[GRASS-SVN] r34366 - grass/branches/develbranch_6/raster/r.recode
Tue Nov 18 08:27:00 EST 2008
Author: martinl
Date: 2008-11-18 08:27:00 -0500 (Tue, 18 Nov 2008)
New Revision: 34366
   grass/branches/develbranch_6/raster/r.recode/main.c
   grass/branches/develbranch_6/raster/r.recode/read_rules.c
   grass/branches/develbranch_6/raster/r.recode/recode.c
r.recode: standardize messages
	  disable interactive mode
Modified: grass/branches/develbranch_6/raster/r.recode/main.c
--- grass/branches/develbranch_6/raster/r.recode/main.c	2008-11-18 13:19:01 UTC (rev 34365)
+++ grass/branches/develbranch_6/raster/r.recode/main.c	2008-11-18 13:27:00 UTC (rev 34366)
@@ -6,7 +6,7 @@
  *               Bob Covill <bcovill tekmap.ns.ca>, Hamish Bowman <hamish_nospam yahoo.com>,
  *               Jan-Oliver Wagner <jan intevation.de>
  * PURPOSE:      Recode categorical raster maps
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -34,12 +34,12 @@
     } parm;
     /* any interaction must run in a term window */
-    G_putenv("GRASS_UI_TERM", "1");
+    /* G_putenv("GRASS_UI_TERM", "1"); */
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("raster");
+    module->keywords = _("raster, recode category");
     module->description = _("Recodes categorical raster maps.");
     parm.input = G_define_standard_option(G_OPT_R_INPUT);
@@ -47,12 +47,10 @@
     parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
-    parm.rules = G_define_option();
+    parm.rules = G_define_standard_option(G_OPT_F_INPUT);
     parm.rules->key = "rules";
-    parm.rules->type = TYPE_STRING;
-    parm.rules->description = _("File containing recode rules");
-    parm.rules->key_desc = "name";
-    parm.rules->gisprompt = "old_file,file,input";
+    parm.rules->label = _("File containing recode rules");
+    parm.rules->required = NO;
     parm.title = G_define_option();
     parm.title->key = "title";
@@ -91,7 +89,7 @@
     if (parm.rules->answer) {
 	srcfp = fopen(parm.rules->answer, "r");
 	if (!srcfp)
-	    G_fatal_error(_("Cannot open rules file <%s>"),
+	    G_fatal_error(_("Unable to open rules file <%s>"),
 			  parm.rules->answer);
@@ -107,5 +105,8 @@
     do_recode();
+    G_done_msg(_("Raster map <%s> created."),
+	       result);
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/raster/r.recode/read_rules.c
--- grass/branches/develbranch_6/raster/r.recode/read_rules.c	2008-11-18 13:19:01 UTC (rev 34365)
+++ grass/branches/develbranch_6/raster/r.recode/read_rules.c	2008-11-18 13:27:00 UTC (rev 34366)
@@ -16,29 +16,33 @@
     inp_type = G_raster_map_type(name, mapset);
     if (inp_type != CELL_TYPE) {
 	if (G_read_fp_range(name, mapset, &drange) <= 0)
-	    G_fatal_error(_("Unable to read f_range for map %s"), name);
+	    G_fatal_error(_("Unable to read fp range of raster map <%s>"),
+			  G_fully_qualified_name(name, mapset));
 	G_get_fp_range_min_max(&drange, &old_dmin, &old_dmax);
 	if (G_is_d_null_value(&old_dmin) || G_is_d_null_value(&old_dmax))
-	    G_message(_("Data range is empty"));
+	    G_important_message(_("Data range of raster map <%s> is empty"),
 	else {
 	    sprintf(buff, "%.10f", old_dmin);
 	    sprintf(buff2, "%.10f", old_dmax);
 	    G_trim_decimal(buff);
 	    G_trim_decimal(buff2);
-	    G_message(_("Data range of %s is %s to %s (entire map)"), name,
-		      buff, buff2);
+	    G_message(_("Data range of raster map <%s> is %s to %s (entire map)"),
+		      G_fully_qualified_name(name, mapset), buff, buff2);
     if (G_read_range(name, mapset, &range) <= 0)
-	G_fatal_error(_("Unable to read range for map <%s>"), name);
+	G_fatal_error(_("Unable to read range of raster map <%s>"),
     G_get_range_min_max(&range, &old_min, &old_max);
     if (G_is_c_null_value(&old_min) || G_is_c_null_value(&old_max))
-	G_message(_("Integer data range of %s is empty"), name);
+	G_important_message(_("Integer data range of raster map <%s> is empty"),
     else
-	G_message(_("Integer data range of %s is %d to %d"),
-		  name, (int)old_min, (int)old_max);
+	G_message(_("Integer data range of raster mao <%s> is %d to %d"),
+		  G_fully_qualified_name(name, mapset), (int) old_min, (int) old_max);
     return 0;
@@ -120,7 +124,7 @@
 		G_fpreclass_set_neg_infinite_rule(&rcl_struct, oHigh, nLow);
 	    else
-		G_message(_("%s is not a valid rule"), buf);
+		G_message(_("'%s' is not a valid rule"), buf);
 	    break;
 	}			/* switch */
     }				/* loop */
Modified: grass/branches/develbranch_6/raster/r.recode/recode.c
--- grass/branches/develbranch_6/raster/r.recode/recode.c	2008-11-18 13:19:01 UTC (rev 34365)
+++ grass/branches/develbranch_6/raster/r.recode/recode.c	2008-11-18 13:27:00 UTC (rev 34366)
@@ -1,4 +1,7 @@
 #include <stdio.h>
+#include <grass/glocale.h>
 #include "global.h"
 #define F2I(map_type) \
@@ -42,7 +45,8 @@
     /* open the input file for reading */
     in_fd = G_open_cell_old(name, mapset);
     if (in_fd < 0)
-	G_fatal_error("Can't open input map");
+	G_fatal_error(_("Unable to open raster map <%s>"),
     out_fd = G_open_raster_new(result, out_type);
