[GRASS-SVN] r34612 - in grass/branches/develbranch_6/raster/r.watershed2: . ram seg
Fri Nov 28 21:11:14 EST 2008
Author: hamish
Date: 2008-11-28 21:11:14 -0500 (Fri, 28 Nov 2008)
New Revision: 34612
   grass/branches/develbranch_6/raster/r.watershed2/README
   grass/branches/develbranch_6/raster/r.watershed2/ram/close_maps2.c
   grass/branches/develbranch_6/raster/r.watershed2/ram/find_pour.c
   grass/branches/develbranch_6/raster/r.watershed2/ram/flag.h
   grass/branches/develbranch_6/raster/r.watershed2/ram/init_vars.c
   grass/branches/develbranch_6/raster/r.watershed2/ram/ramseg.h
   grass/branches/develbranch_6/raster/r.watershed2/seg/Gwater.h
   grass/branches/develbranch_6/raster/r.watershed2/seg/close_maps2.c
   grass/branches/develbranch_6/raster/r.watershed2/seg/cseg.h
   grass/branches/develbranch_6/raster/r.watershed2/seg/find_pour.c
   grass/branches/develbranch_6/raster/r.watershed2/seg/init_vars.c
minimize diffs with r.w1, merge in changes to r.w1 since r.w2 was forked
Modified: grass/branches/develbranch_6/raster/r.watershed2/README
--- grass/branches/develbranch_6/raster/r.watershed2/README	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/README	2008-11-29 02:11:14 UTC (rev 34612)
@@ -5,28 +5,8 @@
   Implemented is a new sorting algorithm for both the ram and the
   segmented version, resulting in significant speed improvements,
   with identical results.
-  The following procedure assumes that GRASS was compiled from source
-  and that the configured source tree is available.
-  To compile and install the test version of r.watershed for GRASS,
-  1) copy the directory <r.watershed2> into the directory
-     <raster> of the GRASS souorce tree
-  2) edit <Makefile> in directory <raster>
-     add the line
-     r.watershed2 \
-     e.g. after
-     r.watershed \
-  3) change to directory <r.watershed2>
-     run make
-  4) optionally change to GRASS source directory, something like
-     grass-6.4.svn
-     run as su
-     make install
   Testing
@@ -37,6 +17,7 @@
   version, but the new segmented version is already much faster than
   the original ram version. A new option is available for the segmented
   mode specifying the maximum amount of memory to be used in MB.
   Set up a watershed analysis with the original version, run it.
   The command will have been r.watershed <options>
   To test, use the same input options, but different output maps
@@ -46,5 +27,3 @@
   If you find critical differences between the original and the fast version,
   please let me know at
   markus.metz.giswork at gmail.com
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/close_maps2.c
--- grass/branches/develbranch_6/raster/r.watershed2/ram/close_maps2.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/close_maps2.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -47,6 +47,8 @@
 			    flag = 1;
 			    while (flag) {
 				G_get_color(r, &red, &green, &blue, &colors);
+				/* if existing rule is too dark then append a new
+				   rule to override it */
 				if ((blue * .11 + red * .30 + green * .59) <
 				    100) {
 				    G_set_color(r, rd, gr, bl, &colors);
@@ -75,7 +77,8 @@
 	else
 	    G_debug(1,
-		    "Too many subbasins to reasonably check neighboring color spread");
+		    "Too many subbasins to reasonably check for color brightness");
+	/* using the existing method ... */
     /* stream segments map */
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/find_pour.c
--- grass/branches/develbranch_6/raster/r.watershed2/ram/find_pour.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/find_pour.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -8,7 +8,7 @@
     basin_num = 0;
     for (row = 0; row < nrows; row++) {
-	G_percent(row, nrows, 1);
+	G_percent(row, nrows, 3);
 	northing = window.north - (row + .5) * window.ns_res;
 	for (col = 0; col < ncols; col++) {
 	    value = FLAG_GET(swale, row, col);
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/flag.h
--- grass/branches/develbranch_6/raster/r.watershed2/ram/flag.h	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/flag.h	2008-11-29 02:11:14 UTC (rev 34612)
@@ -3,53 +3,52 @@
 /* flag.[ch] is a set of routines which will set up an array of bits
-** that allow the programmer to "flag" cells in a raster map.
-** FLAG *
-** flag_create(nrows,ncols)
-** int nrows, ncols;
-**	opens the structure flag.
-**	The flag structure will be a two dimensional array of bits the
-**	size of nrows by ncols.  Will initalize flags to zero (unset).
-** flag_destroy(flags)
-** FLAG *flags;
-**	closes flags and gives the memory back to the system.
-** flag_clear_all(flags)
-** FLAG *flags;
-**	sets all values in flags to zero.
-** flag_unset(flags, row, col)
-** FLAG *flags;
-** int row, col;
-**	sets the value of (row, col) in flags to zero.
-** flag_set(flags, row, col)
-** FLAG *flags;
-** int row, col;
-**	will set the value of (row, col) in flags to one.
-** int
-** flag_get(flags, row, col)
-** FLAG *flags;
-** int row, col;
-**	returns the value in flags that is at (row, col).
-** idea by Michael Shapiro
-** code by Chuck Ehlschlaeger
-** April 03, 1989
+ ** that allow the programmer to "flag" cells in a raster map.
+ ** FLAG *
+ ** flag_create(nrows,ncols)
+ ** int nrows, ncols;
+ **     opens the structure flag.
+ **     The flag structure will be a two dimensional array of bits the
+ **     size of nrows by ncols.  Will initalize flags to zero (unset).
+ ** flag_destroy(flags)
+ ** FLAG *flags;
+ **     closes flags and gives the memory back to the system.
+ ** flag_clear_all(flags)
+ ** FLAG *flags;
+ **     sets all values in flags to zero.
+ ** flag_unset(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     sets the value of (row, col) in flags to zero.
+ ** flag_set(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     will set the value of (row, col) in flags to one.
+ ** int
+ ** flag_get(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ **     returns the value in flags that is at (row, col).
+ ** idea by Michael Shapiro
+ ** code by Chuck Ehlschlaeger
+ ** April 03, 1989
 #define FLAG struct _flagsss_
-FLAG
-	int	nrows, ncols, leng;
-	unsigned char	**array;
+FLAG {
+    int nrows, ncols, leng;
+    unsigned char **array;
 #define FLAG_UNSET(flags,row,col) \
 	(flags)->array[(row)][(col)>>3] &= ~(1<<((col) & 7))
 #define FLAG_SET(flags,row,col) \
 	(flags)->array[(row)][(col)>>3] |= (1<<((col) & 7))
@@ -58,14 +57,19 @@
 /* flag_clr_all.c */
 int flag_clear_all(FLAG *);
 /* flag_create.c */
 FLAG *flag_create(int, int);
 /* flag_destroy.c */
 int flag_destroy(FLAG *);
 /* flag_get.c */
 int flag_get(FLAG *, int, int);
 /* flag_set.c */
 int flag_set(FLAG *, int, int);
 /* flag_unset.c */
 int flag_unset(FLAG *, int, int);
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/init_vars.c
--- grass/branches/develbranch_6/raster/r.watershed2/ram/init_vars.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/init_vars.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -170,8 +170,7 @@
 		wat[SEG_INDEX(wat_seg, r, c)] = 1;
-    asp =
-	(CELL *) G_malloc(size_array(&asp_seg, nrows, ncols) * sizeof(CELL));
+    asp = (CELL *) G_malloc(size_array(&asp_seg, nrows, ncols) * sizeof(CELL));
     if (pit_flag) {
 	pit_mapset = do_exist(pit_name);
@@ -393,7 +392,7 @@
 int do_legal(char *file_name)
     if (G_legal_filename(file_name) == -1)
-	G_fatal_error(_("map layer [%s] not legal for GRASS"), file_name);
+	G_fatal_error(_("<%s> is an illegal file name"), file_name);
     return 0;
@@ -403,7 +402,7 @@
     char *file_mapset = G_find_cell2(file_name, "");
     if (file_mapset == NULL)
-	G_fatal_error(_("[%s] map not found."), file_name);
+	G_fatal_error(_("Raster map <%s> not found"), file_name);
     return (file_mapset);
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/ramseg.h
--- grass/branches/develbranch_6/raster/r.watershed2/ram/ramseg.h	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/ramseg.h	2008-11-29 02:11:14 UTC (rev 34612)
@@ -4,8 +4,8 @@
 #define RAMSEG		int
 #define RAMSEGBITS 	4
-#define DOUBLEBITS 	8	/* 2 * ramsegbits	*/
-#define SEGLENLESS 	15	/* 2 ^ ramsegbits - 1	*/
+#define DOUBLEBITS 	8	/* 2 * ramsegbits       */
+#define SEGLENLESS 	15	/* 2 ^ ramsegbits - 1   */
 #define SEG_INDEX(s,r,c) (int) \
    (((((r) >> RAMSEGBITS) * (s) + ((c) >> RAMSEGBITS)) << DOUBLEBITS) \
Modified: grass/branches/develbranch_6/raster/r.watershed2/seg/Gwater.h
--- grass/branches/develbranch_6/raster/r.watershed2/seg/Gwater.h	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/seg/Gwater.h	2008-11-29 02:11:14 UTC (rev 34612)
@@ -3,9 +3,9 @@
 /* program to map out drainage basin structure  */
-/* this one uses the A * search algorithm   	*/
-/* written by Chuck Ehlschlaeger        	*/
-/* last modified 03/26/91           		*/
+/* this one uses the A * search algorithm       */
+/* written by Chuck Ehlschlaeger                */
+/* last modified 03/26/91                       */
 #include <math.h>
 #include <grass/gis.h>
 #include "cseg.h"
@@ -30,10 +30,9 @@
 #define TST(a)		(fprintf (stderr, "%e\n", (double) (a)))
 #define POINT       struct points
-POINT
-    SHORT       r, c, downr, downc;
-    int		nxt;
+POINT {
+    SHORT r, c, downr, downc;
+    int nxt;
 #ifdef MAIN
@@ -51,78 +50,95 @@
 #endif
 #define HEAP    struct heap_item
-HEAP
+HEAP {
    int point;
    CELL ele;
-GLOBAL struct Cell_head		window;
+GLOBAL struct Cell_head window;
-GLOBAL SSEG		heap_index;
-GLOBAL int 		heap_size;
-GLOBAL int	first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
-GLOBAL SHORT    nrows, ncols;
-GLOBAL double   half_res, diag, max_length, dep_slope;
-GLOBAL int	bas_thres, tot_parts;
-GLOBAL SSEG	astar_pts;
-GLOBAL BSEG     worked, in_list, s_b, swale;
-GLOBAL CSEG     dis, alt, wat, asp, bas, haf, r_h, dep;
-GLOBAL DSEG     slp, s_l, s_g, l_s, ril;
-GLOBAL CELL	one, zero;
-GLOBAL double	ril_value, dzero;
-GLOBAL SHORT    sides;
-GLOBAL SHORT	drain[3][3]	DRAINVAR;
-GLOBAL SHORT	updrain[3][3]	UPDRAINVAR;
-GLOBAL SHORT	nextdr[8]	NEXTDRVAR;
-GLOBAL SHORT	nextdc[8]	NEXTDCVAR;
-GLOBAL char     ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX], *pit_mapset;
-GLOBAL char     run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
-GLOBAL char	ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX], *dep_mapset;
+GLOBAL SSEG heap_index;
+GLOBAL int heap_size;
+GLOBAL int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+GLOBAL SHORT nrows, ncols;
+GLOBAL double half_res, diag, max_length, dep_slope;
+GLOBAL int bas_thres, tot_parts;
+GLOBAL SSEG astar_pts;
+GLOBAL BSEG worked, in_list, s_b, swale;
+GLOBAL CSEG dis, alt, wat, asp, bas, haf, r_h, dep;
+GLOBAL DSEG slp, s_l, s_g, l_s, ril;
+GLOBAL CELL one, zero;
+GLOBAL double ril_value, dzero;
+GLOBAL SHORT sides;
+GLOBAL SHORT drain[3][3] DRAINVAR;
+GLOBAL SHORT updrain[3][3] UPDRAINVAR;
+GLOBAL SHORT nextdr[8] NEXTDRVAR;
+GLOBAL SHORT nextdc[8] NEXTDCVAR;
+GLOBAL char ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX],
+    *pit_mapset;
+GLOBAL char run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
+GLOBAL char ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX],
+    *dep_mapset;
-GLOBAL char	*this_mapset;
-GLOBAL char     seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
-GLOBAL char     ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
-GLOBAL char     wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
-GLOBAL char     ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
-GLOBAL char     wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
-GLOBAL char     bas_flag, seg_flag, haf_flag, er_flag;
-GLOBAL char	st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
-GLOBAL FILE     *fp;
+GLOBAL char *this_mapset;
+GLOBAL char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX],
+    thr_name[8];
+GLOBAL char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX],
+    sg_name[GNAME_MAX];
+GLOBAL char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX],
+    dis_name[GNAME_MAX];
+GLOBAL char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+GLOBAL char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+GLOBAL char bas_flag, seg_flag, haf_flag, er_flag;
+GLOBAL char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
+GLOBAL FILE *fp;
 /* close_maps.c */
 int close_maps(void);
 /* close_maps2.c */
 int close_array_seg(void);
 /* def_basin.c */
 CELL def_basin(int, int, CELL, double, CELL);
 /* do_astar.c */
 int do_astar(void);
 int add_pt(SHORT, SHORT, SHORT, SHORT, CELL, CELL);
 int drop_pt(void);
 double get_slope(SHORT, SHORT, SHORT, SHORT, CELL, CELL);
 int replace(SHORT, SHORT, SHORT, SHORT);
 /* do_cum.c */
 int do_cum(void);
 /* find_pour.c */
 int find_pourpts(void);
 /* haf_side.c */
 int haf_basin_side(SHORT, SHORT, SHORT);
 /* init_vars.c */
 int init_vars(int, char *[]);
 int do_legal(char *);
 char *do_exist(char *);
 /* no_stream.c */
 int no_stream(int, int, CELL, double, CELL);
 /* over_cells.c */
 int overland_cells(int, int, CELL, CELL, CELL *);
 /* sg_factor.c */
 int sg_factor(void);
 int len_slp_equ(double, double, double, int, int);
 /* slope_len.c */
 int slope_length(SHORT, SHORT, SHORT, SHORT);
 /* split_str.c */
-CELL split_stream(int, int, int [], int [], int, CELL, double, CELL);
+CELL split_stream(int, int, int[], int[], int, CELL, double, CELL);
 /* usage.c */
 void usage(char *);
Modified: grass/branches/develbranch_6/raster/r.watershed2/seg/close_maps2.c
--- grass/branches/develbranch_6/raster/r.watershed2/seg/close_maps2.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/seg/close_maps2.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -40,6 +40,8 @@
 			    flag = 1;
 			    while (flag) {
 				    100) {
@@ -64,7 +66,8 @@
 	else
 	    G_debug(1,
Modified: grass/branches/develbranch_6/raster/r.watershed2/seg/cseg.h
--- grass/branches/develbranch_6/raster/r.watershed2/seg/cseg.h	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/seg/cseg.h	2008-11-29 02:11:14 UTC (rev 34612)
@@ -5,92 +5,114 @@
 #include <grass/segment.h>
 #define CSEG struct _c_s_e_g_
-CSEG
-	SEGMENT	seg;         /* segment structure */
-	int	fd;          /* fd for reading/writing segment file */
-	char	*filename;   /* name of segment file */
-	char	*name;       /* raster map read into segment file */
-	char	*mapset;
+CSEG {
+    SEGMENT seg;		/* segment structure */
+    int fd;			/* fd for reading/writing segment file */
+    char *filename;		/* name of segment file */
+    char *name;			/* raster map read into segment file */
+    char *mapset;
 #define DSEG struct _d_s_e_g_
-DSEG
-	char	*mapset;
+DSEG {
+    char *mapset;
 #define BSEG struct _b_s_e_g_
-BSEG
-	char	*mapset;
+BSEG {
+    char *mapset;
 #define SSEG struct _s_s_e_g_
-SSEG
+SSEG {
 /* bseg_close.c */
 int bseg_close(BSEG *);
 /* bseg_get.c */
 int bseg_get(BSEG *, CELL *, int, int);
 /* bseg_open.c */
 int bseg_open(BSEG *, int, int, int);
 /* bseg_put.c */
 int bseg_put(BSEG *, CELL *, int, int);
 /* bseg_read.c */
 int bseg_read_cell(BSEG *, char *, char *);
 /* bseg_write.c */
 int bseg_write_cellfile(BSEG *, char *);
 /* cseg_close.c */
 int cseg_close(CSEG *);
 /* cseg_get.c */
 int cseg_get(CSEG *, CELL *, int, int);
 /* cseg_open.c */
 int cseg_open(CSEG *, int, int, int);
 /* cseg_put.c */
 int cseg_put(CSEG *, CELL *, int, int);
 /* cseg_read.c */
 int cseg_read_cell(CSEG *, char *, char *);
 /* cseg_write.c */
 int cseg_write_cellfile(CSEG *, char *);
 /* dseg_close.c */
 int dseg_close(DSEG *);
 /* dseg_get.c */
 int dseg_get(DSEG *, double *, int, int);
 /* dseg_open.c */
 int dseg_open(DSEG *, int, int, int);
 /* dseg_put.c */
 int dseg_put(DSEG *, double *, int, int);
 /* dseg_read.c */
 int dseg_read_cell(DSEG *, char *, char *);
 /* dseg_write.c */
 int dseg_write_cellfile(DSEG *, char *);
 /* seg_close.c */
 int seg_close(SSEG *);
 /* seg_get.c */
 int seg_get(SSEG *, char *, int, int);
 /* seg_open.c */
 int seg_open(SSEG *, int, int, int, int, int, int);
 /* seg_put.c */
 int seg_put(SSEG *, char *, int, int);
 /* sseg_close.c */
 /* sseg_get.c */
 /* sseg_open.c */
 /* sseg_put.c */
Modified: grass/branches/develbranch_6/raster/r.watershed2/seg/find_pour.c
--- grass/branches/develbranch_6/raster/r.watershed2/seg/find_pour.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/seg/find_pour.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -8,7 +8,7 @@
     basin_num = 0;
 	    /* cseg_get (&wat, &value, row, col);
Modified: grass/branches/develbranch_6/raster/r.watershed2/seg/init_vars.c
--- grass/branches/develbranch_6/raster/r.watershed2/seg/init_vars.c	2008-11-29 02:02:24 UTC (rev 34611)
+++ grass/branches/develbranch_6/raster/r.watershed2/seg/init_vars.c	2008-11-29 02:11:14 UTC (rev 34612)
@@ -225,7 +225,7 @@
     if (NULL != G_find_file("cell", "MASK", G_mapset())) {
 	MASK_flag = 1;
 	if ((fd = G_open_cell_old("MASK", G_mapset())) < 0) {
-	    G_fatal_error(_("unable to open MASK"));
+	    G_fatal_error(_("Unable to open MASK"));
 	else {
 	    buf = G_allocate_cell_buf();
@@ -450,7 +450,7 @@
     return 0;
@@ -460,7 +460,7 @@
-	G_fatal_error(_("[%s] map not found"), file_name);
