[GRASS-SVN] r34614 - grass/branches/develbranch_6/raster/r.watershed2/front
Fri Nov 28 21:56:47 EST 2008
Author: hamish
Date: 2008-11-28 21:56:47 -0500 (Fri, 28 Nov 2008)
New Revision: 34614
   grass/branches/develbranch_6/raster/r.watershed2/front/description.html
gr6 option names; no >< in html (merge r34578 from trunk)
Modified: grass/branches/develbranch_6/raster/r.watershed2/front/description.html
--- grass/branches/develbranch_6/raster/r.watershed2/front/description.html	2008-11-29 02:53:00 UTC (rev 34613)
+++ grass/branches/develbranch_6/raster/r.watershed2/front/description.html	2008-11-29 02:56:47 UTC (rev 34614)
@@ -68,7 +68,7 @@
 overland flow each cell contributes to surface flow.  If omitted, a
 value of one (1) is assumed. The algorithm is D8 flow accumulation.
-<dt><em>disturbed_land</em>
+<dt><em>disturbed.land</em>
 <dd>Raster map input layer or value containing the percent of disturbed
 land (i.e., croplands, and construction sites) where the raster or input
@@ -86,11 +86,11 @@
 <dd>The minimum size of an exterior watershed basin in cells, if no flow
 map is input, or overland flow units when a flow map is given.
 Warning: low threshold values will dramactically increase run time and
-generate difficult too read basin and half_basin results.
+generate difficult too read basin and half.basin results.
 This parameter also controls the level of detail in the <em>stream</em>
 segments map.
-<dt><em>max_slope_length</em>
+<dt><em>max.slope.length</em>
 <dd>Input value indicating the maximum length of overland surface flow
 in meters.  If overland flow travels greater than the maximum length,
@@ -134,7 +134,7 @@
 <dd>Output map: stream segments.  Values correspond to the watershed
 basin values.
-<dt><em>half_basin</em>
+<dt><em>half.basin</em>
 <dd>Output map: each half-basin is given a unique value.  Watershed
 basins are divided into left and right sides.  The right-hand side
@@ -151,7 +151,7 @@
 are changed to zero.  All positive values above the basin threshold
 are given the value of the <em>threshold</em> parameter.
-<dt><em>length_slope</em>
+<dt><em>length.slope</em>
 <dd>Output map: slope length and steepness (LS) factor.  Contains the LS
 factor for the Revised Universal Soil Loss Equation.  Equations taken
@@ -160,7 +160,7 @@
 Since the LS factor is a small number, it is multiplied by 100 for the
 GRASS output map.
-<dt><em>slope_steepness</em>
+<dt><em>slope.steepness</em>
 <dd>Output map: slope steepness (S) factor for RUSLE.
 Contains the revised S factor for the Universal Soil
@@ -185,7 +185,7 @@
 valleys while  <em>r.watershed</em> performed much better. Thus, if forest
 canopy exists in valleys, SRTM, IFSAR, and similar data products will cause
 major errors in <em>r.terraflow</em> stream output. Under similar conditions,
-<em>r.watershed</em> will generate better <b>stream</b> and <b>half_basin</b>
+<em>r.watershed</em> will generate better <b>stream</b> and <b>half.basin</b>
 results. If watershed divides contain flat to low slope, <em>r.watershed</em>
 will generate better basin results than <em>r.terraflow</em>.
 (<em>r.terraflow</em> uses the same type of algorithm as ESRI's ArcGIS
@@ -421,7 +421,10 @@
 <h2>AUTHORS</h2>
-Original version: Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory<br>
-Markus Metz <markus.metz.giswork at gmail.com>
+Original version:
+Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
+<br>
+Speedups: Markus Metz &lt;markus.metz.giswork at gmail.com&gt;
 <p>
 <i>Last changed: $Date: 2008-09-28 01:36:15 +0200 (Sun, 28 Sep 2008) $</i>
