[GRASS-SVN] r33640 - grass-addons/gipe/i.evapo.time_integration
Wed Oct 1 11:34:02 EDT 2008
Author: ychemin
Date: 2008-10-01 11:34:02 -0400 (Wed, 01 Oct 2008)
New Revision: 33640
   grass-addons/gipe/i.evapo.time_integration/main.c
Module was modified, corrected and tested by Ines (see new author)
Modified: grass-addons/gipe/i.evapo.time_integration/main.c
--- grass-addons/gipe/i.evapo.time_integration/main.c	2008-10-01 15:31:40 UTC (rev 33639)
+++ grass-addons/gipe/i.evapo.time_integration/main.c	2008-10-01 15:34:02 UTC (rev 33640)
@@ -1,423 +1,399 @@
- * MODULE:       i.evapo.time_integration
- * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
- * PURPOSE:      Integrate in time the evapotranspiration from satellite,
- *		 following a daily pattern from meteorological ETo.
- * COPYRIGHT:    (C) 2008 by the GRASS Development Team
- *               This program is free software under the GNU Lesser General Public
- *   	    	 License. Read the file COPYING that comes with GRASS for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#define MAXFILES 400
-int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/*region+header info */
-    char *mapset;		/*mapset name */
-    int nrows, ncols;
-    int row, col;
-    struct GModule *module;
-    struct Option *input, *input1, *input2, *input3, *output;
-    struct History history;	/*metadata */
-    struct Colors colors;	/*Color rules */
-    /* FMEO Declarations**************** */
-    char *name, *name1, *name2;	/*input raster name */
-    char *result;		/*output raster name */
-    /*File Descriptors */
-    int nfiles, nfiles1, nfiles2;
-    int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
-    int outfd;
-    /* Pointers for file names              */
-    char **names;
-    char **ptr;
-    char **names1;
-    char **ptr1;
-    char **names2;
-    char **ptr2;
-    double DOYbeforeETa[MAXFILES], DOYafterETa[MAXFILES];
-    int bfr, aft;
-    int ok;
-    int i = 0, j = 0;
-    double etodoy;		/*minimum ETo DOY */
-    void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
-    DCELL *outrast;
-    int data_format;		/* 0=double  1=float  2=32bit signed int  5=8bit unsigned int (ie text) */
-    RASTER_MAP_TYPE in_data_type[MAXFILES];	/* ETa */
-    RASTER_MAP_TYPE in_data_type1[MAXFILES];	/* DOY of ETa */
-    RASTER_MAP_TYPE in_data_type2[MAXFILES];	/* ETo */
-    RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    module->keywords = _("evapotranspiration,temporal,integration");
-    module->description =
-	_("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
-    /* Define the different options */
-    input = G_define_standard_option(G_OPT_R_INPUTS);
-    input->key = _("eta");
-    input->description = _("Names of satellite ETa layers [mm/d or cm/d]");
-    input1 = G_define_standard_option(G_OPT_R_INPUTS);
-    input1->key = _("eta_doy");
-    input1->description =
-	_("Names of satellite ETa Day of Year (DOY) layers [0-400] [-]");
-    input2 = G_define_standard_option(G_OPT_R_INPUTS);
-    input2->key = _("eto");
-    input2->description =
-	_("Names of meteorological station ETo layers [0-400] [mm/d or cm/d]");
-    input3 = G_define_option();
-    input3->key = _("eto_doy_min");
-    input3->type = TYPE_DOUBLE;
-    input3->required = YES;
-    input3->description = _("Value of DOY for ETo first day");
-    output = G_define_standard_option(G_OPT_R_OUTPUT);
-    output->description =
-	_("Name of the output temporally integrated ETa layer");
-    /* FMEO init nfiles */
-    nfiles = 1;
-    nfiles1 = 1;
-    nfiles2 = 1;
-    if (G_parser(argc, argv))
-	exit(-1);
-    ok = 1;
-    names = input->answers;
-    ptr = input->answers;
-    names1 = input1->answers;
-    ptr1 = input1->answers;
-    names2 = input2->answers;
-    ptr2 = input2->answers;
-    etodoy = atof(input3->answer);
-    result = output->answer;
-    if (G_legal_filename(result) < 0) {
-	G_fatal_error(_("[%s] is an illegal name"), result);
-	ok = 0;
-    for (; *ptr != NULL; ptr++) {
-	if (nfiles > MAXFILES)
-	    G_fatal_error(_("%s - too many ETa files. Only %d allowed"),
-			  G_program_name(), MAXFILES);
-	name = *ptr;
-	/* find map in mapset */
-	mapset = G_find_cell2(name, "");
-	if (mapset == NULL) {
-	    G_fatal_error(_("cell file [%s] not found"), name);
-	    ok = 0;
-	if (!ok) {
-	    continue;
-	infd[nfiles] = G_open_cell_old(name, mapset);
-	if (infd[nfiles] < 0) {
-	    ok = 0;
-	    continue;
-	/* Allocate input buffer */
-	in_data_type[nfiles] = G_raster_map_type(name, mapset);
-	if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0) {
-	    G_fatal_error(_("Cannot open cell file [%s]"), name);
-	if ((G_get_cellhd(name, mapset, &cellhd)) < 0) {
-	    G_fatal_error(_("Cannot read file header of [%s]"), name);
-	inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
-	nfiles++;
-    nfiles--;
-    if (nfiles <= 1) {
-	G_fatal_error(_("The min specified input map is two"));
-    ok = 1;
-    for (; *ptr1 != NULL; ptr1++) {
-	if (nfiles1 > MAXFILES)
-	name1 = *ptr1;
-	mapset = G_find_cell2(name1, "");
-	    G_fatal_error(_("cell file [%s] not found"), name1);
-	    ok = 0;
-	if (!ok) {
-	    continue;
-	infd1[nfiles] = G_open_cell_old(name1, mapset);
-	if (infd1[nfiles] < 0) {
-	    ok = 0;
-	    continue;
-	in_data_type1[nfiles] = G_raster_map_type(name1, mapset);
-	if ((infd1[nfiles] = G_open_cell_old(name1, mapset)) < 0) {
-	    G_fatal_error(_("Cannot open cell file [%s]"), name1);
-	if ((G_get_cellhd(name1, mapset, &cellhd)) < 0) {
-	    G_fatal_error(_("Cannot read file header of [%s]"), name1);
-	inrast1[nfiles] = G_allocate_raster_buf(in_data_type[nfiles1]);
-	nfiles1++;
-    nfiles1--;
-    if (nfiles1 <= 1) {
-    if (nfiles != nfiles1)
-	G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
-    ok = 1;
-    for (; *ptr2 != NULL; ptr2++) {
-	name2 = *ptr2;
-	mapset = G_find_cell2(name2, "");
-	    G_fatal_error(_("cell file [%s] not found"), name2);
-	    ok = 0;
-	if (!ok) {
-	    continue;
-	infd2[nfiles2] = G_open_cell_old(name2, mapset);
-	if (infd2[nfiles2] < 0) {
-	    ok = 0;
-	    continue;
-	in_data_type2[nfiles2] = G_raster_map_type(name2, mapset);
-	if ((infd2[nfiles2] = G_open_cell_old(name2, mapset)) < 0) {
-	    G_fatal_error(_("Cannot open cell file [%s]"), name2);
-	if ((G_get_cellhd(name2, mapset, &cellhd)) < 0) {
-	    G_fatal_error(_("Cannot read file header of [%s]"), name2);
-	inrast2[nfiles2] = G_allocate_raster_buf(in_data_type2[nfiles2]);
-	nfiles2++;
-    nfiles2--;
-    if (nfiles2 <= 1) {
-    /* Allocate output buffer, use input map data_type */
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    outrast = G_allocate_raster_buf(out_data_type);
-    /* Create New raster files */
-    if ((outfd = G_open_raster_new(result, 1)) < 0) {
-	G_fatal_error(_("Could not open <%s>"), result);
-    /* Process pixels */
-    double doy[MAXFILES];
-    double sum[MAXFILES];
-    for (row = 0; row < nrows; row++) {
-	DCELL d_out;
-	DCELL d_ETrF[MAXFILES];
-	DCELL d[MAXFILES];
-	DCELL d1[MAXFILES];
-	DCELL d2[MAXFILES];
-	G_percent(row, nrows, 2);
-	/* read input map */
-	for (i = 1; i <= nfiles; i++) {
-	    if ((G_get_raster_row(infd[i], inrast[i], row, in_data_type[i])) <
-		0) {
-		G_fatal_error(_("Could not read from <%s>"), name);
-	for (i = 1; i <= nfiles1; i++) {
-		 (infd1[i], inrast1[i], row, in_data_type1[i])) < 0) {
-		G_fatal_error(_("Could not read from <%s>"), name1);
-	for (i = 1; i <= nfiles2; i++) {
-		 (infd2[i], inrast2[i], row, in_data_type2[i])) < 0) {
-		G_fatal_error(_("Could not read from <%s>"), name2);
-	/*process the data */
-	for (col = 0; col < ncols; col++) {
-		switch (in_data_type[i]) {
-		case CELL_TYPE:
-		    d[i] = (double)((CELL *) inrast[i])[col];
-		    break;
-		case FCELL_TYPE:
-		    d[i] = (double)((FCELL *) inrast[i])[col];
-		    break;
-		case DCELL_TYPE:
-		    d[i] = (double)((DCELL *) inrast[i])[col];
-		    break;
-		switch (in_data_type1[i]) {
-		case CELL_TYPE:
-		    d1[i] = (double)((CELL *) inrast1[i])[col];
-		    break;
-		case FCELL_TYPE:
-		    d1[i] = (double)((FCELL *) inrast1[i])[col];
-		    break;
-		case DCELL_TYPE:
-		    d1[i] = (double)((DCELL *) inrast1[i])[col];
-		    break;
-		switch (in_data_type2[i]) {
-		case CELL_TYPE:
-		    d2[i] = (double)((CELL *) inrast2[i])[col];
-		    break;
-		case FCELL_TYPE:
-		    d2[i] = (double)((FCELL *) inrast2[i])[col];
-		    break;
-		case DCELL_TYPE:
-		    d2[i] = (double)((DCELL *) inrast2[i])[col];
-		    break;
-	    /* Find out the DOY of the eto image    */
-	    /* DOY_eto_index = ModisDOY - etodoymin */
-		doy[i] = d1[i] - etodoy;
-		d_ETrF[i] = d[i] / d2[(int)doy[i]];
-		if (i == 1)
-		    DOYbeforeETa[i] = etodoy;
-		else
-		    DOYbeforeETa[i] = (d[i] - d[i - 1]) / 2.0;
-		if (i == nfiles1)
-		    DOYafterETa[i] = etodoy + nfiles2;
-		else
-		    DOYafterETa[i] = (d[i + 1] - d[i]) / 2.0;
-	    sum[MAXFILES] = 0.0;
-		bfr = (int)DOYbeforeETa[i];
-		aft = (int)DOYafterETa[i];
-		for (j = bfr; j < aft; j++) {
-		    sum[i] += d2[j];
-	    d_out = 0.0;
-		d_out += d_ETrF[i] * sum[i];
-	    outrast[col] = d_out;
-	if (G_put_raster_row(outfd, outrast, out_data_type) < 0)
-	    G_fatal_error(_("Cannot write to <%s>"), result);
-	G_free(inrast[i]);
-	G_close_cell(infd[i]);
-	G_free(inrast1[i]);
-	G_close_cell(infd1[i]);
-	G_free(inrast2[i]);
-	G_close_cell(infd2[i]);
-    G_free(outrast);
-    G_close_cell(outfd);
-    /* Color table from 0.0 to 10.0 */
-    G_init_colors(&colors);
-    G_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
-    /* Metadata */
-    G_short_history(result, "raster", &history);
-    G_command_history(&history);
-    G_write_history(result, &history);
-    exit(EXIT_SUCCESS);
+ * MODULE:       i.evapo.time_integration
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * 		 Ines Cherif - icherif at yahoo.com
+ * PURPOSE:      Integrate in time the evapotranspiration from satellite,
+ *		 following a daily pattern from meteorological ETo.
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU Lesser General Public
+ *   	    	 License. Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#define MAXFILES 400
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    char *mapset;		/*mapset name */
+    int nrows, ncols;
+    int row, col;
+    struct GModule *module;
+    struct Option *input, *input1, *input2, *input3, *output;
+    struct History history;	/*metadata */
+    struct Colors colors;	/*Color rules */
+    /* FMEO Declarations**************** */
+    char *name, *name1, *name2;	/*input raster name */
+    char *result;		/*output raster name */
+    /*File Descriptors */
+    int nfiles, nfiles1, nfiles2;
+    int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
+    int outfd;
+    /* Pointers for file names              */
+    char **names;
+    char **ptr;
+    char **names1;
+    char **ptr1;
+    char **names2;
+    char **ptr2;
+    int DOYbeforeETa[MAXFILES], DOYafterETa[MAXFILES];
+    int bfr, aft;
+    int ok;
+    int i = 0, j = 0;
+    double etodoy;		/*minimum ETo DOY */
+    void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
+    DCELL *outrast;
+    int data_format;		/* 0=double  1=float  2=32bit signed int  5=8bit unsigned int (ie text) */
+    RASTER_MAP_TYPE in_data_type[MAXFILES];	/* ETa */
+    RASTER_MAP_TYPE in_data_type1[MAXFILES];	/* DOY of ETa */
+    RASTER_MAP_TYPE in_data_type2[MAXFILES];	/* ETo */
+    RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("evapotranspiration,temporal,integration");
+    module->description =
+	_("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
+    /* Define the different options */
+    input = G_define_standard_option(G_OPT_R_INPUTS);
+    input->key = _("eta");
+    input->description = _("Names of satellite ETa layers [mm/d or cm/d]");
+    input1 = G_define_standard_option(G_OPT_R_INPUTS);
+    input1->key = _("eta_doy");
+    input1->description =
+	_("Names of satellite ETa Day of Year (DOY) layers [0-400] [-]");
+    input2 = G_define_standard_option(G_OPT_R_INPUTS);
+    input2->key = _("eto");
+    input2->description =
+	_("Names of meteorological station ETo layers [0-400] [mm/d or cm/d]");
+    input3 = G_define_option();
+    input3->key = _("eto_doy_min");
+    input3->type = TYPE_DOUBLE;
+    input3->required = YES;
+    input3->description = _("Value of DOY for ETo first day");
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
+    output->description =
+	_("Name of the output temporally integrated ETa layer");
+    /* FMEO init nfiles */
+    nfiles = 1;
+    nfiles1 = 1;
+    nfiles2 = 1;
+    if (G_parser(argc, argv))
+	exit(-1);
+    ok = 1;
+    names = input->answers;
+    ptr = input->answers;
+    names1 = input1->answers;
+    ptr1 = input1->answers;
+    names2 = input2->answers;
+    ptr2 = input2->answers;
+    etodoy = atof(input3->answer);
+    result = output->answer;
+    if (G_legal_filename(result) < 0) {
+	G_fatal_error(_("[%s] is an illegal name"), result);
+	ok = 0;
+    for (; *ptr != NULL; ptr++) {
+	if (nfiles > MAXFILES)
+	    G_fatal_error(_("%s - too many ETa files. Only %d allowed"),
+			  G_program_name(), MAXFILES);
+	name = *ptr;
+	/* find map in mapset */
+	mapset = G_find_cell2(name, "");
+	if (mapset == NULL) {
+	    G_fatal_error(_("cell file [%s] not found"), name);
+	    ok = 0;
+	if (!ok) {
+	    continue;
+	infd[nfiles] = G_open_cell_old(name, mapset);
+	if (infd[nfiles] < 0) {
+	    ok = 0;
+	    continue;
+	/* Allocate input buffer */
+	in_data_type[nfiles] = G_raster_map_type(name, mapset);
+	if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0) {
+	    G_fatal_error(_("Cannot open cell file [%s]"), name);
+	if ((G_get_cellhd(name, mapset, &cellhd)) < 0) {
+	    G_fatal_error(_("Cannot read file header of [%s]"), name);
+	inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
+	nfiles++;
+    nfiles--;
+    if (nfiles <= 1) {
+	G_fatal_error(_("The min specified input map is two"));
+    ok = 1;
+    for (; *ptr1 != NULL; ptr1++) {
+	if (nfiles1 > MAXFILES)
+	name1 = *ptr1;
+	mapset = G_find_cell2(name1, "");
+	    G_fatal_error(_("cell file [%s] not found"), name1);
+	    ok = 0;
+	if (!ok) {
+	    continue;
+	infd1[nfiles1] = G_open_cell_old(name1, mapset);
+	if (infd1[nfiles1] < 0) {
+	    ok = 0;
+	    continue;
+	in_data_type1[nfiles1] = G_raster_map_type(name1, mapset);
+	if ((infd1[nfiles1] = G_open_cell_old(name1, mapset)) < 0) {
+	    G_fatal_error(_("Cannot open cell file [%s]"), name1);
+	if ((G_get_cellhd(name1, mapset, &cellhd)) < 0) {
+	    G_fatal_error(_("Cannot read file header of [%s]"), name1);
+	inrast1[nfiles1] = G_allocate_raster_buf(in_data_type1[nfiles1]);
+	nfiles1++;
+    nfiles1--;
+    if (nfiles1 <= 1) {
+    if (nfiles != nfiles1)	G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
+    ok = 1;
+    for (; *ptr2 != NULL; ptr2++) {
+	name2 = *ptr2;
+	mapset = G_find_cell2(name2, "");
+	    G_fatal_error(_("cell file [%s] not found"), name2);
+	    ok = 0;
+	if (!ok) {
+	    continue;
+	infd2[nfiles2] = G_open_cell_old(name2, mapset);
+	if (infd2[nfiles2] < 0) {
+	    ok = 0;
+	    continue;
+	in_data_type2[nfiles2] = G_raster_map_type(name2, mapset);
+	if ((infd2[nfiles2] = G_open_cell_old(name2, mapset)) < 0) {
+	    G_fatal_error(_("Cannot open cell file [%s]"), name2);
+	if ((G_get_cellhd(name2, mapset, &cellhd)) < 0) {
+	    G_fatal_error(_("Cannot read file header of [%s]"), name2);
+	inrast2[nfiles2] = G_allocate_raster_buf(in_data_type2[nfiles2]);
+	nfiles2++;
+    nfiles2--;
+    if (nfiles2 <= 1) {
+    /* Allocate output buffer, use input map data_type */
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    outrast = G_allocate_raster_buf(out_data_type);
+    /* Create New raster files */
+    if ((outfd = G_open_raster_new(result, 1)) < 0) {
+	G_fatal_error(_("Could not open <%s>"), result);
+    /* Process pixels */
+    double doy[MAXFILES];
+    double sum[MAXFILES];
+    for (row = 0; row < nrows; row++) {
+	DCELL d_out;
+	DCELL d_ETrF[MAXFILES];
+	DCELL d[MAXFILES];
+	DCELL d1[MAXFILES];
+	DCELL d2[MAXFILES];
+	G_percent(row, nrows, 2);
+	/* read input map */
+	for (i = 1; i <= nfiles; i++) {
+	    if ((G_get_raster_row(infd[i], inrast[i], row, in_data_type[i])) <	0) {
+		G_fatal_error(_("Could not read from <%s>"), name);
+	for (i = 1; i <= nfiles1; i++) {
+	    if ((G_get_raster_row(infd1[i], inrast1[i], row, in_data_type1[i])) < 0) {
+		G_fatal_error(_("Could not read from <%s>"), name1);
+	for (i = 1; i <= nfiles2; i++) {
+	    if ((G_get_raster_row (infd2[i], inrast2[i], row, in_data_type2[i])) < 0) {
+		G_fatal_error(_("Could not read from <%s>"), name2);
+	/*process the data */
+	for (col = 0; col < ncols; col++) {
+		switch (in_data_type[i]) {
+		case CELL_TYPE:
+		    d[i] = (double)((CELL *) inrast[i])[col];
+		    break;
+		case FCELL_TYPE:
+		    d[i] = (double)((FCELL *) inrast[i])[col];
+		    break;
+		case DCELL_TYPE:
+		    d[i] = (double)((DCELL *) inrast[i])[col];
+		    break;
+		switch (in_data_type1[i]) {
+		case CELL_TYPE:
+		    d1[i] = (double)((CELL *) inrast1[i])[col];
+		    break;
+		case FCELL_TYPE:
+		    d1[i] = (double)((FCELL *) inrast1[i])[col];
+		    break;
+		case DCELL_TYPE:
+		    d1[i] = (double)((DCELL *) inrast1[i])[col];
+		    break;
+		switch (in_data_type2[i]) {
+		case CELL_TYPE:
+		    d2[i] = (double)((CELL *) inrast2[i])[col];
+		    break;
+		case FCELL_TYPE:
+		    d2[i] = (double)((FCELL *) inrast2[i])[col];
+		    break;
+		case DCELL_TYPE:
+		    d2[i] = (double)((DCELL *) inrast2[i])[col];
+		    break;
+	    /* Find out the DOY of the eto image    */
+	    /* DOY_eto_index = ModisDOY - etodoymin */
+		doy[i] = d1[i] - etodoy+1;
+		d_ETrF[i] = d[i] / d2[(int)doy[i]];
+		if (i == 1)
+		    DOYbeforeETa[i] = etodoy;
+		else
+		    DOYbeforeETa[i] = 1+ (d1[i] + d1[i - 1]) / 2.0;
+		if (i == nfiles1)
+		    DOYafterETa[i] = etodoy + nfiles2-1;
+		else
+		    DOYafterETa[i] = (d1[i + 1] + d1[i]) / 2.0;
+/*		//Sum over 8-day periods, if no missing periods
+		DOYbeforeETa[i] = etodoy+8*(i-1);
+		if (i == nfiles1)
+		else
+		    DOYafterETa[i] = etodoy+8*i-1;
+	    sum[MAXFILES] = 0.0;
+		bfr = (int)DOYbeforeETa[i];
+		aft = (int)DOYafterETa[i];
+		sum[i]=0.0;
+		for (j = bfr; j < aft; j++) {
+		    sum[i] += d2[(int)(j-etodoy+1)];
+	    d_out = 0.0;
+		d_out += d_ETrF[i] * sum[i];
+	    outrast[col] = d_out;
+	if (G_put_raster_row(outfd, outrast, out_data_type) < 0)
+	    G_fatal_error(_("Cannot write to <%s>"), result);
+	G_free(inrast[i]);
+	G_close_cell(infd[i]);
+	G_free(inrast1[i]);
+	G_close_cell(infd1[i]);
+	G_free(inrast2[i]);
+	G_close_cell(infd2[i]);
+    G_free(outrast);
+    G_close_cell(outfd);
+    /* Color table from 0.0 to 10.0 */
+    G_init_colors(&colors);
+    G_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
+    /* Metadata */
+    G_short_history(result, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result, &history);
+    exit(EXIT_SUCCESS);
