[GRASS-SVN] r34487 - in grass/trunk: . include include/Make lib/gis raster/r.mapcalc
Tue Nov 25 18:47:02 EST 2008
Author: glynn
Date: 2008-11-25 18:47:02 -0500 (Tue, 25 Nov 2008)
New Revision: 34487
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/include/config.h.in
   grass/trunk/lib/gis/Makefile
   grass/trunk/lib/gis/counter.c
   grass/trunk/lib/gis/worker.c
   grass/trunk/raster/r.mapcalc/Makefile
   grass/trunk/raster/r.mapcalc/evaluate.c
   grass/trunk/raster/r.mapcalc/map.c
Add --with-pthread etc to configure script
Fix bugs in counter.c, r.mapcalc
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/configure	2008-11-25 23:47:02 UTC (rev 34487)
@@ -63,6 +63,8 @@
 ac_help="$ac_help
   --with-regex            support regex functionality (default: yes)"
 ac_help="$ac_help
+  --with-pthread          support POSIX threads functionality (default: no)"
+ac_help="$ac_help
   --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
 e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
 ac_help="$ac_help
@@ -188,6 +190,12 @@
 ac_help="$ac_help
   --with-regex-libs=DIRS  regex library files are in DIRS"
 ac_help="$ac_help
+  --with-pthread-includes=DIRS
+                          POSIX threads include files are in DIRS"
+ac_help="$ac_help
+  --with-pthread-libs=DIRS
+                          POSIX threads library files are in DIRS"
+ac_help="$ac_help
   --with-x                use the X Window System"
 ac_help="$ac_help
   --enable-largefile      enable support for large files (LFS)"
@@ -723,7 +731,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:727: checking host system type" >&5
+echo "configure:735: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -746,7 +754,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:750: checking for $ac_word" >&5
+echo "configure:758: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -773,7 +781,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:777: checking for $ac_word" >&5
+echo "configure:785: checking for $ac_word" >&5
@@ -821,7 +829,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:825: checking for $ac_word" >&5
+echo "configure:833: checking for $ac_word" >&5
@@ -850,7 +858,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:854: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:862: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -861,12 +869,12 @@
 cat > conftest.$ac_ext << EOF
-#line 865 "configure"
+#line 873 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -892,19 +900,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:896: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:904: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:901: checking whether we are using GNU C" >&5
+echo "configure:909: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -922,7 +930,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:926: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:934: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -951,10 +959,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:955: checking for Cygwin environment" >&5
+echo "configure:963: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 958 "configure"
+#line 966 "configure"
 int main() {
@@ -965,7 +973,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:977: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -981,17 +989,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:985: checking for mingw32 environment" >&5
+echo "configure:993: checking for mingw32 environment" >&5
-#line 988 "configure"
+#line 996 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:995: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1009,7 +1017,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1013: checking for executable suffix" >&5
+echo "configure:1021: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1028,23 +1036,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1032: checking for full floating-point support" >&5
+echo "configure:1040: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1037: checking whether "cc -mieee" works" >&5
+echo "configure:1045: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1041 "configure"
+#line 1049 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1048: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1060,7 +1068,7 @@
 else
-#line 1064 "configure"
+#line 1072 "configure"
 #include <float.h>
@@ -1074,7 +1082,7 @@
 EOF
-if { (eval echo configure:1078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1087,14 +1095,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1091: checking for full floating-point support with -mieee" >&5
+echo "configure:1099: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1098 "configure"
+#line 1106 "configure"
 #include <float.h>
@@ -1108,7 +1116,7 @@
 EOF
-if { (eval echo configure:1112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1145,7 +1153,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1149: checking for $ac_word" >&5
+echo "configure:1157: checking for $ac_word" >&5
 case "$pwd" in
@@ -1183,7 +1191,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1187: checking for source directory" >&5
+echo "configure:1195: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1194,7 +1202,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1198: checking for build directory" >&5
+echo "configure:1206: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1279,7 +1287,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1283: checking for MacOSX App" >&5
+echo "configure:1291: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1302,7 +1310,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1306: checking how to build libraries" >&5
+echo "configure:1314: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1345,7 +1353,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1349: checking for $ac_word" >&5
+echo "configure:1357: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1370,7 +1378,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1374: checking how to run the C preprocessor" >&5
+echo "configure:1382: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1383,13 +1391,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1387 "configure"
+#line 1395 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1401: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1400,13 +1408,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1404 "configure"
+#line 1412 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1417,13 +1425,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1421 "configure"
+#line 1429 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1451,7 +1459,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1455: checking if 64bit support is requested" >&5
+echo "configure:1463: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1471,7 +1479,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1475: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1483: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1495,7 +1503,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1499: checking system version (for dynamic loading)" >&5
+echo "configure:1507: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1521,13 +1529,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1525: checking for dlopen in -ldl" >&5
+echo "configure:1533: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1531 "configure"
+#line 1539 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1538,7 +1546,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1585,7 +1593,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1589: checking for $ac_word" >&5
+echo "configure:1597: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1714,13 +1722,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1718: checking for gettimeofday in -lbsd" >&5
+echo "configure:1726: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1724 "configure"
+#line 1732 "configure"
@@ -1731,7 +1739,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1772,13 +1780,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1776: checking for inet_ntoa in -lbind" >&5
+echo "configure:1784: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1782 "configure"
+#line 1790 "configure"
@@ -1789,7 +1797,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1850,13 +1858,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1854: checking for shl_load in -ldld" >&5
+echo "configure:1862: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1860 "configure"
+#line 1868 "configure"
@@ -1867,7 +1875,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1932,13 +1940,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1936: checking for shl_load in -ldld" >&5
+echo "configure:1944: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1942 "configure"
+#line 1950 "configure"
@@ -1949,7 +1957,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2071,15 +2079,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2075: checking for dld.h" >&5
+echo "configure:2083: checking for dld.h" >&5
-#line 2078 "configure"
+#line 2086 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2091: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2139,15 +2147,15 @@
 	    else
-echo "configure:2143: checking for dld.h" >&5
+echo "configure:2151: checking for dld.h" >&5
-#line 2146 "configure"
+#line 2154 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2244,9 +2252,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2248: checking for ELF" >&5
+echo "configure:2256: checking for ELF" >&5
-#line 2250 "configure"
+#line 2258 "configure"
 #ifdef __ELF__
@@ -2276,15 +2284,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2280: checking for dlfcn.h" >&5
+echo "configure:2288: checking for dlfcn.h" >&5
-#line 2283 "configure"
+#line 2291 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2288: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2308,9 +2316,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2312: checking for ELF" >&5
+echo "configure:2320: checking for ELF" >&5
-#line 2314 "configure"
+#line 2322 "configure"
 #ifdef __ELF__
@@ -2634,17 +2642,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2638: checking for ld accepts -Bexport flag" >&5
+echo "configure:2646: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2641 "configure"
+#line 2649 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2972,6 +2980,16 @@
 fi
+# Check whether --with-pthread or --without-pthread was given.
+if test "${with_pthread+set}" = set; then
+  withval="$with_pthread"
+else
+  with_pthread=no
+fi
 # Check whether --with-python or --without-python was given.
 if test "${with_python+set}" = set; then
   withval="$with_python"
@@ -3376,6 +3394,23 @@
+# Check whether --with-pthread-includes or --without-pthread-includes was given.
+if test "${with_pthread_includes+set}" = set; then
+  withval="$with_pthread_includes"
+fi
+# Check whether --with-pthread-libs or --without-pthread-libs was given.
+if test "${with_pthread_libs+set}" = set; then
+  withval="$with_pthread_libs"
+fi
 # Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
 # With includes option
@@ -3385,7 +3420,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3389: checking for additional include dirs" >&5
+echo "configure:3424: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3408,7 +3443,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3412: checking for additional library dirs" >&5
+echo "configure:3447: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3442,7 +3477,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3446: checking for a BSD compatible install" >&5
+echo "configure:3481: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3495,7 +3530,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3499: checking for $ac_word" >&5
+echo "configure:3534: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3526,13 +3561,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3530: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3565: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3536 "configure"
+#line 3571 "configure"
@@ -3543,7 +3578,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3568,7 +3603,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3572: checking for $ac_word" >&5
+echo "configure:3607: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3608,7 +3643,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3612: checking for $ac_word" >&5
+echo "configure:3647: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3639,7 +3674,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3643: checking for $ac_word" >&5
+echo "configure:3678: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3677,7 +3712,7 @@
-echo "configure:3681: checking for $ac_word" >&5
+echo "configure:3716: checking for $ac_word" >&5
@@ -3706,7 +3741,7 @@
-echo "configure:3710: checking for $ac_word" >&5
+echo "configure:3745: checking for $ac_word" >&5
@@ -3737,7 +3772,7 @@
-echo "configure:3741: checking for $ac_word" >&5
+echo "configure:3776: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3766,7 +3801,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3770: checking for $ac_word" >&5
+echo "configure:3805: checking for $ac_word" >&5
 case "$PERL" in
@@ -3797,10 +3832,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3801: checking for ANSI C header files" >&5
+echo "configure:3836: checking for ANSI C header files" >&5
-#line 3804 "configure"
+#line 3839 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3808,7 +3843,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3825,7 +3860,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3829 "configure"
+#line 3864 "configure"
 #include <string.h>
 EOF
@@ -3843,7 +3878,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3847 "configure"
+#line 3882 "configure"
 #include <stdlib.h>
 EOF
@@ -3864,7 +3899,7 @@
 else
-#line 3868 "configure"
+#line 3903 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3875,7 +3910,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3902,15 +3937,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3906: checking for $ac_hdr" >&5
+echo "configure:3941: checking for $ac_hdr" >&5
-#line 3909 "configure"
+#line 3944 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3949: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3939,15 +3974,15 @@
 do
-echo "configure:3943: checking for $ac_hdr" >&5
+echo "configure:3978: checking for $ac_hdr" >&5
-#line 3946 "configure"
+#line 3981 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3976,15 +4011,15 @@
 do
-echo "configure:3980: checking for $ac_hdr" >&5
+echo "configure:4015: checking for $ac_hdr" >&5
-#line 3983 "configure"
+#line 4018 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3988: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4013,15 +4048,15 @@
 do
-echo "configure:4017: checking for $ac_hdr" >&5
+echo "configure:4052: checking for $ac_hdr" >&5
-#line 4020 "configure"
+#line 4055 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4025: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4050,15 +4085,15 @@
 do
-echo "configure:4054: checking for $ac_hdr" >&5
+echo "configure:4089: checking for $ac_hdr" >&5
-#line 4057 "configure"
+#line 4092 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4084,10 +4119,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4088: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4123: checking whether time.h and sys/time.h may both be included" >&5
-#line 4091 "configure"
+#line 4126 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4096,7 +4131,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4100: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4135: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4116,10 +4151,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4120: checking for off_t" >&5
+echo "configure:4155: checking for off_t" >&5
-#line 4123 "configure"
+#line 4158 "configure"
 #if STDC_HEADERS
@@ -4146,10 +4181,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4150: checking for uid_t in sys/types.h" >&5
+echo "configure:4185: checking for uid_t in sys/types.h" >&5
-#line 4153 "configure"
+#line 4188 "configure"
 EOF
@@ -4177,10 +4212,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4181: checking return type of signal handlers" >&5
+echo "configure:4216: checking return type of signal handlers" >&5
-#line 4184 "configure"
+#line 4219 "configure"
 #include <signal.h>
@@ -4197,7 +4232,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4201: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4215,10 +4250,10 @@
-echo "configure:4219: checking for Cygwin environment" >&5
+echo "configure:4254: checking for Cygwin environment" >&5
-#line 4222 "configure"
+#line 4257 "configure"
 int main() {
@@ -4229,7 +4264,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4247,10 +4282,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4251: checking for $ac_func" >&5
+echo "configure:4286: checking for $ac_func" >&5
-#line 4254 "configure"
+#line 4289 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4273,7 +4308,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4299,10 +4334,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4303: checking for $ac_func" >&5
+echo "configure:4338: checking for $ac_func" >&5
-#line 4306 "configure"
+#line 4341 "configure"
@@ -4325,7 +4360,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4351,10 +4386,10 @@
 for ac_func in drand48
 do
-echo "configure:4355: checking for $ac_func" >&5
+echo "configure:4390: checking for $ac_func" >&5
-#line 4358 "configure"
+#line 4393 "configure"
@@ -4377,7 +4412,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4403,10 +4438,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4407: checking for $ac_func" >&5
+echo "configure:4442: checking for $ac_func" >&5
-#line 4410 "configure"
+#line 4445 "configure"
@@ -4429,7 +4464,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4455,10 +4490,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4459: checking for $ac_func" >&5
+echo "configure:4494: checking for $ac_func" >&5
-#line 4462 "configure"
+#line 4497 "configure"
@@ -4481,7 +4516,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4506,13 +4541,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4510: checking whether setpgrp takes no argument" >&5
+echo "configure:4545: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4516 "configure"
+#line 4551 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4532,7 +4567,7 @@
 EOF
-if { (eval echo configure:4536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4560,16 +4595,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4564: checking for long long int" >&5
+echo "configure:4599: checking for long long int" >&5
-#line 4566 "configure"
+#line 4601 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4573: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4608: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4589,7 +4624,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4593: checking for W11" >&5
+echo "configure:4628: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4617,7 +4652,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4621: checking for X" >&5
+echo "configure:4656: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4677,12 +4712,12 @@
   # First, try using that file with no special directory specified.
-#line 4681 "configure"
+#line 4716 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4751,14 +4786,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4755 "configure"
+#line 4790 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4863,17 +4898,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4867: checking whether -R must be followed by a space" >&5
+echo "configure:4902: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4870 "configure"
+#line 4905 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4889,14 +4924,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4893 "configure"
+#line 4928 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4928,13 +4963,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4932: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4967: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4938 "configure"
+#line 4973 "configure"
@@ -4945,7 +4980,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4966,13 +5001,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4970: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5005: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4976 "configure"
+#line 5011 "configure"
@@ -4983,7 +5018,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5011,10 +5046,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5015: checking for gethostbyname" >&5
+echo "configure:5050: checking for gethostbyname" >&5
-#line 5018 "configure"
+#line 5053 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5037,7 +5072,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5057,13 +5092,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5061: checking for gethostbyname in -lnsl" >&5
+echo "configure:5096: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5067 "configure"
+#line 5102 "configure"
@@ -5074,7 +5109,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5103,10 +5138,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5107: checking for connect" >&5
+echo "configure:5142: checking for connect" >&5
-#line 5110 "configure"
+#line 5145 "configure"
     which can conflict with char connect(); below.  */
@@ -5129,7 +5164,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5149,13 +5184,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5153: checking for connect in -lsocket" >&5
+echo "configure:5188: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5159 "configure"
+#line 5194 "configure"
@@ -5166,7 +5201,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5189,10 +5224,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5193: checking for remove" >&5
+echo "configure:5228: checking for remove" >&5
-#line 5196 "configure"
+#line 5231 "configure"
     which can conflict with char remove(); below.  */
@@ -5215,7 +5250,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5235,13 +5270,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5239: checking for remove in -lposix" >&5
+echo "configure:5274: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5245 "configure"
+#line 5280 "configure"
@@ -5252,7 +5287,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5275,10 +5310,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5279: checking for shmat" >&5
+echo "configure:5314: checking for shmat" >&5
-#line 5282 "configure"
+#line 5317 "configure"
     which can conflict with char shmat(); below.  */
@@ -5301,7 +5336,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5321,13 +5356,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5325: checking for shmat in -lipc" >&5
+echo "configure:5360: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5331 "configure"
+#line 5366 "configure"
@@ -5338,7 +5373,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5370,13 +5405,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5374: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5409: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5380 "configure"
+#line 5415 "configure"
@@ -5387,7 +5422,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5427,12 +5462,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5431: checking for library containing cuserid" >&5
+echo "configure:5466: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5436 "configure"
+#line 5471 "configure"
@@ -5443,7 +5478,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5454,7 +5489,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5458 "configure"
+#line 5493 "configure"
@@ -5465,7 +5500,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5491,10 +5526,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5495: checking for xdrmem_create" >&5
+echo "configure:5530: checking for xdrmem_create" >&5
-#line 5498 "configure"
+#line 5533 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5517,7 +5552,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5535,13 +5570,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5539: checking for xdrmem_create in -lsun" >&5
+echo "configure:5574: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5545 "configure"
+#line 5580 "configure"
@@ -5552,7 +5587,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5571,13 +5606,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5575: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5610: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5581 "configure"
+#line 5616 "configure"
@@ -5588,7 +5623,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5607,13 +5642,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5611: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5646: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5617 "configure"
+#line 5652 "configure"
@@ -5624,7 +5659,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5643,13 +5678,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5647: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5682: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5653 "configure"
+#line 5688 "configure"
@@ -5660,7 +5695,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5694,10 +5729,10 @@
 for ac_func in asprintf
 do
-echo "configure:5698: checking for $ac_func" >&5
+echo "configure:5733: checking for $ac_func" >&5
-#line 5701 "configure"
+#line 5736 "configure"
@@ -5720,7 +5755,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5747,10 +5782,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5751: checking for atan" >&5
+echo "configure:5786: checking for atan" >&5
-#line 5754 "configure"
+#line 5789 "configure"
     which can conflict with char atan(); below.  */
@@ -5773,7 +5808,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5791,13 +5826,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5795: checking for atan in -lm" >&5
+echo "configure:5830: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5801 "configure"
+#line 5836 "configure"
@@ -5808,7 +5843,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5835,10 +5870,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5839: checking for dlsym" >&5
+echo "configure:5874: checking for dlsym" >&5
-#line 5842 "configure"
+#line 5877 "configure"
     which can conflict with char dlsym(); below.  */
@@ -5861,7 +5896,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -5879,13 +5914,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5883: checking for dlsym in -ldl" >&5
+echo "configure:5918: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 5889 "configure"
+#line 5924 "configure"
@@ -5896,7 +5931,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5923,10 +5958,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5927: checking for iconv" >&5
+echo "configure:5962: checking for iconv" >&5
-#line 5930 "configure"
+#line 5965 "configure"
     which can conflict with char iconv(); below.  */
@@ -5949,7 +5984,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -5967,13 +6002,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:5971: checking for iconv in -liconv" >&5
+echo "configure:6006: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 5977 "configure"
+#line 6012 "configure"
@@ -5984,7 +6019,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6003,13 +6038,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6007: checking for iconv in -lgiconv" >&5
+echo "configure:6042: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6013 "configure"
+#line 6048 "configure"
@@ -6020,7 +6055,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6039,10 +6074,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6043: checking for libiconv" >&5
+echo "configure:6078: checking for libiconv" >&5
-#line 6046 "configure"
+#line 6081 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6065,7 +6100,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6083,13 +6118,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6087: checking for libiconv in -liconv" >&5
+echo "configure:6122: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6093 "configure"
+#line 6128 "configure"
@@ -6100,7 +6135,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6119,13 +6154,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6123: checking for libiconv in -lgiconv" >&5
+echo "configure:6158: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6129 "configure"
+#line 6164 "configure"
@@ -6136,7 +6171,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6173,10 +6208,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6177: checking for socket" >&5
+echo "configure:6212: checking for socket" >&5
-#line 6180 "configure"
+#line 6215 "configure"
     which can conflict with char socket(); below.  */
@@ -6199,7 +6234,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6217,13 +6252,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6221: checking for socket in -lsocket" >&5
+echo "configure:6256: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6227 "configure"
+#line 6262 "configure"
@@ -6234,7 +6269,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6282,7 +6317,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6286: checking for location of zlib includes" >&5
+echo "configure:6321: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6308,15 +6343,15 @@
 do
-echo "configure:6312: checking for $ac_hdr" >&5
+echo "configure:6347: checking for $ac_hdr" >&5
-#line 6315 "configure"
+#line 6350 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6350,7 +6385,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6354: checking for location of zlib library" >&5
+echo "configure:6389: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6375,13 +6410,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6379: checking for deflate in -lz" >&5
+echo "configure:6414: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6385 "configure"
+#line 6420 "configure"
@@ -6392,7 +6427,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6440,7 +6475,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6444: checking for location of External PROJ.4 includes" >&5
+echo "configure:6479: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6466,15 +6501,15 @@
 do
-echo "configure:6470: checking for $ac_hdr" >&5
+echo "configure:6505: checking for $ac_hdr" >&5
-#line 6473 "configure"
+#line 6508 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6478: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6511,7 +6546,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6515: checking External PROJ.4 version" >&5
+echo "configure:6550: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6519,7 +6554,7 @@
 else
-#line 6523 "configure"
+#line 6558 "configure"
 #include <stdio.h>
@@ -6531,7 +6566,7 @@
 EOF
-if { (eval echo configure:6535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6556,7 +6591,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6560: checking for location of External PROJ.4 library" >&5
+echo "configure:6595: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6581,13 +6616,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6585: checking for pj_get_def in -lproj" >&5
+echo "configure:6620: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6591 "configure"
+#line 6626 "configure"
@@ -6598,7 +6633,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6632,7 +6667,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6636: checking for location of External PROJ.4 data files" >&5
+echo "configure:6671: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6656,14 +6691,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6660: checking for epsg" >&5
+echo "configure:6695: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6667: checking for $PROJSHARE/epsg" >&5
+echo "configure:6702: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6695,7 +6730,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:6699: checking for $ac_word" >&5
+echo "configure:6734: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6735,7 +6770,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6739: checking whether to use regex" >&5
+echo "configure:6774: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6755,7 +6790,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6759: checking for location of regex includes" >&5
+echo "configure:6794: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6781,15 +6816,15 @@
 do
-echo "configure:6785: checking for $ac_hdr" >&5
+echo "configure:6820: checking for $ac_hdr" >&5
-#line 6788 "configure"
+#line 6823 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6823,7 +6858,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6827: checking for location of regex library" >&5
+echo "configure:6862: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6848,10 +6883,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6852: checking for regcomp" >&5
+echo "configure:6887: checking for regcomp" >&5
-#line 6855 "configure"
+#line 6890 "configure"
     which can conflict with char regcomp(); below.  */
@@ -6874,7 +6909,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6901,13 +6936,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6905: checking for regcomp in -lregex" >&5
+echo "configure:6940: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 6911 "configure"
+#line 6946 "configure"
 #include "confdefs.h"
@@ -6918,7 +6953,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6968,7 +7003,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6972: checking whether to use Readline" >&5
+echo "configure:7007: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -6989,7 +7024,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6993: checking for location of Readline includes" >&5
+echo "configure:7028: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7015,15 +7050,15 @@
 do
-echo "configure:7019: checking for $ac_hdr" >&5
+echo "configure:7054: checking for $ac_hdr" >&5
-#line 7022 "configure"
+#line 7057 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7059,15 +7094,15 @@
 do
-echo "configure:7063: checking for $ac_hdr" >&5
+echo "configure:7098: checking for $ac_hdr" >&5
-#line 7066 "configure"
+#line 7101 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7101,7 +7136,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7105: checking for location of Readline library" >&5
+echo "configure:7140: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7126,13 +7161,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7130: checking for readline in -lreadline" >&5
+echo "configure:7165: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7136 "configure"
+#line 7171 "configure"
@@ -7143,7 +7178,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7178,13 +7213,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7182: checking for add_history in -lhistory" >&5
+echo "configure:7217: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7188 "configure"
+#line 7223 "configure"
@@ -7195,7 +7230,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7238,7 +7273,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7242: checking whether to use JPEG" >&5
+echo "configure:7277: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7258,7 +7293,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7262: checking for location of JPEG includes" >&5
+echo "configure:7297: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7284,15 +7319,15 @@
 do
-echo "configure:7288: checking for $ac_hdr" >&5
+echo "configure:7323: checking for $ac_hdr" >&5
-#line 7291 "configure"
+#line 7326 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7326,7 +7361,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7330: checking for location of JPEG library" >&5
+echo "configure:7365: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7353,13 +7388,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7357: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7392: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7363 "configure"
+#line 7398 "configure"
@@ -7370,7 +7405,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7389,13 +7424,13 @@
-echo "configure:7393: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7428: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7399 "configure"
+#line 7434 "configure"
@@ -7406,7 +7441,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7455,7 +7490,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7459: checking whether to use GDAL" >&5
+echo "configure:7494: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7473,7 +7508,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7477: checking for $ac_word" >&5
+echo "configure:7512: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7528,14 +7563,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7532 "configure"
+#line 7567 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7544,14 +7579,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7548 "configure"
+#line 7583 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7584,7 +7619,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7588: checking whether to use TIFF" >&5
+echo "configure:7623: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7604,7 +7639,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7608: checking for location of TIFF includes" >&5
+echo "configure:7643: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7630,15 +7665,15 @@
 do
-echo "configure:7634: checking for $ac_hdr" >&5
+echo "configure:7669: checking for $ac_hdr" >&5
-#line 7637 "configure"
+#line 7672 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7642: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7677: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7672,7 +7707,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7676: checking for location of TIFF library" >&5
+echo "configure:7711: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7703,13 +7738,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7707: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7742: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7713 "configure"
+#line 7748 "configure"
@@ -7720,7 +7755,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7739,13 +7774,13 @@
-echo "configure:7743: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7778: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7749 "configure"
+#line 7784 "configure"
@@ -7756,7 +7791,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7775,13 +7810,13 @@
-echo "configure:7779: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7814: checking for TIFFOpen in -ltiff" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7785 "configure"
+#line 7820 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7792,7 +7827,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7811,13 +7846,13 @@
-echo "configure:7815: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7850: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7821 "configure"
+#line 7856 "configure"
@@ -7828,7 +7863,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7847,13 +7882,13 @@
-echo "configure:7851: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7886: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7857 "configure"
+#line 7892 "configure"
@@ -7864,7 +7899,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7883,13 +7918,13 @@
-echo "configure:7887: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7922: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7893 "configure"
+#line 7928 "configure"
@@ -7900,7 +7935,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7919,13 +7954,13 @@
-echo "configure:7923: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7958: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7929 "configure"
+#line 7964 "configure"
@@ -7936,7 +7971,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7955,13 +7990,13 @@
-echo "configure:7959: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7994: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7965 "configure"
+#line 8000 "configure"
@@ -7972,7 +8007,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8070,7 +8105,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8074: checking whether to use PNG" >&5
+echo "configure:8109: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8089,7 +8124,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8093: checking for location of PNG includes" >&5
+echo "configure:8128: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8115,15 +8150,15 @@
 do
-echo "configure:8119: checking for $ac_hdr" >&5
+echo "configure:8154: checking for $ac_hdr" >&5
-#line 8122 "configure"
+#line 8157 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8127: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8157,7 +8192,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8161: checking for location of PNG library" >&5
+echo "configure:8196: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8182,13 +8217,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8186: checking for png_read_image in -lpng" >&5
+echo "configure:8221: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8192 "configure"
+#line 8227 "configure"
@@ -8199,7 +8234,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8241,7 +8276,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8245: checking whether to use Tcl/Tk" >&5
+echo "configure:8280: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8261,7 +8296,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8265: checking for location of Tcl/Tk includes" >&5
+echo "configure:8300: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8287,15 +8322,15 @@
 do
-echo "configure:8291: checking for $ac_hdr" >&5
+echo "configure:8326: checking for $ac_hdr" >&5
-#line 8294 "configure"
+#line 8329 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8332,15 +8367,15 @@
 do
-echo "configure:8336: checking for $ac_hdr" >&5
+echo "configure:8371: checking for $ac_hdr" >&5
-#line 8339 "configure"
+#line 8374 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8374,7 +8409,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8378: checking Tcl version" >&5
+echo "configure:8413: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8382,7 +8417,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8386 "configure"
+#line 8421 "configure"
 #include <stdio.h>
@@ -8394,7 +8429,7 @@
 EOF
-if { (eval echo configure:8398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8412,7 +8447,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8416: checking Tk version" >&5
+echo "configure:8451: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8420,7 +8455,7 @@
 else
-#line 8424 "configure"
+#line 8459 "configure"
 #include <stdio.h>
@@ -8432,7 +8467,7 @@
 EOF
-if { (eval echo configure:8436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8461,7 +8496,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8465: checking for location of Tcl/Tk library" >&5
+echo "configure:8500: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8491,13 +8526,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8495: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8530: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8501 "configure"
+#line 8536 "configure"
@@ -8508,7 +8543,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8527,13 +8562,13 @@
-echo "configure:8531: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8566: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8537 "configure"
+#line 8572 "configure"
@@ -8544,7 +8579,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8571,13 +8606,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8575: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8610: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8581 "configure"
+#line 8616 "configure"
@@ -8588,7 +8623,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8607,13 +8642,13 @@
-echo "configure:8611: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8646: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8617 "configure"
+#line 8652 "configure"
@@ -8624,7 +8659,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8651,13 +8686,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8655: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8690: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8661 "configure"
+#line 8696 "configure"
@@ -8668,7 +8703,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8687,13 +8722,13 @@
-echo "configure:8691: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8726: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8697 "configure"
+#line 8732 "configure"
@@ -8704,7 +8739,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8782,13 +8817,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8786: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8821: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8792 "configure"
+#line 8827 "configure"
@@ -8799,7 +8834,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8818,13 +8853,13 @@
-echo "configure:8822: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8857: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8828 "configure"
+#line 8863 "configure"
@@ -8835,7 +8870,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8862,13 +8897,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8866: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8901: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8872 "configure"
+#line 8907 "configure"
@@ -8879,7 +8914,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8898,13 +8933,13 @@
-echo "configure:8902: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8937: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8908 "configure"
+#line 8943 "configure"
@@ -8915,7 +8950,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8942,13 +8977,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8946: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8981: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 8952 "configure"
+#line 8987 "configure"
@@ -8959,7 +8994,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8978,13 +9013,13 @@
-echo "configure:8982: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9017: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8988 "configure"
+#line 9023 "configure"
@@ -8995,7 +9030,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9087,7 +9122,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9091: checking whether to use PostgreSQL" >&5
+echo "configure:9126: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9114,7 +9149,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9118: checking for location of PostgreSQL includes" >&5
+echo "configure:9153: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9140,15 +9175,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9144: checking for $ac_hdr" >&5
+echo "configure:9179: checking for $ac_hdr" >&5
-#line 9147 "configure"
+#line 9182 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9186,7 +9221,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9190: checking for location of PostgreSQL library" >&5
+echo "configure:9225: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9215,13 +9250,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9219: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9254: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9225 "configure"
+#line 9260 "configure"
@@ -9232,7 +9267,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9251,13 +9286,13 @@
-echo "configure:9255: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9290: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9261 "configure"
+#line 9296 "configure"
@@ -9268,7 +9303,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9287,13 +9322,13 @@
-echo "configure:9291: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9326: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9297 "configure"
+#line 9332 "configure"
@@ -9304,7 +9339,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9323,13 +9358,13 @@
-echo "configure:9327: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9362: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9333 "configure"
+#line 9368 "configure"
@@ -9340,7 +9375,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9397,13 +9432,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9401: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9436: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9407 "configure"
+#line 9442 "configure"
@@ -9414,7 +9449,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9436,13 +9471,13 @@
-echo "configure:9440: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9475: checking for PQcmdTuples in -lpq" >&5
-#line 9446 "configure"
+#line 9481 "configure"
@@ -9453,7 +9488,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9496,7 +9531,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9500: checking whether to use MySQL" >&5
+echo "configure:9535: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9516,7 +9551,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9520: checking for location of MySQL includes" >&5
+echo "configure:9555: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9542,15 +9577,15 @@
 do
-echo "configure:9546: checking for $ac_hdr" >&5
+echo "configure:9581: checking for $ac_hdr" >&5
-#line 9549 "configure"
+#line 9584 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9589: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9587,7 +9622,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9591: checking for location of MySQL library" >&5
+echo "configure:9626: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9618,13 +9653,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9622: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9657: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9628 "configure"
+#line 9663 "configure"
@@ -9635,7 +9670,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9654,13 +9689,13 @@
-echo "configure:9658: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9693: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9664 "configure"
+#line 9699 "configure"
@@ -9671,7 +9706,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9690,13 +9725,13 @@
-echo "configure:9694: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9729: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9700 "configure"
+#line 9735 "configure"
@@ -9707,7 +9742,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9726,13 +9761,13 @@
-echo "configure:9730: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9765: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9736 "configure"
+#line 9771 "configure"
@@ -9743,7 +9778,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9762,13 +9797,13 @@
-echo "configure:9766: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9801: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9772 "configure"
+#line 9807 "configure"
@@ -9779,7 +9814,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9798,13 +9833,13 @@
-echo "configure:9802: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9837: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9808 "configure"
+#line 9843 "configure"
@@ -9815,7 +9850,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9834,13 +9869,13 @@
-echo "configure:9838: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9873: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9844 "configure"
+#line 9879 "configure"
@@ -9851,7 +9886,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9870,13 +9905,13 @@
-echo "configure:9874: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9909: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9880 "configure"
+#line 9915 "configure"
@@ -9887,7 +9922,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9977,7 +10012,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9981: checking for $ac_word" >&5
+echo "configure:10016: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10026,10 +10061,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10030: checking for mysql_server_init" >&5
+echo "configure:10065: checking for mysql_server_init" >&5
-#line 10033 "configure"
+#line 10068 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10055,7 +10090,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10107,7 +10142,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10111: checking whether to use SQLite" >&5
+echo "configure:10146: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10127,7 +10162,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10131: checking for location of SQLite includes" >&5
+echo "configure:10166: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10153,15 +10188,15 @@
 do
-echo "configure:10157: checking for $ac_hdr" >&5
+echo "configure:10192: checking for $ac_hdr" >&5
-#line 10160 "configure"
+#line 10195 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10204,7 +10239,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10208: checking for location of SQLite library" >&5
+echo "configure:10243: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10231,13 +10266,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10235: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10270: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10241 "configure"
+#line 10276 "configure"
@@ -10248,7 +10283,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10267,13 +10302,13 @@
-echo "configure:10271: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10306: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10277 "configure"
+#line 10312 "configure"
@@ -10284,7 +10319,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10337,7 +10372,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10341: checking whether to use FFMPEG" >&5
+echo "configure:10376: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10357,7 +10392,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10361: checking for location of FFMPEG includes" >&5
+echo "configure:10396: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10383,15 +10418,15 @@
 do
-echo "configure:10387: checking for $ac_hdr" >&5
+echo "configure:10422: checking for $ac_hdr" >&5
-#line 10390 "configure"
+#line 10425 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10395: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10427,15 +10462,15 @@
 do
-echo "configure:10431: checking for $ac_hdr" >&5
+echo "configure:10466: checking for $ac_hdr" >&5
-#line 10434 "configure"
+#line 10469 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10474: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10471,15 +10506,15 @@
 do
-echo "configure:10475: checking for $ac_hdr" >&5
+echo "configure:10510: checking for $ac_hdr" >&5
-#line 10478 "configure"
+#line 10513 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10483: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10518: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10522,7 +10557,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10526: checking for location of FFMPEG library" >&5
+echo "configure:10561: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10549,13 +10584,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10553: checking for av_free in -lavutil" >&5
+echo "configure:10588: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10559 "configure"
+#line 10594 "configure"
@@ -10566,7 +10601,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10585,13 +10620,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10589: checking for av_free in -lavutil" >&5
+echo "configure:10624: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10595 "configure"
+#line 10630 "configure"
@@ -10602,7 +10637,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10647,13 +10682,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10651: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10686: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10657 "configure"
+#line 10692 "configure"
@@ -10664,7 +10699,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10683,13 +10718,13 @@
-echo "configure:10687: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10722: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10693 "configure"
+#line 10728 "configure"
@@ -10700,7 +10735,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10745,13 +10780,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10749: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10784: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10755 "configure"
+#line 10790 "configure"
@@ -10762,7 +10797,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10781,13 +10816,13 @@
-echo "configure:10785: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10820: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10791 "configure"
+#line 10826 "configure"
@@ -10798,7 +10833,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10858,7 +10893,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10862: checking whether to use OpenGL" >&5
+echo "configure:10897: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10892,7 +10927,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10896: checking for location of OpenGL includes" >&5
+echo "configure:10931: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10918,15 +10953,15 @@
 do
-echo "configure:10922: checking for $ac_hdr" >&5
+echo "configure:10957: checking for $ac_hdr" >&5
-#line 10925 "configure"
+#line 10960 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10960,7 +10995,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10964: checking for location of OpenGL library" >&5
+echo "configure:10999: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10989,13 +11024,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10993: checking for glBegin in -lGL" >&5
+echo "configure:11028: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10999 "configure"
+#line 11034 "configure"
@@ -11006,7 +11041,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11025,13 +11060,13 @@
-echo "configure:11029: checking for glBegin in -lGL" >&5
+echo "configure:11064: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11035 "configure"
+#line 11070 "configure"
@@ -11042,7 +11077,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11061,13 +11096,13 @@
-echo "configure:11065: checking for glBegin in -lGL" >&5
+echo "configure:11100: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11071 "configure"
+#line 11106 "configure"
@@ -11078,7 +11113,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11097,13 +11132,13 @@
-echo "configure:11101: checking for glBegin in -lGL" >&5
+echo "configure:11136: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11107 "configure"
+#line 11142 "configure"
@@ -11114,7 +11149,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11176,13 +11211,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11180: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11215: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11186 "configure"
+#line 11221 "configure"
@@ -11193,7 +11228,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11212,13 +11247,13 @@
-echo "configure:11216: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11251: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11222 "configure"
+#line 11257 "configure"
@@ -11229,7 +11264,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11276,10 +11311,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11280: checking for glXCreatePbuffer" >&5
+echo "configure:11315: checking for glXCreatePbuffer" >&5
-#line 11283 "configure"
+#line 11318 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11302,7 +11337,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11339,10 +11374,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11343: checking for glXCreateGLXPixmap" >&5
+echo "configure:11378: checking for glXCreateGLXPixmap" >&5
-#line 11346 "configure"
+#line 11381 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11365,7 +11400,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11408,7 +11443,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11412: checking for location of OpenGL framework" >&5
+echo "configure:11447: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11432,15 +11467,15 @@
 do
-echo "configure:11436: checking for $ac_hdr" >&5
+echo "configure:11471: checking for $ac_hdr" >&5
-#line 11439 "configure"
+#line 11474 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11476,10 +11511,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11480: checking for glBegin" >&5
+echo "configure:11515: checking for glBegin" >&5
-#line 11483 "configure"
+#line 11518 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11502,7 +11537,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11539,10 +11574,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11543: checking for gluBeginCurve" >&5
+echo "configure:11578: checking for gluBeginCurve" >&5
-#line 11546 "configure"
+#line 11581 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11565,7 +11600,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11613,7 +11648,7 @@
-echo "configure:11617: checking for location of OpenGL includes" >&5
+echo "configure:11652: checking for location of OpenGL includes" >&5
@@ -11639,15 +11674,15 @@
 do
-echo "configure:11643: checking for $ac_hdr" >&5
+echo "configure:11678: checking for $ac_hdr" >&5
-#line 11646 "configure"
+#line 11681 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11681,7 +11716,7 @@
-echo "configure:11685: checking for location of OpenGL library" >&5
+echo "configure:11720: checking for location of OpenGL library" >&5
@@ -11706,18 +11741,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11710: checking for OpenGL library" >&5
+echo "configure:11745: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11714 "configure"
+#line 11749 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11741,18 +11776,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11745: checking for GLU library" >&5
+echo "configure:11780: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11749 "configure"
+#line 11784 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11801,7 +11836,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11805: checking whether to use ODBC" >&5
+echo "configure:11840: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11820,7 +11855,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11824: checking for location of ODBC includes" >&5
+echo "configure:11859: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11846,15 +11881,15 @@
 do
-echo "configure:11850: checking for $ac_hdr" >&5
+echo "configure:11885: checking for $ac_hdr" >&5
-#line 11853 "configure"
+#line 11888 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11888,7 +11923,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11892: checking for location of ODBC library" >&5
+echo "configure:11927: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11913,13 +11948,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11917: checking for SQLConnect in -lodbc" >&5
+echo "configure:11952: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11923 "configure"
+#line 11958 "configure"
@@ -11930,7 +11965,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11955,13 +11990,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11959: checking for SQLConnect in -liodbc" >&5
+echo "configure:11994: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11965 "configure"
+#line 12000 "configure"
@@ -11972,7 +12007,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11997,11 +12032,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12001: checking for ODBC library" >&5
+echo "configure:12036: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12005 "configure"
+#line 12040 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12009,7 +12044,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12058,7 +12093,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12062: checking whether to use FFTW" >&5
+echo "configure:12097: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12077,7 +12112,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12081: checking for location of FFTW includes" >&5
+echo "configure:12116: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12103,15 +12138,15 @@
 do
-echo "configure:12107: checking for $ac_hdr" >&5
+echo "configure:12142: checking for $ac_hdr" >&5
-#line 12110 "configure"
+#line 12145 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12139,15 +12174,15 @@
 do
-echo "configure:12143: checking for $ac_hdr" >&5
+echo "configure:12178: checking for $ac_hdr" >&5
-#line 12146 "configure"
+#line 12181 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12175,15 +12210,15 @@
 do
-echo "configure:12179: checking for $ac_hdr" >&5
+echo "configure:12214: checking for $ac_hdr" >&5
-#line 12182 "configure"
+#line 12217 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12229,7 +12264,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12233: checking for location of FFTW library" >&5
+echo "configure:12268: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12254,13 +12289,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12258: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12293: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12264 "configure"
+#line 12299 "configure"
@@ -12271,7 +12306,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12296,13 +12331,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12300: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12335: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12306 "configure"
+#line 12341 "configure"
@@ -12313,7 +12348,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12338,13 +12373,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12342: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12377: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12348 "configure"
+#line 12383 "configure"
@@ -12355,7 +12390,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12412,7 +12447,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12416: checking whether to use BLAS" >&5
+echo "configure:12451: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12433,7 +12468,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12437: checking for location of BLAS includes" >&5
+echo "configure:12472: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12453,7 +12488,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12457: checking for location of BLAS library" >&5
+echo "configure:12492: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12479,15 +12514,15 @@
 do
-echo "configure:12483: checking for $ac_hdr" >&5
+echo "configure:12518: checking for $ac_hdr" >&5
-#line 12486 "configure"
+#line 12521 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12522,13 +12557,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12526: checking for dnrm2_ in -lblas" >&5
+echo "configure:12561: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12532 "configure"
+#line 12567 "configure"
@@ -12539,7 +12574,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12558,13 +12593,13 @@
-echo "configure:12562: checking for dnrm2_ in -lblas" >&5
+echo "configure:12597: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12568 "configure"
+#line 12603 "configure"
@@ -12575,7 +12610,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12619,13 +12654,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12623: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12658: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12629 "configure"
+#line 12664 "configure"
@@ -12636,7 +12671,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12651,13 +12686,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12655: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12690: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12661 "configure"
+#line 12696 "configure"
@@ -12668,7 +12703,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12683,13 +12718,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12687: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12722: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12693 "configure"
+#line 12728 "configure"
@@ -12700,7 +12735,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12745,16 +12780,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12749: checking for sgemm in $vlib_flags" >&5
+echo "configure:12784: checking for sgemm in $vlib_flags" >&5
-#line 12751 "configure"
+#line 12786 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12772,13 +12807,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12776: checking for sgemm_ in -lblas" >&5
+echo "configure:12811: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12782 "configure"
+#line 12817 "configure"
@@ -12789,7 +12824,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12804,13 +12839,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12808: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12843: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldgemm -lblas $LIBS"
-#line 12814 "configure"
+#line 12849 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12821,7 +12856,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12836,13 +12871,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12840: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12875: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12846 "configure"
+#line 12881 "configure"
@@ -12853,7 +12888,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12887,13 +12922,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12891: checking for acosp in -lsunmath" >&5
+echo "configure:12926: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12897 "configure"
+#line 12932 "configure"
@@ -12904,7 +12939,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12919,13 +12954,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12923: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12958: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12929 "configure"
+#line 12964 "configure"
@@ -12936,7 +12971,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12966,13 +13001,13 @@
 # Generic BLAS library
-echo "configure:12970: checking for sgemm_ in -lblas" >&5
+echo "configure:13005: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12976 "configure"
+#line 13011 "configure"
@@ -12983,7 +13018,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13022,7 +13057,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13026: checking whether to use LAPACK" >&5
+echo "configure:13061: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13047,7 +13082,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13051: checking for location of LAPACK includes" >&5
+echo "configure:13086: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13067,7 +13102,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13071: checking for location of LAPACK library" >&5
+echo "configure:13106: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13093,15 +13128,15 @@
 do
-echo "configure:13097: checking for $ac_hdr" >&5
+echo "configure:13132: checking for $ac_hdr" >&5
-#line 13100 "configure"
+#line 13135 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13133,10 +13168,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13137: checking for dsegv_" >&5
+echo "configure:13172: checking for dsegv_" >&5
-#line 13140 "configure"
+#line 13175 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13159,7 +13194,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13186,13 +13221,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13190: checking for desgv_ in -llapack" >&5
+echo "configure:13225: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13196 "configure"
+#line 13231 "configure"
@@ -13203,7 +13238,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13235,13 +13270,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13239: checking for dgesv_ in -llapack" >&5
+echo "configure:13274: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13245 "configure"
+#line 13280 "configure"
@@ -13252,7 +13287,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13271,13 +13306,13 @@
-echo "configure:13275: checking for dgesv_ in -llapack" >&5
+echo "configure:13310: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13281 "configure"
+#line 13316 "configure"
@@ -13288,7 +13323,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13344,7 +13379,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13348: checking whether to use Cairo" >&5
+echo "configure:13383: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13365,7 +13400,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13369: checking for location of cairo includes" >&5
+echo "configure:13404: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13391,15 +13426,15 @@
 do
-echo "configure:13395: checking for $ac_hdr" >&5
+echo "configure:13430: checking for $ac_hdr" >&5
-#line 13398 "configure"
+#line 13433 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13435,7 +13470,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13439: checking for location of cairo library" >&5
+echo "configure:13474: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13455,7 +13490,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13459: checking for cairo linking flags" >&5
+echo "configure:13494: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13471,10 +13506,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13475: checking for cairo_create" >&5
+echo "configure:13510: checking for cairo_create" >&5
-#line 13478 "configure"
+#line 13513 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13497,7 +13532,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13540,7 +13575,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13544: checking whether to use FreeType" >&5
+echo "configure:13579: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13559,7 +13594,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13563: checking for location of FreeType includes" >&5
+echo "configure:13598: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13585,15 +13620,15 @@
 do
-echo "configure:13589: checking for $ac_hdr" >&5
+echo "configure:13624: checking for $ac_hdr" >&5
-#line 13592 "configure"
+#line 13627 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13627,7 +13662,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13631: checking for location of FreeType library" >&5
+echo "configure:13666: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13652,13 +13687,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13656: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13691: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13662 "configure"
+#line 13697 "configure"
@@ -13669,7 +13704,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13710,7 +13745,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13714: checking whether to use NLS" >&5
+echo "configure:13749: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13730,10 +13765,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13734: checking for gettext" >&5
+echo "configure:13769: checking for gettext" >&5
-#line 13737 "configure"
+#line 13772 "configure"
     which can conflict with char gettext(); below.  */
@@ -13756,7 +13791,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13774,13 +13809,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13778: checking for gettext in -lintl" >&5
+echo "configure:13813: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13784 "configure"
+#line 13819 "configure"
@@ -13791,7 +13826,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13826,7 +13861,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13830: checking whether to use C++" >&5
+echo "configure:13865: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13842,7 +13877,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13846: checking for $ac_word" >&5
+echo "configure:13881: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13871,7 +13906,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13875: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13910: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13882,12 +13917,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13886 "configure"
+#line 13921 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13913,19 +13948,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13917: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13952: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13922: checking whether we are using GNU C++" >&5
+echo "configure:13957: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13929: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13943,7 +13978,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13947: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13982: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13984,7 +14019,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13988: checking whether to use openDWG" >&5
+echo "configure:14023: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14004,7 +14039,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14008: checking for location of openDGW includes" >&5
+echo "configure:14043: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14030,15 +14065,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14034: checking for $ac_hdr" >&5
+echo "configure:14069: checking for $ac_hdr" >&5
-#line 14037 "configure"
+#line 14072 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14072,7 +14107,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14076: checking for location of openDWG library" >&5
+echo "configure:14111: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14109,6 +14144,239 @@
 # Done checking OPENDWG
+# Enable pthread option
+echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
+echo "configure:14152: checking whether to use POSIX threads" >&5
+echo "$ac_t"""$with_pthread"" 1>&6
+case "$with_pthread" in
+	"no")	USE_PTHREAD=	;;
+	"yes")	USE_PTHREAD="1"	;;
+	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
+esac
+PTHREADINCPATH=
+PTHREADLIBPATH=
+PTHREADLIB=
+if test -n "$USE_PTHREAD"; then
+# With pthread includes directory
+echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
+echo "configure:14172: checking for location of POSIX threads includes" >&5
+case "$with_pthread_includes" in
+y | ye | yes | n | no)
+	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_pthread_includes" 1>&6
+if test -n "$with_pthread_includes" ; then
+    for dir in $with_pthread_includes; do
+        if test -d "$dir"; then
+            PTHREADINCPATH="$PTHREADINCPATH -I$dir"
+        else
+            { echo "configure: error: *** POSIX threads includes directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$PTHREADINCPATH $CPPFLAGS"
+for ac_hdr in pthread.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:14198: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 14201 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:14206: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate POSIX threads includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+# With pthread library directory
+echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
+echo "configure:14240: checking for location of POSIX threads library" >&5
+case "$with_pthread_libs" in
+	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_pthread_libs" 1>&6
+if test -n "$with_pthread_libs"; then
+    for dir in $with_pthread_libs; do
+            PTHREADLIBPATH="$PTHREADLIBPATH -L$dir"
+        else
+            { echo "configure: error: *** POSIX threads library directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS="  $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
+echo "configure:14265: checking for pthread_create" >&5
+#line 14268 "configure"
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char pthread_create(); below.  */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char pthread_create();
+int main() {
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_pthread_create) || defined (__stub___pthread_create)
+choke me
+#else
+pthread_create();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:14291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_func_pthread_create=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_func_pthread_create=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'pthread_create`\" = yes"; then
+    PTHREADLIB="$PTHREADLIB "
+else
+LDFLAGS="$PTHREADLIBPATH $LDFLAGS"
+echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
+echo "configure:14318: checking for pthread_create in -lpthread" >&5
+ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lpthread  $LIBS"
+#line 14324 "configure"
+int main() {
+pthread_create()
+; return 0; }
+EOF
+if { (eval echo configure:14335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  PTHREADLIB="$PTHREADLIB -lpthread "
+else
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate POSIX threads library." 1>&2; exit 1; }
+fi
+fi
+LIBS=${ac_save_libs}
+fi # $USE_PTHREAD
+# Done checking pthread
 # Enable LFS (from cdr-tools)
 # Check whether --enable-largefile or --disable-largefile was given.
 if test "${enable_largefile+set}" = set; then
@@ -14119,7 +14387,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14123: checking for special C compiler options needed for large files" >&5
+echo "configure:14391: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14127,7 +14395,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14131 "configure"
+#line 14399 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14143,7 +14411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14152,7 +14420,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14156 "configure"
+#line 14424 "configure"
@@ -14168,7 +14436,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14440: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14188,11 +14456,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14192: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14460: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14196 "configure"
+#line 14464 "configure"
@@ -14208,14 +14476,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14212: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14480: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14219 "configure"
+#line 14487 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14233,7 +14501,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14237: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14505: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14252,11 +14520,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14256: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14524: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14260 "configure"
+#line 14528 "configure"
@@ -14272,14 +14540,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14276: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14544: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14283 "configure"
+#line 14551 "configure"
 #define _LARGE_FILES 1
@@ -14297,7 +14565,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14301: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14316,25 +14584,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14320: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14588: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14324 "configure"
+#line 14592 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14331: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14599: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14338 "configure"
+#line 14606 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14343,7 +14611,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14347: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14615: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14364,10 +14632,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14368: checking if system supports Large Files at all" >&5
+echo "configure:14636: checking if system supports Large Files at all" >&5
-#line 14371 "configure"
+#line 14639 "configure"
 #include <stdio.h>
@@ -14399,7 +14667,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14671: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14428,7 +14696,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14432: checking whether to use Python" >&5
+echo "configure:14700: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14448,7 +14716,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14452: checking for $ac_word" >&5
+echo "configure:14720: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14493,15 +14761,15 @@
 do
-echo "configure:14497: checking for $ac_hdr" >&5
+echo "configure:14765: checking for $ac_hdr" >&5
-#line 14500 "configure"
+#line 14768 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14541,7 +14809,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14545: checking for $ac_word" >&5
+echo "configure:14813: checking for $ac_word" >&5
 case "$SWIG" in
@@ -14587,7 +14855,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14591: checking whether to use wxWidgets" >&5
+echo "configure:14859: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14607,7 +14875,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14611: checking for $ac_word" >&5
+echo "configure:14879: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14655,7 +14923,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14659: checking wxWidgets version" >&5
+echo "configure:14927: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14678,15 +14946,15 @@
 do
-echo "configure:14682: checking for $ac_hdr" >&5
+echo "configure:14950: checking for $ac_hdr" >&5
-#line 14685 "configure"
+#line 14953 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14722,15 +14990,15 @@
 do
-echo "configure:14726: checking for $ac_hdr" >&5
+echo "configure:14994: checking for $ac_hdr" >&5
-#line 14729 "configure"
+#line 14997 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15027,6 +15295,10 @@
 s%@OPENDWGLIBPATH@%$OPENDWGLIBPATH%g
 s%@OPENDWGLIB@%$OPENDWGLIB%g
 s%@USE_OPENDWG@%$USE_OPENDWG%g
+s%@PTHREADINCPATH@%$PTHREADINCPATH%g
+s%@PTHREADLIBPATH@%$PTHREADLIBPATH%g
+s%@PTHREADLIB@%$PTHREADLIB%g
+s%@USE_PTHREAD@%$USE_PTHREAD%g
 s%@USE_LARGEFILES@%$USE_LARGEFILES%g
 s%@PY_CONFIG@%$PY_CONFIG%g
 s%@SWIG@%$SWIG%g
@@ -15373,5 +15645,9 @@
 echo "  X11 support:                `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
+echo "  Regex support:              `if test -n "${USE_REGEX}" ; then echo yes ; else echo no ; fi`"
+echo "  POSIX thread support:       `if test -n "${USE_PTHREAD}" ; then echo yes ; else echo no ; fi`"
 echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/configure.in	2008-11-25 23:47:02 UTC (rev 34487)
@@ -195,6 +195,7 @@
 LOC_ARG_WITH(readline, Readline, no)
 LOC_ARG_WITH(opendwg, openDWG, no)
 LOC_ARG_WITH(regex, regex)
+LOC_ARG_WITH(pthread, POSIX threads, no)
 AC_ARG_WITH(python,
 [  --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
 e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
@@ -277,6 +278,9 @@
 LOC_ARG_WITH_INC(regex, regex)
 LOC_ARG_WITH_LIB(regex, regex)
+LOC_ARG_WITH_INC(pthread, POSIX threads)
+LOC_ARG_WITH_LIB(pthread, POSIX threads)
 # Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
 # With includes option
@@ -1517,6 +1521,39 @@
+LOC_CHECK_USE(pthread,POSIX threads,USE_PTHREAD)
+PTHREADINCPATH=
+PTHREADLIBPATH=
+PTHREADLIB=
+LOC_CHECK_INC_PATH(pthread,POSIX threads,PTHREADINCPATH)
+LOC_CHECK_INCLUDES(pthread.h,POSIX threads,$PTHREADINCPATH)
+LOC_CHECK_LIB_PATH(pthread,POSIX threads,PTHREADLIBPATH)
+LOC_CHECK_FUNC(pthread_create,POSIX threads functions,PTHREADLIB,,,,,[
+LOC_CHECK_LIBS(pthread,pthread_create,POSIX threads,$PTHREADLIBPATH,PTHREADLIB,,,)
+fi # $USE_PTHREAD
+AC_SUBST(PTHREADINCPATH)
+AC_SUBST(PTHREADLIBPATH)
+AC_SUBST(PTHREADLIB)
+AC_SUBST(USE_PTHREAD)
 dnl Check for large file support
 dnl Do this last to make sure that no large file definition
@@ -1719,4 +1756,6 @@
 LOC_MSG_USE(wxWidgets support,USE_WXWIDGETS)
 LOC_MSG_USE(TIFF support,USE_TIFF)
 LOC_MSG_USE(X11 support,USE_X11)
+LOC_MSG_USE(Regex support,USE_REGEX)
+LOC_MSG_USE(POSIX thread support,USE_PTHREAD)
 LOC_MSG()
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/include/Make/Platform.make.in	2008-11-25 23:47:02 UTC (rev 34487)
@@ -231,6 +231,12 @@
 REGEXLIB            = @REGEXLIB@
 USE_REGEX           = @USE_REGEX@
+#pthreads
+PTHREADINCPATH      = @PTHREADINCPATH@
+PTHREADLIBPATH      = @PTHREADLIBPATH@
+PTHREADLIB          = @PTHREADLIB@
+USE_PTHREAD         = @USE_PTHREAD@
 #i18N
 HAVE_NLS            = @HAVE_NLS@
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/include/config.h.in	2008-11-25 23:47:02 UTC (rev 34487)
@@ -236,6 +236,9 @@
 /* define if regex.h exists */
 #undef HAVE_REGEX_H
+/* define if pthread.h exists */
+#undef HAVE_PTHREAD_H
  * configuration information solely dependent on the above
  * nothing below this point should need changing
Modified: grass/trunk/lib/gis/Makefile
--- grass/trunk/lib/gis/Makefile	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/lib/gis/Makefile	2008-11-25 23:47:02 UTC (rev 34487)
@@ -4,9 +4,9 @@
 GDAL_DYNAMIC = 1
 LIB_NAME = $(GIS_LIBNAME)
-EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
+EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(INTLLIB) $(MATHLIB)
 DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections gui.tcl
-EXTRA_INC = $(ZLIBINCPATH)
+EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
 include $(MODULE_TOPDIR)/include/Make/Lib.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
@@ -37,12 +37,6 @@
 endif
-ifneq ($(USE_PTHREAD),)
-PTHREADLIB = -lpthread
-EXTRA_CFLAGS += -DUSE_PTHREAD
-EXTRA_LIBS += $(PTHREADLIB)
-endif
 default: lib $(FMODE_OBJ) $(DATAFILES) $(COLORFILES) $(ETC)/colors.desc $(ETC)/element_list
 $(FMODE_OBJ): fmode.dat
Modified: grass/trunk/lib/gis/counter.c
--- grass/trunk/lib/gis/counter.c	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/lib/gis/counter.c	2008-11-25 23:47:02 UTC (rev 34487)
@@ -1,32 +1,15 @@
+#include <grass/config.h>
+#ifdef HAVE_PTHREAD_H
+#define _XOPEN_SOURCE 500
+#endif
 #include <grass/gis.h>
-#ifdef USE_PTHREADS
 #include <pthread.h>
 static pthread_mutex_t mutex;
 #endif
-void G_init_counter(struct Counter *c, int v)
-    make_mutex();
-#endif
-    c->value = v;
-int G_counter_next(struct Counter *c)
-    int v;
-    pthread_mutex_lock(&mutex);
-#endif
-    v = c->value++;
-    pthread_mutex_unlock(&mutex);
-#endif
-    return v;
 static void make_mutex(void)
     static pthread_mutex_t t_mutex = PTHREAD_MUTEX_INITIALIZER;
@@ -45,19 +28,40 @@
     pthread_mutexattr_init(&attr);
     pthread_mutexattr_settype(&attr, PTHREAD_MUTEX_RECURSIVE);
-    pthread_mutex_init(&r_mutex, &attr);
+    pthread_mutex_init(&mutex, &attr);
     initialized = 1;
     pthread_mutex_unlock(&t_mutex);
 #endif
+void G_init_counter(struct Counter *c, int v)
+    make_mutex();
+#endif
+    c->value = v;
+int G_counter_next(struct Counter *c)
+    int v;
+    pthread_mutex_lock(&mutex);
+#endif
+    v = c->value++;
+    pthread_mutex_unlock(&mutex);
+#endif
+    return v;
 int G_is_initialized(int *p)
     if (*p)
 	return 1;
     make_mutex();
 #endif
@@ -68,7 +72,7 @@
     *p = 1;
 #endif
Modified: grass/trunk/lib/gis/worker.c
--- grass/trunk/lib/gis/worker.c	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/lib/gis/worker.c	2008-11-25 23:47:02 UTC (rev 34487)
@@ -4,7 +4,7 @@
 #include <grass/glocale.h>
-#ifdef USE_PTHREAD
@@ -132,6 +132,7 @@
     for (i = 0; i < num_workers; i++) {
 	struct worker *w = &workers[i];
 	w->cancel = 1;
+	pthread_cancel(w->thread);
Modified: grass/trunk/raster/r.mapcalc/Makefile
--- grass/trunk/raster/r.mapcalc/Makefile	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/raster/r.mapcalc/Makefile	2008-11-25 23:47:02 UTC (rev 34487)
@@ -11,17 +11,10 @@
 include $(MODULE_TOPDIR)/include/Make/Multi.make
-EXTRA_CFLAGS = $(READLINEINCPATH)
-LIBES2 = $(GISLIB) $(BTREELIB) $(ROWIOLIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB)
-LIBES3 = $(G3DLIB) $(GISLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB)
+EXTRA_CFLAGS = $(READLINEINCPATH) $(PTHREADINCPATH)
+LIBES2 =           $(GISLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
+LIBES3 = $(G3DLIB) $(GISLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
-LIBES2 += $(PTHREADLIB)
-LIBES3 += $(PTHREADLIB)
-endif
 default: multi
 $(BIN)/$(PGM2)$(EXE): LIBES = $(LIBES2)
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/raster/r.mapcalc/evaluate.c	2008-11-25 23:47:02 UTC (rev 34487)
@@ -103,7 +103,7 @@
 static void begin_evaluate(struct expression *e)
-    G_begin_execute(do_evaluate, e, &e->worker, 1);
+    G_begin_execute(do_evaluate, e, &e->worker, 0);
 static void end_evaluate(struct expression *e)
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c	2008-11-25 21:15:33 UTC (rev 34486)
+++ grass/trunk/raster/r.mapcalc/map.c	2008-11-25 23:47:02 UTC (rev 34487)
@@ -3,7 +3,7 @@
 #include <limits.h>
 #include <string.h>
 #include <unistd.h>
-#ifdef USE_PTHREAD
 #endif
@@ -57,7 +57,7 @@
     struct Colors colors;
     BTREE btree;
     struct row_cache cache;
-#ifdef USE_PTHREAD
 #endif
@@ -75,7 +75,7 @@
 static int max_rows_in_memory = 8;
-#ifdef USE_PTHREAD
 static pthread_mutex_t cats_mutex;
 #endif
@@ -307,7 +307,7 @@
     void *ptr;
     char *label;
-#ifdef XUSE_PTHREAD
     pthread_mutex_lock(&cats_mutex);
 #endif
@@ -355,7 +355,7 @@
 	    *xcell = values[idx];
     pthread_mutex_unlock(&cats_mutex);
 #endif
@@ -370,7 +370,7 @@
     int nrows = m->max_row - m->min_row + 1;
-#ifdef USE_PTHREAD
     pthread_mutex_init(&m->mutex, NULL);
 #endif
@@ -430,7 +430,7 @@
 	G_fatal_error(_("Unable to close raster map <%s@%s>"),
 		      m->name, m->mapset);
-#ifdef USE_PTHREAD
     pthread_mutex_destroy(&m->mutex);
 #endif
@@ -579,7 +579,7 @@
     int i;
-#ifdef USE_PTHREAD
     pthread_mutex_init(&cats_mutex, NULL);
 #endif
@@ -594,7 +594,7 @@
     DCELL *fbuf;
     struct map *m = &maps[idx];
-#ifdef USE_PTHREAD
     pthread_mutex_lock(&m->mutex);
 #endif
@@ -624,7 +624,7 @@
 	break;
-#ifdef USE_PTHREAD
     pthread_mutex_unlock(&m->mutex);
 #endif
@@ -638,7 +638,7 @@
     num_maps = 0;
-#ifdef USE_PTHREAD
     pthread_mutex_destroy(&cats_mutex);
 #endif
