[GRASS-SVN] r34549 - in grass/branches/develbranch_6: include lib/gis raster/r.colors
Thu Nov 27 16:05:46 EST 2008
Author: neteler
Date: 2008-11-27 16:05:46 -0500 (Thu, 27 Nov 2008)
New Revision: 34549
   grass/branches/develbranch_6/include/gis.h
   grass/branches/develbranch_6/lib/gis/color_xform.c
   grass/branches/develbranch_6/raster/r.colors/local_proto.h
   grass/branches/develbranch_6/raster/r.colors/main.c
   grass/branches/develbranch_6/raster/r.colors/stats.c
glynn: Add -a (log-abs) flag to r.colors (merge from trunk, r34415)
Modified: grass/branches/develbranch_6/include/gis.h
--- grass/branches/develbranch_6/include/gis.h	2008-11-27 20:59:04 UTC (rev 34548)
+++ grass/branches/develbranch_6/include/gis.h	2008-11-27 21:05:46 UTC (rev 34549)
@@ -532,6 +532,7 @@
 struct FP_stats {
     int geometric;
+    int geom_abs;
     int flip;
     int count;
     DCELL min, max;
Modified: grass/branches/develbranch_6/lib/gis/color_xform.c
--- grass/branches/develbranch_6/lib/gis/color_xform.c	2008-11-27 20:59:04 UTC (rev 34548)
+++ grass/branches/develbranch_6/lib/gis/color_xform.c	2008-11-27 21:05:46 UTC (rev 34549)
@@ -162,9 +162,10 @@
 	val2 = statf->min + (statf->max - statf->min) * i / statf->count;
 	if (statf->geometric)
 	    val2 = exp(val2);
+	if (statf->geom_abs)
+	    val2 = exp(val2) - 1;
 	if (statf->flip)
 	    val2 = -val2;
 	x = min + (max - min) * sum / statf->total;
 	G_get_d_raster_color(&x, &red2, &grn2, &blu2, src);
@@ -297,10 +298,17 @@
 	    x = exp(lx);
-	if (i > 0)
-	    G_add_d_raster_color_rule(&prev, red, grn, blu,
-				      &x, red2, grn2, blu2,
+	if (i > 0) {
+	    DCELL x0 = prev, x1 = x;
+	    G_add_d_raster_color_rule(&x0, red, grn, blu,
+				      &x1, red2, grn2, blu2,
 				      dst);
+	    x0 = -x0;
+	    x1 = -x1;
+				      dst);
 	prev = x;
Modified: grass/branches/develbranch_6/raster/r.colors/local_proto.h
--- grass/branches/develbranch_6/raster/r.colors/local_proto.h	2008-11-27 20:59:04 UTC (rev 34548)
+++ grass/branches/develbranch_6/raster/r.colors/local_proto.h	2008-11-27 21:05:46 UTC (rev 34549)
@@ -26,7 +26,7 @@
 int get_stats(const char *, const char *, struct Cell_stats *);
 void get_fp_stats(const char *name, const char *mapset,
 		  struct FP_stats *statf,
-		  DCELL min, DCELL max, int geometric);
+		  DCELL min, DCELL max, int geometric, int geom_abs);
 /* main.c */
 int main(int, char *[]);
Modified: grass/branches/develbranch_6/raster/r.colors/main.c
--- grass/branches/develbranch_6/raster/r.colors/main.c	2008-11-27 20:59:04 UTC (rev 34548)
+++ grass/branches/develbranch_6/raster/r.colors/main.c	2008-11-27 21:05:46 UTC (rev 34549)
@@ -151,7 +151,7 @@
     struct GModule *module;
     struct
-	struct Flag *r, *w, *l, *g, *e, *i, *q, *n;
+	struct Flag *r, *w, *l, *g, *a, *e, *i, *q, *n;
     } flag;
     struct
@@ -219,6 +219,11 @@
     flag.g->description = _("Logarithmic scaling");
     flag.g->guisection = _("Colors");
+    flag.a = G_define_flag();
+    flag.a->key = 'a';
+    flag.a->description = _("Logarithmic-absolute scaling");
+    flag.a->guisection = _("Colors");
     flag.e = G_define_flag();
     flag.e->key = 'e';
     flag.e->description = _("Histogram equalization");
@@ -278,6 +283,9 @@
 	rules = NULL;
+    if (flag.g->answer && flag.a->answer)
+	G_fatal_error(_("-g and -a flags are mutually exclusive"));
     mapset = G_find_cell2(name, "");
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
@@ -374,7 +382,7 @@
     if (flag.e->answer) {
 	if (fp) {
 	    struct FP_stats fpstats;
-	    get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer);
+	    get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
 	    G_histogram_eq_colors_fp(&colors_tmp, &colors, &fpstats);
 	else {
@@ -390,6 +398,11 @@
 	colors = colors_tmp;
+    if (flag.a->answer) {
+	G_abs_log_colors(&colors_tmp, &colors, 100);
+	colors = colors_tmp;
     if (fp)
 	G_mark_colors_as_fp(&colors);
Modified: grass/branches/develbranch_6/raster/r.colors/stats.c
--- grass/branches/develbranch_6/raster/r.colors/stats.c	2008-11-27 20:59:04 UTC (rev 34548)
+++ grass/branches/develbranch_6/raster/r.colors/stats.c	2008-11-27 21:05:46 UTC (rev 34549)
@@ -56,7 +56,7 @@
     DCELL *dcell;
     int row, col, nrows, ncols;
@@ -71,6 +71,7 @@
     ncols = G_window_cols();
     statf->geometric = geometric;
+    statf->geom_abs = geom_abs;
     statf->flip = 0;
     if (statf->geometric) {
@@ -87,6 +88,13 @@
 	max = log(max);
+    if (statf->geom_abs) {
+	double a = log(fabs(min) + 1);
+	double b = log(fabs(max) + 1);
+	min = a < b ? a : b;
+	max = a > b ? a : b;
     statf->count = 1000;
     statf->min = min;
     statf->max = max;
@@ -114,6 +122,8 @@
 		x = -x;
 		x = log(x);
+		x = log(fabs(x) + 1);
 	    i = (int) floor(statf->count * (x - statf->min) / (statf->max - statf->min));
 	    statf->stats[i]++;
