[GRASS-SVN] r34400 - grass/trunk/raster/r.grow
Thu Nov 20 11:27:25 EST 2008
Author: glynn
Date: 2008-11-20 11:27:25 -0500 (Thu, 20 Nov 2008)
New Revision: 34400
   grass/trunk/raster/r.grow/main.c
Remove -q flag
Fix spelling of "euclidean"
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c	2008-11-20 10:59:22 UTC (rev 34399)
+++ grass/trunk/raster/r.grow/main.c	2008-11-20 16:27:25 UTC (rev 34400)
@@ -33,7 +33,7 @@
 typedef int metric_fn(int, int);
-static int distance_euclidian_squared(int dx, int dy)
+static int distance_euclidean_squared(int dx, int dy)
     return dx * dx + dy * dy;
@@ -75,11 +75,11 @@
-static void setup_neighbors_euclidian(double radius)
+static void setup_neighbors_euclidean(double radius)
     int r2 = (int)(radius * radius);
-    setup_neighbors(radius, r2, distance_euclidian_squared);
+    setup_neighbors(radius, r2, distance_euclidean_squared);
 static void setup_neighbors_maximum(double radius)
@@ -99,14 +99,9 @@
 	struct Option *in, *out, *rad, *met, *old, *new;
     } opt;
-    struct
-	struct Flag *q;
-    } flag;
     struct Colors colr;
     struct Categories cats;
     struct History history;
-    int verbose;
     int colrfile;
     char *in_name;
     char *out_name;
@@ -145,8 +140,8 @@
     opt.met->type = TYPE_STRING;
     opt.met->required = NO;
     opt.met->description = _("Metric");
-    opt.met->options = "euclidian,maximum,manhattan";
-    opt.met->answer = "euclidian";
+    opt.met->options = "euclidean,maximum,manhattan";
+    opt.met->answer = "euclidean";
     opt.old = G_define_option();
     opt.old->key = "old";
@@ -161,10 +156,6 @@
     opt.new->required = NO;
     opt.new->description = _("Value to write for \"grown\" cells");
-    flag.q = G_define_flag();
-    flag.q->key = 'q';
-    flag.q->description = _("Quiet");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -179,13 +170,11 @@
     if (opt.new->answer)
 	newval = atoi(opt.new->answer);
-    verbose = !flag.q->answer;
     nrows = G_window_rows();
     ncols = G_window_cols();
-    if (strcmp(opt.met->answer, "euclidian") == 0)
-	setup_neighbors_euclidian(radius);
+    if (strcmp(opt.met->answer, "euclidean") == 0)
+	setup_neighbors_euclidean(radius);
     else if (strcmp(opt.met->answer, "maximum") == 0)
 	setup_neighbors_maximum(radius);
     else if (strcmp(opt.met->answer, "manhattan") == 0)
@@ -277,8 +266,7 @@
 	G_put_d_raster_row(out_fd, out_row);
-	if (verbose)
-	    G_percent(row, nrows, 2);
+	G_percent(row, nrows, 2);
 	tmp = in_rows[0];
 	for (i = 0; i < size * 2; i++)
@@ -286,8 +274,7 @@
 	in_rows[size * 2] = tmp;
-    if (verbose)
     G_close_cell(in_fd);
     G_close_cell(out_fd);
