[GRASS-SVN] r34462 - in grass/trunk: include lib/gis
Sun Nov 23 22:41:31 EST 2008
Author: glynn
Date: 2008-11-23 22:41:31 -0500 (Sun, 23 Nov 2008)
New Revision: 34462
   grass/trunk/include/gisdefs.h
   grass/trunk/lib/gis/G.h
   grass/trunk/lib/gis/debug.c
   grass/trunk/lib/gis/gisinit.c
   grass/trunk/lib/gis/opencell.c
   grass/trunk/lib/gis/progrm_nme.c
   grass/trunk/lib/gis/whoami.c
Remove unnecessary static variables from opencell.c
Move remaining static variables from opencell.c to fields of G__
Remove unnecessary return values
Miscellaneous clean-up
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/include/gisdefs.h	2008-11-24 03:41:31 UTC (rev 34462)
@@ -833,8 +833,8 @@
 int G__open_cell_old(const char *, const char *);
 int G_open_cell_new(const char *);
 int G_open_cell_new_uncompressed(const char *);
-int G_want_histogram(int);
-int G_set_cell_format(int);
+void G_want_histogram(int);
+void G_set_cell_format(int);
 int G_cellvalue_format(CELL);
 int G_open_fp_cell_new(const char *);
 int G_open_fp_cell_new_uncompressed(const char *);
@@ -896,7 +896,7 @@
 /* progrm_nme.c */
 const char *G_program_name(void);
-int G_set_program_name(const char *);
+void G_set_program_name(const char *);
 /* proj1.c */
 int G_projection(void);
Modified: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/G.h	2008-11-24 03:41:31 UTC (rev 34462)
@@ -72,13 +72,14 @@
 struct G__			/*  Structure of library globals */
-    int fp_nbytes;		/* size of cell in floating maps */
     RASTER_MAP_TYPE fp_type;	/* type for writing floating maps */
     struct Cell_head window;	/* Contains the current window          */
     int window_set;		/* Flag: window set?                    */
     int mask_fd;		/* File descriptor for automatic mask   */
     int auto_mask;		/* Flag denoting automatic masking      */
     int want_histogram;
+    int nbytes;
+    int compression_type;
     int fileinfo_count;
     struct fileinfo *fileinfo;
Modified: grass/trunk/lib/gis/debug.c
--- grass/trunk/lib/gis/debug.c	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/debug.c	2008-11-24 03:41:31 UTC (rev 34462)
@@ -45,7 +45,6 @@
 int G_debug(int level, const char *msg, ...)
-#ifdef GDEBUG
     char *lstr, *filen;
     va_list ap;
     FILE *fd;
@@ -84,7 +83,6 @@
 	va_end(ap);
-#endif
     return 1;
@@ -105,7 +103,6 @@
     const struct fileinfo *fcb = &G__.fileinfo[fd];
     G_message("G_dump: memory allocated to G__");
-    G_message("Size of cell in fp maps = %d", G__.fp_nbytes);
     G_message("type for writing floating maps = %d", G__.fp_type);
     G_message("current window = %p", &G__.window);
     G_message("Flag: window set? %d", G__.window_set);
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/gisinit.c	2008-11-24 03:41:31 UTC (rev 34462)
@@ -120,12 +120,14 @@
     G__.want_histogram = 0;
     /* set the write type for floating maps */
-    G__.fp_type = FCELL_TYPE;
-    G__.fp_nbytes = XDR_FLOAT_NBYTES;
+    G__.fp_type = -1;
     /* Set masking flag unknown */
     G__.auto_mask = -1;
+    G__.nbytes = sizeof(CELL);
+    G__.compression_type = 0;
     initialized = 1;
     setlocale(LC_NUMERIC, "C");
Modified: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/opencell.c	2008-11-24 03:41:31 UTC (rev 34462)
@@ -67,7 +67,8 @@
  *  \return int
-static int G__open_raster_new(const char *name, int open_mode);
+static int G__open_raster_new(const char *name, int open_mode,
+			      RASTER_MAP_TYPE map_type);
   \brief Open an existing integer raster map (cell)
@@ -148,7 +149,7 @@
     struct fileinfo *fcb;
     int fd;
-    char cell_dir[100];
+    char *cell_dir;
     const char *r_name;
     const char *r_mapset;
     struct Cell_head cellhd;
@@ -237,18 +238,18 @@
     /* record number of bytes per cell */
     if (MAP_TYPE == FCELL_TYPE) {
-	strcpy(cell_dir, "fcell");
+	cell_dir = "fcell";
 	INTERN_SIZE = sizeof(FCELL);
 	MAP_NBYTES = XDR_FLOAT_NBYTES;
     else if (MAP_TYPE == DCELL_TYPE) {
 	INTERN_SIZE = sizeof(DCELL);
 	MAP_NBYTES = XDR_DOUBLE_NBYTES;
     else {			/* integer */
-	strcpy(cell_dir, "cell");
+	cell_dir = "cell";
 	INTERN_SIZE = sizeof(CELL);
 	MAP_NBYTES = CELL_nbytes;
@@ -345,29 +346,6 @@
-static int WRITE_NBYTES = sizeof(CELL);
-/* bytes per cell for current map */
-static int NBYTES = sizeof(CELL);
-/* bytes per cell for writing integer maps */
-static RASTER_MAP_TYPE WRITE_MAP_TYPE = CELL_TYPE;
-/* a type of current map */
-static int COMPRESSION_TYPE = 0;
-#define FP_NBYTES G__.fp_nbytes
-/* bytes per cell for writing floating point maps */
-#define FP_TYPE  G__.fp_type
-/* a type of floating maps to be open */
-static int FP_TYPE_SET = 0;	/* wether or not the f.p. type was set explicitly
-				   by calling G_set_fp_type() */
-static char cell_dir[100];
   \brief Opens a new cell file in a database (compressed)
@@ -397,11 +375,7 @@
 int G_open_cell_new(const char *name)
-    WRITE_MAP_TYPE = CELL_TYPE;
-    /* bytes per cell for current map */
-    WRITE_NBYTES = NBYTES;
-    return G__open_raster_new(name, OPEN_NEW_COMPRESSED);
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
@@ -416,11 +390,7 @@
 int G_open_cell_new_uncompressed(const char *name)
-    WRITE_MAP_TYPE = CELL_TYPE;	/* a type of current map */
-    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED);
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
@@ -433,11 +403,9 @@
   \return 0
-int G_want_histogram(int flag)
+void G_want_histogram(int flag)
     G__.want_histogram = flag;
-    return 0;
@@ -454,18 +422,14 @@
   \return 0
-int G_set_cell_format(int n)
+void G_set_cell_format(int n)
 /* sets the format for integer raster map */
-    if (WRITE_MAP_TYPE == CELL_TYPE) {
-	NBYTES = n + 1;
-	if (NBYTES <= 0)
-	    NBYTES = 1;
-	if ((unsigned int) NBYTES > sizeof(CELL))
-	    NBYTES = sizeof(CELL);
-    return 0;
+    G__.nbytes = n + 1;
+    if (G__.nbytes <= 0)
+	G__.nbytes = 1;
+    if (G__.nbytes > sizeof(CELL))
@@ -486,6 +450,16 @@
     return sizeof(CELL) - 1;
+static int get_fp_type(void)
+    if (G__.fp_type <= 0)
+	G__.fp_type = getenv("GRASS_FP_DOUBLE")
+	    ? DCELL_TYPE
+	    : FCELL_TYPE;
+    return G__.fp_type;
   \brief Opens new fcell file in a database
@@ -505,24 +479,7 @@
 int G_open_fp_cell_new(const char *name)
-    /* use current float. type for writing float point maps */
-    /* if the FP type was NOT explicitly set by G_set_fp_type()
-       use environment variable */
-    if (!FP_TYPE_SET) {
-	if (getenv("GRASS_FP_DOUBLE")) {
-	    FP_TYPE = DCELL_TYPE;
-	    FP_NBYTES = XDR_DOUBLE_NBYTES;
-	else {
-	    FP_TYPE = FCELL_TYPE;
-	    FP_NBYTES = XDR_FLOAT_NBYTES;
-    WRITE_MAP_TYPE = FP_TYPE;
-    WRITE_NBYTES = FP_NBYTES;
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, get_fp_type());
@@ -537,26 +494,11 @@
 int G_open_fp_cell_new_uncompressed(const char *name)
-	else {
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, get_fp_type());
-/* opens a f-cell or cell file depending on WRITE_MAP_TYPE */
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
@@ -564,7 +506,27 @@
     char *tempname;
     char *map;
     char *mapset;
+    const char *cell_dir;
+    int nbytes;
+    switch (map_type) {
+    case CELL_TYPE:
+	nbytes = G__.nbytes;
+	break;
+    case FCELL_TYPE:
+	nbytes = XDR_FLOAT_NBYTES;
+	break;
+    case DCELL_TYPE:
+	nbytes =  XDR_DOUBLE_NBYTES;
+	break;
+    default:
+	G_fatal_error(_("Invalid map type <%d>"), map_type);
+	break;
     if (G__unqualified_name(name, G_mapset(), xname, xmapset) < 0)
 	G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
 		      name, G_mapset());
@@ -599,7 +561,7 @@
     G__make_mapset_element(cell_dir);
     /* mark closed */
-    fcb->map_type = WRITE_MAP_TYPE;
+    fcb->map_type = map_type;
     fcb->open_mode = -1;
     /* for writing fcb->data is allocated to be G__.window.cols *
@@ -607,8 +569,8 @@
     fcb->data = (unsigned char *)G_calloc(G__.window.cols,
 					  G_raster_size(fcb->map_type));
-    if (open_mode == OPEN_NEW_COMPRESSED && !COMPRESSION_TYPE)
-	COMPRESSION_TYPE = getenv("GRASS_INT_ZLIB") ? 2 : 1;
+    if (open_mode == OPEN_NEW_COMPRESSED && !G__.compression_type)
+	G__.compression_type = getenv("GRASS_INT_ZLIB") ? 2 : 1;
      * copy current window into cell header
@@ -622,17 +584,17 @@
 	fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
 	G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
 	G__write_row_ptrs(fd);
-	fcb->cellhd.compressed = COMPRESSION_TYPE;
+	fcb->cellhd.compressed = G__.compression_type;
 	fcb->nbytes = 1;	/* to the minimum */
     else {
-	fcb->nbytes = WRITE_NBYTES;
+	fcb->nbytes = nbytes;
 	if (open_mode == OPEN_NEW_COMPRESSED) {
 	else
 	    fcb->cellhd.compressed = 0;
@@ -709,18 +671,15 @@
 int G_set_fp_type(RASTER_MAP_TYPE map_type)
-    FP_TYPE_SET = 1;
-    if (map_type != FCELL_TYPE && map_type != DCELL_TYPE) {
+    case FCELL_TYPE:
+    case DCELL_TYPE:
+	G__.fp_type = map_type;
+	return 1;
+    default:
 	G_warning(_("G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
 	return -1;
-    FP_TYPE = map_type;
-    if (map_type == DCELL_TYPE)
-    else
-    return 1;
@@ -899,11 +858,7 @@
 int G_open_raster_new(const char *name, RASTER_MAP_TYPE wr_type)
-    if (wr_type == CELL_TYPE)
-	return G_open_cell_new(name);
-    G_set_fp_type(wr_type);
-    return G_open_fp_cell_new(name);
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
@@ -919,11 +874,7 @@
 int G_open_raster_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
-	return G_open_cell_new_uncompressed(name);
-    return G_open_fp_cell_new_uncompressed(name);
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
Modified: grass/trunk/lib/gis/progrm_nme.c
--- grass/trunk/lib/gis/progrm_nme.c	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/progrm_nme.c	2008-11-24 03:41:31 UTC (rev 34462)
@@ -35,7 +35,7 @@
     return name;
-int G_set_program_name(const char *s)
+void G_set_program_name(const char *s)
     int i;
     char *temp;
@@ -51,6 +51,4 @@
     G_basename(temp, "exe");
     name = G_store(temp);
     G_free(temp);
-    return 0;
Modified: grass/trunk/lib/gis/whoami.c
--- grass/trunk/lib/gis/whoami.c	2008-11-23 23:25:53 UTC (rev 34461)
+++ grass/trunk/lib/gis/whoami.c	2008-11-24 03:41:31 UTC (rev 34462)
@@ -39,41 +39,30 @@
 char *G_whoami(void)
-#ifdef __MINGW32__
-    char *name = getenv("USERNAME");
+    static char *name;
-    if (name == NULL) {
-	name = "user_name";
-#else
-    static char *name = NULL;
+    if (name)
+	return name;
-#ifdef COMMENTED_OUT
-    char *getlogin();
-    char *ttyname();
+#ifdef __MINGW32__
+    name = getenv("USERNAME");
+#endif
+    if (!name || !*name)
+	name = getenv("LOGNAME");
-	char *x;
+	name = getenv("USER");
-	x = ttyname(0);
-	if (x && *x) {
-	    x = getlogin();
-	    if (x && *x)
-		name = G_store(x);
-#endif /* COMMENTED_OUT */
-	struct passwd *p;
-	if ((p = getpwuid(getuid())))
+#ifndef __MINGW32__
+    if (!name || !*name) {
+	struct passwd *p = getpwuid(getuid());
+	if (p && p->pw_name && *p->pw_name)
 	    name = G_store(p->pw_name);
-    if (name == NULL)
-	name = G_store("?");
 #endif
+	name = "anonymous";
     return name;
