[GRASS-SVN] r34414 - in grass/trunk/raster: r.reclass r.recode
Thu Nov 20 16:37:40 EST 2008
Author: glynn
Date: 2008-11-20 16:37:39 -0500 (Thu, 20 Nov 2008)
New Revision: 34414
   grass/trunk/raster/r.reclass/main.c
   grass/trunk/raster/r.recode/main.c
Use rules=- to read from stdin
Modified: grass/trunk/raster/r.reclass/main.c
--- grass/trunk/raster/r.reclass/main.c	2008-11-20 21:26:40 UTC (rev 34413)
+++ grass/trunk/raster/r.reclass/main.c	2008-11-20 21:37:39 UTC (rev 34414)
@@ -60,9 +60,10 @@
     parm.rules = G_define_option();
     parm.rules->key = "rules";
     parm.rules->type = TYPE_STRING;
-    parm.rules->description = _("File containing reclass rules");
+    parm.rules->description = _("File containing reclass rules; \"-\" to read from stdin");
     parm.rules->key_desc = "name";
     parm.rules->gisprompt = "old_file,file,input";
+    parm.rules->answer = "-";
     parm.title = G_define_option();
     parm.title->key = "title";
@@ -82,7 +83,7 @@
 	G_fatal_error(_("Input map can NOT be the same as output map"));
     srcfp = stdin;
-    if (parm.rules->answer) {
+    if (strcmp(parm.rules->answer, "-") != 0) {
 	srcfp = fopen(parm.rules->answer, "r");
 	if (!srcfp)
 	    G_fatal_error(_("Cannot open rules file <%s>"),
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c	2008-11-20 21:26:40 UTC (rev 34413)
+++ grass/trunk/raster/r.recode/main.c	2008-11-20 21:37:39 UTC (rev 34414)
@@ -42,9 +42,6 @@
 	struct Flag *a, *d;
     } parm;
-    /* any interaction must run in a term window */
-    G_putenv("GRASS_UI_TERM", "1");
     G_gisinit(argv[0]);
     module = G_define_module();
@@ -59,9 +56,10 @@
-    parm.rules->description = _("File containing recode rules");
+    parm.rules->description = _("File containing recode rules; \"-\" to read from stdin");
@@ -87,7 +85,7 @@
     make_dcell = parm.d->answer;
     srcfp = stdin;
 	if (!srcfp)
