[GRASS-SVN] r34514 - grass-addons/vector/v.parallel2
Wed Nov 26 16:29:49 EST 2008
Author: neteler
Date: 2008-11-26 16:29:49 -0500 (Wed, 26 Nov 2008)
New Revision: 34514
   grass-addons/vector/v.parallel2/Makefile
   grass-addons/vector/v.parallel2/main.c
moved here from GRASS Addons
Modified: grass-addons/vector/v.parallel2/Makefile
--- grass-addons/vector/v.parallel2/Makefile	2008-11-26 21:26:09 UTC (rev 34513)
+++ grass-addons/vector/v.parallel2/Makefile	2008-11-26 21:29:49 UTC (rev 34514)
@@ -1,7 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = v.parallel2
+PGM = v.parallel
 LIBES = $(VECTLIB) $(GISLIB)
 DEPENDENCIES= $(VECTDEP) $(GISDEP)
Modified: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c	2008-11-26 21:26:09 UTC (rev 34513)
+++ grass-addons/vector/v.parallel2/main.c	2008-11-26 21:29:49 UTC (rev 34514)
@@ -167,12 +167,13 @@
-/*    Vect_build_partial(&Out, GV_BUILD_BASE, stderr);
-    Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL, stderr);
-    Vect_break_lines(&Out, GV_BOUNDARY, NULL, stderr);
-    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL, stderr);
-    Vect_build_partial (&Out, GV_BUILD_NONE, NULL); */
-    Vect_build (&Out, stderr);
+/*    Vect_build_partial(&Out, GV_BUILD_BASE);
+    Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+    Vect_break_lines(&Out, GV_BOUNDARY, NULL);
+    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
+    Vect_build_partial (&Out, GV_BUILD_NONE);
+    Vect_build (&Out);
     Vect_close (&In);
     Vect_close (&Out);
