BASE, stderr);
+    Vect_build_partial(&Out, GV_BUILD_BASE);
     /* Warning: snapping must be done, otherwise colinear boundaries are not broken and
      * topology cannot be built (the same angle). But snapping distance must be very, very
@@ -613,13 +613,13 @@
      * the same angles of lines at nodes, don't forget about LongLat data, probably
      * calculate different threshold for each map, depending on map's bounding box */
     G_message(_("Snapping boundaries..."));
-    Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL, stderr);
+    Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
     G_message(_("Breaking boundaries..."));
-    Vect_break_lines(&Out, GV_BOUNDARY, NULL, stderr);
+    Vect_break_lines(&Out, GV_BOUNDARY, NULL);
     G_message(_("Removing duplicates..."));
-    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL, stderr);
+    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
     /* Dangles and bridges don't seem to be necessary if snapping is small enough. */
@@ -631,7 +631,7 @@
     G_message(_("Attaching islands..."));
-    Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES, stderr);
+    Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES);
     /* Calculate new centroids for all areas */
     nareas = Vect_get_num_areas(&Out);
@@ -745,7 +745,7 @@
     G_message(_("Attaching centroids..."));
-    Vect_build_partial(&Out, GV_BUILD_CENTROIDS, stderr);
+    Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
     stop(&In, &Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.build/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -82,7 +82,7 @@
 	Vect_set_open_level(1);
 	Vect_open_old(&Map, map_opt->answer, G_mapset());
+	Vect_build(&Map);
     /* dump topology */
     if (dump || sdump || cdump) {
@@ -150,7 +150,7 @@
-	Vect_build(&Err, stderr);
+	Vect_build(&Err);
 	Vect_close(&Err);
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.build.polylines/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -213,11 +213,7 @@
     G_free(lines_visited);
     Vect_close(&map);
-    if (G_verbose() > G_verbose_min())
-    else
-	Vect_build(&Out, NULL);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.category/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -483,12 +483,7 @@
     if (option == O_ADD || option == O_DEL || option == O_CHFIELD ||
 	option == O_SUM) {
 	Vect_copy_tables(&In, &Out, 0);
-	if (G_verbose() > G_verbose_min()) {
-	else {
+	Vect_build(&Out);
 	Vect_close(&Out);
     Vect_close(&In);
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.clean/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -35,7 +35,6 @@
     int level;
     int count;
     double size;
-    FILE *output;		/* NULL | stderr */
     G_gisinit(argv[0]);
@@ -277,32 +276,27 @@
     Vect_set_release_support(&In);
     Vect_close(&In);
-	output = stderr;
-    else
-	output = NULL;
     /* Start with GV_BUILD_NONE and for each tool use unly the necessary level! */
     for (i = 0; i < ntools; i++) {
 	if (tools[i] == TOOL_RMDAC || tools[i] == TOOL_PRUNE ||
 	    tools[i] == TOOL_RMAREA) {
 	    if (Vect_get_built(&Out) >= GV_BUILD_CENTROIDS) {
-		Vect_build_partial(&Out, GV_BUILD_CENTROIDS, NULL);
 	    else {
 		G_important_message(_("Rebuilding parts of topology..."));
-		Vect_build_partial(&Out, GV_BUILD_CENTROIDS, output);
 		G_message(SEP);
 	else {
 	    if (Vect_get_built(&Out) >= GV_BUILD_BASE) {
-		Vect_build_partial(&Out, GV_BUILD_BASE, NULL);
 	    else {
-		Vect_build_partial(&Out, GV_BUILD_BASE, output);
 		G_message(SEP);
@@ -310,27 +304,27 @@
 	switch (tools[i]) {
 	case TOOL_BREAK:
 	    G_message(_("Tool: Break lines at intersections"));
-	    Vect_break_lines(&Out, otype, pErr, output);
+	    Vect_break_lines(&Out, otype, pErr);
 	    break;
 	case TOOL_RMDUPL:
 	    G_message(_("Tool: Remove duplicates"));
-	    Vect_remove_duplicates(&Out, otype, pErr, output);
+	    Vect_remove_duplicates(&Out, otype, pErr);
 	    break;
 	case TOOL_RMDANGLE:
 	    G_message(_("Tool: Remove dangles"));
-	    Vect_remove_dangles(&Out, otype, threshs[i], pErr, output);
+	    Vect_remove_dangles(&Out, otype, threshs[i], pErr);
 	    break;
 	case TOOL_CHDANGLE:
 	    G_message(_("Tool: Change type of boundary dangles"));
-	    Vect_chtype_dangles(&Out, threshs[i], pErr, stderr);
+	    Vect_chtype_dangles(&Out, threshs[i], pErr);
 	    break;
 	case TOOL_RMBRIDGE:
 	    G_message(_("Tool: Remove bridges"));
-	    Vect_remove_bridges(&Out, pErr, output);
+	    Vect_remove_bridges(&Out, pErr);
 	    break;
 	case TOOL_CHBRIDGE:
 	    G_message(_("Tool: Change type of boundary bridges"));
-	    Vect_chtype_bridges(&Out, pErr, output);
+	    Vect_chtype_bridges(&Out, pErr);
 	    break;
 	case TOOL_RMDAC:
 	    G_message(_("Tool: Remove duplicate area centroids"));
@@ -338,11 +332,11 @@
 	    break;
 	case TOOL_SNAP:
 	    G_message(_("Tool: Snap line to vertex in threshold"));
-	    Vect_snap_lines(&Out, otype, threshs[i], pErr, output);
+	    Vect_snap_lines(&Out, otype, threshs[i], pErr);
 	    break;
 	case TOOL_BPOL:
 	    G_message(_("Tool: Break polygons"));
-	    Vect_break_polygons(&Out, otype, pErr, stderr);
+	    Vect_break_polygons(&Out, otype, pErr);
 	    break;
 	case TOOL_PRUNE:
 	    G_message(_("Tool: Prune lines/boundaries"));
@@ -351,14 +345,13 @@
 	case TOOL_RMAREA:
 	    G_message(_("Tool: Remove small areas"));
 	    count =
-		Vect_remove_small_areas(&Out, threshs[i], pErr, output,
-					&size);
+		Vect_remove_small_areas(&Out, threshs[i], pErr, &size);
 	    G_message(_("%d areas of total size %g removed"), count, size);
 	    break;
 	case TOOL_RMSA:
 	    G_message(_("Tool: Remove small angles at nodes"));
 	    count =
-		Vect_clean_small_angles_at_nodes(&Out, otype, pErr, output);
+		Vect_clean_small_angles_at_nodes(&Out, otype, pErr);
 	    G_message(_("%d modifications done"), count);
 	    break;
 	case TOOL_RMLINE:
@@ -373,18 +366,18 @@
     if (!no_build_flag->answer) {
 	G_important_message(_("Rebuilding topology for output vector map..."));
-	Vect_build_partial(&Out, GV_BUILD_NONE, NULL);
-	Vect_build(&Out, output);
+	Vect_build_partial(&Out, GV_BUILD_NONE);
+	Vect_build(&Out);
     else {
-	Vect_build_partial(&Out, GV_BUILD_NONE, NULL);	/* -> topo not saved */
+	Vect_build_partial(&Out, GV_BUILD_NONE);	/* -> topo not saved */
     Vect_close(&Out);
     if (pErr) {
 	G_message(SEP);
 	G_important_message(_("Building topology for error vector map..."));
-	Vect_build(pErr, output);
+	Vect_build(pErr);
 	Vect_close(pErr);
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.clean/prune.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -56,11 +56,8 @@
     if (Err)
-	Vect_build_partial(Err, GV_BUILD_BASE, NULL);
+	Vect_build_partial(Err, GV_BUILD_BASE);
-	fprintf(stderr, _("Removed vertices: %5d"), nremoved);
 	if (!Vect_line_alive(Out, line))
@@ -210,11 +207,6 @@
 	    nremoved += norig - TPoints->n_points;
 	    G_debug(4, "%d vertices removed", norig - TPoints->n_points);
-	    fprintf(stderr, "\r%s: %5d", _("Removed vertices"), nremoved);
-	fflush(stderr);
     G_important_message(_("\n%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"),
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.convert/old2new.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -141,7 +141,7 @@
     /* Convert dig_cats to table */
     attributes(in, &Mapout);
-    Vect_build(&Mapout, stderr);
+    Vect_build(&Mapout);
     Vect_close(&Mapout);
     fclose(Digin);
Modified: grass/trunk/vector/v.digit/centre.c
--- grass/trunk/vector/v.digit/centre.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.digit/centre.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -168,8 +168,8 @@
 void end(void)
     G_debug(1, "end()");
-    Vect_build_partial(&Map, GV_BUILD_NONE, NULL);
-    Vect_build(&Map, stdout);
+    Vect_build_partial(&Map, GV_BUILD_NONE);
+    Vect_build(&Map);
     Vect_close(&Map);
     if (1 == G_put_window(&GRegion))
Modified: grass/trunk/vector/v.digit/main.c
--- grass/trunk/vector/v.digit/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.digit/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -192,7 +192,7 @@
 	if (new_f->answer) {
 	    G_message(_("New empty map created."));
 	    Vect_open_new(&Map, map_opt->answer, 0);
-	    Vect_build(&Map, NULL);
+	    Vect_build(&Map);
 	    Vect_close(&Map);
 	    Vect_open_update(&Map, map_opt->answer, G_mapset());
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.distance/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -1131,10 +1131,7 @@
     Vect_close(&From);
     if (Outp != NULL) {
-	    Vect_build(Outp, stderr);
-	else
-	    Vect_build(Outp, NULL);
+	Vect_build(Outp);
 	Vect_close(Outp);
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.drape/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -267,13 +267,7 @@
     /* close input vector */
     Vect_close(&In);
     /* build topology for output vector */
-    else {
+    Vect_build(&Out);
     /* close output vector */
     Vect_close(&Out);
Modified: grass/trunk/vector/v.edit/a2b.c
--- grass/trunk/vector/v.edit/a2b.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.edit/a2b.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -299,7 +299,7 @@
     nlines_modified = 0;
-    Vect_build_partial(Map, GV_BUILD_BASE, NULL);
+    Vect_build_partial(Map, GV_BUILD_BASE);
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.edit/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -286,8 +286,7 @@
 				    coord, thresh[THRESH_COORDS], NULL);
 	else {
-	    ret = Vect_break_lines_list(&Map, List, NULL,
+	    ret = Vect_break_lines_list(&Map, List, NULL, GV_LINES, NULL);
 	G_message(_("%d lines broken"), ret);
 	break;
@@ -410,11 +409,8 @@
     /* build topology only if requested or if tool!=select */
     if (!(action_mode == MODE_SELECT || params.topo->answer == 1 ||
 	 !MODE_NONE)) {
-	else
+	Vect_build(&Map);
     if (List)
Modified: grass/trunk/vector/v.edit/snap.c
--- grass/trunk/vector/v.edit/snap.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.edit/snap.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -31,21 +31,13 @@
 int snap_lines(struct Map_info *Map, struct ilist *List, double thresh)
-    FILE *output;
+    if (G_verbose() > G_verbose_min())
 	G_important_message(SEP);
-	output = stderr;
-    else
-	output = NULL;
-    Vect_snap_lines_list(Map, List, thresh, NULL, output);
+    Vect_snap_lines_list(Map, List, thresh, NULL);
     return 1;
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.external/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -158,7 +158,7 @@
     fclose(fd);
     Vect_open_old(&Map, out_opt->answer, G_mapset());
+    Vect_build(&Map);
     Vect_close(&Map);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.extract/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -369,12 +369,8 @@
     xtract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve,
 		field, type_only, r_flag->answer ? 1 : 0);
-    else
+    Vect_build(&Out);
     /* Copy tables */
     if (!t_flag->answer) {
 	int nlines, line;
@@ -500,11 +496,8 @@
 		Vect_delete_line(&Out, line);
-	else
+	Vect_build(&Out);
     Vect_close(&Out);
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.extrude/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -61,6 +61,7 @@
     dbColumn *column;
     dbValue *value;
     int more;
+    char *comment;
     module = G_define_module();
     module->keywords = _("vector, geometry, 3D");
@@ -324,14 +325,9 @@
 	db_shutdown_driver(driver);
-    else
+    Vect_build(&Out);
     /* header */
-    char *comment;
     G_asprintf(&comment, "Generated by %s from vector map <%s>",
 	       G_program_name(), old->answer);
     Vect_set_comment(&Out, comment);
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.generalize/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -432,7 +432,7 @@
     /* remove incorrect boundaries
      * they may occur only if they were generalized */
     if (mask_type & GV_BOUNDARY) {
-	Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES, NULL);
 	n_lines = Vect_get_num_lines(&Out);
 	for (i = 1; i <= n_lines; i++) {
 	    type = Vect_read_line(&Out, Points, Cats, i);
@@ -452,7 +452,7 @@
      * were generalized
     if ((mask_type & GV_BOUNDARY) && method != DISPLACEMENT) {
 	n_areas = Vect_get_num_areas(&Out);
 	for (i = 1; i <= n_areas; i++) {
 	    /* skip dead area */
@@ -472,14 +472,11 @@
     /* remove small areas */
     if (rs_flag->answer && simplification && (mask_type & GV_AREA)) {
-	Vect_remove_small_areas(&Out, thresh, NULL, NULL, &slide);
+	Vect_remove_small_areas(&Out, thresh, NULL, &slide);
-    else
+    Vect_build(&Out);
     /* finally copy tables */
     if (ca_flag->answer)
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.hull/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -368,7 +368,7 @@
     /* clean up and bye bye */
+    Vect_build(&Map);
     Vect_close(&Map);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.ascii/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -221,7 +221,7 @@
     Vect_hist_command(&Map);
     if (e_flag->answer) {
+	Vect_build(&Map);
 	Vect_close(&Map);
 	exit(EXIT_SUCCESS);
@@ -535,7 +535,7 @@
 	Vect_close(&Map);
     else {
+	Vect_build(&Map);
 	Vect_close(&Map);
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.db/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -223,11 +223,7 @@
 			    fi->database, fi->driver);
-    else
+    Vect_build(&Map);
     Vect_close(&Map);
     G_done_msg(" ");
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.dxf/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -163,7 +163,7 @@
 	if (found_layers) {
 	    if (Vect_open_old(Map, output, G_mapset())) {
 		if (!flag_topo)
-		    if (!Vect_build(Map, stderr))
+		    if (!Vect_build(Map))
 			G_warning(_("Building topology failed"));
 		Vect_close(Map);
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -94,7 +94,6 @@
     int navailable_layers;
     int layer_id;
     int overwrite;
-    FILE *output;
     G_gisinit(argv[0]);
@@ -246,11 +245,6 @@
     OGRRegisterAll();
-	output = stderr;
-    else
-	output = NULL;
     /* list supported formats */
     if (formats_flag->answer) {
 	int iDriver;
@@ -888,7 +882,7 @@
     G_message("%s", separator);
     /* TODO: is it necessary to build here? probably not, consumes time */
-    Vect_build(&Map, output);
+    Vect_build(&Map);
     if (!no_clean_flag->answer &&
 	Vect_get_num_primitives(&Map, GV_BOUNDARY) > 0) {
@@ -908,12 +902,12 @@
 	Vect_set_release_support(&Map);
 	Vect_close(&Map);
 	Vect_open_update(&Map, out_opt->answer, G_mapset());
-	Vect_build_partial(&Map, GV_BUILD_BASE, output);	/* Downgrade topo */
+	Vect_build_partial(&Map, GV_BUILD_BASE);	/* Downgrade topo */
 	if (snap >= 0) {
 	    G_message(_("Snap boundaries (threshold = %.3e):"), snap);
-	    Vect_snap_lines(&Map, GV_BOUNDARY, snap, NULL, output);
+	    Vect_snap_lines(&Map, GV_BOUNDARY, snap, NULL);
 	/* It is not to clean to snap centroids, but I have seen data with 2 duplicate polygons
@@ -927,12 +921,12 @@
 	G_message(_("Break polygons:"));
-	Vect_break_polygons(&Map, GV_BOUNDARY, NULL, output);
+	Vect_break_polygons(&Map, GV_BOUNDARY, NULL);
 	/* It is important to remove also duplicate centroids in case of duplicate imput polygons */
 	G_message(_("Remove duplicates:"));
-	Vect_remove_duplicates(&Map, GV_BOUNDARY | GV_CENTROID, NULL, output);
+	Vect_remove_duplicates(&Map, GV_BOUNDARY | GV_CENTROID, NULL);
 	/* Vect_clean_small_angles_at_nodes() can change the geometry so that new intersections
 	 * are created. We must call Vect_break_lines(), Vect_remove_duplicates()
@@ -940,42 +934,41 @@
 	do {
 	    G_message(_("Break boundaries:"));
-	    Vect_break_lines(&Map, GV_BOUNDARY, NULL, output);
+	    Vect_break_lines(&Map, GV_BOUNDARY, NULL);
-	    Vect_remove_duplicates(&Map, GV_BOUNDARY, NULL, output);
+	    Vect_remove_duplicates(&Map, GV_BOUNDARY, NULL);
 	    G_message(_("Clean boundaries at nodes:"));
 	    nmodif =
-		Vect_clean_small_angles_at_nodes(&Map, GV_BOUNDARY, NULL,
-						 output);
+		Vect_clean_small_angles_at_nodes(&Map, GV_BOUNDARY, NULL);
 	} while (nmodif > 0);
 	if (type & GV_BOUNDARY) {	/* that means lines were converted boundaries */
 	    G_message(_("Change boundary dangles to lines:"));
-	    Vect_chtype_dangles(&Map, -1.0, NULL, output);
+	    Vect_chtype_dangles(&Map, -1.0, NULL);
 	else {
 	    G_message(_("Change dangles to lines:"));
-	    Vect_remove_dangles(&Map, GV_BOUNDARY, -1.0, NULL, output);
+	    Vect_remove_dangles(&Map, GV_BOUNDARY, -1.0, NULL);
 	    G_message(_("Change boundary bridges to lines:"));
-	    Vect_chtype_bridges(&Map, NULL, output);
+	    Vect_chtype_bridges(&Map, NULL);
 	else {
 	    G_message(_("Remove bridges:"));
-	    Vect_remove_bridges(&Map, NULL, output);
+	    Vect_remove_bridges(&Map, NULL);
 	/* Boundaries are hopefully clean, build areas */
-	Vect_build_partial(&Map, GV_BUILD_ATTACH_ISLES, output);
+	Vect_build_partial(&Map, GV_BUILD_ATTACH_ISLES);
 	/* Calculate new centroids for all areas, centroids have the same id as area */
 	ncentr = Vect_get_num_areas(&Map);
@@ -1059,10 +1052,10 @@
 	if (Centr)
 	    G_free(Centr);
+	Vect_build(&Map);
Modified: grass/trunk/vector/v.in.region/main.c
--- grass/trunk/vector/v.in.region/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.region/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -94,7 +94,7 @@
 	Vect_write_line(&Out, GV_LINE, Points, Cats);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.in.sites/main.c
--- grass/trunk/vector/v.in.sites/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.in.sites/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -247,7 +247,7 @@
     db_close_database(driver);
+    Vect_build(&Map);
     Vect_close(&Map);
     G_site_free_struct(s);
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.kcv/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -253,7 +253,7 @@
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.kernel/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -384,7 +384,7 @@
 	Vect_close(&Net);
+	Vect_build(&Out);
 	Vect_close(&Out);
     else {
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -861,13 +861,13 @@
     Vect_close(&PMap);
     G_message(_("Building topology for output (out_lines) map..."));
+    Vect_build(&Out);
     Vect_close(&Out);
     /* Write errors */
     if (err_opt->answer) {
 	G_message(_("Building topology for error (err) map..."));
-	Vect_build(&EMap, stderr);
+	Vect_build(&EMap);
 	Vect_close(&EMap);
Modified: grass/trunk/vector/v.lrs/v.lrs.label/main.c
--- grass/trunk/vector/v.lrs/v.lrs.label/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.lrs/v.lrs.label/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -513,7 +513,7 @@
     db_close_database(rsdriver);
+    Vect_build(&Out);
     /* Free, close ... */
     Vect_close(&In);
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -334,7 +334,7 @@
+    Vect_build(&Out);
     Vect_close(&In);
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.mkgrid/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -276,10 +276,7 @@
-    else
+    Vect_build(&Map);
     Vect_close(&Map);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net/connect.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -54,7 +54,7 @@
     /* rewrite all primitives to output file */
     Vect_copy_map_lines(In, Out);
-    Vect_build_partial(Out, GV_BUILD_BASE, NULL);
+    Vect_build_partial(Out, GV_BUILD_BASE);
     /* go thorough all points in point map and write a new arcs if missing */
     while ((type = Vect_read_next_line(Pnts, Points, Cats)) >= 0) {
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -185,11 +185,8 @@
 	/* support */
-	else
+	Vect_build(&Out);
 	Vect_close(&In);
 	Vect_close(&Out);
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.alloc/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -360,7 +360,7 @@
+    Vect_build(&Out);
     /* Free, ... */
     G_free(Nodes);
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.iso/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -520,7 +520,7 @@
+    Vect_build(&Out);
     /* Free, ... */
     G_free(Nodes);
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.path/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -142,7 +142,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.salesman/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -371,7 +371,7 @@
     fprintf(stdout, "\n\n");
+    Vect_build(&Out);
     /* Free, ... */
     Vect_destroy_list(StArcs);
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.steiner/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -629,7 +629,7 @@
+    Vect_build(&Out);
     /* Free, ... */
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.net.visibility/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -118,11 +118,7 @@
     G_free(points);
     G_free(lines);
-	Vect_build(&out, stderr);
-    else
-	Vect_build(&out, NULL);
+    Vect_build(&out);
     Vect_close(&out);
     Vect_close(&in);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.overlay/area_area.c
--- grass/trunk/vector/v.overlay/area_area.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.overlay/area_area.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -29,13 +29,6 @@
     dbString stmt;
     int nmodif;
-    FILE *output;
-	output = stderr;
-    else
-	output = NULL;
@@ -44,15 +37,15 @@
      * and Vect_clean_small_angles_at_nodes() until no more small dangles are found */
     do {
 	G_message(_("Breaking lines..."));
-	Vect_break_lines(Out, GV_LINE | GV_BOUNDARY, NULL, output);
+	Vect_break_lines(Out, GV_LINE | GV_BOUNDARY, NULL);
 	/* Probably not necessary for LINE x AREA */
-	Vect_remove_duplicates(Out, GV_BOUNDARY, NULL, output);
+	Vect_remove_duplicates(Out, GV_BOUNDARY, NULL);
 	G_message(_("Cleaning boundaries at nodes..."));
 	nmodif =
-	    Vect_clean_small_angles_at_nodes(Out, GV_BOUNDARY, NULL, output);
+	    Vect_clean_small_angles_at_nodes(Out, GV_BOUNDARY, NULL);
     /* ?: May be result of Vect_break_lines() + Vect_remove_duplicates() any dangle or bridge?
@@ -60,7 +53,7 @@
     /* Attach islands */
-    Vect_build_partial(Out, GV_BUILD_ATTACH_ISLES, output);
+    Vect_build_partial(Out, GV_BUILD_ATTACH_ISLES);
@@ -269,7 +262,7 @@
     /* Build topology and remove boundaries with area without centroid on both sides */
-    Vect_build_partial(Out, GV_BUILD_ALL, output);
+    Vect_build_partial(Out, GV_BUILD_ALL);
     /* Create a list of lines to be deleted */
     nlines = Vect_get_num_lines(Out);
Modified: grass/trunk/vector/v.overlay/line_area.c
--- grass/trunk/vector/v.overlay/line_area.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.overlay/line_area.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -67,13 +67,10 @@
     db_init_string(&stmt);
-	Vect_break_lines(Out, GV_LINE | GV_BOUNDARY, NULL, stderr);
-    else
-	Vect_break_lines(Out, GV_LINE | GV_BOUNDARY, NULL, NULL);
     /* Basic topology needed only */
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.overlay/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -461,7 +461,7 @@
     G_message(_("Building partial topology..."));
     /* do not print output, because befor cleaning it is nonsense */
     /* AREA x AREA */
     if (type[0] == GV_AREA) {
@@ -472,11 +472,8 @@
-    else
+    Vect_build(&Out);
     /* Build topology to show the final result and prepare for Vect_close() */
     if (driver) {
Modified: grass/trunk/vector/v.parallel/main.c
--- grass/trunk/vector/v.parallel/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.parallel/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -89,7 +89,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.patch/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -353,11 +353,7 @@
     Vect_set_map_name(&OutMap, "Output from v.patch");
     Vect_set_person(&OutMap, G_whoami());
-	Vect_build(&OutMap, stderr);
-    else
-	Vect_build(&OutMap, NULL);
+    Vect_build(&OutMap);
     Vect_close(&OutMap);
     if (bbox_name) {
@@ -366,11 +362,7 @@
 	G_important_message("");
 	G_important_message(_("Building topology for vector map <%s>..."),
 			    bbox_name);
-	    Vect_build(&BBoxMap, stderr);
-	else
-	    Vect_build(&BBoxMap, NULL);
+	Vect_build(&BBoxMap);
 	Vect_close(&BBoxMap);
Modified: grass/trunk/vector/v.perturb/main.c
--- grass/trunk/vector/v.perturb/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.perturb/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -241,7 +241,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     return (EXIT_SUCCESS);
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.proj/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -279,11 +279,7 @@
     Vect_close(&Map);
-	Vect_build(&Out_Map, stderr);
-    else
-	Vect_build(&Out_Map, NULL);
+    Vect_build(&Out_Map);
     Vect_close(&Out_Map);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.qcount/main.c
--- grass/trunk/vector/v.qcount/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.qcount/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -147,7 +147,7 @@
 	    Vect_write_line(&Out, GV_POINT, Points, Cats);
+	Vect_build(&Out);
 	Vect_close(&Out);
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.random/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -296,10 +296,7 @@
     if (!flag.notopo->answer) {
-	else
+	Vect_build(&Out);
     Vect_close(&Out);
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.reclass/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -414,7 +414,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     G_message(_("%d features reclassed"), rclelem);
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.sample/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -283,7 +283,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.segment/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -228,13 +228,7 @@
     G_message(_("%d lines written to output map (%d lost)"),
 	      lines_written, lines_read - lines_written);
-    else {
+    Vect_build(&Out);
     Vect_close(&In);
     Vect_close(&Out);
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.select/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -509,7 +509,7 @@
     Vect_close(&(In[0]));
+    Vect_build(&Out);
     Vect_close(&Out);
     G_done_msg(" ");
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.split/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -183,7 +183,7 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(0);
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.surf.rst/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -597,7 +597,7 @@
 	   TreeMap.head.plani_zone = G_zone ();
 	print_tree(root, x_orig, y_orig, &TreeMap);
-	Vect_build(&TreeMap, NULL);
+	Vect_build(&TreeMap);
 	Vect_close(&TreeMap);
@@ -691,7 +691,7 @@
 	   OverMap.head.plani_zone = G_zone ();
 	print_tree(root, x_orig, y_orig, &OverMap);
-	Vect_build(&OverMap, NULL);
+	Vect_build(&OverMap);
 	Vect_close(&OverMap);
@@ -711,7 +711,7 @@
     if (cvdev != NULL || devi != NULL) {
 	/*  db_close_database_shutdown_driver ( driver2 ); */
 	db_close_database(driver2);
-	Vect_build(&Map2, stderr);
+	Vect_build(&Map2);
 	Vect_close(&Map2);
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.to.points/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -367,7 +367,7 @@
+    Vect_build(&Out);
     Vect_close(&In);
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.transform/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -338,12 +338,8 @@
     Vect_copy_tables(&Old, &New, 0);
     Vect_close(&Old);
+    Vect_build(&New);
-	Vect_build(&New, stderr);
-    else
-	Vect_build(&New, NULL);
     if (!quiet_flag->answer) {
 	Vect_get_map_box(&New, &box);
 	G_message(_("\nNew vector map <%s> boundary coordinates:"),
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.type/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -226,7 +226,7 @@
+    Vect_build(&Out);
     Vect_close(&Out);
     Vect_close(&In);
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.vol.rst/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -885,7 +885,7 @@
+		Vect_build(&Map);
 		Vect_close(&Map);
Modified: grass/trunk/vector/v.voronoi/dt_main.c
--- grass/trunk/vector/v.voronoi/dt_main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.voronoi/dt_main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -98,7 +98,7 @@
     Vect_hist_copy(&In, &Out);
     Vect_hist_command(&Out);
     /* initialize working region */
     G_get_window(&Window);
@@ -119,7 +119,7 @@
     Vect_close(&In);
     G_debug(3, "nareas = %d", nareas);
@@ -150,8 +150,8 @@
 	Vect_write_line(&Out, GV_CENTROID, Points, Cats);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.voronoi/vo_main.c
--- grass/trunk/vector/v.voronoi/vo_main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.voronoi/vo_main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -177,7 +177,7 @@
     voronoi(triangulate, nextone);
     /* Close free ends by cyrrent region */
     ncoor = 0;
     acoor = 100;
@@ -346,8 +346,8 @@
     Vect_close(&In);
+    Vect_build(&Out);
     Vect_close(&Out);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c	2008-11-14 11:22:33 UTC (rev 34283)
+++ grass/trunk/vector/v.what/main.c	2008-11-14 11:26:17 UTC (rev 34284)
@@ -137,7 +137,7 @@
 			      vect[i]);
 	    G_verbose_message(_("Building spatial index..."));
-	    Vect_build_spatial_index(&Map[i], NULL);
+	    Vect_build_spatial_index(&Map[i]);
