[GRASS-SVN] r33787 - in grass/trunk: lib/python vector/v.db.connect
Thu Oct 9 06:42:55 EDT 2008
Author: glynn
Date: 2008-10-09 06:42:55 -0400 (Thu, 09 Oct 2008)
New Revision: 33787
   grass/trunk/lib/python/grass.py
   grass/trunk/vector/v.db.connect/main.c
Add fs= option to v.db.connect (for use by -g)
Change vector_db to use fs=| (to allow for spaces in pathnames)
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2008-10-09 09:03:08 UTC (rev 33786)
+++ grass/trunk/lib/python/grass.py	2008-10-09 10:42:55 UTC (rev 33787)
@@ -442,10 +442,10 @@
     """Return the database connection details for a vector map
     (interface to `v.db.connect -g').
-    s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, **args)
+    s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, fs = '|', **args)
     result = []
     for l in s.splitlines():
-	f = l.split(' ')
+	f = l.split('|')
 	if len(f) != 5:
 	    continue
 	if layer and int(layer) == int(f[0]):
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2008-10-09 09:03:08 UTC (rev 33786)
+++ grass/trunk/vector/v.db.connect/main.c	2008-10-09 10:42:55 UTC (rev 33787)
@@ -33,7 +33,7 @@
     char *input;
     struct GModule *module;
     struct Option *inopt, *dbdriver, *dbdatabase, *dbtable, *field_opt,
-	*dbkey;
+	*dbkey, *sep_opt;
     struct Flag *overwrite, *print, *columns, *delete, *shell_print;
     dbDriver *driver;
     dbString table_name;
@@ -72,6 +72,9 @@
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    sep_opt = G_define_standard_option(G_OPT_F_SEP);
+    sep_opt->answer = " ";
     print = G_define_flag();
     print->key = 'p';
     print->description = _("Print all map connection parameters and exit");
@@ -148,15 +151,18 @@
 			G_fatal_error(_("Database connection not defined"));
 		    if (shell_print->answer) {
+			const char *sep = sep_opt->answer;
 			if (fi->name) {
-			    fprintf(stdout, "%d/%s %s %s %s %s\n", fi->number,
-				    fi->name, fi->table, fi->key,
-				    fi->database, fi->driver);
+			    fprintf(stdout, "%d/%s%s%s%s%s%s%s%s%s\n",
+				    fi->number, fi->name, sep,
+				    fi->table, sep, fi->key, sep,
+				    fi->database, sep, fi->driver);
 			else {
-			    fprintf(stdout, "%d %s %s %s %s\n", fi->number,
-				    fi->table, fi->key, fi->database,
-				    fi->driver);
+			    fprintf(stdout, "%d%s%s%s%s%s%s%s%s\n",
+				    fi->number, sep,
 		    else {
