[GRASS-SVN] r34355 - grass/trunk/locale/po
Tue Nov 18 05:45:31 EST 2008
Author: neteler
Date: 2008-11-18 05:45:30 -0500 (Tue, 18 Nov 2008)
New Revision: 34355
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grasstcl_de.po
   grass/trunk/locale/po/grasswxpy_de.po
Robert Nuske <rnuske gwdg.de>: cont'ed + update via template refresh
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2008-11-18 10:35:56 UTC (rev 34354)
+++ grass/trunk/locale/po/grasslibs_de.po	2008-11-18 10:45:30 UTC (rev 34355)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-10-11 22:08+0200\n"
+"POT-Creation-Date: 2008-11-18 11:38+0100\n"
 "PO-Revision-Date: 2008-10-11 18:08+0200\n"
 "Last-Translator: Markus Neteler <neteler osgeo.org>\n"
 "Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
@@ -413,6 +413,7 @@
 #: ../lib/ogsf/Gs3.c:284 ../lib/ogsf/Gs3.c:357 ../lib/ogsf/Gs3.c:472
 #: ../lib/ogsf/Gs3.c:568 ../lib/ogsf/Gs3.c:635 ../lib/ogsf/Gs3.c:692
 #: ../lib/ogsf/Gs3.c:761 ../lib/ogsf/Gs3.c:829 ../lib/ogsf/Gp3.c:54
+#: ../lib/manage/do_remove.c:53 ../lib/manage/do_rename.c:53
 #, fuzzy, c-format
 msgid "Raster map <%s> not found"
 msgstr "Eingabevektorkarte <%s> nicht gefunden."
@@ -582,8 +583,8 @@
 #: ../lib/db/dbmi_client/copy_tab.c:105 ../lib/db/dbmi_client/copy_tab.c:126
 #: ../lib/db/dbmi_client/db.c:46 ../lib/db/dbmi_client/delete_tab.c:49
-#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/map.c:269
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/map.c:616
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:268
+#: ../lib/vector/Vlib/map.c:402 ../lib/vector/Vlib/map.c:614
 #: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:355
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
@@ -857,108 +858,111 @@
 msgid "Requested format is not compiled in this version"
 msgstr "Das angeforderte Format ist in dieser Version nicht einkompiliert."
-#: ../lib/vector/Vlib/build.c:144
-#, c-format
-msgid "Building topology for vector map <%s>...\n"
+#: ../lib/vector/Vlib/build.c:122
+#, fuzzy, c-format
+msgid "Building topology for vector map <%s>..."
 msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
-#: ../lib/vector/Vlib/build.c:160
-msgid "Topology was built\n"
+#: ../lib/vector/Vlib/build.c:138
+#, fuzzy
+msgid "Topology was built"
 msgstr "Die Topologie wurde erstellt\n"
-#: ../lib/vector/Vlib/build.c:172
-#, c-format
-msgid "Number of nodes     :   %d\n"
+#: ../lib/vector/Vlib/build.c:148
+#, fuzzy, c-format
+msgid "Number of nodes: %d"
 msgstr "Anzahl von Knoten     :   %d\n"
-#: ../lib/vector/Vlib/build.c:173
-#, c-format
-msgid "Number of primitives:   %d\n"
+#: ../lib/vector/Vlib/build.c:149
+#, fuzzy, c-format
+msgid "Number of primitives: %d"
 msgstr "Anzahl von Primitives :   %d\n"
-#: ../lib/vector/Vlib/build.c:174
-#, c-format
-msgid "Number of points    :   %d\n"
+#: ../lib/vector/Vlib/build.c:150
+#, fuzzy, c-format
+msgid "Number of points: %d"
 msgstr "Anzahl von Punkten    :   %d\n"
-#: ../lib/vector/Vlib/build.c:175
-#, c-format
-msgid "Number of lines     :   %d\n"
+#: ../lib/vector/Vlib/build.c:151
+#, fuzzy, c-format
+msgid "Number of lines: %d"
 msgstr "Anzahl von Linien     :   %d\n"
-#: ../lib/vector/Vlib/build.c:176
-#, c-format
-msgid "Number of boundaries:   %d\n"
+#: ../lib/vector/Vlib/build.c:152
+#, fuzzy, c-format
+msgid "Number of boundaries: %d"
 msgstr "Anzahl von Boundaries :   %d\n"
-#: ../lib/vector/Vlib/build.c:177
-#, c-format
-msgid "Number of centroids :   %d\n"
+#: ../lib/vector/Vlib/build.c:153
+#, fuzzy, c-format
+msgid "Number of centroids: %d"
 msgstr "Anzahl von Zentroiden :   %d\n"
-#: ../lib/vector/Vlib/build.c:180
-#, c-format
-msgid "Number of faces     :   %d\n"
+#: ../lib/vector/Vlib/build.c:156
+#, fuzzy, c-format
+msgid "Number of faces: %d"
 msgstr "Anzahl von Faces      :   %d\n"
-#: ../lib/vector/Vlib/build.c:183
-#, c-format
-msgid "Number of kernels   :   %d\n"
+#: ../lib/vector/Vlib/build.c:159
+#, fuzzy, c-format
+msgid "Number of kernels: %d"
 msgstr "Anzahl von Kerneln   :   %d\n"
-#: ../lib/vector/Vlib/build.c:223
-#, c-format
-msgid "Number of areas     :   %d\n"
+#: ../lib/vector/Vlib/build.c:199
+#, fuzzy, c-format
+msgid "Number of areas: %d"
 msgstr "Anzahl von Flächen    :   %d\n"
-#: ../lib/vector/Vlib/build.c:224
-#, c-format
-msgid "Number of isles     :   %d\n"
+#: ../lib/vector/Vlib/build.c:200
+#, fuzzy, c-format
+msgid "Number of isles: %d"
 msgstr "Anzahl von Inseln     :   %d\n"
-#: ../lib/vector/Vlib/build.c:227
-#, c-format
-msgid "Number of incorrect boundaries   :   %d\n"
+#: ../lib/vector/Vlib/build.c:203
+#, fuzzy, c-format
+msgid "Number of incorrect boundaries: %d"
 msgstr "Anzahl inkorrekter Boundaries   :   %d\n"
-#: ../lib/vector/Vlib/build.c:231
-#, c-format
-msgid "Number of centroids outside area :   %d\n"
+#: ../lib/vector/Vlib/build.c:207
+#, fuzzy, c-format
+msgid "Number of centroids outside area: %d"
 msgstr "Anzahl von Zentroiden außerhalb von Flächen :   %d\n"
-#: ../lib/vector/Vlib/build.c:235
-#, c-format
-msgid "Number of duplicate centroids    :   %d\n"
+#: ../lib/vector/Vlib/build.c:211
+#, fuzzy, c-format
+msgid "Number of duplicate centroids: %d"
 msgstr "Anzahl mehrfacher Zentroide    :   %d\n"
-#: ../lib/vector/Vlib/build.c:239
-#, c-format
-msgid "Number of areas without centroid :   %d\n"
+#: ../lib/vector/Vlib/build.c:215
+#, fuzzy, c-format
+msgid "Number of areas without centroid: %d"
 msgstr "Anzahl von Flächen ohne Zentroid :   %d\n"
-#: ../lib/vector/Vlib/build.c:244
-msgid "Number of areas     :   -\n"
+#: ../lib/vector/Vlib/build.c:220
+#, fuzzy
+msgid "Number of areas: -"
 msgstr "Anzahl von Flächen    :   -\n"
-#: ../lib/vector/Vlib/build.c:245
-msgid "Number of isles     :   -\n"
+#: ../lib/vector/Vlib/build.c:221
+#, fuzzy
+msgid "Number of isles: -"
 msgstr "Anzahl von Inseln     :   -\n"
-#: ../lib/vector/Vlib/build.c:274
+#: ../lib/vector/Vlib/build.c:250
 #, c-format
 msgid "Unable to open topo file for write <%s>"
 msgstr "Kann Topologiedatei nicht zum Schreiben von <%s> öffnen"
-#: ../lib/vector/Vlib/build.c:282
+#: ../lib/vector/Vlib/build.c:258
 msgid "Error writing out topo file"
 msgstr "Fehler beim Schreiben der Topologiedatei"
-#: ../lib/vector/Vlib/build.c:425
+#: ../lib/vector/Vlib/build.c:401
 #, c-format
 msgid "Unable open spatial index file for write <%s>"
 msgstr "Kann spatial index-Datei nicht zum Schreiben von <%s> öffnen"
-#: ../lib/vector/Vlib/build.c:433
+#: ../lib/vector/Vlib/build.c:409
 msgid "Error writing out spatial index file"
 msgstr "Fehler beim Schreiben des spatial index aufgetreten "
@@ -975,14 +979,22 @@
 msgstr ""
 "Fehler in Vect_segment_intersection() (collineare nicht vertikale Segmente)"
+#: ../lib/vector/Vlib/intersect.c:1096 ../lib/vector/Vlib/intersect.c:1102
+#: ../lib/vector/Vlib/intersect.c:1104 ../lib/vector/Vlib/intersect.c:1149
+#: ../lib/vector/Vlib/intersect.c:1158 ../lib/vector/Vlib/intersect.c:1179
+#: ../lib/vector/Vlib/intersect.c:1196
+msgid "Error while adding point to array. Out of memory"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:100
 #, c-format
 msgid "Programmer requested unknown open level %d"
 msgstr "Programmierer fordert unbekanntes open_level %d an"
 #: ../lib/vector/Vlib/open.c:168 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/map.c:326
-#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109
+#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/map.c:324
+#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109 ../lib/manage/do_remove.c:37
+#: ../lib/manage/do_rename.c:37
 #, c-format
 msgid "Vector map <%s> not found"
@@ -1032,19 +1044,19 @@
 msgid "%s is not in the current mapset (%s)"
 msgstr "Keine %s Dateien im aktuellen Mapset vorhanden\n"
-#: ../lib/vector/Vlib/open.c:540 ../lib/vector/Vlib/map.c:176
-#: ../lib/vector/Vlib/map.c:313
+#: ../lib/vector/Vlib/open.c:540 ../lib/vector/Vlib/map.c:175
+#: ../lib/vector/Vlib/map.c:311
 #, fuzzy, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "Kartenname ist nicht SQL-kompatibel."
-#: ../lib/vector/Vlib/open.c:547 ../lib/vector/Vlib/map.c:187
-#: ../lib/vector/Vlib/map.c:317
+#: ../lib/vector/Vlib/open.c:547 ../lib/vector/Vlib/map.c:186
+#: ../lib/vector/Vlib/map.c:315
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Die Vektorkarte '%s' existiert bereits und wird überschrieben."
-#: ../lib/vector/Vlib/open.c:552 ../lib/vector/Vlib/map.c:191
+#: ../lib/vector/Vlib/open.c:552 ../lib/vector/Vlib/map.c:190
 #, fuzzy, c-format
 msgid "Unable to delete vector map <%s>"
 msgstr "Kann nicht zum Verzeichnis %s wechseln."
@@ -1070,42 +1082,6 @@
 msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr "Bitte Topologie für Vektorkarte '%s@%s' neu erzeugen"
-#: ../lib/vector/Vlib/snap.c:124 ../lib/vector/Vlib/snap.c:170
-#: ../lib/vector/Vlib/break_polygons.c:214
-#: ../lib/vector/Vlib/break_polygons.c:221
-#, fuzzy
-msgid "Registering points"
-msgstr "Registriere Linien..."
-#: ../lib/vector/Vlib/snap.c:180
-msgid "All vertices"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:181
-#, fuzzy
-msgid "Registered points"
-#: ../lib/vector/Vlib/snap.c:230
-msgid "Nodes marked as anchor"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:232
-msgid "Nodes marked to be snapped"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:243 ../lib/vector/Vlib/snap.c:412
-msgid "Snaps"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:421
-msgid "Snapped vertices"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:423
-msgid "New vertices"
-msgstr ""
 #: ../lib/vector/Vlib/close.c:134
 #, fuzzy, c-format
 msgid "Unable to close vector <%s>"
@@ -1186,10 +1162,6 @@
 msgid "Unable to open category index file for vector map <%s@%s>"
 msgstr "Kann den Kategorieindex der Vektorkarte <%s> nicht öffnen."
-#: ../lib/vector/Vlib/clean_nodes.c:54 ../lib/vector/Vlib/clean_nodes.c:250
-msgid "Modifications"
-msgstr ""
 #: ../lib/vector/Vlib/read.c:99
 #, fuzzy
 msgid "vector map is not opened"
@@ -1202,73 +1174,38 @@
 "map <%s>: %d)"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:173 ../lib/vector/Vlib/dangles.c:272
-#: ../lib/vector/Vlib/dangles.c:284
-msgid "Removed dangles:"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:98
+#: ../lib/vector/Vlib/array.c:99
 #, c-format
 msgid "%d errors in category string."
 msgstr ""
-#: ../lib/vector/Vlib/array.c:143 ../lib/vector/Vlib/array.c:267
+#: ../lib/vector/Vlib/array.c:145 ../lib/vector/Vlib/array.c:269
 msgid "Mixed area and other type requested for vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:153 ../lib/vector/Vlib/array.c:176
-#: ../lib/vector/Vlib/array.c:301 ../lib/vector/Vlib/array.c:334
+#: ../lib/vector/Vlib/array.c:155 ../lib/vector/Vlib/array.c:178
+#: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
 msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/map.c:241
-#: ../lib/vector/Vlib/map.c:363 ../lib/vector/Vlib/map.c:469
-#: ../lib/vector/Vlib/map.c:583 ../lib/vector/Vlib/map.c:681
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:240
+#: ../lib/vector/Vlib/map.c:361 ../lib/vector/Vlib/map.c:467
+#: ../lib/vector/Vlib/map.c:581 ../lib/vector/Vlib/map.c:679
 #: ../lib/vector/Vlib/net.c:179 ../lib/vector/Vlib/net.c:350
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:292
+#: ../lib/vector/Vlib/array.c:294
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
 msgstr "Kann Header-Datei für [%s in %s] nicht erstellen."
-#: ../lib/vector/Vlib/break_lines.c:122
-#, c-format
-msgid "%s %5d"
-msgstr ""
-#: ../lib/vector/Vlib/break_lines.c:122 ../lib/vector/Vlib/break_lines.c:366
-#: ../lib/vector/Vlib/break_lines.c:387
-#, fuzzy
-msgid "Intersections:"
+#: ../lib/vector/Vlib/break_lines.c:115 ../lib/vector/Vlib/break_lines.c:370
+#, fuzzy, c-format
+msgid "Intersections: %5d"
 msgstr "Andere Projektion"
-#: ../lib/vector/Vlib/break_polygons.c:223
-msgid "All points (vertices)"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:225
-#, fuzzy
-msgid "Registered points (unique coordinates)"
-#: ../lib/vector/Vlib/break_polygons.c:226
-msgid "Points marked for break"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:233
-#: ../lib/vector/Vlib/break_polygons.c:310
-#: ../lib/vector/Vlib/break_polygons.c:333
-msgid "Breaks"
-msgstr ""
-#: ../lib/vector/Vlib/bridges.c:121 ../lib/vector/Vlib/bridges.c:202
-#: ../lib/vector/Vlib/bridges.c:209
-msgid "Removed bridges"
-msgstr ""
 #: ../lib/vector/Vlib/poly.c:235
 #, fuzzy
 msgid "Unable to find point in polygon"
@@ -1309,19 +1246,19 @@
 "topo level 2"
 msgstr ""
-#: ../lib/vector/Vlib/sindex.c:169
+#: ../lib/vector/Vlib/sindex.c:168
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/sindex.c:181
+#: ../lib/vector/Vlib/sindex.c:180
 msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/sindex.c:200
+#: ../lib/vector/Vlib/sindex.c:199
 msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/sindex.c:219
+#: ../lib/vector/Vlib/sindex.c:218
 msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
 msgstr ""
@@ -1361,69 +1298,71 @@
 msgid "dglShortestPath error: %s"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:96
+#: ../lib/vector/Vlib/build_nat.c:93
 #, fuzzy
 msgid "Unable to add area (map closed, topo saved)"
 msgstr ""
 "Kann Fläche nicht hinzufügen. (Karte ist geschlossen, Topologie "
 "abgespeichert)."
-#: ../lib/vector/Vlib/build_nat.c:105
+#: ../lib/vector/Vlib/build_nat.c:102
 #, fuzzy
 msgid "Unable to add isle (map closed, topo saved)"
 msgstr ""
 "Kann Inselfläche nicht hinzufügen. (Karte ist geschlossen, Topologie "
 "gespeichert)."
-#: ../lib/vector/Vlib/build_nat.c:115
+#: ../lib/vector/Vlib/build_nat.c:112
 msgid "Area of size = 0.0 ignored"
 msgstr "Flächen mit der Größe = 0.0 werden ignoriert."
-#: ../lib/vector/Vlib/build_nat.c:151
+#: ../lib/vector/Vlib/build_nat.c:148
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:510
+#: ../lib/vector/Vlib/build_nat.c:505
 #, fuzzy
-msgid "Registering primitives: "
+msgid "Registering primitives:"
-#: ../lib/vector/Vlib/build_nat.c:520
+#: ../lib/vector/Vlib/build_nat.c:515
 #, fuzzy
 msgid "Unable to read vector map"
-#: ../lib/vector/Vlib/build_nat.c:560
-#, fuzzy
-msgid "primitives registered"
+#: ../lib/vector/Vlib/build_nat.c:548
+#, fuzzy, c-format
+msgid "%d primitives registered"
 msgstr "\r%d primitives registriert \n"
-#: ../lib/vector/Vlib/build_nat.c:561
-#, fuzzy
-msgid "vertices registered"
+#: ../lib/vector/Vlib/build_nat.c:549
+#, fuzzy, c-format
+msgid "%d vertices registered"
-#: ../lib/vector/Vlib/build_nat.c:572
+#: ../lib/vector/Vlib/build_nat.c:560
 #, fuzzy
-msgid "Building areas: "
+msgid "Building areas:"
 msgstr "Erzeuge Topologie ...\n"
-#: ../lib/vector/Vlib/build_nat.c:595
-#, fuzzy
-msgid "areas built"
+#: ../lib/vector/Vlib/build_nat.c:583
+#, fuzzy, c-format
+msgid "%d areas built"
 msgstr "Der Graph wurde erstellt"
-#: ../lib/vector/Vlib/build_nat.c:596
-#, fuzzy
-msgid "isles built"
+#: ../lib/vector/Vlib/build_nat.c:584
+#, fuzzy, c-format
+msgid "%d isles built"
-#: ../lib/vector/Vlib/build_nat.c:605
-msgid "Attaching islands: "
+#: ../lib/vector/Vlib/build_nat.c:593
+#, fuzzy
+msgid "Attaching islands:"
 msgstr "Füge Inselflächen hinzu: "
-#: ../lib/vector/Vlib/build_nat.c:622
-msgid "Attaching centroids: "
+#: ../lib/vector/Vlib/build_nat.c:608
+#, fuzzy
+msgid "Attaching centroids:"
 msgstr "Füge Zentroide hinzu: "
 #: ../lib/vector/Vlib/open_nat.c:145
@@ -1440,37 +1379,37 @@
 "missing)."
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:275
+#: ../lib/vector/Vlib/build_ogr.c:272
 #, fuzzy, c-format
 msgid "Unable to calculate centroid for area %d"
 msgstr "Kann den Zentroid für die Fläche %d nicht berechnen."
-#: ../lib/vector/Vlib/build_ogr.c:312 ../lib/vector/Vlib/read_ogr.c:120
+#: ../lib/vector/Vlib/build_ogr.c:309 ../lib/vector/Vlib/read_ogr.c:120
 #: ../lib/vector/Vlib/read_ogr.c:306
 #, fuzzy, c-format
 msgid "OGR feature type %d not supported"
 msgstr "OGR Feature Typ %d wird nicht unterstützt."
-#: ../lib/vector/Vlib/build_ogr.c:337
+#: ../lib/vector/Vlib/build_ogr.c:333
 msgid "Partial build for OGR is not supported"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:348
+#: ../lib/vector/Vlib/build_ogr.c:342
 msgid ""
 "Random read is not supported by OGR for this layer, cannot build support"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:355
+#: ../lib/vector/Vlib/build_ogr.c:349
 #, fuzzy
 msgid "Feature: "
 msgstr "Eigenschaften"
-#: ../lib/vector/Vlib/build_ogr.c:373
+#: ../lib/vector/Vlib/build_ogr.c:361
 #, c-format
 msgid "Feature %d without geometry ignored"
 msgstr "Feature %d ohne Geometrie ignoriert."
-#: ../lib/vector/Vlib/build_ogr.c:380
+#: ../lib/vector/Vlib/build_ogr.c:368
 #, fuzzy
 msgid "OGR feature without ID ignored"
 msgstr "OGR feature ohne ID ignoriert."
@@ -1538,20 +1477,10 @@
 "vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:59 ../lib/vector/Vlib/remove_areas.c:180
-msgid "Removed areas"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:98
+#: ../lib/vector/Vlib/remove_areas.c:93
 msgid "Area is composed of dead boundary"
 msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:69
-#: ../lib/vector/Vlib/remove_duplicates.c:117
-#, fuzzy
-msgid "Duplicates"
-msgstr "Doppeltes Ost-Feld"
 #: ../lib/vector/Vlib/map.c:55
 #, fuzzy
 msgid "input vector map is not open"
@@ -1563,74 +1492,74 @@
 msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/map.c:180
+#: ../lib/vector/Vlib/map.c:179
 #, fuzzy, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
-#: ../lib/vector/Vlib/map.c:211 ../lib/vector/Vlib/map.c:330
+#: ../lib/vector/Vlib/map.c:210 ../lib/vector/Vlib/map.c:328
 #, fuzzy, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:380
-#: ../lib/vector/Vlib/map.c:608 ../lib/vector/Vlib/map.c:715
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:378
+#: ../lib/vector/Vlib/map.c:606 ../lib/vector/Vlib/map.c:713
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
 msgstr "Kann Datei %s nicht öffnen."
-#: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/map.c:409
-#: ../lib/vector/Vlib/map.c:621
+#: ../lib/vector/Vlib/map.c:273 ../lib/vector/Vlib/map.c:407
+#: ../lib/vector/Vlib/map.c:619
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-#: ../lib/vector/Vlib/map.c:394 ../lib/vector/Vlib/map.c:489
+#: ../lib/vector/Vlib/map.c:392 ../lib/vector/Vlib/map.c:487
 #, fuzzy, c-format
 msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:443
+#: ../lib/vector/Vlib/map.c:441
 #, fuzzy, c-format
 msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:457
+#: ../lib/vector/Vlib/map.c:455
 #, fuzzy, c-format
 msgid "Unable to open header file for vector map <%s>"
 msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
-#: ../lib/vector/Vlib/map.c:479
+#: ../lib/vector/Vlib/map.c:477
 #, fuzzy, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr "Kann to topo-Datei der Vektorkarte <%s> nicht öffnen."
-#: ../lib/vector/Vlib/map.c:495
+#: ../lib/vector/Vlib/map.c:493
 #, fuzzy, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:509
+#: ../lib/vector/Vlib/map.c:507
 #, fuzzy, c-format
 msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:523
+#: ../lib/vector/Vlib/map.c:521
 #, fuzzy, c-format
 msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:538
 #, fuzzy, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:548
+#: ../lib/vector/Vlib/map.c:546
 #, fuzzy, c-format
 msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/map.c:599 ../lib/vector/Vlib/map.c:700
+#: ../lib/vector/Vlib/map.c:597 ../lib/vector/Vlib/map.c:698
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
@@ -2254,6 +2183,14 @@
 msgid "G_list: Unknown element type"
 msgstr "Unbekannter Vektortyp."
+#: ../lib/gis/error.c:257
+msgid "WARNING: "
+msgstr "WARNUNG: "
+#: ../lib/gis/error.c:258
+msgid "ERROR: "
+msgstr "FEHLER: "
 #: ../lib/gis/proj2.c:46
 msgid "Latitude-Longitude"
 msgstr "Längen- und Breitengrad"
@@ -2553,7 +2490,7 @@
 msgid "can't read range file for [%s in %s]"
 msgstr "Kann range Datei für [%s in %s] nicht lesen."
-#: ../lib/gis/range.c:359 ../lib/gis/range.c:412
+#: ../lib/gis/range.c:357 ../lib/gis/range.c:408
 #, c-format
 msgid "can't write range file for [%s in %s]"
 msgstr "Kann range Datei für [%s in %s] nicht schreiben."
@@ -2720,14 +2657,6 @@
 msgid "unable to determine user's home directory"
 msgstr "Kann das Home-Verzeichnis des Benutzers nicht finden."
-#: ../lib/gis/error.c:257
-msgid "WARNING: "
-msgstr "WARNUNG: "
-#: ../lib/gis/error.c:258
-msgid "ERROR: "
-msgstr "FEHLER: "
 #: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
 #, fuzzy, c-format
 msgid "Unable to read header file for raster map <%s@%s>."
@@ -2874,92 +2803,92 @@
 msgid "Driver name"
 msgstr ""
-#: ../lib/gis/parser.c:383
+#: ../lib/gis/parser.c:384
 msgid "Database name"
 msgstr ""
-#: ../lib/gis/parser.c:391
+#: ../lib/gis/parser.c:393
 msgid "Name of attribute column"
 msgstr "Name der Attributspalte"
-#: ../lib/gis/parser.c:400
+#: ../lib/gis/parser.c:402
 msgid "Name of attribute column(s)"
 msgstr "Name der Vektoreingabekarte"
-#: ../lib/gis/parser.c:411
+#: ../lib/gis/parser.c:413
 msgid "Name of input imagery group"
 msgstr "Name der Eingabe-Bildgruppe"
-#: ../lib/gis/parser.c:419
+#: ../lib/gis/parser.c:421
 #, fuzzy
 msgid "Name of input imagery subgroup"
-#: ../lib/gis/parser.c:429 ../lib/gis/parser.c:454
+#: ../lib/gis/parser.c:431 ../lib/gis/parser.c:456
 msgid "Name of input raster map"
 msgstr "Name der Eingaberasterkarte."
-#: ../lib/gis/parser.c:438 ../lib/gis/parser.c:463
+#: ../lib/gis/parser.c:440 ../lib/gis/parser.c:465
 msgid "Name of input raster map(s)"
 msgstr "Name der Eingaberasterkarte(n)."
-#: ../lib/gis/parser.c:446
+#: ../lib/gis/parser.c:448
 msgid "Name for output raster map"
 msgstr "Name der Ausgaberasterkarte."
-#: ../lib/gis/parser.c:471
+#: ../lib/gis/parser.c:473
 msgid "Name of base raster map"
 msgstr "Name der Basisrasterkarte."
-#: ../lib/gis/parser.c:479
+#: ../lib/gis/parser.c:481
 msgid "Name of cover raster map"
 msgstr "Name der Überlagerungskarte."
-#: ../lib/gis/parser.c:487
+#: ../lib/gis/parser.c:489
 msgid "Name of elevation raster map"
 msgstr "Name der Höhenrasterkarte."
-#: ../lib/gis/parser.c:496
+#: ../lib/gis/parser.c:498
 msgid "Name of elevation raster map(s)"
 msgstr "Name der Höhenrasterkarte(n)."
-#: ../lib/gis/parser.c:506 ../lib/gis/parser.c:531
+#: ../lib/gis/parser.c:508 ../lib/gis/parser.c:533
 msgid "Name of input raster3d map"
 msgstr "Name der 3D Eingaberasterkarte."
-#: ../lib/gis/parser.c:515 ../lib/gis/parser.c:540
+#: ../lib/gis/parser.c:517 ../lib/gis/parser.c:542
 msgid "Name of input raster3d map(s)"
 msgstr "Name der 3D Eingaberasterkarte(n)."
-#: ../lib/gis/parser.c:523
+#: ../lib/gis/parser.c:525
 msgid "Name for output raster3d map"
 msgstr "Name der 3D Ausgaberasterkarte."
-#: ../lib/gis/parser.c:550 ../lib/gis/parser.c:575
+#: ../lib/gis/parser.c:552 ../lib/gis/parser.c:577
 msgid "Name of input vector map"
 msgstr "Name der Vektoreingabekarte."
-#: ../lib/gis/parser.c:559 ../lib/gis/parser.c:584
+#: ../lib/gis/parser.c:561 ../lib/gis/parser.c:586
 msgid "Name of input vector map(s)"
 msgstr "Name der Vektoreingabekarte(n)"
-#: ../lib/gis/parser.c:567
+#: ../lib/gis/parser.c:569
 msgid "Name for output vector map"
 msgstr "Name der Vektorausgabekarte."
-#: ../lib/gis/parser.c:593
+#: ../lib/gis/parser.c:595
 msgid "Type"
 msgstr "Typ"
-#: ../lib/gis/parser.c:594
+#: ../lib/gis/parser.c:596
 msgid "Feature type(s)"
-#: ../lib/gis/parser.c:601
+#: ../lib/gis/parser.c:603
 msgid "Layer number"
 msgstr "Layer-Nummer"
-#: ../lib/gis/parser.c:603
+#: ../lib/gis/parser.c:605
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
 "number determines which table to use."
@@ -2967,65 +2896,65 @@
 "Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden."
 "Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
-#: ../lib/gis/parser.c:610
+#: ../lib/gis/parser.c:613
 msgid "Category value"
 msgstr "Kategoriewert"
-#: ../lib/gis/parser.c:617
+#: ../lib/gis/parser.c:620
 msgid "Category values"
 msgstr "Kategoriewerte"
-#: ../lib/gis/parser.c:618
+#: ../lib/gis/parser.c:621
 msgid "Example: 1,3,7-9,13"
 msgstr "Beispiel: 1,3,7-9,13"
-#: ../lib/gis/parser.c:628
+#: ../lib/gis/parser.c:631
 msgid "Name of input file"
 msgstr "Name der Eingabedatei"
-#: ../lib/gis/parser.c:636
+#: ../lib/gis/parser.c:639
 msgid "Name for output file"
 msgstr "Name der Ausgabedatei"
-#: ../lib/gis/parser.c:644
+#: ../lib/gis/parser.c:647
 msgid "Field separator"
 msgstr ""
-#: ../lib/gis/parser.c:655
+#: ../lib/gis/parser.c:658
 msgid "Color"
 msgstr ""
-#: ../lib/gis/parser.c:656
+#: ../lib/gis/parser.c:659
 msgid "Either a standard color name or R:G:B triplet"
 msgstr ""
-#: ../lib/gis/parser.c:665
+#: ../lib/gis/parser.c:668
 msgid "Background color"
 msgstr ""
-#: ../lib/gis/parser.c:667
+#: ../lib/gis/parser.c:670
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../lib/gis/parser.c:811
+#: ../lib/gis/parser.c:814
 #, c-format
 msgid "BUG in descriptions, option '%s' in <%s> does not exist"
 msgstr ""
-#: ../lib/gis/parser.c:906
+#: ../lib/gis/parser.c:909
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
 msgstr ""
-#: ../lib/gis/parser.c:920
+#: ../lib/gis/parser.c:923
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
 msgstr ""
-#: ../lib/gis/parser.c:950
+#: ../lib/gis/parser.c:953
 #, c-format
 msgid "Sorry <%s> is not a valid option\n"
 msgstr "Tut mir leid, <%s> ist keine erlaubte Option\n"
-#: ../lib/gis/parser.c:1058
+#: ../lib/gis/parser.c:1061
 #, c-format
 msgid ""
 "\n"
@@ -3034,7 +2963,7 @@
 "\n"
 "Beschreibung:\n"
-#: ../lib/gis/parser.c:1065
+#: ../lib/gis/parser.c:1068
 #, c-format
 msgid ""
 "\n"
@@ -3043,7 +2972,7 @@
 "\n"
 "Schlüsselwörter:\n"
-#: ../lib/gis/parser.c:1069
+#: ../lib/gis/parser.c:1072
 #, c-format
 msgid ""
 "\n"
@@ -3054,7 +2983,7 @@
 "Benutzung:\n"
-#: ../lib/gis/parser.c:1137
+#: ../lib/gis/parser.c:1140
 #, c-format
 msgid ""
 "\n"
@@ -3063,19 +2992,19 @@
 "\n"
 "Flags:\n"
-#: ../lib/gis/parser.c:1160 ../lib/gis/parser.c:1639 ../lib/gis/parser.c:1931
+#: ../lib/gis/parser.c:1163 ../lib/gis/parser.c:1642 ../lib/gis/parser.c:1934
 msgid "Allow output files to overwrite existing files"
 msgstr "Ausgabedateien dürfen bereits existierende Dateien überschreiben."
-#: ../lib/gis/parser.c:1162 ../lib/gis/parser.c:1643
+#: ../lib/gis/parser.c:1165 ../lib/gis/parser.c:1646
 msgid "Verbose module output"
 msgstr "Gesprächige Modulausgabe (verbose)"
-#: ../lib/gis/parser.c:1163 ../lib/gis/parser.c:1646
+#: ../lib/gis/parser.c:1166 ../lib/gis/parser.c:1649
 msgid "Quiet module output"
 msgstr "Schweigsame Modulausgabe"
-#: ../lib/gis/parser.c:1168
+#: ../lib/gis/parser.c:1171
 #, c-format
 msgid ""
 "\n"
@@ -3084,90 +3013,90 @@
 "\n"
 "Parameter:\n"
-#: ../lib/gis/parser.c:1191
+#: ../lib/gis/parser.c:1194
 #, c-format
 msgid "  %*s   default: %s\n"
 msgstr "  %*s    Standard: %s\n"
-#: ../lib/gis/parser.c:1530
+#: ../lib/gis/parser.c:1533
 msgid "NAME"
 msgstr ""
-#: ../lib/gis/parser.c:1543
+#: ../lib/gis/parser.c:1546
 msgid "KEYWORDS"
 msgstr ""
-#: ../lib/gis/parser.c:1548
+#: ../lib/gis/parser.c:1551
 msgid "SYNOPSIS"
 msgstr ""
-#: ../lib/gis/parser.c:1616
+#: ../lib/gis/parser.c:1619
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "Flags:\n"
-#: ../lib/gis/parser.c:1654
+#: ../lib/gis/parser.c:1657
 #, fuzzy
 msgid "Parameters"
 msgstr ""
 "\n"
 "Parameter:\n"
-#: ../lib/gis/parser.c:1694
+#: ../lib/gis/parser.c:1697
 #, fuzzy
 msgid "Options"
 msgstr " Optionen: %s\n"
-#: ../lib/gis/parser.c:1700
+#: ../lib/gis/parser.c:1703
 #, fuzzy
 msgid "Default"
 msgstr " Standard: %s\n"
-#: ../lib/gis/parser.c:1933
+#: ../lib/gis/parser.c:1936
 msgid "Allow overwrite"
 msgstr ""
-#: ../lib/gis/parser.c:1941
+#: ../lib/gis/parser.c:1944
 msgid "Run with minimal output messages"
 msgstr ""
-#: ../lib/gis/parser.c:1943
+#: ../lib/gis/parser.c:1946
 msgid "Run quietly"
 msgstr ""
-#: ../lib/gis/parser.c:1976
+#: ../lib/gis/parser.c:1979
 #, fuzzy
 msgid "Unable to spawn the 'wish' program"
 msgstr "Kann %s nicht öffnen."
-#: ../lib/gis/parser.c:1995
+#: ../lib/gis/parser.c:1998
 #, fuzzy
 msgid "Unable to determine program name"
-#: ../lib/gis/parser.c:2052
+#: ../lib/gis/parser.c:2055
 #, c-format
 msgid "  %*s   options: "
 msgstr "  %*s   Optionen: "
-#: ../lib/gis/parser.c:2097 ../lib/gis/parser.c:2112
+#: ../lib/gis/parser.c:2100 ../lib/gis/parser.c:2115
 #, c-format
 msgid "Sorry, <%c> is not a valid flag\n"
 msgstr "Tut mir leid, <%c> ist keine gültiges Flag\n"
-#: ../lib/gis/parser.c:2170
+#: ../lib/gis/parser.c:2173
 #, c-format
 msgid "Sorry, <%s=> is ambiguous\n"
 msgstr "Tut mir leid, <%s=> ist nicht eindeutig\n"
-#: ../lib/gis/parser.c:2176
+#: ../lib/gis/parser.c:2179
 #, c-format
 msgid "Sorry, <%s> is not a valid parameter\n"
 msgstr "Tut mir leid, <%s> ist kein gültiger Parameter\n"
-#: ../lib/gis/parser.c:2254
+#: ../lib/gis/parser.c:2257
 #, c-format
 msgid ""
 "\n"
@@ -3176,12 +3105,12 @@
 "\n"
 "Fehler: Ungültige Spannensyntax für den Parameter <%s>\n"
-#: ../lib/gis/parser.c:2255
+#: ../lib/gis/parser.c:2258
 #, c-format
 msgid "       Presented as: %s\n"
 msgstr "       Präsentiert als: %s\n"
-#: ../lib/gis/parser.c:2259
+#: ../lib/gis/parser.c:2262
 #, c-format
 msgid ""
 "\n"
@@ -3190,12 +3119,12 @@
 "\n"
 "FEHLER: Wert <%s> ist außerhalb der Spanne von Parameter <%s>\n"
-#: ../lib/gis/parser.c:2261
+#: ../lib/gis/parser.c:2264
 #, c-format
 msgid "       Legal range: %s\n"
 msgstr "       Erlaubte Spanne: %s\n"
-#: ../lib/gis/parser.c:2264
+#: ../lib/gis/parser.c:2267
 #, c-format
 msgid ""
 "\n"
@@ -3204,7 +3133,7 @@
 "\n"
 "FEHLER: Fehlender Wert für Parameter <%s>\n"
-#: ../lib/gis/parser.c:2268
+#: ../lib/gis/parser.c:2271
 #, fuzzy, c-format
 msgid ""
 "\n"
@@ -3213,12 +3142,12 @@
 "\n"
-#: ../lib/gis/parser.c:2270
+#: ../lib/gis/parser.c:2273
 #, fuzzy, c-format
 msgid "       valid options: %s\n"
-#: ../lib/gis/parser.c:2398
+#: ../lib/gis/parser.c:2401
 #, c-format
 msgid ""
 "\n"
@@ -3229,7 +3158,7 @@
 "Fehler: Benötigter Parameter <%s> ist nicht gesetzt:\n"
 "    (%s).\n"
-#: ../lib/gis/parser.c:2493
+#: ../lib/gis/parser.c:2496
 #, c-format
 msgid ""
 "\n"
@@ -3238,12 +3167,12 @@
 "\n"
 "FEHLER: Option <%s> muss als Vielfaches von %d angegeben werden\n"
-#: ../lib/gis/parser.c:2495
+#: ../lib/gis/parser.c:2498
 #, c-format
 msgid "       You provided %d items:\n"
 msgstr "       Sie haben %d Punkte angegeben:\n"
-#: ../lib/gis/parser.c:2553
+#: ../lib/gis/parser.c:2556
 #, c-format
 msgid "ERROR: option <%s>: <%s> exists.\n"
 msgstr "FEHLER: Option <%s>: <%s> existiert bereits.\n"
@@ -3661,17 +3590,20 @@
 " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
 "derzeitigen GRASS-Fenster."
-#: ../lib/gis/alloc.c:45
-msgid "G_malloc: out of memory"
-msgstr "G_malloc: Kein Speicher mehr da."
+#: ../lib/gis/alloc.c:43
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+msgstr ""
-#: ../lib/gis/alloc.c:79
-msgid "G_calloc: out of memory"
-msgstr "G_calloc: Kein Speicher mehr da."
+#: ../lib/gis/alloc.c:76
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+msgstr ""
-#: ../lib/gis/alloc.c:117
-msgid "G_realloc: out of memory"
-msgstr "G_realloc: Kein Speicher mehr da."
+#: ../lib/gis/alloc.c:114
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+msgstr ""
 #: ../lib/gis/histogram.c:57
 #, c-format
@@ -3693,6 +3625,51 @@
 msgid "can't create histogram for [%s in %s]"
 msgstr "Kann kein Histogramm für [%s in %s] erstellen."
+#: ../lib/sites/sites.c:97
+#, fuzzy, c-format
+msgid "Attributes for category %d not found"
+msgstr "Datenbank-Eintrag für die Kategorie (cat) %d  nicht gefunden."
+#: ../lib/sites/sites.c:136
+msgid "Category must be integer"
+msgstr ""
+#: ../lib/sites/sites.c:210
+msgid "Memory error in writing timestamp"
+msgstr ""
+#: ../lib/sites/sites.c:212
+msgid "Illegal TimeStamp string"
+msgstr ""
+#: ../lib/sites/sites.c:241
+msgid "Memory error in allocating timestamp"
+msgstr ""
+#: ../lib/sites/sites.c:296 ../lib/sites/sites.c:424
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
+msgstr ""
+#: ../lib/sites/sites.c:320 ../lib/sites/sites.c:1195
+#, fuzzy, c-format
+msgid "Cannot open database %s by driver %s"
+msgstr "Kann Datenbank '%s' nicht öffnen."
+#: ../lib/sites/sites.c:328 ../lib/sites/sites.c:1203
+msgid "Cannot select attributes"
+msgstr ""
+#: ../lib/sites/sites.c:343
+#, fuzzy
+msgid "Cannot fetch row"
+msgstr "Kann die Layer-Informationen nicht abfragen."
+#: ../lib/sites/sites.c:525
+msgid "G_oldsite_new_struct: invalid # dims or fields"
+msgstr ""
 #: ../lib/imagery/fopen.c:23
 #, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
@@ -3773,6 +3750,7 @@
 msgstr "Lese Rasterkarte <%s> in den Speicher."
 #: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
+#: ../lib/manage/do_remove.c:58 ../lib/manage/do_rename.c:58
 #, fuzzy, c-format
 msgid "3D raster map <%s> not found"
@@ -4514,7 +4492,106 @@
 msgid "Unable to define new light"
+#: ../lib/manage/do_remove.c:22
+#, fuzzy, c-format
+msgid "Removing %s <%s>"
+msgstr "Kann [%s] nicht finden."
+#: ../lib/manage/do_remove.c:45 ../lib/manage/do_remove.c:87
+msgid "couldn't be removed"
+msgstr ""
+#: ../lib/manage/do_remove.c:65 ../lib/manage/do_rename.c:65
+#, c-format
+msgid "%s: couldn't be removed"
+msgstr ""
+#: ../lib/manage/do_remove.c:70 ../lib/manage/do_remove.c:92
+#: ../lib/manage/do_rename.c:70 ../lib/manage/do_rename.c:92
+#: ../lib/manage/do_copy.c:41
+#, fuzzy, c-format
+msgid "%s: missing"
+msgstr "welche fehlt"
+#: ../lib/manage/do_remove.c:74 ../lib/manage/do_remove.c:96
+#, c-format
+msgid "%s: removed"
+msgstr ""
+#: ../lib/manage/do_remove.c:105
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
+#: ../lib/manage/read_list.c:108
+#, c-format
+msgid ""
+"Format error: <%s>\n"
+"Line: %d\n"
+"%s"
+msgstr ""
+#: ../lib/manage/do_rename.c:25
+#, c-format
+msgid "Rename %s <%s> to <%s>\n"
+msgstr ""
+#: ../lib/manage/do_rename.c:45
+#, fuzzy, c-format
+msgid "Cannot rename <%s> to <%s>"
+#: ../lib/manage/do_rename.c:74 ../lib/manage/do_rename.c:96
+#, c-format
+msgid "%s: renamed"
+msgstr ""
+#: ../lib/manage/do_rename.c:87
+#, c-format
+msgid "%s: couldn't be renamed"
+msgstr ""
+#: ../lib/manage/do_rename.c:105
+#, c-format
+msgid "<%s> nothing renamed"
+msgstr ""
+#: ../lib/manage/do_copy.c:20
+#, fuzzy, c-format
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr "Keine %s Dateien im aktuellen Mapset vorhanden\n"
+#: ../lib/manage/do_copy.c:51
+#, c-format
+msgid "%s: copied"
+msgstr ""
 #, fuzzy
+msgid "Registering points"
+msgstr "Registriere Linien..."
+#, fuzzy
+msgid "Registered points"
+#, fuzzy
+msgid "Registered points (unique coordinates)"
+#, fuzzy
+msgid "Duplicates"
+msgstr "Doppeltes Ost-Feld"
+msgid "G_malloc: out of memory"
+msgstr "G_malloc: Kein Speicher mehr da."
+msgid "G_calloc: out of memory"
+msgstr "G_calloc: Kein Speicher mehr da."
+msgid "G_realloc: out of memory"
+msgstr "G_realloc: Kein Speicher mehr da."
+#, fuzzy
 msgid "Cannot describe table <%s>"
 msgstr "Kann Tabelle <%s> nicht beschreiben"
@@ -4884,10 +4961,6 @@
 "%d Inselflächen erstellt\n"
 #, fuzzy
-msgid "Cannot open database <%s> by driver <%s>"
-msgstr "Kann Datenbank '%s' nicht öffnen."
-#, fuzzy
 msgid "Cannot get column info"
@@ -4912,10 +4985,6 @@
 msgstr "Kann temporäre Datei nicht öffnen."
 #, fuzzy
-msgid "Cannot delete line"
-msgstr "Kann temporäre Datei nicht öffnen."
-#, fuzzy
 msgid "Output name '%s' is not valid vector name."
 msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2008-11-18 10:35:56 UTC (rev 34354)
+++ grass/trunk/locale/po/grassmods_de.po	2008-11-18 10:45:30 UTC (rev 34355)
@@ -10,8 +10,8 @@
 msgstr ""
 "Project-Id-Version: grassmods_de\n"
-"PO-Revision-Date: 2008-11-03 22:31+0100\n"
+"PO-Revision-Date: 2008-11-18 11:05+0100\n"
 "Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
@@ -24,8 +24,8 @@
 #: ../db/base/tables.c:46 ../db/base/droptable.c:44 ../db/base/select.c:62
 #: ../db/base/columns.c:45 ../db/base/describe.c:52 ../db/base/databases.c:52
 #: ../display/d.vect/main.c:448 ../display/d.thematic.area/main.c:198
-#: ../doc/vector/v.example/main.c:123 ../vector/v.db.connect/main.c:183
-#: ../vector/v.db.connect/main.c:249 ../vector/v.edit/select.c:513
+#: ../doc/vector/v.example/main.c:123 ../vector/v.db.connect/main.c:184
+#: ../vector/v.db.connect/main.c:250 ../vector/v.edit/select.c:513
 #: ../vector/v.in.sites/main.c:158 ../vector/v.out.svg/main.c:136
 #: ../vector/v.out.ogr/main.c:317 ../vector/v.extract/main.c:273
 #, c-format
@@ -62,7 +62,7 @@
 #: ../db/base/execute.c:150
 msgid "Use db.select for SELECT SQL statements"
-msgstr ""
+msgstr "Verwenden Sie db.select für SELECT SQL Ausdrücke."
 #: ../db/base/createdb.c:71 ../db/base/dropdb.c:71 ../db/base/droptable.c:78
 #: ../db/base/databases.c:90 ../db/db.login/main.c:43
@@ -154,8 +154,8 @@
 #: ../db/base/tables.c:95 ../db/base/drivers.c:74 ../db/base/columns.c:92
 #: ../db/base/describe.c:125 ../db/base/connect.c:45
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
 #: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
 #: ../locale/scriptstrings/db.test_to_translate.c:2
@@ -195,7 +195,7 @@
 msgstr "Beispiel: 'select * from wald where baum = 'Buche'"
 #: ../db/base/select.c:195 ../locale/scriptstrings/r.tileset_to_translate.c:13
-#: ../raster/r.distance/parse.c:47 ../raster/r.stats/main.c:107
+#: ../raster/r.distance/parse.c:47 ../raster/r.stats/main.c:120
 #: ../raster/r.category/main.c:72 ../vector/v.db.select/main.c:62
 msgid "Output field separator"
 msgstr "Ausgabe Feld-Trennzeichen"
@@ -237,7 +237,7 @@
 msgstr "Listet alle Spalten einer Tabelle."
 #: ../db/base/describe.c:63 ../doc/vector/v.example/main.c:134
-#: ../vector/v.db.connect/main.c:194 ../vector/v.in.ascii/main.c:402
+#: ../vector/v.db.connect/main.c:195 ../vector/v.in.ascii/main.c:402
 #: ../vector/v.patch/main.c:139 ../vector/v.patch/main.c:177
 #: ../vector/v.random/main.c:199 ../vector/v.out.svg/main.c:149
 #: ../vector/v.out.ogr/main.c:327
@@ -367,7 +367,7 @@
 #: ../db/drivers/sqlite/describe.c:159
 #, fuzzy, c-format
 msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
-msgstr "SQLite Treiber: Spalte '%s', SQLite Type %d wird nicht unterstützt."
+msgstr "SQLite Treiber: Spalte <%s>, SQLite Typ %d wird nicht unterstützt."
 #: ../db/drivers/mysql/listtab.c:36
 msgid "Cannot get list of tables:\n"
@@ -416,7 +416,7 @@
 "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
 "damaged"
 msgstr ""
-"Spalte '%s': Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
+"Spalte <%s> : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
 "Datensätze könnten beschädigt sein."
 #: ../db/drivers/mysql/db.c:64
@@ -488,8 +488,8 @@
 "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
 "may be damaged"
 msgstr ""
-"Spalte '%s' vom Typ int8 (bigint) wird als integer (4 bytes) abgespeichert. "
-"Einige Daten können u.U. verloren sein."
+"Spalte <%s> : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. "
+"Einige Datensätze könnten beschädigt sein."
 #: ../db/drivers/postgres/describe.c:120
 #, fuzzy, c-format
@@ -497,8 +497,8 @@
 "column '%s' : type character varying is stored as varchar(250) some data may "
 "be lost"
 msgstr ""
-"Spalte '%s' vom Typ 'character' ist als Typ varchar(250) abgespeichert. "
-"Einige Daten könnten verloren sein."
+"Spalte <%s> : Typ 'character' wird als Typ varchar(250) abgespeichert. "
+"Einige Daten könnten verloren gehen."
 #: ../db/drivers/postgres/describe.c:126
 #, fuzzy, c-format
@@ -506,8 +506,8 @@
 "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
 "(true)"
 msgstr ""
-"Spalte '%s' vom Typ bool (boolean) ist als Typ char(1) abgespeichert. Werte: "
-"0 (falsch), 1 (wahr)"
+"Spalte <%s> : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 "
+"(falsch), 1 (wahr) abgespeichert."
 #: ../db/drivers/postgres/fetch.c:172
 msgid "Cannot recognize boolean value"
@@ -524,8 +524,8 @@
 "column '%s', type 'string': unknown width -> stored as varchar(250) some "
 "data may be lost"
 msgstr ""
-"Spalte '%s' mit Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
-"abgespeichert. Einige Daten könnten verloren sein."
+"Spalte <%s>, Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
+"abgespeichert. Einige Daten könnten verloren gehen."
 #: ../db/drivers/ogr/describe.c:161 ../db/drivers/ogr/fetch.c:129
 msgid "Unknown type"
@@ -537,13 +537,14 @@
 #: ../display/d.colors/main.c:41 ../display/d.what.vect/main.c:57
 #: ../display/d.font/main.c:46 ../display/d.rast.num/main.c:70
 #: ../display/d.linegraph/main.c:120 ../display/d.colorlist/main.c:35
-#: ../display/d.what.rast/main.c:42 ../display/d.title/main.c:49
+#: ../display/d.what.rast/main.c:49 ../display/d.title/main.c:49
 #: ../display/d.geodesic/main.c:44 ../display/d.labels/main.c:44
 #: ../display/d.info/main.c:32 ../display/d.rast.arrow/main.c:92
 #: ../display/d.thematic.area/main.c:76 ../display/d.extract/main.c:50
 #: ../display/d.rgb/main.c:52 ../display/d.where/main.c:44
 #: ../display/d.his/main.c:62 ../display/d.zoom/main.c:62
 #: ../display/d.rhumbline/main.c:44 ../display/d.nviz/main.c:68
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
 #: ../visualization/ximgview/main.c:289
 msgid "display"
 msgstr "Darstellung"
@@ -567,7 +568,7 @@
 #: ../display/d.profile/main.c:262 ../display/d.measure/main.c:85
 #: ../display/d.what.vect/main.c:143 ../display/d.font/main.c:86
 #: ../display/d.rast.num/main.c:159 ../display/d.linegraph/main.c:258
-#: ../display/d.what.rast/main.c:89 ../display/d.geodesic/main.c:96
+#: ../display/d.what.rast/main.c:96 ../display/d.geodesic/main.c:96
 #: ../display/d.labels/main.c:117 ../display/d.info/main.c:68
 #: ../display/d.legend/main.c:262 ../display/d.graph/main.c:99
 #: ../display/d.vect/main.c:358 ../display/d.vect.chart/main.c:252
@@ -578,8 +579,7 @@
 #: ../display/d.zoom/main.c:217 ../display/d.zoom/redraw.c:39
 #: ../display/d.grid/main.c:186 ../display/d.rhumbline/main.c:96
 #: ../display/d.colortable/main.c:136 ../display/d.path/main.c:152
-#: ../imagery/i.class/main.c:128 ../imagery/i.points/main.c:80
-#: ../imagery/i.ortho.photo/photo.2target/main.c:90
+#: ../imagery/i.class/main.c:128 ../imagery/i.points/main.c:123
 #: ../vector/v.label/main.c:233
 msgid "No graphics device selected"
 msgstr "Keine Graphik-Ausgabe ausgewählt."
@@ -826,17 +826,17 @@
 #: ../display/d.nviz/main.c:182 ../doc/raster/r.example/main.c:118
 #: ../imagery/i.his.rgb/openfiles.c:33 ../imagery/i.his.rgb/openfiles.c:38
 #: ../imagery/i.his.rgb/openfiles.c:43 ../imagery/i.smap/shapiro/opencell.c:16
-#: ../imagery/i.pca/main.c:126 ../imagery/i.vi/main.c:158
-#: ../imagery/i.vi/main.c:162 ../imagery/i.vi/main.c:167
-#: ../imagery/i.vi/main.c:173 ../imagery/i.vi/main.c:179
-#: ../imagery/i.vi/main.c:185 ../imagery/i.albedo/main.c:156
+#: ../imagery/i.pca/main.c:126 ../imagery/i.vi/main.c:210
+#: ../imagery/i.vi/main.c:215 ../imagery/i.vi/main.c:221
+#: ../imagery/i.vi/main.c:227 ../imagery/i.vi/main.c:233
+#: ../imagery/i.vi/main.c:239 ../imagery/i.albedo/main.c:156
 #: ../raster/r.resamp.stats/main.c:329 ../raster/r.surf.area/main.c:118
 #: ../raster/r.resamp.interp/main.c:138 ../raster/r.los/main.c:200
 #: ../raster/r.los/main.c:211 ../raster/r.out.ascii/main.c:146
 #: ../raster/r.carve/main.c:164 ../raster/r.profile/main.c:132
 #: ../raster/r.texture/main.c:211 ../raster/r.sum/main.c:60
-#: ../raster/r.null/main.c:298 ../raster/r.lake/main.c:242
-#: ../raster/r.lake/main.c:248 ../raster/r.out.gdal/main.c:104
+#: ../raster/r.null/main.c:318 ../raster/r.lake/main.c:242
+#: ../raster/r.lake/main.c:248 ../raster/r.out.gdal/export_band.c:44
 #: ../raster/r.surf.idw2/read_cell.c:27 ../raster/r.out.mat/main.c:86
 #: ../raster/r.to.rast3elev/main.c:118 ../raster/r.uslek/main.c:88
 #: ../raster/r.uslek/main.c:92 ../raster/r.uslek/main.c:96
@@ -844,18 +844,19 @@
 #: ../raster/r.thin/io.c:95 ../raster/r.out.pov/main.c:174
 #: ../raster/r.covar/main.c:80 ../raster/r.out.arc/main.c:113
 #: ../raster/r.random/count.c:24 ../raster/r.random/count.c:29
-#: ../raster/r.sunmask/main.c:454 ../raster/r.quantile/main.c:282
+#: ../raster/r.sunmask/main.c:454 ../raster/r.quantile/main.c:300
 #: ../raster/r.his/main.c:126 ../raster/r.his/main.c:147
 #: ../raster/r.his/main.c:166 ../raster/r.univar/r.univar_main.c:145
 #: ../raster/r.resamp.rst/main.c:373 ../raster/r.resamp.rst/main.c:397
-#: ../raster/r.out.ppm/main.c:99 ../raster/r.cost/main.c:330
+#: ../raster/r.colors/stats.c:33 ../raster/r.out.ppm/main.c:99
+#: ../raster/r.usler/main.c:82 ../raster/r.cost/main.c:330
 #: ../raster/r.out.vtk/main.c:127 ../raster/r.out.vtk/main.c:190
 #: ../raster/r.out.vtk/main.c:215 ../raster/r.out.vtk/main.c:258
 #: ../raster/r.support/main.c:284 ../raster/r.out.bin/main.c:127
-#: ../raster/r.neighbors/main.c:190 ../raster/r.clump/main.c:72
+#: ../raster/r.neighbors/main.c:193 ../raster/r.clump/main.c:72
 #: ../raster/r.to.vect/main.c:122 ../raster/r.out.ppm3/main.c:103
-#: ../raster/r.contour/main.c:136 ../raster/r.cross/main.c:101
-#: ../raster/r.series/main.c:169 ../raster/r.out.tiff/main.c:161
+#: ../raster/r.contour/main.c:136 ../raster/r.cross/main.c:112
+#: ../raster/r.series/main.c:181 ../raster/r.out.tiff/main.c:161
 #: ../raster/r.walk/main.c:528 ../raster/r.walk/main.c:531
 #: ../raster/r.walk/main.c:831 ../raster/r.mapcalc/map3.c:510
 #: ../raster/r.composite/main.c:156 ../raster/wildfire/r.ros/main.c:471
@@ -871,12 +872,12 @@
 #: ../raster/wildfire/r.spread/main.c:403
 #: ../raster/wildfire/r.spread/main.c:472 ../raster/r.buffer/read_map.c:42
 #: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:100
-#: ../raster/r.to.rast3/main.c:351 ../raster/r.grow.distance/main.c:154
+#: ../raster/r.to.rast3/main.c:351 ../raster/r.grow.distance/main.c:157
 #: ../raster/r.grow/main.c:198 ../raster/r.category/main.c:150
-#: ../vector/v.what.rast/main.c:134 ../vector/v.extrude/main.c:175
+#: ../vector/v.what.rast/main.c:134 ../vector/v.extrude/main.c:176
 #: ../vector/v.sample/main.c:149 ../vector/v.vol.rst/main.c:636
 #: ../vector/v.to.rast/support.c:262 ../vector/v.to.rast/support.c:418
-#: ../vector/v.drape/main.c:127 ../visualization/xganim/main.c:387
+#: ../vector/v.drape/main.c:127
 #, c-format
 msgid "Unable to open raster map <%s>"
 msgstr "Kann die Rasterkarte <%s> nicht öffnen."
@@ -920,7 +921,7 @@
 msgstr "Warnung: Vektorkarte '%s' wurde nicht gefunden.\n"
 #: ../display/d.what.vect/what.c:147 ../display/d.what.vect/what.c:149
-#: ../vector/v.what/what.c:87 ../vector/v.what/what.c:89
+#: ../vector/v.what/what.c:176 ../vector/v.what/what.c:178
 #, c-format
 msgid "Nothing Found.\n"
 msgstr "Nichts gefunden.\n"
@@ -930,8 +931,8 @@
 msgid "Line: %d  Type: %s  Left: %d  Right: %d  "
 msgstr "Linie: %d  Typ: %s  Links: %d  Right %d  "
-#: ../display/d.what.vect/what.c:209 ../vector/v.what/what.c:136
-#: ../vector/v.what/what.c:170
+#: ../display/d.what.vect/what.c:209 ../vector/v.what/what.c:225
+#: ../vector/v.what/what.c:259
 #, c-format
 msgid "Length: %f\n"
 msgstr "Länge: %f\n"
@@ -951,12 +952,12 @@
 msgid "length %f\n"
-#: ../display/d.what.vect/what.c:263 ../vector/v.what/what.c:179
+#: ../display/d.what.vect/what.c:263 ../vector/v.what/what.c:268
 #, c-format
 msgid "Point height: %f\n"
 msgstr "Punkthöhe: %f\n"
-#: ../display/d.what.vect/what.c:281 ../vector/v.what/what.c:190
+#: ../display/d.what.vect/what.c:281 ../vector/v.what/what.c:279
 #, c-format
 msgid "Line height: %f\n"
 msgstr "Länge der Linie: %f\n"
@@ -1011,7 +1012,7 @@
 "Kategorie: %d\n"
 #: ../display/d.what.vect/what.c:399 ../display/d.vect/main.c:444
-#: ../display/d.thematic.area/main.c:194 ../vector/v.db.connect/main.c:151
+#: ../display/d.thematic.area/main.c:194 ../vector/v.db.connect/main.c:152
 #, c-format
 msgid "Database connection not defined"
 msgstr "Datenbankverbindung nicht definiert."
@@ -1063,7 +1064,7 @@
 "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
 "aktuellen Region."
-#: ../display/d.what.vect/main.c:66 ../display/d.what.rast/main.c:70
+#: ../display/d.what.vect/main.c:66 ../display/d.what.rast/main.c:77
 msgid "Identify just one location"
 msgstr "Nur einmal abfragen"
@@ -1072,7 +1073,7 @@
 msgid "Name of existing vector map"
 msgstr "Name einer existierenden Vektorkarte."
-#: ../display/d.what.vect/main.c:79 ../display/d.what.rast/main.c:74
+#: ../display/d.what.vect/main.c:79 ../display/d.what.rast/main.c:81
 msgid "Terse output. For parsing by programs"
 msgstr "Knappe Ausgabe zum Einlesen (parsing) durch Programme."
@@ -1103,9 +1104,9 @@
 msgstr "Kann die Vektorkarte <%s> nicht öffnen."
 #: ../display/d.what.vect/main.c:131 ../display/d.extract/main.c:98
-#: ../doc/vector/v.example/main.c:73 ../general/g.region/main.c:487
-#: ../general/g.mremove/do_remove.c:33 ../raster/r.carve/main.c:155
-#: ../raster/r.cost/main.c:296 ../vector/v.edit/main.c:126
+#: ../doc/vector/v.example/main.c:73 ../general/g.region/main.c:494
+#: ../raster/r.carve/main.c:155 ../raster/r.cost/main.c:296
+#: ../vector/v.edit/main.c:126
 #: ../vector/lidar/v.lidar.edgedetection/main.c:171
 #: ../vector/lidar/v.lidar.correction/main.c:148
 #: ../vector/lidar/v.outlier/main.c:145
@@ -1304,39 +1305,36 @@
 msgid "Problem reading <%s> data file at line %d"
 msgstr "Problem beim Lesen von <%s> Datei in der Zeile %d."
-#: ../display/d.what.rast/opencell.c:13 ../display/d.what.rast/main.c:109
+#: ../display/d.what.rast/opencell.c:13 ../display/d.what.rast/main.c:116
 #: ../display/d.nviz/main.c:180 ../doc/raster/r.example/main.c:111
-#: ../general/g.region/main.c:436 ../general/g.region/main.c:762
-#: ../general/g.region/main.c:770 ../general/g.mremove/do_remove.c:49
-#: ../imagery/i.his.rgb/openfiles.c:31 ../imagery/i.his.rgb/openfiles.c:36
-#: ../imagery/i.his.rgb/openfiles.c:41 ../imagery/i.group/main.c:205
-#: ../imagery/i.group/main.c:244 ../imagery/i.rgb.his/openfiles.c:14
-#: ../imagery/i.rgb.his/openfiles.c:16 ../imagery/i.rgb.his/openfiles.c:18
-#: ../imagery/i.pca/main.c:123 ../imagery/i.class/main.c:165
-#: ../imagery/i.gensig/parse.c:48 ../imagery/i.zc/main.c:104
-#: ../imagery/i.fft/main.c:118
-#: ../imagery/i.ortho.photo/photo.2target/main.c:203
-#: ../imagery/i.ortho.photo/photo.2target/main.c:233 ../ps/ps.map/outl_io.c:68
+#: ../general/g.region/main.c:443 ../general/g.region/main.c:769
+#: ../general/g.region/main.c:777 ../imagery/i.his.rgb/openfiles.c:31
+#: ../imagery/i.his.rgb/openfiles.c:36 ../imagery/i.his.rgb/openfiles.c:41
+#: ../imagery/i.group/main.c:205 ../imagery/i.group/main.c:244
+#: ../imagery/i.rgb.his/openfiles.c:14 ../imagery/i.rgb.his/openfiles.c:16
+#: ../imagery/i.rgb.his/openfiles.c:18 ../imagery/i.pca/main.c:123
+#: ../imagery/i.class/main.c:165 ../imagery/i.gensig/parse.c:48
+#: ../imagery/i.zc/main.c:104 ../ps/ps.map/outl_io.c:68
 #: ../raster/r.resamp.stats/main.c:296 ../raster/r.param.scale/interface.c:172
-#: ../raster/r.resamp.interp/main.c:103 ../raster/r.coin/cmd_parms.c:80
-#: ../raster/r.coin/cmd_parms.c:83 ../raster/r.distance/parse.c:64
+#: ../raster/r.resamp.interp/main.c:103 ../raster/r.coin/main.c:125
+#: ../raster/r.coin/main.c:127 ../raster/r.distance/parse.c:64
 #: ../raster/r.distance/parse.c:71 ../raster/r.reclass/main.c:78
 #: ../raster/r.los/main.c:168 ../raster/r.los/main.c:174
-#: ../raster/r.carve/main.c:161 ../raster/r.null/main.c:105
-#: ../raster/r.out.gridatb/check_ready.c:12 ../raster/simwe/simlib/input.c:180
-#: ../raster/simwe/simlib/input.c:186 ../raster/simwe/simlib/input.c:191
-#: ../raster/simwe/simlib/input.c:200 ../raster/simwe/simlib/input.c:208
-#: ../raster/simwe/simlib/input.c:214 ../raster/simwe/simlib/input.c:220
-#: ../raster/simwe/simlib/input.c:227 ../raster/simwe/simlib/input.c:234
-#: ../raster/simwe/simlib/input.c:241 ../raster/simwe/simlib/input.c:248
+#: ../raster/r.carve/main.c:161 ../raster/r.null/main.c:113
+#: ../raster/r.out.gridatb/check_ready.c:12 ../raster/simwe/simlib/input.c:178
+#: ../raster/simwe/simlib/input.c:184 ../raster/simwe/simlib/input.c:189
+#: ../raster/simwe/simlib/input.c:198 ../raster/simwe/simlib/input.c:206
+#: ../raster/simwe/simlib/input.c:212 ../raster/simwe/simlib/input.c:218
+#: ../raster/simwe/simlib/input.c:225 ../raster/simwe/simlib/input.c:232
+#: ../raster/simwe/simlib/input.c:239 ../raster/simwe/simlib/input.c:246
 #: ../raster/r.info/main.c:118 ../raster/r.flow/io.c:63
 #: ../raster/r.report/parse.c:243 ../raster/r.kappa/stats.c:30
-#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:126
+#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:141
 #: ../raster/r.slope.aspect/main.c:368 ../raster/r.colors/main.c:257
 #: ../raster/r.colors/main.c:332 ../raster/r.fill.dir/main.c:172
 #: ../raster/r.cost/main.c:317 ../raster/r.to.vect/main.c:119
 #: ../raster/r.watershed/ram/init_vars.c:376
-#: ../raster/r.watershed/seg/init_vars.c:404 ../raster/r.cross/main.c:97
+#: ../raster/r.watershed/seg/init_vars.c:404 ../raster/r.cross/main.c:108
 #: ../raster/r.water.outlet/legal.c:11 ../raster/r.out.mpeg/main.c:286
 #: ../raster/r.mapcalc/map.c:377 ../raster/wildfire/r.ros/main.c:322
 #: ../raster/wildfire/r.ros/main.c:335 ../raster/wildfire/r.ros/main.c:340
@@ -1348,12 +1346,12 @@
 #: ../raster/wildfire/r.spread/main.c:363
 #: ../raster/wildfire/r.spread/main.c:367
 #: ../raster/wildfire/r.spread/main.c:370
-#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.buffer/main.c:100
+#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.buffer/main.c:110
 #: ../raster/r.category/main.c:125 ../raster/r.category/main.c:146
 #: ../raster3d/base/r3.info.main.c:121
 #: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../vector/v.vol.rst/main.c:633 ../vector/v.drape/main.c:122
-#: ../visualization/xganim/main.c:383 ../visualization/nviz2/cmd/surface.c:56
+#: ../visualization/nviz2/cmd/surface.c:56
 #: ../visualization/nviz2/cmd/surface.c:106
 #, c-format
@@ -1363,7 +1361,7 @@
 msgid "You are clicking outside the map"
 msgstr "Sie klicken außerhalb der Karte."
-#: ../display/d.what.rast/main.c:44
+#: ../display/d.what.rast/main.c:51
 msgid ""
 "Allows the user to interactively query the category contents of multiple "
 "raster map layers at user specified locations within the current geographic "
@@ -1372,15 +1370,15 @@
 "Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an "
 "einem angeklickten Punkt in der aktuellen Region abzufragen."
-#: ../display/d.what.rast/main.c:57 ../raster/r.compress/main.c:70
+#: ../display/d.what.rast/main.c:64 ../raster/r.compress/main.c:70
 msgid "Name of existing raster map(s)"
 msgstr "Name existierender Rasterkarte(n)"
-#: ../display/d.what.rast/main.c:65
+#: ../display/d.what.rast/main.c:72
 msgid "Field separator (terse mode only)"
 msgstr "Feld-Trennzeichen"
-#: ../display/d.what.rast/main.c:79
+#: ../display/d.what.rast/main.c:86
 msgid "Print out col/row for the entire map in grid resolution of the region"
 msgstr ""
 "Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der "
@@ -1420,11 +1418,12 @@
 msgid "No map name given"
 msgstr "Keine Karte angegeben."
-#: ../display/d.title/main.c:107 ../imagery/i.rectify/main.c:165
-#: ../imagery/i.rectify/main.c:171 ../imagery/i.albedo/main.c:159
-#: ../raster/r.texture/main.c:217 ../raster/r.region/main.c:156
-#: ../raster/r.region/main.c:200 ../raster/r.region/main.c:314
-#: ../raster/r.out.tiff/main.c:142 ../raster/r.bitpattern/main.c:106
+#: ../display/d.title/main.c:107 ../imagery/i.rectify/main.c:193
+#: ../imagery/i.rectify/main.c:199 ../imagery/i.albedo/main.c:159
+#: ../raster/r.texture/main.c:217 ../raster/r.null/main.c:157
+#: ../raster/r.region/main.c:156 ../raster/r.region/main.c:200
+#: ../raster/r.region/main.c:314 ../raster/r.out.tiff/main.c:142
+#: ../raster/r.bitpattern/main.c:106
 #, c-format
 msgid "Unable to read header of raster map <%s>"
 msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
@@ -1558,9 +1557,7 @@
 msgstr "Stelle das Screen-Rechteck der aktuellen Region dar."
 #: ../display/d.info/main.c:56
-msgid ""
-"Display screen rectangle coordinates and resolution (west, east, north, "
-"south, ewres, nsres)"
+msgid "Display geographic coordinates and resolution of entire screen"
 msgstr ""
 #: ../display/d.legend/main.c:84 ../display/d.graph/main.c:57
@@ -1577,6 +1574,7 @@
 "Zeichnet eine Legende für eine Rasterkarte in dem aktiven Grafik-Fenster."
 #: ../display/d.legend/main.c:90 ../display/d.zoom/main.c:76
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
 msgid "Name of raster map"
 msgstr "Name der Rasterkarte"
@@ -1647,6 +1645,7 @@
 msgstr "Zeichne geglätteten Gradient"
 #: ../display/d.legend/main.c:178
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
 msgid "Flip legend"
 msgstr "Drehe Legende."
@@ -1662,10 +1661,9 @@
 "werden."
 #: ../display/d.legend/main.c:311
-#, fuzzy
 msgid "Drawing horizontal legend as box width exceeds height"
 msgstr ""
-"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet.\n"
+"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
 #: ../display/d.legend/main.c:322
 #, c-format
@@ -1774,7 +1772,7 @@
 #: ../display/d.vect/plot1.c:111 ../display/d.vect/area.c:59
 #: ../display/d.vect/attr.c:44 ../display/d.thematic.area/plot1.c:110
-#: ../vector/v.in.ogr/main.c:759 ../vector/v.surf.rst/main.c:544
+#: ../vector/v.in.ogr/main.c:753 ../vector/v.surf.rst/main.c:544
 #, c-format
 msgstr "Kann Datenbank '%s' mit Treiber '%s' nicht öffnen."
@@ -1879,8 +1877,8 @@
 #: ../vector/v.edit/args.c:132 ../vector/v.edit/args.c:141
 #: ../vector/v.edit/args.c:150 ../vector/v.edit/args.c:159
 #: ../vector/v.edit/args.c:162 ../vector/v.edit/args.c:176
-#: ../vector/v.in.ogr/main.c:130 ../vector/v.in.ogr/main.c:144
-#: ../vector/v.in.ogr/main.c:166
+#: ../vector/v.in.ogr/main.c:129 ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:165
 msgid "Query"
 msgstr "Abfrage"
@@ -2515,7 +2513,7 @@
 #: ../display/d.where/main.c:56
 #, fuzzy
 msgid "Display coordinates to convert"
-msgstr "Keine Koordinaten angegeben."
+msgstr "Name des Grafik-Fensters, das gestartet werden soll."
 #: ../display/d.where/main.c:61
 #, fuzzy
@@ -2552,26 +2550,30 @@
 msgstr ""
 "Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
-#: ../display/d.where/main.c:105 ../general/g.region/printwindow.c:243
-#: ../general/g.region/printwindow.c:487
+#: ../display/d.where/main.c:105 ../general/g.region/printwindow.c:248
+#: ../general/g.region/printwindow.c:489 ../general/g.region/printwindow.c:608
+#: ../imagery/i.latlong/main.c:100
 msgid "Can't get projection info of current location"
 msgstr ""
 "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
-#: ../display/d.where/main.c:108 ../general/g.region/printwindow.c:246
-#: ../general/g.region/printwindow.c:490 ../raster/r.sun/main.c:468
+#: ../display/d.where/main.c:108 ../general/g.region/printwindow.c:251
+#: ../general/g.region/printwindow.c:492 ../general/g.region/printwindow.c:611
+#: ../imagery/i.latlong/main.c:102 ../raster/r.sun/main.c:468
 msgid "Can't get projection units of current location"
 msgstr "Kann die Projektionseinheit der aktuellen Location nicht ermitteln."
 #: ../display/d.where/main.c:111 ../display/d.grid/plot.c:289
-#: ../general/g.region/printwindow.c:249 ../general/g.region/printwindow.c:493
+#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:495
+#: ../general/g.region/printwindow.c:614 ../imagery/i.latlong/main.c:104
 #: ../ps/ps.map/do_geogrid.c:272 ../raster/r.sun/main.c:472
 msgid "Can't get projection key values of current location"
 msgstr "Kann die Projektionsinformationen der aktuellen Location nicht holen."
 #: ../display/d.where/main.c:118 ../display/d.where/main.c:144
 #: ../display/d.grid/plot.c:296 ../display/d.grid/plot.c:323
-#: ../ps/ps.map/do_geogrid.c:278 ../raster/r.sun/main.c:482
+#: ../imagery/i.latlong/main.c:113 ../ps/ps.map/do_geogrid.c:278
+#: ../raster/r.sun/main.c:482
 msgid "Unable to set up lat/long projection parameters"
 msgstr "Kann LL-Projektionsparameter nicht einrichten."
@@ -2789,14 +2791,15 @@
 #: ../display/d.grid/plot.c:239 ../display/d.grid/plot.c:245
 #: ../display/d.grid/plot.c:374 ../display/d.grid/plot.c:390
 #: ../display/d.grid/plot.c:407 ../display/d.grid/plot.c:424
-#: ../ps/ps.map/do_geogrid.c:87 ../ps/ps.map/do_geogrid.c:92
-#: ../ps/ps.map/do_geogrid.c:116 ../ps/ps.map/do_geogrid.c:121
-#: ../ps/ps.map/do_geogrid.c:191 ../ps/ps.map/do_geogrid.c:230
-#: ../ps/ps.map/do_geogrid.c:306 ../ps/ps.map/do_geogrid.c:322
-#: ../ps/ps.map/do_geogrid.c:339 ../ps/ps.map/do_geogrid.c:356
-#: ../ps/ps.map/do_geogrid.c:409 ../ps/ps.map/do_geogrid.c:415
-#: ../ps/ps.map/do_geogrid.c:419 ../ps/ps.map/do_geogrid.c:427
-#: ../ps/ps.map/do_geogrid.c:431 ../raster/r.sun/main.c:1314
+#: ../imagery/i.latlong/main.c:134 ../ps/ps.map/do_geogrid.c:87
+#: ../ps/ps.map/do_geogrid.c:92 ../ps/ps.map/do_geogrid.c:116
+#: ../ps/ps.map/do_geogrid.c:121 ../ps/ps.map/do_geogrid.c:191
+#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
+#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
+#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:409
+#: ../ps/ps.map/do_geogrid.c:415 ../ps/ps.map/do_geogrid.c:419
+#: ../ps/ps.map/do_geogrid.c:427 ../ps/ps.map/do_geogrid.c:431
+#: ../raster/r.sun/main.c:1314
 msgid "Error in pj_do_proj"
 msgstr "Error in pj_do_proj"
@@ -3177,27 +3180,28 @@
 #: ../doc/raster/r.example/main.c:137 ../imagery/i.his.rgb/openfiles.c:15
 #: ../imagery/i.his.rgb/openfiles.c:17 ../imagery/i.his.rgb/openfiles.c:19
 #: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:392
-#: ../imagery/i.vi/main.c:195 ../imagery/i.albedo/main.c:175
-#: ../raster/r.resamp.stats/main.c:341 ../raster/r.resamp.interp/main.c:148
-#: ../raster/r.los/main.c:205 ../raster/r.in.ascii/main.c:204
-#: ../raster/r.carve/main.c:172 ../raster/r.texture/main.c:286
-#: ../raster/r.basins.fill/main.c:108 ../raster/r.null/main.c:303
-#: ../raster/r.lake/main.c:217 ../raster/r.lake/main.c:296
-#: ../raster/r.in.bin/main.c:497 ../raster/r.surf.idw2/main.c:108
-#: ../raster/r.patch/main.c:124 ../raster/r.uslek/main.c:109
-#: ../raster/r.circle/main.c:127 ../raster/r.surf.idw/main.c:171
-#: ../raster/r.thin/io.c:163 ../raster/r.li/r.li.daemon/daemon.c:117
-#: ../raster/r.flow/io.c:167 ../raster/r.flow/io.c:202
-#: ../raster/r.in.gdal/main.c:710 ../raster/r.in.gdal/main.c:715
-#: ../raster/r.in.gdal/main.c:729 ../raster/r.sunmask/main.c:456
-#: ../raster/r.surf.random/randsurf.c:28 ../raster/r.surf.random/randsurf.c:32
-#: ../raster/r.in.xyz/main.c:495 ../raster/r.slope.aspect/opennew.c:16
+#: ../imagery/i.rectify/write.c:49 ../imagery/i.vi/main.c:249
+#: ../imagery/i.albedo/main.c:175 ../raster/r.resamp.stats/main.c:341
+#: ../raster/r.resamp.interp/main.c:148 ../raster/r.los/main.c:205
+#: ../raster/r.in.ascii/main.c:204 ../raster/r.carve/main.c:172
+#: ../raster/r.texture/main.c:286 ../raster/r.basins.fill/main.c:108
+#: ../raster/r.null/main.c:323 ../raster/r.lake/main.c:217
+#: ../raster/r.lake/main.c:296 ../raster/r.in.bin/main.c:497
+#: ../raster/r.surf.idw2/main.c:108 ../raster/r.patch/main.c:124
+#: ../raster/r.uslek/main.c:109 ../raster/r.circle/main.c:127
+#: ../raster/r.surf.idw/main.c:171 ../raster/r.thin/io.c:163
+#: ../raster/r.li/r.li.daemon/daemon.c:117 ../raster/r.flow/io.c:167
+#: ../raster/r.flow/io.c:202 ../raster/r.in.gdal/main.c:708
+#: ../raster/r.in.gdal/main.c:713 ../raster/r.in.gdal/main.c:727
+#: ../raster/r.sunmask/main.c:456 ../raster/r.surf.random/randsurf.c:28
+#: ../raster/r.surf.random/randsurf.c:32 ../raster/r.in.xyz/main.c:495
+#: ../raster/r.slope.aspect/opennew.c:16 ../raster/r.usler/main.c:92
 #: ../raster/r.clump/main.c:76 ../raster/r.in.mat/main.c:412
-#: ../raster/r.cross/main.c:117 ../raster/r.series/main.c:198
+#: ../raster/r.cross/main.c:128 ../raster/r.series/main.c:210
 #: ../raster/r.mapcalc/map3.c:585 ../raster/r.mapcalc/map.c:512
 #: ../raster/r.composite/main.c:185 ../raster/r.buffer/write_map.c:40
 #: ../raster/r.in.arc/main.c:154 ../raster/r.bitpattern/main.c:117
-#: ../raster/r.grow.distance/main.c:158 ../raster/r.grow/main.c:204
+#: ../raster/r.grow.distance/main.c:161 ../raster/r.grow/main.c:204
 #: ../raster3d/r3.to.rast/main.c:183 ../vector/lidar/v.surf.bspline/main.c:291
 #: ../vector/v.kernel/main.c:242 ../vector/v.surf.idw/main.c:246
 #: ../vector/v.neighbors/main.c:90 ../vector/v.to.rast/vect2rast.c:122
@@ -3207,17 +3211,20 @@
 msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
 #: ../doc/raster/r.example/main.c:150 ../imagery/i.gensig/get_train.c:33
-#: ../imagery/i.vi/main.c:210 ../imagery/i.vi/main.c:213
-#: ../imagery/i.vi/main.c:217 ../imagery/i.vi/main.c:222
-#: ../imagery/i.vi/main.c:227 ../imagery/i.vi/main.c:232
+#: ../imagery/i.vi/main.c:264 ../imagery/i.vi/main.c:268
+#: ../imagery/i.vi/main.c:273 ../imagery/i.vi/main.c:278
+#: ../imagery/i.vi/main.c:283 ../imagery/i.vi/main.c:288
 #: ../imagery/i.albedo/main.c:352 ../raster/r.los/main.c:266
-#: ../raster/r.los/main.c:274 ../raster/r.lake/main.c:266
-#: ../raster/r.lake/main.c:271 ../raster/r.out.gdal/main.c:251
-#: ../raster/r.out.gdal/main.c:282 ../raster/r.out.gdal/main.c:313
-#: ../raster/r.patch/main.c:136 ../raster/r.patch/main.c:143
-#: ../raster/r.uslek/main.c:123 ../raster/r.uslek/main.c:126
-#: ../raster/r.uslek/main.c:129 ../raster/r.uslek/main.c:132
-#: ../raster/r.topidx/file_io.c:62 ../raster/r.out.ppm/main.c:165
+#: ../raster/r.los/main.c:274 ../raster/r.null/main.c:334
+#: ../raster/r.lake/main.c:266 ../raster/r.lake/main.c:271
+#: ../raster/r.out.gdal/export_band.c:201
+#: ../raster/r.out.gdal/export_band.c:232
+#: ../raster/r.out.gdal/export_band.c:263 ../raster/r.patch/main.c:136
+#: ../raster/r.patch/main.c:143 ../raster/r.uslek/main.c:123
+#: ../raster/r.uslek/main.c:126 ../raster/r.uslek/main.c:129
+#: ../raster/r.uslek/main.c:132 ../raster/r.topidx/file_io.c:62
+#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:102
+#: ../raster/r.out.ppm/main.c:165 ../raster/r.usler/main.c:103
 #: ../raster/r.cost/main.c:395 ../raster/r.cost/main.c:599
 #: ../raster/r.walk/main.c:680 ../raster/r.walk/main.c:739
 #: ../raster/r.walk/main.c:845 ../raster/r.walk/main.c:1386
@@ -3263,10 +3270,10 @@
 msgid "Unable to create vector map <%s>"
 msgstr "Kann die Vektorkarte <%s> nicht erzeugen."
-#: ../doc/vector/v.example/main.c:103 ../vector/v.db.connect/main.c:179
+#: ../doc/vector/v.example/main.c:103 ../vector/v.db.connect/main.c:180
 #: ../vector/v.edit/select.c:506 ../vector/v.distance/main.c:345
 #: ../vector/v.distance/main.c:381 ../vector/v.db.select/main.c:129
-#: ../vector/v.what.rast/main.c:122 ../vector/v.extrude/main.c:158
+#: ../vector/v.what.rast/main.c:122 ../vector/v.extrude/main.c:159
 #: ../vector/v.sample/main.c:155 ../vector/v.generalize/misc.c:160
 #: ../vector/v.surf.idw/read_sites.c:34 ../vector/v.overlay/main.c:267
 #: ../vector/v.to.rast/support.c:123 ../vector/v.to.rast/support.c:275
@@ -3278,14 +3285,14 @@
 #: ../doc/vector/v.example/main.c:128 ../ps/ps.map/catval.c:54
 #: ../ps/ps.map/catval.c:116 ../ps/ps.map/catval.c:182
 #: ../raster/r.to.vect/main.c:164 ../raster/r.contour/main.c:158
-#: ../vector/v.db.connect/main.c:189 ../vector/v.db.connect/main.c:297
+#: ../vector/v.db.connect/main.c:190 ../vector/v.db.connect/main.c:298
 #: ../vector/v.to.rast3/main.c:83 ../vector/v.edit/select.c:520
 #: ../vector/v.in.dxf/write_vect.c:188
 #: ../vector/lidar/v.surf.bspline/main.c:305 ../vector/v.distance/main.c:350
 #: ../vector/v.distance/main.c:387 ../vector/v.reclass/main.c:122
 #: ../vector/v.in.ascii/main.c:311 ../vector/v.db.select/main.c:135
 #: ../vector/v.db.select/main.c:266 ../vector/v.what.rast/main.c:128
-#: ../vector/v.extrude/main.c:163 ../vector/v.sample/main.c:195
+#: ../vector/v.extrude/main.c:164 ../vector/v.sample/main.c:195
 #: ../vector/v.in.sites/main.c:163 ../vector/v.patch/main.c:132
 #: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:274
 #: ../vector/v.patch/main.c:331 ../vector/v.surf.idw/read_sites.c:39
@@ -3306,14 +3313,14 @@
 msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
 #: ../doc/vector/v.example/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get attribute data for cat %d"
-msgstr "Kann die Attribute für cat=%d nicht auswählen."
+msgstr "Kann die Attribute für cat %d nicht bekommen."
 #: ../doc/vector/v.example/main.c:176
-#, fuzzy, c-format
+#, c-format
 msgid "Error while retrieving database record for cat %d"
-msgstr "Fehler beim Entfernen der alten Maske MASK."
+msgstr "Fehler beim Abfragen des Datenbankeintrags für cat %d"
 #: ../doc/vector/v.example/main.c:209
 #, fuzzy, c-format
@@ -3323,8 +3330,8 @@
 #: ../general/g.gisenv/main.c:37 ../general/g.access/main.c:37
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcomp/main.c:281
 #: ../general/g.proj/main.c:60 ../general/g.findetc/main.c:28
-#: ../general/g.findfile/main.c:34 ../general/g.filename/main.c:39
-#: ../general/g.region/main.c:64 ../general/g.message/main.c:32
+#: ../general/g.findfile/main.c:35 ../general/g.filename/main.c:39
+#: ../general/g.region/main.c:60 ../general/g.message/main.c:32
 #: ../general/g.version/main.c:34
 msgid "general"
 msgstr "Allgemein"
@@ -3380,8 +3387,8 @@
 msgstr "Kann die Zugriffsrechte des Mapsets nicht ermitteln."
 #: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:39
-#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:99
-#: ../general/g.mremove/main.c:58 ../general/g.mlist/main.c:64
+#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:98
+#: ../general/g.mremove/main.c:55 ../general/g.mlist/main.c:62
 msgid "general, map management"
 msgstr "Allgemein, Kartenverwaltung"
@@ -3447,32 +3454,32 @@
 msgid "<%s> already exists"
 msgstr "<%s> existiert bereits"
-#: ../general/manage/cmd/list.c:42 ../general/g.mlist/main.c:66
+#: ../general/manage/cmd/list.c:42 ../general/g.mlist/main.c:64
 msgid ""
 "Lists available GRASS data base files of the user-specified data type to "
 "standard output."
 msgstr "Gibt die Daten des angegeben Typs auf die Standardausgabe."
-#: ../general/manage/cmd/list.c:71 ../general/g.mlist/main.c:114
+#: ../general/manage/cmd/list.c:71 ../general/g.mlist/main.c:112
 msgid "Mapset to list (default: current search path)"
 msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
-#: ../general/manage/cmd/list.c:75 ../general/g.mlist/main.c:140
+#: ../general/manage/cmd/list.c:75 ../general/g.mlist/main.c:138
 msgid "Verbose listing (also list map titles)"
 msgstr "Ausführliche Ausgabe (liste ebenfalls Kartentitel)."
-#: ../general/manage/cmd/remove.c:38 ../general/g.mremove/check_reclass.c:14
+#: ../general/manage/cmd/remove.c:37 ../general/g.mremove/check_reclass.c:14
 #, fuzzy, c-format
 msgid "[%s@%s] is a base map for [%s]. Remove forced."
 msgstr "[%s@%s] ist die Ausgangskarte für <%s>. Löschen wurde erzwungen."
-#: ../general/manage/cmd/remove.c:41 ../general/g.mremove/check_reclass.c:18
+#: ../general/manage/cmd/remove.c:40 ../general/g.mremove/check_reclass.c:18
 #, c-format
 msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
 msgstr ""
 "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
-#: ../general/manage/cmd/remove.c:63 ../general/manage/cmd/remove.c:76
+#: ../general/manage/cmd/remove.c:62 ../general/manage/cmd/remove.c:75
 #: ../general/g.mremove/check_reclass.c:41
 #: ../general/g.mremove/check_reclass.c:55
 #, c-format
@@ -3481,15 +3488,15 @@
 "Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist "
 "fehlgeschlagen."
-#: ../general/manage/cmd/remove.c:101 ../general/g.mremove/main.c:60
+#: ../general/manage/cmd/remove.c:100 ../general/g.mremove/main.c:57
 msgid "Removes data base element files from the user's current mapset."
 msgstr "Löscht Karten aus dem aktuellen Mapset."
-#: ../general/manage/cmd/remove.c:106
+#: ../general/manage/cmd/remove.c:105
 msgid "Force remove"
 msgstr "Erzwinge das Löschen"
-#: ../general/manage/cmd/remove.c:120 ../general/g.mremove/main.c:96
+#: ../general/manage/cmd/remove.c:119 ../general/g.mremove/main.c:93
 #, c-format
 msgid "%s file(s) to be removed"
 msgstr "%s Datei(en), die entfernt werden sollen."
@@ -3878,23 +3885,27 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr "Kann SEARCH_PATH nicht zum Schreiben öffnen."
-#: ../general/g.findfile/main.c:36
+#: ../general/g.findfile/main.c:37
 msgid "Searches for GRASS data base files and sets variables for the shell."
 msgstr ""
-#: ../general/g.findfile/main.c:47 ../general/g.filename/main.c:48
+#: ../general/g.findfile/main.c:48 ../general/g.filename/main.c:48
 msgid "Name of an element"
 msgstr "Name des Elements."
-#: ../general/g.findfile/main.c:53
+#: ../general/g.findfile/main.c:54
+msgid "Name of an existing map"
+msgstr "Name einer existierenden Karte."
+#: ../general/g.findfile/main.c:60
 msgid "Name of a mapset"
 msgstr "Name eines Mapsets"
-#: ../general/g.findfile/main.c:60
-msgid "Name of an existing map"
-msgstr "Name einer existierenden Karte."
+#: ../general/g.findfile/main.c:65
+msgid "Don't add quotes"
+msgstr ""
-#: ../general/g.findfile/main.c:74
+#: ../general/g.findfile/main.c:79
 #, c-format
 msgid ""
 "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
@@ -3913,77 +3924,88 @@
 msgid "Name of a mapset (default: current)"
 msgstr "Name des Mapsets (Standard: das aktuelle)"
-#: ../general/g.region/main.c:66
+#: ../general/g.region/main.c:62
 msgid "Manages the boundary definitions for the geographic region."
 msgstr "Verwaltet die Einstellungen der geographischen Region."
-#: ../general/g.region/main.c:72 ../raster/r.region/main.c:63
+#: ../general/g.region/main.c:68 ../raster/r.region/main.c:63
 msgid "Set from default region"
 msgstr "Übernehme von der Standard-Region."
-#: ../general/g.region/main.c:73 ../general/g.region/main.c:78
-#: ../general/g.region/main.c:146 ../general/g.region/main.c:153
-#: ../general/g.region/main.c:162 ../general/g.region/main.c:169
-#: ../general/g.region/main.c:179
+#: ../general/g.region/main.c:69 ../general/g.region/main.c:74
+#: ../general/g.region/main.c:150 ../general/g.region/main.c:157
+#: ../general/g.region/main.c:166 ../general/g.region/main.c:173
+#: ../general/g.region/main.c:183
 msgid "Existing"
 msgstr "Vorhanden"
+#: ../general/g.region/main.c:73
 msgid "Save as default region"
 msgstr "Als Standard-Region speichern."
-#: ../general/g.region/main.c:82
+#: ../general/g.region/main.c:78
 msgid "Print the current region"
 msgstr "Gib die aktuelle Region aus."
-#: ../general/g.region/main.c:83 ../general/g.region/main.c:89
-#: ../general/g.region/main.c:94 ../general/g.region/main.c:100
-#: ../general/g.region/main.c:106 ../general/g.region/main.c:111
-#: ../general/g.region/main.c:117 ../general/g.region/main.c:122
-#: ../imagery/i.group/main.c:78 ../imagery/i.group/main.c:84
-#: ../raster/r.external/main.c:555 ../raster/r.out.gdal/main.c:399
-#: ../raster/r.in.gdal/main.c:135 ../raster/r.stats/main.c:135
-#: ../raster/r.stats/main.c:140 ../raster/r.stats/main.c:145
-#: ../raster/r.stats/main.c:151 ../raster/r.stats/main.c:156
-#: ../raster/r.stats/main.c:161 ../raster/r.stats/main.c:166
-#: ../raster/r.stats/main.c:171 ../vector/v.to.db/parse.c:96
-#: ../vector/v.to.db/parse.c:101 ../vector/v.to.db/parse.c:107
+#: ../general/g.region/main.c:79 ../general/g.region/main.c:85
+#: ../general/g.region/main.c:90 ../general/g.region/main.c:96
+#: ../general/g.region/main.c:102 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:115 ../general/g.region/main.c:121
+#: ../general/g.region/main.c:126 ../imagery/i.group/main.c:78
+#: ../imagery/i.group/main.c:84 ../raster/r.external/main.c:555
+#: ../raster/r.out.gdal/main.c:131 ../raster/r.in.gdal/main.c:135
+#: ../raster/r.stats/main.c:148 ../raster/r.stats/main.c:153
+#: ../raster/r.stats/main.c:158 ../raster/r.stats/main.c:164
+#: ../raster/r.stats/main.c:169 ../raster/r.stats/main.c:174
+#: ../raster/r.stats/main.c:179 ../raster/r.stats/main.c:184
+#: ../vector/v.to.db/parse.c:96 ../vector/v.to.db/parse.c:101
+#: ../vector/v.to.db/parse.c:107
 msgid "Print"
 msgstr "Drucke"
-#: ../general/g.region/main.c:87
+#: ../general/g.region/main.c:83
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
 msgstr ""
 "Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen "
 "Ellipsoid/Datum aus."
-#: ../general/g.region/main.c:93
+#: ../general/g.region/main.c:89
 msgid "Print the current region extent"
 msgstr "Gib die Ausdehnung der aktuellen Region aus."
-#: ../general/g.region/main.c:99
+#: ../general/g.region/main.c:95
 msgid "Print the current region map center coordinates"
 msgstr "Gib die Koordinaten der Kartenmitte der aktuellen Region aus."
-#: ../general/g.region/main.c:105
+#: ../general/g.region/main.c:101
 msgid "Print region resolution in meters (geodesic)"
 msgstr "Gib Auflösung der Region in Meter aus (geodätisch)."
-#: ../general/g.region/main.c:110
+#: ../general/g.region/main.c:106
+msgid "Print the convergence angle (degrees CCW)"
+msgstr ""
+#: ../general/g.region/main.c:108
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
+msgstr ""
+#: ../general/g.region/main.c:114
 msgid "Print also 3D settings"
 msgstr "Gebe auch 3D-Einstellungen aus."
-#: ../general/g.region/main.c:116
+#: ../general/g.region/main.c:120
 msgid "Print the maximum bounding box in lat/long on WGS84"
 msgstr "Gebe die maximale Bounding-Box in Lat/Long Koordinaten in WGS84 aus."
-#: ../general/g.region/main.c:121
+#: ../general/g.region/main.c:125
 #: ../locale/scriptstrings/i.oif_to_translate.c:9
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:3
 msgid "Print in shell script style"
 msgstr "Gebe im Shell-Skript-Style aus."
-#: ../general/g.region/main.c:127
+#: ../general/g.region/main.c:131
 msgid ""
 "Align region to resolution (default = align to bounds, works only for 2D "
 "resolution)"
@@ -3991,216 +4013,219 @@
 "Passe Region an die Auflösung an (Standard = passe an die Grenzen an; "
 "funktioniert nur für 2D-Auflösung)."
-#: ../general/g.region/main.c:129 ../general/g.region/main.c:188
-#: ../general/g.region/main.c:197 ../general/g.region/main.c:206
-#: ../general/g.region/main.c:215 ../general/g.region/main.c:224
-#: ../general/g.region/main.c:233 ../general/g.region/main.c:309
-#: ../general/g.region/main.c:320 ../raster/r.in.bin/main.c:150
+#: ../general/g.region/main.c:133 ../general/g.region/main.c:192
+#: ../general/g.region/main.c:201 ../general/g.region/main.c:210
+#: ../general/g.region/main.c:219 ../general/g.region/main.c:228
+#: ../general/g.region/main.c:237 ../general/g.region/main.c:313
+#: ../general/g.region/main.c:324 ../raster/r.in.bin/main.c:150
 #: ../raster/r.in.bin/main.c:182 ../raster/r.in.bin/main.c:190
 #: ../raster/r.in.bin/main.c:198 ../raster/r.in.bin/main.c:206
 #: ../raster/r.in.bin/main.c:213 ../raster/r.in.bin/main.c:220
 msgid "Bounds"
 msgstr "Umrandung"
-#: ../general/g.region/main.c:133
+#: ../general/g.region/main.c:137
 msgid "Do not update the current region"
 msgstr "Die aktuelle Region nicht verändern."
-#: ../general/g.region/main.c:134 ../general/g.region/main.c:331
+#: ../general/g.region/main.c:138 ../general/g.region/main.c:335
 #: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
 #: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
 msgid "Effects"
 msgstr "Effekte"
-#: ../general/g.region/main.c:144
+#: ../general/g.region/main.c:148
 msgid "Set current region from named region"
 msgstr "Übernehme Einstellungen von einer benannten Region."
-#: ../general/g.region/main.c:152 ../raster/r.region/main.c:90
+#: ../general/g.region/main.c:156 ../raster/r.region/main.c:90
 msgid "Set region to match this raster map"
 msgstr "Setze Region angepasst an diese Rasterkarte."
-#: ../general/g.region/main.c:160
+#: ../general/g.region/main.c:164
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
 msgstr ""
 "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-"
 "Werte)."
-#: ../general/g.region/main.c:168 ../raster/r.region/main.c:98
+#: ../general/g.region/main.c:172 ../raster/r.region/main.c:98
 msgid "Set region to match this vector map"
 msgstr "Setze Region angepasst an diese Vektorkarte."
-#: ../general/g.region/main.c:177 ../raster/r.region/main.c:106
+#: ../general/g.region/main.c:181 ../raster/r.region/main.c:106
 msgid "Set region to match this 3dview file"
 msgstr "Setze Region angepasst an diese 3dview-Datei."
-#: ../general/g.region/main.c:187 ../raster/r.region/main.c:114
+#: ../general/g.region/main.c:191 ../raster/r.region/main.c:114
 msgid "Value for the northern edge"
 msgstr "Wert für die nördliche Grenze."
-#: ../general/g.region/main.c:196 ../raster/r.region/main.c:122
+#: ../general/g.region/main.c:200 ../raster/r.region/main.c:122
 msgid "Value for the southern edge"
 msgstr "Wert für die südliche Grenze."
-#: ../general/g.region/main.c:205 ../raster/r.region/main.c:130
+#: ../general/g.region/main.c:209 ../raster/r.region/main.c:130
 msgid "Value for the eastern edge"
 msgstr "Wert für die östliche Grenze."
-#: ../general/g.region/main.c:214 ../raster/r.region/main.c:138
+#: ../general/g.region/main.c:218 ../raster/r.region/main.c:138
 msgid "Value for the western edge"
 msgstr "Wert für die westliche Grenze."
-#: ../general/g.region/main.c:223
+#: ../general/g.region/main.c:227
 msgid "Value for the top edge"
 msgstr "Wert für die obere Ecke."
-#: ../general/g.region/main.c:232
+#: ../general/g.region/main.c:236
 msgid "Value for the bottom edge"
 msgstr "Wert für die untere Ecke."
-#: ../general/g.region/main.c:241
+#: ../general/g.region/main.c:245
 msgid "Number of rows in the new region"
 msgstr "Anzahl der Zeilen in der neuen Region."
-#: ../general/g.region/main.c:242 ../general/g.region/main.c:251
-#: ../general/g.region/main.c:261 ../general/g.region/main.c:271
-#: ../general/g.region/main.c:280 ../general/g.region/main.c:289
-#: ../general/g.region/main.c:298
+#: ../general/g.region/main.c:246 ../general/g.region/main.c:255
+#: ../general/g.region/main.c:265 ../general/g.region/main.c:275
+#: ../general/g.region/main.c:284 ../general/g.region/main.c:293
+#: ../general/g.region/main.c:302
 msgid "Resolution"
 msgstr "Auflösung"
-#: ../general/g.region/main.c:250
+#: ../general/g.region/main.c:254
 msgid "Number of columns in the new region"
 msgstr "Anzahl der Spalten in der neuen Region."
-#: ../general/g.region/main.c:260
+#: ../general/g.region/main.c:264
 msgid "Grid resolution 2D (both north-south and east-west)"
 msgstr "2D Rasterauflösung (Nord-Süd und Ost-West)."
-#: ../general/g.region/main.c:270
+#: ../general/g.region/main.c:274
 msgid "3D grid resolution (north-south, east-west and top-bottom)"
 msgstr "3D Rasterauflösung (Nord-Süd, Ost-West und Oben-Unten)."
-#: ../general/g.region/main.c:279
+#: ../general/g.region/main.c:283
 msgid "North-south grid resolution 2D"
 msgstr "Nord-Süd 2D Rasterauflösung"
-#: ../general/g.region/main.c:288
+#: ../general/g.region/main.c:292
 msgid "East-west grid resolution 2D"
 msgstr "Ost-West 2D Rasterauflösung"
-#: ../general/g.region/main.c:297
+#: ../general/g.region/main.c:301
 msgid "Top-bottom grid resolution 3D"
 msgstr "Oben-Unten 3D Rasterauflösung"
-#: ../general/g.region/main.c:307
+#: ../general/g.region/main.c:311
 msgid "Shrink region until it meets non-NULL data from this raster map"
 msgstr ""
 "Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
 "Rasterkarte stösst."
-#: ../general/g.region/main.c:318
+#: ../general/g.region/main.c:322
 msgid "Adjust region cells to cleanly align with this raster map"
 msgstr "Richte die Zellen der Region an denen dieser Rasterkarte aus."
-#: ../general/g.region/main.c:329
+#: ../general/g.region/main.c:333
 msgid "Save current region settings in named region file"
 msgstr ""
 "Speichere die Einstellungen der aktuellen Region in eine benannte Regions-"
 "Datei."
-#: ../general/g.region/main.c:379
+#: ../general/g.region/main.c:386
 #, c-format
 msgid "Region <%s> not found"
 msgstr "Region <%s> nicht gefunden."
-#: ../general/g.region/main.c:381
+#: ../general/g.region/main.c:388
 #, c-format
 msgid "Unable to read region <%s> in <%s>"
 msgstr "Kann Region <%s> in <%s> nicht lesen."
-#: ../general/g.region/main.c:393
+#: ../general/g.region/main.c:400
 #, c-format
 msgid "3dview file <%s> not found"
 msgstr "3dview-Datei <%s> nicht gefunden."
-#: ../general/g.region/main.c:398
-#, fuzzy, c-format
+#: ../general/g.region/main.c:405
+#, c-format
 msgid "Unable to open 3dview file <%s> in <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht öffnen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht öffnen."
-#: ../general/g.region/main.c:404
-#, fuzzy, c-format
+#: ../general/g.region/main.c:411
+#, c-format
 msgid "Unable to read 3dview file <%s> in <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht lesen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
-#: ../general/g.region/main.c:407
-#, fuzzy, c-format
+#: ../general/g.region/main.c:414
+#, c-format
 msgid "Old 3dview file. Region <%s> not found in <%s>"
-msgstr "Alte 3dview-Datei. Region <%s> in <%s> konnte nicht gefunden werden."
+msgstr "Alte 3Dview-Datei. Region <%s> konnte in <%s> nicht gefunden werden."
-#: ../general/g.region/main.c:438 ../general/g.region/main.c:772
+#: ../general/g.region/main.c:445 ../general/g.region/main.c:779
 #, c-format
 msgid "Unable to read header of raster map <%s@%s>"
 msgstr "Kann den Header der Rasterkarte <%s@%s> nicht lesen."
-#: ../general/g.region/main.c:464 ../general/g.mremove/do_remove.c:54
+#: ../general/g.region/main.c:471
 #, c-format
 msgstr "3D-Rasterkarte <%s> nicht gefunden."
-#: ../general/g.region/main.c:467
+#: ../general/g.region/main.c:474
 #, c-format
 msgid "Unable to read header of 3D raster map <%s@%s>"
 msgstr "Kann den Header der 3D-Rasterkarte <%s@%s> nicht lesen."
-#: ../general/g.region/main.c:493
+#: ../general/g.region/main.c:500
 #, c-format
 msgid "Unable to open vector map <%s@%s>"
 msgstr "Kann die Vektorkarte <%s@%s> nicht öffnen."
-#: ../general/g.region/main.c:775
+#: ../general/g.region/main.c:782
 #, c-format
 msgid "Raster map <%s@%s>: %s"
 msgstr "Rasterkarte <%s@%s>: %s"
-#: ../general/g.region/main.c:783
+#: ../general/g.region/main.c:790
 #, c-format
 msgid "Unable to set region <%s>"
 msgstr "Kann die Region <%s> einrichten."
-#: ../general/g.region/main.c:789
+#: ../general/g.region/main.c:796
 msgid "Unable to update current region"
 msgstr "Kann die derzeitige Region nicht aktualisieren."
-#: ../general/g.region/main.c:797
+#: ../general/g.region/main.c:804
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
 msgstr ""
 "Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht "
 "<PERMANENT>."
-#: ../general/g.region/main.c:814
+#: ../general/g.region/main.c:821
 #, c-format
 msgid "Invalid input <%s=%s>"
 msgstr "Ungültige Eingabe <%s=%s>."
-#: ../general/g.region/printwindow.c:259 ../general/g.region/printwindow.c:512
+#: ../general/g.region/printwindow.c:264 ../general/g.region/printwindow.c:502
+#: ../general/g.region/printwindow.c:633
 msgid "Unable to update lat/long projection parameters"
 msgstr "Kann lat/long Projektions Parameter nicht aktualisieren."
-#: ../general/g.region/printwindow.c:277 ../general/g.region/printwindow.c:285
-#: ../general/g.region/printwindow.c:293 ../general/g.region/printwindow.c:301
-#: ../general/g.region/printwindow.c:541 ../general/g.region/printwindow.c:549
-#: ../general/g.region/printwindow.c:557 ../general/g.region/printwindow.c:565
+#: ../general/g.region/printwindow.c:282 ../general/g.region/printwindow.c:290
+#: ../general/g.region/printwindow.c:298 ../general/g.region/printwindow.c:306
+#: ../general/g.region/printwindow.c:520 ../general/g.region/printwindow.c:528
+#: ../general/g.region/printwindow.c:536 ../general/g.region/printwindow.c:544
+#: ../general/g.region/printwindow.c:662 ../general/g.region/printwindow.c:670
+#: ../general/g.region/printwindow.c:678 ../general/g.region/printwindow.c:686
 msgid "Error in pj_do_proj (projection of input coordinate pair)"
 msgstr "Fehler in pj_do_proj (Projektion des Eingabekoordinatenpaars)."
-#: ../general/g.region/printwindow.c:406
+#: ../general/g.region/printwindow.c:411
 msgid "You are already in Lat/Long. Use the -p flag instead."
 msgstr ""
 "Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
-#: ../general/g.region/printwindow.c:408
+#: ../general/g.region/printwindow.c:413
 msgid ""
 "You are in a simple XY location, projection to Lat/Lon is not possible. Use "
 "the -p flag instead."
@@ -4208,7 +4233,7 @@
 "Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
 "ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
-#: ../general/g.region/printwindow.c:502
+#: ../general/g.region/printwindow.c:623
 msgid ""
 "WGS84 output not possible as this location does not contain datum "
 "transformation parameters. Try running g.setproj."
@@ -4216,7 +4241,7 @@
 "WGS84 Ausgabe nicht möglich, da diese Location keine "
 "Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
-#: ../general/g.region/printwindow.c:648
+#: ../general/g.region/printwindow.c:769
 msgid "Lat/Long calculations are not possible from a simple XY system"
 msgstr ""
@@ -4225,7 +4250,9 @@
 msgid "Unable to open raster map <%s> in <%s>"
 msgstr "Kann Rasterkarte <%s> in <%s> nicht öffnen."
-#: ../general/g.region/zoom.c:35 ../imagery/i.modis.qc/main.c:154
+#: ../general/g.region/zoom.c:35 ../imagery/i.emissivity/main.c:84
+#: ../imagery/i.modis.qc/main.c:162 ../imagery/i.latlong/main.c:126
+#: ../imagery/i.sunhours/main.c:99 ../imagery/i.sunhours/main.c:101
 #, c-format
 msgid "Could not read from <%s>"
 msgstr "Konnte nicht von <%s> lesen."
@@ -4294,20 +4321,18 @@
 msgstr ""
 #: ../general/g.gui/main.c:45
-msgid ""
-"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
-"Display Manager (d.m);wxpython;wxPython based next generation GUI"
+msgid "wxpython;wxPython based GUI"
 msgstr ""
-#: ../general/g.gui/main.c:53
+#: ../general/g.gui/main.c:51
 msgid "Name of workspace file"
 msgstr "Name der Workspace-Datei."
-#: ../general/g.gui/main.c:57
+#: ../general/g.gui/main.c:55
 msgid "Update default GUI setting"
 msgstr "Aktualisiert die Standard-GUI Einstellungen."
-#: ../general/g.gui/main.c:75
+#: ../general/g.gui/main.c:73
 #, c-format
 msgid "<%s> is now the default GUI"
 msgstr "<%s> ist jetzt das Standard-GUI."
@@ -4613,183 +4638,127 @@
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mremove/do_remove.c:20
-#, c-format
-msgid "Removing %s <%s>"
-msgstr "Entferne %s <%s>."
-#: ../general/g.mremove/do_remove.c:41 ../general/g.mremove/do_remove.c:83
-msgid "couldn't be removed"
-msgstr "konnte nicht entfernt werden."
-#: ../general/g.mremove/do_remove.c:61
-#, c-format
-msgid "%s: couldn't be removed"
-msgstr "%s: konnte nicht entfernt werden."
-#: ../general/g.mremove/do_remove.c:66 ../general/g.mremove/do_remove.c:88
-#, c-format
-msgid "%s: missing"
-msgstr "%s: fehlt."
-#: ../general/g.mremove/do_remove.c:70 ../general/g.mremove/do_remove.c:92
-#, c-format
-msgid "%s: removed"
-msgstr "%s: gelöscht."
-#: ../general/g.mremove/do_remove.c:99
-#, c-format
-msgid "<%s> nothing removed"
-msgstr "<%s> nichts gelöscht."
-#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:119
+#: ../general/g.mremove/main.c:63 ../general/g.mlist/main.c:117
 msgid "Use basic regular expressions instead of wildcards"
 msgstr "Verwende einfache reguläre Ausdrücke an Stelle von wildcards."
-#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:124
+#: ../general/g.mremove/main.c:68 ../general/g.mlist/main.c:122
 msgid "Use extended regular expressions instead of wildcards"
 msgstr "Verwende erweiterte reguläre Ausdrücke an Stelle von wildcards."
-#: ../general/g.mremove/main.c:76
+#: ../general/g.mremove/main.c:73
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
 #: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
 msgid "Force removal (required for actual deletion of files)"
 msgstr "Erzwinge das Löschen (benötigt um tatsächlich Dateien zu löschen)."
-#: ../general/g.mremove/main.c:80
+#: ../general/g.mremove/main.c:77
 msgid "Remove base maps"
 msgstr "Entferne Basiskarten"
-#: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:148
+#: ../general/g.mremove/main.c:101 ../general/g.mlist/main.c:146
 msgid "-r and -e are mutually exclusive"
 msgstr "-r und -e schliessen sich gegenseitig aus."
-#: ../general/g.mremove/main.c:107
+#: ../general/g.mremove/main.c:104
 msgid "The following files would be deleted:"
 msgstr "Die folgenden Karten würden gelöscht:"
-#: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:156
+#: ../general/g.mremove/main.c:127 ../general/g.mlist/main.c:154
 #, c-format
 msgid "Unable to compile regular expression %s"
 msgstr "Kann den regulären Ausdruck nicht kompilieren %s"
-#: ../general/g.mremove/main.c:158
+#: ../general/g.mremove/main.c:155
 msgid "You must use the force flag to actually remove them. Exiting."
 msgstr ""
 "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
 "mich."
-#: ../general/g.mremove/read_list.c:144 ../general/g.mlist/read_list.c:144
-#, c-format
-msgid ""
-"Format error: <%s>\n"
-"Line: %d\n"
-"%s"
-msgstr ""
-"Formatfehler: <%s>\n"
-"Zeile: %d\n"
-"%s"
-#: ../general/g.mlist/main.c:97
+#: ../general/g.mlist/main.c:95
 msgid "Map name search pattern (default: all)"
 msgstr "Suchmuster für Kartennamen (Standard: alle)."
-#: ../general/g.mlist/main.c:106
+#: ../general/g.mlist/main.c:104
 msgid "One-character output separator, newline, comma, space, or tab"
 msgstr ""
 "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
 "Tabulator."
-#: ../general/g.mlist/main.c:128
+#: ../general/g.mlist/main.c:126
 msgid "Print data types"
 msgstr "Gebe Datentypen aus."
-#: ../general/g.mlist/main.c:132
+#: ../general/g.mlist/main.c:130
 msgid "Print mapset names"
 msgstr "Gebe den Namen des Mapsets aus."
-#: ../general/g.mlist/main.c:136
+#: ../general/g.mlist/main.c:134
 msgid "Pretty printing in human readable format"
 msgstr "Schöne Ausgabe in menschenlesbaren Format."
-#: ../imagery/i.ifft/orig_wind.c:27
-msgid "The real and imaginary original windows did not match."
-msgstr "Das Original und das Bildfenster stimmen nicht überein."
-#: ../imagery/i.ifft/main.c:49 ../imagery/i.gensigset/main.c:40
+#: ../imagery/i.ifft/main.c:58 ../imagery/i.gensigset/main.c:40
 #: ../imagery/i.his.rgb/main.c:45 ../imagery/i.group/main.c:53
 #: ../imagery/i.rgb.his/main.c:45 ../imagery/i.smap/shapiro/main.c:38
-#: ../imagery/i.vpoints/main.c:49 ../imagery/i.pca/main.c:63
-#: ../imagery/i.class/main.c:91 ../imagery/i.rectify/main.c:56
-#: ../imagery/i.gensig/main.c:39 ../imagery/i.points/main.c:53
-#: ../imagery/i.zc/main.c:52 ../imagery/i.fft/main.c:71
-#: ../imagery/i.cluster/main.c:80
-#: ../imagery/i.ortho.photo/photo.2target/main.c:46
-#: ../imagery/i.ortho.photo/menu/main.c:43 ../imagery/i.maxlik/main.c:51
-#: ../imagery/i.cca/main.c:83 ../imagery/i.target/main.c:45
+#: ../imagery/i.vpoints/main.c:94 ../imagery/i.pca/main.c:63
+#: ../imagery/i.class/main.c:91 ../imagery/i.gensig/main.c:39
+#: ../imagery/i.points/main.c:96 ../imagery/i.zc/main.c:52
+#: ../imagery/i.fft/main.c:77 ../imagery/i.cluster/main.c:80
+#: ../imagery/i.maxlik/main.c:63 ../imagery/i.cca/main.c:83
+#: ../imagery/i.target/main.c:45
 msgid "imagery"
 msgstr "Bildverarbeitung"
-#: ../imagery/i.ifft/main.c:51
-#, fuzzy
+#: ../imagery/i.ifft/main.c:60
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr "Inverse Fast Fourier Transformation (ifft) für die Bildverarbeitung."
+msgstr "Inverse Fast Fourier Transformation (IFFT) für die Bildverarbeitung."
-#: ../imagery/i.ifft/main.c:60
-#, fuzzy
+#: ../imagery/i.ifft/main.c:69
 msgid "Input raster map (image fft, real part)"
-msgstr "Eingabe-Rasterkarte (Bild fft, realer Teil)"
+msgstr "Eingabe-Rasterkarte (fft Bild, realer Teil)"
-#: ../imagery/i.ifft/main.c:68
-#, fuzzy
+#: ../imagery/i.ifft/main.c:77
 msgid "Input raster map (image fft, imaginary part"
-msgstr "Eingabe-Rasterkarte (Bild fft, imaginärer Teil "
+msgstr "Eingabe-Rasterkarte (fft Bild, imaginärer Teil)"
-#: ../imagery/i.ifft/main.c:76
+#: ../imagery/i.ifft/main.c:85
 #, fuzzy
 msgid "Output inverse raster map after IFFT"
 msgstr "Invertierte Ausgabe-Rasterkarte (nach ifft)"
-#: ../imagery/i.ifft/main.c:88
+#: ../imagery/i.ifft/main.c:98
 #, fuzzy, c-format
-msgid "Unable to find the real-image map <%s>"
-msgstr "%s: %s - Kann das Echt-Zeit-Bild nicht finden."
+msgid "Unable to open real input map <%s>"
+msgstr "Kann die Rasterkarte <%s> nicht öffnen."
-#: ../imagery/i.ifft/main.c:94
-msgid ""
-"Unable to open real-image in the cell_misc directory.\n"
-"Input map probably wasn't created by i.fft"
-msgstr ""
-"Kann das Echt-Zeit-Bild im cell_misc-Ordner nicht öffnen.\n"
-"Eingabekarte ist warscheinlich nicht mit ifft erstellt worden."
-#: ../imagery/i.ifft/main.c:97
+#: ../imagery/i.ifft/main.c:102
 #, fuzzy, c-format
-msgid "Unable to find the imaginary-image <%s>"
-msgstr "%s: %s - Kann das zu verarbeitende Bild nicht finden."
+msgid "Unable to open imaginary input map <%s>"
-#: ../imagery/i.ifft/main.c:103
-msgid ""
-"Unable to open imaginary-image in the cell_misc directory.\n"
-msgstr ""
-"Kann die Bilddatei im cell_misc Ordner nicht öffnen.\n"
-"Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#: ../imagery/i.ifft/main.c:116
+msgid "The real and imaginary original windows did not match."
+msgstr "Das Original und das Bildfenster stimmen nicht überein."
-#: ../imagery/i.ifft/main.c:120
-#, c-format
-msgid "Power 2 values : [%d] rows [%d] columns."
-msgstr "'hoch zwei'-Werte: [%d] Zeilen [%d] Spalten."
-#: ../imagery/i.ifft/main.c:130
+#: ../imagery/i.ifft/main.c:138
 msgid "Reading the raster maps..."
 msgstr "Lese die Rasterkarten..."
-#: ../imagery/i.ifft/main.c:137
+#: ../imagery/i.ifft/main.c:141
+#, fuzzy
+msgid "Error while reading real input raster map."
+msgstr "Ein Fehler trat während des Lesens der Eingabe-Rasterkarte auf."
+#: ../imagery/i.ifft/main.c:143
+#, fuzzy
+msgid "Error while reading imaginary input raster map."
+#: ../imagery/i.ifft/main.c:155
 msgid "Masking the raster maps..."
-msgstr "Maskiere Rasterkarten..."
+msgstr "Maskiere die Rasterkarten..."
-#: ../imagery/i.ifft/main.c:158
+#: ../imagery/i.ifft/main.c:188
 msgid "Rotating data arrays..."
 msgstr "Rotiere Daten-Arrays..."
@@ -4801,15 +4770,18 @@
 msgid "Inverse FFT completed..."
 msgstr "Inverse FFT fertiggestellt...."
+#: ../imagery/i.ifft/main.c:203 ../raster/r.resample/main.c:114
+#: ../raster/r.statistics2/main.c:500 ../raster/r.statistics3/main.c:339
+#, fuzzy, c-format
+msgid "Unable to open output map <%s>"
+msgstr "Kann Ausgabedatei <%s> nicht öffnen."
 #: ../imagery/i.ifft/main.c:206
-msgid "Unable to open output file."
-msgstr "Öffnen der Ausgabedatei nicht möglich"
+#, fuzzy
+msgid "Writing output map..."
+msgstr "Schreibe Ausgabekarte ..."
-#: ../imagery/i.ifft/main.c:211
-msgid "Writing data to file..."
-msgstr "Schreibe Daten in die Datei..."
-#: ../imagery/i.ifft/main.c:237 ../imagery/i.fft/main.c:270
+#: ../imagery/i.ifft/main.c:223 ../imagery/i.fft/main.c:211
 msgid "Transform successful."
 msgstr "Transformation erfolgreich."
@@ -4842,19 +4814,16 @@
 msgstr "Name der Sättigungs-Karte"
 #: ../imagery/i.his.rgb/main.c:65
-#, fuzzy
 msgid "Output map representing the red"
-msgstr "Ausgabekarte, die den Rot-Kanal repräsentiert."
+msgstr "Ausgabekarte, die rot repräsentiert."
 #: ../imagery/i.his.rgb/main.c:69
-#, fuzzy
 msgid "Output map representing the green"
-msgstr "Ausgabekarte, die den Grün-Kanal repräsentiert."
+msgstr "Ausgabekarte, die grün repräsentiert."
 #: ../imagery/i.his.rgb/main.c:73
-#, fuzzy
 msgid "Output map representing the blue"
-msgstr "Ausgabekarte, die den Blau-Kanal repräsentiert."
+msgstr "Ausgabekarte, die blau repräsentiert."
 #: ../imagery/i.his.rgb/main.c:94 ../imagery/i.rgb.his/main.c:92
 msgid "Cannot read row from raster map"
@@ -4875,7 +4844,6 @@
 msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
 #: ../imagery/i.group/main.c:59
-#: ../imagery/i.ortho.photo/photo.2target/main.c:55
 msgid "Name of imagery group"
 msgstr "Name der Bildgruppe."
@@ -4884,7 +4852,6 @@
 msgstr "Name der Bild-Untergruppe."
 #: ../imagery/i.group/main.c:69
-#, fuzzy
 msgid "Name of raster map(s) to include in group"
 msgstr "Name der Rasterkarte(n), die in die Gruppe eingefügt werden sollen."
@@ -4897,9 +4864,8 @@
 msgstr "Liste Dateien der angegebenen (Unter-)gruppe auf (extravagant)."
 #: ../imagery/i.group/main.c:83
-#, fuzzy
 msgid "List files from specified (sub)group (shell script style)"
-msgstr "Liste Dateien der angegebenen (Unter-)gruppe auf (einfach)."
+msgstr "Liste Dateien der angegebenen (Unter-)gruppe (im Shellskript-Stil)."
 #: ../imagery/i.group/main.c:103
 msgid "No input raster map(s) specified"
@@ -5105,7 +5071,7 @@
 msgstr "Schreibe <%s> ..."
 #: ../imagery/i.smap/shapiro/closefiles.c:14
-#: ../raster/r.basins.fill/main.c:157 ../raster/r.cross/main.c:166
+#: ../raster/r.basins.fill/main.c:157 ../raster/r.cross/main.c:177
 #: ../raster/r.resample/main.c:131
 #, c-format
 msgid "Creating support files for <%s>..."
@@ -5125,19 +5091,19 @@
 msgid "Use maximum likelihood estimation (instead of smap)"
 msgstr "Benutze Maximum Likelihood Bewertung (anstelle von SMAP)."
-#: ../imagery/i.smap/shapiro/parse.c:42 ../imagery/i.maxlik/main.c:89
+#: ../imagery/i.smap/shapiro/parse.c:42 ../imagery/i.maxlik/main.c:101
 msgid "Run quietly"
 msgstr "Arbeite schweigsam."
 #: ../imagery/i.smap/shapiro/parse.c:57
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] not found."
-msgstr "Gruppe <%s> nicht gefunden."
+msgstr "Gruppe [%s] nicht gefunden."
 #: ../imagery/i.smap/shapiro/parse.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "Subgroup [%s] not found."
-msgstr "Untergruppe <%s> nicht gefunden."
+msgstr "Untergruppe [%s] nicht gefunden."
 #: ../imagery/i.smap/shapiro/read_sig.c:23
 #, fuzzy, c-format
@@ -5147,9 +5113,9 @@
 #: ../imagery/i.smap/shapiro/read_sig.c:27
 #, fuzzy, c-format
 msgid "Signature file [%s] is invalid."
-msgstr "Signatur-Datei <%s> ist ungültig."
+msgstr "Signaturdatei <%s> ist ungültig."
-#: ../imagery/i.vpoints/main.c:51
+#: ../imagery/i.vpoints/main.c:96
 msgid ""
 "Set registration points for an imagery group from a vector map or keyboard "
 "entry."
@@ -5157,27 +5123,27 @@
 "Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder "
 "durch Koordinateneingaben über die Tastatur."
-#: ../imagery/i.vpoints/main.c:59 ../imagery/i.points/main.c:62
+#: ../imagery/i.vpoints/main.c:104 ../imagery/i.points/main.c:105
 msgid "Name of imagery group to be registered"
 msgstr "Name der Bildgruppe, die registriert werden soll."
-#: ../imagery/i.vpoints/main.c:82 ../imagery/i.points/main.c:87
+#: ../imagery/i.vpoints/main.c:127 ../imagery/i.points/main.c:130
 #, fuzzy, c-format
 msgid "[%s] Only local groups may be used"
-msgstr "<%s> Nur lokale Gruppen können benutzt werden."
+msgstr "<%s> Nur lokale Gruppen können verwendet werden."
-#: ../imagery/i.vpoints/main.c:91 ../imagery/i.vpoints/main.c:95
-#: ../imagery/i.points/main.c:96 ../imagery/i.points/main.c:100
+#: ../imagery/i.vpoints/main.c:136 ../imagery/i.vpoints/main.c:140
+#: ../imagery/i.points/main.c:139 ../imagery/i.points/main.c:143
 #, fuzzy, c-format
 msgid "Group [%s] contains no maps, run i.group"
-msgstr "Gruppe <%s> enthält keine Dateien. Bitte i.group benutzen."
+msgstr "Gruppe <%s> enthält keine Karten. Führen Sie i.group aus."
-#: ../imagery/i.vpoints/main.c:209 ../imagery/i.points/main.c:205
+#: ../imagery/i.vpoints/main.c:254 ../imagery/i.points/main.c:248
 #, c-format
 msgid "ERROR: %s"
 msgstr "FEHLER: %s"
-#: ../imagery/i.vpoints/main.c:211 ../imagery/i.points/main.c:207
+#: ../imagery/i.vpoints/main.c:256 ../imagery/i.points/main.c:250
 #, c-format
 msgid "WARNING: %s (click mouse to continue)"
 msgstr "WARNUNG: %s (klicken Sie mit der Maus zum fortfahren)."
@@ -5191,9 +5157,8 @@
 msgstr ""
 #: ../imagery/i.pca/main.c:87
-#, fuzzy
 msgid "Sorry, at least 2 input bands must be provided"
-msgstr "Es müssen mindestens 4 Punkte %d angegeben werden."
+msgstr "Sorry, es müssen mindestens 2 Eingabe Kanäle angegeben werden."
 #: ../imagery/i.pca/main.c:130
 msgid "Calculating covariance matrix:"
@@ -5321,13 +5286,11 @@
 msgstr "Kann die undefinierte Region nicht löschen."
 #: ../imagery/i.class/curses.c:22
-#: ../imagery/i.ortho.photo/photo.2target/curses.c:22
 #, c-format
 msgid "make_window(%d,%d,%d,%d): illegal screen values."
 msgstr "make_window(%d,%d,%d,%d): illegale screen Werte."
 #: ../imagery/i.class/curses.c:153
-#: ../imagery/i.ortho.photo/photo.2target/curses.c:148
 #, c-format
 msgid "%s"
 msgstr "%s"
@@ -5374,14 +5337,12 @@
 msgstr "Name der Eingabe-Bild-Untergruppe."
 #: ../imagery/i.class/main.c:115 ../imagery/i.cluster/main.c:101
-#, fuzzy
 msgid "File to contain result signatures"
-msgstr "Datei enthält resultierende Signatur."
+msgstr "Datei, in die die resultierenden Signaturen geschrieben werden sollen."
 #: ../imagery/i.class/main.c:120
-#, fuzzy
 msgid "File containing input signatures (seed)"
-msgstr "Datei enthält Eingabe-Signaturen."
+msgstr "Datei, die die Eingabe-Signaturen (Startwerte) enthält."
 #: ../imagery/i.class/main.c:132
 msgid "You have a mask set. Unset mask and run again"
@@ -5410,9 +5371,8 @@
 msgstr "Untergruppe <%s> hat nur eine Datei."
 #: ../imagery/i.class/main.c:270
-#, fuzzy
 msgid "Unable to read cell header for first band file"
-msgstr "Kann die Cell-Kopf für das erste Band nicht lesen."
+msgstr "Kann den Zell-Header des ersten Kanals nicht lesen."
 #: ../imagery/i.class/main.c:275
 msgid ""
@@ -5425,7 +5385,7 @@
 #: ../imagery/i.class/main.c:280
 #, fuzzy, c-format
 msgid "Unable to open output signature file '%s'"
-msgstr "Kann die Ausgabe-Signaturdatei '%s' nicht öffnen."
+msgstr "Kann die Ausgabe-Signaturdatei <%s> nicht öffnen."
 #: ../imagery/i.class/main.c:286
 msgid ""
@@ -5480,55 +5440,213 @@
 msgid "No zoom window is defined."
 msgstr "Kein Zoomfenster definiert."
-#: ../imagery/i.rectify/main.c:58
+#: ../imagery/i.rectify/get_wind.c:46
+#, c-format
+msgid "Region N=%f S=%f E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:48
+#, fuzzy, c-format
+msgid "Resolution EW=%f NS=%f"
+msgstr ""
+"\n"
+"Auflösung = %d, Periode =%d"
+#: ../imagery/i.rectify/cp.c:15
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
+msgstr ""
+#: ../imagery/i.rectify/cp.c:21
+#, fuzzy, c-format
+msgid "Not enough active control points for current order, %d are required."
+msgstr "Nicht genügend Punkte, %d werden benötigt."
+#: ../imagery/i.rectify/cp.c:25
+#, fuzzy
+msgid "Poorly placed control points."
+msgstr "Schlecht platzierte Kontrollpunkte."
+#: ../imagery/i.rectify/cp.c:26
+#, fuzzy
+msgid " Can not generate the transformation equation."
+msgstr "Kann die undefinierte Region nicht löschen."
+#: ../imagery/i.rectify/cp.c:29
+msgid "Not enough memory to solve for transformation equation"
+msgstr ""
+#: ../imagery/i.rectify/cp.c:32
+#, fuzzy
+msgid "Invalid order"
+msgstr "Ungültige Koordinaten."
+#: ../imagery/i.rectify/rectify.c:94
+#, fuzzy, c-format
+msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
+#: ../imagery/i.rectify/rectify.c:100
+#, fuzzy, c-format
+msgid "Raster map <%s@%s>: zone don't match current settings"
+#: ../imagery/i.rectify/report.c:12
+#, fuzzy, c-format
+msgid "Rectify <%s@%s> (location <%s>)"
+msgstr "Lese <%s> in <%s>"
+#: ../imagery/i.rectify/report.c:15
+#, fuzzy, c-format
+msgid "into  <%s@%s> (location <%s>) ... %s"
+msgstr "Mapset <%s> in Eingabe-Location <%s> - %s"
+#: ../imagery/i.rectify/report.c:16
+#, fuzzy
+msgid "complete"
+msgstr "Unvollständige Regel"
+#, fuzzy
+msgid "failed"
+msgstr "Eingabe fehlgeschlagen."
+#: ../imagery/i.rectify/report.c:27
+#, c-format
+msgid "%d rows, %d cols (%ld cells) completed in"
+msgstr ""
+#: ../imagery/i.rectify/report.c:34
+#, c-format
+msgid "%.1f cells per minute"
+msgstr ""
+#: ../imagery/i.rectify/report.c:47
+msgid "data compression required an additional"
+msgstr ""
+#: ../imagery/i.rectify/main.c:84
+#, fuzzy
+msgid "imagery, rectify"
+msgstr "Bildgruppe"
+#: ../imagery/i.rectify/main.c:86
+#, fuzzy
 msgid ""
 "Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points"
+"in the image based on the control points."
 msgstr ""
 "Entzerrt ein Bild indem eine Koordinatentransformation für jeden Bildpunkt "
 "des Bildes basierend auf Kontrollpunkten durchgeführt wird."
-#: ../imagery/i.rectify/main.c:72
+#: ../imagery/i.rectify/main.c:100
 #, fuzzy
 msgid "Output raster map(s) suffix"
 msgstr "Titel der Ausgabe-Rasterkarte."
-#: ../imagery/i.rectify/main.c:78
+#: ../imagery/i.rectify/main.c:106
 msgid "Rectification polynom order (1-3)"
 msgstr "Polynomgrad der Entzerrung (1-3)."
-#: ../imagery/i.rectify/main.c:83
+#: ../imagery/i.rectify/main.c:111
+#, fuzzy
 msgid ""
-"Use curr. region settings in target location (def.=calculate smallest area)"
+"Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 "Benutze aktuelle Regionseinstellungen für die Ziellocation (Standard: "
 "kleinster gemeinsamer Bereich wird berechnet)."
-#: ../imagery/i.rectify/main.c:87
+#: ../imagery/i.rectify/main.c:115
 #, fuzzy
 msgid "Rectify all raster maps in group"
 msgstr "Entzerre alle Bilder in der Gruppe."
-#: ../imagery/i.rectify/main.c:110
+#: ../imagery/i.rectify/main.c:138
 #, c-format
 msgid "Invalid order (%d); please enter 1 to %d"
 msgstr ""
-#: ../imagery/i.rectify/main.c:115
+#: ../imagery/i.rectify/main.c:143
 #, c-format
 msgid "Group <%s> does not exist"
 msgstr "Gruppe <%s> existiert nicht."
-#: ../imagery/i.rectify/main.c:118
+#: ../imagery/i.rectify/main.c:146
 #, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "Gruppe <%s> enthält keine Dateien; führen Sie i.group aus."
-#: ../imagery/i.rectify/main.c:177
+#: ../imagery/i.rectify/main.c:205
 #, c-format
-msgid "Using Region: N=%f S=%f, E=%f W=%f"
+msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr ""
+#: ../imagery/i.rectify/main.c:219
+#, fuzzy, c-format
+msgid ""
+"Input raster map <%s> does not exist in group <%s>.\n"
+" Try:\n"
+msgstr "Rasterkarte <%s> existiert nicht in der Untergruppe <%s>."
+#: ../imagery/i.rectify/main.c:225
+#, fuzzy
+msgid "Exit!"
+msgstr "Vorhanden"
+#: ../imagery/i.rectify/exec.c:54
+#, fuzzy, c-format
+msgid "Rectified input raster map <%s> will be saved as <%s>"
+msgstr "Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
+#: ../imagery/i.rectify/target.c:14
+#, fuzzy, c-format
+msgid "Target information for group <%s> missing"
+msgstr "Bereich-Information für <%s> nicht vorhanden."
+#: ../imagery/i.rectify/target.c:20
+#, fuzzy, c-format
+msgid "Target location <%s> not found"
+msgstr "Region <%s> nicht gefunden."
+#: ../imagery/i.rectify/target.c:32 ../raster/r.in.gdal/main.c:626
+#, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr "Mapset <%s> in Ziel-Location <%s> - "
+#: ../imagery/i.rectify/target.c:33 ../raster/r.in.gdal/main.c:628
+#: ../raster/r.proj/main.c:244
+msgid "permission denied"
+msgstr "Zugang verweigert."
+#: ../imagery/i.rectify/target.c:33 ../raster/r.in.gdal/main.c:629
+#: ../raster/r.proj/main.c:245
+msgid "not found"
+msgstr "nicht gefunden"
+#: ../imagery/i.rectify/target.c:35
+msgid "Please run i.target for group."
+msgstr ""
+#: ../imagery/i.rectify/write.c:27
+#, fuzzy
+msgid "Error while writing to temp file"
+msgstr "Fehler beim Lesen der 'history'-Datei."
+#: ../imagery/i.rectify/write.c:54 ../raster/r.resample/main.c:123
+#, fuzzy, c-format
+msgid "Error writing row %d"
+msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
+#: ../imagery/i.rectify/write.c:56 ../imagery/i.vi/main.c:370
+#: ../imagery/i.albedo/main.c:389 ../raster/r.los/main.c:382
+#: ../raster/r.texture/main.c:333 ../raster/r.texture/main.c:337
+#: ../raster/r.texture/main.c:344 ../raster/r.null/main.c:342
+#: ../raster/r.uslek/main.c:164 ../raster/r.usler/main.c:129
+#: ../raster/r.buffer/write_map.c:78 ../raster/r.proj/main.c:437
+#, c-format
+msgid "Failed writing raster map <%s> row %d"
+msgstr "Konnte Rasterkarte <%s> Zeile %d nicht schreiben."
 #: ../imagery/i.gensig/means.c:26
 msgid "Calculating class mean ..."
 msgstr "Berechne Klassenmittel..."
@@ -5617,15 +5735,15 @@
 #, fuzzy, c-format
 msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
 msgstr ""
-"Kann die Siganturdatei <%s> für die Untergruppe <%s> in Gruppe <%s> nicht "
+"Kann die Signaturdatei <%s> der Untergruppe <%s> in Gruppe <%s> nicht "
 "erzeugen."
 #: ../imagery/i.gensig/write_sig.c:19
 #, fuzzy, c-format
 msgid "Writing signature file [%s] ..."
-msgstr "Schreibe Signaturdatei <%s>..."
+msgstr "Schreibe Signaturdatei <%s> ..."
-#: ../imagery/i.points/main.c:55
+#: ../imagery/i.points/main.c:98
 msgid "Mark ground control points on image to be rectified."
 msgstr "Markiere die Kontrollpunkte (GCP) auf dem zu entzerrenden Bild."
@@ -5685,11 +5803,11 @@
 msgid "Reading raster map..."
 msgstr "Lese Rasterkarte..."
-#: ../imagery/i.zc/main.c:159 ../imagery/i.fft/main.c:170
+#: ../imagery/i.zc/main.c:159 ../imagery/i.fft/main.c:144
 msgid "Error while reading input raster map."
-#: ../imagery/i.zc/main.c:177 ../imagery/i.fft/main.c:223
+#: ../imagery/i.zc/main.c:177
 msgid "Writing transformed data to file..."
 msgstr "Schreibe transformierte Daten in Datei..."
@@ -5706,7 +5824,8 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:78
-msgid "Uses red and nir, and only some requiring additional bands."
+msgid ""
+"Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:83
@@ -5721,14 +5840,15 @@
 #: ../imagery/i.vi/main.c:87
 msgid ""
-"sr;Simple Ratio;ndvi;Normalized Difference Vegetation Index;ipvi;Infrared "
-"Percentage Vegetation Index;dvi;Difference Vegetation Index;evi;Enhanced "
-"Vegetation Index;pvi;Perpendicular Vegetation Index;wdvi;Weighted Difference "
-"Vegetation Index;savi;Soil Adjusted Vegetation Index;msavi;Modified Soil "
-"Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation "
-"Index;gemi;Global Environmental Monitoring Index;arvi;Atmospherically "
-"Resistant Vegetation Indices;gvi;Green Vegetation Index;gari;Green "
-"atmospherically resistant vegetation index;"
+"arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation "
+"Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green "
+"atmospherically resistant vegetation index;gemi;Global Environmental "
+"Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified "
+"Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted "
+"Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;"
+"Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple "
+"Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference "
+"Vegetation Index;"
 msgstr ""
 #: ../imagery/i.vi/main.c:106
@@ -5736,106 +5856,157 @@
 msgid "Name of the red channel surface reflectance map"
 msgstr "Name der Karte mit der fraktalen Oberfläche."
-#: ../imagery/i.vi/main.c:107 ../imagery/i.vi/main.c:113
-#: ../imagery/i.vi/main.c:120 ../imagery/i.vi/main.c:127
-#: ../imagery/i.vi/main.c:134 ../imagery/i.vi/main.c:141
+#: ../imagery/i.vi/main.c:107 ../imagery/i.vi/main.c:114
+#: ../imagery/i.vi/main.c:121 ../imagery/i.vi/main.c:128
+#: ../imagery/i.vi/main.c:135 ../imagery/i.vi/main.c:142
 msgid "Range: [0.0;1.0]"
 msgstr ""
-#: ../imagery/i.vi/main.c:112
+#: ../imagery/i.vi/main.c:113
 #, fuzzy
 msgid "Name of the nir channel surface reflectance map"
 msgstr "Name einer existierenden Vektorkarte."
-#: ../imagery/i.vi/main.c:119
+#: ../imagery/i.vi/main.c:120
 #, fuzzy
 msgid "Name of the green channel surface reflectance map"
-#: ../imagery/i.vi/main.c:126
+#: ../imagery/i.vi/main.c:127
 #, fuzzy
 msgid "Name of the blue channel surface reflectance map"
 msgstr "Name der resultierenden Karte."
-#: ../imagery/i.vi/main.c:133
+#: ../imagery/i.vi/main.c:134
 #, fuzzy
 msgid "Name of the chan5 channel surface reflectance map"
-#: ../imagery/i.vi/main.c:140
+#: ../imagery/i.vi/main.c:141
 #, fuzzy
 msgid "Name of the chan7 channel surface reflectance map"
-#: ../imagery/i.vi/main.c:306 ../imagery/i.albedo/main.c:389
-#: ../raster/r.los/main.c:382 ../raster/r.texture/main.c:333
-#: ../raster/r.texture/main.c:337 ../raster/r.texture/main.c:344
-#: ../raster/r.uslek/main.c:164 ../raster/r.buffer/write_map.c:78
-#: ../raster/r.proj/main.c:437
-#, c-format
-msgid "Failed writing raster map <%s> row %d"
-msgstr "Konnte Rasterkarte <%s> Zeile %d nicht schreiben."
+#: ../imagery/i.vi/main.c:159
+msgid "sr index requires red and nir maps"
+msgstr ""
-#: ../imagery/i.fft/main.c:73
+#: ../imagery/i.vi/main.c:162
+msgid "ndvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:165
+msgid "ipvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:168
+msgid "dvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:171
+msgid "pvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:174
+msgid "wdvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:177
+msgid "savi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:180
+msgid "msavi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:183
+msgid "msavi2 index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:186
+msgid "gemi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:190
+msgid "arvi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:194
+msgid "evi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:198
+msgid "vari index requires blue, green and red maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:202
+msgid "gari index requires blue, green, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:207
+msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
+msgstr ""
+#: ../imagery/i.fft/main.c:79
 msgid "Fast Fourier Transform (FFT) for image processing."
 msgstr "Fast Fourier Transformation (FFT) für die Bildverarbeitung."
-#: ../imagery/i.fft/main.c:82
+#: ../imagery/i.fft/main.c:88
 msgid "Input raster map being fft"
 msgstr "Eingabe-Rasterkarte, die fft ist."
-#: ../imagery/i.fft/main.c:90
+#: ../imagery/i.fft/main.c:96
 #, fuzzy
 msgid "Output real part arrays stored as raster map"
 msgstr "Ausgabe der Real-part-Arrays (als Rasterkarte)."
-#: ../imagery/i.fft/main.c:98
+#: ../imagery/i.fft/main.c:104
 #, fuzzy
 msgid "Output imaginary part arrays stored as raster map"
 msgstr "Augabe deAusgabe part"
-#: ../imagery/i.fft/main.c:106
-msgid "Range of values in output display files"
-msgstr "Wertebereich in den Ausgabedateien."
+#: ../imagery/i.fft/main.c:115 ../raster/r.resample/main.c:91
+#, fuzzy, c-format
+msgid "Unable to open input map <%s>"
+msgstr "Kann die Eingabedatei <%s> nicht öffnen."
-#: ../imagery/i.fft/main.c:125
+#: ../imagery/i.fft/main.c:118
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
 msgstr ""
 "Raster MASKE gefunden, denken Sie über das Löschen nach (siehe man-Seiten). "
 "Fahre trotzdem fort..."
-#: ../imagery/i.fft/main.c:130
-msgid "Range less than or equal to zero not allowed."
-msgstr "Bereich weniger oder gleich Null ist nicht erlaubt."
-#: ../imagery/i.fft/main.c:152
-msgid "Initializing data...\n"
-msgstr "Initialisiere Daten...\n"
-#: ../imagery/i.fft/main.c:167
+#: ../imagery/i.fft/main.c:141
 msgid "Reading the raster map..."
 msgstr "Lese die Rasterkarte..."
-#: ../imagery/i.fft/main.c:179
+#: ../imagery/i.fft/main.c:155
 msgid "Starting FFT..."
 msgstr "Starte FFT..."
-#: ../imagery/i.fft/main.c:181
+#: ../imagery/i.fft/main.c:157
 msgid "FFT completed..."
 msgstr "FFT fertiggestellt..."
-#: ../imagery/i.fft/main.c:199
+#: ../imagery/i.fft/main.c:161
+#, fuzzy, c-format
+msgid "Unable to open real output map <%s>"
+#: ../imagery/i.fft/main.c:163
+#, fuzzy, c-format
+msgid "Unable to open imaginary output map <%s>"
+#: ../imagery/i.fft/main.c:179
 msgid "Rotating data..."
 msgstr "Drehe Daten..."
-#: ../imagery/i.fft/main.c:229
-msgid "Writing viewable versions of transformed data to files..."
-msgstr "Schreibe sichtbare Versionen der transformierten Daten in Dateien..."
+#: ../imagery/i.fft/main.c:187
+#, fuzzy
+msgid "Writing transformed data..."
+msgstr "Schreibe transformierte Daten in Datei..."
-#: ../imagery/i.fft/save_fft.c:17 ../imagery/i.fft/save_fft.c:22
-msgid "Unable to open file in the cell_misc directory."
-msgstr "Kann Datei im cell_misc Verzeichnis nicht öffnen."
 #: ../imagery/i.find/main.c:63
 #, c-format
 msgid "usage: %s location mapset element file."
@@ -5972,19 +6143,19 @@
 msgstr "Kann nicht weitermachen."
 #: ../imagery/i.cluster/open_files.c:61
-#, fuzzy, c-format
+#, c-format
 msgid "Can't open seed signature file <%s>"
-msgstr "** Kann die Seed-Signaturdatei <%s> nicht öffnen.**"
+msgstr "Kann die Start-Signaturdatei <%s> nicht öffnen."
 #: ../imagery/i.cluster/open_files.c:67
-#, fuzzy, c-format
+#, c-format
 msgid "Can't read signature file <%s>"
 msgstr "Kann die Signaturdatei <%s> nicht lesen."
 #: ../imagery/i.cluster/open_files.c:71
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> has too many signatures (limit is 255)"
-msgstr "** <%s> hat zu viele Signaturen (Limit ist bei 255)"
+msgstr "<%s> hat zu viele Signaturen (Limit ist 255)"
 #: ../imagery/i.cluster/main.c:82
 msgid ""
@@ -6050,7 +6221,7 @@
 "<%s> -- illegal number of initial classes"
 msgstr ""
 "\n"
-"<%s> -- Ungültige Anzahl der Klassen."
+"<%s> -- Ungültige Anzahl der Anfangs-Klassen."
 #: ../imagery/i.cluster/main.c:191
 #, c-format
@@ -6059,7 +6230,7 @@
 "<%s> -- illegal value(s) of sample intervals"
 msgstr ""
 "\n"
-"<%s> -- Ungültig(r) Wert(e) für die Sample-Intervalle."
+"<%s> -- Ungültige(r) Wert(e) für die Stichproben-Intervalle."
 #: ../imagery/i.cluster/main.c:207
 #, c-format
@@ -6077,7 +6248,7 @@
 "<%s> -- illegal value of convergence"
 msgstr ""
 "\n"
-"<%s> -- ungültiger Wert für Konvergenz."
+"<%s> -- Ungültiger Wert für Konvergenz."
 #: ../imagery/i.cluster/main.c:222
 #, c-format
@@ -6313,63 +6484,6 @@
 msgid " stddev "
 msgstr " Stdabw."
-#: ../imagery/i.ortho.photo/photo.2target/main.c:47
-#, fuzzy
-msgid "Creates control points on an image to be ortho-rectified."
-msgstr ""
-"Erzeuge Kontrollounkte auf einem Bild, welches orthorektifiziert werden soll."
-#: ../imagery/i.ortho.photo/photo.2target/main.c:59
-#, fuzzy
-msgid "Name of image to be rectified which will  be initially drawn on screen."
-msgstr ""
-"Name der Karte die entzerrt werden soll. Sie wird sofort auf dem Bildschirm "
-"dargestellt."
-#: ../imagery/i.ortho.photo/photo.2target/main.c:65
-#, fuzzy
-msgid ""
-"Name of a map from target mapset which  will be initially drawn on screen."
-msgstr ""
-"Name einer Karte im Zielmapset. Sie wird sofort auf dem Bildschirm "
-"dargestellt."
-#: ../imagery/i.ortho.photo/photo.2target/main.c:208
-#: ../imagery/i.ortho.photo/photo.2target/main.c:239
-#, c-format
-msgid "Unable to read head of %s"
-msgstr "Kann den Header von <%s> nicht lesen."
-#: ../imagery/i.ortho.photo/menu/main.c:44
-msgid "Menu driver for the photo imagery programs."
-msgstr ""
-#: ../imagery/i.ortho.photo/menu/main.c:48
-#, fuzzy
-msgid "Name of imagery group for ortho-rectification"
-msgstr "Name der Ziellocation für das Bild."
-#: ../imagery/i.ortho.photo/photo.rectify/write.c:34
-#, c-format
-msgid "Unable to write temp file: %s"
-msgstr "Kann die temporäre Datei <%s> nicht schreiben."
-#: ../imagery/i.ortho.photo/photo.rectify/write.c:58
-#, c-format
-msgid "Unable to open map %s"
-msgstr "Kann die Karte <%s> nicht öffnen."
-#: ../imagery/i.ortho.photo/photo.rectify/write.c:63
-#, c-format
-msgid "Unable to write row %d"
-msgstr "Kann die Zeile %d nicht schreiben."
-#: ../imagery/i.ortho.photo/photo.rectify/write.c:66
-msgid ""
-"Unable to write raster map. You might want to check available disk space and "
-"write permissions."
-msgstr ""
 #: ../imagery/i.maxlik/open.c:16
 #, fuzzy, c-format
 msgid "group=[%s] - not found."
@@ -6378,7 +6492,7 @@
 #: ../imagery/i.maxlik/open.c:19
 #, fuzzy, c-format
 msgid "subgroup=[%s] (of group [%s]) - not found."
-msgstr "Untergruppe=<%s> (der Grupppe <%s>) kann nicht gefunden werden."
+msgstr "Untergruppe=<%s> (der Gruppe <%s>) - nicht gefunden."
 #: ../imagery/i.maxlik/open.c:26
 #, fuzzy, c-format
@@ -6413,11 +6527,11 @@
 msgid "Unable to create reject layer [%s]."
 msgstr "Kann die Reject-Karte <%s> nicht erzeugen."
-#: ../imagery/i.maxlik/main.c:53
+#: ../imagery/i.maxlik/main.c:65
 msgid "Classifies the cell spectral reflectances in imagery data."
 msgstr ""
-#: ../imagery/i.maxlik/main.c:55
+#: ../imagery/i.maxlik/main.c:67
 #, fuzzy
 msgid ""
 "Classification is based on the spectral signature information generated by "
@@ -6427,23 +6541,23 @@
 "basierend auf der spektralen Signaturinformation (generiert durch i.cluster, "
 "i.class oder i.gensig) klassifiziert."
-#: ../imagery/i.maxlik/main.c:59
+#: ../imagery/i.maxlik/main.c:71
 msgid "Imagery group to be classified"
 msgstr "Bildgruppe, die klassifiziert werden soll."
-#: ../imagery/i.maxlik/main.c:66
+#: ../imagery/i.maxlik/main.c:78
 msgid "Subgroup containing image files to be classified"
 msgstr "Untergruppe, die die Bilder zur Klassifikation enthält."
-#: ../imagery/i.maxlik/main.c:72
+#: ../imagery/i.maxlik/main.c:84
 msgid "Signatures to use for classification"
 msgstr "Signaturen, die für die Klassifikation genutzt werden sollen."
-#: ../imagery/i.maxlik/main.c:78
+#: ../imagery/i.maxlik/main.c:90
 msgid "Raster map to hold classification results"
 msgstr "Rasterkarte mit den Klassifikationsergebnissen"
-#: ../imagery/i.maxlik/main.c:85
+#: ../imagery/i.maxlik/main.c:97
 msgid "Raster map to hold reject threshold results"
 msgstr "Rasterkarte mit den zurückgewiesenen Resultaten."
@@ -6557,6 +6671,43 @@
 " ODER\n"
 " die Variablen manuell eingeben."
+#: ../imagery/i.emissivity/main.c:43
+msgid "emissivity, land flux, energy balance"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:45
+msgid "Emissivity from NDVI, generic method for spares land."
+msgstr ""
+#: ../imagery/i.emissivity/main.c:49
+#, fuzzy
+msgid "Name of the NDVI map [-]"
+msgstr "Name der Rasterkarte"
+#: ../imagery/i.emissivity/main.c:52
+#, fuzzy
+msgid "Name of the output emissivity layer"
+msgstr "Name der Ausgabekarte"
+#: ../imagery/i.emissivity/main.c:63 ../imagery/i.modis.qc/main.c:138
+#: ../imagery/i.latlong/main.c:78 ../imagery/i.sunhours/main.c:71
+#: ../imagery/i.sunhours/main.c:76
+#, fuzzy, c-format
+msgid "Cannot open cell file [%s]"
+msgstr "Kann die Regel-Datei <%s> nicht öffnen."
+#: ../imagery/i.emissivity/main.c:73 ../imagery/i.modis.qc/main.c:152
+#: ../imagery/i.latlong/main.c:119 ../imagery/i.sunhours/main.c:85
+#, fuzzy, c-format
+msgid "Could not open <%s>"
+msgstr "Kann die Karte %s nicht öffnen."
+#: ../imagery/i.emissivity/main.c:100 ../imagery/i.modis.qc/main.c:221
+#: ../imagery/i.latlong/main.c:142 ../imagery/i.sunhours/main.c:118
+#, fuzzy
+msgid "Cannot write to output raster file"
+msgstr "Name der Ausgabe-Rasterkarte."
 #: ../imagery/i.albedo/main.c:86
 msgid "imagery, albedo, surface reflectance"
 msgstr ""
@@ -6610,108 +6761,168 @@
 msgid "Unable to read raster map <%s> row %d >"
 msgstr "Kann die Rasterkarte <%s> Zeile %d nicht lesen."
-#: ../imagery/i.modis.qc/main.c:70
+#: ../imagery/i.modis.qc/main.c:66
 msgid "QC, Quality Control, surface reflectance, Modis"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:72
+#: ../imagery/i.modis.qc/main.c:68
 #, fuzzy
 msgid "Extract quality control parameters from Modis QC layers"
 msgstr "Extrahiert Terrainparameter aus einem DGM."
-#: ../imagery/i.modis.qc/main.c:76
+#: ../imagery/i.modis.qc/main.c:72
 #, fuzzy
 msgid "qcname"
 msgstr "Name"
-#: ../imagery/i.modis.qc/main.c:79
+#: ../imagery/i.modis.qc/main.c:75
 #, fuzzy
 msgid "Name of QC type to extract"
-msgstr "Name der zu editierenden Vektorkarte"
+msgstr "Name der Rasterkarte, die angezeigt werden soll."
-#: ../imagery/i.modis.qc/main.c:80
+#: ../imagery/i.modis.qc/main.c:76
 #, fuzzy
 msgid "Name of QC"
-#: ../imagery/i.modis.qc/main.c:82
+#: ../imagery/i.modis.qc/main.c:77
+msgid ""
+"adjcorr;Adjacency Correction;atcorr;Atmospheric Correction;cloud;Cloud State;"
+"data_quality;Band-Wise Data Quality Flag;diff_orbit_from_500m;250m Band is "
+"at Different Orbit than 500m;modland_qa_bits;MODIS Land General Quality "
+"Assessment;"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:83
 msgid "modland_qa_bits"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:86
+#: ../imagery/i.modis.qc/main.c:87
 #, fuzzy
 msgid "Name of the surface reflectance QC layer [bit array]"
-#: ../imagery/i.modis.qc/main.c:94
+#: ../imagery/i.modis.qc/main.c:95
 msgid "Band number of Modis product 250m=[1,2],500m=[1-7]"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:97
+#: ../imagery/i.modis.qc/main.c:96
+msgid ""
+"1;250m/500m Band 1: Red;2;250m/500m Band 2: NIR;3;500m Band 3: Blue;4;500m "
+"Band 4: Green;5;500m Band 5: SWIR 1;6;500m Band 6: SWIR 2;7;500m Band 7: "
+"SWIR 3;"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:105
 #, fuzzy
 msgid "output"
 msgstr "Ausgabe:"
-#: ../imagery/i.modis.qc/main.c:99
+#: ../imagery/i.modis.qc/main.c:107
 #, fuzzy
 msgid "Name of the output QC type classification layer"
 msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
-#: ../imagery/i.modis.qc/main.c:100
+#: ../imagery/i.modis.qc/main.c:108
 msgid "qc"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:105
+#: ../imagery/i.modis.qc/main.c:113
 msgid "QC for MOD09A product @ 500m instead of default MOD09Q at 250m"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:120
-msgid "Those flags cannot work with MOD09A @ 500m products"
+#: ../imagery/i.modis.qc/main.c:128
+msgid "This flag is not available for MOD09A @ 500m products"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:124
+#: ../imagery/i.modis.qc/main.c:132
 #, fuzzy
 msgid "band number out of allowed range [1-7]"
 msgstr "Kantenanzahl außerhalb der Spanne."
-#: ../imagery/i.modis.qc/main.c:126
+#: ../imagery/i.modis.qc/main.c:134
 #, fuzzy
 msgid "250m band number is out of allowed range [1,2]"
-#: ../imagery/i.modis.qc/main.c:130
+#: ../imagery/i.modis.qc/main.c:141
 #, fuzzy, c-format
-msgid "Cannot open cell file [%s]"
-msgstr "Kann die Regel-Datei <%s> nicht öffnen."
-#: ../imagery/i.modis.qc/main.c:133
-#, fuzzy, c-format
 msgid "Cannot read file header of [%s]"
 msgstr "Kann die Header-Datei für <%s> nicht lesen."
-#: ../imagery/i.modis.qc/main.c:144
+#: ../imagery/i.modis.qc/main.c:215
+msgid "Unknown flag name, please check spelling"
+msgstr ""
+#: ../imagery/i.latlong/main.c:55
+msgid "imagery, latitude, longitude, projection"
+msgstr ""
+#: ../imagery/i.latlong/main.c:56
+#, fuzzy
+msgid "creates a latitude/longitude map"
+msgstr "Erzeuge eine integer-Rasterkarte."
+#: ../imagery/i.latlong/main.c:60
+#, fuzzy
+msgid "Name of the input map"
+msgstr "Name der Eingabe-Rasterkarte."
+#: ../imagery/i.latlong/main.c:63
+#, fuzzy
+msgid "Name of the output latitude or longitude layer"
+msgstr "Name der Eingabe-Vektorkarte."
+#: ../imagery/i.latlong/main.c:67
+#, fuzzy
+msgid "Longitude output"
+msgstr "Lese r.stats Ausgabe."
+#: ../imagery/i.latlong/main.c:80
 #, fuzzy, c-format
-msgid "Could not open <%s>"
-msgstr "Kann die Karte %s nicht öffnen."
+msgid "Cannot read file header of [%s])"
+msgstr "Kann die Header-Datei für <%s> nicht lesen."
-#: ../imagery/i.modis.qc/main.c:207
-msgid "Unknown flag name, please check spelling"
+#: ../imagery/i.sunhours/main.c:46
+msgid "sunshine, hours, daytime"
 msgstr ""
-#: ../imagery/i.modis.qc/main.c:213
+#: ../imagery/i.sunhours/main.c:47
 #, fuzzy
-msgid "Cannot write to output raster file"
-msgstr "Name der Ausgabe-Rasterkarte."
+msgid "creates a sunshine hours map"
+#: ../imagery/i.sunhours/main.c:51
+msgid "doy"
+msgstr ""
+#: ../imagery/i.sunhours/main.c:52
+#, fuzzy
+msgid "Name of the doy input map"
+msgstr "Name der Spalte"
+#: ../imagery/i.sunhours/main.c:55
+msgid "lat"
+msgstr ""
+#: ../imagery/i.sunhours/main.c:56
+#, fuzzy
+msgid "Name of the latitude input map"
+msgstr "Eingabe-Rasterkarte mit Höheninformationen."
+#: ../imagery/i.sunhours/main.c:59
+#, fuzzy
+msgid "Name of the output sunshine hours map"
+msgstr "von"
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:1
 #, fuzzy
 msgid "Configuration editor for r.li.'index'"
 msgstr "Konfigurationsdatei"
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-#, fuzzy
 msgid "raster, landscape structure analysis"
-msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
+msgstr "Raster, Landschaftsstruktur Analyse"
 #: ../locale/scriptstrings/d.polar_to_translate.c:1
 msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -6719,9 +6930,8 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:2
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#, fuzzy
 msgid "display, diagram"
-msgstr "Darstellung, Kartographie"
+msgstr "Anzeige, Diagramm"
 #: ../locale/scriptstrings/d.polar_to_translate.c:3
 #, fuzzy
@@ -6741,19 +6951,6 @@
 msgid "Plot using Xgraph"
 msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#, fuzzy
-msgid "raster input map"
-msgstr "Raster, Import"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
 msgid "Interactively edit cell values in a raster map."
 msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
@@ -6795,6 +6992,38 @@
 msgid "Maximum number of columns to load"
 msgstr "Maximale Anzahl der Spalten: %d"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+#, fuzzy
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+#, fuzzy
+msgid "Omit entries with missing label"
+msgstr "Überspringe Kategorien ohne Label."
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+#, fuzzy
+msgid "Number of lines to appear in the legend"
+msgstr "Wie oft soll der Filter wiederholt werden?"
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+#, fuzzy
+msgid "Name of raster map to generate legend from"
+msgstr "Name der Rasterkarte für <%s>."
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between data layers (in pairs)."
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+msgid "raster input map"
+msgstr "Eingabe-Rasterkarte"
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
 msgid "Drapes a color raster over a shaded relief map using d.his"
 msgstr ""
@@ -6814,16 +7043,6 @@
 msgid "Percent to brighten"
 msgstr "Prozent Konvergenz."
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Drops an attribute table."
-msgstr "Datenbank, Attributtabelle"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#, fuzzy
-msgid "Table to drop"
-msgstr "Kann nicht weitermachen."
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:1
 #, fuzzy
 msgid "Drops a column from selected attribute table"
@@ -6836,10 +7055,19 @@
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:5
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
-#, fuzzy
 msgid "Name of the column"
-msgstr "Anzahl der Spalten"
+#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+#, fuzzy
+msgid "Drops an attribute table."
+msgstr "Datenbank, Attributtabelle"
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+#, fuzzy
+msgid "Table to drop"
+msgstr "Kann nicht weitermachen."
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
 msgid "Imports attribute tables in various formats."
 msgstr "Importiert Attributtabellen aus verschiedenen Formaten."
@@ -6855,9 +7083,8 @@
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-#, fuzzy
 msgid "Name for output table"
-msgstr "Name der Ausgabedatei"
+msgstr "Name für die auszugebende Tabelle"
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
 msgid "Name for auto-generated unique key column"
@@ -6868,27 +7095,24 @@
 msgstr "Exportiert Attributtabellen in verschiedene Formate."
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#, fuzzy
 msgid "GRASS table name"
-msgstr "Eingabetabelle"
+msgstr "GRASS Tabellenname"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
 msgid "Table file to be exported or DB connection string"
 msgstr "Tabellendatei, die exportiert werden soll oder DB-Verbindung"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
 msgid "Table format"
-msgstr "Format"
+msgstr "Tabellenformat"
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
 msgstr ""
 #: ../locale/scriptstrings/db.test_to_translate.c:3
-#, fuzzy
 msgid "Test name"
-msgstr "Schriftname"
+msgstr "Testname"
 #: ../locale/scriptstrings/g.manual_to_translate.c:1
 msgid "Display the HTML man pages of GRASS"
@@ -6919,9 +7143,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, fusion"
-msgstr "Raster, Import, Konvertierung"
+msgstr "Raster, Bilder, Fusion"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
 msgid "sensor: LANDSAT"
@@ -6954,16 +7177,15 @@
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
 #, fuzzy
 msgid "raster output map prefix (e.g. 'brov')"
-msgstr "Präfix für TC-Ausgabe-Rasterkarten."
+msgstr "Überschreibe Ausgabedatei."
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
 msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
 msgstr ""
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, mosaicking"
+msgstr "Raster, Bilder, Mosaikieren"
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
 msgid "1st map for mosaic (top of image stack)."
@@ -6988,9 +7210,8 @@
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, import"
+msgstr "Raster, Bilder, Import"
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
 msgid "also import quality map (SM status map layer) and filter NDVI map"
@@ -7005,9 +7226,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, colors"
+msgstr "Raster, Import, Farben"
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
 msgid "LANDSAT red channel"
@@ -7042,9 +7262,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.oif_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, statistics"
-msgstr "Raster, Statistik"
+msgstr "Raster, Bilder, Statistik"
 #: ../locale/scriptstrings/i.oif_to_translate.c:3
 msgid "LANDSAT TM band 1."
@@ -7070,68 +7289,49 @@
 msgid "LANDSAT TM band 7."
 msgstr "LANDSAT TM Kanal 7."
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#: ../locale/scriptstrings/i.spectral_to_translate.c:1
+msgid ""
+"displays spectral response at user specified locations in group or images"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-#, fuzzy
-msgid "miscellaneous, projection"
-msgstr "Verschiedenes"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+msgid "imagery, raster, multispectral"
+msgstr "Bildverarbeitung, Raster, Multispektral"
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-#, fuzzy
-msgid "Input coordinate file (omit to read from stdin)"
-msgstr "Pfad zur Datei mit Regeln (\"-\" um Regeln von stdin zu lesen)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-msgid "Output coordinate file (omit to send to stdout)"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+msgid "group input"
 msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#, fuzzy
-msgid "Field separator"
-msgstr "Ausgabe Feld-Trennzeichen"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+msgid "raster input maps"
+msgstr "Eingabe-Rasterkarten"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
 #, fuzzy
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr "* Eingabe-Projektion der GCP-Tabelle: %s"
+msgid "write output to PNG image"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-#, fuzzy
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr "* Ausgabe-Projektion der GCP-Tabelle: %s"
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "Use LL WGS84 as input and current location as output projection"
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+msgid "Use image list and not group"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#, fuzzy
+msgid "Select multiple points"
+msgstr "Dateityp"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
-"places"
-msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+#, fuzzy
+msgid "label with coordinates instead of numbering"
+msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:1
 msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
 msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery"
-msgstr "Raster, Kartenalgebra"
+msgstr "Raster, Bilder"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:3
 msgid "use transformation rules for LANDSAT-4"
@@ -7174,6 +7374,61 @@
 msgid "raster output TC maps prefix"
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous, projection"
+msgstr "Verschiedenes, Projektion"
+#: ../locale/scriptstrings/m.proj_to_translate.c:3
+#, fuzzy
+msgid "Input coordinate file (omit to read from stdin)"
+msgstr ""
+"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
+"soll)."
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+msgid "Output coordinate file (omit to send to stdout)"
+msgstr ""
+"soll)."
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#, fuzzy
+msgid "Field separator"
+msgstr "Ausgabe Feld-Trennzeichen"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
+msgid "Input projection parameters (PROJ.4 style)"
+msgstr "* Eingabe-Projektion der GCP-Tabelle: %s"
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#, fuzzy
+msgid "Output projection parameters (PROJ.4 style)"
+msgstr "* Ausgabe-Projektion der GCP-Tabelle: %s"
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+msgid "Use LL WGS84 as input and current location as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+msgid "Use current location as input and LL WGS84 as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+msgid ""
+"Output long/lat in decimal degrees or other projections with many decimal "
+"places"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+msgid "Verbose mode (print projection parameters and filenames to stderr)"
+msgstr ""
 #: ../locale/scriptstrings/r.blend_to_translate.c:1
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr ""
@@ -7181,47 +7436,46 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:2
 #: ../raster/r.describe/main.c:54 ../raster/r.rescale.eq/main.c:46
-#: ../raster/r.surf.area/main.c:87 ../raster/r.coin/cmd_parms.c:39
+#: ../raster/r.surf.area/main.c:87 ../raster/r.coin/main.c:65
 #: ../raster/r.out.png/main.c:127 ../raster/r.distance/main.c:38
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.reclass/main.c:49
 #: ../raster/r.los/main.c:90 ../raster/r.drain/main.c:102
 #: ../raster/r.carve/main.c:73 ../raster/r.profile/main.c:49
 #: ../raster/r.texture/main.c:71 ../raster/r.basins.fill/main.c:53
 #: ../raster/r.sum/main.c:45 ../raster/r.sun/main.c:173
-#: ../raster/r.volume/main.c:57 ../raster/r.null/main.c:45
-#: ../raster/r.average/main.c:50 ../raster/r.lake/main.c:150
-#: ../raster/r.out.gridatb/main.c:48 ../raster/r.surf.idw2/main.c:60
-#: ../raster/r.transect/main.c:50 ../raster/r.mode/main.c:50
-#: ../raster/r.info/main.c:69 ../raster/r.compress/main.c:61
-#: ../raster/r.patch/main.c:53 ../raster/r.le/r.le.setup/main.c:58
-#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.le/r.le.trace/main.c:57
-#: ../raster/r.le/r.le.patch/main.c:48 ../raster/r.digit/main.c:44
-#: ../raster/r.circle/main.c:51 ../raster/r.surf.idw/main.c:103
-#: ../raster/r.thin/main.c:55 ../raster/r.surf.contour/main.c:62
-#: ../raster/r.topidx/main.c:41 ../raster/r.out.pov/main.c:120
-#: ../raster/r.covar/main.c:50 ../raster/r.out.arc/main.c:58
-#: ../raster/r.rescale/main.c:43 ../raster/r.random/main.c:51
-#: ../raster/r.sunmask/main.c:125 ../raster/r.his/main.c:62
-#: ../raster/r.topmodel/main.c:62 ../raster/r.kappa/main.c:52
-#: ../raster/r.median/main.c:46 ../raster/r.resamp.rst/main.c:146
-#: ../raster/r.surf.random/main.c:36 ../raster/r.surf.gauss/main.c:38
-#: ../raster/r.fill.dir/main.c:84 ../raster/r.timestamp/main.c:34
-#: ../raster/r.what/main.c:91 ../raster/r.random.surface/main.c:60
-#: ../raster/r.out.vtk/main.c:58 ../raster/r.out.bin/main.c:62
-#: ../raster/r.neighbors/main.c:105 ../raster/r.clump/main.c:46
-#: ../raster/r.what.color/main.c:87 ../raster/r.in.gridatb/main.c:44
-#: ../raster/r.random.cells/main.c:48 ../raster/r.to.vect/main.c:71
-#: ../raster/r.region/main.c:51 ../raster/r.out.ppm3/main.c:55
-#: ../raster/r.in.mat/main.c:90 ../raster/r.watershed/front/main.c:50
-#: ../raster/r.quant/main.c:46 ../raster/r.contour/main.c:85
-#: ../raster/r.cross/main.c:61 ../raster/r.out.mpeg/main.c:85
-#: ../raster/r.walk/main.c:183 ../raster/r.mapcalc/main.c:111
-#: ../raster/r.recode/main.c:51 ../raster/r.gwflow/main.c:223
-#: ../raster/wildfire/r.ros/main.c:212
+#: ../raster/r.volume/main.c:57 ../raster/r.average/main.c:50
+#: ../raster/r.lake/main.c:150 ../raster/r.out.gridatb/main.c:48
+#: ../raster/r.surf.idw2/main.c:60 ../raster/r.transect/main.c:50
+#: ../raster/r.mode/main.c:50 ../raster/r.info/main.c:69
+#: ../raster/r.compress/main.c:61 ../raster/r.patch/main.c:53
+#: ../raster/r.le/r.le.setup/main.c:58 ../raster/r.le/r.le.pixel/main.c:45
+#: ../raster/r.le/r.le.trace/main.c:57 ../raster/r.le/r.le.patch/main.c:48
+#: ../raster/r.digit/main.c:44 ../raster/r.circle/main.c:51
+#: ../raster/r.surf.idw/main.c:103 ../raster/r.thin/main.c:55
+#: ../raster/r.surf.contour/main.c:62 ../raster/r.topidx/main.c:41
+#: ../raster/r.out.pov/main.c:120 ../raster/r.covar/main.c:50
+#: ../raster/r.out.arc/main.c:58 ../raster/r.rescale/main.c:43
+#: ../raster/r.random/main.c:51 ../raster/r.sunmask/main.c:125
+#: ../raster/r.his/main.c:62 ../raster/r.topmodel/main.c:62
+#: ../raster/r.kappa/main.c:67 ../raster/r.median/main.c:46
+#: ../raster/r.resamp.rst/main.c:146 ../raster/r.surf.random/main.c:36
+#: ../raster/r.surf.gauss/main.c:38 ../raster/r.fill.dir/main.c:84
+#: ../raster/r.timestamp/main.c:34 ../raster/r.what/main.c:91
+#: ../raster/r.random.surface/main.c:60 ../raster/r.out.vtk/main.c:58
+#: ../raster/r.out.bin/main.c:62 ../raster/r.neighbors/main.c:105
+#: ../raster/r.clump/main.c:46 ../raster/r.what.color/main.c:87
+#: ../raster/r.in.gridatb/main.c:44 ../raster/r.random.cells/main.c:48
+#: ../raster/r.to.vect/main.c:71 ../raster/r.region/main.c:51
+#: ../raster/r.out.ppm3/main.c:55 ../raster/r.in.mat/main.c:90
+#: ../raster/r.watershed/front/main.c:50 ../raster/r.quant/main.c:46
+#: ../raster/r.contour/main.c:85 ../raster/r.cross/main.c:72
+#: ../raster/r.out.mpeg/main.c:85 ../raster/r.walk/main.c:183
+#: ../raster/r.mapcalc/main.c:111 ../raster/r.recode/main.c:51
+#: ../raster/r.gwflow/main.c:223 ../raster/wildfire/r.ros/main.c:212
 #: ../raster/wildfire/r.spreadpath/main.c:88
 #: ../raster/wildfire/r.spread/main.c:101 ../raster/r.resample/main.c:53
 #: ../raster/r.in.arc/main.c:59 ../raster/r.bitpattern/main.c:62
-#: ../raster/r.grow.distance/main.c:119 ../raster/r.grow/main.c:127
+#: ../raster/r.grow.distance/main.c:120 ../raster/r.grow/main.c:127
 #: ../raster/r.category/main.c:51
 #: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
 msgid "raster"
@@ -7252,14 +7506,12 @@
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#, fuzzy
 msgid "raster, elevation, interpolation"
-msgstr "Vektor, Interpolation"
+msgstr "Vektor, Höhenwerte, Interpolation"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#, fuzzy
 msgid "Raster map in which to fill nulls"
-msgstr "Rasterkarte, bei der die NULL-Datei editiert werden soll."
+msgstr "Rasterkarte, in der die NULL-Zellen gefüllt werden sollen."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
 msgid ""
@@ -7269,14 +7521,12 @@
 "umgebenden Werte gefüllt wurden."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-#, fuzzy
 msgid "Spline tension parameter"
-msgstr "Spannung (Tension) Parameter."
+msgstr "Spline-Spannung (Tension) Parameter."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-#, fuzzy
 msgid "Spline smoothing parameter"
-msgstr "Glättungs-(smooth) Parameter"
+msgstr "Spline-Glättungs-(smooth) Parameter"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
 msgid ""
@@ -7321,6 +7571,35 @@
 msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
 msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Create a MASK for limiting raster operation"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+msgid "raster, mask"
+msgstr "Raster, Maske"
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+#, fuzzy
+msgid "Raster map to use as MASK"
+msgstr "Rasterkarte, die umgeschlüsselt werden soll."
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+msgid "Create inverse MASK from specified 'maskcats' list"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
+msgid "Overwrite existing MASK"
+msgstr "Überschreibe existierende Maske (MASK)."
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Remove existing MASK (overrides other options)"
+msgstr "Entferne existierende Maske (MASK). Übersteuert andere Optionen."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 msgid "Downloads and imports data from WMS servers."
 msgstr ""
@@ -7347,9 +7626,8 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:38
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:49
-#, fuzzy
 msgid "Request"
-msgstr "Benötigt"
+msgstr "Anfrage"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:5
 msgid "Skip to downloading (to resume downloads faster)"
@@ -7427,12 +7705,12 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
 #, fuzzy
 msgid "Maximum columns to request at a time"
-msgstr "Mapserver, von dem Daten angefragt werden sollen."
+msgstr "Kann Daten der Tabelle nicht selektieren."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:34
 #, fuzzy
 msgid "Maximum rows to request at a time"
-msgstr "Maximale Distanz vom Punkt zum Netzwerk."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
 msgid "Additional options for r.tileset"
@@ -7474,50 +7752,20 @@
 msgid "Verbosity level"
 msgstr "Wasserniveau"
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Create a MASK for limiting raster operation"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#, fuzzy
-msgid "raster, mask"
-msgstr "Raster, Metadaten"
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-#, fuzzy
-msgid "Raster map to use as MASK"
-msgstr "Rasterkarte, die umgeschlüsselt werden soll."
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Overwrite existing MASK"
-msgstr "Überschreibe existierende Maske (MASK)."
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Remove existing MASK (overrides other options)"
-msgstr "Entferne existierende Maske (MASK). Übersteuert andere Optionen."
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 msgid ""
 "Export a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../raster/r.out.ascii/main.c:58 ../raster/r.out.gdal/main.c:394
+#: ../raster/r.out.ascii/main.c:58 ../raster/r.out.gdal/main.c:126
 #: ../raster/r.out.mat/main.c:61 ../raster/r.out.ppm/main.c:52
 #: ../raster/r.out.tiff/main.c:91
 msgid "raster, export"
 msgstr "Raster, Export"
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../raster/r.stats/main.c:102
+#: ../raster/r.stats/main.c:115
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr ""
 "Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die "
@@ -7529,14 +7777,13 @@
 "Creates raster plane map given dip (inclination), aspect (azimuth) and one "
 "point."
 msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorpunktkarte, die zufällig "
-"angeordnete Punkte enthalten."
+"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
+"Punkte enthalten."
 #: ../locale/scriptstrings/r.plane_to_translate.c:2
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-#, fuzzy
 msgid "raster, elevation"
-msgstr "Profildatei"
+msgstr "Raster, Höhenwerte"
 #: ../locale/scriptstrings/r.plane_to_translate.c:3
 #, fuzzy
@@ -7578,9 +7825,8 @@
 msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#, fuzzy
 msgid "raster, statistics, aggregation"
+msgstr "Raster, Statistik, Aggregation"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
 msgid "lesser val option that sets the <= area size limit [hectares]"
@@ -7600,9 +7846,10 @@
 msgstr "Berechnet eine lineare Regression von zwei Rasterkarten: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
-#: ../raster/r.statistics/main.c:59 ../raster/r.report/main.c:27
-#: ../raster/r.quantile/main.c:230 ../raster/r.univar/r.univar_main.c:73
-#: ../raster/r.stats/main.c:91 ../raster/r.statistics2/main.c:100
+#: ../raster/r.statistics/main.c:59 ../raster/r.report/main.c:64
+#: ../raster/r.quantile/main.c:243 ../raster/r.univar/r.univar_main.c:73
+#: ../raster/r.stats/main.c:104 ../raster/r.statistics2/main.c:100
+#: ../raster/r.statistics3/main.c:390
 msgid "raster, statistics"
@@ -7652,16 +7899,14 @@
 msgstr "A: Winkel der Sonne, gemessen von Norden (in Grad)."
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-#, fuzzy
 msgid "Factor for exaggerating relief"
-msgstr "Format für die Hangneigung."
+msgstr "Faktor für die Überhöhung des Reliefs"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-#, fuzzy
 msgid "Scale factor for converting horizontal units to elevation units"
 msgstr ""
-"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
-"wurde)."
+"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
+"Höheneinheiten"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
 msgid ""
@@ -7675,19 +7920,17 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#, fuzzy
 msgid "raster, tiling"
-msgstr "Raster, Projektion"
+msgstr "Raster, Kachelung"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#, fuzzy
 msgid "Produces shell script output"
-msgstr "Gebe im Shell-Skript-Style aus."
+msgstr "Erzeugt Ausgabe im Shell-Skript-Stil"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
 #, fuzzy
 msgid "Produces web map server query string output"
-msgstr "Erzeugt Shell-Skript Ausgabe."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:5
 #, fuzzy
@@ -7741,8 +7984,8 @@
 #: ../vector/v.vol.rst/main.c:239 ../vector/v.mkgrid/main.c:61
 #: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:44
 #: ../vector/v.voronoi/vo_main.c:117 ../vector/v.out.vtk/main.c:47
-#: ../vector/v.select/main.c:132 ../vector/v.surf.rst/main.c:147
-#: ../vector/v.buffer/main.c:254 ../vector/v.extract/main.c:91
+#: ../vector/v.surf.rst/main.c:147 ../vector/v.buffer/main.c:254
+#: ../vector/v.extract/main.c:91
 msgid "vector"
 msgstr "Vektor"
@@ -7752,9 +7995,8 @@
 msgstr "%d Linien zu Grenzen verwandelt"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#, fuzzy
 msgid "vector, centroid, area"
-msgstr "Vektor, Import"
+msgstr "Vektor, Zentroid, Fläche"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:3
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -7768,14 +8010,12 @@
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:6
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-#, fuzzy
 msgid "Name for output vector map"
-msgstr "Name der Ausgabe-Vektorkarte."
+msgstr "Name für die Ausgabe-Vektorkarte"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:5
-#, fuzzy
 msgid "Action to be taken"
-msgstr "Erzwinge das Löschen"
+msgstr "Aktion, die ausgeführt werden soll"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:6
 #: ../locale/scriptstrings/v.report_to_translate.c:6
@@ -7798,15 +8038,13 @@
 msgid ""
 "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
 "format"
-msgstr ""
-"Konvertiert alle alten GRASS sites (Version < 5.7) im aktuellen Mapset in "
-"Vektorkarten."
+msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
 #: ../vector/v.in.dxf/main.c:68 ../vector/v.in.ascii/main.c:48
-#: ../vector/v.in.ogr/main.c:102 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.in.ogr/main.c:101 ../vector/v.in.dwg/main.c:82
 #: ../vector/v.in.db/main.c:52
 msgid "vector, import"
@@ -7905,9 +8143,8 @@
 msgstr "Vermisse Spalte <%s> in der Tabelle <%s>."
 #: ../locale/scriptstrings/v.db.join_to_translate.c:6
-#, fuzzy
 msgid "Other table name"
-msgstr "Ausgabe-Tabellenname"
+msgstr "Anderer Tabellenname"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:7
 #, fuzzy
@@ -7996,9 +8233,8 @@
 msgstr "Altes Schema"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-#, fuzzy
 msgid "New schema"
-msgstr "Datenbank-Schema"
+msgstr "Neues Schema"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
 #, fuzzy
@@ -8021,9 +8257,8 @@
 msgstr "Mehr statistische Kennzahlen (Quartile und 90% Perzentil)."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#, fuzzy
 msgid "Name of data table"
-msgstr "Name der Datenbank-Datei."
+msgstr "Name der Datentabelle"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
@@ -8035,9 +8270,8 @@
 msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#, fuzzy
 msgid "Database driver"
-msgstr "Listet alle verfügbaren Datenbanktreiber auf."
+msgstr "Datenbanktreiber"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "WHERE conditions of SQL statement without 'where' keyword"
@@ -8059,9 +8293,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
-#, fuzzy
 msgid "Column to update"
-msgstr "Spaltentyp nicht unterstützt."
+msgstr "Spalte, die aktualisiert werden soll"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
 msgid ""
@@ -8070,9 +8303,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
 msgid "Column to query"
-msgstr "Spaltentypen stimmen nicht überein."
+msgstr "Spalte, die abgefragt werden soll"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
 msgid ""
@@ -8090,16 +8322,21 @@
 "Attributes."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#, fuzzy
 msgid "vector, area, dissolve"
-msgstr "Raster, Volumen, Konvertierung"
+msgstr "Raster, Fläche, Dissolve"
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:5
 #, fuzzy
-msgid "Layer number. If -1, all layers are extracted"
+msgid "Layer number. If -1, all layers are extracted."
 msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer dargestellt."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
 #, fuzzy
 msgid "Name of column used to dissolve common boundaries"
 msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
@@ -8124,6 +8361,20 @@
 msgid "Input type point, line or area"
 msgstr "Wähle Typ aus: Linie oder Fläche"
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+#, fuzzy
+msgid "Imports geonames.org country files into a GRASS vector points map."
+msgstr "von"
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
+msgid "vector, import, gazetteer"
+msgstr "Vektor, Import, Gazetteer"
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+msgid "Uncompressed geonames file from (with .txt extension)"
+msgstr ""
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
 msgid ""
 "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
@@ -8132,9 +8383,8 @@
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-#, fuzzy
 msgid "vector, import, GPS"
+msgstr "Vektor, Import, GPS"
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
 msgid "Download Waypoints from GPS"
@@ -8176,21 +8426,6 @@
 msgid "Port Garmin receiver is connected to"
 msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
-msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr "von"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-#, fuzzy
-msgid "vector, import, gazetteer"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-msgid "Uncompressed geonames file from (with .txt extension)"
-msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
 msgid ""
 "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
@@ -8208,14 +8443,12 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
-#, fuzzy
 msgid "Import waypoints"
-msgstr "Importiere Punkte..."
+msgstr "Importiere Wegpunkte"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
-#, fuzzy
 msgid "Import routes"
+msgstr "Importiere Routen"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
 msgid "Import track"
@@ -8269,9 +8502,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#, fuzzy
 msgid "Vector output map"
-msgstr "Keine Ausgabekarte angegeben."
+msgstr "Vektor-Ausgabekarte"
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
 #, fuzzy
@@ -8280,9 +8512,8 @@
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-#, fuzzy
 msgid "sites, vector, import"
+msgstr "Sites, Vektor, Import"
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
 #, fuzzy
@@ -8298,9 +8529,8 @@
 "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#, fuzzy
 msgid "vector, raster, statistics"
+msgstr "Vektor, Raster, Statistik"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
 msgid "Continue if upload column(s) already exist"
@@ -8339,14 +8569,12 @@
 msgstr "Gibt statistische Werte für eine Rasterkarte aus."
 #: ../locale/scriptstrings/v.report_to_translate.c:2
-#, fuzzy
 msgid "vector, report, statistics"
-msgstr "Vektor, Statistik"
+msgstr "Vektor, Bericht, Statistik"
 #: ../locale/scriptstrings/v.report_to_translate.c:3
-#, fuzzy
 msgid "Reverse sort the result"
-msgstr "Kehre die Auswahl um"
+msgstr "Sortiere die Ergebnisse rückwärts."
 #: ../locale/scriptstrings/v.report_to_translate.c:4
 msgid "Sort the result"
@@ -8358,9 +8586,8 @@
 msgstr "Wert zum Laden in die Attributtabelle."
 #: ../locale/scriptstrings/v.report_to_translate.c:8
-#, fuzzy
 msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
+msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
 #, fuzzy
@@ -8384,34 +8611,23 @@
 msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#, fuzzy
 msgid "Vector map to be queried"
-msgstr "Rasterkarte, die abgefragt werden soll."
+msgstr "Vektorkarte, die abgefragt werden soll."
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:7
 #, fuzzy
 msgid "Layer of the query vector containing data"
-msgstr "Eingabekarte enthält Linien."
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-#, fuzzy
 msgid "Column to be queried"
+msgstr "Spalte, die abgefragt werden soll."
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:9
 #, fuzzy
 msgid "Maximum query distance in map units"
 msgstr "Pufferdistanz in Karteneinheiten."
-#: ../locale/scriptstrings/gis.m_to_translate.c:1
-msgid "GIS manager for GRASS"
-msgstr "GIS Manager für GRASS."
-#: ../locale/scriptstrings/gis.m_to_translate.c:2
-#, fuzzy
-msgid "Name of GIS manager settings file (.grc)"
-msgstr "Name der MAT-Datei (v4)"
 #: ../misc/m.cogo/main.c:225
 msgid "miscellaneous"
@@ -8463,9 +8679,8 @@
 #: ../ps/ps.map/ps_vlines.c:55 ../ps/ps.map/ps_vareas.c:163
 #: ../ps/ps.map/ps_vpoints.c:71
-#, fuzzy
 msgid "Cannot load data from table"
-msgstr "Kann Daten nicht aus der Tabelle selektieren."
+msgstr "Kann Daten nicht aus der Tabelle laden."
 #: ../ps/ps.map/ps_vlines.c:83 ../ps/ps.map/ps_vareas.c:66
 #: ../ps/ps.map/ps_vareas.c:77 ../ps/ps.map/ps_vpoints.c:127
@@ -8527,9 +8742,9 @@
 msgstr "Lese Rasterkarte <%s> ..."
 #: ../ps/ps.map/ps_clrtbl.c:30 ../ps/ps.map/ps_fclrtbl.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Creating color table for <%s in %s>..."
-msgstr "Erstelle Farbtabelle für <%s in %s> ..."
+msgstr "Erstelle Farbtabelle für <%s in %s>..."
 #: ../ps/ps.map/ps_clrtbl.c:39 ../ps/ps.map/ps_fclrtbl.c:69
 msgid "Unable to read colors for colorbar"
@@ -8594,12 +8809,10 @@
 msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:51
-#, fuzzy
 msgid "Range information not available (run r.support)"
-msgstr "Bereich-Information nicht vorhanden. (Benutzen Sie r.support)."
+msgstr "Bereich-Information nicht vorhanden (Führen Sie r.support aus)."
 #: ../ps/ps.map/ps_fclrtbl.c:64
-#, fuzzy
 msgid "A floating point colortable must contain a range of values"
 msgstr "Eine Fließkommafarbtabelle muss eine Wertespanne enthalten."
@@ -8646,9 +8859,9 @@
 msgstr "Kann das Symbol nicht lesen, benutze das Standard-Symbol."
 #: ../ps/ps.map/ps_vpoints.c:181
-#, fuzzy, c-format
+#, c-format
 msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr "Attribut hat ungültige Größe (%.3f) für Kategorie %d."
+msgstr "Attribut hat ungültige Größe [%.3f] für Kategorie [%d]."
 #: ../ps/ps.map/do_plt.c:41
 msgid "Reading point/line file ..."
@@ -8755,7 +8968,7 @@
 #: ../ps/ps.map/read_cfg.c:64
 #, fuzzy, c-format
 msgid "Paper '%s' not found, using defaults"
-msgstr "Papier '%s' nicht gefunden, verwende Standardwerte."
+msgstr "Papier <%s> nicht gefunden, verwende Standardwerte."
 #: ../raster/r.describe/describe.c:46
 #, fuzzy, c-format
@@ -8771,7 +8984,7 @@
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr "Gibt eine kurze Liste der Kategoriewerte einer Rasterkarte aus."
-#: ../raster/r.describe/main.c:67 ../raster/r.stats/main.c:115
+#: ../raster/r.describe/main.c:67 ../raster/r.stats/main.c:128
 msgid "String representing no data cell value"
 msgstr "Zeichenkette, die NODATA-Werte repräsentiert."
@@ -8787,7 +9000,7 @@
 msgid "Only print the range of the data"
 msgstr "Gebe nur die Spanne der Daten aus."
-#: ../raster/r.describe/main.c:89 ../raster/r.stats/main.c:175
+#: ../raster/r.describe/main.c:89 ../raster/r.stats/main.c:188
 msgid "Suppress reporting of any NULLs"
 msgstr "Unterdrücke die Ausgabe von NULL-Werten."
@@ -8841,7 +9054,6 @@
 msgstr ""
 #: ../raster/r.rescale.eq/get_stats.c:20 ../raster/r.rescale/get_range.c:25
-#: ../raster/r.colors/stats.c:38
 #, c-format
 msgid "Reading %s ..."
 msgstr "Lese %s..."
@@ -8851,7 +9063,6 @@
 msgstr "Raster, Resamplen"
 #: ../raster/r.resamp.stats/main.c:261
-#, fuzzy
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr "Erzeugt eine neue Rasterkarte gröberer Auflösung mittels Aggregation."
@@ -8859,7 +9070,7 @@
 msgid "Aggregation method"
 msgstr "Aggregationsmethode."
-#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:147
+#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:154
 msgid "Propagate NULLs"
 msgstr "Reiche NULLs durch"
@@ -8873,7 +9084,6 @@
 msgstr "Unbekannte Methode <%s>."
 #: ../raster/r.resamp.stats/main.c:374 ../raster/r.resamp.interp/main.c:320
-#: ../raster/r.colors/main.c:335
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr "Kann die Farbtabelle für %s nicht lesen."
@@ -8986,12 +9196,12 @@
 "konvertieren, zwecks Überprüfung."
 #: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:317
-#: ../vector/v.in.ogr/main.c:499
+#: ../vector/v.in.ogr/main.c:493
 msgid "Over-riding projection check"
 msgstr "Übersteuere die Überprüfung der Projektion."
 #: ../raster/r.external/main.c:107 ../raster/r.in.gdal/main.c:328
-#: ../vector/v.in.ogr/main.c:508
+#: ../vector/v.in.ogr/main.c:502
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -9009,21 +9219,19 @@
 msgstr "Datensatz PROJ_INFO:\n"
 #: ../raster/r.external/main.c:150 ../raster/r.in.gdal/main.c:371
-#: ../vector/v.in.ogr/main.c:524 ../vector/v.in.ogr/main.c:531
+#: ../vector/v.in.ogr/main.c:518 ../vector/v.in.ogr/main.c:525
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "Zu importierender Datensatz PROJ_INFO:\n"
 #: ../raster/r.external/main.c:172
-#, fuzzy
 msgid ""
 "\n"
 "You can use the -o flag to r.external to override this check and use the "
 "location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
-"Projektion zu übersteuern und die Projektionsinformation der Location für "
-"diesen Import zu verwenden.\n"
+"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern "
+"und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
 #: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:396
 msgid ""
@@ -9035,7 +9243,7 @@
 "erzeugen.\n"
 #: ../raster/r.external/main.c:180 ../raster/r.in.gdal/main.c:401
-#: ../vector/v.in.ogr/main.c:582
+#: ../vector/v.in.ogr/main.c:576
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
 "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
@@ -9056,9 +9264,9 @@
 #: ../raster/r.external/main.c:315
-#, fuzzy, c-format
+#, c-format
 msgid "Copying color table for %s"
+msgstr "Kopiere Farbtabelle für %s."
 #: ../raster/r.external/main.c:333
 #, fuzzy, c-format
@@ -9106,11 +9314,11 @@
 msgstr "Kann nicht in die Datei schreiben."
 #: ../raster/r.external/main.c:470
-#, fuzzy, c-format
+#, c-format
 msgid "Creating support files for %s"
-msgstr "Erstelle Support-Dateien für <%s>..."
+msgstr "Erstelle Support-Dateien für <%s>."
-#: ../raster/r.external/main.c:480 ../raster/r.in.gdal/main.c:922
+#: ../raster/r.external/main.c:480
 #, c-format
 msgid "<%s> created"
 msgstr "<%s> erzeugt."
@@ -9128,11 +9336,11 @@
 msgstr "Zu importierende Rasterdatei."
 #: ../raster/r.external/main.c:512 ../raster/r.external/main.c:522
-#: ../raster/r.out.gdal/main.c:404 ../raster/r.out.gdal/main.c:440
+#: ../raster/r.out.gdal/main.c:141 ../raster/r.out.gdal/main.c:177
 #: ../raster/r.in.gdal/main.c:90 ../raster/r.in.gdal/main.c:94
 #: ../raster/r.colors/main.c:170 ../raster/r.colors.out/main.c:68
-#: ../vector/v.in.ascii/main.c:57 ../vector/v.in.ogr/main.c:114
-#: ../vector/v.in.ogr/main.c:118
+#: ../vector/v.in.ascii/main.c:57 ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:117
 msgid "Required"
 msgstr "Benötigt"
@@ -9142,9 +9350,8 @@
 msgstr "Name der neuen Datenbank."
 #: ../raster/r.external/main.c:528
-#, fuzzy
 msgid "Band to select"
-msgstr "Kein Grafik-Fenster ausgewählt."
+msgstr "Zu selektierender Kanal"
 #: ../raster/r.external/main.c:536 ../raster/r.in.ascii/main.c:85
 #: ../raster/r.in.bin/main.c:166 ../raster/r.in.gdal/main.c:114
@@ -9161,7 +9368,7 @@
 msgstr "Übersteuere die Projektion (verwende Projektion der Location)."
 #: ../raster/r.external/main.c:546 ../raster/r.in.gdal/main.c:130
-#: ../vector/v.in.ogr/main.c:229
+#: ../vector/v.in.ogr/main.c:228
 msgid "Extend location extents based on new dataset"
 msgstr "Vergrößere die Location basierend auf dem neuen Datensatz."
@@ -9170,19 +9377,17 @@
 msgstr ""
 #: ../raster/r.external/main.c:554 ../raster/r.in.gdal/main.c:134
-#: ../vector/v.in.ogr/main.c:200
+#: ../vector/v.in.ogr/main.c:199
 msgid "List supported formats and exit"
 msgstr "Zeige unterstützte Formate an und beendet sich."
 #: ../raster/r.external/main.c:584
-#, fuzzy
 msgid "Name for input source not specified"
-msgstr "Name der Ausgabe-Rasterkarte nicht angegeben."
+msgstr "Name der Eingabe-Qulle nicht angegeben."
 #: ../raster/r.external/main.c:587
-#, fuzzy
 msgid "input= and source= are mutually exclusive"
-msgstr "weight= und -c schließen sich gegenseitig aus."
+msgstr "'input=' und 'source=' schließen sich gegenseitig aus."
 #: ../raster/r.external/main.c:590 ../raster/r.in.gdal/main.c:202
 msgid "Name for output raster map not specified"
@@ -9198,14 +9403,13 @@
 msgstr "Der ausgewählte Kanal (%d) existiert nicht."
 #: ../raster/r.external/main.c:618
-#, fuzzy
 msgid "Unable to set window"
-msgstr "Kann die Größe nicht setzen."
+msgstr "Kann das Fenster nicht setzen."
 #: ../raster/r.resamp.interp/main.c:74
-#, fuzzy
 msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr "Generiert eine Rasterkarte mit Wassereinzugsgebieten."
+msgstr ""
+"Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
 #: ../raster/r.resamp.interp/main.c:83
 msgid "Interpolation method"
@@ -9216,40 +9420,40 @@
 msgid "Invalid method: %s"
 msgstr "Ungültige Methode: %s."
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
-msgstr "Erstelle den Bericht ..."
-#: ../raster/r.coin/cmd_parms.c:41
+#: ../raster/r.coin/main.c:67
 #, fuzzy
 msgid ""
 "Tabulates the mutual occurrence (coincidence) of categories for two raster "
 "map layers."
 msgstr "Reskaliert die Spanne der Kategoriewerte einer Rasterkarte."
-#: ../raster/r.coin/cmd_parms.c:49
+#: ../raster/r.coin/main.c:75
 msgid "Name of first raster map"
 msgstr "Name der ersten Rasterkarte."
-#: ../raster/r.coin/cmd_parms.c:56
+#: ../raster/r.coin/main.c:82
 msgid "Name of second raster map"
 msgstr "Name der zweiten Rasterkarte."
-#: ../raster/r.coin/cmd_parms.c:62
+#: ../raster/r.coin/main.c:88
 msgid "Unit of measure"
 msgstr "Maßeinheit"
-#: ../raster/r.coin/cmd_parms.c:64
+#: ../raster/r.coin/main.c:90
 msgid ""
 "c(ells), p(ercent), x(percent of category [column]), y(percent of category "
 "[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
-#: ../raster/r.coin/cmd_parms.c:71
+#: ../raster/r.coin/main.c:97
 msgid "Wide report, 132 columns (default: 80)"
 msgstr "Breite Ausgabe mit 132 Spalten (Standard: 80)"
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr "Erstelle den Bericht ..."
 #: ../raster/r.coin/make_coin.c:44
 #, c-format
 msgid "Tabulating Coincidence between '%s' and '%s'"
@@ -9831,13 +10035,12 @@
 "Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
 #: ../raster/r.carve/main.c:74
-#, fuzzy
 msgid ""
 "Takes vector stream data, transforms it to raster and subtracts depth from "
 "the output DEM."
 msgstr ""
-"Nimmt eine Vektorkarte als Fluss, transformiert diese in das Rasterformat "
-"und substrahiert die Tiefe vom Ausgabe-DEM."
+"Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat "
+"und subtrahiert die Tiefe vom Ausgabe-DEM."
 #: ../raster/r.carve/main.c:79
 msgid "Name of input raster elevation map"
@@ -10055,7 +10258,7 @@
 #: ../raster/r.texture/main.c:348
 #, c-format
-msgid "Calculated measure #%d (56 measures available)"
+msgid "Calculated measure #%d <%s%s> (56 measures available)"
 msgstr ""
 #: ../raster/r.texture/h_measure.c:84
@@ -10124,7 +10327,7 @@
 #: ../raster/r.what/main.c:335
 #, fuzzy, c-format
 msgid "Error reading <%s>"
-msgstr "Fehler beim Lesen der Datenspanne für <%s>."
+msgstr "Fehler beim Lesen der Karte '%s'."
 #: ../raster/r.sum/main.c:46
 msgid "Sums up the raster cell values."
@@ -10181,18 +10384,16 @@
 #: ../raster/simwe/r.sim.sediment/main.c:152
 #: ../raster/simwe/r.sim.sediment/main.c:158
 #: ../raster/simwe/r.sim.sediment/main.c:166
-#: ../raster/simwe/r.sim.sediment/main.c:174
-#: ../raster/simwe/r.sim.water/main.c:125
-#: ../raster/simwe/r.sim.water/main.c:130
-#: ../raster/simwe/r.sim.water/main.c:135
-#: ../raster/simwe/r.sim.water/main.c:142
-#: ../raster/simwe/r.sim.water/main.c:151
-#: ../raster/simwe/r.sim.water/main.c:158
-#: ../raster/simwe/r.sim.water/main.c:167
-#: ../raster/simwe/r.sim.water/main.c:173
-#: ../raster/simwe/r.sim.water/main.c:181
-#: ../raster/simwe/r.sim.water/main.c:188
-#: ../raster/simwe/r.sim.water/main.c:195
+#: ../raster/simwe/r.sim.water/main.c:126
+#: ../raster/simwe/r.sim.water/main.c:131
+#: ../raster/simwe/r.sim.water/main.c:136
+#: ../raster/simwe/r.sim.water/main.c:143
+#: ../raster/simwe/r.sim.water/main.c:152
+#: ../raster/simwe/r.sim.water/main.c:159
+#: ../raster/simwe/r.sim.water/main.c:168
+#: ../raster/simwe/r.sim.water/main.c:174
+#: ../raster/simwe/r.sim.water/main.c:182
+#: ../raster/simwe/r.sim.water/main.c:189
 #: ../raster/r.watershed/front/main.c:56 ../raster/r.watershed/front/main.c:64
 #: ../raster/r.watershed/front/main.c:72 ../raster/r.watershed/front/main.c:81
 #: ../raster/r.watershed/front/main.c:90 ../raster/r.watershed/front/main.c:99
@@ -10258,15 +10459,14 @@
 #: ../raster/r.sun/main.c:289 ../raster/r.sun/main.c:298
 #: ../raster/r.sun/main.c:307 ../raster/r.sun/main.c:316
-#: ../raster/r.sun/main.c:325 ../raster/simwe/r.sim.sediment/main.c:180
-#: ../raster/simwe/r.sim.sediment/main.c:187
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#: ../raster/simwe/r.sim.sediment/main.c:200
-#: ../raster/simwe/r.sim.sediment/main.c:207
-#: ../raster/simwe/r.sim.water/main.c:201
-#: ../raster/simwe/r.sim.water/main.c:207
-#: ../raster/simwe/r.sim.water/main.c:213
-#: ../raster/simwe/r.sim.water/main.c:220 ../raster/r.resamp.rst/main.c:185
+#: ../raster/r.sun/main.c:325 ../raster/simwe/r.sim.sediment/main.c:181
+#: ../raster/simwe/r.sim.sediment/main.c:188
+#: ../raster/simwe/r.sim.sediment/main.c:195
+#: ../raster/simwe/r.sim.sediment/main.c:201
+#: ../raster/simwe/r.sim.sediment/main.c:208
+#: ../raster/simwe/r.sim.water/main.c:204
+#: ../raster/simwe/r.sim.water/main.c:210
+#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.resamp.rst/main.c:185
 #: ../raster/r.resamp.rst/main.c:193 ../raster/r.resamp.rst/main.c:201
 #: ../raster/r.resamp.rst/main.c:209 ../raster/r.resamp.rst/main.c:217
 #: ../raster/r.resamp.rst/main.c:281 ../raster/r.watershed/front/main.c:117
@@ -10396,76 +10596,154 @@
 "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
 "Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
-#: ../raster/r.volume/main.c:69
+#: ../raster/r.volume/main.c:65
 msgid "Existing raster map representing data that will be summed within clumps"
 msgstr ""
 "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
 "aufsummiert werden."
-#: ../raster/r.volume/main.c:77
+#: ../raster/r.volume/main.c:71
 msgid "Existing raster map, preferably the output of r.clump"
 msgstr "Existierende Rasterkarte, idealerweise die Ausgabekarte von r.clump."
-#: ../raster/r.volume/main.c:84
+#: ../raster/r.volume/main.c:76
 msgid "Vector points map to contain clump centroids"
 msgstr "Vektorkarte, die die Zentroide der Daten-\"Klumpen\" enthalten soll."
-#: ../raster/r.volume/main.c:88
+#: ../raster/r.volume/main.c:80
 msgid "Generate unformatted report"
 msgstr "Erzeuge unformatierten Report."
-#: ../raster/r.volume/main.c:117
+#: ../raster/r.volume/main.c:109
 msgid "No data map specified"
 msgstr "Keine Eingabekarte angegeben."
-#: ../raster/r.volume/main.c:140
+#: ../raster/r.volume/main.c:132
 msgid "Unable to open centroids vector points map"
 msgstr "Kann die Vektorkarte mit Zentroiden nicht öffnen."
-#: ../raster/r.volume/main.c:162
+#: ../raster/r.volume/main.c:154
 msgid "Data or Clump file not open"
 msgstr "Daten- oder Klumpendatei nicht geöffnet."
-#: ../raster/r.null/main.c:46
-msgid "Creates explicitly the NULL-value bitmap file."
-msgstr "Erzeugt ausdrücklich eine NULL-Wert Bitmap-Datei."
+#: ../raster/r.null/main.c:58
+#, fuzzy
+msgid "raster, null data"
+msgstr "Raster, Metadaten"
-#: ../raster/r.null/main.c:54
+#: ../raster/r.null/main.c:59
+#, fuzzy
+msgid "Manages NULL-values of given raster map."
+msgstr "Mapset der Eingabe-Rasterkarte."
+#: ../raster/r.null/main.c:62
 msgid "Raster map for which to edit null file"
-#: ../raster/r.null/main.c:62 ../raster3d/base/r3.null.main.c:63
+#: ../raster/r.null/main.c:70 ../raster3d/base/r3.null.main.c:63
 msgid "List of cell values to be set to NULL"
 msgstr "Liste von Werten, die auf NULL gesetzt werden sollen."
-#: ../raster/r.null/main.c:69 ../raster3d/base/r3.null.main.c:70
+#: ../raster/r.null/main.c:77 ../raster3d/base/r3.null.main.c:70
 msgid "The value to replace the null value by"
 msgstr "Wert, der den NULL-Werte ersetzen soll."
-#: ../raster/r.null/main.c:73
+#: ../raster/r.null/main.c:81
 msgid "Only do the work if the map is floating-point"
 msgstr "Nur ausführen, wenn die Karte Fließkommawerte enthält."
-#: ../raster/r.null/main.c:77
+#: ../raster/r.null/main.c:85
 msgid "Only do the work if the map is integer"
 msgstr "Nur ausführen, wenn die Karte ganze Zahlen enthält."
-#: ../raster/r.null/main.c:82
+#: ../raster/r.null/main.c:90
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
 msgstr ""
 "Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
 "existiert."
-#: ../raster/r.null/main.c:87
+#: ../raster/r.null/main.c:95
 msgid "Create NULL-value bitmap file validating all data cells"
 msgstr ""
 "Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
 "erklärt."
-#: ../raster/r.null/main.c:91
+#: ../raster/r.null/main.c:99
 msgid "Remove NULL-value bitmap file"
 msgstr "Entferne NULL-Wert Bitmap-Datei."
+#: ../raster/r.null/main.c:117
+#, c-format
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
+msgstr ""
+#: ../raster/r.null/main.c:123
+#, fuzzy, c-format
+msgid "Raster map <%s> is not in your mapset <%s>"
+msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
+#: ../raster/r.null/main.c:130
+#, fuzzy, c-format
+msgid "%s is illegal entry for null"
+msgstr "Ungültiger Wert für NULL."
+#: ../raster/r.null/main.c:137
+#, fuzzy, c-format
+msgid "Raster map <%s> already has a null bitmap file"
+msgstr "Die Rasterkarte <%s> existiert bereits und wird überschrieben."
+#: ../raster/r.null/main.c:141
+#, fuzzy, c-format
+msgid "<%s> is integer raster map (CELL)"
+msgstr "Name der Terrain Rasterkarte (DEM)."
+#: ../raster/r.null/main.c:145
+#, c-format
+msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr ""
+#: ../raster/r.null/main.c:151
+#, fuzzy, c-format
+msgid "<%s> is floating pointing raster map"
+msgstr "Rasterkarte mit Startpunkten."
+#: ../raster/r.null/main.c:169
+#, fuzzy, c-format
+msgid "Writing new null file for raster map <%s>..."
+msgstr "Schreibe neue NULL-Datei für Karte <%s>... "
+#: ../raster/r.null/main.c:176
+#, fuzzy, c-format
+msgid "Error writing null row %d"
+msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
+#: ../raster/r.null/main.c:181 ../raster/r.null/main.c:194
+#, fuzzy, c-format
+msgid "Raster map <%s> modified."
+msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
+#: ../raster/r.null/main.c:188
+#, fuzzy, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr "Entferne NULL-Datei für <%s>...\n"
+#: ../raster/r.null/main.c:258
+#, fuzzy, c-format
+msgid "%s: %s: illegal value spec"
+msgstr "%s: ungültiger Wert."
+#: ../raster/r.null/main.c:260 ../raster3d/base/mask_functions.c:100
+#, c-format
+msgid "%s: illegal value spec"
+#: ../raster/r.null/main.c:327
+#, fuzzy, c-format
+msgid "Writing new data for raster map <%s>..."
+msgstr "Schreibe Rasterkarte <%s>..."
 #: ../raster/r.average/main.c:52
 msgid ""
 "Finds the average of values in a cover map within areas assigned the same "
@@ -10509,18 +10787,16 @@
 #: ../raster/r.lake/main.c:163
-#, fuzzy
 msgid "Name for output raster map with lake"
+msgstr "Name der Ausgabe-Rasterkarte mit See."
 #: ../raster/r.lake/main.c:168
 msgid "Seed point coordinates"
-msgstr "Koordinaten der Saatpunkte"
+msgstr "Koordinaten der Startpunkte"
 #: ../raster/r.lake/main.c:177
-#, fuzzy
 msgid "Name of raster map with seed (at least 1 cell > 0)"
-msgstr "Name der Rasterkarte, die als Maske (MASK) benutzt werden soll."
+msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
 #: ../raster/r.lake/main.c:183
 msgid "Use negative depth values for lake raster map"
@@ -10528,27 +10804,31 @@
 #: ../raster/r.lake/main.c:188
 msgid "Overwrite seed map with result (lake) map"
-msgstr "Überschreibe die Saatkarte mit der resultierenden Seekarte."
+msgstr ""
+"Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
 #: ../raster/r.lake/main.c:194
-#, fuzzy
 msgid "Both seed map and coordinates cannot be specified"
 msgstr ""
-"Sowohl die Saatkarte als auch die Koordinaten können nicht verwendet werden."
+"Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig "
+"verwendet werden."
 #: ../raster/r.lake/main.c:197
 msgid "Seed map or seed coordinates must be set!"
-msgstr "Die Saatkarte oder Saatkoordinaten müssen angegeben werden."
+msgstr ""
+"Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben "
+"werden."
+# Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
 #: ../raster/r.lake/main.c:200
 msgid "Seed coordinates and output map lake= must be set!"
 msgstr ""
 #: ../raster/r.lake/main.c:203
-#, fuzzy
 msgid "Both lake and overwrite cannot be specified"
 msgstr ""
+"Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet "
+"werden."
 #: ../raster/r.lake/main.c:206
 msgid "Output lake map or overwrite flag must be set!"
@@ -10557,9 +10837,8 @@
 "werden."
 #: ../raster/r.lake/main.c:236
-#, fuzzy
 msgid "Seed point outside the current region"
-msgstr "Saatpunkt außerhalb der aktuellen Region."
+msgstr "Startpunkt außerhalb der aktuellen Region."
 #: ../raster/r.lake/main.c:255
 msgid "G_malloc: out of memory"
@@ -10602,99 +10881,90 @@
 msgid "Supported formats:\n"
 msgstr "Unterstützte Formate:\n"
-#: ../raster/r.out.gdal/main.c:112
-msgid "Unable to get raster band"
-msgstr "Kann den Rasterkanal nicht bekommen."
+#: ../raster/r.out.gdal/main.c:125
+#, fuzzy
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
-#: ../raster/r.out.gdal/main.c:228 ../raster/r.out.gdal/main.c:234
-msgid "Unable to allocate buffer for reading raster map"
-msgstr "Kann keinen Speicherplatz zum Lesen der Rasterkarte belegen."
+#: ../raster/r.out.gdal/main.c:130
+msgid "List supported output formats"
+msgstr "Zeige unterstützte Dateiformate."
-#: ../raster/r.out.gdal/main.c:268 ../raster/r.out.gdal/main.c:299
-#: ../raster/r.out.gdal/main.c:330
-msgid "Unable to write GDAL raster file"
-msgstr "Kann GDAL-Rasterdatei nicht schreiben."
+#: ../raster/r.out.gdal/main.c:135
+#, fuzzy
+msgid "Do not export long colortable"
+msgstr "Lösche existierende Farbtabelle."
-#: ../raster/r.out.gdal/main.c:339
-#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d was "
-"used to represent no-data values in the input map.You can specify nodata "
-"value by %s parameter."
+#: ../raster/r.out.gdal/main.c:136
+msgid "Only applicable to Byte or UInt16 data types."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:344
-#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g was "
-msgstr ""
-#: ../raster/r.out.gdal/main.c:393
-msgid "Exports GRASS raster map into GDAL supported formats."
-msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
-#: ../raster/r.out.gdal/main.c:398
-msgid "List supported output formats"
-msgstr "Zeige unterstützte Dateiformate."
-#: ../raster/r.out.gdal/main.c:403
+#: ../raster/r.out.gdal/main.c:140
 msgid "Name of raster map (or group) to export"
 msgstr "Name der Rasterkarte (oder Gruppe), die exportiert werden soll."
-#: ../raster/r.out.gdal/main.c:410
+#: ../raster/r.out.gdal/main.c:147
 msgid "GIS format to write (case sensitive, see also -l flag)"
 msgstr ""
 "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
 "beachten, siehe auch den Schalter -l)."
-#: ../raster/r.out.gdal/main.c:431
+#: ../raster/r.out.gdal/main.c:168
 msgid "File type"
 msgstr "Dateityp"
-#: ../raster/r.out.gdal/main.c:439
+#: ../raster/r.out.gdal/main.c:176
 msgid "Name for output raster file"
-#: ../raster/r.out.gdal/main.c:445
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed."
+#: ../raster/r.out.gdal/main.c:183
+#, fuzzy
+msgid "Creation option(s) to pass to the output format driver"
 msgstr ""
 "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
 "Optionen angegeben werden."
-#: ../raster/r.out.gdal/main.c:453
-msgid "Metadata key passed on the output dataset if possible"
+#: ../raster/r.out.gdal/main.c:185
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
 msgstr ""
-#: ../raster/r.out.gdal/main.c:462
+#: ../raster/r.out.gdal/main.c:193
+msgid "Metadata key(s) and value(s) to include"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:195
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:204
 msgid "Assign a specified nodata value to output bands"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:480 ../raster/r.in.gdal/main.c:199
-#: ../raster/r.proj/main.c:257 ../vector/v.in.ogr/main.c:275
-#: ../vector/v.in.ogr/main.c:327 ../vector/v.proj/main.c:163
+#: ../raster/r.out.gdal/main.c:224 ../raster/r.in.gdal/main.c:199
+#: ../raster/r.proj/main.c:257 ../vector/v.in.ogr/main.c:269
+#: ../vector/v.in.ogr/main.c:321 ../vector/v.proj/main.c:163
 #, c-format
 msgid "Required parameter <%s> not set"
 msgstr "Benötigter Parameter <%s> wurde nicht angegeben."
-#: ../raster/r.out.gdal/main.c:494
+#: ../raster/r.out.gdal/main.c:237
 #, c-format
 msgid "Raster map or group <%s> not found"
 msgstr "Rasterkarte oder Gruppe <%s> nicht gefunden."
-#: ../raster/r.out.gdal/main.c:498
+#: ../raster/r.out.gdal/main.c:241
 #, c-format
 msgid "No raster maps in group <%s>"
 msgstr "Keine Rasterkarten in der Gruppe <%s>."
-#: ../raster/r.out.gdal/main.c:512
+#: ../raster/r.out.gdal/main.c:255
 #, c-format
 msgid "Unable to get <%s> driver"
 msgstr "Kann den Treiber <%s> nicht bekommen."
-#: ../raster/r.out.gdal/main.c:518
+#: ../raster/r.out.gdal/main.c:261
 #, c-format
 msgid ""
 "Driver <%s> does not support direct writing. Using MEM driver for "
@@ -10703,56 +10973,87 @@
 "Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-"
 "Treiber für einen Zwischendatensatz."
-#: ../raster/r.out.gdal/main.c:523
+#: ../raster/r.out.gdal/main.c:266
 msgid "Unable to get in-memory raster driver"
 msgstr "Kann den 'in-memory' Raster-Treiber nicht bekommen."
-#: ../raster/r.out.gdal/main.c:527
+#: ../raster/r.out.gdal/main.c:270
 #, c-format
 msgid "Driver <%s> does not support creating rasters"
 msgstr "Der Treiber <%s> unterstützt die Erzeugung von Rasterdaten nicht."
-#: ../raster/r.out.gdal/main.c:652
+#: ../raster/r.out.gdal/main.c:400
 #, c-format
 msgid "Exporting to GDAL data type: %s"
 msgstr ""
-#: ../raster/r.out.gdal/main.c:672
+#: ../raster/r.out.gdal/main.c:420
 msgid "Output file name not specified"
 msgstr "Name der Ausgabedatei nicht angegeben."
-#: ../raster/r.out.gdal/main.c:678
+#: ../raster/r.out.gdal/main.c:426
 msgid "Unable to create dataset using memory raster driver"
 msgstr "Kann den Datensatz nicht mit 'memory' Raster-Treiber erzeugen."
-#: ../raster/r.out.gdal/main.c:687
+#: ../raster/r.out.gdal/main.c:435
 #, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
 msgstr "Kann den Datensatz <%s> nicht mit dem Treiber <%s> erzeugen."
-#: ../raster/r.out.gdal/main.c:702
+#: ../raster/r.out.gdal/main.c:450
 msgid "Unable to set geo transform"
 msgstr "Kann geo transform nicht setzen."
-#: ../raster/r.out.gdal/main.c:710
+#: ../raster/r.out.gdal/main.c:458
 msgid "Unable to set projection"
 msgstr "Kann Projektion nicht setzten."
-#: ../raster/r.out.gdal/main.c:720
+#: ../raster/r.out.gdal/main.c:468
 #, c-format
 msgid "Exporting raster map <%s> (band %d)..."
 msgstr "Exportiere Rasterkarte <%s> (Kanal %d)..."
-#: ../raster/r.out.gdal/main.c:728
+#: ../raster/r.out.gdal/main.c:476
 #, c-format
 msgid "Unable to export raster map <%s>"
 msgstr "Kann die Rasterkarte <%s> nicht exportieren."
-#: ../raster/r.out.gdal/main.c:738
+#: ../raster/r.out.gdal/main.c:486
 #, c-format
 msgid "Unable to create raster map <%s> using driver <%s>"
 msgstr "Kann Rasterkarte <%s> mit dem Treiber <%s> nicht erzeugen."
+#: ../raster/r.out.gdal/export_band.c:52
+msgid "Unable to get raster band"
+msgstr "Kann den Rasterkanal nicht bekommen."
+#: ../raster/r.out.gdal/export_band.c:178
+#: ../raster/r.out.gdal/export_band.c:184
+msgid "Unable to allocate buffer for reading raster map"
+msgstr "Kann keinen Speicherplatz zum Lesen der Rasterkarte belegen."
+#: ../raster/r.out.gdal/export_band.c:218
+#: ../raster/r.out.gdal/export_band.c:249
+#: ../raster/r.out.gdal/export_band.c:280
+msgid "Unable to write GDAL raster file"
+msgstr "Kann GDAL-Rasterdatei nicht schreiben."
+#: ../raster/r.out.gdal/export_band.c:289
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d was "
+"used to represent no-data values in the input map. You can specify nodata "
+"value by %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:294
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g was "
+msgstr ""
 #: ../raster/r.in.bin/main.c:124
 msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
@@ -10854,9 +11155,8 @@
 msgstr ""
 #: ../raster/r.in.bin/main.c:244
-#, fuzzy
 msgid "Bad number of bytes per cell"
-msgstr "        Anzahl der Bytes pro Zelle"
+msgstr "Schlechte Anzahl von Bytes pro Zelle."
 #: ../raster/r.in.bin/main.c:250
 msgid "Byte Swapping Turned On."
@@ -10994,7 +11294,8 @@
 msgid "Cannot get row"
 msgstr "Kann Zeile nicht bekommen."
-#: ../raster/r.surf.idw2/read_cell.c:31 ../raster/r.series/main.c:166
+#: ../raster/r.surf.idw2/read_cell.c:31 ../raster/r.colors/stats.c:41
+#: ../raster/r.colors/stats.c:96 ../raster/r.series/main.c:178
 #, c-format
 msgid "Reading raster map <%s>..."
@@ -11019,6 +11320,11 @@
 msgid "Char string to represent no data cell"
 msgstr "Zeichenkette, die NODATA-Zellen repräsentiert."
+#: ../raster/r.transect/main.c:118
+#, fuzzy, c-format
+msgid "End coordinate: %.15g, %.15g"
+msgstr "Ungültige Koordinaten %s %s."
 #: ../raster/r.mode/main.c:52
 msgid ""
 "Finds the mode of values in a cover map within areas assigned the same "
@@ -11059,7 +11365,7 @@
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:118
-#: ../raster/simwe/r.sim.water/main.c:124
+#: ../raster/simwe/r.sim.water/main.c:125
 msgid "Name of the elevation raster map [m]"
 msgstr "Name der Rasterkarte, die Höheninformation enthält [m]."
@@ -11068,12 +11374,12 @@
 msgstr "Name der Rasterkarte, die die Wasserhöhe angibt [m]."
 #: ../raster/simwe/r.sim.sediment/main.c:128
-#: ../raster/simwe/r.sim.water/main.c:129
+#: ../raster/simwe/r.sim.water/main.c:130
 msgid "Name of the x-derivatives raster map [m/m]"
 msgstr "Name der Rasterkarte, die die Ableitung nach X enthält [m/m]."
 #: ../raster/simwe/r.sim.sediment/main.c:133
-#: ../raster/simwe/r.sim.water/main.c:134
+#: ../raster/simwe/r.sim.water/main.c:135
 msgid "Name of the y-derivatives raster map [m/m]"
 msgstr "Name der Rasterkarte, die die Ableitung nach Y enthält [m/m]."
@@ -11093,7 +11399,7 @@
 msgstr "Name einer neuen Rasterkarte"
 #: ../raster/simwe/r.sim.sediment/main.c:157
-#: ../raster/simwe/r.sim.water/main.c:172
+#: ../raster/simwe/r.sim.water/main.c:173
 #, fuzzy
 msgid "Name of the Mannings n raster map"
 msgstr "Name der Eingabe-Rasterkarte"
@@ -11103,285 +11409,247 @@
 msgid "Name of the Mannings n value"
-#: ../raster/simwe/r.sim.sediment/main.c:173
-#: ../raster/simwe/r.sim.water/main.c:194
+#: ../raster/simwe/r.sim.sediment/main.c:180
 #, fuzzy
-msgid "Name of the sampling locations vector points map"
-msgstr "Name der Eingabe-Vektorkarte."
-#: ../raster/simwe/r.sim.sediment/main.c:179
-#, fuzzy
 msgid "Output transport capacity raster map [kg/ms]"
 msgstr "Ausgabekarte mit Hangexposition."
-#: ../raster/simwe/r.sim.sediment/main.c:186
+#: ../raster/simwe/r.sim.sediment/main.c:187
 #, fuzzy
 msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
 msgstr "section"
-#: ../raster/simwe/r.sim.sediment/main.c:193
+#: ../raster/simwe/r.sim.sediment/main.c:194
 #, fuzzy
 msgid "Output sediment concentration raster map [particle/m3]"
 msgstr "Name der Fließrichtungskarte (Ausgabe)"
-#: ../raster/simwe/r.sim.sediment/main.c:199
+#: ../raster/simwe/r.sim.sediment/main.c:200
 #, fuzzy
 msgid "Output sediment flux raster map [kg/ms]"
 msgstr "Name der Rasterkarte mit Abflussinformationen "
-#: ../raster/simwe/r.sim.sediment/main.c:206
+#: ../raster/simwe/r.sim.sediment/main.c:207
 #, fuzzy
 msgid "Output erosion-deposition raster map [kg/m2s]"
 msgstr "section"
-#: ../raster/simwe/r.sim.sediment/main.c:213
+#: ../raster/simwe/r.sim.sediment/main.c:214
 #, fuzzy
 msgid "Number of walkers"
 msgstr "Anzahl der Frames."
-#: ../raster/simwe/r.sim.sediment/main.c:214
-#: ../raster/simwe/r.sim.sediment/main.c:222
-#: ../raster/simwe/r.sim.sediment/main.c:231
-#: ../raster/simwe/r.sim.sediment/main.c:239
-#: ../raster/simwe/r.sim.sediment/main.c:247
-#: ../raster/simwe/r.sim.water/main.c:228
-#: ../raster/simwe/r.sim.water/main.c:236
-#: ../raster/simwe/r.sim.water/main.c:245
-#: ../raster/simwe/r.sim.water/main.c:253
-#: ../raster/simwe/r.sim.water/main.c:261
-#: ../raster/simwe/r.sim.water/main.c:270
-#: ../raster/simwe/r.sim.water/main.c:278
-#: ../raster/simwe/r.sim.water/main.c:287
+#: ../raster/simwe/r.sim.sediment/main.c:215
+#: ../raster/simwe/r.sim.sediment/main.c:223
+#: ../raster/simwe/r.sim.sediment/main.c:232
+#: ../raster/simwe/r.sim.sediment/main.c:250
+#: ../raster/simwe/r.sim.water/main.c:233
+#: ../raster/simwe/r.sim.water/main.c:241
+#: ../raster/simwe/r.sim.water/main.c:250
+#: ../raster/simwe/r.sim.water/main.c:268
+#: ../raster/simwe/r.sim.water/main.c:277
+#: ../raster/simwe/r.sim.water/main.c:285
+#: ../raster/simwe/r.sim.water/main.c:294
 msgid "Parameters"
 msgstr "Parameter"
-#: ../raster/simwe/r.sim.sediment/main.c:221
-#: ../raster/simwe/r.sim.water/main.c:235
+#: ../raster/simwe/r.sim.sediment/main.c:222
+#: ../raster/simwe/r.sim.water/main.c:240
 msgid "Time used for iterations [minutes]"
 msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:230
-#: ../raster/simwe/r.sim.water/main.c:244
+#: ../raster/simwe/r.sim.sediment/main.c:231
+#: ../raster/simwe/r.sim.water/main.c:249
 #, fuzzy
 msgid "Time interval for creating output maps [minutes]"
 msgstr "Rastereingabekarte(n)"
-#: ../raster/simwe/r.sim.sediment/main.c:238
-#: ../raster/simwe/r.sim.water/main.c:252
-#, fuzzy
-msgid "Density of output walkers"
-msgstr "Name der Ausgabedatei"
-#: ../raster/simwe/r.sim.sediment/main.c:246
-#: ../raster/simwe/r.sim.water/main.c:260
+#: ../raster/simwe/r.sim.sediment/main.c:249
+#: ../raster/simwe/r.sim.water/main.c:267
 msgid "Water diffusion constant"
 msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:328
-#: ../raster/simwe/r.sim.water/main.c:438
+#: ../raster/simwe/r.sim.sediment/main.c:331
+#: ../raster/simwe/r.sim.water/main.c:444
 msgid "More than 100 files are going to be created !!!!!"
 msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:334
-#: ../raster/simwe/r.sim.water/main.c:444
+#: ../raster/simwe/r.sim.sediment/main.c:337
+#: ../raster/simwe/r.sim.water/main.c:450
 #, c-format
 msgid "default nwalk=%d, rwalk=%f"
 msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:343
-#: ../raster/simwe/r.sim.water/main.c:454
+#: ../raster/simwe/r.sim.sediment/main.c:346
+#: ../raster/simwe/r.sim.water/main.c:460
 #, c-format
 msgid "Using metric conversion factor %f, step=%f"
 msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:352
+#: ../raster/simwe/r.sim.sediment/main.c:355
 #, fuzzy
 msgid "You are not outputting any raster or site files"
 msgstr "Es werden weder Vektor- noch Rasterdaten ausgegeben."
-#: ../raster/simwe/r.sim.sediment/main.c:355
-#: ../raster/simwe/r.sim.water/main.c:466 ../vector/v.surf.rst/main.c:580
+#: ../raster/simwe/r.sim.sediment/main.c:358
+#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:580
 #: ../vector/v.surf.rst/main.c:634
 msgid "Input failed"
 msgstr "Eingabe fehlgeschlagen."
-#: ../raster/simwe/r.sim.sediment/main.c:414
-#: ../raster/simwe/r.sim.water/main.c:510
+#: ../raster/simwe/r.sim.sediment/main.c:417
+#: ../raster/simwe/r.sim.water/main.c:525
 msgid "Cannot write raster maps"
 msgstr "Kann Rasterkarten nicht schreiben."
-#: ../raster/simwe/simlib/input.c:49
-#, fuzzy, c-format
-msgid "File [%s] not found"
-msgstr "Datei <%s> nicht gefunden."
-#: ../raster/simwe/simlib/input.c:52
-#, fuzzy, c-format
-msgid "Unable to open file [%s]"
-msgstr "Kann die Datei <%s> nicht öffnen."
-#: ../raster/simwe/simlib/input.c:55
-msgid "Failed to guess file format"
-msgstr "Das Erraten des Datei-Formates ist fehlgeschlagen."
-#: ../raster/simwe/simlib/input.c:58
+#: ../raster/simwe/simlib/input.c:409
 #, c-format
-msgid "Reading sites map (%s) ..."
-msgstr "Lese Sites-Karte (%s) ..."
-#: ../raster/simwe/simlib/input.c:411
-#, c-format
 msgid ""
 "Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
 "to process"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:543
+#: ../raster/simwe/simlib/input.c:541
 msgid "Zero value in Mannings n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:594
+#: ../raster/simwe/simlib/input.c:592
 msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
 msgstr ""
-#: ../raster/simwe/simlib/input.c:618
+#: ../raster/simwe/simlib/input.c:616
 #, c-format
 msgid ""
 "Min elevation \t= %.2f m\n"
 "Max elevation \t= %.2f m\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:620
+#: ../raster/simwe/simlib/input.c:618
 #, c-format
 msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:622
+#: ../raster/simwe/simlib/input.c:620
 #, c-format
 msgid "Mean flow velocity \t= %f m/s\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:623
+#: ../raster/simwe/simlib/input.c:621
 #, c-format
 msgid "Mean Mannings \t= %f\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:627
+#: ../raster/simwe/simlib/input.c:625
 #, c-format
 msgid "Number of iterations \t= %d cells\n"
 msgstr "Anzahl der Iterationen \t= %d Zellen\n"
-#: ../raster/simwe/simlib/input.c:628
+#: ../raster/simwe/simlib/input.c:626
 #, c-format
 msgid "Time step \t= %.2f s\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:630
+#: ../raster/simwe/simlib/input.c:628
 #, c-format
 msgid ""
 "Sigmax \t= %f\n"
 "Max velocity \t= %f m/s\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:632
+#: ../raster/simwe/simlib/input.c:630
 #, c-format
 msgid "Time step used \t= %.2f s\n"
 msgstr ""
-#: ../raster/simwe/simlib/input.c:684
+#: ../raster/simwe/simlib/input.c:682
 msgid "Unable to write et file"
 msgstr "Kann die et Datei nicht schreiben."
-#: ../raster/simwe/simlib/hydro.c:117
+#: ../raster/simwe/simlib/hydro.c:119
 msgid "nwalk > maxw!"
 msgstr ""
-#: ../raster/simwe/simlib/hydro.c:332
+#: ../raster/simwe/simlib/hydro.c:339
 msgid "Unable to write raster maps"
-#: ../raster/simwe/r.sim.water/main.c:117
+#: ../raster/simwe/r.sim.water/main.c:118
 msgid "raster, flow, hydrology"
 msgstr "Raster, Abfluss, Hydrologie"
-#: ../raster/simwe/r.sim.water/main.c:119
+#: ../raster/simwe/r.sim.water/main.c:120
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:141
+#: ../raster/simwe/r.sim.water/main.c:142
 #, fuzzy
 msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:150
+#: ../raster/simwe/r.sim.water/main.c:151
 #, fuzzy
 msgid "Rainfall excess rate unique value [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:157
+#: ../raster/simwe/r.sim.water/main.c:158
 #, fuzzy
 msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:166
+#: ../raster/simwe/r.sim.water/main.c:167
 #, fuzzy
 msgid "Runoff infiltration rate unique value [mm/hr]"
-#: ../raster/simwe/r.sim.water/main.c:180
+#: ../raster/simwe/r.sim.water/main.c:181
 msgid "Mannings n unique value"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:187
+#: ../raster/simwe/r.sim.water/main.c:188
 #, fuzzy
 msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#: ../raster/simwe/r.sim.water/main.c:200
+#: ../raster/simwe/r.sim.water/main.c:203
 #, fuzzy
 msgid "Output water depth raster map [m]"
 msgstr "Ausgabekarte mit der Hangläne (Raster)."
-#: ../raster/simwe/r.sim.water/main.c:206
+#: ../raster/simwe/r.sim.water/main.c:209
 #, fuzzy
 msgid "Output water discharge raster map [m3/s]"
 msgstr "Ausgabekarte mit der mittleren Wölbung."
-#: ../raster/simwe/r.sim.water/main.c:212
+#: ../raster/simwe/r.sim.water/main.c:215
 #, fuzzy
 msgid "Output simulation error raster map [m]"
 msgstr "Ausgabekarte mit der Hangneigung."
-#: ../raster/simwe/r.sim.water/main.c:219
-#, fuzzy
-msgid "Name of the output walkers vector points map"
-#: ../raster/simwe/r.sim.water/main.c:227
+#: ../raster/simwe/r.sim.water/main.c:232
 msgid "Number of walkers, default is twice the no. of cells"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:269
+#: ../raster/simwe/r.sim.water/main.c:276
 msgid ""
 "Threshold water depth [m] (diffusion increases after this water depth is "
 "reached)"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:277
+#: ../raster/simwe/r.sim.water/main.c:284
 msgid "Diffusion increase constant"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:286
+#: ../raster/simwe/r.sim.water/main.c:293
 msgid "Weighting factor for water flow velocity vector"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:291
+#: ../raster/simwe/r.sim.water/main.c:298
 msgid "Time-series output"
 msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:463
+#: ../raster/simwe/r.sim.water/main.c:477
 #, fuzzy
-msgid "You are not outputting any raster or vector points maps"
+msgid "You are not outputting any raster maps"
 #: ../raster/r.out.mat/main.c:62
@@ -11524,9 +11792,10 @@
 msgstr "Raster, Raster3D, Voxel, Konvertieren"
 #: ../raster/r.to.rast3elev/main.c:359
-#, fuzzy
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr "Erzeugt eine section von Lautstärke ein"
+msgstr ""
+"Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren "
+"Rasterkarten."
 #: ../raster/r.to.rast3elev/main.c:390
 msgid "The upper value is not valid"
@@ -11558,7 +11827,7 @@
 #: ../raster/r.to.rast3elev/main.c:493 ../raster/r.to.rast3/main.c:326
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:300
 #: ../raster3d/r3.in.v5d/main.c:220 ../raster3d/r3.out.v5d/main.c:329
-#: ../raster3d/base/r3.info.main.c:421 ../raster3d/r3.to.rast/main.c:387
+#: ../raster3d/base/r3.info.main.c:425 ../raster3d/r3.to.rast/main.c:387
 msgid "Error closing 3d raster map"
 msgstr "Fehler beim Schließen der 3D-Rasterkarte."
@@ -11594,7 +11863,7 @@
 msgid "This module currently only works for integer (CELL) maps"
 msgstr ""
-#: ../raster/r.statistics/main.c:111 ../raster/r.neighbors/main.c:200
+#: ../raster/r.statistics/main.c:111 ../raster/r.neighbors/main.c:203
 #: ../raster/r.proj/main.c:209 ../raster/r.statistics2/main.c:162
 #, c-format
 msgid "<%s=%s> unknown %s"
@@ -11612,7 +11881,7 @@
 #: ../raster/r.statistics/main.c:198
 #, fuzzy, c-format
 msgid "An output raster map needs to be defined with method '%s'"
-msgstr "Name der Rasterkarte für <%s>"
+msgstr "Eine Ausgabe-Rasterkarte muss mit der Methode <%s> definiert werden."
 #: ../raster/r.statistics/o_skew.c:97
 msgid "o_skew: No data in array"
@@ -11671,7 +11940,7 @@
 msgid "Unable to read range file"
 msgstr "Kann die Ausdehnungs-Datei nicht lesen."
-#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:424
+#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:428
 #: ../raster3d/base/r3.info.main.c:158 ../raster3d/base/r3.info.main.c:166
 #: ../raster3d/base/r3.info.main.c:172 ../raster3d/base/r3.info.main.c:177
 #: ../raster3d/base/r3.info.main.c:184 ../raster3d/base/r3.info.main.c:195
@@ -11695,9 +11964,9 @@
 msgstr "Entkomprimiert die Karte"
 #: ../raster/r.compress/main.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "[%s] not found"
-msgstr "<%s> nicht gefunden werden."
+msgstr "[%s] nicht gefunden werden."
 #: ../raster/r.compress/main.c:108
 #, fuzzy, c-format
@@ -11782,7 +12051,7 @@
 msgstr "Eine oder mehrere Rasterkarte nicht gefunden."
 #: ../raster/r.patch/main.c:132 ../raster/r.slope.aspect/main.c:576
-#: ../raster/r.series/main.c:209
+#: ../raster/r.series/main.c:221
 msgid "Percent complete..."
 msgstr "Prozent fertig..."
@@ -11939,7 +12208,7 @@
 #: ../raster/r.uslek/main.c:74
 #, fuzzy
-msgid "Name of the output USLE K factor layer"
+msgid "Name of the output USLE K factor map [t.ha.hr/ha.MJ.mm]"
 msgstr "Name der Ausgabekarte"
 #: ../raster/r.circle/main.c:53
@@ -12707,7 +12976,7 @@
 msgid "Problem reading r.stats output"
 msgstr "Problem beim Lesen der 'r.stats'-Ausgabe."
-#: ../raster/r.report/main.c:28
+#: ../raster/r.report/main.c:65
 msgid "Reports statistics for raster map layers."
@@ -12749,7 +13018,7 @@
 msgid "Name of an output file to hold the report"
 msgstr "Name der Ausgabedatei zum Speichern des Reports."
-#: ../raster/r.report/parse.c:91 ../raster/r.stats/main.c:124
+#: ../raster/r.report/parse.c:91 ../raster/r.stats/main.c:137
 msgid "Number of fp subranges to collect stats from"
 msgstr ""
 "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
@@ -12774,11 +13043,11 @@
 msgid "Filter out cells where all maps have no data"
 msgstr "Filtere alle Zellen heraus, wo alle Karten NODATA-Werte haben."
-#: ../raster/r.report/parse.c:122 ../raster/r.stats/main.c:184
+#: ../raster/r.report/parse.c:122 ../raster/r.stats/main.c:197
 msgid "Report for cats fp ranges (fp maps only)"
 msgstr "Gebe Fließkomma-Spannen der Cats aus. (nur bei Fließkomma-Karten)"
-#: ../raster/r.report/parse.c:127 ../raster/r.stats/main.c:188
+#: ../raster/r.report/parse.c:127 ../raster/r.stats/main.c:201
 msgid "Read fp map as integer (use map's quant rules)"
 msgstr ""
 "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der "
@@ -12833,7 +13102,7 @@
 "Name der Location, von der Projektionsinformationen für eine GCP-"
 "Transformation gelesen werden soll."
-#: ../raster/r.in.gdal/main.c:121 ../vector/v.in.ogr/main.c:181
+#: ../raster/r.in.gdal/main.c:121 ../vector/v.in.ogr/main.c:180
 msgid "Name for new location to create"
 msgstr "Name der neu zu erstellenden Location."
@@ -12915,45 +13184,37 @@
 msgid "Error in pj_do_proj (can't re-projection GCP %i)"
 msgstr "Fehler in pj_do_proj (kann den GCP %i nicht umprojezieren)."
-#: ../raster/r.in.gdal/main.c:605
+#: ../raster/r.in.gdal/main.c:603
 msgid "Unable to translate projection key values of input GCPs"
 msgstr "Kann die Kennzahlen der Projektion der Eingabe-GCPs nicht übersetzten."
-#: ../raster/r.in.gdal/main.c:621
+#: ../raster/r.in.gdal/main.c:619
 msgid "Unable to get projection info of target location"
 msgstr "Kann die Projektionsinformation der Ziel-Location nicht ermitteln."
-#: ../raster/r.in.gdal/main.c:623
+#: ../raster/r.in.gdal/main.c:621
 msgid "Unable to get projection units of target location"
 msgstr "Kann die Projektionseinheit der Ziel-Location nicht ermitteln."
-#: ../raster/r.in.gdal/main.c:625
+#: ../raster/r.in.gdal/main.c:623
 msgid "Unable to get projection key values of target location"
 msgstr "Kann die Kennzahlen der Projektion der Ziel-Location nicht ermitteln."
-#: ../raster/r.in.gdal/main.c:628
+#: ../raster/r.in.gdal/main.c:896
 #, c-format
-msgid "Mapset <%s> in target location <%s> - "
-msgstr "Mapset <%s> in Ziel-Location <%s> - "
-#: ../raster/r.in.gdal/main.c:630 ../raster/r.proj/main.c:244
-msgid "permission denied"
-msgstr "Zugang verweigert."
-#: ../raster/r.in.gdal/main.c:631 ../raster/r.proj/main.c:245
-msgid "not found"
-msgstr "nicht gefunden"
-#: ../raster/r.in.gdal/main.c:898
-#, c-format
 msgid "Setting grey color table for <%s> (8bit, full range)"
 msgstr "Erstelle Graustufen Farbtabelle für <%s> (8bit, full range)."
-#: ../raster/r.in.gdal/main.c:911
+#: ../raster/r.in.gdal/main.c:909
 #, c-format
 msgid "Setting grey color table for <%s> (16bit, image range)"
 msgstr "Erstelle Graustufen Farbtabelle für <%s> (16bit, image range)."
+#: ../raster/r.in.gdal/main.c:920
+#, fuzzy, c-format
+msgid "Raster map <%s> created."
+msgstr "Die Rasterkarte <%s> existiert bereits."
 #: ../raster/r.rescale/main.c:45
 msgid "Rescales the range of category values in a raster map layer."
@@ -13015,13 +13276,12 @@
 msgstr "Nur [%ld] Zufallspunkte erzeugt."
 #: ../raster/r.random/main.c:53
-#, fuzzy
 msgid ""
 "Creates a raster map layer and vector point map containing randomly located "
 "points."
 msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorpunktkarte, die zufällig "
-"angeordnete Punkte enthalten."
+"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
+"Punkte enthalten."
 #: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
 msgid "Name of cover raster map"
@@ -13388,38 +13648,42 @@
 msgid "Computing histogram"
 msgstr "Berechne Histogramm"
-#: ../raster/r.quantile/main.c:96
+#: ../raster/r.quantile/main.c:96 ../raster/r.statistics3/main.c:110
 msgid "Computing bins"
 msgstr "Berechne Klassen"
-#: ../raster/r.quantile/main.c:133
+#: ../raster/r.quantile/main.c:133 ../raster/r.statistics3/main.c:165
 msgid "Binning data"
 msgstr "Klassiere Daten"
-#: ../raster/r.quantile/main.c:178
+#: ../raster/r.quantile/main.c:178 ../raster/r.statistics3/main.c:217
 msgid "Sorting bins"
 msgstr "Sortiere Klassen"
-#: ../raster/r.quantile/main.c:188
+#: ../raster/r.quantile/main.c:188 ../raster/r.statistics3/main.c:256
 msgid "Computing quantiles"
 msgstr "Berechne Quantile"
-#: ../raster/r.quantile/main.c:231
+#: ../raster/r.quantile/main.c:244
 msgid "Compute quantiles using two passes."
 msgstr "Berechne Quantile in zwei Durchgängen"
-#: ../raster/r.quantile/main.c:239
+#: ../raster/r.quantile/main.c:252 ../raster/r.statistics3/main.c:401
 msgid "Number of quantiles"
 msgstr "Anzahl der Quantile"
-#: ../raster/r.quantile/main.c:247
+#: ../raster/r.quantile/main.c:260 ../raster/r.statistics3/main.c:407
 msgid "List of percentiles"
 msgstr "Liste der Perzentile"
-#: ../raster/r.quantile/main.c:253
+#: ../raster/r.quantile/main.c:266 ../raster/r.statistics3/main.c:414
 msgid "Number of bins to use"
 msgstr "Anzahl der zu verwendenden Klassen"
+#: ../raster/r.quantile/main.c:271
+msgid "Generate recode rules based on quantile-defined intervals."
+msgstr ""
 #: ../raster/r.his/main.c:64
 msgid ""
 "Generates red, green and blue raster map layers combining hue, intensity and "
@@ -13531,9 +13795,9 @@
 "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
 #: ../raster/r.univar/r.univar_main.c:119
-#, fuzzy, c-format
+#, c-format
 msgid "Raster <%s> type mismatch"
-msgstr "FEHLER: <%s> existiert bereits!\n"
+msgstr "Raster <%s> Typen passen nicht."
 #: ../raster/r.univar/r.univar_main.c:192
 #, c-format
@@ -13575,7 +13839,7 @@
 msgid "Cannot open file <%s> to write header"
 msgstr "Kann die Datei <%s> nicht zum Schreiben des Headers öffnen."
-#: ../raster/r.kappa/main.c:54
+#: ../raster/r.kappa/main.c:69
 msgid ""
 "Calculate error matrix and kappa parameter for accuracy assessment of "
 "classification result."
@@ -13583,31 +13847,31 @@
 "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
 "(accuracy assessment) der Klassifikationsergebnisse."
-#: ../raster/r.kappa/main.c:60
+#: ../raster/r.kappa/main.c:75
 msgid "Name of raster map containing classification result"
 msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
-#: ../raster/r.kappa/main.c:65
+#: ../raster/r.kappa/main.c:80
 msgid "Name of raster map containing reference classes"
 msgstr "Name der Rasterkarte mit Referenzklassen"
-#: ../raster/r.kappa/main.c:70
+#: ../raster/r.kappa/main.c:85
 msgid "Name for output file containing error matrix and kappa"
 msgstr "Name der Ausgabedatei mit der Fehlermatrix und Kappawert."
-#: ../raster/r.kappa/main.c:76
+#: ../raster/r.kappa/main.c:91
 msgid "Title for error matrix and kappa"
 msgstr "Titel für Fehlermatrix und Kappa."
-#: ../raster/r.kappa/main.c:81
+#: ../raster/r.kappa/main.c:96
 msgid "Wide report"
 msgstr ""
-#: ../raster/r.kappa/main.c:82
+#: ../raster/r.kappa/main.c:97
 msgid "132 columns (default: 80)"
 msgstr "132 Zeichen (Standard: 80)"
-#: ../raster/r.kappa/main.c:86
+#: ../raster/r.kappa/main.c:101
 msgid "No header in the report"
 msgstr "Keinen Header im Report."
@@ -13763,7 +14027,7 @@
 #: ../raster/r.support/histo.c:21 ../raster/r.resample/main.c:100
 #, fuzzy, c-format
 msgid "Unable to read header for <%s>"
-msgstr "Kann den Header für <%s> nicht schreiben."
+msgstr "Kann den Header von %s nicht lesen."
 #: ../raster/r.resamp.rst/main.c:379
 #, fuzzy, c-format
@@ -13847,66 +14111,66 @@
 msgid "Error writing temporary file <%s>"
 msgstr "%s: Fehler beim Schreiben der temporären Datei."
-#: ../raster/r.stats/main.c:93
+#: ../raster/r.stats/main.c:106
 msgid "Generates area statistics for raster map layers."
 msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
-#: ../raster/r.stats/main.c:130
+#: ../raster/r.stats/main.c:143
 msgid "One cell (range) per line"
 msgstr "Eine Zelle(nspanne) pro Linie."
-#: ../raster/r.stats/main.c:134
+#: ../raster/r.stats/main.c:147
 msgid "Print averaged values instead of intervals"
 msgstr "Gib gemittelte Werte anstatt Intervalle aus."
-#: ../raster/r.stats/main.c:139
+#: ../raster/r.stats/main.c:152
 msgid "Print area totals"
 msgstr "Gebe Flächensummen aus."
-#: ../raster/r.stats/main.c:144
+#: ../raster/r.stats/main.c:157
 msgid "Print cell counts"
 msgstr "Gebe Zellenanzahlen aus."
-#: ../raster/r.stats/main.c:150
+#: ../raster/r.stats/main.c:163
 msgid "Print APPROXIMATE percents (total percent may not be 100%)"
 msgstr ""
 "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
-#: ../raster/r.stats/main.c:155
+#: ../raster/r.stats/main.c:168
 msgid "Print category labels"
 msgstr "Gebe Kategorielabel aus."
-#: ../raster/r.stats/main.c:160
+#: ../raster/r.stats/main.c:173
 msgid "Print grid coordinates (east and north)"
 msgstr "Gebe Rasterkoordinaten aus (Ost und Nord)."
-#: ../raster/r.stats/main.c:165
+#: ../raster/r.stats/main.c:178
 msgid "Print x and y (column and row)"
 msgstr "Gebe x und y aus (Spalte und Zeile)."
-#: ../raster/r.stats/main.c:170
+#: ../raster/r.stats/main.c:183
 msgid "Print raw indexes of fp ranges (fp maps only)"
 msgstr "Gebe rohe Indizes der Fließkomma-Spannen aus (nur Fließkommakarten)."
-#: ../raster/r.stats/main.c:180
+#: ../raster/r.stats/main.c:193
 msgid "Suppress reporting of NULLs when all values are NULL"
 msgstr "Unterdrücke die Ausgabe von NULL-Werten, wenn alle Werte NULL sind."
-#: ../raster/r.stats/main.c:196
+#: ../raster/r.stats/main.c:209
 #, c-format
 msgid "Unable to open file <%s> for writing"
 msgstr "Kann Datei <%s> nicht zum Schreiben öffnen."
-#: ../raster/r.stats/main.c:202
+#: ../raster/r.stats/main.c:215
 #, fuzzy, c-format
 msgid "'%s' must be greater than zero; using %s=255"
 msgstr "<%s> muss größer sein als Null; verwende %s=255."
-#: ../raster/r.stats/main.c:249 ../raster/r.series/main.c:158
+#: ../raster/r.stats/main.c:262 ../raster/r.series/main.c:170
 msgid "Raster map not found"
 msgstr "Rasterkarte nicht gefunden."
-#: ../raster/r.stats/main.c:269
+#: ../raster/r.stats/main.c:282
 #, fuzzy, c-format
 msgid ""
 "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
@@ -13915,7 +14179,7 @@
 "Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
 "Option<%s> werden ignoriert."
-#: ../raster/r.stats/main.c:285
+#: ../raster/r.stats/main.c:298
 #, c-format
 msgid ""
 "Cats for raster map <%s> are either missing or have no explicit labels. "
@@ -13924,7 +14188,7 @@
 "Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
 "Beschriftungen. Verwende %s=%d."
-#: ../raster/r.stats/main.c:291
+#: ../raster/r.stats/main.c:304
 #, fuzzy, c-format
 msgid ""
 "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
@@ -13933,12 +14197,12 @@
 "Der Schalter '-%c' wurde angegeben. Verwende die fp-Kategoriespanne der "
 "Rasterkarte <%s> und ignoriere die Option <%s>."
-#: ../raster/r.stats/main.c:297
+#: ../raster/r.stats/main.c:310
 #, c-format
 msgid "Unable to read fp range of raster map <%s>"
 msgstr "Kann den fp Bereich der Rasterkarte <%s> nicht lesen."
-#: ../raster/r.stats/main.c:317 ../raster/r.recode/read_rules.c:34
+#: ../raster/r.stats/main.c:330 ../raster/r.recode/read_rules.c:34
 #, c-format
 msgid "Unable to read range for map <%s>"
 msgstr "Kann die Spanne für die Karte <%s> nicht lesen."
@@ -14331,6 +14595,10 @@
 msgid "Standard deviation"
 msgstr "Standardabweichung"
+#: ../raster/r.colors/stats.c:78
+msgid "Unable to use logarithmic scaling if range includes zero"
+msgstr ""
 #: ../raster/r.colors/main.c:164 ../raster/r.colors.out/main.c:62
 msgid "raster, color table"
 msgstr "Raster, Farbtabellen"
@@ -14377,8 +14645,9 @@
 msgstr "Visualisieren"
 #: ../raster/r.colors/main.c:243
-msgid "No map specified"
-msgstr "Keine Karte angegeben."
+#, fuzzy
+msgid "No raster map specified"
+msgstr "Keine Eingabekarte angegeben."
 #: ../raster/r.colors/main.c:246
 #, fuzzy
@@ -14396,40 +14665,48 @@
 "aus."
 #: ../raster/r.colors/main.c:263
-#, c-format
-msgid "%s - unable to remove color table"
-msgstr "%s - kann die Farbtabelle nicht löschen."
+#, fuzzy, c-format
+msgid "Unable to remove color table of raster map <%s>"
+msgstr "Kann die Farbdatei für die Rasterkarte <%s> nicht lesen."
 #: ../raster/r.colors/main.c:265
-#, c-format
-msgid "%s - color table not found"
-msgstr "%s - Farbtabelle nicht gefunden."
+#, fuzzy, c-format
+msgid "Color table of raster map <%s> not found"
+msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
 #: ../raster/r.colors/main.c:293
-msgid "Can't make random color table for floating point map"
+#, fuzzy
+msgid "Color table 'random' is not supported for floating point raster map"
 msgstr "Kann keine zufällige Farbtabelle für Fließkomma-Karten erzeugen."
 #: ../raster/r.colors/main.c:298
-msgid "Can't make grey.eq color table for floating point map"
+#, fuzzy
+msgid "Color table 'grey.eq' is not supported for floating point raster map"
 msgstr "Kann keine grey.ey Farbtabelle für Fließkomma-Karten erzeugen."
 #: ../raster/r.colors/main.c:305
-msgid "Can't make logarithmic color table for floating point map"
-msgstr "Kann keine logarithmische Farbtabelle für Fließkomma-Karten erzeugen."
+#, fuzzy
+msgid "Color table 'grey.log' is not supported for floating point raster map"
+msgstr "Kann keine grey.ey Farbtabelle für Fließkomma-Karten erzeugen."
 #: ../raster/r.colors/main.c:314
-#, c-format
-msgid "%s - unknown color request"
+#, fuzzy, c-format
+msgid "Unknown color request '%s'"
 msgstr "%s - unbekannte Farbanfrage."
 #: ../raster/r.colors/main.c:325
-#, c-format
-msgid "Unable to load rules file %s"
+#, fuzzy, c-format
+msgid "Unable to load rules file <%s>"
 msgstr "Kann die Rules-Datei %s nicht laden."
-#: ../raster/r.colors/main.c:360
-#, c-format
-msgid "Color table for <%s> set to %s"
+#: ../raster/r.colors/main.c:335
+#, fuzzy, c-format
+msgid "Unable to read color table for raster map <%s>"
+msgstr "Kann die Farbdatei für die Rasterkarte <%s@%s> nicht lesen."
+#: ../raster/r.colors/main.c:367
+#, fuzzy, c-format
+msgid "Color table for raster map <%s> set to '%s'"
 msgstr "Farbtabelle für <%s> ist auf %s gesetzt."
 #: ../raster/r.colors/rules.c:42
@@ -14540,13 +14817,12 @@
 msgstr "Einzugsgebiet Durchgang %d"
 #: ../raster/r.fill.dir/main.c:86
-#, fuzzy
 msgid ""
 "Filters and generates a depressionless elevation map and a flow direction "
 "map from a given elevation layer."
 msgstr ""
 "Filtere und generiere ein depressionsloses Höhenmodell und eine "
-"Fließrichtungskarte auf Basis eines gegebenen Höhenmodells"
+"Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
 #: ../raster/r.fill.dir/main.c:98
 msgid "Output elevation raster map after filling"
@@ -14644,6 +14920,36 @@
 msgid "Unable to read category file for <%s>"
 msgstr "Kann die Kategorie-Datei der Rasterkarte <%s@%s> nicht lesen."
+#: ../raster/r.usler/main.c:50
+#, fuzzy
+msgid "raster, rainfall, erosion, USLE"
+msgstr "Raster, Sedimente, Erosion, Deposition"
+#: ../raster/r.usler/main.c:51
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../raster/r.usler/main.c:54
+#, fuzzy
+msgid "Name of the annual precipitation map [mm/year]"
+msgstr "Name der Rasterkarte mit Höheninformationen [in Meter]."
+#: ../raster/r.usler/main.c:57
+#, fuzzy
+msgid "Name of the USLE R map [MJ.mm/ha.hr.year]"
+msgstr "Name der Ausgabekarte"
+#: ../raster/r.usler/main.c:64
+#, fuzzy
+msgid "Name of USLE R equation"
+msgstr "Name der Höhenkarte"
+#: ../raster/r.usler/main.c:66
+msgid ""
+"roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-"
+"Swaify (1985)"
+msgstr ""
 #: ../raster/r.random.surface/save.c:103
 #, fuzzy, c-format
 msgid ""
@@ -15146,9 +15452,8 @@
 msgstr ""
 #: ../raster/r.support/main.c:115 ../raster/r.category/main.c:78
-#, fuzzy
 msgid "Raster map from which to copy category table"
-msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
+msgstr "Rasterkarte, von der die Kategorietabelle kopiert werden soll."
 #: ../raster/r.support/main.c:120
 msgid "Text file from which to load history"
@@ -15162,8 +15467,7 @@
 #, fuzzy
 msgid "Update statistics (histogram, range)"
 msgstr ""
-"Wollen Sie die Statistik (Histogramm, Spannweite) für die Karte <%s> "
-"aktualisieren?"
+"Wollen Sie die Statistik (Histogramm, Spannweite) für <%s> aktualisieren?"
 #: ../raster/r.support/main.c:133
 #, fuzzy
@@ -15187,7 +15491,7 @@
 #: ../raster/r.support/main.c:291
 #, fuzzy, c-format
 msgid "cats table for [%s] set to %s"
-msgstr "Farbtabelle für <%s> ist auf %s gesetzt."
+msgstr "cats Tabelle für <%s> ist auf %s gesetzt."
 #: ../raster/r.support/main.c:315 ../raster/r.support/main.c:345
 #, fuzzy, c-format
@@ -15216,7 +15520,7 @@
 "  Updating statistics for [%s]"
 msgstr ""
 "\n"
-"  Aktualisiere die Statistik für Karte <%s>."
+"  Aktualisiere die Statistik für <%s>."
 #: ../raster/r.support/check.c:68
 #, fuzzy, c-format
@@ -15280,27 +15584,27 @@
 msgstr ""
 #: ../raster/r.out.bin/main.c:310
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting raster as integer values (bytes=%d)"
-msgstr "Exportiere Rasterkarte als Ganzezahlen."
+msgstr "Exportiere Rasterkarte als integer (Byte=%d)."
 #: ../raster/r.out.bin/main.c:313
 msgid "Writing GMT integer format ID=2"
 msgstr ""
 #: ../raster/r.out.bin/main.c:316
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting raster as floating values (bytes=%d)"
-msgstr "Exportiere Rasterkarte als Fließkommazahlen."
+msgstr "Exportiere Rasterkarte als Fließkommazahlen (Byte=%d)."
 #: ../raster/r.out.bin/main.c:319
 msgid "Writing GMT float format ID=1"
 msgstr ""
 #: ../raster/r.out.bin/main.c:322
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting raster as double values (bytes=%d)"
-msgstr "Exportiere Rasterkarte als Double-Werte."
+msgstr "Exportiere Rasterkarte als Double-Werte (Byte=%d)."
 #: ../raster/r.out.bin/main.c:325
 msgid "Using the current region settings..."
@@ -15354,35 +15658,41 @@
 msgid "Neighborhood operation"
 msgstr "Nachbarschaftsoperation"
-#: ../raster/r.neighbors/main.c:136
+#: ../raster/r.neighbors/main.c:131 ../raster/r.neighbors/main.c:139
+#: ../raster/r.neighbors/main.c:162
+#, fuzzy
+msgid "Neighborhood"
+msgstr "Nachbarschaftsgröße"
+#: ../raster/r.neighbors/main.c:137
 msgid "Neighborhood size"
-#: ../raster/r.neighbors/main.c:144
+#: ../raster/r.neighbors/main.c:146
 msgid "Title of the output raster map"
 msgstr "Titel der Ausgabekarte."
-#: ../raster/r.neighbors/main.c:151
+#: ../raster/r.neighbors/main.c:153
 msgid "File containing weights"
 msgstr "Datei die Gewichte enthält."
-#: ../raster/r.neighbors/main.c:155
+#: ../raster/r.neighbors/main.c:157
 msgid "Do not align output with the input"
 msgstr "Ausgabe nicht an der Eingabe bündig ausrichten."
-#: ../raster/r.neighbors/main.c:159
+#: ../raster/r.neighbors/main.c:161
 msgid "Use circular neighborhood"
 msgstr ""
-#: ../raster/r.neighbors/main.c:166
+#: ../raster/r.neighbors/main.c:169
 msgid "Neighborhood size must be positive"
 msgstr "Die Größe der Nachbarschaft muss positiv sein."
-#: ../raster/r.neighbors/main.c:168
+#: ../raster/r.neighbors/main.c:171
 msgid "Neighborhood size must be odd"
 msgstr "Die Größe der Nachbarschaft muss ungerade sein."
-#: ../raster/r.neighbors/main.c:172
+#: ../raster/r.neighbors/main.c:175
 msgid "weight= and -c are mutually exclusive"
@@ -15433,19 +15743,16 @@
 msgstr "%d Klassen."
 #: ../raster/r.what.color/main.c:88
-#, fuzzy
 msgid "Queries colors for a raster map layer."
-msgstr "Gibt statistische Werte für eine Rasterkarte aus."
+msgstr "Fragt Farben einer Rasterkarte ab."
 #: ../raster/r.what.color/main.c:96
-#, fuzzy
 msgid "Name of existing raster map to query colors"
-msgstr "Rasterkarte(n) zum abfragen."
+msgstr "Name einer existierenden Rasterkarte, die abgefragt werden soll."
 #: ../raster/r.what.color/main.c:103
-#, fuzzy
 msgid "Values to query colors for"
-msgstr "Kann die Farbe für den Farbstreifen nicht lesen."
+msgstr "Werte für die Farben abgefragt werden sollen."
 #: ../raster/r.what.color/main.c:110
 msgid "Output format (printf-style)"
@@ -15469,9 +15776,8 @@
 msgstr "Datei nicht gefunden: %s"
 #: ../raster/r.in.gridatb/file_io.c:34
-#, fuzzy
 msgid "Setting window header failed"
-msgstr "Vektorkarte mit Startpunkten"
+msgstr "Schreiben des Fenster-Headers fehlgeschlagen."
 #: ../raster/r.random.cells/main.c:50
 msgid "Generates random cell values with spatial dependence."
@@ -15496,7 +15802,7 @@
 msgstr ""
 #: ../raster/r.to.vect/areas_io.c:371 ../raster/r.to.vect/util.c:156
-#: ../vector/v.in.ogr/main.c:867 ../vector/v.random/main.c:284
+#: ../vector/v.in.ogr/main.c:861 ../vector/v.random/main.c:284
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Kann neue Zeile %s nicht einfügen."
@@ -15520,12 +15826,11 @@
 "Sequenzen (nur bei CELL-Karten)."
 #: ../raster/r.to.vect/main.c:99
-#, fuzzy
 msgid ""
 "Write raster values as z coordinate. Table is not created. Currently "
 "supported only for points."
 msgstr ""
-"Schreibe Rasterwerte als Z-Koodinate. Attributtabelle wurde nicht erzeugt. "
+"Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. "
 "Derzeit werden nur Punkte unterstützt."
 #: ../raster/r.to.vect/main.c:105
@@ -15564,14 +15869,14 @@
 #: ../vector/v.in.ascii/main.c:389 ../vector/v.sample/main.c:211
 #: ../vector/v.in.sites/main.c:179 ../vector/v.mkgrid/main.c:228
 #: ../vector/v.random/main.c:189 ../vector/v.overlay/main.c:454
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to grant privileges on table <%s>"
-msgstr "Kann Privilegien für die Tabelle '%s' nicht zuweisen."
+msgstr "Kann Rechte für die Tabelle <%s> nicht setzen."
 #: ../raster/r.to.vect/main.c:279
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to insert into table: %s"
-msgstr "Kann nicht an Tabelle '%s' anfügen."
+msgstr "Kann nicht in Tabelle <%s> einfügen."
 #: ../raster/r.to.vect/lines.c:69
 msgid "Extracting lines..."
@@ -15639,17 +15944,17 @@
 #: ../raster/r.region/main.c:180
 #, fuzzy, c-format
 msgid "Unable to open 3dview file <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht öffnen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht öffnen."
 #: ../raster/r.region/main.c:184
 #, fuzzy, c-format
 msgid "Unable to read 3dview file <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht lesen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
 #: ../raster/r.region/main.c:186
 #, fuzzy, c-format
 msgid "Old 3dview file. Region <%s> not found"
-msgstr "Alte 3dview-Datei. Region <%s> in <%s> konnte nicht gefunden werden."
+msgstr "Alte 3Dview-Datei. Region <%s> konnte in <%s> nicht gefunden werden."
 #: ../raster/r.region/main.c:331
 msgid "Unable to update boundaries"
@@ -15728,9 +16033,8 @@
 msgstr "Schreibe Farb-Datei..."
 #: ../raster/r.in.mat/main.c:92
-#, fuzzy
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "Importiere eine Binär-MAT-Datei (v4) als GRASS Rasterkarte."
+msgstr "Importiert eine binäre MAT-Datei (v4) als GRASS Rasterkarte."
 #: ../raster/r.in.mat/main.c:101
 msgid "Name of an existing MAT-File(v4)"
@@ -15800,7 +16104,7 @@
 #: ../raster/r.in.mat/main.c:319
 #, fuzzy, c-format
 msgid "Skipping unknown array '%s'"
-msgstr "Überspringe unbekanntes Array '%s'."
+msgstr "Überspringe unbekanntes Array <%s>."
 #: ../raster/r.in.mat/main.c:347
 #, c-format
@@ -15813,14 +16117,13 @@
 msgstr ""
 #: ../raster/r.in.mat/main.c:361
-#, fuzzy, c-format
+#, c-format
 msgid "Setting map name to <%s>"
-msgstr "Einstellung des Kartenfensters."
+msgstr "Setze den Kartennamen auf <%s>."
 #: ../raster/r.in.mat/main.c:365
-#, fuzzy
 msgid "No 'map_name' array found; using <MatFile>"
-msgstr "Kein 'map_data'-Array in <%s> gefunden."
+msgstr "Kein 'map_name'-Array gefunden; verwende <MatFile>."
 #: ../raster/r.in.mat/main.c:376
 msgid "Missing bound"
@@ -15840,9 +16143,9 @@
 msgstr "Schreibe neue Rasterkarte..."
 #: ../raster/r.in.mat/main.c:473
-#, fuzzy, c-format
+#, c-format
 msgid "Writing raster map, row %d"
-msgstr "Schreibe Karte, derzeit Zeile %d."
+msgstr "Schreibe Rasterkarte, Zeile %d."
 #: ../raster/r.watershed/ram/init_vars.c:84
 #, c-format
@@ -15906,13 +16209,12 @@
 #: ../raster/r.watershed/ram/do_cum.c:12 ../raster/r.watershed/seg/do_cum.c:14
 msgid "SECTION 3: Accumulating Surface Flow."
-msgstr ""
+msgstr "Abschnitt 3: Akkumuliere Oberflächenabfluß."
 #: ../raster/r.watershed/ram/sg_factor.c:12
 #: ../raster/r.watershed/seg/sg_factor.c:12
-#, fuzzy
 msgid "SECTION 4: Length Slope determination."
-msgstr "Länge:"
+msgstr "Abschnitt 4: Bestimme die Hanglänge."
 #: ../raster/r.watershed/ram/main.c:67 ../raster/r.watershed/ram/main.c:83
 #, c-format
@@ -15922,7 +16224,7 @@
 #: ../raster/r.watershed/ram/main.c:81
 #, c-format
 msgid "SECTION %d: Watershed determination."
-msgstr ""
+msgstr "Abschnitt %d: Bestimme Wassereinzugsgebiet."
 #: ../raster/r.watershed/ram/close_maps.c:22
 #: ../raster/r.watershed/ram/close_maps.c:60
@@ -15944,9 +16246,8 @@
 msgstr "Kann die neue Expositionskarte nicht öffnen."
 #: ../raster/r.watershed/ram/close_maps.c:96
-#, fuzzy
 msgid "unable to open new L map layer."
-msgstr "Kann die Karte MASK nicht öffnen."
+msgstr "Kann neue L-Karte nicht öffnen."
 #: ../raster/r.watershed/ram/close_maps.c:114
 #, fuzzy
@@ -15954,9 +16255,8 @@
 #: ../raster/r.watershed/ram/close_maps.c:136
-#, fuzzy
 msgid "unable to open new S map layer."
+msgstr "Kann neue S-Karte nicht öffnen."
 #: ../raster/r.watershed/ram/do_astar.c:14
 #: ../raster/r.watershed/seg/do_astar.c:18
@@ -15991,58 +16291,67 @@
 "\n"
 "This set of questions will organize the command line for the"
 msgstr ""
+"\n"
+"Die folgenden Fragen werden die Kommandozeile vorbereiten für das"
 #: ../raster/r.watershed/shed/com_line.c:22
 #, c-format
 msgid "%s program to run properly for your application."
-msgstr ""
+msgstr "%s Programm, damit es für Ihre Anwendung korrekt ausgeführt wird."
 #: ../raster/r.watershed/shed/com_line.c:24
 #, c-format
 msgid "The first question is whether you want %s to run"
-msgstr ""
+msgstr "Die erste Frage ist, ob Sie %s "
 #: ../raster/r.watershed/shed/com_line.c:26
-#, fuzzy, c-format
+#, c-format
 msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr "in"
+msgstr ""
+"im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
 #: ../raster/r.watershed/shed/com_line.c:28
-#, fuzzy
 msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr "in"
+msgstr ""
+"im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig "
+"sein "
 #: ../raster/r.watershed/shed/com_line.c:29
-#, fuzzy
 msgid "than in the slow mode, but will not allow other programs to run"
-msgstr "in"
+msgstr ""
+"als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
 #: ../raster/r.watershed/shed/com_line.c:30
 msgid "at the same time.  The fast mode also places all of the data into"
 msgstr ""
+"zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle "
+"Daten"
 #: ../raster/r.watershed/shed/com_line.c:31
 msgid "RAM, which limits the size of window that can be run.  The slow"
 msgstr ""
+"in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
 #: ../raster/r.watershed/shed/com_line.c:32
-#, fuzzy
 msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr "in GRASS"
+msgstr ""
+"Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS "
+"befindet. "
 #: ../raster/r.watershed/shed/com_line.c:33
-#, fuzzy
 msgid "stored.  Thus, if the program does not work in the slow mode, you will"
-msgstr "in"
+msgstr "  Daher müssen Sie unnötige Dateien auf der Partition löschen, wenn "
 #: ../raster/r.watershed/shed/com_line.c:34
 msgid "need to remove unnecessary files from that partition.  The slow mode"
 msgstr ""
+"das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
 #: ../raster/r.watershed/shed/com_line.c:35
 #, c-format
 msgid "will allow other processes to run concurrently with %s.\n"
 msgstr ""
+"gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
 #: ../raster/r.watershed/shed/com_line.c:67
 #: ../raster/r.watershed/shed/com_line.c:179
@@ -16050,11 +16359,13 @@
 "\n"
 "If you hit <return> by itself for the next question, this"
 msgstr ""
+"\n"
+"Wenn Sie nur <return> drücken bei der nächsten Frage, wird das "
 #: ../raster/r.watershed/shed/com_line.c:68
 #: ../raster/r.watershed/shed/com_line.c:180
 msgid "program will terminate."
-msgstr "Programm wird sich beenden."
+msgstr "Programm beendet."
 #: ../raster/r.watershed/shed/com_line.c:79
 #, c-format
@@ -16311,6 +16622,8 @@
 "\n"
 "Input value here [0-100]: "
 msgstr ""
+"\n"
+"Eingabewerte hier [0-100]: "
 #: ../raster/r.watershed/shed/com_line.c:376
 msgid ""
@@ -16360,9 +16673,8 @@
 msgstr ""
 #: ../raster/r.watershed/shed/file_in.c:15
-#, fuzzy
 msgid "unable to open ARMSED file"
-msgstr "Kann die Ausgabedatei nicht öffnen."
+msgstr "Kann die ARMSED-Datei nicht öffnen."
 #: ../raster/r.watershed/shed/intro.c:8
 #, c-format
@@ -16607,11 +16919,8 @@
 msgstr "Minimale Anzahl der im Hauptspeicher zu haltenden Zeile ist 1."
 #: ../raster/r.quant/main.c:48
-#, fuzzy
 msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Diese Routine produziert eine Quantisierungsdatei für eine Fließkommazahl-"
-"Karte."
+msgstr "Erzeugt Quantisierungsdatei für eine Fließkommazahl-Karte."
 #: ../raster/r.quant/main.c:56
 msgid "Raster map(s) to be quantized"
@@ -16695,14 +17004,14 @@
 msgstr "Keine Regeln angegeben. Quant-Tabelle nicht geändert."
 #: ../raster/r.quant/main.c:182
-#, fuzzy, c-format
+#, c-format
 msgid "Quant table not changed for %s"
-msgstr "Kann die Headerinformationen für Karte %s nicht bekommen."
+msgstr "Quantisierungstabelle für <%s> wurde nicht geändert."
 #: ../raster/r.quant/main.c:184
-#, fuzzy, c-format
+#, c-format
 msgid "New quant table created for %s"
-msgstr "Kann %s nicht erzeugen."
+msgstr "Neue Quantisierungstabelle für <%s> erzeugt."
 #: ../raster/r.quant/read_rules.c:49
 msgid "Old data range is empty"
@@ -16763,12 +17072,9 @@
 msgstr "Kantenanzahl außerhalb der Spanne."
 #: ../raster/r.contour/main.c:86
-#, fuzzy
 msgid ""
 "Produces a vector map layer of specified contours from a raster map layer."
-msgstr ""
-"Erzeugt eine GRASS Binär-Vektorkarte mit Kontourlinien einer GRASS "
-"Rasterkarte."
+msgstr "Erzeugt eine Vektorkarte mit Kontourlinien aus einer Rasterkarte."
 #: ../raster/r.contour/main.c:97
 msgid "List of contour levels"
@@ -16798,9 +17104,9 @@
 msgid "Could not read range file"
 msgstr "Kann die Range-Datei nicht lesen."
-#: ../raster/r.contour/main.c:173 ../vector/v.db.connect/main.c:302
+#: ../raster/r.contour/main.c:173 ../vector/v.db.connect/main.c:303
 #: ../vector/v.reclass/main.c:216 ../vector/v.to.points/main.c:293
-#: ../vector/v.sample/main.c:207 ../vector/v.in.ogr/main.c:771
+#: ../vector/v.sample/main.c:207 ../vector/v.in.ogr/main.c:765
 #: ../vector/v.net.path/path.c:113
 msgid "Cannot create index"
 msgstr "Kann keinen Index erstellen."
@@ -16816,23 +17122,22 @@
 msgstr "Lese Daten:"
 #: ../raster/r.contour/main.c:244
-#, fuzzy, c-format
+#, c-format
 msgid "Range of data:    min =  %f max = %f"
-msgstr "Bereich"
+msgstr "Wertebereich:    min =  %f max = %f"
 #: ../raster/r.contour/main.c:246
-#, fuzzy
 msgid "Range of data:    empty"
-msgstr "Bereich"
+msgstr "Wertebereich:    leer."
 #: ../raster/r.contour/main.c:273 ../raster/r.contour/main.c:277
 msgid "This step value is not allowed."
 msgstr "Diese Schrittgröße ist nicht erlaubt."
 #: ../raster/r.contour/main.c:301
-#, fuzzy, c-format
+#, c-format
 msgid "Range of levels: min = %f max = %f"
-msgstr "Bereich"
+msgstr "Bereich der Stufen: min = %f max = %f"
 #: ../raster/r.contour/main.c:330
 #, fuzzy
@@ -16844,37 +17149,37 @@
 msgid "%s: STEP 3 ... "
 msgstr "%s: Schritt 3 ... "
-#: ../raster/r.cross/main.c:63
+#: ../raster/r.cross/main.c:74
 msgid ""
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr ""
 "Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
-#: ../raster/r.cross/main.c:72
+#: ../raster/r.cross/main.c:83
 #, c-format
 msgid "Names of 2-%d input raster maps"
-msgstr "Name der 2-%d Eingabe-Rasterkarte"
+msgstr "Namen der 2-%d Eingabe-Rasterkarten"
-#: ../raster/r.cross/main.c:81
+#: ../raster/r.cross/main.c:92
 msgid "Non-zero data only"
 msgstr "Nur nicht-Null Daten"
-#: ../raster/r.cross/main.c:94
+#: ../raster/r.cross/main.c:105
 #, c-format
 msgid "More than %d files not allowed"
 msgstr "Mehr als %d Dateien sind nicht erlaubt."
-#: ../raster/r.cross/main.c:112
+#: ../raster/r.cross/main.c:123
 msgid "Must specify 2 or more input maps"
 msgstr "Es müssen mindestens 2 oder mehr Karten angegeben werden."
-#: ../raster/r.cross/main.c:133
+#: ../raster/r.cross/main.c:144
 #, c-format
 msgid "%s: STEP 2 ..."
 msgstr "%s: SCHRITT  2 ..."
-#: ../raster/r.cross/main.c:176
+#: ../raster/r.cross/main.c:187
 #, c-format
 msgid "%ld categories"
 msgstr "%ld Kategorien"
@@ -16884,11 +17189,11 @@
 msgid "%s: STEP 1 ... "
 msgstr "%s: SCHRITT 1 ... "
-#: ../raster/r.series/main.c:126
+#: ../raster/r.series/main.c:127
 msgid "raster, series"
 msgstr "Raster, Serien"
-#: ../raster/r.series/main.c:128
+#: ../raster/r.series/main.c:129
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
 "corresponding cells in the input raster map layers."
@@ -16896,11 +17201,15 @@
 "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
 "korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
-#: ../raster/r.series/main.c:142
+#: ../raster/r.series/main.c:143
 msgid "Aggregate operation"
 msgstr "Aggregationsverfahren"
-#: ../raster/r.series/main.c:182
+#: ../raster/r.series/main.c:150
+msgid "Ignore values outside this range"
+msgstr ""
+#: ../raster/r.series/main.c:194
 msgid "output= and method= must have the same number of values"
 msgstr ""
@@ -16986,8 +17295,8 @@
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
 "to integer"
 msgstr ""
-"Die Karte <%s> in Mapset <%s> ist eine Fließkommakarte. Dezimalwerte werden "
-"zu ganzzahligen Werten gerundet!"
+"Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
+"Nachkommastellen werden auf ganze Zahlen gerundet!"
 #: ../raster/r.out.tiff/main.c:156
 msgid ""
@@ -17021,7 +17330,7 @@
 msgid "Raster File Series to MPEG Conversion Program."
 msgstr "Konvertiert Folgen von Rasterkarten zu einem MPEG-Film."
-#: ../raster/r.out.mpeg/main.c:97 ../visualization/xganim/main.c:102
+#: ../raster/r.out.mpeg/main.c:97
 #, c-format
 msgid "Raster file(s) for View%d"
 msgstr "Rasterkarte(n) für View%d"
@@ -17062,13 +17371,13 @@
 #: ../raster/r.out.mpeg/main.c:297
 #, fuzzy, c-format
 msgid "Error reading row <%d>"
-msgstr "Fehler beim Lesen eine Datenzeile."
+msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
 #: ../raster/r.out.mpeg/main.c:339 ../raster/r.out.mpeg/main.c:369
 msgid "mpeg_encode ERROR"
 msgstr "mpeg_encode FEHLER."
-#: ../raster/r.out.mpeg/main.c:403 ../visualization/xganim/main.c:561
+#: ../raster/r.out.mpeg/main.c:403
 msgid "Error reading wildcard"
 msgstr "Fehler beim Lesen der Wildcard."
@@ -17238,37 +17547,37 @@
 #: ../raster/r.mapcalc/evaluate.c:152
 #, fuzzy, c-format
 msgid "Too few arguments for function '%s'"
-msgstr "Zu wenige Argumente für die Funktion '%s'."
+msgstr "Zu wenige Argumente für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:156
 #, fuzzy, c-format
 msgid "Too many arguments for function '%s'"
-msgstr "Zu viele Argumente für die Funktion '%s'."
+msgstr "Zu viele Argumente für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:160
 #, fuzzy, c-format
 msgid "Invalid argument type for function '%s'"
-msgstr "Ungültiger Argument-Typ für die Funktion '%s'."
+msgstr "Ungültiger Argument-Typ für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:164
 #, fuzzy, c-format
 msgid "Invalid return type for function '%s'"
-msgstr "Ungültiger Rückgabewert für die Funktion '%s'."
+msgstr "Ungültiger Rückgabewert für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:168
 #, fuzzy, c-format
 msgid "Unknown type for function '%s'"
-msgstr "Unbekannter Typ für die Funktion '%s'."
+msgstr "Unbekannter Typ für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:171
 #, fuzzy, c-format
 msgid "Number of arguments for function '%s'"
-msgstr "Anzahl der Argumente für die Funktion '%s'."
+msgstr "Anzahl der Argumente für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:175
 #, fuzzy, c-format
 msgid "Unknown error for function '%s'"
-msgstr "Unbekannter Fehler für die Funktion '%s'."
+msgstr "Unbekannter Fehler für die Funktion <%s>."
 #: ../raster/r.mapcalc/evaluate.c:284
 #, fuzzy, c-format
@@ -17283,7 +17592,7 @@
 #: ../raster/r.mapcalc/expression.c:201
 #, fuzzy, c-format
 msgid "Undefined variable '%s'"
-msgstr "Undefinierte Variable '%s'."
+msgstr "Undefinierte Variable <%s>."
 #: ../raster/r.mapcalc/expression.c:216
 #, c-format
@@ -17293,7 +17602,7 @@
 #: ../raster/r.mapcalc/expression.c:257
 #, fuzzy, c-format
 msgid "Undefined function '%s'"
-msgstr "Undefinierte Funktion '%s'."
+msgstr "Undefinierte Funktion <%s>."
 #: ../raster/r.mapcalc/expression.c:262
 #, c-format
@@ -17327,7 +17636,7 @@
 #: ../raster/r.mapcalc/expression.c:443
 #, fuzzy, c-format
 msgid "Illegal number of arguments (%d) for operator '%s'"
-msgstr "Ungültige Anzahl von Argumenten (%d) für den Operator '%s'."
+msgstr "Ungültige Anzahl von Argumenten (%d) für den Operator <%s>."
 #: ../raster/r.mapcalc/expression.c:483
 #, c-format
@@ -17433,28 +17742,28 @@
 msgstr "Keine Regeln angegeben. Rasterkarte <%s> nicht erzeugt."
 #: ../raster/r.recode/read_rules.c:19
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read f_range for map %s"
-msgstr "%s: Kann die Spanne für [%s] nicht lesen."
+msgstr "Kann f_range für die Karte <%s> nicht lesen."
 #: ../raster/r.recode/read_rules.c:23
 msgid "Data range is empty"
 msgstr "Datenspanne ist leer."
 #: ../raster/r.recode/read_rules.c:29
-#, fuzzy, c-format
+#, c-format
 msgid "Data range of %s is %s to %s (entire map)"
-msgstr "fp: Datenspanne reicht von %.25f bis %.25f\n"
+msgstr "Wertebereich für %s ist %s bis %s (komplette Karte)."
 #: ../raster/r.recode/read_rules.c:38
-#, fuzzy, c-format
+#, c-format
 msgid "Integer data range of %s is empty"
-msgstr "Datenspanne reicht von %ld bis %ld\n"
+msgstr "Integer Wertebereich von %s ist leer."
 #: ../raster/r.recode/read_rules.c:40
-#, fuzzy, c-format
+#, c-format
 msgid "Integer data range of %s is %d to %d"
+msgstr "Integer Wertebereich von %s ist %d bis %d."
 #: ../raster/r.recode/read_rules.c:59
 #, fuzzy
@@ -17462,9 +17771,8 @@
 msgstr "Bitte geben Sie eine Regel in einem der folgende Formate ein:\n"
 #: ../raster/r.recode/read_rules.c:80
-#, fuzzy
 msgid "Enter a rule in one of these formats:"
-msgstr "Bitte geben Sie eine Regel in einem der folgende Formate ein:\n"
+msgstr "Bitte geben Sie eine Regel in einem dieser Formate ein:"
 #: ../raster/r.recode/read_rules.c:81
 msgid "old_low:old_high:new_low:new_high"
@@ -17580,9 +17888,8 @@
 msgstr "Schreibe Rasterkarte <%s>."
 #: ../raster/r.composite/main.c:71
-#, fuzzy
 msgid "raster, composite"
-msgstr "Raster, Import"
+msgstr "Raster, Komposite"
 #: ../raster/r.composite/main.c:73
 #, fuzzy
@@ -17613,19 +17920,18 @@
 msgstr "Benutze nächste Farbe"
 #: ../raster/r.composite/main.c:192
-#, fuzzy, c-format
+#, c-format
 msgid "Writing raster map <%s>..."
-msgstr "Schreibe Rasterkarte <%s> ..."
+msgstr "Schreibe Rasterkarte <%s>..."
 #: ../raster/r.composite/main.c:203
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading raster map <%s>"
 msgstr "Fehler beim Lesen der Rasterkarte <%s>."
 #: ../raster/r.composite/main.c:291
-#, fuzzy
 msgid "Creating color table for output raster map..."
-msgstr "Erstelle Farbtabelle für <%s in %s> ..."
+msgstr "Erstelle Farbtabelle für Ausgabe-Rasterkarte..."
 #: ../raster/r.gwflow/main.c:58 ../raster3d/r3.gwflow/main.c:55
 msgid "The initial piezometric head in [m]"
@@ -17976,12 +18282,10 @@
 "Name der Rasterkarte, die die Ausbreitungszeit als Ergebnis enthalten soll."
 #: ../raster/wildfire/r.spread/main.c:222
-#, fuzzy
 msgid "Name of raster map to contain X_BACK coordinates"
 msgstr "Name der Rasterkarte, die die X_BACK Koordinaten enthält."
 #: ../raster/wildfire/r.spread/main.c:230
-#, fuzzy
 msgid "Name of raster map to contain Y_BACK coordinates"
 msgstr "Name der Rasterkarte, die die Y_BACK-Koordinaten enthält."
@@ -18018,24 +18322,9 @@
 msgid "Name of an output layer"
-#: ../raster/r.resample/main.c:91
-#, fuzzy, c-format
-msgid "Unable to open input map <%s>"
-msgstr "Kann die Eingabedatei <%s> nicht öffnen."
-#: ../raster/r.resample/main.c:114 ../raster/r.statistics2/main.c:500
-#, fuzzy, c-format
-msgid "Unable to open output map <%s>"
-msgstr "Kann Ausgabedatei <%s> nicht öffnen."
 #: ../raster/r.resample/main.c:121
 #, fuzzy, c-format
 msgid "Error reading row %d"
-#: ../raster/r.resample/main.c:123
-#, fuzzy, c-format
-msgid "Error writing row %d"
 #: ../raster/r.resample/main.c:144
@@ -18051,11 +18340,11 @@
 msgid "Reading input raster map <%s>..."
 msgstr "Lese Eingabe-Rasterkarte <%s>..."
-#: ../raster/r.buffer/main.c:55
+#: ../raster/r.buffer/main.c:65
 msgid "raster, buffer"
 msgstr "Raster, Buffer"
-#: ../raster/r.buffer/main.c:57
+#: ../raster/r.buffer/main.c:67
 msgid ""
 "Creates a raster map layer showing buffer zones surrounding cells that "
 "contain non-NULL category values."
@@ -18063,23 +18352,23 @@
 "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte "
 "haben."
-#: ../raster/r.buffer/main.c:69
+#: ../raster/r.buffer/main.c:79
 msgid "Distance zone(s)"
 msgstr "Distanzzone(n)"
-#: ../raster/r.buffer/main.c:76
+#: ../raster/r.buffer/main.c:86
 msgid "Units of distance"
 msgstr "Distanzeinheiten"
-#: ../raster/r.buffer/main.c:82
+#: ../raster/r.buffer/main.c:92
 msgid "Ignore zero (0) data cells instead of NULL cells"
 msgstr "Ignoriere 0-Werte anstatt der NULL-Zellen."
-#: ../raster/r.buffer/main.c:119
+#: ../raster/r.buffer/main.c:129
 msgid "Parse distances error"
 msgstr "Fehler beim Analysieren der Distanz."
-#: ../raster/r.buffer/main.c:138
+#: ../raster/r.buffer/main.c:148
 #, c-format
 msgid "Pass %d (of %d)"
 msgstr "Durchlauf %d (von %d)."
@@ -18302,6 +18591,7 @@
 msgstr "Eingabe-Rasterkarte ist außerhalb der aktuellen Region."
 #: ../raster/r.proj/readcell.c:57 ../raster/r.statistics2/main.c:482
+#: ../raster/r.statistics3/main.c:308
 msgid "Unable to open temporary file"
 msgstr "Kann temporäre Datei nicht öffnen."
@@ -18382,26 +18672,31 @@
 msgid "Resultant raster map"
 msgstr "Name der resultierenden Rasterkarte."
-#: ../raster/r.statistics2/main.c:146
+#: ../raster/r.statistics2/main.c:146 ../raster/r.statistics3/main.c:425
 msgid "Create reclass map with statistics as category labels"
 msgstr ""
-#: ../raster/r.statistics2/main.c:172 ../raster/r.statistics2/main.c:176
+#: ../raster/r.statistics2/main.c:172 ../raster/r.statistics3/main.c:475
 #, fuzzy, c-format
 msgid "Unable to open base map <%s>"
 msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+#: ../raster/r.statistics2/main.c:176 ../raster/r.statistics3/main.c:479
+#, fuzzy, c-format
+msgid "Unable to open cover map <%s>"
+msgstr "Kann die Vektorkarte <%s> nicht öffnen."
 #: ../raster/r.statistics2/main.c:179
 #, fuzzy, c-format
 msgid "Unable to read category file of cover map <%s>"
-#: ../raster/r.statistics2/main.c:182
+#: ../raster/r.statistics2/main.c:182 ../raster/r.statistics3/main.c:482
 #, fuzzy
 msgid "The base map must be an integer (CELL) map"
 msgstr "Musterkarte sollte eine binäre 0/1 Rasterkarte sein."
-#: ../raster/r.statistics2/main.c:185
+#: ../raster/r.statistics2/main.c:185 ../raster/r.statistics3/main.c:485
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
@@ -18424,23 +18719,23 @@
 msgid "Writing output map"
 msgstr "Schreibe Ausgabekarte ..."
-#: ../raster/r.grow.distance/main.c:121
+#: ../raster/r.grow.distance/main.c:122
 #, fuzzy
 msgid "Generates a raster map layer of distance to features in input layer."
 msgstr ""
 "Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
 "Flächen."
-#: ../raster/r.grow.distance/main.c:131 ../raster/r.grow/main.c:147
+#: ../raster/r.grow.distance/main.c:132 ../raster/r.grow/main.c:147
 msgid "Metric"
 msgstr "Metrisch"
-#: ../raster/r.grow.distance/main.c:150 ../raster/r.grow/main.c:194
+#: ../raster/r.grow.distance/main.c:153 ../raster/r.grow/main.c:194
 #, fuzzy, c-format
 msgid "Unknown metric: [%s]."
 msgstr "Unbekannte Einheit: <%s>."
-#: ../raster/r.grow.distance/main.c:163
+#: ../raster/r.grow.distance/main.c:166
 #, fuzzy, c-format
 msgid "Unable to create temporary file <%s>"
 msgstr "Kann die temporäre Datei nicht schreiben."
@@ -18481,11 +18776,10 @@
 msgstr "Fehler beim Schreiben der Farb-Datei für <%s>."
 #: ../raster/r.category/main.c:53
-#, fuzzy
 msgid ""
 "Manages category values and labels associated with user-specified raster map "
 "layers."
-msgstr "Gibt die Kategoriewerte und Label einer Rasterkarte aus."
+msgstr "Verwaltet die Kategoriewerte und Label von Rasterkarten."
 #: ../raster/r.category/main.c:66
 msgid "Comma separated value list"
@@ -18547,9 +18841,9 @@
 msgstr "Kann den Header der Rasterkarte <%s> in <%s> nicht lesen."
 #: ../raster/r.category/cats.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open cell file of raster map <%s> in <%s>"
-msgstr "Kann die Terrain Rasterkarte <%s@%s> nicht öffnen!"
+msgstr "Kann die Zelldatei der Rasterkarte <%s> in <%s> nicht öffnen."
 #: ../raster/r.category/cats.c:51
 #, c-format
@@ -18576,6 +18870,63 @@
 msgid "Can't read color table for <%s>"
 msgstr "%s: Kann die Farbtabelle für <%s@%s> nicht lesen."
+#: ../raster/r.statistics3/main.c:75
+#, fuzzy
+msgid "Computing histograms"
+msgstr "Berechne Histogramm"
+#: ../raster/r.statistics3/main.c:241
+#, fuzzy
+msgid "Printing quantiles"
+msgstr "Berechne Quantile"
+#: ../raster/r.statistics3/main.c:293
+#, fuzzy
+msgid "Generating reclass maps"
+msgstr "Benenne reclass-Karten um."
+#: ../raster/r.statistics3/main.c:332
+#, fuzzy
+msgid "Writing output maps"
+msgstr "Schreibe Ausgabekarte ..."
+#: ../raster/r.statistics3/main.c:391
+#, fuzzy
+msgid "Compute category quantiles using two passes."
+msgstr "Berechne Quantile in zwei Durchgängen"
+#: ../raster/r.statistics3/main.c:418
+#, fuzzy
+msgid "Resultant raster map(s)"
+msgstr "Name der resultierenden Rasterkarte."
+#: ../raster/r.statistics3/main.c:430
+#, fuzzy
+msgid "Don't create output maps; just print statistics"
+msgstr "Kann Ausgabekarte nicht erzeugen."
+#: ../raster/r.statistics3/main.c:442
+#, fuzzy
+msgid "Either -p or output= must be given"
+msgstr "Entweder \"-i\" oder \"value=\" muss angegeben werden."
+#: ../raster/r.statistics3/main.c:445
+#, fuzzy
+msgid "-p and output= are mutually exclusive"
+msgstr "-r und -e schliessen sich gegenseitig aus."
+#: ../raster/r.statistics3/main.c:469
+#, fuzzy, c-format
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
+msgstr ""
+"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
+"Spalten (%d) der Eingabe überein."
+#: ../raster/r.statistics3/main.c:490
+#, fuzzy, c-format
+msgid "Base map <%s> has too many categories (max: %d)"
+msgstr "<%s> hat zu viele Signaturen (Limit ist 255)"
 #: ../raster3d/r3.in.ascii/main.c:79
 msgid "Ascii raster map to be imported"
 msgstr "ZU importierende ASCII Raster-Datei."
@@ -18652,10 +19003,8 @@
 msgstr "Erzeugt Volumenstatistiken für 3D-Rasterkarten."
 #: ../raster3d/r3.stats/main.c:580
-#, fuzzy
 msgid "Number of sub-ranges to collect stats from"
-msgstr ""
-"Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+msgstr "Anzahl der Unterbereiche für die Statistiken berechnet werden sollen"
 #: ../raster3d/r3.stats/main.c:586
 msgid "Calculate statistics based on equal value groups"
@@ -19005,7 +19354,7 @@
 "Geb nur 3D-Rasterkarten-Datumsstempel (Tag.Monat.Jahr Stunde:Minute:Sekunde) "
 "aus."
-#: ../raster3d/base/r3.info.main.c:400
+#: ../raster3d/base/r3.info.main.c:404
 msgid "Error while reading history file"
 msgstr "Fehler beim Lesen der 'history'-Datei."
@@ -19057,11 +19406,6 @@
 msgid "Adding rule: %lf - %lf"
 msgstr "Füge Regel hinzu: %lf - %lf"
-#: ../raster3d/base/mask_functions.c:100
-#, c-format
-msgid "%s: illegal value spec"
-msgstr "%s: ungültiger Wert."
 #: ../raster3d/base/r3.timestamp.main.c:45
 msgid "Print/add/remove a timestamp for a 3D raster map"
 msgstr "Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für 3D-Rasterkarten."
@@ -19084,19 +19428,17 @@
 msgstr "Kann die Eingabe-3D-Rasterkarte nicht schließen."
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:39
-#, fuzzy
 msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr "write_vtk_structured_elevation_header: Schreibe VTK-Header"
+msgstr "write_vtk_structured_point_header: Schreibe VTKStructuredPoint-Header"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:95
-#, fuzzy
 msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
+msgstr "write_vtk_structured_grid_header: Schreibe VTKStructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:116
-#, fuzzy
 msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
+msgstr ""
+"write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "G3D map(s) to be converted to VTK-ASCII data format"
@@ -19414,9 +19756,9 @@
 msgstr "EXPOSITION <%s> KOMPLETT"
 #: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1197
-#, fuzzy, c-format
+#, c-format
 msgid "SLOPE [%s] COMPLETE"
-msgstr "E-W NEIGUNG <%s> KOMPLETT"
+msgstr "NEIGUNG [%s] KOMPLETT"
 #: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1268
 #, fuzzy, c-format
@@ -19497,96 +19839,96 @@
 msgid "Must refer to an integer column"
 msgstr "Muss auf eine Integer-Spalte verweisen."
-#: ../vector/v.db.connect/main.c:80
+#: ../vector/v.db.connect/main.c:81
 msgid "Print all map connection parameters and exit"
 msgstr "Gibt alle Verbindungsparameter aus und beendet sich."
-#: ../vector/v.db.connect/main.c:84
+#: ../vector/v.db.connect/main.c:85
 msgid "Print all map connection parameters and exit in shell script style"
 msgstr ""
 "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
-#: ../vector/v.db.connect/main.c:87
+#: ../vector/v.db.connect/main.c:88
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:93
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
 "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
 "beende sich. "
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:99
 msgid "Overwrite connection parameter for certain layer"
 msgstr "Überschreibe die Verbindungsparameter für den angegebenen Layer."
-#: ../vector/v.db.connect/main.c:103
+#: ../vector/v.db.connect/main.c:104
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Lösche die Verbindung zur Tabelle (nicht aber die Tabelle)."
-#: ../vector/v.db.connect/main.c:127
+#: ../vector/v.db.connect/main.c:128
 msgid "Please choose only one print style"
 msgstr "Bitte nur einen Druck-Stil auswählen."
-#: ../vector/v.db.connect/main.c:133
+#: ../vector/v.db.connect/main.c:134
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
-#: ../vector/v.db.connect/main.c:140 ../vector/v.info/main.c:186
+#: ../vector/v.db.connect/main.c:141 ../vector/v.info/main.c:186
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
 "Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-"
 "Datei."
-#: ../vector/v.db.connect/main.c:146
+#: ../vector/v.db.connect/main.c:147
 #, c-format
 msgid "Vector map <%s> is connected by:"
 msgstr "Vectorkarte <%s> ist verbunden durch:"
-#: ../vector/v.db.connect/main.c:170
+#: ../vector/v.db.connect/main.c:171
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:232
+#: ../vector/v.db.connect/main.c:233
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:240 ../vector/v.db.connect/main.c:280
+#: ../vector/v.db.connect/main.c:241 ../vector/v.db.connect/main.c:281
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "Die Tabelle <%s> existiert nicht in der Datenbank <%s>."
-#: ../vector/v.db.connect/main.c:255 ../vector/v.transform/trans_digit.c:93
+#: ../vector/v.db.connect/main.c:256 ../vector/v.transform/trans_digit.c:93
 #: ../vector/v.in.db/main.c:137
 #, c-format
 msgid "Missing column <%s> in table <%s>"
 msgstr "Vermisse Spalte <%s> in der Tabelle <%s>."
-#: ../vector/v.db.connect/main.c:261 ../vector/v.in.db/main.c:140
+#: ../vector/v.db.connect/main.c:262 ../vector/v.in.db/main.c:140
 msgid "Data type of key column must be integer"
 msgstr "Datentyp der Schlüssel-Spalte (key column) muss ein integer sein."
-#: ../vector/v.db.connect/main.c:268 ../vector/v.db.connect/main.c:286
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:287
 #, fuzzy, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
 "overwritten by GRASS modules"
 msgstr "GRASS"
-#: ../vector/v.db.connect/main.c:307 ../vector/v.in.ogr/main.c:776
+#: ../vector/v.db.connect/main.c:308 ../vector/v.in.ogr/main.c:770
 #, c-format
 msgid "Cannot grant privileges on table %s"
-#: ../vector/v.db.connect/main.c:310
+#: ../vector/v.db.connect/main.c:311
 msgid "Select privileges were granted on the table"
 msgstr ""
-#: ../vector/v.db.connect/main.c:317
+#: ../vector/v.db.connect/main.c:318
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -19659,7 +20001,7 @@
 msgid "Cannot open data source"
 msgstr "Kann Datenquelle nicht öffnen."
-#: ../vector/v.external/main.c:128 ../vector/v.in.ogr/main.c:361
+#: ../vector/v.external/main.c:128 ../vector/v.in.ogr/main.c:355
 #, c-format
 msgid "Layer <%s> not available"
 msgstr "Layer <%s> ist nicht vorhanden."
@@ -19722,14 +20064,14 @@
 msgstr ""
 #: ../vector/v.edit/select.c:72
-#, fuzzy, c-format
+#, c-format
 msgid "Threshold value for coordinates is %.2f"
-msgstr "für z"
+msgstr "Schwellwert für Koordinaten ist %.2f."
 #: ../vector/v.edit/select.c:159
-#, fuzzy, c-format
+#, c-format
 msgid "Threshold value for querying is %.2f"
-msgstr "Mindestens 2 Layer müssen angegeben werden."
+msgstr "Schwellwert für Abfragen ist %.2f."
 #: ../vector/v.edit/select.c:175
 #, c-format
@@ -19740,7 +20082,7 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr "Layer muss > 0 sein für 'where'."
-#: ../vector/v.edit/snap.c:119 ../vector/v.edit/a2b.c:328
+#: ../vector/v.edit/snap.c:111 ../vector/v.edit/a2b.c:328
 #, fuzzy, c-format
 msgid "Unable to rewrite line %d"
 msgstr "Kann kein Face erzeugen."
@@ -19749,7 +20091,7 @@
 #: ../vector/v.edit/a2b.c:147
 #, fuzzy, c-format
 msgid "Error reading ASCII file: '%s'"
-msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
+msgstr "Fehler beim Lesen der ASCII-Datei: <%s>."
 #: ../vector/v.edit/a2b.c:136 ../vector/v.in.ascii/a2b.c:102
 msgid "End of ASCII file reached before end of coordinates"
@@ -19762,7 +20104,7 @@
 #: ../vector/v.edit/a2b.c:189
 #, fuzzy, c-format
 msgid "Error reading categories: '%s'"
-msgstr "Fehler beim Lesen der Kategorien: '%s'."
+msgstr "Fehler beim Lesen der Kategorien: <%s>."
 #: ../vector/v.edit/a2b.c:236
 #, fuzzy, c-format
@@ -19770,9 +20112,9 @@
 msgstr "Kann die Vektorkarte %s nicht öffnen."
 #: ../vector/v.edit/a2b.c:270
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown keyword '%s' in vector head"
-msgstr "Unbekanntes Schlüsselwort <%s im Vektor-Header."
+msgstr "Unbekanntes Schlüsselwort '%s' im Vektor-Header."
 #: ../vector/v.edit/main.c:54
 msgid "vector, editing, geometry"
@@ -19795,7 +20137,7 @@
 msgid "Unable to open ASCII file <%s>"
 msgstr "Kann die ASCII-Datei <%s> nicht öffnen."
-#: ../vector/v.edit/main.c:87 ../vector/v.in.ogr/main.c:336
+#: ../vector/v.edit/main.c:87 ../vector/v.in.ogr/main.c:330
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr "Vektorkarte <%s> existiert bereits."
@@ -19834,11 +20176,11 @@
 msgstr "%d Feature hinzugefügt"
 #: ../vector/v.edit/main.c:240 ../vector/v.edit/main.c:261
-#: ../vector/v.edit/main.c:269 ../vector/v.edit/main.c:295
-#: ../vector/v.edit/main.c:332
-#, fuzzy, c-format
+#: ../vector/v.edit/main.c:269 ../vector/v.edit/main.c:294
+#: ../vector/v.edit/main.c:331
+#, c-format
 msgid "Threshold value for snapping is %.2f"
+msgstr "Schwellwert für Snapping ist %.2f."
 #: ../vector/v.edit/main.c:249
 #, c-format
@@ -19870,73 +20212,73 @@
 msgid "%d vertices removed"
 msgstr "%d Vertices gelöscht"
-#: ../vector/v.edit/main.c:292
+#: ../vector/v.edit/main.c:291
 #, c-format
 msgid "%d lines broken"
 msgstr "%d Linien aufgeknackt"
-#: ../vector/v.edit/main.c:298
+#: ../vector/v.edit/main.c:297
 #, c-format
 msgid "%d lines connected"
 msgstr "%d Linien verbunden"
-#: ../vector/v.edit/main.c:302
+#: ../vector/v.edit/main.c:301
 #, c-format
 msgid "%d lines merged"
 msgstr "%d Linien zusammengefasst"
-#: ../vector/v.edit/main.c:310 ../vector/v.edit/main.c:314
+#: ../vector/v.edit/main.c:309 ../vector/v.edit/main.c:313
 #, c-format
 msgid "%d features modified"
 msgstr "%d Feature verändert"
-#: ../vector/v.edit/main.c:319
+#: ../vector/v.edit/main.c:318
 #, c-format
 msgid ""
 "Multiple background maps were given. Selected features will be copied only "
 "from vector map <%s>."
 msgstr ""
-#: ../vector/v.edit/main.c:329
+#: ../vector/v.edit/main.c:328
 #, c-format
 msgid "%d features copied"
 msgstr "%d Feature kopiert"
-#: ../vector/v.edit/main.c:338
+#: ../vector/v.edit/main.c:337
 #, c-format
 msgid "%d lines flipped"
 msgstr "%d Linien umgedreht"
-#: ../vector/v.edit/main.c:358
+#: ../vector/v.edit/main.c:357
 #, c-format
 msgid "%d lines labeled"
 msgstr "%d Linien beschriftet"
-#: ../vector/v.edit/main.c:370
+#: ../vector/v.edit/main.c:369
 #, c-format
 msgid "%d points converted to centroids"
 msgstr "%d Punkte in Zentroide verwandelt"
-#: ../vector/v.edit/main.c:373
+#: ../vector/v.edit/main.c:372
 #, c-format
 msgid "%d centroids converted to points"
 msgstr "%d Zentroide in Punkte verwandelt"
-#: ../vector/v.edit/main.c:377
+#: ../vector/v.edit/main.c:376
 #, c-format
 msgid "%d lines converted to boundaries"
 msgstr "%d Linien zu Grenzen verwandelt"
-#: ../vector/v.edit/main.c:380
+#: ../vector/v.edit/main.c:379
 #, c-format
 msgid "%d boundaries converted to lines"
 msgstr "%d Grenzen zu Linien verwandelt"
-#: ../vector/v.edit/main.c:385
+#: ../vector/v.edit/main.c:384
 msgid "No feature modified"
 msgstr "Keine Feature verändert"
-#: ../vector/v.edit/main.c:390
+#: ../vector/v.edit/main.c:389
 msgid "Operation not implemented"
 msgstr "Operation nicht implementiert."
@@ -19980,9 +20322,8 @@
 msgstr ""
 #: ../vector/v.edit/args.c:118
-#, fuzzy
 msgid "Threshold distance (coords,snap,query)"
-msgstr "Maximale Distanz vom Punkt zum Netzwerk."
+msgstr "Schwellwerte (coords,snap,query)."
 #: ../vector/v.edit/args.c:120
 #, fuzzy
@@ -20006,9 +20347,8 @@
 msgstr ""
 #: ../vector/v.edit/args.c:168
-#, fuzzy
 msgid "Query tool"
-msgstr "Abfrage"
+msgstr "Abfrage-Werkzeug"
 #: ../vector/v.edit/args.c:170
 msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
@@ -20068,14 +20408,13 @@
 msgstr ""
 #: ../vector/v.edit/args.c:251
-#, fuzzy
 msgid "Polygon must have at least 3 coordinate pairs"
-msgstr "Es müssen mindestens 4 Punkte %d angegeben werden."
+msgstr "Polygon muss mindestens 3 Koordinatenpaare haben."
 #: ../vector/v.edit/args.c:312
 #, fuzzy, c-format
 msgid "Operation '%s' not implemented"
-msgstr "Operation '%s' nicht implementiert."
+msgstr "Operation <%s> ist nicht implementiert."
 #: ../vector/v.edit/args.c:321
 #, c-format
@@ -20095,9 +20434,9 @@
 msgstr "TEXT: Vertizes"
 #: ../vector/v.in.dxf/add_polyline.c:78
-#, fuzzy, c-format
+#, c-format
 msgid "3-d data in dxf file. Polyline_flag: %d"
-msgstr "WARNUNG: 3D-Daten in der DXF-Datei."
+msgstr "3D-Daten in der DXF-Datei. Polyline_flag: %d"
 #: ../vector/v.in.dxf/layer_list.c:57
 #, c-format
@@ -20158,9 +20497,8 @@
 #: ../vector/v.in.dxf/main.c:91 ../vector/v.in.dxf/main.c:97
 #: ../vector/v.in.dxf/main.c:102 ../vector/v.in.dxf/main.c:116
-#, fuzzy
 msgid "DXF layers"
-msgstr "Start Layer"
+msgstr "DXF Layer"
 #: ../vector/v.in.dxf/main.c:96
 msgid "Invert selection by layers (don't import layers in list)"
@@ -20172,18 +20510,17 @@
 msgstr "Importiere alle Objekte in einen Layer."
 #: ../vector/v.in.dxf/main.c:105
-#, fuzzy
 msgid "Name of input DXF file"
-msgstr "Namen der Eingabedateien."
+msgstr "Name der Eingabe-DXF-Datei"
 #: ../vector/v.in.dxf/main.c:115
 msgid "List of layers to import"
 msgstr "Liste der zu importierenden Layer."
 #: ../vector/v.in.dxf/main.c:130
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open DXF file <%s>"
-msgstr "Kann die Datei <%s> nicht öffnen."
+msgstr "Kann die DXF-Datei <%s> nicht öffnen."
 #: ../vector/v.in.dxf/main.c:136
 msgid "Layer number: layer name / GRASS compliant name"
@@ -20482,9 +20819,9 @@
 #: ../vector/lidar/v.outlier/main.c:168
 #: ../vector/lidar/v.surf.bspline/main.c:229
 #: ../vector/lidar/v.surf.bspline/main.c:249
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector map <%s> at the topological level"
-msgstr "Kann Vektorkarte <%s> in <%s> nicht öffnen."
+msgstr "Kann Vektorkarte <%s> nicht im topologischen Modus öffnen."
 #: ../vector/lidar/v.outlier/main.c:319
 msgid "It was impossible to create <Auxiliar_outlier_table>."
@@ -20635,12 +20972,12 @@
 msgstr "Nun, -husch husch- die Ergebnisse in eine Tabelle:\n"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:320
-#, fuzzy, c-format
+#, c-format
 msgid " lambda    | mean        | rms         |\n"
 msgstr " lambda    | mean (m)    | rms (m)     |\n"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:322
-#, fuzzy, c-format
+#, c-format
 msgid " %-10.5f| %-12.4f| %-12.4f|\n"
 msgstr " %-10.5f| %-12.3f| %-12.3f|\n"
@@ -20703,9 +21040,8 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:221
-#, fuzzy
 msgid "No raster nor vector output"
-msgstr "Name der Ausgabedatei."
+msgstr "Weder Raster- noch Vektor-Ausgabe."
 #: ../vector/lidar/v.surf.bspline/main.c:235
 #, fuzzy, c-format
@@ -20714,9 +21050,9 @@
 msgstr "Nein"
 #: ../vector/lidar/v.surf.bspline/main.c:241
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> vector map will be interpolated"
-msgstr "Vektordatei, die erstellt werden soll."
+msgstr "<%s> Vektorkarte wird interpoliert."
 #: ../vector/lidar/v.surf.bspline/main.c:257
 #, c-format
@@ -20726,9 +21062,9 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:320
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] records selected from table"
-msgstr "%d Datensätze aus der Tabelle selektiert."
+msgstr "[%d] Datensätze aus der Tabelle selektiert."
 #: ../vector/lidar/v.surf.bspline/main.c:333
 msgid "Cross validation didn't finish correctly"
@@ -20746,9 +21082,9 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:541
-#, fuzzy, c-format
+#, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
-msgstr "Kein Eintrag für Linie (cat = %d)."
+msgstr "Interpolation: (%d,%d): Kein Eintrag für den Punkt (cat = %d)."
 #: ../vector/lidar/v.surf.bspline/main.c:602
 #, fuzzy, c-format
@@ -20839,9 +21175,8 @@
 msgstr "Maximale Distanz oder -1 für unbegrenzt."
 #: ../vector/v.distance/main.c:170
-#, fuzzy
 msgid "Minimum distance or -1 for no limit"
-msgstr "Maximale Distanz oder -1 für unbegrenzt."
+msgstr "Minimale Distanz oder -1 für unbegrenzt."
 #: ../vector/v.distance/main.c:179
 msgid "Values describing the relation between two nearest features"
@@ -20917,7 +21252,6 @@
 msgstr "Kann die Standard-Datenbank nicht öffnen."
 #: ../vector/v.distance/main.c:429
-#, fuzzy
 msgid "Incompatible column types"
 msgstr "Inkompatible Spaltentypen."
@@ -20935,9 +21269,9 @@
 msgstr ""
 #: ../vector/v.distance/main.c:808 ../vector/v.overlay/main.c:444
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create table: '%s'"
-msgstr "Kann Tabelle nicht erzeugen: %s"
+msgstr "Kann Tabelle nicht erzeugen: '%s'"
 #: ../vector/v.distance/main.c:845
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
@@ -21019,7 +21353,8 @@
 msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
 #: ../vector/v.reclass/main.c:81
-msgid "The column must be type integer or string"
+#, fuzzy
+msgid "The source for the new key column must be type integer or string"
 msgstr "Die Spalte muss vom Typ integer oder string sein."
 #: ../vector/v.reclass/main.c:84
@@ -21047,9 +21382,9 @@
 #: ../vector/v.reclass/main.c:221 ../vector/v.to.points/main.c:298
 #: ../vector/v.net.path/path.c:117
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot grant privileges on table <%s>"
+msgstr "Kann keine Rechte für die Tabelle <%s> setzen."
 #: ../vector/v.reclass/main.c:230
 msgid "Cannot fetch data"
@@ -21058,7 +21393,7 @@
 #: ../vector/v.reclass/main.c:255
 #, fuzzy, c-format
 msgid "Cannot insert data: [%s]"
-msgstr "Kann Daten nicht einfügen: <%s>"
+msgstr "Kann Daten nicht einfügen: <%s>."
 #: ../vector/v.reclass/main.c:281
 msgid "Column type must be integer or string"
@@ -21072,12 +21407,12 @@
 #: ../vector/v.reclass/main.c:309
 #, fuzzy, c-format
 msgid "Category %d overwritten by '%s'"
-msgstr "Kategorie %d überschrieben mit '%s'."
+msgstr "Kategorie %d überschrieben mit <%s>."
 #: ../vector/v.reclass/main.c:313
 #, fuzzy, c-format
 msgid "Category '%s' invalid"
-msgstr "Kategorie '%s' ist nicht gültig."
+msgstr "Kategorie <%s> ist nicht gültig."
 #: ../vector/v.reclass/main.c:317
 #, fuzzy, c-format
@@ -21133,26 +21468,25 @@
 #: ../vector/v.in.ascii/a2b.c:89
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-msgstr "Fehler beim Lesen der ascii-Datei <%s>."
+msgstr "Fehler beim Lesen der ASCII-Datei: (unbekannter Typ) <%s>."
 #: ../vector/v.in.ascii/a2b.c:112
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr "Fehler beim Lesen der ASCII-Datei: (schlechter Punkt) <%s>."
 #: ../vector/v.in.ascii/a2b.c:143
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
 #: ../vector/v.in.ascii/a2b.c:153
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading categories: [%s]"
+msgstr "Fehler beim Lesen der Kategorien: [%s]."
 #: ../vector/v.in.ascii/points.c:83
-#, fuzzy
 msgid "Scanning input for column types..."
-msgstr "Zeilen."
+msgstr "Scanne die Eingabe zur Ermittelung der Spaltentypen..."
 #: ../vector/v.in.ascii/points.c:165
 #, fuzzy, c-format
@@ -21191,9 +21525,8 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:70
-#, fuzzy
 msgid "Input file format"
-msgstr "Quelldatei"
+msgstr "Format der Inputdatei"
 #: ../vector/v.in.ascii/main.c:81
 #, fuzzy
@@ -21288,7 +21621,6 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:178
-#, fuzzy
 msgid "Please specify reasonable number of lines to skip"
 msgstr ""
 "Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
@@ -21413,9 +21745,8 @@
 msgstr "Länge der Spalte %d (%d) ist geringer als die maximale Wertlänge (%d)."
 #: ../vector/v.in.ascii/main.c:517
-#, fuzzy
 msgid "Populating table..."
-msgstr "Kopiere Tabellen..."
+msgstr "Fülle Tabelle..."
 #: ../vector/v.to.points/main.c:172 ../vector/v.segment/main.c:52
 #: ../vector/v.split/main.c:42 ../vector/v.overlay/main.c:54
@@ -21462,9 +21793,9 @@
 msgid "Maximum distance between points in map units"
 msgstr "Maximale Distanz zwischen den Punkten in Karteneinheiten (mapunits)."
-#: ../vector/v.to.points/main.c:212 ../vector/v.in.ogr/main.c:213
+#: ../vector/v.to.points/main.c:212 ../vector/v.in.ogr/main.c:212
 #: ../vector/v.overlay/main.c:113 ../vector/v.voronoi/vo_main.c:137
-#: ../vector/v.select/main.c:171
+#: ../vector/v.select/main.c:178
 msgid "Do not create attribute table"
 msgstr "Keine Attributtabelle erzeugen."
@@ -21474,11 +21805,10 @@
 msgstr "Wähle entweder den Schalter -n oder -s."
 #: ../vector/v.to.points/main.c:268 ../vector/v.voronoi/vo_main.c:336
-#: ../vector/v.select/main.c:496
 msgid "Cannot copy table"
 msgstr "Kann die Tabelle nicht kopieren."
-#: ../vector/v.to.points/main.c:289 ../vector/v.in.ogr/main.c:766
+#: ../vector/v.to.points/main.c:289 ../vector/v.in.ogr/main.c:760
 #: ../vector/v.vol.rst/main.c:623 ../vector/v.convert/att.c:78
 #: ../vector/v.net.path/path.c:109 ../vector/v.surf.rst/main.c:550
 #, c-format
@@ -21542,7 +21872,7 @@
 msgid "Unable to open dig_att file <%s>\n"
 msgstr "Kann die Datei dig_att <%s> nicht öffnen.\n"
-#: ../vector/v.build/main.c:34 ../vector/v.clean/main.c:43
+#: ../vector/v.build/main.c:34 ../vector/v.clean/main.c:42
 msgid "vector, topology"
 msgstr "Vektor, Topology"
@@ -21953,81 +22283,81 @@
 msgid "Cannot get line segment, segment out of line"
 msgstr "Kann die Segmentdatei %s nicht erzeugen."
-#: ../vector/v.extrude/main.c:66
+#: ../vector/v.extrude/main.c:67
 #, fuzzy
 msgid "vector, geometry, 3D"
 msgstr "Vektor, Geometrie"
-#: ../vector/v.extrude/main.c:68
+#: ../vector/v.extrude/main.c:69
 #, fuzzy
 msgid "Extrudes flat vector object to 3D with defined height."
 msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
-#: ../vector/v.extrude/main.c:72
+#: ../vector/v.extrude/main.c:73
 #, fuzzy
 msgid "Trace elevation"
 msgstr "Profildatei"
-#: ../vector/v.extrude/main.c:75
+#: ../vector/v.extrude/main.c:76
 #, fuzzy
 msgid "Name of input 2D vector map"
 msgstr "von"
-#: ../vector/v.extrude/main.c:78
+#: ../vector/v.extrude/main.c:79
 #, fuzzy
 msgid "Name of resulting 3D vector map"
 msgstr "von"
-#: ../vector/v.extrude/main.c:82 ../vector/v.transform/main.c:146
+#: ../vector/v.extrude/main.c:83 ../vector/v.transform/main.c:146
 #, fuzzy
 msgid "Shifting value for z coordinates"
 msgstr "für z"
-#: ../vector/v.extrude/main.c:90
+#: ../vector/v.extrude/main.c:91
 msgid "Elevation raster for height extraction"
 msgstr "Höhenmodell zum Extrahieren der Höhen."
-#: ../vector/v.extrude/main.c:97
+#: ../vector/v.extrude/main.c:98
 #, fuzzy
 msgid "Fixed height for 3D vector objects"
 msgstr "für"
-#: ../vector/v.extrude/main.c:102
+#: ../vector/v.extrude/main.c:103
 #, fuzzy
 msgid "Name of attribute column with object heights"
 msgstr "von attribute Tabelle"
-#: ../vector/v.extrude/main.c:116
+#: ../vector/v.extrude/main.c:117
 #, fuzzy, c-format
 msgid "One of '%s' or '%s' parameters must be set"
 msgstr "von s s"
-#: ../vector/v.extrude/main.c:185
+#: ../vector/v.extrude/main.c:186
 #, fuzzy
 msgid "Extruding areas..."
 msgstr "Verarbeite Flächen ..."
-#: ../vector/v.extrude/main.c:195 ../vector/v.out.svg/main.c:210
+#: ../vector/v.extrude/main.c:196 ../vector/v.out.svg/main.c:210
 #, c-format
 msgid "Skipping area %d without centroid"
 msgstr ""
-#: ../vector/v.extrude/main.c:210
+#: ../vector/v.extrude/main.c:211
 #, fuzzy, c-format
 msgid "Cannot select attributes for area %d"
 msgstr "für Bereich"
-#: ../vector/v.extrude/main.c:249
+#: ../vector/v.extrude/main.c:250
 #, fuzzy
 msgid "Extruding vector primitives..."
-#: ../vector/v.extrude/main.c:282
+#: ../vector/v.extrude/main.c:283
 #, fuzzy, c-format
 msgid "Cannot select attributes for area #%d"
-#: ../vector/v.extrude/main.c:300
+#: ../vector/v.extrude/main.c:301
 #, fuzzy, c-format
 msgid "Column <%s>: invalid data type"
 msgstr "Spalte <%s>: ungültiger Datentyp."
@@ -22409,7 +22739,7 @@
 msgid "Unable to calculate centroid for area %d"
 msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
-#: ../vector/v.generalize/main.c:489
+#: ../vector/v.generalize/main.c:486
 #, c-format
 msgid "Number of vertices was reduced from %d to %d [%d%%]"
 msgstr ""
@@ -22419,13 +22749,14 @@
 msgid "Calculating centrality measures..."
 msgstr "Berechne die Klassenmittel..."
-#: ../vector/v.generalize/misc.c:124 ../vector/v.extract/main.c:417
+#: ../vector/v.generalize/misc.c:124 ../vector/v.select/main.c:454
+#: ../vector/v.extract/main.c:413
 #, fuzzy
 msgid "Writing attributes..."
 msgstr "Schreibe Attribute ..."
 #: ../vector/v.generalize/misc.c:156 ../vector/v.voronoi/vo_main.c:316
-#: ../vector/v.select/main.c:476 ../vector/v.extract/main.c:450
+#: ../vector/v.extract/main.c:446
 #, c-format
 msgid "Layer %d"
 msgstr "Layer %d"
@@ -22577,18 +22908,18 @@
 msgid "  Comments:"
 msgstr "Mittelwert"
-#: ../vector/v.in.ogr/main.c:103
+#: ../vector/v.in.ogr/main.c:102
 #, fuzzy
 msgid "Convert OGR vector layers to GRASS vector map."
 msgstr ""
 "Konvertiere OGR Vektoren in das GRASS-Format: Vorhandene Treiber sind:\n"
-#: ../vector/v.in.ogr/main.c:110
+#: ../vector/v.in.ogr/main.c:109
 #, fuzzy
 msgid "OGR datasource name"
 msgstr "Datenbankname"
-#: ../vector/v.in.ogr/main.c:111
+#: ../vector/v.in.ogr/main.c:110
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -22599,14 +22930,14 @@
 "\t\tESRI Shapefile: Verzeichnis, welches die Shapes beinhaltet.\n"
 "\t\tMapInfo File: Verzeichnis, welches die MapInfo-Files enthält."
-#: ../vector/v.in.ogr/main.c:126
+#: ../vector/v.in.ogr/main.c:125
 #, fuzzy
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
 "Ausgabevektor. Wenn nichts angegeben ist, werden alle verfügbaren Layer nur "
 "angezeigt."
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:127
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -22617,32 +22948,32 @@
 " \t\tESRI Shapefile: shapefile-Name\n"
 "\t\tMapInfo Datei: Mapinfo-Dateiname."
-#: ../vector/v.in.ogr/main.c:138
+#: ../vector/v.in.ogr/main.c:137
 #, fuzzy
 msgid "Import subregion only"
 msgstr "Gebe nur Rasterkartenausdehnung aus."
-#: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:223
+#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.ogr/main.c:222
 #, fuzzy
 msgid "Subregion"
 msgstr "Region\n"
-#: ../vector/v.in.ogr/main.c:141
+#: ../vector/v.in.ogr/main.c:140
 #, fuzzy
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
 "Nur Sub-Region importieren (xmin, ymin, xmax, ymax - normalerweise W, S, E, "
 "N)."
-#: ../vector/v.in.ogr/main.c:152
+#: ../vector/v.in.ogr/main.c:151
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:153 ../vector/v.in.ogr/main.c:174
+#: ../vector/v.in.ogr/main.c:152 ../vector/v.in.ogr/main.c:173
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:153
 #, fuzzy
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
@@ -22650,12 +22981,12 @@
 "Einheit). Kleinere Flächen und Inseln werden ignoriert. Die Zahl soll größer "
 "als snap^2 sein."
-#: ../vector/v.in.ogr/main.c:160
+#: ../vector/v.in.ogr/main.c:159
 #, fuzzy
 msgid "Optionally change default input type"
 msgstr "Ausgabe-Rasterkarte (Standard: Eingabe Kachel)."
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:161
 #, fuzzy
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
@@ -22667,16 +22998,16 @@
 "\t boundary -> importiere Linien als Flächengrenzen\n"
 "\t centroid -> importiere Punkte als Zentroiden."
-#: ../vector/v.in.ogr/main.c:173
+#: ../vector/v.in.ogr/main.c:172
 #, fuzzy
 msgid "Snapping threshold for boundaries"
 msgstr "Schnapp-Schwellenwert für Boundaries. -1 für kein Schnappen."
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:174
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:189
+#: ../vector/v.in.ogr/main.c:188
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
@@ -22684,69 +23015,69 @@
 "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
 "Erste entspricht der Kategoriespalte."
-#: ../vector/v.in.ogr/main.c:191 ../vector/v.in.ogr/main.c:214
-#: ../vector/v.in.ogr/main.c:235 ../vector/v.to.rast/main.c:70
+#: ../vector/v.in.ogr/main.c:190 ../vector/v.in.ogr/main.c:213
+#: ../vector/v.in.ogr/main.c:234 ../vector/v.to.rast/main.c:70
 #: ../vector/v.to.rast/main.c:92 ../vector/v.to.rast/main.c:98
 #, fuzzy
 msgid "Attributes"
 msgstr "Datenbank, Attributtabelle"
-#: ../vector/v.in.ogr/main.c:196
+#: ../vector/v.in.ogr/main.c:195
 msgid "List available layers in data source and exit"
 msgstr "Zeigt die vorhandenen Datensätze in der Datenquelle und beendet sich."
-#: ../vector/v.in.ogr/main.c:205
+#: ../vector/v.in.ogr/main.c:204
 msgid "Do not clean polygons (not recommended)"
 msgstr "Polygone nicht säubern (clean) (nicht empfehlenswert)."
-#: ../vector/v.in.ogr/main.c:209 ../vector/v.random/main.c:122
+#: ../vector/v.in.ogr/main.c:208 ../vector/v.random/main.c:122
 msgid "Create 3D output"
 msgstr "Erzeuge eine 3D-Ausgabe."
-#: ../vector/v.in.ogr/main.c:219
+#: ../vector/v.in.ogr/main.c:218
 msgid "Override dataset projection (use location's projection)"
 msgstr ""
 "Übersteuere die Projektion des Datensatzes (verwende Projektion der "
 "Location)."
-#: ../vector/v.in.ogr/main.c:224
+#: ../vector/v.in.ogr/main.c:223
 #, fuzzy
 msgid "Limit import to the current region"
 msgstr "Die aktuelle Region nicht verändern."
-#: ../vector/v.in.ogr/main.c:234
+#: ../vector/v.in.ogr/main.c:233
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:258
+#: ../vector/v.in.ogr/main.c:252
 msgid "Available OGR Drivers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:296
+#: ../vector/v.in.ogr/main.c:290
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
-#: ../vector/v.in.ogr/main.c:304
+#: ../vector/v.in.ogr/main.c:298
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:333
+#: ../vector/v.in.ogr/main.c:327
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Die Vektorkarte '%s' existiert bereits und wird überschrieben."
-#: ../vector/v.in.ogr/main.c:377
+#: ../vector/v.in.ogr/main.c:371
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:405
+#: ../vector/v.in.ogr/main.c:399
 #, fuzzy
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "4 Werte sind für den Parameter 'spatial' nötig."
-#: ../vector/v.in.ogr/main.c:472
+#: ../vector/v.in.ogr/main.c:466
 #, fuzzy
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
@@ -22755,7 +23086,7 @@
 "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
 "erstelle daher keine neue Location."
-#: ../vector/v.in.ogr/main.c:484
+#: ../vector/v.in.ogr/main.c:478
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
@@ -22763,12 +23094,12 @@
 "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
 "konvertieren, zwecks Überprüfung."
-#: ../vector/v.in.ogr/main.c:514
+#: ../vector/v.in.ogr/main.c:508
 #, fuzzy
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "Location PROJ_INFO:\n"
-#: ../vector/v.in.ogr/main.c:574
+#: ../vector/v.in.ogr/main.c:568
 #, c-format
 msgid ""
 "\n"
@@ -22778,7 +23109,7 @@
 "Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
 "übersteuern.\n"
-#: ../vector/v.in.ogr/main.c:577
+#: ../vector/v.in.ogr/main.c:571
 #, fuzzy
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
@@ -22787,24 +23118,24 @@
 "Ziehen Sie das Erzeugen einer neuen Location mit dem Parameter 'location=' "
 "vom Eingabedatensatz in Betracht.\n"
-#: ../vector/v.in.ogr/main.c:605 ../vector/v.in.ogr/main.c:1006
+#: ../vector/v.in.ogr/main.c:599 ../vector/v.in.ogr/main.c:999
 #, fuzzy, c-format
 msgid "Layer: %s"
 msgstr "Layer %d"
-#: ../vector/v.in.ogr/main.c:669
+#: ../vector/v.in.ogr/main.c:663
 #, fuzzy, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "Spaltenname '%s' wurde in '%s' geändert."
-#: ../vector/v.in.ogr/main.c:705
+#: ../vector/v.in.ogr/main.c:699
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
 "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
 "abgeschnitten worden sein). "
-#: ../vector/v.in.ogr/main.c:728
+#: ../vector/v.in.ogr/main.c:722
 #, fuzzy, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
@@ -22813,83 +23144,83 @@
 "Spaltenbreite für die Spalte '%s' wird auf 255 gesetzt (nicht angegeben bei "
 "OGR). Einige Texte können abgeschnitten worden sein!"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:734
 #, fuzzy, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:744
+#: ../vector/v.in.ogr/main.c:738
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Spaltentyp (%s) wird nicht unterstützt."
-#: ../vector/v.in.ogr/main.c:786
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Importing map %d features..."
 msgstr "Importiere %d Objekte der Karte..."
-#: ../vector/v.in.ogr/main.c:882
+#: ../vector/v.in.ogr/main.c:876
 #, c-format
 msgid "%d %s without geometry"
 msgstr "%d %s ohne Geometrie."
-#: ../vector/v.in.ogr/main.c:906
+#: ../vector/v.in.ogr/main.c:900
 #, fuzzy
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "Säubere Polygone; für das Resultat wird nicht garantiert!\n"
-#: ../vector/v.in.ogr/main.c:915
+#: ../vector/v.in.ogr/main.c:909
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:923
 #, fuzzy
 msgid "Break polygons:"
 msgstr "Exportiere Linien als Polygone."
-#: ../vector/v.in.ogr/main.c:934 ../vector/v.in.ogr/main.c:946
+#: ../vector/v.in.ogr/main.c:928 ../vector/v.in.ogr/main.c:940
 #, fuzzy
 msgid "Remove duplicates:"
 msgstr "Entfernen"
-#: ../vector/v.in.ogr/main.c:942
+#: ../vector/v.in.ogr/main.c:936
 #, fuzzy
 msgid "Break boundaries:"
 msgstr "nicht"
-#: ../vector/v.in.ogr/main.c:950
+#: ../vector/v.in.ogr/main.c:944
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:958
+#: ../vector/v.in.ogr/main.c:951
 #, fuzzy
 msgid "Change boundary dangles to lines:"
 msgstr "Wechseln "
-#: ../vector/v.in.ogr/main.c:962
+#: ../vector/v.in.ogr/main.c:955
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:968
+#: ../vector/v.in.ogr/main.c:961
 #, fuzzy
 msgid "Change boundary bridges to lines:"
 msgstr "Wechseln "
-#: ../vector/v.in.ogr/main.c:972
+#: ../vector/v.in.ogr/main.c:965
 #, fuzzy
 msgid "Remove bridges:"
 msgstr "Entfernen"
-#: ../vector/v.in.ogr/main.c:991 ../vector/v.overlay/area_area.c:75
+#: ../vector/v.in.ogr/main.c:984 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.voronoi/dt_main.c:136 ../vector/v.buffer/main.c:657
 #: ../vector/v.buffer/main.c:737
 msgid "Cannot calculate area centroid"
 msgstr "Kann den Flächenzentroiden nicht berechnen."
-#: ../vector/v.in.ogr/main.c:1070
+#: ../vector/v.in.ogr/main.c:1063
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -22901,27 +23232,27 @@
 "der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
 "als Kategoriewert im Layer %d abgelegt."
-#: ../vector/v.in.ogr/main.c:1076
+#: ../vector/v.in.ogr/main.c:1069
 #, fuzzy, c-format
 msgid "%d input polygons"
 msgstr "%d Eingabepolygone\n"
-#: ../vector/v.in.ogr/main.c:1080
+#: ../vector/v.in.ogr/main.c:1073
 #, fuzzy, c-format
 msgid "Total area: %e (%d areas)"
-#: ../vector/v.in.ogr/main.c:1084
+#: ../vector/v.in.ogr/main.c:1077
 #, c-format
 msgid "Overlapping area: %e (%d areas)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1089
+#: ../vector/v.in.ogr/main.c:1082
 #, fuzzy, c-format
 msgid "Area without category: %e (%d areas)"
 msgstr "%d Punkte ohne Kategorie übersprungen."
-#: ../vector/v.in.ogr/main.c:1125
+#: ../vector/v.in.ogr/main.c:1118
 #, fuzzy
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
@@ -23096,48 +23427,48 @@
 msgstr ""
 "Fehler beim Lesen der Datei '%s'. Einige Daten könnten nicht korrekt sein.\n"
-#: ../vector/v.patch/main.c:367
+#: ../vector/v.patch/main.c:363
 #, fuzzy, c-format
 msgid "Building topology for vector map <%s>..."
 msgstr ""
 "\n"
 "Erstelle Topologie für %s ..."
-#: ../vector/v.patch/main.c:377
+#: ../vector/v.patch/main.c:369
 msgid "Intersections at borders will have to be snapped"
 msgstr ""
-#: ../vector/v.patch/main.c:378
+#: ../vector/v.patch/main.c:370
 msgid "Lines common between files will have to be edited"
 msgstr ""
-#: ../vector/v.patch/main.c:379
+#: ../vector/v.patch/main.c:371
 #, fuzzy
 msgid "The header information also may have to be edited"
 msgstr "Die Projektionsinformationen werden nicht aktualisiert."
-#: ../vector/v.patch/main.c:381
+#: ../vector/v.patch/main.c:373
 #, fuzzy, c-format
 msgid "%d vector maps patched"
 msgstr "%d Einträge aktualisiert."
-#: ../vector/v.patch/main.c:404
+#: ../vector/v.patch/main.c:396
 #, fuzzy, c-format
 msgid "Cannot open select cursor: '%s'"
 msgstr "Kann den Select-Cursor '%s' nicht öffnen."
-#: ../vector/v.patch/main.c:415
+#: ../vector/v.patch/main.c:407
 msgid "Cannot fetch row"
 msgstr "Kann die Zeile nicht holen."
-#: ../vector/v.patch/main.c:466
+#: ../vector/v.patch/main.c:458
 msgid "Unknown column type"
 msgstr "Unbekannter Spalten-Typ."
-#: ../vector/v.patch/main.c:474
-#, fuzzy, c-format
+#: ../vector/v.patch/main.c:466
+#, c-format
 msgid "Cannot insert new record: '%s'"
-msgstr "Kann neuen Eintrag nicht einfügen: %s"
+msgstr "Kann neuen Eintrag nicht einfügen: '%s'"
 #: ../vector/v.digit/centre.c:176
 msgid "Region restored to original extent."
@@ -23578,24 +23909,24 @@
 msgid "Unable to tokenize column string: %s"
 msgstr "Kann die Spalte '%s' nicht verwenden."
-#: ../vector/v.transform/main.c:349
+#: ../vector/v.transform/main.c:345
 #, fuzzy, c-format
 msgid ""
 "\n"
 "New vector map <%s> boundary coordinates:"
 msgstr "Randkoordinaten der neuen Vektorkarte <%s>:"
-#: ../vector/v.transform/main.c:351
+#: ../vector/v.transform/main.c:347
 #, c-format
 msgid " N: %-10.3f    S: %-10.3f"
 msgstr " N: %-10.3f    S: %-10.3f"
-#: ../vector/v.transform/main.c:352
+#: ../vector/v.transform/main.c:348
 #, c-format
 msgid " E: %-10.3f    W: %-10.3f"
 msgstr " O: %-10.3f    W: %-10.3f"
-#: ../vector/v.transform/main.c:353
+#: ../vector/v.transform/main.c:349
 #, c-format
 msgid " B: %6.3f    T: %6.3f"
 msgstr " B: %6.3f    T: %6.3f"
@@ -24083,49 +24414,49 @@
 msgid "[%d] categories read into memory"
 msgstr "%-5d Kategorien in den Speicher gelesen.\n"
-#: ../vector/v.overlay/line_area.c:69 ../vector/v.overlay/area_area.c:46
+#: ../vector/v.overlay/line_area.c:69 ../vector/v.overlay/area_area.c:39
 #, fuzzy
 msgid "Breaking lines..."
 msgstr "Extrahiere Zeilen ..."
-#: ../vector/v.overlay/line_area.c:164 ../vector/v.overlay/line_area.c:192
-#: ../vector/v.overlay/area_area.c:110 ../vector/v.overlay/area_area.c:190
-#: ../vector/v.overlay/area_area.c:218
+#: ../vector/v.overlay/line_area.c:161 ../vector/v.overlay/line_area.c:189
+#: ../vector/v.overlay/area_area.c:103 ../vector/v.overlay/area_area.c:183
+#: ../vector/v.overlay/area_area.c:211
 #, fuzzy
 msgid "Attribute not found"
 msgstr "Attribut-Spalte(n)"
-#: ../vector/v.overlay/line_area.c:220 ../vector/v.overlay/area_area.c:245
-#, fuzzy, c-format
+#: ../vector/v.overlay/line_area.c:217 ../vector/v.overlay/area_area.c:238
+#, c-format
 msgid "Unable to insert new record: '%s'"
-msgstr "Kann den neuen Datensatz '%s' nicht einfügen."
-#: ../vector/v.overlay/area_area.c:50 ../vector/v.buffer/main.c:621
+#: ../vector/v.overlay/area_area.c:43 ../vector/v.buffer/main.c:621
 #, fuzzy
 msgid "Removing duplicates..."
 msgstr "Entferne Doppelte ..."
-#: ../vector/v.overlay/area_area.c:53
+#: ../vector/v.overlay/area_area.c:46
 #, fuzzy
 msgid "Cleaning boundaries at nodes..."
-#: ../vector/v.overlay/area_area.c:62 ../vector/v.buffer/main.c:633
+#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer/main.c:633
 #, fuzzy
 msgid "Attaching islands..."
 msgstr "Füge Kategorien an...\n"
-#: ../vector/v.overlay/area_area.c:85
+#: ../vector/v.overlay/area_area.c:78
 #, fuzzy, c-format
 msgid "Querying vector map <%s>..."
 msgstr "Übetrage in die Karte ..."
-#: ../vector/v.overlay/area_area.c:121
+#: ../vector/v.overlay/area_area.c:114
 #, fuzzy
 msgid "Writing centroids..."
 msgstr "Schreibe Vertices..."
-#: ../vector/v.overlay/area_area.c:271 ../vector/v.buffer/main.c:747
+#: ../vector/v.overlay/area_area.c:264 ../vector/v.buffer/main.c:747
 #, fuzzy
 msgid "Attaching centroids..."
@@ -24394,20 +24725,20 @@
 msgid "%s: No font definition file"
 msgstr "%s: Keine FreeType Definitionsdatei gefunden."
-#: ../vector/v.clean/main.c:44
+#: ../vector/v.clean/main.c:43
 #, fuzzy
 msgid "Toolset for cleaning topology of vector map."
 msgstr "Werkzeugkasten zum Säubern der Vektortopologie"
-#: ../vector/v.clean/main.c:53
+#: ../vector/v.clean/main.c:52
 msgid "Name of output map where errors are written"
 msgstr "Name der Ausgabekarte, in die die Fehler geschrieben werden sollen."
-#: ../vector/v.clean/main.c:64
+#: ../vector/v.clean/main.c:63
 msgid "Cleaning tool"
 msgstr ""
-#: ../vector/v.clean/main.c:66
+#: ../vector/v.clean/main.c:65
 #, fuzzy
 msgid ""
 "break;break lines at each intersection;rmdupl;remove duplicate geometry "
@@ -24428,194 +24759,194 @@
 "is ignored;rmsa;remove small angles between lines at nodes"
 msgstr "in in"
-#: ../vector/v.clean/main.c:94
+#: ../vector/v.clean/main.c:93
 msgid ""
 "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
 msgstr ""
 "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: "
 "0.0[,0.0,...])."
-#: ../vector/v.clean/main.c:100
+#: ../vector/v.clean/main.c:99
 msgid "Don't build topology for the output vector"
 msgstr "Erzeugt keine Topologie für die Ausgabe Vektorkarte."
-#: ../vector/v.clean/main.c:121
+#: ../vector/v.clean/main.c:120
 msgid "You must select at least one tool"
 msgstr "Es muss mindestens ein Werkzeug ausgewählt werden."
-#: ../vector/v.clean/main.c:156
+#: ../vector/v.clean/main.c:155
 msgid "Tool doesn't exist"
 msgstr "Werkzeug existiert nicht."
-#: ../vector/v.clean/main.c:176
+#: ../vector/v.clean/main.c:175
 #, c-format
 msgid "Threshold for tool %d may not be > 0, set to 0"
 msgstr "Der Schwellwert für %d sollte nicht > 0 sein, setze auf 0."
-#: ../vector/v.clean/main.c:185
+#: ../vector/v.clean/main.c:184
 msgid "Tool: Threshold"
 msgstr ""
-#: ../vector/v.clean/main.c:190
+#: ../vector/v.clean/main.c:189
 #, fuzzy
 msgid "Break"
 msgstr "Fläche:\n"
-#: ../vector/v.clean/main.c:193
+#: ../vector/v.clean/main.c:192
 #, fuzzy
 msgid "Remove duplicates"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:196
+#: ../vector/v.clean/main.c:195
 #, fuzzy
 msgid "Remove dangles"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:199
+#: ../vector/v.clean/main.c:198
 #, fuzzy
 msgid "Change type of boundary dangles"
 msgstr "Wechseln "
-#: ../vector/v.clean/main.c:203
+#: ../vector/v.clean/main.c:202
 #, fuzzy
 msgid "Remove bridges"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:206
+#: ../vector/v.clean/main.c:205
 #, fuzzy
 msgid "Change type of boundary bridges"
 msgstr "Wechseln "
-#: ../vector/v.clean/main.c:210
+#: ../vector/v.clean/main.c:209
 #, fuzzy
 msgid "Snap vertices"
-#: ../vector/v.clean/main.c:213
+#: ../vector/v.clean/main.c:212
 #, fuzzy
 msgid "Remove duplicate area centroids"
 msgstr "Entferne doppelte Zentroiden..."
-#: ../vector/v.clean/main.c:217
+#: ../vector/v.clean/main.c:216
 #, fuzzy
 msgid "Break polygons"
-#: ../vector/v.clean/main.c:220
+#: ../vector/v.clean/main.c:219
 #, fuzzy
 msgid "Prune"
 msgstr "Drucke"
-#: ../vector/v.clean/main.c:223
+#: ../vector/v.clean/main.c:222
 #, fuzzy
 msgid "Remove small areas"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:226
+#: ../vector/v.clean/main.c:225
 #, fuzzy
 msgid "Remove small angles at nodes"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:231
+#: ../vector/v.clean/main.c:230
 msgid "Remove all lines or boundaries of zero length"
 msgstr ""
-#: ../vector/v.clean/main.c:268
+#: ../vector/v.clean/main.c:267
 #, fuzzy
 msgid "Copying vector lines..."
 msgstr "Kopiere Vektorlinien ..."
-#: ../vector/v.clean/main.c:294 ../vector/v.clean/main.c:304
+#: ../vector/v.clean/main.c:288 ../vector/v.clean/main.c:298
 #, fuzzy
 msgid "Rebuilding parts of topology..."
 msgstr "Erstelle Teile der Topologie ..."
-#: ../vector/v.clean/main.c:312
+#: ../vector/v.clean/main.c:306
 msgid "Tool: Break lines at intersections"
 msgstr ""
-#: ../vector/v.clean/main.c:316
+#: ../vector/v.clean/main.c:310
 #, fuzzy
 msgid "Tool: Remove duplicates"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:320
+#: ../vector/v.clean/main.c:314
 #, fuzzy
 msgid "Tool: Remove dangles"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:324
+#: ../vector/v.clean/main.c:318
 #, fuzzy
 msgid "Tool: Change type of boundary dangles"
 msgstr "Wechseln"
-#: ../vector/v.clean/main.c:328
+#: ../vector/v.clean/main.c:322
 #, fuzzy
 msgid "Tool: Remove bridges"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:332
+#: ../vector/v.clean/main.c:326
 #, fuzzy
 msgid "Tool: Change type of boundary bridges"
 msgstr "Wechseln"
-#: ../vector/v.clean/main.c:336
+#: ../vector/v.clean/main.c:330
 #, fuzzy
 msgid "Tool: Remove duplicate area centroids"
-#: ../vector/v.clean/main.c:340
+#: ../vector/v.clean/main.c:334
 #, fuzzy
 msgid "Tool: Snap line to vertex in threshold"
 msgstr "in"
-#: ../vector/v.clean/main.c:344
+#: ../vector/v.clean/main.c:338
 msgid "Tool: Break polygons"
 msgstr ""
-#: ../vector/v.clean/main.c:348
+#: ../vector/v.clean/main.c:342
 #, fuzzy
 msgid "Tool: Prune lines/boundaries"
 msgstr "nicht"
-#: ../vector/v.clean/main.c:352
+#: ../vector/v.clean/main.c:346
 #, fuzzy
 msgid "Tool: Remove small areas"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:356
+#: ../vector/v.clean/main.c:349
 #, c-format
 msgid "%d areas of total size %g removed"
 msgstr ""
-#: ../vector/v.clean/main.c:359
+#: ../vector/v.clean/main.c:352
 #, fuzzy
 msgid "Tool: Remove small angles at nodes"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:362
+#: ../vector/v.clean/main.c:355
 #, c-format
 msgid "%d modifications done"
 msgstr ""
-#: ../vector/v.clean/main.c:365
+#: ../vector/v.clean/main.c:358
 #, fuzzy
 msgid "Tool: Remove all lines and boundaries of zero length"
 msgstr "Entfernen"
-#: ../vector/v.clean/main.c:367
+#: ../vector/v.clean/main.c:360
 #, fuzzy, c-format
 msgid "%d lines / boundaries removed"
 msgstr "%s Datei(en), die entfernt werden sollen."
-#: ../vector/v.clean/main.c:375
+#: ../vector/v.clean/main.c:368
 #, fuzzy
 msgid "Rebuilding topology for output vector map..."
 msgstr ""
 "\n"
-#: ../vector/v.clean/main.c:386
+#: ../vector/v.clean/main.c:379
 #, fuzzy
 msgid "Building topology for error vector map..."
 msgstr ""
@@ -24632,24 +24963,14 @@
 msgid "Duplicate area centroids"
 msgstr "Doppelte Flächen-Zentroide: %5d"
-#: ../vector/v.clean/prune.c:62
+#: ../vector/v.clean/prune.c:212
 #, c-format
-msgid "Removed vertices: %5d"
-msgstr ""
-#: ../vector/v.clean/prune.c:215
-#, fuzzy
-msgid "Removed vertices"
-msgstr "Entfernen"
-#: ../vector/v.clean/prune.c:220
-#, c-format
 msgid ""
 "\n"
 "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
-#: ../vector/v.clean/prune.c:224
+#: ../vector/v.clean/prune.c:216
 #, fuzzy, c-format
 msgid "%d boundaries not pruned because pruning would damage topology"
 msgstr "weil."
@@ -24858,7 +25179,7 @@
 msgid "Output tessellation as a graph (lines), not areas"
 msgstr "Ergebnis"
-#: ../vector/v.voronoi/vo_main.c:321 ../vector/v.extract/main.c:455
+#: ../vector/v.voronoi/vo_main.c:321 ../vector/v.extract/main.c:451
 #, fuzzy
 msgid "No table"
 msgstr "Keine Tabelle."
@@ -24871,7 +25192,7 @@
 msgid "Offset in map units, positive for right side, negative for left side."
 msgstr ""
-#: ../vector/v.what/what.c:132
+#: ../vector/v.what/what.c:221
 #, fuzzy, c-format
 msgid ""
 "Id: %d\n"
@@ -24884,7 +25205,7 @@
 "Links: %d  \n"
 "Rechts: %d  \n"
-#: ../vector/v.what/what.c:152
+#: ../vector/v.what/what.c:241
 #, fuzzy, c-format
 msgid ""
 "Node[%d]: %d\n"
@@ -24895,7 +25216,7 @@
 "Anzahl der Linien: %d  \n"
 "Koordinaten: %.6f, %.6f, %.6f\n"
-#: ../vector/v.what/what.c:160
+#: ../vector/v.what/what.c:249
 #, fuzzy, c-format
 msgid ""
 "Id: %5d\n"
@@ -24904,17 +25225,17 @@
 "Linie: %5d  \n"
 "Winkel: %.8f\n"
-#: ../vector/v.what/what.c:167
+#: ../vector/v.what/what.c:256
 #, fuzzy, c-format
 msgid "Type: %s"
 msgstr "Layer %d"
-#: ../vector/v.what/what.c:168
+#: ../vector/v.what/what.c:257
 #, c-format
 msgid "Id: %d\n"
 msgstr "Id: %d\n"
-#: ../vector/v.what/what.c:194
+#: ../vector/v.what/what.c:283
 #, fuzzy, c-format
 msgid ""
 "Line height min: %f\n"
@@ -24923,7 +25244,7 @@
 "Linien-Höhe min: %f \n"
 "Linien-Höhe max: %f\n"
-#: ../vector/v.what/what.c:203
+#: ../vector/v.what/what.c:292
 #, fuzzy, c-format
 msgid ""
 "Type: Area\n"
@@ -24932,12 +25253,12 @@
 "Objekttyp: Fläche \n"
 "Flächen-Höhe: %f\n"
-#: ../vector/v.what/what.c:207
+#: ../vector/v.what/what.c:296
 #, fuzzy, c-format
 msgid "Type: Area\n"
 msgstr "Objekttyp: Fläche\n"
-#: ../vector/v.what/what.c:214
+#: ../vector/v.what/what.c:303
 #, fuzzy, c-format
 msgid ""
 "Area: %d\n"
@@ -24946,17 +25267,17 @@
 "Fläche: %d  \n"
 "Anzahl der Inseln: %d\n"
-#: ../vector/v.what/what.c:219
+#: ../vector/v.what/what.c:308
 #, c-format
 msgid "Isle[%d]: %d\n"
 msgstr "Insel[%d]: %d\n"
-#: ../vector/v.what/what.c:226
+#: ../vector/v.what/what.c:315
 #, c-format
 msgid "Island: %d In area: %d\n"
 msgstr "Insel: %d in der Fläche: %d\n"
-#: ../vector/v.what/what.c:231 ../vector/v.what/what.c:238
+#: ../vector/v.what/what.c:320 ../vector/v.what/what.c:327
 #, fuzzy, c-format
 msgid ""
 "Sq Meters: %.3f\n"
@@ -24965,7 +25286,7 @@
 "Quadratmeter: %.3f \n"
 "Hektar: %.3f\n"
-#: ../vector/v.what/what.c:233 ../vector/v.what/what.c:241
+#: ../vector/v.what/what.c:322 ../vector/v.what/what.c:330
 #, fuzzy, c-format
 msgid ""
 "Acres: %.3f\n"
@@ -24974,7 +25295,7 @@
 "Acres: %.3f \n"
 "Sq Miles: %.4f\n"
-#: ../vector/v.what/what.c:259
+#: ../vector/v.what/what.c:348
 #, fuzzy, c-format
 msgid ""
 "Layer: %d\n"
@@ -24983,7 +25304,7 @@
 "Layer: %d\n"
 "Category: %d \n"
-#: ../vector/v.what/what.c:266
+#: ../vector/v.what/what.c:354
 #, fuzzy, c-format
 msgid ""
 "\n"
@@ -25406,32 +25727,84 @@
 msgid "Unable to open history file for vector map <%s>"
+#: ../vector/v.select/main.c:132
+#, fuzzy
+msgid "vector, query"
+msgstr "Vektor, Netzwerk"
 #: ../vector/v.select/main.c:134
 #, fuzzy
-msgid "Select features from ainput by features from binput"
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
 msgstr "von von"
-#: ../vector/v.select/main.c:164
+#: ../vector/v.select/main.c:137
 #, fuzzy
+msgid "Name of input vector map (A)"
+msgstr "Name für die Eingabe-Vektorkarte"
+#: ../vector/v.select/main.c:141
+#, fuzzy
+msgid "Feature type (vector map A)"
+msgstr "Erzeuge 3D-Vektorkarte."
+#: ../vector/v.select/main.c:145
+#, fuzzy
+msgid "Layer number (vector map A)"
+msgstr "Lesefehler in Vektordatei."
+#: ../vector/v.select/main.c:149
+#, fuzzy
+msgid "Name of input vector map (B)"
+#: ../vector/v.select/main.c:153
+#, fuzzy
+msgid "Feature type (vector map B)"
+#: ../vector/v.select/main.c:157
+#, fuzzy
+msgid "Layer number (vector map B)"
+#: ../vector/v.select/main.c:170
+#, fuzzy
+msgid "Operator defines required relation between features"
+msgstr "%d Punkte in die Vektorkarte geschrieben."
+#: ../vector/v.select/main.c:172
+#, fuzzy
 msgid ""
-"Operator defines required relation between features. A feature is written to "
-"output if the result of operation 'ainput operator binput' is true. An input "
-"feature is considered to be true, if category of given layer is defined.\n"
-"\t overlap: features partially or completely overlap"
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+"given layer is defined."
 msgstr "Operator zwischen feature ist Ausgabe von ist feature ist von ist n"
-#: ../vector/v.select/main.c:216
-msgid "Processing ainput lines ..."
-msgstr "Verarbeite ainput Zeilen ..."
+#: ../vector/v.select/main.c:174
+msgid "overlap;features partially or completely overlap"
+msgstr ""
-#: ../vector/v.select/main.c:296
-msgid "Processing ainput areas ..."
+#: ../vector/v.select/main.c:223
+#, fuzzy
+msgid "Processing vector features..."
 msgstr "Verarbeite ainput Flächen ..."
-#: ../vector/v.select/main.c:447
-msgid "Writing attributes ..."
-msgstr "Schreibe Attribute ..."
+#: ../vector/v.select/main.c:303
+#, fuzzy
+msgid "Processing vector areas..."
+msgstr "Verarbeite ainput Flächen ..."
+#: ../vector/v.select/main.c:486
+#, fuzzy, c-format
+msgid "Layer %d - no table"
+msgstr "Layer <%s> ist nicht vorhanden."
+#: ../vector/v.select/main.c:501
+#, fuzzy, c-format
+msgid "Layer %d - unable to copy table"
+msgstr "Kann temporäre Datei nicht öffnen."
 #: ../vector/v.net.alloc/main.c:62
 msgid "Allocate subnets for nearest centres (direction from centre)."
 msgstr ""
@@ -25811,7 +26184,7 @@
 msgid "%d points written to vector map"
-#: ../vector/v.in.db/main.c:219 ../vector/v.extract/main.c:470
+#: ../vector/v.in.db/main.c:219 ../vector/v.extract/main.c:466
 #, fuzzy
 msgid "Unable to copy table"
@@ -26051,11 +26424,11 @@
 msgstr "Kann die Eingabevektorkarte <%s> nicht finden."
 #: ../vector/v.drape/main.c:157
-#, c-format
+#, fuzzy, c-format
 msgid ""
 "Elevation raster map <%s> does not cover the entire area of the input vector "
 "map <%s>. "
-msgstr ""
+msgstr "Kann die Eingabevektorkarte <%s> nicht finden."
 #: ../vector/v.out.ogr/main.c:87
 #, fuzzy
@@ -26789,18 +27162,12 @@
 msgstr "Kann Referenzdatensatz nicht einfügen: %s"
 #: ../vector/v.lrs/v.lrs.create/main.c:863
-#, fuzzy
 msgid "Building topology for output (out_lines) map..."
-msgstr ""
-"\n"
-"Erstelle Topologie für %s ..."
+msgstr "Erstelle Topologie für Ausgabekarte (out_lines)..."
 #: ../vector/v.lrs/v.lrs.create/main.c:869
-#, fuzzy
 msgid "Building topology for error (err) map..."
-msgstr ""
-"\n"
+msgstr "Erstelle Topologie für Fehlerkarte (err)..."
 #: ../vector/v.lrs/v.lrs.where/main.c:60
 msgid ""
@@ -26814,29 +27181,28 @@
 msgstr "Eingabekarte mit den Trainingspunkten."
 #: ../vector/v.lrs/v.lrs.where/main.c:108
-#, fuzzy
 msgid "Maximum distance to nearest line"
+msgstr "Maximale Distanz zur nächsten Linie."
 #: ../vector/v.lrs/v.lrs.where/main.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] positions found"
-msgstr "%d Positionen gefunden."
+msgstr "[%d] Positionen gefunden."
 #: ../vector/v.lrs/v.lrs.where/main.c:223
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points outside threshold"
-msgstr "%d Punkte außerhalb des Schwellenwertes."
+msgstr "[%d] Punkte außerhalb des Schwellenwertes."
 #: ../vector/v.lrs/v.lrs.where/main.c:225
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points - no record found"
-msgstr "%d Punkte - kein Eintrag gefunden."
+msgstr "[%d] Punkte - kein Eintrag gefunden."
 #: ../vector/v.lrs/v.lrs.where/main.c:227
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points - too many records found"
-msgstr "%d Punkte - zu viele Einträge gefunden."
+msgstr "[%d] Punkte - zu viele Einträge gefunden."
 #: ../vector/v.buffer/main.c:256
 #, fuzzy
@@ -26889,12 +27255,11 @@
 msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt."
 #: ../vector/v.buffer/main.c:428
-#, fuzzy
 msgid "Lines buffers... "
-msgstr "Linien Buffer ..."
+msgstr "Linien-Buffer... "
 #: ../vector/v.buffer/main.c:469 ../vector/v.buffer/main.c:546
-#, fuzzy, c-format
+#, c-format
 msgid "Attribute is of invalid size (%.3f) for category %d"
 msgstr "Attribut hat ungültige Größe (%.3f) für Kategorie %d."
@@ -26905,18 +27270,16 @@
 "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
 #: ../vector/v.buffer/main.c:505
-#, fuzzy
 msgid "Areas buffers... "
-msgstr "Flächen Buffer ..."
+msgstr "Flächen-Buffer ..."
 #: ../vector/v.buffer/main.c:603
 msgid "Building parts of topology..."
 msgstr "Erstelle Teile der Topologie..."
 #: ../vector/v.buffer/main.c:615
-#, fuzzy
 msgid "Snapping boundaries..."
-msgstr "Drehe Daten..."
+msgstr "Snappe Grenzen..."
 #: ../vector/v.buffer/main.c:618
 msgid "Breaking boundaries..."
@@ -26958,12 +27321,12 @@
 #: ../vector/v.proj/main.c:156
 #, c-format
 msgid "Checking location <%s> mapset <%s>"
-msgstr "Prüfe Location <%s>, Mapset <%s>."
+msgstr "Prüfe Location <%s> Mapset <%s>."
 #: ../vector/v.proj/main.c:170
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden."
+msgstr "Vektorkarte <%s> in der Location <%s> im Mapset <%s> nicht gefunden."
 #: ../vector/v.proj/main.c:194
 #, c-format
@@ -27011,18 +27374,16 @@
 msgstr ""
 #: ../vector/v.extract/main.c:119
-#, fuzzy
 msgid "If -1, all features in all layers of given type are extracted"
 msgstr ""
-"Layernummer: Wenn -1 angegeben ist, werden alle Layer des angegebenen Typs "
-"extrahiert."
+"Wenn -1, dann werden alle Feature in allen Layern des angegebenen Typs "
+"werden extrahiert."
 #: ../vector/v.extract/main.c:127
-#, fuzzy
 msgid "Enter -1 to keep original categories or the desired NEW category value"
 msgstr ""
-"Geben Sie -1 ein, um die Original-Kategorie beizubehalten oder eine NEUE "
-"Kategorienummer. Keine Tabelle wird kopiert, wenn 'new >= 0' angegeben wird."
+"Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der "
+"erwünschte NEUE Kategoriewert."
 #: ../vector/v.extract/main.c:128
 msgid "If new >= 0, table is not copied"
@@ -27058,27 +27419,27 @@
 #: ../vector/v.extract/main.c:215
 #, fuzzy, c-format
 msgid "Category value in '%s' not valid"
-msgstr "Kategorie-Wert in <%s> ist nicht gültig."
+msgstr "Kategoriewert in <%s> ist nicht gültig."
 #: ../vector/v.extract/main.c:231
-#, fuzzy, c-format
+#, c-format
 msgid "Process file <%s> for category numbers"
-msgstr "Prozess Datei <%s> für die Kategorienummern.\n"
+msgstr "Bearbeite Datei <%s> für Kategorienummern."
 #: ../vector/v.extract/main.c:236
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open specified file <%s>"
 msgstr "Kann die angegebenen Datei <%s> nicht öffnen."
 #: ../vector/v.extract/main.c:246
 #, c-format
 msgid "Ignored text entry: %s"
-msgstr "Ignoriere Text-Eintrag: %s."
+msgstr "Ignorierter Text-Eintrag: %s."
 #: ../vector/v.extract/main.c:284
-#, fuzzy, c-format
+#, c-format
 msgid "%d categories loaded from table <%s>"
-msgstr "geladen von Tabelle"
+msgstr "%d Kategorien von der Tabelle <%s> geladen."
 #: ../vector/v.extract/main.c:299
 msgid ""
@@ -27087,11 +27448,8 @@
 msgstr ""
 #: ../vector/v.extract/main.c:305
-#, fuzzy
 msgid "Please specify random number larger than 0"
-msgstr ""
-"Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
-"sollen."
+msgstr "Bitte geben Sie eine Zufallszahl größer als 0 an."
 #: ../vector/v.extract/main.c:309
 #, c-format
@@ -27107,30 +27465,24 @@
 "count %d"
 msgstr ""
-#: ../vector/v.extract/main.c:487
+#: ../vector/v.extract/main.c:483
 msgid "Removing duplicate centroids..."
 msgstr "Lösche doppelte Zentroide..."
 #: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#: ../visualization/xganim/Clr_table.c:94
-#: ../visualization/xganim/Clr_table.c:292
-#: ../visualization/xganim/Clr_table.c:318
 #, c-format
 msgid "Unknown visual class [%d]."
 msgstr "Unbekannte sichtbare Klasse [%d]."
 #: ../visualization/ximgview/color.c:239
-#: ../visualization/xganim/Clr_table.c:243
 msgid "Unable to get sufficient gray shades."
 msgstr "Kann keine zufriedenstellenden Grauschattierungen finden."
 #: ../visualization/ximgview/color.c:256
-#: ../visualization/xganim/Clr_table.c:260
 msgid "Unable to get sufficient colors."
 msgstr "Kann keine zufriedenstellenden Farben finden."
 #: ../visualization/ximgview/color.c:269
-#: ../visualization/xganim/Clr_table.c:273
 msgid "Using private colormap for DirectColor visual."
 msgstr "Benutze private Farbtabelle für DirectColor Visualisierung."
@@ -27173,23 +27525,6 @@
 msgid "Percentage of CPU time to use"
 msgstr ""
-#: ../visualization/xganim/main.c:379
-#, fuzzy, c-format
-msgid "Reading file [%s]..."
-msgstr "Lese Datei <%s>..."
-#: ../visualization/xganim/main.c:401
-msgid "Unable to determine raster cell type"
-msgstr "Kann den Rasterzelltyp nicht bestimmen."
-#: ../visualization/xganim/main.c:405
-msgid "Unable to read color file"
-msgstr "Kann die Farbdatei nicht lesen."
-#: ../visualization/xganim/main.c:410
-msgid "Unable to read raster row"
-msgstr "Kann Rasterzeile nicht lesen."
 #: ../visualization/nviz/src/nviz_init.c:52
 msgid "raster, vector, visualization"
 msgstr "Raster, Vektor, Visualisierung"
@@ -27256,9 +27591,8 @@
 msgstr "Führe Skriptdatei beim Starten aus."
 #: ../visualization/nviz/src/nviz_init.c:130
-#, fuzzy
 msgid "Load previously saved state file"
-msgstr "Lade gespeicherte 'State'-Datei."
+msgstr "Lade gespeicherte Zustandsdatei."
 #: ../visualization/nviz/src/nviz_init.c:279
 msgid "Number of elevation files does not match number of colors files"
@@ -27267,9 +27601,8 @@
 "Farbinformationen überein."
 #: ../visualization/nviz/src/nviz_init.c:290
-#, fuzzy
 msgid "Loading data failed"
-msgstr "Lese Daten:"
+msgstr "Laden der Daten fehlgeschlagen."
 #: ../visualization/nviz2/cmd/main.c:46
 msgid "visualization, raster, vector, raster3d"
@@ -27303,15 +27636,13 @@
 msgstr "Verwende Zeichen-Modus für alle geladenen Oberflächen."
 #: ../visualization/nviz2/cmd/args.c:74
-#, fuzzy
 msgid "Name for output file (do not add extension)"
 msgstr "Name der Ausgabedatei (Fügen Sie keine Dateiendung an)."
 #: ../visualization/nviz2/cmd/args.c:75 ../visualization/nviz2/cmd/args.c:85
 #: ../visualization/nviz2/cmd/args.c:95
-#, fuzzy
 msgid "Image"
-msgstr "Bilder"
+msgstr "Bild"
 #: ../visualization/nviz2/cmd/args.c:83
 msgid "Graphics file format"
@@ -27406,9 +27737,8 @@
 msgstr "Shading"
 #: ../visualization/nviz2/cmd/args.c:265
-#, fuzzy
 msgid "Wire color"
-msgstr "Linien-Farbe"
+msgstr "Gitternetzfarbe"
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
@@ -27423,19 +27753,16 @@
 #: ../visualization/nviz2/cmd/args.c:302 ../visualization/nviz2/cmd/args.c:313
 #: ../visualization/nviz2/cmd/args.c:324 ../visualization/nviz2/cmd/args.c:336
 #: ../visualization/nviz2/cmd/args.c:346 ../visualization/nviz2/cmd/args.c:358
-#, fuzzy
 msgid "Vector lines"
-msgstr "Vektor"
+msgstr "Vektorlinie"
 #: ../visualization/nviz2/cmd/args.c:312
-#, fuzzy
 msgid "Vector line width"
 msgstr "Linienbreite"
 #: ../visualization/nviz2/cmd/args.c:321
-#, fuzzy
 msgid "Vector line color"
-msgstr "Umrandungsfarbe."
+msgstr "Linienfarbe"
 #: ../visualization/nviz2/cmd/args.c:333
 #, fuzzy
@@ -27454,12 +27781,10 @@
 #: ../visualization/nviz2/cmd/args.c:370 ../visualization/nviz2/cmd/args.c:381
 #: ../visualization/nviz2/cmd/args.c:393 ../visualization/nviz2/cmd/args.c:404
 #: ../visualization/nviz2/cmd/args.c:417 ../visualization/nviz2/cmd/args.c:427
-#, fuzzy
 msgid "Vector points"
-msgstr "Vektorkarte %s nicht gefunden."
+msgstr "Vektorpunkte"
 #: ../visualization/nviz2/cmd/args.c:380
-#, fuzzy
 msgid "Icon size"
 msgstr "Symbolgröße"
@@ -27563,9 +27888,9 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/surface.c:126
-#, fuzzy, c-format
+#, c-format
 msgid "Color attribute not defined, using default <%s>"
-msgstr "Papier '%s' nicht gefunden, verwende Standardwerte."
+msgstr "Farbwert nicht angegeben, verwende Standardwert <%s>."
 #: ../visualization/nviz2/cmd/surface.c:203
 #, fuzzy, c-format
@@ -27579,14 +27904,13 @@
 msgstr "Kann den Header von %s nicht lesen."
 #: ../visualization/nviz2/cmd/vector.c:181
-#, fuzzy
 msgid "Unknown icon marker"
-msgstr "Unbekannter Spalten-Typ."
+msgstr "Unbekannter Symbolmarker"
 #: ../visualization/nviz2/cmd/volume.c:74
 #, fuzzy, c-format
 msgid "Error tokenize '%s'"
-msgstr "Fehler beim Öffnen der G3D-Rasterkarte <%s>."
+msgstr "Error tokenize <%s>"
 #: ../visualization/nviz2/cmd/volume.c:81
 #, fuzzy, c-format
@@ -27604,7 +27928,201 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Kann folgende Attribute nicht auswählen: %s"
+msgid "Removing %s <%s>"
+msgstr "Entferne %s <%s>."
+msgid "couldn't be removed"
+msgstr "konnte nicht entfernt werden."
+msgid "%s: couldn't be removed"
+msgstr "%s: konnte nicht entfernt werden."
+msgid "%s: missing"
+msgstr "%s: fehlt."
+msgid "%s: removed"
+msgstr "%s: gelöscht."
+msgid "<%s> nothing removed"
+msgstr "<%s> nichts gelöscht."
 msgid ""
+"Format error: <%s>\n"
+"Line: %d\n"
+"%s"
+msgstr ""
+"Formatfehler: <%s>\n"
+"Zeile: %d\n"
+"%s"
+#, fuzzy
+msgid "Unable to find the real-image map <%s>"
+msgstr "%s: %s - Kann das Realteil-Bild nicht finden."
+msgid ""
+"Unable to open real-image in the cell_misc directory.\n"
+"Input map probably wasn't created by i.fft"
+msgstr ""
+"Kann das Realteil-Bild im cell_misc-Ordner nicht öffnen.\n"
+"Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#, fuzzy
+msgid "Unable to find the imaginary-image <%s>"
+msgstr "%s: %s - Kann das Bild mit dem imaginären Teil nicht finden."
+msgid ""
+"Unable to open imaginary-image in the cell_misc directory.\n"
+msgstr ""
+"Kann das Bild mit dem imaginären Teil im cell_misc Ordner nicht öffnen.\n"
+msgid "Power 2 values : [%d] rows [%d] columns."
+msgstr "'hoch zwei'-Werte: [%d] Zeilen [%d] Spalten."
+msgid "Unable to open output file."
+msgstr "Öffnen der Ausgabedatei nicht möglich"
+msgid "Writing data to file..."
+msgstr "Schreibe Daten in die Datei..."
+msgid "Range of values in output display files"
+msgstr "Wertebereich in den Ausgabedateien."
+msgid "Range less than or equal to zero not allowed."
+msgstr "Bereich weniger oder gleich Null ist nicht erlaubt."
+msgid "Initializing data...\n"
+msgstr "Initialisiere Daten...\n"
+msgid "Writing viewable versions of transformed data to files..."
+msgstr "Schreibe sichtbare Versionen der transformierten Daten in Dateien..."
+msgid "Unable to open file in the cell_misc directory."
+msgstr "Kann Datei im cell_misc Verzeichnis nicht öffnen."
+#, fuzzy
+msgid "Creates control points on an image to be ortho-rectified."
+msgstr ""
+"Erzeuge Kontrollounkte auf einem Bild, welches orthorektifiziert werden soll."
+#, fuzzy
+msgid "Name of image to be rectified which will  be initially drawn on screen."
+msgstr ""
+"Name der Karte die entzerrt werden soll. Sie wird sofort auf dem Bildschirm "
+"dargestellt."
+#, fuzzy
+msgid ""
+"Name of a map from target mapset which  will be initially drawn on screen."
+msgstr ""
+"Name einer Karte im Zielmapset. Sie wird sofort auf dem Bildschirm "
+"dargestellt."
+msgid "Unable to read head of %s"
+msgstr "Kann den Header von <%s> nicht lesen."
+#, fuzzy
+msgid "Name of imagery group for ortho-rectification"
+msgstr "Name der Ziellocation für das Bild."
+msgid "Unable to write temp file: %s"
+msgstr "Kann die temporäre Datei <%s> nicht schreiben."
+msgid "Unable to open map %s"
+msgstr "Kann die Karte <%s> nicht öffnen."
+msgid "Unable to write row %d"
+msgstr "Kann die Zeile %d nicht schreiben."
+msgid "GIS manager for GRASS"
+msgstr "GIS Manager für GRASS."
+#, fuzzy
+msgid "Name of GIS manager settings file (.grc)"
+msgstr "Name der MAT-Datei (v4)"
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr "Erzeugt ausdrücklich eine NULL-Wert Bitmap-Datei."
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed."
+msgstr ""
+"Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
+"Optionen angegeben werden."
+#, fuzzy
+msgid "Name of the sampling locations vector points map"
+msgstr "Name der Eingabe-Vektorkarte."
+#, fuzzy
+msgid "Density of output walkers"
+msgstr "Name der Ausgabedatei"
+msgid "File [%s] not found"
+msgstr "Datei [%s] nicht gefunden."
+msgid "Unable to open file [%s]"
+msgstr "Kann die Datei [%s] nicht öffnen."
+msgid "Failed to guess file format"
+msgstr "Das Erraten des Datei-Formates ist fehlgeschlagen."
+msgid "Reading sites map (%s) ..."
+msgstr "Lese Sites-Karte (%s) ..."
+#, fuzzy
+msgid "Name of the output walkers vector points map"
+#, fuzzy
+msgid "You are not outputting any raster or vector points maps"
+msgstr "Es werden weder Vektor- noch Rasterdaten ausgegeben."
+msgid "No map specified"
+msgstr "Keine Karte angegeben."
+msgid "%s - unable to remove color table"
+msgstr "%s - kann die Farbtabelle nicht löschen."
+msgid "%s - color table not found"
+msgstr "%s - Farbtabelle nicht gefunden."
+msgid "Can't make logarithmic color table for floating point map"
+msgstr "Kann keine logarithmische Farbtabelle für Fließkomma-Karten erzeugen."
+#, fuzzy
+msgid "Removed vertices"
+msgstr "Entfernen"
+#, fuzzy
+msgid ""
+"Operator defines required relation between features. A feature is written to "
+"output if the result of operation 'ainput operator binput' is true. An input "
+"feature is considered to be true, if category of given layer is defined.\n"
+"\t overlap: features partially or completely overlap"
+msgstr "Operator zwischen feature ist Ausgabe von ist feature ist von ist n"
+msgid "Processing ainput lines ..."
+msgstr "Verarbeite ainput Zeilen ..."
+msgid "Writing attributes ..."
+msgstr "Schreibe Attribute ..."
+#, fuzzy
+msgid "Reading file [%s]..."
+msgstr "Lese Datei <%s>..."
+msgid "Unable to determine raster cell type"
+msgstr "Kann den Rasterzelltyp nicht bestimmen."
+msgid "Unable to read color file"
+msgstr "Kann die Farbdatei nicht lesen."
+msgid "Unable to read raster row"
+msgstr "Kann Rasterzeile nicht lesen."
+msgid ""
 "Optional where condition (without WHERE key word), e.g.:\n"
 "\t\tobec = 'Liptakov'"
 msgstr ""
@@ -27631,16 +28149,14 @@
 msgid "Source monitor"
 msgstr "Quell Grafik-Fenster."
-#, fuzzy
 msgid "display, export, GPS"
-msgstr "Darstellung, Vektor"
+msgstr "Anzeige, Export, GPS"
 msgid "Make JPEG instead of PNG image"
 msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
-#, fuzzy
 msgid "display, export"
+msgstr "Anzeige, Export"
 #, fuzzy
 msgid "Saves the contents of the active display monitor to a graphics file."
@@ -27651,31 +28167,17 @@
 msgid "Compression for PNG files"
 msgstr "Komprimierung für PNG-Dateien."
-#, fuzzy
 msgid "Paper size for PostScript output"
-msgstr "PostScript Ausgabedatei"
+msgstr "Papiergröße für die PostScript-Ausgabe"
-#, fuzzy
 msgid "PostScript"
+msgstr "PostScript"
 #, fuzzy
 msgid "Set transparent background"
 msgstr "Bestimmt die Farbe des Menü Hintergrunds."
 #, fuzzy
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
-#, fuzzy
-msgid "omit entries with missing label"
-msgstr "Überspringe Kategorien ohne Label."
-#, fuzzy
-msgid "Number of lines to appear in the legend"
-msgstr "Wie oft soll der Filter wiederholt werden?"
-#, fuzzy
 msgid "Redraws the current display frame in the GRASS monitor"
 msgstr "Gebe die Namen aller im GRASS Fenster dargestellten Karten aus."
@@ -27697,9 +28199,8 @@
 msgid "Slide show of GRASS raster/vector maps."
 msgstr "von"
-#, fuzzy
 msgid "display, slideshow"
-msgstr "Darstellung, Setup"
+msgstr "Anzeige, Diashow"
 #, fuzzy
 msgid "Show vector maps rather than raster maps"
@@ -27727,9 +28228,8 @@
 msgid "How to split display"
 msgstr "Darzustellender Text"
-#, fuzzy
 msgid "display, legend"
-msgstr "Drehe Legende."
+msgstr "Anzeige, Legende"
 #, fuzzy
 msgid "Vector map to display thematically"
@@ -27738,9 +28238,8 @@
 msgid "Theme_prefs"
 msgstr "Theme_prefs"
-#, fuzzy
 msgid "Vector map type"
-msgstr "Vektorkartentyp."
+msgstr "Vektorkartentyp"
 #, fuzzy
 msgid "Attribute column to use for thematic display (must be numeric)"
@@ -27754,9 +28253,8 @@
 msgid "Layer to use for thematic display"
 msgstr "Text für das vertikale Datum der Karte."
-#, fuzzy
 msgid "Points"
-msgstr "Drucke"
+msgstr "Punkte"
 #, fuzzy
 msgid "Vector point icon for point data"
@@ -27766,17 +28264,15 @@
 msgid "Number of classes for interval theme (integer)"
 msgstr "Anzahl der Kopien."
-#, fuzzy
 msgid "Misc"
-msgstr "Metrisch"
+msgstr "Verschiedenes"
 #, fuzzy
 msgid "Mapset(s) to list (default: current mapset search path)"
 msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
-#, fuzzy
 msgid "Output separator (default: newline)"
-msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
+msgstr "Ausgabe-Trennzeichen (Standard: Zeilenumbruch)."
 #, fuzzy
 msgid "Raster to remove"
@@ -27798,29 +28294,13 @@
 msgid "Label to remove"
 msgstr "Kann nicht weitermachen."
-#, fuzzy
 msgid "3dview to remove"
-msgstr "%d Vertices gelöscht"
+msgstr "3dview der gelöscht werden soll"
 msgid "Group to remove"
 msgstr "Gruppe, die entfernt werden soll."
-msgid "imagery, raster, multispectral"
-msgstr "Bildverarbeitung, Raster, Multispektral"
 #, fuzzy
-msgid "raster input maps"
-msgstr "Raster, Import"
-#, fuzzy
-msgid "write output to PNG image"
-msgstr "Überschreibe Ausgabedatei."
-#, fuzzy
-msgid "label with coordinates instead of numbering"
-msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
-#, fuzzy
 msgid "Keep band numbers instead of using band color names."
 msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
@@ -27848,26 +28328,13 @@
 msgid "Show help"
 msgstr "Zeige die Hilfe an."
-#, fuzzy
 msgid "Do not overwrite existing map"
-msgstr "Name einer existierenden Karte."
+msgstr "Überschreibe nicht eine bereits existierende Karte."
 #, fuzzy
 msgid "Exports GRASS raster into GDAL supported formats."
 msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
-#, fuzzy
-msgid "Region sensitive output"
-msgstr "Lese r.stats Ausgabe."
-#, fuzzy
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
-"Optionen angegeben werden."
-#, fuzzy
 msgid "Output field seperator"
 msgstr "Ausgabe Feld-Trennzeichen"
@@ -27883,33 +28350,26 @@
 msgid "Percentile to calculate (requires -e flag)"
 msgstr "Kann die Eingabekarte nicht schließen."
-#, fuzzy
 msgid "A (grid3D file)"
-msgstr "Eingabe-grid3D-Datei"
+msgstr "A (grid3D file)"
-#, fuzzy
 msgid "B (grid3D file)"
+msgstr "B (grid3D file)"
-#, fuzzy
 msgid "C (grid3D file)"
+msgstr "C (grid3D file)"
-#, fuzzy
 msgid "D (grid3D file)"
+msgstr "D (grid3D file)"
-#, fuzzy
 msgid "E (grid3D file)"
+msgstr "E (grid3D file)"
-#, fuzzy
 msgid "F (grid3D file)"
+msgstr "F (grid3D file)"
-#, fuzzy
 msgid "Name for output grid3D volume"
-msgstr "Name der Ausgabedatei"
+msgstr "Name für das Ausgabe-grid3D-Volumen"
 #, fuzzy
 msgid "raster, imagery, dehaze"
@@ -27937,9 +28397,8 @@
 msgid "raster output dehazed maps prefix"
 msgstr "Prefix der Ausgabe-Rasterkarte."
-#, fuzzy
 msgid "%s: [%s] not found"
-msgstr "%s: <%s> nicht gefunden."
+msgstr "%s: [%s] nicht gefunden."
 msgid "     'c': cells"
 msgstr "     'c': Zellen"
@@ -28031,9 +28490,6 @@
 msgid "linkein raster map <%s> not found"
 msgstr "linkin Rasterkarte <%s> wurde nicht gefunden."
-msgid "albedo raster map <%s> not found"
-msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
 msgid "latin raster map <%s> not found"
 msgstr "latin Rasterkarte <%s> wurde nicht gefunden."
@@ -28053,25 +28509,21 @@
 msgid "Unable to find clump map"
 msgstr "Kann die Rasterkarte mit Klumpen nicht finden."
-#, fuzzy
 msgid "Memory allocation error"
-msgstr "Metrische Belegung."
+msgstr "Speicherbelegungsfehler."
-#, fuzzy
 msgid "Saving new map"
-msgstr "Lese Karte"
+msgstr "Speichere neue Karte"
 #, fuzzy
 msgid "Terrain raster map (DEM)"
-msgstr "Terrain Rasterkarte (DEM)."
+msgstr "Name der Terrain Rasterkarte (DEM)."
-#, fuzzy
 msgid "Output raster map with lake"
-msgstr "Titel der Ausgabe-Rasterkarte."
+msgstr "Ausgabe-Rasterkarte mit See"
-#, fuzzy
 msgid "Cannot write lake raster map <%s>!"
-msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+msgstr "Kann die See-Rasterkarte <%s> nicht schreiben!"
 #, fuzzy
 msgid "Terrain raster map <%s> not found!"
@@ -28081,21 +28533,17 @@
 msgid "Cannot open terrain raster map <%s@%s>!"
 msgstr "Kann die Rasterkarte <%s> nicht öffnen!"
-#, fuzzy
 msgid "Seed map <%s> not found!"
-msgstr "%s Karte <%s> nicht gefunden."
+msgstr "Karte mit Startpunkten <%s> nicht gefunden."
-#, fuzzy
 msgid "Cannot open seed map <%s@%s>!"
-msgstr "Kann die Rasterkarte <%s> nicht öffnen!"
+msgstr "Kann die Karte mit Startpunkten <%s@%s> nicht öffnen!"
-#, fuzzy
 msgid "Failure to allocate memory for row pointers"
-msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
+msgstr "Kann keinen Speicherplatz für Zeilen-Zeiger belegen."
-#, fuzzy
 msgid "Loading maps: "
+msgstr "Lade Karten: "
 #, fuzzy
 msgid "Error reading terrain raster map. Probably broken file."
@@ -28105,9 +28553,8 @@
 msgid "Error reading seed raster map. Probably broken file."
 msgstr "Fehler beim Lesen der temporären Datei."
-#, fuzzy
 msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "Kann die See-Rasterkarte <%s@%s> nicht schreiben!"
 msgid ""
 "Starting lake filling at level of %8.4f in %d passes. \n"
@@ -28116,13 +28563,11 @@
 "Beginne mit dem Füllen des Sees bei Niveau von %8.4f mit %d Durchgängen. \n"
 "Prozent erledigt:"
-#, fuzzy
 msgid "Pass: %d\n"
-msgstr "Maske: %s\n"
+msgstr "Durchgang: %d\n"
-#, fuzzy
 msgid "Error writing color file for <%s@%s>!"
-msgstr "Fehler beim Schreiben der Farb-Datei für <%s>."
+msgstr "Fehler beim Schreiben der Farb-Datei für <%s@%s>!"
 msgid "All done."
 msgstr "Alles erledigt."
@@ -28176,29 +28621,24 @@
 "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
 "schreiben."
-#, fuzzy
 msgid "Raster input maps(s)"
-msgstr "Eingabe-Rasterkarte für rot."
+msgstr "Eingabe-Rasterkarte(n)"
-#, fuzzy
 msgid "Output file name"
-msgstr "Ausgabe-Tabellenname"
+msgstr "Ausgabe-Dateiname"
-#, fuzzy
 msgid "%s: can't read fp range for [%s]"
-msgstr "Kann die fp Spanne für <%s> nicht lesen."
+msgstr "%s: Kann die fp Spanne für [%s] nicht lesen."
-#, fuzzy
 msgid ""
 "Raster map [%s] already exists.\n"
 "Please try another."
 msgstr ""
-"Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen "
-"Namen."
+"Rasterkarte [%s] existiert bereits.\n"
+"Bitte wählen Sie eine Andere."
-#, fuzzy
 msgid "Path to rules file"
-msgstr "Pfad zur Font-Datei."
+msgstr "Pfad zur Regel-Datei."
 msgid "RGB raster map <%s> not found"
 msgstr "RGB Rasterkarte <%s> nicht gefunden."
@@ -28241,9 +28681,8 @@
 "<%s> ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht "
 "editieren!"
-#, fuzzy
 msgid "Cannot open raster map [%s]!"
+msgstr "Kann die Rasterkarte [%s] nicht öffnen!"
 #, fuzzy
 msgid "Raster file [%s] is empty."
@@ -28273,7 +28712,7 @@
 #, fuzzy
 msgid "The header for [%s] says the file is not compressed. "
-msgstr "Der Header der Datei <%s> sagt, dass die Datei nicht komprimiert ist."
+msgstr "Der Header von <%s> sagt, dass die Datei nicht komprimiert ist."
 msgid "The file appears to be compressed.\n"
 msgstr "Die Datei erscheint, als sei sie komprimiert.\n"
@@ -28285,7 +28724,7 @@
 #, fuzzy
 msgid "The header for [%s] says the file is compressed. "
-msgstr "Der Header der Datei <%s> sagt, dass die Datei komprimiert ist."
+msgstr "Der Header von <%s> sagt, dass die Datei komprimiert ist."
 msgid "The file does NOT appear to be compressed.\n"
 msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
@@ -28469,9 +28908,8 @@
 msgid "G_put_raster_row failed (file system full?)"
 msgstr "G_put_raster_row failed (Dateisystem voll?)"
-#, fuzzy
 msgid "Run verbosly"
-msgstr "Detaillierte Ausgabe"
+msgstr "Im gesprächigen Modus ausführen."
 msgid "Run VERBOSELY"
 msgstr "Ausführliche Ausgabe."
@@ -28482,33 +28920,27 @@
 msgid "Vector map <%s> not found in the current mapset"
 msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
-#, fuzzy
 msgid "Cannot execute: %s"
-msgstr "Kann folgende Attribute nicht auswählen: %s"
+msgstr "Kann nicht ausgeführt werden: %s"
-#, fuzzy
 msgid "Cannot link table: %s"
-msgstr "Kann die Tabelle '%s' nicht verändern."
+msgstr "Kann Tabelle nicht verlinken: '%s'"
-#, fuzzy
 msgid "DXF input file"
-msgstr "DXF Ausgabedatei."
+msgstr "DXF Eingabedatei."
-#, fuzzy
 msgid "Cannot open dxf file <%s>"
-msgstr "Kann die Filter-Datei <%s> nicht öffnen."
+msgstr "Kann die dxf-Datei <%s> nicht öffnen."
 #, fuzzy
 msgid "Use output= option to change vector map name"
 msgstr "Ausgabe option"
-#, fuzzy
 msgid "Cannot open new vector map <%s>"
-msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
+msgstr "Kann neue Vektorkarte <%s> nicht öffnen."
-#, fuzzy
 msgid "Conversion of <%s> to vector map:"
-msgstr "Kann die Vektordatei %s nicht erzeugen."
+msgstr "Konvertiere <%s> in eine Vektorkarte:"
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
 msgstr ""
@@ -28536,33 +28968,24 @@
 msgid "Hilight color for text"
 msgstr "für"
-#, fuzzy
 msgid "Line: %d\n"
-msgstr "Länge der Linie: %f\n"
+msgstr "Zeile: %d\n"
 #, fuzzy
 msgid "Insufficent memory for allocation of data structure"
 msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
-#, fuzzy
 msgid "Specified group does not exist"
-msgstr "Angegebene Gruppe existiert nicht im aktuellen Mapset."
+msgstr "Angegebene Gruppe existiert nicht."
-#, fuzzy
-msgid "imagery group"
-msgstr "Bildgruppe"
-#, fuzzy
 msgid "imagery subgroup"
+msgstr "Bilduntergruppe"
-#, fuzzy
 msgid "output raster map"
-msgstr "Ausgabe-Farbton-Rasterkarte (hue)."
+msgstr "Ausgabe-Rasterkarte"
-#, fuzzy
 msgid "Name of input raster map(s)"
-msgstr "Name der Eingabe-Rasterkarte."
+msgstr "Name der Eingabe-Rasterkarte(n)"
 msgid "Output file extension (inputfile(s) + extension)"
 msgstr ""
@@ -28580,23 +29003,21 @@
 msgid "usage: %s file [prompt %%x %%y]\n"
 msgstr "Verwendung: %s Datei [Prompt %%x %%y]\n"
-#, fuzzy
 msgid "Illegal file name for real part: %s"
-msgstr "%s: %s - Ungültiger Name für den realen Teil\n"
+msgstr "Ungültiger Name für den realen Teil: %s"
-#, fuzzy
 msgid "Illegal file name for imaginary part: %s"
-msgstr "%s: %s - ungültiger Dateiname für den Bildteil\n"
+msgstr "Ungültiger Dateiname für den imaginären Teil: %s"
-#, fuzzy
 msgid "** Can't read signature file <%s> **"
-msgstr "Kann die Signaturdatei <%s> nicht lesen."
+msgstr "** Kann die Signaturdatei <%s> nicht lesen. **"
-#, fuzzy
 msgid ""
 "\n"
 "<%s> -- illegal result signature file name"
-msgstr "Ungültiger Signaturdateiname <%s>."
+msgstr ""
+"\n"
+"<%s> -- Ungültiger Dateiname für die resultierende Signatur."
 msgid "Illegal group name <%s>"
 msgstr "Ungültiger Gruppen-Name <%s>."
@@ -29061,9 +29482,8 @@
 msgid "<%s> is an illegal region name"
 msgstr "<%s> ist ein ungültiger Regions-Name."
-#, fuzzy
 msgid "No LatLong information for XY-Projection"
-msgstr "Geo-Gitter Option ist für XY-Projektionen nicht verfügbar."
+msgstr "Keine LatLong-Information für XY-Projektionen."
 msgid "Erasing monitors..."
 msgstr "Lösche Monitore... "
@@ -29175,7 +29595,7 @@
 #, fuzzy
 msgid "Writing subgroup REF"
-msgstr "Schreibe %s"
 msgid "Found file <%s@%s> in group."
 msgstr "Habe Datei <%s@%s> in der Gruppe gefunden."
@@ -29221,11 +29641,11 @@
 #, fuzzy
 msgid "%s: can't read range for [%s]"
-msgstr "Kann Range-Datei für %s nicht öffnen."
 #, fuzzy
 msgid "Raster file [%s] not found"
-msgstr "3dview-Datei <%s> nicht gefunden."
+msgstr "Rasterkarte <%s> nicht gefunden. Beende mich. "
 #, fuzzy
 msgid "It was not possible writing in <%s>."
@@ -29260,7 +29680,7 @@
 #, fuzzy
 msgid "Unknown query tool '%s'"
-msgstr "Unbekannte Methode <%s>."
+msgstr "Unbekannter Typ"
 #, fuzzy
 msgid ""
@@ -29298,7 +29718,7 @@
 #, fuzzy
 msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
 #, fuzzy
 msgid ""
@@ -29333,7 +29753,7 @@
 #, fuzzy
 msgid "Creating support files for [%s]."
-msgstr "Erstelle Support-Dateien für <%s>..."
+msgstr "Erstelle Support-Dateien für <%s>."
 #, fuzzy
 msgid "Category file for [%s] not available"
@@ -29361,7 +29781,7 @@
 #, fuzzy
 msgid "%s not found"
-msgstr "<%s> nicht gefunden werden."
+msgstr "[%s] nicht gefunden werden."
 #, fuzzy
 msgid "Could not access %s layer"
@@ -29412,20 +29832,16 @@
 msgstr "Kann den Header der Rasterkarte <%s> in <%s> nicht lesen."
 #, fuzzy
-msgid "region <%s> not found"
-msgstr "Region <%s> nicht gefunden."
-#, fuzzy
 msgid "can't read region <%s> in <%s>"
 msgstr "Kann Region <%s> in <%s> nicht lesen."
 #, fuzzy
 msgid "can't open 3dview file <%s> in <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht öffnen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht öffnen."
 #, fuzzy
 msgid "can't read 3dview file <%s> in <%s>"
-msgstr "Kann 3D-View-Datei <%s> in <%s> nicht lesen."
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
 #, fuzzy
 msgid "can't open vector map <%s> in <%s>"
@@ -29445,11 +29861,11 @@
 #, fuzzy
 msgid "%s file [%s] not found!"
 #, fuzzy
 msgid "%s: %s - map not found"
 #, fuzzy
 msgid "%s: unable to open %s"
@@ -29457,7 +29873,7 @@
 #, fuzzy
 msgid "%s - not found"
 #, fuzzy
 msgid "Cannot read %s"
@@ -29469,15 +29885,15 @@
 #, fuzzy
 msgid "[%s] map not found."
 #, fuzzy
 msgid "[%s] map not found"
 #, fuzzy
 msgid "elevation file [%s] not found"
-msgstr "Label-Datei <%s> nicht gefunden."
 #, fuzzy
 msgid "min computed aspect %.4f  max computed aspect %.4f"
@@ -29565,7 +29981,7 @@
 #, fuzzy
 msgid "Training map [%s] not found."
+msgstr "Gruppe [%s] nicht gefunden."
 #, fuzzy
 msgid "%s map not found"
@@ -29605,7 +30021,7 @@
 #, fuzzy
 msgid "%s: %s - not found"
 #, fuzzy
 msgid "%s: %s - illegal units"
@@ -29613,7 +30029,7 @@
 #, fuzzy
 msgid "%s: %s - can't open"
 #, fuzzy
 msgid "Reading input map (%s)    ... "
@@ -29652,7 +30068,7 @@
 #, fuzzy
 msgid "Output separator character (default: tab)"
-msgstr "Suchmuster für Kartennamen (Standard: alle)."
 #, fuzzy
 msgid "Cannot read category file of raster map <%s> in <%s>"
@@ -29660,7 +30076,7 @@
 #, fuzzy
 msgid "Cannot find file %s"
-msgstr "Kann die Datei %s nicht finden."
 #, fuzzy
 msgid "Cannot get header for %s"
@@ -29692,7 +30108,7 @@
 #, fuzzy
 msgid "Cannot open raster map [%s]"
-msgstr "Kann die Rasterkarte <%s> nicht öffnen."
 #, fuzzy
 msgid "Cannot get raster band."
@@ -29736,7 +30152,7 @@
 #, fuzzy
 msgid "Cannot open TIFF file <%s>"
-msgstr "Kann die Regel-Datei <%s> nicht öffnen."
 #, fuzzy
 msgid "Reading raster map"
@@ -29748,7 +30164,7 @@
 #, fuzzy
 msgid "Illegal file name. Please try another."
 #, fuzzy
 msgid "%s: can't open %s"
@@ -29760,7 +30176,7 @@
 #, fuzzy
 msgid "memory allocation failure"
 #, fuzzy
 msgid "Can't find data map."
@@ -29776,7 +30192,7 @@
 #, fuzzy
 msgid "Cannot open vector map <%s> at the topological level"
-msgstr "Kann Vektorkarte <%s> in <%s> nicht öffnen."
+msgstr "Kann Vektorkarte <%s> nicht im topologischen Modus öffnen."
 #, fuzzy
 msgid "Rebuilding topology ..."
@@ -29844,7 +30260,7 @@
 #, fuzzy
 msgid "can't open raster map [%s]"
 #, fuzzy
 msgid "Cannot rewrite line %d"
@@ -29913,7 +30329,7 @@
 #, fuzzy
 msgid "Could not find vector map <%s> in current mapset"
-msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
+msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
 #, fuzzy
 msgid "Could not find input map <%s>."
@@ -29936,10 +30352,6 @@
 msgstr "Ausgabekarte mit den Punkten wird geschrieben."
 #, fuzzy
-msgid "Cannot get layer information for vector map"
-msgstr "Kann die Layer-Informationen der Vektorkarte nicht bekommen."
-#, fuzzy
 msgid "<%s> cellfile not found"
 msgstr "Cell-Datei nicht gefunden."
@@ -30029,11 +30441,11 @@
 #, fuzzy
 msgid "unable to open [%s] in [%s]"
-msgstr "Kann die Karte <%s> nicht öffnen."
 #, fuzzy
 msgid "warning: unable to open [%s] in [%s]"
-msgstr "Kann die Datei mit Gewichten <%s> nicht öffnen."
 #, fuzzy
 msgid "Unable to open raster map [%s] in [%s]"
@@ -30041,7 +30453,7 @@
 #, fuzzy
 msgid "Unable to find input cell map '%s'"
-msgstr "Kann die Rasterkarte mit Klumpen nicht finden."
+msgstr "Kann die Datei %s nicht finden."
 #, fuzzy
 msgid "Table to be imported"
@@ -30057,7 +30469,7 @@
 #, fuzzy
 msgid "Input file [%s] not found."
 #, fuzzy
 msgid "Unable to open output file <%s>."
@@ -30084,10 +30496,6 @@
 #, fuzzy
-msgid "Cannot open file for <%s>"
-#, fuzzy
 msgid "Name of the random surface to be produced"
 msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche."
@@ -30113,7 +30521,7 @@
 #, fuzzy
 msgid "Table name"
-msgstr "Eingabetabelle"
+msgstr "Testname"
 #, fuzzy
 msgid ""
@@ -30140,7 +30548,7 @@
 #, fuzzy
 msgid "Cannot fetch data from table"
-msgstr "Kann Daten nicht aus der Tabelle selektieren."
+msgstr "Kann Daten nicht aus der Tabelle laden."
 #, fuzzy
 msgid ""
@@ -30154,7 +30562,7 @@
 #, fuzzy
 msgid "SVG file <%s> cannot be opened"
-msgstr "<%s> konnte nicht gefunden werden!"
+msgstr "3dview-Datei <%s> nicht gefunden."
 #, fuzzy
 msgid "Querying input '%s' ... "
@@ -30245,7 +30653,7 @@
 #, fuzzy
 msgid "Not able to find cellfile [%s]"
+msgstr "Kann Grid3-Datei für <%s> nicht finden."
 #, fuzzy
 msgid "Raster map [%s] not available"
@@ -30301,7 +30709,7 @@
 #, fuzzy
 msgid "Exports GRASS raster data into various formats (requires GDAL)."
-msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
+msgstr "Exportiert Attributtabellen in verschiedene Formate."
 #, fuzzy
 msgid "Couldn't find raster map %s"
@@ -30312,7 +30720,7 @@
 #, fuzzy
 msgid "%s: <%s> illegal name"
-msgstr "%s=%s - unzulässiger Wert."
+msgstr "%s: ungültiger Wert."
 #, fuzzy
 msgid "%s: Cannot open <%s>"
@@ -30341,10 +30749,6 @@
 msgstr "Kann die Rasterkarte '%s' nicht erzeugen."
 #, fuzzy
-msgid "Name of the input raster map"
-#, fuzzy
 msgid "Filtering [%s] in [%s]"
 msgstr "Lese <%s> in <%s>"
@@ -30390,7 +30794,7 @@
 #, fuzzy
 msgid "Raster input map"
+msgstr "Eingabe-Rasterkarte"
 #, fuzzy
 msgid "Mapset of input map"
@@ -30398,7 +30802,7 @@
 #, fuzzy
 msgid "Checking location %s, mapset %s:"
 #, fuzzy
 msgid "Input map [%s] in location [%s] in mapset [%s] not found."
@@ -30454,13 +30858,9 @@
 #, fuzzy
 msgid "Couldn't find raster map [%s]"
 #, fuzzy
-msgid "%s in %s -can't open raster map"
-msgstr "CHILD[pid = %i] kann Rasterkarte nicht öffnen."
-#, fuzzy
 msgid "%s - can't create raster map"
@@ -30540,7 +30940,7 @@
 #, fuzzy
 msgid "Could not find input map <%s> in current mapset."
-msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
 #, fuzzy
 msgid "Vector file [%s] not available in search list"
@@ -30556,7 +30956,7 @@
 #, fuzzy
 msgid "Cannot open driver <%s>"
 #, fuzzy
 msgid "Could not find input vector map %s"
@@ -30587,7 +30987,7 @@
 #, fuzzy
 msgid "error opening raster map [%s]."
-msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>."
+msgstr "Fehler beim Lesen der Rasterkarte <%s>."
 #, fuzzy
 msgid "Topology is not available"
@@ -30636,20 +31036,16 @@
 msgstr "Ungültiger Ausgabe-Dateiname<%s>."
 #, fuzzy
-msgid "Can't create output map"
-msgstr "Kann Ausgabekarte nicht erzeugen."
-#, fuzzy
 msgid "Could not close new 3d raster map"
 msgstr "Kann die neue 3D-Rasterkarte nicht schließen."
 #, fuzzy
 msgid "%s: cellfile [%s] not found."
-msgstr "Cell-Datei nicht gefunden."
 #, fuzzy
 msgid "Unable to open cellfile [%s]."
-msgstr "Kann die Datei <%s> nicht öffnen."
 #, fuzzy
 msgid "Error reading wildcard."
@@ -30697,10 +31093,6 @@
 msgstr "Auflösung der Ausgabe-Karte"
 #, fuzzy
-msgid "name for new vector map"
-msgstr "Name der Vektorkarte"
-#, fuzzy
 msgid "name for new vector map (omit for display to stdout)"
 msgstr "Name der Vektorausgabekarte mit den angepassten Punkten im Fluss."
@@ -30822,7 +31214,7 @@
 #, fuzzy
 msgid "Problem opening input file [%s]"
-msgstr "FEHLER: Problem beim Öffnen der Ausgabedatei."
+msgstr "Fehler beim Öffnen der Displaydatei <%s>."
 #, fuzzy
 msgid "Problem opening output file [%s]"
@@ -30860,8 +31252,9 @@
 msgid "CREATING SUPPORT FILES"
 msgstr "Erstelle Support-Dateien."
+#, fuzzy
 msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-msgstr "Höhenprodukte für mapset [%s] in [%s]."
+msgstr "Höhen-Ergebnisse für Mapset <%s> in <%s>."
 #, fuzzy
 msgid "It could not be find input map <%s>"
@@ -31098,7 +31491,7 @@
 #, fuzzy
 msgid "Unknown keyword [%s] in vector head."
-msgstr "Unbekanntes Schlüsselwort <%s im Vektor-Header."
+msgstr "Unbekanntes Schlüsselwort '%s' im Vektor-Header."
 #, fuzzy
 msgid "Region Growing"
@@ -31114,11 +31507,11 @@
 #, fuzzy
 msgid "Error while writing new cell map."
-msgstr "Fehler beim Entfernen der alten Maske MASK."
+msgstr "Fehler beim Lesen der 'history'-Datei."
 #, fuzzy
 msgid "Error in opening output file <%s>"
-msgstr "Fehler beim Öffnen der Displaydatei <%s>."
+msgstr "Konnte die Ausgabedate <%s> nicht öffnen."
 #, fuzzy
 msgid "Unable to find input cell map <%s>"
@@ -31146,7 +31539,7 @@
 #, fuzzy
 msgid "Cannot find map %s"
-msgstr "Kann %s nicht öffnen."
 #, fuzzy
 msgid "Cannot open map %s"
@@ -31174,7 +31567,7 @@
 #, fuzzy
 msgid "%s - unknown color"
-msgstr "%s - unbekannte Farbanfrage."
+msgstr "Unbekannte Farbe: <%s>."
 #, fuzzy
 msgid "Valid colors are:\n"
@@ -31253,11 +31646,11 @@
 #, fuzzy
 msgid "Error reading ASCII file <%s>"
-msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
+msgstr "Fehler beim Lesen der ASCII-Datei: <%s>."
 #, fuzzy
 msgid "Error reading categories: <%s>"
-msgstr "Fehler beim Lesen der Kategorien: '%s'."
+msgstr "Fehler beim Lesen der Kategorien: <%s>."
 #, fuzzy
 msgid "category [%d]"
@@ -31281,7 +31674,7 @@
 #, fuzzy
 msgid "Failed opening output vector map '%s'"
-msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
+msgstr "Name für die Ausgabe-Vektorkarte"
 #, fuzzy
 msgid "Do not create attribute table."
@@ -31375,7 +31768,7 @@
 #, fuzzy
 msgid "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d"
-msgstr "Kein Eintrag für Linie (cat = %d)."
+msgstr "Interpolation: (%d,%d): Kein Eintrag für den Punkt (cat = %d)."
 #, fuzzy
 msgid "Interpolation: (%d,%d): Bilinear interpolation..."
@@ -31419,7 +31812,7 @@
 #, fuzzy
 msgid "vector map to be created"
-msgstr "Vektordaten werden nicht erzeugt."
+msgstr "Vektorkarte, die abgefragt werden soll."
 msgid "%s: Error reading from raster map <%s> in mapset <%s>"
 msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
@@ -31427,13 +31820,13 @@
 msgid "Color table for <%s> updated"
 msgstr "Farbtabelle für <%s> aktualisiert."
+#, fuzzy
 msgid "Error reading raster map <%s>."
 msgid "        Number of bytes per cell"
 msgstr "        Anzahl der Bytes pro Zelle"
-#, fuzzy
 msgid "Option <%s>: <%s> exists."
 msgstr "Option <%s>: <%s> existiert."
@@ -31494,49 +31887,125 @@
 msgid "Cannot open raster map <%s>!"
-#, fuzzy
 msgid "Group <%s> not found."
 msgstr "Gruppe <%s> nicht gefunden."
-#, fuzzy
 msgid "Subgroup <%s> not found."
 msgstr "Untergruppe <%s> nicht gefunden."
+#, fuzzy
 msgid "Monitor <%s> terminated"
 msgstr "Grafik-Fenster <%s> beendet."
 msgid "format"
 msgstr "Format"
-#, fuzzy
 msgid "Name of PNG file"
-msgstr "Name der Farb-Datei."
+msgstr "Name der PNG-Datei."
-#, fuzzy
 msgid "Files"
-msgstr "Sites"
+msgstr "Dateien"
 msgid "Expert mode (enter a set of r3.mapcalc expressions)"
 msgstr "Expertenmodus (Geben Sie ein Satz von r3.mapcalc Befehlen an)."
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules"
-#~ "\" und \"raster\"."
+msgid ""
+"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
+"options"
+msgstr ""
+"Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" "
+"und \"raster\"."
-#~ msgid "Error - Monitor <%s> was not running"
-#~ msgstr "Fehler - Grafik-Fenster <%s> wurde nicht ausgeführt."
+#, fuzzy
+msgid "Error - Monitor <%s> was not running"
+msgstr "Fehler - Grafik-Fenster <%s> wurde nicht ausgeführt."
-#~ msgid "Error - Monitor <%s> in use by another user"
+#, fuzzy
+msgid "Error - Monitor <%s> in use by another user"
+msgstr ""
+"Fehler - Grafik-Fenster <%s> wird von einem anderen Benutzer verwendet."
+msgid "Middle: Keep original frame\n"
+msgstr "Middle: Behalte original Fenster\n"
+msgid "Enable interactive prompting (for command-line use only)"
+msgstr ""
+"Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
+"Befehlszeile)."
+#~ msgid "albedo raster map <%s> not found"
+#~ msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
+#, fuzzy
+#~ msgid "Layer is only used for WHERE SQL statement"
+#~ msgstr "Verwenden Sie db.select für SELECT SQL Ausdrücke."
+#, fuzzy
+#~ msgid "Group [%s] not found"
+#~ msgstr "Gruppe [%s] nicht gefunden."
+#, fuzzy
+#~ msgid "No photo points for group [%s]"
+#~ msgstr "%s: Keine Datenpunkte gefunden."
+#, fuzzy
+#~ msgid "Poorly placed photo points for group [%s]"
+#~ msgstr "Schlecht platzierte Kontrollpunkte."
+#, fuzzy
+#~ msgid "Computing equations ..."
+#~ msgstr "Berechne Quantile"
+#, fuzzy
+#~ msgid "Unable to read raster header of <%s>"
+#~ msgstr "Kann die Header-Datei für <%s> nicht lesen."
+#, fuzzy
+#~ msgid "Name of camera reference file to use"
+#~ msgstr "Name einer neuen Rasterkarte."
+#, fuzzy
+#~ msgid "Target location [%s] not found\n"
+#~ msgstr "Mapset <%s> in Eingabe-Location <%s> nicht gefunden."
+#, fuzzy
+#~ msgid "Mapset [%s] in target location [%s] - "
+#~ msgstr "Mapset <%s> in Ziel-Location <%s> - "
+#, fuzzy
+#~ msgid "Pre-selected group <%s> not found"
 #~ msgstr ""
-#~ "Fehler - Grafik-Fenster <%s> wird von einem anderen Benutzer verwendet."
+#~ "\n"
+#~ "Gruppe <%s> nicht gefunden."
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Middle: Behalte original Fenster\n"
+#, fuzzy
+#~ msgid "Enter imagery group for ortho-rectification"
+#~ msgstr "Name der Ziellocation für das Bild."
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr ""
-#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
-#~ "Befehlszeile)."
+#, fuzzy
+#~ msgid "Group [%s] contains no files"
+#~ msgstr "Untergruppe <%s> in Gruppe <%s> enthält keine Dateien."
+#, fuzzy
+#~ msgid "Image Group [%s] not found"
+#, fuzzy
+#~ msgid "Poorly placed psuedo control points. "
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Gebe Korrelations-Matrix aus"
+#, fuzzy
+#~ msgid "No active psuedo control points"
+#~ msgstr "Keine aktiven Kontrollpunkte."
+#, fuzzy
+#~ msgid "Interactively select or modify the imagery group target."
+#~ msgstr "Selectiere interaktiv eine Route."
+#, fuzzy
+#~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
+#~ msgstr "Gruppe <%s> ziel auf Location <%s>, Mapset <%s>."
Modified: grass/trunk/locale/po/grasstcl_de.po
--- grass/trunk/locale/po/grasstcl_de.po	2008-11-18 10:35:56 UTC (rev 34354)
+++ grass/trunk/locale/po/grasstcl_de.po	2008-11-18 10:45:30 UTC (rev 34355)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasstcl_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-10-11 22:08+0200\n"
+"POT-Creation-Date: 2008-11-18 11:38+0100\n"
 "PO-Revision-Date: 2008-04-03 10:13+0200\n"
 "Last-Translator: Markus Neteler <neteler osgeo.org>\n"
 "Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
@@ -20,291 +20,847 @@
 "X-Generator: KBabel 1.11.4\n"
 "Plural-Forms:  nplurals=2; plural=(n != 1);\n"
-#: ../gui/tcltk/gis.m/thematic.tcl:107 ../gui/tcltk/gis.m/thematic.tcl:607
-#: ../gui/tcltk/gis.m/thematic.tcl:680 ../gui/tcltk/gis.m/labels.tcl:78
-#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastarrows.tcl:83
-#: ../gui/tcltk/gis.m/rastarrows.tcl:357 ../gui/tcltk/gis.m/rastnums.tcl:79
-#: ../gui/tcltk/gis.m/rastnums.tcl:360 ../gui/tcltk/gis.m/frames.tcl:78
-#: ../gui/tcltk/gis.m/frames.tcl:275 ../gui/tcltk/gis.m/animate.tcl:88
-#: ../gui/tcltk/gis.m/mapprint.tcl:194 ../gui/tcltk/gis.m/mapprint.tcl:201
-#: ../gui/tcltk/gis.m/gridline.tcl:99 ../gui/tcltk/gis.m/gridline.tcl:406
-#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:506
-#: ../gui/tcltk/gis.m/raster.tcl:86 ../gui/tcltk/gis.m/raster.tcl:463
-#: ../gui/tcltk/gis.m/chart.tcl:89 ../gui/tcltk/gis.m/chart.tcl:441
-#: ../gui/tcltk/gis.m/vector.tcl:194 ../gui/tcltk/gis.m/vector.tcl:819
-#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:212 ../gui/tcltk/gis.m/mapcanvas.tcl:221
-#: ../gui/tcltk/gis.m/barscale.tcl:91 ../gui/tcltk/gis.m/barscale.tcl:401
-#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
-#: ../gui/tcltk/gis.m/dtext.tcl:92 ../gui/tcltk/gis.m/dtext.tcl:401
-#: ../gui/tcltk/gis.m/georect.tcl:406 ../gui/tcltk/gis.m/rules.tcl:207
-#: ../gui/tcltk/gis.m/histogram.tcl:84 ../gui/tcltk/gis.m/histogram.tcl:368
-msgid "Error creating tempfile"
+#: ../lib/gtcltk/select.tcl:103
+#, fuzzy
+msgid "Select item"
+msgstr "4. Wähle zu referenzierende Karte"
+#: ../lib/gtcltk/select.tcl:208
+msgid "Ok"
 msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:220
+#: ../lib/gtcltk/select.tcl:209 ../lib/init/epsg_option.tcl:167
+#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
+#: ../lib/init/file_option.tcl:266
+msgid "Cancel"
+msgstr "Abbrechen"
+#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
+#: ../lib/gis/gui.tcl:310
+msgid "Error"
+msgstr ""
+#: ../lib/gis/gui.tcl:229
+#, fuzzy
+msgid "Save File"
+msgstr "Speichere Gruppe"
+#: ../lib/gis/gui.tcl:231
+msgid "Load File"
+msgstr ""
+#: ../lib/gis/gui.tcl:295 ../lib/gis/gui.tcl:480
+msgid "Output"
+msgstr "Ergebnis"
+#: ../lib/gis/gui.tcl:355
+msgid "Options"
+msgstr "Optionen"
+#: ../lib/gis/gui.tcl:464
+#, fuzzy
+msgid "Copy"
+msgstr "Kopiere Karten"
+#: ../lib/gis/gui.tcl:503
+msgid "Run"
+msgstr "Los"
+#: ../lib/gis/gui.tcl:504 ../lib/init/gis_set.tcl:507
+msgid "Help"
+msgstr "Hilfe"
+#: ../lib/gis/gui.tcl:505
+msgid "Clear"
+msgstr "Löschen"
+#: ../lib/gis/gui.tcl:506 ../lib/init/epsg_option.tcl:394
+#: ../lib/init/epsg_option.tcl:438
+msgid "Close"
+msgstr "Schließen"
+#: ../lib/gis/gui.tcl:577
+msgid "required"
+msgstr "benötigt"
+msgid "optional"
+msgstr "optional"
+#: ../lib/gis/gui.tcl:578
+msgid "multiple"
+msgstr "viele "
+#: ../lib/init/epsg_option.tcl:93
+msgid "WARNING: cant get enviromental variable"
+msgstr "WARNUNG: kann Umgebungsvariable nicht lesen"
+#: ../lib/init/epsg_option.tcl:94
+msgid ""
+"Warning: Unable to get enviromental variable GRASS_PROJSHARE. \n"
+"This is a GRASS installation error. \n"
+"Set enviromental variable GRASS_PROJSHARE to point to directory with Proj4 "
+"EPSG file. "
+msgstr ""
+#: ../lib/init/epsg_option.tcl:103
+msgid "Define location using EPSG projection codes"
+msgstr "Definieren Sie eine Location basierend auf dem EPSG-Code."
+#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:92
+msgid "Name of new location"
+msgstr "Name der neuen Location"
+#: ../lib/init/epsg_option.tcl:125
+msgid "Enter name for location to be created"
+msgstr "Geben SIe den Namen der neu zu erzeugenden Location ein"
+#: ../lib/init/epsg_option.tcl:129 ../lib/init/epsg_option.tcl:132
+msgid "Path to the EPSG-codes file"
+msgstr "Pfad zur EPSG-Datei."
+#: ../lib/init/epsg_option.tcl:135 ../lib/init/epsg_option.tcl:148
+#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:105
+msgid "Browse..."
+msgstr "Blättern..."
+#: ../lib/init/epsg_option.tcl:136
+msgid "Browse to locate EPSG file"
+msgstr "Suchen Sie die EPSG-Datei."
+#: ../lib/init/epsg_option.tcl:143
+msgid "EPSG code number of projection"
+msgstr "EPSG-Nummer der Projektion"
+#: ../lib/init/epsg_option.tcl:146
+msgid "Enter EPSG code for selected projection"
+msgstr "Bitte geben Sie den EPSG-Code für die gewählte Projektion ein"
+#: ../lib/init/epsg_option.tcl:149
+msgid "View EPSG codes and projection information."
+msgstr "EPSG-Code und Projektionsinformaionen anschauen."
+#: ../lib/init/epsg_option.tcl:155
+msgid "WARNING: epsg-codes file not found"
+msgstr "WARNUNG: EPSG-Datei wurde nicht gefunden."
+#: ../lib/init/epsg_option.tcl:156
+msgid "WARNING: The epsg-codes file was not found!"
+msgstr "WARNUNG: Die EPSG-Datei konnte nicht gefunden werden!"
+#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:111
+msgid "Define location"
+msgstr "Location erzeugen"
+#: ../lib/init/epsg_option.tcl:187
+msgid "Invalid EPSG Code!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:188
+#, tcl-format
+msgid "ERROR: Invalid EPSG code %s: should be an integer."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:198
+msgid "Location Exists!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:199
+#, tcl-format
+msgid "WARNING: Location '%s' already exists: please try another name."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:236 ../lib/init/epsg_option.tcl:263
+#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
+#, fuzzy
+msgid "Error creating location!"
+msgstr "WARNUNG: Fehler beim Erstellen der Location"
+#: ../lib/init/epsg_option.tcl:237 ../lib/init/epsg_option.tcl:264
+#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
+#, tcl-format
+msgid ""
+"g.proj returned the following message:\n"
+"%s"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:244 ../lib/init/epsg_option.tcl:268
+#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
+msgid "Informational output from g.proj"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:245 ../lib/init/epsg_option.tcl:269
+#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
+#, tcl-format
+msgid ""
+"g.proj returned the following informational message:\n"
+"%s"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:240
+#, fuzzy
+msgid "Select datum transformation parameters:"
+msgstr "Standardschrift einstellen"
+#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:244
+msgid ""
+"Continue without specifying parameters - if used when creating a location, "
+"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
+"for this datum if necessary in the future."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:311 ../lib/init/file_option.tcl:263
+#: ../vector/v.digit/settings.tcl:175
+msgid "OK"
+msgstr "OK"
+#: ../lib/init/epsg_option.tcl:344
+msgid "You can select EPSG code (in <braces>) and copy it for later use."
+msgstr ""
+"Sie können die EPSG-Codes (in <Klammern>) auswählen und für später kopieren. "
+#: ../lib/init/epsg_option.tcl:381
+msgid "GUESS THAT IS NOT THE EPSG FILE"
+msgstr "ICH SCHÄZTE DIES IST NICHT DIE EPSG-DATEI."
+#: ../lib/init/epsg_option.tcl:387 ../lib/init/epsg_option.tcl:416
+#: ../lib/init/epsg_option.tcl:435
+msgid "Search"
+msgstr "Suchen"
+#: ../lib/init/epsg_option.tcl:389
+msgid "Grab code"
+msgstr "Einen Code wählen"
+#: ../lib/init/epsg_option.tcl:422
+msgid "Search text: "
+msgstr "Text suchen:"
+#: ../lib/init/epsg_option.tcl:423
+msgid "Search for entered text in EPSG file"
+msgstr "Den eingegebenen Text in der EPSG-Datei suchen."
+#: ../lib/init/epsg_option.tcl:428
+msgid "forward search"
+msgstr "Vorwärzsuche"
+#: ../lib/init/epsg_option.tcl:429
+msgid "backward search"
+msgstr "Rückwärzsuche"
+#: ../lib/init/gis_set.tcl:107
+#, fuzzy
+msgid "WARNING: can not save"
+msgstr "WARNUNG: Verzeichniswechsel fehlgeschlagen"
+#: ../lib/init/gis_set.tcl:108
+#, tcl-format
+msgid ""
+"Warning: unable to save data to <%s> file.\n"
+"Error message: %s"
+msgstr ""
+#: ../lib/init/gis_set.tcl:128 ../lib/init/gis_set.tcl:379
+#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:609
+#: ../lib/init/gis_set.tcl:630 ../lib/init/gis_set.tcl:648
+#: ../lib/init/gis_set.tcl:676
+msgid "WARNING: invalid location"
+msgstr "WARNUNG:ungültige Location"
+#: ../lib/init/gis_set.tcl:129
+#, tcl-format
+msgid ""
+"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr ""
+"Warnung. Location <%s> in GISDBASE <%s> ist kein Ordner oder existiert nicht."
+#: ../lib/init/gis_set.tcl:179
+#, tcl-format
+msgid "GRASS %s Startup"
+msgstr "GRASS %s Start"
+#: ../lib/init/gis_set.tcl:202
+msgid "Welcome to GRASS GIS Version"
+msgstr "Willkommen in GRASS GIS Version"
+#: ../lib/init/gis_set.tcl:204
+msgid ""
+"The world's leading open source GIS\n"
+"\n"
+msgstr ""
+"Das weltweit führende quelloffene GIS\n"
+"\n"
+#: ../lib/init/gis_set.tcl:205
+msgid "Select an existing project location and mapset\n"
+msgstr "Wählen Sie eine existierende Location mit Mapset\n"
+#: ../lib/init/gis_set.tcl:206
+msgid "or define a new location\n"
+msgstr "oder definieren Sie eine neue Location\n"
+#: ../lib/init/gis_set.tcl:229
+msgid "GIS Data Directory: "
+msgstr "Datenbankverzeichnis"
+#: ../lib/init/gis_set.tcl:245
+msgid "New GIS data directory"
+msgstr "Neues GIS Datenverzeichnis"
+#: ../lib/init/gis_set.tcl:268
+#, fuzzy
+msgid "Project Location (projection/coordinate system)"
+msgstr ""
+"Projekt Location\n"
+"(Projektion/Koordinatensystem)"
+#: ../lib/init/gis_set.tcl:301
+#, fuzzy
+msgid "Accessible Mapsets (directories of GIS files)"
+msgstr ""
+"Verfügbare Mapsets\n"
+"(Ordner mit GIS-Daten)"
+#: ../lib/init/gis_set.tcl:358
+#, fuzzy
+msgid "Create new mapset in selected location"
+msgstr ""
+"Neues Mapset in der ausge-\n"
+"wählten Location erstellen"
+#: ../lib/init/gis_set.tcl:366
+msgid "Create new mapset"
+msgstr "Neues Mapset erstellen"
+#: ../lib/init/gis_set.tcl:371
+#, fuzzy
+msgid "WARNING: invalid mapset name"
+msgstr "WARNUNG:ungültiges Mapset"
+#: ../lib/init/gis_set.tcl:372
+#, fuzzy, tcl-format
+msgid ""
+"Warning: Mapset with name <%s> already exists. \n"
+"New mapset is NOT created. \n"
+"Choose different mapset name and try again."
+msgstr ""
+"Warnung: Ausgewählte Location <%s> ist nicht gültig.\n"
+" Neues Mapset wurde NICHT erstellt.\n"
+".Wählen Sie eine gültige Location und versuchen Sie es erneut."
+#: ../lib/init/gis_set.tcl:380
+#, tcl-format
+msgid ""
+"Warning: selected location <%s> is not valid. \n"
+" New mapset is NOT created. \n"
+" Select valid location and try again."
+msgstr ""
+#: ../lib/init/gis_set.tcl:387
+#, fuzzy
+msgid "WARNING: unable to mkdir"
+#: ../lib/init/gis_set.tcl:388
+#, tcl-format
+msgid ""
+"Warning: Unable to create directory for new mapset. \n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:413
+msgid "Define new location with..."
+msgstr "Definieren einer neuen Location mit..."
+#: ../lib/init/gis_set.tcl:417
+msgid "Georeferenced file"
+msgstr "einer georeferenzierten Datei"
+#: ../lib/init/gis_set.tcl:430
+msgid "EPSG codes"
+msgstr "einem EPSG-Code"
+#: ../lib/init/gis_set.tcl:443
+msgid "Projection values"
+msgstr "Projektionsinformationen"
+#: ../lib/init/gis_set.tcl:481
+msgid "Enter GRASS"
+msgstr "GRASS starten"
+#: ../lib/init/gis_set.tcl:486
+#, tcl-format
+msgid ""
+msgstr ""
+#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:654
+msgid "WARNING: invalid mapset"
+#: ../lib/init/gis_set.tcl:492
+#, tcl-format
+msgid "Warning: <%s> is not a valid mapset"
+msgstr "Warnung: <%s> ist kein gültiges Mapset"
+#: ../lib/init/gis_set.tcl:512
+msgid "Help already opened"
+msgstr "Hilfe ist bereits geöffnet"
+#: ../lib/init/gis_set.tcl:525
+msgid "Exit"
+msgstr "Beenden"
+#: ../lib/init/gis_set.tcl:561
+msgid "WARNING: Invalid Database"
+msgstr "WARNUNG: ungültige Datenbank"
+#: ../lib/init/gis_set.tcl:562
+msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
+msgstr ""
+"WARNUNG: Ungültige Datenbasis. Finde ersten gültigen Ordner im "
+"Verzeichnisbaum"
+#: ../lib/init/gis_set.tcl:610 ../lib/init/gis_set.tcl:631
+#: ../lib/init/gis_set.tcl:649 ../lib/init/gis_set.tcl:677
+#, tcl-format
+msgid ""
+"Warning: selected location <%%s> is not valid. \n"
+msgstr ""
+"Warnung: Ausgewählte Location <%%s> ist nicht gültig.\n"
+".Wählen Sie eine neue Location und versuchen Sie es erneut."
+#: ../lib/init/gis_set.tcl:655
+#, tcl-format
+msgid "Warning: <%%s> is not a valid mapset"
+msgstr "Warnung: <%%s> ist kein gültiges Mapset"
+#: ../lib/init/gis_set.tcl:747
+msgid "WARNING: change directory failed"
+#: ../lib/init/gis_set.tcl:748
+#, tcl-format
+msgid ""
+"Warning: could not change directory to <%s>.\n"
+"Check directory permissions."
+msgstr ""
+"Warnung: Konnte nicht in das Verzeichnis <%s> wechseln.\n"
+"Überprüfen Sie die Verzeichnisberechtigung."
+#: ../lib/init/file_option.tcl:72
+msgid "Define location using projection information in georeferenced file"
+msgstr ""
+"Definieren Sie die Projektionsinformationen, die für die georeferenzierte "
+"Datei angewandt werden sollen."
+#: ../lib/init/file_option.tcl:95
+msgid "Enter name of location to be created"
+msgstr "Geben SIe den Namen der neu zu erzeugenden Location ein."
+#: ../lib/init/file_option.tcl:99
+msgid "Path to georeferenced file"
+msgstr "Pfad zur georeferenzierten Datei"
+#: ../lib/init/file_option.tcl:102
+msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
+msgstr ""
+"Pfad zur georeferenzierten Datei (Format muss von GDAL/OGR lesebar sein)"
+#: ../lib/init/file_option.tcl:106
+msgid "Browse to locate georeferenced file"
+msgstr "Suchen Sie den Pfad zur georeferenzierten Datei"
+#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
+msgid "Choose georeferenced file"
+msgstr "Wählen Sie die georeferenzierten Datei."
+#: ../lib/init/file_option.tcl:152
+msgid ""
+"WARNING: Please supply a\n"
+"valid georeferenced file"
+msgstr ""
+"WARNUNG: Bitte geben Sie eine\n"
+"gültige georeferenzierte Datei an."
+#: ../vector/v.digit/settings.tcl:76
+msgid "Add new column"
+msgstr "Neue Spalte hinzufügen"
+#: ../vector/v.digit/settings.tcl:79
+msgid "Create table"
+msgstr "Erzeuge Tabelle"
+#: ../vector/v.digit/settings.tcl:112
+msgid "Add command"
+msgstr "Kommando hinzufügen"
+#: ../vector/v.digit/settings.tcl:150
+msgid "Table successfully created"
+msgstr "Tabelle erfolgreich erstellt."
+#: ../vector/v.digit/settings.tcl:166
+msgid "Settings already opened"
+msgstr "Einstellungen sind bereits geöffnet"
+#: ../vector/v.digit/settings.tcl:184
+msgid "Symbology"
+msgstr "Bezeichnungen"
+#: ../vector/v.digit/settings.tcl:188 ../vector/v.digit/settings.tcl:341
+msgid "Background"
+msgstr "Hintergrund"
+#: ../vector/v.digit/settings.tcl:195
+msgid "Highlight"
+msgstr "Hervorheben"
+#: ../vector/v.digit/settings.tcl:202
+msgid "Point"
+msgstr "Punkt"
+#: ../vector/v.digit/settings.tcl:211
+msgid "Line"
+msgstr "Linie"
+#: ../vector/v.digit/settings.tcl:220
+msgid "Boundary (no area)"
+msgstr "Boundary (keine Fläche)"
+#: ../vector/v.digit/settings.tcl:228
+msgid "Boundary (1 area)"
+msgstr "Boundary (1 Fläche)"
+#: ../vector/v.digit/settings.tcl:236
+msgid "Boundary (2 areas)"
+msgstr "Umrandung (2 Flächen)"
+#: ../vector/v.digit/settings.tcl:245
+msgid "Centroid (in area)"
+msgstr "Zentroid (in Fläche)"
+#: ../vector/v.digit/settings.tcl:253
+msgid "Centroid (outside area)"
+msgstr "Zentroid (außerhalb einer Fläche)"
+#: ../vector/v.digit/settings.tcl:261
+msgid "Centroid (duplicate in area)"
+msgstr "Zentroid (Duplikat in einer Fläche)"
+#: ../vector/v.digit/settings.tcl:270
+msgid "Node (1 line)"
+msgstr "Knoten (1 Linie)"
+#: ../vector/v.digit/settings.tcl:278
+msgid "Node (2 lines)"
+msgstr "Knoten (2 Linien)"
+#: ../vector/v.digit/settings.tcl:288
+msgid "Settings"
+msgstr "Einstellungen"
+#: ../vector/v.digit/settings.tcl:293
+msgid "Snapping threshold in screen pixels"
+msgstr "Schnappdistanz (in Bildschirmpixel)"
+#: ../vector/v.digit/settings.tcl:303
+msgid "Snapping threshold in map units"
+msgstr "Schnappdistanz (in Karteneinheiten)"
+#: ../vector/v.digit/settings.tcl:320
+msgid "Line width in screen pixels"
+msgstr "Linienbreite in Bildschirmpixeln"
+#: ../vector/v.digit/settings.tcl:322
+msgid "Set line width in pixels"
+msgstr "LegeLinienbreite in Pixel fest"
+#: ../vector/v.digit/settings.tcl:330
+msgid "Table"
+msgstr "Tabelle"
+#: ../vector/v.digit/toolbox.tcl:20
+msgid "Welcome to v.digit"
+msgstr "Willkommen bei v.digit"
+#: ../vector/v.digit/toolbox.tcl:21
+msgid "Left button"
+msgstr "Linker Mausknopf"
+#: ../vector/v.digit/toolbox.tcl:22
+msgid "Middle button"
+msgstr "Mittlerer Mausknopf"
+#: ../vector/v.digit/toolbox.tcl:23
+msgid "Right button"
+msgstr "Rechter Mausknopf"
+#: ../vector/v.digit/toolbox.tcl:76
+msgid "  Layer"
+msgstr "  Ebene"
+#: ../vector/v.digit/toolbox.tcl:80
+msgid "  Category"
+msgstr "  Kategorie"
+#: ../vector/v.digit/toolbox.tcl:84
+msgid "  Mode "
+msgstr "  Modus"
+#: ../vector/v.digit/toolbox.tcl:96
+msgid "Insert new record into table"
+msgstr "Neuen Eintrag in Tabelle einfügen"
+#: ../vector/v.digit/toolbox.tcl:113
+msgid "Digitize new point"
+msgstr "Neuen Punkt digitalisieren"
+#: ../vector/v.digit/toolbox.tcl:118
+msgid "Digitize new line"
+msgstr "Neue Linie digitalisieren"
+#: ../vector/v.digit/toolbox.tcl:123
+msgid "Digitize new boundary"
+msgstr "Digitalisiere neue Umrandung (Boundary)"
+#: ../vector/v.digit/toolbox.tcl:128
+msgid "Digitize new centroid"
+msgstr "Digitalisiere neuen Zentroid"
+#: ../vector/v.digit/toolbox.tcl:134
+msgid "Move vertex"
+msgstr "Verschiebe Vertex"
+#: ../vector/v.digit/toolbox.tcl:139
+msgid "Add vertex"
+msgstr "Füge Vertex hinzu"
+#: ../vector/v.digit/toolbox.tcl:144
+msgid "Remove vertex"
+msgstr "Entferne Vertex"
+#: ../vector/v.digit/toolbox.tcl:149
+msgid "Split line"
+msgstr "Teile Linie"
+#: ../vector/v.digit/toolbox.tcl:154
+msgid "Edit line/boundary"
+msgstr "Editiere Linie/Boundary"
+#: ../vector/v.digit/toolbox.tcl:159
+msgid "Move point, line, boundary, or centroid"
+msgstr "Verschiebe Punkt, Linie, Boundary oder Zentroid."
+#: ../vector/v.digit/toolbox.tcl:164
+msgid "Delete point, line, boundary, or centroid"
+msgstr "Lösche Punkt, Linie, Boundary oder Zentroid."
+#: ../vector/v.digit/toolbox.tcl:175
+msgid "Redraw"
+msgstr "Neu zeichnen"
+#: ../vector/v.digit/toolbox.tcl:180
+msgid "Zoom in by window"
+msgstr "Hereinzoomen"
+#: ../vector/v.digit/toolbox.tcl:185
+msgid "Zoom out"
+msgstr "Herauszoomen"
+#: ../vector/v.digit/toolbox.tcl:190
+msgid "Pan"
+msgstr "Verschieben"
+#: ../vector/v.digit/toolbox.tcl:195
+msgid "Zoom to default region"
+msgstr "Zoomen auf die Standardregion"
+#: ../vector/v.digit/toolbox.tcl:208
+#, fuzzy
+msgid "Zoom to saved region"
+msgstr "Zoomen auf die Region"
+#: ../vector/v.digit/toolbox.tcl:214
+msgid "Display categories"
+msgstr "Zeige Kategorien"
+#: ../vector/v.digit/toolbox.tcl:219
+msgid "Copy categories"
+msgstr "Kategorien kopieren"
+#: ../vector/v.digit/toolbox.tcl:224
+msgid "Display attributes"
+msgstr "Zeige Attribute"
+#: ../vector/v.digit/toolbox.tcl:236
+msgid "Open settings"
+msgstr "Öffnen Einstellungen"
+#: ../vector/v.digit/toolbox.tcl:242
+msgid "Save and exit"
+msgstr "Speichern und beenden"
+#: ../vector/v.digit/toolbox.tcl:253
+msgid "mouse button actions (left, middle, right)"
+msgstr "Mausknopfbelegung (links, mitte, rechts)"
+#: ../vector/v.digit/cats.tcl:20
+msgid "Delete"
+msgstr "Löschen"
+#: ../vector/v.digit/cats.tcl:34
+#, fuzzy
+msgid "Categories already opened"
+#: ../vector/v.digit/cats.tcl:42
+msgid "Categories"
+msgstr "Kategorien"
+#: ../vector/v.digit/cats.tcl:53
+msgid "Layer:"
+msgstr "Ebene:"
+#: ../vector/v.digit/cats.tcl:55
+#, fuzzy
+msgid "   Category:"
+#: ../vector/v.digit/cats.tcl:62
+msgid "Insert new record to table"
+msgstr "Füge neuen Eintrag in Tabelle ein"
+#: ../vector/v.digit/cats.tcl:63
+msgid "Add new"
+msgstr "Neu hinzufügen"
+#: ../visualization/nviz/scripts/panel_animation.tcl:275
+msgid "Test"
+msgstr "Testen"
 msgid "Vector map"
 msgstr "Vektorkarte"
-#: ../gui/tcltk/gis.m/thematic.tcl:132
-#, fuzzy, tcl-format
+#, fuzzy
 msgid "thematic map for %s"
 msgstr "Thematische Karten-Ebene hinzufügen"
-#: ../gui/tcltk/gis.m/thematic.tcl:141 ../gui/tcltk/gis.m/thematic.tcl:148
-#: ../gui/tcltk/gis.m/thematic.tcl:154 ../gui/tcltk/gis.m/maplabels.tcl:135
-#: ../gui/tcltk/gis.m/maptext.tcl:80
-msgid "This is font sample text."
-msgstr ""
 #, fuzzy
 msgid "Select font"
 msgstr "Schrift für Text"
-#: ../gui/tcltk/gis.m/thematic.tcl:194 ../gui/tcltk/gis.m/vector.tcl:281
 #, fuzzy
 msgid "Vector point symbol"
 msgstr "Vektorlinien -> Vektorpunkte"
-#: ../gui/tcltk/gis.m/thematic.tcl:210
-msgid "Display vector maps thematically by graduate colors (all types)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:216
-msgid "  or by graduated sizes (points and lines)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:223 ../gui/tcltk/gis.m/labels.tcl:118
-#: ../gui/tcltk/gis.m/rastarrows.tcl:147 ../gui/tcltk/gis.m/rastnums.tcl:146
-#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
-#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
-#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
-#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
-#: ../gui/tcltk/gis.m/dtext.tcl:166 ../gui/tcltk/gis.m/histogram.tcl:145
 msgid "Opaque "
 msgstr "Transparenz"
-#: ../gui/tcltk/gis.m/thematic.tcl:227 ../gui/tcltk/gis.m/labels.tcl:122
-#: ../gui/tcltk/gis.m/rastarrows.tcl:151 ../gui/tcltk/gis.m/rastnums.tcl:150
-#: ../gui/tcltk/gis.m/gridline.tcl:151 ../gui/tcltk/gis.m/legend.tcl:204
-#: ../gui/tcltk/gis.m/raster.tcl:172 ../gui/tcltk/gis.m/chart.tcl:170
-#: ../gui/tcltk/gis.m/cmd.tcl:109 ../gui/tcltk/gis.m/barscale.tcl:164
-#: ../gui/tcltk/gis.m/rgbhis.tcl:147 ../gui/tcltk/gis.m/dtext.tcl:170
-#: ../gui/tcltk/gis.m/histogram.tcl:149
 msgid " Transparent"
 msgstr " Transparent"
-#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:316
 msgid "Vector map:"
 msgstr "Vektorkarte:"
-#: ../gui/tcltk/gis.m/thematic.tcl:236
 msgid "vector for thematic mapping"
 msgstr "Vektor für thematische Karte"
-#: ../gui/tcltk/gis.m/thematic.tcl:241 ../gui/tcltk/gis.m/thematic.tcl:245
-#: ../gui/tcltk/gis.m/profile.tcl:131 ../gui/tcltk/gis.m/profile.tcl:135
-#: ../gui/tcltk/gis.m/labels.tcl:136 ../gui/tcltk/gis.m/labels.tcl:140
-#: ../gui/tcltk/gis.m/rastarrows.tcl:164 ../gui/tcltk/gis.m/rastarrows.tcl:167
-#: ../gui/tcltk/gis.m/runandoutput.tcl:47 ../gui/tcltk/gis.m/rastnums.tcl:163
-#: ../gui/tcltk/gis.m/rastnums.tcl:166 ../gui/tcltk/gis.m/frames.tcl:118
-#: ../gui/tcltk/gis.m/frames.tcl:122 ../gui/tcltk/gis.m/animate.tcl:405
-#: ../gui/tcltk/gis.m/animate.tcl:409 ../gui/tcltk/gis.m/animate.tcl:478
-#: ../gui/tcltk/gis.m/animate.tcl:481 ../gui/tcltk/gis.m/dnviz.tcl:208
-#: ../gui/tcltk/gis.m/dnviz.tcl:212 ../gui/tcltk/gis.m/gridline.tcl:162
-#: ../gui/tcltk/gis.m/gridline.tcl:214 ../gui/tcltk/gis.m/gridline.tcl:241
-#: ../gui/tcltk/gis.m/legend.tcl:219 ../gui/tcltk/gis.m/legend.tcl:222
-#: ../gui/tcltk/gis.m/raster.tcl:192 ../gui/tcltk/gis.m/raster.tcl:196
-#: ../gui/tcltk/gis.m/chart.tcl:184 ../gui/tcltk/gis.m/chart.tcl:188
-#: ../gui/tcltk/gis.m/vector.tcl:330 ../gui/tcltk/gis.m/vector.tcl:334
-#: ../gui/tcltk/gis.m/barscale.tcl:180 ../gui/tcltk/gis.m/barscale.tcl:184
-#: ../gui/tcltk/gis.m/rgbhis.tcl:156 ../gui/tcltk/gis.m/rgbhis.tcl:165
-#: ../gui/tcltk/gis.m/dtext.tcl:177 ../gui/tcltk/gis.m/dtext.tcl:181
-#: ../gui/tcltk/gis.m/georect.tcl:705 ../gui/tcltk/gis.m/georect.tcl:709
-#: ../gui/tcltk/gis.m/georect.tcl:1132 ../gui/tcltk/gis.m/georect.tcl:1136
-#: ../gui/tcltk/gis.m/rules.tcl:139 ../gui/tcltk/gis.m/rules.tcl:143
-#: ../gui/tcltk/gis.m/histogram.tcl:162 ../gui/tcltk/gis.m/histogram.tcl:165
-#: ../lib/gis/gui.tcl:504 ../lib/init/gis_set.tcl:507
-msgid "Help"
-msgstr "Hilfe"
-#: ../gui/tcltk/gis.m/thematic.tcl:251
 msgid "    vector type"
 msgstr "    Vectortyp"
-#: ../gui/tcltk/gis.m/thematic.tcl:254
 #, fuzzy
 msgid " attribute layer"
 msgstr "Attributspalte für die Labels"
-#: ../gui/tcltk/gis.m/thematic.tcl:261
-msgid "    NUMERIC attribute column to use for thematic map"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:268
 msgid "    show attribute columns"
 msgstr "    zeige Attributspalten"
-#: ../gui/tcltk/gis.m/thematic.tcl:269 ../gui/tcltk/gis.m/chart.tcl:213
-#: ../gui/tcltk/gis.m/vector.tcl:484
 msgid "columns"
 msgstr "Spalten"
-#: ../gui/tcltk/gis.m/thematic.tcl:273 ../gui/tcltk/gis.m/chart.tcl:217
-#: ../gui/tcltk/gis.m/vector.tcl:488
 msgid "Show columns"
 msgstr "Zeige Spalten"
-#: ../gui/tcltk/gis.m/thematic.tcl:274
 msgid "   show data"
 msgstr "   Zeige Daten"
-#: ../gui/tcltk/gis.m/thematic.tcl:275 ../gui/tcltk/gis.m/chart.tcl:219
-#: ../gui/tcltk/gis.m/vector.tcl:490
 msgid "data"
 msgstr "Daten"
-#: ../gui/tcltk/gis.m/thematic.tcl:279 ../gui/tcltk/gis.m/chart.tcl:223
-#: ../gui/tcltk/gis.m/vector.tcl:494
 msgid "Show data"
 msgstr "Zeige Daten"
-#: ../gui/tcltk/gis.m/thematic.tcl:285
 msgid "Thematic map: type"
 msgstr "Thematische Karte: Typ"
-#: ../gui/tcltk/gis.m/thematic.tcl:288
-msgid " map by"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:297
-msgid "    number of intervals to map (interval themes):"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:305
-msgid "    custom breakpoints (val val ...)  "
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:312
-msgid "    query with SQL where clause   "
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:319
-msgid "Graduated points & lines: "
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:320
 msgid "icon"
 msgstr "Icon"
-#: ../gui/tcltk/gis.m/thematic.tcl:324
 msgid "point color"
 msgstr "Punktfarbe"
-#: ../gui/tcltk/gis.m/thematic.tcl:326
 msgid "line color"
 msgstr "Linienfarbe"
-#: ../gui/tcltk/gis.m/thematic.tcl:333
-msgid "    size/min size (graduated pts/lines)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:335
-msgid "icon size/min size (graduated pts/lines)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:336
-msgid "max size (graduated pts)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:338
-msgid " max size (graduated pts/lines)"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:344
 msgid "Graduated colors: preset color schemes"
 msgstr "Abgestufte Farben: Farbschemata setzen"
-#: ../gui/tcltk/gis.m/thematic.tcl:354
-msgid "    custom color scheme - start color"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:356
 #, fuzzy
 msgid " end color"
 msgstr "  Farbe"
-#: ../gui/tcltk/gis.m/thematic.tcl:358
 msgid "draw border"
 msgstr "Zeichne Rahmen"
-#: ../gui/tcltk/gis.m/thematic.tcl:365
 msgid "save thematic colors to GRASSRGB column of vector file"
 msgstr "speichere thematische Farben in GRASSRGB-Spalte der Vektordatei"
-#: ../gui/tcltk/gis.m/thematic.tcl:372
 msgid "Legend: title font "
 msgstr "Legende: Titelschrift "
-#: ../gui/tcltk/gis.m/thematic.tcl:375
 msgid "title font for legend"
 msgstr "Titelschrift für Legende"
-#: ../gui/tcltk/gis.m/thematic.tcl:379 ../gui/tcltk/gis.m/thematic.tcl:405
 #, fuzzy
 msgid " font color"
 msgstr "Punktfarbe"
-#: ../gui/tcltk/gis.m/thematic.tcl:386
 msgid "    subtitle font    "
 msgstr "    Untertitelschrift    "
-#: ../gui/tcltk/gis.m/thematic.tcl:389
 msgid "subtitle font for legend"
 msgstr "Schrift für den Untetitel der Legende"
-#: ../gui/tcltk/gis.m/thematic.tcl:398
 msgid "    label font       "
 msgstr "    Labelschrift       "
-#: ../gui/tcltk/gis.m/thematic.tcl:401
 msgid "label font for legend"
 msgstr "Schrift für die Legendenlabel"
-#: ../gui/tcltk/gis.m/thematic.tcl:413
 msgid "use math notation in legend"
 msgstr "Benutze mathematische Notation in der Lengende"
-#: ../gui/tcltk/gis.m/thematic.tcl:420
-msgid "Name for ps.map instruction files"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:630
-#, tcl-format
-msgid "Legend for Map %d, %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/thematic.tcl:653
 #, fuzzy
 msgid "clear"
 msgstr "Löschen"
-#: ../gui/tcltk/gis.m/thematic.tcl:655
 msgid "Clear legend"
 msgstr "Lösche Legende"
-#: ../gui/tcltk/gis.m/thematic.tcl:656
 #, fuzzy
 msgid "save"
 msgstr "Speichern"
-#: ../gui/tcltk/gis.m/thematic.tcl:658
 msgid "Save legend to EPS file"
 msgstr "Legende als EPS-Datei speichern"
-#: ../gui/tcltk/gis.m/profile.tcl:110
 msgid ""
 "Select raster map to profile.\n"
 "Currently selected raster is default."
@@ -312,3759 +868,2165 @@
 "Rasterkarte für das Profile auswählen.\n"
 "Die derzeit gewählte Rasterkarte ist der Standard."
-#: ../gui/tcltk/gis.m/profile.tcl:115
 msgid "Draw profile transect in map display"
 msgstr "Zeichne Profiltransekt im Kartenfenster"
-#: ../gui/tcltk/gis.m/profile.tcl:120
 msgid "Draw profile"
 msgstr "Zeichne Profil"
-#: ../gui/tcltk/gis.m/profile.tcl:125
 msgid "Clear profile"
 msgstr "Lösche Profil"
-#: ../gui/tcltk/gis.m/profile.tcl:130
 msgid "Save profile to EPS file"
 msgstr "Speicher Profil als EPS-Datei"
-#: ../gui/tcltk/gis.m/profile.tcl:177
 #, fuzzy
 msgid "r.univar error"
 msgstr "Vorwärz-Fehler"
-#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:433
-msgid "g.proj or projection error"
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:436
-msgid "You must select a raster to profile"
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:437
 #, fuzzy
 msgid "No raster map selected"
 msgstr "Volumen zu Rasterkartenserien"
-#: ../gui/tcltk/gis.m/profile.tcl:443
-msgid "You must draw a transect to profile"
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:444
-msgid "No transect drawn"
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:449
 msgid "Please wait while profile elevations are calculated"
 msgstr "Bitte warten Sie, während die Profilhöhen berechnet werden"
-#: ../gui/tcltk/gis.m/profile.tcl:454
-msgid ""
-"Elevation range for selected raster is zero.\n"
-"No profile can be created."
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:455
-msgid "Zero elevation range"
-msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:534 ../gui/tcltk/gis.m/profile.tcl:619
-msgid "r.profile error"
-msgstr ""
-#: ../gui/tcltk/gis.m/labels.tcl:96
 #, fuzzy
 msgid "Labels for vectors"
 msgstr "Beschrifte Vektoren:"
-#: ../gui/tcltk/gis.m/labels.tcl:111
-msgid "Display labels for vector objects (created with v.label)"
-msgstr ""
-#: ../gui/tcltk/gis.m/labels.tcl:128 ../gui/tcltk/gis.m/maplabels.tcl:172
 msgid "Labels file:"
 msgstr "Beschriftungen:"
-#: ../gui/tcltk/gis.m/labels.tcl:131 ../gui/tcltk/gis.m/maplabels.tcl:175
 msgid "labels file to display"
 msgstr "Label-Datei, die dargestellt werden soll"
-#: ../gui/tcltk/gis.m/labels.tcl:146
 msgid "Display constraints:"
 msgstr "Display-Bedingungen:"
-#: ../gui/tcltk/gis.m/labels.tcl:147
-msgid "min"
-msgstr ""
-#: ../gui/tcltk/gis.m/labels.tcl:149
-msgid "max"
-msgstr ""
-#: ../gui/tcltk/gis.m/labels.tcl:151
 msgid "region size"
 msgstr "Regionsgröße"
-#: ../gui/tcltk/gis.m/labels.tcl:157
 msgid " ignore rotation setting and draw horizontally"
 msgstr " Ignoriere Rotationseinstellungen und zeichne horizontal"
-#: ../gui/tcltk/gis.m/labels.tcl:164 ../gui/tcltk/gis.m/maplabels.tcl:279
-msgid "Launch v.label to create labels file"
-msgstr ""
-#: ../gui/tcltk/gis.m/labels.tcl:165 ../gui/tcltk/gis.m/maplabels.tcl:280
 msgid "v.label"
 msgstr "v.label"
-#: ../gui/tcltk/gis.m/gm.tcl:197
 msgid "Loading GIS Manager"
 msgstr "Lade GIS Manager"
-#: ../gui/tcltk/gis.m/gm.tcl:204
 msgid "Creating MainFrame..."
 msgstr "Erzeuge Hauprahmen..."
-#: ../gui/tcltk/gis.m/gm.tcl:244
 msgid "Done"
 msgstr "Fertig."
-#: ../gui/tcltk/gis.m/gm.tcl:246
 #, fuzzy
 msgid "Welcome to GRASS GIS"
-#: ../gui/tcltk/gis.m/gm.tcl:279
+#, fuzzy
 msgid "Map Display %d"
 msgstr "Darstellung: "
-#: ../gui/tcltk/gis.m/gm.tcl:304
-#, tcl-format
 msgid "GRASS%s GIS Manager - %s"
 msgstr "GRASS %s GIS Manager - %s"
-#: ../gui/tcltk/gis.m/gm.tcl:378
 #, fuzzy
 msgid "Select GRASS display font"
-#: ../gui/tcltk/gis.m/gm.tcl:388
 #, fuzzy
 msgid "Font: "
 msgstr "Schrift:"
-#: ../gui/tcltk/gis.m/gm.tcl:423
-msgid "Character encoding: "
-msgstr ""
-#: ../gui/tcltk/gis.m/gm.tcl:430 ../gui/tcltk/gis.m/animate.tcl:533
-#: ../gui/tcltk/gis.m/dnviz.tcl:228 ../gui/tcltk/gis.m/rules.tcl:170
-#: ../lib/init/epsg_option.tcl:311 ../lib/init/file_option.tcl:263
-#: ../vector/v.digit/settings.tcl:161
-msgid "OK"
-msgstr "OK"
-#: ../gui/tcltk/gis.m/gm.tcl:433 ../gui/tcltk/gis.m/animate.tcl:535
-#: ../gui/tcltk/gis.m/dnviz.tcl:230 ../gui/tcltk/gis.m/mapcanvas.tcl:855
-#: ../gui/tcltk/gis.m/georect.tcl:700 ../gui/tcltk/gis.m/rules.tcl:172
-#: ../lib/gtcltk/select.tcl:209 ../lib/init/epsg_option.tcl:167
-#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
-#: ../lib/init/file_option.tcl:266
-msgid "Cancel"
-msgstr "Abbrechen"
-#: ../gui/tcltk/gis.m/gm.tcl:504
-#, tcl-format
 msgid "GRASS%s GIS Manager - %s %s"
 msgstr "GRASS%s GIS Manager - %s %s"
-#: ../gui/tcltk/gis.m/rastarrows.tcl:106
 #, fuzzy
 msgid "Aspect map"
-#: ../gui/tcltk/gis.m/rastarrows.tcl:109 ../gui/tcltk/gis.m/rastarrows.tcl:121
-#, tcl-format
-msgid "arrows for %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:118
-msgid "Slope/intensity map"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:134
-msgid "Display arrows whose orientations are based on raster aspect map"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:140
-msgid "  (optionally, arrow lengths are based on slope or intensity map)"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:157
 #, fuzzy
 msgid "Aspect map: "
-#: ../gui/tcltk/gis.m/rastarrows.tcl:173
 #, fuzzy
 msgid "    aspect value type"
 msgstr "    Vectortyp"
-#: ../gui/tcltk/gis.m/rastarrows.tcl:181
-msgid "    draw arrows every Nth grid cell"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:189
 #, fuzzy
 msgid "    arrow color      "
 msgstr "            "
-#: ../gui/tcltk/gis.m/rastarrows.tcl:194
 #, fuzzy
 msgid "     cell grid color"
 msgstr " Gitterfarbe "
-#: ../gui/tcltk/gis.m/rastarrows.tcl:204
 #, fuzzy
 msgid "    null value color"
 msgstr "     Neuer Vektor"
-#: ../gui/tcltk/gis.m/rastarrows.tcl:219
-msgid "Slope/intensity map: "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:230
 msgid "    scale factor for computing arrow length"
 msgstr "    Skalierungsfaktor zur Pfeillängenberechnung"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:44
-#: ../gui/tcltk/gis.m/runandoutput.tcl:116 ../lib/gis/gui.tcl:503
-msgid "Run"
-msgstr "Los"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:48 ../gui/tcltk/gis.m/gmmenu.tcl:90
-#: ../gui/tcltk/gis.m/mapprint.tcl:366 ../lib/gis/gui.tcl:506
-#: ../lib/init/epsg_option.tcl:394 ../lib/init/epsg_option.tcl:438
-msgid "Close"
-msgstr "Schließen"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:118
 #, fuzzy
 msgid "Run (background)"
 msgstr "Los (im Hintergrund)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:120
 #, fuzzy
 msgid "Run (GUI)"
 msgstr "Starte UI"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:122
 #, fuzzy
 msgid "Run (in Xterm)"
 msgstr "Aufrufen in Xterm"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:125 ../gui/tcltk/gis.m/gmmenu.tcl:88
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:859
 msgid "Save"
 msgstr "Speichern"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:127 ../lib/gis/gui.tcl:505
-msgid "Clear"
-msgstr "Löschen"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:148
 msgid "Output - GIS.m"
 msgstr "Ausgabe - GIS.m"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:259
-#: ../gui/tcltk/gis.m/runandoutput.tcl:265
-#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:137
-#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310
-msgid "Error"
-msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:266
-msgid "This module requires X11 support, but no xmons were found"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:41 ../gui/tcltk/gis.m/georecttool.tcl:40
 msgid "Display active layers"
 msgstr "Zeige aktive Ebenen"
-#: ../gui/tcltk/gis.m/maptool.tcl:48
 msgid "Redraw all layers"
 msgstr "Alle Ebenen neu zeichnen"
-#: ../gui/tcltk/gis.m/maptool.tcl:55
 msgid "Start NVIZ using active layers in current region"
 msgstr "Starte NVIZ mit den aktiven Ebenen in der aktuellen Region"
-#: ../gui/tcltk/gis.m/maptool.tcl:61
 #, fuzzy
 msgid "Create flythough path for NVIZ"
 msgstr "Pfad zum Durchflug mit NVIZ"
-#: ../gui/tcltk/gis.m/maptool.tcl:68 ../gui/tcltk/gis.m/georecttool.tcl:47
 msgid "Erase to white"
 msgstr "Lösche Display (in weiß)"
-#: ../gui/tcltk/gis.m/maptool.tcl:94
 msgid "Pointer"
 msgstr "Mauszeiger"
-#: ../gui/tcltk/gis.m/maptool.tcl:113 ../gui/tcltk/gis.m/georecttool.tcl:92
 msgid "Zoom In"
-#: ../gui/tcltk/gis.m/maptool.tcl:132 ../gui/tcltk/gis.m/georecttool.tcl:111
 msgid "Zoom Out"
-#: ../gui/tcltk/gis.m/maptool.tcl:151 ../gui/tcltk/gis.m/georecttool.tcl:130
-#: ../vector/v.digit/toolbox.tcl:190
-msgid "Pan"
-msgstr "Verschieben"
-#: ../gui/tcltk/gis.m/maptool.tcl:165 ../gui/tcltk/gis.m/georecttool.tcl:144
 msgid "Return to previous zoom"
 msgstr "Zurück zur vorherigen Zoom-Einstellung."
-#: ../gui/tcltk/gis.m/maptool.tcl:172
 msgid "Zoom to..."
 msgstr "Zoome zu..."
-#: ../gui/tcltk/gis.m/maptool.tcl:184
 #, fuzzy
 msgid "Zoom display to selected map"
 msgstr "Auf die Karte zoomen"
-#: ../gui/tcltk/gis.m/maptool.tcl:187
 #, fuzzy
 msgid "Zoom display to saved region"
-#: ../gui/tcltk/gis.m/maptool.tcl:190
 #, fuzzy
 msgid "Save display extents to named region"
 msgstr "Speichere aktuelle Geometrien in einer benannten Region"
-#: ../gui/tcltk/gis.m/maptool.tcl:193
-msgid "Zoom display to computational region (set with g.region)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:196
 #, fuzzy
 msgid "Zoom display to default region"
-#: ../gui/tcltk/gis.m/maptool.tcl:199
-msgid "Set computational region extents to match display"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:228 ../gui/tcltk/gis.m/gmmenu.tcl:622
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1859
 msgid "Query"
 msgstr "Abfragen"
-#: ../gui/tcltk/gis.m/maptool.tcl:247
 msgid "Measure"
 msgstr "Messen"
-#: ../gui/tcltk/gis.m/maptool.tcl:254
 msgid "Create profile of raster map"
 msgstr "Erzeuge Profil vom Raster"
-#: ../gui/tcltk/gis.m/maptool.tcl:271
 msgid "Print raster & vector maps to eps file"
 msgstr "Drucke Raster und Vektordateien in eine EPS-Datei"
-#: ../gui/tcltk/gis.m/maptool.tcl:278
 msgid "Export display to graphics file"
 msgstr "Exportiere Darstellung als Bilddatei"
-#: ../gui/tcltk/gis.m/maptool.tcl:289
-msgid "low quality (50)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:291
-msgid "mid quality (75)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:293
-msgid "high quality (95)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:295
-msgid "very high resolution (300% your current resolution)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:300
 #, fuzzy
 msgid "(* requires gdal)"
 msgstr "benötigt"
-#: ../gui/tcltk/gis.m/maptool.tcl:325
-msgid "Constrain map to region geometry"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:344
 msgid "Map fills display window"
 msgstr "Karte füllt Monitorfenster"
-#: ../gui/tcltk/gis.m/maptool.tcl:394
-msgid "Could not create BMP"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:401 ../gui/tcltk/gis.m/maptool.tcl:406
-msgid "Could not create JPG"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:414
-msgid "Could not create PNG"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptool.tcl:424
-msgid "Could not create TIF"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastnums.tcl:103 ../gui/tcltk/gis.m/raster.tcl:114
 msgid "Raster map"
 msgstr "Rasterkarte"
-#: ../gui/tcltk/gis.m/rastnums.tcl:106
+#, fuzzy
 msgid "cell values for %s"
 msgstr "Zell-Ebene hinzufügen"
-#: ../gui/tcltk/gis.m/rastnums.tcl:134
-msgid "Display cell values from raster map or image"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastnums.tcl:140
-msgid "  (resolution must be 100x100 or less)"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastnums.tcl:156
 #, fuzzy
 msgid "Raster to display: "
 msgstr "Text zum Darstellen: "
-#: ../gui/tcltk/gis.m/rastnums.tcl:172
-msgid "Color for cell grid:       "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastnums.tcl:177
 #, fuzzy
 msgid "  cell values font "
-#: ../gui/tcltk/gis.m/rastnums.tcl:180 ../gui/tcltk/gis.m/gridline.tcl:187
-#: ../gui/tcltk/gis.m/legend.tcl:264 ../gui/tcltk/gis.m/barscale.tcl:204
-#: ../gui/tcltk/gis.m/maptext.tcl:180 ../gui/tcltk/gis.m/dtext.tcl:226
-#: ../gui/tcltk/gis.m/histogram.tcl:177
 msgid "select font for text"
-#: ../gui/tcltk/gis.m/rastnums.tcl:187
 #, fuzzy
 msgid "Color for cell values:   "
 msgstr "Benutze Rasterfarben für Zellenwerte"
-#: ../gui/tcltk/gis.m/rastnums.tcl:192
 msgid "use raster colors for cell values"
-#: ../gui/tcltk/gis.m/rastnums.tcl:273
-msgid ""
-"Cell values can only be displayed\n"
-"for regions of < 10,000 cells"
-msgstr ""
-#: ../gui/tcltk/gis.m/frames.tcl:105
-msgid "Divide map display into frames for displaying multiple maps"
-msgstr ""
-#: ../gui/tcltk/gis.m/frames.tcl:112
 msgid "create and select frame"
 msgstr "Erzeuge und selektiere Rahmen"
-#: ../gui/tcltk/gis.m/frames.tcl:114
 msgid "select frame"
 msgstr "Selektiere Rahmen"
-#: ../gui/tcltk/gis.m/frames.tcl:116
 msgid "remove all frames   "
 msgstr "Alle Rahmen entfernen"
-#: ../gui/tcltk/gis.m/frames.tcl:128
-msgid "Frame name (optional): "
-msgstr ""
-#: ../gui/tcltk/gis.m/frames.tcl:135
-#, tcl-format
-msgid "Set frame borders at 0-100% from lower left corner of display "
-msgstr ""
-#: ../gui/tcltk/gis.m/frames.tcl:141
-msgid "     set borders (bottom,top,left,right): "
-msgstr ""
-#: ../gui/tcltk/gis.m/tksys.tcl:57
-msgid ""
-"\n"
-"***** Please wait *****"
-msgstr ""
-#: ../gui/tcltk/gis.m/tksys.tcl:58
-msgid "Gathering information about your system"
-msgstr ""
-#: ../gui/tcltk/gis.m/tksys.tcl:230
-msgid "***** Done *****"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:296
 #, fuzzy
 msgid "Select maps to animate"
 msgstr "Diagramm aus Vektorkarte"
-#: ../gui/tcltk/gis.m/animate.tcl:310
 #, fuzzy
 msgid "Rewind animation"
 msgstr "MPEG-1 Animationen"
-#: ../gui/tcltk/gis.m/animate.tcl:316
 #, fuzzy
 msgid "Replay animation"
-#: ../gui/tcltk/gis.m/animate.tcl:322
-msgid "Step backwards through animation"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:328
 #, fuzzy
 msgid "Stop animation"
-#: ../gui/tcltk/gis.m/animate.tcl:334
-msgid "Step forwards through animation"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:340
 #, fuzzy
 msgid "Play animation"
-#: ../gui/tcltk/gis.m/animate.tcl:353
 #, fuzzy
 msgid "Slower animation"
 msgstr "Fließakkumulation auf riesigen Rasterdatengrids"
-#: ../gui/tcltk/gis.m/animate.tcl:359
 #, fuzzy
 msgid "Faster animation"
-#: ../gui/tcltk/gis.m/animate.tcl:369
-msgid "Continuously loop through animation"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:377
-msgid "Run animation alternately forward and backward"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:388
-msgid "Show map names in animation window"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:401
 #, fuzzy
 msgid "Quit animation"
 msgstr " Ausrichtung"
-#: ../gui/tcltk/gis.m/animate.tcl:432
 #, fuzzy
 msgid "Select maps"
-#: ../gui/tcltk/gis.m/animate.tcl:460
 #, fuzzy
 msgid "Maps for Animation"
 msgstr "Informationen"
-#: ../gui/tcltk/gis.m/animate.tcl:476
-msgid "Select maps to animate in one or more frames (1 frame required)"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:489
-msgid "Maps for frame 1 (required): "
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:500
-msgid "Maps for frame 2 (optional): "
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:511
-msgid "Maps for frame 3 (optional): "
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:522
-msgid "Maps for frame 4 (optional): "
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:537 ../gui/tcltk/gis.m/dnviz.tcl:232
-#: ../gui/tcltk/gis.m/rules.tcl:174
-msgid "Apply"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:560
-msgid "You must select maps to animate for frame 1"
-msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:561
 #, fuzzy
 msgid "No maps selected"
-#: ../gui/tcltk/gis.m/animate.tcl:1028
-msgid "Animation Window"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmtool1.tcl:28
 msgid "Start new map display monitor"
 msgstr "Starte neuen Monitor"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:42
 msgid "Add raster layer"
 msgstr "Rasterebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:49
 msgid "Add RGB or HIS layer"
 msgstr "RGB oder HIS-Ebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:56
 msgid "Add histogram layer"
 msgstr "Histogramm hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:63
 msgid "Add cell values layer"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:70
 msgid "Add directional arrows layer"
 msgstr "Füge Ebene mit Richtungspfeilen hinzu"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:76
 msgid "Add raster legend layer"
 msgstr "Rasterlegende hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:92
 msgid "Add vector layer"
 msgstr "Vektorebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:99
 msgid "Add thematic map layer"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:108
 msgid "Add thematic charts layer"
 msgstr "Thematische Diagramm-Ebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:121
 msgid "Add raster labels layer (using v.labels file)"
 msgstr "Rasterlabel Ebene hinzufügen (mit v.labels)"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:128
 msgid "Add text layer"
 msgstr "Textebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:135
 msgid "Add postscript labels layer (using v.labels file)"
 msgstr "PS-Ebene hinzufügen (mit v.labels)"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:142
 msgid "Add postscript text layer"
 msgstr "PS-Textebene hinzufügen"
-#: ../gui/tcltk/gis.m/gmtree.tcl:69
+#, fuzzy
 msgid "Map Layers for Display %s"
 msgstr "Vektoren für die Darstellung abfragen: "
-#: ../gui/tcltk/gis.m/gmtree.tcl:308
-msgid "You must open a display before adding map layers"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmtree.tcl:483 ../gui/tcltk/gis.m/gmtree.tcl:631
-#: ../gui/tcltk/gis.m/gmtree.tcl:1150 ../gui/tcltk/gis.m/gmtree.tcl:1156
-msgid "No layer selected"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmtree.tcl:865
 #, fuzzy
 msgid "Loading layers..."
-#: ../gui/tcltk/gis.m/gmtree.tcl:1050
-msgid "Layers loaded"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmtree.tcl:1166
 #, fuzzy
 msgid "Selected raster layer is empty"
-#: ../gui/tcltk/gis.m/gmtree.tcl:1177
 #, fuzzy
 msgid "Selected vector layer is empty"
-#: ../gui/tcltk/gis.m/gmtree.tcl:1183
 #, fuzzy
 msgid "You can digitize raster or vector maps only"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:26
 msgid "Scalebar and north arrow"
 msgstr "Maßstab und Nordenpfeil"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:32
 msgid "Overlay grids and lines"
 msgstr "Überlagere Gradnetz und Linien"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:39
 msgid "Add command layer"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:59
 msgid "Add group"
 msgstr "Gruppe hinzufügen"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:65
 msgid "Duplicate Layer"
 msgstr "Ebene duplizieren"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:70
 msgid "Delete layer"
 msgstr "Lösche Ebene"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:84
 msgid "Create new workspace file (erase current workspace settings first)"
 msgstr "Erstelle neue Projektdatei (zuerst aktuelle Einstellungen löschen)"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:90
 msgid "Open existing workspace file"
 msgstr "Öffne existierendes Projekt"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:96
 msgid "Save workspace file"
 msgstr "Speichere Projekt"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:111
 msgid "Animate raster map series"
 msgstr "Animiere Rasterkartenserien"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:127
 msgid "Digitize map (select or create new map first)"
 msgstr "Digitalisiere Ebene (Selektiere die Ebene zuerst)"
-#: ../gui/tcltk/gis.m/georecttool.tcl:73
 msgid "Set ground control points"
 msgstr "Setze Ground Control Points (GCP)"
-#: ../gui/tcltk/gis.m/georecttool.tcl:151
 msgid "Zoom to map"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:85
 msgid "&File"
 msgstr "&Datei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:86
 msgid "Workspace"
 msgstr "Projekt"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:87
 msgid "Open..."
 msgstr "Öffnen..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:89
 msgid "Save as..."
 msgstr "Speichern unter..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:93
 #, fuzzy
 msgid "Import raster map"
 msgstr "Stichprobe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:94 ../gui/tcltk/gis.m/gmmenu.tcl:129
 msgid "Multiple formats using GDAL"
 msgstr "Viele Formate mit GDAL importieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:96
 #, fuzzy
 msgid "Aggregate ASCII xyz"
 msgstr "Fasse ASCII xyz-Daten in einem Raster zusammen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:97 ../gui/tcltk/gis.m/gmmenu.tcl:131
 #, fuzzy
 msgid "ASCII grid"
 msgstr "ASCII 3D Datei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:98
-msgid "ASCII polygons and lines"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:100 ../gui/tcltk/gis.m/gmmenu.tcl:138
 #, fuzzy
 msgid "Binary"
 msgstr "Binärdatei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:101
-msgid "ESRI grid"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:102 ../gui/tcltk/gis.m/gmmenu.tcl:135
-msgid "GRIDATB.FOR"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:103 ../gui/tcltk/gis.m/gmmenu.tcl:136
-msgid "MAT-File (v.4)"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:104
-msgid "SPOT NDVI"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:105
 #, fuzzy
 msgid "SRTM hgt"
 msgstr "SRTM hgt Dateien"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:106
 #, fuzzy
 msgid "Terra ASTER"
 msgstr "Terra ASTER HDF Dateien"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:108
 msgid "Web Mapping Server"
 msgstr "Web Mapping Server"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:110
 #, fuzzy
 msgid "Import vector map"
 msgstr "Raster zu Vektorkonvertierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:111 ../gui/tcltk/gis.m/gmmenu.tcl:150
 #, fuzzy
 msgid "Multiple formats using OGR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:113 ../gui/tcltk/gis.m/gmmenu.tcl:152
 #, fuzzy
 msgid "ASCII points or GRASS ASCII vector"
 msgstr "ASCII Punktdatei oder GRASS ASCII Vektordatei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:114
 #, fuzzy
 msgid "Old GRASS vector"
 msgstr "Alte GRASS-Vektordatei importieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:116 ../gui/tcltk/gis.m/gmmenu.tcl:153
-msgid "DXF"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:117
 #, fuzzy
 msgid "ESRI e00"
 msgstr "ESRI e00-Format"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:118
-msgid "Garmin GPS"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:119
-msgid "GPSBabel GPS"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:120
-msgid "GEOnet"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:121
 #, fuzzy
 msgid "Matlab and MapGen"
 msgstr "Matlab und MapGen Dateien"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:123
 #, fuzzy
 msgid "Import grid 3D volume"
 msgstr "Verwalte Zeitstempel für grid3D-Volumen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:124 ../gui/tcltk/gis.m/gmmenu.tcl:159
 #, fuzzy
 msgid "ASCII 3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:125 ../gui/tcltk/gis.m/gmmenu.tcl:160
 #, fuzzy
 msgid "Vis5D"
 msgstr "Vis5D Datei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:128
 #, fuzzy
 msgid "Export raster map"
 msgstr "Stichprobe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:132
-msgid "ASCII x,y,z"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:134
 #, fuzzy
 msgid "ESRI ASCII grid"
 msgstr "ESRI Arc/Info ASCII GRID"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:140
-msgid "MPEG-1"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:141
-msgid "PNG"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:142
-msgid "PPM"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:143
-msgid "PPM from RGB"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:144 ../gui/tcltk/gis.m/gmmenu.tcl:154
 #, fuzzy
 msgid "POV-Ray"
 msgstr "POV-Ray Format"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:145
-msgid "TIFF"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:146
 #, fuzzy
 msgid "VRML"
 msgstr "VRML Datei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:147 ../gui/tcltk/gis.m/gmmenu.tcl:156
-#: ../gui/tcltk/gis.m/gmmenu.tcl:161
-msgid "VTK"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:149
 #, fuzzy
 msgid "Export vector map"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:155
-msgid "SVG"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:158
 #, fuzzy
 msgid "Export grid 3D volume"
 msgstr "Organisiere NULLs für grid3D-Volumen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:164
 msgid "Manage maps and volumes"
 msgstr "Organisiere Karten und Volumen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:165 ../lib/gis/gui.tcl:464
 #, fuzzy
-msgid "Copy"
-msgstr "Kopiere Karten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:167
-#, fuzzy
 msgid "List"
 msgstr "Karten auflisten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:168
 #, fuzzy
 msgid "List filtered"
 msgstr "Treiber auflisten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:170
 #, fuzzy
 msgid "Rename"
 msgstr "Nenne Karten um"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:172 ../vector/v.digit/cats.tcl:20
-msgid "Delete"
-msgstr "Löschen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:173
 #, fuzzy
 msgid "Delete filtered"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:175
 msgid "Map type conversions"
 msgstr "Kartentyp-Konvertierungen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:176
 #, fuzzy
 msgid "Raster to vector"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:177
 #, fuzzy
 msgid "Raster series to volume"
 msgstr "Rasterkartenserie zu Volumina"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:178
 #, fuzzy
 msgid "Raster 2.5D to volume"
 msgstr "2.5D Rasterkarte zu Volumina"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:180
 msgid "Vector to raster"
 msgstr "Vektor -> Raster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:181
 #, fuzzy
 msgid "Vector to volume"
 msgstr "Vektor -> Vektor"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:182
 #, fuzzy
 msgid "Sites to vector"
 msgstr "Sites (GRASS 5.0) -> Vektor"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:184
 #, fuzzy
 msgid "Volume to raster series"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:187
 msgid "Georectify"
 msgstr "Georeferenzieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:189
 #, fuzzy
 msgid "Animate raster maps"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:191
 #, fuzzy
 msgid "Bearing/distance to coordinates"
 msgstr "Geographische Koordinaten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:193
-msgid "3D rendering"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:194
-msgid "NVIZ"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:195
 #, fuzzy
 msgid "NVIZ fly through path"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:197
-msgid "PostScript plot"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:199
 msgid "E&xit"
 msgstr "B&eenden"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:201
 msgid "&Config"
 msgstr "&Konfiguration"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:202
 msgid "Region"
 msgstr "Region"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:203
 msgid "Display region settings"
 msgstr "Stelle Regions-Einstellungen dar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:204
 msgid "Change region settings"
 msgstr "Region-Einstellungen ändern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:206
 msgid "GRASS working environment"
 msgstr "GRASS Arbeitsumgebung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:207
-msgid "Mapset access"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:208
 #, fuzzy
 msgid "Change working environment"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:209
-msgid "User access"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:210
 #, fuzzy
 msgid "Show settings"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:211
 #, fuzzy
 msgid "Change settings"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:212
 msgid "Show current GRASS version"
 msgstr "Aktuelle GRASS-Version anzeigen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:214 ../gui/tcltk/gis.m/gmmenu.tcl:215
 msgid "Manage projections"
 msgstr "Projektionen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:216
 #, fuzzy
 msgid "Projection for current location"
 msgstr "Projektionsinformationen der aktuellen Location editieren/erzeugen."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:218
 #, fuzzy
 msgid "Convert coordinates"
 msgstr "xy Koordinaten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:220
 #, fuzzy
 msgid "Display font"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:222
 msgid "&Raster"
 msgstr "&Raster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:223 ../gui/tcltk/gis.m/gmmenu.tcl:419
 msgid "Develop map"
 msgstr "Bearbeite Karte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:224
 msgid "Digitize raster"
 msgstr "Rasterdigitalisierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:230
 #, fuzzy
 msgid "Compress/decompress"
 msgstr "Raster komprimieren/dekomprimieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:232
 #, fuzzy
 msgid "Boundaries"
 msgstr "Umrandung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:233
 #, fuzzy
 msgid "Null values"
 msgstr "NULL-Werte bearbeiten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:234
 #, fuzzy
 msgid "Quantization"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:235
 #, fuzzy
 msgid "Timestamps"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:237
-msgid "Resample using aggregate statistics"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:238
 #, fuzzy
 msgid "Resample using multiple methods"
 msgstr "Resamplen mit weiteren Interpolationsmethoden"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:239
 #, fuzzy
 msgid "Resample using nearest neighbor"
 msgstr "Resamplen mit der Nearest-Neighbor-Method"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:240
 #, fuzzy
 msgid "Resample using spline tension"
 msgstr "Resamplen mit der RST-Methode"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:242
 #, fuzzy
 msgid "Support file maintenance"
 msgstr "DateiUnterstützungb"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:243
 #, fuzzy
 msgid "Update map statistics"
 msgstr "Univariate Statistik"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:245
-msgid "Reproject"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:246
-msgid "Tiling"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:248
 msgid "Manage map colors"
 msgstr "Kartenfarben organisieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:249
 #, fuzzy
 msgid "Color tables"
 msgstr "Tabelle kopieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:250
 #, fuzzy
 msgid "Color rules"
 msgstr "Hilfe zur Loxodrome"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:252
-msgid "Blend"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:253
 #, fuzzy
 msgid "Create RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:254 ../gui/tcltk/gis.m/gmmenu.tcl:538
 #, fuzzy
 msgid "HIS to RGB"
 msgstr "Hilfe für RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:257
 msgid "Query by coordinate(s)"
 msgstr "Abfragen unter Koordinaten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:259
-msgid "Buffers"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:260
 #, fuzzy
 msgid "Closest points"
 msgstr "Erzeuge Punkte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:261
-msgid "MASK"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:262
 msgid "Map calculator"
 msgstr "Kartenrechner"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:263
 msgid "Neighborhood analysis"
 msgstr "Nachbarschaftsanalysen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:264
 #, fuzzy
 msgid "Moving window"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:265
 #, fuzzy
 msgid "Neighborhood points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:267 ../gui/tcltk/gis.m/gmmenu.tcl:482
 msgid "Overlay maps"
 msgstr "Karten überlagern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:268
 msgid "Cross product"
 msgstr "Kreuzprodukt"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:269
 #, fuzzy
 msgid "Map series"
 msgstr "Kategorien"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:270
 msgid "Patch maps"
 msgstr "Karten zusammenkleben"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:272
-msgid "Statistical overlay"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:274
-msgid "Solar radiance and shadows"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:275
 #, fuzzy
 msgid "Solar irradiance irradiation"
 msgstr "Kovarianz/Korrelation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:276
 #, fuzzy
 msgid "Shadows map"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:278
 msgid "Terrain analysis"
 msgstr "Oberflächenanalysen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:279
 #, fuzzy
 msgid "Cumulative movement costs"
 msgstr "zwischen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:280
 msgid "Cost surface"
 msgstr "Kostenoberfläche"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:281
 msgid "Least cost route or flow"
 msgstr "Kürzester Abflussweg oder Oberflächenfluss"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:283
 #, fuzzy
 msgid "Shaded relief"
 msgstr "Reliefschattierungen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:285
 msgid "Slope and aspect"
 msgstr "Hangneigung und -ausrichtung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:286
 msgid "Terrain parameters"
 msgstr "Reliefparameter"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:287
 msgid "Textural features"
 msgstr "Texturelle Objekte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:289
-msgid "Visibility"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:291
 msgid "Transform features"
 msgstr "Umformungsfunktionen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:292
-msgid "Clump"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:293
 #, fuzzy
 msgid "Grow"
 msgstr "Blättern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:294
-msgid "Thin"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:297
 msgid "Hydrologic modeling"
 msgstr "Hydrologische Modellierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:298
-msgid "Carve stream channels"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:299
 #, fuzzy
 msgid "Fill lake"
 msgstr "Fülle Flächen:"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:301
 #, fuzzy
 msgid "Depressionless map and flowlines"
 msgstr "Senkenloses Höhenmodeel mit Abflusslinienkarte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:302
 #, fuzzy
 msgid "Flow accumulation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:303
 #, fuzzy
 msgid "Flow lines"
 msgstr "Zeilen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:305 ../gui/tcltk/gis.m/gmmenu.tcl:592
-msgid "Groundwater flow model"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:307
 msgid "SIMWE overland flow modeling"
 msgstr "SIMWE Überschwemmungs-Modelierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:308
 #, fuzzy
 msgid "SIMWE sediment flux modeling"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:310
 msgid "Topographic index map"
 msgstr "Topographischen Index erstellen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:311
 msgid "TOPMODEL simulation"
 msgstr "TOPMODEL Simulation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:313
 msgid "Watershed subbasins"
 msgstr "Einzugsgebietsflächen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:314
 msgid "Watershed analysis"
 msgstr "Einzugsgebietsanalysen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:315
 msgid "Watershed basin creation"
 msgstr "Wassereinzugsgebietsberechnung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:317
 msgid "Landscape structure modeling"
 msgstr "Landschaftsstrukturmodellierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:318
-msgid "Set up"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:324
 #, fuzzy
 msgid "Analyze landscape"
 msgstr "Landschaftliche Charakteristiken analysieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:325
-msgid "Analyze patches"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:326 ../lib/gis/gui.tcl:295
-#: ../lib/gis/gui.tcl:480
-msgid "Output"
-msgstr "Ergebnis"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:328
 #, fuzzy
 msgid "Landscape patch analysis"
 msgstr "Querformat"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:329
 #, fuzzy
 msgid "Set up sampling and analysis framework"
 msgstr "Setzen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:331
-msgid "Edge density"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:332
-msgid "Contrast weighted edge density"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:334
 #, fuzzy
 msgid "Patch size mean"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:335
-msgid "Patch area range"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:336
-msgid "Patch area Std Dev"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:337
-msgid "Patch area Coeff Var"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:338
 #, fuzzy
 msgid "Patch density"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:339
 #, fuzzy
 msgid "Patch number"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:341
-msgid "Dominance's diversity"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:342
-msgid "Shannon's diversity"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:343
-msgid "Simpson's diversity"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:345
 #, fuzzy
 msgid "Ricness"
 msgstr "Zeilen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:346
 #, fuzzy
 msgid "Shape index"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:348
 msgid "Wildfire modeling"
 msgstr "Buschfeuermodellierung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:349
 #, fuzzy
 msgid "Rate of spread"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:350
 #, fuzzy
 msgid "Least-cost spread paths"
 msgstr "Erzeuge einen 'Geringsten-Kosten-Ausbreitungspfad'"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:351
 #, fuzzy
 msgid "Anisotropic spread simulation"
 msgstr "Simulieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:354
 msgid "Change category values and labels"
 msgstr "Kategoriewerte und Label ändern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:355
 #, fuzzy
 msgid "Interactively edit category values"
 msgstr "Bereich der Kategoriewerte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:357
 #, fuzzy
 msgid "Reclassify by size"
 msgstr "Bild klassifizieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:358
 #, fuzzy
 msgid "Reclassify interactively"
 msgstr "Reklassifizieren der Kategorien mit Regelen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:359 ../gui/tcltk/gis.m/gmmenu.tcl:490
 #, fuzzy
 msgid "Reclassify using rules file"
 msgstr "Reklassifizierung der Objekte mit einer Regeldatei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:361
-msgid "Recode interactively"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:362
 #, fuzzy
 msgid "Recode using rules file"
 msgstr "Reklassifizieren der Kategorien mit einer Regel-Datei"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:364
-msgid "Rescale"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:365
 #, fuzzy
 msgid "Rescale with histogram"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:368
-msgid "Concentric circles"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:369
 msgid "Generate random cells"
 msgstr "Erzeugt zufällige Zellen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:370
 #, fuzzy
 msgid "Random cells"
 msgstr "Zufällige Farben"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:371
 #, fuzzy
 msgid "Random cells and vector points"
 msgstr "Zufällige Zellen und Vektorpunkte aus einer Rasterkarte erzeugen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:373
 msgid "Generate surfaces"
 msgstr "Erzeuge Oberflächen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:374
 #, fuzzy
 msgid "Fractal surface"
 msgstr "Erzeuge fraktale Oberfläche"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:376
-msgid "Gausian kernal density surface"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:377
 #, fuzzy
 msgid "Gaussian deviates surface"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:379
 #, fuzzy
 msgid "Plane"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:381
 #, fuzzy
 msgid "Random deviates surface"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:382
 #, fuzzy
 msgid "Random surface with spatial dependence"
 msgstr "Erzeuge zufällige Oberfläche mit räumlicher Abhängigkeit"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:384
 #, fuzzy
 msgid "Contour lines"
 msgstr "Kategorien"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:385
 msgid "Interpolate surfaces"
 msgstr "Interpoliere Oberflächen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:386
 #, fuzzy
 msgid "Bilinear from raster points"
 msgstr "Rasterpunkte mit der bilinearen Interpolation errechnen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:387
 #, fuzzy
 msgid "Bilinear and bicubic from vector points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:389
 #, fuzzy
 msgid "IDW from raster points"
 msgstr "Interpolation von Rasterkonturen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:390
 #, fuzzy
 msgid "IDW from vector points"
 msgstr "Mit Vektorpunkten arbeiten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:392
 #, fuzzy
 msgid "Raster contours"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:393
 #, fuzzy
 msgid "Regularized spline tension"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:395
-msgid "Fill NULL cells"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:398 ../gui/tcltk/gis.m/gmmenu.tcl:517
-#: ../gui/tcltk/gis.m/gmmenu.tcl:578
 msgid "Reports and statistics"
 msgstr "Reports und Statistiken"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:399
 msgid "Report basic file information"
 msgstr "Grundlegende Dateiinformationen anzeigen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:400
 #, fuzzy
 msgid "Manage category information"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:402
 msgid "General statistics"
 msgstr "Allgemeine Statistiken"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:403
 #, fuzzy
 msgid "Range of category values"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:404
 #, fuzzy
 msgid "Sum cell category values"
 msgstr "Alle Kategorien zusammenfassen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:405
 msgid "Sum area by map and category"
 msgstr "Flächen je Karte und Kategorie summieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:406
 #, fuzzy
 msgid "Statistics for clumped cells (works with r.clump)"
 msgstr "Statistik der geklumpten Zellen ausgeben (funktioniert mit r.clump)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:407
 #, fuzzy
 msgid "Total surface area corrected for topography"
 msgstr "Bereich für"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:408
 msgid "Univariate statistics"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:410
 #, fuzzy
 msgid "Sample transects"
 msgstr "Stichprobenwerte entlang eines Transekts"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:411
 #, fuzzy
 msgid "Sample transects (bearing/distance)"
 msgstr "Stichprobenwerte entlang eines Transekts (mit Azimuth, Distanz)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:413
 msgid "Covariance/correlation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:414
 #, fuzzy
 msgid "Linear regression"
 msgstr "Lineare Regression zwischen zwei Karten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:415
-msgid "Mutual category occurences"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:418
 msgid "&Vector"
 msgstr "&Vektor"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:420
 msgid "Digitize"
 msgstr "Digitalisieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:421
 #, fuzzy
 msgid "Edit features"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:423
 #, fuzzy
 msgid "Create/rebuild topology: "
 msgstr "Erstelle oder baue Topologie neu"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:424
 #, fuzzy
 msgid "Clean vector"
 msgstr "Vektordatei säubern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:425
 #, fuzzy
 msgid "Generalization"
 msgstr "Ebene erzeugen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:427
 #, fuzzy
 msgid "Convert object types"
 msgstr "Vektortypen konvertieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:429
 #, fuzzy
 msgid "Add centroids"
 msgstr "Zentroide"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:431
-msgid "Build polylines"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:432
 #, fuzzy
 msgid "Split polylines"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:433
 #, fuzzy
 msgid "Parallel lines"
 msgstr "Zeichne Linien:"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:435
 #, fuzzy
 msgid "Dissolve boundaries"
 msgstr "Angrenzende Umrandungen zusammenfassen (Dissolve)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:437
 #, fuzzy
 msgid "Create 3D vector over raster"
 msgstr "Vektorpuffer erstellen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:438
 #, fuzzy
 msgid "Extrude 3D vector"
 msgstr "Erzeuge 3D-Vektoren aus 2D-Vektoren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:440
-msgid "Link to OGR"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:442
 #, fuzzy
 msgid "Create labels"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:444
 #, fuzzy
 msgid "Reposition vector"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:445
 #, fuzzy
 msgid "Reproject vector"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:447
-msgid "Metadata support"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:451
 #, fuzzy
 msgid "Query with attributes"
 msgstr "Nach Attributen abfragen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:452
 #, fuzzy
 msgid "Query with coordinate(s)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:453
-msgid "Query with another map"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:455
 #, fuzzy
 msgid "Buffer vectors"
 msgstr "Vektor abfragen:"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:456
 #, fuzzy
 msgid "Lidar analysis"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:457
-msgid "Detect edges"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:458
-msgid "Detect interiors"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:459
-msgid "Correct and reclassify objects"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:461
 #, fuzzy
 msgid "Linear referencing"
 msgstr "Lineare Referenzierung für Vektoren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:462
 #, fuzzy
 msgid "Create LRS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:463
 #, fuzzy
 msgid "Create stationing"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:464
 #, fuzzy
 msgid "Create points/segments"
 msgstr "Neues Mapset erstellen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:465
-msgid "Find ID and offset"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:467
 #, fuzzy
 msgid "Nearest features"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:468
 msgid "Network analysis"
 msgstr "Netzwerkanalysen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:469
 msgid "Allocate subnets"
 msgstr "Subnetze ausweisen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:470
 msgid "Network maintenance"
 msgstr "Netzwerkbearbeitung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:471
 #, fuzzy
 msgid "Visibility network"
 msgstr "Sichtbarkeitsanalyse"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:472
 msgid "Shortest route"
 msgstr "Kürzester Wege"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:473
 #, fuzzy
 msgid "Display shortest route"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:478
 #, fuzzy
 msgid "Split net"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:479
 msgid "Steiner tree"
 msgstr "Steiner-Problematik"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:480
 msgid "Traveling salesman analysis"
 msgstr "Traveling-Salesman-Problematik"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:483
 #, fuzzy
 msgid "Overlay"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:484
 #, fuzzy
 msgid "Patch (combine)"
 msgstr "Viele Karten kombinieren (patchen)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:487
 msgid "Change attributes"
 msgstr "Attribute verändern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:488
 #, fuzzy
 msgid "Manage or report categories"
 msgstr "Kategorien hinzufügen, löschen oder berichten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:489
 #, fuzzy
 msgid "Reclassify objects interactively"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:493
 #, fuzzy
 msgid "Generate area for current region"
 msgstr "Bereich feature für von"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:494
 msgid "Generate areas from points"
 msgstr "Flächen aus Punkten erzeugen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:495
-msgid "Convex hull"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:496
 #, fuzzy
 msgid "Delaunay triangles"
 msgstr "Delaunay-Dreiecke aus Punktwolke erzeugen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:497
 #, fuzzy
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr "Voronoi Diagram/Thiessen Polygone aus Punktwolke erzeugen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:499
 #, fuzzy
 msgid "Generate grid"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:500
 msgid "Generate points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:501
 #, fuzzy
 msgid "Generate points from database"
 msgstr "Erzeuge Punkte aus einer Datenbank mit x/y-Koordinaten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:502
 #, fuzzy
 msgid "Generate points along lines"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:503
 msgid "Generate random points"
 msgstr "Erzeuge zufällige Punkte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:504
 #, fuzzy
 msgid "Perturb points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:507
 #, fuzzy
 msgid "Remove outliers in point sets"
 msgstr "Interpoliere Volumen aus Punkten mit Hilfe von Splines"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:508
-msgid "Test/training sets"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:510
 #, fuzzy
 msgid "Update area attributes from raster"
 msgstr "Editiere Attribute (im Formmodus)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:511
 #, fuzzy
 msgid "Update point attributes from areas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:512
 #, fuzzy
 msgid "Update point attributes from raster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:513
 #, fuzzy
 msgid "Sample raster map at point locations"
 msgstr "an Punkt"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:514
 #, fuzzy
 msgid "Sample raster neighborhood around points"
 msgstr "Stichprobe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:518 ../gui/tcltk/gis.m/gmmenu.tcl:595
 msgid "Basic information"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:520
-msgid "Report topology by category"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:521
-msgid "Upload or report topology"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:523
 #, fuzzy
 msgid "Univariate attribute statistics"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:525
-msgid "Quadrat indices"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:526
-msgid "Test normality"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:529
 msgid "&Imagery"
 msgstr "&Bildbearbeitung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:530
 #, fuzzy
 msgid "Develop images and groups"
 msgstr "Bilder"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:531
 #, fuzzy
 msgid "Create/edit group"
 msgstr "2. Erzeuge/bearbeite Gruppe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:532
 #, fuzzy
 msgid "Target group"
 msgstr "Zielbildgruppe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:534
 #, fuzzy
 msgid "Mosaic images"
 msgstr "Bis zu 4 zusammenpassende Bilder mosaikieren"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:536
 msgid "Manage image colors"
 msgstr "Verwalte Bildfarben"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:537
-msgid "Color balance for RGB"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:539
 #, fuzzy
 msgid "RGB to HIS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:541
 msgid "Ortho photo rectification"
 msgstr "Orthophoto-Entzerrung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:547
-msgid "Basic RS processing"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:548
-msgid "MODIS Quality flags"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:550
-msgid "Albedo"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:552
-msgid "Vegetation Indices"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:554
-msgid "Brovey sharpening"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:555
 msgid "Classify image"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:556
 #, fuzzy
 msgid "Clustering input for unsupervised classification"
 msgstr "für"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:558
 msgid "Maximum likelyhood classification (MLC)"
 msgstr "Maximum likelyhood Klassifikation (MLC)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:559
 msgid "Sequential maximum a posteriory classification (SMAP)"
 msgstr "Sequential maximum a posteriory Klassifikation (SMAP)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:561
 msgid "Interactive input for supervised classification"
 msgstr "Interaktive Eingabe für die überwachte Klassifikation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:562
-msgid "Input for supervised MLC"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:563
-msgid "Input for supervised SMAP"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:565
 msgid "Filter image"
 msgstr "Bild filtern"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:566
 #, fuzzy
 msgid "Edge detection"
 msgstr "Linierichtung"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:567
 #, fuzzy
 msgid "Matrix/convolving filter"
 msgstr "Benutzerdefinierter Matrix/Convolv-Filter"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:569
 msgid "Spectral response"
 msgstr "Spektrale Antwort"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:570
 #, fuzzy
 msgid "Tassled cap vegetation index"
 msgstr "index"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:571
 msgid "Transform image"
 msgstr "Bild umformen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:572
 #, fuzzy
 msgid "Canonical correlation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:573
 #, fuzzy
 msgid "Principal components"
 msgstr "Hauptkomponente"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:574
 #, fuzzy
 msgid "Fast Fourier"
 msgstr "Fast Fourier Transformation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:575
 #, fuzzy
 msgid "Inverse Fast Fourier"
 msgstr "Inverse Fast Fourier Transformtion"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:579
 #, fuzzy
 msgid "Bit pattern comparison"
 msgstr "für von"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:580
 #, fuzzy
 msgid "Kappa analysis"
 msgstr "Querformat"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:581
 #, fuzzy
 msgid "OIF for LandSat TM"
 msgstr "Optimaler Indexfaktor für LandSat TM"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:584
 #, fuzzy
 msgid "&Volumes"
 msgstr "Spalten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:585
-msgid "Develop grid3D volumes"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:586
 msgid "Manage nulls for grid3D volume"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:587
 msgid "Manage timestamp for grid3D volume"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:589
-msgid "3D MASK"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:590
 #, fuzzy
 msgid "3D Map calculator"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:591
 #, fuzzy
 msgid "Cross section from volume"
 msgstr "für Lautstärke"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:593
 #, fuzzy
 msgid "Interpolate volume from vector points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:594
 msgid "Report and Statistics"
 msgstr "Report und Statistiken"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:598
 msgid "&Databases"
 msgstr "&Datenbanken"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:599
 msgid "Database information"
 msgstr "Datenbankinformation"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:600
 msgid "Describe table"
 msgstr "Tabelle beschreiben"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:601
 msgid "List columns"
 msgstr "Spalten auflisten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:602
 msgid "List drivers"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:603
 msgid "List tables"
 msgstr "Tabellen auflisten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:606
 msgid "Manage database"
 msgstr "Datenbanken verwalten"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:607
 msgid "Connect to database"
 msgstr "Zu Datenbank verbinden"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:608
 msgid "Login to database"
 msgstr "In Datenbank einloggen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:610
 msgid "Copy table"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:611
 #, fuzzy
 msgid "New table"
 msgstr "Erzeuge Tabelle"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:612
 #, fuzzy
 msgid "Remove table"
 msgstr "Entferne Vertex"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:614
 #, fuzzy
 msgid "Add columns"
 msgstr "Neue Spalte hinzufügen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:615
 #, fuzzy
 msgid "Change values"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:616
 #, fuzzy
 msgid "Drop column"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:617
 #, fuzzy
 msgid "Rename a column"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:619
 msgid "Test database"
 msgstr "Datenbank testen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:623
 #, fuzzy
 msgid "Query any table"
 msgstr "Daten abfragen (SQL Select)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:624
 #, fuzzy
 msgid "Query vector attribute table"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:625
 #, fuzzy
 msgid "SQL statement"
 msgstr "SQL-Statement ausführen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:627
 msgid "Vector<->database connections"
 msgstr "Vektor <-> Datenbankverbindungen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:628
 #, fuzzy
 msgid "Reconnect vector to database"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:629
 #, fuzzy
 msgid "Set vector - database connection"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:632
 msgid "&Help"
 msgstr "&Hilfe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:633
 msgid "GRASS help"
 msgstr "GRASS Hilfe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:634
 msgid "GIS Manager &help"
 msgstr "GIS Manager &Hilfe"
 msgid "GIS Manager help"
 msgstr "GIS Manager Hilfe"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:635
 msgid "About &GRASS"
 msgstr "Über &GRASS"
 msgid "About GRASS"
 msgstr "Über GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:636
 msgid "About &System"
 msgstr "Über das &System"
 msgid "About System"
 msgstr "Über das System"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:644
 msgid "&Xtns"
 msgstr "&Xtns"
-#: ../gui/tcltk/gis.m/mapprint.tcl:109
 #, fuzzy
 msgid "Ghostscript not available"
-#: ../gui/tcltk/gis.m/mapprint.tcl:250
 msgid "Postscript and LPR printing of map display"
 msgstr "Postscript und LPR-Druck der Kartendarstellung"
-#: ../gui/tcltk/gis.m/mapprint.tcl:264
 msgid "Preset paper type"
 msgstr "Papiertyp festlegen"
-#: ../gui/tcltk/gis.m/mapprint.tcl:275
 msgid "Custom paper size"
 msgstr "Angepasste Papiergröße"
-#: ../gui/tcltk/gis.m/mapprint.tcl:276
 msgid "width:"
 msgstr "Breite:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:278
 msgid "  height:"
 msgstr "  Höhe:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:285
 msgid "Margins  left:"
 msgstr "Ränder Links:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:287
 msgid " right:"
 msgstr "Rechts:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:289
 msgid " top:"
 msgstr "oben:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:291
 msgid " bottom:"
 msgstr "unten:"
-#: ../gui/tcltk/gis.m/mapprint.tcl:299
 msgid "Resolution (dpi) for printing and PDF "
 msgstr "Auflösung (DPI) für Druck ins PDF"
-#: ../gui/tcltk/gis.m/mapprint.tcl:317
 #, fuzzy
 msgid "Print on LPR printer"
 msgstr "An LPR-Drucker schicken*"
-#: ../gui/tcltk/gis.m/mapprint.tcl:325
 #, fuzzy
 msgid "Print on postscript device* "
 msgstr "An PostScript-Device schicken* "
-#: ../gui/tcltk/gis.m/mapprint.tcl:336
 msgid "Save to PDF file*              "
 msgstr "Speichere als PDF-Datei*"
-#: ../gui/tcltk/gis.m/mapprint.tcl:339 ../gui/tcltk/gis.m/mapprint.tcl:351
 msgid "Browse"
 msgstr "Blättern"
-#: ../gui/tcltk/gis.m/mapprint.tcl:349
 msgid "Save to EPS file               "
 msgstr "Speichere als EPS-Datei"
-#: ../gui/tcltk/gis.m/mapprint.tcl:357
 msgid "*requires ghostscript to be installed and in path"
 msgstr "*benötigt ghostscript im Pfad"
-#: ../gui/tcltk/gis.m/mapprint.tcl:365
 msgid "Print"
 msgstr "Drucke"
-#: ../gui/tcltk/gis.m/gmlib.tcl:85 ../gui/tcltk/gis.m/gmlib.tcl:114
-msgid "Map Resource File"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:86 ../gui/tcltk/gis.m/gmlib.tcl:116
-msgid "All Files"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:90
 #, fuzzy
 msgid "Open File"
 msgstr "Öffne Gruppe"
-#: ../gui/tcltk/gis.m/gmlib.tcl:115
-msgid "DM Resource File"
-msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:119 ../lib/gis/gui.tcl:229
 #, fuzzy
-msgid "Save File"
-msgstr "Speichere Gruppe"
-#: ../gui/tcltk/gis.m/dnviz.tcl:49 ../gui/tcltk/gis.m/rules.tcl:35
-#, fuzzy
 msgid "Select input map"
 msgstr "4. Wähle zu referenzierende Karte"
-#: ../gui/tcltk/gis.m/dnviz.tcl:106
 #, fuzzy
 msgid "NVIZ flythrough path"
-#: ../gui/tcltk/gis.m/dnviz.tcl:122
 #, fuzzy
 msgid "Create flythough path for NVIZ display"
-#: ../gui/tcltk/gis.m/dnviz.tcl:129
 #, fuzzy
 msgid "Raster surface map "
-#: ../gui/tcltk/gis.m/dnviz.tcl:140
 #, fuzzy
 msgid "Output script file "
 msgstr "Scriptdatei:"
-#: ../gui/tcltk/gis.m/dnviz.tcl:151
 #, fuzzy
 msgid "Flythrough path "
-#: ../gui/tcltk/gis.m/dnviz.tcl:157
 #, fuzzy
 msgid "Create path with mouse in map display"
-#: ../gui/tcltk/gis.m/dnviz.tcl:160
-msgid "Coordinate pairs for flythrough path (x1,y1,x2,y2,...)"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:169
 #, fuzzy
 msgid "Flythrough images prefix "
-#: ../gui/tcltk/gis.m/dnviz.tcl:170
-msgid "Prefix for image series created by flythough"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:177
-msgid "Camera layback "
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:178
-msgid "Camera layback distance (in map units)"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:180
 #, fuzzy
 msgid "Camera height "
 msgstr "  Höhe:"
-#: ../gui/tcltk/gis.m/dnviz.tcl:181
-msgid "Camera height above terrain"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:188
-msgid "Number of frames "
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:189
-msgid "Number of frames to create for flythrough"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:191
-msgid "Start frame "
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:192
-msgid "Starting frame number..."
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:199
-msgid "Enable vector rendering"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:201
-msgid "Full render (save images)"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:203
-msgid "Render images offscreen"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:215
-msgid "Height value is elevation"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:217
-msgid "Output keyframe file"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:219 ../gui/tcltk/gis.m/rules.tcl:147
 #, fuzzy
 msgid "Overwrite existing file"
 msgstr "Existierende überschreiben"
-#: ../gui/tcltk/gis.m/dnviz.tcl:224
 #, fuzzy
 msgid "Reset"
 msgstr "Testen"
-#: ../gui/tcltk/gis.m/dnviz.tcl:226
 #, fuzzy
 msgid "Clear all path coordinates"
-#: ../gui/tcltk/gis.m/dnviz.tcl:359 ../gui/tcltk/gis.m/rules.tcl:194
-msgid "You must select an input map"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:360 ../gui/tcltk/gis.m/rules.tcl:194
 #, fuzzy
 msgid "No input map selected"
-#: ../gui/tcltk/gis.m/dnviz.tcl:365
-msgid "You must specify an output file"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:366
 #, fuzzy
 msgid "No output file specified"
-#: ../gui/tcltk/gis.m/dnviz.tcl:374
-msgid "You must specify at least 4 points (x,y coordinate pairs)"
-msgstr ""
-#: ../gui/tcltk/gis.m/dnviz.tcl:375
-msgid "Insufficient coordinates specified"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:140
-msgid "Display grid lines, and geodesic lines or rhumblines"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:157
 #, fuzzy
 msgid "Grid options: "
 msgstr "Textoptionen: Farbe"
-#: ../gui/tcltk/gis.m/gridline.tcl:158
 msgid "draw grid"
 msgstr "Zeichne Raster"
-#: ../gui/tcltk/gis.m/gridline.tcl:159
 msgid "geodetic grid  "
 msgstr "Geodätisches Gradnetz"
-#: ../gui/tcltk/gis.m/gridline.tcl:161
 #, fuzzy
 msgid "grid color "
-#: ../gui/tcltk/gis.m/gridline.tcl:166
 msgid "Help for grids"
 msgstr "Hilfe für Grids"
-#: ../gui/tcltk/gis.m/gridline.tcl:172
-msgid "    grid size (map units)"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:174
-msgid " grid origin (east, north)"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:182
 #, fuzzy
 msgid "draw border text "
 msgstr "Zeichne Randfarbe  "
-#: ../gui/tcltk/gis.m/gridline.tcl:184
 #, fuzzy
 msgid "text color "
 msgstr "Textfarbe"
-#: ../gui/tcltk/gis.m/gridline.tcl:189
 #, fuzzy
 msgid "text font "
 msgstr "Schrift für Text"
-#: ../gui/tcltk/gis.m/gridline.tcl:190
 #, fuzzy
 msgid "  text size"
 msgstr " Textgröße"
-#: ../gui/tcltk/gis.m/gridline.tcl:192
 #, fuzzy
 msgid "Grid text size in points"
 msgstr "Neuen Punkt digitalisieren"
-#: ../gui/tcltk/gis.m/gridline.tcl:199
 #, fuzzy
 msgid "draw grid border "
 msgstr "Zeichne Gitterrahmen"
-#: ../gui/tcltk/gis.m/gridline.tcl:201
 #, fuzzy
 msgid "border color "
 msgstr " Rahmenfarbe"
-#: ../gui/tcltk/gis.m/gridline.tcl:206
-msgid "Geodesic and rhumblines for latlong locations only"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:213
 msgid "draw geodesic line"
 msgstr "Zeichne geodätische Linie"
-#: ../gui/tcltk/gis.m/gridline.tcl:218
 msgid "Help for geodesic lines"
 msgstr "Hilfe für geodätische Linien"
-#: ../gui/tcltk/gis.m/gridline.tcl:219 ../gui/tcltk/gis.m/gridline.tcl:246
 #, fuzzy
 msgid " line color"
 msgstr "Linienfarbe"
-#: ../gui/tcltk/gis.m/gridline.tcl:223
 #, fuzzy
 msgid " text color"
 msgstr "Textfarbe"
-#: ../gui/tcltk/gis.m/gridline.tcl:232 ../gui/tcltk/gis.m/gridline.tcl:255
-msgid "     line endpoints (x1,y1,x2,y2)"
-msgstr ""
-#: ../gui/tcltk/gis.m/gridline.tcl:240
 msgid "draw rhumbline"
 msgstr "Zeichne Loxodrome"
-#: ../gui/tcltk/gis.m/gridline.tcl:245
 msgid "Help for rhumblines"
-#: ../gui/tcltk/gis.m/legend.tcl:149
 #, fuzzy
 msgid "Raster map for legend"
 msgstr "Rasterkarte für die Legende:"
-#: ../gui/tcltk/gis.m/legend.tcl:152
-#, tcl-format
-msgid "legend for %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:193
-msgid "Display legend for raster map using cat values and labels"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:210
 #, fuzzy
 msgid "Raster map: "
-#: ../gui/tcltk/gis.m/legend.tcl:229
-#, tcl-format
-msgid "Legend placement and size as 0-100% of display"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:235
-#, tcl-format
-msgid "    x,y of lower left corner (in % from display top left)"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:238 ../gui/tcltk/gis.m/barscale.tcl:191
-#: ../gui/tcltk/gis.m/maptext.tcl:150 ../gui/tcltk/gis.m/dtext.tcl:197
 msgid "place with mouse"
 msgstr "Mit der Maus platzieren"
-#: ../gui/tcltk/gis.m/legend.tcl:246
-msgid "    legend height "
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:248
-#, tcl-format
-msgid "Legend height (% of display)"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:249
 #, fuzzy
 msgid "%  width"
 msgstr "Breite:"
-#: ../gui/tcltk/gis.m/legend.tcl:251
-#, tcl-format
-msgid "Legend width (% of display)"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:258
 msgid "Legend appearance: text color"
 msgstr "Legendedarstellung: Textfarbe"
-#: ../gui/tcltk/gis.m/legend.tcl:262
 #, fuzzy
 msgid "  legend text font "
 msgstr "Legende: Titelschrift "
-#: ../gui/tcltk/gis.m/legend.tcl:273
 msgid "do not display labels"
 msgstr "Keine Label darstellen"
-#: ../gui/tcltk/gis.m/legend.tcl:275
 msgid "do not display values"
 msgstr "Keine Werte darstellen"
-#: ../gui/tcltk/gis.m/legend.tcl:282
-msgid "    number of lines (0=display all):"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:284
 #, fuzzy
 msgid "Lines to display"
-#: ../gui/tcltk/gis.m/legend.tcl:286
 msgid "invert legend"
 msgstr "Legende invertieren"
-#: ../gui/tcltk/gis.m/legend.tcl:293
 #, fuzzy
 msgid "    interval between categories (integer maps)"
 msgstr "Kategorien reklassifizieren (erzeugt neue Karte)"
-#: ../gui/tcltk/gis.m/legend.tcl:295
-msgid "Thinning interval"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:302
 msgid "draw smooth gradient (fp maps)"
 msgstr "Glättungsgradient zeichnen (nur bei FP-Karten)"
-#: ../gui/tcltk/gis.m/legend.tcl:304
-msgid "with maximum of"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:306
-msgid "Maximum lines to display for gradient"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:307 ../gui/tcltk/gis.m/chart.tcl:196
 msgid "lines"
 msgstr "Zeilen"
-#: ../gui/tcltk/gis.m/legend.tcl:313
-msgid "Display legend for subset of raster values"
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:320
 msgid "skip categories with no labels"
 msgstr "Überspringe Kategorien ohne Label"
-#: ../gui/tcltk/gis.m/legend.tcl:327
-msgid "    legend for only these categories     "
-msgstr ""
-#: ../gui/tcltk/gis.m/legend.tcl:334
-msgid "    legend for only this range of values"
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:135 ../gui/tcltk/gis.m/maptext.tcl:80
 #, fuzzy
 msgid "Select label font"
 msgstr "Standardschrift einstellen"
-#: ../gui/tcltk/gis.m/maplabels.tcl:158
 #, fuzzy
 msgid "Create postscript labels for vector objects from v.labels file"
-#: ../gui/tcltk/gis.m/maplabels.tcl:165
-msgid "  (for postscript eps, pdf, and print output only)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:184
 msgid "Override offset, alignment, and color settings in v.labels file: "
 msgstr ""
 "Überschreibe Offset-, Anordnung- und Farbeinstellungen in der v.labels-"
 "Datei: "
-#: ../gui/tcltk/gis.m/maplabels.tcl:191
 msgid "Align label with vector object: "
 msgstr "Label am Vektorobjekt ausrichten"
-#: ../gui/tcltk/gis.m/maplabels.tcl:200
 #, fuzzy
 msgid "Offset label from vector object: "
 msgstr "von "
-#: ../gui/tcltk/gis.m/maplabels.tcl:201
 msgid "x offset"
 msgstr "x offset"
-#: ../gui/tcltk/gis.m/maplabels.tcl:204
 msgid "y offset"
 msgstr "y offset"
-#: ../gui/tcltk/gis.m/maplabels.tcl:212
 msgid "Justification: "
 msgstr "Zentrierung:"
-#: ../gui/tcltk/gis.m/maplabels.tcl:215
-msgid " Label line max length: "
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:222
-msgid "Enclose label in box: "
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:225
 #, fuzzy
 msgid "Draw label background: "
 msgstr "Transparenter Hintergrund"
-#: ../gui/tcltk/gis.m/maplabels.tcl:229
 #, fuzzy
 msgid "Background color:"
 msgstr " Hintergrundfarbe: "
-#: ../gui/tcltk/gis.m/maplabels.tcl:236
 #, fuzzy
 msgid "Draw box outline: "
-#: ../gui/tcltk/gis.m/maplabels.tcl:240
 #, fuzzy
 msgid "Border width:"
 msgstr "Breite:"
-#: ../gui/tcltk/gis.m/maplabels.tcl:243
 #, fuzzy
 msgid "Border color:"
-#: ../gui/tcltk/gis.m/maplabels.tcl:250
-msgid "Distance between label and enclosing box. Horizontal: "
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:253
-msgid " Vertical: "
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:261
 #, fuzzy
 msgid "Font"
 msgstr "Schrift:"
-#: ../gui/tcltk/gis.m/maplabels.tcl:264
 msgid "select font for label"
 msgstr "Schrift für Label"
-#: ../gui/tcltk/gis.m/maplabels.tcl:266
-msgid "family:"
-msgstr ""
-#: ../gui/tcltk/gis.m/maplabels.tcl:269
 #, fuzzy
 msgid "size:"
 msgstr "Größe"
-#: ../gui/tcltk/gis.m/maplabels.tcl:272 ../gui/tcltk/gis.m/maptext.tcl:184
-#: ../gui/tcltk/gis.m/dtext.tcl:228
 msgid "  color"
 msgstr "  Farbe"
-#: ../gui/tcltk/gis.m/maplabels.tcl:326
-msgid "Could not open labels file "
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:127
 #, fuzzy
 msgid "Raster drape map"
-#: ../gui/tcltk/gis.m/raster.tcl:161
 #, fuzzy
 msgid "Display raster maps"
 msgstr "Stichprobe"
-#: ../gui/tcltk/gis.m/raster.tcl:178
 #, fuzzy
 msgid "Base map:\t"
-#: ../gui/tcltk/gis.m/raster.tcl:181
 msgid "base raster map to display"
 msgstr "Basisrasterkarte zum darstellen"
-#: ../gui/tcltk/gis.m/raster.tcl:186 ../gui/tcltk/gis.m/raster.tcl:190
 #, fuzzy
 msgid "base map info"
-#: ../gui/tcltk/gis.m/raster.tcl:202
 #, fuzzy
 msgid "\tvalues to display"
 msgstr "Label-Datei, die dargestellt werden soll"
-#: ../gui/tcltk/gis.m/raster.tcl:209
-msgid "\tOptional color draping. Use base map for shading,"
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:214
-msgid "\tdrape map for color in color relief map or data fusion"
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:219
-msgid "\tdrape map:  "
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:222
 msgid "raster map to drape over base map"
 msgstr "Rasterkarte, die über eine Basiskarte gelegt werden soll"
-#: ../gui/tcltk/gis.m/raster.tcl:227 ../gui/tcltk/gis.m/raster.tcl:231
 #, fuzzy
 msgid "drape map info"
-#: ../gui/tcltk/gis.m/raster.tcl:237
-msgid "\tdrape map brightness adjustment\t "
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:239
-msgid "Adjust brightness of drape map"
-msgstr ""
-#: ../gui/tcltk/gis.m/raster.tcl:246 ../gui/tcltk/gis.m/rgbhis.tcl:220
 #, fuzzy
 msgid "overlay maps from other layers (transparent null value cells)"
 msgstr "Überlagere Ebenen von Weitere"
-#: ../gui/tcltk/gis.m/raster.tcl:253
-msgid " Set background color (colored null value cells)"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:111
 #, fuzzy
 msgid "Vector map for chart"
 msgstr "Vektorkarte"
-#: ../gui/tcltk/gis.m/chart.tcl:114
-#, tcl-format
-msgid "chart for %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:159
-msgid ""
-"Display pie and bar charts of attribute values at vector object locations"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:176
 msgid "Vector map to chart:"
-#: ../gui/tcltk/gis.m/chart.tcl:179
 msgid "vector map to chart"
-#: ../gui/tcltk/gis.m/chart.tcl:194
 msgid "Vector type:"
 msgstr "Vektortype:"
-#: ../gui/tcltk/gis.m/chart.tcl:195
 msgid "points"
 msgstr "Punkte"
-#: ../gui/tcltk/gis.m/chart.tcl:197
 msgid "boundaries"
 msgstr "Umrandung"
-#: ../gui/tcltk/gis.m/chart.tcl:198
 msgid "centroids"
 msgstr "Zentroide"
-#: ../gui/tcltk/gis.m/chart.tcl:199
 msgid "areas"
 msgstr "Flächen"
-#: ../gui/tcltk/gis.m/chart.tcl:205
-msgid "Attributes to chart: attribute layer"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:212
 msgid "     show attribute columns"
 msgstr "     zeige Attributspalten"
-#: ../gui/tcltk/gis.m/chart.tcl:218
 msgid "   show attribute data"
 msgstr "   zeige Attributdaten"
-#: ../gui/tcltk/gis.m/chart.tcl:229
-msgid "\tcolumns to chart (col1,col2,...)  "
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:236
-msgid "\tcolors for columns (clr1,clr2,...)"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:243
-msgid "\tcolumn for variable chart size"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:245
-msgid "  scale factor"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:252
 msgid "Chart type:"
 msgstr "Diagrammtype:"
-#: ../gui/tcltk/gis.m/chart.tcl:255
-msgid "\tfixed chart size (if size column not used)"
-msgstr ""
-#: ../gui/tcltk/gis.m/chart.tcl:262
 #, fuzzy
 msgid "\tchart outline color:"
 msgstr "    Diagramaußenfarbe:"
-#: ../gui/tcltk/gis.m/vector.tcl:229
 #, fuzzy
 msgid "Vector output map"
-#: ../gui/tcltk/gis.m/vector.tcl:299
 #, fuzzy
 msgid "Display vector maps"
 msgstr "Zeige Kategorien"
-#: ../gui/tcltk/gis.m/vector.tcl:310
 #, fuzzy
 msgid "Transparent"
 msgstr " Transparent"
-#: ../gui/tcltk/gis.m/vector.tcl:319
 msgid "vector map to display"
 msgstr "Vektorkarte, die dargestellt werden soll"
-#: ../gui/tcltk/gis.m/vector.tcl:324 ../gui/tcltk/gis.m/vector.tcl:328
 #, fuzzy
 msgid "Vector Info"
 msgstr "Vektorname:"
-#: ../gui/tcltk/gis.m/vector.tcl:340
 msgid "Display: "
 msgstr "Darstellung: "
-#: ../gui/tcltk/gis.m/vector.tcl:341
 #, fuzzy
 msgid "Shapes "
 msgstr "Formen"
-#: ../gui/tcltk/gis.m/vector.tcl:343
 #, fuzzy
 msgid "Categories "
 msgstr "Kategorien"
-#: ../gui/tcltk/gis.m/vector.tcl:345
 #, fuzzy
 msgid "Topology "
 msgstr "Topologie"
-#: ../gui/tcltk/gis.m/vector.tcl:347
 #, fuzzy
 msgid "Line directions "
-#: ../gui/tcltk/gis.m/vector.tcl:355
 #, fuzzy
 msgid "Points "
 msgstr "Punkt"
-#: ../gui/tcltk/gis.m/vector.tcl:357
 #, fuzzy
 msgid "Lines "
 msgstr "Linie"
-#: ../gui/tcltk/gis.m/vector.tcl:359
 #, fuzzy
 msgid "Boundaries "
 msgstr "Umrandung"
-#: ../gui/tcltk/gis.m/vector.tcl:361
 #, fuzzy
 msgid "Areas "
 msgstr "Flächen"
-#: ../gui/tcltk/gis.m/vector.tcl:363
 #, fuzzy
 msgid "Centroids "
 msgstr "Zentroide"
-#: ../gui/tcltk/gis.m/vector.tcl:365
 #, fuzzy
 msgid "Faces "
 msgstr "Faces"
-#: ../gui/tcltk/gis.m/vector.tcl:372
-msgid "Point symbols:"
-msgstr ""
-#: ../gui/tcltk/gis.m/vector.tcl:373
 #, fuzzy
 msgid "Icon"
 msgstr "Icon"
-#: ../gui/tcltk/gis.m/vector.tcl:377
 #, fuzzy
 msgid "   Size"
 msgstr "Größe"
-#: ../gui/tcltk/gis.m/vector.tcl:379
 #, fuzzy
 msgid "Icon size"
 msgstr "Größe"
-#: ../gui/tcltk/gis.m/vector.tcl:385
 msgid "Draw lines:"
-#: ../gui/tcltk/gis.m/vector.tcl:388 ../gui/tcltk/gis.m/vector.tcl:404
 #, fuzzy
 msgid "Color"
 msgstr "Farbe"
-#: ../gui/tcltk/gis.m/vector.tcl:391
 #, fuzzy
 msgid "   Width"
 msgstr "Breite:"
-#: ../gui/tcltk/gis.m/vector.tcl:393
 #, fuzzy
 msgid "Line width"
 msgstr "Breite:"
-#: ../gui/tcltk/gis.m/vector.tcl:395
-msgid "(pixels) "
-msgstr ""
-#: ../gui/tcltk/gis.m/vector.tcl:401
 msgid "Fill areas:"
-#: ../gui/tcltk/gis.m/vector.tcl:408
 #, fuzzy
 msgid "Random colors "
-#: ../gui/tcltk/gis.m/vector.tcl:410
 msgid "GRASSRGB column colors"
 msgstr "GRASSRGB Spalte"
-#: ../gui/tcltk/gis.m/vector.tcl:417
 msgid "Label vectors:"
 msgstr "Beschrifte Vektoren:"
-#: ../gui/tcltk/gis.m/vector.tcl:418
 msgid "label"
 msgstr "Label"
-#: ../gui/tcltk/gis.m/vector.tcl:420
 #, fuzzy
 msgid " Text color"
 msgstr "Textfarbe"
-#: ../gui/tcltk/gis.m/vector.tcl:423
 #, fuzzy
 msgid "   Text size"
 msgstr " Textgröße"
-#: ../gui/tcltk/gis.m/vector.tcl:425
 msgid "text size"
 msgstr "Textgröße"
-#: ../gui/tcltk/gis.m/vector.tcl:433
 #, fuzzy
 msgid "Label part to align with vector point"
 msgstr "part Punkt"
-#: ../gui/tcltk/gis.m/vector.tcl:437
 #, fuzzy
 msgid "   Justification"
-#: ../gui/tcltk/gis.m/vector.tcl:446
 #, fuzzy
 msgid "     Layer for labels"
 msgstr "     Ebene für Label"
-#: ../gui/tcltk/gis.m/vector.tcl:448
 #, fuzzy
 msgid "   Attribute col for labels"
 msgstr "Attributspalte für die Labels"
-#: ../gui/tcltk/gis.m/vector.tcl:455
 msgid "Query vectors for display: "
-#: ../gui/tcltk/gis.m/vector.tcl:456
 msgid "layer for query"
 msgstr "Ebene zur Abfrage"
-#: ../gui/tcltk/gis.m/vector.tcl:464
 #, fuzzy
 msgid "Query cat values"
 msgstr " Kategoriewerte abfragen"
-#: ../gui/tcltk/gis.m/vector.tcl:475
 #, fuzzy
 msgid "Use SQL query"
 msgstr "SQL-Abfrage benutzen"
-#: ../gui/tcltk/gis.m/vector.tcl:483
 #, fuzzy
 msgid "    Show attribute columns"
-#: ../gui/tcltk/gis.m/vector.tcl:489
 #, fuzzy
 msgid "      Show attribute data"
-#: ../gui/tcltk/gis.m/vector.tcl:501
 #, fuzzy
 msgid "Save displayed objects to new vector file "
 msgstr "Speichere dargestellte Vektoren in einer neuen Vektorkarte"
-#: ../gui/tcltk/gis.m/vector.tcl:503
 #, fuzzy
 msgid "Overwrite existing"
-#: ../gui/tcltk/gis.m/vector.tcl:510
 #, fuzzy
 msgid "     New vector"
 msgstr "     Neuer Vektor"
-#: ../gui/tcltk/gis.m/vector.tcl:514
 #, fuzzy
 msgid "Select existing vector for saving queried objects"
 msgstr "Wähle vorhandene Vektoren zum Speichern der abgefragten Objekte"
-#: ../gui/tcltk/gis.m/vector.tcl:522
 msgid "Display when avg. region dimension is"
 msgstr "Zeichne, wenn die Regionsausdehnung ist"
-#: ../gui/tcltk/gis.m/vector.tcl:525
-msgid " or <"
-msgstr ""
-#: ../gui/tcltk/gis.m/cmd.tcl:115
 msgid "Command:"
 msgstr "Kommando:"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:523
-msgid "Maximum zoom-in reached"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:593 ../gui/tcltk/gis.m/mapcanvas.tcl:1219
-#: ../gui/tcltk/gis.m/georect.tcl:1576
-msgid "Error setting region"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:601
-msgid "please wait..."
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:760 ../gui/tcltk/gis.m/mapcanvas.tcl:1813
 #, fuzzy
 msgid "You have to select map layer first"
 msgstr "Karte abfragen (erst eine Karte auswählen)"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:761 ../gui/tcltk/gis.m/mapcanvas.tcl:1814
-msgid "No map layer selected"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:833
 #, fuzzy
 msgid "Save Region"
 msgstr "Region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:836
 msgid "Save current display geometry to named region"
 msgstr "Speichere aktuelle Geometrien in einer benannten Region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:842
 msgid "Enter region name"
 msgstr "Regionsname eingeben"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:877
-#, tcl-format
-msgid ""
-"Region file %s already exists. \n"
-"Do you want to overwrite it?"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1064
-#, tcl-format
-msgid "Display: rows=%d cols=%d  N-S res=%g  E-W res=%g"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1136
-msgid "Error setting region (Problem with g.region?)"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1182 ../gui/tcltk/gis.m/mapcanvas.tcl:1187
-msgid "Error reading current resolution with g.region"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1244 ../gui/tcltk/gis.m/georect.tcl:2018
-msgid "Drag or click mouse to zoom"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1246 ../gui/tcltk/gis.m/georect.tcl:2020
-msgid "Drag or click mouse to unzoom"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1481 ../gui/tcltk/gis.m/georect.tcl:2218
 #, fuzzy
 msgid "Drag with mouse to pan"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1608
 #, fuzzy
 msgid "Measurement"
 msgstr "Messen"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1627
-msgid "Draw measure line with mouse"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1784
-msgid "Click to query feature"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1852
-msgid "This layer type does not support queries"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1853
-msgid "Query not supported"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1860
-msgid "You must select a map to query\n"
-msgstr ""
-#: ../gui/tcltk/gis.m/barscale.tcl:153
 #, fuzzy
 msgid "Display scale and north arrow"
-#: ../gui/tcltk/gis.m/barscale.tcl:170
-#, tcl-format
-msgid "Scale placement: 0-100% from top left of display"
-msgstr ""
-#: ../gui/tcltk/gis.m/barscale.tcl:176
-msgid "\t enter x,y of scale/arrow upper left corner"
-msgstr ""
-#: ../gui/tcltk/gis.m/barscale.tcl:179
 msgid "    "
 msgstr "    "
-#: ../gui/tcltk/gis.m/barscale.tcl:190
 #, fuzzy
 msgid "\t "
 msgstr " "
-#: ../gui/tcltk/gis.m/barscale.tcl:199
 msgid "Scale appearance:  text color"
 msgstr "Maßstabserscheinung:  Textfarbe"
-#: ../gui/tcltk/gis.m/barscale.tcl:201
 #, fuzzy
 msgid "  font "
 msgstr "     Schrift "
-#: ../gui/tcltk/gis.m/barscale.tcl:211
 #, fuzzy
 msgid "\tbackground color "
 msgstr "Hintergrundfarbe"
-#: ../gui/tcltk/gis.m/barscale.tcl:214 ../gui/tcltk/gis.m/histogram.tcl:189
 msgid "transparent background"
-#: ../gui/tcltk/gis.m/barscale.tcl:222
 msgid "display N. arrow only"
 msgstr "Nur Nordpfeil zeigen"
-#: ../gui/tcltk/gis.m/barscale.tcl:224
 msgid "display scale only"
 msgstr "Zeige nur Maßstab"
-#: ../gui/tcltk/gis.m/barscale.tcl:232
 msgid "text on top of scale, instead of to right"
 msgstr "Text oberhalb des Maßstabs anstelle von rechts"
-#: ../gui/tcltk/gis.m/barscale.tcl:240
 #, fuzzy
 msgid "line scale instead of bar"
 msgstr "Linie skalieren von"
-#: ../gui/tcltk/gis.m/barscale.tcl:242
 msgid "use feet/miles instead of meters"
 msgstr "Fuß/Meilen statt Meter"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:104
 #, fuzzy
 msgid "Raster map for red or hue channel"
 msgstr "Rasterkarte für den Rot- oder Wertkanale"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:107
-#, tcl-format
-msgid "RGB-HIS %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/rgbhis.tcl:114
 #, fuzzy
 msgid "Raster map for green or intensity channel"
 msgstr "Rasterkarte für den Grün- oder Intensitätskanal"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:122
 #, fuzzy
 msgid "Raster map for blue or saturation channel"
 msgstr "Rasterkarte für den Blau- oder Sättigungskanal"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:136
 #, fuzzy
 msgid ""
 "Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:155
 msgid "display maps as RGB"
 msgstr "Stelle Karten als RGB dar"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:160
 msgid "Help for RGB"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:164
 msgid "display maps as HIS"
 msgstr "Stelle Karte als HIS-Darstellung dar"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:169
 msgid "Help for HIS"
 msgstr "Hilfe für HIS"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:175
 #, fuzzy
 msgid "red (RGB) or hue (HIS): "
 msgstr "Rot (RGB) oder Wert (HIS):"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:178
 #, fuzzy
 msgid "raster map for red or hue channel (HIS drape)"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:187
 #, fuzzy
 msgid "green (RGB) or intensity (HIS): "
 msgstr "Grün (RGB) oder Intensität (HIS):"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:190
 #, fuzzy
 msgid "raster map for green or intensity channel (HIS relief)"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:199
 #, fuzzy
 msgid "blue (RGB) or saturation (HIS): "
 msgstr "Blau (RGB) oder Sättigung (HIS):"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:202
 msgid "raster map for blue or saturation channel"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:211
-msgid "HIS brightness adjustment\t "
-msgstr ""
-#: ../gui/tcltk/gis.m/rgbhis.tcl:213
-msgid "Adjusts the HIS intensity channel brightness"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptext.tcl:126
-msgid ""
-"Create postscript text object (for postscript eps, pdf, and print output "
-"only)"
-msgstr ""
-#: ../gui/tcltk/gis.m/maptext.tcl:133
 #, fuzzy
 msgid "Text to display:"
 msgstr "Text zum Darstellen: "
-#: ../gui/tcltk/gis.m/maptext.tcl:140 ../gui/tcltk/gis.m/dtext.tcl:188
 msgid "Text placement: x,y coordinates (from upper left) "
 msgstr "Textplazierung: X,Y Koordinaten (von oben links)"
-#: ../gui/tcltk/gis.m/maptext.tcl:147 ../gui/tcltk/gis.m/dtext.tcl:194
 #, fuzzy
 msgid "     coordinate type for text placement "
 msgstr "für"
-#: ../gui/tcltk/gis.m/maptext.tcl:158 ../gui/tcltk/gis.m/dtext.tcl:205
 #, fuzzy
 msgid "     align text with coordinate point  "
 msgstr "Punkt "
-#: ../gui/tcltk/gis.m/maptext.tcl:167
 msgid "     justification"
 msgstr "     Ausrichtung"
-#: ../gui/tcltk/gis.m/maptext.tcl:170
 #, fuzzy
 msgid "  line width"
 msgstr "  Zeilenabstand"
-#: ../gui/tcltk/gis.m/maptext.tcl:177
 msgid "Font:"
 msgstr "Schrift:"
-#: ../gui/tcltk/gis.m/dtext.tcl:159
 #, fuzzy
 msgid "Display text"
-#: ../gui/tcltk/gis.m/dtext.tcl:176
 msgid "Text to display: "
-#: ../gui/tcltk/gis.m/dtext.tcl:214
 msgid "     text rotation (degrees)"
 msgstr "     Textrotation (Grad)"
-#: ../gui/tcltk/gis.m/dtext.tcl:223
 #, fuzzy
 msgid "Text options: font "
 msgstr "Textoptionen: Schrifttyp"
-#: ../gui/tcltk/gis.m/dtext.tcl:230
 msgid "bold text"
 msgstr "Fetter Text"
-#: ../gui/tcltk/gis.m/dtext.tcl:237
 msgid "     text height in pixels "
 msgstr "     Texthöhe in Pixel "
-#: ../gui/tcltk/gis.m/dtext.tcl:239
 msgid "  line spacing"
-#: ../gui/tcltk/gis.m/georect.tcl:282
-msgid ""
-"There is no raster group file (REF). You must select the 'create/edit group' "
-"option to create a group file."
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:304
-msgid ""
-"There is no vector group file (VREF). You must select the 'create/edit "
-"group' option to create a group file."
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:385
 #, fuzzy
 msgid "Select mapset of raster to georectify"
 msgstr "Wähle Gruppe zum Georeferenzieren"
-#: ../gui/tcltk/gis.m/georect.tcl:433
-msgid "Create a group REF file and directory for vectors"
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:446
 msgid "Create/replace vector group"
 msgstr "Erzeuge/ersetze Vektorgruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:472
 msgid "group name"
 msgstr "Gruppenname"
-#: ../gui/tcltk/gis.m/georect.tcl:474
 msgid "Select existing vector group or name new group"
 msgstr "Wähle existierende Vektorgruppe oder benenne neue Gruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:484
 msgid "vector"
 msgstr "Vektor"
-#: ../gui/tcltk/gis.m/georect.tcl:486
 msgid "Select xy vector(s) for group"
 msgstr "Wähle XY-Vektor(en) für die Gruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:496
 msgid "Vector group"
 msgstr "Vektorgruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:613
 #, fuzzy
 msgid "GRASS Georectifier"
 msgstr "Georectifizierer beenden"
-#: ../gui/tcltk/gis.m/georect.tcl:624
-msgid "Set up environment for georectifying rasters or vectors"
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:633
 msgid "Georeference raster"
 msgstr "Georefenzieren von Rasterkarten"
-#: ../gui/tcltk/gis.m/georect.tcl:637
 msgid "Georeference vector"
 msgstr "Vektoren georeferenzieren"
-#: ../gui/tcltk/gis.m/georect.tcl:644
 msgid "1. Select mapset"
 msgstr "1. Wähle Mapset"
-#: ../gui/tcltk/gis.m/georect.tcl:646
 msgid "Mapset of xy raster group"
 msgstr "Mapset einer xy Rastergruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:656
 msgid "2. Create/edit group"
-#: ../gui/tcltk/gis.m/georect.tcl:658
 msgid "Create/edit group (rasters or vectors to georectify)"
 msgstr ""
 "Erstelle/Editiere Gruppe (Raster oder Vektoren, die georeferenziert werden "
 "sollen)"
-#: ../gui/tcltk/gis.m/georect.tcl:666
 msgid "3. Select group"
 msgstr "3. Wähle Gruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:668
 msgid "Select existing group to georectify"
-#: ../gui/tcltk/gis.m/georect.tcl:678
 msgid "4. Select map"
-#: ../gui/tcltk/gis.m/georect.tcl:680
 msgid ""
 "Select non-georectified raster or vector to display for marking ground "
 "control points"
@@ -4072,868 +3034,115 @@
 "Wähle eine nicht-georeferenzierte Raster- oder Vektordatei zur Markierung "
 "von Passpunkten"
-#: ../gui/tcltk/gis.m/georect.tcl:690
 msgid "5. Start georectifying"
 msgstr "5. Georeferenzierung starten"
-#: ../gui/tcltk/gis.m/georect.tcl:692
 msgid "Start georectifying"
 msgstr "Georeferenzierung starten"
-#: ../gui/tcltk/gis.m/georect.tcl:702
 msgid "Cancel georectification"
 msgstr "Georecfifizierung abbrechen"
-#: ../gui/tcltk/gis.m/georect.tcl:799
-msgid "Displaying xy map to be georectified"
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:1006
 msgid "Select rectification method for rasters"
 msgstr "Entzerrungsmethode für Rasterkarten auswählen"
-#: ../gui/tcltk/gis.m/georect.tcl:1009
 msgid "1st order"
 msgstr "Erste Ordnung"
-#: ../gui/tcltk/gis.m/georect.tcl:1010
 msgid "affine transformation  (rasters & vectors). Requires 3+ GCPs."
 msgstr ""
 "Affine-Transformaion (Raster & Vektor). Benötigt 3 und mehr Passpunkte "
 "(GCPs)."
-#: ../gui/tcltk/gis.m/georect.tcl:1015
 msgid "2nd order"
 msgstr "Zweite Ordnung"
-#: ../gui/tcltk/gis.m/georect.tcl:1016
 #, fuzzy
 msgid "polynomial transformation  (rasters only). Requires 6+ GCPs."
 msgstr ""
 "Polynomtransformation (nur Raster). Benötigt 6 und mehr Passpunkte (GCPs)."
-#: ../gui/tcltk/gis.m/georect.tcl:1020
 msgid "3rd order"
 msgstr "Dritte Ordnung"
-#: ../gui/tcltk/gis.m/georect.tcl:1021
 msgid "polynomial transformation  (rasters only). Requires 10+ GCPs."
 msgstr ""
 "Polynomtransformation (nur Raster). Benötigt 10 und mehr Passpunkte (GCPs)."
-#: ../gui/tcltk/gis.m/georect.tcl:1028
 msgid "Use"
 msgstr "Benutze"
-#: ../gui/tcltk/gis.m/georect.tcl:1030
 msgid "xy coordinates"
-#: ../gui/tcltk/gis.m/georect.tcl:1032
 msgid "geographic coordinates"
-#: ../gui/tcltk/gis.m/georect.tcl:1034
 msgid "forward error"
 msgstr "Vorwärz-Fehler"
-#: ../gui/tcltk/gis.m/georect.tcl:1036
 msgid "backward error"
 msgstr "Rückwärz-Fehler"
-#: ../gui/tcltk/gis.m/georect.tcl:1077
 msgid "Manage ground control points (GCPs)"
 msgstr "Passpunkte bearbeiten"
-#: ../gui/tcltk/gis.m/georect.tcl:1102
 #, fuzzy
 msgid "Save GCPs to POINTS file"
 msgstr "Speichere GCPs (Ground Control Points) in POINTS Datei"
-#: ../gui/tcltk/gis.m/georect.tcl:1109
 #, fuzzy
 msgid "Clear all unchecked GCP entries"
 msgstr "Alle ungeprüften Passpunkte löschen"
-#: ../gui/tcltk/gis.m/georect.tcl:1116
 #, fuzzy
 msgid "Calculate RMS error"
 msgstr "RMS-Fehler berechnen"
-#: ../gui/tcltk/gis.m/georect.tcl:1123
 msgid "Rectify maps in group"
 msgstr "Entzerre die Karten in der angegebenen Gruppe"
-#: ../gui/tcltk/gis.m/georect.tcl:1126
 msgid "Quit"
 msgstr "Beenden"
-#: ../gui/tcltk/gis.m/georect.tcl:1130
 msgid "Exit georectifier"
-#: ../gui/tcltk/gis.m/georect.tcl:1313
-msgid ""
-"There is no POINTS file of ground control points for group. You must create "
-"ground control points before georectifying map."
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:1343
-msgid ""
-"Insufficient ground control points for georectification method. You need at "
-"least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd "
-"order."
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:1373
-msgid ""
-"No valid ground control points in GCP file. You must create valid ground "
-"control points before georectifying map."
-msgstr ""
-#: ../gui/tcltk/gis.m/georect.tcl:1585
-msgid "Please wait..."
-msgstr ""
-#: ../gui/tcltk/gis.m/rules.tcl:97
-msgid "Interactive rules entry"
-msgstr ""
-#: ../gui/tcltk/gis.m/rules.tcl:199
-msgid "You must specify an output map"
-msgstr ""
 #, fuzzy
 msgid "No output map specified"
 msgstr "Volumen zu Rasterkartenserien"
-#: ../gui/tcltk/gis.m/rules.tcl:221
 #, fuzzy
 msgid "Error creating rules file"
-#: ../gui/tcltk/gis.m/histogram.tcl:107
 #, fuzzy
 msgid "Raster map for histogram"
-#: ../gui/tcltk/gis.m/histogram.tcl:110
-#, tcl-format
-msgid "histogram of %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/histogram.tcl:138
-msgid "Draw histogram of values from raster map or image"
-msgstr ""
-#: ../gui/tcltk/gis.m/histogram.tcl:155
 #, fuzzy
 msgid "Raster to histogram: "
 msgstr "Raster zu Vektorkonvertierung"
-#: ../gui/tcltk/gis.m/histogram.tcl:171
-msgid "Graph style"
-msgstr ""
-#: ../gui/tcltk/gis.m/histogram.tcl:174
 #, fuzzy
 msgid "\ttext font "
-#: ../gui/tcltk/gis.m/histogram.tcl:184
 #, fuzzy
 msgid "Histogram color: text & frame"
 msgstr " Rahmen & Textfarbe"
-#: ../gui/tcltk/gis.m/histogram.tcl:186
 #, fuzzy
 msgid "  background"
 msgstr "Hintergrund"
-#: ../gui/tcltk/gis.m/histogram.tcl:196
-msgid "Steps/bins for values (fp maps only)"
-msgstr ""
-#: ../gui/tcltk/gis.m/histogram.tcl:200
 msgid "include null values"
 msgstr "NULL-Werte mit einbeziehen"
-#: ../gui/tcltk/gis.m/histogram.tcl:263
 #, fuzzy
 msgid "r.info error"
-#: ../lib/gtcltk/select.tcl:103
-#, fuzzy
-msgid "Select item"
-msgstr "4. Wähle zu referenzierende Karte"
-#: ../lib/gtcltk/select.tcl:208
-msgid "Ok"
-msgstr ""
-#: ../lib/gis/gui.tcl:231
-msgid "Load File"
-msgstr ""
-#: ../lib/gis/gui.tcl:355
-msgid "Options"
-msgstr "Optionen"
-#: ../lib/gis/gui.tcl:577
-msgid "required"
-msgstr "benötigt"
-msgid "optional"
-msgstr "optional"
-#: ../lib/gis/gui.tcl:578
-msgid "multiple"
-msgstr "viele "
-#: ../lib/init/epsg_option.tcl:93
-msgid "WARNING: cant get enviromental variable"
-msgstr "WARNUNG: kann Umgebungsvariable nicht lesen"
-#: ../lib/init/epsg_option.tcl:94
-msgid ""
-"Warning: Unable to get enviromental variable GRASS_PROJSHARE. \n"
-"This is a GRASS installation error. \n"
-"Set enviromental variable GRASS_PROJSHARE to point to directory with Proj4 "
-"EPSG file. "
-msgstr ""
-#: ../lib/init/epsg_option.tcl:103
-msgid "Define location using EPSG projection codes"
-msgstr "Definieren Sie eine Location basierend auf dem EPSG-Code."
-#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:92
-msgid "Name of new location"
-msgstr "Name der neuen Location"
-#: ../lib/init/epsg_option.tcl:125
-msgid "Enter name for location to be created"
-msgstr "Geben SIe den Namen der neu zu erzeugenden Location ein"
-#: ../lib/init/epsg_option.tcl:129 ../lib/init/epsg_option.tcl:132
-msgid "Path to the EPSG-codes file"
-msgstr "Pfad zur EPSG-Datei."
-#: ../lib/init/epsg_option.tcl:135 ../lib/init/epsg_option.tcl:148
-#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:105
-msgid "Browse..."
-msgstr "Blättern..."
-#: ../lib/init/epsg_option.tcl:136
-msgid "Browse to locate EPSG file"
-msgstr "Suchen Sie die EPSG-Datei."
-#: ../lib/init/epsg_option.tcl:143
-msgid "EPSG code number of projection"
-msgstr "EPSG-Nummer der Projektion"
-#: ../lib/init/epsg_option.tcl:146
-msgid "Enter EPSG code for selected projection"
-msgstr "Bitte geben Sie den EPSG-Code für die gewählte Projektion ein"
-#: ../lib/init/epsg_option.tcl:149
-msgid "View EPSG codes and projection information."
-msgstr "EPSG-Code und Projektionsinformaionen anschauen."
-#: ../lib/init/epsg_option.tcl:155
-msgid "WARNING: epsg-codes file not found"
-msgstr "WARNUNG: EPSG-Datei wurde nicht gefunden."
-#: ../lib/init/epsg_option.tcl:156
-msgid "WARNING: The epsg-codes file was not found!"
-msgstr "WARNUNG: Die EPSG-Datei konnte nicht gefunden werden!"
-#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:111
-msgid "Define location"
-msgstr "Location erzeugen"
-#: ../lib/init/epsg_option.tcl:187
-msgid "Invalid EPSG Code!"
-msgstr ""
-#: ../lib/init/epsg_option.tcl:188
-#, tcl-format
-msgid "ERROR: Invalid EPSG code %s: should be an integer."
-msgstr ""
-#: ../lib/init/epsg_option.tcl:198
-msgid "Location Exists!"
-msgstr ""
-#: ../lib/init/epsg_option.tcl:199
-#, tcl-format
-msgid "WARNING: Location '%s' already exists: please try another name."
-msgstr ""
-#: ../lib/init/epsg_option.tcl:236 ../lib/init/epsg_option.tcl:263
-#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
-#, fuzzy
-msgid "Error creating location!"
-msgstr "WARNUNG: Fehler beim Erstellen der Location"
-#: ../lib/init/epsg_option.tcl:237 ../lib/init/epsg_option.tcl:264
-#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
-#, tcl-format
-msgid ""
-"g.proj returned the following message:\n"
-"%s"
-msgstr ""
-#: ../lib/init/epsg_option.tcl:244 ../lib/init/epsg_option.tcl:268
-#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
-msgid "Informational output from g.proj"
-msgstr ""
-#: ../lib/init/epsg_option.tcl:245 ../lib/init/epsg_option.tcl:269
-#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
-#, tcl-format
-msgid ""
-"g.proj returned the following informational message:\n"
-"%s"
-msgstr ""
-#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:240
-#, fuzzy
-msgid "Select datum transformation parameters:"
-msgstr "Standardschrift einstellen"
-#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:244
-msgid ""
-"Continue without specifying parameters - if used when creating a location, "
-"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
-"for this datum if necessary in the future."
-msgstr ""
-#: ../lib/init/epsg_option.tcl:344
-msgid "You can select EPSG code (in <braces>) and copy it for later use."
-msgstr ""
-"Sie können die EPSG-Codes (in <Klammern>) auswählen und für später kopieren. "
-#: ../lib/init/epsg_option.tcl:381
-msgid "GUESS THAT IS NOT THE EPSG FILE"
-msgstr "ICH SCHÄZTE DIES IST NICHT DIE EPSG-DATEI."
-#: ../lib/init/epsg_option.tcl:387 ../lib/init/epsg_option.tcl:416
-#: ../lib/init/epsg_option.tcl:435
-msgid "Search"
-msgstr "Suchen"
-#: ../lib/init/epsg_option.tcl:389
-msgid "Grab code"
-msgstr "Einen Code wählen"
-#: ../lib/init/epsg_option.tcl:422
-msgid "Search text: "
-msgstr "Text suchen:"
-#: ../lib/init/epsg_option.tcl:423
-msgid "Search for entered text in EPSG file"
-msgstr "Den eingegebenen Text in der EPSG-Datei suchen."
-#: ../lib/init/epsg_option.tcl:428
-msgid "forward search"
-msgstr "Vorwärzsuche"
-#: ../lib/init/epsg_option.tcl:429
-msgid "backward search"
-msgstr "Rückwärzsuche"
-#: ../lib/init/gis_set.tcl:107
-#, fuzzy
-msgid "WARNING: can not save"
-msgstr "WARNUNG: Verzeichniswechsel fehlgeschlagen"
-#: ../lib/init/gis_set.tcl:108
-#, tcl-format
-msgid ""
-"Warning: unable to save data to <%s> file.\n"
-"Error message: %s"
-msgstr ""
-#: ../lib/init/gis_set.tcl:128 ../lib/init/gis_set.tcl:379
-#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:609
-#: ../lib/init/gis_set.tcl:630 ../lib/init/gis_set.tcl:648
-#: ../lib/init/gis_set.tcl:676
-msgid "WARNING: invalid location"
-msgstr "WARNUNG:ungültige Location"
-#: ../lib/init/gis_set.tcl:129
-#, tcl-format
-msgid ""
-"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
-msgstr ""
-"Warnung. Location <%s> in GISDBASE <%s> ist kein Ordner oder existiert nicht."
-#: ../lib/init/gis_set.tcl:179
-#, tcl-format
-msgid "GRASS %s Startup"
-msgstr "GRASS %s Start"
-#: ../lib/init/gis_set.tcl:202
-msgid "Welcome to GRASS GIS Version"
-msgstr "Willkommen in GRASS GIS Version"
-#: ../lib/init/gis_set.tcl:204
-msgid ""
-"The world's leading open source GIS\n"
-"\n"
-msgstr ""
-"Das weltweit führende quelloffene GIS\n"
-"\n"
-#: ../lib/init/gis_set.tcl:205
-msgid "Select an existing project location and mapset\n"
-msgstr "Wählen Sie eine existierende Location mit Mapset\n"
-#: ../lib/init/gis_set.tcl:206
-msgid "or define a new location\n"
-msgstr "oder definieren Sie eine neue Location\n"
-#: ../lib/init/gis_set.tcl:229
-msgid "GIS Data Directory: "
-msgstr "Datenbankverzeichnis"
-#: ../lib/init/gis_set.tcl:245
-msgid "New GIS data directory"
-msgstr "Neues GIS Datenverzeichnis"
-#: ../lib/init/gis_set.tcl:268
-#, fuzzy
-msgid "Project Location (projection/coordinate system)"
-msgstr ""
-"Projekt Location\n"
-"(Projektion/Koordinatensystem)"
-#: ../lib/init/gis_set.tcl:301
-#, fuzzy
-msgid "Accessible Mapsets (directories of GIS files)"
-msgstr ""
-"Verfügbare Mapsets\n"
-"(Ordner mit GIS-Daten)"
-#: ../lib/init/gis_set.tcl:358
-#, fuzzy
-msgid "Create new mapset in selected location"
-msgstr ""
-"Neues Mapset in der ausge-\n"
-"wählten Location erstellen"
-#: ../lib/init/gis_set.tcl:366
-msgid "Create new mapset"
-msgstr "Neues Mapset erstellen"
-#: ../lib/init/gis_set.tcl:371
-#, fuzzy
-msgid "WARNING: invalid mapset name"
-msgstr "WARNUNG:ungültiges Mapset"
-#: ../lib/init/gis_set.tcl:372
-#, fuzzy, tcl-format
-msgid ""
-"Warning: Mapset with name <%s> already exists. \n"
-"New mapset is NOT created. \n"
-"Choose different mapset name and try again."
-msgstr ""
-"Warnung: Ausgewählte Location <%s> ist nicht gültig.\n"
-" Neues Mapset wurde NICHT erstellt.\n"
-".Wählen Sie eine gültige Location und versuchen Sie es erneut."
-#: ../lib/init/gis_set.tcl:380
-#, tcl-format
-msgid ""
-"Warning: selected location <%s> is not valid. \n"
-" New mapset is NOT created. \n"
-" Select valid location and try again."
-msgstr ""
-#: ../lib/init/gis_set.tcl:387
-#, fuzzy
-msgid "WARNING: unable to mkdir"
-#: ../lib/init/gis_set.tcl:388
-#, tcl-format
-msgid ""
-"Warning: Unable to create directory for new mapset. \n"
-msgstr ""
-#: ../lib/init/gis_set.tcl:413
-msgid "Define new location with..."
-msgstr "Definieren einer neuen Location mit..."
-#: ../lib/init/gis_set.tcl:417
-msgid "Georeferenced file"
-msgstr "einer georeferenzierten Datei"
-#: ../lib/init/gis_set.tcl:430
-msgid "EPSG codes"
-msgstr "einem EPSG-Code"
-#: ../lib/init/gis_set.tcl:443
-msgid "Projection values"
-msgstr "Projektionsinformationen"
-#: ../lib/init/gis_set.tcl:481
-msgid "Enter GRASS"
-msgstr "GRASS starten"
-#: ../lib/init/gis_set.tcl:486
-#, tcl-format
-msgid ""
-msgstr ""
-#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:654
-msgid "WARNING: invalid mapset"
-#: ../lib/init/gis_set.tcl:492
-#, tcl-format
-msgid "Warning: <%s> is not a valid mapset"
-msgstr "Warnung: <%s> ist kein gültiges Mapset"
-#: ../lib/init/gis_set.tcl:512
-msgid "Help already opened"
-msgstr "Hilfe ist bereits geöffnet"
-#: ../lib/init/gis_set.tcl:525
-msgid "Exit"
-msgstr "Beenden"
-#: ../lib/init/gis_set.tcl:561
-msgid "WARNING: Invalid Database"
-msgstr "WARNUNG: ungültige Datenbank"
-#: ../lib/init/gis_set.tcl:562
-msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
-msgstr ""
-"WARNUNG: Ungültige Datenbasis. Finde ersten gültigen Ordner im "
-"Verzeichnisbaum"
-#: ../lib/init/gis_set.tcl:610 ../lib/init/gis_set.tcl:631
-#: ../lib/init/gis_set.tcl:649 ../lib/init/gis_set.tcl:677
-#, tcl-format
-msgid ""
-"Warning: selected location <%%s> is not valid. \n"
-msgstr ""
-"Warnung: Ausgewählte Location <%%s> ist nicht gültig.\n"
-".Wählen Sie eine neue Location und versuchen Sie es erneut."
-#: ../lib/init/gis_set.tcl:655
-#, tcl-format
-msgid "Warning: <%%s> is not a valid mapset"
-msgstr "Warnung: <%%s> ist kein gültiges Mapset"
-#: ../lib/init/gis_set.tcl:747
-msgid "WARNING: change directory failed"
-#: ../lib/init/gis_set.tcl:748
-#, tcl-format
-msgid ""
-"Warning: could not change directory to <%s>.\n"
-"Check directory permissions."
-msgstr ""
-"Warnung: Konnte nicht in das Verzeichnis <%s> wechseln.\n"
-"Überprüfen Sie die Verzeichnisberechtigung."
-#: ../lib/init/file_option.tcl:72
-msgid "Define location using projection information in georeferenced file"
-msgstr ""
-"Definieren Sie die Projektionsinformationen, die für die georeferenzierte "
-"Datei angewandt werden sollen."
-#: ../lib/init/file_option.tcl:95
-msgid "Enter name of location to be created"
-msgstr "Geben SIe den Namen der neu zu erzeugenden Location ein."
-#: ../lib/init/file_option.tcl:99
-msgid "Path to georeferenced file"
-msgstr "Pfad zur georeferenzierten Datei"
-#: ../lib/init/file_option.tcl:102
-msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
-msgstr ""
-"Pfad zur georeferenzierten Datei (Format muss von GDAL/OGR lesebar sein)"
-#: ../lib/init/file_option.tcl:106
-msgid "Browse to locate georeferenced file"
-msgstr "Suchen Sie den Pfad zur georeferenzierten Datei"
-#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
-msgid "Choose georeferenced file"
-msgstr "Wählen Sie die georeferenzierten Datei."
-#: ../lib/init/file_option.tcl:152
-msgid ""
-"WARNING: Please supply a\n"
-"valid georeferenced file"
-msgstr ""
-"WARNUNG: Bitte geben Sie eine\n"
-"gültige georeferenzierte Datei an."
-#: ../vector/v.digit/settings.tcl:64
-msgid "Add new column"
-msgstr "Neue Spalte hinzufügen"
-#: ../vector/v.digit/settings.tcl:67
-msgid "Create table"
-msgstr "Erzeuge Tabelle"
-#: ../vector/v.digit/settings.tcl:100
-msgid "Add command"
-msgstr "Kommando hinzufügen"
-#: ../vector/v.digit/settings.tcl:136
-msgid "Table successfully created"
-msgstr "Tabelle erfolgreich erstellt."
-#: ../vector/v.digit/settings.tcl:152
-msgid "Settings already opened"
-msgstr "Einstellungen sind bereits geöffnet"
-#: ../vector/v.digit/settings.tcl:170
-msgid "Symbology"
-msgstr "Bezeichnungen"
-#: ../vector/v.digit/settings.tcl:174 ../vector/v.digit/settings.tcl:327
-msgid "Background"
-msgstr "Hintergrund"
-#: ../vector/v.digit/settings.tcl:181
-msgid "Highlight"
-msgstr "Hervorheben"
-#: ../vector/v.digit/settings.tcl:188
-msgid "Point"
-msgstr "Punkt"
-#: ../vector/v.digit/settings.tcl:197
-msgid "Line"
-msgstr "Linie"
-#: ../vector/v.digit/settings.tcl:206
-msgid "Boundary (no area)"
-msgstr "Boundary (keine Fläche)"
-#: ../vector/v.digit/settings.tcl:214
-msgid "Boundary (1 area)"
-msgstr "Boundary (1 Fläche)"
-#: ../vector/v.digit/settings.tcl:222
-msgid "Boundary (2 areas)"
-msgstr "Umrandung (2 Flächen)"
-#: ../vector/v.digit/settings.tcl:231
-msgid "Centroid (in area)"
-msgstr "Zentroid (in Fläche)"
-#: ../vector/v.digit/settings.tcl:239
-msgid "Centroid (outside area)"
-msgstr "Zentroid (außerhalb einer Fläche)"
-#: ../vector/v.digit/settings.tcl:247
-msgid "Centroid (duplicate in area)"
-msgstr "Zentroid (Duplikat in einer Fläche)"
-#: ../vector/v.digit/settings.tcl:256
-msgid "Node (1 line)"
-msgstr "Knoten (1 Linie)"
-#: ../vector/v.digit/settings.tcl:264
-msgid "Node (2 lines)"
-msgstr "Knoten (2 Linien)"
-#: ../vector/v.digit/settings.tcl:274
-msgid "Settings"
-msgstr "Einstellungen"
-#: ../vector/v.digit/settings.tcl:279
-msgid "Snapping threshold in screen pixels"
-msgstr "Schnappdistanz (in Bildschirmpixel)"
-#: ../vector/v.digit/settings.tcl:289
-msgid "Snapping threshold in map units"
-msgstr "Schnappdistanz (in Karteneinheiten)"
-#: ../vector/v.digit/settings.tcl:306
-msgid "Line width in screen pixels"
-msgstr "Linienbreite in Bildschirmpixeln"
-#: ../vector/v.digit/settings.tcl:308
-msgid "Set line width in pixels"
-msgstr "LegeLinienbreite in Pixel fest"
-#: ../vector/v.digit/settings.tcl:316
-msgid "Table"
-msgstr "Tabelle"
-#: ../vector/v.digit/toolbox.tcl:20
-msgid "Welcome to v.digit"
-msgstr "Willkommen bei v.digit"
-#: ../vector/v.digit/toolbox.tcl:21
-msgid "Left button"
-msgstr "Linker Mausknopf"
-#: ../vector/v.digit/toolbox.tcl:22
-msgid "Middle button"
-msgstr "Mittlerer Mausknopf"
-#: ../vector/v.digit/toolbox.tcl:23
-msgid "Right button"
-msgstr "Rechter Mausknopf"
-#: ../vector/v.digit/toolbox.tcl:76
-msgid "  Layer"
-msgstr "  Ebene"
-#: ../vector/v.digit/toolbox.tcl:80
-msgid "  Category"
-msgstr "  Kategorie"
-#: ../vector/v.digit/toolbox.tcl:84
-msgid "  Mode "
-msgstr "  Modus"
-#: ../vector/v.digit/toolbox.tcl:96
-msgid "Insert new record into table"
-msgstr "Neuen Eintrag in Tabelle einfügen"
-#: ../vector/v.digit/toolbox.tcl:113
-msgid "Digitize new point"
-msgstr "Neuen Punkt digitalisieren"
-#: ../vector/v.digit/toolbox.tcl:118
-msgid "Digitize new line"
-msgstr "Neue Linie digitalisieren"
-#: ../vector/v.digit/toolbox.tcl:123
-msgid "Digitize new boundary"
-msgstr "Digitalisiere neue Umrandung (Boundary)"
-#: ../vector/v.digit/toolbox.tcl:128
-msgid "Digitize new centroid"
-msgstr "Digitalisiere neuen Zentroid"
-#: ../vector/v.digit/toolbox.tcl:134
-msgid "Move vertex"
-msgstr "Verschiebe Vertex"
-#: ../vector/v.digit/toolbox.tcl:139
-msgid "Add vertex"
-msgstr "Füge Vertex hinzu"
-#: ../vector/v.digit/toolbox.tcl:144
-msgid "Remove vertex"
-msgstr "Entferne Vertex"
-#: ../vector/v.digit/toolbox.tcl:149
-msgid "Split line"
-msgstr "Teile Linie"
-#: ../vector/v.digit/toolbox.tcl:154
-msgid "Edit line/boundary"
-msgstr "Editiere Linie/Boundary"
-#: ../vector/v.digit/toolbox.tcl:159
-msgid "Move point, line, boundary, or centroid"
-msgstr "Verschiebe Punkt, Linie, Boundary oder Zentroid."
-#: ../vector/v.digit/toolbox.tcl:164
-msgid "Delete point, line, boundary, or centroid"
-msgstr "Lösche Punkt, Linie, Boundary oder Zentroid."
-#: ../vector/v.digit/toolbox.tcl:175
-msgid "Redraw"
-msgstr "Neu zeichnen"
-#: ../vector/v.digit/toolbox.tcl:180
-msgid "Zoom in by window"
-msgstr "Hereinzoomen"
-#: ../vector/v.digit/toolbox.tcl:185
-msgid "Zoom out"
-msgstr "Herauszoomen"
-#: ../vector/v.digit/toolbox.tcl:195
-msgid "Zoom to default region"
-msgstr "Zoomen auf die Standardregion"
-#: ../vector/v.digit/toolbox.tcl:208
-#, fuzzy
-msgid "Zoom to saved region"
-msgstr "Zoomen auf die Region"
-#: ../vector/v.digit/toolbox.tcl:214
-msgid "Display categories"
-msgstr "Zeige Kategorien"
-#: ../vector/v.digit/toolbox.tcl:219
-msgid "Copy categories"
-msgstr "Kategorien kopieren"
-#: ../vector/v.digit/toolbox.tcl:224
-msgid "Display attributes"
-msgstr "Zeige Attribute"
-#: ../vector/v.digit/toolbox.tcl:236
-msgid "Open settings"
-msgstr "Öffnen Einstellungen"
-#: ../vector/v.digit/toolbox.tcl:242
-msgid "Save and exit"
-msgstr "Speichern und beenden"
-#: ../vector/v.digit/toolbox.tcl:253
-msgid "mouse button actions (left, middle, right)"
-msgstr "Mausknopfbelegung (links, mitte, rechts)"
-#: ../vector/v.digit/cats.tcl:34
-#, fuzzy
-msgid "Categories already opened"
-#: ../vector/v.digit/cats.tcl:42
-msgid "Categories"
-msgstr "Kategorien"
-#: ../vector/v.digit/cats.tcl:53
-msgid "Layer:"
-msgstr "Ebene:"
-#: ../vector/v.digit/cats.tcl:55
-#, fuzzy
-msgid "   Category:"
-#: ../vector/v.digit/cats.tcl:62
-msgid "Insert new record to table"
-msgstr "Füge neuen Eintrag in Tabelle ein"
-#: ../vector/v.digit/cats.tcl:63
-msgid "Add new"
-msgstr "Neu hinzufügen"
-#: ../visualization/nviz/scripts/panel_animation.tcl:275
-msgid "Test"
-msgstr "Testen"
 msgid "     show data"
 msgstr "     Zeige Daten"
@@ -6053,3 +4262,7 @@
 #, fuzzy
 msgid "X Windows not available"
 msgstr "PS-Textebene hinzufügen"
+#, fuzzy
+#~ msgid "Required"
+#~ msgstr "benötigt"
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po	2008-11-18 10:35:56 UTC (rev 34354)
+++ grass/trunk/locale/po/grasswxpy_de.po	2008-11-18 10:45:30 UTC (rev 34355)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasswxpy_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-10-11 22:08+0200\n"
+"POT-Creation-Date: 2008-11-18 11:38+0100\n"
 "PO-Revision-Date: 2008-10-13 09:57+0200\n"
 "Last-Translator: Markus Neteler <neteler osgeo.org>\n"
 "Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
@@ -114,7 +114,7 @@
 msgstr "Darstellung"
 #: ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/gui_modules/mapdisp.py:3268
+#: ../gui/wxpython/gui_modules/mapdisp.py:3297
 #, fuzzy
 msgid "Print display"
 msgstr "Drucke Darstellung"
@@ -232,7 +232,7 @@
 #: ../gui/wxpython/icons/icon.py:315
-#: ../gui/wxpython/gui_modules/mapdisp.py:3846
+#: ../gui/wxpython/gui_modules/mapdisp.py:3876
 #, fuzzy
 msgid "Add text layer"
 msgstr "Textebene hinzufügen"
@@ -284,7 +284,7 @@
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:335
-#: ../gui/wxpython/gui_modules/toolbars.py:689
+#: ../gui/wxpython/gui_modules/toolbars.py:695
 #, fuzzy
@@ -478,7 +478,7 @@
 msgstr "Einstellungen anzeigen"
 #: ../gui/wxpython/gui_modules/menuform.py:138
-#: ../gui/wxpython/gui_modules/menuform.py:1179
+#: ../gui/wxpython/gui_modules/menuform.py:1234
 msgid "Select Color"
 msgstr "Wählen Sie eine Farbe"
@@ -486,79 +486,78 @@
 msgid "unknown"
 msgstr "unbekannt"
-#: ../gui/wxpython/gui_modules/menuform.py:203
+#: ../gui/wxpython/gui_modules/menuform.py:201
 #, python-format
 msgid "Parameter not found: %s"
 msgstr "Parameter nicht gefunden %s"
-#: ../gui/wxpython/gui_modules/menuform.py:221
+#: ../gui/wxpython/gui_modules/menuform.py:220
 #, python-format
 msgid "Flag not found: %s"
 msgstr "Option nicht gefunden %s"
-#: ../gui/wxpython/gui_modules/menuform.py:255
-#: ../gui/wxpython/gui_modules/menuform.py:1408
+#: ../gui/wxpython/gui_modules/menuform.py:254
 msgid "<required>"
 msgstr "<notwendig>"
-#: ../gui/wxpython/gui_modules/menuform.py:256
+#: ../gui/wxpython/gui_modules/menuform.py:255
 #, python-format
 msgid "Parameter %(name)s (%(desc)s) is missing.\n"
 msgstr "Parameter %(name)s (%(desc)s) fehlt.\n"
-#: ../gui/wxpython/gui_modules/menuform.py:627
+#: ../gui/wxpython/gui_modules/menuform.py:626
 msgid "Enter parameters for "
 msgstr "Geben Sie Parameter ein für"
-#: ../gui/wxpython/gui_modules/menuform.py:631
+#: ../gui/wxpython/gui_modules/menuform.py:630
 msgid " (those in bold typeface are required)"
 msgstr "(fett gedruckte werden benötigt)"
-#: ../gui/wxpython/gui_modules/menuform.py:642
+#: ../gui/wxpython/gui_modules/menuform.py:641
 #, fuzzy
 msgid "Close this window without executing the command"
 msgstr "Schließen"
-#: ../gui/wxpython/gui_modules/menuform.py:647
+#: ../gui/wxpython/gui_modules/menuform.py:646
 msgid "Show manual page of the command"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:665
+#: ../gui/wxpython/gui_modules/menuform.py:664
 msgid "&Run"
 msgstr "&Los"
-#: ../gui/wxpython/gui_modules/menuform.py:666
+#: ../gui/wxpython/gui_modules/menuform.py:665
 msgid "Run the command"
 msgstr "Fühen Sie das Kommando aus"
-#: ../gui/wxpython/gui_modules/menuform.py:670
+#: ../gui/wxpython/gui_modules/menuform.py:669
 msgid "Abort the running command"
 msgstr "Breche das laufende Kommando ab"
-#: ../gui/wxpython/gui_modules/menuform.py:674
+#: ../gui/wxpython/gui_modules/menuform.py:673
 msgid "Copy the current command string to the clipboard"
 msgstr "Kopiere die aktuelle Kommandozeile in die Zwischenablage"
-#: ../gui/wxpython/gui_modules/menuform.py:706
+#: ../gui/wxpython/gui_modules/menuform.py:705
 #: ../gui/wxpython/gui_modules/gdialogs.py:68
-#: ../gui/wxpython/gui_modules/preferences.py:1089
+#: ../gui/wxpython/gui_modules/preferences.py:1111
 #, fuzzy
 msgid "Add created map into layer tree"
 msgstr "Kartenebenen in eine Baumstruktur laden"
-#: ../gui/wxpython/gui_modules/menuform.py:715
-#: ../gui/wxpython/gui_modules/preferences.py:1079
+#: ../gui/wxpython/gui_modules/menuform.py:714
+#: ../gui/wxpython/gui_modules/preferences.py:1101
 msgid "Close dialog on finish"
 msgstr "Schließe den Dialog beim Beenden"
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/menuform.py:826
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "%s in die Zwischenablage kopiert"
 #: ../gui/wxpython/gui_modules/menuform.py:882
 #: ../gui/wxpython/gui_modules/menuform.py:895
-#: ../gui/wxpython/gui_modules/menuform.py:1275
+#: ../gui/wxpython/gui_modules/menuform.py:1377
 msgid "Required"
 msgstr "wird benötigt"
@@ -567,8 +566,8 @@
 msgid "Optional"
 msgstr "Optional"
-#: ../gui/wxpython/gui_modules/menuform.py:923 ../gui/wxpython/wxgui.py:310
-#: ../gui/wxpython/wxgui.py:400
+#: ../gui/wxpython/gui_modules/menuform.py:923 ../gui/wxpython/wxgui.py:308
+#: ../gui/wxpython/wxgui.py:398
 msgid "Command output"
 msgstr "Kommando Ausgabe"
@@ -580,51 +579,51 @@
 msgid "[multiple]"
 msgstr "[viele]"
-#: ../gui/wxpython/gui_modules/menuform.py:1043
+#: ../gui/wxpython/gui_modules/menuform.py:1054
 msgid "Valid range"
 msgstr "Gültiger Bereich"
-#: ../gui/wxpython/gui_modules/menuform.py:1198
+#: ../gui/wxpython/gui_modules/menuform.py:1253
 msgid "Transparent"
 msgstr "Transparent"
-#: ../gui/wxpython/gui_modules/menuform.py:1215
+#: ../gui/wxpython/gui_modules/menuform.py:1270
 #, python-format
 msgid "Choose %s"
 msgstr "Wähle %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1216
+#: ../gui/wxpython/gui_modules/menuform.py:1271
 #: ../gui/wxpython/gui_modules/menudata.py:26
 msgid "File"
 msgstr "Datei"
-#: ../gui/wxpython/gui_modules/menuform.py:1217
+#: ../gui/wxpython/gui_modules/menuform.py:1272
 #: ../gui/wxpython/gui_modules/location_wizard.py:137
 #: ../gui/wxpython/gui_modules/location_wizard.py:1076
 #: ../gui/wxpython/gui_modules/location_wizard.py:1154
 #: ../gui/wxpython/gui_modules/location_wizard.py:1246
-#: ../gui/wxpython/gui_modules/gdialogs.py:801
-#: ../gui/wxpython/gui_modules/gdialogs.py:811 ../gui/wxpython/gis_set.py:123
+#: ../gui/wxpython/gui_modules/gdialogs.py:802
+#: ../gui/wxpython/gui_modules/gdialogs.py:812 ../gui/wxpython/gis_set.py:123
 msgid "Browse"
 msgstr "Blättern"
-#: ../gui/wxpython/gui_modules/menuform.py:1477
+#: ../gui/wxpython/gui_modules/menuform.py:1560
 #, fuzzy, python-format
 msgid "Error in %s"
 msgstr "Fehler"
-#: ../gui/wxpython/gui_modules/menuform.py:1511
+#: ../gui/wxpython/gui_modules/menuform.py:1594
 #, python-format
 msgid "Unable to fetch interface description for command '%s'."
 msgstr ""
 "Kann die Schnittstellenbeschreibung für das Kommando nicht ermitteln %s."
-#: ../gui/wxpython/gui_modules/menuform.py:1595
+#: ../gui/wxpython/gui_modules/menuform.py:1678
 #, python-format
 msgid "Unable to parse command %s"
 msgstr "Kann das Kommando %s nicht parsen"
-#: ../gui/wxpython/gui_modules/menuform.py:1683
+#: ../gui/wxpython/gui_modules/menuform.py:1766
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "Syntax: %s <grass command>"
@@ -666,18 +665,18 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:2249
 #: ../gui/wxpython/gui_modules/location_wizard.py:2556
 #: ../gui/wxpython/gui_modules/gdialogs.py:144
-#: ../gui/wxpython/gui_modules/gdialogs.py:1000
-#: ../gui/wxpython/gui_modules/mapdisp.py:1138
-#: ../gui/wxpython/gui_modules/mapdisp.py:1769
-#: ../gui/wxpython/gui_modules/mapdisp.py:2718
-#: ../gui/wxpython/gui_modules/preferences.py:1501
+#: ../gui/wxpython/gui_modules/gdialogs.py:1001
+#: ../gui/wxpython/gui_modules/mapdisp.py:1160
+#: ../gui/wxpython/gui_modules/mapdisp.py:1791
+#: ../gui/wxpython/gui_modules/mapdisp.py:2743
+#: ../gui/wxpython/gui_modules/preferences.py:1523
 #: ../gui/wxpython/gui_modules/gcmd.py:59
 #: ../gui/wxpython/gui_modules/gcmd.py:82
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:406
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:431
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1224
-#: ../gui/wxpython/gui_modules/georect.py:885
-#: ../gui/wxpython/gui_modules/georect.py:922
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:409
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:441
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1234
+#: ../gui/wxpython/gui_modules/georect.py:893
+#: ../gui/wxpython/gui_modules/georect.py:930
 #: ../gui/wxpython/gui_modules/workspace.py:617
 #: ../gui/wxpython/gui_modules/dbm.py:188
 #: ../gui/wxpython/gui_modules/dbm.py:272
@@ -694,11 +693,12 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2554
 #: ../gui/wxpython/gui_modules/dbm.py:2561
 #: ../gui/wxpython/gui_modules/dbm.py:2599
+#: ../gui/wxpython/gui_modules/render.py:448
 #: ../gui/wxpython/gui_modules/vdigit.py:1895
 #: ../gui/wxpython/gui_modules/vdigit.py:2073
 #: ../gui/wxpython/gui_modules/vdigit.py:2097 ../gui/wxpython/gis_set.py:672
-#: ../gui/wxpython/wxgui.py:731 ../gui/wxpython/wxgui.py:863
-#: ../gui/wxpython/wxgui.py:872
+#: ../gui/wxpython/wxgui.py:734 ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:875
 msgid "Error"
 msgstr "Fehler"
@@ -1075,7 +1075,7 @@
 msgstr "Abfragen Vektor Daten"
 #: ../gui/wxpython/gui_modules/gdialogs.py:127
-#: ../gui/wxpython/gui_modules/menudata.py:1201
+#: ../gui/wxpython/gui_modules/menudata.py:1218
 #, fuzzy
 msgid "Create new vector map"
 msgstr "Vektor"
@@ -1139,7 +1139,7 @@
 msgstr "Name der Location:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:499
-#: ../gui/wxpython/gui_modules/preferences.py:960
+#: ../gui/wxpython/gui_modules/preferences.py:963
 msgid "Set font"
 msgstr ""
@@ -1172,82 +1172,82 @@
 msgstr "Karten auflisten:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:728
-#: ../gui/wxpython/gui_modules/gdialogs.py:1081
+#: ../gui/wxpython/gui_modules/gdialogs.py:1082
 #: ../gui/wxpython/gui_modules/dbm.py:959
 msgid "Select all"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gdialogs.py:729
-#: ../gui/wxpython/gui_modules/gdialogs.py:1082
+#: ../gui/wxpython/gui_modules/gdialogs.py:1083
 #: ../gui/wxpython/gui_modules/dbm.py:960
 msgid "Deselect all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:782
+#: ../gui/wxpython/gui_modules/gdialogs.py:783
 #, fuzzy
 msgid "Multiple import"
 msgstr "WMS Import"
-#: ../gui/wxpython/gui_modules/gdialogs.py:796
+#: ../gui/wxpython/gui_modules/gdialogs.py:797
 #, fuzzy
 msgid "Input DXF file"
 msgstr "Eingabe"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 #, fuzzy
 msgid "Choose DXF file:"
 msgstr "Wählen Sie bitte die EPSG-Code Datei:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:800
+#: ../gui/wxpython/gui_modules/gdialogs.py:801
 msgid "Choose DXF file to import"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:806
+#: ../gui/wxpython/gui_modules/gdialogs.py:807
 #, fuzzy
 msgid "Input directory"
 msgstr "Eingabe"
-#: ../gui/wxpython/gui_modules/gdialogs.py:807
+#: ../gui/wxpython/gui_modules/gdialogs.py:808
 #, fuzzy
 msgid "Choose directory:"
 msgstr "Wählen Sie das GRASS Datenverzeichnis "
-#: ../gui/wxpython/gui_modules/gdialogs.py:810
+#: ../gui/wxpython/gui_modules/gdialogs.py:811
 #, fuzzy
 msgid "Choose input directory"
-#: ../gui/wxpython/gui_modules/gdialogs.py:814
+#: ../gui/wxpython/gui_modules/gdialogs.py:815
 #, fuzzy
 msgid "Select file extension:"
 msgstr "Wählen Sie bitte eine Projektion"
-#: ../gui/wxpython/gui_modules/gdialogs.py:831
+#: ../gui/wxpython/gui_modules/gdialogs.py:832
 #, fuzzy
 msgid "Add imported layers into layer tree"
-#: ../gui/wxpython/gui_modules/gdialogs.py:839
+#: ../gui/wxpython/gui_modules/gdialogs.py:840
 #, fuzzy
 msgid "Close dialog"
 msgstr "Schließen"
-#: ../gui/wxpython/gui_modules/gdialogs.py:842
+#: ../gui/wxpython/gui_modules/gdialogs.py:843
 #, fuzzy
 msgid "&Import"
 msgstr "&Importieren"
-#: ../gui/wxpython/gui_modules/gdialogs.py:843
+#: ../gui/wxpython/gui_modules/gdialogs.py:844
 #, fuzzy
 msgid "Import selected layers"
 msgstr "Importieren"
-#: ../gui/wxpython/gui_modules/gdialogs.py:883
+#: ../gui/wxpython/gui_modules/gdialogs.py:884
 msgid " List of %s layers "
 msgstr "Karten auflisten "
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
 #, python-format
 msgid ""
 "File <%(file)s>: Unable to get list of DXF layers.\n"
@@ -1255,7 +1255,7 @@
 "%(details)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1044
+#: ../gui/wxpython/gui_modules/gdialogs.py:1045
 #: ../gui/wxpython/gui_modules/dbm.py:2019
 #: ../gui/wxpython/gui_modules/dbm.py:2120
 #: ../gui/wxpython/gui_modules/dbm.py:2356
@@ -1268,76 +1268,76 @@
 msgid "Layer"
 msgstr "Layer %d"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1045
+#: ../gui/wxpython/gui_modules/gdialogs.py:1046
 #, fuzzy
 msgid "Layer name"
 msgstr "Layer %d Name"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1046
+#: ../gui/wxpython/gui_modules/gdialogs.py:1047
 #, fuzzy
 msgid "Output vector map name"
 msgstr "Vektor Name"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1128
+#: ../gui/wxpython/gui_modules/gdialogs.py:1129
 #, fuzzy
 msgid "Set Map Layer Opacity"
 msgstr "Layer %d"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1152
+#: ../gui/wxpython/gui_modules/gdialogs.py:1153
 #, fuzzy
 msgid "transparent"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1155
+#: ../gui/wxpython/gui_modules/gdialogs.py:1156
 msgid "opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1137
-#: ../gui/wxpython/gui_modules/mapdisp.py:1768
+#: ../gui/wxpython/gui_modules/mapdisp.py:1159
+#: ../gui/wxpython/gui_modules/mapdisp.py:1790
 msgid "No vector map selected for editing."
 msgstr "Keine Vektorkarte zum bearbeiten ausgewählt."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1285
-#: ../gui/wxpython/gui_modules/mapdisp.py:1292
+#: ../gui/wxpython/gui_modules/mapdisp.py:1307
+#: ../gui/wxpython/gui_modules/mapdisp.py:1314
 msgid "Update categories"
 msgstr "Aktualisiere die Kategorien"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1886
+#: ../gui/wxpython/gui_modules/mapdisp.py:1908
 msgid "Z bulk-labeling dialog"
 msgstr "Dialog \"Z-Bulk-Label\""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2353
+#: ../gui/wxpython/gui_modules/mapdisp.py:2378
 msgid "Zoom to saved region extents"
 msgstr "Auf die Ausdehnung der gespeicherten Region vergrößern"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2404
+#: ../gui/wxpython/gui_modules/mapdisp.py:2429
 #, python-format
 msgid "Region file <%s> already exists. Do you want to overwrite it?"
 msgstr "Die Regions-Datei <%s> existiert? Soll sie überschrieben werden?"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2406
+#: ../gui/wxpython/gui_modules/mapdisp.py:2431
 #: ../gui/wxpython/gui_modules/workspace.py:633
 msgid "Warning"
 msgstr "Warnung"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2467
+#: ../gui/wxpython/gui_modules/mapdisp.py:2492
 #, fuzzy
 msgid "GRASS GIS - Map display"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2541
+#: ../gui/wxpython/gui_modules/mapdisp.py:2566
 msgid "Render"
 msgstr "Rendern"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2544
+#: ../gui/wxpython/gui_modules/mapdisp.py:2569
 msgid "Enable/disable auto-rendering"
 msgstr "Auto-Rendering ein-/ausschalten"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2547
+#: ../gui/wxpython/gui_modules/mapdisp.py:2572
 msgid "Show computational extent"
 msgstr "Zeige die  berechnete Ausdehnung"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2552
+#: ../gui/wxpython/gui_modules/mapdisp.py:2577
 #, fuzzy
 msgid ""
 "Show/hide computational region extent (set with g.region). Display region "
@@ -1345,33 +1345,33 @@
 "inside a display region as a red box)."
 msgstr "Darstellung Darstellung."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2560
-#: ../gui/wxpython/gui_modules/preferences.py:1020
+#: ../gui/wxpython/gui_modules/mapdisp.py:2585
+#: ../gui/wxpython/gui_modules/preferences.py:1042
 #, fuzzy
 msgid "Constrain display resolution to computational settings"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2564
+#: ../gui/wxpython/gui_modules/mapdisp.py:2589
 #, fuzzy
 msgid ""
 "Constrain display resolution to computational region settings. Default value "
 "for new map displays can be set up in 'User GUI settings' dialog."
 msgstr "Darstellung."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2663
+#: ../gui/wxpython/gui_modules/mapdisp.py:2688
 msgid "Map Toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2677
+#: ../gui/wxpython/gui_modules/mapdisp.py:2702
 #, fuzzy
 msgid "Vector digitizer toolbar"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2694
+#: ../gui/wxpython/gui_modules/mapdisp.py:2719
 msgid "Georectification toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2706
+#: ../gui/wxpython/gui_modules/mapdisp.py:2731
 msgid ""
 "Unable to start Nviz. The GLCanvas class has not been included with this "
@@ -1380,7 +1380,7 @@
 "Details: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2711
+#: ../gui/wxpython/gui_modules/mapdisp.py:2736
 msgid ""
 "Unable to start Nviz. Python extension for Nviz was not found or loaded "
@@ -1389,50 +1389,50 @@
 "Details: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2742
+#: ../gui/wxpython/gui_modules/mapdisp.py:2767
 #, fuzzy
 msgid "Please wait, loading data..."
 msgstr "Daten."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2772
+#: ../gui/wxpython/gui_modules/mapdisp.py:2797
 msgid "Nviz toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3260
+#: ../gui/wxpython/gui_modules/mapdisp.py:3289
 msgid "Page setup"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3264
+#: ../gui/wxpython/gui_modules/mapdisp.py:3293
 #, fuzzy
 msgid "Print preview"
 msgstr "Drucke"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3358
+#: ../gui/wxpython/gui_modules/mapdisp.py:3387
 msgid "No map layer selected for querying."
 msgstr "Es wurde keine Kartenebene für die Abfrage ausgewählt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3359
-#: ../gui/wxpython/gui_modules/mapdisp.py:3443
-#: ../gui/wxpython/gui_modules/dbm.py:2784 ../gui/wxpython/wxgui.py:1102
-#: ../gui/wxpython/wxgui.py:1470
+#: ../gui/wxpython/gui_modules/mapdisp.py:3388
+#: ../gui/wxpython/gui_modules/mapdisp.py:3472
+#: ../gui/wxpython/gui_modules/dbm.py:2784 ../gui/wxpython/wxgui.py:1106
+#: ../gui/wxpython/wxgui.py:1474
 msgid "Message"
 msgstr "Nachricht"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3442
+#: ../gui/wxpython/gui_modules/mapdisp.py:3471
 msgid "No vector map selected for querying."
 msgstr "Es wurde keine Vektorkarte für die Abfrage ausgewählt."
-#: ../gui/wxpython/gui_modules/mapdisp.py:3504
+#: ../gui/wxpython/gui_modules/mapdisp.py:3534
 #, fuzzy
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Abfrage Raster Vektor Darstellung"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3512
+#: ../gui/wxpython/gui_modules/mapdisp.py:3542
 #, fuzzy
 msgid "Query vector map (edit mode)"
 msgstr "Abfrage Vektor"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3626
+#: ../gui/wxpython/gui_modules/mapdisp.py:3656
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -1441,131 +1441,131 @@
 "Klicken und ziehen mit der linken Maustaste um zu messen.%szum Löschen, "
 "Doppelklick mit der linken Maustaste."
-#: ../gui/wxpython/gui_modules/mapdisp.py:3633
+#: ../gui/wxpython/gui_modules/mapdisp.py:3663
 #, fuzzy
 msgid "Measuring distance"
 msgstr "gemessene Strecke:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3637
+#: ../gui/wxpython/gui_modules/mapdisp.py:3667
 msgid "Measuring distance:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3795
+#: ../gui/wxpython/gui_modules/mapdisp.py:3825
 msgid "Scale and North arrow"
 msgstr "Maßstab und Nordpfeil"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3801
+#: ../gui/wxpython/gui_modules/mapdisp.py:3831
 msgid "Show/hide scale and North arrow"
 msgstr "Maßstab und Nordpfeil anzeigen/verbergen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3802
+#: ../gui/wxpython/gui_modules/mapdisp.py:3832
 msgid "scale object"
 msgstr "Maßstabs Objekt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3828
+#: ../gui/wxpython/gui_modules/mapdisp.py:3858
 msgid "Show/hide legend"
 msgstr "Legende anzeigen/verbergen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3829
+#: ../gui/wxpython/gui_modules/mapdisp.py:3859
 msgid "legend object"
 msgstr "Legendenobjekt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3894
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:266
+#: ../gui/wxpython/gui_modules/mapdisp.py:3924
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:267
 msgid "Zoom to selected map"
 msgstr "Auf die gewählte Karte zoomen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3898
+#: ../gui/wxpython/gui_modules/mapdisp.py:3928
 msgid "Zoom to computational region (set with g.region)"
 msgstr ""
 "vergrößen auf den berechneten Bereich (zu setzen des Bereichs g.region "
 "verwenden)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3902
+#: ../gui/wxpython/gui_modules/mapdisp.py:3932
 msgstr "Auf die Standardregion vergrößern"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3906
+#: ../gui/wxpython/gui_modules/mapdisp.py:3936
 msgstr "Auf die gespeicherte Region vergrößern"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3910
+#: ../gui/wxpython/gui_modules/mapdisp.py:3940
 msgid "Set computational region from display"
 msgstr "Zu berechnende Region aus der aktuellen Darstellung übernehmen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3914
+#: ../gui/wxpython/gui_modules/mapdisp.py:3944
 #, fuzzy
 msgid "Save display geometry to named region"
-#: ../gui/wxpython/gui_modules/preferences.py:359
+#: ../gui/wxpython/gui_modules/preferences.py:362
 msgid "Segment break"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:491
+#: ../gui/wxpython/gui_modules/preferences.py:494
 msgid "Collapse all except PERMANENT and current"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:492
+#: ../gui/wxpython/gui_modules/preferences.py:495
 msgid "Collapse all except PERMANENT"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:493
+#: ../gui/wxpython/gui_modules/preferences.py:496
 msgid "Collapse all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:494
+#: ../gui/wxpython/gui_modules/preferences.py:497
 msgid "Expand all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:495
+#: ../gui/wxpython/gui_modules/preferences.py:498
 #: ../gui/wxpython/gui_modules/dbm.py:951
 msgid "Edit selected record"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:496
+#: ../gui/wxpython/gui_modules/preferences.py:499
 #, fuzzy
 msgid "Display selected"
-#: ../gui/wxpython/gui_modules/preferences.py:521
+#: ../gui/wxpython/gui_modules/preferences.py:524
 msgid "box"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:522
+#: ../gui/wxpython/gui_modules/preferences.py:525
 msgid "sphere"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:523
+#: ../gui/wxpython/gui_modules/preferences.py:526
 msgid "cube"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:524
+#: ../gui/wxpython/gui_modules/preferences.py:527
 msgid "diamond"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:525
+#: ../gui/wxpython/gui_modules/preferences.py:528
 msgid "dtree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:526
+#: ../gui/wxpython/gui_modules/preferences.py:529
 msgid "ctree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:527
+#: ../gui/wxpython/gui_modules/preferences.py:530
 #, fuzzy
 msgid "aster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/preferences.py:528
+#: ../gui/wxpython/gui_modules/preferences.py:531
 msgid "gyro"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:529
+#: ../gui/wxpython/gui_modules/preferences.py:532
 msgid "histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:596
+#: ../gui/wxpython/gui_modules/preferences.py:599
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
@@ -1576,11 +1576,11 @@
 "\n"
 " Linie"
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:629
 msgid "Uknown settings file location."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:660
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -1588,32 +1588,32 @@
 "Details: %(detail)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:756
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Unable to set "
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:791
+#: ../gui/wxpython/gui_modules/preferences.py:794
 msgid "User GUI settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:815
+#: ../gui/wxpython/gui_modules/preferences.py:818
 msgid "Set to default"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:823
+#: ../gui/wxpython/gui_modules/preferences.py:826
 msgid "Revert settings to default and apply changes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:825
-#: ../gui/wxpython/gui_modules/georect.py:1541
+#: ../gui/wxpython/gui_modules/preferences.py:828
+#: ../gui/wxpython/gui_modules/georect.py:1551
 #: ../gui/wxpython/gui_modules/profile.py:990
 #: ../gui/wxpython/gui_modules/profile.py:1335
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1269
 msgid "Apply changes for the current session"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:827
-#: ../gui/wxpython/gui_modules/georect.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:830
+#: ../gui/wxpython/gui_modules/georect.py:1553
 #: ../gui/wxpython/gui_modules/profile.py:992
 #: ../gui/wxpython/gui_modules/profile.py:1337
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1271
@@ -1622,8 +1622,8 @@
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr "Speichern"
-#: ../gui/wxpython/gui_modules/preferences.py:830
-#: ../gui/wxpython/gui_modules/georect.py:1546
+#: ../gui/wxpython/gui_modules/preferences.py:833
+#: ../gui/wxpython/gui_modules/georect.py:1556
 #: ../gui/wxpython/gui_modules/profile.py:995
 #: ../gui/wxpython/gui_modules/profile.py:1340
 #: ../gui/wxpython/gui_modules/vdigit.py:1075
@@ -1631,243 +1631,249 @@
 msgid "Close dialog and ignore changes"
 msgstr "Schließen"
-#: ../gui/wxpython/gui_modules/preferences.py:858
+#: ../gui/wxpython/gui_modules/preferences.py:861
 #: ../gui/wxpython/gui_modules/vdigit.py:1136
 #: ../gui/wxpython/gui_modules/nviz_tools.py:956
 msgid "General"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:861
+#: ../gui/wxpython/gui_modules/preferences.py:864
 msgid "General settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:872
+#: ../gui/wxpython/gui_modules/preferences.py:875
 msgid "Element list:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:894
+#: ../gui/wxpython/gui_modules/preferences.py:897
 #, fuzzy
 msgid "Save current window layout as default"
 msgstr "Speichern"
-#: ../gui/wxpython/gui_modules/preferences.py:897
+#: ../gui/wxpython/gui_modules/preferences.py:900
 #, fuzzy
 msgid ""
 "Save current position and size of Layer Manager window and opened Map "
 "Display window(s) and use as default for next sessions."
 msgstr "Layer %d Darstellung."
-#: ../gui/wxpython/gui_modules/preferences.py:910
+#: ../gui/wxpython/gui_modules/preferences.py:913
 #, fuzzy
 msgid "Layer Manager settings"
 msgstr "Layer %d"
-#: ../gui/wxpython/gui_modules/preferences.py:922
+#: ../gui/wxpython/gui_modules/preferences.py:925
 #, fuzzy
 msgid "Ask when removing map layer from layer tree"
-#: ../gui/wxpython/gui_modules/preferences.py:940
+#: ../gui/wxpython/gui_modules/preferences.py:943
 #: ../gui/wxpython/gui_modules/vdigit.py:1143
 #, fuzzy
 msgid "Display"
-#: ../gui/wxpython/gui_modules/preferences.py:944
-#: ../gui/wxpython/gui_modules/preferences.py:1560
+#: ../gui/wxpython/gui_modules/preferences.py:947
+#: ../gui/wxpython/gui_modules/preferences.py:1582
 #: ../gui/wxpython/gui_modules/profile.py:925
 #, fuzzy
 msgid "Font settings"
 msgstr "Schriftart"
-#: ../gui/wxpython/gui_modules/preferences.py:955
+#: ../gui/wxpython/gui_modules/preferences.py:958
 msgid "Default font for GRASS displays:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:969
+#: ../gui/wxpython/gui_modules/preferences.py:972
 #, fuzzy
 msgid "Default display settings"
-#: ../gui/wxpython/gui_modules/preferences.py:980
+#: ../gui/wxpython/gui_modules/preferences.py:983
 #, fuzzy
 msgid "Display driver:"
 msgstr "Darstellung:"
-#: ../gui/wxpython/gui_modules/preferences.py:1000
+#: ../gui/wxpython/gui_modules/preferences.py:1003
 #, fuzzy
 msgid "Statusbar mode:"
 msgstr "Datumscode:"
-#: ../gui/wxpython/gui_modules/preferences.py:1033
+#: ../gui/wxpython/gui_modules/preferences.py:1023
+#: ../gui/wxpython/gui_modules/nviz_tools.py:962
 #, fuzzy
+msgid "Background color:"
+msgstr " Hintergrundfarbe: "
+#: ../gui/wxpython/gui_modules/preferences.py:1055
+#, fuzzy
 msgid "Enable auto-rendering"
-#: ../gui/wxpython/gui_modules/preferences.py:1054
+#: ../gui/wxpython/gui_modules/preferences.py:1076
 msgid "Command"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1057
+#: ../gui/wxpython/gui_modules/preferences.py:1079
 msgid "Command dialog settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1069
+#: ../gui/wxpython/gui_modules/preferences.py:1091
 msgid "Allow output files to overwrite existing files"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1099
+#: ../gui/wxpython/gui_modules/preferences.py:1121
 msgid "Verbosity level:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1118
+#: ../gui/wxpython/gui_modules/preferences.py:1140
 #, fuzzy
 msgid "Raster settings"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/preferences.py:1129
+#: ../gui/wxpython/gui_modules/preferences.py:1151
 msgid "Make null cells opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1143
+#: ../gui/wxpython/gui_modules/preferences.py:1165
 #, fuzzy
 msgid "Vector settings"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/preferences.py:1149
+#: ../gui/wxpython/gui_modules/preferences.py:1171
 #: ../gui/wxpython/gui_modules/nviz_tools.py:569
 #, fuzzy
 msgid "Display:"
-#: ../gui/wxpython/gui_modules/preferences.py:1171
+#: ../gui/wxpython/gui_modules/preferences.py:1193
 #: ../gui/wxpython/gui_modules/vdigit.py:1364
 #, fuzzy
 msgid "Attributes"
 msgstr "Attribute"
-#: ../gui/wxpython/gui_modules/preferences.py:1179
+#: ../gui/wxpython/gui_modules/preferences.py:1201
 msgid "Highlighting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1195
+#: ../gui/wxpython/gui_modules/preferences.py:1217
 #, fuzzy
 msgid "Line width (in pixels)"
 msgstr "Linie"
-#: ../gui/wxpython/gui_modules/preferences.py:1218
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Data browser"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1223
+#: ../gui/wxpython/gui_modules/preferences.py:1245
 msgid "Left mouse double click"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1234
+#: ../gui/wxpython/gui_modules/preferences.py:1256
 msgid "Encoding"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1245
+#: ../gui/wxpython/gui_modules/preferences.py:1267
 #, fuzzy
 msgid "Ask when deleting data record(s) from table"
 msgstr "Daten"
-#: ../gui/wxpython/gui_modules/preferences.py:1266
+#: ../gui/wxpython/gui_modules/preferences.py:1288
 #, fuzzy
-#: ../gui/wxpython/gui_modules/preferences.py:1273
+#: ../gui/wxpython/gui_modules/preferences.py:1295
 #: ../gui/wxpython/gui_modules/dbm.py:2142
 #: ../gui/wxpython/gui_modules/dbm.py:2166
 #: ../gui/wxpython/gui_modules/dbm.py:2382
 msgid "Key column"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1299
+#: ../gui/wxpython/gui_modules/preferences.py:1321
 #: ../gui/wxpython/gui_modules/menudata.py:27
 #, fuzzy
 msgid "Workspace"
 msgstr "Projekt"
-#: ../gui/wxpython/gui_modules/preferences.py:1302
+#: ../gui/wxpython/gui_modules/preferences.py:1324
 #, fuzzy
 msgid "Loading workspace"
 msgstr "Speichere Projekt"
-#: ../gui/wxpython/gui_modules/preferences.py:1314
+#: ../gui/wxpython/gui_modules/preferences.py:1336
 #, fuzzy
 msgid "Suppress positioning Map Display Window(s)"
-#: ../gui/wxpython/gui_modules/preferences.py:1325
+#: ../gui/wxpython/gui_modules/preferences.py:1347
 #, fuzzy
 msgid "Suppress positioning Layer Manager window"
 msgstr "Layer %d"
-#: ../gui/wxpython/gui_modules/preferences.py:1343
+#: ../gui/wxpython/gui_modules/preferences.py:1365
 #: ../gui/wxpython/gui_modules/dbm.py:589
 #, fuzzy
 msgid "Advanced"
 msgstr "Fortgeschritten"
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 #, fuzzy
 msgid "Advanced settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1358
+#: ../gui/wxpython/gui_modules/preferences.py:1380
 msgid "Place where to store settings:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1379
+#: ../gui/wxpython/gui_modules/preferences.py:1401
 #, fuzzy
 msgid "Icon theme:"
 msgstr "Icon:"
-#: ../gui/wxpython/gui_modules/preferences.py:1396
+#: ../gui/wxpython/gui_modules/preferences.py:1418
 msgid "Note: Requires GUI restart."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1416
+#: ../gui/wxpython/gui_modules/preferences.py:1438
 #, fuzzy
 msgid "Select default display font"
-#: ../gui/wxpython/gui_modules/preferences.py:1440
+#: ../gui/wxpython/gui_modules/preferences.py:1462
 msgid "Settings saved to file '%s'."
 msgstr "Einstellungen."
-#: ../gui/wxpython/gui_modules/preferences.py:1500
+#: ../gui/wxpython/gui_modules/preferences.py:1522
 msgid "Key column cannot be empty string."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1567
+#: ../gui/wxpython/gui_modules/preferences.py:1589
 #, fuzzy
 msgid "Select font:"
-#: ../gui/wxpython/gui_modules/preferences.py:1666
+#: ../gui/wxpython/gui_modules/preferences.py:1688
 msgid "Set/unset access to mapsets in current location"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1680
+#: ../gui/wxpython/gui_modules/preferences.py:1702
 #, python-format
 msgid ""
 "Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
 "and current mapset are always accessible."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1747
+#: ../gui/wxpython/gui_modules/preferences.py:1769
 msgid "Mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1748
+#: ../gui/wxpython/gui_modules/preferences.py:1770
 msgid "Owner"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1749
+#: ../gui/wxpython/gui_modules/preferences.py:1771
 msgid "Group"
 msgstr ""
@@ -1918,68 +1924,68 @@
 msgid "Unable to exectute command: '%s'"
-#: ../gui/wxpython/gui_modules/colorrules.py:92
+#: ../gui/wxpython/gui_modules/colorrules.py:94
 #, fuzzy
 msgid "Create new color table for raster map"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/colorrules.py:94
-#: ../gui/wxpython/gui_modules/colorrules.py:388
+#: ../gui/wxpython/gui_modules/colorrules.py:96
+#: ../gui/wxpython/gui_modules/colorrules.py:389
 #, fuzzy
 msgid "Enter raster cat values or percents"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/colorrules.py:96
+#: ../gui/wxpython/gui_modules/colorrules.py:98
 #, fuzzy
 msgid "Create new color table for vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/colorrules.py:98
+#: ../gui/wxpython/gui_modules/colorrules.py:100
 #, fuzzy
 msgid "Enter vector attribute values or ranges (n or n1 to n2)"
 msgstr "Vektor"
+#: ../gui/wxpython/gui_modules/colorrules.py:111
+#, fuzzy
+msgid "Select raster map:"
+msgstr "Raster:"
 #: ../gui/wxpython/gui_modules/colorrules.py:113
 #, fuzzy
+msgid "Select vector map:"
+msgstr "Vektor:"
+#: ../gui/wxpython/gui_modules/colorrules.py:122
+#, fuzzy
 msgid "replace existing color table"
 msgstr "Farbe"
-#: ../gui/wxpython/gui_modules/colorrules.py:119
+#: ../gui/wxpython/gui_modules/colorrules.py:128
 #, fuzzy
 msgid "Layer:"
 msgstr "Layer %d:"
-#: ../gui/wxpython/gui_modules/colorrules.py:121
+#: ../gui/wxpython/gui_modules/colorrules.py:130
 #, fuzzy
 msgid "Attribute column:"
 msgstr "Datenbank, Attributtabelle"
-#: ../gui/wxpython/gui_modules/colorrules.py:123
+#: ../gui/wxpython/gui_modules/colorrules.py:132
 #, fuzzy
 msgid "RGB color column:"
 msgstr "Farbe:"
-#: ../gui/wxpython/gui_modules/colorrules.py:152
+#: ../gui/wxpython/gui_modules/colorrules.py:161
 #, fuzzy
 msgid "Preview"
 msgstr "Vorschau"
-#: ../gui/wxpython/gui_modules/colorrules.py:200
-#, fuzzy
-msgid "Select raster map:"
-msgstr "Raster:"
-#: ../gui/wxpython/gui_modules/colorrules.py:202
-#, fuzzy
-msgid "Select vector map:"
-msgstr "Vektor:"
-#: ../gui/wxpython/gui_modules/colorrules.py:391
+#: ../gui/wxpython/gui_modules/colorrules.py:392
-msgid "Enter raster cat values or percents (range = %d-%d)"
+msgid "Enter raster cat values or percents (range = %(min)d-%(max)d)"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/colorrules.py:463
+#: ../gui/wxpython/gui_modules/colorrules.py:468
 #, fuzzy
 msgid "Please select attribute column and RGB color column first"
 msgstr "Farbe"
@@ -2070,283 +2076,288 @@
 msgid "Map Layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:251
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:252
 msgid "Remove"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:256
 #: ../gui/wxpython/gui_modules/menudata.py:374
 #, fuzzy
 msgid "Rename"
 msgstr "Nenne Karten um"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:262
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:263
 msgid "Change opacity level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:264
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:265
 msgid "Properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:269
 #, fuzzy
 msgid "Set computational region from selected map"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:281
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:282
 #, fuzzy
 msgid "Show attribute data"
 msgstr "Daten"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:284
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
 msgid "Start editing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:286
 msgid "Stop editing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:300
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:301
 #, fuzzy
 msgid "Use as background vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:326
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:342
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:327
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
 msgid "Metadata"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:333
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:334
 #, fuzzy
 msgid "Zoom to selected map (ignore NULLs)"
 msgstr "Zoom"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:335
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
 #, fuzzy
 msgid "Set computational region from selected map (ignore NULLs)"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:338
-#: ../gui/wxpython/gui_modules/menudata.py:1690
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:339
+#, fuzzy
+msgid "Set color table"
+msgstr "Farbtabellen"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:341
+#: ../gui/wxpython/gui_modules/menudata.py:1723
 msgid "Histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:340
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:343
 #: ../gui/wxpython/gui_modules/profile.py:1109
 msgid "Profile"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:348
 msgid "Nviz properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:404
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:407
 #, fuzzy
 msgid "Unable to create profile of raster map."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:429
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:439
 #, fuzzy
 msgid "Unable to display histogram of raster map."
 msgstr "Darstellung Raster."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:514
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:524
 #, python-format
 msgid "Set opacity <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:588
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:598
 #, fuzzy
 msgid "Layer group:"
 msgstr "Layer %d:"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:593
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1144
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:603
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1154
 #, fuzzy
 msgid "Click to edit layer settings"
 msgstr "3D Einstellungen zu verbergen"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
-#: ../gui/wxpython/gui_modules/georect.py:302
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:650
+#: ../gui/wxpython/gui_modules/georect.py:304
 #, fuzzy
 msgid "raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:643
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:646
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:649
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:652
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:655
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:658
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:661
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:664
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:667
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:670
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:673
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:676
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:679
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:653
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:656
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:659
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:662
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:665
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:668
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:671
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:674
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:677
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:680
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:683
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:686
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:689
 msgid "(double click to set properties)"
 msgstr ""
 #, fuzzy
 msgid "3d raster"
 msgstr "Raster"
 msgid "RGB"
 msgstr ""
 msgid "HIS"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:738
+#: ../gui/wxpython/gui_modules/menudata.py:744
 #, fuzzy
 msgid "Shaded relief"
 msgstr "Reliefschattierungen"
 #, fuzzy
 msgid "raster cell numbers"
 msgstr "Raster"
 #, fuzzy
 msgid "raster flow arrows"
 msgstr "Raster"
 #, fuzzy
 msgid "vector"
 msgstr "Vektor"
 msgid "thematic map"
 msgstr ""
 msgid "thematic charts"
 msgstr ""
 msgid "grid"
 msgstr ""
 msgid "geodesic line"
 msgstr ""
 msgid "rhumbline"
 msgstr ""
 #, fuzzy
 msgid "vector labels"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:953
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:963
 #, fuzzy
 msgid "Please wait, updating data..."
 msgstr "Daten."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1223
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1233
 msgid "Map <%s> not found."
 msgstr "Datei nicht gefunden"
-#: ../gui/wxpython/gui_modules/toolbars.py:697
+#: ../gui/wxpython/gui_modules/toolbars.py:703
 #, fuzzy
 msgid "Duplicate attributes"
-#: ../gui/wxpython/gui_modules/toolbars.py:764
+#: ../gui/wxpython/gui_modules/toolbars.py:770
 msgid "Digitization settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:774
+#: ../gui/wxpython/gui_modules/toolbars.py:780
 #, fuzzy
 msgid "Copy features from (background) vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/gui_modules/toolbars.py:788
 #, fuzzy
 msgid "Flip selected lines/boundaries"
 msgstr "Zeilen Umrandung"
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:796
 #, fuzzy
 msgid "Merge selected lines/boundaries"
-#: ../gui/wxpython/gui_modules/toolbars.py:798
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 #, fuzzy
 msgid "Break selected lines/boundaries at intersection"
 msgstr "Fläche:\n"
-#: ../gui/wxpython/gui_modules/toolbars.py:806
+#: ../gui/wxpython/gui_modules/toolbars.py:812
 #, fuzzy
 msgid "Snap selected lines/boundaries (only to nodes)"
-#: ../gui/wxpython/gui_modules/toolbars.py:814
+#: ../gui/wxpython/gui_modules/toolbars.py:820
 #, fuzzy
 msgid "Connect selected lines/boundaries"
-#: ../gui/wxpython/gui_modules/toolbars.py:822
+#: ../gui/wxpython/gui_modules/toolbars.py:828
 #, fuzzy
 msgid "Query features"
 msgstr "Abfrage"
-#: ../gui/wxpython/gui_modules/toolbars.py:830
+#: ../gui/wxpython/gui_modules/toolbars.py:836
 #, fuzzy
 msgid "Z bulk-labeling of 3D lines"
 msgstr "Zeilen"
-#: ../gui/wxpython/gui_modules/toolbars.py:838
+#: ../gui/wxpython/gui_modules/toolbars.py:844
 #, fuzzy
 msgid "Feature type conversion"
 msgstr "Kartentyp-Konvertierungen"
-#: ../gui/wxpython/gui_modules/toolbars.py:1007
-#: ../gui/wxpython/gui_modules/toolbars.py:1099
-#: ../gui/wxpython/gui_modules/toolbars.py:1172
+#: ../gui/wxpython/gui_modules/toolbars.py:1013
+#: ../gui/wxpython/gui_modules/toolbars.py:1105
+#: ../gui/wxpython/gui_modules/toolbars.py:1178
 #, fuzzy
 msgid "Select vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/toolbars.py:1045
+#: ../gui/wxpython/gui_modules/toolbars.py:1051
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/toolbars.py:1067
+#: ../gui/wxpython/gui_modules/toolbars.py:1073
 #, fuzzy
 msgid "Digitize"
 msgstr "Digitalisieren"
-#: ../gui/wxpython/gui_modules/toolbars.py:1105
+#: ../gui/wxpython/gui_modules/toolbars.py:1111
 msgid "Do you want to save changes in vector map <%s>?"
 msgstr "Vektor?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
+#: ../gui/wxpython/gui_modules/toolbars.py:1113
 #, fuzzy
 msgid "Save changes?"
 msgstr "Speichern?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1114
+#: ../gui/wxpython/gui_modules/toolbars.py:1120
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/toolbars.py:1178
-#: ../gui/wxpython/gui_modules/toolbars.py:1183
+#: ../gui/wxpython/gui_modules/toolbars.py:1184
+#: ../gui/wxpython/gui_modules/toolbars.py:1189
 #, fuzzy
 msgid "New vector map"
 msgstr "Vektor"
@@ -2357,162 +2368,162 @@
 msgid "GRASS %s Map Calculator"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:107
+#: ../gui/wxpython/gui_modules/georect.py:109
 msgid "Setup for georectification"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:137
-#: ../gui/wxpython/gui_modules/georect.py:140
+#: ../gui/wxpython/gui_modules/georect.py:139
+#: ../gui/wxpython/gui_modules/georect.py:142
 msgid "Georectifying setup canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:175
+#: ../gui/wxpython/gui_modules/georect.py:177
 #, fuzzy
 msgid "Set ground control points (GCPs)"
 msgstr "Punkte"
-#: ../gui/wxpython/gui_modules/georect.py:274
+#: ../gui/wxpython/gui_modules/georect.py:276
 #, fuzzy
 msgid "Select map type and location/mapset"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/georect.py:301
+#: ../gui/wxpython/gui_modules/georect.py:303
 #, fuzzy
 msgid "Map type to georectify"
-#: ../gui/wxpython/gui_modules/georect.py:308
+#: ../gui/wxpython/gui_modules/georect.py:310
 #, fuzzy
 msgid "Select source location:"
 msgstr "Löschen"
-#: ../gui/wxpython/gui_modules/georect.py:319
+#: ../gui/wxpython/gui_modules/georect.py:321
 #, fuzzy
 msgid "Select source mapset:"
 msgstr "Löschen"
-#: ../gui/wxpython/gui_modules/georect.py:373
+#: ../gui/wxpython/gui_modules/georect.py:375
 msgid "You must select a valid location before selecting a mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:384
+#: ../gui/wxpython/gui_modules/georect.py:386
 msgid "You must select a valid location and mapset in order to continue"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:401
+#: ../gui/wxpython/gui_modules/georect.py:403
 msgid "Select image/map group to georectify"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:420
+#: ../gui/wxpython/gui_modules/georect.py:422
 #, fuzzy
 msgid "Select group:"
-#: ../gui/wxpython/gui_modules/georect.py:431
+#: ../gui/wxpython/gui_modules/georect.py:433
 msgid "Create group if none exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:434
+#: ../gui/wxpython/gui_modules/georect.py:436
 #, fuzzy
 msgid "Create/edit group..."
 msgstr "2. Erzeuge/bearbeite Gruppe"
-#: ../gui/wxpython/gui_modules/georect.py:440
+#: ../gui/wxpython/gui_modules/georect.py:442
 msgid "Extension for output maps:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:491
+#: ../gui/wxpython/gui_modules/georect.py:493
 msgid "You must select a valid image/map group in order to continue"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:496
+#: ../gui/wxpython/gui_modules/georect.py:498
 #, fuzzy
 msgid "You must enter an map name extension in order to continue"
 msgstr "Name"
-#: ../gui/wxpython/gui_modules/georect.py:541
+#: ../gui/wxpython/gui_modules/georect.py:543
 #, fuzzy
 msgid "Select image/map to display for ground control point (GCP) creation"
-#: ../gui/wxpython/gui_modules/georect.py:549
+#: ../gui/wxpython/gui_modules/georect.py:551
 #, fuzzy
 msgid "Select display image/map:"
-#: ../gui/wxpython/gui_modules/georect.py:581
+#: ../gui/wxpython/gui_modules/georect.py:583
 msgid "You must select a valid image/map in order to continue"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:605
+#: ../gui/wxpython/gui_modules/georect.py:607
 #, fuzzy
 msgid "Create & manage ground control points"
 msgstr "Punkte"
-#: ../gui/wxpython/gui_modules/georect.py:699
+#: ../gui/wxpython/gui_modules/georect.py:701
 #, fuzzy
 msgid "Select rectification method for rasters"
 msgstr "Entzerrungsmethode für Rasterkarten auswählen"
-#: ../gui/wxpython/gui_modules/georect.py:700
+#: ../gui/wxpython/gui_modules/georect.py:702
 #, fuzzy
 msgid "1st order"
 msgstr "Erste Ordnung"
 #, fuzzy
 msgid "2nd order"
 msgstr "Zweite Ordnung"
 #, fuzzy
 msgid "3rd order"
 msgstr "Dritte Ordnung"
-#: ../gui/wxpython/gui_modules/georect.py:706
+#: ../gui/wxpython/gui_modules/georect.py:708
 #, fuzzy
 msgid "clip to computational region in target location"
 msgstr ""
 "verwenden)"
-#: ../gui/wxpython/gui_modules/georect.py:711
+#: ../gui/wxpython/gui_modules/georect.py:713
 msgid "Ground Control Points"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:777
+#: ../gui/wxpython/gui_modules/georect.py:779
 msgid "At least %d GCPs required. Operation cancelled."
 msgstr "benötigt."
-#: ../gui/wxpython/gui_modules/georect.py:778
+#: ../gui/wxpython/gui_modules/georect.py:780
 #, fuzzy
 msgid "Delete GCP"
 msgstr "Löschen"
-#: ../gui/wxpython/gui_modules/georect.py:879
+#: ../gui/wxpython/gui_modules/georect.py:887
 #, python-format
 msgid "POINTS file <%s> saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:880
+#: ../gui/wxpython/gui_modules/georect.py:888
 msgid "POINTS file saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:883
+#: ../gui/wxpython/gui_modules/georect.py:891
 msgid "Writing POINTS file failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:920
+#: ../gui/wxpython/gui_modules/georect.py:928
 msgid "Reading POINTS file failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:965
+#: ../gui/wxpython/gui_modules/georect.py:973
 #, fuzzy
 msgid "RMS Error"
 msgstr "Fehler"
-#: ../gui/wxpython/gui_modules/georect.py:966
+#: ../gui/wxpython/gui_modules/georect.py:974
 #, fuzzy
 msgid ""
 "Insufficient points defined and active (checked) for selected rectification "
@@ -2522,90 +2533,90 @@
 "10+ points for 3rd order."
 msgstr "Punkte Punkte Punkte Punkte."
-#: ../gui/wxpython/gui_modules/georect.py:1037
+#: ../gui/wxpython/gui_modules/georect.py:1047
 #, fuzzy
 msgid "Georectifier settings"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/georect.py:1127
+#: ../gui/wxpython/gui_modules/georect.py:1137
 msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
 msgstr "Punkte"
-#: ../gui/wxpython/gui_modules/georect.py:1160
+#: ../gui/wxpython/gui_modules/georect.py:1170
 msgid "use| X coord"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1161
+#: ../gui/wxpython/gui_modules/georect.py:1171
 msgid "Y coord"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1162
+#: ../gui/wxpython/gui_modules/georect.py:1172
 msgid "E coord"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1163
+#: ../gui/wxpython/gui_modules/georect.py:1173
 msgid "N coord"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1164
+#: ../gui/wxpython/gui_modules/georect.py:1174
 msgid "Forward error"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1165
+#: ../gui/wxpython/gui_modules/georect.py:1175
 msgid "Backward error"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1265
-#: ../gui/wxpython/gui_modules/georect.py:1373
+#: ../gui/wxpython/gui_modules/georect.py:1275
+#: ../gui/wxpython/gui_modules/georect.py:1383
 #, fuzzy
 msgid "Edit GCP"
 msgstr "GUI schliessen"
-#: ../gui/wxpython/gui_modules/georect.py:1266
+#: ../gui/wxpython/gui_modules/georect.py:1276
 msgid "Invalid coordinate value. Operation cancelled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1384
+#: ../gui/wxpython/gui_modules/georect.py:1394
 #, fuzzy
 msgid "Ground Control Point"
 msgstr "Punkt"
-#: ../gui/wxpython/gui_modules/georect.py:1398
+#: ../gui/wxpython/gui_modules/georect.py:1408
 msgid "X:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1399
+#: ../gui/wxpython/gui_modules/georect.py:1409
 msgid "Y:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1400
+#: ../gui/wxpython/gui_modules/georect.py:1410
 msgid "E:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1401
+#: ../gui/wxpython/gui_modules/georect.py:1411
 msgid "N:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1487
+#: ../gui/wxpython/gui_modules/georect.py:1497
 #, fuzzy
 msgid "Symbol settings"
-#: ../gui/wxpython/gui_modules/georect.py:1496
+#: ../gui/wxpython/gui_modules/georect.py:1506
 #: ../gui/wxpython/gui_modules/nviz_tools.py:554
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1243
 #, fuzzy
 msgid "Color:"
 msgstr "Farben:"
-#: ../gui/wxpython/gui_modules/georect.py:1513
+#: ../gui/wxpython/gui_modules/georect.py:1523
 #: ../gui/wxpython/gui_modules/nviz_tools.py:538
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1214
 msgid "Width:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1573
+#: ../gui/wxpython/gui_modules/georect.py:1583
 msgid "Georectifier settings saved to file '%s'."
@@ -2713,7 +2724,7 @@
 msgid "Load map layers"
 msgstr "Kartenebenen laden"
-#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:741
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:744
 msgid "Load map layers into layer tree"
@@ -2726,8 +2737,8 @@
 msgid "Load map layers from GRC file to layer tree (not fully implemented)"
-#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:825
-#: ../gui/wxpython/wxgui.py:843
+#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:828
+#: ../gui/wxpython/wxgui.py:846
 msgid "Save workspace"
@@ -3646,21 +3657,30 @@
 msgstr "Aktualisiere die Statistik der Rasterkarte."
 #: ../gui/wxpython/gui_modules/menudata.py:604
+msgid "Link to GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:605
 #, fuzzy
+msgid "Link GDAL supported raster file to a binary raster map layer."
+msgstr "Importiere Rasterdatei über GDAL in binäre Rasterkarte."
+#: ../gui/wxpython/gui_modules/menudata.py:610
+#, fuzzy
 msgid "Reproject raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:605
+#: ../gui/wxpython/gui_modules/menudata.py:611
 #, fuzzy
 msgid "Re-projects a raster map from one location to the current location."
 msgstr ""
 "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location"
-#: ../gui/wxpython/gui_modules/menudata.py:609
+#: ../gui/wxpython/gui_modules/menudata.py:615
 msgid "Tiling"
 msgstr "Kacheln erzeugen"
-#: ../gui/wxpython/gui_modules/menudata.py:610
+#: ../gui/wxpython/gui_modules/menudata.py:616
 msgid ""
 "Produces tilings of the source projection for use in the destination region "
 "and projection."
@@ -3668,51 +3688,51 @@
 "Erzeugt Kacheln der Quelloprojection um sie in der Zielprojektion und -"
 "location zu nutzen"
-#: ../gui/wxpython/gui_modules/menudata.py:615
-#: ../gui/wxpython/gui_modules/menudata.py:1293
+#: ../gui/wxpython/gui_modules/menudata.py:621
+#: ../gui/wxpython/gui_modules/menudata.py:1310
 msgid "Manage colors"
 msgstr "Farben bearbeiten "
-#: ../gui/wxpython/gui_modules/menudata.py:617
+#: ../gui/wxpython/gui_modules/menudata.py:623
 msgid "Color tables"
-#: ../gui/wxpython/gui_modules/menudata.py:618
+#: ../gui/wxpython/gui_modules/menudata.py:624
 msgid "Creates/modifies the color table associated with a raster map layer."
 msgstr "Erzeugt / modifiziert die Farbtabelle zu einer Rasterkarte"
-#: ../gui/wxpython/gui_modules/menudata.py:622
+#: ../gui/wxpython/gui_modules/menudata.py:628
 msgid "Color rules"
 msgstr "Farbregeln"
-#: ../gui/wxpython/gui_modules/menudata.py:623
-#: ../gui/wxpython/gui_modules/menudata.py:1294
+#: ../gui/wxpython/gui_modules/menudata.py:629
+#: ../gui/wxpython/gui_modules/menudata.py:1311
 msgid "Set colors interactively by entering color rules"
 msgstr "Farben durch die Eingabe von Farbtabellen festlegen"
-#: ../gui/wxpython/gui_modules/menudata.py:628
+#: ../gui/wxpython/gui_modules/menudata.py:634
 msgid "Blend 2 color rasters"
 msgstr "Vereinen von 2 Farbrastern"
-#: ../gui/wxpython/gui_modules/menudata.py:629
+#: ../gui/wxpython/gui_modules/menudata.py:635
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr "Vereint Farbkomponenten von zwei Rasterkarten"
-#: ../gui/wxpython/gui_modules/menudata.py:633
+#: ../gui/wxpython/gui_modules/menudata.py:639
 msgid "Create RGB"
 msgstr "Erzeuge RGB"
-#: ../gui/wxpython/gui_modules/menudata.py:634
+#: ../gui/wxpython/gui_modules/menudata.py:640
 msgid ""
 "Combines red, green and blue map layers into a single composite map layer."
 msgstr "Kombiniert die Farbkanäle rot, grün und blau zu einer Komposit-Karte"
-#: ../gui/wxpython/gui_modules/menudata.py:638
-#: ../gui/wxpython/gui_modules/menudata.py:1598
+#: ../gui/wxpython/gui_modules/menudata.py:644
+#: ../gui/wxpython/gui_modules/menudata.py:1615
 msgid "RGB to HIS"
 msgstr "Konvertiert Farben von RGB zu HIS"
-#: ../gui/wxpython/gui_modules/menudata.py:639
+#: ../gui/wxpython/gui_modules/menudata.py:645
 msgid ""
 "Generates red, green and blue raster map layers combining hue, intensity and "
 "saturation (HIS) values from user-specified input raster map layers."
@@ -3720,19 +3740,19 @@
 "Erzeugt rot, grün und blaue (RGB) Karten aus einer benutzerspezifizierten "
 "Kombination von Wert-, Intensitäts- und Sättigungs-Karten (HIS)."
-#: ../gui/wxpython/gui_modules/menudata.py:645
+#: ../gui/wxpython/gui_modules/menudata.py:651
 msgid "Query by coordinates"
 msgstr "Abfrage über Koordinaten"
-#: ../gui/wxpython/gui_modules/menudata.py:646
+#: ../gui/wxpython/gui_modules/menudata.py:652
 msgid "Queries raster map layers on their category values and category labels."
 msgstr "Fragt Rasterkartenwerte und deren Kategorielabel ab."
-#: ../gui/wxpython/gui_modules/menudata.py:651
+#: ../gui/wxpython/gui_modules/menudata.py:657
 msgid "Buffer rasters"
 msgstr "Raster buffern"
-#: ../gui/wxpython/gui_modules/menudata.py:652
+#: ../gui/wxpython/gui_modules/menudata.py:658
 msgid ""
 "Creates a raster map layer showing buffer zones surrounding cells that "
 "contain non-NULL category values."
@@ -3740,44 +3760,44 @@
 "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte "
 "haben."
-#: ../gui/wxpython/gui_modules/menudata.py:656
+#: ../gui/wxpython/gui_modules/menudata.py:662
 msgid "Closest points"
 msgstr "Nächste Punkte"
-#: ../gui/wxpython/gui_modules/menudata.py:657
+#: ../gui/wxpython/gui_modules/menudata.py:663
 msgid "Locates the closest points between objects in two raster maps."
 msgstr "Findet den nächsten Punkt zwischen Objekten in zwei Rasterkarten."
-#: ../gui/wxpython/gui_modules/menudata.py:661
+#: ../gui/wxpython/gui_modules/menudata.py:667
 #: ../gui/wxpython/gui_modules/nviz_tools.py:251
 #: ../gui/wxpython/gui_modules/nviz_tools.py:432
 #: ../gui/wxpython/gui_modules/nviz_tools.py:850
 msgid "Mask"
 msgstr "Maske"
-#: ../gui/wxpython/gui_modules/menudata.py:662
+#: ../gui/wxpython/gui_modules/menudata.py:668
 msgid "Create a MASK for limiting raster operation"
 msgstr "Erzeugt eine MASK für räumlich eingeschränkte Rasteroperationen"
-#: ../gui/wxpython/gui_modules/menudata.py:666
+#: ../gui/wxpython/gui_modules/menudata.py:672
 #, fuzzy
 msgid "Map calculator"
 msgstr "Kartenrechner"
-#: ../gui/wxpython/gui_modules/menudata.py:667
+#: ../gui/wxpython/gui_modules/menudata.py:673
 msgid "Map calculator for raster map algebra"
 msgstr "Kartenrechner für Rasterkartenalgebra"
-#: ../gui/wxpython/gui_modules/menudata.py:670
+#: ../gui/wxpython/gui_modules/menudata.py:676
 #, fuzzy
 msgid "Neighborhood analysis"
 msgstr "Nachbarschaftsanalysen"
-#: ../gui/wxpython/gui_modules/menudata.py:672
+#: ../gui/wxpython/gui_modules/menudata.py:678
 msgid "Moving window"
 msgstr "Fenster bewegen"
-#: ../gui/wxpython/gui_modules/menudata.py:673
+#: ../gui/wxpython/gui_modules/menudata.py:679
 msgid ""
 "Makes each cell category value a function of the category values assigned to "
 "the cells around it, and stores new cell values in an output raster map "
@@ -3787,11 +3807,11 @@
 "Kategoriewerte basierend auf einer Fenstergrösse zu und erstellt neue "
 "Zellenwerte in einer Ausgabe-Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:677
+#: ../gui/wxpython/gui_modules/menudata.py:683
 msgid "Neighborhood points"
 msgstr "Nachbarschaftspunkte"
-#: ../gui/wxpython/gui_modules/menudata.py:678
+#: ../gui/wxpython/gui_modules/menudata.py:684
 msgid ""
 "Makes each cell value a function of the attribute values assigned to the "
 "vector points or centroids around it, and stores new cell values in an "
@@ -3801,25 +3821,25 @@
 "Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-"
 "Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:683
+#: ../gui/wxpython/gui_modules/menudata.py:689
 msgid "Overlay rasters"
 msgstr "Karten überlagern"
-#: ../gui/wxpython/gui_modules/menudata.py:685
+#: ../gui/wxpython/gui_modules/menudata.py:691
 msgid "Cross product"
 msgstr "Kreuzprodukt"
-#: ../gui/wxpython/gui_modules/menudata.py:686
+#: ../gui/wxpython/gui_modules/menudata.py:692
 msgid ""
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr "Erzeugt ein Kreuzprodukt der Kategriewerte verschiedener Rasterkarten"
-#: ../gui/wxpython/gui_modules/menudata.py:690
+#: ../gui/wxpython/gui_modules/menudata.py:696
 msgid "Raster series"
 msgstr "Rasterkarten Serien"
-#: ../gui/wxpython/gui_modules/menudata.py:691
+#: ../gui/wxpython/gui_modules/menudata.py:697
 #, fuzzy
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
@@ -3828,11 +3848,11 @@
 "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
 "korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
-#: ../gui/wxpython/gui_modules/menudata.py:695
+#: ../gui/wxpython/gui_modules/menudata.py:701
 msgid "Patch raster maps"
 msgstr "Rasterkarten patchen"
-#: ../gui/wxpython/gui_modules/menudata.py:696
+#: ../gui/wxpython/gui_modules/menudata.py:702
 msgid ""
 "Creates a composite raster map layer by using known category values from one "
 "(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
@@ -3840,24 +3860,24 @@
 "Erzeugt eine Komposit-Rasterkarte unter Nutzung von Werten aus einer (oder "
 "mehrerer) Karte, um NULL-Werte einer anderen Karte zu füllen."
-#: ../gui/wxpython/gui_modules/menudata.py:701
+#: ../gui/wxpython/gui_modules/menudata.py:707
 msgid "Statistical overlay"
 msgstr "Statistische Überlagerung"
-#: ../gui/wxpython/gui_modules/menudata.py:702
+#: ../gui/wxpython/gui_modules/menudata.py:708
 #, fuzzy
 msgid "Calculates category or object oriented statistics."
 msgstr "Kategorie- oder objektorientierte Statistik."
-#: ../gui/wxpython/gui_modules/menudata.py:707
+#: ../gui/wxpython/gui_modules/menudata.py:713
 msgid "Solar radiance and shadows"
 msgstr "Solarstrahlung und -verschattung"
-#: ../gui/wxpython/gui_modules/menudata.py:709
+#: ../gui/wxpython/gui_modules/menudata.py:715
 msgid "Solar irradiance and irradiation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:710
+#: ../gui/wxpython/gui_modules/menudata.py:716
 msgid ""
 "Computes direct (beam), diffuse and reflected solar irradiation raster maps "
 "for given day, latitude, surface and atmospheric conditions. Solar "
@@ -3876,11 +3896,11 @@
 "Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann "
 "eingebunden werden."
-#: ../gui/wxpython/gui_modules/menudata.py:714
+#: ../gui/wxpython/gui_modules/menudata.py:720
 msgid "Shadows map"
 msgstr "Schattenkarten"
-#: ../gui/wxpython/gui_modules/menudata.py:715
+#: ../gui/wxpython/gui_modules/menudata.py:721
 msgid ""
 "Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
 "position is specified, or B: date/time to calculate the sun position by r."
@@ -3890,16 +3910,16 @@
 "wird eintweder eine genaue Sonnenposition oder Datumsinformationen zur "
 "Berechnung (mit r.sunmask) erwartet."
-#: ../gui/wxpython/gui_modules/menudata.py:720
+#: ../gui/wxpython/gui_modules/menudata.py:726
 #, fuzzy
 msgid "Terrain analysis"
 msgstr "Oberflächenanalysen"
-#: ../gui/wxpython/gui_modules/menudata.py:722
+#: ../gui/wxpython/gui_modules/menudata.py:728
 msgid "Cumulative movement costs"
 msgstr "Kumulierte Bewegungskosten"
-#: ../gui/wxpython/gui_modules/menudata.py:723
+#: ../gui/wxpython/gui_modules/menudata.py:729
 msgid ""
 "Outputs a raster map layer showing the anisotropic cumulative cost of moving "
 "between different geographic locations on an input elevation raster map "
@@ -3911,12 +3931,12 @@
 "Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
 "mit Reibungs-Kosten kombiniert."
-#: ../gui/wxpython/gui_modules/menudata.py:727
+#: ../gui/wxpython/gui_modules/menudata.py:733
 #, fuzzy
 msgid "Cost surface"
 msgstr "Kostenoberfläche"
-#: ../gui/wxpython/gui_modules/menudata.py:728
+#: ../gui/wxpython/gui_modules/menudata.py:734
 msgid ""
 "Outputs a raster map layer showing the cumulative cost of moving between "
 "different geographic locations on an input raster map layer whose cell "
@@ -3926,26 +3946,26 @@
 "zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
 "Kategoriewerte der Eingabekarte repräsentieren die Kosten."
-#: ../gui/wxpython/gui_modules/menudata.py:732
+#: ../gui/wxpython/gui_modules/menudata.py:738
 #, fuzzy
 msgid "Least cost route or flow"
 msgstr "Kürzester Abflussweg oder Oberflächenfluss"
-#: ../gui/wxpython/gui_modules/menudata.py:733
+#: ../gui/wxpython/gui_modules/menudata.py:739
 msgid "Traces a flow through an elevation model on a raster map layer."
 msgstr "Verfolgt einen Fluss durch ein Höhenmodell."
-#: ../gui/wxpython/gui_modules/menudata.py:739
+#: ../gui/wxpython/gui_modules/menudata.py:745
 msgid "Creates shaded relief map from an elevation map (DEM)."
 msgstr ""
 "Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
-#: ../gui/wxpython/gui_modules/menudata.py:744
+#: ../gui/wxpython/gui_modules/menudata.py:750
 #, fuzzy
 msgid "Slope and aspect"
 msgstr "Hangneigung und -ausrichtung"
-#: ../gui/wxpython/gui_modules/menudata.py:745
+#: ../gui/wxpython/gui_modules/menudata.py:751
 msgid ""
 "Generates raster map layers of slope, aspect, curvatures and partial "
 "derivatives from a raster map layer of true elevation values. Aspect is "
@@ -3955,12 +3975,12 @@
 "Ableitungskarten von einer Rasterkarte mit Höheninformationen."
 "Hangexpositionen werden von Osten gegen den Uhrzeigersinn berechnet."
-#: ../gui/wxpython/gui_modules/menudata.py:749
+#: ../gui/wxpython/gui_modules/menudata.py:755
 #, fuzzy
 msgid "Terrain parameters"
 msgstr "Reliefparameter"
-#: ../gui/wxpython/gui_modules/menudata.py:750
+#: ../gui/wxpython/gui_modules/menudata.py:756
 msgid ""
 "Uses a multi-scale approach by taking fitting quadratic parameters to any "
 "size window (via least squares)."
@@ -3969,34 +3989,34 @@
 "multi-skalaren Ansatz, in dem quadratische Parameter auf jede Fenstergröße "
 "angepasst werden (kleinste Quadrate)."
-#: ../gui/wxpython/gui_modules/menudata.py:754
+#: ../gui/wxpython/gui_modules/menudata.py:760
 #, fuzzy
 msgid "Textural features"
 msgstr "Texturelle Objekte"
-#: ../gui/wxpython/gui_modules/menudata.py:755
+#: ../gui/wxpython/gui_modules/menudata.py:761
 #, fuzzy
 msgid "Generate images with textural features from a raster map."
 msgstr "Erzeugt Texturbilder einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:760
+#: ../gui/wxpython/gui_modules/menudata.py:766
 msgid "Visibility"
 msgstr "Sichtbarkeit"
-#: ../gui/wxpython/gui_modules/menudata.py:761
+#: ../gui/wxpython/gui_modules/menudata.py:767
 msgid "Line-of-sight raster analysis program."
 msgstr "Sichtbarkeitsanalyse (Line of Sight)für Rasterkarten."
-#: ../gui/wxpython/gui_modules/menudata.py:766
+#: ../gui/wxpython/gui_modules/menudata.py:772
 #, fuzzy
 msgid "Transform features"
 msgstr "Umformungsfunktionen"
-#: ../gui/wxpython/gui_modules/menudata.py:768
+#: ../gui/wxpython/gui_modules/menudata.py:774
 msgid "Clump"
 msgstr "Clump"
-#: ../gui/wxpython/gui_modules/menudata.py:769
+#: ../gui/wxpython/gui_modules/menudata.py:775
 msgid ""
 "Recategorizes data in a raster map layer by grouping cells that form "
 "physically discrete areas into unique categories."
@@ -4004,36 +4024,36 @@
 "Rekategoriziert Daten aus Rasterkarten durch zusammenfassen von räumliche "
 "getrennten, aber gleichartigen Zellen zu eigenständigen Kategorien."
-#: ../gui/wxpython/gui_modules/menudata.py:773
+#: ../gui/wxpython/gui_modules/menudata.py:779
 msgid "Grow"
 msgstr "Wachsen"
-#: ../gui/wxpython/gui_modules/menudata.py:774
+#: ../gui/wxpython/gui_modules/menudata.py:780
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 msgstr ""
 "Erstellt eine Rasterkarte mit Flächen, die um jeweils eine Zelle erweitert "
 "wurde"
-#: ../gui/wxpython/gui_modules/menudata.py:778
+#: ../gui/wxpython/gui_modules/menudata.py:784
 msgid "Thin"
 msgstr "Verdünnen"
-#: ../gui/wxpython/gui_modules/menudata.py:779
+#: ../gui/wxpython/gui_modules/menudata.py:785
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
 msgstr ""
 "Dünnt Rasterstrukturen aus, die nicht null (0) sind und linienhafte "
 "Strukturen zeigen."
-#: ../gui/wxpython/gui_modules/menudata.py:785
+#: ../gui/wxpython/gui_modules/menudata.py:791
 #, fuzzy
 msgid "Hydrologic modeling"
 msgstr "Hydrologische Modellierung"
-#: ../gui/wxpython/gui_modules/menudata.py:787
+#: ../gui/wxpython/gui_modules/menudata.py:793
 msgid "Carve stream channels"
 msgstr "Abflusslinien graben"
-#: ../gui/wxpython/gui_modules/menudata.py:788
+#: ../gui/wxpython/gui_modules/menudata.py:794
 msgid ""
 "Takes vector stream data, transforms it to raster and subtracts depth from "
 "the output DEM."
@@ -4041,19 +4061,19 @@
 "Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe "
 "vom ausgegebenen DHM "
-#: ../gui/wxpython/gui_modules/menudata.py:792
+#: ../gui/wxpython/gui_modules/menudata.py:798
 msgid "Fill lake"
 msgstr "Fülle Seen:"
-#: ../gui/wxpython/gui_modules/menudata.py:793
+#: ../gui/wxpython/gui_modules/menudata.py:799
 msgid "Fills lake from seed at given level"
 msgstr "Füllt Seen (oder andere Vertiefungen) bis zu einem bestimmten Level"
-#: ../gui/wxpython/gui_modules/menudata.py:798
+#: ../gui/wxpython/gui_modules/menudata.py:804
 msgid "Depressionless map and flowlines"
 msgstr "Senkenloses Höhenmodell und Abflusslinienkarte"
-#: ../gui/wxpython/gui_modules/menudata.py:799
+#: ../gui/wxpython/gui_modules/menudata.py:805
 msgid ""
 "Filters and generates a depressionless elevation map and a flow direction "
 "map from a given elevation layer."
@@ -4061,21 +4081,21 @@
 "Filtert und generiert ein depressionsloses Höhenmodell und eine "
 "Fliessrichtungskarte auf Basis eines gegebenen Höhenmodells"
-#: ../gui/wxpython/gui_modules/menudata.py:803
+#: ../gui/wxpython/gui_modules/menudata.py:809
 msgid "Flow accumulation"
 msgstr "Fließakkumulation"
-#: ../gui/wxpython/gui_modules/menudata.py:804
+#: ../gui/wxpython/gui_modules/menudata.py:810
 msgid "Flow computation for massive grids (Float version)."
 msgstr ""
 "Berechnung von Fließrichtung und -mengen auf sehr großen Rastern (Float-"
 "Version)"
-#: ../gui/wxpython/gui_modules/menudata.py:808
+#: ../gui/wxpython/gui_modules/menudata.py:814
 msgid "Flow lines"
 msgstr "Fließlinien"
-#: ../gui/wxpython/gui_modules/menudata.py:809
+#: ../gui/wxpython/gui_modules/menudata.py:815
 msgid ""
 "Construction of slope curves (flowlines), flowpath lengths, and flowline "
 "densities (upslope areas) from a raster digital elevation model (DEM)"
@@ -4083,19 +4103,19 @@
 "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem "
 "digitalen Höhenmodell (DHM)"
-#: ../gui/wxpython/gui_modules/menudata.py:814
+#: ../gui/wxpython/gui_modules/menudata.py:820
 msgid "SIMWE Overland flow modeling"
 msgstr "SIMWE Fliessmodellierung"
-#: ../gui/wxpython/gui_modules/menudata.py:815
+#: ../gui/wxpython/gui_modules/menudata.py:821
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
 msgstr "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-#: ../gui/wxpython/gui_modules/menudata.py:819
+#: ../gui/wxpython/gui_modules/menudata.py:825
 msgid "SIMWE Sediment flux modeling"
 msgstr "SIMWE Sedimentbewegungsmodellierung"
-#: ../gui/wxpython/gui_modules/menudata.py:820
+#: ../gui/wxpython/gui_modules/menudata.py:826
 msgid ""
 "Sediment transport and erosion/deposition simulation using path sampling "
 "method (SIMWE)"
@@ -4103,77 +4123,93 @@
 "Sedimenttransport and Erosions-/Depositionsimulation durch die path sampling "
 "method (SIMWE)"
-#: ../gui/wxpython/gui_modules/menudata.py:825
+#: ../gui/wxpython/gui_modules/menudata.py:831
 msgid "Topographic index map"
 msgstr "Topographische Indexkarte erstellen"
-#: ../gui/wxpython/gui_modules/menudata.py:826
+#: ../gui/wxpython/gui_modules/menudata.py:832
 msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
 msgstr ""
 "Erstellt Topographischen Index (ln(a/tan(beta))) auf Basis einer Höhenkarte "
 "(DHM)."
-#: ../gui/wxpython/gui_modules/menudata.py:830
+#: ../gui/wxpython/gui_modules/menudata.py:836
 #, fuzzy
 msgid "TOPMODEL simulation"
 msgstr "TOPMODEL Simulation"
-#: ../gui/wxpython/gui_modules/menudata.py:831
+#: ../gui/wxpython/gui_modules/menudata.py:837
 #, fuzzy
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr ""
 "Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
-#: ../gui/wxpython/gui_modules/menudata.py:836
+#: ../gui/wxpython/gui_modules/menudata.py:842
+msgid "USLE K Factor"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:843
+msgid "USLE K Factor: Soil Erodibility."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:847
+msgid "USLE R Factor"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:848
+msgid "USLE R Factor: Rainfall Erosivity."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:853
 #, fuzzy
 msgid "Watershed subbasins"
 msgstr "Einzugsgebietsflächen"
-#: ../gui/wxpython/gui_modules/menudata.py:837
+#: ../gui/wxpython/gui_modules/menudata.py:854
 #, fuzzy
 msgid "Generates a raster map layer showing watershed subbasins."
 msgstr "Generiert eine Rasterkarte mit Wassereinzugsgebieten."
-#: ../gui/wxpython/gui_modules/menudata.py:841
+#: ../gui/wxpython/gui_modules/menudata.py:858
 #, fuzzy
 msgid "Watershed analysis"
 msgstr "Einzugsgebietsanalysen"
-#: ../gui/wxpython/gui_modules/menudata.py:842
+#: ../gui/wxpython/gui_modules/menudata.py:859
 #, fuzzy
 msgid "Watershed basin analysis program."
 msgstr "Modul zur Analyse von Wassereinzugsgebieten."
-#: ../gui/wxpython/gui_modules/menudata.py:846
+#: ../gui/wxpython/gui_modules/menudata.py:863
 #, fuzzy
 msgid "Watershed basin creation"
 msgstr "Wassereinzugsgebietsberechnung"
-#: ../gui/wxpython/gui_modules/menudata.py:847
+#: ../gui/wxpython/gui_modules/menudata.py:864
 #, fuzzy
 msgid "Watershed basin creation program."
 msgstr "Modul zur Berechnung von Wassereinzugsgebieten."
-#: ../gui/wxpython/gui_modules/menudata.py:852
+#: ../gui/wxpython/gui_modules/menudata.py:869
 #, fuzzy
 msgid "Landscape structure modeling"
 msgstr "Landschaftsstrukturmodellierung"
-#: ../gui/wxpython/gui_modules/menudata.py:854
+#: ../gui/wxpython/gui_modules/menudata.py:871
 msgid "Set up (requires XTerm)"
 msgstr "Setup (erfordert XTerm)"
-#: ../gui/wxpython/gui_modules/menudata.py:855
-#: ../gui/wxpython/gui_modules/menudata.py:878
+#: ../gui/wxpython/gui_modules/menudata.py:872
+#: ../gui/wxpython/gui_modules/menudata.py:895
 msgid "Set up sampling and analysis framework"
 msgstr "Definiert eine Test- und Analyseumgebung"
-#: ../gui/wxpython/gui_modules/menudata.py:860
+#: ../gui/wxpython/gui_modules/menudata.py:877
 #, fuzzy
 msgid "Analyze landscape"
 msgstr "Landschaftliche Charakteristiken analysieren"
-#: ../gui/wxpython/gui_modules/menudata.py:861
+#: ../gui/wxpython/gui_modules/menudata.py:878
 msgid ""
 "Contains a set of measures for attributes, diversity, texture, "
 "juxtaposition, and edge."
@@ -4181,11 +4217,11 @@
 "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
 "Nebeneinanderstellung und Kanten"
-#: ../gui/wxpython/gui_modules/menudata.py:865
+#: ../gui/wxpython/gui_modules/menudata.py:882
 msgid "Analyze patches"
 msgstr "Patchanalyse"
-#: ../gui/wxpython/gui_modules/menudata.py:866
+#: ../gui/wxpython/gui_modules/menudata.py:883
 msgid ""
 "Calculates attribute, patch size, core (interior) size, shape, fractal "
 "dimension, and perimeter measures for sets of patches in a landscape."
@@ -4193,12 +4229,12 @@
 "Berechnet Attribute, Patch-Grösse, Kerngebiets-Grösse, Form, Fraktale "
 "Dimension und Umfang für ein Satz von Patches in einer Landschaft."
-#: ../gui/wxpython/gui_modules/menudata.py:870
+#: ../gui/wxpython/gui_modules/menudata.py:887
 #, fuzzy
 msgid "Output"
 msgstr "Ergebnis"
-#: ../gui/wxpython/gui_modules/menudata.py:871
+#: ../gui/wxpython/gui_modules/menudata.py:888
 msgid ""
 "Displays the boundary of each r.le patch and shows how the boundary is "
 "traced, displays the attribute, size, perimeter and shape indices for each "
@@ -4208,40 +4244,40 @@
 "Größe, Umfang und Flächenindizes jedes Patches und speichert die Daten in "
 "einer Ergebnisdatei "
-#: ../gui/wxpython/gui_modules/menudata.py:876
+#: ../gui/wxpython/gui_modules/menudata.py:893
 msgid "Landscape patch analysis"
 msgstr "Landschafts-Patchanalyse"
-#: ../gui/wxpython/gui_modules/menudata.py:879
+#: ../gui/wxpython/gui_modules/menudata.py:896
 msgid "Configuration editor for r.li.'index'"
 msgstr "Editor für Konfigurationsdateien für r.li.'index'."
-#: ../gui/wxpython/gui_modules/menudata.py:884
+#: ../gui/wxpython/gui_modules/menudata.py:901
 msgid "Edge density"
 msgstr "Kantendichte"
-#: ../gui/wxpython/gui_modules/menudata.py:885
+#: ../gui/wxpython/gui_modules/menudata.py:902
 msgid ""
 "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 "Berechnet die Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines "
 "4-Nachbarn-Algorithmus."
-#: ../gui/wxpython/gui_modules/menudata.py:889
+#: ../gui/wxpython/gui_modules/menudata.py:906
 msgid "Contrast weighted edge density"
 msgstr "Kantendichte (gewichtet nach Kontrast)"
-#: ../gui/wxpython/gui_modules/menudata.py:890
+#: ../gui/wxpython/gui_modules/menudata.py:907
 msgid "Calculates contrast weighted edge density index on a raster map"
 msgstr ""
 "Berechnet den Kanten-Dichte-Index einer Rasterkarte gewichtet nach dem "
 "Kontrast"
-#: ../gui/wxpython/gui_modules/menudata.py:895
+#: ../gui/wxpython/gui_modules/menudata.py:912
 msgid "Patch area mean"
 msgstr "Mittlere Patchgröße"
-#: ../gui/wxpython/gui_modules/menudata.py:896
+#: ../gui/wxpython/gui_modules/menudata.py:913
 msgid ""
 "Calculates mean patch size index on a raster map, using a 4 neighbour "
 "algorithm"
@@ -4249,102 +4285,102 @@
 "Berechnet die mittlere Patchgrößein einer Rasterkarte, unter Verwendung "
 "eines 4-Nachbarn-Algorithmus."
-#: ../gui/wxpython/gui_modules/menudata.py:900
+#: ../gui/wxpython/gui_modules/menudata.py:917
 msgid "Patch area range"
 msgstr "Patchgröße (Spannweite)"
-#: ../gui/wxpython/gui_modules/menudata.py:901
+#: ../gui/wxpython/gui_modules/menudata.py:918
 msgid "Calculates range of patch area size on a raster map"
 msgstr "Berechnet die Spanne der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:905
+#: ../gui/wxpython/gui_modules/menudata.py:922
 msgid "Patch area Std Dev"
 msgstr "Patchgröße (Standardabweichung)"
-#: ../gui/wxpython/gui_modules/menudata.py:906
+#: ../gui/wxpython/gui_modules/menudata.py:923
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr "Berechnet die Standardabweichung der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:910
+#: ../gui/wxpython/gui_modules/menudata.py:927
 msgid "Patch area Coeff Var"
 msgstr "Patchgröße (Variationskoeffizient)"
-#: ../gui/wxpython/gui_modules/menudata.py:911
+#: ../gui/wxpython/gui_modules/menudata.py:928
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr "Berechnet Variationskoeffizient der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:915
+#: ../gui/wxpython/gui_modules/menudata.py:932
 msgid "Patch density"
 msgstr "Patchdichte"
-#: ../gui/wxpython/gui_modules/menudata.py:916
+#: ../gui/wxpython/gui_modules/menudata.py:933
 msgid ""
 "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
 "Nachbarn-Algorithmus."
-#: ../gui/wxpython/gui_modules/menudata.py:920
+#: ../gui/wxpython/gui_modules/menudata.py:937
 msgid "Patch number"
 msgstr "Patchanzahl"
-#: ../gui/wxpython/gui_modules/menudata.py:921
+#: ../gui/wxpython/gui_modules/menudata.py:938
 msgid ""
 "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
-#: ../gui/wxpython/gui_modules/menudata.py:926
+#: ../gui/wxpython/gui_modules/menudata.py:943
 #, fuzzy
 msgid "Dominance's diversity"
 msgstr "Diversitätsindex (nach Dominanz)"
-#: ../gui/wxpython/gui_modules/menudata.py:927
-#: ../gui/wxpython/gui_modules/menudata.py:943
+#: ../gui/wxpython/gui_modules/menudata.py:944
+#: ../gui/wxpython/gui_modules/menudata.py:960
 msgid "Calculates dominance's diversity index on a raster map"
 msgstr "Berechnet den Dominanz-Diversitäts-Index einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:931
+#: ../gui/wxpython/gui_modules/menudata.py:948
 msgid "Shannon's diversity"
 msgstr "Diversitätsindex (nach Shannon)"
-#: ../gui/wxpython/gui_modules/menudata.py:932
+#: ../gui/wxpython/gui_modules/menudata.py:949
 msgid "Calculates Shannon's diversity index on a raster map"
 msgstr "Berechnet Shannons Diversitäts-Index einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:936
+#: ../gui/wxpython/gui_modules/menudata.py:953
 msgid "Simpson's diversity"
 msgstr "Diversitätsindex (nach Simpson)"
-#: ../gui/wxpython/gui_modules/menudata.py:937
+#: ../gui/wxpython/gui_modules/menudata.py:954
 msgid "Calculates Simpson's diversity index on a raster map"
 msgstr "Berechnet Simpsons-Diversitäts-Index einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:942
+#: ../gui/wxpython/gui_modules/menudata.py:959
 msgid "Richness"
 msgstr "Vielfalt"
-#: ../gui/wxpython/gui_modules/menudata.py:947
+#: ../gui/wxpython/gui_modules/menudata.py:964
 msgid "Shape index"
 msgstr "Shape Index"
-#: ../gui/wxpython/gui_modules/menudata.py:948
+#: ../gui/wxpython/gui_modules/menudata.py:965
 #, fuzzy
 msgid "Calculates shape index on a raster map"
 msgstr "Berechnet den Form-Index einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:953
+#: ../gui/wxpython/gui_modules/menudata.py:970
 #, fuzzy
 msgid "Wildfire modeling"
 msgstr "Buschfeuermodellierung"
-#: ../gui/wxpython/gui_modules/menudata.py:955
+#: ../gui/wxpython/gui_modules/menudata.py:972
 #, fuzzy
 msgid "Rate of spread"
 msgstr "Text zum Darstellen: "
-#: ../gui/wxpython/gui_modules/menudata.py:956
+#: ../gui/wxpython/gui_modules/menudata.py:973
 msgid ""
 "Generates three, or four raster map layers showing 1) the base "
 "(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
@@ -4356,12 +4392,12 @@
 "die Richtung der größten Ausbreitung, und optional 4) die maximal zu "
 "erkennende potentielle Ausbreitung, zeigen."
-#: ../gui/wxpython/gui_modules/menudata.py:960
+#: ../gui/wxpython/gui_modules/menudata.py:977
 #, fuzzy
 msgid "Least-cost spread paths"
 msgstr "Erzeuge einen 'Geringsten-Kosten-Ausbreitungspfad'"
-#: ../gui/wxpython/gui_modules/menudata.py:961
+#: ../gui/wxpython/gui_modules/menudata.py:978
 msgid ""
 "Recursively traces the least cost path backwards to cells from which the "
 "cumulative cost was determined."
@@ -4369,36 +4405,36 @@
 "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
 "denen der kumulative Weg bestimmt wurde."
-#: ../gui/wxpython/gui_modules/menudata.py:965
+#: ../gui/wxpython/gui_modules/menudata.py:982
 msgid "Anisotropic spread simulation"
 msgstr "Anisotropische Ausbreitungssimulation"
-#: ../gui/wxpython/gui_modules/menudata.py:966
+#: ../gui/wxpython/gui_modules/menudata.py:983
 #, fuzzy
 msgid ""
 "It optionally produces raster maps to contain backlink UTM coordinates for "
 "tracing spread paths."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/menudata.py:972
+#: ../gui/wxpython/gui_modules/menudata.py:989
 #, fuzzy
 msgid "Change category values and labels"
 msgstr "Kategoriewerte und Label ändern"
-#: ../gui/wxpython/gui_modules/menudata.py:974
+#: ../gui/wxpython/gui_modules/menudata.py:991
 msgid "Interactively edit category values"
 msgstr "Interaktive Bearbeitung der Kategoriewerte"
-#: ../gui/wxpython/gui_modules/menudata.py:975
+#: ../gui/wxpython/gui_modules/menudata.py:992
 #, fuzzy
 msgid "Interactively edit cell values in a raster map."
 msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:980
+#: ../gui/wxpython/gui_modules/menudata.py:997
 msgid "Reclassify by size"
 msgstr "Klassifizieren nach Größe"
-#: ../gui/wxpython/gui_modules/menudata.py:981
+#: ../gui/wxpython/gui_modules/menudata.py:998
 msgid ""
 "Reclasses a raster map greater or less than user specified area size (in "
 "hectares)"
@@ -4406,19 +4442,19 @@
 "Reklassifiziert Bereiche eine Rasterkarte (größer oder kleiner) nach einer "
 "benutzerspezifischen Größe (in ha)"
-#: ../gui/wxpython/gui_modules/menudata.py:985
+#: ../gui/wxpython/gui_modules/menudata.py:1002
 msgid "Reclassify interactively"
 msgstr "Interaktive Reglassifizierung"
-#: ../gui/wxpython/gui_modules/menudata.py:986
+#: ../gui/wxpython/gui_modules/menudata.py:1003
 msgid "Reclassify raster categories interactively by entering reclass rules"
 msgstr "Reklassifiziert Rasterkategorien interaktiv"
-#: ../gui/wxpython/gui_modules/menudata.py:990
+#: ../gui/wxpython/gui_modules/menudata.py:1007
 msgid "Reclassify using rules file"
 msgstr "Reklassifizierung mit einer Regeldatei"
-#: ../gui/wxpython/gui_modules/menudata.py:991
+#: ../gui/wxpython/gui_modules/menudata.py:1008
 #, fuzzy
 msgid ""
 "Creates a new map layer whose category values are based upon a "
@@ -4427,11 +4463,11 @@
 "Erzeugt eine neue Karte basierend auf nutzereigenen Reklassifizierungsregeln "
 "der Kategoriewerte von einer existierenden Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:996
+#: ../gui/wxpython/gui_modules/menudata.py:1013
 msgid "Recode interactively"
 msgstr "Interaktive Bearbeitung von Rasterwerte (Recode)"
-#: ../gui/wxpython/gui_modules/menudata.py:997
+#: ../gui/wxpython/gui_modules/menudata.py:1014
 msgid ""
 "Recode raster categories interactively by entering recode rules (create new "
 "raster map)"
@@ -4439,30 +4475,30 @@
 "Neukodieren von Rasterwerten nach interaktiven Regeln, erzeugt eine neue "
 "Karte"
-#: ../gui/wxpython/gui_modules/menudata.py:1001
+#: ../gui/wxpython/gui_modules/menudata.py:1018
 msgid "Recode using rules file"
 msgstr "Neukodieren der Kategorien mit einer Regel-Datei"
-#: ../gui/wxpython/gui_modules/menudata.py:1002
+#: ../gui/wxpython/gui_modules/menudata.py:1019
 #, fuzzy
 msgid ""
 "r.recode.rules - Use ascii rules file to recode categories in raster map"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1007
+#: ../gui/wxpython/gui_modules/menudata.py:1024
 msgid "Rescale"
 msgstr "Neu skalieren"
-#: ../gui/wxpython/gui_modules/menudata.py:1008
+#: ../gui/wxpython/gui_modules/menudata.py:1025
 #, fuzzy
 msgid "Rescales the range of category values in a raster map layer."
 msgstr "Reskaliert die Spanne der Kategoriewerte einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1012
+#: ../gui/wxpython/gui_modules/menudata.py:1029
 msgid "Rescale with histogram"
 msgstr "Neuskalierung mit Histogramm"
-#: ../gui/wxpython/gui_modules/menudata.py:1013
+#: ../gui/wxpython/gui_modules/menudata.py:1030
 msgid ""
 "Rescales histogram equalized the range of category values in a raster map "
 "layer."
@@ -4470,35 +4506,35 @@
 "Reskaliert ein normalisiertes Histogram basierend auf der Spanne der "
 "Kategoriewerte einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1020
+#: ../gui/wxpython/gui_modules/menudata.py:1037
 msgid "Concentric circles"
 msgstr "Konzentrische Kreise"
-#: ../gui/wxpython/gui_modules/menudata.py:1021
+#: ../gui/wxpython/gui_modules/menudata.py:1038
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
 "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
 "Punkt ziehen."
-#: ../gui/wxpython/gui_modules/menudata.py:1024
+#: ../gui/wxpython/gui_modules/menudata.py:1041
 #, fuzzy
 msgid "Generate random cells"
 msgstr "Erzeugt zufällige Zellen"
-#: ../gui/wxpython/gui_modules/menudata.py:1026
+#: ../gui/wxpython/gui_modules/menudata.py:1043
 msgid "Random cells"
 msgstr "Zufällige Zellen"
-#: ../gui/wxpython/gui_modules/menudata.py:1027
+#: ../gui/wxpython/gui_modules/menudata.py:1044
 msgid "Generates random cell values with spatial dependence."
 msgstr "Erzeugt zufällig Zellwerte mit räumlicher Abhängigkeit."
-#: ../gui/wxpython/gui_modules/menudata.py:1031
+#: ../gui/wxpython/gui_modules/menudata.py:1048
 #, fuzzy
 msgid "Random cells and vector points"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1032
+#: ../gui/wxpython/gui_modules/menudata.py:1049
 msgid ""
 "Creates a raster map layer and vector point map containing randomly located "
 "sites."
@@ -4506,26 +4542,26 @@
 "Erzeugt eine Rasterkarte und eine Vektorkarte (Punkte) deren Inhalte "
 "räumliche zufällig verteilt sind"
-#: ../gui/wxpython/gui_modules/menudata.py:1037
+#: ../gui/wxpython/gui_modules/menudata.py:1054
 #, fuzzy
 msgid "Generate surfaces"
 msgstr "Erzeuge Oberflächen"
-#: ../gui/wxpython/gui_modules/menudata.py:1039
+#: ../gui/wxpython/gui_modules/menudata.py:1056
 #, fuzzy
 msgid "Fractal surface"
 msgstr "Erzeuge fraktale Oberfläche"
-#: ../gui/wxpython/gui_modules/menudata.py:1040
+#: ../gui/wxpython/gui_modules/menudata.py:1057
 msgid "Creates a fractal surface of a given fractal dimension."
 msgstr ""
 "Erzeugt fraktale Oberflächen nach einer definierten fraktalen Dimension "
-#: ../gui/wxpython/gui_modules/menudata.py:1045
+#: ../gui/wxpython/gui_modules/menudata.py:1062
 msgid "Gaussian kernel density surface"
 msgstr "Oberflächen (Gauß'sche Kerneldichte)"
-#: ../gui/wxpython/gui_modules/menudata.py:1046
+#: ../gui/wxpython/gui_modules/menudata.py:1063
 msgid ""
 "Generates a raster density map from vector points data using a moving 2D "
 "isotropic Gaussian kernel or optionally generates a vector density map on "
@@ -4535,11 +4571,11 @@
 "isotropischen Gauß'schen Kernel oder erzeugt eine Vektor-Dichte-Karte auf "
 "Basis eines Vektornetzwerks mit einem 1D-Kernel (optional)"
-#: ../gui/wxpython/gui_modules/menudata.py:1050
+#: ../gui/wxpython/gui_modules/menudata.py:1067
 msgid "Gaussian deviates surface"
 msgstr "Oberflächen (Gauß'sche Deviate)"
-#: ../gui/wxpython/gui_modules/menudata.py:1051
+#: ../gui/wxpython/gui_modules/menudata.py:1068
 msgid ""
 "GRASS module to produce a raster map layer of gaussian deviates whose mean "
 "and standard deviation can be expressed by the user. It uses a gaussian "
@@ -4550,23 +4586,23 @@
 "angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
 "verwendet."
-#: ../gui/wxpython/gui_modules/menudata.py:1056
+#: ../gui/wxpython/gui_modules/menudata.py:1073
 msgid "Plane"
 msgstr "Ebene erzeugen"
-#: ../gui/wxpython/gui_modules/menudata.py:1057
+#: ../gui/wxpython/gui_modules/menudata.py:1074
 #, fuzzy
 msgid ""
 "Creates raster plane map given dip (inclination), aspect (azimuth) and one "
 "point."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/menudata.py:1062
+#: ../gui/wxpython/gui_modules/menudata.py:1079
 #, fuzzy
 msgid "Random deviates surface"
-#: ../gui/wxpython/gui_modules/menudata.py:1063
+#: ../gui/wxpython/gui_modules/menudata.py:1080
 #, fuzzy
 msgid ""
 "Produces a raster map layer of uniform random deviates whose range can be "
@@ -4575,22 +4611,22 @@
 "Erzeugt eine Rasterkarte mit zufälligen Werten, die vom Benutzer festgelegt "
 "werden können."
-#: ../gui/wxpython/gui_modules/menudata.py:1067
+#: ../gui/wxpython/gui_modules/menudata.py:1084
 #, fuzzy
 msgid "Random surface with spatial dependence"
 msgstr "Erzeuge zufällige Oberfläche mit räumlicher Abhängigkeit"
-#: ../gui/wxpython/gui_modules/menudata.py:1068
+#: ../gui/wxpython/gui_modules/menudata.py:1085
 #, fuzzy
 msgid "Generates random surface(s) with spatial dependence."
 msgstr "Erzeugt zufällige Oberfläche(n) mit räumlicher Abhängigkeit."
-#: ../gui/wxpython/gui_modules/menudata.py:1074
+#: ../gui/wxpython/gui_modules/menudata.py:1091
 #, fuzzy
 msgid "Generate contour lines"
 msgstr "Zeilen"
-#: ../gui/wxpython/gui_modules/menudata.py:1075
+#: ../gui/wxpython/gui_modules/menudata.py:1092
 #, fuzzy
 msgid ""
 "Produces a vector map layer of specified contours from a raster map layer."
@@ -4598,46 +4634,46 @@
 "Erzeugt eine GRASS Binär-Vektorkarte mit Kontourlinien einer GRASS "
 "Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1078
+#: ../gui/wxpython/gui_modules/menudata.py:1095
 #, fuzzy
 msgid "Interpolate surfaces"
 msgstr "Interpoliere Oberflächen"
-#: ../gui/wxpython/gui_modules/menudata.py:1080
+#: ../gui/wxpython/gui_modules/menudata.py:1097
 #, fuzzy
 msgid "Bilinear from raster points"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1081
+#: ../gui/wxpython/gui_modules/menudata.py:1098
 #, fuzzy
 msgid "Bilinear interpolation utility for raster map layers."
 msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#: ../gui/wxpython/gui_modules/menudata.py:1085
+#: ../gui/wxpython/gui_modules/menudata.py:1102
 #, fuzzy
 msgid "Bilinear and bicubic from vector points"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1086
+#: ../gui/wxpython/gui_modules/menudata.py:1103
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1091
+#: ../gui/wxpython/gui_modules/menudata.py:1108
 #, fuzzy
 msgid "IDW from raster points"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1092
+#: ../gui/wxpython/gui_modules/menudata.py:1109
 #, fuzzy
 msgid "Surface interpolation utility for raster map layers."
 msgstr "Oberflächeninterpolationswerkzeug für Rasterkarten."
-#: ../gui/wxpython/gui_modules/menudata.py:1096
+#: ../gui/wxpython/gui_modules/menudata.py:1113
 #, fuzzy
 msgid "IDW from vector points"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1097
+#: ../gui/wxpython/gui_modules/menudata.py:1114
 #, fuzzy
 msgid ""
 "Surface interpolation from vector point data by Inverse Distance Squared "
@@ -4646,24 +4682,24 @@
 "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
 "Squared Weighting."
-#: ../gui/wxpython/gui_modules/menudata.py:1102
+#: ../gui/wxpython/gui_modules/menudata.py:1119
 #, fuzzy
 msgid "Raster contours"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1103
+#: ../gui/wxpython/gui_modules/menudata.py:1120
 #, fuzzy
 msgid "Surface generation program from rasterized contours."
 msgstr ""
 "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
 "Höheninformationen."
-#: ../gui/wxpython/gui_modules/menudata.py:1107
+#: ../gui/wxpython/gui_modules/menudata.py:1124
 #, fuzzy
 msgid "Regularized spline tension"
 msgstr "Resamplen mit der RST-Methode"
-#: ../gui/wxpython/gui_modules/menudata.py:1108
+#: ../gui/wxpython/gui_modules/menudata.py:1125
 #, fuzzy
 msgid ""
 "Spatial approximation and topographic analysis from given point or isoline "
@@ -4671,87 +4707,87 @@
 "spline with tension."
 msgstr "von Punkt Punkt mit."
-#: ../gui/wxpython/gui_modules/menudata.py:1113
+#: ../gui/wxpython/gui_modules/menudata.py:1130
 msgid "Fill NULL cells"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1114
+#: ../gui/wxpython/gui_modules/menudata.py:1131
 #, fuzzy
 msgid ""
 "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1120
-#: ../gui/wxpython/gui_modules/menudata.py:1732
+#: ../gui/wxpython/gui_modules/menudata.py:1137
+#: ../gui/wxpython/gui_modules/menudata.py:1765
 msgid "Report and statistics"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1122
+#: ../gui/wxpython/gui_modules/menudata.py:1139
 #, fuzzy
 msgid "Basic raster metadata"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1123
+#: ../gui/wxpython/gui_modules/menudata.py:1140
 #, fuzzy
 msgid "Output basic information about a raster map layer."
 msgstr "Gibt grundlegende Informationen über eine Rasterkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1127
+#: ../gui/wxpython/gui_modules/menudata.py:1144
 #, fuzzy
 msgid "Manage category information"
 msgstr "Grundlegende Dateiinformationen anzeigen"
-#: ../gui/wxpython/gui_modules/menudata.py:1128
+#: ../gui/wxpython/gui_modules/menudata.py:1145
 #, fuzzy
 msgid ""
 "Manages category values and labels associated with user-specified raster map "
 "layers."
 msgstr "Gibt die Kategoriewerte und Label einer Rasterkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1133
+#: ../gui/wxpython/gui_modules/menudata.py:1150
 #, fuzzy
 msgid "General statistics"
 msgstr "Allgemeine Statistiken"
-#: ../gui/wxpython/gui_modules/menudata.py:1134
+#: ../gui/wxpython/gui_modules/menudata.py:1151
 #, fuzzy
 msgid "Generates area statistics for raster map layers."
 msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
-#: ../gui/wxpython/gui_modules/menudata.py:1138
+#: ../gui/wxpython/gui_modules/menudata.py:1155
 #, fuzzy
 msgid "Range of category values"
 msgstr "Bereich der Kategoriewerte"
-#: ../gui/wxpython/gui_modules/menudata.py:1139
+#: ../gui/wxpython/gui_modules/menudata.py:1156
 #, fuzzy
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr "Gibt eine kurze Liste der Kategoriewerte einer Rasterkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1143
+#: ../gui/wxpython/gui_modules/menudata.py:1160
 msgid "Sum category values"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1144
+#: ../gui/wxpython/gui_modules/menudata.py:1161
 #, fuzzy
 msgid "Sums up the raster cell values."
 msgstr "Summierert die Rasterzellenwerte auf."
-#: ../gui/wxpython/gui_modules/menudata.py:1148
+#: ../gui/wxpython/gui_modules/menudata.py:1165
 #, fuzzy
 msgid "Sum area by raster map and category"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1149
+#: ../gui/wxpython/gui_modules/menudata.py:1166
 #, fuzzy
 msgid "Reports statistics for raster map layers."
 msgstr "Gibt statistische Werte für eine Rasterkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1153
+#: ../gui/wxpython/gui_modules/menudata.py:1170
 msgid "Statistics for clumped cells"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1154
+#: ../gui/wxpython/gui_modules/menudata.py:1171
 #, fuzzy
 msgid ""
 "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
@@ -4760,21 +4796,21 @@
 "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
 "Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
-#: ../gui/wxpython/gui_modules/menudata.py:1158
+#: ../gui/wxpython/gui_modules/menudata.py:1175
 msgid "Total corrected area"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1159
+#: ../gui/wxpython/gui_modules/menudata.py:1176
 #, fuzzy
 msgid "Surface area estimation for rasters."
 msgstr "Abschätzung der Oberfläche von Rasterkarten"
-#: ../gui/wxpython/gui_modules/menudata.py:1163
+#: ../gui/wxpython/gui_modules/menudata.py:1180
 #, fuzzy
 msgid "Univariate raster statistics"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1164
+#: ../gui/wxpython/gui_modules/menudata.py:1181
 #, fuzzy
 msgid ""
 "Calculates univariate statistics from the non-null cells of a raster map."
@@ -4782,24 +4818,24 @@
 "Berechnet univariate Statistikparameter einer Rasterkarte (nur Nicht-Null-"
 "Zellen)."
-#: ../gui/wxpython/gui_modules/menudata.py:1169
+#: ../gui/wxpython/gui_modules/menudata.py:1186
 #, fuzzy
 msgid "Sample transects"
 msgstr "Stichprobenwerte entlang eines Transekts"
-#: ../gui/wxpython/gui_modules/menudata.py:1170
+#: ../gui/wxpython/gui_modules/menudata.py:1187
 #, fuzzy
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
 "Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) "
 "benutzerdefinierter Linien liegt."
-#: ../gui/wxpython/gui_modules/menudata.py:1174
+#: ../gui/wxpython/gui_modules/menudata.py:1191
 #, fuzzy
 msgid "Sample transects (bearing/distance)"
 msgstr "Stichprobenwerte entlang eines Transekts (mit Azimuth, Distanz)"
-#: ../gui/wxpython/gui_modules/menudata.py:1175
+#: ../gui/wxpython/gui_modules/menudata.py:1192
 #, fuzzy
 msgid ""
 "Outputs raster map layer values lying along user defined transect line(s)."
@@ -4807,12 +4843,12 @@
 "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den "
 "Benutzer festgelegten Linie(n) liegen."
-#: ../gui/wxpython/gui_modules/menudata.py:1180
+#: ../gui/wxpython/gui_modules/menudata.py:1197
 #, fuzzy
 msgid "Covariance/correlation"
 msgstr "Kovarianz/Korrelation"
-#: ../gui/wxpython/gui_modules/menudata.py:1181
+#: ../gui/wxpython/gui_modules/menudata.py:1198
 #, fuzzy
 msgid ""
 "Outputs a covariance/correlation matrix for user-specified raster map layer"
@@ -4821,235 +4857,233 @@
 "Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert "
 "Rasterkarte(n) aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1185
+#: ../gui/wxpython/gui_modules/menudata.py:1202
 #, fuzzy
 msgid "Linear regression"
 msgstr "Lineare Regression zwischen zwei Karten"
-#: ../gui/wxpython/gui_modules/menudata.py:1186
+#: ../gui/wxpython/gui_modules/menudata.py:1203
 #, fuzzy
 msgid "Calculates linear regression from two raster maps: y = a + b*x"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1190
+#: ../gui/wxpython/gui_modules/menudata.py:1207
 msgid "Mutual category occurrences"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1191
+#: ../gui/wxpython/gui_modules/menudata.py:1208
 #, fuzzy
 msgid ""
 "Tabulates the mutual occurrence (coincidence) of categories for two raster "
 "map layers."
-#: ../gui/wxpython/gui_modules/menudata.py:1198
+#: ../gui/wxpython/gui_modules/menudata.py:1215
 #, fuzzy
 msgid "Vector"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1199
+#: ../gui/wxpython/gui_modules/menudata.py:1216
 #, fuzzy
 msgid "Develop vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1202
+#: ../gui/wxpython/gui_modules/menudata.py:1219
 #, fuzzy
 msgid "Create new empty vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1207
+#: ../gui/wxpython/gui_modules/menudata.py:1224
 #, fuzzy
 msgid "Create/rebuild topology"
 msgstr "Erstelle oder baue Topologie neu"
-#: ../gui/wxpython/gui_modules/menudata.py:1208
+#: ../gui/wxpython/gui_modules/menudata.py:1225
 #, fuzzy
 msgid "Creates topology for GRASS vector map."
 msgstr "Erzeugt Paint-Label für GRASS Vektordateien und angehängte Label."
-#: ../gui/wxpython/gui_modules/menudata.py:1212
+#: ../gui/wxpython/gui_modules/menudata.py:1229
 #, fuzzy
 msgid "Clean vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1213
+#: ../gui/wxpython/gui_modules/menudata.py:1230
 #, fuzzy
 msgid "Toolset for cleaning topology of vector map."
 msgstr "Werkzeugkasten zum Säubern der Vektortopologie"
-#: ../gui/wxpython/gui_modules/menudata.py:1217
+#: ../gui/wxpython/gui_modules/menudata.py:1234
 #, fuzzy
 msgid "Generalization"
-#: ../gui/wxpython/gui_modules/menudata.py:1218
+#: ../gui/wxpython/gui_modules/menudata.py:1235
 #, fuzzy
 msgid "Vector based generalization."
 msgstr "Vektor, Raster, Aggregation"
-#: ../gui/wxpython/gui_modules/menudata.py:1223
+#: ../gui/wxpython/gui_modules/menudata.py:1240
 #, fuzzy
 msgid "Convert object types"
 msgstr "Vektortypen konvertieren"
-#: ../gui/wxpython/gui_modules/menudata.py:1224
+#: ../gui/wxpython/gui_modules/menudata.py:1241
 msgid "Change the type of geometry elements."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1229
+#: ../gui/wxpython/gui_modules/menudata.py:1246
 #, fuzzy
 msgid "Add centroids"
 msgstr "Zentroide"
-#: ../gui/wxpython/gui_modules/menudata.py:1230
+#: ../gui/wxpython/gui_modules/menudata.py:1247
 #, fuzzy
 msgid "Adds missing centroids to closed boundaries."
 msgstr "Zentroide Umrandung."
-#: ../gui/wxpython/gui_modules/menudata.py:1235
+#: ../gui/wxpython/gui_modules/menudata.py:1252
 msgid "Build polylines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1236
+#: ../gui/wxpython/gui_modules/menudata.py:1253
 #, fuzzy
 msgid "Builds polylines from lines or boundaries."
 msgstr "Zeilen Umrandung."
-#: ../gui/wxpython/gui_modules/menudata.py:1240
+#: ../gui/wxpython/gui_modules/menudata.py:1257
 #, fuzzy
 msgid "Split polylines"
 msgstr "Teile Linie"
-#: ../gui/wxpython/gui_modules/menudata.py:1241
+#: ../gui/wxpython/gui_modules/menudata.py:1258
 #, fuzzy
 msgid "Creates points/segments from input vector lines and positions."
 msgstr "Erzeuge Punkte entlang der Eingabelinie."
-#: ../gui/wxpython/gui_modules/menudata.py:1245
+#: ../gui/wxpython/gui_modules/menudata.py:1262
 #, fuzzy
 msgid "Parallel lines"
 msgstr "Zeichne Linien:"
-#: ../gui/wxpython/gui_modules/menudata.py:1246
+#: ../gui/wxpython/gui_modules/menudata.py:1263
 #, fuzzy
 msgid "Create parallel line to input lines"
 msgstr "Zeilen"
-#: ../gui/wxpython/gui_modules/menudata.py:1251
+#: ../gui/wxpython/gui_modules/menudata.py:1268
 #, fuzzy
 msgid "Dissolve boundaries"
 msgstr "Angrenzende Umrandungen zusammenfassen (Dissolve)"
-#: ../gui/wxpython/gui_modules/menudata.py:1252
+#: ../gui/wxpython/gui_modules/menudata.py:1269
 #, fuzzy
 msgid ""
 "Dissolves boundaries between adjacent areas sharing a common category number "
 "or attribute."
 msgstr "Umrandung Flächen."
-#: ../gui/wxpython/gui_modules/menudata.py:1257
+#: ../gui/wxpython/gui_modules/menudata.py:1274
 #, fuzzy
 msgid "Create 3D vector over raster"
 msgstr "Vektor Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1258
+#: ../gui/wxpython/gui_modules/menudata.py:1275
 #, fuzzy
 msgid "Converts vector map to 3D by sampling of elevation raster map."
 msgstr ""
 "Konvertiert 2D Vektorkarte in eine 3D-Vektorkarte, in dem die Höhenkarte "
 "gesamplet wird. Standardmäßig wird die Nearest Neighbor-Methode verwendet."
-#: ../gui/wxpython/gui_modules/menudata.py:1262
+#: ../gui/wxpython/gui_modules/menudata.py:1279
 #, fuzzy
 msgid "Extrude 3D vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1263
+#: ../gui/wxpython/gui_modules/menudata.py:1280
 #, fuzzy
 msgid "Extrudes flat vector object to 3D with defined height."
 msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
-#: ../gui/wxpython/gui_modules/menudata.py:1268
+#: ../gui/wxpython/gui_modules/menudata.py:1285
 msgid "Link to OGR"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1269
-msgid ""
-"Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS,TIGER,S57,DGN,"
-"VRT,REC,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,ODBC,PGeo,PostgreSQL,"
-"AVCBin"
-msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1286
+#, fuzzy
+msgid "Creates a new vector as a read-only link to OGR layer."
+msgstr "Konvertiert eine GRASS-Binärkarte vom Vektor- in das Rasterformat."
-#: ../gui/wxpython/gui_modules/menudata.py:1274
+#: ../gui/wxpython/gui_modules/menudata.py:1291
 #, fuzzy
 msgid "Create labels"
 msgstr "Erzeuge Tabelle"
-#: ../gui/wxpython/gui_modules/menudata.py:1275
+#: ../gui/wxpython/gui_modules/menudata.py:1292
 #, fuzzy
 msgid "Creates paint labels for a vector map from attached attributes."
-#: ../gui/wxpython/gui_modules/menudata.py:1280
+#: ../gui/wxpython/gui_modules/menudata.py:1297
 #, fuzzy
 msgid "Reposition vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1281
+#: ../gui/wxpython/gui_modules/menudata.py:1298
 #, fuzzy
 msgid ""
 "Performs an affine transformation (shift, scale and rotate, or GPCs) on "
 "vector map."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1285
+#: ../gui/wxpython/gui_modules/menudata.py:1302
 #, fuzzy
 msgid "Reproject vector map"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1286
+#: ../gui/wxpython/gui_modules/menudata.py:1303
 #, fuzzy
 msgid "Allows projection conversion of vector maps."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1299
+#: ../gui/wxpython/gui_modules/menudata.py:1316
 #, fuzzy
 msgid "Query with attributes"
 msgstr "Abfrage"
-#: ../gui/wxpython/gui_modules/menudata.py:1300
+#: ../gui/wxpython/gui_modules/menudata.py:1317
 #, fuzzy
 msgid ""
 "Selects vector objects from an existing vector map and creates a new map "
 "containing only the selected objects."
 msgstr "Vektor Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1304
+#: ../gui/wxpython/gui_modules/menudata.py:1321
 #, fuzzy
 msgid "Query with coordinate(s)"
 msgstr "Abfrage"
-#: ../gui/wxpython/gui_modules/menudata.py:1305
+#: ../gui/wxpython/gui_modules/menudata.py:1322
 #, fuzzy
 msgid "Queries a vector map layer at given locations."
 msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
-#: ../gui/wxpython/gui_modules/menudata.py:1309
+#: ../gui/wxpython/gui_modules/menudata.py:1326
 #, fuzzy
 msgid "Query with another vector map"
 msgstr "Abfrage Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1310
+#: ../gui/wxpython/gui_modules/menudata.py:1327
 #, fuzzy
 msgid "Select features from ainput by features from binput"
 msgstr "von von"
-#: ../gui/wxpython/gui_modules/menudata.py:1315
+#: ../gui/wxpython/gui_modules/menudata.py:1332
 #, fuzzy
 msgid "Buffer vectors"
 msgstr "Vektor abfragen:"
-#: ../gui/wxpython/gui_modules/menudata.py:1316
+#: ../gui/wxpython/gui_modules/menudata.py:1333
 #, fuzzy
 msgid ""
 "Creates a buffer around features of given type (areas must contain centroid)."
@@ -5057,288 +5091,288 @@
 "Erzeugt einen Puffer um die angegebenen Geometrietypen (Flächen müssen "
 "Zentroiden enthalten)."
-#: ../gui/wxpython/gui_modules/menudata.py:1319
+#: ../gui/wxpython/gui_modules/menudata.py:1336
 #, fuzzy
 msgid "Lidar analysis"
-#: ../gui/wxpython/gui_modules/menudata.py:1321
+#: ../gui/wxpython/gui_modules/menudata.py:1338
 msgid "Detect edges"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1322
+#: ../gui/wxpython/gui_modules/menudata.py:1339
 #, fuzzy
 msgid "Detects the object's edges from a LIDAR data set."
 msgstr "Erkennt Kanten von Objekten aus einem LIDAR-Datensatz."
-#: ../gui/wxpython/gui_modules/menudata.py:1326
+#: ../gui/wxpython/gui_modules/menudata.py:1343
 msgid "Detect interiors"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1327
+#: ../gui/wxpython/gui_modules/menudata.py:1344
 #, fuzzy
 msgid ""
 "Building contour determination and Region Growing algorithm for determining "
 "the building inside"
 msgstr "Region"
-#: ../gui/wxpython/gui_modules/menudata.py:1331
+#: ../gui/wxpython/gui_modules/menudata.py:1348
 msgid "Correct and reclassify objects"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1332
+#: ../gui/wxpython/gui_modules/menudata.py:1349
 msgid ""
 "Correction of the v.lidar.growing output. It is the last of the three "
 "algorithms for LIDAR filtering."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1337
+#: ../gui/wxpython/gui_modules/menudata.py:1354
 #, fuzzy
 msgid "Linear referencing"
 msgstr "Lineare Referenzierung für Vektoren"
-#: ../gui/wxpython/gui_modules/menudata.py:1339
+#: ../gui/wxpython/gui_modules/menudata.py:1356
 #, fuzzy
 msgid "Create LRS"
-#: ../gui/wxpython/gui_modules/menudata.py:1340
+#: ../gui/wxpython/gui_modules/menudata.py:1357
 msgid "Create Linear Reference System"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1344
+#: ../gui/wxpython/gui_modules/menudata.py:1361
 #, fuzzy
 msgid "Create stationing"
 msgstr "Region-Einstellungen ändern"
-#: ../gui/wxpython/gui_modules/menudata.py:1345
+#: ../gui/wxpython/gui_modules/menudata.py:1362
 #, fuzzy
 msgid "Create stationing from input lines, and linear reference system"
 msgstr "Zeilen"
-#: ../gui/wxpython/gui_modules/menudata.py:1349
+#: ../gui/wxpython/gui_modules/menudata.py:1366
 #, fuzzy
 msgid "Create points/segments"
 msgstr "Neues Mapset erstellen"
-#: ../gui/wxpython/gui_modules/menudata.py:1350
+#: ../gui/wxpython/gui_modules/menudata.py:1367
 #, fuzzy
 msgid ""
 "Creates points/segments from input lines, linear reference system and "
 "positions read from stdin or a file."
-#: ../gui/wxpython/gui_modules/menudata.py:1354
+#: ../gui/wxpython/gui_modules/menudata.py:1371
 msgid "Find line id and offset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1355
+#: ../gui/wxpython/gui_modules/menudata.py:1372
 #, fuzzy
 msgid ""
 "Finds line id and real km+offset for given points in vector map using linear "
 "reference system."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1361
+#: ../gui/wxpython/gui_modules/menudata.py:1378
 #, fuzzy
 msgid "Nearest features"
-#: ../gui/wxpython/gui_modules/menudata.py:1362
+#: ../gui/wxpython/gui_modules/menudata.py:1379
 #, fuzzy
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
-#: ../gui/wxpython/gui_modules/menudata.py:1365
+#: ../gui/wxpython/gui_modules/menudata.py:1382
 #, fuzzy
 msgid "Network analysis"
 msgstr "Netzwerkanalysen"
-#: ../gui/wxpython/gui_modules/menudata.py:1367
+#: ../gui/wxpython/gui_modules/menudata.py:1384
 #, fuzzy
 msgid "Allocate subnets"
 msgstr "Subnetze ausweisen"
-#: ../gui/wxpython/gui_modules/menudata.py:1368
+#: ../gui/wxpython/gui_modules/menudata.py:1385
 msgid ""
 "Centre node must be opened (costs >= 0). Costs of centre node are used in "
 "calculation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1372
+#: ../gui/wxpython/gui_modules/menudata.py:1389
 #, fuzzy
 msgid "Network maintenance"
 msgstr "Netzwerkbearbeitung"
-#: ../gui/wxpython/gui_modules/menudata.py:1373
+#: ../gui/wxpython/gui_modules/menudata.py:1390
 msgid "Network maintenance."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1377
+#: ../gui/wxpython/gui_modules/menudata.py:1394
 #, fuzzy
 msgid "Visibility network"
 msgstr "Sichtbarkeitsanalyse"
-#: ../gui/wxpython/gui_modules/menudata.py:1378
+#: ../gui/wxpython/gui_modules/menudata.py:1395
 msgid "Visibility graph construction."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1382
+#: ../gui/wxpython/gui_modules/menudata.py:1399
 msgid "Shortest path"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1383
+#: ../gui/wxpython/gui_modules/menudata.py:1400
 #, fuzzy
 msgid "Finds shortest path on vector network."
 msgstr "Finden."
-#: ../gui/wxpython/gui_modules/menudata.py:1387
+#: ../gui/wxpython/gui_modules/menudata.py:1404
 #, fuzzy
 msgid "Display shortest route (requires XTerm)"
 msgstr "Darstellung"
-#: ../gui/wxpython/gui_modules/menudata.py:1388
+#: ../gui/wxpython/gui_modules/menudata.py:1405
 #, fuzzy
 msgid ""
 "Display shortest route along network between 2 nodes (visualization only, "
 "requires XTerm))"
-#: ../gui/wxpython/gui_modules/menudata.py:1392
+#: ../gui/wxpython/gui_modules/menudata.py:1409
 #, fuzzy
 msgid "Split net"
-#: ../gui/wxpython/gui_modules/menudata.py:1393
+#: ../gui/wxpython/gui_modules/menudata.py:1410
 msgid ""
 "Splits net to bands between cost isolines (direction from centre). Centre "
 "node must be opened (costs >= 0). Costs of centre node are used in "
 "calculation."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1397
+#: ../gui/wxpython/gui_modules/menudata.py:1414
 #, fuzzy
 msgid "Steiner tree"
 msgstr "Steiner-Problematik"
-#: ../gui/wxpython/gui_modules/menudata.py:1398
+#: ../gui/wxpython/gui_modules/menudata.py:1415
 msgid ""
 "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
 "is used in this module so the result may be sub optimal"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1402
+#: ../gui/wxpython/gui_modules/menudata.py:1419
 #, fuzzy
 msgid "Traveling salesman analysis"
 msgstr "Traveling-Salesman-Problematik"
-#: ../gui/wxpython/gui_modules/menudata.py:1403
+#: ../gui/wxpython/gui_modules/menudata.py:1420
 msgid ""
 "Note that TSP is NP-hard, heuristic algorithm is used by this module and "
 "created cycle may be sub optimal"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1408
-#: ../gui/wxpython/gui_modules/menudata.py:1410
+#: ../gui/wxpython/gui_modules/menudata.py:1425
+#: ../gui/wxpython/gui_modules/menudata.py:1427
 #, fuzzy
 msgid "Overlay vector maps"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1411
+#: ../gui/wxpython/gui_modules/menudata.py:1428
 #, fuzzy
 msgid "Overlays two vector maps."
 msgstr "Name der Vektorkarte"
-#: ../gui/wxpython/gui_modules/menudata.py:1415
+#: ../gui/wxpython/gui_modules/menudata.py:1432
 #, fuzzy
 msgid "Patch vector maps"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1416
+#: ../gui/wxpython/gui_modules/menudata.py:1433
 #, fuzzy
 msgid "Create a new vector map layer by combining other vector map layers."
-#: ../gui/wxpython/gui_modules/menudata.py:1422
+#: ../gui/wxpython/gui_modules/menudata.py:1439
 #, fuzzy
 msgid "Change attributes"
 msgstr "Attribute verändern"
-#: ../gui/wxpython/gui_modules/menudata.py:1424
+#: ../gui/wxpython/gui_modules/menudata.py:1441
 #, fuzzy
 msgid "Manage or report categories"
 msgstr "Kategorien hinzufügen, löschen oder berichten"
-#: ../gui/wxpython/gui_modules/menudata.py:1425
+#: ../gui/wxpython/gui_modules/menudata.py:1442
 #, fuzzy
 msgid "Attach, delete or report vector categories to map geometry."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1429
+#: ../gui/wxpython/gui_modules/menudata.py:1446
 #, fuzzy
 msgid "Reclassify objects interactively"
 msgstr "Bild klassifizieren"
-#: ../gui/wxpython/gui_modules/menudata.py:1430
+#: ../gui/wxpython/gui_modules/menudata.py:1447
 #, fuzzy
 msgid "Reclassify vector objects interactively by entering SQL rules"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1434
+#: ../gui/wxpython/gui_modules/menudata.py:1451
 msgid "Reclassify objects using rules file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1435
+#: ../gui/wxpython/gui_modules/menudata.py:1452
 #, fuzzy
 msgid ""
 "Changes vector category values for an existing vector map according to "
 "results of SQL queries or a value in attribute table column."
-#: ../gui/wxpython/gui_modules/menudata.py:1442
+#: ../gui/wxpython/gui_modules/menudata.py:1459
 #, fuzzy
 msgid "Generate area for current region"
 msgstr "Bereich feature für von"
-#: ../gui/wxpython/gui_modules/menudata.py:1443
+#: ../gui/wxpython/gui_modules/menudata.py:1460
 #, fuzzy
 msgid "Create a new vector from the current region."
 msgstr "Startpunkt %d ist außerhalb der aktuellen Region."
-#: ../gui/wxpython/gui_modules/menudata.py:1446
+#: ../gui/wxpython/gui_modules/menudata.py:1463
 #, fuzzy
 msgid "Generate areas from points"
 msgstr "Flächen aus Punkten erzeugen"
-#: ../gui/wxpython/gui_modules/menudata.py:1448
+#: ../gui/wxpython/gui_modules/menudata.py:1465
 msgid "Convex hull"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1449
+#: ../gui/wxpython/gui_modules/menudata.py:1466
 #, fuzzy
 msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#: ../gui/wxpython/gui_modules/menudata.py:1453
+#: ../gui/wxpython/gui_modules/menudata.py:1470
 #, fuzzy
 msgid "Delaunay triangles"
 msgstr "Delaunay-Dreiecke aus Punktwolke erzeugen"
-#: ../gui/wxpython/gui_modules/menudata.py:1454
+#: ../gui/wxpython/gui_modules/menudata.py:1471
 #, fuzzy
 msgid ""
 "Creates a Delaunay triangulation from an input vector map containing points "
 "or centroids."
 msgstr "Erstellen."
-#: ../gui/wxpython/gui_modules/menudata.py:1458
+#: ../gui/wxpython/gui_modules/menudata.py:1475
 #, fuzzy
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr "Voronoi Diagram/Thiessen Polygone aus Punktwolke erzeugen"
-#: ../gui/wxpython/gui_modules/menudata.py:1459
+#: ../gui/wxpython/gui_modules/menudata.py:1476
 #, fuzzy
 msgid ""
 "Creates a Voronoi diagram from an input vector map containing points or "
@@ -5347,26 +5381,26 @@
 "Erstellt eine Rasterkarte und eine Vektorpunktkarte, die zufällig "
 "angeordnete Punkte enthalten."
-#: ../gui/wxpython/gui_modules/menudata.py:1465
+#: ../gui/wxpython/gui_modules/menudata.py:1482
 #, fuzzy
 msgid "Generate grid"
 msgstr "Erzeuge Punkte"
-#: ../gui/wxpython/gui_modules/menudata.py:1466
+#: ../gui/wxpython/gui_modules/menudata.py:1483
 #, fuzzy
 msgid "Creates a GRASS vector map of a user-defined grid."
-#: ../gui/wxpython/gui_modules/menudata.py:1469
+#: ../gui/wxpython/gui_modules/menudata.py:1486
 #, fuzzy
 msgid "Generate points"
-#: ../gui/wxpython/gui_modules/menudata.py:1471
+#: ../gui/wxpython/gui_modules/menudata.py:1488
 msgid "Generate from database"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1472
+#: ../gui/wxpython/gui_modules/menudata.py:1489
 #, fuzzy
 msgid ""
 "Creates new vector (points) map from database table containing coordinates."
@@ -5374,248 +5408,248 @@
 "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
 "Koordinaten beinhaltet."
-#: ../gui/wxpython/gui_modules/menudata.py:1476
+#: ../gui/wxpython/gui_modules/menudata.py:1493
 #, fuzzy
 msgid "Generate points along lines"
-#: ../gui/wxpython/gui_modules/menudata.py:1477
+#: ../gui/wxpython/gui_modules/menudata.py:1494
 #, fuzzy
 msgid "Create points along input lines in new vector with 2 layers."
-#: ../gui/wxpython/gui_modules/menudata.py:1481
+#: ../gui/wxpython/gui_modules/menudata.py:1498
 #, fuzzy
 msgid "Generate random points"
 msgstr "Erzeuge zufällige Punkte"
-#: ../gui/wxpython/gui_modules/menudata.py:1482
+#: ../gui/wxpython/gui_modules/menudata.py:1499
 #, fuzzy
 msgid "Randomly generate a 2D/3D vector points map."
 msgstr "Erzeugt zufällige 3D/3D GRASS Vektorpunkt-Karten."
-#: ../gui/wxpython/gui_modules/menudata.py:1486
+#: ../gui/wxpython/gui_modules/menudata.py:1503
 #, fuzzy
 msgid "Perturb points"
-#: ../gui/wxpython/gui_modules/menudata.py:1487
+#: ../gui/wxpython/gui_modules/menudata.py:1504
 #, fuzzy
 msgid "Random location perturbations of GRASS vector points"
 msgstr "von"
-#: ../gui/wxpython/gui_modules/menudata.py:1494
+#: ../gui/wxpython/gui_modules/menudata.py:1511
 #, fuzzy
 msgid "Remove outliers in point sets"
 msgstr "Interpoliere Volumen aus Punkten mit Hilfe von Splines"
-#: ../gui/wxpython/gui_modules/menudata.py:1495
+#: ../gui/wxpython/gui_modules/menudata.py:1512
 #, fuzzy
 msgid "Removes outliers from vector point data."
 msgstr "Name der Eingabe-Vektorkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1499
+#: ../gui/wxpython/gui_modules/menudata.py:1516
 #, fuzzy
 msgid "Test/training point sets"
 msgstr "Testen"
-#: ../gui/wxpython/gui_modules/menudata.py:1500
+#: ../gui/wxpython/gui_modules/menudata.py:1517
 #, fuzzy
 msgid "Randomly partition points into test/train sets."
 msgstr "Punkte."
-#: ../gui/wxpython/gui_modules/menudata.py:1505
+#: ../gui/wxpython/gui_modules/menudata.py:1522
 #, fuzzy
 msgid "Update area attributes from raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1506
+#: ../gui/wxpython/gui_modules/menudata.py:1523
 #, fuzzy
 msgid ""
 "Calculates univariate statistics from a GRASS raster map based on vector "
 "polygons and uploads statistics to new attribute columns."
 msgstr "Raster Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1510
+#: ../gui/wxpython/gui_modules/menudata.py:1527
 #, fuzzy
 msgid "Update point attributes from areas"
 msgstr "Editiere Attribute (im Formmodus)"
-#: ../gui/wxpython/gui_modules/menudata.py:1511
+#: ../gui/wxpython/gui_modules/menudata.py:1528
 #, fuzzy
 msgid "Uploads vector values at positions of vector points to the table."
-#: ../gui/wxpython/gui_modules/menudata.py:1514
+#: ../gui/wxpython/gui_modules/menudata.py:1531
 #, fuzzy
 msgid "Update point attributes from raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1516
+#: ../gui/wxpython/gui_modules/menudata.py:1533
 #, fuzzy
 msgid "Sample raster maps at point locations"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1517
+#: ../gui/wxpython/gui_modules/menudata.py:1534
 #, fuzzy
 msgid "Uploads raster values at positions of vector points to the table."
 msgstr ""
 "Überninmmt die Rasterwerte an einem angegebenen Vektor-Punkt in die "
 "Attributtabelle."
-#: ../gui/wxpython/gui_modules/menudata.py:1521
+#: ../gui/wxpython/gui_modules/menudata.py:1538
 #, fuzzy
 msgid "Sample raster neighborhood around points"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1522
+#: ../gui/wxpython/gui_modules/menudata.py:1539
 #, fuzzy
 msgid "Samples a raster map at vector point locations."
 msgstr "a an"
-#: ../gui/wxpython/gui_modules/menudata.py:1528
+#: ../gui/wxpython/gui_modules/menudata.py:1545
 #, fuzzy
 msgid "Reports and statistics"
 msgstr "Reports und Statistiken"
-#: ../gui/wxpython/gui_modules/menudata.py:1530
+#: ../gui/wxpython/gui_modules/menudata.py:1547
 #, fuzzy
 msgid "Basic vector metadata"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1531
+#: ../gui/wxpython/gui_modules/menudata.py:1548
 #, fuzzy
 msgid "Outputs basic information about a user-specified vector map layer."
 msgstr "Gibt Basisinformationen über eine angegebene Vektorkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1536
+#: ../gui/wxpython/gui_modules/menudata.py:1553
 #, fuzzy
 msgid "Report topology by category"
 msgstr "Topologie"
-#: ../gui/wxpython/gui_modules/menudata.py:1537
+#: ../gui/wxpython/gui_modules/menudata.py:1554
 #, fuzzy
 msgid "Reports geometry statistics for vectors."
 msgstr "Berichtet statistische Kennzahlen der Geometrien einer Vektorkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1541
+#: ../gui/wxpython/gui_modules/menudata.py:1558
 #, fuzzy
 msgid "Upload or report topology"
 msgstr "Topologie"
-#: ../gui/wxpython/gui_modules/menudata.py:1542
+#: ../gui/wxpython/gui_modules/menudata.py:1559
 #, fuzzy
 msgid "Populate database values from vector features."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1547
+#: ../gui/wxpython/gui_modules/menudata.py:1564
 #, fuzzy
 msgid "Univariate attribute statistics"
 msgstr "Univariate Statistik"
-#: ../gui/wxpython/gui_modules/menudata.py:1548
+#: ../gui/wxpython/gui_modules/menudata.py:1565
 #, fuzzy
 msgid ""
 "Calculates univariate statistics for attribute. Variance and standard "
 "deviation is calculated only for points if specified."
 msgstr "für attribute Abweichung ist für"
-#: ../gui/wxpython/gui_modules/menudata.py:1553
+#: ../gui/wxpython/gui_modules/menudata.py:1570
 msgid "Quadrat indices"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1554
+#: ../gui/wxpython/gui_modules/menudata.py:1571
 #, fuzzy
 msgid "Indices for quadrat counts of sites lists."
 msgstr "Sites."
-#: ../gui/wxpython/gui_modules/menudata.py:1558
+#: ../gui/wxpython/gui_modules/menudata.py:1575
 #, fuzzy
 msgid "Test normality"
 msgstr "Testen"
-#: ../gui/wxpython/gui_modules/menudata.py:1559
+#: ../gui/wxpython/gui_modules/menudata.py:1576
 #, fuzzy
 msgid "Tests for normality for points."
 msgstr "Zu viele Startpunkte."
-#: ../gui/wxpython/gui_modules/menudata.py:1566
+#: ../gui/wxpython/gui_modules/menudata.py:1583
 msgid "Imagery"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1567
+#: ../gui/wxpython/gui_modules/menudata.py:1584
 #, fuzzy
 msgid "Develop images and groups"
 msgstr "Bilder"
-#: ../gui/wxpython/gui_modules/menudata.py:1569
+#: ../gui/wxpython/gui_modules/menudata.py:1586
 #, fuzzy
 msgid "Create/edit group"
 msgstr "2. Erzeuge/bearbeite Gruppe"
-#: ../gui/wxpython/gui_modules/menudata.py:1570
+#: ../gui/wxpython/gui_modules/menudata.py:1587
 #, fuzzy
 msgid "Creates, edits, and lists groups and subgroups of imagery files."
 msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
-#: ../gui/wxpython/gui_modules/menudata.py:1574
+#: ../gui/wxpython/gui_modules/menudata.py:1591
 #, fuzzy
 msgid "Target group"
 msgstr "Zielbildgruppe"
-#: ../gui/wxpython/gui_modules/menudata.py:1575
+#: ../gui/wxpython/gui_modules/menudata.py:1592
 #, fuzzy
 msgid "Targets an imagery group to a GRASS location and mapset."
 msgstr "Legt das Ziel für eine Bildgruppe auf eine GRASS Location mit Mapset."
-#: ../gui/wxpython/gui_modules/menudata.py:1580
+#: ../gui/wxpython/gui_modules/menudata.py:1597
 #, fuzzy
 msgid "Mosaic images"
 msgstr "Bis zu 4 zusammenpassende Bilder mosaikieren"
-#: ../gui/wxpython/gui_modules/menudata.py:1581
+#: ../gui/wxpython/gui_modules/menudata.py:1598
 msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1586
+#: ../gui/wxpython/gui_modules/menudata.py:1603
 #, fuzzy
 msgid "Manage image colors"
 msgstr "Verwalte Bildfarben"
-#: ../gui/wxpython/gui_modules/menudata.py:1588
+#: ../gui/wxpython/gui_modules/menudata.py:1605
 #, fuzzy
 msgid "Color balance for RGB"
 msgstr "Farben"
-#: ../gui/wxpython/gui_modules/menudata.py:1589
+#: ../gui/wxpython/gui_modules/menudata.py:1606
 msgid "Auto-balancing of colors for LANDSAT images"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1593
+#: ../gui/wxpython/gui_modules/menudata.py:1610
 #, fuzzy
 msgid "HIS to RGB"
 msgstr "Hilfe für RGB"
-#: ../gui/wxpython/gui_modules/menudata.py:1594
+#: ../gui/wxpython/gui_modules/menudata.py:1611
 #, fuzzy
 msgid ""
 "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
 "transformation function."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/menudata.py:1599
+#: ../gui/wxpython/gui_modules/menudata.py:1616
 #, fuzzy
 msgid ""
 "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
 "transformation function"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1605
+#: ../gui/wxpython/gui_modules/menudata.py:1622
 #, fuzzy
 msgid "Rectify image or raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1606
+#: ../gui/wxpython/gui_modules/menudata.py:1623
 #, fuzzy
 msgid ""
 "Rectifies an image by computing a coordinate transformation for each pixel "
@@ -5624,63 +5658,88 @@
 "Entzerrt ein Bild indem eine Koordinatentransformation für jeden Bildpunkt "
 "des Bildes basierend auf Kontrollpunkten durchgeführt wird."
-#: ../gui/wxpython/gui_modules/menudata.py:1610
+#: ../gui/wxpython/gui_modules/menudata.py:1627
 msgid "Ortho photo rectification (requires Xterm)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1611
+#: ../gui/wxpython/gui_modules/menudata.py:1628
 msgid "Ortho Photo rectification"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1616
+#: ../gui/wxpython/gui_modules/menudata.py:1633
 msgid "Basic RS processing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1618
+#: ../gui/wxpython/gui_modules/menudata.py:1635
 msgid "MODIS Quality Flags"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1619
+#: ../gui/wxpython/gui_modules/menudata.py:1636
 msgid "Extract Modis Quality flags as raster values."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1624
+#: ../gui/wxpython/gui_modules/menudata.py:1640
+msgid "Latitude/longitude maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1641
+msgid "Creates Latitude or Longitude map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1645
+msgid "Potential Sunshine Hours"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1646
+msgid "Creates Potential Sunshine Hours map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1651
 msgid "Albedo"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1625
+#: ../gui/wxpython/gui_modules/menudata.py:1652
 msgid "Albedo from Modis, Aster, Landsat, AVHRR."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1629
+#: ../gui/wxpython/gui_modules/menudata.py:1656
 #, fuzzy
 msgid "Vegetation Indices"
 msgstr "Regionsgrenzen"
-#: ../gui/wxpython/gui_modules/menudata.py:1630
+#: ../gui/wxpython/gui_modules/menudata.py:1657
 msgid "14 types of vegetation Indices."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1637
+#: ../gui/wxpython/gui_modules/menudata.py:1662
+#, fuzzy
+msgid "Emissivity"
+msgstr "Sichtbarkeit"
+#: ../gui/wxpython/gui_modules/menudata.py:1663
+msgid "Emissivity from NDVI."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1670
 msgid "Brovey sharpening"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1638
+#: ../gui/wxpython/gui_modules/menudata.py:1671
 msgid ""
 "Brovey transform to merge multispectral and high-res panchromatic channels"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1641
+#: ../gui/wxpython/gui_modules/menudata.py:1674
 #, fuzzy
 msgid "Classify image"
-#: ../gui/wxpython/gui_modules/menudata.py:1643
+#: ../gui/wxpython/gui_modules/menudata.py:1676
 #, fuzzy
 msgid "Clustering input for unsupervised classification"
 msgstr "für"
-#: ../gui/wxpython/gui_modules/menudata.py:1644
+#: ../gui/wxpython/gui_modules/menudata.py:1677
 #, fuzzy
 msgid ""
 "The resulting signature file is used as input for i.maxlik, to generate an "
@@ -5690,11 +5749,11 @@
 "aus einem Bild ermittelt. Die resultierende Signaturdatei kann als Eingabe "
 "für i.maxlik für eine unüberwachte Klassifikation verwendet werden."
-#: ../gui/wxpython/gui_modules/menudata.py:1649
+#: ../gui/wxpython/gui_modules/menudata.py:1682
 msgid "Maximum likelihood classification (MLC)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1650
+#: ../gui/wxpython/gui_modules/menudata.py:1683
 #, fuzzy
 msgid ""
 "Classification is based on the spectral signature information generated by "
@@ -5704,11 +5763,11 @@
 "basierend auf der spektralen Signaturinformation (generiert durch i.cluster, "
 "i.class oder i.gensig) klassifiziert."
-#: ../gui/wxpython/gui_modules/menudata.py:1654
+#: ../gui/wxpython/gui_modules/menudata.py:1687
 msgid "Sequential maximum a posteriori classification (SMAP)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1655
+#: ../gui/wxpython/gui_modules/menudata.py:1688
 #, fuzzy
 msgid ""
 "Performs contextual image classification using sequential maximum a "
@@ -5717,153 +5776,153 @@
 "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
 "'sequential maximum a posteriori (SMAP)' Ansatzes durch."
-#: ../gui/wxpython/gui_modules/menudata.py:1660
+#: ../gui/wxpython/gui_modules/menudata.py:1693
 msgid "Interactive input for supervised classification (requires Xterm)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1661
+#: ../gui/wxpython/gui_modules/menudata.py:1694
 #, fuzzy
 msgid "Interactive input for supervised classification"
 msgstr "Interaktive Eingabe für die überwachte Klassifikation"
-#: ../gui/wxpython/gui_modules/menudata.py:1665
+#: ../gui/wxpython/gui_modules/menudata.py:1698
 #, fuzzy
 msgid "Input for supervised MLC"
 msgstr "Eingabe"
-#: ../gui/wxpython/gui_modules/menudata.py:1666
+#: ../gui/wxpython/gui_modules/menudata.py:1699
 #, fuzzy
 msgid "Generates statistics for i.maxlik from raster map layer."
 msgstr "Erstelle Statistiken für i.maxlik aus der Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1670
+#: ../gui/wxpython/gui_modules/menudata.py:1703
 #, fuzzy
 msgid "Input for supervised SMAP"
 msgstr "Eingabe"
-#: ../gui/wxpython/gui_modules/menudata.py:1671
+#: ../gui/wxpython/gui_modules/menudata.py:1704
 #, fuzzy
 msgid "Generate statistics for i.smap from raster map layer."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/menudata.py:1676
+#: ../gui/wxpython/gui_modules/menudata.py:1709
 #, fuzzy
 msgid "Filter image"
 msgstr "Bild filtern"
-#: ../gui/wxpython/gui_modules/menudata.py:1678
+#: ../gui/wxpython/gui_modules/menudata.py:1711
 #, fuzzy
 msgid "Edge detection"
 msgstr "Linierichtung"
-#: ../gui/wxpython/gui_modules/menudata.py:1679
+#: ../gui/wxpython/gui_modules/menudata.py:1712
 #, fuzzy
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/menudata.py:1683
+#: ../gui/wxpython/gui_modules/menudata.py:1716
 #, fuzzy
 msgid "Matrix/convolving filter"
 msgstr "Benutzerdefinierter Matrix/Convolv-Filter"
-#: ../gui/wxpython/gui_modules/menudata.py:1684
+#: ../gui/wxpython/gui_modules/menudata.py:1717
 #, fuzzy
 msgid "Raster map matrix filter."
 msgstr "Rasterdatei mit Matrix-Filter"
-#: ../gui/wxpython/gui_modules/menudata.py:1691
+#: ../gui/wxpython/gui_modules/menudata.py:1724
 msgid "Generate histogram of image"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1695
+#: ../gui/wxpython/gui_modules/menudata.py:1728
 #, fuzzy
 msgid "Spectral response"
 msgstr "Spektrale Antwort"
-#: ../gui/wxpython/gui_modules/menudata.py:1696
+#: ../gui/wxpython/gui_modules/menudata.py:1729
 msgid ""
 "displays spectral response at user specified locations in group or images"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1700
+#: ../gui/wxpython/gui_modules/menudata.py:1733
 msgid "Tasseled cap vegetation index"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1701
+#: ../gui/wxpython/gui_modules/menudata.py:1734
 #, fuzzy
 msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
 msgstr "Daten"
-#: ../gui/wxpython/gui_modules/menudata.py:1704
+#: ../gui/wxpython/gui_modules/menudata.py:1737
 #, fuzzy
 msgid "Transform image"
 msgstr "Bild umformen"
-#: ../gui/wxpython/gui_modules/menudata.py:1706
+#: ../gui/wxpython/gui_modules/menudata.py:1739
 #, fuzzy
 msgid "Canonical correlation"
-#: ../gui/wxpython/gui_modules/menudata.py:1707
+#: ../gui/wxpython/gui_modules/menudata.py:1740
 #, fuzzy
 msgid "Canonical components analysis (cca) program for image processing."
 msgstr ""
 "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
-#: ../gui/wxpython/gui_modules/menudata.py:1711
+#: ../gui/wxpython/gui_modules/menudata.py:1744
 #, fuzzy
 msgid "Principal components"
 msgstr "Hauptkomponente"
-#: ../gui/wxpython/gui_modules/menudata.py:1712
+#: ../gui/wxpython/gui_modules/menudata.py:1745
 #, fuzzy
 msgid "Principal components analysis (pca) program for image processing."
 msgstr "Hauptkomponentenanalyse (PCA) Program für die Bildverarbeitung."
-#: ../gui/wxpython/gui_modules/menudata.py:1716
+#: ../gui/wxpython/gui_modules/menudata.py:1749
 #, fuzzy
 msgid "Fast Fourier"
 msgstr "Fast Fourier Transformation"
-#: ../gui/wxpython/gui_modules/menudata.py:1717
+#: ../gui/wxpython/gui_modules/menudata.py:1750
 #, fuzzy
 msgid "Fast Fourier Transform (FFT) for image processing."
 msgstr "Fast Fourier Transformation (FFT) für die Bildverarbeitung."
-#: ../gui/wxpython/gui_modules/menudata.py:1721
+#: ../gui/wxpython/gui_modules/menudata.py:1754
 #, fuzzy
 msgid "Inverse Fast Fourier"
 msgstr "Inverse Fast Fourier Transformtion"
-#: ../gui/wxpython/gui_modules/menudata.py:1722
+#: ../gui/wxpython/gui_modules/menudata.py:1755
 #, fuzzy
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
 msgstr "Inverse Fast Fourier Transformation (ifft) für die Bildverarbeitung."
-#: ../gui/wxpython/gui_modules/menudata.py:1727
+#: ../gui/wxpython/gui_modules/menudata.py:1760
 #, fuzzy
 msgid "Atmospheric correction"
-#: ../gui/wxpython/gui_modules/menudata.py:1728
+#: ../gui/wxpython/gui_modules/menudata.py:1761
 msgid "Performs atmospheric correction using the 6S algorithm."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1734
+#: ../gui/wxpython/gui_modules/menudata.py:1767
 msgid "Bit pattern comparison "
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1735
+#: ../gui/wxpython/gui_modules/menudata.py:1768
 #, fuzzy
 msgid "Compares bit patterns with a raster map."
 msgstr "Vergleicht Bitpattern mit einer Rasterkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1739
+#: ../gui/wxpython/gui_modules/menudata.py:1772
 #, fuzzy
 msgid "Kappa analysis"
 msgstr "Querformat"
-#: ../gui/wxpython/gui_modules/menudata.py:1740
+#: ../gui/wxpython/gui_modules/menudata.py:1773
 #, fuzzy
 msgid ""
 "Calculate error matrix and kappa parameter for accuracy assessment of "
@@ -5872,333 +5931,333 @@
 "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
 "(accuracy assessment) der Klassifikationsergebnisse."
-#: ../gui/wxpython/gui_modules/menudata.py:1744
+#: ../gui/wxpython/gui_modules/menudata.py:1777
 #, fuzzy
 msgid "OIF for LandSat TM"
 msgstr "Optimaler Indexfaktor für LandSat TM"
-#: ../gui/wxpython/gui_modules/menudata.py:1745
+#: ../gui/wxpython/gui_modules/menudata.py:1778
 msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1752
+#: ../gui/wxpython/gui_modules/menudata.py:1785
 msgid "Volumes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1753
+#: ../gui/wxpython/gui_modules/menudata.py:1786
 msgid "Develop volumes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1755
+#: ../gui/wxpython/gui_modules/menudata.py:1788
 msgid "Manage 3D NULL values"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1756
+#: ../gui/wxpython/gui_modules/menudata.py:1789
 #, fuzzy
 msgid "Explicitly create the 3D NULL-value bitmap file."
 msgstr "Erstelle explizit ein 3D NULL-Wert Bitmap-Bild."
-#: ../gui/wxpython/gui_modules/menudata.py:1760
+#: ../gui/wxpython/gui_modules/menudata.py:1793
 msgid "Manage timestamp"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1761
+#: ../gui/wxpython/gui_modules/menudata.py:1794
 #, fuzzy
 msgid "Print/add/remove a timestamp for a 3D raster map"
 msgstr "Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für 3D-Rasterkarten"
-#: ../gui/wxpython/gui_modules/menudata.py:1768
+#: ../gui/wxpython/gui_modules/menudata.py:1801
 msgid "3D Mask"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1769
+#: ../gui/wxpython/gui_modules/menudata.py:1802
 #, fuzzy
 msgid "Establishes the current working 3D raster mask."
 msgstr "Aktuelle 3D Maske erstellt."
-#: ../gui/wxpython/gui_modules/menudata.py:1773
+#: ../gui/wxpython/gui_modules/menudata.py:1806
 #, fuzzy
 msgid "3D raster map calculator"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/menudata.py:1774
+#: ../gui/wxpython/gui_modules/menudata.py:1807
 msgid "Map calculator for volumetric map algebra"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1778
+#: ../gui/wxpython/gui_modules/menudata.py:1811
 msgid "Cross section"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1779
+#: ../gui/wxpython/gui_modules/menudata.py:1812
 #, fuzzy
 msgid ""
 "Creates cross section 2D raster map from 3d raster map based on 2D elevation "
 "map"
 msgstr "Erzeugt eine section von Lautstärke ein"
-#: ../gui/wxpython/gui_modules/menudata.py:1783
+#: ../gui/wxpython/gui_modules/menudata.py:1816
 #, fuzzy
 msgid "Interpolate volume from points"
 msgstr "Punkte"
-#: ../gui/wxpython/gui_modules/menudata.py:1784
+#: ../gui/wxpython/gui_modules/menudata.py:1817
 #, fuzzy
 msgid ""
 "Interpolates point data to a G3D grid volume using regularized spline with "
 "tension (RST) algorithm."
 msgstr "Daten."
-#: ../gui/wxpython/gui_modules/menudata.py:1788
+#: ../gui/wxpython/gui_modules/menudata.py:1821
 #, fuzzy
 msgid "Report and Statistics"
 msgstr "Report und Statistiken"
-#: ../gui/wxpython/gui_modules/menudata.py:1790
+#: ../gui/wxpython/gui_modules/menudata.py:1823
 msgid "Basic volume metadata"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1791
+#: ../gui/wxpython/gui_modules/menudata.py:1824
 #, fuzzy
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr ""
 "Gibt Basisinformationen über eine durch den Benutzer angegebene 3D "
 "Rasterkarte aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1798
+#: ../gui/wxpython/gui_modules/menudata.py:1831
 #: ../gui/wxpython/gui_modules/dbm.py:2019
 #: ../gui/wxpython/gui_modules/dbm.py:2131
 #: ../gui/wxpython/gui_modules/dbm.py:2370
 msgid "Database"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1799
+#: ../gui/wxpython/gui_modules/menudata.py:1832
 #, fuzzy
 msgid "Database information"
 msgstr "Datenbankinformation"
-#: ../gui/wxpython/gui_modules/menudata.py:1801
+#: ../gui/wxpython/gui_modules/menudata.py:1834
 #, fuzzy
 msgid "Describe table"
 msgstr "Tabelle beschreiben"
-#: ../gui/wxpython/gui_modules/menudata.py:1802
+#: ../gui/wxpython/gui_modules/menudata.py:1835
 #, fuzzy
 msgid "Describes a table in detail."
 msgstr "Beschreibt eine Tabelle (im Detail)."
-#: ../gui/wxpython/gui_modules/menudata.py:1806
+#: ../gui/wxpython/gui_modules/menudata.py:1839
 #, fuzzy
 msgid "List columns"
 msgstr "Spalten auflisten"
-#: ../gui/wxpython/gui_modules/menudata.py:1807
+#: ../gui/wxpython/gui_modules/menudata.py:1840
 #, fuzzy
 msgid "List all columns for a given table."
 msgstr "Listet alle Spalten einer Tabelle auf."
-#: ../gui/wxpython/gui_modules/menudata.py:1811
+#: ../gui/wxpython/gui_modules/menudata.py:1844
 #, fuzzy
 msgid "List drivers"
 msgstr "Treiber auflisten"
-#: ../gui/wxpython/gui_modules/menudata.py:1812
+#: ../gui/wxpython/gui_modules/menudata.py:1845
 #, fuzzy
 msgid "List all database drivers."
 msgstr "Listet alle verfügbaren Datenbanktreiber auf."
-#: ../gui/wxpython/gui_modules/menudata.py:1816
+#: ../gui/wxpython/gui_modules/menudata.py:1849
 #, fuzzy
 msgid "List tables"
 msgstr "Tabellen auflisten"
-#: ../gui/wxpython/gui_modules/menudata.py:1817
+#: ../gui/wxpython/gui_modules/menudata.py:1850
 #, fuzzy
 msgid "Lists all tables for a given database."
 msgstr "Listet alle Tabellen für eine angegebene Datenbank auf."
-#: ../gui/wxpython/gui_modules/menudata.py:1823
+#: ../gui/wxpython/gui_modules/menudata.py:1856
 msgid "Manage databases"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1825
+#: ../gui/wxpython/gui_modules/menudata.py:1858
 msgid "Connect"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1826
+#: ../gui/wxpython/gui_modules/menudata.py:1859
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset and exits."
 msgstr ""
 "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
 "beendet sich."
-#: ../gui/wxpython/gui_modules/menudata.py:1830
+#: ../gui/wxpython/gui_modules/menudata.py:1863
 msgid "Login"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1831
+#: ../gui/wxpython/gui_modules/menudata.py:1864
 #, fuzzy
 msgid "Sets user/password for driver/database."
 msgstr "Setzt Benutzername/Passwort für Treiber/Datenbank."
-#: ../gui/wxpython/gui_modules/menudata.py:1836
+#: ../gui/wxpython/gui_modules/menudata.py:1869
 #, fuzzy
 msgid "Copy table"
 msgstr "Tabelle kopieren"
-#: ../gui/wxpython/gui_modules/menudata.py:1837
+#: ../gui/wxpython/gui_modules/menudata.py:1870
 #, fuzzy
 msgid ""
 "Copy a table. Either 'from_table' (optionally with 'where') can be used or "
 "'select' option, but not 'from_table' and 'select' at the same time."
 msgstr "Kopiere Karten."
-#: ../gui/wxpython/gui_modules/menudata.py:1841
+#: ../gui/wxpython/gui_modules/menudata.py:1874
 #, fuzzy
 msgid "New table"
-#: ../gui/wxpython/gui_modules/menudata.py:1842
+#: ../gui/wxpython/gui_modules/menudata.py:1875
 #, fuzzy
 msgid ""
 "Creates and adds a new attribute table to a given layer of an existing "
 "vector map."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1846
+#: ../gui/wxpython/gui_modules/menudata.py:1879
 #, fuzzy
 msgid "Remove table"
 msgstr "Entferne Vertex"
-#: ../gui/wxpython/gui_modules/menudata.py:1847
+#: ../gui/wxpython/gui_modules/menudata.py:1880
 #, fuzzy
 msgid "Drops an attribute table."
 msgstr "Abfragen Vektor Daten"
-#: ../gui/wxpython/gui_modules/menudata.py:1852
+#: ../gui/wxpython/gui_modules/menudata.py:1885
 #, fuzzy
 msgid "Add columns"
 msgstr "Neue Spalte hinzufügen"
-#: ../gui/wxpython/gui_modules/menudata.py:1853
+#: ../gui/wxpython/gui_modules/menudata.py:1886
 #, fuzzy
 msgid ""
 "Adds one or more columns to the attribute table connected to a given vector "
 "map."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1857
+#: ../gui/wxpython/gui_modules/menudata.py:1890
 #, fuzzy
 msgid "Change values"
-#: ../gui/wxpython/gui_modules/menudata.py:1858
+#: ../gui/wxpython/gui_modules/menudata.py:1891
 #, fuzzy
 msgid ""
 "Allows to update a column in the attribute table connected to a vector map."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1862
+#: ../gui/wxpython/gui_modules/menudata.py:1895
 #: ../gui/wxpython/gui_modules/dbm.py:765
 #, fuzzy
 msgid "Rename column"
 msgstr "Nenne Karten um"
-#: ../gui/wxpython/gui_modules/menudata.py:1863
+#: ../gui/wxpython/gui_modules/menudata.py:1896
 #, fuzzy
 msgid ""
 "Renames a column in the attribute table connected to a given vector map."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/menudata.py:1868
+#: ../gui/wxpython/gui_modules/menudata.py:1901
 #, fuzzy
 msgid "Test"
 msgstr "Testen"
-#: ../gui/wxpython/gui_modules/menudata.py:1869
+#: ../gui/wxpython/gui_modules/menudata.py:1902
 #, fuzzy
 msgid "Test database driver, database must exist and set by db.connect."
 msgstr "Testen."
-#: ../gui/wxpython/gui_modules/menudata.py:1874
+#: ../gui/wxpython/gui_modules/menudata.py:1907
 #, fuzzy
 msgid "Query"
 msgstr "Abfrage"
-#: ../gui/wxpython/gui_modules/menudata.py:1876
+#: ../gui/wxpython/gui_modules/menudata.py:1909
 #, fuzzy
 msgid "Query any table"
 msgstr "Abfrage"
-#: ../gui/wxpython/gui_modules/menudata.py:1877
+#: ../gui/wxpython/gui_modules/menudata.py:1910
 #, fuzzy
 msgid "Selects data from table."
 msgstr "Selektiert Daten aus der Tabelle"
-#: ../gui/wxpython/gui_modules/menudata.py:1881
+#: ../gui/wxpython/gui_modules/menudata.py:1914
 #, fuzzy
 msgid "Query vector attribute data"
-#: ../gui/wxpython/gui_modules/menudata.py:1882
+#: ../gui/wxpython/gui_modules/menudata.py:1915
 #, fuzzy
 msgid "Prints vector map attributes."
 msgstr "Gebe Vektorattribute aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1886
+#: ../gui/wxpython/gui_modules/menudata.py:1919
 #, fuzzy
 msgid "SQL statement"
 msgstr "SQL-Statement ausführen"
-#: ../gui/wxpython/gui_modules/menudata.py:1887
+#: ../gui/wxpython/gui_modules/menudata.py:1920
 #, fuzzy
 msgid "Executes any SQL statement."
 msgstr "Führt jeglichen SQL-Befehl aus."
-#: ../gui/wxpython/gui_modules/menudata.py:1893
+#: ../gui/wxpython/gui_modules/menudata.py:1926
 #, fuzzy
 msgid "Vector database connections"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1895
+#: ../gui/wxpython/gui_modules/menudata.py:1928
 #, fuzzy
 msgid "Reconnect vector to database"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1896
+#: ../gui/wxpython/gui_modules/menudata.py:1929
 msgid "Reconnects vectors to a new database."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1900
+#: ../gui/wxpython/gui_modules/menudata.py:1933
 #, fuzzy
 msgid "Set vector map - database connection"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/menudata.py:1901
+#: ../gui/wxpython/gui_modules/menudata.py:1934
 #, fuzzy
 msgid "Prints/sets DB connection for a vector map to attribute table."
 msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte."
-#: ../gui/wxpython/gui_modules/menudata.py:1908
+#: ../gui/wxpython/gui_modules/menudata.py:1941
 #, fuzzy
 msgid "Help"
 msgstr "Hilfe"
-#: ../gui/wxpython/gui_modules/menudata.py:1910
+#: ../gui/wxpython/gui_modules/menudata.py:1943
 msgid "GRASS GIS help"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1911
-#: ../gui/wxpython/gui_modules/menudata.py:1916
+#: ../gui/wxpython/gui_modules/menudata.py:1944
+#: ../gui/wxpython/gui_modules/menudata.py:1949
 #, fuzzy
 msgid "Display the HTML man pages of GRASS"
-#: ../gui/wxpython/gui_modules/menudata.py:1915
+#: ../gui/wxpython/gui_modules/menudata.py:1948
 msgid "GRASS GIS GUI help"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:1920
-#: ../gui/wxpython/gui_modules/menudata.py:1921
+#: ../gui/wxpython/gui_modules/menudata.py:1953
+#: ../gui/wxpython/gui_modules/menudata.py:1954
 msgid "About GRASS GIS"
 msgstr ""
@@ -6880,7 +6939,7 @@
 msgid "Submit"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:3467 ../gui/wxpython/wxgui.py:1128
+#: ../gui/wxpython/gui_modules/dbm.py:3467 ../gui/wxpython/wxgui.py:1132
 #, fuzzy
 msgid "GRASS GIS Attribute Table Manager"
 msgstr "Tabelle"
@@ -6965,28 +7024,32 @@
 msgid "Unable to open file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:615
+#: ../gui/wxpython/gui_modules/render.py:450
+msgid "wxGUI closed."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:617
 #, fuzzy, python-format
 msgid "Unable to zoom to raster map <%s>."
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/render.py:618
+#: ../gui/wxpython/gui_modules/render.py:620
 msgid "Unable to zoom to vector map <%s>."
 msgstr "Vektor."
-#: ../gui/wxpython/gui_modules/render.py:964
-#: ../gui/wxpython/gui_modules/render.py:1051
+#: ../gui/wxpython/gui_modules/render.py:969
+#: ../gui/wxpython/gui_modules/render.py:1056
 #, python-format
 msgid "Unable to render map layer <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1167
+#: ../gui/wxpython/gui_modules/render.py:1172
 #, python-format
 msgid "Unable render overlay <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1201
+#: ../gui/wxpython/gui_modules/render.py:1206
 msgid "Unable render overlay <%s>"
 msgstr "Vektor."
@@ -7653,11 +7716,6 @@
 msgid "Topography level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:962
-#, fuzzy
-msgid "Background color:"
-msgstr " Hintergrundfarbe: "
 #: ../gui/wxpython/gui_modules/nviz_tools.py:997
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1076
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1106
@@ -7942,116 +8000,116 @@
 msgid "GRASS Quickstart"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:100
+#: ../gui/wxpython/wxgui.py:98
 #, fuzzy
 msgid "GRASS GIS Layer Manager (Experimental Prototype)"
 msgstr "Layer %d"
-#: ../gui/wxpython/wxgui.py:306
+#: ../gui/wxpython/wxgui.py:304
 #, fuzzy
 msgid "Map layers for each display"
-#: ../gui/wxpython/wxgui.py:431
+#: ../gui/wxpython/wxgui.py:434
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:552
+#: ../gui/wxpython/wxgui.py:555
 #, fuzzy
 msgid ""
 "Workspace is not empty. Do you want to store current settings to workspace "
 "file?"
 msgstr "Projekt?"
-#: ../gui/wxpython/wxgui.py:555
+#: ../gui/wxpython/wxgui.py:558
 #, fuzzy
 msgid "Save current settings?"
 msgstr "Speichern?"
-#: ../gui/wxpython/wxgui.py:570
+#: ../gui/wxpython/wxgui.py:573
 msgid "Choose workspace file"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:634 ../gui/wxpython/wxgui.py:639
+#: ../gui/wxpython/wxgui.py:637 ../gui/wxpython/wxgui.py:642
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed. Invalid file, unable to parse XML "
 "document."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:644 ../gui/wxpython/wxgui.py:749
-#: ../gui/wxpython/wxgui.py:785
+#: ../gui/wxpython/wxgui.py:647 ../gui/wxpython/wxgui.py:752
+#: ../gui/wxpython/wxgui.py:788
 #, fuzzy
 msgid "Please wait, loading workspace..."
 msgstr "Öffne existierendes Projekt"
-#: ../gui/wxpython/wxgui.py:729
+#: ../gui/wxpython/wxgui.py:732
 msgid "Unable to read workspace file"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:769
+#: ../gui/wxpython/wxgui.py:772
 msgid "Choose GRC file to load"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:808
+#: ../gui/wxpython/wxgui.py:811
 #, fuzzy
 msgid "Choose file to save current workspace"
 msgstr "Speichern"
-#: ../gui/wxpython/wxgui.py:823 ../gui/wxpython/wxgui.py:840
+#: ../gui/wxpython/wxgui.py:826 ../gui/wxpython/wxgui.py:843
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Projekt?"
-#: ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:865
 #, python-format
 msgid "Unable to open workspace file <%s> for writing."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:871
+#: ../gui/wxpython/wxgui.py:874
 #, python-format
 msgid "Writing current settings to workspace file failed (%s)."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1063
+#: ../gui/wxpython/wxgui.py:1067
 #, fuzzy
 msgid "Import DXF layers"
 msgstr "Importieren"
-#: ../gui/wxpython/wxgui.py:1069
+#: ../gui/wxpython/wxgui.py:1073
 #, fuzzy
 msgid "Import GDAL layers"
-#: ../gui/wxpython/wxgui.py:1075
+#: ../gui/wxpython/wxgui.py:1079
 #, fuzzy
 msgid "Import OGR layers"
-#: ../gui/wxpython/wxgui.py:1100
+#: ../gui/wxpython/wxgui.py:1104
 #, fuzzy
 msgid "Attribute management is available only for vector maps."
 msgstr "Vektor."
-#: ../gui/wxpython/wxgui.py:1123
+#: ../gui/wxpython/wxgui.py:1127
 #, fuzzy
 msgid "Please wait, loading attribute data..."
 msgstr "Daten."
-#: ../gui/wxpython/wxgui.py:1436
+#: ../gui/wxpython/wxgui.py:1440
 msgid "Do you want to remove map layer %s from layer tree?"
 msgstr "Kartenebenen in eine Baumstruktur laden"
-#: ../gui/wxpython/wxgui.py:1439
+#: ../gui/wxpython/wxgui.py:1443
 msgid "Do you want to remove selected map layer from layer tree?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1443
+#: ../gui/wxpython/wxgui.py:1447
 msgid "Remove map layer"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1469
+#: ../gui/wxpython/wxgui.py:1473
 msgid "No map layer selected. Operation cancelled."
 msgstr ""
